commit d7824370e26325c881b665350ce64fb0a4fde24a upstream.
This commit makes the stack guard page somewhat less visible to user
space. It does this by:
- not showing the guard page in /proc/<pid>/maps
It looks like lvm-tools will actually read /proc/self/maps to figure
out where all its mappings are, and effectively do a specialized
"mlockall()" in user space. By not showing the guard page as part of
the mapping (by just adding PAGE_SIZE to the start for grows-up
pages), lvm-tools ends up not being aware of it.
- by also teaching the _real_ mlock() functionality not to try to lock
the guard page.
That would just expand the mapping down to create a new guard page,
so there really is no point in trying to lock it in place.
It would perhaps be nice to show the guard page specially in
/proc/<pid>/maps (or at least mark grow-down segments some way), but
let's not open ourselves up to more breakage by user space from programs
that depends on the exact deails of the 'maps' file.
Special thanks to Henrique de Moraes Holschuh for diving into lvm-tools
source code to see what was going on with the whole new warning.
Reported-and-tested-by: François Valenduc <francois.valenduc@tvcablenet.be
Reported-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br>
Support for the PMU's BTS features has been upstreamed in
v2.6.32, but we still have the old and disabled ptrace-BTS,
as Linus noticed it not so long ago.
It's buggy: TIF_DEBUGCTLMSR is trampling all over that MSR without
regard for other uses (perf) and doesn't provide the flexibility
needed for perf either.
Its users are ptrace-block-step and ptrace-bts, since ptrace-bts
was never used and ptrace-block-step can be implemented using a
much simpler approach.
So axe all 3000 lines of it. That includes the *locked_memory*()
APIs in mm/mlock.c as well.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Roland McGrath <roland@redhat.com>
Cc: Markus Metzger <markus.t.metzger@intel.com>
LKML-Reference: <20100325135413.938004390@chello.nl>
Make sure compiler won't do weird things with limits. E.g. fetching them
twice may return 2 different values after writable limits are implemented.
I.e. either use rlimit helpers added in
3e10e716abf3c71bdb5d86b8f507f9e72236c9cd ("resource: add helpers for
fetching rlimits") or ACCESS_ONCE if not applicable.
Cleanup stale comments on munlock_vma_page().
Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com>
Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk>
When KSM merges an mlocked page, it has been forgetting to munlock it:
that's been left to free_page_mlock(), which reports it in /proc/vmstat as
unevictable_pgs_mlockfreed instead of unevictable_pgs_munlocked (and
whinges "Page flag mlocked set for process" in mmotm, whereas mainline is
silently forgiving). Call munlock_vma_page() to fix that.
Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Cc: Izik Eidus <ieidus@redhat.com>
Cc: Chris Wright <chrisw@redhat.com>
Acked-by: Mel Gorman <mel@csn.ul.ie>
There's contorted mlock/munlock handling in try_to_unmap_anon() and
try_to_unmap_file(), which we'd prefer not to repeat for KSM swapping.
Simplify it by moving it all down into try_to_unmap_one().
One thing is then lost, try_to_munlock()'s distinction between when no vma
holds the page mlocked, and when a vma does mlock it, but we could not get
mmap_sem to set the page flag. But its only caller takes no interest in
that distinction (and is better testing SWAP_MLOCK anyway), so let's keep
the code simple and return SWAP_AGAIN for both cases.
try_to_unmap_file()'s TTU_MUNLOCK nonlinear handling was particularly
amusing: once unravelled, it turns out to have been choosing between two
different ways of doing the same nothing. Ah, no, one way was actually
returning SWAP_FAIL when it meant to return SWAP_SUCCESS.
[kosaki.motohiro@jp.fujitsu.com: comment adding to mlocking in try_to_unmap_one]
[akpm@linux-foundation.org: remove test of MLOCK_PAGES]
Cc: Nick Piggin <npiggin@suse.de>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Minchan Kim <minchan.kim@gmail.com>
I'm still reluctant to clutter __get_user_pages() with another flag, just
to avoid touching ZERO_PAGE count in mlock(); though we can add that later
if it shows up as an issue in practice.
But when mlocking, we can test page->mapping slightly earlier, to avoid
the potentially bouncy rescheduling of lock_page on ZERO_PAGE - mlock
didn't lock_page in olden ZERO_PAGE days, so we might have regressed.
And when munlocking, it turns out that FOLL_DUMP coincidentally does
what's needed to avoid all updates to ZERO_PAGE, so use that here also.
Plus add comment suggested by KAMEZAWA Hiroyuki.
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
__get_user_pages() has been taking its own GUP flags, then processing
them into FOLL flags for follow_page(). Though oddly named, the FOLL
flags are more widely used, so pass them to __get_user_pages() now.
Sorry, VM flags, VM_FAULT flags and FAULT_FLAGs are still distinct.
(The patch to __get_user_pages() looks peculiar, with both gup_flags
and foll_flags: the gup_flags remain constant; but as before there's
an exceptional case, out of scope of the patch, in which foll_flags
per page have FOLL_WRITE masked off.)
