commit 668f9abbd4334e6c29fa8acd71635c4f9101caa7 upstream.
Commit bf6bddf1924e ("mm: introduce compaction and migration for
ballooned pages") introduces page_count(page) into memory compaction
which dereferences page->first_page if PageTail(page).
This results in a very rare NULL pointer dereference on the
aforementioned page_count(page). Indeed, anything that does
compound_head(), including page_count() is susceptible to racing with
prep_compound_page() and seeing a NULL or dangling page->first_page
pointer.
This patch uses Andrea's implementation of compound_trans_head() that
deals with such a race and makes it the default compound_head()
implementation. This includes a read memory barrier that ensures that
if PageTail(head) is true that we return a head page that is neither
NULL nor dangling. The patch then adds a store memory barrier to
prep_compound_page() to ensure page->first_page is set.
This is the safest way to ensure we see the head page that we are
expecting, PageTail(page) is already in the unlikely() path and the
memory barriers are unfortunately required.
Hugetlbfs is the exception, we don't enforce a store memory barrier
during init since no race is possible.
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Holger Kiehl <Holger.Kiehl@dwd.de>
Cc: Christoph Lameter <cl@linux.com>
Cc: Rafael Aquini <aquini@redhat.com>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
commit 8d547ff4ac5927245e0833ac18528f939da0ee0e upstream.
mce-test detected a test failure when injecting error to a thp tail
page. This is because we take page refcount of the tail page in
madvise_hwpoison() while the fix in commit a3e0f9e47d5e
("mm/memory-failure.c: transfer page count from head page to tail page
after split thp") assumes that we always take refcount on the head page.
When a real memory error happens we take refcount on the head page where
memory_failure() is called without MF_COUNT_INCREASED set, so it seems
to me that testing memory error on thp tail page using madvise makes
little sense.
This patch cancels moving refcount in !MF_COUNT_INCREASED for valid
testing.
[akpm@linux-foundation.org: s/&&/&/]
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com>
Cc: Chen Gong <gong.chen@linux.intel.com>
commit f15bdfa802bfa5eb6b4b5a241b97ec9fa1204a35 upstream.
After a successful page migration by soft offlining, the source page is
not properly freed and it's never reusable even if we unpoison it
afterward.
This is caused by the race between freeing page and setting PG_hwpoison.
In successful soft offlining, the source page is put (and the refcount
becomes 0) by putback_lru_page() in unmap_and_move(), where it's linked
to pagevec and actual freeing back to buddy is delayed. So if
PG_hwpoison is set for the page before freeing, the freeing does not
functions as expected (in such case freeing aborts in
free_pages_prepare() check.)
This patch tries to make sure to free the source page before setting
PG_hwpoison on it. To avoid reallocating, the page keeps
MIGRATE_ISOLATE until after setting PG_hwpoison.
This patch also removes obsolete comments about "keeping elevated
refcount" because what they say is not true. Unlike memory_failure(),
soft_offline_page() uses no special page isolation code, and the
soft-offlined pages have no elevated.
Cc: Xishi Qiu <qiuxishi@huawei.com>
commit 54b9dd14d09f24927285359a227aa363ce46089e upstream.
After thp split in hwpoison_user_mappings(), we hold page lock on the
raw error page only between try_to_unmap, hence we are in danger of race
condition.
I found in the RHEL7 MCE-relay testing that we have "bad page" error
when a memory error happens on a thp tail page used by qemu-kvm:
Triggering MCE exception on CPU 10
mce: [Hardware Error]: Machine check events logged
MCE exception done on CPU 10
MCE 0x38c535: Killing qemu-kvm:8418 due to hardware memory corruption
MCE 0x38c535: dirty LRU page recovery: Recovered
qemu-kvm[8418]: segfault at 20 ip 00007ffb0f0f229a sp 00007fffd6bc5240 error 4 in qemu-kvm[7ffb0ef14000+420000]
BUG: Bad page state in process qemu-kvm pfn:38c400
page:ffffea000e310000 count:0 mapcount:0 mapping: (null) index:0x7ffae3c00
page flags: 0x2fffff0008001d(locked|referenced|uptodate|dirty|swapbacked)
Modules linked in: hwpoison_inject mce_inject vhost_net macvtap macvlan ...
