path: root/mm/khugepaged.c
2019-06-22coredump: fix race condition between collapse_huge_page() and core dumpingAndrea Arcangeli
commit 59ea6d06cfa9247b586a695c21f94afa7183af74 upstream. When fixing the race conditions between the coredump and the mmap_sem holders outside the context of the process, we focused on mmget_not_zero()/get_task_mm() callers in 04f5866e41fb70 ("coredump: fix race condition between mmget_not_zero()/get_task_mm() and core dumping"), but those aren't the only cases where the mmap_sem can be taken outside of the context of the process as Michal Hocko noticed while backporting that commit to older -stable kernels. If mmgrab() is called in the context of the process, but then the mm_count reference is transferred outside the context of the process, that can also be a problem if the mmap_sem has to be taken for writing through that mm_count reference. khugepaged registration calls mmgrab() in the context of the process, but the mmap_sem for writing is taken later in the context of the khugepaged kernel thread. collapse_huge_page() after taking the mmap_sem for writing doesn't modify any vma, so it's not obvious that it could cause a problem to the coredump, but it happens to modify the pmd in a way that breaks an invariant that pmd_trans_huge_lock() relies upon. collapse_huge_page() needs the mmap_sem for writing just to block concurrent page faults that call pmd_trans_huge_lock(). Specifically the invariant that "!pmd_trans_huge()" cannot become a "pmd_trans_huge()" doesn't hold while collapse_huge_page() runs. The coredump will call __get_user_pages() without mmap_sem for reading, which eventually can invoke a lockless page fault which will need a functional pmd_trans_huge_lock(). So collapse_huge_page() needs to use mmget_still_valid() to check it's not running concurrently with the coredump... as long as the coredump can invoke page faults without holding the mmap_sem for reading. This has "Fixes: khugepaged" to facilitate backporting, but in my view it's more a bug in the coredump code that will eventually have to be rewritten to stop invoking page faults without the mmap_sem for reading. So the long term plan is still to drop all mmget_still_valid(). Link: http://lkml.kernel.org/r/20190607161558.32104-1-aarcange@redhat.com Fixes: ba76149f47d8 ("thp: khugepaged") Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Reported-by: Michal Hocko <mhocko@suse.com> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Jann Horn <jannh@google.com> Cc: Hugh Dickins <hughd@google.com> Cc: Mike Rapoport <rppt@linux.vnet.ibm.com> Cc: Mike Kravetz <mike.kravetz@oracle.com> Cc: Peter Xu <peterx@redhat.com> Cc: Jason Gunthorpe <jgg@mellanox.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-12-05mm/khugepaged: collapse_shmem() do not crash on CompoundHugh Dickins
commit 06a5e1268a5fb9c2b346a3da6b97e85f2eba0f07 upstream. collapse_shmem()'s VM_BUG_ON_PAGE(PageTransCompound) was unsafe: before it holds page lock of the first page, racing truncation then extension might conceivably have inserted a hugepage there already. Fail with the SCAN_PAGE_COMPOUND result, instead of crashing (CONFIG_DEBUG_VM=y) or otherwise mishandling the unexpected hugepage - though later we might code up a more constructive way of handling it, with SCAN_SUCCESS. Link: http://lkml.kernel.org/r/alpine.LSU.2.11.1811261529310.2275@eggly.anvils Fixes: f3f0e1d2150b2 ("khugepaged: add support of collapse for tmpfs/shmem pages") Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Jerome Glisse <jglisse@redhat.com> Cc: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Cc: Matthew Wilcox <willy@infradead.org> Cc: <stable@vger.kernel.org> [4.8+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2018-12-05mm/khugepaged: collapse_shmem() without freezing new_pageHugh Dickins
commit 87c460a0bded56195b5eb497d44709777ef7b415 upstream. khugepaged's collapse_shmem() does almost all of its work, to assemble the huge new_page from 512 scattered old pages, with the new_page's refcount frozen to 0 (and refcounts of all old pages so far also frozen to 0). Including shmem_getpage() to read in any which were out on swap, memory reclaim if necessary to allocate their intermediate pages, and copying over all the data from old to new. Imagine the frozen refcount as a spinlock held, but without any lock debugging to highlight the abuse: it's not good, and under serious load heads into lockups - speculative getters of the page are not expecting to spin while khugepaged is rescheduled. One can get a little further under load by hacking around elsewhere; but fortunately, freezing the new_page turns out to have been entirely unnecessary, with no hacks needed elsewhere. The huge new_page lock is already held throughout, and guards all its subpages as they are brought one by one into the page cache tree; and anything reading the data in that page, without the lock, before it has been marked PageUptodate, would already be in the wrong. So simply eliminate the freezing of the new_page. Each of the old pages remains frozen with refcount 0 after it has been replaced by a new_page subpage in the page cache tree, until they are all unfrozen on success or failure: just as before. They could be unfrozen sooner, but cause no problem once no longer visible to find_get_entry(), filemap_map_pages() and other speculative lookups. Link: http://lkml.kernel.org/r/alpine.LSU.2.11.1811261527570.2275@eggly.anvils Fixes: f3f0e1d2150b2 ("khugepaged: add support of collapse for tmpfs/shmem pages") Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Jerome Glisse <jglisse@redhat.com> Cc: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Cc: Matthew Wilcox <willy@infradead.org> Cc: <stable@vger.kernel.org> [4.8+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2018-12-05mm/khugepaged: minor reorderings in collapse_shmem()Hugh Dickins
