commit 8bdd638091605dc66d92c57c4b80eb87fffc15f7 upstream.
Shortly before 3.16-rc1, Dave Jones reported:
WARNING: CPU: 3 PID: 19721 at fs/xfs/xfs_aops.c:971
xfs_vm_writepage+0x5ce/0x630 [xfs]()
CPU: 3 PID: 19721 Comm: trinity-c61 Not tainted 3.15.0+ #3
Call Trace:
shrink_page_list+0x8f9/0xb90
shrink_inactive_list+0x253/0x510
shrink_lruvec+0x563/0x6c0
shrink_zone+0x3b/0x100
shrink_zones+0x1f1/0x3c0
try_to_free_pages+0x164/0x380
__alloc_pages_nodemask+0x822/0xc90
alloc_pages_vma+0xaf/0x1c0
handle_mm_fault+0xa31/0xc50
etc.
970 if (WARN_ON_ONCE((current->flags & (PF_MEMALLOC|PF_KSWAPD)) ==
971 PF_MEMALLOC))
I did not respond at the time, because a glance at the PageDirty block
in shrink_page_list() quickly shows that this is impossible: we don't do
writeback on file pages (other than tmpfs) from direct reclaim nowadays.
Dave was hallucinating, but it would have been disrespectful to say so.
However, my own /var/log/messages now shows similar complaints
WARNING: CPU: 1 PID: 28814 at fs/ext4/inode.c:1881 ext4_writepage+0xa7/0x38b()
WARNING: CPU: 0 PID: 27347 at fs/ext4/inode.c:1764 ext4_writepage+0xa7/0x38b()
from stressing some mmotm trees during July.
Could a dirty xfs or ext4 file page somehow get marked PageSwapBacked,
so fail shrink_page_list()'s page_is_file_cache() test, and so proceed
to mapping->a_ops->writepage()?
Yes, 3.16-rc1's commit 68711a746345 ("mm, migration: add destination
page freeing callback") has provided such a way to compaction: if
migrating a SwapBacked page fails, its newpage may be put back on the
list for later use with PageSwapBacked still set, and nothing will clear
it.
Whether that can do anything worse than issue WARN_ON_ONCEs, and get
some statistics wrong, is unclear: easier to fix than to think through
the consequences.
Fixing it here, before the put_new_page(), addresses the bug directly,
but is probably the worst place to fix it. Page migration is doing too
many parts of the job on too many levels: fixing it in
move_to_new_page() to complement its SetPageSwapBacked would be
preferable, except why is it (and newpage->mapping and newpage->index)
done there, rather than down in migrate_page_move_mapping(), once we are
sure of success? Not a cleanup to get into right now, especially not
with memcg cleanups coming in 3.17.
Reported-by: Dave Jones <davej@redhat.com>
commit 68711a746345c44ae00c64d8dbac6a9ce13ac54a upstream.
Memory migration uses a callback defined by the caller to determine how to
allocate destination pages. When migration fails for a source page,
however, it frees the destination page back to the system.
This patch adds a memory migration callback defined by the caller to
determine how to free destination pages. If a caller, such as memory
compaction, builds its own freelist for migration targets, this can reuse
already freed memory instead of scanning additional memory.
If the caller provides a function to handle freeing of destination pages,
it is called when page migration fails. If the caller passes NULL then
freeing back to the system will be handled as usual. This patch
introduces no functional change.
Signed-off-by: David Rientjes <rientjes@google.com>
Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
commit d3cb8bf6081b8b7a2dabb1264fe968fd870fa595 upstream.
A migration entry is marked as write if pte_write was true at the time the
entry was created. The VMA protections are not double checked when migration
entries are being removed as mprotect marks write-migration-entries as
read. It means that potentially we take a spurious fault to mark PTEs write
again but it's straight-forward. However, there is a race between write
migrations being marked read and migrations finishing. This potentially
allows a PTE to be write that should have been read. Close this race by
double checking the VMA permissions using maybe_mkwrite when migration
completes.
[torvalds@linux-foundation.org: use maybe_mkwrite]
Add remove_linear_migration_ptes_from_nonlinear(), to fix an interesting
little include/linux/swapops.h:131 BUG_ON(!PageLocked) found by trinity:
indicating that remove_migration_ptes() failed to find one of the
migration entries that was temporarily inserted.
