path: root/mm/migrate.c
2015-04-15mm/migrate: check-before-clear PageSwapCacheNaoya Horiguchi
With the page flag sanitization patchset, an invalid usage of ClearPageSwapCache() is detected in migration_page_copy(). migrate_page_copy() is shared by both normal and hugepage (both thp and hugetlb) code path, so let's check PageSwapCache() and clear it if it's set to avoid misuse of the invalid clear operation. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-14mm: numa: remove migrate_ratelimitedMel Gorman
This code is dead since commit 9e645ab6d089 ("sched/numa: Continue PTE scanning even if migrate rate limited") so remove it. Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-14mm/migrate: mark unmap_and_move() "noinline" to avoid ICE in gcc 4.7.3Geert Uytterhoeven
With gcc version 4.7.3 (Ubuntu/Linaro 4.7.3-12ubuntu1) : mm/migrate.c: In function `migrate_pages': mm/migrate.c:1148:1: internal compiler error: in push_minipool_fix, at config/arm/arm.c:13500 Please submit a full bug report, with preprocessed source if appropriate. See <file:///usr/share/doc/gcc-4.7/README.Bugs> for instructions. Preprocessed source stored into /tmp/ccPoM1tr.out file, please attach this to your bugreport. make[1]: *** [mm/migrate.o] Error 1 make: *** [mm/migrate.o] Error 2 Mark unmap_and_move() (which is used in a single place only) "noinline" to work around this compiler bug. [akpm@linux-foundation.org: make it conditional on gcc-4.7.3 and arm] [khilman@kernel.org: fine-tune compiler versions] [akpm@linux-foundation.org: fix comment] Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Reported-by: Kevin Hilman <khilman@kernel.org> Cc: Marc Zyngier <marc.zyngier@arm.com> Tested-by: Kevin Hilman <khilman@linaro.org> Tested-by: Lina Iyer <lina.iyer@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-12mm: convert p[te|md]_mknonnuma and remaining page table manipulationsMel Gorman
With PROT_NONE, the traditional page table manipulation functions are sufficient. [andre.przywara@arm.com: fix compiler warning in pmdp_invalidate()] [akpm@linux-foundation.org: fix build with STRICT_MM_TYPECHECKS] Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: Aneesh Kumar <aneesh.kumar@linux.vnet.ibm.com> Tested-by: Sasha Levin <sasha.levin@oracle.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Dave Jones <davej@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-12mm: numa: do not dereference pmd outside of the lock during NUMA hinting faultMel Gorman
Automatic NUMA balancing depends on being able to protect PTEs to trap a fault and gather reference locality information. Very broadly speaking it would mark PTEs as not present and use another bit to distinguish between NUMA hinting faults and other types of faults. It was universally loved by everybody and caused no problems whatsoever. That last sentence might be a lie. This series is very heavily based on patches from Linus and Aneesh to replace the existing PTE/PMD NUMA helper functions with normal change protections. I did alter and add parts of it but I consider them relatively minor contributions. At their suggestion, acked-bys are in there but I've no problem converting them to Signed-off-by if requested. AFAIK, this has received no testing on ppc64 and I'm depending on Aneesh for that. I tested trinity under kvm-tool and passed and ran a few other basic tests. At the time of writing, only the short-lived tests have completed but testing of V2 indicated that long-term testing had no surprises. In most cases I'm leaving out detail as it's not that interesting. specjbb single JVM: There was negligible performance difference in the benchmark itself for short runs. However, system activity is higher and interrupts are much higher over time -- possibly TLB flushes. Migrations are also higher. Overall, this is more overhead but considering the problems faced with the old approach I think we just have to suck it up and find another way of reducing the overhead. specjbb multi JVM: Negligible performance difference to the actual benchmark but like the single JVM case, the system overhead is noticeably higher. Again, interrupts are a major factor. autonumabench: This was all over the place and about all that can be reasonably concluded is that it's different but not necessarily better or worse. autonumabench 3.18.0-rc5 3.18.0-rc5 mmotm-20141119 protnone-v3r3 User NUMA01 32380.24 ( 0.00%) 21642.92 ( 33.16%) User NUMA01_THEADLOCAL 22481.02 ( 0.00%) 22283.22 ( 0.88%) User NUMA02 3137.00 ( 0.00%) 3116.54 ( 0.65%) User NUMA02_SMT 1614.03 ( 0.00%) 1543.53 ( 4.37%) System NUMA01 322.97 ( 0.00%) 1465.89 (-353.88%) System NUMA01_THEADLOCAL 91.87 ( 0.00%) 49.32 ( 46.32%) System NUMA02 37.83 ( 0.00%) 14.61 ( 61.38%) System NUMA02_SMT 7.36 ( 0.00%) 7.45 ( -1.22%) Elapsed NUMA01 716.63 ( 0.00%) 599.29 ( 16.37%) Elapsed NUMA01_THEADLOCAL 553.98 ( 0.00%) 539.94 ( 2.53%) Elapsed NUMA02 83.85 ( 0.00%) 83.04 ( 0.97%) Elapsed NUMA02_SMT 86.57 ( 0.00%) 79.15 ( 8.57%) CPU NUMA01 4563.00 ( 0.00%) 3855.00 ( 15.52%) CPU NUMA01_THEADLOCAL 4074.00 ( 0.00%) 4136.00 ( -1.52%) CPU NUMA02 3785.00 ( 0.00%) 3770.00 ( 0.40%) CPU NUMA02_SMT 1872.00 ( 0.00%) 1959.00 ( -4.65%) System CPU usage of NUMA01 is worse but it's an adverse workload on this machine so I'm reluctant to conclude that it's a problem that matters. On the other workloads that are sensible on this machine, system CPU usage is great. Overall time to complete the benchmark is comparable 3.18.0-rc5 3.18.0-rc5 mmotm-20141119protnone-v3r3 User 59612.50 48586.44 System 460.22 1537.45 Elapsed 1442.20 1304.29 NUMA alloc hit 5075182 5743353 NUMA alloc miss 0 0 NUMA interleave hit 0 0 NUMA alloc local 5075174 5743339 NUMA base PTE updates 637061448 443106883 NUMA huge PMD updates 1243434 864747 NUMA page range updates 1273699656 885857347 NUMA hint faults 1658116 1214277 NUMA hint local faults 959487 754113 NUMA hint local percent 57 62 NUMA pages migrated 5467056 61676398 The NUMA pages migrated look terrible but when I looked at a graph of the activity over time I see that the massive spike in migration activity was during NUMA01. This correlates with high system CPU usage and could be simply down to bad luck but any modifications that affect that workload would be related to scan rates and migrations, not the protection mechanism. For all other workloads, migration activity was comparable. Overall, headline performance figures are comparable but the overhead is higher, mostly in interrupts. To some extent, higher overhead from this approach was anticipated but not to this degree. It's going to be necessary to reduce this again with a separate series in the future. It's still worth going ahead with this series though as it's likely to avoid constant headaches with Xen and is probably easier to maintain. This patch (of 10): A transhuge NUMA hinting fault may find the page is migrating and should wait until migration completes. The check is race-prone because the pmd is deferenced outside of the page lock and while the race is tiny, it'll be larger if the PMD is cleared while marking PMDs for hinting fault. This patch closes the race. Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Dave Jones <davej@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Rik van Riel <riel@redhat.com> Cc: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-11mm/hugetlb: take page table lock in follow_huge_pmd()Naoya Horiguchi
