commit dce5b0bdeec61bdbee56121ceb1d014151d5cab1 upstream.
The only references outside of the #ifdef have been removed, so now we
get a warning in non-SMP configurations:
mm/kmemleak.c:1404:13: error: unused function 'scan_large_block' [-Werror,-Wunused-function]
Add a new #ifdef around it.
Link: http://lkml.kernel.org/r/20190416123148.3502045-1-arnd@arndb.de
Fixes: 298a32b13208 ("kmemleak: powerpc: skip scanning holes in the .bss section")
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Cc: Vincent Whitchurch <vincent.whitchurch@axis.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Nobuhiro Iwamatsu <nobuhiro1.iwamatsu@toshiba.co.jp>
[ Upstream commit 298a32b132087550d3fa80641ca58323c5dfd4d9 ]
Commit 2d4f567103ff ("KVM: PPC: Introduce kvm_tmp framework") adds
kvm_tmp[] into the .bss section and then free the rest of unused spaces
back to the page allocator.
kernel_init
kvm_guest_init
kvm_free_tmp
free_reserved_area
free_unref_page
free_unref_page_prepare
With DEBUG_PAGEALLOC=y, it will unmap those pages from kernel. As the
result, kmemleak scan will trigger a panic when it scans the .bss
section with unmapped pages.
This patch creates dedicated kmemleak objects for the .data, .bss and
potentially .data..ro_after_init sections to allow partial freeing via
the kmemleak_free_part() in the powerpc kvm_free_tmp() function.
Link: http://lkml.kernel.org/r/20190321171917.62049-1-catalin.marinas@arm.com
Reported-by: Qian Cai <cai@lca.pw>
Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Tested-by: Qian Cai <cai@lca.pw>
Cc: Avi Kivity <avi@redhat.com>
Cc: Radim Krcmar <rkrcmar@redhat.com>
[ Upstream commit 914b6dfff790544d9b77dfd1723adb3745ec9700 ]
A crash is observed when kmemleak_scan accesses the object->pointer,
likely due to the following race.
TASK A TASK B TASK C
kmemleak_write
(with "scan" and
NOT "scan=on")
kmemleak_scan()
create_object
kmem_cache_alloc fails
kmemleak_disable
kmemleak_do_cleanup
kmemleak_free_enabled = 0
kfree
kmemleak_free bails out
(kmemleak_free_enabled is 0)
slub frees object->pointer
update_checksum
crash - object->pointer
freed (DEBUG_PAGEALLOC)
kmemleak_do_cleanup waits for the scan thread to complete, but not for
direct call to kmemleak_scan via kmemleak_write. So add a wait for
kmemleak_scan completion before disabling kmemleak_free, and while at it
fix the comment on stop_scan_thread.
[vinmenon@codeaurora.org: fix stop_scan_thread comment]
Link: http://lkml.kernel.org/r/1522219972-22809-1-git-send-email-vinmenon@codeaurora.org
Link: http://lkml.kernel.org/r/1522063429-18992-1-git-send-email-vinmenon@codeaurora.org
Signed-off-by: Vinayak Menon <vinmenon@codeaurora.org>
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
commit 4950276672fce5c241857540f8561c440663673d upstream.
Patch series "kmemcheck: kill kmemcheck", v2.
As discussed at LSF/MM, kill kmemcheck.
KASan is a replacement that is able to work without the limitation of
kmemcheck (single CPU, slow). KASan is already upstream.
We are also not aware of any users of kmemcheck (or users who don't
consider KASan as a suitable replacement).
The only objection was that since KASAN wasn't supported by all GCC
versions provided by distros at that time we should hold off for 2
years, and try again.
Now that 2 years have passed, and all distros provide gcc that supports
KASAN, kill kmemcheck again for the very same reasons.
This patch (of 4):
Remove kmemcheck annotations, and calls to kmemcheck from the kernel.
