commit 68711a746345c44ae00c64d8dbac6a9ce13ac54a upstream.
Memory migration uses a callback defined by the caller to determine how to
allocate destination pages. When migration fails for a source page,
however, it frees the destination page back to the system.
This patch adds a memory migration callback defined by the caller to
determine how to free destination pages. If a caller, such as memory
compaction, builds its own freelist for migration targets, this can reuse
already freed memory instead of scanning additional memory.
If the caller provides a function to handle freeing of destination pages,
it is called when page migration fails. If the caller passes NULL then
freeing back to the system will be handled as usual. This patch
introduces no functional change.
Signed-off-by: David Rientjes <rientjes@google.com>
Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
commit d26914d11751b23ca2e8747725f2cae10c2f2c1b upstream.
Since put_mems_allowed() is strictly optional, its a seqcount retry, we
don't need to evaluate the function if the allocation was in fact
successful, saving a smp_rmb some loads and comparisons on some relative
fast-paths.
Since the naming, get/put_mems_allowed() does suggest a mandatory
pairing, rename the interface, as suggested by Mel, to resemble the
seqcount interface.
This gives us: read_mems_allowed_begin() and read_mems_allowed_retry(),
where it is important to note that the return value of the latter call
is inverted from its previous incarnation.
commit 391acf970d21219a2a5446282d3b20eace0c0d7a upstream.
When runing with the kernel(3.15-rc7+), the follow bug occurs:
[ 9969.258987] BUG: sleeping function called from invalid context at kernel/locking/mutex.c:586
[ 9969.359906] in_atomic(): 1, irqs_disabled(): 0, pid: 160655, name: python
[ 9969.441175] INFO: lockdep is turned off.
[ 9969.488184] CPU: 26 PID: 160655 Comm: python Tainted: G A 3.15.0-rc7+ #85
[ 9969.581032] Hardware name: FUJITSU-SV PRIMEQUEST 1800E/SB, BIOS PRIMEQUEST 1000 Series BIOS Version 1.39 11/16/2012
[ 9969.706052] ffffffff81a20e60 ffff8803e941fbd0 ffffffff8162f523 ffff8803e941fd18
[ 9969.795323] ffff8803e941fbe0 ffffffff8109995a ffff8803e941fc58 ffffffff81633e6c
[ 9969.884710] ffffffff811ba5dc ffff880405c6b480 ffff88041fdd90a0 0000000000002000
[ 9969.974071] Call Trace:
[ 9970.003403] [<ffffffff8162f523>] dump_stack+0x4d/0x66
[ 9970.065074] [<ffffffff8109995a>] __might_sleep+0xfa/0x130
[ 9970.130743] [<ffffffff81633e6c>] mutex_lock_nested+0x3c/0x4f0
[ 9970.200638] [<ffffffff811ba5dc>] ? kmem_cache_alloc+0x1bc/0x210
[ 9970.272610] [<ffffffff81105807>] cpuset_mems_allowed+0x27/0x140
[ 9970.344584] [<ffffffff811b1303>] ? __mpol_dup+0x63/0x150
[ 9970.409282] [<ffffffff811b1385>] __mpol_dup+0xe5/0x150
[ 9970.471897] [<ffffffff811b1303>] ? __mpol_dup+0x63/0x150
[ 9970.536585] [<ffffffff81068c86>] ? copy_process.part.23+0x606/0x1d40
[ 9970.613763] [<ffffffff810bf28d>] ? trace_hardirqs_on+0xd/0x10
[ 9970.683660] [<ffffffff810ddddf>] ? monotonic_to_bootbased+0x2f/0x50
[ 9970.759795] [<ffffffff81068cf0>] copy_process.part.23+0x670/0x1d40
[ 9970.834885] [<ffffffff8106a598>] do_fork+0xd8/0x380
[ 9970.894375] [<ffffffff81110e4c>] ? __audit_syscall_entry+0x9c/0xf0
[ 9970.969470] [<ffffffff8106a8c6>] SyS_clone+0x16/0x20
[ 9971.030011] [<ffffffff81642009>] stub_clone+0x69/0x90
[ 9971.091573] [<ffffffff81641c29>] ? system_call_fastpath+0x16/0x1b
The cause is that cpuset_mems_allowed() try to take
mutex_lock(&callback_mutex) under the rcu_read_lock(which was hold in
__mpol_dup()). And in cpuset_mems_allowed(), the access to cpuset is
under rcu_read_lock, so in __mpol_dup, we can reduce the rcu_read_lock
protection region to protect the access to cpuset only in
current_cpuset_is_being_rebound(). So that we can avoid this bug.
