path: root/mm/migrate.c
2011-10-19mm: fix race between mremap and removing migration entryHugh Dickins
I don't usually pay much attention to the stale "? " addresses in stack backtraces, but this lucky report from Pawel Sikora hints that mremap's move_ptes() has inadequate locking against page migration. 3.0 BUG_ON(!PageLocked(p)) in migration_entry_to_page(): kernel BUG at include/linux/swapops.h:105! RIP: 0010:[<ffffffff81127b76>] [<ffffffff81127b76>] migration_entry_wait+0x156/0x160 [<ffffffff811016a1>] handle_pte_fault+0xae1/0xaf0 [<ffffffff810feee2>] ? __pte_alloc+0x42/0x120 [<ffffffff8112c26b>] ? do_huge_pmd_anonymous_page+0xab/0x310 [<ffffffff81102a31>] handle_mm_fault+0x181/0x310 [<ffffffff81106097>] ? vma_adjust+0x537/0x570 [<ffffffff81424bed>] do_page_fault+0x11d/0x4e0 [<ffffffff81109a05>] ? do_mremap+0x2d5/0x570 [<ffffffff81421d5f>] page_fault+0x1f/0x30 mremap's down_write of mmap_sem, together with i_mmap_mutex or lock, and pagetable locks, were good enough before page migration (with its requirement that every migration entry be found) came in, and enough while migration always held mmap_sem; but not enough nowadays, when there's memory hotremove and compaction. The danger is that move_ptes() lets a migration entry dodge around behind remove_migration_pte()'s back, so it's in the old location when looking at the new, then in the new location when looking at the old. Either mremap's move_ptes() must additionally take anon_vma lock(), or migration's remove_migration_pte() must stop peeking for is_swap_entry() before it takes pagetable lock. Consensus chooses the latter: we prefer to add overhead to migration than to mremapping, which gets used by JVMs and by exec stack setup. Reported-and-tested-by: Paweł Sikora <pluto@agmk.net> Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Mel Gorman <mgorman@suse.de> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-16migrate: don't account swapcache as shmemAndrea Arcangeli
swapcache will reach the below code path in migrate_page_move_mapping, and swapcache is accounted as NR_FILE_PAGES but it's not accounted as NR_SHMEM. Hugh pointed out we must use PageSwapCache instead of comparing mapping to &swapper_space, to avoid build failure with CONFIG_SWAP=n. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: use refcounts for page_lock_anon_vma()Peter Zijlstra
Convert page_lock_anon_vma() over to use refcounts. This is done to prepare for the conversion of anon_vma from spinlock to mutex. Sadly this inceases the cost of page_lock_anon_vma() from one to two atomics, a follow up patch addresses this, lets keep that simple for now. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Miller <davem@davemloft.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Tony Luck <tony.luck@intel.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23memcg: fix ugly initialization of return value is in callerKAMEZAWA Hiroyuki
Remove initialization of vaiable in caller of memory cgroup function. Actually, it's return value of memcg function but it's initialized in caller. Some memory cgroup uses following style to bring the result of start function to the end function for avoiding races. mem_cgroup_start_A(&(*ptr)) /* Something very complicated can happen here. */ mem_cgroup_end_A(*ptr) In some calls, *ptr should be initialized to NULL be caller. But it's ugly. This patch fixes that *ptr is initialized by _start function. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22mm: compaction: Use async migration for __GFP_NO_KSWAPD and enforce no writebackAndrea Arcangeli
__GFP_NO_KSWAPD allocations are usually very expensive and not mandatory to succeed as they have graceful fallback. Waiting for I/O in those, tends to be overkill in terms of latencies, so we can reduce their latency by disabling sync migrate. Unfortunately, even with async migration it's still possible for the process to be blocked waiting for a request slot (e.g. get_request_wait in the block layer) when ->writepage is called. To prevent __GFP_NO_KSWAPD blocking, this patch prevents ->writepage being called on dirty page cache for asynchronous migration. Addresses https://bugzilla.kernel.org/show_bug.cgi?id=31142 [mel@csn.ul.ie: Avoid writebacks for NFS, retry locked pages, use bool] Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Arthur Marsh <arthur.marsh@internode.on.net> Cc: Clemens Ladisch <cladisch@googlemail.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Minchan Kim <minchan.kim@gmail.com> Reported-by: Alex Villacis Lasso <avillaci@ceibo.fiec.espol.edu.ec> Tested-by: Alex Villacis Lasso <avillaci@ceibo.fiec.espol.edu.ec> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22mm: rename drop_anon_vma() to put_anon_vma()Peter Zijlstra
The normal code pattern used in the kernel is: get/put. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Hugh Dickins <hughd@google.com> Reviewed-by: Rik van Riel <riel@redhat.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22mm: add replace_page_cache_page() functionMiklos Szeredi
This function basically does: remove_from_page_cache(old); page_cache_release(old); add_to_page_cache_locked(new); Except it does this atomically, so there's no possibility for the "add" to fail because of a race. If memory cgroups are enabled, then the memory cgroup charge is also moved from the old page to the new. This function is currently used by fuse to move pages into the page cache on read, instead of copying the page contents. [minchan.kim@gmail.com: add freepage() hook to replace_page_cache_page()] Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-25mm: grab rcu read lock in move_pages()Greg Thelen
