path: root/mm/mempolicy.c
2011-03-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits) doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore Update cpuset info & webiste for cgroups dcdbas: force SMI to happen when expected arch/arm/Kconfig: remove one to many l's in the word. asm-generic/user.h: Fix spelling in comment drm: fix printk typo 'sracth' Remove one to many n's in a word Documentation/filesystems/romfs.txt: fixing link to genromfs drivers:scsi Change printk typo initate -> initiate serial, pch uart: Remove duplicate inclusion of linux/pci.h header fs/eventpoll.c: fix spelling mm: Fix out-of-date comments which refers non-existent functions drm: Fix printk typo 'failled' coh901318.c: Change initate to initiate. mbox-db5500.c Change initate to initiate. edac: correct i82975x error-info reported edac: correct i82975x mci initialisation edac: correct commented info fs: update comments to point correct document target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c ... Trivial conflict in fs/eventpoll.c (spelling vs addition)
2011-03-04mm: use correct numa policy node for transparent hugepagesAndi Kleen
Pass down the correct node for a transparent hugepage allocation. Most callers continue to use the current node, however the hugepaged daemon now uses the previous node of the first to be collapsed page instead. This ensures that khugepaged does not mess up local memory for an existing process which uses local policy. The choice of node is somewhat primitive currently: it just uses the node of the first page in the pmd range. An alternative would be to look at multiple pages and use the most popular node. I used the simplest variant for now which should work well enough for the case of all pages being on the same node. [akpm@linux-foundation.org: coding-style fixes] Acked-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-04mm: change alloc_pages_vma to pass down the policy node for local policyAndi Kleen
Currently alloc_pages_vma() always uses the local node as policy node for the LOCAL policy. Pass this node down as an argument instead. No behaviour change from this patch, but will be needed for followons. Acked-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-01Remove one to many n's in a wordJustin P. Mattock
Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-02-25thp: fix interleaving for transparent hugepagesAndi Kleen
The THP code didn't pass the correct interleaving shift to the memory policy code. Fix this here by adjusting for the order. Signed-off-by: Andi Kleen <ak@linux.intel.com> Reviewed-by: Christoph Lameter <cl@linux.com> Acked-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13thp: add numa awareness to hugepage allocationsAndrea Arcangeli
It's mostly a matter of replacing alloc_pages with alloc_pages_vma after introducing alloc_pages_vma. khugepaged needs special handling as the allocation has to happen inside collapse_huge_page where the vma is known and an error has to be returned to the outer loop to sleep alloc_sleep_millisecs in case of failure. But it retains the more efficient logic of handling allocation failures in khugepaged in case of CONFIG_NUMA=n. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13thp: split_huge_page_mm/vmaAndrea Arcangeli
split_huge_page_pmd compat code. Each one of those would need to be expanded to hundred of lines of complex code without a fully reliable split_huge_page_pmd design. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13mempolicy: remove tasklist_lock from migrate_pagesKOSAKI Motohiro
Today, tasklist_lock in migrate_pages doesn't protect anything. rcu_read_lock() provide enough protection from pid hash walk. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reported-by: Peter Zijlstra <peterz@infradead.org> Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13mm: migration: cleanup migrate_pages API by matching types for offlining and ↵Mel Gorman
sync With the introduction of the boolean sync parameter, the API looks a little inconsistent as offlining is still an int. Convert offlining to a bool for the sake of being tidy. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13mm: migration: allow migration to operate asynchronously and avoid ↵Mel Gorman
synchronous compaction in the faster path Migration synchronously waits for writeback if the initial passes fails. Callers of memory compaction do not necessarily want this behaviour if the caller is latency sensitive or expects that synchronous migration is not going to have a significantly better success rate. This patch adds a sync parameter to migrate_pages() allowing the caller to indicate if wait_on_page_writeback() is allowed within migration or not. For reclaim/compaction, try_to_compact_pages() is first called asynchronously, direct reclaim runs and then try_to_compact_pages() is called synchronously as there is a greater expectation that it'll succeed. [akpm@linux-foundation.org: build/merge fix] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-02mm/mempolicy.c: add rcu read lock to protect pid structureZeng Zhaoming