The problem comes from remap_file_pages()'s switch from vma_interval_tree
(good for inserting the migration entry) to i_mmap_nonlinear list (no good
for locating it again); but can only be a problem if the remap_file_pages()
range does not cover the whole of the vma (zap_pte() clears the range).
remove_migration_ptes() needs a file_nonlinear method to go down the
i_mmap_nonlinear list, applying linear location to look for migration
entries in those vmas too, just in case there was this race.
The file_nonlinear method does need rmap_walk_control.arg to do this;
but it never needed vma passed in - vma comes from its own iteration.
Reported-and-tested-by: Dave Jones <davej@redhat.com>
Reported-and-tested-by: Sasha Levin <sasha.levin@oracle.com>
GFP_THISNODE is for callers that implement their own clever fallback to
remote nodes. It restricts the allocation to the specified node and
does not invoke reclaim, assuming that the caller will take care of it
when the fallback fails, e.g. through a subsequent allocation request
without GFP_THISNODE set.
However, many current GFP_THISNODE users only want the node exclusive
aspect of the flag, without actually implementing their own fallback or
triggering reclaim if necessary. This results in things like page
migration failing prematurely even when there is easily reclaimable
memory available, unless kswapd happens to be running already or a
concurrent allocation attempt triggers the necessary reclaim.
Convert all callsites that don't implement their own fallback strategy
to __GFP_THISNODE. This restricts the allocation a single node too, but
at the same time allows the allocator to enter the slowpath, wake
kswapd, and invoke direct reclaim if necessary, to make the allocation
happen when memory is full.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Cc: Jan Stancek <jstancek@redhat.com>
Commit 7851a45cd3f6 ("mm: numa: Copy cpupid on page migration") copies
over the cpupid at page migration time. It is unnecessary to set it
again in alloc_misplaced_dst_page().
Signed-off-by: Wanpeng Li <liwanp@linux.vnet.ibm.com>
Commit 7851a45cd3f6 ("mm: numa: Copy cpupid on page migration") copiess
again in migrate_misplaced_transhuge_page().
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Most of the VM_BUG_ON assertions are performed on a page. Usually, when
one of these assertions fails we'll get a BUG_ON with a call stack and
the registers.
I've recently noticed based on the requests to add a small piece of code
that dumps the page to various VM_BUG_ON sites that the page dump is
quite useful to people debugging issues in mm.
This patch adds a VM_BUG_ON_PAGE(cond, page) which beyond doing what
VM_BUG_ON() does, also dumps the page before executing the actual
BUG_ON.
[akpm@linux-foundation.org: fix up includes]
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
fail_migrate_page() isn't used anywhere, so remove it.
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Acked-by: Christoph Lameter <cl@linux.com>
Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com>
Cc: Rafael Aquini <aquini@redhat.com>
Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com>
Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
Some part of putback_lru_pages() and putback_movable_pages() is
duplicated, so it could confuse us what we should use. We can remove
putback_lru_pages() since it is not really needed now. This makes us
undestand and maintain the code more easily.
And comment on putback_movable_pages() is stale now, so fix it.
Cc: Christoph Lameter <cl@linux.com>
We should remove the page from the list if we fail with ENOSYS, since
migrate_pages() consider error cases except -ENOMEM and -EAGAIN as
permanent failure and it assumes that the page would be removed from the
list. Without this patch, we could overcount number of failure.
In addition, we should put back the new hugepage if
!hugepage_migration_support(). If not, we would leak hugepage memory.
Let's add a comment about where the failed page goes to, which makes
code more readable.
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Acked-by: Rafael Aquini <aquini@redhat.com>
A low local/remote numa hinting fault ratio is potentially explained by
failed migrations. This patch adds a tracepoint that fires when
migration fails due to migration rate limitation.
Cc: Alex Thorlton <athorlton@sgi.com>
NUMA migrate rate limiting protects a migration counter and window using
a lock but in some cases this can be a contended lock. It is not
critical that the number of pages be perfect, lost updates are
acceptable. Reduce the importance of this lock.
numamigrate_update_ratelimit and numamigrate_isolate_page only have
callers in mm/migrate.c. This patch makes them static.
In each rmap traverse case, there is some difference so that we need
function pointers and arguments to them in order to handle these
For this purpose, struct rmap_walk_control is introduced in this patch,
and will be extended in following patch. Introducing and extending are
separate, because it clarify changes.