This patch is a temporary solution that just addresses the bug
mentioned above, can not fix the long-standing issue about cpuset.mems
rebinding on fork():
"When the forker's task_struct is duplicated (which includes
->mems_allowed) and it races with an update to cpuset_being_rebound
in update_tasks_nodemask() then the task's mems_allowed doesn't get
updated. And the child task's mems_allowed can be wrong if the
cpuset's nodemask changes before the child has been added to the
cgroup's tasklist."
Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com>
Acked-by: Li Zefan <lizefan@huawei.com>
commit d05f0cdcbe6388723f1900c549b4850360545201 upstream.
In v2.6.34 commit 9d8cebd4bcd7 ("mm: fix mbind vma merge problem")
introduced vma merging to mbind(), but it should have also changed the
convention of passing start vma from queue_pages_range() (formerly
check_range()) to new_vma_page(): vma merging may have already freed
that structure, resulting in BUG at mm/mempolicy.c:1738 and probably
worse crashes.
Fixes: 9d8cebd4bcd7 ("mm: fix mbind vma merge problem")
Reported-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Tested-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Acked-by: Christoph Lameter <cl@linux.com>
Cc: Minchan Kim <minchan.kim@gmail.com>
commit d4c54919ed86302094c0ca7d48a8cbd4ee753e92 upstream.
The age table walker doesn't check non-present hugetlb entry in common
path, so hugetlb_entry() callbacks must check it. The reason for this
behavior is that some callers want to handle it in its own way.
[ I think that reason is bogus, btw - it should just do what the regular
code does, which is to call the "pte_hole()" function for such hugetlb
entries - Linus]
However, some callers don't check it now, which causes unpredictable
result, for example when we have a race between migrating hugepage and
reading /proc/pid/numa_maps. This patch fixes it by adding !pte_present
checks on buggy callbacks.
This bug exists for years and got visible by introducing hugepage
migration.
ChangeLog v2:
- fix if condition (check !pte_present() instead of pte_present())
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
[ Backported to 3.15. Signed-off-by: Josh Boyer <jwboyer@fedoraproject.org> ]
As a result of commit 5606e3877ad8 ("mm: numa: Migrate on reference
policy"), /proc/<pid>/numa_maps prints the mempolicy for any <pid> as
"prefer:N" for the local node, N, of the process reading the file.
This should only be printed when the mempolicy of <pid> is
MPOL_PREFERRED for node N.
If the process is actually only using the default mempolicy for local
node allocation, make sure "default" is printed as expected.
Reported-by: Robert Lippert <rlippert@google.com>
Cc: <stable@vger.kernel.org> [3.7+]
A few printk(KERN_*'s have snuck in there.
The command line parsing takes place before jump labels are initialised
which generates a warning if numa_balancing= is specified and
CONFIG_JUMP_LABEL is set.
On older kernels before commit c4b2c0c5f647 ("static_key: WARN on usage
before jump_label_init was called") the kernel would have crashed. This
patch enables automatic numa balancing later in the initialisation
process if numa_balancing= is specified.
Cc: stable <stable@vger.kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull powerpc updates from Ben Herrenschmidt:
"So here's my next branch for powerpc. A bit late as I was on vacation
last week. It's mostly the same stuff that was in next already, I
just added two patches today which are the wiring up of lockref for
powerpc, which for some reason fell through the cracks last time and
is trivial.
The highlights are, in addition to a bunch of bug fixes:
- Reworked Machine Check handling on kernels running without a
hypervisor (or acting as a hypervisor). Provides hooks to handle
some errors in real mode such as TLB errors, handle SLB errors,
etc...
- Support for retrieving memory error information from the service
processor on IBM servers running without a hypervisor and routing
them to the memory poison infrastructure.
- _PAGE_NUMA support on server processors
- 32-bit BookE relocatable kernel support
- FSL e6500 hardware tablewalk support
- A bunch of new/revived board support
- FSL e6500 deeper idle states and altivec powerdown support
You'll notice a generic mm change here, it has been acked by the
relevant authorities and is a pre-req for our _PAGE_NUMA support"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (121 commits)
powerpc: Implement arch_spin_is_locked() using arch_spin_value_unlocked()
powerpc: Add support for the optimised lockref implementation
powerpc/powernv: Call OPAL sync before kexec'ing
powerpc/eeh: Escalate error on non-existing PE
powerpc/eeh: Handle multiple EEH errors
powerpc: Fix transactional FP/VMX/VSX unavailable handlers
powerpc: Don't corrupt transactional state when using FP/VMX in kernel
powerpc: Reclaim two unused thread_info flag bits
powerpc: Fix races with irq_work
Move precessing of MCE queued event out from syscall exit path.