We have a race condition between move_pages() and freeing hugepages, where move_pages() calls follow_page(FOLL_GET) for hugepages internally and tries to get its refcount without preventing concurrent freeing. This race crashes the kernel, so this patch fixes it by moving FOLL_GET code for hugepages into follow_huge_pmd() with taking the page table lock. This patch intentionally removes page==NULL check after pte_page. This is justified because pte_page() never returns NULL for any architectures or configurations. This patch changes the behavior of follow_huge_pmd() for tail pages and then tail pages can be pinned/returned. So the caller must be changed to properly handle the returned tail pages. We could have a choice to add the similar locking to follow_huge_(addr|pud) for consistency, but it's not necessary because currently these functions don't support FOLL_GET flag, so let's leave it for future development. Here is the reproducer: $ cat movepages.c #include <stdio.h> #include <stdlib.h> #include <numaif.h> #define ADDR_INPUT 0x700000000000UL #define HPS 0x200000 #define PS 0x1000 int main(int argc, char *argv[]) { int i; int nr_hp = strtol(argv[1], NULL, 0); int nr_p = nr_hp * HPS / PS; int ret; void **addrs; int *status; int *nodes; pid_t pid; pid = strtol(argv[2], NULL, 0); addrs = malloc(sizeof(char *) * nr_p + 1); status = malloc(sizeof(char *) * nr_p + 1); nodes = malloc(sizeof(char *) * nr_p + 1); while (1) { for (i = 0; i < nr_p; i++) { addrs[i] = (void *)ADDR_INPUT + i * PS; nodes[i] = 1; status[i] = 0; } ret = numa_move_pages(pid, nr_p, addrs, nodes, status, MPOL_MF_MOVE_ALL); if (ret == -1) err("move_pages"); for (i = 0; i < nr_p; i++) { addrs[i] = (void *)ADDR_INPUT + i * PS; nodes[i] = 0; status[i] = 0; } ret = numa_move_pages(pid, nr_p, addrs, nodes, status, MPOL_MF_MOVE_ALL); if (ret == -1) err("move_pages"); } return 0; } $ cat hugepage.c #include <stdio.h> #include <sys/mman.h> #include <string.h> #define ADDR_INPUT 0x700000000000UL #define HPS 0x200000 int main(int argc, char *argv[]) { int nr_hp = strtol(argv[1], NULL, 0); char *p; while (1) { p = mmap((void *)ADDR_INPUT, nr_hp * HPS, PROT_READ | PROT_WRITE, MAP_PRIVATE | MAP_ANONYMOUS | MAP_HUGETLB, -1, 0); if (p != (void *)ADDR_INPUT) { perror("mmap"); break; } memset(p, 0, nr_hp * HPS); munmap(p, nr_hp * HPS); } } $ sysctl vm.nr_hugepages=40 $ ./hugepage 10 & $ ./movepages 10 $(pgrep -f hugepage) Fixes: e632a938d914 ("mm: migrate: add hugepage migration code to move_pages()") Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Reported-by: Hugh Dickins <hughd@google.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Luiz Capitulino <lcapitulino@redhat.com> Cc: Nishanth Aravamudan <nacc@linux.vnet.ibm.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Steve Capper <steve.capper@linaro.org> Cc: <stable@vger.kernel.org> [3.12+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-10rmap: drop support of non-linear mappingsKirill A. Shutemov
We don't create non-linear mappings anymore. Let's drop code which handles them in rmap. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-17vm_area_operations: kill ->migrate()Al Viro
the only instance this method has ever grown was one in kernfs - one that call ->migrate() of another vm_ops if it exists. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-12-15Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm updates from Dave Airlie: "Highlights: - AMD KFD driver merge This is the AMD HSA interface for exposing a lowlevel interface for GPGPU use. They have an open source userspace built on top of this interface, and the code looks as good as it was going to get out of tree. - Initial atomic modesetting work The need for an atomic modesetting interface to allow userspace to try and send a complete set of modesetting state to the driver has arisen, and been suffering from neglect this past year. No more, the start of the common code and changes for msm driver to use it are in this tree. Ongoing work to get the userspace ioctl finished and the code clean will probably wait until next kernel. - DisplayID 1.3 and tiled monitor exposed to userspace. Tiled monitor property is now exposed for userspace to make use of. - Rockchip drm driver merged. - imx gpu driver moved out of staging Other stuff: - core: panel - MIPI DSI + new panels. expose suggested x/y properties for virtual GPUs - i915: Initial Skylake (SKL) support gen3/4 reset work start of dri1/ums removal infoframe tracking fixes for lots of things. - nouveau: tegra k1 voltage support GM204 modesetting support GT21x memory reclocking work - radeon: CI dpm fixes GPUVM improvements Initial DPM fan control - rcar-du: HDMI support added removed some support for old boards slave encoder driver for Analog Devices adv7511 - exynos: Exynos4415 SoC support - msm: a4xx gpu support atomic helper conversion - tegra: iommu support universal plane support ganged-mode DSI support - sti: HDMI i2c improvements - vmwgfx: some late fixes. - qxl: use suggested x/y properties" * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (969 commits) drm: sti: fix module compilation issue drm/i915: save/restore GMBUS freq across suspend/resume on gen4 drm: sti: correctly cleanup CRTC and planes drm: sti: add HQVDP plane drm: sti: add cursor plane drm: sti: enable auxiliary CRTC drm: sti: fix delay in VTG programming drm: sti: prepare sti_tvout to support auxiliary crtc drm: sti: use drm_crtc_vblank_{on/off} instead of drm_vblank_{on/off} drm: sti: fix hdmi avi infoframe drm: sti: remove event lock while disabling vblank drm: sti: simplify gdp code drm: sti: clear all mixer control drm: sti: remove gpio for HDMI hot plug detection drm: sti: allow to change hdmi ddc i2c adapter drm/doc: Document drm_add_modes_noedid() usage drm/i915: Remove '& 0xffff' from the mask given to WA_REG() drm/i915: Invert the mask and val arguments in wa_add() and WA_REG() drm: Zero out DRM object memory upon cleanup drm/i915/bdw: Fix the write setting up the WIZ hashing mode ...