commit 042a30824871fa3149b0127009074b75cc25863c upstream. Several cleanups in collapse_shmem(): most of which probably do not really matter, beyond doing things in a more familiar and reassuring order. Simplify the failure gotos in the main loop, and on success update stats while interrupts still disabled from the last iteration. Link: http://lkml.kernel.org/r/alpine.LSU.2.11.1811261526400.2275@eggly.anvils Fixes: f3f0e1d2150b2 ("khugepaged: add support of collapse for tmpfs/shmem pages") Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Jerome Glisse <jglisse@redhat.com> Cc: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Cc: Matthew Wilcox <willy@infradead.org> Cc: <stable@vger.kernel.org> [4.8+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2018-12-05mm/khugepaged: collapse_shmem() remember to clear holesHugh Dickins
commit 2af8ff291848cc4b1cce24b6c943394eb2c761e8 upstream. Huge tmpfs testing reminds us that there is no __GFP_ZERO in the gfp flags khugepaged uses to allocate a huge page - in all common cases it would just be a waste of effort - so collapse_shmem() must remember to clear out any holes that it instantiates. The obvious place to do so, where they are put into the page cache tree, is not a good choice: because interrupts are disabled there. Leave it until further down, once success is assured, where the other pages are copied (before setting PageUptodate). Link: http://lkml.kernel.org/r/alpine.LSU.2.11.1811261525080.2275@eggly.anvils Fixes: f3f0e1d2150b2 ("khugepaged: add support of collapse for tmpfs/shmem pages") Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Jerome Glisse <jglisse@redhat.com> Cc: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Cc: Matthew Wilcox <willy@infradead.org> Cc: <stable@vger.kernel.org> [4.8+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2018-12-05mm/khugepaged: fix crashes due to misaccounted holesHugh Dickins
commit aaa52e340073b7f4593b3c4ddafcafa70cf838b5 upstream. Huge tmpfs testing on a shortish file mapped into a pmd-rounded extent hit shmem_evict_inode()'s WARN_ON(inode->i_blocks) followed by clear_inode()'s BUG_ON(inode->i_data.nrpages) when the file was later closed and unlinked. khugepaged's collapse_shmem() was forgetting to update mapping->nrpages on the rollback path, after it had added but then needs to undo some holes. There is indeed an irritating asymmetry between shmem_charge(), whose callers want it to increment nrpages after successfully accounting blocks, and shmem_uncharge(), when __delete_from_page_cache() already decremented nrpages itself: oh well, just add a comment on that to them both. And shmem_recalc_inode() is supposed to be called when the accounting is expected to be in balance (so it can deduce from imbalance that reclaim discarded some pages): so change shmem_charge() to update nrpages earlier (though it's rare for the difference to matter at all). Link: http://lkml.kernel.org/r/alpine.LSU.2.11.1811261523450.2275@eggly.anvils Fixes: 800d8c63b2e98 ("shmem: add huge pages support") Fixes: f3f0e1d2150b2 ("khugepaged: add support of collapse for tmpfs/shmem pages") Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Jerome Glisse <jglisse@redhat.com> Cc: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Cc: Matthew Wilcox <willy@infradead.org> Cc: <stable@vger.kernel.org> [4.8+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2018-12-05mm/khugepaged: collapse_shmem() stop if punched or truncatedHugh Dickins
commit 701270fa193aadf00bdcf607738f64997275d4c7 upstream. Huge tmpfs testing showed that although collapse_shmem() recognizes a concurrently truncated or hole-punched page correctly, its handling of holes was liable to refill an emptied extent. Add check to stop that. Link: http://lkml.kernel.org/r/alpine.LSU.2.11.1811261522040.2275@eggly.anvils Fixes: f3f0e1d2150b2 ("khugepaged: add support of collapse for tmpfs/shmem pages") Signed-off-by: Hugh Dickins <hughd@google.com> Reviewed-by: Matthew Wilcox <willy@infradead.org> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Jerome Glisse <jglisse@redhat.com> Cc: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Cc: <stable@vger.kernel.org> [4.8+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2018-05-30mm, thp: do not cause memcg oom for thpDavid Rientjes
[ Upstream commit 9d3c3354bb85bab4d865fe95039443f09a4c8394 ] Commit 2516035499b9 ("mm, thp: remove __GFP_NORETRY from khugepaged and madvised allocations") changed the page allocator to no longer detect thp allocations based on __GFP_NORETRY. It did not, however, modify the mem cgroup try_charge() path to avoid oom kill for either khugepaged collapsing or thp faulting. It is never expected to oom kill a process to allocate a hugepage for thp; reclaim is governed by the thp defrag mode and MADV_HUGEPAGE, but allocations (and charging) should fallback instead of oom killing processes. Link: http://lkml.kernel.org/r/alpine.DEB.2.20.1803191409420.124411@chino.kir.corp.google.com Fixes: 2516035499b9 ("mm, thp: remove __GFP_NORETRY from khugepaged and madvised allocations") Signed-off-by: David Rientjes <rientjes@google.com> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-26mm: thp: use down_read_trylock() in khugepaged to avoid long blockYang Shi