pseries/cpuidle: Remove redundant call to ppc64_runlatch_off() in cpu idle routines
powerpc: Make add_system_ram_resources() __init
powerpc: add SATA_MV to ppc64_defconfig
powerpc/powernv: Increase candidate fw image size
powerpc: Add debug checks to catch invalid cpu-to-node mappings
powerpc: Fix the setup of CPU-to-Node mappings during CPU online
powerpc/iommu: Don't detach device without IOMMU group
powerpc/eeh: Hotplug improvement
powerpc/eeh: Call opal_pci_reinit() on powernv for restoring config space
powerpc/eeh: Add restore_config operation
Commit 11c731e81bb0 ("mm/mempolicy: fix !vma in new_vma_page()") has
removed BUG_ON(!vma) from new_vma_page which is partially correct
because page_address_in_vma will return EFAULT for non-linear mappings
and at least shared shmem might be mapped this way.
The patch also tried to prevent NULL ptr for hugetlb pages which is not
correct AFAICS because hugetlb pages cannot be mapped as VM_NONLINEAR
and other conditions in page_address_in_vma seem to be legit and catch
real bugs.
This patch restores BUG_ON for PageHuge to catch potential issues when
the to-be-migrated page is not setup properly.
Reviewed-by: Bob Liu <bob.liu@oracle.com>
Cc: Sasha Levin <sasha.levin@oracle.com>
Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Add a working sysctl to enable/disable automatic numa memory balancing
at runtime.
This allows us to track down performance problems with this feature and
is generally a good idea.
This was possible earlier through debugfs, but only with special
debugging options set. Also fix the boot message.
[akpm@linux-foundation.org: s/sched_numa_balancing/sysctl_numa_balancing/]
BUG_ON(!vma) assumption is introduced by commit 0bf598d863e3 ("mbind:
add BUG_ON(!vma) in new_vma_page()"), however, even if
address = __vma_address(page, vma);
and
vma->start < address < vma->end
page_address_in_vma() may still return -EFAULT because of many other
conditions in it. As a result the while loop in new_vma_page() may end
with vma=NULL.
This patch revert the commit and also fix the potential dereference NULL
pointer reported by Dan.
http://marc.info/?l=linux-mm&m=137689530323257&w=2
kernel BUG at mm/mempolicy.c:1204!
invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
CPU: 3 PID: 7056 Comm: trinity-child3 Not tainted 3.13.0-rc3+ #2
task: ffff8801ca5295d0 ti: ffff88005ab20000 task.ti: ffff88005ab20000
RIP: new_vma_page+0x70/0x90
RSP: 0000:ffff88005ab21db0 EFLAGS: 00010246
RAX: fffffffffffffff2 RBX: 0000000000000000 RCX: 0000000000000000
RDX: 0000000008040075 RSI: ffff8801c3d74600 RDI: ffffea00079a8b80
RBP: ffff88005ab21dc8 R08: 0000000000000004 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: fffffffffffffff2
R13: ffffea00079a8b80 R14: 0000000000400000 R15: 0000000000400000
FS: 00007ff49c6f4740(0000) GS:ffff880244e00000(0000) knlGS:0000000000000000
CR2: 00007ff49c68f994 CR3: 000000005a205000 CR4: 00000000001407e0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Stack:
ffffea00079a8b80 ffffea00079a8bc0 ffffea00079a8ba0 ffff88005ab21e50
ffffffff811adc7a 0000000000000000 ffff8801ca5295d0 0000000464e224f8
0000000000000000 0000000000000002 0000000000000000 ffff88020ce75c00
Call Trace:
migrate_pages+0x12a/0x850
SYSC_mbind+0x513/0x6a0
SyS_mbind+0xe/0x10
ia32_do_call+0x13/0x13
Code: 85 c0 75 2f 4c 89 e1 48 89 da 31 f6 bf da 00 02 00 65 44 8b 04 25 08 f7 1c 00 e8 ec fd ff ff 5b 41 5c 41 5d 5d c3 0f 1f 44 00 00 <0f> 0b 66 0f 1f 44 00 00 4c 89 e6 48 89 df ba 01 00 00 00 e8 48
RIP [<ffffffff8119f200>] new_vma_page+0x70/0x90
RSP <ffff88005ab21db0>
Signed-off-by: Wanpeng Li <liwanp@linux.vnet.ibm.com>
Reported-by: Dave Jones <davej@redhat.com>
queue_pages_range() isolates hugetlbfs pages and putback_lru_pages()
can't handle these. We should change it to putback_movable_pages().
Naoya said that it is worth going into stable, because it can break
in-use hugepage list.
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Acked-by: Rafael Aquini <aquini@redhat.com>
Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
Cc: <stable@vger.kernel.org> [3.12.x]
change_prot_numa should work even if _PAGE_NUMA != _PAGE_PROTNONE.