Cc: Hillf Danton <dhillf@gmail.com>
The arbitrary restriction on page counts offered by the core
migrate_page_move_mapping() code results in rather suspicious looking
fiddling with page reference counts in the aio_migratepage() operation.
To fix this, make migrate_page_move_mapping() take an extra_count parameter
that allows aio to tell the code about its own reference count on the page
being migrated.
While cleaning up aio_migratepage(), make it validate that the old page
being passed in is actually what aio_migratepage() expects to prevent
misbehaviour in the case of races.
Signed-off-by: Benjamin LaHaise <bcrl@kvack.org>
THP migration can fail for a variety of reasons. Avoid flushing the TLB
to deal with THP migration races until the copy is ready to start.
Cc: <stable@vger.kernel.org>
do_huge_pmd_numa_page() handles the case where there is parallel THP
migration. However, by the time it is checked the NUMA hinting
information has already been disrupted. This patch adds an earlier
check with some helpers.
If a PMD changes during a THP migration then migration aborts but the
failure path is doing more work than is necessary.
MMU notifiers must be called on THP page migration or secondary MMUs
will get very confused.
Base pages are unmapped and flushed from cache and TLB during normal
page migration and replaced with a migration entry that causes any
parallel NUMA hinting fault or gup to block until migration completes.
THP does not unmap pages due to a lack of support for migration entries
at a PMD level. This allows races with get_user_pages and
get_user_pages_fast which commit 3f926ab945b6 ("mm: Close races between
THP migration and PMD numa clearing") made worse by introducing a
pmd_clear_flush().
This patch forces get_user_page (fast and normal) on a pmd_numa page to
go through the slow get_user_page path where it will serialise against
THP migration and properly account for the NUMA hinting fault. On the
migration side the page table lock is taken for each PTE update.
Right now, the migration code in migrate_page_copy() uses copy_huge_page()
for hugetlbfs and thp pages:
if (PageHuge(page) || PageTransHuge(page))
copy_huge_page(newpage, page);
So, yay for code reuse. But:
void copy_huge_page(struct page *dst, struct page *src)
struct hstate *h = page_hstate(src);
and a non-hugetlbfs page has no page_hstate(). This works 99% of the
time because page_hstate() determines the hstate from the page order
alone. Since the page order of a THP page matches the default hugetlbfs
page order, it works.
But, if you change the default huge page size on the boot command-line
(say default_hugepagesz=1G), then we might not even *have* a 2MB hstate
so page_hstate() returns null and copy_huge_page() oopses pretty fast
since copy_huge_page() dereferences the hstate:
if (unlikely(pages_per_huge_page(h) > MAX_ORDER_NR_PAGES)) {
Mel noticed that the migration code is really the only user of these
functions. This moves all the copy code over to migrate.c and makes
copy_huge_page() work for THP by checking for it explicitly.
I believe the bug was introduced in commit b32967ff101a ("mm: numa: Add
THP migration for the NUMA working set scanning fault case")
[akpm@linux-foundation.org: fix coding-style and comment text, per Naoya Horiguchi]
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Tested-by: Dave Jiang <dave.jiang@intel.com>
Only trivial cases left. Let's convert them altogether.
Tested-by: Alex Thorlton <athorlton@sgi.com>
Cc: "Eric W . Biederman" <ebiederm@xmission.com>
Cc: "Paul E . McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Dave Jones <davej@redhat.com>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: Robin Holt <robinmholt@gmail.com>
Cc: Sedat Dilek <sedat.dilek@gmail.com>
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Hugetlb supports multiple page sizes. We use split lock only for PMD
level, but not for PUD.
Resolve cherry-picking conflicts:
mm/huge_memory.c
mm/memory.c
mm/mprotect.c
See this upstream merge commit for more details:
52469b4fcd4f Merge branch 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip
THP migration uses the page lock to guard against parallel allocations
but there are cases like this still open
Task A Task B
do_huge_pmd_numa_page do_huge_pmd_numa_page
lock_page
mpol_misplaced == -1
unlock_page
goto clear_pmdnuma
lock_page
mpol_misplaced == 2
pmd = pmd_mknonnuma
set_pmd_at
During hours of testing, one crashed with weird errors and while I have
no direct evidence, I suspect something like the race above happened.
