path: root/mm/memory.c
2010-04-07mm: avoid null-pointer deref in sync_mm_rss()KAMEZAWA Hiroyuki
- We weren't zeroing p->rss_stat[] at fork() - Consequently sync_mm_rss() was dereferencing tsk->mm for kernel threads and was oopsing. - Make __sync_task_rss_stat() static, too. Addresses https://bugzilla.kernel.org/show_bug.cgi?id=15648 [akpm@linux-foundation.org: remove the BUG_ON(!mm->rss)] Reported-by: Troels Liebe Bentsen <tlb@rapanden.dk> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> "Michael S. Tsirkin" <mst@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-24exit: fix oops in sync_mm_rssMichael S. Tsirkin
In 2.6.34-rc1, removing vhost_net module causes an oops in sync_mm_rss (called from do_exit) when workqueue is destroyed. This does not happen on net-next, or with vhost on top of to 2.6.33. The issue seems to be introduced by 34e55232e59f7b19050267a05ff1226e5cd122a5 ("mm: avoid false sharing of mm_counter) which added sync_mm_rss() that is passed task->mm, and dereferences it without checking. If task is a kernel thread, mm might be NULL. I think this might also happen e.g. with aio. This patch fixes the oops by calling sync_mm_rss when task->mm is set to NULL. I also added BUG_ON to detect any other cases where counters get incremented while mm is NULL. The oops I observed looks like this: BUG: unable to handle kernel NULL pointer dereference at 00000000000002a8 IP: [<ffffffff810b436d>] sync_mm_rss+0x33/0x6f PGD 0 Oops: 0002 [#1] SMP last sysfs file: /sys/devices/system/cpu/cpu7/cache/index2/shared_cpu_map CPU 2 Modules linked in: vhost_net(-) tun bridge stp sunrpc ipv6 cpufreq_ondemand acpi_cpufreq freq_table kvm_intel kvm i5000_edac edac_core rtc_cmos bnx2 button i2c_i801 i2c_core rtc_core e1000e sg joydev ide_cd_mod serio_raw pcspkr rtc_lib cdrom virtio_net virtio_blk virtio_pci virtio_ring virtio af_packet e1000 shpchp aacraid uhci_hcd ohci_hcd ehci_hcd [last unloaded: microcode] Pid: 2046, comm: vhost Not tainted 2.6.34-rc1-vhost #25 System Planar/IBM System x3550 -[7978B3G]- RIP: 0010:[<ffffffff810b436d>] [<ffffffff810b436d>] sync_mm_rss+0x33/0x6f RSP: 0018:ffff8802379b7e60 EFLAGS: 00010202 RAX: 0000000000000008 RBX: ffff88023f2390c0 RCX: 0000000000000000 RDX: ffff88023f2396b0 RSI: 0000000000000000 RDI: ffff88023f2390c0 RBP: ffff8802379b7e60 R08: 0000000000000000 R09: 0000000000000000 R10: ffff88023aecfbc0 R11: 0000000000013240 R12: 0000000000000000 R13: ffffffff81051a6c R14: ffffe8ffffc0f540 R15: 0000000000000000 FS: 0000000000000000(0000) GS:ffff880001e80000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 00000000000002a8 CR3: 000000023af23000 CR4: 00000000000406e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process vhost (pid: 2046, threadinfo ffff8802379b6000, task ffff88023f2390c0) Stack: ffff8802379b7ee0 ffffffff81040687 ffffe8ffffc0f558 ffffffffa00a3e2d <0> 0000000000000000 ffff88023f2390c0 ffffffff81055817 ffff8802379b7e98 <0> ffff8802379b7e98 0000000100000286 ffff8802379b7ee0 ffff88023ad47d78 Call Trace: [<ffffffff81040687>] do_exit+0x147/0x6c4 [<ffffffffa00a3e2d>] ? handle_rx_net+0x0/0x17 [vhost_net] [<ffffffff81055817>] ? autoremove_wake_function+0x0/0x39 [<ffffffff81051a6c>] ? worker_thread+0x0/0x229 [<ffffffff810553c9>] kthreadd+0x0/0xf2 [<ffffffff810038d4>] kernel_thread_helper+0x4/0x10 [<ffffffff81055342>] ? kthread+0x0/0x87 [<ffffffff810038d0>] ? kernel_thread_helper+0x0/0x10 Code: 00 8b 87 6c 02 00 00 85 c0 74 14 48 98 f0 48 01 86 a0 02 00 00 c7 87 6c 02 00 00 00 00 00 00 8b 87 70 02 00 00 85 c0 74 14 48 98 <f0> 48 01 86 a8 02 00 00 c7 87 70 02 00 00 00 00 00 00 8b 87 74 RIP [<ffffffff810b436d>] sync_mm_rss+0x33/0x6f RSP <ffff8802379b7e60> CR2: 00000000000002a8 ---[ end trace 41603ba922beddd2 ]--- Fixing recursive fault but reboot is needed! (note: handle_rx_net is a work item using workqueue in question). sync_mm_rss+0x33/0x6f gave me a hint. I also tried reverting 34e55232e59f7b19050267a05ff1226e5cd122a5 and the oops goes away. The module in question calls use_mm and later unuse_mm from a kernel thread. It is when this kernel thread is destroyed that the crash happens. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Andrea Arcangeli <aarcange@redhat.com> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12mm: introduce dump_page() and print symbolic flag namesWu Fengguang
- introduce dump_page() to print the page info for debugging some error condition. - convert three mm users: bad_page(), print_bad_pte() and memory offline failure. - print an extra field: the symbolic names of page->flags Example dump_page() output: [ 157.521694] page:ffffea0000a7cba8 count:2 mapcount:1 mapping:ffff88001c901791 index:0x147 [ 157.525570] page flags: 0x100000000100068(uptodate|lru|active|swapbacked) Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Alex Chiang <achiang@hp.com> Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Mel Gorman <mel@linux.vnet.ibm.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12nommu: fix build breakageKAMEZAWA Hiroyuki
Commit 34e55232e59f7b19050267a05ff1226e5cd122a5 ("mm: avoid false sharing of mm_counter") added sync_mm_rss() for syncing loosely accounted rss counters. It's for CONFIG_MMU but sync_mm_rss is called even in NOMMU enviroment (kerne/exit.c, fs/exec.c). Above commit doesn't handle it well. This patch changes SPLIT_RSS_COUNTING depends on SPLIT_PTLOCKS && CONFIG_MMU And for avoid unnecessary function calls, sync_mm_rss changed to be inlined noop function in header file. Reported-by: David Howells <dhowells@redhat.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Michal Simek <monstr@monstr.eu> Signed-off-by: David Howells <dhowells@redhat.com> Cc: Greg Ungerer <gerg@snapgear.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06rmap: move exclusively owned pages to own anon_vma in do_wp_page()Rik van Riel