CPU: 0 PID: 8418 Comm: qemu-kvm Tainted: G M -------------- 3.10.0-54.0.1.el7.mce_test_fixed.x86_64 #1
Hardware name: NEC NEC Express5800/R120b-1 [N8100-1719F]/MS-91E7-001, BIOS 4.6.3C19 02/10/2011
Call Trace:
dump_stack+0x19/0x1b
bad_page.part.59+0xcf/0xe8
free_pages_prepare+0x148/0x160
free_hot_cold_page+0x31/0x140
free_hot_cold_page_list+0x46/0xa0
release_pages+0x1c1/0x200
free_pages_and_swap_cache+0xad/0xd0
tlb_flush_mmu.part.46+0x4c/0x90
tlb_finish_mmu+0x55/0x60
exit_mmap+0xcb/0x170
mmput+0x67/0xf0
vhost_dev_cleanup+0x231/0x260 [vhost_net]
vhost_net_release+0x3f/0x90 [vhost_net]
__fput+0xe9/0x270
____fput+0xe/0x10
task_work_run+0xc4/0xe0
do_exit+0x2bb/0xa40
do_group_exit+0x3f/0xa0
get_signal_to_deliver+0x1d0/0x6e0
do_signal+0x48/0x5e0
do_notify_resume+0x71/0xc0
retint_signal+0x48/0x8c
The reason of this bug is that a page fault happens before unlocking the
head page at the end of memory_failure(). This strange page fault is
trying to access to address 0x20 and I'm not sure why qemu-kvm does
this, but anyway as a result the SIGSEGV makes qemu-kvm exit and on the
way we catch the bad page bug/warning because we try to free a locked
page (which was the former head page.)
To fix this, this patch suggests to shift page lock from head page to
tail page just after thp split. SIGSEGV still happens, but it affects
only error affected VMs, not a whole system.
commit a49ecbcd7b0d5a1cda7d60e03df402dd0ef76ac8 upstream.
After a successful hugetlb page migration by soft offline, the source
page will either be freed into hugepage_freelists or buddy(over-commit
page). If page is in buddy, page_hstate(page) will be NULL. It will
hit a NULL pointer dereference in dequeue_hwpoisoned_huge_page().
BUG: unable to handle kernel NULL pointer dereference at 0000000000000058
IP: [<ffffffff81163761>] dequeue_hwpoisoned_huge_page+0x131/0x1d0
PGD c23762067 PUD c24be2067 PMD 0
Oops: 0000 [#1] SMP
So check PageHuge(page) after call migrate_pages() successfully.
[wujg: backport to 3.10:
- adjust context]
Signed-off-by: Jianguo Wu <wujianguo@huawei.com>
Tested-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
split thp
commit a3e0f9e47d5ef7858a26cc12d90ad5146e802d47 upstream.
Memory failures on thp tail pages cause kernel panic like below:
MCE exception done on CPU 7
IP: [<ffffffff811b7cd1>] dequeue_hwpoisoned_huge_page+0x131/0x1e0
PGD bae42067 PUD ba47d067 PMD 0
Oops: 0000 [#1] SMP
CPU: 7 PID: 128 Comm: kworker/7:2 Tainted: G M O 3.13.0-rc4-131217-1558-00003-g83b7df08e462 #25
Call Trace:
me_huge_page+0x3e/0x50
memory_failure+0x4bb/0xc20
mce_process_work+0x3e/0x70
process_one_work+0x171/0x420
worker_thread+0x11b/0x3a0
? manage_workers.isra.25+0x2b0/0x2b0
kthread+0xe4/0x100
? kthread_create_on_node+0x190/0x190
ret_from_fork+0x7c/0xb0
RIP dequeue_hwpoisoned_huge_page+0x131/0x1e0
CR2: 0000000000000058
The reasoning of this problem is shown below:
- when we have a memory error on a thp tail page, the memory error
handler grabs a refcount of the head page to keep the thp under us.
- Before unmapping the error page from processes, we split the thp,
where page refcounts of both of head/tail pages don't change.
- Then we call try_to_unmap() over the error page (which was a tail
page before). We didn't pin the error page to handle the memory error,
this error page is freed and removed from LRU list.
- We never have the error page on LRU list, so the first page state
check returns "unknown page," then we move to the second check
with the saved page flag.
- The saved page flag have PG_tail set, so the second page state check
returns "hugepage."
