path: root/mm/internal.h
2010-01-06ksm: fix mlockfreed to munlockedHugh Dickins
2.6.33-rc1 commit 73848b4684e84a84cfd1555af78d41158f31e16b, adjusted to include 31e855ea7173bdb0520f9684580423a9560f66e0's movement of the unlock_page(oldpage), but omit other intervening cleanups. When KSM merges an mlocked page, it has been forgetting to munlock it: that's been left to free_page_mlock(), which reports it in /proc/vmstat as unevictable_pgs_mlockfreed instead of unevictable_pgs_munlocked, which indicates that such pages _might_ be left unevictable for long after they should be evictable. Call munlock_vma_page() to fix that. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-22mm: move highest_memmap_pfnHugh Dickins
Move highest_memmap_pfn __read_mostly from page_alloc.c next to zero_pfn __read_mostly in memory.c: to help them share a cacheline, since they're very often tested together in vm_normal_page(). Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Rik van Riel <riel@redhat.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22mm: FOLL flags for GUP flagsHugh Dickins
__get_user_pages() has been taking its own GUP flags, then processing them into FOLL flags for follow_page(). Though oddly named, the FOLL flags are more widely used, so pass them to __get_user_pages() now. Sorry, VM flags, VM_FAULT flags and FAULT_FLAGs are still distinct. (The patch to __get_user_pages() looks peculiar, with both gup_flags and foll_flags: the gup_flags remain constant; but as before there's an exceptional case, out of scope of the patch, in which foll_flags per page have FOLL_WRITE masked off.) Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Rik van Riel <riel@redhat.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22mm: FOLL_DUMP replace FOLL_ANONHugh Dickins
The "FOLL_ANON optimization" and its use_zero_page() test have caused confusion and bugs: why does it test VM_SHARED? for the very good but unsatisfying reason that VMware crashed without. As we look to maybe reinstating anonymous use of the ZERO_PAGE, we need to sort this out. Easily done: it's silly for __get_user_pages() and follow_page() to be guessing whether it's safe to assume that they're being used for a coredump (which can take a shortcut snapshot where other uses must handle a fault) - just tell them with GUP_FLAGS_DUMP and FOLL_DUMP. get_dump_page() doesn't even want a ZERO_PAGE: an error suits fine. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22mm: remove unused GUP flagsHugh Dickins
GUP_FLAGS_IGNORE_VMA_PERMISSIONS and GUP_FLAGS_IGNORE_SIGKILL were flags added solely to prevent __get_user_pages() from doing some of what it usually does, in the munlock case: we can now remove them. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Acked-by: Rik van Riel <riel@redhat.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16vmscan: do not unconditionally treat zones that fail zone_reclaim() as fullMel Gorman
On NUMA machines, the administrator can configure zone_reclaim_mode that is a more targetted form of direct reclaim. On machines with large NUMA distances for example, a zone_reclaim_mode defaults to 1 meaning that clean unmapped pages will be reclaimed if the zone watermarks are not being met. The problem is that zone_reclaim() failing at all means the zone gets marked full. This can cause situations where a zone is usable, but is being skipped because it has been considered full. Take a situation where a large tmpfs mount is occuping a large percentage of memory overall. The pages do not get cleaned or reclaimed by zone_reclaim(), but the zone gets marked full and the zonelist cache considers them not worth trying in the future. This patch makes zone_reclaim() return more fine-grained information about what occured when zone_reclaim() failued. The zone only gets marked full if it really is unreclaimable. If it's a case that the scan did not occur or if enough pages were not reclaimed with the limited reclaim_mode, then the zone is simply skipped. There is a side-effect to this patch. Currently, if zone_reclaim() successfully reclaimed SWAP_CLUSTER_MAX, an allocation attempt would go ahead. With this patch applied, zone watermarks are rechecked after zone_reclaim() does some work. This bug was introduced by commit 9276b1bc96a132f4068fdee00983c532f43d3a26 ("memory page_alloc zonelist caching speedup") way back in 2.6.19 when the zonelist_cache was introduced. It was not intended that zone_reclaim() aggressively consider the zone to be full when it failed as full direct reclaim can still be an option. Due to the age of the bug, it should be considered a -stable candidate. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Wu Fengguang <fengguang.wu@intel.com> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16mm: remove CONFIG_UNEVICTABLE_LRU config optionKOSAKI Motohiro
Currently, nobody wants to turn UNEVICTABLE_LRU off. Thus this configurability is unnecessary. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Andi Kleen <andi@firstfloor.org> Acked-by: Minchan Kim <minchan.kim@gmail.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Matt Mackall <mpm@selenic.com> Cc: Rik van Riel <riel@redhat.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16mm: introduce PageHuge() for testing huge/gigantic pagesWu Fengguang