This patch extends the page lock to being held until the pmd_numa is
cleared to prevent migration starting in parallel while the pmd_numa is
being cleared. It also flushes the old pmd entry and orders pagetable
insertion before rmap insertion.
Cc: <stable@kernel.org>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/1381141781-10992-9-git-send-email-mgorman@suse.de
If page migration is turned on in config and the page is migrating, we
may lose the soft dirty bit. If fork and mprotect are called on
migrating pages (once migration is complete) pages do not obtain the
soft dirty bit in the correspond pte entries. Fix it adding an
appropriate test on swap entries.
Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Pavel Emelyanov <xemul@parallels.com>
Cc: Matt Mackall <mpm@selenic.com>
Cc: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: KOSAKI Motohiro <kosaki.motohiro@gmail.com>
Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com>
After page migration, the new page has the nidpid unset. This makes
every fault on a recently migrated page look like a first numa fault,
leading to another page migration.
Copying over the nidpid at page migration time should prevent erroneous
migrations of recently migrated pages.
Signed-off-by: Rik van Riel <riel@redhat.com>
Link: http://lkml.kernel.org/r/1381141781-10992-46-git-send-email-mgorman@suse.de
Change the per page last fault tracking to use cpu,pid instead of
nid,pid. This will allow us to try and lookup the alternate task more
easily. Note that even though it is the cpu that is store in the page
flags that the mpol_misplaced decision is still based on the node.
Link: http://lkml.kernel.org/r/1381141781-10992-43-git-send-email-mgorman@suse.de
[ Fixed build failure on 32-bit systems. ]
Ideally it would be possible to distinguish between NUMA hinting faults that
are private to a task and those that are shared. If treated identically
there is a risk that shared pages bounce between nodes depending on
the order they are referenced by tasks. Ultimately what is desirable is
that task private pages remain local to the task while shared pages are
interleaved between sharing tasks running on different nodes to give good
average performance. This is further complicated by THP as even
applications that partition their data may not be partitioning on a huge
page boundary.
To start with, this patch assumes that multi-threaded or multi-process
applications partition their data and that in general the private accesses
are more important for cpu->memory locality in the general case. Also,
no new infrastructure is required to treat private pages properly but
interleaving for shared pages requires additional infrastructure.
To detect private accesses the pid of the last accessing task is required
but the storage requirements are a high. This patch borrows heavily from
Ingo Molnar's patch "numa, mm, sched: Implement last-CPU+PID hash tracking"
to encode some bits from the last accessing task in the page flags as
well as the node information. Collisions will occur but it is better than
just depending on the node information. Node information is then used to
determine if a page needs to migrate. The PID information is used to detect
private/shared accesses. The preferred NUMA node is selected based on where
the maximum number of approximately private faults were measured. Shared
faults are not taken into consideration for a few reasons.
First, if there are many tasks sharing the page then they'll all move
towards the same node. The node will be compute overloaded and then
scheduled away later only to bounce back again. Alternatively the shared
tasks would just bounce around nodes because the fault information is
effectively noise. Either way accounting for shared faults the same as
private faults can result in lower performance overall.
The second reason is based on a hypothetical workload that has a small
number of very important, heavily accessed private pages but a large shared
array. The shared array would dominate the number of faults and be selected
as a preferred node even though it's the wrong decision.
The third reason is that multiple threads in a process will race each
other to fault the shared page making the fault information unreliable.
[ Fix complication error when !NUMA_BALANCING. ]
Link: http://lkml.kernel.org/r/1381141781-10992-30-git-send-email-mgorman@suse.de
Currently automatic NUMA balancing is unable to distinguish between false
shared versus private pages except by ignoring pages with an elevated
page_mapcount entirely. This avoids shared pages bouncing between the
nodes whose task is using them but that is ignored quite a lot of data.
This patch kicks away the training wheels in preparation for adding support
for identifying shared/private pages is now in place. The ordering is so
that the impact of the shared/private detection can be easily measured. Note
that the patch does not migrate shared, file-backed within vmas marked
VM_EXEC as these are generally shared library pages. Migrating such pages
is not beneficial as there is an expectation they are read-shared between
caches and iTLB and iCache pressure is generally low.