find_task_by_vpid() should be protected by rcu_read_lock(), to prevent free_pid() reclaiming pid. Signed-off-by: Zeng Zhaoming <zengzm.kernel@gmail.com> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-28numa: fix slab_node(MPOL_BIND)Eric Dumazet
When a node contains only HighMem memory, slab_node(MPOL_BIND) dereferences a NULL pointer. [ This code seems to go back all the way to commit 19770b32609b: "mm: filter based on a nodemask as well as a gfp_mask". Which was back in April 2008, and it got merged into 2.6.26. - Linus ] Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Christoph Lameter <cl@linux.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26mm/mempolicy.c: check return code of check_rangeVasiliy Kulikov
Function check_range may return ERR_PTR(...). Check for it. Signed-off-by: Vasiliy Kulikov <segooon@gmail.com> Acked-by: David Rientjes <rientjes@google.com> Reviewed-by: Christoph Lameter <cl@linux.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26mm: compaction: fix COMPACTPAGEFAILED countingMinchan Kim
Presently update_nr_listpages() doesn't have a role. That's because lists passed is always empty just after calling migrate_pages. The migrate_pages cleans up page list which have failed to migrate before returning by aaa994b3. [PATCH] page migration: handle freeing of pages in migrate_pages() Do not leave pages on the lists passed to migrate_pages(). Seems that we will not need any postprocessing of pages. This will simplify the handling of pages by the callers of migrate_pages(). At that time, we thought we don't need any postprocessing of pages. But the situation is changed. The compaction need to know the number of failed to migrate for COMPACTPAGEFAILED stat This patch makes new rule for caller of migrate_pages to call putback_lru_pages. So caller need to clean up the lists so it has a chance to postprocess the pages. [suggested by Christoph Lameter] Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Cc: Hugh Dickins <hughd@google.com> Cc: Andi Kleen <andi@firstfloor.org> Reviewed-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Wu Fengguang <fengguang.wu@intel.com> Acked-by: Christoph Lameter <cl@linux.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09mempolicy: reduce stack size of migrate_pages()KOSAKI Motohiro
migrate_pages() is using >500 bytes stack. Reduce it. mm/mempolicy.c: In function 'sys_migrate_pages': mm/mempolicy.c:1344: warning: the frame size of 528 bytes is larger than 512 bytes [akpm@linux-foundation.org: don't play with a might-be-NULL pointer] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09oom: select task from tasklist for mempolicy oomsDavid Rientjes
The oom killer presently kills current whenever there is no more memory free or reclaimable on its mempolicy's nodes. There is no guarantee that current is a memory-hogging task or that killing it will free any substantial amount of memory, however. In such situations, it is better to scan the tasklist for nodes that are allowed to allocate on current's set of nodes and kill the task with the highest badness() score. This ensures that the most memory-hogging task, or the one configured by the user with /proc/pid/oom_adj, is always selected in such scenarios. Signed-off-by: David Rientjes <rientjes@google.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-06-29mempolicy: fix dangling reference to tmpfs superblock mpolLee Schermerhorn
My patch to "Factor out duplicate put/frees in mpol_shared_policy_init() to a common return path"; and Dan Carpenter's fix thereto both left a dangling reference to the incoming tmpfs superblock mempolicy structure. A similar leak was introduced earlier when the nodemask was moved offstack to the scratch area despite the note in the comment block regarding the incoming ref. Move the remaining 'put of the incoming "mpol" to the common exit path to drop the reference. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Acked-by: Dan Carpenter <error27@gmail.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-26mempolicy: ERR_PTR dereference in mpol_shared_policy_init()Dan Carpenter
The original code called mpol_put(new) while "new" was an ERR_PTR. Signed-off-by: Dan Carpenter <error27@gmail.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux-foundation.org> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25mm: consider the entire user address space during node migrationGreg Thelen