- We call me_huge_page() for freed error page, then we hit the above panic.
The root cause is that we didn't move refcount from the head page to the
tail page after split thp. So this patch suggests to do this.
This panic was introduced by commit 524fca1e73 ("HWPOISON: fix
misjudgement of page_action() for errors on mlocked pages"). Note that we
did have the same refcount problem before this commit, but it was just
ignored because we had only first page state check which returned "unknown
page." The commit changed the refcount problem from "doesn't work" to
"kernel panic."
Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com>
Currently page_action() does not check dirty flag to determine whether
the error page is "clean mlocked/unevictable LRU" page. This doesn't
cause any misjudgement because we do matching against "dirty
mlocked/unevictable LRU" just before the check. But in order to make
code consistent and/or to avoid potential regression, we had better
check dirty flag explicitly.
Suggested-by: Chen Gong <gong.chen@linux.intel.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
error_states[] has two separate states "unevictable LRU page" and
"mlocked LRU page", and the former one has the higher priority now. But
because of that the latter one is rarely chosen because pages with
PageMlocked highly likely have PG_unevictable set. On the other hand,
PG_unevictable without PageMlocked is common for ramfs or SHM_LOCKed
shared memory, so reversing the priority of these two states helps us
clearly distinguish them.
memory_failure() can't handle memory errors on mlocked pages correctly,
because page_action() judges such errors as ones on "unknown pages"
instead of ones on "unevictable LRU page" or "mlocked LRU page". In
order to determine page_state page_action() checks page flags at the
timing of the judgement, but such page flags are not the same with those
just after memory_failure() is called, because memory_failure() does
unmapping of the error pages before doing page_action(). This unmapping
changes the page state, especially page_remove_rmap() (called from
try_to_unmap_one()) clears PG_mlocked, so page_action() can't catch
mlocked pages after that.
With this patch, we store the page flag of the error page before doing
unmap, and (only) if the first check with page flags at the time decided
the error page is unknown, we do the second check with the stored page
flag. This implementation doesn't change error handling for the page
types for which the first check can determine the page state correctly.
[akpm@linux-foundation.org: tweak comments]
No functional change, but the only purpose of the offlining argument to
migrate_pages() etc, was to ensure that __unmap_and_move() could migrate a
KSM page for memory hotremove (which took ksm_thread_mutex) but not for
other callers. Now all cases are safe, remove the arg.
Cc: Petr Holasek <pholasek@redhat.com>
Cc: Izik Eidus <izik.eidus@ravellosystems.com>
Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Cc: KOSAKI Motohiro <kosaki.motohiro@gmail.com>
on thp
num_poisoned_pages counts up the number of pages isolated by memory
errors. But for thp, only one subpage is isolated because memory error
handler splits it, so it's wrong to add (1 << compound_trans_order).
[akpm@linux-foundation.org: tweak comment]
Currently soft_offline_page() is hard to maintain because it has many
return points and goto statements. All of this mess come from
get_any_page().
This function should only get page refcount as the name implies, but it
does some page isolating actions like SetPageHWPoison() and dequeuing
hugepage. This patch corrects it and introduces some internal
subroutines to make soft offlining code more readable and maintainable.
Reviewed-by: Andi Kleen <andi@firstfloor.org>
Cc: Jiang Liu <jiang.liu@huawei.com>
Since MCE is an x86 concept, and this code is in mm/, it would be better
to use the name num_poisoned_pages instead of mce_bad_pages.
[akpm@linux-foundation.org: fix mm/sparse.c]
Signed-off-by: Xishi Qiu <qiuxishi@huawei.com>
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Suggested-by: Borislav Petkov <bp@alien8.de>
There are too many return points randomly intermingled with some "goto
done" return points. So adjust the function structure, one for the
success path, the other for the failure path. Use atomic_long_inc
instead of atomic_long_add.
Suggested-by: Andrew Morton <akpm@linux-foundation.org>
When doing
$ echo paddr > /sys/devices/system/memory/soft_offline_page
to offline a *free* page, the value of mce_bad_pages will be added, and
the page is set HWPoison flag, but it is still managed by page buddy
alocator.
$ cat /proc/meminfo | grep HardwareCorrupted
shows the value.