2014-12-13mm: unmapped page migration avoid unmap+remap overheadHugh Dickins
Page migration's __unmap_and_move(), and rmap's try_to_unmap(), were created for use on pages almost certainly mapped into userspace. But nowadays compaction often applies them to unmapped page cache pages: which may exacerbate contention on i_mmap_rwsem quite unnecessarily, since try_to_unmap_file() makes no preliminary page_mapped() check. Now check page_mapped() in __unmap_and_move(); and avoid repeating the same overhead in rmap_walk_file() - don't remove_migration_ptes() when we never inserted any. (The PageAnon(page) comment blocks now look even sillier than before, but clean that up on some other occasion. And note in passing that try_to_unmap_one() does not use a migration entry when PageSwapCache, so remove_migration_ptes() will then not update that swap entry to newpage pte: not a big deal, but something else to clean up later.) Davidlohr remarked in "mm,fs: introduce helpers around the i_mmap_mutex" conversion to i_mmap_rwsem, that "The biggest winner of these changes is migration": a part of the reason might be all of that unnecessary taking of i_mmap_mutex in page migration; and it's rather a shame that I didn't get around to sending this patch in before his - this one is much less useful after Davidlohr's conversion to rwsem, but still good. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Davidlohr Bueso <dave@stgolabs.net> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-09mm/balloon_compaction: redesign ballooned pages managementKonstantin Khlebnikov
Sasha Levin reported KASAN splash inside isolate_migratepages_range(). Problem is in the function __is_movable_balloon_page() which tests AS_BALLOON_MAP in page->mapping->flags. This function has no protection against anonymous pages. As result it tried to check address space flags inside struct anon_vma. Further investigation shows more problems in current implementation: * Special branch in __unmap_and_move() never works: balloon_page_movable() checks page flags and page_count. In __unmap_and_move() page is locked, reference counter is elevated, thus balloon_page_movable() always fails. As a result execution goes to the normal migration path. virtballoon_migratepage() returns MIGRATEPAGE_BALLOON_SUCCESS instead of MIGRATEPAGE_SUCCESS, move_to_new_page() thinks this is an error code and assigns newpage->mapping to NULL. Newly migrated page lose connectivity with balloon an all ability for further migration. * lru_lock erroneously required in isolate_migratepages_range() for isolation ballooned page. This function releases lru_lock periodically, this makes migration mostly impossible for some pages. * balloon_page_dequeue have a tight race with balloon_page_isolate: balloon_page_isolate could be executed in parallel with dequeue between picking page from list and locking page_lock. Race is rare because they use trylock_page() for locking. This patch fixes all of them. Instead of fake mapping with special flag this patch uses special state of page->_mapcount: PAGE_BALLOON_MAPCOUNT_VALUE = -256. Buddy allocator uses PAGE_BUDDY_MAPCOUNT_VALUE = -128 for similar purpose. Storing mark directly in struct page makes everything safer and easier. PagePrivate is used to mark pages present in page list (i.e. not isolated, like PageLRU for normal pages). It replaces special rules for reference counter and makes balloon migration similar to migration of normal pages. This flag is protected by page_lock together with link to the balloon device. Signed-off-by: Konstantin Khlebnikov <k.khlebnikov@samsung.com> Reported-by: Sasha Levin <sasha.levin@oracle.com> Link: http://lkml.kernel.org/p/53E6CEAA.9020105@oracle.com Cc: Rafael Aquini <aquini@redhat.com> Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com> Cc: <stable@vger.kernel.org> [3.8+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-02mm: migrate: Close race between migration completion and mprotectMel Gorman
A migration entry is marked as write if pte_write was true at the time the entry was created. The VMA protections are not double checked when migration entries are being removed as mprotect marks write-migration-entries as read. It means that potentially we take a spurious fault to mark PTEs write again but it's straight-forward. However, there is a race between write migrations being marked read and migrations finishing. This potentially allows a PTE to be write that should have been read. Close this race by double checking the VMA permissions using maybe_mkwrite when migration completes. [torvalds@linux-foundation.org: use maybe_mkwrite] Cc: stable@vger.kernel.org Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-08mm: memcontrol: rewrite uncharge APIJohannes Weiner
The memcg uncharging code that is involved towards the end of a page's lifetime - truncation, reclaim, swapout, migration - is impressively complicated and fragile. Because anonymous and file pages were always charged before they had their page->mapping established, uncharges had to happen when the page type could still be known from the context; as in unmap for anonymous, page cache removal for file and shmem pages, and swap cache truncation for swap pages. However, these operations happen well before the page is actually freed, and so a lot of synchronization is necessary: - Charging, uncharging, page migration, and charge migration all need to take a per-page bit spinlock as they could race with uncharging. - Swap cache truncation happens during both swap-in and swap-out, and possibly repeatedly before the page is actually freed. This means that the memcg swapout code is called from many contexts that make no sense and it has to figure out the direction from page state to make sure memory and memory+swap are always correctly charged. - On page migration, the old page might be unmapped but then reused, so memcg code has to prevent untimely uncharging in that case. Because this code - which should be a simple charge transfer - is so special-cased, it is not reusable for replace_page_cache(). But now that charged pages always have a page->mapping, introduce mem_cgroup_uncharge(), which is called after the final put_page(), when we know for sure that nobody is looking at the page anymore. For page migration, introduce mem_cgroup_migrate(), which is called after the migration is successful and the new page is fully rmapped. Because the old page is no longer uncharged after migration, prevent double charges by decoupling the page's memcg association (PCG_USED and pc->mem_cgroup) from the page holding an actual charge. The new bits PCG_MEM and PCG_MEMSW represent the respective charges and are transferred to the new page during migration. mem_cgroup_migrate() is suitable for replace_page_cache() as well, which