On archs like ppc64 that don't use _PAGE_PROTNONE and also have
a separate page table outside linux pagetable, we just need to
make sure that when calling change_prot_numa we flush the
hardware page table entry so that next page access result in a numa
fault.
We still need to make sure we use the numa faulting logic only
when CONFIG_NUMA_BALANCING is set. This implies the migrate-on-fault
(Lazy migration) via mbind will only work if CONFIG_NUMA_BALANCING
is set.
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Fengguang Wu reports that compiling mm/mempolicy.c results in a warning:
mm/mempolicy.c: In function 'mpol_to_str':
mm/mempolicy.c:2878:2: error: format not a string literal and no format arguments
Kees says this is because he is using -Wformat-security.
Silence the warning.
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Suggested-by: Kees Cook <keescook@chromium.org>
Hugetlb supports multiple page sizes. We use split lock only for PMD
level, but not for PUD.
Tested-by: Alex Thorlton <athorlton@sgi.com>
Cc: "Eric W . Biederman" <ebiederm@xmission.com>
Cc: "Paul E . McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Dave Jones <davej@redhat.com>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: Robin Holt <robinmholt@gmail.com>
Cc: Sedat Dilek <sedat.dilek@gmail.com>
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Use more appropriate NUMA_NO_NODE instead of -1
Signed-off-by: Jianguo Wu <wujianguo@huawei.com>
Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Acked-by: David Rientjes <rientjes@google.com>
mpol_to_str() should not fail. Currently, it either fails because the
string buffer is too small or because a string hasn't been defined for a
mempolicy mode.
If a new mempolicy mode is introduced and no string is defined for it,
just warn and return "unknown".
If the buffer is too small, just truncate the string and return, the
same behavior as snprintf().
This also fixes a bug where there was no NULL-byte termination when doing
*p++ = '=' and *p++ ':' and maxlen has been reached.
Cc: Chen Gang <gang.chen@asianux.com>
Shared faults can lead to lots of unnecessary page migrations,
slowing down the system, and causing private faults to hit the
per-pgdat migration ratelimit.
This patch adds sysctl numa_balancing_migrate_deferred, which specifies
how many shared page migrations to skip unconditionally, after each page
migration that is skipped because it is a shared fault.
This reduces the number of page migrations back and forth in
shared fault situations. It also gives a strong preference to
the tasks that are already running where most of the memory is,
and to moving the other tasks to near the memory.
Testing this with a much higher scan rate than the default
still seems to result in fewer page migrations than before.
Memory seems to be somewhat better consolidated than previously,
with multi-instance specjbb runs on a 4 node system.
Signed-off-by: Rik van Riel <riel@redhat.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/1381141781-10992-62-git-send-email-mgorman@suse.de
With the scan rate code working (at least for multi-instance specjbb),
the large hammer that is "sched: Do not migrate memory immediately after
switching node" can be replaced with something smarter. Revert temporarily
migration disabling and all traces of numa_migrate_seq.
Link: http://lkml.kernel.org/r/1381141781-10992-61-git-send-email-mgorman@suse.de
Change the per page last fault tracking to use cpu,pid instead of
nid,pid. This will allow us to try and lookup the alternate task more
easily. Note that even though it is the cpu that is store in the page
flags that the mpol_misplaced decision is still based on the node.
Link: http://lkml.kernel.org/r/1381141781-10992-43-git-send-email-mgorman@suse.de
[ Fixed build failure on 32-bit systems. ]
There is a 90% regression observed with a large Oracle performance test
on a 4 node system. Profiles indicated that the overhead was due to
contention on sp_lock when looking up shared memory policies. These
policies do not have the appropriate flags to allow them to be
automatically balanced so trapping faults on them is pointless. This
patch skips VMAs that do not have MPOL_F_MOF set.
[riel@redhat.com: Initial patch]
Reported-and-tested-by: Joe Mario <jmario@redhat.com>
Link: http://lkml.kernel.org/r/1381141781-10992-32-git-send-email-mgorman@suse.de
The load balancer can move tasks between nodes and does not take NUMA
locality into account. With automatic NUMA balancing this may result in the
tasks working set being migrated to the new node. However, as the fault
buffer will still store faults from the old node the schduler may decide to
reset the preferred node and migrate the task back resulting in more
migrations.
The ideal would be that the scheduler did not migrate tasks with a heavy
memory footprint but this may result nodes being overloaded. We could
also discard the fault information on task migration but this would still
cause all the tasks working set to be migrated. This patch simply avoids
migrating the memory for a short time after a task is migrated.
