path: root/mm/migrate.c
2012-07-31mm: memcg: fix compaction/migration failing due to memcg limitsJohannes Weiner
Compaction (and page migration in general) can currently be hindered through pages being owned by memory cgroups that are at their limits and unreclaimable. The reason is that the replacement page is being charged against the limit while the page being replaced is also still charged. But this seems unnecessary, given that only one of the two pages will still be in use after migration finishes. This patch changes the memcg migration sequence so that the replacement page is not charged. Whatever page is still in use after successful or failed migration gets to keep the charge of the page that was going to be replaced. The replacement page will still show up temporarily in the rss/cache statistics, this can be fixed in a later patch as it's less urgent. Reported-by: David Rientjes <rientjes@google.com> Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Hugh Dickins <hughd@google.com> Cc: David Rientjes <rientjes@google.com> Cc: Wanpeng Li <liwp.linux@gmail.com> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31hugetlb/cgroup: migrate hugetlb cgroup info from oldpage to new page during ↵Aneesh Kumar K.V
migration With HugeTLB pages, hugetlb cgroup is uncharged in compound page destructor. Since we are holding a hugepage reference, we can be sure that old page won't get uncharged till the last put_page(). Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: David Rientjes <rientjes@google.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hillf Danton <dhillf@gmail.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31hugetlb: simplify migrate_huge_page()Aneesh Kumar K.V
Since we migrate only one hugepage, don't use linked list for passing the page around. Directly pass the page that need to be migrated as argument. This also removes the usage of page->lru in the migrate path. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Hillf Danton <dhillf@gmail.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-06-03mm: fix warning in __set_page_dirty_nobuffersHugh Dickins
New tmpfs use of !PageUptodate pages for fallocate() is triggering the WARNING: at mm/page-writeback.c:1990 when __set_page_dirty_nobuffers() is called from migrate_page_copy() for compaction. It is anomalous that migration should use __set_page_dirty_nobuffers() on an address_space that does not participate in dirty and writeback accounting; and this has also been observed to insert surprising dirty tags into a tmpfs radix_tree, despite tmpfs not using tags at all. We should probably give migrate_page_copy() a better way to preserve the tag and migrate accounting info, when mapping_cap_account_dirty(). But that needs some more work: so in the interim, avoid the warning by using a simple SetPageDirty on PageSwapBacked pages. Reported-and-tested-by: Dave Jones <davej@redhat.com> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace enhancements from Eric Biederman: "This is a course correction for the user namespace, so that we can reach an inexpensive, maintainable, and reasonably complete implementation. Highlights: - Config guards make it impossible to enable the user namespace and code that has not been converted to be user namespace safe. - Use of the new kuid_t type ensures the if you somehow get past the config guards the kernel will encounter type errors if you enable user namespaces and attempt to compile in code whose permission checks have not been updated to be user namespace safe. - All uids from child user namespaces are mapped into the initial user namespace before they are processed. Removing the need to add an additional check to see if the user namespace of the compared uids remains the same. - With the user namespaces compiled out the performance is as good or better than it is today. - For most operations absolutely nothing changes performance or operationally with the user namespace enabled. - The worst case performance I could come up with was timing 1 billion cache cold stat operations with the user namespace code enabled. This went from 156s to 164s on my laptop (or 156ns to 164ns per stat operation). - (uid_t)-1 and (gid_t)-1 are reserved as an internal error value. Most uid/gid setting system calls treat these value specially anyway so attempting to use -1 as a uid would likely cause entertaining failures in userspace. - If setuid is called with a uid that can not be mapped setuid fails. I have looked at sendmail, login, ssh and every other program I could think of that would call setuid and they all check for and handle the case where setuid fails. - If stat or a similar system call is called from a context in which we can not map a uid we lie and return overflowuid. The LFS experience suggests not lying and returning an error code might be better, but the historical precedent with uids is different and I can not think of anything that would break by lying about a uid we can't map. - Capabilities are localized to the current user namespace making it safe to give the initial user in a user namespace all capabilities. My git tree covers all of the modifications needed to convert the core kernel and enough changes to make a system bootable to runlevel 1." Fix up trivial conflicts due to nearby independent changes in fs/stat.c * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (46 commits) userns: Silence silly gcc warning. cred: use correct cred accessor with regards to rcu read lock userns: Convert the move_pages, and migrate_pages permission checks to use uid_eq userns: Convert cgroup permission checks to use uid_eq userns: Convert tmpfs to use kuid and kgid where appropriate userns: Convert sysfs to use kgid/kuid where appropriate userns: Convert sysctl permission checks to use kuid and kgids. userns: Convert proc to use kuid/kgid where appropriate userns: Convert ext4 to user kuid/kgid where appropriate userns: Convert ext3 to use kuid/kgid where appropriate userns: Convert ext2 to use kuid/kgid where appropriate. userns: Convert devpts to use kuid/kgid where appropriate userns: Convert binary formats to use kuid/kgid where appropriate userns: Add negative depends on entries to avoid building code that is userns unsafe userns: signal remove unnecessary map_cred_ns userns: Teach inode_capable to understand inodes whose uids map to other namespaces. userns: Fail exec for suid and sgid binaries with ids outside our user namespace. userns: Convert stat to return values mapped from kuids and kgids userns: Convert user specfied uids and gids in chown into kuids and kgid userns: Use uid_eq gid_eq helpers when comparing kuids and kgids in the vfs ...
