path: root/mm/ksm.c
2019-12-01mm/ksm.c: don't WARN if page is still mapped in remove_stable_node()Andrey Ryabinin
commit 9a63236f1ad82d71a98aa80320b6cb618fb32f44 upstream. It's possible to hit the WARN_ON_ONCE(page_mapped(page)) in remove_stable_node() when it races with __mmput() and squeezes in between ksm_exit() and exit_mmap(). WARNING: CPU: 0 PID: 3295 at mm/ksm.c:888 remove_stable_node+0x10c/0x150 Call Trace: remove_all_stable_nodes+0x12b/0x330 run_store+0x4ef/0x7b0 kernfs_fop_write+0x200/0x420 vfs_write+0x154/0x450 ksys_write+0xf9/0x1d0 do_syscall_64+0x99/0x510 entry_SYSCALL_64_after_hwframe+0x49/0xbe Remove the warning as there is nothing scary going on. Link: http://lkml.kernel.org/r/20191119131850.5675-1-aryabinin@virtuozzo.com Fixes: cbf86cfe04a6 ("ksm: remove old stable nodes more thoroughly") Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03mm/ksm.c: ignore STABLE_FLAG of rmap_item->address in rmap_walk_ksm()Jia He
commit 1105a2fc022f3c7482e32faf516e8bc44095f778 upstream. In our armv8a server(QDF2400), I noticed lots of WARN_ON caused by PAGE_SIZE unaligned for rmap_item->address under memory pressure tests(start 20 guests and run memhog in the host). WARNING: CPU: 4 PID: 4641 at virt/kvm/arm/mmu.c:1826 kvm_age_hva_handler+0xc0/0xc8 CPU: 4 PID: 4641 Comm: memhog Tainted: G W 4.17.0-rc3+ #8 Call trace: kvm_age_hva_handler+0xc0/0xc8 handle_hva_to_gpa+0xa8/0xe0 kvm_age_hva+0x4c/0xe8 kvm_mmu_notifier_clear_flush_young+0x54/0x98 __mmu_notifier_clear_flush_young+0x6c/0xa0 page_referenced_one+0x154/0x1d8 rmap_walk_ksm+0x12c/0x1d0 rmap_walk+0x94/0xa0 page_referenced+0x194/0x1b0 shrink_page_list+0x674/0xc28 shrink_inactive_list+0x26c/0x5b8 shrink_node_memcg+0x35c/0x620 shrink_node+0x100/0x430 do_try_to_free_pages+0xe0/0x3a8 try_to_free_pages+0xe4/0x230 __alloc_pages_nodemask+0x564/0xdc0 alloc_pages_vma+0x90/0x228 do_anonymous_page+0xc8/0x4d0 __handle_mm_fault+0x4a0/0x508 handle_mm_fault+0xf8/0x1b0 do_page_fault+0x218/0x4b8 do_translation_fault+0x90/0xa0 do_mem_abort+0x68/0xf0 el0_da+0x24/0x28 In rmap_walk_ksm, the rmap_item->address might still have the STABLE_FLAG, then the start and end in handle_hva_to_gpa might not be PAGE_SIZE aligned. Thus it will cause exceptions in handle_hva_to_gpa on arm64. This patch fixes it by ignoring (not removing) the low bits of address when doing rmap_walk_ksm. IMO, it should be backported to stable tree. the storm of WARN_ONs is very easy for me to reproduce. More than that, I watched a panic (not reproducible) as follows: page:ffff7fe003742d80 count:-4871 mapcount:-2126053375 mapping: (null) index:0x0 flags: 0x1fffc00000000000() raw: 1fffc00000000000 0000000000000000 0000000000000000 ffffecf981470000 raw: dead000000000100 dead000000000200 ffff8017c001c000 0000000000000000 page dumped because: nonzero _refcount CPU: 29 PID: 18323 Comm: qemu-kvm Tainted: G W 4.14.15-5.hxt.aarch64 #1 Hardware name: <snip for confidential issues> Call trace: dump_backtrace+0x0/0x22c show_stack+0x24/0x2c dump_stack+0x8c/0xb0 bad_page+0xf4/0x154 free_pages_check_bad+0x90/0x9c free_pcppages_bulk+0x464/0x518 free_hot_cold_page+0x22c/0x300 __put_page+0x54/0x60 unmap_stage2_range+0x170/0x2b4 kvm_unmap_hva_handler+0x30/0x40 handle_hva_to_gpa+0xb0/0xec kvm_unmap_hva_range+0x5c/0xd0 I even injected a fault on purpose in kvm_unmap_hva_range by seting size=size-0x200, the call trace is similar as above. So I thought the panic is similarly caused by the root cause of WARN_ON. Andrea said: : It looks a straightforward safe fix, on x86 hva_to_gfn_memslot would : zap those bits and hide the misalignment caused by the low metadata : bits being erroneously left set in the address, but the arm code : notices when that's the last page in the memslot and the hva_end is : getting aligned and the size is below one page. : : I think the problem triggers in the addr += PAGE_SIZE of : unmap_stage2_ptes that never matches end because end is aligned but : addr is not. : : } while (pte++, addr += PAGE_SIZE, addr != end); : : x86 again only works on hva_start/hva_end after converting it to : gfn_start/end and that being in pfn units the bits are zapped before : they risk to cause trouble. Jia He said: : I've tested by myself in arm64 server (QDF2400,46 cpus,96G mem) Without : this patch, the WARN_ON is very easy for reproducing. After this patch, I : have run the same benchmarch for a whole day without any WARN_ONs Link: http://lkml.kernel.org/r/1525403506-6750-1-git-send-email-hejianet@gmail.com Signed-off-by: Jia He <jia.he@hxt-semitech.com> Reviewed-by: Andrea Arcangeli <aarcange@redhat.com> Tested-by: Jia He <hejianet@gmail.com> Cc: Suzuki K Poulose <Suzuki.Poulose@arm.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Claudio Imbrenda <imbrenda@linux.vnet.ibm.com> Cc: Arvind Yadav <arvind.yadav.cs@gmail.com> Cc: Mike Rapoport <rppt@linux.vnet.ibm.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30mm/ksm: fix interaction with THPClaudio Imbrenda
[ Upstream commit 77da2ba0648a4fd52e5ff97b8b2b8dd312aec4b0 ] This patch fixes a corner case for KSM. When two pages belong or belonged to the same transparent hugepage, and they should be merged, KSM fails to split the page, and therefore no merging happens. This bug can be reproduced by: * making sure ksm is running (in case disabling ksmtuned) * enabling transparent hugepages * allocating a THP-aligned 1-THP-sized buffer e.g. on amd64: posix_memalign(&p, 1<<21, 1<<21) * filling it with the same values e.g. memset(p, 42, 1<<21) * performing madvise to make it mergeable e.g. madvise(p, 1<<21, MADV_MERGEABLE) * waiting for KSM to perform a few scans The expected outcome is that the all the pages get merged (1 shared and the rest sharing); the actual outcome is that no pages get merged (1 unshared and the rest volatile) The reason of this behaviour is that we increase the reference count once for both pages we want to merge, but if they belong to the same hugepage (or compound page), the reference counter used in both cases is the one of the head of the compound page. This means that split_huge_page will find a value of the reference counter too high and will fail. This patch solves this problem by testing if the two pages to merge belong to the same hugepage when attempting to merge them. If so, the hugepage is split safely. This means that the hugepage is not split if not necessary. Link: http://lkml.kernel.org/r/1521548069-24758-1-git-send-email-imbrenda@linux.vnet.ibm.com Signed-off-by: Claudio Imbrenda <imbrenda@linux.vnet.ibm.com> Co-authored-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Hugh Dickins <hughd@google.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-24mm/ksm.c: fix inconsistent accounting of zero pagesClaudio Imbrenda
commit a38c015f3156895b07e71d4e4414289f8a3b2745 upstream. When using KSM with use_zero_pages, we replace anonymous pages containing only zeroes with actual zero pages, which are not anonymous. We need to do proper accounting of the mm counters, otherwise we will get wrong values in /proc and a BUG message in dmesg when tearing down the mm. Link: http://lkml.kernel.org/r/1522931274-15552-1-git-send-email-imbrenda@linux.vnet.ibm.com Fixes: e86c59b1b1 ("mm/ksm: improve deduplication of zero pages with colouring") Signed-off-by: Claudio Imbrenda <imbrenda@linux.vnet.ibm.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Hugh Dickins <hughd@google.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-03ksm: fix unlocked iteration over vmas in cmp_and_merge_page()Kirill Tkhai
In this place mm is unlocked, so vmas or list may change. Down read mmap_sem to protect them from modifications. Link: http://lkml.kernel.org/r/150512788393.10691.8868381099691121308.stgit@localhost.localdomain Fixes: e86c59b1b12d ("mm/ksm: improve deduplication of zero pages with colouring") Signed-off-by: Kirill Tkhai <ktkhai@virtuozzo.com> Acked-by: Michal Hocko <mhocko@suse.com> Reviewed-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Minchan Kim <minchan@kernel.org> Cc: zhong jiang <zhongjiang@huawei.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Claudio Imbrenda <imbrenda@linux.vnet.ibm.com> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Hugh Dickins <hughd@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-09-06mm/ksm.c: constify attribute_group structuresArvind Yadav
