path: root/mm/memory-failure.c
2009-12-16HWPOISON: add an interface to switch off/on all the page filtersHaicheng Li
In some use cases, user doesn't need extra filtering. E.g. user program can inject errors through madvise syscall to its own pages, however it might not know what the page state exactly is or which inode the page belongs to. So introduce an one-off interface "corrupt-filter-enable". Echo 0 to switch off page filters, and echo 1 to switch on the filters. [AK: changed default to 0] Signed-off-by: Haicheng Li <haicheng.li@linux.intel.com> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-12-16HWPOISON: add memory cgroup filterAndi Kleen
The hwpoison test suite need to inject hwpoison to a collection of selected task pages, and must not touch pages not owned by them and thus kill important system processes such as init. (But it's OK to mis-hwpoison free/unowned pages as well as shared clean pages. Mis-hwpoison of shared dirty pages will kill all tasks, so the test suite will target all or non of such tasks in the first place.) The memory cgroup serves this purpose well. We can put the target processes under the control of a memory cgroup, and tell the hwpoison injection code to only kill pages associated with some active memory cgroup. The prerequisite for doing hwpoison stress tests with mem_cgroup is, the mem_cgroup code tracks task pages _accurately_ (unless page is locked). Which we believe is/should be true. The benefits are simplification of hwpoison injector code. Also the mem_cgroup code will automatically be tested by hwpoison test cases. The alternative interfaces pin-pfn/unpin-pfn can also delegate the (process and page flags) filtering functions reliably to user space. However prototype implementation shows that this scheme adds more complexity than we wanted. Example test case: mkdir /cgroup/hwpoison usemem -m 100 -s 1000 & echo `jobs -p` > /cgroup/hwpoison/tasks memcg_ino=$(ls -id /cgroup/hwpoison | cut -f1 -d' ') echo $memcg_ino > /debug/hwpoison/corrupt-filter-memcg page-types -p `pidof init` --hwpoison # shall do nothing page-types -p `pidof usemem` --hwpoison # poison its pages [AK: Fix documentation] [Add fix for problem noticed by Li Zefan <lizf@cn.fujitsu.com>; dentry in the css could be NULL] CC: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> CC: Hugh Dickins <hugh.dickins@tiscali.co.uk> CC: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> CC: Balbir Singh <balbir@linux.vnet.ibm.com> CC: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> CC: Li Zefan <lizf@cn.fujitsu.com> CC: Paul Menage <menage@google.com> CC: Nick Piggin <npiggin@suse.de> CC: Andi Kleen <andi@firstfloor.org> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-12-16HWPOISON: add page flags filterWu Fengguang
When specified, only poison pages if ((page_flags & mask) == value). - corrupt-filter-flags-mask - corrupt-filter-flags-value This allows stress testing of many kinds of pages. Strictly speaking, the buddy pages requires taking zone lock, to avoid setting PG_hwpoison on a "was buddy but now allocated to someone" page. However we can just do nothing because we set PG_locked in the beginning, this prevents the page allocator from allocating it to someone. (It will BUG() on the unexpected PG_locked, which is fine for hwpoison testing.) [AK: Add select PROC_PAGE_MONITOR to satisfy dependency] CC: Nick Piggin <npiggin@suse.de> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-12-16HWPOISON: add fs/device filtersWu Fengguang
Filesystem data/metadata present the most tricky-to-isolate pages. It requires careful code review and stress testing to get them right. The fs/device filter helps to target the stress tests to some specific filesystem pages. The filter condition is block device's major/minor numbers: - corrupt-filter-dev-major - corrupt-filter-dev-minor When specified (non -1), only page cache pages that belong to that device will be poisoned. The filters are checked reliably on the locked and refcounted page. Haicheng: clear PG_hwpoison and drop bad page count if filter not OK AK: Add documentation CC: Haicheng Li <haicheng.li@intel.com> CC: Nick Piggin <npiggin@suse.de> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-12-16HWPOISON: return 0 to indicate success reliablyWu Fengguang
Return 0 to indicate success, when - action result is RECOVERED or DELAYED - no extra page reference Note that dirty swapcache pages are kept in swapcache, so can have one more reference count. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-12-16HWPOISON: make semantics of IGNORED/DELAYED clearWu Fengguang
Change semantics for - IGNORED: not handled; it may well be _unsafe_ - DELAYED: to be handled later; it is _safe_ With this change, - IGNORED/FAILED mean (maybe) Error - DELAYED/RECOVERED mean Success Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-12-16HWPOISON: Add unpoisoning supportWu Fengguang
The unpoisoning interface is useful for stress testing tools to reclaim poisoned pages (to prevent OOM) There is no hardware level unpoisioning, so this cannot be used for real memory errors, only for software injected errors. Note that it may leak pages silently - those who have been removed from LRU cache, but not isolated from page cache/swap cache at hwpoison time. Especially the stress test of dirty swap cache pages shall reboot system before exhausting memory. AK: Fix comments, add documentation, add printks, rename symbol Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-12-16HWPOISON: detect free buddy pages explicitlyWu Fengguang
Most free pages in the buddy system have no PG_buddy set. Introduce is_free_buddy_page() for detecting them reliably. CC: Nick Piggin <npiggin@suse.de> CC: Mel Gorman <mel@linux.vnet.ibm.com> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-12-16HWPOISON: remove the free buddy page handlerWu Fengguang
The buddy page has already be handled in the very beginning. So remove redundant code. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-12-16HWPOISON: introduce delete_from_lru_cache()Wu Fengguang
Introduce delete_from_lru_cache() to - clear PG_active, PG_unevictable to avoid complains at unpoison time - move the isolate_lru_page() call back to the handlers instead of the entrance of __memory_failure(), this is more hwpoison filter friendly Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-12-16HWPOISON: comment the possible set_page_dirty() raceWu Fengguang