The move_pages() usage of find_task_by_vpid() requires rcu_read_lock() to prevent free_pid() from reclaiming the pid. Without this patch, RCU warnings are printed in v2.6.38-rc4 move_pages() with: CONFIG_LOCKUP_DETECTOR=y CONFIG_PREEMPT=y CONFIG_LOCKDEP=y CONFIG_PROVE_LOCKING=y CONFIG_PROVE_RCU=y Previously, migrate_pages() went through a similar transformation replacing usage of tasklist_lock with rcu read lock: commit 55cfaa3cbdd29c4919ecb5fb8965c310f357e48c Author: Zeng Zhaoming <zengzm.kernel@gmail.com> Date: Thu Dec 2 14:31:13 2010 -0800 mm/mempolicy.c: add rcu read lock to protect pid structure commit 1e50df39f6e2c3a4a3394df62baa8a213df16c54 Author: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Date: Thu Jan 13 15:46:14 2011 -0800 mempolicy: remove tasklist_lock from migrate_pages Signed-off-by: Greg Thelen <gthelen@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Zeng Zhaoming <zengzm.kernel@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-02mm/migration: fix page corruption during hugepage migrationMinchan Kim
If migrate_huge_page by memory-failure fails , it calls put_page in itself to decrease page reference and caller of migrate_huge_page also calls putback_lru_pages. It can do double free of page so it can make page corruption on page holder. In addtion, clean of pages on caller is consistent behavior with migrate_pages by cf608ac19c ("mm: compaction: fix COMPACTPAGEFAILED counting"). Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Christoph Lameter <cl@linux.com> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-02mm: when migrate_pages returns 0, all pages must have been releasedAndrea Arcangeli
In some cases migrate_pages could return zero while still leaving a few pages in the pagelist (and some caller wouldn't notice it has to call putback_lru_pages after commit cf608ac19c9 ("mm: compaction: fix COMPACTPAGEFAILED counting")). Add one missing putback_lru_pages not added by commit cf608ac19c95 ("mm: compaction: fix COMPACTPAGEFAILED counting"). Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: Christoph Lameter <cl@linux.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-26mm: migration: clarify migrate_pages() commentMinchan Kim
Callers of migrate_pages should putback_lru_pages to return pages isolated to LRU or free list. Now comment is rather confusing. It says caller always have to call it. It is more clear to point out that the caller has to call it if migrate_pages's return value isn't zero. Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Cc: Christoph Lameter <cl@linux.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13memcg: fix memory migration of shmem swapcacheDaisuke Nishimura
In the current implementation mem_cgroup_end_migration() decides whether the page migration has succeeded or not by checking "oldpage->mapping". But if we are tring to migrate a shmem swapcache, the page->mapping of it is NULL from the begining, so the check would be invalid. As a result, mem_cgroup_end_migration() assumes the migration has succeeded even if it's not, so "newpage" would be freed while it's not uncharged. This patch fixes it by passing mem_cgroup_end_migration() the result of the page migration. Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13mm: fix hugepage migrationHugh Dickins
2.6.37 added an unmap_and_move_huge_page() for memory failure recovery, but its anon_vma handling was still based around the 2.6.35 conventions. Update it to use page_lock_anon_vma, get_anon_vma, page_unlock_anon_vma, drop_anon_vma in the same way as we're now changing unmap_and_move(). I don't particularly like to propose this for stable when I've not seen its problems in practice nor tested the solution: but it's clearly out of synch at present. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik van Riel <riel@redhat.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: "Jun'ichi Nomura" <j-nomura@ce.jp.nec.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: <stable@kernel.org> [2.6.37, 2.6.36] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13mm: fix migration hangs on anon_vma lockHugh Dickins
Increased usage of page migration in mmotm reveals that the anon_vma locking in unmap_and_move() has been deficient since 2.6.36 (or even earlier). Review at the time of f18194275c39835cb84563500995e0d503a32d9a ("mm: fix hang on anon_vma->root->lock") missed the issue here: the anon_vma to which we get a reference may already have been freed back to its slab (it is in use when we check page_mapped, but that can change), and so its anon_vma->root may be switched at any moment by reuse in anon_vma_prepare. Perhaps we could fix that with a get_anon_vma_unless_zero(), but let's not: just rely on page_lock_anon_vma() to do all the hard thinking for us, then we don't need any rcu read locking over here. In removing the rcu_unlock label: since PageAnon is a bit in page->mapping, it's impossible for a !page->mapping page to be anon; but insert VM_BUG_ON in case the implementation ever changes. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Hugh Dickins <hughd@google.com> Reviewed-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: "Jun'ichi Nomura" <j-nomura@ce.jp.nec.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: <stable@kernel.org> [2.6.37, 2.6.36] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13mm: migration: use rcu_dereference_protected when dereferencing the radix ↵Mel Gorman
tree slot during file page migration migrate_pages() -> unmap_and_move() only calls rcu_read_lock() for anonymous pages, as introduced by git commit 989f89c57e6361e7d16fbd9572b5da7d313b073d ("fix rcu_read_lock() in page migraton"). The point of the RCU protection there is part of getting a stable reference to anon_vma and is only held for anon pages as file pages are locked which is sufficient protection against freeing. However, while a file page's mapping is being migrated, the radix tree is double checked to ensure it is the expected page. This uses radix_tree_deref_slot() -> rcu_dereference() without the RCU lock held triggering the following warning. [ 173.674290] =================================================== [ 173.676016] [ INFO: suspicious rcu_dereference_check() usage. ] [ 173.676016] --------------------------------------------------- [ 173.676016] include/linux/radix-tree.h:145 invoked rcu_dereference_check() without protection! [ 173.676016] [ 173.676016] other info that might help us debug this: [ 173.676016] [ 173.676016] [ 173.676016] rcu_scheduler_active = 1, debug_locks = 0 [ 173.676016] 1 lock held by hugeadm/2899: [ 173.676016] #0: (&(&inode->i_data.tree_lock)->rlock){..