A series of patches to enhance the /proc/pagemap interface and to add a userspace executable which can be used to present the pagemap data. Export 10 more flags to end users (and more for kernel developers): 11. KPF_MMAP (pseudo flag) memory mapped page 12. KPF_ANON (pseudo flag) memory mapped page (anonymous) 13. KPF_SWAPCACHE page is in swap cache 14. KPF_SWAPBACKED page is swap/RAM backed 15. KPF_COMPOUND_HEAD (*) 16. KPF_COMPOUND_TAIL (*) 17. KPF_HUGE hugeTLB pages 18. KPF_UNEVICTABLE page is in the unevictable LRU list 19. KPF_HWPOISON hardware detected corruption 20. KPF_NOPAGE (pseudo flag) no page frame at the address (*) For compound pages, exporting _both_ head/tail info enables users to tell where a compound page starts/ends, and its order. a simple demo of the page-types tool # ./page-types -h page-types [options] -r|--raw Raw mode, for kernel developers -a|--addr addr-spec Walk a range of pages -b|--bits bits-spec Walk pages with specified bits -l|--list Show page details in ranges -L|--list-each Show page details one by one -N|--no-summary Don't show summay info -h|--help Show this usage message addr-spec: N one page at offset N (unit: pages) N+M pages range from N to N+M-1 N,M pages range from N to M-1 N, pages range from N to end ,M pages range from 0 to M bits-spec: bit1,bit2 (flags & (bit1|bit2)) != 0 bit1,bit2=bit1 (flags & (bit1|bit2)) == bit1 bit1,~bit2 (flags & (bit1|bit2)) == bit1 =bit1,bit2 flags == (bit1|bit2) bit-names: locked error referenced uptodate dirty lru active slab writeback reclaim buddy mmap anonymous swapcache swapbacked compound_head compound_tail huge unevictable hwpoison nopage reserved(r) mlocked(r) mappedtodisk(r) private(r) private_2(r) owner_private(r) arch(r) uncached(r) readahead(o) slob_free(o) slub_frozen(o) slub_debug(o) (r) raw mode bits (o) overloaded bits # ./page-types flags page-count MB symbolic-flags long-symbolic-flags 0x0000000000000000 487369 1903 _________________________________ 0x0000000000000014 5 0 __R_D____________________________ referenced,dirty 0x0000000000000020 1 0 _____l___________________________ lru 0x0000000000000024 34 0 __R__l___________________________ referenced,lru 0x0000000000000028 3838 14 ___U_l___________________________ uptodate,lru 0x0001000000000028 48 0 ___U_l_______________________I___ uptodate,lru,readahead 0x000000000000002c 6478 25 __RU_l___________________________ referenced,uptodate,lru 0x000100000000002c 47 0 __RU_l_______________________I___ referenced,uptodate,lru,readahead 0x0000000000000040 8344 32 ______A__________________________ active 0x0000000000000060 1 0 _____lA__________________________ lru,active 0x0000000000000068 348 1 ___U_lA__________________________ uptodate,lru,active 0x0001000000000068 12 0 ___U_lA______________________I___ uptodate,lru,active,readahead 0x000000000000006c 988 3 __RU_lA__________________________ referenced,uptodate,lru,active 0x000100000000006c 48 0 __RU_lA______________________I___ referenced,uptodate,lru,active,readahead 0x0000000000004078 1 0 ___UDlA_______b__________________ uptodate,dirty,lru,active,swapbacked 0x000000000000407c 34 0 __RUDlA_______b__________________ referenced,uptodate,dirty,lru,active,swapbacked 0x0000000000000400 503 1 __________B______________________ buddy 0x0000000000000804 1 0 __R________M_____________________ referenced,mmap 0x0000000000000828 1029 4 ___U_l_____M_____________________ uptodate,lru,mmap 0x0001000000000828 43 0 ___U_l_____M_________________I___ uptodate,lru,mmap,readahead 0x000000000000082c 382 1 __RU_l_____M_____________________ referenced,uptodate,lru,mmap 0x000100000000082c 12 0 __RU_l_____M_________________I___ referenced,uptodate,lru,mmap,readahead 0x0000000000000868 192 0 ___U_lA____M_____________________ uptodate,lru,active,mmap 0x0001000000000868 12 0 ___U_lA____M_________________I___ uptodate,lru,active,mmap,readahead 0x000000000000086c 800 3 __RU_lA____M_____________________ referenced,uptodate,lru,active,mmap 0x000100000000086c 31 0 __RU_lA____M_________________I___ referenced,uptodate,lru,active,mmap,readahead 0x0000000000004878 2 0 ___UDlA____M__b__________________ uptodate,dirty,lru,active,mmap,swapbacked 0x0000000000001000 492 1 ____________a____________________ anonymous 0x0000000000005808 4 0 ___U_______Ma_b__________________ uptodate,mmap,anonymous,swapbacked 0x0000000000005868 2839 11 ___U_lA____Ma_b__________________ uptodate,lru,active,mmap,anonymous,swapbacked 0x000000000000586c 30 0 __RU_lA____Ma_b__________________ referenced,uptodate,lru,active,mmap,anonymous,swapbacked total 513968 2007 # ./page-types -r flags page-count MB symbolic-flags long-symbolic-flags 0x0000000000000000 468002 1828 _________________________________ 0x0000000100000000 19102 74 _____________________r___________ reserved 0x0000000000008000 41 0 _______________H_________________ compound_head 0x0000000000010000 188 0 ________________T________________ compound_tail 0x0000000000008014 1 0 __R_D__________H_________________ referenced,dirty,compound_head 0x0000000000010014 4 0 __R_D___________T________________ referenced,dirty,compound_tail 0x0000000000000020 1 0 _____l___________________________ lru 0x0000000800000024 34 0 __R__l__________________P________ referenced,lru,private 0x0000000000000028 3794 14 ___U_l___________________________ uptodate,lru 0x0001000000000028 46 0 ___U_l_______________________I___ uptodate,lru,readahead 0x0000000400000028 44 0 ___U_l_________________d_________ uptodate,lru,mappedtodisk 0x0001000400000028 2 0 ___U_l_________________d_____I___ uptodate,lru,mappedtodisk,readahead 0x000000000000002c 6434 25 __RU_l___________________________ referenced,uptodate,lru 0x000100000000002c 47 0 __RU_l_______________________I___ referenced,uptodate,lru,readahead 0x000000040000002c 14 0 __RU_l_________________d_________ referenced,uptodate,lru,mappedtodisk 0x000000080000002c 30 0 __RU_l__________________P________ referenced,uptodate,lru,private 0x0000000800000040 8124 31 ______A_________________P________ active,private 0x0000000000000040 219 0 ______A__________________________ active 0x0000000800000060 1 0 _____lA_________________P________ lru,active,private 0x0000000000000068 322 1 ___U_lA__________________________ uptodate,lru,active 0x0001000000000068 12 0 ___U_lA______________________I___ uptodate,lru,active,readahead 0x0000000400000068 13 0 ___U_lA________________d_________ uptodate,lru,active,mappedtodisk 0x0000000800000068 12 0 ___U_lA_________________P________ uptodate,lru,active,private 0x000000000000006c 977 3 __RU_lA__________________________ referenced,uptodate,lru,active 0x000100000000006c 48 0 __RU_lA______________________I___ referenced,uptodate,lru,active,readahead 0x000000040000006c 5 0 __RU_lA________________d_________ referenced,uptodate,lru,active,mappedtodisk 0x000000080000006c 3 0 __RU_lA_________________P________ referenced,uptodate,lru,active,private 0x0000000c0000006c 3 0 __RU_lA________________dP________ referenced,uptodate,lru,active,mappedtodisk,private 0x0000000c00000068 1 0 ___U_lA________________dP________ uptodate,lru,active,mappedtodisk,private 0x0000000000004078 1 0 ___UDlA_______b__________________ uptodate,dirty,lru,active,swapbacked 0x000000000000407c 34 0 __RUDlA_______b__________________ referenced,uptodate,dirty,lru,active,swapbacked 0x0000000000000400 538 2 __________B______________________ buddy 0x0000000000000804 1 0 __R________M_____________________ referenced,mmap 0x0000000000000828 1029 4 ___U_l_____M_____________________ uptodate,lru,mmap 0x0001000000000828 43 0 ___U_l_____M_________________I___ uptodate,lru,mmap,readahead 0x000000000000082c 382 1 __RU_l_____M_____________________ referenced,uptodate,lru,mmap 0x000100000000082c 12 0 __RU_l_____M_________________I___ referenced,uptodate,lru,mmap,readahead 0x0000000000000868 192 0 ___U_lA____M_____________________ uptodate,lru,active,mmap 0x0001000000000868 12 0 ___U_lA____M_________________I___ uptodate,lru,active,mmap,readahead 0x000000000000086c 800 3 __RU_lA____M_____________________ referenced,uptodate,lru,active,mmap 0x000100000000086c 31 0 __RU_lA____M_________________I___ referenced,uptodate,lru,active,mmap,readahead 0x0000000000004878 2 0 ___UDlA____M__b__________________ uptodate,dirty,lru,active,mmap,swapbacked 0x0000000000001000 492 1 ____________a____________________ anonymous 0x0000000000005008 2 0 ___U________a_b__________________ uptodate,anonymous,swapbacked 0x0000000000005808 4 0 ___U_______Ma_b__________________ uptodate,mmap,anonymous,swapbacked 0x000000000000580c 1 0 __RU_______Ma_b__________________ referenced,uptodate,mmap,anonymous,swapbacked 0x0000000000005868 2839 11 ___U_lA____Ma_b__________________ uptodate,lru,active,mmap,anonymous,swapbacked 0x000000000000586c 29 0 __RU_lA____Ma_b__________________ referenced,uptodate,lru,active,mmap,anonymous,swapbacked total 513968 2007 # ./page-types --raw --list --no-summary --bits reserved offset count flags 0 15 _____________________r___________ 31 4 _____________________r___________ 159 97 _____________________r___________ 4096 2067 _____________________r___________ 6752 2390 _____________________r___________ 9355 3 _____________________r___________ 9728 14526 _____________________r___________ This patch: Introduce PageHuge(), which identifies huge/gigantic pages by their dedicated compound destructor functions. Also move prep_compound_gigantic_page() to hugetlb.c and make __free_pages_ok() non-static. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Matt Mackall <mpm@selenic.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16page allocator: move free_page_mlock() to page_alloc.cKOSAKI Motohiro
Currently, free_page_mlock() is only called from page_alloc.c. Thus, we can move it to page_alloc.c. Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16page allocator: do not disable interrupts in free_page_mlock()Mel Gorman