2012-05-15userns: Convert the move_pages, and migrate_pages permission checks to use ↵Eric W. Biederman
uid_eq Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-04-25mm: fix NULL ptr dereference in move_pagesSasha Levin
Commit 3268c63 ("mm: fix move/migrate_pages() race on task struct") has added an odd construct where 'mm' is checked for being NULL, and if it is, it would get dereferenced anyways by mput()ing it. Signed-off-by: Sasha Levin <levinsasha928@gmail.com> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hugh Dickins <hughd@google.com> Acked-by: Christoph Lameter <cl@linux.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21mm: fix move/migrate_pages() race on task structChristoph Lameter
Migration functions perform the rcu_read_unlock too early. As a result the task pointed to may change from under us. This can result in an oops, as reported by Dave Hansen in https://lkml.org/lkml/2012/2/23/302. The following patch extend the period of the rcu_read_lock until after the permissions checks are done. We also take a refcount so that the task reference is stable when calling security check functions and performing cpuset node validation (which takes a mutex). The refcount is dropped before actual page migration occurs so there is no change to the refcounts held during page migration. Also move the determination of the mm of the task struct to immediately before the do_migrate*() calls so that it is clear that we switch from handling the task during permission checks to the mm for the actual migration. Since the determination is only done once and we then no longer use the task_struct we can be sure that we operate on a specific address space that will not change from under us. [akpm@linux-foundation.org: checkpatch fixes] Signed-off-by: Christoph Lameter <cl@linux.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Reported-by: Dave Hansen <dave@linux.vnet.ibm.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-05memcg: fix GPF when cgroup removal races with last exitHugh Dickins
When moving tasks from old memcg (with move_charge_at_immigrate on new memcg), followed by removal of old memcg, hit General Protection Fault in mem_cgroup_lru_del_list() (called from release_pages called from free_pages_and_swap_cache from tlb_flush_mmu from tlb_finish_mmu from exit_mmap from mmput from exit_mm from do_exit). Somewhat reproducible, takes a few hours: the old struct mem_cgroup has been freed and poisoned by SLAB_DEBUG, but mem_cgroup_lru_del_list() is still trying to update its stats, and take page off lru before freeing. A task, or a charge, or a page on lru: each secures a memcg against removal. In this case, the last task has been moved out of the old memcg, and it is exiting: anonymous pages are uncharged one by one from the memcg, as they are zapped from its pagetables, so the charge gets down to 0; but the pages themselves are queued in an mmu_gather for freeing. Most of those pages will be on lru (and force_empty is careful to lru_add_drain_all, to add pages from pagevec to lru first), but not necessarily all: perhaps some have been isolated for page reclaim, perhaps some isolated for other reasons. So, force_empty may find no task, no charge and no page on lru, and let the removal proceed. There would still be no problem if these pages were immediately freed; but typically (and the put_page_testzero protocol demands it) they have to be added back to lru before they are found freeable, then removed from lru and freed. We don't see the issue when adding, because the mem_cgroup_iter() loops keep their own reference to the memcg being scanned; but when it comes to mem_cgroup_lru_del_list(). I believe this was not an issue in v3.2: there, PageCgroupAcctLRU and PageCgroupUsed flags were used (like a trick with mirrors) to deflect view of pc->mem_cgroup to the stable root_mem_cgroup when neither set. 38c5d72f3ebe ("memcg: simplify LRU handling by new rule") mercifully removed those convolutions, but left this General Protection Fault. But it's surprisingly easy to restore the old behaviour: just check PageCgroupUsed in mem_cgroup_lru_add_list() (which decides on which lruvec to add), and reset pc to root_mem_cgroup if page is uncharged. A risky change? just going back to how it worked before; testing, and an audit of uses of pc->mem_cgroup, show no problem. And there's a nice bonus: with mem_cgroup_lru_add_list() itself making sure that an uncharged page goes to root lru, mem_cgroup_reset_owner() no longer has any purpose, and we can safely revert 4e5f01c2b9b9 ("memcg: clear pc->mem_cgroup if necessary"). Calling update_page_reclaim_stat() after add_page_to_lru_list() in swap.c is not strictly necessary: the lru_lock there, with RCU before memcg structures are freed, makes mem_cgroup_get_reclaim_stat_from_page safe without that; but it seems cleaner to rely on one dependency less. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Konstantin Khlebnikov <khlebnikov@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-03mm: postpone migrated page mapping resetKonstantin Khlebnikov
Postpone resetting page->mapping until the final remove_migration_ptes(). Otherwise the expression PageAnon(migration_entry_to_page(entry)) does not work. Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Hugh Dickins <hughd@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12mm: compaction: introduce sync-light migration for use by compactionMel Gorman