Link: http://lkml.kernel.org/r/1381141781-10992-31-git-send-email-mgorman@suse.de
Ideally it would be possible to distinguish between NUMA hinting faults that
are private to a task and those that are shared. If treated identically
there is a risk that shared pages bounce between nodes depending on
the order they are referenced by tasks. Ultimately what is desirable is
that task private pages remain local to the task while shared pages are
interleaved between sharing tasks running on different nodes to give good
average performance. This is further complicated by THP as even
applications that partition their data may not be partitioning on a huge
page boundary.
To start with, this patch assumes that multi-threaded or multi-process
applications partition their data and that in general the private accesses
are more important for cpu->memory locality in the general case. Also,
no new infrastructure is required to treat private pages properly but
interleaving for shared pages requires additional infrastructure.
To detect private accesses the pid of the last accessing task is required
but the storage requirements are a high. This patch borrows heavily from
Ingo Molnar's patch "numa, mm, sched: Implement last-CPU+PID hash tracking"
to encode some bits from the last accessing task in the page flags as
well as the node information. Collisions will occur but it is better than
just depending on the node information. Node information is then used to
determine if a page needs to migrate. The PID information is used to detect
private/shared accesses. The preferred NUMA node is selected based on where
the maximum number of approximately private faults were measured. Shared
faults are not taken into consideration for a few reasons.
First, if there are many tasks sharing the page then they'll all move
towards the same node. The node will be compute overloaded and then
scheduled away later only to bounce back again. Alternatively the shared
tasks would just bounce around nodes because the fault information is
effectively noise. Either way accounting for shared faults the same as
private faults can result in lower performance overall.
The second reason is based on a hypothetical workload that has a small
number of very important, heavily accessed private pages but a large shared
array. The shared array would dominate the number of faults and be selected
as a preferred node even though it's the wrong decision.
The third reason is that multiple threads in a process will race each
other to fault the shared page making the fault information unreliable.
[ Fix complication error when !NUMA_BALANCING. ]
Link: http://lkml.kernel.org/r/1381141781-10992-30-git-send-email-mgorman@suse.de
new_vma_page() is called only by page migration called from do_mbind(),
where pages to be migrated are queued into a pagelist by
queue_pages_range(). queue_pages_range() confirms that a queued page
belongs to some vma, so !vma case is not supposed to be happen. This
patch adds BUG_ON() to catch this unexpected case.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
The function check_range() (and its family) is not well-named, because it
does not only checking something, but moving pages from list to list to do
page migration for them. So queue_pages_*range is more desirable name.
Cc: Hillf Danton <dhillf@gmail.com>
Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com>
Extend do_mbind() to handle vma with VM_HUGETLB set. We will be able to
migrate hugepage with mbind(2) after applying the enablement patch which
comes later in this series.
Acked-by: Andi Kleen <ak@linux.intel.com>
Acked-by: Hillf Danton <dhillf@gmail.com>
Extend check_range() to handle vma with VM_HUGETLB set. We will be able
to migrate hugepage with migrate_pages(2) after applying the enablement
patch which comes later in this series.
Note that for larger hugepages (covered by pud entries, 1GB for x86_64 for
example), we simply skip it now.
Note that using pmd_huge/pud_huge assumes that hugepages are pointed to by
pmd/pud. This is not true in some architectures implementing hugepage
with other mechanisms like ia64, but it's OK because pmd_huge/pud_huge
simply return 0 in such arch and page walker simply ignores such
hugepages.
If node == NUMA_NO_NODE, pol is NULL, we should return NULL instead of
do "if (!pol->mode)" check.
[akpm@linux-foundation.org: reorganise code]
Cc: Hanjun Guo <guohanjun@huawei.com>
Simple cleanup. Every user of vma_set_policy() does the same work, this
looks a bit annoying imho. And the new trivial helper which does
mpol_dup() + vma_set_policy() to simplify the callers.
vma_adjust() does vma_set_policy(vma, vma_policy(next)) and this
is doubly wrong:
1. This leaks vma->vm_policy if it is not NULL and not equal to
next->vm_policy.
This can happen if vma_merge() expands "area", not prev (case 8).
2. This sets the wrong policy if vma_merge() joins prev and area,
area is the vma the caller needs to update and it still has the
old policy.
Revert commit 1444f92c8498 ("mm: merging memory blocks resets
mempolicy") which introduced these problems.
Change mbind_range() to recheck mpol_equal() after vma_merge() to fix
the problem that commit tried to address.
Cc: Steven T Hampson <steven.t.hampson@intel.com>
Currently, n_new is wrongly initialized. start and end parameter are
inverted. Let's fix it.
n->end is accessed in sp_insert(). Thus it should be update
before calling sp_insert(). This mistake may make kernel panic.