-.-.}, at: [<c10e3d2b>] migrate_page_move_mapping+0x40/0x1ab [ 173.676016] [ 173.676016] stack backtrace: [ 173.676016] Pid: 2899, comm: hugeadm Not tainted 2.6.37-rc5-autobuild [ 173.676016] Call Trace: [ 173.676016] [<c128cc01>] ? printk+0x14/0x1b [ 173.676016] [<c1063502>] lockdep_rcu_dereference+0x7d/0x86 [ 173.676016] [<c10e3db5>] migrate_page_move_mapping+0xca/0x1ab [ 173.676016] [<c10e41ad>] migrate_page+0x23/0x39 [ 173.676016] [<c10e491b>] buffer_migrate_page+0x22/0x107 [ 173.676016] [<c10e48f9>] ? buffer_migrate_page+0x0/0x107 [ 173.676016] [<c10e425d>] move_to_new_page+0x9a/0x1ae [ 173.676016] [<c10e47e6>] migrate_pages+0x1e7/0x2fa This patch introduces radix_tree_deref_slot_protected() which calls rcu_dereference_protected(). Users of it must pass in the mapping->tree_lock that is protecting this dereference. Holding the tree lock protects against parallel updaters of the radix tree meaning that rcu_dereference_protected is allowable. [akpm@linux-foundation.org: remove unneeded casts] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Milton Miller <miltonm@bga.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: <stable@kernel.org> [2.6.37.early] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13thp: pmd_trans_huge migrate bugcheckAndrea Arcangeli
No pmd_trans_huge should ever materialize in migration ptes areas, because we split the hugepage before migration ptes are instantiated. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13mm: migration: cleanup migrate_pages API by matching types for offlining and ↵Mel Gorman
sync With the introduction of the boolean sync parameter, the API looks a little inconsistent as offlining is still an int. Convert offlining to a bool for the sake of being tidy. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13mm: migration: allow migration to operate asynchronously and avoid ↵Mel Gorman
synchronous compaction in the faster path Migration synchronously waits for writeback if the initial passes fails. Callers of memory compaction do not necessarily want this behaviour if the caller is latency sensitive or expects that synchronous migration is not going to have a significantly better success rate. This patch adds a sync parameter to migrate_pages() allowing the caller to indicate if wait_on_page_writeback() is allowed within migration or not. For reclaim/compaction, try_to_compact_pages() is first called asynchronously, direct reclaim runs and then try_to_compact_pages() is called synchronously as there is a greater expectation that it'll succeed. [akpm@linux-foundation.org: build/merge fix] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13mm: vmscan: reclaim order-0 and use compaction instead of lumpy reclaimMel Gorman
Lumpy reclaim is disruptive. It reclaims a large number of pages and ignores the age of the pages it reclaims. This can incur significant stalls and potentially increase the number of major faults. Compaction has reached the point where it is considered reasonably stable (meaning it has passed a lot of testing) and is a potential candidate for displacing lumpy reclaim. This patch introduces an alternative to lumpy reclaim whe compaction is available called reclaim/compaction. The basic operation is very simple - instead of selecting a contiguous range of pages to reclaim, a number of order-0 pages are reclaimed and then compaction is later by either kswapd (compact_zone_order()) or direct compaction (__alloc_pages_direct_compact()). [akpm@linux-foundation.org: fix build] [akpm@linux-foundation.org: use conventional task_struct naming] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-22mm/migrate.c: fix compilation errorMichal Nazarewicz
GCC complained about update_mmu_cache() not being defined in migrate.c. Including <asm/tlbflush.h> seems to solve the problem. Signed-off-by: Michal Nazarewicz <m.nazarewicz@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26mm: fix error reporting in move_pages() syscallGleb Natapov
The vma returned by find_vma does not necessarily include the target address. If this happens the code tries to follow a page outside of any vma and returns ENOENT instead of EFAULT. Signed-off-by: Gleb Natapov <gleb@redhat.com> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26mm: compaction: fix COMPACTPAGEFAILED countingMinchan Kim
Presently update_nr_listpages() doesn't have a role. That's because lists passed is always empty just after calling migrate_pages. The migrate_pages cleans up page list which have failed to migrate before returning by aaa994b3. [PATCH] page migration: handle freeing of pages in migrate_pages() Do not leave pages on the lists passed to migrate_pages(). Seems that we will not need any postprocessing of pages. This will simplify the handling of pages by the callers of migrate_pages(). At that time, we thought we don't need any postprocessing of pages. But the situation is changed. The compaction need to know the number of failed to migrate for COMPACTPAGEFAILED stat This patch makes new rule for caller of migrate_pages to call putback_lru_pages. So caller need to clean up the lists so it has a chance to postprocess the pages. [suggested by Christoph Lameter] Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Cc: Hugh Dickins <hughd@google.com> Cc: Andi Kleen <andi@firstfloor.org> Reviewed-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Wu Fengguang <fengguang.wu@intel.com> Acked-by: Christoph Lameter <cl@linux.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26writeback: remove nonblocking/encountered_congestion referencesWu Fengguang