This patch adds a lightweight sync migrate operation MIGRATE_SYNC_LIGHT mode that avoids writing back pages to backing storage. Async compaction maps to MIGRATE_ASYNC while sync compaction maps to MIGRATE_SYNC_LIGHT. For other migrate_pages users such as memory hotplug, MIGRATE_SYNC is used. This avoids sync compaction stalling for an excessive length of time, particularly when copying files to a USB stick where there might be a large number of dirty pages backed by a filesystem that does not support ->writepages. [aarcange@redhat.com: This patch is heavily based on Andrea's work] [akpm@linux-foundation.org: fix fs/nfs/write.c build] [akpm@linux-foundation.org: fix fs/btrfs/disk-io.c build] Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Dave Jones <davej@redhat.com> Cc: Jan Kara <jack@suse.cz> Cc: Andy Isaacson <adi@hexapodia.org> Cc: Nai Xia <nai.xia@gmail.com> Cc: Johannes Weiner <jweiner@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12mm: compaction: determine if dirty pages can be migrated without blocking ↵Mel Gorman
within ->migratepage Asynchronous compaction is used when allocating transparent hugepages to avoid blocking for long periods of time. Due to reports of stalling, there was a debate on disabling synchronous compaction but this severely impacted allocation success rates. Part of the reason was that many dirty pages are skipped in asynchronous compaction by the following check; if (PageDirty(page) && !sync && mapping->a_ops->migratepage != migrate_page) rc = -EBUSY; This skips over all mapping aops using buffer_migrate_page() even though it is possible to migrate some of these pages without blocking. This patch updates the ->migratepage callback with a "sync" parameter. It is the responsibility of the callback to fail gracefully if migration would block. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Dave Jones <davej@redhat.com> Cc: Jan Kara <jack@suse.cz> Cc: Andy Isaacson <adi@hexapodia.org> Cc: Nai Xia <nai.xia@gmail.com> Cc: Johannes Weiner <jweiner@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12memcg: clear pc->mem_cgroup if necessary.KAMEZAWA Hiroyuki
This is a preparation before removing a flag PCG_ACCT_LRU in page_cgroup and reducing atomic ops/complexity in memcg LRU handling. In some cases, pages are added to lru before charge to memcg and pages are not classfied to memory cgroup at lru addtion. Now, the lru where the page should be added is determined a bit in page_cgroup->flags and pc->mem_cgroup. I'd like to remove the check of flag. To handle the case pc->mem_cgroup may contain stale pointers if pages are added to LRU before classification. This patch resets pc->mem_cgroup to root_mem_cgroup before lru additions. [akpm@linux-foundation.org: fix CONFIG_CGROUP_MEM_CONT=n build] [hughd@google.com: fix CONFIG_CGROUP_MEM_RES_CTLR=y CONFIG_CGROUP_MEM_RES_CTLR_SWAP=n build] [akpm@linux-foundation.org: ksm.c needs memcontrol.h, per Michal] [hughd@google.com: stop oops in mem_cgroup_reset_owner()] [hughd@google.com: fix page migration to reset_owner] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Miklos Szeredi <mszeredi@suse.cz> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Ying Han <yinghan@google.com> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10mm/migrate.c: remove the unused macro lru_to_pageWang Sheng-Hui
lru_to_page is not used in mm/migrate.c. Signed-off-by: Wang Sheng-Hui <shhuiw@gmail.com> Acked-by: Mel Gorman <mgorman@suse.de> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10mm/migrate.c: cleanup comment for migration_entry_wait()Wang Sheng-Hui
migration_entry_wait() can also be called from hugetlb_fault() now. Remove the incorrect comment. Signed-off-by: Wang Sheng-Hui <shhuiw@gmail.com> Acked-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10mm: migrate: one less atomic operationJacobo Giralt
migrate_page_move_mapping() drops a reference from the old page after unfreezing its counter. Both operations can be merged into a single atomic operation by directly unfreezing to one less reference. The same applies to migrate_huge_page_move_mapping(). Signed-off-by: Jacobo Giralt <jacobo.giralt@gmail.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Johannes Weiner <jweiner@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-12-09mm/migrate.c: pair unlock_page() and lock_page() when migrating huge pagesHillf Danton
Avoid unlocking and unlocked page if we failed to lock it. Signed-off-by: Hillf Danton <dhillf@gmail.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-06Merge branch 'modsplit-Oct31_2011' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux * 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits) Revert "tracing: Include module.h in define_trace.h" irq: don't put module.h into irq.h for tracking irqgen modules. bluetooth: macroize two small inlines to avoid module.h ip_vs.h: fix implicit use of module_get/module_put from module.h nf_conntrack.h: fix up fallout from implicit moduleparam.h presence include: replace linux/module.h with "struct module" wherever possible include: convert various register fcns to macros to avoid include chaining crypto.h: remove unused crypto_tfm_alg_modname() inline uwb.h: fix implicit use of asm/page.h for PAGE_SIZE pm_runtime.h: explicitly requires notifier.h linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h miscdevice.h: fix up implicit use of lists and types stop_machine.h: fix implicit use of smp.h for smp_processor_id of: fix implicit use of errno.h in include/linux/of.h of_platform.h: delete needless include <linux/module.h> acpi: remove module.h include from platform/aclinux.h miscdevice.h: delete unnecessary inclusion of module.h device_cgroup.h: delete needless include <linux/module.h> net: sch_generic remove redundant use of <linux/module.h> net: inet_timewait_sock doesnt need <linux/module.h> ... Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in - drivers/media/dvb/frontends/dibx000_common.c - drivers/media/video/{mt9m111.c,ov6650.c} - drivers/mfd/ab3550-core.c - include/linux/dmaengine.h