attribute_group are not supposed to change at runtime. All functions working with attribute_group provided by <linux/sysfs.h> work with const attribute_group. So mark the non-const structs as const. Link: http://lkml.kernel.org/r/1501157167-3706-2-git-send-email-arvind.yadav.cs@gmail.com Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-08-10mm: fix KSM data corruptionMinchan Kim
Nadav reported KSM can corrupt the user data by the TLB batching race[1]. That means data user written can be lost. Quote from Nadav Amit: "For this race we need 4 CPUs: CPU0: Caches a writable and dirty PTE entry, and uses the stale value for write later. CPU1: Runs madvise_free on the range that includes the PTE. It would clear the dirty-bit. It batches TLB flushes. CPU2: Writes 4 to /proc/PID/clear_refs , clearing the PTEs soft-dirty. We care about the fact that it clears the PTE write-bit, and of course, batches TLB flushes. CPU3: Runs KSM. Our purpose is to pass the following test in write_protect_page(): if (pte_write(*pvmw.pte) || pte_dirty(*pvmw.pte) || (pte_protnone(*pvmw.pte) && pte_savedwrite(*pvmw.pte))) Since it will avoid TLB flush. And we want to do it while the PTE is stale. Later, and before replacing the page, we would be able to change the page. Note that all the operations the CPU1-3 perform canhappen in parallel since they only acquire mmap_sem for read. We start with two identical pages. Everything below regards the same page/PTE. CPU0 CPU1 CPU2 CPU3 ---- ---- ---- ---- Write the same value on page [cache PTE as dirty in TLB] MADV_FREE pte_mkclean() 4 > clear_refs pte_wrprotect() write_protect_page() [ success, no flush ] pages_indentical() [ ok ] Write to page different value [Ok, using stale PTE] replace_page() Later, CPU1, CPU2 and CPU3 would flush the TLB, but that is too late. CPU0 already wrote on the page, but KSM ignored this write, and it got lost" In above scenario, MADV_FREE is fixed by changing TLB batching API including [set|clear]_tlb_flush_pending. Remained thing is soft-dirty part. This patch changes soft-dirty uses TLB batching API instead of flush_tlb_mm and KSM checks pending TLB flush by using mm_tlb_flush_pending so that it will flush TLB to avoid data lost if there are other parallel threads pending TLB flush. [1] http://lkml.kernel.org/r/BD3A0EBE-ECF4-41D4-87FA-C755EA9AB6BD@gmail.com Link: http://lkml.kernel.org/r/20170802000818.4760-8-namit@vmware.com Signed-off-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Nadav Amit <namit@vmware.com> Reported-by: Nadav Amit <namit@vmware.com> Tested-by: Nadav Amit <namit@vmware.com> Reviewed-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Hugh Dickins <hughd@google.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Andy Lutomirski <luto@kernel.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Nadav Amit <nadav.amit@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Russell King <linux@armlinux.org.uk> Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-07-06ksm: optimize refile of stable_node_dup at the head of the chainAndrea Arcangeli
If a candidate stable_node_dup has been found and it can accept further merges it can be refiled to the head of the list to speedup next searches without altering which dup is found and how the dups accumulate in the chain. We already refiled it back to the head in the prune_stale_stable_nodes case, but we didn't refile it if not pruning (which is more common). And we also refiled it when it was already at the head which is unnecessary (in the prune_stale_stable_nodes case, nr > 1 means there's more than one dup in the chain, it doesn't mean it's not already at the head of the chain). The stable_node_chain list is single threaded and there's no SMP locking contention so it should be faster to refile it to the head of the list also if prune_stale_stable_nodes is false. Profiling shows the refile happens 1.9% of the time when a dup is found with a max_page_sharing limit setting of 3 (with max_page_sharing of 2 the refile never happens of course as there's never space for one more merge) which is reasonably low. At higher max_page_sharing values it should be much less frequent. This is just an optimization. Link: http://lkml.kernel.org/r/20170518173721.22316-4-aarcange@redhat.com Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Evgheni Dereveanchin <ederevea@redhat.com> Cc: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Petr Holasek <pholasek@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Davidlohr Bueso <dave@stgolabs.net> Cc: Gavin Guo <gavin.guo@canonical.com> Cc: Jay Vosburgh <jay.vosburgh@canonical.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-07-06ksm: swap the two output parameters of chain/chain_pruneAndrea Arcangeli
Some static checker complains if chain/chain_prune returns a potentially stale pointer. There are two output parameters to chain/chain_prune, one is tree_page the other is stable_node_dup. Like in get_ksm_page the caller has to check tree_page is NULL before touching the stable_node. Similarly in chain/chain_prune the caller has to check tree_page before touching the stable_node_dup returned or the original stable_node passed as parameter. Because the tree_page is never returned as a stale pointer, it may be more intuitive to return tree_page and to pass stable_node_dup for reference instead of the reverse. This patch purely swaps the two output parameters of chain/chain_prune as a cleanup for the static checker and to mimic the get_ksm_page behavior more closely. There's no change to the caller at all except the swap, it's purely a cleanup and it is a noop from the caller point of view. Link: http://lkml.kernel.org/r/20170518173721.22316-3-aarcange@redhat.com Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Tested-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: Evgheni Dereveanchin <ederevea@redhat.com> Cc: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Petr Holasek <pholasek@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Davidlohr Bueso <dave@stgolabs.net> Cc: Gavin Guo <gavin.guo@canonical.com> Cc: Jay Vosburgh <jay.vosburgh@canonical.com> Cc: Mel Gorman <mgorman@techsingularity.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-07-06ksm: cleanup stable_node chain collapse caseAndrea Arcangeli
Patch series "KSMscale cleanup/optimizations". There are no fixes here it's just minor cleanups and optimizations. 1/3 removes makes the "fix" for the stale stable_node fall in the standard case without introducing new cases. Setting stable_node to NULL was marginally safer, but stale pointer is still wiped from the caller, this looks cleaner. 2/3 should fix the false positive from Dan's static checker. 3/3 is a microoptimization to apply the the refile of future merge candidate dups at the head of the chain in all cases and to skip it in one case where we did it and but it was a noop (to avoid checking if it was already at the head but now we've to check it anyway so it got optimized away). This patch (of 3): When the stable_node chain is collapsed we can as well set the caller stable_node to match the returned stable_node_dup in chain_prune(). This way the collapse case becomes indistinguishable from the regular stable_node case and we can remove two branches from the KSM page migration handling slow paths. While it was all correct this looks cleaner (and faster) as the caller has to deal with fewer special cases. Link: http://lkml.kernel.org/r/20170518173721.22316-2-aarcange@redhat.com Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Evgheni Dereveanchin <ederevea@redhat.com> Cc: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Petr Holasek <pholasek@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Davidlohr Bueso <dave@stgolabs.net> Cc: Gavin Guo <gavin.guo@canonical.com> Cc: Jay Vosburgh <jay.vosburgh@canonical.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-07-06ksm: fix use after free with merge_across_nodes = 0Andrea Arcangeli