If we offline the same page, the value of mce_bad_pages will be added
*again*, this means the value is incorrect now. Assume the page is
still free during this short time.
soft_offline_page()
get_any_page()
"else if (is_free_buddy_page(p))" branch return 0
"goto done";
"atomic_long_add(1, &mce_bad_pages);"
This patch:
Move poisoned page check at the beginning of the function in order to
fix the error.
git://git.kernel.org/pub/scm/linux/kernel/git/mel/linux-balancenuma
Pull Automatic NUMA Balancing bare-bones from Mel Gorman:
"There are three implementations for NUMA balancing, this tree
(balancenuma), numacore which has been developed in tip/master and
autonuma which is in aa.git.
In almost all respects balancenuma is the dumbest of the three because
its main impact is on the VM side with no attempt to be smart about
scheduling. In the interest of getting the ball rolling, it would be
desirable to see this much merged for 3.8 with the view to building
scheduler smarts on top and adapting the VM where required for 3.9.
The most recent set of comparisons available from different people are
mel: https://lkml.org/lkml/2012/12/9/108
mingo: https://lkml.org/lkml/2012/12/7/331
tglx: https://lkml.org/lkml/2012/12/10/437
srikar: https://lkml.org/lkml/2012/12/10/397
The results are a mixed bag. In my own tests, balancenuma does
reasonably well. It's dumb as rocks and does not regress against
mainline. On the other hand, Ingo's tests shows that balancenuma is
incapable of converging for this workloads driven by perf which is bad
but is potentially explained by the lack of scheduler smarts. Thomas'
results show balancenuma improves on mainline but falls far short of
numacore or autonuma. Srikar's results indicate we all suffer on a
large machine with imbalanced node sizes.
My own testing showed that recent numacore results have improved
dramatically, particularly in the last week but not universally.
We've butted heads heavily on system CPU usage and high levels of
migration even when it shows that overall performance is better.
There are also cases where it regresses. Of interest is that for
specjbb in some configurations it will regress for lower numbers of
warehouses and show gains for higher numbers which is not reported by
the tool by default and sometimes missed in treports. Recently I
reported for numacore that the JVM was crashing with
NullPointerExceptions but currently it's unclear what the source of
this problem is. Initially I thought it was in how numacore batch
handles PTEs but I'm no longer think this is the case. It's possible
numacore is just able to trigger it due to higher rates of migration.
These reports were quite late in the cycle so I/we would like to start
with this tree as it contains much of the code we can agree on and has
not changed significantly over the last 2-3 weeks."
* tag 'balancenuma-v11' of git://git.kernel.org/pub/scm/linux/kernel/git/mel/linux-balancenuma: (50 commits)
mm/rmap, migration: Make rmap_walk_anon() and try_to_unmap_anon() more scalable
mm/rmap: Convert the struct anon_vma::mutex to an rwsem
mm: migrate: Account a transhuge page properly when rate limiting
mm: numa: Account for failed allocations and isolations as migration failures
mm: numa: Add THP migration for the NUMA working set scanning fault case build fix
mm: numa: Add THP migration for the NUMA working set scanning fault case.
mm: sched: numa: Delay PTE scanning until a task is scheduled on a new node
mm: sched: numa: Control enabling and disabling of NUMA balancing if !SCHED_DEBUG
mm: sched: Adapt the scanning rate if a NUMA hinting fault does not migrate
mm: numa: Use a two-stage filter to restrict pages being migrated for unlikely task<->node relationships
mm: numa: migrate: Set last_nid on newly allocated page
mm: numa: split_huge_page: Transfer last_nid on tail page
mm: numa: Introduce last_nid to the page frame
sched: numa: Slowly increase the scanning period as NUMA faults are handled
mm: numa: Rate limit setting of pte_numa if node is saturated
mm: numa: Rate limit the amount of memory that is migrated between nodes
mm: numa: Structures for Migrate On Fault per NUMA migration rate limiting
mm: numa: Migrate pages handled during a pmd_numa hinting fault
mm: numa: Migrate on reference policy
action_result() fails to print out "dirty" even if an error occurred on
a dirty pagecache, because when we check PageDirty in action_result() it
was cleared after page isolation even if it's dirty before error
handling. This can break some applications that monitor this message,
so should be fixed.
There are several callers of action_result() except page_action(), but
either of them are not for LRU pages but for free pages or kernel pages,
so we don't have to consider dirty or not for them.