2011-10-31mm: migration: clean up unmap_and_move()Minchan Kim
unmap_and_move() is one a big messy function. Clean it up. Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31mm: Map most files to use export.h instead of module.hPaul Gortmaker
The files changed within are only using the EXPORT_SYMBOL macro variants. They are not using core modular infrastructure and hence don't need module.h but only the export.h header. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-19mm: fix race between mremap and removing migration entryHugh Dickins
I don't usually pay much attention to the stale "? " addresses in stack backtraces, but this lucky report from Pawel Sikora hints that mremap's move_ptes() has inadequate locking against page migration. 3.0 BUG_ON(!PageLocked(p)) in migration_entry_to_page(): kernel BUG at include/linux/swapops.h:105! RIP: 0010:[<ffffffff81127b76>] [<ffffffff81127b76>] migration_entry_wait+0x156/0x160 [<ffffffff811016a1>] handle_pte_fault+0xae1/0xaf0 [<ffffffff810feee2>] ? __pte_alloc+0x42/0x120 [<ffffffff8112c26b>] ? do_huge_pmd_anonymous_page+0xab/0x310 [<ffffffff81102a31>] handle_mm_fault+0x181/0x310 [<ffffffff81106097>] ? vma_adjust+0x537/0x570 [<ffffffff81424bed>] do_page_fault+0x11d/0x4e0 [<ffffffff81109a05>] ? do_mremap+0x2d5/0x570 [<ffffffff81421d5f>] page_fault+0x1f/0x30 mremap's down_write of mmap_sem, together with i_mmap_mutex or lock, and pagetable locks, were good enough before page migration (with its requirement that every migration entry be found) came in, and enough while migration always held mmap_sem; but not enough nowadays, when there's memory hotremove and compaction. The danger is that move_ptes() lets a migration entry dodge around behind remove_migration_pte()'s back, so it's in the old location when looking at the new, then in the new location when looking at the old. Either mremap's move_ptes() must additionally take anon_vma lock(), or migration's remove_migration_pte() must stop peeking for is_swap_entry() before it takes pagetable lock. Consensus chooses the latter: we prefer to add overhead to migration than to mremapping, which gets used by JVMs and by exec stack setup. Reported-and-tested-by: Paweł Sikora <pluto@agmk.net> Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Mel Gorman <mgorman@suse.de> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-16migrate: don't account swapcache as shmemAndrea Arcangeli
swapcache will reach the below code path in migrate_page_move_mapping, and swapcache is accounted as NR_FILE_PAGES but it's not accounted as NR_SHMEM. Hugh pointed out we must use PageSwapCache instead of comparing mapping to &swapper_space, to avoid build failure with CONFIG_SWAP=n. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: use refcounts for page_lock_anon_vma()Peter Zijlstra
Convert page_lock_anon_vma() over to use refcounts. This is done to prepare for the conversion of anon_vma from spinlock to mutex. Sadly this inceases the cost of page_lock_anon_vma() from one to two atomics, a follow up patch addresses this, lets keep that simple for now. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Miller <davem@davemloft.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Tony Luck <tony.luck@intel.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23memcg: fix ugly initialization of return value is in callerKAMEZAWA Hiroyuki
Remove initialization of vaiable in caller of memory cgroup function. Actually, it's return value of memcg function but it's initialized in caller. Some memory cgroup uses following style to bring the result of start function to the end function for avoiding races. mem_cgroup_start_A(&(*ptr)) /* Something very complicated can happen here. */ mem_cgroup_end_A(*ptr) In some calls, *ptr should be initialized to NULL be caller. But it's ugly. This patch fixes that *ptr is initialized by _start function. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22mm: compaction: Use async migration for __GFP_NO_KSWAPD and enforce no writebackAndrea Arcangeli
__GFP_NO_KSWAPD allocations are usually very expensive and not mandatory to succeed as they have graceful fallback. Waiting for I/O in those, tends to be overkill in terms of latencies, so we can reduce their latency by disabling sync migrate. Unfortunately, even with async migration it's still possible for the process to be blocked waiting for a request slot (e.g. get_request_wait in the block layer) when ->writepage is called. To prevent __GFP_NO_KSWAPD blocking, this patch prevents ->writepage being called on dirty page cache for asynchronous migration. Addresses https://bugzilla.kernel.org/show_bug.cgi?id=31142 [mel@csn.ul.ie: Avoid writebacks for NFS, retry locked pages, use bool] Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Arthur Marsh <arthur.marsh@internode.on.net> Cc: Clemens Ladisch <cladisch@googlemail.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Minchan Kim <minchan.kim@gmail.com> Reported-by: Alex Villacis Lasso <avillaci@ceibo.fiec.espol.edu.ec> Tested-by: Alex Villacis Lasso <avillaci@ceibo.fiec.espol.edu.ec> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22mm: rename drop_anon_vma() to put_anon_vma()Peter Zijlstra
The normal code pattern used in the kernel is: get/put. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Hugh Dickins <hughd@google.com> Reviewed-by: Rik van Riel <riel@redhat.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22mm: add replace_page_cache_page() functionMiklos Szeredi