If merge_across_nodes was manually set to 0 (not the default value) by the admin or a tuned profile on NUMA systems triggering cross-NODE page migrations, a stable_node use after free could materialize. If the chain is collapsed stable_node would point to the old chain that was already freed. stable_node_dup would be the stable_node dup now converted to a regular stable_node and indexed in the rbtree in replacement of the freed stable_node chain (not anymore a dup). This special case where the chain is collapsed in the NUMA replacement path, is now detected by setting stable_node to NULL by the chain_prune callee if it decides to collapse the chain. This tells the NUMA replacement code that even if stable_node and stable_node_dup are different, this is not a chain if stable_node is NULL, as the stable_node_dup was converted to a regular stable_node and the chain was collapsed. It is generally safer for the callee to force the caller stable_node to NULL the moment it become stale so any other mistake like this would result in an instant Oops easier to debug than an use after free. Otherwise the replace logic would act like if stable_node was a valid chain, when in fact it was freed. Notably stable_node_chain_add_dup(page_node, stable_node) would run on a stable stable_node. Andrey Ryabinin found the source of the use after free in chain_prune(). Link: http://lkml.kernel.org/r/20170512193805.8807-2-aarcange@redhat.com Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Reported-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Reported-by: Evgheni Dereveanchin <ederevea@redhat.com> Tested-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Petr Holasek <pholasek@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Davidlohr Bueso <dave@stgolabs.net> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Gavin Guo <gavin.guo@canonical.com> Cc: Jay Vosburgh <jay.vosburgh@canonical.com> Cc: Mel Gorman <mgorman@techsingularity.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-07-06ksm: introduce ksm_max_page_sharing per page deduplication limitAndrea Arcangeli
Without a max deduplication limit for each KSM page, the list of the rmap_items associated to each stable_node can grow infinitely large. During the rmap walk each entry can take up to ~10usec to process because of IPIs for the TLB flushing (both for the primary MMU and the secondary MMUs with the MMU notifier). With only 16GB of address space shared in the same KSM page, that would amount to dozens of seconds of kernel runtime. A ~256 max deduplication factor will reduce the latencies of the rmap walks on KSM pages to order of a few msec. Just doing the cond_resched() during the rmap walks is not enough, the list size must have a limit too, otherwise the caller could get blocked in (schedule friendly) kernel computations for seconds, unexpectedly. There's room for optimization to significantly reduce the IPI delivery cost during the page_referenced(), but at least for page_migration in the KSM case (used by hard NUMA bindings, compaction and NUMA balancing) it may be inevitable to send lots of IPIs if each rmap_item->mm is active on a different CPU and there are lots of CPUs. Even if we ignore the IPI delivery cost, we've still to walk the whole KSM rmap list, so we can't allow millions or billions (ulimited) number of entries in the KSM stable_node rmap_item lists. The limit is enforced efficiently by adding a second dimension to the stable rbtree. So there are three types of stable_nodes: the regular ones (identical as before, living in the first flat dimension of the stable rbtree), the "chains" and the "dups". Every "chain" and all "dups" linked into a "chain" enforce the invariant that they represent the same write protected memory content, even if each "dup" will be pointed by a different KSM page copy of that content. This way the stable rbtree lookup computational complexity is unaffected if compared to an unlimited max_sharing_limit. It is still enforced that there cannot be KSM page content duplicates in the stable rbtree itself. Adding the second dimension to the stable rbtree only after the max_page_sharing limit hits, provides for a zero memory footprint increase on 64bit archs. The memory overhead of the per-KSM page stable_tree and per virtual mapping rmap_item is unchanged. Only after the max_page_sharing limit hits, we need to allocate a stable_tree "chain" and rb_replace() the "regular" stable_node with the newly allocated stable_node "chain". After that we simply add the "regular" stable_node to the chain as a stable_node "dup" by linking hlist_dup in the stable_node_chain->hlist. This way the "regular" (flat) stable_node is converted to a stable_node "dup" living in the second dimension of the stable rbtree. During stable rbtree lookups the stable_node "chain" is identified as stable_node->rmap_hlist_len == STABLE_NODE_CHAIN (aka is_stable_node_chain()). When dropping stable_nodes, the stable_node "dup" is identified as stable_node->head == STABLE_NODE_DUP_HEAD (aka is_stable_node_dup()). The STABLE_NODE_DUP_HEAD must be an unique valid pointer never used elsewhere in any stable_node->head/node to avoid a clashes with the stable_node->node.rb_parent_color pointer, and different from &migrate_nodes. So the second field of &migrate_nodes is picked and verified as always safe with a BUILD_BUG_ON in case the list_head implementation changes in the future. The STABLE_NODE_DUP is picked as a random negative value in stable_node->rmap_hlist_len. rmap_hlist_len cannot become negative when it's a "regular" stable_node or a stable_node "dup". The stable_node_chain->nid is irrelevant. The stable_node_chain->kpfn is aliased in a union with a time field used to rate limit the stable_node_chain->hlist prunes. The garbage collection of the stable_node_chain happens lazily during stable rbtree lookups (as for all other kind of stable_nodes), or while disabling KSM with "echo 2 >/sys/kernel/mm/ksm/run" while collecting the entire stable rbtree. While the "regular" stable_nodes and the stable_node "dups" must wait for their underlying tree_page to be freed before they can be freed themselves, the stable_node "chains" can be freed immediately if the stable_node->hlist turns empty. This is because the "chains" are never pointed by any page->mapping and they're effectively stable rbtree KSM self contained metadata. [akpm@linux-foundation.org: fix non-NUMA build] Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Tested-by: Petr Holasek <pholasek@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Davidlohr Bueso <dave@stgolabs.net> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Evgheni Dereveanchin <ederevea@redhat.com> Cc: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Gavin Guo <gavin.guo@canonical.com> Cc: Jay Vosburgh <jay.vosburgh@canonical.com> Cc: Mel Gorman <mgorman@techsingularity.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-06-02ksm: prevent crash after write_protect_page failsAndrea Arcangeli
"err" needs to be left set to -EFAULT if split_huge_page succeeds. Otherwise if "err" gets clobbered with zero and write_protect_page fails, try_to_merge_one_page() will succeed instead of returning -EFAULT and then try_to_merge_with_ksm_page() will continue thinking kpage is a PageKsm when in fact it's still an anonymous page. Eventually it'll crash in page_add_anon_rmap. This has been reproduced on Fedora25 kernel but I can reproduce with upstream too. The bug was introduced in commit f765f540598a ("ksm: prepare to new THP semantics") introduced in v4.5. page:fffff67546ce1cc0 count:4 mapcount:2 mapping:ffffa094551e36e1 index:0x7f0f46673 flags: 0x2ffffc0004007c(referenced|uptodate|dirty|lru|active|swapbacked) page dumped because: VM_BUG_ON_PAGE(!PageLocked(page)) page->mem_cgroup:ffffa09674bf0000 ------------[ cut here ]------------ kernel BUG at mm/rmap.c:1222! CPU: 1 PID: 76 Comm: ksmd Not tainted 4.9.3-200.fc25.x86_64 #1 RIP: do_page_add_anon_rmap+0x1c4/0x240 Call Trace: page_add_anon_rmap+0x18/0x20 try_to_merge_with_ksm_page+0x50b/0x780 ksm_scan_thread+0x1211/0x1410 ? prepare_to_wait_event+0x100/0x100 ? try_to_merge_with_ksm_page+0x780/0x780 kthread+0xd9/0xf0 ? kthread_park+0x60/0x60 ret_from_fork+0x25/0x30 Fixes: f765f54059 ("ksm: prepare to new THP semantics") Link: http://lkml.kernel.org/r/20170513131040.21732-1-aarcange@redhat.com Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Reported-by: Federico Simoncelli <fsimonce@redhat.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Hugh Dickins <hughd@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-05-03mm: make rmap_one boolean functionMinchan Kim