[ Upstream commit 3b454ad35043dfbd3b5d2bb92b0991d6342afb44 ] In the current design, khugepaged needs to acquire mmap_sem before scanning an mm. But in some corner cases, khugepaged may scan a process which is modifying its memory mapping, so khugepaged blocks in uninterruptible state. But the process might hold the mmap_sem for a long time when modifying a huge memory space and it may trigger the below khugepaged hung issue: INFO: task khugepaged:270 blocked for more than 120 seconds. Tainted: G E 4.9.65-006.ali3000.alios7.x86_64 #1 "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message. khugepaged D 0 270 2 0x00000000  ffff883f3deae4c0 0000000000000000 ffff883f610596c0 ffff883f7d359440 ffff883f63818000 ffffc90019adfc78 ffffffff817079a5 d67e5aa8c1860a64 0000000000000246 ffff883f7d359440 ffffc90019adfc88 ffff883f610596c0 Call Trace: schedule+0x36/0x80 rwsem_down_read_failed+0xf0/0x150 call_rwsem_down_read_failed+0x18/0x30 down_read+0x20/0x40 khugepaged+0x476/0x11d0 kthread+0xe6/0x100 ret_from_fork+0x25/0x30 So it sounds pointless to just block khugepaged waiting for the semaphore so replace down_read() with down_read_trylock() to move to scan the next mm quickly instead of just blocking on the semaphore so that other processes can get more chances to install THP. Then khugepaged can come back to scan the skipped mm when it has finished the current round full_scan. And it appears that the change can improve khugepaged efficiency a little bit. Below is the test result when running LTP on a 24 cores 4GB memory 2 nodes NUMA VM: pristine w/ trylock full_scan 197 187 pages_collapsed 21 26 thp_fault_alloc 40818 44466 thp_fault_fallback 18413 16679 thp_collapse_alloc 21 150 thp_collapse_alloc_failed 14 16 thp_file_alloc 369 369 [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: tweak comment] [arnd@arndb.de: avoid uninitialized variable use] Link: http://lkml.kernel.org/r/20171215125129.2948634-1-arnd@arndb.de Link: http://lkml.kernel.org/r/1513281203-54878-1-git-send-email-yang.s@alibaba-inc.com Signed-off-by: Yang Shi <yang.s@alibaba-inc.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Hugh Dickins <hughd@google.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-28mm/khugepaged.c: convert VM_BUG_ON() to collapse failKirill A. Shutemov
commit fece2029a9e65b9a990831afe2a2b83290cbbe26 upstream. khugepaged is not yet able to convert PTE-mapped huge pages back to PMD mapped. We do not collapse such pages. See check khugepaged_scan_pmd(). But if between khugepaged_scan_pmd() and __collapse_huge_page_isolate() somebody managed to instantiate THP in the range and then split the PMD back to PTEs we would have a problem -- VM_BUG_ON_PAGE(PageCompound(page)) will get triggered. It's possible since we drop mmap_sem during collapse to re-take for write. Replace the VM_BUG_ON() with graceful collapse fail. Link: http://lkml.kernel.org/r/20180315152353.27989-1-kirill.shutemov@linux.intel.com Fixes: b1caa957ae6d ("khugepaged: ignore pmd tables with THP mapped with ptes") Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Laura Abbott <labbott@redhat.com> Cc: Jerome Marchand <jmarchan@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-10mm: make PR_SET_THP_DISABLE immediately activeMichal Hocko
PR_SET_THP_DISABLE has a rather subtle semantic. It doesn't affect any existing mapping because it only updated mm->def_flags which is a template for new mappings. The mappings created after prctl(PR_SET_THP_DISABLE) have VM_NOHUGEPAGE flag set. This can be quite surprising for all those applications which do not do prctl(); fork() & exec() and want to control their own THP behavior. Another usecase when the immediate semantic of the prctl might be useful is a combination of pre- and post-copy migration of containers with CRIU. In this case CRIU populates a part of a memory region with data that was saved during the pre-copy stage. Afterwards, the region is registered with userfaultfd and CRIU expects to get page faults for the parts of the region that were not yet populated. However, khugepaged collapses the pages and the expected page faults do not occur. In more general case, the prctl(PR_SET_THP_DISABLE) could be used as a temporary mechanism for enabling/disabling THP process wide. Implementation wise, a new MMF_DISABLE_THP flag is added. This flag is tested when decision whether to use huge pages is taken either during page fault of at the time of THP collapse. It should be noted, that the new implementation makes PR_SET_THP_DISABLE master override to any per-VMA setting, which was not the case previously. Fixes: a0715cc22601 ("mm, thp: add VM_INIT_DEF_MASK and PRCTL_THP_DISABLE") Link: http://lkml.kernel.org/r/1496415802-30944-1-git-send-email-rppt@linux.vnet.ibm.com Signed-off-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Pavel Emelyanov <xemul@virtuozzo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-06-23mm, thp: remove cond_resched from __collapse_huge_page_copyDavid Rientjes
This is a partial revert of commit 338a16ba1549 ("mm, thp: copying user pages must schedule on collapse") which added a cond_resched() to __collapse_huge_page_copy(). On x86 with CONFIG_HIGHPTE, __collapse_huge_page_copy is called in atomic context and thus scheduling is not possible. This is only a possible config on arm and i386. Although need_resched has been shown to be set for over 100 jiffies while doing the iteration in __collapse_huge_page_copy, this is better than doing if (in_atomic()) cond_resched() to cover only non-CONFIG_HIGHPTE configs. Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1706191341550.97821@chino.kir.corp.google.com Signed-off-by: David Rientjes <rientjes@google.com> Reported-by: Larry Finger <Larry.Finger@lwfinger.net> Tested-by: Larry Finger <Larry.Finger@lwfinger.net> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-05-12mm, thp: copying user pages must schedule on collapseDavid Rientjes