Link: http://lkml.kernel.org/r/1381141781-10992-28-git-send-email-mgorman@suse.de
Task A Task B
lock_page
unlock_page
goto clear_pmdnuma
lock_page
mpol_misplaced == 2
pmd = pmd_mknonnuma
set_pmd_at
Isolated balloon pages can wrongly end up in LRU lists when
migrate_pages() finishes its round without draining all the isolated
page list.
The same issue can happen when reclaim_clean_pages_from_list() tries to
reclaim pages from an isolated page list, before migration, in the CMA
path. Such balloon page leak opens a race window against LRU lists
shrinkers that leads us to the following kernel panic:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000028
IP: [<ffffffff810c2625>] shrink_page_list+0x24e/0x897
PGD 3cda2067 PUD 3d713067 PMD 0
Oops: 0000 [#1] SMP
CPU: 0 PID: 340 Comm: kswapd0 Not tainted 3.12.0-rc1-22626-g4367597 #87
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
RIP: shrink_page_list+0x24e/0x897
RSP: 0000:ffff88003da499b8 EFLAGS: 00010286
RAX: 0000000000000000 RBX: ffff88003e82bd60 RCX: 00000000000657d5
RDX: 0000000000000000 RSI: 000000000000031f RDI: ffff88003e82bd40
RBP: ffff88003da49ab0 R08: 0000000000000001 R09: 0000000081121a45
R10: ffffffff81121a45 R11: ffff88003c4a9a28 R12: ffff88003e82bd40
R13: ffff88003da0e800 R14: 0000000000000001 R15: ffff88003da49d58
FS: 0000000000000000(0000) GS:ffff88003fc00000(0000) knlGS:0000000000000000
CR2: 00000000067d9000 CR3: 000000003ace5000 CR4: 00000000000407b0
Call Trace:
shrink_inactive_list+0x240/0x3de
shrink_lruvec+0x3e0/0x566
__shrink_zone+0x94/0x178
shrink_zone+0x3a/0x82
balance_pgdat+0x32a/0x4c2
kswapd+0x2f0/0x372
kthread+0xa2/0xaa
ret_from_fork+0x7c/0xb0
Code: 80 7d 8f 01 48 83 95 68 ff ff ff 00 4c 89 e7 e8 5a 7b 00 00 48 85 c0 49 89 c5 75 08 80 7d 8f 00 74 3e eb 31 48 8b 80 18 01 00 00 <48> 8b 74 0d 48 8b 78 30 be 02 00 00 00 ff d2 eb
RIP [<ffffffff810c2625>] shrink_page_list+0x24e/0x897
RSP <ffff88003da499b8>
CR2: 0000000000000028
---[ end trace 703d2451af6ffbfd ]---
Kernel panic - not syncing: Fatal exception
This patch fixes the issue, by assuring the proper tests are made at
putback_movable_pages() & reclaim_clean_pages_from_list() to avoid
isolated balloon pages being wrongly reinserted in LRU lists.
[akpm@linux-foundation.org: clarify awkward comment text]
Signed-off-by: Rafael Aquini <aquini@redhat.com>
Reported-by: Luiz Capitulino <lcapitulino@redhat.com>
Tested-by: Luiz Capitulino <lcapitulino@redhat.com>
Pull aio changes from Ben LaHaise:
"First off, sorry for this pull request being late in the merge window.
Al had raised a couple of concerns about 2 items in the series below.
I addressed the first issue (the race introduced by Gu's use of
mm_populate()), but he has not provided any further details on how he
wants to rework the anon_inode.c changes (which were sent out months
ago but have yet to be commented on).
The bulk of the changes have been sitting in the -next tree for a few
months, with all the issues raised being addressed"
* git://git.kvack.org/~bcrl/aio-next: (22 commits)
aio: rcu_read_lock protection for new rcu_dereference calls
aio: fix race in ring buffer page lookup introduced by page migration support
aio: fix rcu sparse warnings introduced by ioctx table lookup patch
aio: remove unnecessary debugging from aio_free_ring()
aio: table lookup: verify ctx pointer
staging/lustre: kiocb->ki_left is removed
aio: fix error handling and rcu usage in "convert the ioctx list to table lookup v3"
aio: be defensive to ensure request batching is non-zero instead of BUG_ON()
aio: convert the ioctx list to table lookup v3
aio: double aio_max_nr in calculations
aio: Kill ki_dtor
aio: Kill ki_users
aio: Kill unneeded kiocb members
aio: Kill aio_rw_vect_retry()
aio: Don't use ctx->tail unnecessarily
aio: io_cancel() no longer returns the io_event
aio: percpu ioctx refcount
aio: percpu reqs_available
aio: reqs_active -> reqs_available
aio: fix build when migration is disabled
This patch is based on KOSAKI's work and I add a little more description,
please refer https://lkml.org/lkml/2012/6/14/74.