rmap_one's return value controls whether rmap_work should contine to scan other ptes or not so it's target for changing to boolean. Return true if the scan should be continued. Otherwise, return false to stop the scanning. This patch makes rmap_one's return value to boolean. Link: http://lkml.kernel.org/r/1489555493-14659-10-git-send-email-minchan@kernel.org Signed-off-by: Minchan Kim <minchan@kernel.org> Cc: Anshuman Khandual <khandual@linux.vnet.ibm.com> Cc: Hillf Danton <hillf.zj@alibaba-inc.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-05-03mm: make rmap_walk() return voidMinchan Kim
There is no user of the return value from rmap_walk() and friends so this patch makes them void-returning functions. Link: http://lkml.kernel.org/r/1489555493-14659-9-git-send-email-minchan@kernel.org Signed-off-by: Minchan Kim <minchan@kernel.org> Cc: Anshuman Khandual <khandual@linux.vnet.ibm.com> Cc: Hillf Danton <hillf.zj@alibaba-inc.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-03-02sched/headers: Prepare for new header dependencies before moving code to ↵Ingo Molnar
<linux/sched/coredump.h> We are going to split <linux/sched/coredump.h> out of <linux/sched.h>, which will have to be picked up from other headers and a couple of .c files. Create a trivial placeholder <linux/sched/coredump.h> file that just maps to <linux/sched.h> to make this patch obviously correct and bisectable. Include the new header in the files that are going to need it. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
<linux/sched/mm.h> We are going to split <linux/sched/mm.h> out of <linux/sched.h>, which will have to be picked up from other headers and a couple of .c files. Create a trivial placeholder <linux/sched/mm.h> file that just maps to <linux/sched.h> to make this patch obviously correct and bisectable. The APIs that are going to be moved first are: mm_alloc() __mmdrop() mmdrop() mmdrop_async_fn() mmdrop_async() mmget_not_zero() mmput() mmput_async() get_task_mm() mm_access() mm_release() Include the new header in the files that are going to need it. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-02-27mm: add new mmgrab() helperVegard Nossum
Apart from adding the helper function itself, the rest of the kernel is converted mechanically using: git grep -l 'atomic_inc.*mm_count' | xargs sed -i 's/atomic_inc(&\(.*\)->mm_count);/mmgrab\(\1\);/' git grep -l 'atomic_inc.*mm_count' | xargs sed -i 's/atomic_inc(&\(.*\)\.mm_count);/mmgrab\(\&\1\);/' This is needed for a later patch that hooks into the helper, but might be a worthwhile cleanup on its own. (Michal Hocko provided most of the kerneldoc comment.) Link: http://lkml.kernel.org/r/20161218123229.22952-1-vegard.nossum@oracle.com Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-02-24mm/ksm: handle protnone saved writes when making page write protectAneesh Kumar K.V
Without this KSM will consider the page write protected, but a numa fault can later mark the page writable. This can result in memory corruption. Link: http://lkml.kernel.org/r/1487498625-10891-3-git-send-email-aneesh.kumar@linux.vnet.ibm.com Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-02-24mm, ksm: convert write_protect_page() to use page_vma_mapped_walk()Kirill A. Shutemov
For consistency, it worth converting all page_check_address() to page_vma_mapped_walk(), so we could drop the former. Link: http://lkml.kernel.org/r/20170129173858.45174-9-kirill.shutemov@linux.intel.com Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Hillf Danton <hillf.zj@alibaba-inc.com> Cc: Hugh Dickins <hughd@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Vladimir Davydov <vdavydov.dev@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-02-24mm/ksm: improve deduplication of zero pages with colouringClaudio Imbrenda
Some architectures have a set of zero pages (coloured zero pages) instead of only one zero page, in order to improve the cache performance. In those cases, the kernel samepage merger (KSM) would merge all the allocated pages that happen to be filled with zeroes to the same deduplicated page, thus losing all the advantages of coloured zero pages. This behaviour is noticeable when a process accesses large arrays of allocated pages containing zeroes. A test I conducted on s390 shows that there is a speed penalty when KSM merges such pages, compared to not merging them or using actual zero pages from the start without breaking the COW. This patch fixes this behaviour. When coloured zero pages are present, the checksum of a zero page is calculated during initialisation, and compared with the checksum of the current canditate during merging. In case of a match, the normal merging routine is used to merge the page with the correct coloured zero page, which ensures the candidate page is checked to be equal to the target zero page. A sysfs entry is also added to toggle this behaviour, since it can potentially introduce performance regressions, especially on architectures without coloured zero pages. The default value is disabled, for backwards compatibility. With this patch, the performance with KSM is the same as with non COW-broken actual zero pages, which is also the same as without KSM. [akpm@linux-foundation.org: make zero_checksum and ksm_use_zero_pages __read_mostly, per Andrea] [imbrenda@linux.vnet.ibm.com: documentation for coloured zero pages deduplication] Link: http://lkml.kernel.org/r/1484927522-1964-1-git-send-email-imbrenda@linux.vnet.ibm.com Link: http://lkml.kernel.org/r/1484850953-23941-1-git-send-email-imbrenda@linux.vnet.ibm.com Signed-off-by: Claudio Imbrenda <imbrenda@linux.vnet.ibm.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Hugh Dickins <hughd@google.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-07mm,ksm: add __GFP_HIGH to the allocation in alloc_stable_node()zhong jiang
According to Hugh's suggestion, alloc_stable_node() with GFP_KERNEL can in rare cases cause a hung task warning. At present, if alloc_stable_node() allocation fails, two break_cows may want to allocate a couple of pages, and the issue will come up when free memory is under pressure. We fix it by adding __GFP_HIGH to GFP, to grant access to memory reserves, increasing the likelihood of allocation success. [akpm@linux-foundation.org: tweak comment] Link: http://lkml.kernel.org/r/1474354484-58233-1-git-send-email-zhongjiang@huawei.com Signed-off-by: zhong jiang <zhongjiang@huawei.com> Suggested-by: Hugh Dickins <hughd@google.com> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-09-28mm,ksm: fix endless looping in allocating memory when ksm enablezhong jiang
I hit the following hung task when runing a OOM LTP test case with 4.1 kernel. Call trace: [<ffffffc000086a88>] __switch_to+0x74/0x8c [<ffffffc000a1bae0>] __schedule+0x23c/0x7bc [<ffffffc000a1c09c>] schedule+0x3c/0x94 [<ffffffc000a1eb84>] rwsem_down_write_failed+0x214/0x350 [<ffffffc000a1e32c>] down_write+0x64/0x80 [<ffffffc00021f794>] __ksm_exit+0x90/0x19c [<ffffffc0000be650>] mmput+0x118/0x11c [<ffffffc0000c3ec4>] do_exit+0x2dc/0xa74 [<ffffffc0000c46f8>] do_group_exit+0x4c/0xe4 [<ffffffc0000d0f34>] get_signal+0x444/0x5e0 [<ffffffc000089fcc>] do_signal+0x1d8/0x450 [<ffffffc00008a35c>] do_notify_resume+0x70/0x78 The oom victim cannot terminate because it needs to take mmap_sem for write while the lock is held by ksmd for read which loops in the page allocator ksm_do_scan scan_get_next_rmap_item down_read get_next_rmap_item alloc_rmap_item #ksmd will loop permanently. There is no way forward because the oom victim cannot release any memory in 4.1 based kernel. Since 4.6 we have the oom reaper which would solve this problem because it would release the memory asynchronously. Nevertheless we can relax alloc_rmap_item requirements and use __GFP_NORETRY because the allocation failure is acceptable as ksm_do_scan would just retry later after the lock got dropped. Such a patch would be also easy to backport to older stable kernels which do not have oom_reaper. While we are at it add GFP_NOWARN so the admin doesn't have to be alarmed by the allocation failure. Link: http://lkml.kernel.org/r/1474165570-44398-1-git-send-email-zhongjiang@huawei.com Signed-off-by: zhong jiang <zhongjiang@huawei.com> Suggested-by: Hugh Dickins <hughd@google.com> Suggested-by: Michal Hocko <mhocko@suse.cz> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26mm: do not pass mm_struct into handle_mm_faultKirill A. Shutemov