When the parent process breaks the COW on a page, both the original which is mapped at child and the new page which is mapped parent end up in that same anon_vma. Generally this won't be a problem, but for some workloads it could preserve the O(N) rmap scanning complexity. A simple fix is to ensure that, when a page which is mapped child gets reused in do_wp_page, because we already are the exclusive owner, the page gets moved to our own exclusive child's anon_vma. Signed-off-by: Rik van Riel <riel@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Larry Woodman <lwoodman@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06mm: change anon_vma linking to fix multi-process server scalability issueRik van Riel
The old anon_vma code can lead to scalability issues with heavily forking workloads. Specifically, each anon_vma will be shared between the parent process and all its child processes. In a workload with 1000 child processes and a VMA with 1000 anonymous pages per process that get COWed, this leads to a system with a million anonymous pages in the same anon_vma, each of which is mapped in just one of the 1000 processes. However, the current rmap code needs to walk them all, leading to O(N) scanning complexity for each page. This can result in systems where one CPU is walking the page tables of 1000 processes in page_referenced_one, while all other CPUs are stuck on the anon_vma lock. This leads to catastrophic failure for a benchmark like AIM7, where the total number of processes can reach in the tens of thousands. Real workloads are still a factor 10 less process intensive than AIM7, but they are catching up. This patch changes the way anon_vmas and VMAs are linked, which allows us to associate multiple anon_vmas with a VMA. At fork time, each child process gets its own anon_vmas, in which its COWed pages will be instantiated. The parents' anon_vma is also linked to the VMA, because non-COWed pages could be present in any of the children. This reduces rmap scanning complexity to O(1) for the pages of the 1000 child processes, with O(N) complexity for at most 1/N pages in the system. This reduces the average scanning cost in heavily forking workloads from O(N) to 2. The only real complexity in this patch stems from the fact that linking a VMA to anon_vmas now involves memory allocations. This means vma_adjust can fail, if it needs to attach a VMA to anon_vma structures. This in turn means error handling needs to be added to the calling functions. A second source of complexity is that, because there can be multiple anon_vmas, the anon_vma linking in vma_adjust can no longer be done under "the" anon_vma lock. To prevent the rmap code from walking up an incomplete VMA, this patch introduces the VM_LOCK_RMAP VMA flag. This bit flag uses the same slot as the NOMMU VM_MAPPED_COPY, with an ifdef in mm.h to make sure it is impossible to compile a kernel that needs both symbolic values for the same bitflag. Some test results: Without the anon_vma changes, when AIM7 hits around 9.7k users (on a test box with 16GB RAM and not quite enough IO), the system ends up running >99% in system time, with every CPU on the same anon_vma lock in the pageout code. With these changes, AIM7 hits the cross-over point around 29.7k users. This happens with ~99% IO wait time, there never seems to be any spike in system time. The anon_vma lock contention appears to be resolved. [akpm@linux-foundation.org: cleanups] Signed-off-by: Rik van Riel <riel@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Larry Woodman <lwoodman@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06mm: count swap usageKAMEZAWA Hiroyuki
A frequent questions from users about memory management is what numbers of swap ents are user for processes. And this information will give some hints to oom-killer. Besides we can count the number of swapents per a process by scanning /proc/<pid>/smaps, this is very slow and not good for usual process information handler which works like 'ps' or 'top'. (ps or top is now enough slow..) This patch adds a counter of swapents to mm_counter and update is at each swap events. Information is exported via /proc/<pid>/status file as [kamezawa@bluextal memory]$ cat /proc/self/status Name: cat State: R (running) Tgid: 2910 Pid: 2910 PPid: 2823 TracerPid: 0 Uid: 500 500 500 500 Gid: 500 500 500 500 FDSize: 256 Groups: 500 VmPeak: 82696 kB VmSize: 82696 kB VmLck: 0 kB VmHWM: 432 kB VmRSS: 432 kB VmData: 172 kB VmStk: 84 kB VmExe: 48 kB VmLib: 1568 kB VmPTE: 40 kB VmSwap: 0 kB <=============== this. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06mm: avoid false sharing of mm_counterKAMEZAWA Hiroyuki
Considering the nature of per mm stats, it's the shared object among threads and can be a cache-miss point in the page fault path. This patch adds per-thread cache for mm_counter. RSS value will be counted into a struct in task_struct and synchronized with mm's one at events. Now, in this patch, the event is the number of calls to handle_mm_fault. Per-thread value is added to mm at each 64 calls. rough estimation with small benchmark on parallel thread (2threads) shows [before] 4.5 cache-miss/faults [after] 4.0 cache-miss/faults Anyway, the most contended object is mmap_sem if the number of threads grows. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06mm: clean up mm_counterKAMEZAWA Hiroyuki
Presently, per-mm statistics counter is defined by macro in sched.h This patch modifies it to - defined in mm.h as inlinf functions - use array instead of macro's name creation. This patch is for reducing patch size in future patch to modify implementation of per-mm counter. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-20MM: Pass a PTE pointer to update_mmu_cache() rather than the PTE itselfRussell King