Use mm->task_size instead of TASK_SIZE to ensure that the entire user address space is migrated. mm->task_size is independent of the calling task context. TASK SIZE may be dependant on the address space size of the calling process. Usage of TASK_SIZE can lead to partial address space migration if the calling process was 32 bit and the migrating process was 64 bit. Here is the test script used on 64 system with a 32 bit echo process: mount -t cgroup none /cgroup -o cpuset cd /cgroup mkdir 0 echo 1 > 0/cpuset.cpus echo 0 > 0/cpuset.mems echo 1 > 0/cpuset.memory_migrate mkdir 1 echo 1 > 1/cpuset.cpus echo 1 > 1/cpuset.mems echo 1 > 1/cpuset.memory_migrate echo $$ > 0/tasks 64_bit_process & pid=$! echo $pid > 1/tasks # This does not migrate all process pages without # this patch. If 64 bit echo is used or this patch is # applied, then the full address space of $pid is # migrated. To check memory migration, I watched: grep MemUsed /sys/devices/system/node/node*/meminfo Signed-off-by: Greg Thelen <gthelen@google.com> Acked-by: Christoph Lameter <cl@linux-foundation.org> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25cpuset,mm: fix no node to alloc memory when changing cpuset's memsMiao Xie
Before applying this patch, cpuset updates task->mems_allowed and mempolicy by setting all new bits in the nodemask first, and clearing all old unallowed bits later. But in the way, the allocator may find that there is no node to alloc memory. The reason is that cpuset rebinds the task's mempolicy, it cleans the nodes which the allocater can alloc pages on, for example: (mpol: mempolicy) task1 task1's mpol task2 alloc page 1 alloc on node0? NO 1 1 change mems from 1 to 0 1 rebind task1's mpol 0-1 set new bits 0 clear disallowed bits alloc on node1? NO 0 ... can't alloc page goto oom This patch fixes this problem by expanding the nodes range first(set newly allowed bits) and shrink it lazily(clear newly disallowed bits). So we use a variable to tell the write-side task that read-side task is reading nodemask, and the write-side task clears newly disallowed nodes after read-side task ends the current memory allocation. [akpm@linux-foundation.org: fix spello] Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Paul Menage <menage@google.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Ravikiran Thirumalai <kiran@scalex86.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25mempolicy: restructure rebinding-mempolicy functionsMiao Xie
Nick Piggin reported that the allocator may see an empty nodemask when changing cpuset's mems[1]. It happens only on the kernel that do not do atomic nodemask_t stores. (MAX_NUMNODES > BITS_PER_LONG) But I found that there is also a problem on the kernel that can do atomic nodemask_t stores. The problem is that the allocator can't find a node to alloc page when changing cpuset's mems though there is a lot of free memory. The reason is like this: (mpol: mempolicy) task1 task1's mpol task2 alloc page 1 alloc on node0? NO 1 1 change mems from 1 to 0 1 rebind task1's mpol 0-1 set new bits 0 clear disallowed bits alloc on node1? NO 0 ... can't alloc page goto oom I can use the attached program reproduce it by the following step: # mkdir /dev/cpuset # mount -t cpuset cpuset /dev/cpuset # mkdir /dev/cpuset/1 # echo `cat /dev/cpuset/cpus` > /dev/cpuset/1/cpus # echo `cat /dev/cpuset/mems` > /dev/cpuset/1/mems # echo $$ > /dev/cpuset/1/tasks # numactl --membind=`cat /dev/cpuset/mems` ./cpuset_mem_hog <nr_tasks> & <nr_tasks> = max(nr_cpus - 1, 1) # killall -s SIGUSR1 cpuset_mem_hog # ./change_mems.sh several hours later, oom will happen though there is a lot of free memory. This patchset fixes this problem by expanding the nodes range first(set newly allowed bits) and shrink it lazily(clear newly disallowed bits). So we use a variable to tell the write-side task that read-side task is reading nodemask, and the write-side task clears newly disallowed nodes after read-side task ends the current memory allocation. This patch: In order to fix no node to alloc memory, when we want to update mempolicy and mems_allowed, we expand the set of nodes first (set all the newly nodes) and shrink the set of nodes lazily(clean disallowed nodes), But the mempolicy's rebind functions may breaks the expanding. So we restructure the mempolicy's rebind functions and split the rebind work to two steps, just like the update of cpuset's mems: The 1st step: expand the set of the mempolicy's nodes. The 2nd step: shrink the set of the mempolicy's nodes. It is used when there is no real lock to protect the mempolicy in the read-side. Otherwise we can do rebind work at once. In order to implement it, we define enum mpol_rebind_step { MPOL_REBIND_ONCE, MPOL_REBIND_STEP1, MPOL_REBIND_STEP2, MPOL_REBIND_NSTEP, }; If the mempolicy needn't be updated by two steps, we can pass MPOL_REBIND_ONCE to the rebind functions. Or we can pass MPOL_REBIND_STEP1 to do the first step of the rebind work and pass MPOL_REBIND_STEP2 to do the second step work. Besides that, it maybe long time between these two step and we have to release the lock that protects mempolicy and mems_allowed. If we hold the lock once again, we must check whether the current mempolicy is under the rebinding (the first step has been done) or not, because the task may alloc a new mempolicy when we don't hold the lock. So we defined the following flag to identify it: #define MPOL_F_REBINDING (1 << 2) The new functions will be used in the next patch. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Paul Menage <menage@google.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Ravikiran Thirumalai <kiran@scalex86.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25mempolicy: factor mpol_shared_policy_init() return pathsLee Schermerhorn
Factor out duplicate put/frees in mpol_shared_policy_init() to a common return path. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Ravikiran Thirumalai <kiran@scalex86.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25mempolicy: rename policy_types and cleanup initializationLee Schermerhorn
Rename 'policy_types[]' to 'policy_modes[]' to better match the array contents. Use designated intializer syntax for policy_modes[]. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Ravikiran Thirumalai <kiran@scalex86.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25mempolicy: lose unnecessary loop variable in mpol_parse_str()Lee Schermerhorn
We don't really need the extra variable 'i' in mpol_parse_str(). The only use is as the the loop variable. Then, it's assigned to 'mode'. Just use mode, and loose the 'uninitialized_var()' macro. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Ravikiran Thirumalai <kiran@scalex86.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25mempolicy: don't call mpol_set_nodemask() when no_contextLee Schermerhorn
No need to call mpol_set_nodemask() when we have no context for the mempolicy. This can occur when we're parsing a tmpfs 'mpol' mount option. Just save the raw nodemask in the mempolicy's w.user_nodemask member for use when a tmpfs/shmem file is created. mpol_shared_policy_init() will "contextualize" the policy for the new file based on the creating task's context. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Ravikiran Thirumalai <kiran@scalex86.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25mempolicy: remove redundant checkBob Liu
Lee's patch "mempolicy: use MPOL_PREFERRED for system-wide default policy" has made the MPOL_DEFAULT only used in the memory policy APIs. So, no need to check in __mpol_equal also. Also get rid of mpol_match_intent() and move its logic directly into __mpol_equal(). Signed-off-by: Bob Liu <lliubbo@gmail.com> Acked-by: David Rientjes <rientjes@google.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25mempolicy: remove case MPOL_INTERLEAVE from policy_zonelist()Bob Liu
In policy_zonelist() mode MPOL_INTERLEAVE shouldn't happen, so fall through to BUG() instead of break to return. I also fixed the comment. Signed-off-by: Bob Liu <lliubbo@gmail.com> Acked-by: David Rientjes <rientjes@google.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25mempolicy: remove redundant codeBob Liu
1. In funtion is_valid_nodemask(), varibable k will be inited to 0 in the following loop, needn't init to policy_zone anymore. 2. (MPOL_F_STATIC_NODES | MPOL_F_RELATIVE_NODES) has already defined to MPOL_MODE_FLAGS in mempolicy.h. Signed-off-by: Bob Liu <lliubbo@gmail.com> Acked-by: David Rientjes <rientjes@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-24mempolicy: fix get_mempolicy() for relative and static nodesLee Schermerhorn
Discovered while testing other mempolicy changes: get_mempolicy() does not handle static/relative mode flags correctly. Return the value that the user specified so that it can be restored via set_mempolicy() if desired. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Ravikiran Thirumalai <kiran@scalex86.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-24tmpfs: cleanup mpol_parse_str()KOSAKI Motohiro
mpol_parse_str() made lots 'err' variable related bug. Because it is ugly and reviewing unfriendly. This patch simplifies it. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Ravikiran Thirumalai <kiran@scalex86.org> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Mel Gorman <mel@csn.ul.ie> Acked-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-24tmpfs: handle MPOL_LOCAL mount option properlyKOSAKI Motohiro