This removes more dead code that was somehow missed by commit 0d99519efef (writeback: remove unused nonblocking and congestion checks). There are no behavior change except for the removal of two entries from one of the ext4 tracing interface. The nonblocking checks in ->writepages are no longer used because the flusher now prefer to block on get_request_wait() than to skip inodes on IO congestion. The latter will lead to more seeky IO. The nonblocking checks in ->writepage are no longer used because it's redundant with the WB_SYNC_NONE check. We no long set ->nonblocking in VM page out and page migration, because a) it's effectively redundant with WB_SYNC_NONE in current code b) it's old semantic of "Don't get stuck on request queues" is mis-behavior: that would skip some dirty inodes on congestion and page out others, which is unfair in terms of LRU age. Inspired by Christoph Hellwig. Thanks! Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: David Howells <dhowells@redhat.com> Cc: Sage Weil <sage@newdream.net> Cc: Steve French <sfrench@samba.org> Cc: Chris Mason <chris.mason@oracle.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-11Fix migration.c compilation on s390Andi Kleen
31bit s390 doesn't have huge pages and failed with: > mm/migrate.c: In function 'remove_migration_pte': > mm/migrate.c:143:3: error: implicit declaration of function 'pte_mkhuge' > mm/migrate.c:143:7: error: incompatible types when assigning to type 'pte_t' from type 'int' Put that code into a ifdef. Reported by Heiko Carstens Signed-off-by: Andi Kleen <ak@linux.intel.com>
2010-10-08hugetlb: hugepage migration coreNaoya Horiguchi
This patch extends page migration code to support hugepage migration. One of the potential users of this feature is soft offlining which is triggered by memory corrected errors (added by the next patch.) Todo: - there are other users of page migration such as memory policy, memory hotplug and memocy compaction. They are not ready for hugepage support for now. ChangeLog since v4: - define migrate_huge_pages() - remove changes on isolation/putback_lru_page() ChangeLog since v2: - refactor isolate/putback_lru_page() to handle hugepage - add comment about race on unmap_and_move_huge_page() ChangeLog since v1: - divide migration code path for hugepage - define routine checking migration swap entry for hugetlb - replace "goto" with "if/else" in remove_migration_pte() Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2010-08-09mm: extend KSM refcounts to the anon_vma rootRik van Riel
KSM reference counts can cause an anon_vma to exist after the processe it belongs to have already exited. Because the anon_vma lock now lives in the root anon_vma, we need to ensure that the root anon_vma stays around until after all the "child" anon_vmas have been freed. The obvious way to do this is to have a "child" anon_vma take a reference to the root in anon_vma_fork. When the anon_vma is freed at munmap or process exit, we drop the refcount in anon_vma_unlink and possibly free the root anon_vma. The KSM anon_vma reference count function also needs to be modified to deal with the possibility of freeing 2 levels of anon_vma. The easiest way to do this is to break out the KSM magic and make it generic. When compiling without CONFIG_KSM, this code is compiled out. Signed-off-by: Rik van Riel <riel@redhat.com> Tested-by: Larry Woodman <lwoodman@redhat.com> Acked-by: Larry Woodman <lwoodman@redhat.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Tested-by: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09mm: always lock the root (oldest) anon_vmaRik van Riel
Always (and only) lock the root (oldest) anon_vma whenever we do something in an anon_vma. The recently introduced anon_vma scalability is due to the rmap code scanning only the VMAs that need to be scanned. Many common operations still took the anon_vma lock on the root anon_vma, so always taking that lock is not expected to introduce any scalability issues. However, always taking the same lock does mean we only need to take one lock, which means rmap_walk on pages from any anon_vma in the vma is excluded from occurring during an munmap, expand_stack or other operation that needs to exclude rmap_walk and similar functions. Also add the proper locking to vma_adjust. Signed-off-by: Rik van Riel <riel@redhat.com> Tested-by: Larry Woodman <lwoodman@redhat.com> Acked-by: Larry Woodman <lwoodman@redhat.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09mm: change direct call of spin_lock(anon_vma->lock) to inline functionRik van Riel
Subsitute a direct call of spin_lock(anon_vma->lock) with an inline function doing exactly the same. This makes it easier to do the substitution to the root anon_vma lock in a following patch. We will deal with the handful of special locks (nested, dec_and_lock, etc) separately. Signed-off-by: Rik van Riel <riel@redhat.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Tested-by: Larry Woodman <lwoodman@redhat.com> Acked-by: Larry Woodman <lwoodman@redhat.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27memcg: fix mis-accounting of file mapped racy with migrationakpm@linux-foundation.org
FILE_MAPPED per memcg of migrated file cache is not properly updated, because our hook in page_add_file_rmap() can't know to which memcg FILE_MAPPED should be counted. Basically, this patch is for fixing the bug but includes some big changes to fix up other messes. Now, at migrating mapped file, events happen in following sequence. 1. allocate a new page. 2. get memcg of an old page. 3. charge ageinst a new page before migration. But at this point, no changes to new page's page_cgroup, no commit for the charge. (IOW, PCG_USED bit is not set.) 4. page migration replaces radix-tree, old-page and new-page. 5. page migration remaps the new page if the old page was mapped. 6. Here, the new page is unlocked. 7. memcg commits the charge for newpage, Mark the new page's page_cgroup as PCG_USED. Because "commit" happens after page-remap, we can count FILE_MAPPED at "5", because we should avoid to trust page_cgroup->mem_cgroup. if PCG_USED bit is unset. (Note: memcg's LRU removal code does that but LRU-isolation logic is used for helping it. When we overwrite page_cgroup->mem_cgroup, page_cgroup is not on LRU or page_cgroup->mem_cgroup is NULL.) We can lose file_mapped accounting information at 5 because FILE_MAPPED is updated only when mapcount changes 0->1. So we should catch it. BTW, historically, above implemntation comes from migration-failure of anonymous page. Because we charge both of old page and new page with mapcount=0, we can't catch - the page is really freed before remap. - migration fails but it's freed before remap or .....corner cases. New migration sequence with memcg is: 1. allocate a new page. 2. mark PageCgroupMigration to the old page. 3. charge against a new page onto the old page's memcg. (here, new page's pc is marked as PageCgroupUsed.) 