[alexander.levin@verizon.com: correctly remove kmemcheck call from dma_map_sg_attrs]
Link: http://lkml.kernel.org/r/20171012192151.26531-1-alexander.levin@verizon.com
Link: http://lkml.kernel.org/r/20171007030159.22241-2-alexander.levin@verizon.com
Cc: Alexander Potapenko <glider@google.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Tim Hansen <devtimhansen@gmail.com>
Cc: Vegard Nossum <vegardno@ifi.uio.no>
[ Upstream commit bde5f6bc68db51128f875a756e9082a6c6ff7b4c ]
kmemleak_scan() will scan struct page for each node and it can be really
large and resulting in a soft lockup. We have seen a soft lockup when
do scan while compile kernel:
watchdog: BUG: soft lockup - CPU#53 stuck for 22s! [bash:10287]
Call Trace:
kmemleak_scan+0x21a/0x4c0
kmemleak_write+0x312/0x350
full_proxy_write+0x5a/0xa0
__vfs_write+0x33/0x150
vfs_write+0xad/0x1a0
SyS_write+0x52/0xc0
do_syscall_64+0x61/0x1a0
entry_SYSCALL64_slow_path+0x25/0x25
Fix this by adding cond_resched every MAX_SCAN_SIZE.
Link: http://lkml.kernel.org/r/1511439788-20099-1-git-send-email-xieyisheng1@huawei.com
Signed-off-by: Yisheng Xie <xieyisheng1@huawei.com>
Suggested-by: Catalin Marinas <catalin.marinas@arm.com>
Kmemleak requires that vmalloc'ed objects have a minimum reference count
of 2: one in the corresponding vm_struct object and the other owned by
the vmalloc() caller. There are cases, however, where the original
vmalloc() returned pointer is lost and, instead, a pointer to vm_struct
is stored (see free_thread_stack()). Kmemleak currently reports such
objects as leaks.
This patch adds support for treating any surplus references to an object
as additional references to a specified object. It introduces the
kmemleak_vmalloc() API function which takes a vm_struct pointer and sets
its surplus reference passing to the actual vmalloc() returned pointer.
The __vmalloc_node_range() calling site has been modified accordingly.
Link: http://lkml.kernel.org/r/1495726937-23557-4-git-send-email-catalin.marinas@arm.com
Reported-by: "Luis R. Rodriguez" <mcgrof@kernel.org>
Cc: "Luis R. Rodriguez" <mcgrof@kernel.org>
scan_block() updates the number of references (pointers) to objects,
adding them to the gray_list when object->min_count is reached. The
patch factors out this functionality into a separate update_refs()
function.
Link: http://lkml.kernel.org/r/1495726937-23557-3-git-send-email-catalin.marinas@arm.com
architectures
Change the kmemleak_object.flags type to unsigned int and moves the
early_log.min_count (int) near early_log.op_type (int) to slightly
reduce the size of these structures on 64-bit architectures.
Link: http://lkml.kernel.org/r/1495726937-23557-2-git-send-email-catalin.marinas@arm.com
A section name for .data..ro_after_init was added by both:
commit d07a980c1b8d ("s390: add proper __ro_after_init support")
and
commit d7c19b066dcf ("mm: kmemleak: scan .data.ro_after_init")
The latter adds incorrect wrapping around the existing s390 section, and
came later. I'd prefer the s390 naming, so this moves the s390-specific
name up to the asm-generic/sections.h and renames the section as used by
kmemleak (and in the future, kernel/extable.c).
Link: http://lkml.kernel.org/r/20170327192213.GA129375@beast
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> [s390 parts]
Acked-by: Jakub Kicinski <jakub.kicinski@netronome.com>
Cc: Eddie Kovsky <ewk@edkovsky.org>
<linux/sched/task_stack.h>
We are going to split <linux/sched/task_stack.h> out of <linux/sched.h>, which
will have to be picked up from other headers and a couple of .c files.
Create a trivial placeholder <linux/sched/task_stack.h> file that just
maps to <linux/sched.h> to make this patch obviously correct and
bisectable.