free_page_mlock() tests and clears PG_mlocked using locked versions of the bit operations. If set, it disables interrupts to update counters and this happens on every page free even though interrupts are disabled very shortly afterwards a second time. This is wasteful. This patch splits what free_page_mlock() does. The bit check is still made. However, the update of counters is delayed until the interrupts are disabled and the non-lock version for clearing the bit is used. One potential weirdness with this split is that the counters do not get updated if the bad_page() check is triggered but a system showing bad pages is getting screwed already. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Reviewed-by: Pekka Enberg <penberg@cs.helsinki.fi> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Acked-by: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01nommu: there is no mlock() for NOMMU, so don't provide the bitsDavid Howells
The mlock() facility does not exist for NOMMU since all mappings are effectively locked anyway, so we don't make the bits available when they're not useful. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Greg Ungerer <gerg@snapgear.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Rik van Riel <riel@redhat.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Enrik Berkhan <Enrik.Berkhan@ge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06mm: make get_user_pages() interruptibleYing Han
The initial implementation of checking TIF_MEMDIE covers the cases of OOM killing. If the process has been OOM killed, the TIF_MEMDIE is set and it return immediately. This patch includes: 1. add the case that the SIGKILL is sent by user processes. The process can try to get_user_pages() unlimited memory even if a user process has sent a SIGKILL to it(maybe a monitor find the process exceed its memory limit and try to kill it). In the old implementation, the SIGKILL won't be handled until the get_user_pages() returns. 2. change the return value to be ERESTARTSYS. It makes no sense to return ENOMEM if the get_user_pages returned by getting a SIGKILL signal. Considering the general convention for a system call interrupted by a signal is ERESTARTNOSYS, so the current return value is consistant to that. Lee: An unfortunate side effect of "make-get_user_pages-interruptible" is that it prevents a SIGKILL'd task from munlock-ing pages that it had mlocked, resulting in freeing of mlocked pages. Freeing of mlocked pages, in itself, is not so bad. We just count them now--altho' I had hoped to remove this stat and add PG_MLOCKED to the free pages flags check. However, consider pages in shared libraries mapped by more than one task that a task mlocked--e.g., via mlockall(). If the task that mlocked the pages exits via SIGKILL, these pages would be left mlocked and unevictable. Proposed fix: Add another GUP flag to ignore sigkill when calling get_user_pages from munlock()--similar to Kosaki Motohiro's 'IGNORE_VMA_PERMISSIONS flag for the same purpose. We are not actually allocating memory in this case, which "make-get_user_pages-interruptible" intends to avoid. We're just munlocking pages that are already resident and mapped, and we're reusing get_user_pages() to access those pages. ?? Maybe we should combine 'IGNORE_VMA_PERMISSIONS and '_IGNORE_SIGKILL into a single flag: GUP_FLAGS_MUNLOCK ??? [Lee.Schermerhorn@hp.com: ignore sigkill in get_user_pages during munlock] Signed-off-by: Paul Menage <menage@google.com> Signed-off-by: Ying Han <yinghan@google.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Hugh Dickins <hugh@veritas.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Rohit Seth <rohitseth@google.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06badpage: vm_normal_page use print_bad_pteHugh Dickins
print_bad_pte() is so far being called only when zap_pte_range() finds negative page_mapcount, or there's a fault on a pte_file where it does not belong. That's weak coverage when we suspect pagetable corruption. Originally, it was called when vm_normal_page() found an invalid pfn: but pfn_valid is expensive on some architectures and configurations, so 2.6.24 put that under CONFIG_DEBUG_VM (which doesn't help in the field), then 2.6.26 replaced it by a VM_BUG_ON (likewise). Reinstate the print_bad_pte() in vm_normal_page(), but use a cheaper test than pfn_valid(): memmap_init_zone() (used in bootup and hotplug) keep a __read_mostly note of the highest_memmap_pfn, vm_normal_page() then check pfn against that. We could call this pfn_plausible() or pfn_sane(), but I doubt we'll need it elsewhere: of course it's not reliable, but gives much stronger pagetable validation on many boxes. Also use print_bad_pte() when the pte_special bit is found outside a VM_PFNMAP or VM_MIXEDMAP area, instead of VM_BUG_ON. Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-06hugetlb: pull gigantic page initialisation out of the default pathAndy Whitcroft
As we can determine exactly when a gigantic page is in use we can optimise the common regular page cases by pulling out gigantic page initialisation into its own function. As gigantic pages are never released to buddy we do not need a destructor. This effectivly reverts the previous change to the main buddy allocator. It also adds a paranoid check to ensure we never release gigantic pages from hugetlbfs to the main buddy. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Cc: Jon Tollefson <kniht@linux.vnet.ibm.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: <stable@kernel.org> [2.6.27.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-06hugetlbfs: handle pages higher order than MAX_ORDERAndy Whitcroft