commit 71fe804b6d5 (mempolicy: use struct mempolicy pointer in shmem_sb_info) added mpol=local mount option. but its feature is broken since it was born. because such code always return 1 (i.e. mount failure). This patch fixes it. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Ravikiran Thirumalai <kiran@scalex86.org> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Mel Gorman <mel@csn.ul.ie> Acked-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-24tmpfs: mpol=bind:0 don't cause mount error.KOSAKI Motohiro
Currently, following mount operation cause mount error. % mount -t tmpfs -ompol=bind:0 none /tmp Because commit 71fe804b6d5 (mempolicy: use struct mempolicy pointer in shmem_sb_info) corrupted MPOL_BIND parse code. This patch restore the needed one. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Ravikiran Thirumalai <kiran@scalex86.org> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Mel Gorman <mel@csn.ul.ie> Acked-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-24tmpfs: fix oops on mounts with mpol=defaultRavikiran G Thirumalai
Fix an 'oops' when a tmpfs mount point is mounted with the mpol=default mempolicy. Upon remounting a tmpfs mount point with 'mpol=default' option, the mount code crashed with a null pointer dereference. The initial problem report was on 2.6.27, but the problem exists in mainline 2.6.34-rc as well. On examining the code, we see that mpol_new returns NULL if default mempolicy was requested. This 'NULL' mempolicy is accessed to store the node mask resulting in oops. The following patch fixes it. Signed-off-by: Ravikiran Thirumalai <kiran@scalex86.org> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Mel Gorman <mel@csn.ul.ie> Acked-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-13Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: locking: Make sparse work with inline spinlocks and rwlocks x86/mce: Fix RCU lockdep splats rcu: Increase RCU CPU stall timeouts if PROVE_RCU ftrace: Replace read_barrier_depends() with rcu_dereference_raw() rcu: Suppress RCU lockdep warnings during early boot rcu, ftrace: Fix RCU lockdep splat in ftrace_perf_buf_prepare() rcu: Suppress __mpol_dup() false positive from RCU lockdep rcu: Make rcu_read_lock_sched_held() handle !PREEMPT rcu: Add control variables to lockdep_rcu_dereference() diagnostics rcu, cgroup: Relax the check in task_subsys_state() as early boot is now handled by lockdep-RCU rcu: Use wrapper function instead of exporting tasklist_lock sched, rcu: Fix rcu_dereference() for RCU-lockdep rcu: Make task_subsys_state() RCU-lockdep checks handle boot-time use rcu: Fix holdoff for accelerated GPs for last non-dynticked CPU x86/gart: Unexport gart_iommu_aperture Fix trivial conflicts in kernel/trace/ftrace.c
2010-03-06mm/mempolicy.c: fix indentation of the comments of do_migrate_pagesKOSAKI Motohiro
Currently, do_migrate_pages() have very long comment and this is not indent properly. I often misunderstand it is function starting commnents and confused it. this patch fixes it. note: this patch doesn't break 80 column rule. I guess original author intended this indentaion, but an accident corrupted it. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06mm: fix mbind vma merge problemKOSAKI Motohiro
Strangely, current mbind() doesn't merge vma with neighbor vma although it's possible. Unfortunately, many vma can reduce performance... This patch fixes it. reproduced program ---------------------------------------------------------------- #include <numaif.h> #include <numa.h> #include <sys/mman.h> #include <stdio.h> #include <unistd.h> #include <stdlib.h> #include <string.h> static unsigned long pagesize; int main(int argc, char** argv) { void* addr; int ch; int node; struct bitmask *nmask = numa_allocate_nodemask(); int err; int node_set = 0; char buf[128]; while ((ch = getopt(argc, argv, "n:")) != -1){ switch (ch){ case 'n': node = strtol(optarg, NULL, 0); numa_bitmask_setbit(nmask, node); node_set = 1; break; default: ; } } argc -= optind; argv += optind; if (!node_set) numa_bitmask_setbit(nmask, 0); pagesize = getpagesize(); addr = mmap(NULL, pagesize*3, PROT_READ|PROT_WRITE, MAP_ANON|MAP_PRIVATE, 0, 0); if (addr == MAP_FAILED) perror("mmap "), exit(1); fprintf(stderr, "pid = %d \n" "addr = %p\n", getpid(), addr); /* make page populate */ memset(addr, 0, pagesize*3); /* first mbind */ err = mbind(addr+pagesize, pagesize, MPOL_BIND, nmask->maskp, nmask->size, MPOL_MF_MOVE_ALL); if (err) error("mbind1 "); /* second mbind */ err = mbind(addr, pagesize*3, MPOL_DEFAULT, NULL, 0, 0); if (err) error("mbind2 "); sprintf(buf, "cat /proc/%d/maps", getpid()); system(buf); return 0; } ---------------------------------------------------------------- result without this patch addr = 0x7fe26ef09000 [snip] 7fe26ef09000-7fe26ef0a000 rw-p 00000000 00:00 0 7fe26ef0a000-7fe26ef0b000 rw-p 00000000 00:00 0 7fe26ef0b000-7fe26ef0c000 rw-p 00000000 00:00 0 7fe26ef0c000-7fe26ef0d000 rw-p 00000000 00:00 0 => 0x7fe26ef09000-0x7fe26ef0c000 have three vmas. result with this patch addr = 0x7fc9ebc76000 [snip] 7fc9ebc76000-7fc9ebc7a000 rw-p 00000000 00:00 0 7fffbe690000-7fffbe6a5000 rw-p 00000000 00:00 0 [stack] => 0x7fc9ebc76000-0x7fc9ebc7a000 have only one vma. [minchan.kim@gmail.com: fix file offset passed to vma_merge()] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-04rcu: Suppress __mpol_dup() false positive from RCU lockdepPaul E. McKenney