Note that PG_dirty can be set outside page locks as described in commit
6746aff74da2 ("HWPOISON: shmem: call set_page_dirty() with locked
page"), so this patch does not completely closes the race window, but
just narrows it.
Reviewed-by: Andi Kleen <ak@linux.intel.com>
Cc: "Jun'ichi Nomura" <j-nomura@ce.jp.nec.com>
hwpoisoned may be set when we offline a page by the sysfs interface
/sys/devices/system/memory/soft_offline_page or
/sys/devices/system/memory/hard_offline_page. If we don't clear
this flag when onlining pages, this page can't be freed, and will
not in free list. So we can't offline these pages again. So we
should skip such page when offlining pages.
Signed-off-by: Wen Congyang <wency@cn.fujitsu.com>
Cc: Jiang Liu <liuj97@gmail.com>
Cc: Len Brown <len.brown@intel.com>
Cc: Minchan Kim <minchan.kim@gmail.com>
Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
rmap_walk_anon() and try_to_unmap_anon() appears to be too
careful about locking the anon vma: while it needs protection
against anon vma list modifications, it does not need exclusive
access to the list itself.
Transforming this exclusive lock to a read-locked rwsem removes
a global lock from the hot path of page-migration intense
threaded workloads which can cause pathological performance like
this:
96.43% process 0 [kernel.kallsyms] [k] perf_trace_sched_switch
--- perf_trace_sched_switch
__schedule
schedule
schedule_preempt_disabled
__mutex_lock_common.isra.6
__mutex_lock_slowpath
mutex_lock
|--50.61%-- rmap_walk
| move_to_new_page
| migrate_pages
| migrate_misplaced_page
| __do_numa_page.isra.69
| handle_pte_fault
| handle_mm_fault
| __do_page_fault
| do_page_fault
| page_fault
| __memset_sse2
| --100.00%-- worker_thread
| --100.00%-- start_thread
--49.39%-- page_lock_anon_vma
try_to_unmap_anon
try_to_unmap
migrate_pages
handle_pte_fault
handle_mm_fault
__do_page_fault
do_page_fault
page_fault
__memset_sse2
start_thread
With this change applied the profile is now nicely flat
and there's no anon-vma related scheduling/blocking.
Rename anon_vma_[un]lock() => anon_vma_[un]lock_write(),
to make it clearer that it's an exclusive write-lock in
that case - suggested by Rik van Riel.
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Paul Turner <pjt@google.com>
The pgmigrate_success and pgmigrate_fail vmstat counters tells the user
about migration activity but not the type or the reason. This patch adds
a tracepoint to identify the type of page migration and why the page is
being migrated.
When we try to soft-offline a thp tail page, put_page() is called on the
tail page unthinkingly and VM_BUG_ON is triggered in put_compound_page().
This patch splits thp before going into the main body of soft-offlining.
Cc: Andi Kleen <andi.kleen@intel.com>
Cc: <stable@vger.kernel.org>
When a large VMA (anon or private file mapping) is first touched, which
will populate its anon_vma field, and then split into many regions through
the use of mprotect(), the original anon_vma ends up linking all of the
vmas on a linked list. This can cause rmap to become inefficient, as we
have to walk potentially thousands of irrelevent vmas before finding the
one a given anon page might fall into.
By replacing the same_anon_vma linked list with an interval tree (where
each avc's interval is determined by its vma's start and last pgoffs), we
can make rmap efficient for this use case again.
While the change is large, all of its pieces are fairly simple.
Most places that were walking the same_anon_vma list were looking for a
known pgoff, so they can just use the anon_vma_interval_tree_foreach()
interval tree iterator instead. The exception here is ksm, where the
page's index is not known. It would probably be possible to rework ksm so
that the index would be known, but for now I have decided to keep things
simple and just walk the entirety of the interval tree there.
When updating vma's that already have an anon_vma assigned, we must take
care to re-index the corresponding avc's on their interval tree. This is
done through the use of anon_vma_interval_tree_pre_update_vma() and
anon_vma_interval_tree_post_update_vma(), which remove the avc's from
their interval tree before the update and re-insert them after the update.
The anon_vma stays locked during the update, so there is no chance that
rmap would miss the vmas that are being updated.