gets rid of mem_cgroup_replace_page_cache(). However, care needs to be taken because both the source and the target page can already be charged and on the LRU when fuse is splicing: grab the page lock on the charge moving side to prevent changing pc->mem_cgroup of a page under migration. Also, the lruvecs of both pages change as we uncharge the old and charge the new during migration, and putback may race with us, so grab the lru lock and isolate the pages iff on LRU to prevent races and ensure the pages are on the right lruvec afterward. Swap accounting is massively simplified: because the page is no longer uncharged as early as swap cache deletion, a new mem_cgroup_swapout() can transfer the page's memory+swap charge (PCG_MEMSW) to the swap entry before the final put_page() in page reclaim. Finally, page_cgroup changes are now protected by whatever protection the page itself offers: anonymous pages are charged under the page table lock, whereas page cache insertions, swapin, and migration hold the page lock. Uncharging happens under full exclusion with no outstanding references. Charging and uncharging also ensure that the page is off-LRU, which serializes against charge migration. Remove the very costly page_cgroup lock and set pc->flags non-atomically. [mhocko@suse.cz: mem_cgroup_charge_statistics needs preempt_disable] [vdavydov@parallels.com: fix flags definition] Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Hugh Dickins <hughd@google.com> Cc: Tejun Heo <tj@kernel.org> Cc: Vladimir Davydov <vdavydov@parallels.com> Tested-by: Jet Chen <jet.chen@intel.com> Acked-by: Michal Hocko <mhocko@suse.cz> Tested-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Vladimir Davydov <vdavydov@parallels.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-07-26mm: fix direct reclaim writeback regressionHugh Dickins
Shortly before 3.16-rc1, Dave Jones reported: WARNING: CPU: 3 PID: 19721 at fs/xfs/xfs_aops.c:971 xfs_vm_writepage+0x5ce/0x630 [xfs]() CPU: 3 PID: 19721 Comm: trinity-c61 Not tainted 3.15.0+ #3 Call Trace: xfs_vm_writepage+0x5ce/0x630 [xfs] shrink_page_list+0x8f9/0xb90 shrink_inactive_list+0x253/0x510 shrink_lruvec+0x563/0x6c0 shrink_zone+0x3b/0x100 shrink_zones+0x1f1/0x3c0 try_to_free_pages+0x164/0x380 __alloc_pages_nodemask+0x822/0xc90 alloc_pages_vma+0xaf/0x1c0 handle_mm_fault+0xa31/0xc50 etc. 970 if (WARN_ON_ONCE((current->flags & (PF_MEMALLOC|PF_KSWAPD)) == 971 PF_MEMALLOC)) I did not respond at the time, because a glance at the PageDirty block in shrink_page_list() quickly shows that this is impossible: we don't do writeback on file pages (other than tmpfs) from direct reclaim nowadays. Dave was hallucinating, but it would have been disrespectful to say so. However, my own /var/log/messages now shows similar complaints WARNING: CPU: 1 PID: 28814 at fs/ext4/inode.c:1881 ext4_writepage+0xa7/0x38b() WARNING: CPU: 0 PID: 27347 at fs/ext4/inode.c:1764 ext4_writepage+0xa7/0x38b() from stressing some mmotm trees during July. Could a dirty xfs or ext4 file page somehow get marked PageSwapBacked, so fail shrink_page_list()'s page_is_file_cache() test, and so proceed to mapping->a_ops->writepage()? Yes, 3.16-rc1's commit 68711a746345 ("mm, migration: add destination page freeing callback") has provided such a way to compaction: if migrating a SwapBacked page fails, its newpage may be put back on the list for later use with PageSwapBacked still set, and nothing will clear it. Whether that can do anything worse than issue WARN_ON_ONCEs, and get some statistics wrong, is unclear: easier to fix than to think through the consequences. Fixing it here, before the put_new_page(), addresses the bug directly, but is probably the worst place to fix it. Page migration is doing too many parts of the job on too many levels: fixing it in move_to_new_page() to complement its SetPageSwapBacked would be preferable, except why is it (and newpage->mapping and newpage->index) done there, rather than down in migrate_page_move_mapping(), once we are sure of success? Not a cleanup to get into right now, especially not with memcg cleanups coming in 3.17. Reported-by: Dave Jones <davej@redhat.com> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-23mm: let mm_find_pmd fix buggy race with THP faultHugh Dickins
Trinity has reported: BUG: unable to handle kernel NULL pointer dereference at 0000000000000018 IP: __lock_acquire (kernel/locking/lockdep.c:3070 (discriminator 1)) CPU: 6 PID: 16173 Comm: trinity-c364 Tainted: G W 3.15.0-rc1-next-20140415-sasha-00020-gaa90d09 #398 lock_acquire (arch/x86/include/asm/current.h:14 kernel/locking/lockdep.c:3602) _raw_spin_lock (include/linux/spinlock_api_smp.h:143 kernel/locking/spinlock.c:151) remove_migration_pte (mm/migrate.c:137) rmap_walk (mm/rmap.c:1628 mm/rmap.c:1699) remove_migration_ptes (mm/migrate.c:224) migrate_pages (mm/migrate.c:922 mm/migrate.c:960 mm/migrate.c:1126) migrate_misplaced_page (mm/migrate.c:1733) __handle_mm_fault (mm/memory.c:3762 mm/memory.c:3812 mm/memory.c:3925) handle_mm_fault (mm/memory.c:3948) __get_user_pages (mm/memory.c:1851) __mlock_vma_pages_range (mm/mlock.c:255) __mm_populate (mm/mlock.c:711) SyS_mlockall (include/linux/mm.h:1799 mm/mlock.c:817 mm/mlock.c:791) I believe this comes about because, whereas collapsing and splitting THP functions take anon_vma lock in write mode (which excludes concurrent rmap walks), faulting THP functions (write protection and misplaced NUMA) do not - and mostly they do not need to. But they do use a pmdp_clear_flush(), set_pmd_at() sequence which, for an instant (indeed, for a long instant, given the inter-CPU TLB flush in there), leaves *pmd neither present not trans_huge. Which can confuse a concurrent rmap walk, as when removing migration ptes, seen in the dumped trace. Although that rmap walk has a 4k page to insert, anon_vmas containing THPs are in no way segregated from 4k-page anon_vmas, so the 4k-intent mm_find_pmd() does need to cope with that instant when a trans_huge pmd is temporarily absent. I don't think we need strengthen the locking at the THP end: it's easily handled with an ACCESS_ONCE() before testing both conditions. And since mm_find_pmd() had only one caller who wanted a THP rather than a pmd, let's slightly repurpose it to fail when it hits a THP or non-present pmd, and open code split_huge_page_address() again. Signed-off-by: Hugh Dickins <hughd@google.com> Reported-by: Sasha Levin <sasha.levin@oracle.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Bob Liu <bob.liu@oracle.com> Cc: Christoph Lameter <cl@gentwo.org> Cc: Dave Jones <davej@redhat.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04hugetlb: rename hugepage_migration_support() to ..._supported()Naoya Horiguchi