When working with hugepages, hugetlbfs assumes that those hugepages are smaller than MAX_ORDER. Specifically it assumes that the mem_map is contigious and uses that to optimise access to the elements of the mem_map that represent the hugepage. Gigantic pages (such as 16GB pages on powerpc) by definition are of greater order than MAX_ORDER (larger than MAX_ORDER_NR_PAGES in size). This means that we can no longer make use of the buddy alloctor guarentees for the contiguity of the mem_map, which ensures that the mem_map is at least contigious for maximmally aligned areas of MAX_ORDER_NR_PAGES pages. This patch adds new mem_map accessors and iterator helpers which handle any discontiguity at MAX_ORDER_NR_PAGES boundaries. It then uses these to implement gigantic page versions of copy_huge_page and clear_huge_page, and to allow follow_hugetlb_page handle gigantic pages. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Cc: Jon Tollefson <kniht@linux.vnet.ibm.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: <stable@kernel.org> [2.6.27.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20mlock: count attempts to free mlocked pageLee Schermerhorn
Allow free of mlock()ed pages. This shouldn't happen, but during developement, it occasionally did. This patch allows us to survive that condition, while keeping the statistics and events correct for debug. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20vmstat: mlocked pages statisticsNick Piggin
Add NR_MLOCK zone page state, which provides a (conservative) count of mlocked pages (actually, the number of mlocked pages moved off the LRU). Reworked by lts to fit in with the modified mlock page support in the Reclaim Scalability series. [kosaki.motohiro@jp.fujitsu.com: fix incorrect Mlocked field of /proc/meminfo] [lee.schermerhorn@hp.com: mlocked-pages: add event counting with statistics] Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20mmap: handle mlocked pages during map, remap, unmapRik van Riel
Originally by Nick Piggin <npiggin@suse.de> Remove mlocked pages from the LRU using "unevictable infrastructure" during mmap(), munmap(), mremap() and truncate(). Try to move back to normal LRU lists on munmap() when last mlocked mapping removed. Remove PageMlocked() status when page truncated from file. [akpm@linux-foundation.org: cleanup] [kamezawa.hiroyu@jp.fujitsu.com: fix double unlock_page()] [kosaki.motohiro@jp.fujitsu.com: split LRU: munlock rework] [lee.schermerhorn@hp.com: mlock: fix __mlock_vma_pages_range comment block] [akpm@linux-foundation.org: remove bogus kerneldoc token] Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: KAMEZAWA Hiroyuki <kamewzawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20mlock: mlocked pages are unevictableNick Piggin
Make sure that mlocked pages also live on the unevictable LRU, so kswapd will not scan them over and over again. This is achieved through various strategies: 1) add yet another page flag--PG_mlocked--to indicate that the page is locked for efficient testing in vmscan and, optionally, fault path. This allows early culling of unevictable pages, preventing them from getting to page_referenced()/try_to_unmap(). Also allows separate accounting of mlock'd pages, as Nick's original patch did. Note: Nick's original mlock patch used a PG_mlocked flag. I had removed this in favor of the PG_unevictable flag + an mlock_count [new page struct member]. I restored the PG_mlocked flag to eliminate the new count field. 2) add the mlock/unevictable infrastructure to mm/mlock.c, with internal APIs in mm/internal.h. This is a rework of Nick's original patch to these files, taking into account that mlocked pages are now kept on unevictable LRU list. 3) update vmscan.c:page_evictable() to check PageMlocked() and, if vma passed in, the vm_flags. Note that the vma will only be passed in for new pages in the fault path; and then only if the "cull unevictable pages in fault path" patch is included. 4) add try_to_unlock() to rmap.c to walk a page's rmap and ClearPageMlocked() if no other vmas have it mlocked. Reuses as much of try_to_unmap() as possible. This effectively replaces the use of one of the lru list links as an mlock count. If this mechanism let's pages in mlocked vmas leak through w/o PG_mlocked set [I don't know that it does], we should catch them later in try_to_unmap(). One hopes this will be rare, as it will be relatively expensive. Original mm/internal.h, mm/rmap.c and mm/mlock.c changes: Signed-off-by: Nick Piggin <npiggin@suse.de> splitlru: introduce __get_user_pages(): New munlock processing need to GUP_FLAGS_IGNORE_VMA_PERMISSIONS. because current get_user_pages() can't grab PROT_NONE pages theresore it cause PROT_NONE pages can't munlock. [akpm@linux-foundation.org: fix this for pagemap-pass-mm-into-pagewalkers.patch] [akpm@linux-foundation.org: untangle patch interdependencies] [akpm@linux-foundation.org: fix things after out-of-order merging] [hugh@veritas.com: fix page-flags mess] [lee.schermerhorn@hp.com: fix munlock page table walk - now requires 'mm'] [kosaki.motohiro@jp.fujitsu.com: build fix] [kosaki.motohiro@jp.fujitsu.com: fix truncate race and sevaral comments] [kosaki.motohiro@jp.fujitsu.com: splitlru: introduce __get_user_pages()] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20Unevictable LRU InfrastructureLee Schermerhorn