We always have vma->vm_mm around. Link: http://lkml.kernel.org/r/1466021202-61880-8-git-send-email-kirill.shutemov@linux.intel.com Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26mm: migrate: support non-lru movable page migrationMinchan Kim
We have allowed migration for only LRU pages until now and it was enough to make high-order pages. But recently, embedded system(e.g., webOS, android) uses lots of non-movable pages(e.g., zram, GPU memory) so we have seen several reports about troubles of small high-order allocation. For fixing the problem, there were several efforts (e,g,. enhance compaction algorithm, SLUB fallback to 0-order page, reserved memory, vmalloc and so on) but if there are lots of non-movable pages in system, their solutions are void in the long run. So, this patch is to support facility to change non-movable pages with movable. For the feature, this patch introduces functions related to migration to address_space_operations as well as some page flags. If a driver want to make own pages movable, it should define three functions which are function pointers of struct address_space_operations. 1. bool (*isolate_page) (struct page *page, isolate_mode_t mode); What VM expects on isolate_page function of driver is to return *true* if driver isolates page successfully. On returing true, VM marks the page as PG_isolated so concurrent isolation in several CPUs skip the page for isolation. If a driver cannot isolate the page, it should return *false*. Once page is successfully isolated, VM uses page.lru fields so driver shouldn't expect to preserve values in that fields. 2. int (*migratepage) (struct address_space *mapping, struct page *newpage, struct page *oldpage, enum migrate_mode); After isolation, VM calls migratepage of driver with isolated page. The function of migratepage is to move content of the old page to new page and set up fields of struct page newpage. Keep in mind that you should indicate to the VM the oldpage is no longer movable via __ClearPageMovable() under page_lock if you migrated the oldpage successfully and returns 0. If driver cannot migrate the page at the moment, driver can return -EAGAIN. On -EAGAIN, VM will retry page migration in a short time because VM interprets -EAGAIN as "temporal migration failure". On returning any error except -EAGAIN, VM will give up the page migration without retrying in this time. Driver shouldn't touch page.lru field VM using in the functions. 3. void (*putback_page)(struct page *); If migration fails on isolated page, VM should return the isolated page to the driver so VM calls driver's putback_page with migration failed page. In this function, driver should put the isolated page back to the own data structure. 4. non-lru movable page flags There are two page flags for supporting non-lru movable page. * PG_movable Driver should use the below function to make page movable under page_lock. void __SetPageMovable(struct page *page, struct address_space *mapping) It needs argument of address_space for registering migration family functions which will be called by VM. Exactly speaking, PG_movable is not a real flag of struct page. Rather than, VM reuses page->mapping's lower bits to represent it. #define PAGE_MAPPING_MOVABLE 0x2 page->mapping = page->mapping | PAGE_MAPPING_MOVABLE; so driver shouldn't access page->mapping directly. Instead, driver should use page_mapping which mask off the low two bits of page->mapping so it can get right struct address_space. For testing of non-lru movable page, VM supports __PageMovable function. However, it doesn't guarantee to identify non-lru movable page because page->mapping field is unified with other variables in struct page. As well, if driver releases the page after isolation by VM, page->mapping doesn't have stable value although it has PAGE_MAPPING_MOVABLE (Look at __ClearPageMovable). But __PageMovable is cheap to catch whether page is LRU or non-lru movable once the page has been isolated. Because LRU pages never can have PAGE_MAPPING_MOVABLE in page->mapping. It is also good for just peeking to test non-lru movable pages before more expensive checking with lock_page in pfn scanning to select victim. For guaranteeing non-lru movable page, VM provides PageMovable function. Unlike __PageMovable, PageMovable functions validates page->mapping and mapping->a_ops->isolate_page under lock_page. The lock_page prevents sudden destroying of page->mapping. Driver using __SetPageMovable should clear the flag via __ClearMovablePage under page_lock before the releasing the page. * PG_isolated To prevent concurrent isolation among several CPUs, VM marks isolated page as PG_isolated under lock_page. So if a CPU encounters PG_isolated non-lru movable page, it can skip it. Driver doesn't need to manipulate the flag because VM will set/clear it automatically. Keep in mind that if driver sees PG_isolated page, it means the page have been isolated by VM so it shouldn't touch page.lru field. PG_isolated is alias with PG_reclaim flag so driver shouldn't use the flag for own purpose. [opensource.ganesh@gmail.com: mm/compaction: remove local variable is_lru] Link: http://lkml.kernel.org/r/20160618014841.GA7422@leo-test Link: http://lkml.kernel.org/r/1464736881-24886-3-git-send-email-minchan@kernel.org Signed-off-by: Gioh Kim <gi-oh.kim@profitbricks.com> Signed-off-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Ganesh Mahendran <opensource.ganesh@gmail.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Hugh Dickins <hughd@google.com> Cc: Rafael Aquini <aquini@redhat.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: John Einar Reitan <john.reitan@foss.arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-12ksm: fix conflict between mmput and scan_get_next_rmap_itemZhou Chengming
A concurrency issue about KSM in the function scan_get_next_rmap_item. task A (ksmd): |task B (the mm's task): | mm = slot->mm; | down_read(&mm->mmap_sem); | | ... | | spin_lock(&ksm_mmlist_lock); | | ksm_scan.mm_slot go to the next slot; | | spin_unlock(&ksm_mmlist_lock); | |mmput() -> | ksm_exit(): | |spin_lock(&ksm_mmlist_lock); |if (mm_slot && ksm_scan.mm_slot != mm_slot) { | if (!mm_slot->rmap_list) { | easy_to_free = 1; | ... | |if (easy_to_free) { | mmdrop(mm); | ... | |So this mm_struct may be freed in the mmput(). | up_read(&mm->mmap_sem); | As we can see above, the ksmd thread may access a mm_struct that already been freed to the kmem_cache. Suppose a fork will get this mm_struct from the kmem_cache, the ksmd thread then call up_read(&mm->mmap_sem), will cause mmap_sem.count to become -1. As suggested by Andrea Arcangeli, unmerge_and_remove_all_rmap_items has the same SMP race condition, so fix it too. My prev fix in function scan_get_next_rmap_item will introduce a different SMP race condition, so just invert the up_read/spin_unlock order as Andrea Arcangeli said. Link: http://lkml.kernel.org/r/1462708815-31301-1-git-send-email-zhouchengming1@huawei.com Signed-off-by: Zhou Chengming <zhouchengming1@huawei.com> Suggested-by: Andrea Arcangeli <aarcange@redhat.com> Reviewed-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Geliang Tang <geliangtang@163.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Hanjun Guo <guohanjun@huawei.com> Cc: Ding Tianhong <dingtianhong@huawei.com> Cc: Li Bin <huawei.libin@huawei.com> Cc: Zhen Lei <thunder.leizhen@huawei.com> Cc: Xishi Qiu <qiuxishi@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-02-18mm/core: Do not enforce PKEY permissions on remote mm accessDave Hansen