We already have a function named hugepages_supported(), and the similar name hugepage_migration_support() is a bit unconfortable, so let's rename it hugepage_migration_supported(). Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04mm, migration: add destination page freeing callbackDavid Rientjes
Memory migration uses a callback defined by the caller to determine how to allocate destination pages. When migration fails for a source page, however, it frees the destination page back to the system. This patch adds a memory migration callback defined by the caller to determine how to free destination pages. If a caller, such as memory compaction, builds its own freelist for migration targets, this can reuse already freed memory instead of scanning additional memory. If the caller provides a function to handle freeing of destination pages, it is called when page migration fails. If the caller passes NULL then freeing back to the system will be handled as usual. This patch introduces no functional change. Signed-off-by: David Rientjes <rientjes@google.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Acked-by: Mel Gorman <mgorman@suse.de> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Greg Thelen <gthelen@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04mm: numa: add migrated transhuge pages to LRU the same way as base pagesMel Gorman
Migration of misplaced transhuge pages uses page_add_new_anon_rmap() when putting the page back as it avoided an atomic operations and added the new page to the correct LRU. A side-effect is that the page gets marked activated as part of the migration meaning that transhuge and base pages are treated differently from an aging perspective than base page migration. This patch uses page_add_anon_rmap() and putback_lru_page() on completion of a transhuge migration similar to base page migration. It would require fewer atomic operations to use lru_cache_add without taking an additional reference to the page. The downside would be that it's still different to base page migration and unevictable pages may be added to the wrong LRU for cleaning up later. Testing of the usual workloads did not show any adverse impact to the change. Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Sasha Levin <sasha.levin@oracle.com> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-20mm: fix swapops.h:131 bug if remap_file_pages raced migrationHugh Dickins
Add remove_linear_migration_ptes_from_nonlinear(), to fix an interesting little include/linux/swapops.h:131 BUG_ON(!PageLocked) found by trinity: indicating that remove_migration_ptes() failed to find one of the migration entries that was temporarily inserted. The problem comes from remap_file_pages()'s switch from vma_interval_tree (good for inserting the migration entry) to i_mmap_nonlinear list (no good for locating it again); but can only be a problem if the remap_file_pages() range does not cover the whole of the vma (zap_pte() clears the range). remove_migration_ptes() needs a file_nonlinear method to go down the i_mmap_nonlinear list, applying linear location to look for migration entries in those vmas too, just in case there was this race. The file_nonlinear method does need rmap_walk_control.arg to do this; but it never needed vma passed in - vma comes from its own iteration. Reported-and-tested-by: Dave Jones <davej@redhat.com> Reported-and-tested-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-10mm: fix GFP_THISNODE callers and clarifyJohannes Weiner
GFP_THISNODE is for callers that implement their own clever fallback to remote nodes. It restricts the allocation to the specified node and does not invoke reclaim, assuming that the caller will take care of it when the fallback fails, e.g. through a subsequent allocation request without GFP_THISNODE set. However, many current GFP_THISNODE users only want the node exclusive aspect of the flag, without actually implementing their own fallback or triggering reclaim if necessary. This results in things like page migration failing prematurely even when there is easily reclaimable memory available, unless kswapd happens to be running already or a concurrent allocation attempt triggers the necessary reclaim. Convert all callsites that don't implement their own fallback strategy to __GFP_THISNODE. This restricts the allocation a single node too, but at the same time allows the allocator to enter the slowpath, wake kswapd, and invoke direct reclaim if necessary, to make the allocation happen when memory is full. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Rik van Riel <riel@redhat.com> Cc: Jan Stancek <jstancek@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-27mm/migrate.c: fix setting of cpupid on page migration twice against normal pageWanpeng Li
Commit 7851a45cd3f6 ("mm: numa: Copy cpupid on page migration") copies over the cpupid at page migration time. It is unnecessary to set it again in alloc_misplaced_dst_page(). Signed-off-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Acked-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23sched/numa: fix setting of cpupid on page migration twiceWanpeng Li
Commit 7851a45cd3f6 ("mm: numa: Copy cpupid on page migration") copiess over the cpupid at page migration time. It is unnecessary to set it again in migrate_misplaced_transhuge_page(). Signed-off-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23mm: dump page when hitting a VM_BUG_ON using VM_BUG_ON_PAGESasha Levin
Most of the VM_BUG_ON assertions are performed on a page. Usually, when one of these assertions fails we'll get a BUG_ON with a call stack and the registers. I've recently noticed based on the requests to add a small piece of code that dumps the page to various VM_BUG_ON sites that the page dump is quite useful to people debugging issues in mm. This patch adds a VM_BUG_ON_PAGE(cond, page) which beyond doing what VM_BUG_ON() does, also dumps the page before executing the actual BUG_ON. [akpm@linux-foundation.org: fix up includes] Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-21mm/migrate: remove unused function, fail_migrate_page()Joonsoo Kim
fail_migrate_page() isn't used anywhere, so remove it. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Christoph Lameter <cl@linux.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Rafael Aquini <aquini@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-21mm/migrate: remove putback_lru_pages, fix comment on putback_movable_pagesJoonsoo Kim
Some part of putback_lru_pages() and putback_movable_pages() is duplicated, so it could confuse us what we should use. We can remove putback_lru_pages() since it is not really needed now. This makes us undestand and maintain the code more easily. And comment on putback_movable_pages() is stale now, so fix it. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Christoph Lameter <cl@linux.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Rafael Aquini <aquini@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-21mm/migrate: correct failure handling if !hugepage_migration_support()Joonsoo Kim