This function basically does: remove_from_page_cache(old); page_cache_release(old); add_to_page_cache_locked(new); Except it does this atomically, so there's no possibility for the "add" to fail because of a race. If memory cgroups are enabled, then the memory cgroup charge is also moved from the old page to the new. This function is currently used by fuse to move pages into the page cache on read, instead of copying the page contents. [minchan.kim@gmail.com: add freepage() hook to replace_page_cache_page()] Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-25mm: grab rcu read lock in move_pages()Greg Thelen
The move_pages() usage of find_task_by_vpid() requires rcu_read_lock() to prevent free_pid() from reclaiming the pid. Without this patch, RCU warnings are printed in v2.6.38-rc4 move_pages() with: CONFIG_LOCKUP_DETECTOR=y CONFIG_PREEMPT=y CONFIG_LOCKDEP=y CONFIG_PROVE_LOCKING=y CONFIG_PROVE_RCU=y Previously, migrate_pages() went through a similar transformation replacing usage of tasklist_lock with rcu read lock: commit 55cfaa3cbdd29c4919ecb5fb8965c310f357e48c Author: Zeng Zhaoming <zengzm.kernel@gmail.com> Date: Thu Dec 2 14:31:13 2010 -0800 mm/mempolicy.c: add rcu read lock to protect pid structure commit 1e50df39f6e2c3a4a3394df62baa8a213df16c54 Author: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Date: Thu Jan 13 15:46:14 2011 -0800 mempolicy: remove tasklist_lock from migrate_pages Signed-off-by: Greg Thelen <gthelen@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Zeng Zhaoming <zengzm.kernel@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-02mm/migration: fix page corruption during hugepage migrationMinchan Kim
If migrate_huge_page by memory-failure fails , it calls put_page in itself to decrease page reference and caller of migrate_huge_page also calls putback_lru_pages. It can do double free of page so it can make page corruption on page holder. In addtion, clean of pages on caller is consistent behavior with migrate_pages by cf608ac19c ("mm: compaction: fix COMPACTPAGEFAILED counting"). Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Christoph Lameter <cl@linux.com> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-02mm: when migrate_pages returns 0, all pages must have been releasedAndrea Arcangeli
In some cases migrate_pages could return zero while still leaving a few pages in the pagelist (and some caller wouldn't notice it has to call putback_lru_pages after commit cf608ac19c9 ("mm: compaction: fix COMPACTPAGEFAILED counting")). Add one missing putback_lru_pages not added by commit cf608ac19c95 ("mm: compaction: fix COMPACTPAGEFAILED counting"). Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: Christoph Lameter <cl@linux.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-26mm: migration: clarify migrate_pages() commentMinchan Kim
Callers of migrate_pages should putback_lru_pages to return pages isolated to LRU or free list. Now comment is rather confusing. It says caller always have to call it. It is more clear to point out that the caller has to call it if migrate_pages's return value isn't zero. Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Cc: Christoph Lameter <cl@linux.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13memcg: fix memory migration of shmem swapcacheDaisuke Nishimura
In the current implementation mem_cgroup_end_migration() decides whether the page migration has succeeded or not by checking "oldpage->mapping". But if we are tring to migrate a shmem swapcache, the page->mapping of it is NULL from the begining, so the check would be invalid. As a result, mem_cgroup_end_migration() assumes the migration has succeeded even if it's not, so "newpage" would be freed while it's not uncharged. This patch fixes it by passing mem_cgroup_end_migration() the result of the page migration. Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13mm: fix hugepage migrationHugh Dickins
2.6.37 added an unmap_and_move_huge_page() for memory failure recovery, but its anon_vma handling was still based around the 2.6.35 conventions. Update it to use page_lock_anon_vma, get_anon_vma, page_unlock_anon_vma, drop_anon_vma in the same way as we're now changing unmap_and_move(). I don't particularly like to propose this for stable when I've not seen its problems in practice nor tested the solution: but it's clearly out of synch at present. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik van Riel <riel@redhat.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: "Jun'ichi Nomura" <j-nomura@ce.jp.nec.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: <stable@kernel.org> [2.6.37, 2.6.36] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13mm: fix migration hangs on anon_vma lockHugh Dickins