We have encountered need_resched warnings in __collapse_huge_page_copy() while doing {clear,copy}_user_highpage() over HPAGE_PMD_NR source pages. mm->mmap_sem is held for write, but the iteration is well bounded. Reschedule as needed. Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1705101426380.109808@chino.kir.corp.google.com Signed-off-by: David Rientjes <rientjes@google.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Mel Gorman <mgorman@techsingularity.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-05-12mm/khugepaged: add missed tracepoint for collapse_huge_page_swapinSeongJae Park
One return case of `__collapse_huge_page_swapin()` does not invoke tracepoint while every other return case does. This commit adds a tracepoint invocation for the case. Link: http://lkml.kernel.org/r/20170507101813.30187-1-sj38.park@gmail.com Signed-off-by: SeongJae Park <sj38.park@gmail.com> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-05-03mm: do not use double negation for testing page flagsMinchan Kim
With the discussion[1], I found it seems there are every PageFlags functions return bool at this moment so we don't need double negation any more. Although it's not a problem to keep it, it makes future users confused to use double negation for them, too. Remove such possibility. [1] https://marc.info/?l=linux-kernel&m=148881578820434 Frankly sepaking, I like every PageFlags to return bool instead of int. It will make it clear. AFAIR, Chen Gang had tried it but don't know why it was not merged at that time. http://lkml.kernel.org/r/1469336184-1904-1-git-send-email-chengang@emindsoft.com.cn Link: http://lkml.kernel.org/r/1488868597-32222-1-git-send-email-minchan@kernel.org Signed-off-by: Minchan Kim <minchan@kernel.org> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Kirill A. Shutemov <kirill@shutemov.name> Cc: Chen Gang <gang.chen.5i5j@gmail.com> Cc: Anshuman Khandual <khandual@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-05-03mm: don't assume anonymous pages have SwapBacked flagShaohua Li
There are a few places the code assumes anonymous pages should have SwapBacked flag set. MADV_FREE pages are anonymous pages but we are going to add them to LRU_INACTIVE_FILE list and clear SwapBacked flag for them. The assumption doesn't hold any more, so fix them. Link: http://lkml.kernel.org/r/3945232c0df3dd6c4ef001976f35a95f18dcb407.1487965799.git.shli@fb.com Signed-off-by: Shaohua Li <shli@fb.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Hillf Danton <hillf.zj@alibaba-inc.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Hugh Dickins <hughd@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@techsingularity.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-03-02sched/headers: Prepare for new header dependencies before moving code to ↵Ingo Molnar
<linux/sched/coredump.h> We are going to split <linux/sched/coredump.h> out of <linux/sched.h>, which will have to be picked up from other headers and a couple of .c files. Create a trivial placeholder <linux/sched/coredump.h> file that just maps to <linux/sched.h> to make this patch obviously correct and bisectable. Include the new header in the files that are going to need it. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
<linux/sched/mm.h> We are going to split <linux/sched/mm.h> out of <linux/sched.h>, which will have to be picked up from other headers and a couple of .c files. Create a trivial placeholder <linux/sched/mm.h> file that just maps to <linux/sched.h> to make this patch obviously correct and bisectable. The APIs that are going to be moved first are: mm_alloc() __mmdrop() mmdrop() mmdrop_async_fn() mmdrop_async() mmget_not_zero() mmput() mmput_async() get_task_mm() mm_access() mm_release() Include the new header in the files that are going to need it. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-02-27mm: add new mmgrab() helperVegard Nossum
Apart from adding the helper function itself, the rest of the kernel is converted mechanically using: git grep -l 'atomic_inc.*mm_count' | xargs sed -i 's/atomic_inc(&\(.*\)->mm_count);/mmgrab\(\1\);/' git grep -l 'atomic_inc.*mm_count' | xargs sed -i 's/atomic_inc(&\(.*\)\.mm_count);/mmgrab\(\&\1\);/' This is needed for a later patch that hooks into the helper, but might be a worthwhile cleanup on its own. (Michal Hocko provided most of the kerneldoc comment.) Link: http://lkml.kernel.org/r/20161218123229.22952-1-vegard.nossum@oracle.com Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-01-10mm: get rid of __GFP_OTHER_NODEMichal Hocko
The flag was introduced by commit 78afd5612deb ("mm: add __GFP_OTHER_NODE flag") to allow proper accounting of remote node allocations done by kernel daemons on behalf of a process - e.g. khugepaged. After "mm: fix remote numa hits statistics" we do not need and actually use the flag so we can safely remove it because all allocations which are satisfied from their "home" node are accounted properly. [mhocko@suse.com: fix build] Link: http://lkml.kernel.org/r/20170106122225.GK5556@dhcp22.suse.cz Link: http://lkml.kernel.org/r/20170102153057.9451-3-mhocko@kernel.org Signed-off-by: Michal Hocko <mhocko@suse.com> Acked-by: Mel Gorman <mgorman@suse.de> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Michal Hocko <mhocko@suse.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Taku Izumi <izumi.taku@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-01-10mm/thp/pagecache/collapse: free the pte page table on collapse for thp page ↵Aneesh Kumar K.V