We try to enforce protection keys in software the same way that we do in hardware. (See long example below). But, we only want to do this when accessing our *own* process's memory. If GDB set PKRU[6].AD=1 (disable access to PKEY 6), then tried to PTRACE_POKE a target process which just happened to have some mprotect_pkey(pkey=6) memory, we do *not* want to deny the debugger access to that memory. PKRU is fundamentally a thread-local structure and we do not want to enforce it on access to _another_ thread's data. This gets especially tricky when we have workqueues or other delayed-work mechanisms that might run in a random process's context. We can check that we only enforce pkeys when operating on our *own* mm, but delayed work gets performed when a random user context is active. We might end up with a situation where a delayed-work gup fails when running randomly under its "own" task but succeeds when running under another process. We want to avoid that. To avoid that, we use the new GUP flag: FOLL_REMOTE and add a fault flag: FAULT_FLAG_REMOTE. They indicate that we are walking an mm which is not guranteed to be the same as current->mm and should not be subject to protection key enforcement. Thanks to Jerome Glisse for pointing out this scenario. Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Cc: Alexey Kardashevskiy <aik@ozlabs.ru> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Andy Lutomirski <luto@kernel.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Boaz Harrosh <boaz@plexistor.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Dave Chinner <dchinner@redhat.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: David Gibson <david@gibson.dropbear.id.au> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Dominik Dingel <dingel@linux.vnet.ibm.com> Cc: Dominik Vogt <vogt@linux.vnet.ibm.com> Cc: Eric B Munson <emunson@akamai.com> Cc: Geliang Tang <geliangtang@163.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Hugh Dickins <hughd@google.com> Cc: Jan Kara <jack@suse.cz> Cc: Jason Low <jason.low2@hp.com> Cc: Jerome Marchand <jmarchan@redhat.com> Cc: Joerg Roedel <joro@8bytes.org> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Laurent Dufour <ldufour@linux.vnet.ibm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Matthew Wilcox <willy@linux.intel.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Michal Hocko <mhocko@suse.com> Cc: Mikulas Patocka <mpatocka@redhat.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Shachar Raindel <raindel@mellanox.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Xie XiuQi <xiexiuqi@huawei.com> Cc: iommu@lists.linux-foundation.org Cc: linux-arch@vger.kernel.org Cc: linux-kernel@vger.kernel.org Cc: linux-mm@kvack.org Cc: linux-s390@vger.kernel.org Cc: linuxppc-dev@lists.ozlabs.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-02-16mm/gup: Switch all callers of get_user_pages() to not pass tsk/mmDave Hansen
We will soon modify the vanilla get_user_pages() so it can no longer be used on mm/tasks other than 'current/current->mm', which is by far the most common way it is called. For now, we allow the old-style calls, but warn when they are used. (implemented in previous patch) This patch switches all callers of: get_user_pages() get_user_pages_unlocked() get_user_pages_locked() to stop passing tsk/mm so they will no longer see the warnings. Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Dave Hansen <dave@sr71.net> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: jack@suse.cz Cc: linux-mm@kvack.org Link: http://lkml.kernel.org/r/20160212210156.113E9407@viggo.jf.intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-01-15mm/ksm.c: mark stable page dirtyMinchan Kim
The MADV_FREE patchset changes page reclaim to simply free a clean anonymous page with no dirty ptes, instead of swapping it out; but KSM uses clean write-protected ptes to reference the stable ksm page. So be sure to mark that page dirty, so it's never mistakenly discarded. [hughd@google.com: adjusted comments] Signed-off-by: Minchan Kim <minchan@kernel.org> Acked-by: Hugh Dickins <hughd@google.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Cc: Shaohua Li <shli@kernel.org> Cc: <yalin.wang2010@gmail.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chen Gang <gang.chen.5i5j@gmail.com> Cc: Chris Zankel <chris@zankel.net> Cc: Daniel Micay <danielmicay@gmail.com> Cc: Darrick J. Wong <darrick.wong@oracle.com> Cc: David S. Miller <davem@davemloft.net> Cc: Helge Deller <deller@gmx.de> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Jason Evans <je@fb.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Kirill A. Shutemov <kirill@shutemov.name> Cc: Matt Turner <mattst88@gmail.com> Cc: Max Filippov <jcmvbkbc@gmail.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Mika Penttil <mika.penttila@nextfour.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Rik van Riel <riel@redhat.com> Cc: Roland Dreier <roland@kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Shaohua Li <shli@kernel.org> Cc: Will Deacon <will.deacon@arm.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-15ksm: prepare to new THP semanticsKirill A. Shutemov
We don't need special code to stabilize THP. If you've got reference to any subpage of THP it will not be split under you. New split_huge_page() also accepts tail pages: no need in special code to get reference to head page. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Tested-by: Sasha Levin <sasha.levin@oracle.com> Tested-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Jerome Marchand <jmarchan@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Steve Capper <steve.capper@linaro.org> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-15rmap: add argument to charge compound pageKirill A. Shutemov
We're going to allow mapping of individual 4k pages of THP compound page. It means we cannot rely on PageTransHuge() check to decide if map/unmap small page or THP. The patch adds new argument to rmap functions to indicate whether we want to operate on whole compound page or only the small page. [n-horiguchi@ah.jp.nec.com: fix mapcount mismatch in hugepage migration] Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Tested-by: Sasha Levin <sasha.levin@oracle.com> Tested-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Jerome Marchand <jmarchan@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Steve Capper <steve.capper@linaro.org> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-15page-flags: define PG_locked behavior on compound pagesKirill A. Shutemov
lock_page() must operate on the whole compound page. It doesn't make much sense to lock part of compound page. Change code to use head page's PG_locked, if tail page is passed. This patch also gets rid of custom helper functions -- __set_page_locked() and __clear_page_locked(). They are replaced with helpers generated by __SETPAGEFLAG/__CLEARPAGEFLAG. Tail pages to these helper would trigger VM_BUG_ON(). SLUB uses PG_locked as a bit spin locked. IIUC, tail pages should never appear there. VM_BUG_ON() is added to make sure that this assumption is correct. [akpm@linux-foundation.org: fix fs/cifs/file.c] Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Christoph Lameter <cl@linux.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Steve Capper <steve.capper@linaro.org> Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Jerome Marchand <jmarchan@redhat.com> Cc: Jérôme Glisse <jglisse@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-14mm/ksm.c: use list_for_each_entry_safeGeliang Tang
Use list_for_each_entry_safe() instead of list_for_each_safe() to simplify the code. Signed-off-by: Geliang Tang <geliangtang@163.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-05ksm: unstable_tree_search_insert error checking cleanupAndrea Arcangeli
get_mergeable_page() can only return NULL (also in case of errors) or the pinned mergeable page. It can't return an error different than NULL. This optimizes away the unnecessary error check. Add a return after the "out:" label in the callee to make it more readable. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: Petr Holasek <pholasek@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-05ksm: use find_mergeable_vma in try_to_merge_with_ksm_pageAndrea Arcangeli