Signed-off-by: Hillf Danton <dhillf@gmail.com>
Make a sweep through mm/ and convert code that uses -1 directly to using
the more appropriate NUMA_NO_NODE.
Reviewed-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
No functional change, but the only purpose of the offlining argument to
migrate_pages() etc, was to ensure that __unmap_and_move() could migrate a
KSM page for memory hotremove (which took ksm_thread_mutex) but not for
other callers. Now all cases are safe, remove the arg.
Cc: Petr Holasek <pholasek@redhat.com>
Cc: Izik Eidus <izik.eidus@ravellosystems.com>
Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Cc: KOSAKI Motohiro <kosaki.motohiro@gmail.com>
Migration of KSM pages is now safe: remove the PageKsm restrictions from
mempolicy.c and migrate.c.
But keep PageKsm out of __unmap_and_move()'s anon_vma contortions, which
are irrelevant to KSM: it looks as if that code was preventing hotremove
migration of KSM pages, unless they happened to be in swapcache.
There is some question as to whether enforcing a NUMA mempolicy migration
ought to migrate KSM pages, mapped into entirely unrelated processes; but
moving page_mapcount > 1 is only permitted with MPOL_MF_MOVE_ALL anyway,
and it seems reasonable to assume that you wouldn't set MADV_MERGEABLE on
any area where this is a worry.
The function names page_xchg_last_nid(), page_last_nid() and
reset_page_last_nid() were judged to be inconsistent so rename them to a
struct_field_op style pattern. As it looked jarring to have
reset_page_mapcount() and page_nid_reset_last() beside each other in
memmap_init_zone(), this patch also renames reset_page_mapcount() to
page_mapcount_reset(). There are others like init_page_count() but as
it is used throughout the arch code a rename would likely cause more
conflicts than it is worth.
[akpm@linux-foundation.org: fix zcache]
Suggested-by: Andrew Morton <akpm@linux-foundation.org>
is_valid_nodemask() was introduced by commit 19770b32609b ("mm: filter
based on a nodemask as well as a gfp_mask"). but it does not match its
comments, because it does not check the zone which > policy_zone.
Also in commit b377fd3982ad ("Apply memory policies to top two highest
zones when highest zone is ZONE_MOVABLE"), this commits told us, if
highest zone is ZONE_MOVABLE, we should also apply memory policies to
it. so ZONE_MOVABLE should be valid zone for policies.
is_valid_nodemask() need to be changed to match it.
Fix: check all zones, even its zoneid > policy_zone. Use
nodes_intersects() instead open code to check it.
Reported-by: Wen Congyang <wency@cn.fujitsu.com>
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
Cc: Jiang Liu <jiang.liu@huawei.com>
Cc: Jianguo Wu <wujianguo@huawei.com>
Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Sasha was fuzzing with trinity and reported the following problem:
BUG: sleeping function called from invalid context at kernel/mutex.c:269
in_atomic(): 1, irqs_disabled(): 0, pid: 6361, name: trinity-main
2 locks held by trinity-main/6361:
#0: (&mm->mmap_sem){++++++}, at: [<ffffffff810aa314>] __do_page_fault+0x1e4/0x4f0
#1: (&(&mm->page_table_lock)->rlock){+.+...}, at: [<ffffffff8122f017>] handle_pte_fault+0x3f7/0x6a0
Pid: 6361, comm: trinity-main Tainted: G W
3.7.0-rc2-next-20121024-sasha-00001-gd95ef01-dirty #74
Call Trace:
__might_sleep+0x1c3/0x1e0
mutex_lock_nested+0x29/0x50
mpol_shared_policy_lookup+0x2e/0x90
shmem_get_policy+0x2e/0x30
get_vma_policy+0x5a/0xa0
mpol_misplaced+0x41/0x1d0
handle_pte_fault+0x465/0x6a0
This was triggered by a different version of automatic NUMA balancing
but in theory the current version is vunerable to the same problem.
do_numa_page
-> numa_migrate_prep
-> mpol_misplaced
-> get_vma_policy
-> shmem_get_policy
It's very unlikely this will happen as shared pages are not marked
pte_numa -- see the page_mapcount() check in change_pte_range() -- but
it is possible.
To address this, this patch restores sp->lock as originally implemented
by Kosaki Motohiro. In the path where get_vma_policy() is called, it
should not be calling sp_alloc() so it is not necessary to treat the PTL
specially.
Tested-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Remove the unused argument (formerly no_context) from mpol_parse_str()
and from mpol_to_str().