4. page migration replaces radix-tree, page table, etc... 5. At remapping, new page's page_cgroup is now makrked as "USED" We can catch 0->1 event and FILE_MAPPED will be properly updated. And we can catch SWAPOUT event after unlock this and freeing this page by unmap() can be caught. 7. Clear PageCgroupMigration of the old page. So, FILE_MAPPED will be correctly updated. Then, for what MIGRATION flag is ? Without it, at migration failure, we may have to charge old page again because it may be fully unmapped. "charge" means that we have to dive into memory reclaim or something complated. So, it's better to avoid charge it again. Before this patch, __commit_charge() was working for both of the old/new page and fixed up all. But this technique has some racy condtion around FILE_MAPPED and SWAPOUT etc... Now, the kernel use MIGRATION flag and don't uncharge old page until the end of migration. I hope this change will make memcg's page migration much simpler. This page migration has caused several troubles. Worth to add a flag for simplification. Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Tested-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Reported-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25mm: compaction: memory compaction coreMel Gorman
This patch is the core of a mechanism which compacts memory in a zone by relocating movable pages towards the end of the zone. A single compaction run involves a migration scanner and a free scanner. Both scanners operate on pageblock-sized areas in the zone. The migration scanner starts at the bottom of the zone and searches for all movable pages within each area, isolating them onto a private list called migratelist. The free scanner starts at the top of the zone and searches for suitable areas and consumes the free pages within making them available for the migration scanner. The pages isolated for migration are then migrated to the newly isolated free pages. [aarcange@redhat.com: Fix unsafe optimisation] [mel@csn.ul.ie: do not schedule work on other CPUs for compaction] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Rik van Riel <riel@redhat.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25mm: migration: allow the migration of PageSwapCache pagesMel Gorman
PageAnon pages that are unmapped may or may not have an anon_vma so are not currently migrated. However, a swap cache page can be migrated and fits this description. This patch identifies page swap caches and allows them to be migrated but ensures that no attempt to made to remap the pages would would potentially try to access an already freed anon_vma. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25mm: migration: do not try to migrate unmapped anonymous pagesMel Gorman
rmap_walk_anon() was triggering errors in memory compaction that look like use-after-free errors. The problem is that between the page being isolated from the LRU and rcu_read_lock() being taken, the mapcount of the page dropped to 0 and the anon_vma gets freed. This can happen during memory compaction if pages being migrated belong to a process that exits before migration completes. Hence, the use-after-free race looks like 1. Page isolated for migration 2. Process exits 3. page_mapcount(page) drops to zero so anon_vma was no longer reliable 4. unmap_and_move() takes the rcu_lock but the anon_vma is already garbage 4. call try_to_unmap, looks up tha anon_vma and "locks" it but the lock is garbage. This patch checks the mapcount after the rcu lock is taken. If the mapcount is zero, the anon_vma is assumed to be freed and no further action is taken. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Rik van Riel <riel@redhat.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25mm: migration: share the anon_vma ref counts between KSM and page migrationMel Gorman
For clarity of review, KSM and page migration have separate refcounts on the anon_vma. While clear, this is a waste of memory. This patch gets KSM and page migration to share their toys in a spirit of harmony. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25mm: migration: take a reference to the anon_vma before migratingMel Gorman
This patchset is a memory compaction mechanism that reduces external fragmentation memory by moving GFP_MOVABLE pages to a fewer number of pageblocks. The term "compaction" was chosen as there are is a number of mechanisms that are not mutually exclusive that can be used to defragment memory. For example, lumpy reclaim is a form of defragmentation as was slub "defragmentation" (really a form of targeted reclaim). Hence, this is called "compaction" to distinguish it from other forms of defragmentation. In this implementation, a full compaction run involves two scanners operating within a zone - a migration and a free scanner. The migration scanner starts at the beginning of a zone and finds all movable pages within one pageblock_nr_pages-sized area and isolates them on a migratepages list. The free scanner begins at the end of the zone and searches on a per-area basis for enough free pages to migrate all the pages on the migratepages list. As each area is respectively migrated or exhausted of free pages, the scanners are advanced one area. A compaction run completes within a zone when the two scanners meet. This method is a bit primitive but is easy to understand and greater sophistication would require maintenance of counters on a per-pageblock basis. This would have a big impact on allocator fast-paths to improve compaction which is a poor trade-off. It also does not try relocate virtually contiguous pages to be physically contiguous. However, assuming transparent hugepages were in use, a hypothetical khugepaged might reuse compaction code to isolate free pages, split them and relocate userspace pages for promotion. Memory compaction can be triggered in one of three ways. It may be triggered explicitly by writing any value