Doing the VM_MERGEABLE check after the page == kpage check won't provide any meaningful benefit. The !vma->anon_vma check of find_mergeable_vma is the only superfluous bit in using find_mergeable_vma because the !PageAnon check of try_to_merge_one_page() implicitly checks for that, but it still looks cleaner to share the same find_mergeable_vma(). Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: Petr Holasek <pholasek@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-05ksm: use the helper method to do the hlist_empty checkAndrea Arcangeli
This just uses the helper function to cleanup the assumption on the hlist_node internals. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: Petr Holasek <pholasek@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-05ksm: don't fail stable tree lookups if walking over stale stable_nodesAndrea Arcangeli
The stable_nodes can become stale at any time if the underlying pages gets freed. The stable_node gets collected and removed from the stable rbtree if that is detected during the rbtree lookups. Don't fail the lookup if running into stale stable_nodes, just restart the lookup after collecting the stale stable_nodes. Otherwise the CPU spent in the preparation stage is wasted and the lookup must be repeated at the next loop potentially failing a second time in a second stale stable_node. If we don't prune aggressively we delay the merging of the unstable node candidates and at the same time we delay the freeing of the stale stable_nodes. Keeping stale stable_nodes around wastes memory and it can't provide any benefit. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: Petr Holasek <pholasek@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-05ksm: add cond_resched() to the rmap_walksAndrea Arcangeli
While at it add it to the file and anon walks too. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: Petr Holasek <pholasek@redhat.com> Acked-by: Davidlohr Bueso <dbueso@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-15mm: remove rest of ACCESS_ONCE() usagesJason Low
We converted some of the usages of ACCESS_ONCE to READ_ONCE in the mm/ tree since it doesn't work reliably on non-scalar types. This patch removes the rest of the usages of ACCESS_ONCE, and use the new READ_ONCE API for the read accesses. This makes things cleaner, instead of using separate/multiple sets of APIs. Signed-off-by: Jason Low <jason.low2@hp.com> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Davidlohr Bueso <dave@stgolabs.net> Acked-by: Rik van Riel <riel@redhat.com> Reviewed-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-10mm: remove rest usage of VM_NONLINEAR and pte_file()Kirill A. Shutemov
One bit in ->vm_flags is unused now! Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Dan Carpenter <dan.carpenter@oracle.com> Cc: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-01-29vm: add VM_FAULT_SIGSEGV handling supportLinus Torvalds
The core VM already knows about VM_FAULT_SIGBUS, but cannot return a "you should SIGSEGV" error, because the SIGSEGV case was generally handled by the caller - usually the architecture fault handler. That results in lots of duplication - all the architecture fault handlers end up doing very similar "look up vma, check permissions, do retries etc" - but it generally works. However, there are cases where the VM actually wants to SIGSEGV, and applications _expect_ SIGSEGV. In particular, when accessing the stack guard page, libsigsegv expects a SIGSEGV. And it usually got one, because the stack growth is handled by that duplicated architecture fault handler. However, when the generic VM layer started propagating the error return from the stack expansion in commit fee7e49d4514 ("mm: propagate error from stack expansion even for guard page"), that now exposed the existing VM_FAULT_SIGBUS result to user space. And user space really expected SIGSEGV, not SIGBUS. To fix that case, we need to add a VM_FAULT_SIGSEGV, and teach all those duplicate architecture fault handlers about it. They all already have the code to handle SIGSEGV, so it's about just tying that new return value to the existing code, but it's all a bit annoying. This is the mindless minimal patch to do this. A more extensive patch would be to try to gather up the mostly shared fault handling logic into one generic helper routine, and long-term we really should do that cleanup. Just from this patch, you can generally see that most architectures just copied (directly or indirectly) the old x86 way of doing things, but in the meantime that original x86 model has been improved to hold the VM semaphore for shorter times etc and to handle VM_FAULT_RETRY and other "newer" things, so it would be a good idea to bring all those improvements to the generic case and teach other architectures about them too. Reported-and-tested-by: Takashi Iwai <tiwai@suse.de> Tested-by: Jan Engelhardt <jengelh@inai.de> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> # "s390 still compiles and boots" Cc: linux-arch@vger.kernel.org Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-13mmu_notifier: call mmu_notifier_invalidate_range() from VMMJoerg Roedel
Add calls to the new mmu_notifier_invalidate_range() function to all places in the VMM that need it. Signed-off-by: Joerg Roedel <jroedel@suse.de> Reviewed-by: Andrea Arcangeli <aarcange@redhat.com> Reviewed-by: Jérôme Glisse <jglisse@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Rik van Riel <riel@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Johannes Weiner <jweiner@redhat.com> Cc: Jay Cornwall <Jay.Cornwall@amd.com> Cc: Oded Gabbay <Oded.Gabbay@amd.com> Cc: Suravee Suthikulpanit <Suravee.Suthikulpanit@amd.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Oded Gabbay <oded.gabbay@amd.com>
2014-10-09mm: ksm use pr_err instead of printkPaul McQuade
WARNING: Prefer: pr_err(... to printk(KERN_ERR ... [akpm@linux-foundation.org: remove KERN_ERR] Signed-off-by: Paul McQuade <paulmcquad@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-07-16sched: Remove proliferation of wait_on_bit() action functionsNeilBrown
The current "wait_on_bit" interface requires an 'action' function to be provided which does the actual waiting. There are over 20 such functions, many of them identical. Most cases can be satisfied by one of just two functions, one which uses io_schedule() and one which just uses schedule(). So: Rename wait_on_bit and wait_on_bit_lock to wait_on_bit_action and wait_on_bit_lock_action to make it explicit that they need an action function. Introduce new wait_on_bit{,_lock} and wait_on_bit{,_lock}_io which are *not* given an action function but implicitly use a standard one. The decision to error-out if a signal is pending is now made based on the 'mode' argument rather than being encoded in the action function. All instances of the old wait_on_bit and wait_on_bit_lock which can use the new version have been changed accordingly and their action functions have been discarded. wait_on_bit{_lock} does not return any specific error code in the event of a signal so the caller must check for non-zero and interpolate their own error code as appropriate. The wait_on_bit() call in __fscache_wait_on_invalidate() was ambiguous as it specified TASK_UNINTERRUPTIBLE but used fscache_wait_bit_interruptible as an action function. David Howells confirms this should be uniformly "uninterruptible" The main remaining user of wait_on_bit{,_lock}_action is NFS which needs to use a freezer-aware schedule() call. A comment in fs/gfs2/glock.c notes that having multiple 'action' functions is useful as they display differently in the 'wchan' field of 'ps'. (and /proc/$PID/wchan). As the new bit_wait{,_io} functions are tagged "__sched", they will not show up at all, but something higher in the stack. So the distinction will still be visible, only with different function names (gds2_glock_wait versus gfs2_glock_dq_wait in the gfs2/glock.c case). Since first version of this patch (against 3.15) two new action functions appeared, on in NFS and one in CIFS. CIFS also now uses an action function that makes the same freezer aware schedule call as NFS. Signed-off-by: NeilBrown <neilb@suse.de> Acked-by: David Howells <dhowells@redhat.com> (fscache, keys) Acked-by: Steven Whitehouse <swhiteho@redhat.com> (gfs2) Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Steve French <sfrench@samba.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/20140707051603.28027.72349.stgit@notabene.brown Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-06-23mm: let mm_find_pmd fix buggy race with THP faultHugh Dickins