cache. With THP page cache, when trying to build a huge page from regular pte pages, we just clear the pmd entry. We will take another fault and at that point we will find the huge page in the radix tree, thereby using the huge page to complete the page fault The second fault path will allocate the needed pgtable_t page for archs like ppc64. So no need to deposit the same in collapse path. Depositing them in the collapse path resulting in a pgtable_t memory leak also giving errors like BUG: non-zero nr_ptes on freeing mm: 3 Fixes: 953c66c2b22a ("mm: THP page cache support for ppc64") Link: http://lkml.kernel.org/r/20161212163428.6780-2-aneesh.kumar@linux.vnet.ibm.com Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-12-14radix-tree: improve multiorder iteratorsMatthew Wilcox
This fixes several interlinked problems with the iterators in the presence of multiorder entries. 1. radix_tree_iter_next() would only advance by one slot, which would result in the iterators returning the same entry more than once if there were sibling entries. 2. radix_tree_next_slot() could return an internal pointer instead of a user pointer if a tagged multiorder entry was immediately followed by an entry of lower order. 3. radix_tree_next_slot() expanded to a lot more code than it used to when multiorder support was compiled in. And I wasn't comfortable with entry_to_node() being in a header file. Fixing radix_tree_iter_next() for the presence of sibling entries necessarily involves examining the contents of the radix tree, so we now need to pass 'slot' to radix_tree_iter_next(), and we need to change the calling convention so it is called *before* dropping the lock which protects the tree. Also rename it to radix_tree_iter_resume(), as some people thought it was necessary to call radix_tree_iter_next() each time around the loop. radix_tree_next_slot() becomes closer to how it looked before multiorder support was introduced. It only checks to see if the next entry in the chunk is a sibling entry or a pointer to a node; this should be rare enough that handling this case out of line is not a performance impact (and such impact is amortised by the fact that the entry we just processed was a multiorder entry). Also, radix_tree_next_slot() used to force a new chunk lookup for untagged entries, which is more expensive than the out of line sibling entry skipping. Link: http://lkml.kernel.org/r/1480369871-5271-55-git-send-email-mawilcox@linuxonhyperv.com Signed-off-by: Matthew Wilcox <mawilcox@microsoft.com> Tested-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Matthew Wilcox <mawilcox@microsoft.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-12-14mm: add orig_pte field into vm_faultJan Kara
Add orig_pte field to vm_fault structure to allow ->page_mkwrite handlers to fully handle the fault. This also allows us to save some passing of extra arguments around. Link: http://lkml.kernel.org/r/1479460644-25076-8-git-send-email-jack@suse.cz Signed-off-by: Jan Kara <jack@suse.cz> Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-12-14mm: use pgoff in struct vm_fault instead of passing it separatelyJan Kara
struct vm_fault has already pgoff entry. Use it instead of passing pgoff as a separate argument and then assigning it later. Link: http://lkml.kernel.org/r/1479460644-25076-4-git-send-email-jack@suse.cz Signed-off-by: Jan Kara <jack@suse.cz> Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-12-14mm: join struct fault_env and vm_faultJan Kara
Currently we have two different structures for passing fault information around - struct vm_fault and struct fault_env. DAX will need more information in struct vm_fault to handle its faults so the content of that structure would become event closer to fault_env. Furthermore it would need to generate struct fault_env to be able to call some of the generic functions. So at this point I don't think there's much use in keeping these two structures separate. Just embed into struct vm_fault all that is needed to use it for both purposes. Link: http://lkml.kernel.org/r/1479460644-25076-2-git-send-email-jack@suse.cz Signed-off-by: Jan Kara <jack@suse.cz> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-12-12mm: THP page cache support for ppc64Aneesh Kumar K.V
Add arch specific callback in the generic THP page cache code that will deposit and withdarw preallocated page table. Archs like ppc64 use this preallocated table to store the hash pte slot information. Testing: kernel build of the patch series on tmpfs mounted with option huge=always The related thp stat: thp_fault_alloc 72939 thp_fault_fallback 60547 thp_collapse_alloc 603 thp_collapse_alloc_failed 0 thp_file_alloc 253763 thp_file_mapped 4251 thp_split_page 51518 thp_split_page_failed 1 thp_deferred_split_page 73566 thp_split_pmd 665 thp_zero_page_alloc 3 thp_zero_page_alloc_failed 0 [akpm@linux-foundation.org: remove unneeded parentheses, per Kirill] Link: http://lkml.kernel.org/r/20161113150025.17942-2-aneesh.kumar@linux.vnet.ibm.com Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Michael Neuling <mikey@neuling.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Balbir Singh <bsingharora@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-12-12lib: radix-tree: check accounting of existing slot replacement usersJohannes Weiner