Currently, I found system can enter a state that there are lots of free
pages in a zone but only order-0 and order-1 pages which means the zone is
heavily fragmented, then high order allocation could make direct reclaim
path's long stall(ex, 60 seconds) especially in no swap and no compaciton
enviroment. This problem happened on v3.4, but it seems issue still lives
in current tree, the reason is do_try_to_free_pages enter live lock:
kswapd will go to sleep if the zones have been fully scanned and are still
not balanced. As kswapd thinks there's little point trying all over again
to avoid infinite loop. Instead it changes order from high-order to
0-order because kswapd think order-0 is the most important. Look at
73ce02e9 in detail. If watermarks are ok, kswapd will go back to sleep
and may leave zone->all_unreclaimable =3D 0. It assume high-order users
can still perform direct reclaim if they wish.
Direct reclaim continue to reclaim for a high order which is not a
COSTLY_ORDER without oom-killer until kswapd turn on
zone->all_unreclaimble= . This is because to avoid too early oom-kill.
So it means direct_reclaim depends on kswapd to break this loop.
In worst case, direct-reclaim may continue to page reclaim forever when
kswapd sleeps forever until someone like watchdog detect and finally kill
the process. As described in:
http://thread.gmane.org/gmane.linux.kernel.mm/103737
We can't turn on zone->all_unreclaimable from direct reclaim path because
direct reclaim path don't take any lock and this way is racy. Thus this
patch removes zone->all_unreclaimable field completely and recalculates
zone reclaimable state every time.
Note: we can't take the idea that direct-reclaim see zone->pages_scanned
directly and kswapd continue to use zone->all_unreclaimable. Because, it
is racy. commit 929bea7c71 (vmscan: all_unreclaimable() use
zone->all_unreclaimable as a name) describes the detail.
[akpm@linux-foundation.org: uninline zone_reclaimable_pages() and zone_reclaimable()]
Cc: Aaditya Kumar <aaditya.kumar.30@gmail.com>
Cc: Ying Han <yinghan@google.com>
Cc: Nick Piggin <npiggin@gmail.com>
Cc: Bob Liu <lliubbo@gmail.com>
Cc: Neil Zhang <zhangwm@marvell.com>
Cc: Russell King - ARM Linux <linux@arm.linux.org.uk>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Acked-by: Minchan Kim <minchan@kernel.org>
Signed-off-by: Lisa Du <cldu@marvell.com>
Currently hugepage migration works well only for pmd-based hugepages
(mainly due to lack of testing,) so we had better not enable migration of
other levels of hugepages until we are ready for it.
Some users of hugepage migration (mbind, move_pages, and migrate_pages) do
page table walk and check pud/pmd_huge() there, so they are safe. But the
other users (softoffline and memory hotremove) don't do this, so without
this patch they can try to migrate unexpected types of hugepages.
To prevent this, we introduce hugepage_migration_support() as an
architecture dependent check of whether hugepage are implemented on a pmd
basis or not. And on some architecture multiple sizes of hugepages are
available, so hugepage_migration_support() also checks hugepage size.
Extend move_pages() to handle vma with VM_HUGETLB set. We will be able to
migrate hugepage with move_pages(2) after applying the enablement patch
which comes later in this series.
We avoid getting refcount on tail pages of hugepage, because unlike thp,
hugepage is not split and we need not care about races with splitting.
And migration of larger (1GB for x86_64) hugepage are not enabled.
Acked-by: Andi Kleen <ak@linux.intel.com>
Currently migrate_huge_page() takes a pointer to a hugepage to be migrated
as an argument, instead of taking a pointer to the list of hugepages to be
migrated. This behavior was introduced in commit 189ebff28 ("hugetlb:
simplify migrate_huge_page()"), and was OK because until now hugepage
migration is enabled only for soft-offlining which migrates only one
hugepage in a single call.
But the situation will change in the later patches in this series which
enable other users of page migration to support hugepage migration. They
can kick migration for both of normal pages and hugepages in a single
call, so we need to go back to original implementation which uses linked
lists to collect the hugepages to be migrated.