When the system contains lots of mlocked or otherwise unevictable pages, the pageout code (kswapd) can spend lots of time scanning over these pages. Worse still, the presence of lots of unevictable pages can confuse kswapd into thinking that more aggressive pageout modes are required, resulting in all kinds of bad behaviour. Infrastructure to manage pages excluded from reclaim--i.e., hidden from vmscan. Based on a patch by Larry Woodman of Red Hat. Reworked to maintain "unevictable" pages on a separate per-zone LRU list, to "hide" them from vmscan. Kosaki Motohiro added the support for the memory controller unevictable lru list. Pages on the unevictable list have both PG_unevictable and PG_lru set. Thus, PG_unevictable is analogous to and mutually exclusive with PG_active--it specifies which LRU list the page is on. The unevictable infrastructure is enabled by a new mm Kconfig option [CONFIG_]UNEVICTABLE_LRU. A new function 'page_evictable(page, vma)' in vmscan.c tests whether or not a page may be evictable. Subsequent patches will add the various !evictable tests. We'll want to keep these tests light-weight for use in shrink_active_list() and, possibly, the fault path. To avoid races between tasks putting pages [back] onto an LRU list and tasks that might be moving the page from non-evictable to evictable state, the new function 'putback_lru_page()' -- inverse to 'isolate_lru_page()' -- tests the "evictability" of a page after placing it on the LRU, before dropping the reference. If the page has become unevictable, putback_lru_page() will redo the 'putback', thus moving the page to the unevictable list. This way, we avoid "stranding" evictable pages on the unevictable list. [akpm@linux-foundation.org: fix fallout from out-of-order merge] [riel@redhat.com: fix UNEVICTABLE_LRU and !PROC_PAGE_MONITOR build] [nishimura@mxp.nes.nec.co.jp: remove redundant mapping check] [kosaki.motohiro@jp.fujitsu.com: unevictable-lru-infrastructure: putback_lru_page()/unevictable page handling rework] [kosaki.motohiro@jp.fujitsu.com: kill unnecessary lock_page() in vmscan.c] [kosaki.motohiro@jp.fujitsu.com: revert migration change of unevictable lru infrastructure] [kosaki.motohiro@jp.fujitsu.com: revert to unevictable-lru-infrastructure-kconfig-fix.patch] [kosaki.motohiro@jp.fujitsu.com: restore patch failure of vmstat-unevictable-and-mlocked-pages-vm-events.patch] Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Debugged-by: Benjamin Kidwell <benjkidwell@yahoo.com> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20vmscan: move isolate_lru_page() to vmscan.cNick Piggin
On large memory systems, the VM can spend way too much time scanning through pages that it cannot (or should not) evict from memory. Not only does it use up CPU time, but it also provokes lock contention and can leave large systems under memory presure in a catatonic state. This patch series improves VM scalability by: 1) putting filesystem backed, swap backed and unevictable pages onto their own LRUs, so the system only scans the pages that it can/should evict from memory 2) switching to two handed clock replacement for the anonymous LRUs, so the number of pages that need to be scanned when the system starts swapping is bound to a reasonable number 3) keeping unevictable pages off the LRU completely, so the VM does not waste CPU time scanning them. ramfs, ramdisk, SHM_LOCKED shared memory segments and mlock()ed VMA pages are keept on the unevictable list. This patch: isolate_lru_page logically belongs to be in vmscan.c than migrate.c. It is tough, because we don't need that function without memory migration so there is a valid argument to have it in migrate.c. However a subsequent patch needs to make use of it in the core mm, so we can happily move it to vmscan.c. Also, make the function a little more generic by not requiring that it adds an isolated page to a given list. Callers can do that. Note that we now have '__isolate_lru_page()', that does something quite different, visible outside of vmscan.c for use with memory controller. Methinks we need to rationalize these names/purposes. --lts [akpm@linux-foundation.org: fix mm/memory_hotplug.c build] Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24mm: export prep_compound_page to mmAndi Kleen
hugetlb will need to get compound pages from bootmem to handle the case of them being greater than or equal to MAX_ORDER. Export the constructor function needed for this. Acked-by: Adam Litke <agl@us.ibm.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24mm: remove double indirection on tlb parameter to free_pgd_range() & CoJan Beulich
The double indirection here is not needed anywhere and hence (at least) confusing. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24mm: print out the zonelists on request for manual verificationMel Gorman