Include the new header in the files that are going to need it.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
<linux/sched/task.h>
We are going to split <linux/sched/task.h> out of <linux/sched.h>, which
Create a trivial placeholder <linux/sched/task.h> file that just
bisectable.
<linux/sched/signal.h>
We are going to split <linux/sched/signal.h> out of <linux/sched.h>, which
Create a trivial placeholder <linux/sched/signal.h> file that just
bisectable.
Documentation/kmemleak.txt was moved to Documentation/dev-tools/kmemleak.rst,
this fixes the reference to the new location.
Link: http://lkml.kernel.org/r/1476544946-18804-1-git-send-email-andreas.platschek@opentech.at
Signed-off-by: Andreas Platschek <andreas.platschek@opentech.at>
Limit the number of kmemleak false positives by including
.data.ro_after_init in memory scanning. To achieve this we need to add
symbols for start and end of the section to the linker scripts.
The problem was been uncovered by commit 56989f6d8568 ("genetlink: mark
families as __ro_after_init").
Link: http://lkml.kernel.org/r/1478274173-15218-1-git-send-email-jakub.kicinski@netronome.com
Signed-off-by: Jakub Kicinski <jakub.kicinski@netronome.com>
Cc: Cong Wang <xiyou.wangcong@gmail.com>
Cc: Johannes Berg <johannes@sipsolutions.net>
Commit 68f24b08ee89 ("sched/core: Free the stack early if
CONFIG_THREAD_INFO_IN_TASK") may cause the task->stack to be freed
during kmemleak_scan() execution, leading to either a NULL pointer fault
(if task->stack is NULL) or kmemleak accessing already freed memory.
This patch uses the new try_get_task_stack() API to ensure that the task
stack is not freed during kmemleak stack scanning.
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=173901.
Fixes: 68f24b08ee89 ("sched/core: Free the stack early if CONFIG_THREAD_INFO_IN_TASK")
Link: http://lkml.kernel.org/r/1476266223-14325-1-git-send-email-catalin.marinas@arm.com
Reported-by: CAI Qian <caiqian@redhat.com>
Tested-by: CAI Qian <caiqian@redhat.com>
Cc: CAI Qian <caiqian@redhat.com>
Cc: Hillf Danton <hillf.zj@alibaba-inc.com>
Some of the kmemleak_*() callbacks in memblock, bootmem, CMA convert a
physical address to a virtual one using __va(). However, such physical
addresses may sometimes be located in highmem and using __va() is
incorrect, leading to inconsistent object tracking in kmemleak.
The following functions have been added to the kmemleak API and they take
a physical address as the object pointer. They only perform the
corresponding action if the address has a lowmem mapping:
kmemleak_alloc_phys
kmemleak_free_part_phys
kmemleak_not_leak_phys
kmemleak_ignore_phys
The affected calling places have been updated to use the new kmemleak
API.
Link: http://lkml.kernel.org/r/1471531432-16503-1-git-send-email-catalin.marinas@arm.com
Reported-by: Vignesh R <vigneshr@ti.com>
If the user tries to disable automatic scanning early in the boot
process using e.g.:
echo scan=off > /sys/kernel/debug/kmemleak
then this command will hang until SECS_FIRST_SCAN (= 60) seconds have
elapsed, even though the system is fully initialised.
We can fix this using interruptible sleep and checking if we're supposed
to stop whenever we wake up (like the rest of the code does).
Link: http://lkml.kernel.org/r/1468835005-2873-1-git-send-email-vegard.nossum@oracle.com
Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com>
When kmemleak dumps contents of leaked objects it reads whole objects
regardless of user-requested size. This upsets KASAN. Disable KASAN
checks around object dump.
Link: http://lkml.kernel.org/r/1466617631-68387-1-git-send-email-dvyukov@google.com
Signed-off-by: Dmitry Vyukov <dvyukov@google.com>
Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com>
Kernel style prefers a single string over split strings when the string is
'user-visible'.