2009-12-16HWPOISON: abort on failed unmapWu Fengguang
Don't try to isolate a still mapped page. Otherwise we will hit the BUG_ON(page_mapped(page)) in __remove_from_page_cache(). Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-12-16HWPOISON: Turn ref argument into flags argumentAndi Kleen
Now that "ref" is just a boolean turn it into a flags argument. First step is only a single flag that makes the code's intention more clear, but more may follow. Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-12-16HWPOISON: avoid grabbing the page count multiple times during madvise injectionWu Fengguang
If page is double referenced in madvise_hwpoison() and __memory_failure(), remove_mapping() will fail because it expects page_count=2. Fix it by not grabbing extra page count in __memory_failure(). Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-12-16HWPOISON: return ENXIO on invalid page numberWu Fengguang
Use a different errno than the usual EIO for invalid page numbers. This is mainly for better reporting for the injector. This also avoids calling action_result() with invalid pfn. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-12-16HWPOISON: remove the anonymous entryWu Fengguang
(PG_swapbacked && !PG_lru) pages should not happen. Better to treat them as unknown pages. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-12-16HWPOISON: Be more aggressive at freeing non LRU cachesAndi Kleen
shake_page handles more types of page caches than lru_drain_all() - per cpu page allocator pages - per CPU LRU Stops early when the page became free. Used in followon patches. Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-12-15mm: CONFIG_MMU for PG_mlockedHugh Dickins
Remove three degrees of obfuscation, left over from when we had CONFIG_UNEVICTABLE_LRU. MLOCK_PAGES is CONFIG_HAVE_MLOCKED_PAGE_BIT is CONFIG_HAVE_MLOCK is CONFIG_MMU. rmap.o (and memory-failure.o) are only built when CONFIG_MMU, so don't need such conditions at all. Somehow, I feel no compulsion to remove the CONFIG_HAVE_MLOCK* lines from 169 defconfigs: leave those to evolve in due course. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Izik Eidus <ieidus@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Nick Piggin <npiggin@suse.de> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-10-19HWPOISON: fix invalid page count in printk outputWu Fengguang
The madvise injector already holds a reference when passing in a page to the memory-failure code. The code corrects for this additional reference for its checks, but the final printk output didn't. Fix that. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-10-19HWPOISON: fix oops on ksm pagesHugh Dickins
Memory failure on a KSM page currently oopses on its NULL anon_vma in page_lock_anon_vma(): that may not be much worse than the consequence of ignoring it, but it is better to be consistent with how ZERO_PAGE and hugetlb pages and other awkward cases are treated. Just skip it. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-10-19HWPOISON: return early on non-LRU pagesWu Fengguang
Right now we have some trouble with non atomic access to page flags when locking the page. To plug this hole for now, limit error recovery to LRU pages for now. This could be better fixed by defining a suitable protocol, but let's go this simple way for now This avoids unnecessary races with __set_page_locked() and __SetPageSlab*() and maybe more non-atomic page flag operations. This loses isolated pages which are currently in page reclaim, but these are relatively limited compared to the total memory. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> [AK: new description, bug fixes, cleanups]
2009-09-16HWPOISON: The high level memory error handler in the VM v7Andi Kleen
Add the high level memory handler that poisons pages that got corrupted by hardware (typically by a two bit flip in a DIMM or a cache) on the Linux level. The goal is to prevent everyone from accessing these pages in the future. This done at the VM level by marking a page hwpoisoned and doing the appropriate action based on the type of page it is. The code that does this is portable and lives in mm/memory-failure.c To quote the overview comment: High level machine check handler. Handles pages reported by the hardware as being corrupted usually due to a 2bit ECC memory or cache failure. This focuses on pages detected as corrupted in the background. When the current CPU tries to consume corruption the currently running process can just be killed directly instead. This implies that if the error cannot be handled for some reason it's safe to just ignore it because no corruption has been consumed yet. Instead when that happens another machine check will happen. Handles page cache pages in various states. The tricky part here is that we can access any page asynchronous to other VM users, because memory failures could happen anytime and anywhere, possibly violating some of their assumptions. This is why this code has to be extremely careful. Generally it tries to use normal locking rules, as in get the standard locks, even if that means the error handling takes potentially a long time. Some of the operations here are somewhat inefficient and have non linear algorithmic complexity, because the data structures have not been optimized for this case. This is in particular the case for the mapping from a vma to a process. Since this case is expected to be rare we hope we can get away with this. There are in principle two strategies to kill processes on poison: - just unmap the data and wait for an actual reference before killing - kill as soon as corruption is detected. Both have advantages and disadvantages and should be used in different situations. Right now both are implemented and can be switched with a new sysctl vm.memory_failure_early_kill The default is early kill. The patch does some rmap data structure walking on its own to collect processes to kill. This is unusual because normally all rmap data structure knowledge is in rmap.c only. I put it here for now to keep everything together and rmap knowledge has been seeping out anyways Includes contributions from Johannes Weiner, Chris Mason, Fengguang Wu, Nick Piggin (who did a lot of great work) and others. Cc: npiggin@suse.de Cc: riel@redhat.com Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rik van Riel <riel@redhat.com> Reviewed-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com>