Recently I suggested using "mount -o remount,mpol=local /tmp" in NUMA
mempolicy testing. Very nasty. Reading /proc/mounts, /proc/pid/mounts
or /proc/pid/mountinfo may then corrupt one bit of kernel memory, often
in a page table (causing "Bad swap" or "Bad page map" warning or "Bad
pagetable" oops), sometimes in a vm_area_struct or rbnode or somewhere
worse. "mpol=prefer" and "mpol=prefer:Node" are equally toxic.
Recent NUMA enhancements are not to blame: this dates back to 2.6.35,
when commit e17f74af351c "mempolicy: don't call mpol_set_nodemask() when
no_context" skipped mpol_parse_str()'s call to mpol_set_nodemask(),
which used to initialize v.preferred_node, or set MPOL_F_LOCAL in flags.
With slab poisoning, you can then rely on mpol_to_str() to set the bit
for node 0x6b6b, probably in the next page above the caller's stack.
mpol_parse_str() is only called from shmem_parse_options(): no_context
is always true, so call it unused for now, and remove !no_context code.
Set v.nodes or v.preferred_node or MPOL_F_LOCAL as mpol_to_str() might
expect. Then mpol_to_str() can ignore its no_context argument also,
the mpol being appropriately initialized whether contextualized or not.
Rename its no_context unused too, and let subsequent patch remove them
(that's not needed for stable backporting, which would involve rejects).
I don't understand why MPOL_LOCAL is described as a pseudo-policy:
it's a reasonable policy which suffers from a confusing implementation
in terms of MPOL_PREFERRED with MPOL_F_LOCAL. I believe this would be
much more robust if MPOL_LOCAL were recognized in switch statements
throughout, MPOL_F_LOCAL deleted, and MPOL_PREFERRED use the (possibly
empty) nodes mask like everyone else, instead of its preferred_node
variant (I presume an optimization from the days before MPOL_LOCAL).
But that would take me too long to get right and fully tested.
Cc: stable@vger.kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/mel/linux-balancenuma
Pull Automatic NUMA Balancing bare-bones from Mel Gorman:
"There are three implementations for NUMA balancing, this tree
(balancenuma), numacore which has been developed in tip/master and
autonuma which is in aa.git.
In almost all respects balancenuma is the dumbest of the three because
its main impact is on the VM side with no attempt to be smart about
scheduling. In the interest of getting the ball rolling, it would be
desirable to see this much merged for 3.8 with the view to building
scheduler smarts on top and adapting the VM where required for 3.9.
The most recent set of comparisons available from different people are
mel: https://lkml.org/lkml/2012/12/9/108
mingo: https://lkml.org/lkml/2012/12/7/331
tglx: https://lkml.org/lkml/2012/12/10/437
srikar: https://lkml.org/lkml/2012/12/10/397
The results are a mixed bag. In my own tests, balancenuma does
reasonably well. It's dumb as rocks and does not regress against
mainline. On the other hand, Ingo's tests shows that balancenuma is
incapable of converging for this workloads driven by perf which is bad
but is potentially explained by the lack of scheduler smarts. Thomas'
results show balancenuma improves on mainline but falls far short of
numacore or autonuma. Srikar's results indicate we all suffer on a
large machine with imbalanced node sizes.
My own testing showed that recent numacore results have improved
dramatically, particularly in the last week but not universally.
We've butted heads heavily on system CPU usage and high levels of
migration even when it shows that overall performance is better.
There are also cases where it regresses. Of interest is that for
specjbb in some configurations it will regress for lower numbers of
warehouses and show gains for higher numbers which is not reported by
the tool by default and sometimes missed in treports. Recently I
reported for numacore that the JVM was crashing with
NullPointerExceptions but currently it's unclear what the source of
this problem is. Initially I thought it was in how numacore batch
handles PTEs but I'm no longer think this is the case. It's possible
numacore is just able to trigger it due to higher rates of migration.
These reports were quite late in the cycle so I/we would like to start
with this tree as it contains much of the code we can agree on and has
not changed significantly over the last 2-3 weeks."
* tag 'balancenuma-v11' of git://git.kernel.org/pub/scm/linux/kernel/git/mel/linux-balancenuma: (50 commits)
mm/rmap, migration: Make rmap_walk_anon() and try_to_unmap_anon() more scalable
mm/rmap: Convert the struct anon_vma::mutex to an rwsem
mm: migrate: Account a transhuge page properly when rate limiting
mm: numa: Account for failed allocations and isolations as migration failures
mm: numa: Add THP migration for the NUMA working set scanning fault case build fix
mm: numa: Add THP migration for the NUMA working set scanning fault case.