Miscellanea:
- Add a missing newline
- Realign arguments
Acked-by: Tejun Heo <tj@kernel.org> [percpu]
There are a mixture of pr_warning and pr_warn uses in mm. Use pr_warn
consistently.
Miscellanea:
- Coalesce formats
- Realign arguments
This reverts commit 8f4fc071b192 ("gfp: add __GFP_NOACCOUNT").
Black-list kmem accounting policy (aka __GFP_NOACCOUNT) turned out to be
fragile and difficult to maintain, because there seem to be many more
allocations that should not be accounted than those that should be.
Besides, false accounting an allocation might result in much worse
consequences than not accounting at all, namely increased memory
consumption due to pinned dead kmem caches.
So it was decided to switch to the white-list policy. This patch
reverts bits introducing the black-list policy. The white-list policy
will be introduced later in the series.
Signed-off-by: Vladimir Davydov <vdavydov@virtuozzo.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Christoph Lameter <cl@linux.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Few lines below object is reinitialized by lookup_object() so we don't
need to init it by NULL in the beginning of find_and_get_object().
Signed-off-by: Alexey Klimov <alexey.klimov@linaro.org>
Instead of custom approach let's use recently introduced seq_hex_dump()
helper.
Cc: Joe Perches <joe@perches.com>
Cc: Tadeusz Struk <tadeusz.struk@intel.com>
Cc: Helge Deller <deller@gmx.de>
Cc: Ingo Tuchscherer <ingo.tuchscherer@de.ibm.com>
Cc: Vladimir Kondratiev <qca_vkondrat@qca.qualcomm.com>
In log_early function, crt_early_log should also count once when
'crt_early_log >= ARRAY_SIZE(early_log)'. Otherwise the reported count
from kmemleak_init is one less than 'actual number'.
Then, in kmemleak_init, if early_log buffer size equal actual number,
kmemleak will init sucessful, so change warning condition to
'crt_early_log > ARRAY_SIZE(early_log)'.
Signed-off-by: Wang Kai <morgan.wang@huawei.com>
Beginning at commit d52d3997f843 ("ipv6: Create percpu rt6_info"), the
following INFO splat is logged:
[ INFO: suspicious RCU usage. ]
4.1.0-rc7-next-20150612 #1 Not tainted
kernel/sched/core.c:7318 Illegal context switch in RCU-bh read-side critical section!
rcu_scheduler_active = 1, debug_locks = 0
3 locks held by systemd/1:
#0: (rtnl_mutex){+.+.+.}, at: [<ffffffff815f0c8f>] rtnetlink_rcv+0x1f/0x40
#1: (rcu_read_lock_bh){......}, at: [<ffffffff816a34e2>] ipv6_add_addr+0x62/0x540
#2: (addrconf_hash_lock){+...+.}, at: [<ffffffff816a3604>] ipv6_add_addr+0x184/0x540
stack backtrace:
CPU: 0 PID: 1 Comm: systemd Not tainted 4.1.0-rc7-next-20150612 #1
Hardware name: TOSHIBA TECRA A50-A/TECRA A50-A, BIOS Version 4.20 04/17/2014
Call Trace:
dump_stack+0x4c/0x6e
lockdep_rcu_suspicious+0xe7/0x120
___might_sleep+0x1d5/0x1f0
__might_sleep+0x4d/0x90
kmem_cache_alloc+0x47/0x250
create_object+0x39/0x2e0
kmemleak_alloc_percpu+0x61/0xe0
pcpu_alloc+0x370/0x630
Additional backtrace lines are truncated. In addition, the above splat
is followed by several "BUG: sleeping function called from invalid
context at mm/slub.c:1268" outputs. As suggested by Martin KaFai Lau,
these are the clue to the fix. Routine kmemleak_alloc_percpu() always
uses GFP_KERNEL for its allocations, whereas it should follow the gfp
from its callers.
Reviewed-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com>
Acked-by: Martin KaFai Lau <kafai@fb.com>
Cc: Martin KaFai Lau <kafai@fb.com>
Cc: <stable@vger.kernel.org> [3.18+]
The kmemleak memory scanning uses finer grained object->lock spinlocks
primarily to avoid races with the memory block freeing. However, the
pointer lookup in the rb tree requires the kmemleak_lock to be held.