Signed-off-by: Michel Lespinasse <walken@google.com>
Cc: Daniel Santos <daniel.santos@pobox.com>
Implement an interval tree as a replacement for the VMA prio_tree. The
algorithms are similar to lib/interval_tree.c; however that code can't be
directly reused as the interval endpoints are not explicitly stored in the
VMA. So instead, the common algorithm is moved into a template and the
details (node type, how to get interval endpoints from the node, etc) are
filled in using the C preprocessor.
Once the interval tree functions are available, using them as a
replacement to the VMA prio tree is a relatively simple, mechanical job.
Cc: Hillf Danton <dhillf@gmail.com>
Sanity:
CONFIG_CGROUP_MEM_RES_CTLR -> CONFIG_MEMCG
CONFIG_CGROUP_MEM_RES_CTLR_SWAP -> CONFIG_MEMCG_SWAP
CONFIG_CGROUP_MEM_RES_CTLR_SWAP_ENABLED -> CONFIG_MEMCG_SWAP_ENABLED
CONFIG_CGROUP_MEM_RES_CTLR_KMEM -> CONFIG_MEMCG_KMEM
[mhocko@suse.cz: fix missed bits]
Cc: Glauber Costa <glommer@parallels.com>
Acked-by: Michal Hocko <mhocko@suse.cz>
Cc: Tejun Heo <tj@kernel.org>
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Since we migrate only one hugepage, don't use linked list for passing the
page around. Directly pass the page that need to be migrated as argument.
This also removes the usage of page->lru in the migrate path.
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Commit a6bc32b89922 ("mm: compaction: introduce sync-light migration for
use by compaction") changed the declaration of migrate_pages() and
migrate_huge_pages().
But it missed changing the argument of migrate_huge_pages() in
soft_offline_huge_page(). In this case, we should call
migrate_huge_pages() with MIGRATE_SYNC.
Additionally, there is a mismatch between type the of argument and the
function declaration for migrate_pages().
Signed-off-by: Joonsoo Kim <js1304@gmail.com>
Acked-by: David Rientjes <rientjes@google.com>
Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com>
In commit dad1743e5993f1 ("x86/mce: Only restart instruction after machine
check recovery if it is safe") we fixed mce_notify_process() to force a
signal to the current process if it was not restartable (RIPV bit not
set in MCG_STATUS). But doing it here means that the process doesn't
get told the virtual address of the fault via siginfo_t->si_addr. This
would prevent application level recovery from the fault.
Make a new MF_MUST_KILL flag bit for memory_failure() et al. to use so
that we will provide the right information with the signal.
Signed-off-by: Tony Luck <tony.luck@intel.com>
Acked-by: Borislav Petkov <borislav.petkov@amd.com>
Cc: stable@kernel.org # 3.4+
These things tend to get out of sync with time so let the compiler
automatically enter the current function name using __func__.
No functional change.
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
Acked-by: Andi Kleen <andi@firstfloor.org>
This commit changes various functions that change pages and
pageblocks migrate type between MIGRATE_ISOLATE and
MIGRATE_MOVABLE in such a way as to allow to work with
MIGRATE_CMA migrate type.
Signed-off-by: Michal Nazarewicz <mina86@mina86.com>
Tested-by: Rob Clark <rob.clark@linaro.org>
Tested-by: Ohad Ben-Cohen <ohad@wizery.com>
Tested-by: Benjamin Gaignard <benjamin.gaignard@linaro.org>
Tested-by: Robert Nelson <robertcnelson@gmail.com>
Tested-by: Barry Song <Baohua.Song@csr.com>
Pull MCE changes from Ingo Molnar.
* 'x86-mce-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/mce: Fix return value of mce_chrdev_read() when erst is disabled
x86/mce: Convert static array of pointers to per-cpu variables
x86/mce: Replace hard coded hex constants with symbolic defines
x86/mce: Recognise machine check bank signature for data path error
x86/mce: Handle "action required" errors
x86/mce: Add mechanism to safely save information in MCE handler
x86/mce: Create helper function to save addr/misc when needed
HWPOISON: Add code to handle "action required" errors.
HWPOISON: Clean up memory_failure() vs. __memory_failure()
Andrea Arcangeli pointed out to me that a check in __memory_failure()
which was intended to prevent THP tail pages from being checked for the
absence of the PG_lru flag (something that is always the case), was also
preventing THP head pages from being checked.
A THP head page could actually benefit from the call to shake_page() by
ending up being put back to a LRU, provided it had been waiting in a
pagevec array.