Increased usage of page migration in mmotm reveals that the anon_vma locking in unmap_and_move() has been deficient since 2.6.36 (or even earlier). Review at the time of f18194275c39835cb84563500995e0d503a32d9a ("mm: fix hang on anon_vma->root->lock") missed the issue here: the anon_vma to which we get a reference may already have been freed back to its slab (it is in use when we check page_mapped, but that can change), and so its anon_vma->root may be switched at any moment by reuse in anon_vma_prepare. Perhaps we could fix that with a get_anon_vma_unless_zero(), but let's not: just rely on page_lock_anon_vma() to do all the hard thinking for us, then we don't need any rcu read locking over here. In removing the rcu_unlock label: since PageAnon is a bit in page->mapping, it's impossible for a !page->mapping page to be anon; but insert VM_BUG_ON in case the implementation ever changes. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Hugh Dickins <hughd@google.com> Reviewed-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: "Jun'ichi Nomura" <j-nomura@ce.jp.nec.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: <stable@kernel.org> [2.6.37, 2.6.36] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13mm: migration: use rcu_dereference_protected when dereferencing the radix ↵Mel Gorman
tree slot during file page migration migrate_pages() -> unmap_and_move() only calls rcu_read_lock() for anonymous pages, as introduced by git commit 989f89c57e6361e7d16fbd9572b5da7d313b073d ("fix rcu_read_lock() in page migraton"). The point of the RCU protection there is part of getting a stable reference to anon_vma and is only held for anon pages as file pages are locked which is sufficient protection against freeing. However, while a file page's mapping is being migrated, the radix tree is double checked to ensure it is the expected page. This uses radix_tree_deref_slot() -> rcu_dereference() without the RCU lock held triggering the following warning. [ 173.674290] =================================================== [ 173.676016] [ INFO: suspicious rcu_dereference_check() usage. ] [ 173.676016] --------------------------------------------------- [ 173.676016] include/linux/radix-tree.h:145 invoked rcu_dereference_check() without protection! [ 173.676016] [ 173.676016] other info that might help us debug this: [ 173.676016] [ 173.676016] [ 173.676016] rcu_scheduler_active = 1, debug_locks = 0 [ 173.676016] 1 lock held by hugeadm/2899: [ 173.676016] #0: (&(&inode->i_data.tree_lock)->rlock){..-.-.}, at: [<c10e3d2b>] migrate_page_move_mapping+0x40/0x1ab [ 173.676016] [ 173.676016] stack backtrace: [ 173.676016] Pid: 2899, comm: hugeadm Not tainted 2.6.37-rc5-autobuild [ 173.676016] Call Trace: [ 173.676016] [<c128cc01>] ? printk+0x14/0x1b [ 173.676016] [<c1063502>] lockdep_rcu_dereference+0x7d/0x86 [ 173.676016] [<c10e3db5>] migrate_page_move_mapping+0xca/0x1ab [ 173.676016] [<c10e41ad>] migrate_page+0x23/0x39 [ 173.676016] [<c10e491b>] buffer_migrate_page+0x22/0x107 [ 173.676016] [<c10e48f9>] ? buffer_migrate_page+0x0/0x107 [ 173.676016] [<c10e425d>] move_to_new_page+0x9a/0x1ae [ 173.676016] [<c10e47e6>] migrate_pages+0x1e7/0x2fa This patch introduces radix_tree_deref_slot_protected() which calls rcu_dereference_protected(). Users of it must pass in the mapping->tree_lock that is protecting this dereference. Holding the tree lock protects against parallel updaters of the radix tree meaning that rcu_dereference_protected is allowable. [akpm@linux-foundation.org: remove unneeded casts] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Milton Miller <miltonm@bga.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: <stable@kernel.org> [2.6.37.early] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13thp: pmd_trans_huge migrate bugcheckAndrea Arcangeli
No pmd_trans_huge should ever materialize in migration ptes areas, because we split the hugepage before migration ptes are instantiated. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13mm: migration: cleanup migrate_pages API by matching types for offlining and ↵Mel Gorman
sync With the introduction of the boolean sync parameter, the API looks a little inconsistent as offlining is still an int. Convert offlining to a bool for the sake of being tidy. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13mm: migration: allow migration to operate asynchronously and avoid ↵Mel Gorman
synchronous compaction in the faster path Migration synchronously waits for writeback if the initial passes fails. Callers of memory compaction do not necessarily want this behaviour if the caller is latency sensitive or expects that synchronous migration is not going to have a significantly better success rate. This patch adds a sync parameter to migrate_pages() allowing the caller to indicate if wait_on_page_writeback() is allowed within migration or not. For reclaim/compaction, try_to_compact_pages() is first called asynchronously, direct reclaim runs and then try_to_compact_pages() is called synchronously as there is a greater expectation that it'll succeed. [akpm@linux-foundation.org: build/merge fix] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13mm: vmscan: reclaim order-0 and use compaction instead of lumpy reclaimMel Gorman