This is currently done in the find_and_get_object() function for each
pointer-like location read during scanning. While this allows a low
latency on kmemleak_*() callbacks on other CPUs, the memory scanning is
slower.
This patch moves the kmemleak_lock outside the scan_block() loop,
acquiring/releasing it only once per scanned memory block. The
allow_resched logic is moved outside scan_block() and a new
scan_large_block() function is implemented which splits large blocks in
MAX_SCAN_SIZE chunks with cond_resched() calls in-between. A redundant
(object->flags & OBJECT_NO_SCAN) check is also removed from
scan_object().
With this patch, the kmemleak scanning performance is significantly
improved: at least 50% with lock debugging disabled and over an order of
magnitude with lock proving enabled (on an arm64 system).
While very unlikely (usually kmemleak or sl*b bug), the create_object()
function in mm/kmemleak.c may fail to insert a newly allocated object into
the rb tree. When this happens, kmemleak disables itself and prints
additional information about the object already found in the rb tree.
Such printing is done with the parent->lock acquired, however the
kmemleak_lock is already held. This is a potential race with the scanning
thread which acquires object->lock and kmemleak_lock in a
This patch removes the locking around the 'parent' object information
printing. Such object cannot be freed or removed from object_tree_root
and object_list since kmemleak_lock is already held. There is a very
small risk that some of the object data is being modified on another CPU
but the only downside is inconsistent information printing.
The kmemleak_do_cleanup() work thread already waits for the kmemleak_scan
thread to finish via kthread_stop(). Waiting in kthread_stop() while
scan_mutex is held may lead to deadlock if kmemleak_scan_thread() also
waits to acquire for scan_mutex.
Calling delete_object_*() on the same pointer is not a standard use case
(unless there is a bug in the code calling kmemleak_free()). However,
during kmemleak disabling (error or user triggered via /sys), there is a
potential race between kmemleak_free() calls on a CPU and
__kmemleak_do_cleanup() on a different CPU.
The current delete_object_*() implementation first performs a look-up
holding kmemleak_lock, increments the object->use_count and then
re-acquires kmemleak_lock to remove the object from object_tree_root and
object_list.
This patch simplifies the delete_object_*() mechanism to both look up
and remove an object from the object_tree_root and object_list
atomically (guarded by kmemleak_lock). This allows safe concurrent
calls to delete_object_*() on the same pointer without additional
locking for synchronising the kmemleak_free_enabled flag.
A side effect is a slight improvement in the delete_object_*() performance
by avoiding acquiring kmemleak_lock twice and incrementing/decrementing
object->use_count.
The kmemleak scanning thread can run for minutes. Callbacks like
kmemleak_free() are allowed during this time, the race being taken care
of by the object->lock spinlock. Such lock also prevents a memory block
from being freed or unmapped while it is being scanned by blocking the
kmemleak_free() -> ... -> __delete_object() function until the lock is
released in scan_object().
When a kmemleak error occurs (e.g. it fails to allocate its metadata),
kmemleak_enabled is set and __delete_object() is no longer called on
freed objects. If kmemleak_scan is running at the same time,
kmemleak_free() no longer waits for the object scanning to complete,
allowing the corresponding memory block to be freed or unmapped (in the
case of vfree()). This leads to kmemleak_scan potentially triggering a
page fault.
This patch separates the kmemleak_free() enabling/disabling from the
overall kmemleak_enabled nob so that we can defer the disabling of the
object freeing tracking until the scanning thread completed. The
kmemleak_free_part() is deliberately ignored by this patch since this is
only called during boot before the scanning thread started.