We should remove the page from the list if we fail with ENOSYS, since migrate_pages() consider error cases except -ENOMEM and -EAGAIN as permanent failure and it assumes that the page would be removed from the list. Without this patch, we could overcount number of failure. In addition, we should put back the new hugepage if !hugepage_migration_support(). If not, we would leak hugepage memory. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Christoph Lameter <cl@linux.com> Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Rafael Aquini <aquini@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-21mm/migrate: add comment about permanent failure pathNaoya Horiguchi
Let's add a comment about where the failed page goes to, which makes code more readable. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Christoph Lameter <cl@linux.com> Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Acked-by: Rafael Aquini <aquini@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-21mm: numa: trace tasks that fail migration due to rate limitingMel Gorman
A low local/remote numa hinting fault ratio is potentially explained by failed migrations. This patch adds a tracepoint that fires when migration fails due to migration rate limitation. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Alex Thorlton <athorlton@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-21mm: numa: limit scope of lock for NUMA migrate rate limitingMel Gorman
NUMA migrate rate limiting protects a migration counter and window using a lock but in some cases this can be a contended lock. It is not critical that the number of pages be perfect, lost updates are acceptable. Reduce the importance of this lock. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Alex Thorlton <athorlton@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-21mm: numa: make NUMA-migrate related functions staticMel Gorman
numamigrate_update_ratelimit and numamigrate_isolate_page only have callers in mm/migrate.c. This patch makes them static. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Alex Thorlton <athorlton@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-21mm/rmap: make rmap_walk to get the rmap_walk_control argumentJoonsoo Kim
In each rmap traverse case, there is some difference so that we need function pointers and arguments to them in order to handle these For this purpose, struct rmap_walk_control is introduced in this patch, and will be extended in following patch. Introducing and extending are separate, because it clarify changes. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Hugh Dickins <hughd@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Hillf Danton <dhillf@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-13mmu_notifier: call mmu_notifier_invalidate_range() from VMMJoerg Roedel
Add calls to the new mmu_notifier_invalidate_range() function to all places in the VMM that need it. Signed-off-by: Joerg Roedel <jroedel@suse.de> Reviewed-by: Andrea Arcangeli <aarcange@redhat.com> Reviewed-by: Jérôme Glisse <jglisse@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Rik van Riel <riel@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Johannes Weiner <jweiner@redhat.com> Cc: Jay Cornwall <Jay.Cornwall@amd.com> Cc: Oded Gabbay <Oded.Gabbay@amd.com> Cc: Suravee Suthikulpanit <Suravee.Suthikulpanit@amd.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Oded Gabbay <oded.gabbay@amd.com>
2013-12-21aio/migratepages: make aio migrate pages saneBenjamin LaHaise
The arbitrary restriction on page counts offered by the core migrate_page_move_mapping() code results in rather suspicious looking fiddling with page reference counts in the aio_migratepage() operation. To fix this, make migrate_page_move_mapping() take an extra_count parameter that allows aio to tell the code about its own reference count on the page being migrated. While cleaning up aio_migratepage(), make it validate that the old page being passed in is actually what aio_migratepage() expects to prevent misbehaviour in the case of races. Signed-off-by: Benjamin LaHaise <bcrl@kvack.org>
2013-12-18mm: numa: defer TLB flush for THP migration as long as possibleMel Gorman
THP migration can fail for a variety of reasons. Avoid flushing the TLB to deal with THP migration races until the copy is ready to start. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Alex Thorlton <athorlton@sgi.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-18mm: numa: avoid unnecessary disruption of NUMA hinting during migrationMel Gorman
do_huge_pmd_numa_page() handles the case where there is parallel THP migration. However, by the time it is checked the NUMA hinting information has already been disrupted. This patch adds an earlier check with some helpers. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Alex Thorlton <athorlton@sgi.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-18mm: numa: avoid unnecessary work on the failure pathMel Gorman
If a PMD changes during a THP migration then migration aborts but the failure path is doing more work than is necessary. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Alex Thorlton <athorlton@sgi.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-18mm: numa: call MMU notifiers on THP migrationMel Gorman
MMU notifiers must be called on THP page migration or secondary MMUs will get very confused. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Alex Thorlton <athorlton@sgi.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-18mm: numa: serialise parallel get_user_page against THP migrationMel Gorman
Base pages are unmapped and flushed from cache and TLB during normal page migration and replaced with a migration entry that causes any parallel NUMA hinting fault or gup to block until migration completes. THP does not unmap pages due to a lack of support for migration entries at a PMD level. This allows races with get_user_pages and get_user_pages_fast which commit 3f926ab945b6 ("mm: Close races between THP migration and PMD numa clearing") made worse by introducing a pmd_clear_flush(). This patch forces get_user_page (fast and normal) on a pmd_numa page to go through the slow get_user_page path where it will serialise against THP migration and properly account for the NUMA hinting fault. On the migration side the page table lock is taken for each PTE update. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Alex Thorlton <athorlton@sgi.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-21mm: thp: give transparent hugepage code a separate copy_pageDave Hansen