Common code is used during task creation and after the task has started running. RCU protection is not needed during task creation because no other CPU has access to the under-construction task. Provide the RCU protection anyway to suppress the false positive, as there does not appear to be a good way for the common code to recognize that the task is only accessible to the CPU creating it. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Paul Menage <menage@google.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <1267667418-32233-2-git-send-email-paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15ksm: memory hotremove migration onlyHugh Dickins
The previous patch enables page migration of ksm pages, but that soon gets into trouble: not surprising, since we're using the ksm page lock to lock operations on its stable_node, but page migration switches the page whose lock is to be used for that. Another layer of locking would fix it, but do we need that yet? Do we actually need page migration of ksm pages? Yes, memory hotremove needs to offline sections of memory: and since we stopped allocating ksm pages with GFP_HIGHUSER, they will tend to be GFP_HIGHUSER_MOVABLE candidates for migration. But KSM is currently unconscious of NUMA issues, happily merging pages from different NUMA nodes: at present the rule must be, not to use MADV_MERGEABLE where you care about NUMA. So no, NUMA page migration of ksm pages does not make sense yet. So, to complete support for ksm swapping we need to make hotremove safe. ksm_memory_callback() take ksm_thread_mutex when MEM_GOING_OFFLINE and release it when MEM_OFFLINE or MEM_CANCEL_OFFLINE. But if mapped pages are freed before migration reaches them, stable_nodes may be left still pointing to struct pages which have been removed from the system: the stable_node needs to identify a page by pfn rather than page pointer, then it can safely prune them when MEM_OFFLINE. And make NUMA migration skip PageKsm pages where it skips PageReserved. But it's only when we reach unmap_and_move() that the page lock is taken and we can be sure that raised pagecount has prevented a PageAnon from being upgraded: so add offlining arg to migrate_pages(), to migrate ksm page when offlining (has sufficient locking) but reject it otherwise. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Izik Eidus <ieidus@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Chris Wright <chrisw@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15hugetlb: derive huge pages nodes allowed from task mempolicyLee Schermerhorn
This patch derives a "nodes_allowed" node mask from the numa mempolicy of the task modifying the number of persistent huge pages to control the allocation, freeing and adjusting of surplus huge pages when the pool page count is modified via the new sysctl or sysfs attribute "nr_hugepages_mempolicy". The nodes_allowed mask is derived as follows: * For "default" [NULL] task mempolicy, a NULL nodemask_t pointer is produced. This will cause the hugetlb subsystem to use node_online_map as the "nodes_allowed". This preserves the behavior before this patch. * For "preferred" mempolicy, including explicit local allocation, a nodemask with the single preferred node will be produced. "local" policy will NOT track any internode migrations of the task adjusting nr_hugepages. * For "bind" and "interleave" policy, the mempolicy's nodemask will be used. * Other than to inform the construction of the nodes_allowed node mask, the actual mempolicy mode is ignored. That is, all modes behave like interleave over the resulting nodes_allowed mask with no "fallback". See the updated documentation [next patch] for more information about the implications of this patch. Examples: Starting with: Node 0 HugePages_Total: 0 Node 1 HugePages_Total: 0 Node 2 HugePages_Total: 0 Node 3 HugePages_Total: 0 Default behavior [with or without this patch] balances persistent hugepage allocation across nodes [with sufficient contiguous memory]: sysctl vm.nr_hugepages[_mempolicy]=32 yields: Node 0 HugePages_Total: 8 Node 1 HugePages_Total: 8 Node 2 HugePages_Total: 8 Node 3 HugePages_Total: 8 Of course, we only have nr_hugepages_mempolicy with the patch, but with default mempolicy, nr_hugepages_mempolicy behaves the same as nr_hugepages. Applying mempolicy--e.g., with