This patch prints out the zonelists during boot for manual verification by the user if the mminit_loglevel is MMINIT_VERIFY or higher. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24mm: make defensive checks around PFN values registered for memory usageMel Gorman
There are a number of different views to how much memory is currently active. There is the arch-independent zone-sizing view, the bootmem allocator and memory models view. Architectures register this information at different times and is not necessarily in sync particularly with respect to some SPARSEMEM limitations. This patch introduces mminit_validate_memmodel_limits() which is able to validate and correct PFN ranges with respect to the memory model. It is only SPARSEMEM that currently validates itself. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24mm: verify the page links and memory modelMel Gorman
Print out information on how the page flags are being used if mminit_loglevel is MMINIT_VERIFY or higher and unconditionally performs sanity checks on the flags regardless of loglevel. When the page flags are updated with section, node and zone information, a check are made to ensure the values can be retrieved correctly. Finally we confirm that pfn_to_page and page_to_pfn are the correct inverse functions. [akpm@linux-foundation.org: fix printk warnings] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24mm: add a basic debugging framework for memory initialisationMel Gorman
Boot initialisation is very complex, with significant numbers of architecture-specific routines, hooks and code ordering. While significant amounts of the initialisation is architecture-independent, it trusts the data received from the architecture layer. This is a mistake, and has resulted in a number of difficult-to-diagnose bugs. This patchset adds some validation and tracing to memory initialisation. It also introduces a few basic defensive measures. The validation code can be explicitly disabled for embedded systems. This patch: Add additional debugging and verification code for memory initialisation. Once enabled, the verification checks are always run and when required additional debugging information may be outputted via a mminit_loglevel= command-line parameter. The verification code is placed in a new file mm/mm_init.c. Ideally other mm initialisation code will be moved here over time. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28memory hotplug: free memmaps allocated by bootmemYasunori Goto
This patch is to free memmaps which is allocated by bootmem. Freeing usemap is not necessary. The pages of usemap may be necessary for other sections. If removing section is last section on the node, its section is the final user of usemap page. (usemaps are allocated on its section by previous patch.) But it shouldn't be freed too, because the section must be logical offline state which all pages are isolated against page allocater. If it is freed, page alloctor may use it which will be removed physically soon. It will be disaster. So, this patch keeps it as it is. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Badari Pulavarty <pbadari@us.ibm.com> Cc: Yinghai Lu <yhlu.kernel@gmail.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-23Solve section mismatch for free_area_init_core.Alexander van Heukelum
WARNING: vmlinux.o(.meminit.text+0x649): Section mismatch in reference from the function free_area_init_core() to the function .init.text:setup_usemap() The function __meminit free_area_init_core() references a function __init setup_usemap(). If free_area_init_core is only used by setup_usemap then annotate free_area_init_core with a matching annotation. The warning is covers this stack of functions in mm/page_alloc.c: alloc_bootmem_node must be marked __init. alloc_bootmem_node is used by setup_usemap, if !SPARSEMEM. (usemap_size is only used by setup_usemap, if !SPARSEMEM.) setup_usemap is only used by free_area_init_core. free_area_init_core is only used by free_area_init_node. free_area_init_node is used by: arch/alpha/mm/numa.c: __init paging_init() arch/arm/mm/init.c: __init bootmem_init_node() arch/avr32/mm/init.c: __init paging_init() arch/cris/arch-v10/mm/init.c: __init paging_init() arch/cris/arch-v32/mm/init.c: __init paging_init() arch/m32r/mm/discontig.c: __init zone_sizes_init() arch/m32r/mm/init.c: __init zone_sizes_init() arch/m68k/mm/motorola.c: __init paging_init() arch/m68k/mm/sun3mmu.c: __init paging_init() arch/mips/sgi-ip27/ip27-memory.c: __init paging_init() arch/parisc/mm/init.c: __init paging_init() arch/sparc/mm/srmmu.c: __init srmmu_paging_init() arch/sparc/mm/sun4c.c: __init sun4c_paging_init() arch/sparc64/mm/init.c: __init paging_init() mm/page_alloc.c: __init free_area_init_nodes() mm/page_alloc.c: __init free_area_init() and mm/memory_hotplug.c: hotadd_new_pgdat() hotadd_new_pgdat can not be an __init function, but: It is compiled for MEMORY_HOTPLUG configurations only MEMORY_HOTPLUG depends on SPARSEMEM || X86_64_ACPI_NUMA X86_64_ACPI_NUMA depends on X86_64 ARCH_FLATMEM_ENABLE depends on X86_32 ARCH_DISCONTIGMEM_ENABLE depends on X86_32 So X86_64_ACPI_NUMA implies SPARSEMEM, right? So we can mark the stack of functions __init for !SPARSEMEM, but we must mark them __meminit for SPARSEMEM configurations. This is ok, because then the calls to alloc_bootmem_node are also avoided. Compile-tested on: silly minimal config defconfig x86_32 defconfig x86_64 defconfig x86_64 -HIBERNATION +MEMORY_HOTPLUG Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Reviewed-by: Sam Ravnborg <sam@ravnborg.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05set_page_refcounted() VM_BUG_ON fixQi Yong