Reported-by: Vignesh Radhakrishnan <vigneshr@codeaurora.org>
Tested-by: Vignesh Radhakrishnan <vigneshr@codeaurora.org>
Not all kmem allocations should be accounted to memcg. The following
patch gives an example when accounting of a certain type of allocations to
memcg can effectively result in a memory leak. This patch adds the
__GFP_NOACCOUNT flag which if passed to kmalloc and friends will force the
allocation to go through the root cgroup. It will be used by the next
patch.
Note, since in case of kmemleak enabled each kmalloc implies yet another
allocation from the kmemleak_object cache, we add __GFP_NOACCOUNT to
gfp_kmemleak_mask.
Alternatively, we could introduce a per kmem cache flag disabling
accounting for all allocations of a particular kind, but (a) we would not
be able to bypass accounting for kmalloc then and (b) a kmem cache with
this flag set could not be merged with a kmem cache without this flag,
which would increase the number of global caches and therefore
fragmentation even if the memory cgroup controller is not used.
Despite its generic name, currently __GFP_NOACCOUNT disables accounting
only for kmem allocations while user page allocations are always charged.
To catch abusing of this flag, a warning is issued on an attempt of
passing it to mem_cgroup_try_charge.
Signed-off-by: Vladimir Davydov <vdavydov@parallels.com>
Cc: <stable@vger.kernel.org> [4.0.x]
kmalloc internally round up allocation size, and kmemleak uses rounded up
size as object's size. This makes kasan to complain while kmemleak scans
memory or calculates of object's checksum. The simplest solution here is
to disable kasan.
Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Konstantin Serebryany <kcc@google.com>
Cc: Dmitry Chernenkov <dmitryc@google.com>
Signed-off-by: Andrey Konovalov <adech.fo@gmail.com>
Cc: Yuri Gribov <tetra2005@gmail.com>
Cc: Konstantin Khlebnikov <koct9i@gmail.com>
Cc: Sasha Levin <sasha.levin@oracle.com>
The memory allocation stack trace is not always useful for debugging a
memory leak (e.g. radix_tree_preload). This function, when called,
updates the stack trace for an already allocated object.
Signed-off-by: Jianpeng Ma <majianpeng@gmail.com>
kmem_cache_{create,destroy,shrink} need to get a stable value of
cpu/node online mask, because they init/destroy/access per-cpu/node
kmem_cache parts, which can be allocated or destroyed on cpu/mem
hotplug. To protect against cpu hotplug, these functions use
{get,put}_online_cpus. However, they do nothing to synchronize with
memory hotplug - taking the slab_mutex does not eliminate the
possibility of race as described in patch 2.
What we need there is something like get_online_cpus, but for memory.
We already have lock_memory_hotplug, which serves for the purpose, but
it's a bit of a hammer right now, because it's backed by a mutex. As a
result, it imposes some limitations to locking order, which are not
desirable, and can't be used just like get_online_cpus. That's why in
patch 1 I substitute it with get/put_online_mems, which work exactly
like get/put_online_cpus except they block not cpu, but memory hotplug.
[ v1 can be found at https://lkml.org/lkml/2014/4/6/68. I NAK'ed it by
myself, because it used an rw semaphore for get/put_online_mems,
making them dead lock prune. ]
This patch (of 2):
{un}lock_memory_hotplug, which is used to synchronize against memory
hotplug, is currently backed by a mutex, which makes it a bit of a
hammer - threads that only want to get a stable value of online nodes
mask won't be able to proceed concurrently. Also, it imposes some
strong locking ordering rules on it, which narrows down the set of its
usage scenarios.
This patch introduces get/put_online_mems, which are the same as
get/put_online_cpus, but for memory hotplug, i.e. executing a code
inside a get/put_online_mems section will guarantee a stable value of
online nodes, present pages, etc.
lock_memory_hotplug()/unlock_memory_hotplug() are removed altogether.