Andrea suggested that the "!PageTransCompound(p)" in the if-statement
should be replaced by a "!PageTransTail(p)", thus allowing THP head pages
to be checked and possibly shaken.
Signed-off-by: Dean Nelson <dnelson@redhat.com>
Cc: Jin Dongming <jin.dongming@np.css.fujitsu.com>
Reviewed-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
git://git.kernel.org/pub/scm/linux/kernel/git/ras/ras into x86/mce
Implement MCE recovery for the data load error path and assorted cleanups.
This patch adds a lightweight sync migrate operation MIGRATE_SYNC_LIGHT
mode that avoids writing back pages to backing storage. Async compaction
maps to MIGRATE_ASYNC while sync compaction maps to MIGRATE_SYNC_LIGHT.
For other migrate_pages users such as memory hotplug, MIGRATE_SYNC is
used.
This avoids sync compaction stalling for an excessive length of time,
particularly when copying files to a USB stick where there might be a
large number of dirty pages backed by a filesystem that does not support
->writepages.
[aarcange@redhat.com: This patch is heavily based on Andrea's work]
[akpm@linux-foundation.org: fix fs/nfs/write.c build]
[akpm@linux-foundation.org: fix fs/btrfs/disk-io.c build]
Cc: Dave Jones <davej@redhat.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Andy Isaacson <adi@hexapodia.org>
Cc: Nai Xia <nai.xia@gmail.com>
Cc: Johannes Weiner <jweiner@redhat.com>
Add new flag bit "MF_ACTION_REQUIRED" to be used by machine check
code to force a signal with si_code = BUS_MCEERR_AR in the case
where the error occurs in processor execution context. Pass the
flags argument along call chain:
memory_failure()
kill_procs()
kill_proc()
Drop the "_ao" suffix from kill_procs_ao() and kill_proc_ao() since
they can now handle "action required" as well as "action optional" errors.
Acked-by: Borislav Petkov <bp@amd64.org>
There is only one caller of memory_failure(), all other users call
__memory_failure() and pass in the flags argument explicitly. The
lone user of memory_failure() will soon need to pass flags too.
Add flags argument to the callsite in mce.c. Delete the old memory_failure()
function, and then rename __memory_failure() without the leading "__".
Provide clearer message when action optional memory errors are ignored.
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
* 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits)
Revert "tracing: Include module.h in define_trace.h"
irq: don't put module.h into irq.h for tracking irqgen modules.
bluetooth: macroize two small inlines to avoid module.h
ip_vs.h: fix implicit use of module_get/module_put from module.h
nf_conntrack.h: fix up fallout from implicit moduleparam.h presence
include: replace linux/module.h with "struct module" wherever possible
include: convert various register fcns to macros to avoid include chaining
crypto.h: remove unused crypto_tfm_alg_modname() inline
uwb.h: fix implicit use of asm/page.h for PAGE_SIZE
pm_runtime.h: explicitly requires notifier.h
linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h
miscdevice.h: fix up implicit use of lists and types
stop_machine.h: fix implicit use of smp.h for smp_processor_id
of: fix implicit use of errno.h in include/linux/of.h
of_platform.h: delete needless include <linux/module.h>
acpi: remove module.h include from platform/aclinux.h
miscdevice.h: delete unnecessary inclusion of module.h
device_cgroup.h: delete needless include <linux/module.h>
net: sch_generic remove redundant use of <linux/module.h>
net: inet_timewait_sock doesnt need <linux/module.h>
Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in
- drivers/media/dvb/frontends/dibx000_common.c
- drivers/media/video/{mt9m111.c,ov6650.c}
- drivers/mfd/ab3550-core.c
- include/linux/dmaengine.h
Commit fb46e73520940b ("HWPOISON: Convert pr_debugs to pr_info) authored
by Andi Kleen converted a number of pr_debug()s to pr_info()s.
About the same time additional code with pr_debug()s was added by two
other commits 8c6c2ecb4466 ("HWPOSION, hugetlb: recover from free hugepage
error when !MF_COUNT_INCREASED") and d950b95882f3d ("HWPOISON, hugetlb:
soft offlining for hugepage"). And these pr_debug()s failed to get
converted to pr_info()s.
This patch converts them as well. And does some minor related whitespace
cleanup.