Right now, the migration code in migrate_page_copy() uses copy_huge_page() for hugetlbfs and thp pages: if (PageHuge(page) || PageTransHuge(page)) copy_huge_page(newpage, page); So, yay for code reuse. But: void copy_huge_page(struct page *dst, struct page *src) { struct hstate *h = page_hstate(src); and a non-hugetlbfs page has no page_hstate(). This works 99% of the time because page_hstate() determines the hstate from the page order alone. Since the page order of a THP page matches the default hugetlbfs page order, it works. But, if you change the default huge page size on the boot command-line (say default_hugepagesz=1G), then we might not even *have* a 2MB hstate so page_hstate() returns null and copy_huge_page() oopses pretty fast since copy_huge_page() dereferences the hstate: void copy_huge_page(struct page *dst, struct page *src) { struct hstate *h = page_hstate(src); if (unlikely(pages_per_huge_page(h) > MAX_ORDER_NR_PAGES)) { ... Mel noticed that the migration code is really the only user of these functions. This moves all the copy code over to migrate.c and makes copy_huge_page() work for THP by checking for it explicitly. I believe the bug was introduced in commit b32967ff101a ("mm: numa: Add THP migration for the NUMA working set scanning fault case") [akpm@linux-foundation.org: fix coding-style and comment text, per Naoya Horiguchi] Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Acked-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Hillf Danton <dhillf@gmail.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Tested-by: Dave Jiang <dave.jiang@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-15mm: convert the rest to new page table lock apiKirill A. Shutemov
Only trivial cases left. Let's convert them altogether. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Tested-by: Alex Thorlton <athorlton@sgi.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: "Eric W . Biederman" <ebiederm@xmission.com> Cc: "Paul E . McKenney" <paulmck@linux.vnet.ibm.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Andi Kleen <ak@linux.intel.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Dave Jones <davej@redhat.com> Cc: David Howells <dhowells@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Kees Cook <keescook@chromium.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Robin Holt <robinmholt@gmail.com> Cc: Sedat Dilek <sedat.dilek@gmail.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-15mm, hugetlb: convert hugetlbfs to use split pmd lockKirill A. Shutemov
Hugetlb supports multiple page sizes. We use split lock only for PMD level, but not for PUD. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Tested-by: Alex Thorlton <athorlton@sgi.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: "Eric W . Biederman" <ebiederm@xmission.com> Cc: "Paul E . McKenney" <paulmck@linux.vnet.ibm.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Andi Kleen <ak@linux.intel.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Dave Jones <davej@redhat.com> Cc: David Howells <dhowells@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Kees Cook <keescook@chromium.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Robin Holt <robinmholt@gmail.com> Cc: Sedat Dilek <sedat.dilek@gmail.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-01Merge branch 'linus' into sched/coreIngo Molnar
Resolve cherry-picking conflicts: Conflicts: mm/huge_memory.c mm/memory.c mm/mprotect.c See this upstream merge commit for more details: 52469b4fcd4f Merge branch 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-10-29mm: Close races between THP migration and PMD numa clearingMel Gorman
THP migration uses the page lock to guard against parallel allocations but there are cases like this still open Task A Task B --------------------- --------------------- do_huge_pmd_numa_page do_huge_pmd_numa_page lock_page mpol_misplaced == -1 unlock_page goto clear_pmdnuma lock_page mpol_misplaced == 2 migrate_misplaced_transhuge pmd = pmd_mknonnuma set_pmd_at During hours of testing, one crashed with weird errors and while I have no direct evidence, I suspect something like the race above happened. This patch extends the page lock to being held until the pmd_numa is cleared to prevent migration starting in parallel while the pmd_numa is being cleared. It also flushes the old pmd entry and orders pagetable insertion before rmap insertion. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: <stable@kernel.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1381141781-10992-9-git-send-email-mgorman@suse.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-10-16mm: migration: do not lose soft dirty bit if page is in migration stateCyrill Gorcunov
If page migration is turned on in config and the page is migrating, we may lose the soft dirty bit. If fork and mprotect are called on migrating pages (once migration is complete) pages do not obtain the soft dirty bit in the correspond pte entries. Fix it adding an appropriate test on swap entries. Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Matt Mackall <mpm@selenic.com> Cc: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@gmail.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Peter Zijlstra <peterz@infradead.org> Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-09mm: numa: Copy cpupid on page migrationRik van Riel
After page migration, the new page has the nidpid unset. This makes every fault on a recently migrated page look like a first numa fault, leading to another page migration. Copying over the nidpid at page migration time should prevent erroneous migrations of recently migrated pages. Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1381141781-10992-46-git-send-email-mgorman@suse.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-10-09mm: numa: Change page last {nid,pid} into {cpu,pid}Peter Zijlstra
Change the per page last fault tracking to use cpu,pid instead of nid,pid. This will allow us to try and lookup the alternate task more easily. Note that even though it is the cpu that is store in the page flags that the mpol_misplaced decision is still based on the node. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/1381141781-10992-43-git-send-email-mgorman@suse.de [ Fixed build failure on 32-bit systems. ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-10-09sched/numa: Set preferred NUMA node based on number of private faultsMel Gorman