mm: sched: numa: Delay PTE scanning until a task is scheduled on a new node
mm: sched: numa: Control enabling and disabling of NUMA balancing if !SCHED_DEBUG
mm: sched: Adapt the scanning rate if a NUMA hinting fault does not migrate
mm: numa: Use a two-stage filter to restrict pages being migrated for unlikely task<->node relationships
mm: numa: migrate: Set last_nid on newly allocated page
mm: numa: split_huge_page: Transfer last_nid on tail page
mm: numa: Introduce last_nid to the page frame
sched: numa: Slowly increase the scanning period as NUMA faults are handled
mm: numa: Rate limit setting of pte_numa if node is saturated
mm: numa: Rate limit the amount of memory that is migrated between nodes
mm: numa: Structures for Migrate On Fault per NUMA migration rate limiting
mm: numa: Migrate pages handled during a pmd_numa hinting fault
mm: numa: Migrate on reference policy
N_HIGH_MEMORY stands for the nodes that has normal or high memory.
N_MEMORY stands for the nodes that has any memory.
The code here need to handle with the nodes which have memory, we should
use N_MEMORY instead.
Signed-off-by: Wen Congyang <wency@cn.fujitsu.com>
Cc: Lin Feng <linfeng@cn.fujitsu.com>
Pass vma instead of mm and add address parameter.
In most cases we already have vma on the stack. We provides
split_huge_page_pmd_mm() for few cases when we have mm, but not vma.
This change is preparation to huge zero pmd splitting implementation.
Cc: "H. Peter Anvin" <hpa@linux.intel.com>
Remove some duplicate code and simplify alloc_pages_vma(). No functional
change.
This patch adds Kconfig options and kernel parameters to allow the
enabling and disabling of automatic NUMA balancing. The existance
of such a switch was and is very important when debugging problems
related to transparent hugepages and we should have the same for
automatic NUMA placement.
Note: This two-stage filter was taken directly from the sched/numa patch
"sched, numa, mm: Add the scanning page fault machinery" but is
only a partial extraction. As the end result is not necessarily
recognisable, the signed-offs-by had to be removed. Will be added
back if requested.
While it is desirable that all threads in a process run on its home
node, this is not always possible or necessary. There may be more
threads than exist within the node or the node might over-subscribed
with unrelated processes.
This can cause a situation whereby a page gets migrated off its home
node because the threads clearing pte_numa were running off-node. This
patch uses page->last_nid to build a two-stage filter before pages get
migrated to avoid problems with short or unlikely task<->node
relationships.
This is the simplest possible policy that still does something of note.
When a pte_numa is faulted, it is moved immediately. Any replacement
policy must at least do better than this and in all likelihood this
policy regresses normal workloads.
It is tricky to quantify the basic cost of automatic NUMA placement in a
meaningful manner. This patch adds some vmstats that can be used as part
of a basic costing model.
u = basic unit = sizeof(void *)
Ca = cost of struct page access = sizeof(struct page) / u
Cpte = Cost PTE access = Ca
Cupdate = Cost PTE update = (2 * Cpte) + (2 * Wlock)
where Cpte is incurred twice for a read and a write and Wlock
is a constant representing the cost of taking or releasing a
lock
Cnumahint = Cost of a minor page fault = some high constant e.g. 1000
Cpagerw = Cost to read or write a full page = Ca + PAGE_SIZE/u
Ci = Cost of page isolation = Ca + Wi
where Wi is a constant that should reflect the approximate cost
of the locking operation
Cpagecopy = Cpagerw + (Cpagerw * Wnuma) + Ci + (Ci * Wnuma)
where Wnuma is the approximate NUMA factor. 1 is local. 1.2
would imply that remote accesses are 20% more expensive
Balancing cost = Cpte * numa_pte_updates +
Cnumahint * numa_hint_faults +
Ci * numa_pages_migrated +
Cpagecopy * numa_pages_migrated
Note that numa_pages_migrated is used as a measure of how many pages
were isolated even though it would miss pages that failed to migrate. A
vmstat counter could have been added for it but the isolation cost is
pretty marginal in comparison to the overall cost so it seemed overkill.
The ideal way to measure automatic placement benefit would be to count
the number of remote accesses versus local accesses and do something like
benefit = (remote_accesses_before - remove_access_after) * Wnuma
but the information is not readily available. As a workload converges, the
expection would be that the number of remote numa hints would reduce to 0.
convergence = numa_hint_faults_local / numa_hint_faults
where this is measured for the last N number of
numa hints recorded. When the workload is fully
converged the value is 1.
This can measure if the placement policy is converging and how fast it is
doing it.
The use of MPOL_NOOP and MPOL_MF_LAZY to allow an application to
explicitly request lazy migration is a good idea but the actual
API has not been well reviewed and once released we have to support it.
For now this patch prevents an application using the services. This
will need to be revisited.