numactl [using '-m' a.k.a. '--membind' because it allows multiple nodes to be specified and it's easy to type]--we can allocate huge pages on individual nodes or sets of nodes. So, starting from the condition above, with 8 huge pages per node, add 8 more to node 2 using: numactl -m 2 sysctl vm.nr_hugepages_mempolicy=40 This yields: Node 0 HugePages_Total: 8 Node 1 HugePages_Total: 8 Node 2 HugePages_Total: 16 Node 3 HugePages_Total: 8 The incremental 8 huge pages were restricted to node 2 by the specified mempolicy. Similarly, we can use mempolicy to free persistent huge pages from specified nodes: numactl -m 0,1 sysctl vm.nr_hugepages_mempolicy=32 yields: Node 0 HugePages_Total: 4 Node 1 HugePages_Total: 4 Node 2 HugePages_Total: 16 Node 3 HugePages_Total: 8 The 8 huge pages freed were balanced over nodes 0 and 1. [rientjes@google.com: accomodate reworked NODEMASK_ALLOC] Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Andi Kleen <andi@firstfloor.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Nishanth Aravamudan <nacc@us.ibm.com> Cc: Adam Litke <agl@us.ibm.com> Cc: Andy Whitcroft <apw@canonical.com> Cc: Eric Whitney <eric.whitney@hp.com> Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15mm: move inc_zone_page_state(NR_ISOLATED) to just isolated placeKOSAKI Motohiro
Christoph pointed out inc_zone_page_state(NR_ISOLATED) should be placed in right after isolate_page(). This patch does it. Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29do_mbind(): fix memory leakKOSAKI Motohiro
If migrate_prep is failed, new variable is leaked. This patch fixes it. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29mbind(): fix leak of never putback pagesKOSAKI Motohiro
If mbind() receives an invalid address, do_mbind leaks a page. The following test program detects this leak. This patch fixes it. migrate_efault.c ======================================= #include <numaif.h> #include <numa.h> #include <sys/mman.h> #include <stdio.h> #include <unistd.h> #include <stdlib.h> #include <string.h> static unsigned long pagesize; static void* make_hole_mapping(void) { void* addr; addr = mmap(NULL, pagesize*3, PROT_READ|PROT_WRITE, MAP_ANON|MAP_PRIVATE, 0, 0); if (addr == MAP_FAILED) return NULL; /* make page populate */ memset(addr, 0, pagesize*3); /* make memory hole */ munmap(addr+pagesize, pagesize); return addr; } int main(int argc, char** argv) { void* addr; int ch; int node; struct bitmask *nmask = numa_allocate_nodemask(); int err; int node_set = 0; while ((ch = getopt(argc, argv, "n:")) != -1){ switch (ch){ case 'n': node = strtol(optarg, NULL, 0); numa_bitmask_setbit(nmask, node); node_set = 1; break; default: ; } } argc -= optind; argv += optind; if (!node_set) numa_bitmask_setbit(nmask, 0); pagesize = getpagesize(); addr = make_hole_mapping(); err = mbind(addr, pagesize*3, MPOL_BIND, nmask->maskp, nmask->size, MPOL_MF_MOVE_ALL); if (err) perror("mbind "); return 0; } ======================================= Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-07mm: make set_mempolicy(MPOL_INTERLEAV) N_HIGH_MEMORY awareKAMEZAWA Hiroyuki
At first, init_task's mems_allowed is initialized as this. init_task->mems_allowed == node_state[N_POSSIBLE] And cpuset's top_cpuset mask is initialized as this top_cpuset->mems_allowed = node_state[N_HIGH_MEMORY] Before 2.6.29: policy's mems_allowed is initialized as this. 1. update tasks->mems_allowed by its cpuset->mems_allowed. 2. policy->mems_allowed = nodes_and(tasks->mems_allowed, user's mask) Updating task's mems_allowed in reference to top_cpuset's one. cpuset's mems_allowed is aware of N_HIGH_MEMORY, always. In 2.6.30: After commit 58568d2a8215cb6f55caf2332017d7bdff954e1c ("cpuset,mm: update tasks' mems_allowed in time"), policy's mems_allowed is initialized as this. 1. policy->mems_allowd = nodes_and(task->mems_allowed, user's mask) Here, if task is in top_cpuset, task->mems_allowed is not updated from init's one. Assume user excutes command as #numactrl --interleave=all ,.... policy->mems_allowd = nodes_and(N_POSSIBLE, ALL_SET_MASK) Then, policy's mems_allowd can includes a possible node, which has no pgdat. MPOL's INTERLEAVE just scans nodemask of task->mems_allowd and access this directly. NODE_DATA(nid)->zonelist even if NODE_DATA(nid)==NULL Then, what's we need is making policy->mems_allowed be aware of N_HIGH_MEMORY. This patch does that. But to do so, extra nodemask will be on statck. Because I know cpumask has a new interface of CPUMASK_ALLOC(), I added it to node. This patch stands on old behavior. But I feel this fix itself is just a Band-Aid. But to do fundametal fix, we have to take care of memory hotplug and it takes time. (task->mems_allowd should be N_HIGH_MEMORY, I think.) mpol_set_nodemask() should be aware of N_HIGH_MEMORY and policy's nodemask should be includes only online nodes. In old behavior, this is guaranteed by frequent reference to cpuset's code. Now, most of them are removed and mempolicy has to check it by itself. To do check, a few nodemask_t will be used for calculating nodemask. But, size of nodemask_t can be big and it's not good to allocate them on stack. Now, cpumask_t has CPUMASK_ALLOC/FREE an easy code for get scratch area. NODEMASK_ALLOC/FREE shoudl be there. [akpm@linux-foundation.org: cleanups & tweaks] Tested-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Miao Xie <miaox@cn.fujitsu.