The bug in khugepaged fixed earlier in this series shows that radix tree slot replacement is fragile; and it will become more so when not only NULL<->!NULL transitions need to be caught but transitions from and to exceptional entries as well. We need checks. Re-implement radix_tree_replace_slot() on top of the sanity-checked __radix_tree_replace(). This requires existing callers to also pass the radix tree root, but it'll warn us when somebody replaces slots with contents that need proper accounting (transitions between NULL entries, real entries, exceptional entries) and where a replacement through the slot pointer would corrupt the radix tree node counts. Link: http://lkml.kernel.org/r/20161117193021.GB23430@cmpxchg.org Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Suggested-by: Jan Kara <jack@suse.cz> Reviewed-by: Jan Kara <jack@suse.cz> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Hugh Dickins <hughd@google.com> Cc: Matthew Wilcox <mawilcox@linuxonhyperv.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-12-12mm: khugepaged: fix radix tree node leak in shmem collapse error pathJohannes Weiner
The radix tree counts valid entries in each tree node. Entries stored in the tree cannot be removed by simpling storing NULL in the slot or the internal counters will be off and the node never gets freed again. When collapsing a shmem page fails, restore the holes that were filled with radix_tree_insert() with a proper radix tree deletion. Fixes: f3f0e1d2150b ("khugepaged: add support of collapse for tmpfs/shmem pages") Link: http://lkml.kernel.org/r/20161117191138.22769-3-hannes@cmpxchg.org Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reported-by: Jan Kara <jack@suse.cz> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Reviewed-by: Jan Kara <jack@suse.cz> Cc: Hugh Dickins <hughd@google.com> Cc: Matthew Wilcox <mawilcox@linuxonhyperv.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-12-12mm: khugepaged: close use-after-free race during shmem collapsingJohannes Weiner
Patch series "mm: workingset: radix tree subtleties & single-page file refaults", v3. This is another revision of the radix tree / workingset patches based on feedback from Jan and Kirill. This is a follow-up to d3798ae8c6f3 ("mm: filemap: don't plant shadow entries without radix tree node"). That patch fixed an issue that was caused mainly by the page cache sneaking special shadow page entries into the radix tree and relying on subtleties in the radix tree code to make that work. The fix also had to stop tracking refaults for single-page files because shadow pages stored as direct pointers in radix_tree_root->rnode weren't properly handled during tree extension. These patches make the radix tree code explicitely support and track such special entries, to eliminate the subtleties and to restore the thrash detection for single-page files. This patch (of 9): When a radix tree iteration drops the tree lock, another thread might swoop in and free the node holding the current slot. The iteration needs to do another tree lookup from the current index to continue. [kirill.shutemov@linux.intel.com: re-lookup for replacement] Fixes: f3f0e1d2150b ("khugepaged: add support of collapse for tmpfs/shmem pages") Link: http://lkml.kernel.org/r/20161117191138.22769-2-hannes@cmpxchg.org Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Reviewed-by: Jan Kara <jack@suse.cz> Cc: Hugh Dickins <hughd@google.com> Cc: Matthew Wilcox <mawilcox@linuxonhyperv.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-11-30mm, thp: propagation of conditional compilation in khugepaged.cJérémy Lefaure
Commit b46e756f5e47 ("thp: extract khugepaged from mm/huge_memory.c") moved code from huge_memory.c to khugepaged.c. Some of this code should be compiled only when CONFIG_SYSFS is enabled but the condition around this code was not moved into khugepaged.c. The result is a compilation error when CONFIG_SYSFS is disabled: mm/built-in.o: In function `khugepaged_defrag_store': khugepaged.c:(.text+0x2d095): undefined reference to `single_hugepage_flag_store' mm/built-in.o: In function `khugepaged_defrag_show': khugepaged.c:(.text+0x2d0ab): undefined reference to `single_hugepage_flag_show' This commit adds the #ifdef CONFIG_SYSFS around the code related to sysfs. Link: http://lkml.kernel.org/r/20161114203448.24197-1-jeremy.lefaure@lse.epita.fr Signed-off-by: Jérémy Lefaure <jeremy.lefaure@lse.epita.fr> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Hillf Danton <hillf.zj@alibaba-inc.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-09-19mm, thp: fix leaking mapped pte in __collapse_huge_page_swapin()Ebru Akagunduz
Currently, khugepaged does not permit swapin if there are enough young pages in a THP. The problem is when a THP does not have enough young pages, khugepaged leaks mapped ptes. This patch prohibits leaking mapped ptes. Link: http://lkml.kernel.org/r/1472820276-7831-1-git-send-email-ebru.akagunduz@gmail.com Signed-off-by: Ebru Akagunduz <ebru.akagunduz@gmail.com> Suggested-by: Andrea Arcangeli <aarcange@redhat.com> Reviewed-by: Andrea Arcangeli <aarcange@redhat.com> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-09-19khugepaged: fix use-after-free in collapse_huge_page()Kirill A. Shutemov
hugepage_vma_revalidate() tries to re-check if we still should try to collapse small pages into huge one after the re-acquiring mmap_sem. The problem Dmitry Vyukov reported[1] is that the vma found by hugepage_vma_revalidate() can be suitable for huge pages, but not the same vma we had before dropping mmap_sem. And dereferencing original vma can lead to fun results.. Let's use vma hugepage_vma_revalidate() found instead of assuming it's the same as what we had before the lock was dropped. [1] http://lkml.kernel.org/r/CACT4Y+Z3gigBvhca9kRJFcjX0G70V_nRhbwKBU+yGoESBDKi9Q@mail.gmail.com Link: http://lkml.kernel.org/r/20160907122559.GA6542@black.fi.intel.com Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Reported-by: Dmitry Vyukov <dvyukov@google.com> Reviewed-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Ebru Akagunduz <ebru.akagunduz@gmail.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Vegard Nossum <vegard.nossum@oracle.com> Cc: Sasha Levin <levinsasha928@gmail.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com> Cc: Greg Thelen <gthelen@google.com> Cc: Suleiman Souhlal <suleiman@google.com> Cc: Hugh Dickins <hughd@google.com> Cc: David Rientjes <rientjes@google.com> Cc: syzkaller <syzkaller@googlegroups.com> Cc: Kostya Serebryany <kcc@google.com> Cc: Alexander Potapenko <glider@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-28mm, thp: remove __GFP_NORETRY from khugepaged and madvised allocationsVlastimil Babka