Cc: Tang Chen <tangchen@cn.fujitsu.com>
Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
Cc: Toshi Kani <toshi.kani@hp.com>
Cc: Xishi Qiu <qiuxishi@huawei.com>
Cc: Jiang Liu <liuj97@gmail.com>
Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Cc: Wen Congyang <wency@cn.fujitsu.com>
Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
Commit 8910ae896c8c ("kmemleak: change some global variables to int"),
in addition to the atomic -> int conversion, moved the disabling of
kmemleak_early_log to the beginning of the kmemleak_init() function,
before the full kmemleak tracing is actually enabled. In this small
window, kmem_cache_create() is called by kmemleak which triggers
additional memory allocation that are not traced. This patch restores
the original logic with kmemleak_early_log disabling when kmemleak is
fully functional.
Fixes: 8910ae896c8c (kmemleak: change some global variables to int)
Cc: Li Zefan <lizefan@huawei.com>
They don't have to be atomic_t, because they are simple boolean toggles.
Signed-off-by: Li Zefan <lizefan@huawei.com>
Remove kmemleak_padding() and kmemleak_release().
Currently if kmemleak is disabled, the kmemleak objects can never be
freed, no matter if it's disabled by a user or due to fatal errors.
Those objects can be a big waste of memory.
OBJS ACTIVE USE OBJ SIZE SLABS OBJ/SLAB CACHE SIZE NAME
1200264 1197433 99% 0.30K 46164 26 369312K kmemleak_object
With this patch, after kmemleak was disabled you can reclaim memory
with:
# echo clear > /sys/kernel/debug/kmemleak
Also inform users about this with a printk.
Currently if you stop kmemleak thread before disabling kmemleak,
kmemleak objects will be freed and so you won't be able to check
previously reported leaks.
With this patch, kmemleak objects won't be freed if there're leaks that
can be reported.
Commit 248ac0e1943a ("mm/vmalloc: remove guard page from between vmap
blocks") had the side effect of making vmap_area.va_end member point to
the next vmap_area.va_start. This was creating an artificial reference
to vmalloc'ed objects and kmemleak was rarely reporting vmalloc() leaks.
This patch marks the vmap_area containing pointers explicitly and
reduces the min ref_count to 2 as vm_struct still contains a reference
to the vmalloc'ed object. The kmemleak add_scan_area() function has
been improved to allow a SIZE_MAX argument covering the rest of the
object (for simpler calling sites).
The use of strict_strtoul() is not preferred, because strict_strtoul() is
obsolete. Thus, kstrtoul() should be used.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
I'm not sure why, but the hlist for each entry iterators were conceived
list_for_each_entry(pos, head, member)
The hlist ones were greedy and wanted an extra parameter:
hlist_for_each_entry(tpos, pos, head, member)
Why did they need an extra pos parameter? I'm not quite sure. Not only
they don't really need it, it also prevents the iterator from looking
exactly like the list iterator, which is unfortunate.
Besides the semantic patch, there was some manual work required:
- Fix up the actual hlist iterators in linux/list.h
- Fix up the declaration of other iterators based on the hlist ones.
- A very small amount of places were using the 'node' parameter, this
was modified to use 'obj->member' instead.
- Coccinelle didn't handle the hlist_for_each_entry_safe iterator
properly, so those had to be fixed up manually.