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Paul Menage <menage@google.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: David Rientjes <rientjes@google.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16page allocator: do not check NUMA node ID when the caller knows the node is ↵Mel Gorman
valid Callers of alloc_pages_node() can optionally specify -1 as a node to mean "allocate from the current node". However, a number of the callers in fast paths know for a fact their node is valid. To avoid a comparison and branch, this patch adds alloc_pages_exact_node() that only checks the nid with VM_BUG_ON(). Callers that know their node is valid are then converted. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Paul Mundt <lethal@linux-sh.org> [for the SLOB NUMA bits] Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16cpuset,mm: update tasks' mems_allowed in timeMiao Xie
Fix allocating page cache/slab object on the unallowed node when memory spread is set by updating tasks' mems_allowed after its cpuset's mems is changed. In order to update tasks' mems_allowed in time, we must modify the code of memory policy. Because the memory policy is applied in the process's context originally. After applying this patch, one task directly manipulates anothers mems_allowed, and we use alloc_lock in the task_struct to protect mems_allowed and memory policy of the task. But in the fast path, we didn't use lock to protect them, because adding a lock may lead to performance regression. But if we don't add a lock,the task might see no nodes when changing cpuset's mems_allowed to some non-overlapping set. In order to avoid it, we set all new allowed nodes, then clear newly disallowed ones. [lee.schermerhorn@hp.com: The rework of mpol_new() to extract the adjusting of the node mask to apply cpuset and mpol flags "context" breaks set_mempolicy() and mbind() with MPOL_PREFERRED and a NULL nodemask--i.e., explicit local allocation. Fix this by adding the check for MPOL_PREFERRED and empty node mask to mpol_new_mpolicy(). Remove the now unneeded 'nodes = NULL' from mpol_new(). Note that mpol_new_mempolicy() is always called with a non-NULL 'nodes' parameter now that it has been removed from mpol_new(). Therefore, we don't need to test nodes for NULL before testing it for 'empty'. However, just to be extra paranoid, add a VM_BUG_ON() to verify this assumption.] [lee.schermerhorn@hp.com: I don't think the function name 'mpol_new_mempolicy' is descriptive enough to differentiate it from mpol_new(). This function applies cpuset set context, usually constraining nodes to those allowed by the cpuset. However, when the 'RELATIVE_NODES flag is set, it also translates the nodes. So I settled on 'mpol_set_nodemask()', because the comment block for mpol_new() mentions that we need to call this function to "set nodes". Some additional minor line length, whitespace and typo cleanup.] Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Paul Menage <menage@google.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-14[CVE-2009-0029] System call wrappers part 28Heiko Carstens
2008-11-14Merge branch 'master' into nextJames Morris
Conflicts: security/keys/internal.h security/keys/process_keys.c security/keys/request_key.c Fixed conflicts above by using the non 'tsk' versions. Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Use RCU to access another task's creds and to release a task's own credsDavid Howells
Use RCU to access another task's creds and to release a task's own creds. This means that it will be possible for the credentials of a task to be replaced without another task (a) requiring a full lock to read them, and (b) seeing deallocated memory. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Separate task security context from task_structDavid Howells
Separate the task security context from task_struct. At this point, the security data is temporarily embedded in the task_struct with two pointers pointing to it. Note that the Alpha arch is altered as it refers to (E)UID and (E)GID in entry.S via asm-offsets. With comment fixes Signed-off-by: Marc Dionne <marc.c.dionne@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