to /proc/sys/vm/compact_memory and compacting all of memory. It can be triggered on a per-node basis by writing any value to /sys/devices/system/node/nodeN/compact where N is the node ID to be compacted. When a process fails to allocate a high-order page, it may compact memory in an attempt to satisfy the allocation instead of entering direct reclaim. Explicit compaction does not finish until the two scanners meet and direct compaction ends if a suitable page becomes available that would meet watermarks. The series is in 14 patches. The first three are not "core" to the series but are important pre-requisites. Patch 1 reference counts anon_vma for rmap_walk_anon(). Without this patch, it's possible to use anon_vma after free if the caller is not holding a VMA or mmap_sem for the pages in question. While there should be no existing user that causes this problem, it's a requirement for memory compaction to be stable. The patch is at the start of the series for bisection reasons. Patch 2 merges the KSM and migrate counts. It could be merged with patch 1 but would be slightly harder to review. Patch 3 skips over unmapped anon pages during migration as there are no guarantees about the anon_vma existing. There is a window between when a page was isolated and migration started during which anon_vma could disappear. Patch 4 notes that PageSwapCache pages can still be migrated even if they are unmapped. Patch 5 allows CONFIG_MIGRATION to be set without CONFIG_NUMA Patch 6 exports a "unusable free space index" via debugfs. It's a measure of external fragmentation that takes the size of the allocation request into account. It can also be calculated from userspace so can be dropped if requested Patch 7 exports a "fragmentation index" which only has meaning when an allocation request fails. It determines if an allocation failure would be due to a lack of memory or external fragmentation. Patch 8 moves the definition for LRU isolation modes for use by compaction Patch 9 is the compaction mechanism although it's unreachable at this point Patch 10 adds a means of compacting all of memory with a proc trgger Patch 11 adds a means of compacting a specific node with a sysfs trigger Patch 12 adds "direct compaction" before "direct reclaim" if it is determined there is a good chance of success. Patch 13 adds a sysctl that allows tuning of the threshold at which the kernel will compact or direct reclaim Patch 14 temporarily disables compaction if an allocation failure occurs after compaction. Testing of compaction was in three stages. For the test, debugging, preempt, the sleep watchdog and lockdep were all enabled but nothing nasty popped out. min_free_kbytes was tuned as recommended by hugeadm to help fragmentation avoidance and high-order allocations. It was tested on X86, X86-64 and PPC64. Ths first test represents one of the easiest cases that can be faced for lumpy reclaim or memory compaction. 1. Machine freshly booted and configured for hugepage usage with a) hugeadm --create-global-mounts b) hugeadm --pool-pages-max DEFAULT:8G c) hugeadm --set-recommended-min_free_kbytes d) hugeadm --set-recommended-shmmax The min_free_kbytes here is important. Anti-fragmentation works best when pageblocks don't mix. hugeadm knows how to calculate a value that will significantly reduce the worst of external-fragmentation-related events as reported by the mm_page_alloc_extfrag tracepoint. 2. Load up memory a) Start updatedb b) Create in parallel a X files of pagesize*128 in size. Wait until files are created. By parallel, I mean that 4096 instances of dd were launched, one after the other using &. The crude objective being to mix filesystem metadata allocations with the buffer cache. c) Delete every second file so that pageblocks are likely to have holes d) kill updatedb if it's still running At this point, the system is quiet, memory is full but it's full with clean filesystem metadata and clean buffer cache that is unmapped. This is readily migrated or discarded so you'd expect lumpy reclaim to have no significant advantage over compaction but this is at the POC stage. 3. In increments, attempt to allocate 5% of memory as hugepages. Measure how long it took, how successful it was, how many direct reclaims took place and how how many compactions. Note the compaction figures might not fully add up as compactions can take place for orders other than the hugepage size X86 vanilla compaction Final page count 913 916 (attempted 1002) pages reclaimed 68296 9791 X86-64 vanilla compaction Final page count: 901 902 (attempted 1002) Total pages reclaimed: 112599 53234 PPC64 vanilla compaction Final page count: 93 94 (attempted 110) Total pages reclaimed: 103216 61838 There was not a dramatic improvement in success rates but it wouldn't be expected in this case either. What was important is that fewer pages were reclaimed in all cases reducing the amount of IO required to satisfy a huge page allocation. The second tests were all performance related - kernbench, netperf, iozone and sysbench. None showed anything too remarkable. The last test was a high-order allocation stress test. Many kernel compiles are started to fill memory with a pressured mix of unmovable and movable allocations. During this, an attempt is made to allocate 90% of memory as huge pages - one at a time with small delays between attempts to avoid flooding the IO queue. vanilla compaction Percentage of request allocated X86 98 99 Percentage of request allocated X86-64 95 98 Percentage of request allocated PPC64 55 70 This patch: rmap_walk_anon() does not use page_lock_anon_vma() for looking up and locking an anon_vma and it does not appear to have sufficient locking to ensure the anon_vma does not disappear from under it. This patch copies an approach used by KSM to take a reference on the anon_vma while pages are being migrated. This should prevent rmap_walk() running into nasty surprises later because anon_vma has been freed. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Rik van Riel <riel@redhat.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25mm: remove return value of putback_lru_pages()Minchan Kim