On VIVT ARM, when we have multiple shared mappings of the same file in the same MM, we need to ensure that we have coherency across all copies. We do this via make_coherent() by making the pages uncacheable. This used to work fine, until we allowed highmem with highpte - we now have a page table which is mapped as required, and is not available for modification via update_mmu_cache(). Ralf Beache suggested getting rid of the PTE value passed to update_mmu_cache(): On MIPS update_mmu_cache() calls __update_tlb() which walks pagetables to construct a pointer to the pte again. Passing a pte_t * is much more elegant. Maybe we might even replace the pte argument with the pte_t? Ben Herrenschmidt would also like the pte pointer for PowerPC: Passing the ptep in there is exactly what I want. I want that -instead- of the PTE value, because I have issue on some ppc cases, for I$/D$ coherency, where set_pte_at() may decide to mask out the _PAGE_EXEC. So, pass in the mapped page table pointer into update_mmu_cache(), and remove the PTE value, updating all implementations and call sites to suit. Includes a fix from Stephen Rothwell: sparc: fix fallout from update_mmu_cache API change Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-12-16Merge branch 'hwpoison' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6 * 'hwpoison' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6: (34 commits) HWPOISON: Remove stray phrase in a comment HWPOISON: Try to allocate migration page on the same node HWPOISON: Don't do early filtering if filter is disabled HWPOISON: Add a madvise() injector for soft page offlining HWPOISON: Add soft page offline support HWPOISON: Undefine short-hand macros after use to avoid namespace conflict HWPOISON: Use new shake_page in memory_failure HWPOISON: Use correct name for MADV_HWPOISON in documentation HWPOISON: mention HWPoison in Kconfig entry HWPOISON: Use get_user_page_fast in hwpoison madvise HWPOISON: add an interface to switch off/on all the page filters HWPOISON: add memory cgroup filter memcg: add accessor to mem_cgroup.css memcg: rename and export try_get_mem_cgroup_from_page() HWPOISON: add page flags filter mm: export stable page flags HWPOISON: limit hwpoison injector to known page types HWPOISON: add fs/device filters HWPOISON: return 0 to indicate success reliably HWPOISON: make semantics of IGNORED/DELAYED clear ...
2009-12-16memcg: coalesce uncharge during unmap/truncateKAMEZAWA Hiroyuki
In massive parallel enviroment, res_counter can be a performance bottleneck. One strong techinque to reduce lock contention is reducing calls by coalescing some amount of calls into one. Considering charge/uncharge chatacteristic, - charge is done one by one via demand-paging. - uncharge is done by - in chunk at munmap, truncate, exit, execve... - one by one via vmscan/paging. It seems we have a chance to coalesce uncharges for improving scalability at unmap/truncation. This patch is a for coalescing uncharge. For avoiding scattering memcg's structure to functions under /mm, this patch adds memcg batch uncharge information to the task. A reason for per-task batching is for making use of caller's context information. We do batched uncharge (deleyed uncharge) when truncation/unmap occurs but do direct uncharge when uncharge is called by memory reclaim (vmscan.c). The degree of coalescing depends on callers - at invalidate/trucate... pagevec size - at unmap ....ZAP_BLOCK_SIZE (memory itself will be freed in this degree.) Then, we'll not coalescing too much. On x86-64 8cpu server, I tested overheads of memcg at page fault by running a program which does map/fault/unmap in a loop. Running a task per a cpu by taskset and see sum of the number of page faults in 60secs. [without memcg config] 40156968 page-faults # 0.085 M/sec ( +- 0.046% ) 27.67 cache-miss/faults [root cgroup] 36659599 page-faults # 0.077 M/sec ( +- 0.247% ) 31.58 miss/faults [in a child cgroup] 18444157 page-faults # 0.039 M/sec ( +- 0.133% ) 69.96 miss/faults [child with this patch] 27133719 page-faults # 0.057 M/sec ( +- 0.155% ) 47.16 miss/faults We can see some amounts of improvement. (root cgroup doesn't affected by this patch) Another patch for "charge" will follow this and above will be improved more. Changelog(since 2009/10/02): - renamed filed of memcg_batch (as pages to bytes, memsw to memsw_bytes) - some clean up and commentary/description updates. - added initialize code to copy_process(). (possible bug fix) Changelog(old): - fixed !CONFIG_MEM_CGROUP case. - rebased onto the latest mmotm + softlimit fix patches. - unified patch for callers - added commetns. - make ->do_batch as bool. - removed css_get() at el. We don't need it. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16HWPOISON: comment dirty swapcache pagesWu Fengguang
AK: Improve comment Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-12-15ksm: let shared pages be swappableHugh Dickins
Initial implementation for swapping out KSM's shared pages: add page_referenced_ksm() and try_to_unmap_ksm(), which rmap.c calls when faced with a PageKsm page. Most of what's needed can be got from the rmap_items listed from the stable_node of the ksm page, without discovering the actual vma: so in this patch just fake up a struct vma for page_referenced_one() or try_to_unmap_one(), then refine that in the next patch. Add VM_NONLINEAR to ksm_madvise()'s list of exclusions: it has always been implicit there (being only set with VM_SHARED, already excluded), but let's make it explicit, to help justify the lack of nonlinear unmap. Rely on the page lock to protect against concurrent modifications to that page's node of the stable tree. The awkward part is not swapout but swapin: do_swap_page() and page_add_anon_rmap() now have to allow for new possibilities - perhaps a ksm page still in swapcache, perhaps a swapcache page associated with one location in one anon_vma now needed for another location or anon_vma. (And the vma might even be no longer VM_MERGEABLE when that happens.) ksm_might_need_to_copy() checks for that case, and supplies a duplicate page when necessary, simply leaving it to a subsequent pass of ksmd to rediscover the identity and merge them back into one ksm page. Disappointingly primitive: but the alternative would have to accumulate unswappable info about the swapped out ksm pages, limiting swappability. Remove page_add_ksm_rmap(): page_add_anon_rmap() now has to allow for the particular case it was handling, so just use it instead. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Izik Eidus <ieidus@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Chris Wright <chrisw@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15mm: sigbus instead of abusing oomHugh Dickins
When do_nonlinear_fault() realizes that the page table must have been corrupted for it to have been called, it does print_bad_pte() and returns ... VM_FAULT_OOM, which is hard to understand. It made some sense when I did it for 2.6.15, when do_page_fault() just killed the current process; but nowadays it lets the OOM killer decide who to kill - so page table corruption in one process would be liable to kill another. Change it to return VM_FAULT_SIGBUS instead: that doesn't guarantee that the process will be killed, but is good enough for such a rare abnormality, accompanied as it is by the "BUG: Bad page map" message. And recent HWPOISON work has copied that code into do_swap_page(), when it finds an impossible swap entry: fix that to VM_FAULT_SIGBUS too. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Izik Eidus <ieidus@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Nick Piggin <npiggin@suse.de> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Andi Kleen <andi@firstfloor.org> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Wu Fengguang <fengguang.wu@intel.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15swap_info: swap count continuationsHugh Dickins
Swap is duplicated (reference count incremented by one) whenever the same swap page is inserted into another mm (when forking finds a swap entry in place of a pte, or when reclaim unmaps a pte to insert the swap entry). swap_info_struct's vmalloc'ed swap_map is the array of these reference counts: but what happens when the unsigned short (or unsigned char since the preceding patch) is full? (and its high bit is kept for a cache flag) We then lose track of it, never freeing, leaving it in use until swapoff: at which point we _hope_ that a single pass will have found all instances, assume there are no more, and will lose user data if we're wrong. Swapping of KSM pages has not yet been enabled; but it is implemented, and makes it very easy for a user to overflow the maximum swap count: possible with ordinary process pages, but unlikely, even when pid_max has been raised from PID_MAX_DEFAULT. This patch implements swap count continuations: when the count overflows, a continuation page is allocated and linked to the original vmalloc'ed map page, and this used to hold the continuation counts for that entry and its neighbours. These continuation pages are seldom referenced: the common paths all work on the original swap_map, only referring to a continuation page when the low "digit" of a count is incremented or decremented through SWAP_MAP_MAX. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29Merge branch 'hwpoison-2.6.32' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6 * 'hwpoison-2.6.32' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6: HWPOISON: fix invalid page count in printk output HWPOISON: Allow schedule_on_each_cpu() from keventd HWPOISON: fix/proc/meminfo alignment HWPOISON: fix oops on ksm pages HWPOISON: Fix page count leak in hwpoison late kill in do_swap_page HWPOISON: return early on non-LRU pages HWPOISON: Add brief hwpoison description to Documentation HWPOISON: Clean up PR_MCE_KILL interface
2009-10-29mm: don't call pte_unmap() against an improper pteDaisuke Nishimura
There are some places where we do like: pte = pte_map(); do { (do break in some conditions) } while (pte++, ...); pte_unmap(pte - 1); But if the loop breaks at the first loop, pte_unmap() unmaps invalid pte. This patch is a fix for this problem. Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Reviewd-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-19HWPOISON: Fix page count leak in hwpoison late kill in do_swap_pageAndi Kleen
When returning due to a poisoned page drop the page count. It wasn't a fatal problem because noone cares about the page count on a poisoned page (except when it wraps), but it's cleaner to fix it. Pointed out by Linus. Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-09-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: truncate: use new helpers truncate: new helpers fs: fix overflow in sys_mount() for in-kernel calls fs: Make unload_nls() NULL pointer safe freeze_bdev: grab active reference to frozen superblocks freeze_bdev: kill bd_mount_sem exofs: remove BKL from super operations fs/romfs: correct error-handling code vfs: seq_file: add helpers for data filling vfs: remove redundant position check in do_sendfile vfs: change sb->s_maxbytes to a loff_t vfs: explicitly cast s_maxbytes in fiemap_check_ranges libfs: return error code on failed attr set seq_file: return a negative error code when seq_path_root() fails. vfs: optimize touch_time() too vfs: optimization for touch_atime() vfs: split generic_forget_inode() so that hugetlbfs does not have to copy it fs/inode.c: add dev-id and inode number for debugging in init_special_inode() libfs: make simple_read_from_buffer conventional