After the previous patch, we can distinguish costly allocations that should be really lightweight, such as THP page faults, with __GFP_NORETRY. This means we don't need to recognize khugepaged allocations via PF_KTHREAD anymore. We can also change THP page faults in areas where madvise(MADV_HUGEPAGE) was used to try as hard as khugepaged, as the process has indicated that it benefits from THP's and is willing to pay some initial latency costs. We can also make the flags handling less cryptic by distinguishing GFP_TRANSHUGE_LIGHT (no reclaim at all, default mode in page fault) from GFP_TRANSHUGE (only direct reclaim, khugepaged default). Adding __GFP_NORETRY or __GFP_KSWAPD_RECLAIM is done where needed. The patch effectively changes the current GFP_TRANSHUGE users as follows: * get_huge_zero_page() - the zero page lifetime should be relatively long and it's shared by multiple users, so it's worth spending some effort on it. We use GFP_TRANSHUGE, and __GFP_NORETRY is not added. This also restores direct reclaim to this allocation, which was unintentionally removed by commit e4a49efe4e7e ("mm: thp: set THP defrag by default to madvise and add a stall-free defrag option") * alloc_hugepage_khugepaged_gfpmask() - this is khugepaged, so latency is not an issue. So if khugepaged "defrag" is enabled (the default), do reclaim via GFP_TRANSHUGE without __GFP_NORETRY. We can remove the PF_KTHREAD check from page alloc. As a side-effect, khugepaged will now no longer check if the initial compaction was deferred or contended. This is OK, as khugepaged sleep times between collapsion attempts are long enough to prevent noticeable disruption, so we should allow it to spend some effort. * migrate_misplaced_transhuge_page() - already was masking out __GFP_RECLAIM, so just convert to GFP_TRANSHUGE_LIGHT which is equivalent. * alloc_hugepage_direct_gfpmask() - vma's with VM_HUGEPAGE (via madvise) are now allocating without __GFP_NORETRY. Other vma's keep using __GFP_NORETRY if direct reclaim/compaction is at all allowed (by default it's allowed only for madvised vma's). The rest is conversion to GFP_TRANSHUGE(_LIGHT). [mhocko@suse.com: suggested GFP_TRANSHUGE_LIGHT] Link: http://lkml.kernel.org/r/20160721073614.24395-7-vbabka@suse.cz Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Mel Gorman <mgorman@techsingularity.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-28mm: convert zone_reclaim to node_reclaimMel Gorman
As reclaim is now per-node based, convert zone_reclaim to be node_reclaim. It is possible that a node will be reclaimed multiple times if it has multiple zones but this is unavoidable without caching all nodes traversed so far. The documentation and interface to userspace is the same from a configuration perspective and will will be similar in behaviour unless the node-local allocation requests were also limited to lower zones. Link: http://lkml.kernel.org/r/1467970510-21195-24-git-send-email-mgorman@techsingularity.net Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Hillf Danton <hillf.zj@alibaba-inc.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: Minchan Kim <minchan@kernel.org> Cc: Rik van Riel <riel@surriel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-28mm: move most file-based accounting to the nodeMel Gorman
There are now a number of accounting oddities such as mapped file pages being accounted for on the node while the total number of file pages are accounted on the zone. This can be coped with to some extent but it's confusing so this patch moves the relevant file-based accounted. Due to throttling logic in the page allocator for reliable OOM detection, it is still necessary to track dirty and writeback pages on a per-zone basis. [mgorman@techsingularity.net: fix NR_ZONE_WRITE_PENDING accounting] Link: http://lkml.kernel.org/r/1468404004-5085-5-git-send-email-mgorman@techsingularity.net Link: http://lkml.kernel.org/r/1467970510-21195-20-git-send-email-mgorman@techsingularity.net Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Hillf Danton <hillf.zj@alibaba-inc.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Rik van Riel <riel@surriel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-28mm, vmscan: move LRU lists to nodeMel Gorman