The current PageTail semantic is that a PageTail page is first a PageCompound page. So remove the redundant PageCompound test in set_page_refcounted(). Signed-off-by: Qi Yong <qiyong@fc-cn.com> Cc: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05mm: remove fastcall from mm/Harvey Harrison
fastcall is always defined to be empty, remove it [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Breakout page_order() to internal.h to avoid special knowledge of the buddy ↵Mel Gorman
allocator The statistics patch later needs to know what order a free page is on the free lists. Rather than having special knowledge of page_private() when PageBuddy() is set, this patch places out page_order() in internal.h and adds a VM_BUG_ON to catch using it on non-PageBuddy pages. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Christoph Lameter <clameter@sgi.com> Acked-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07Make page->private usable in compound pagesChristoph Lameter
If we add a new flag so that we can distinguish between the first page and the tail pages then we can avoid to use page->private in the first page. page->private == page for the first page, so there is no real information in there. Freeing up page->private makes the use of compound pages more transparent. They become more usable like real pages. Right now we have to be careful f.e. if we are going beyond PAGE_SIZE allocations in the slab on i386 because we can then no longer use the private field. This is one of the issues that cause us not to support debugging for page size slabs in SLAB. Having page->private available for SLUB would allow more meta information in the page struct. I can probably avoid the 16 bit ints that I have in there right now. Also if page->private is available then a compound page may be equipped with buffer heads. This may free up the way for filesystems to support larger blocks than page size. We add PageTail as an alias of PageReclaim. Compound pages cannot currently be reclaimed. Because of the alias one needs to check PageCompound first. The RFC for the this approach was discussed at http://marc.info/?t=117574302800001&r=1&w=2 [nacc@us.ibm.com: fix hugetlbfs] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-26[PATCH] mm: VM_BUG_ONNick Piggin
Introduce a VM_BUG_ON, which is turned on with CONFIG_DEBUG_VM. Use this in the lightweight, inline refcounting functions; PageLRU and PageActive checks in vmscan, because they're pretty well confined to vmscan. And in page allocate/free fastpaths which can be the hottest parts of the kernel for kbuilds. Unlike BUG_ON, VM_BUG_ON must not be used to execute statements with side-effects, and should not be used outside core mm code. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Hugh Dickins <hugh@veritas.com> Cc: Christoph Lameter <clameter@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[PATCH] remove set_page_count() outside mm/Nick Piggin
set_page_count usage outside mm/ is limited to setting the refcount to 1. Remove set_page_count from outside mm/, and replace those users with init_page_count() and set_page_refcounted(). This allows more debug checking, and tighter control on how code is allowed to play around with page->_count. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[PATCH] mm: nommu use compound pagesNick Piggin
Now that compound page handling is properly fixed in the VM, move nommu over to using compound pages rather than rolling their own refcounting. nommu vm page refcounting is broken anyway, but there is no need to have divergent code in the core VM now, nor when it gets fixed. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: David Howells <dhowells@redhat.com> (Needs testing, please). Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[PATCH] mm: make __put_page internalNick Piggin
Remove __put_page from outside the core mm/. It is dangerous because it does not handle compound pages nicely, and misses 1->0 transitions. If a user later appears that really needs the extra speed we can reevaluate. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] FRV: Clean up bootmem allocator's page freeing algorithmDavid Howells
The attached patch cleans up the way the bootmem allocator frees pages. A new function, __free_pages_bootmem(), is provided in mm/page_alloc.c that is called from mm/bootmem.c to turn pages over to the main allocator. All the bits of code to initialise pages (clearing PG_reserved and setting the page count) are moved to here. The checks on page validity are removed, on the assumption that the struct page arrays will have been prepared correctly. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] mm: set_page_refs optNick Piggin
Inline set_page_refs. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