Lumpy reclaim is disruptive. It reclaims a large number of pages and ignores the age of the pages it reclaims. This can incur significant stalls and potentially increase the number of major faults. Compaction has reached the point where it is considered reasonably stable (meaning it has passed a lot of testing) and is a potential candidate for displacing lumpy reclaim. This patch introduces an alternative to lumpy reclaim whe compaction is available called reclaim/compaction. The basic operation is very simple - instead of selecting a contiguous range of pages to reclaim, a number of order-0 pages are reclaimed and then compaction is later by either kswapd (compact_zone_order()) or direct compaction (__alloc_pages_direct_compact()). [akpm@linux-foundation.org: fix build] [akpm@linux-foundation.org: use conventional task_struct naming] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-22mm/migrate.c: fix compilation errorMichal Nazarewicz
GCC complained about update_mmu_cache() not being defined in migrate.c. Including <asm/tlbflush.h> seems to solve the problem. Signed-off-by: Michal Nazarewicz <m.nazarewicz@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26mm: fix error reporting in move_pages() syscallGleb Natapov
The vma returned by find_vma does not necessarily include the target address. If this happens the code tries to follow a page outside of any vma and returns ENOENT instead of EFAULT. Signed-off-by: Gleb Natapov <gleb@redhat.com> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26mm: compaction: fix COMPACTPAGEFAILED countingMinchan Kim
Presently update_nr_listpages() doesn't have a role. That's because lists passed is always empty just after calling migrate_pages. The migrate_pages cleans up page list which have failed to migrate before returning by aaa994b3. [PATCH] page migration: handle freeing of pages in migrate_pages() Do not leave pages on the lists passed to migrate_pages(). Seems that we will not need any postprocessing of pages. This will simplify the handling of pages by the callers of migrate_pages(). At that time, we thought we don't need any postprocessing of pages. But the situation is changed. The compaction need to know the number of failed to migrate for COMPACTPAGEFAILED stat This patch makes new rule for caller of migrate_pages to call putback_lru_pages. So caller need to clean up the lists so it has a chance to postprocess the pages. [suggested by Christoph Lameter] Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Cc: Hugh Dickins <hughd@google.com> Cc: Andi Kleen <andi@firstfloor.org> Reviewed-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Wu Fengguang <fengguang.wu@intel.com> Acked-by: Christoph Lameter <cl@linux.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26writeback: remove nonblocking/encountered_congestion referencesWu Fengguang
This removes more dead code that was somehow missed by commit 0d99519efef (writeback: remove unused nonblocking and congestion checks). There are no behavior change except for the removal of two entries from one of the ext4 tracing interface. The nonblocking checks in ->writepages are no longer used because the flusher now prefer to block on get_request_wait() than to skip inodes on IO congestion. The latter will lead to more seeky IO. The nonblocking checks in ->writepage are no longer used because it's redundant with the WB_SYNC_NONE check. We no long set ->nonblocking in VM page out and page migration, because a) it's effectively redundant with WB_SYNC_NONE in current code b) it's old semantic of "Don't get stuck on request queues" is mis-behavior: that would skip some dirty inodes on congestion and page out others, which is unfair in terms of LRU age. Inspired by Christoph Hellwig. Thanks! Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: David Howells <dhowells@redhat.com> Cc: Sage Weil <sage@newdream.net> Cc: Steve French <sfrench@samba.org> Cc: Chris Mason <chris.mason@oracle.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-11Fix migration.c compilation on s390Andi Kleen
31bit s390 doesn't have huge pages and failed with: > mm/migrate.c: In function 'remove_migration_pte': > mm/migrate.c:143:3: error: implicit declaration of function 'pte_mkhuge' > mm/migrate.c:143:7: error: incompatible types when assigning to type 'pte_t' from type 'int' Put that code into a ifdef. Reported by Heiko Carstens Signed-off-by: Andi Kleen <ak@linux.intel.com>
2010-10-08hugetlb: hugepage migration coreNaoya Horiguchi
This patch extends page migration code to support hugepage migration. One of the potential users of this feature is soft offlining which is triggered by memory corrected errors (added by the next patch.) Todo: - there are other users of page migration such as memory policy, memory hotplug and memocy compaction. They are not ready for hugepage support for now. ChangeLog since v4: - define migrate_huge_pages() - remove changes on isolation/putback_lru_page() ChangeLog since v2: - refactor isolate/putback_lru_page() to handle hugepage - add comment about race on unmap_and_move_huge_page() ChangeLog since v1: - divide migration code path for hugepage - define routine checking migration swap entry for hugetlb - replace "goto" with "if/else" in remove_migration_pte() Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2010-08-09mm: extend KSM refcounts to the anon_vma rootRik van Riel