Trinity has reported: BUG: unable to handle kernel NULL pointer dereference at 0000000000000018 IP: __lock_acquire (kernel/locking/lockdep.c:3070 (discriminator 1)) CPU: 6 PID: 16173 Comm: trinity-c364 Tainted: G W 3.15.0-rc1-next-20140415-sasha-00020-gaa90d09 #398 lock_acquire (arch/x86/include/asm/current.h:14 kernel/locking/lockdep.c:3602) _raw_spin_lock (include/linux/spinlock_api_smp.h:143 kernel/locking/spinlock.c:151) remove_migration_pte (mm/migrate.c:137) rmap_walk (mm/rmap.c:1628 mm/rmap.c:1699) remove_migration_ptes (mm/migrate.c:224) migrate_pages (mm/migrate.c:922 mm/migrate.c:960 mm/migrate.c:1126) migrate_misplaced_page (mm/migrate.c:1733) __handle_mm_fault (mm/memory.c:3762 mm/memory.c:3812 mm/memory.c:3925) handle_mm_fault (mm/memory.c:3948) __get_user_pages (mm/memory.c:1851) __mlock_vma_pages_range (mm/mlock.c:255) __mm_populate (mm/mlock.c:711) SyS_mlockall (include/linux/mm.h:1799 mm/mlock.c:817 mm/mlock.c:791) I believe this comes about because, whereas collapsing and splitting THP functions take anon_vma lock in write mode (which excludes concurrent rmap walks), faulting THP functions (write protection and misplaced NUMA) do not - and mostly they do not need to. But they do use a pmdp_clear_flush(), set_pmd_at() sequence which, for an instant (indeed, for a long instant, given the inter-CPU TLB flush in there), leaves *pmd neither present not trans_huge. Which can confuse a concurrent rmap walk, as when removing migration ptes, seen in the dumped trace. Although that rmap walk has a 4k page to insert, anon_vmas containing THPs are in no way segregated from 4k-page anon_vmas, so the 4k-intent mm_find_pmd() does need to cope with that instant when a trans_huge pmd is temporarily absent. I don't think we need strengthen the locking at the THP end: it's easily handled with an ACCESS_ONCE() before testing both conditions. And since mm_find_pmd() had only one caller who wanted a THP rather than a pmd, let's slightly repurpose it to fail when it hits a THP or non-present pmd, and open code split_huge_page_address() again. Signed-off-by: Hugh Dickins <hughd@google.com> Reported-by: Sasha Levin <sasha.levin@oracle.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Bob Liu <bob.liu@oracle.com> Cc: Christoph Lameter <cl@gentwo.org> Cc: Dave Jones <davej@redhat.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-04mm: close PageTail raceDavid Rientjes
Commit bf6bddf1924e ("mm: introduce compaction and migration for ballooned pages") introduces page_count(page) into memory compaction which dereferences page->first_page if PageTail(page). This results in a very rare NULL pointer dereference on the aforementioned page_count(page). Indeed, anything that does compound_head(), including page_count() is susceptible to racing with prep_compound_page() and seeing a NULL or dangling page->first_page pointer. This patch uses Andrea's implementation of compound_trans_head() that deals with such a race and makes it the default compound_head() implementation. This includes a read memory barrier that ensures that if PageTail(head) is true that we return a head page that is neither NULL nor dangling. The patch then adds a store memory barrier to prep_compound_page() to ensure page->first_page is set. This is the safest way to ensure we see the head page that we are expecting, PageTail(page) is already in the unlikely() path and the memory barriers are unfortunately required. Hugetlbfs is the exception, we don't enforce a store memory barrier during init since no race is possible. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Holger Kiehl <Holger.Kiehl@dwd.de> Cc: Christoph Lameter <cl@linux.com> Cc: Rafael Aquini <aquini@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Michal Hocko <mhocko@suse.cz> Cc: Mel Gorman <mgorman@suse.de> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23mm: audit/fix non-modular users of module_init in core codePaul Gortmaker
Code that is obj-y (always built-in) or dependent on a bool Kconfig (built-in or absent) can never be modular. So using module_init as an alias for __initcall can be somewhat misleading. Fix these up now, so that we can relocate module_init from init.h into module.h in the future. If we don't do this, we'd have to add module.h to obviously non-modular code, and that would be a worse thing. The audit targets the following module_init users for change: mm/ksm.c bool KSM mm/mmap.c bool MMU mm/huge_memory.c bool TRANSPARENT_HUGEPAGE mm/mmu_notifier.c bool MMU_NOTIFIER Note that direct use of __initcall is discouraged, vs. one of the priority categorized subgroups. As __initcall gets mapped onto device_initcall, our use of subsys_initcall (which makes sense for these files) will thus change this registration from level 6-device to level 4-subsys (i.e. slightly earlier). However no observable impact of that difference has been observed during testing. One might think that core_initcall (l2) or postcore_initcall (l3) would be more appropriate for anything in mm/ but if we look at some actual init functions themselves, we see things like: mm/huge_memory.c --> hugepage_init --> hugepage_init_sysfs mm/mmap.c --> init_user_reserve --> sysctl_user_reserve_kbytes mm/ksm.c --> ksm_init --> sysfs_create_group and hence the choice of subsys_initcall (l4) seems reasonable, and at the same time minimizes the risk of changing the priority too drastically all at once. We can adjust further in the future. Also, several instances of missing ";" at EOL are fixed. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23mm: dump page when hitting a VM_BUG_ON using VM_BUG_ON_PAGESasha Levin
Most of the VM_BUG_ON assertions are performed on a page. Usually, when one of these assertions fails we'll get a BUG_ON with a call stack and the registers. I've recently noticed based on the requests to add a small piece of code that dumps the page to various VM_BUG_ON sites that the page dump is quite useful to people debugging issues in mm. This patch adds a VM_BUG_ON_PAGE(cond, page) which beyond doing what VM_BUG_ON() does, also dumps the page before executing the actual BUG_ON. [akpm@linux-foundation.org: fix up includes] Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-21mm/rmap: use rmap_walk() in page_referenced()Joonsoo Kim
Now, we have an infrastructure in rmap_walk() to handle difference from variants of rmap traversing functions. So, just use it in page_referenced(). In this patch, I change following things. 1. remove some variants of rmap traversing functions. cf> page_referenced_ksm, page_referenced_anon, page_referenced_file 2. introduce new struct page_referenced_arg and pass it to page_referenced_one(), main function of rmap_walk, in order to count reference, to store vm_flags and to check finish condition. 3. mechanical change to use rmap_walk() in page_referenced(). [liwanp@linux.vnet.ibm.com: fix BUG at rmap_walk] Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Hugh Dickins <hughd@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Hillf Danton <dhillf@gmail.com> Signed-off-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-21mm/rmap: use rmap_walk() in try_to_munlock()Joonsoo Kim
Now, we have an infrastructure in rmap_walk() to handle difference from variants of rmap traversing functions. So, just use it in try_to_munlock(). In this patch, I change following things. 1. remove some variants of rmap traversing functions. cf> try_to_unmap_ksm, try_to_unmap_anon, try_to_unmap_file 2. mechanical change to use rmap_walk() in try_to_munlock(). 3. copy and paste comments. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Hugh Dickins <hughd@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Hillf Danton <dhillf@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