These files were getting <linux/module.h> via an implicit include
path, but we want to crush those out of existence since they cost
time during compiles of processing thousands of lines of headers
for no reason. Give them the lightweight header that just contains
the EXPORT_SYMBOL infrastructure.
memory_failure() is the entry point for HWPoison memory error
recovery. It must be called in process context. But commonly
hardware memory errors are notified via MCE or NMI, so some delayed
execution mechanism must be used. In MCE handler, a work queue + ring
buffer mechanism is used.
In addition to MCE, now APEI (ACPI Platform Error Interface) GHES
(Generic Hardware Error Source) can be used to report memory errors
too. To add support to APEI GHES memory recovery, a mechanism similar
to that of MCE is implemented. memory_failure_queue() is the new
entry point that can be called in IRQ context. The next step is to
make MCE handler uses this interface too.
Signed-off-by: Huang Ying <ying.huang@intel.com>
Signed-off-by: Len Brown <len.brown@intel.com>
We cannot take a mutex while holding a spinlock, so flip the order and
fix the locking documentation.
Acked-by: Andi Kleen <ak@linux.intel.com>
Pages isolated for migration are accounted with the vmstat counters
NR_ISOLATE_[ANON|FILE]. Callers of migrate_pages() are expected to
increment these counters when pages are isolated from the LRU. Once the
pages have been migrated, they are put back on the LRU or freed and the
isolated count is decremented.
Memory failure is not properly accounting for pages it isolates causing
the NR_ISOLATED counters to be negative. On SMP builds, this goes
unnoticed as negative counters are treated as 0 due to expected per-cpu
drift. On UP builds, the counter is treated by too_many_isolated() as a
large value causing processes to enter D state during page reclaim or
compaction. This patch accounts for pages isolated by memory failure
correctly.
[mel@csn.ul.ie: rewrote changelog]
Signed-off-by: Minchan Kim <minchan.kim@gmail.com>
Acked-by: Mel Gorman <mel@csn.ul.ie>
Cc: <stable@kernel.org>
Change each shrinker's API by consolidating the existing parameters into
shrink_control struct. This will simplify any further features added w/o
touching each file of shrinker.
[akpm@linux-foundation.org: fix build]
[akpm@linux-foundation.org: fix warning]
[kosaki.motohiro@jp.fujitsu.com: fix up new shrinker API]
[akpm@linux-foundation.org: fix xfs warning]
[akpm@linux-foundation.org: update gfs2]
Signed-off-by: Ying Han <yinghan@google.com>
Acked-by: Pavel Emelyanov <xemul@openvz.org>
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Consolidate the existing parameters to shrink_slab() into a new
shrink_control struct. This is needed later to pass the same struct to
shrinkers.
Drop first page reference only after calling isolate_lru_page() to keep
page stable reference while isolating.
Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
Straightforward conversion of i_mmap_lock to a mutex.
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Namhyung Kim <namhyung@gmail.com>
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits)
Documentation/iostats.txt: bit-size reference etc.
cfq-iosched: removing unnecessary think time checking
cfq-iosched: Don't clear queue stats when preempt.
blk-throttle: Reset group slice when limits are changed
blk-cgroup: Only give unaccounted_time under debug
cfq-iosched: Don't set active queue in preempt
block: fix non-atomic access to genhd inflight structures
block: attempt to merge with existing requests on plug flush
block: NULL dereference on error path in __blkdev_get()
cfq-iosched: Don't update group weights when on service tree
fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away
block: Require subsystems to explicitly allocate bio_set integrity mempool
jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging
jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging
fs: make fsync_buffers_list() plug
mm: make generic_writepages() use plugging
blk-cgroup: Add unaccounted time to timeslice_used.
block: fixup plugging stubs for !CONFIG_BLOCK
block: remove obsolete comments for blkdev_issue_zeroout.
blktrace: Use rq->cmd_flags directly in blk_add_trace_rq.
Fix up conflicts in fs/{aio.c,super.c}
Now we renamed remove_from_page_cache with delete_from_page_cache. As
consistency of __remove_from_swap_cache and remove_from_swap_cache, we
change internal page cache handling function name, too.
Reviewed-by: Johannes Weiner <hannes@cmpxchg.org>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Unused.
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
Code has been converted over to the new explicit on-stack plugging,
and delay users have been converted to use the new API for that.
So lets kill off the old plugging along with aops->sync_page().
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