KSM reference counts can cause an anon_vma to exist after the processe it belongs to have already exited. Because the anon_vma lock now lives in the root anon_vma, we need to ensure that the root anon_vma stays around until after all the "child" anon_vmas have been freed. The obvious way to do this is to have a "child" anon_vma take a reference to the root in anon_vma_fork. When the anon_vma is freed at munmap or process exit, we drop the refcount in anon_vma_unlink and possibly free the root anon_vma. The KSM anon_vma reference count function also needs to be modified to deal with the possibility of freeing 2 levels of anon_vma. The easiest way to do this is to break out the KSM magic and make it generic. When compiling without CONFIG_KSM, this code is compiled out. Signed-off-by: Rik van Riel <riel@redhat.com> Tested-by: Larry Woodman <lwoodman@redhat.com> Acked-by: Larry Woodman <lwoodman@redhat.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Tested-by: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09mm: always lock the root (oldest) anon_vmaRik van Riel
Always (and only) lock the root (oldest) anon_vma whenever we do something in an anon_vma. The recently introduced anon_vma scalability is due to the rmap code scanning only the VMAs that need to be scanned. Many common operations still took the anon_vma lock on the root anon_vma, so always taking that lock is not expected to introduce any scalability issues. However, always taking the same lock does mean we only need to take one lock, which means rmap_walk on pages from any anon_vma in the vma is excluded from occurring during an munmap, expand_stack or other operation that needs to exclude rmap_walk and similar functions. Also add the proper locking to vma_adjust. Signed-off-by: Rik van Riel <riel@redhat.com> Tested-by: Larry Woodman <lwoodman@redhat.com> Acked-by: Larry Woodman <lwoodman@redhat.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09mm: change direct call of spin_lock(anon_vma->lock) to inline functionRik van Riel
Subsitute a direct call of spin_lock(anon_vma->lock) with an inline function doing exactly the same. This makes it easier to do the substitution to the root anon_vma lock in a following patch. We will deal with the handful of special locks (nested, dec_and_lock, etc) separately. Signed-off-by: Rik van Riel <riel@redhat.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Tested-by: Larry Woodman <lwoodman@redhat.com> Acked-by: Larry Woodman <lwoodman@redhat.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27memcg: fix mis-accounting of file mapped racy with migrationakpm@linux-foundation.org
FILE_MAPPED per memcg of migrated file cache is not properly updated, because our hook in page_add_file_rmap() can't know to which memcg FILE_MAPPED should be counted. Basically, this patch is for fixing the bug but includes some big changes to fix up other messes. Now, at migrating mapped file, events happen in following sequence. 1. allocate a new page. 2. get memcg of an old page. 3. charge ageinst a new page before migration. But at this point, no changes to new page's page_cgroup, no commit for the charge. (IOW, PCG_USED bit is not set.) 4. page migration replaces radix-tree, old-page and new-page. 5. page migration remaps the new page if the old page was mapped. 6. Here, the new page is unlocked. 7. memcg commits the charge for newpage, Mark the new page's page_cgroup as PCG_USED. Because "commit" happens after page-remap, we can count FILE_MAPPED at "5", because we should avoid to trust page_cgroup->mem_cgroup. if PCG_USED bit is unset. (Note: memcg's LRU removal code does that but LRU-isolation logic is used for helping it. When we overwrite page_cgroup->mem_cgroup, page_cgroup is not on LRU or page_cgroup->mem_cgroup is NULL.) We can lose file_mapped accounting information at 5 because FILE_MAPPED is updated only when mapcount changes 0->1. So we should catch it. BTW, historically, above implemntation comes from migration-failure of anonymous page. Because we charge both of old page and new page with mapcount=0, we can't catch - the page is really freed before remap. - migration fails but it's freed before remap or .....corner cases. New migration sequence with memcg is: 1. allocate a new page. 2. mark PageCgroupMigration to the old page. 3. charge against a new page onto the old page's memcg. (here, new page's pc is marked as PageCgroupUsed.) 4. page migration replaces radix-tree, page table, etc... 5. At remapping, new page's page_cgroup is now makrked as "USED" We can catch 0->1 event and FILE_MAPPED will be properly updated. And we can catch SWAPOUT event after unlock this and freeing this page by unmap() can be caught. 7. Clear PageCgroupMigration of the old page. So, FILE_MAPPED will be correctly updated. Then, for what MIGRATION flag is ? Without it, at migration failure, we may have to charge old page again because it may be fully unmapped. "charge" means that we have to dive into memory reclaim or something complated. So, it's better to avoid charge it again. Before this patch, __commit_charge() was working for both of the old/new page and fixed up all. But this technique has some racy condtion around FILE_MAPPED and SWAPOUT etc... Now, the kernel use MIGRATION flag and don't uncharge old page until the end of migration. I hope this change will make memcg's page migration much simpler. This page migration has caused several troubles. Worth to add a flag for simplification. Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Tested-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Reported-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