2009-09-24Merge branch 'hwpoison' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6 * 'hwpoison' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6: (21 commits) HWPOISON: Enable error_remove_page on btrfs HWPOISON: Add simple debugfs interface to inject hwpoison on arbitary PFNs HWPOISON: Add madvise() based injector for hardware poisoned pages v4 HWPOISON: Enable error_remove_page for NFS HWPOISON: Enable .remove_error_page for migration aware file systems HWPOISON: The high level memory error handler in the VM v7 HWPOISON: Add PR_MCE_KILL prctl to control early kill behaviour per process HWPOISON: shmem: call set_page_dirty() with locked page HWPOISON: Define a new error_remove_page address space op for async truncation HWPOISON: Add invalidate_inode_page HWPOISON: Refactor truncate to allow direct truncating of page v2 HWPOISON: check and isolate corrupted free pages v2 HWPOISON: Handle hardware poisoned pages in try_to_unmap HWPOISON: Use bitmask/action code for try_to_unmap behaviour HWPOISON: x86: Add VM_FAULT_HWPOISON handling to x86 page fault handler v2 HWPOISON: Add poison check to page fault handling HWPOISON: Add basic support for poisoned pages in fault handler v3 HWPOISON: Add new SIGBUS error codes for hardware poison signals HWPOISON: Add support for poison swap entries v2 HWPOISON: Export some rmap vma locking to outside world ...
2009-09-24truncate: new helpersnpiggin@suse.de
Introduce new truncate helpers truncate_pagecache and inode_newsize_ok. vmtruncate is also consolidated from mm/memory.c and mm/nommu.c and into mm/truncate.c. Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-09-22mm: move highest_memmap_pfnHugh Dickins
Move highest_memmap_pfn __read_mostly from page_alloc.c next to zero_pfn __read_mostly in memory.c: to help them share a cacheline, since they're very often tested together in vm_normal_page(). Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Rik van Riel <riel@redhat.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22mm: ZERO_PAGE without PTE_SPECIALHugh Dickins
Reinstate anonymous use of ZERO_PAGE to all architectures, not just to those which __HAVE_ARCH_PTE_SPECIAL: as suggested by Nick Piggin. Contrary to how I'd imagined it, there's nothing ugly about this, just a zero_pfn test built into one or another block of vm_normal_page(). But the MIPS ZERO_PAGE-of-many-colours case demands is_zero_pfn() and my_zero_pfn() inlines. Reinstate its mremap move_pte() shuffling of ZERO_PAGEs we did from 2.6.17 to 2.6.19? Not unless someone shouts for that: it would have to take vm_flags to weed out some cases. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Rik van Riel <riel@redhat.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22mm: FOLL flags for GUP flagsHugh Dickins
__get_user_pages() has been taking its own GUP flags, then processing them into FOLL flags for follow_page(). Though oddly named, the FOLL flags are more widely used, so pass them to __get_user_pages() now. Sorry, VM flags, VM_FAULT flags and FAULT_FLAGs are still distinct. (The patch to __get_user_pages() looks peculiar, with both gup_flags and foll_flags: the gup_flags remain constant; but as before there's an exceptional case, out of scope of the patch, in which foll_flags per page have FOLL_WRITE masked off.) Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Rik van Riel <riel@redhat.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22mm: reinstate ZERO_PAGEHugh Dickins
KAMEZAWA Hiroyuki has observed customers of earlier kernels taking advantage of the ZERO_PAGE: which we stopped do_anonymous_page() from using in 2.6.24. And there were a couple of regression reports on LKML. Following suggestions from Linus, reinstate do_anonymous_page() use of the ZERO_PAGE; but this time avoid dirtying its struct page cacheline with (map)count updates - let vm_normal_page() regard it as abnormal. Use it only on arches which __HAVE_ARCH_PTE_SPECIAL (x86, s390, sh32, most powerpc): that's not essential, but minimizes additional branches (keeping them in the unlikely pte_special case); and incidentally excludes mips (some models of which needed eight colours of ZERO_PAGE to avoid costly exceptions). Don't be fanatical about avoiding ZERO_PAGE updates: get_user_pages() callers won't want to make exceptions for it, so increment its count there. Changes to mlock and migration? happily seems not needed. In most places it's quicker to check pfn than struct page address: prepare a __read_mostly zero_pfn for that. Does get_dump_page() still need its ZERO_PAGE check? probably not, but keep it anyway. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Acked-by: Rik van Riel <riel@redhat.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22mm: fix anonymous dirtyingHugh Dickins
do_anonymous_page() has been wrong to dirty the pte regardless. If it's not going to mark the pte writable, then it won't help to mark it dirty here, and clogs up memory with pages which will need swap instead of being thrown away. Especially wrong if no overcommit is chosen, and this vma is not yet VM_ACCOUNTed - we could exceed the limit and OOM despite no overcommit. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: <stable@kernel.org> Acked-by: Rik van Riel <riel@redhat.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22mm: follow_hugetlb_page flagsHugh Dickins
follow_hugetlb_page() shouldn't be guessing about the coredump case either: pass the foll_flags down to it, instead of just the write bit. Remove that obscure huge_zeropage_ok() test. The decision is easy, though unlike the non-huge case - here vm_ops->fault is always set. But we know that a fault would serve up zeroes, unless there's already a hugetlbfs pagecache page to back the range. (Alternatively, since hugetlb pages aren't swapped out under pressure, you could save more dump space by arguing that a page not yet faulted into this process cannot be relevant to the dump; but that would be more surprising.) Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Acked-by: Rik van Riel <riel@redhat.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22mm: FOLL_DUMP replace FOLL_ANONHugh Dickins