This moves the LRU lists from the zone to the node and related data such as counters, tracing, congestion tracking and writeback tracking. Unfortunately, due to reclaim and compaction retry logic, it is necessary to account for the number of LRU pages on both zone and node logic. Most reclaim logic is based on the node counters but the retry logic uses the zone counters which do not distinguish inactive and active sizes. It would be possible to leave the LRU counters on a per-zone basis but it's a heavier calculation across multiple cache lines that is much more frequent than the retry checks. Other than the LRU counters, this is mostly a mechanical patch but note that it introduces a number of anomalies. For example, the scans are per-zone but using per-node counters. We also mark a node as congested when a zone is congested. This causes weird problems that are fixed later but is easier to review. In the event that there is excessive overhead on 32-bit systems due to the nodes being on LRU then there are two potential solutions 1. Long-term isolation of highmem pages when reclaim is lowmem When pages are skipped, they are immediately added back onto the LRU list. If lowmem reclaim persisted for long periods of time, the same highmem pages get continually scanned. The idea would be that lowmem keeps those pages on a separate list until a reclaim for highmem pages arrives that splices the highmem pages back onto the LRU. It potentially could be implemented similar to the UNEVICTABLE list. That would reduce the skip rate with the potential corner case is that highmem pages have to be scanned and reclaimed to free lowmem slab pages. 2. Linear scan lowmem pages if the initial LRU shrink fails This will break LRU ordering but may be preferable and faster during memory pressure than skipping LRU pages. Link: http://lkml.kernel.org/r/1467970510-21195-4-git-send-email-mgorman@techsingularity.net Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Hillf Danton <hillf.zj@alibaba-inc.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: Minchan Kim <minchan@kernel.org> Cc: Rik van Riel <riel@surriel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26mm, thp: convert from optimistic swapin collapsing to conservativeEbru Akagunduz
To detect whether khugepaged swapin is worthwhile, this patch checks the amount of young pages. There should be at least half of HPAGE_PMD_NR to swapin. Link: http://lkml.kernel.org/r/1468109451-1615-1-git-send-email-ebru.akagunduz@gmail.com Signed-off-by: Ebru Akagunduz <ebru.akagunduz@gmail.com> Suggested-by: Minchan Kim <minchan@kernel.org> Acked-by: Rik van Riel <riel@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Mel Gorman <mgorman@suse.de> Cc: David Rientjes <rientjes@google.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Boaz Harrosh <boaz@plexistor.com> Cc: Hillf Danton <hillf.zj@alibaba-inc.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26mm, thp: fix comment inconsistency for swapin readahead functionsEbru Akagunduz
After fixing swapin issues, comment lines stayed as in old version. This patch updates the comments. Link: http://lkml.kernel.org/r/1468109345-32258-1-git-send-email-ebru.akagunduz@gmail.com Signed-off-by: Ebru Akagunduz <ebru.akagunduz@gmail.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Mel Gorman <mgorman@suse.de> Cc: David Rientjes <rientjes@google.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Boaz Harrosh <boaz@plexistor.com> Cc: Hillf Danton <hillf.zj@alibaba-inc.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26thp: introduce CONFIG_TRANSPARENT_HUGE_PAGECACHEKirill A. Shutemov
For file mappings, we don't deposit page tables on THP allocation because it's not strictly required to implement split_huge_pmd(): we can just clear pmd and let following page faults to reconstruct the page table. But Power makes use of deposited page table to address MMU quirk. Let's hide THP page cache, including huge tmpfs, under separate config option, so it can be forbidden on Power. We can revert the patch later once solution for Power found. Link: http://lkml.kernel.org/r/1466021202-61880-36-git-send-email-kirill.shutemov@linux.intel.com Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26khugepaged: add support of collapse for tmpfs/shmem pagesKirill A. Shutemov
This patch extends khugepaged to support collapse of tmpfs/shmem pages. We share fair amount of infrastructure with anon-THP collapse. Few design points: - First we are looking for VMA which can be suitable for mapping huge page; - If the VMA maps shmem file, the rest scan/collapse operations operates on page cache, not on page tables as in anon VMA case. - khugepaged_scan_shmem() finds a range which is suitable for huge page. The scan is lockless and shouldn't disturb system too much. - once the candidate for collapse is found, collapse_shmem() attempts to create a huge page: + scan over radix tree, making the range point to new huge page; + new huge page is not-uptodate, locked and freezed (refcount is 0), so nobody can touch them until we say so. + we swap in pages during the scan. khugepaged_scan_shmem() filters out ranges with more than khugepaged_max_ptes_swap swapped out pages. It's HPAGE_PMD_NR/8 by default. + old pages are isolated, unmapped and put to local list in case to be restored back if collapse failed. - if collapse succeed, we retract pte page tables from VMAs where huge pages mapping is possible. The huge page will be mapped as PMD on next minor fault into the range. Link: http://lkml.kernel.org/r/1466021202-61880-35-git-send-email-kirill.shutemov@linux.intel.com Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26khugepaged: move up_read(mmap_sem) out of khugepaged_alloc_page()Kirill A. Shutemov
Both variants of khugepaged_alloc_page() do up_read(&mm->mmap_sem) first: no point keep it inside the function. Link: http://lkml.kernel.org/r/1466021202-61880-33-git-send-email-kirill.shutemov@linux.intel.com Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26thp: extract khugepaged from mm/huge_memory.cKirill A. Shutemov
khugepaged implementation grew to the point when it deserve separate file in source. Let's move it to mm/khugepaged.c. Link: http://lkml.kernel.org/r/1466021202-61880-32-git-send-email-kirill.shutemov@linux.intel.com Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