putback_lru_page() never can fail. So it doesn't matter count of "the number of pages put back". In addition, users of this functions don't use return value. Let's remove unnecessary code. Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-06mm/migrate.c: kill anon local variable from migrate_page_copyKOSAKI Motohiro
commit 01b1ae63c2 ("memcg: simple migration handling") removed mem_cgroup_uncharge_cache_page() call from migrate_page_copy. Local variable `anon' is now unused. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-01Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (100 commits) ARM: Eliminate decompressor -Dstatic= PIC hack ARM: 5958/1: ARM: U300: fix inverted clk round rate ARM: 5956/1: misplaced parentheses ARM: 5955/1: ep93xx: move timer defines into core.c and document ARM: 5954/1: ep93xx: move gpio interrupt support to gpio.c ARM: 5953/1: ep93xx: fix broken build of clock.c ARM: 5952/1: ARM: MM: Add ARM_L1_CACHE_SHIFT_6 for handle inside each ARCH Kconfig ARM: 5949/1: NUC900 add gpio virtual memory map ARM: 5948/1: Enable timer0 to time4 clock support for nuc910 ARM: 5940/2: ARM: MMCI: remove custom DBG macro and printk ARM: make_coherent(): fix problems with highpte, part 2 MM: Pass a PTE pointer to update_mmu_cache() rather than the PTE itself ARM: 5945/1: ep93xx: include correct irq.h in core.c ARM: 5933/1: amba-pl011: support hardware flow control ARM: 5930/1: Add PKMAP area description to memory.txt. ARM: 5929/1: Add checks to detect overlap of memory regions. ARM: 5928/1: Change type of VMALLOC_END to unsigned long. ARM: 5927/1: Make delimiters of DMA area globally visibly. ARM: 5926/1: Add "Virtual kernel memory..." printout. ARM: 5920/1: OMAP4: Enable L2 Cache ... Fix up trivial conflict in arch/arm/mach-mx25/clock.c
2010-02-21mm: Make copy_from_user() in migrate.c statically predictableH. Peter Anvin
x86-32 has had a static test for copy_on_user() overflow for a while. This test currently fails in mm/migrate.c resulting in an allyesconfig/allmodconfig build failure on x86-32: In function ‘copy_from_user’, inlined from ‘do_pages_stat’ at /home/hpa/kernel/git/mm/migrate.c:1012: /home/hpa/kernel/git/arch/x86/include/asm/uaccess_32.h:212: error: call to ‘copy_from_user_overflow’ declared Make the logic more explicit and therefore easier for gcc to understand. v2: rewrite the loop entirely using a more normal structure for a chunked-data loop (Linus Torvalds) Reported-by: Len Brown <lenb@kernel.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Reviewed-and-Tested-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Arjan van de Ven <arjan@linux.kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-20MM: Pass a PTE pointer to update_mmu_cache() rather than the PTE itselfRussell King
On VIVT ARM, when we have multiple shared mappings of the same file in the same MM, we need to ensure that we have coherency across all copies. We do this via make_coherent() by making the pages uncacheable. This used to work fine, until we allowed highmem with highpte - we now have a page table which is mapped as required, and is not available for modification via update_mmu_cache(). Ralf Beache suggested getting rid of the PTE value passed to update_mmu_cache(): On MIPS update_mmu_cache() calls __update_tlb() which walks pagetables to construct a pointer to the pte again. Passing a pte_t * is much more elegant. Maybe we might even replace the pte argument with the pte_t? Ben Herrenschmidt would also like the pte pointer for PowerPC: Passing the ptep in there is exactly what I want. I want that -instead- of the PTE value, because I have issue on some ppc cases, for I$/D$ coherency, where set_pte_at() may decide to mask out the _PAGE_EXEC. So, pass in the mapped page table pointer into update_mmu_cache(), and remove the PTE value, updating all implementations and call sites to suit. Includes a fix from Stephen Rothwell: sparc: fix fallout from update_mmu_cache API change Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-06Fix potential crash with sys_move_pagesLinus Torvalds
We incorrectly depended on the 'node_state/node_isset()' functions testing the node range, rather than checking it explicitly. That's not reliable, even if it might often happen to work. So do the proper explicit test. Reported-by: Marcus Meissner <meissner@suse.de> Acked-and-tested-by: Brice Goglin <Brice.Goglin@inria.fr> Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15mm: remove unevictable_migrate_page functionLee Schermerhorn
unevictable_migrate_page() in mm/internal.h is a relic of the since removed UNEVICTABLE_LRU Kconfig option. This patch removes the function and open codes the test in migrate_page_copy(). Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15ksm: memory hotremove migration onlyHugh Dickins
The previous patch enables page migration of ksm pages, but that soon gets into trouble: not surprising, since we're using the ksm page lock to lock operations on its stable_node, but page migration switches the page whose lock is to be used for that. Another layer of locking would fix it, but do we need that yet? Do we actually need page migration of ksm pages? Yes, memory hotremove needs to offline sections of memory: and since we stopped allocating ksm pages with GFP_HIGHUSER, they will tend to be GFP_HIGHUSER_MOVABLE candidates for migration. But KSM is currently unconscious of NUMA issues, happily merging pages from different NUMA nodes: at present the rule must be, not to use MADV_MERGEABLE where you care about NUMA. So no, NUMA page migration of ksm pages does not make sense yet. So, to complete support for ksm swapping we need to make hotremove safe. ksm_memory_callback() take ksm_thread_mutex when MEM_GOING_OFFLINE and release it when MEM_OFFLINE or MEM_CANCEL_OFFLINE. But if mapped pages are freed before migration reaches them, stable_nodes may be left still pointing to struct pages which have been removed from the system: the stable_node needs to identify a page by pfn rather than page pointer, then it can safely prune them when MEM_OFFLINE. And make NUMA migration skip PageKsm pages where it skips PageReserved. But it's only when we reach unmap_and_move() that the page lock is taken and we can be sure that raised pagecount has prevented a PageAnon from being upgraded: so add offlining arg to migrate_pages(), to migrate ksm page when offlining (has sufficient locking) but reject it otherwise. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Izik Eidus <ieidus@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Chris Wright <chrisw@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15ksm: rmap_walk to remove_migation_ptesHugh Dickins