With this patch, soft_offline_huge_page() switches to use migrate_pages(),
and migrate_huge_page() is not used any more. So let's remove it.
Acked-by: Hillf Danton <dhillf@gmail.com>
Currently hugepage migration is available only for soft offlining, but
it's also useful for some other users of page migration (clearly because
users of hugepage can enjoy the benefit of mempolicy and memory hotplug.)
So this patchset tries to extend such users to support hugepage migration.
The target of this patchset is to enable hugepage migration for NUMA
related system calls (migrate_pages(2), move_pages(2), and mbind(2)), and
memory hotplug.
This patchset does not add hugepage migration for memory compaction,
because users of memory compaction mainly expect to construct thp by
arranging raw pages, and there's little or no need to compact hugepages.
CMA, another user of page migration, can have benefit from hugepage
migration, but is not enabled to support it for now (just because of lack
of testing and expertise in CMA.)
Hugepage migration of non pmd-based hugepage (for example 1GB hugepage in
x86_64, or hugepages in architectures like ia64) is not enabled for now
(again, because of lack of testing.)
As for how these are achived, I extended the API (migrate_pages()) to
handle hugepage (with patch 1 and 2) and adjusted code of each caller to
check and collect movable hugepages (with patch 3-7). Remaining 2 patches
are kind of miscellaneous ones to avoid unexpected behavior. Patch 8 is
about making sure that we only migrate pmd-based hugepages. And patch 9
is about choosing appropriate zone for hugepage allocation.
My test is mainly functional one, simply kicking hugepage migration via
each entry point and confirm that migration is done correctly. Test code
is available here:
git://github.com/Naoya-Horiguchi/test_hugepage_migration_extension.git
And I always run libhugetlbfs test when changing hugetlbfs's code. With
this patchset, no regression was found in the test.
This patch (of 9):
Before enabling each user of page migration to support hugepage,
this patch enables the list of pages for migration to link not only
LRU pages, but also hugepages. As a result, putback_movable_pages()
and migrate_pages() can handle both of LRU pages and hugepages.
As the aio job will pin the ring pages, that will lead to mem migrated
failed. In order to fix this problem we use an anon inode to manage the aio ring
pages, and setup the migratepage callback in the anon inode's address space, so
that when mem migrating the aio ring pages will be moved to other mem node safely.
Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com>
When we have a page fault for the address which is backed by a hugepage
under migration, the kernel can't wait correctly and do busy looping on
hugepage fault until the migration finishes. As a result, users who try
to kick hugepage migration (via soft offlining, for example) occasionally
experience long delay or soft lockup.
This is because pte_offset_map_lock() can't get a correct migration entry
or a correct page table lock for hugepage. This patch introduces
migration_entry_wait_huge() to solve this.
Cc: <stable@vger.kernel.org> [2.6.35+]
Page 'new' during MIGRATION can't be flushed with flush_cache_page().
Using flush_cache_page(vma, addr, pfn) is justified only if the page is
already placed in process page table, and that is done right after
flush_cache_page(). But without it the arch function has no knowledge
of process PTE and does nothing.
Besides that, flush_cache_page() flushes an application cache page, but
the kernel has a different page virtual address and dirtied it.
Replace it with flush_dcache_page(new) which is the proper usage.
The old page is flushed in try_to_unmap_one() before migration.
This bug takes place in Sead3 board with M14Kc MIPS CPU without cache
aliasing (but Harvard arch - separate I and D cache) in tight memory
environment (128MB) each 1-3days on SOAK test. It fails in cc1 during
kernel build (SIGILL, SIGBUS, SIGSEG) if CONFIG_COMPACTION is switched
ON.
Signed-off-by: Leonid Yegoshin <Leonid.Yegoshin@imgtec.com>
Cc: Leonid Yegoshin <yegoshin@mips.com>
The comment over migrate_pages() looks quite weird, and makes it hard to
grasp what it is trying to say. Rewrite it more comprehensibly.
Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Signed-off-by: Jianguo Wu <wujianguo@huawei.com>
No functional change, but the only purpose of the offlining argument to
migrate_pages() etc, was to ensure that __unmap_and_move() could migrate a
KSM page for memory hotremove (which took ksm_thread_mutex) but not for
other callers. Now all cases are safe, remove the arg.