The "FOLL_ANON optimization" and its use_zero_page() test have caused confusion and bugs: why does it test VM_SHARED? for the very good but unsatisfying reason that VMware crashed without. As we look to maybe reinstating anonymous use of the ZERO_PAGE, we need to sort this out. Easily done: it's silly for __get_user_pages() and follow_page() to be guessing whether it's safe to assume that they're being used for a coredump (which can take a shortcut snapshot where other uses must handle a fault) - just tell them with GUP_FLAGS_DUMP and FOLL_DUMP. get_dump_page() doesn't even want a ZERO_PAGE: an error suits fine. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22mm: add get_dump_pageHugh Dickins
In preparation for the next patch, add a simple get_dump_page(addr) interface for the CONFIG_ELF_CORE dumpers to use, instead of calling get_user_pages() directly. They're not interested in errors: they just want to use holes as much as possible, to save space and make sure that the data is aligned where the headers said it would be. Oh, and don't use that horrid DUMP_SEEK(off) macro! Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Acked-by: Rik van Riel <riel@redhat.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22mm: remove unused GUP flagsHugh Dickins
GUP_FLAGS_IGNORE_VMA_PERMISSIONS and GUP_FLAGS_IGNORE_SIGKILL were flags added solely to prevent __get_user_pages() from doing some of what it usually does, in the munlock case: we can now remove them. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Acked-by: Rik van Riel <riel@redhat.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22mm: drop unneeded double negationsJohannes Weiner
Remove double negations where the operand is already boolean. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Mel Gorman <mel@csn.ul.ie> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22ksm: fix deadlock with munlock in exit_mmapAndrea Arcangeli
Rawhide users have reported hang at startup when cryptsetup is run: the same problem can be simply reproduced by running a program int main() { mlockall(MCL_CURRENT | MCL_FUTURE); return 0; } The problem is that exit_mmap() applies munlock_vma_pages_all() to clean up VM_LOCKED areas, and its current implementation (stupidly) tries to fault in absent pages, for example where PROT_NONE prevented them being faulted in when mlocking. Whereas the "ksm: fix oom deadlock" patch, knowing there's a race by which KSM might try to fault in pages after exit_mmap() had finally zapped the range, backs out of such faults doing nothing when its ksm_test_exit() notices mm_users 0. So revert that part of "ksm: fix oom deadlock" which moved the ksm_exit() call from before exit_mmap() to the middle of exit_mmap(); and remove those ksm_test_exit() checks from the page fault paths, so allowing the munlocking to proceed without interference. ksm_exit, if there are rmap_items still chained on this mm slot, takes mmap_sem write side: so preventing KSM from working on an mm while exit_mmap runs. And KSM will bail out as soon as it notices that mm_users is already zero, thanks to its internal ksm_test_exit checks. So that when a task is killed by OOM killer or the user, KSM will not indefinitely prevent it from running exit_mmap to release its memory. This does break a part of what "ksm: fix oom deadlock" was trying to achieve. When unmerging KSM (echo 2 >/sys/kernel/mm/ksm), and even when ksmd itself has to cancel a KSM page, it is possible that the first OOM-kill victim would be the KSM process being faulted: then its memory won't be freed until a second victim has been selected (freeing memory for the unmerging fault to complete). But the OOM killer is already liable to kill a second victim once the intended victim's p->mm goes to NULL: so there's not much point in rejecting this KSM patch before fixing that OOM behaviour. It is very much more important to allow KSM users to boot up, than to haggle over an unlikely and poorly supported OOM case. We also intend to fix munlocking to not fault pages: at which point this patch _could_ be reverted; though that would be controversial, so we hope to find a better solution. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Justin M. Forbes <jforbes@redhat.com> Acked-for-now-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Izik Eidus <ieidus@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22ksm: fix oom deadlockHugh Dickins
There's a now-obvious deadlock in KSM's out-of-memory handling: imagine ksmd or KSM_RUN_UNMERGE handling, holding ksm_thread_mutex, trying to allocate a page to break KSM in an mm which becomes the OOM victim (quite likely in the unmerge case): it's killed and goes to exit, and hangs there waiting to acquire ksm_thread_mutex. Clearly we must not require ksm_thread_mutex in __ksm_exit, simple though that made everything else: perhaps use mmap_sem somehow? And part of the answer lies in the comments on unmerge_ksm_pages: __ksm_exit should also leave all the rmap_item removal to ksmd. But there's a fundamental problem, that KSM relies upon mmap_sem to guarantee the consistency of the mm it's dealing with, yet exit_mmap tears down an mm without taking mmap_sem. And bumping mm_users won't help at all, that just ensures that the pages the OOM killer assumes are on their way to being freed will not be freed. The best answer seems to be, to move the ksm_exit callout from just before exit_mmap, to the middle of exit_mmap: after the mm's pages have been freed (if the mmu_gather is flushed), but before its page tables and vma