A side-effect of making ksm pages swappable is that they have to be placed on the LRUs: which then exposes them to isolate_lru_page() and hence to page migration. Add rmap_walk() for remove_migration_ptes() to use: rmap_walk_anon() and rmap_walk_file() in rmap.c, but rmap_walk_ksm() in ksm.c. Perhaps some consolidation with existing code is possible, but don't attempt that yet (try_to_unmap needs to handle nonlinears, but migration pte removal does not). rmap_walk() is sadly less general than it appears: rmap_walk_anon(), like remove_anon_migration_ptes() which it replaces, avoids calling page_lock_anon_vma(), because that includes a page_mapped() test which fails when all migration ptes are in place. That was valid when NUMA page migration was introduced (holding mmap_sem provided the missing guarantee that anon_vma's slab had not already been destroyed), but I believe not valid in the memory hotremove case added since. For now do the same as before, and consider the best way to fix that unlikely race later on. When fixed, we can probably use rmap_walk() on hwpoisoned ksm pages too: for now, they remain among hwpoison's various exceptions (its PageKsm test comes before the page is locked, but its page_lock_anon_vma fails safely if an anon gets upgraded). Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Izik Eidus <ieidus@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Chris Wright <chrisw@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15mm: define PAGE_MAPPING_FLAGSHugh Dickins
At present we define PageAnon(page) by the low PAGE_MAPPING_ANON bit set in page->mapping, with the higher bits a pointer to the anon_vma; and have defined PageKsm(page) as that with NULL anon_vma. But KSM swapping will need to store a pointer there: so in preparation for that, now define PAGE_MAPPING_FLAGS as the low two bits, including PAGE_MAPPING_KSM (always set along with PAGE_MAPPING_ANON, until some other use for the bit emerges). Declare page_rmapping(page) to return the pointer part of page->mapping, and page_anon_vma(page) to return the anon_vma pointer when that's what it is. Use these in a few appropriate places: notably, unuse_vma() has been testing page->mapping, but is better to be testing page_anon_vma() (cases may be added in which flag bits are set without any pointer). Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Izik Eidus <ieidus@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Nick Piggin <npiggin@suse.de> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15mm: move inc_zone_page_state(NR_ISOLATED) to just isolated placeKOSAKI Motohiro
Christoph pointed out inc_zone_page_state(NR_ISOLATED) should be placed in right after isolate_page(). This patch does it. Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-11mm: Adjust do_pages_stat() so gcc can see copy_from_user() is safeH. Peter Anvin
Slightly adjust the logic for determining the size of the copy_form_user() in do_pages_stat(); with this change, gcc can see that the copying is safe. Without this, we get a build error for i386 allyesconfig: /home/hpa/kernel/linux-2.6-tip.urgent/arch/x86/include/asm/uaccess_32.h:213: error: call to ‘copy_from_user_overflow’ declared with attribute error: copy_from_user() buffer size is not provably correct Unlike an earlier patch from Arjan, this doesn't introduce new variables; merely reshuffles the compare so that gcc can see that an overflow cannot happen. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: Brice Goglin <Brice.Goglin@inria.fr> Cc: Arjan van de Ven <arjan@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> LKML-Reference: <20090926205406.30d55b08@infradead.org>
2009-11-12memcg: fix wrong pointer initialization at page migration when memcg is ↵KAMEZAWA Hiroyuki
disabled. Lee Schermerhorn reported that he saw bad pointer dereference in mem_cgroup_end_migration() when he disabled memcg by boot option. memcg's page migration logic works as mem_cgroup_prepare_migration(page, &ptr); do page migration mem_cgroup_end_migration(page, ptr); Now, ptr is not initialized in prepare_migration when memcg is disabled by boot option. This causes panic in end_migration. This patch fixes it. Reported-by: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24Merge branch 'hwpoison' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6 * 'hwpoison' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6: (21 commits) HWPOISON: Enable error_remove_page on btrfs HWPOISON: Add simple debugfs interface to inject hwpoison on arbitary PFNs HWPOISON: Add madvise() based injector for hardware poisoned pages v4 HWPOISON: Enable error_remove_page for NFS HWPOISON: Enable .remove_error_page for migration aware file systems HWPOISON: The high level memory error handler in the VM v7 HWPOISON: Add PR_MCE_KILL prctl to control early kill behaviour per process HWPOISON: shmem: call set_page_dirty() with locked page HWPOISON: Define a new error_remove_page address space op for async truncation HWPOISON: Add invalidate_inode_page HWPOISON: Refactor truncate to allow direct truncating of page v2 HWPOISON: check and isolate corrupted free pages v2 HWPOISON: Handle hardware poisoned pages in try_to_unmap HWPOISON: Use bitmask/action code for try_to_unmap behaviour HWPOISON: x86: Add VM_FAULT_HWPOISON handling to x86 page fault handler v2 HWPOISON: Add poison check to page fault handling HWPOISON: Add basic support for poisoned pages in fault handler v3 HWPOISON: Add new SIGBUS error codes for hardware poison signals HWPOISON: Add support for poison swap entries v2 HWPOISON: Export some rmap vma locking to outside world ...