Cc: Petr Holasek <pholasek@redhat.com>
Cc: Izik Eidus <izik.eidus@ravellosystems.com>
Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Migration of KSM pages is now safe: remove the PageKsm restrictions from
mempolicy.c and migrate.c.
But keep PageKsm out of __unmap_and_move()'s anon_vma contortions, which
are irrelevant to KSM: it looks as if that code was preventing hotremove
migration of KSM pages, unless they happened to be in swapcache.
There is some question as to whether enforcing a NUMA mempolicy migration
ought to migrate KSM pages, mapped into entirely unrelated processes; but
moving page_mapcount > 1 is only permitted with MPOL_MF_MOVE_ALL anyway,
and it seems reasonable to assume that you wouldn't set MADV_MERGEABLE on
any area where this is a worry.
KSM page migration is already supported in the case of memory hotremove,
which takes the ksm_thread_mutex across all its migrations to keep life
simple.
But the new KSM NUMA merge_across_nodes knob introduces a problem, when
it's set to non-default 0: if a KSM page is migrated to a different NUMA
node, how do we migrate its stable node to the right tree? And what if
that collides with an existing stable node?
So far there's no provision for that, and this patch does not attempt to
deal with it either. But how will I test a solution, when I don't know
how to hotremove memory? The best answer is to enable KSM page migration
in all cases now, and test more common cases. With THP and compaction
added since KSM came in, page migration is now mainstream, and it's a
shame that a KSM page can frustrate freeing a page block.
Without worrying about merge_across_nodes 0 for now, this patch gets KSM
page migration working reliably for default merge_across_nodes 1 (but
leave the patch enabling it until near the end of the series).
It's much simpler than I'd originally imagined, and does not require an
additional tier of locking: page migration relies on the page lock, KSM
page reclaim relies on the page lock, the page lock is enough for KSM page
migration too.
Almost all the care has to be in get_ksm_page(): that's the function which
worries about when a stable node is stale and should be freed, now it also
has to worry about the KSM page being migrated.
The only new overhead is an additional put/get/lock/unlock_page when
stable_tree_search() arrives at a matching node: to make sure migration
respects the raised page count, and so does not migrate the page while
we're busy with it here. That's probably avoidable, either by changing
internal interfaces from using kpage to stable_node, or by moving the
ksm_migrate_page() callsite into a page_freeze_refs() section (even if not
swapcache); but this works well, I've no urge to pull it apart now.
(Descents of the stable tree may pass through nodes whose KSM pages are
under migration: being unlocked, the raised page count does not prevent
that, nor need it: it's safe to memcmp against either old or new page.)
You might worry about mremap, and whether page migration's rmap_walk to
remove migration entries will find all the KSM locations where it inserted
earlier: that should already be handled, by the satisfyingly heavy hammer
of move_vma()'s call to ksm_madvise(,,,MADV_UNMERGEABLE,).
The function names page_xchg_last_nid(), page_last_nid() and
reset_page_last_nid() were judged to be inconsistent so rename them to a
struct_field_op style pattern. As it looked jarring to have
reset_page_mapcount() and page_nid_reset_last() beside each other in
memmap_init_zone(), this patch also renames reset_page_mapcount() to
page_mapcount_reset(). There are others like init_page_count() but as
it is used throughout the arch code a rename would likely cause more
conflicts than it is worth.
[akpm@linux-foundation.org: fix zcache]
Suggested-by: Andrew Morton <akpm@linux-foundation.org>
When correcting commit 04fa5d6a6547 ("mm: migrate: check page_count of
THP before migrating") Hugh Dickins noted that the control flow for
transhuge migration was difficult to follow. Unconditionally calling
put_page() in numamigrate_isolate_page() made the failure paths of both
migrate_misplaced_transhuge_page() and migrate_misplaced_page() more
complex that they should be. Further, he was extremely wary that an
unlock_page() should ever happen after a put_page() even if the
put_page() should never be the final put_page.
Hugh implemented the following cleanup to simplify the path by calling
putback_lru_page() inside numamigrate_isolate_page() if it failed to
isolate and always calling unlock_page() within
There is no functional change after this patch is applied but the code
is easier to follow and unlock_page() always happens before put_page().
[mgorman@suse.de: changelog only]
Cc: Simon Jeons <simon.jeons@gmail.com>