structures have been freed; and down_write,up_write mmap_sem there to serialize with KSM's own reliance on mmap_sem. But KSM then needs to be careful, whenever it downs mmap_sem, to check that the mm is not already exiting: there's a danger of using find_vma on a layout that's being torn apart, or writing into page tables which have been freed for reuse; and even do_anonymous_page and __do_fault need to check they're not being called by break_ksm to reinstate a pte after zap_pte_range has zapped that page table. Though it might be clearer to add an exiting flag, set while holding mmap_sem in __ksm_exit, that wouldn't cover the issue of reinstating a zapped pte. All we need is to check whether mm_users is 0 - but must remember that ksmd may detect that before __ksm_exit is reached. So, ksm_test_exit(mm) added to comment such checks on mm->mm_users. __ksm_exit now has to leave clearing up the rmap_items to ksmd, that needs ksm_thread_mutex; but shift the exiting mm just after the ksm_scan cursor so that it will soon be dealt with. __ksm_enter raise mm_count to hold the mm_struct, ksmd's exit processing (exactly like its processing when it finds all VM_MERGEABLEs unmapped) mmdrop it, similar procedure for KSM_RUN_UNMERGE (which has stopped ksmd). But also give __ksm_exit a fast path: when there's no complication (no rmap_items attached to mm and it's not at the ksm_scan cursor), it can safely do all the exiting work itself. This is not just an optimization: when ksmd is not running, the raised mm_count would otherwise leak mm_structs. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Acked-by: Izik Eidus <ieidus@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22ksm: identify PageKsm pagesHugh Dickins
KSM will need to identify its kernel merged pages unambiguously, and /proc/kpageflags will probably like to do so too. Since KSM will only be substituting anonymous pages, statistics are best preserved by making a PageKsm page a special PageAnon page: one with no anon_vma. But KSM then needs its own page_add_ksm_rmap() - keep it in ksm.h near PageKsm; and do_wp_page() must COW them, unlike singly mapped PageAnons. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Chris Wright <chrisw@redhat.com> Signed-off-by: Izik Eidus <ieidus@redhat.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Avi Kivity <avi@redhat.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22ksm: no debug in page_dup_rmap()Hugh Dickins
page_dup_rmap(), used on each mapped page when forking, was originally just an inline atomic_inc of mapcount. 2.6.22 added CONFIG_DEBUG_VM out-of-line checks to it, which would need to be ever-so-slightly complicated to allow for the PageKsm() we're about to define. But I think these checks never caught anything. And if it's coding errors we're worried about, such checks should be in page_remove_rmap() too, not just when forking; whereas if it's pagetable corruption we're worried about, then they shouldn't be limited to CONFIG_DEBUG_VM. Oh, just revert page_dup_rmap() to an inline atomic_inc of mapcount. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Chris Wright <chrisw@redhat.com> Signed-off-by: Izik Eidus <ieidus@redhat.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Avi Kivity <avi@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22ksm: add mmu_notifier set_pte_at_notify()Izik Eidus
KSM is a linux driver that allows dynamicly sharing identical memory pages between one or more processes. Unlike tradtional page sharing that is made at the allocation of the memory, ksm do it dynamicly after the memory was created. Memory is periodically scanned; identical pages are identified and merged. The sharing is made in a transparent way to the processes that use it. Ksm is highly important for hypervisors (kvm), where in production enviorments there might be many copys of the same data data among the host memory. This kind of data can be: similar kernels, librarys, cache, and so on. Even that ksm was wrote for kvm, any userspace application that want to use it to share its data can try it. Ksm may be useful for any application that might have similar (page aligment) data strctures among the memory, ksm will find this data merge it to one copy, and even if it will be changed and thereforew copy on writed, ksm will merge it again as soon as it will be identical again. Another reason to consider using ksm is the fact that it might simplify alot the userspace code of application that want to use shared private data, instead that the application will mange shared area, ksm will do this for the application, and even write to this data will be allowed without any synchinization acts from the application. Ksm was designed to be a loadable module that doesn't change the VM code of linux. This patch: The set_pte_at_notify() macro allows setting a pte in the shadow page table directly, instead of flushing the shadow page table entry and then getting vmexit to set it. It uses a new change_pte() callback to do so. set_pte_at_notify() is an optimization for kvm, and other users of mmu_notifiers, for COW pages. It is useful for kvm when ksm is used, because it allows kvm not to have to receive vmexit and only then map the ksm page into the shadow page table, but instead map it directly at the same time as Linux maps the page into the host page table. Users of mmu_notifiers who don't implement new mmu_notifier_change_pte() callback will just receive the mmu_notifier_invalidate_page() callback. Signed-off-by: Izik Eidus <ieidus@redhat.com> Signed-off-by: Chris Wright <chrisw@redhat.com> Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Avi Kivity <avi@redhat.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-18headers: taskstats_kern.h trimAlexey Dobriyan