Ideally it would be possible to distinguish between NUMA hinting faults that are private to a task and those that are shared. If treated identically there is a risk that shared pages bounce between nodes depending on the order they are referenced by tasks. Ultimately what is desirable is that task private pages remain local to the task while shared pages are interleaved between sharing tasks running on different nodes to give good average performance. This is further complicated by THP as even applications that partition their data may not be partitioning on a huge page boundary. To start with, this patch assumes that multi-threaded or multi-process applications partition their data and that in general the private accesses are more important for cpu->memory locality in the general case. Also, no new infrastructure is required to treat private pages properly but interleaving for shared pages requires additional infrastructure. To detect private accesses the pid of the last accessing task is required but the storage requirements are a high. This patch borrows heavily from Ingo Molnar's patch "numa, mm, sched: Implement last-CPU+PID hash tracking" to encode some bits from the last accessing task in the page flags as well as the node information. Collisions will occur but it is better than just depending on the node information. Node information is then used to determine if a page needs to migrate. The PID information is used to detect private/shared accesses. The preferred NUMA node is selected based on where the maximum number of approximately private faults were measured. Shared faults are not taken into consideration for a few reasons. First, if there are many tasks sharing the page then they'll all move towards the same node. The node will be compute overloaded and then scheduled away later only to bounce back again. Alternatively the shared tasks would just bounce around nodes because the fault information is effectively noise. Either way accounting for shared faults the same as private faults can result in lower performance overall. The second reason is based on a hypothetical workload that has a small number of very important, heavily accessed private pages but a large shared array. The shared array would dominate the number of faults and be selected as a preferred node even though it's the wrong decision. The third reason is that multiple threads in a process will race each other to fault the shared page making the fault information unreliable. Signed-off-by: Mel Gorman <mgorman@suse.de> [ Fix complication error when !NUMA_BALANCING. ] Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1381141781-10992-30-git-send-email-mgorman@suse.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-10-09mm: numa: Scan pages with elevated page_mapcountMel Gorman
Currently automatic NUMA balancing is unable to distinguish between false shared versus private pages except by ignoring pages with an elevated page_mapcount entirely. This avoids shared pages bouncing between the nodes whose task is using them but that is ignored quite a lot of data. This patch kicks away the training wheels in preparation for adding support for identifying shared/private pages is now in place. The ordering is so that the impact of the shared/private detection can be easily measured. Note that the patch does not migrate shared, file-backed within vmas marked VM_EXEC as these are generally shared library pages. Migrating such pages is not beneficial as there is an expectation they are read-shared between caches and iTLB and iCache pressure is generally low. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1381141781-10992-28-git-send-email-mgorman@suse.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-10-09mm: Close races between THP migration and PMD numa clearingMel Gorman
THP migration uses the page lock to guard against parallel allocations but there are cases like this still open Task A Task B --------------------- --------------------- do_huge_pmd_numa_page do_huge_pmd_numa_page lock_page mpol_misplaced == -1 unlock_page goto clear_pmdnuma lock_page mpol_misplaced == 2 migrate_misplaced_transhuge pmd = pmd_mknonnuma set_pmd_at During hours of testing, one crashed with weird errors and while I have no direct evidence, I suspect something like the race above happened. This patch extends the page lock to being held until the pmd_numa is cleared to prevent migration starting in parallel while the pmd_numa is being cleared. It also flushes the old pmd entry and orders pagetable insertion before rmap insertion. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1381141781-10992-9-git-send-email-mgorman@suse.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-30mm: avoid reinserting isolated balloon pages into LRU listsRafael Aquini
Isolated balloon pages can wrongly end up in LRU lists when migrate_pages() finishes its round without draining all the isolated page list. The same issue can happen when reclaim_clean_pages_from_list() tries to reclaim pages from an isolated page list, before migration, in the CMA path. Such balloon page leak opens a race window against LRU lists shrinkers that leads us to the following kernel panic: BUG: unable to handle kernel NULL pointer dereference at 0000000000000028 IP: [<ffffffff810c2625>] shrink_page_list+0x24e/0x897 PGD 3cda2067 PUD 3d713067 PMD 0 Oops: 0000 [#1] SMP CPU: 0 PID: 340 Comm: kswapd0 Not tainted 3.12.0-rc1-22626-g4367597 #87 Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011 RIP: shrink_page_list+0x24e/0x897 RSP: 0000:ffff88003da499b8 EFLAGS: 00010286 RAX: 0000000000000000 RBX: ffff88003e82bd60 RCX: 00000000000657d5 RDX: 0000000000000000 RSI: 000000000000031f RDI: ffff88003e82bd40 RBP: ffff88003da49ab0 R08: 0000000000000001 R09: 0000000081121a45 R10: ffffffff81121a45 R11: ffff88003c4a9a28 R12: ffff88003e82bd40 R13: ffff88003da0e800 R14: 0000000000000001 R15: ffff88003da49d58 FS: 0000000000000000(0000) GS:ffff88003fc00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 00000000067d9000 CR3: 000000003ace5000 CR4: 00000000000407b0 Call Trace: shrink_inactive_list+0x240/0x3de shrink_lruvec+0x3e0/0x566 __shrink_zone+0x94/0x178 shrink_zone+0x3a/0x82 balance_pgdat+0x32a/0x4c2 kswapd+0x2f0/0x372 kthread+0xa2/0xaa ret_from_fork+0x7c/0xb0 Code: 80 7d 8f 01 48 83 95 68 ff ff ff 00 4c 89 e7 e8 5a 7b 00 00 48 85 c0 49 89 c5 75 08 80 7d 8f 00 74 3e eb 31 48 8b 80 18 01 00 00 <48> 8b 74 0d 48 8b 78 30 be 02 00 00 00 ff d2 eb RIP [<ffffffff810c2625>] shrink_page_list+0x24e/0x897 RSP <ffff88003da499b8> CR2: 0000000000000028 ---[ end trace 703d2451af6ffbfd ]--- Kernel panic - not syncing: Fatal exception This patch fixes the issue, by assuring the proper tests are made at putback_movable_pages() & reclaim_clean_pages_from_list() to avoid isolated balloon pages being wrongly reinserted in LRU lists. [akpm@linux-foundation.org: clarify awkward comment text] Signed-off-by: Rafael Aquini <aquini@redhat.com> Reported-by: Luiz Capitulino <lcapitulino@redhat.com> Tested-by: Luiz Capitulino <lcapitulino@redhat.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik van Riel <riel@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