The semantic patch which is mostly the work of Peter Senna Tschudin is here:
iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host;
type T;
expression a,c,d,e;
identifier b;
statement S;
-T b;
<+... when != b
hlist_for_each_entry(a,
- b,
c, d) S
hlist_for_each_entry_continue(a,
- b,
c) S
hlist_for_each_entry_from(a,
- b,
c) S
hlist_for_each_entry_rcu(a,
- b,
c, d) S
hlist_for_each_entry_rcu_bh(a,
- b,
c, d) S
hlist_for_each_entry_continue_rcu_bh(a,
- b,
c) S
for_each_busy_worker(a, c,
- b,
d) S
ax25_uid_for_each(a,
- b,
c) S
ax25_for_each(a,
- b,
c) S
inet_bind_bucket_for_each(a,
- b,
c) S
sctp_for_each_hentry(a,
- b,
c) S
sk_for_each(a,
- b,
c) S
sk_for_each_rcu(a,
- b,
c) S
sk_for_each_from
-(a, b)
+(a)
S
+ sk_for_each_from(a) S
sk_for_each_safe(a,
- b,
c, d) S
sk_for_each_bound(a,
- b,
c) S
hlist_for_each_entry_safe(a,
- b,
c, d, e) S
hlist_for_each_entry_continue_rcu(a,
- b,
c) S
nr_neigh_for_each(a,
- b,
c) S
nr_neigh_for_each_safe(a,
- b,
c, d) S
nr_node_for_each(a,
- b,
c) S
nr_node_for_each_safe(a,
- b,
c, d) S
- for_each_gfn_sp(a, c, d, b) S
+ for_each_gfn_sp(a, c, d) S
- for_each_gfn_indirect_valid_sp(a, c, d, b) S
+ for_each_gfn_indirect_valid_sp(a, c, d) S
for_each_host(a,
- b,
c) S
for_each_host_safe(a,
- b,
c, d) S
for_each_mesh_entry(a,
- b,
c, d) S
[akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c]
[akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c]
[akpm@linux-foundation.org: checkpatch fixes]
[akpm@linux-foundation.org: fix warnings]
[akpm@linux-foudnation.org: redo intrusive kvm changes]
Tested-by: Peter Senna Tschudin <peter.senna@gmail.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Gleb Natapov <gleb@redhat.com>
Add 2 helpers (zone_end_pfn() and zone_spans_pfn()) to reduce code
duplication.
This also switches to using them in compaction (where an additional
variable needed to be renamed), page_alloc, vmstat, memory_hotplug, and
kmemleak.
Note that in compaction.c I avoid calling zone_end_pfn() repeatedly
because I expect at some point the sycronization issues with start_pfn &
spanned_pages will need fixing, either by actually using the seqlock or
clever memory barrier usage.
Signed-off-by: Cody P Schafer <cody@linux.vnet.ibm.com>
Cc: David Hansen <dave@linux.vnet.ibm.com>
Replace the obsolete simple_strtoul() with kstrtoul().
Signed-off-by: Abhijit Pawar <abhi.c.pawar@gmail.com>
kmemleak uses a tree where each node represents an allocated memory object
in order to quickly find out what object a given address is part of.
However, the objects don't overlap, so rbtrees are a better choice than
prio tree for this use. They are both faster and have lower memory
overhead.
Tested by booting a kernel with kmemleak enabled, loading the
kmemleak_test module, and looking for the expected messages.
Signed-off-by: Michel Lespinasse <walken@google.com>
Cc: Hillf Danton <dhillf@gmail.com>
Tested-by: Catalin Marinas <catalin.marinas@arm.com>
This patch replaces list_for_each_continue_rcu() with
list_for_each_entry_continue_rcu() to save a few lines
of code and allow removing list_for_each_continue_rcu().
Signed-off-by: Michael Wang <wangyun@linux.vnet.ibm.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Commit b6693005 (kmemleak: When the early log buffer is exceeded, report
the actual number) deferred the disabling of the early logging to
kmemleak_init(). However, when CONFIG_DEBUG_KMEMLEAK_DEFAULT_OFF=y, the
early logging was no longer disabled causing __init kmemleak functions
to be called even after the kernel freed the init memory. This patch
disables the early logging during kmemleak_init() if kmemleak is left
disabled.
Reported-by: Dirk Gouders <gouders@et.bocholt.fh-gelsenkirchen.de>
Tested-by: Dirk Gouders <gouders@et.bocholt.fh-gelsenkirchen.de>
Tested-by: Josh Boyer <jwboyer@gmail.com>
Kmemleak should only track valid scan areas with a non-zero size.
Otherwise, such area may reside just at the end of an object and
kmemleak would report "Adding scan area to unknown object".
Signed-off-by: Tiejun Chen <tiejun.chen@windriver.com>
Ensure that memory hotplug can co-exist with kmemleak
by taking the hotplug lock before scanning the memory
banks.
Signed-off-by: Laura Abbott <lauraa@codeaurora.org>