Remove net/genetlink.h inclusion, now sched.c won't be recompiled because of some networking changes. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-16HWPOISON: Add poison check to page fault handlingAndi Kleen
Bail out early when hardware poisoned pages are found in page fault handling. Since they are poisoned they should not be mapped freshly into processes, because that would cause another (potentially deadly) machine check This is generally handled in the same way as OOM, just a different error code is returned to the architecture code. v2: Do a page unlock if needed (Fengguang Wu) Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-09-16HWPOISON: Add basic support for poisoned pages in fault handler v3Andi Kleen
- Add a new VM_FAULT_HWPOISON error code to handle_mm_fault. Right now architectures have to explicitely enable poison page support, so this is forward compatible to all architectures. They only need to add it when they enable poison page support. - Add poison page handling in swap in fault code v2: Add missing delayacct_clear_flag (Hidehiro Kawai) v3: Really use delayacct_clear_flag (Hidehiro Kawai) Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-07-27mm: Pass virtual address to [__]p{te,ud,md}_free_tlb()Benjamin Herrenschmidt
mm: Pass virtual address to [__]p{te,ud,md}_free_tlb() Upcoming paches to support the new 64-bit "BookE" powerpc architecture will need to have the virtual address corresponding to PTE page when freeing it, due to the way the HW table walker works. Basically, the TLB can be loaded with "large" pages that cover the whole virtual space (well, sort-of, half of it actually) represented by a PTE page, and which contain an "indirect" bit indicating that this TLB entry RPN points to an array of PTEs from which the TLB can then create direct entries. Thus, in order to invalidate those when PTE pages are deleted, we need the virtual address to pass to tlbilx or tlbivax instructions. The old trick of sticking it somewhere in the PTE page struct page sucks too much, the address is almost readily available in all call sites and almost everybody implemets these as macros, so we may as well add the argument everywhere. I added it to the pmd and pud variants for consistency. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: David Howells <dhowells@redhat.com> [MN10300 & FRV] Acked-by: Nick Piggin <npiggin@suse.de> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-25clarify get_user_pages() prototypePeter Zijlstra
Currently the 4th parameter of get_user_pages() is called len, but its in pages, not bytes. Rename the thing to nr_pages to avoid future confusion. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-23mm: pass mm to grab_swap_tokenHugh Dickins
If a kthread happens to use get_user_pages() on an mm (as KSM does), there's a chance that it will end up trying to read in a swap page, then oops in grab_swap_token() because the kthread has no mm: GUP passes down the right mm, so grab_swap_token() ought to be using it. We have not identified a stronger case than KSM's daemon (not yet in mainline), but the issue must have come up before, since RHEL has included a fix for this for years (though a different fix, they just back out of grab_swap_token if current->mm is unset: which is what we first proposed, but using the right mm here seems more correct). Reported-by: Izik Eidus <ieidus@redhat.com> Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-23mm: don't rely on flags coincidenceHugh Dickins
Indeed FOLL_WRITE matches FAULT_FLAG_WRITE, matches GUP_FLAGS_WRITE, and it's tempting to devise a set of Grand Unified Paging flags; but not today. So until then, let's rely upon the compiler to spot the coincidence, "rather than have that subtle dependency and a comment for it" - as you remarked in another context yesterday. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Acked-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-21Move FAULT_FLAG_xyz into handle_mm_fault() callersLinus Torvalds
This allows the callers to now pass down the full set of FAULT_FLAG_xyz flags to handle_mm_fault(). All callers have been (mechanically) converted to the new calling convention, there's almost certainly room for architectures to clean up their code and then add FAULT_FLAG_RETRY when that support is added. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-21Remove internal use of 'write_access' in mm/memory.cLinus Torvalds
The fault handling routines really want more fine-grained flags than a single "was it a write fault" boolean - the callers will want to set flags like "you can return a retry error" etc. And that's actually how the VM works internally, but right now the top-level fault handling functions in mm/memory.c all pass just the 'write_access' boolean around. This switches them over to pass around the FAULT_FLAG_xyzzy 'flags' variable instead. The 'write_access' calling convention still exists for the exported 'handle_mm_fault()' function, but that is next. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16mm: introduce follow_pfn()Johannes Weiner
Analoguous to follow_phys(), add a helper that looks up the PFN at a user virtual address in an IO mapping or a raw PFN mapping. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Christoph Hellwig <hch@infradead.org> Acked-by: Magnus Damm <magnus.damm@gmail.com> Cc: Hans Verkuil <hverkuil@xs4all.nl> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16mm: use generic follow_pte() in follow_phys()Johannes Weiner
2009-06-16mm: introduce follow_pte()Johannes Weiner
A generic readonly page table lookup helper to map an address space and an address from it to a pte. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Christoph Hellwig <hch@infradead.org> Acked-by: Magnus Damm <magnus.damm@gmail.com> Cc: Hans Verkuil <hverkuil@xs4all.nl> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