Hiroaki Wakabayashi points out that when mlock() has been interrupted
by SIGKILL, the subsequent munlock() takes unnecessarily long because
its use of __get_user_pages() insists on faulting in all the pages
which mlock() never reached.
It's worse than slowness if mlock() is terminated by Out Of Memory kill:
the munlock_vma_pages_all() in exit_mmap() insists on faulting in all the
pages which mlock() could not find memory for; so innocent bystanders are
killed too, and perhaps the system hangs.
__get_user_pages() does a lot that's silly for munlock(): so remove the
munlock option from __mlock_vma_pages_range(), and use a simple loop of
follow_page()s in munlock_vma_pages_range() instead; ignoring absent
pages, and not marking present pages as accessed or dirty.
(Change munlock() to only go so far as mlock() reached? That does not
work out, given the convention that mlock() claims complete success even
when it has to give up early - in part so that an underlying file can be
extended later, and those pages locked which earlier would give SIGBUS.)
Cc: <stable@kernel.org>
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
Reviewed-by: Hiroaki Wakabayashi <primulaelatior@gmail.com>
Currently, nobody wants to turn UNEVICTABLE_LRU off. Thus this
configurability is unnecessary.
Acked-by: Minchan Kim <minchan.kim@gmail.com>
Cc: Matt Mackall <mpm@selenic.com>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
The current mm interface is asymetric. One function allocates a locked
buffer, another function only refunds the memory.
Change this to have two functions for accounting and refunding locked
memory, respectively; and do the actual buffer allocation in ptrace.
[ Impact: refactor BTS buffer allocation code ]
Signed-off-by: Markus Metzger <markus.t.metzger@intel.com>
Acked-by: Andrew Morton <akpm@linux-foundation.org>
LKML-Reference: <20090424095143.A30265@sedona.ch.intel.com>
Remove the unused free_locked_buffer() API.
When a ptraced task is unlinked, we need to stop branch tracing for
that task.
Since the unlink is called with interrupts disabled, and we need
interrupts enabled to stop branch tracing, we defer the work.
Collect all branch tracing related stuff in a branch tracing context.
Reviewed-by: Oleg Nesterov <oleg@redhat.com>
Cc: roland@redhat.com
Cc: eranian@googlemail.com
Cc: juan.villacis@intel.com
Cc: ak@linux.jf.intel.com
LKML-Reference: <20090403144550.712401000@intel.com>
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, vm86: fix preemption bug
x86, olpc: fix model detection without OFW
x86, hpet: fix for LS21 + HPET = boot hang
x86: CPA avoid repeated lazy mmu flush
x86: warn if arch_flush_lazy_mmu_cpu is called in preemptible context
x86/paravirt: make arch_flush_lazy_mmu/cpu disable preemption
x86, pat: fix warn_on_once() while mapping 0-1MB range with /dev/mem
x86/cpa: make sure cpa is safe to call in lazy mmu mode
x86, ptrace, mm: fix double-free on race
Ptrace_detach() races with __ptrace_unlink() if the traced task is
reaped while detaching. This might cause a double-free of the BTS
buffer.
Change the ptrace_detach() path to only do the memory accounting in
ptrace_bts_detach() and leave the buffer free to ptrace_bts_untrace()
which will be called from __ptrace_unlink().
The fix follows a proposal from Oleg Nesterov.
Reported-by: Oleg Nesterov <oleg@redhat.com>
Commit 27421e211a39784694b597dbf35848b88363c248, Manually revert
"mlock: downgrade mmap sem while populating mlocked regions", has
introduced its own regression: __mlock_vma_pages_range() may report
an error (for example, -EFAULT from trying to lock down pages from
beyond EOF), but mlock_vma_pages_range() must hide that from its
callers as before.
Reported-by: Sami Farin <safari-kernel@safari.iki.fi>
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Cc: stable@kernel.org
This essentially reverts commit 8edb08caf68184fb170f4f69c7445929e199eaea.
It downgraded our mmap semaphore to a read-lock while mlocking pages, in
order to allow other threads (and external accesses like "ps" et al) to
walk the vma lists and take page faults etc. Which is a nice idea, but
the implementation does not work.
Because we cannot upgrade the lock back to a write lock without
releasing the mmap semaphore, the code had to release the lock entirely
and then re-take it as a writelock. However, that meant that the caller
possibly lost the vma chain that it was following, since now another
thread could come in and mmap/munmap the range.
The code tried to work around that by just looking up the vma again and
erroring out if that happened, but quite frankly, that was just a buggy
hack that doesn't actually protect against anything (the other thread
could just have replaced the vma with another one instead of totally
unmapping it).
The only way to downgrade to a read map _reliably_ is to do it at the
end, which is likely the right thing to do: do all the 'vma' operations
with the write-lock held, then downgrade to a read after completing them
all, and then do the "populate the newly mlocked regions" while holding
just the read lock. And then just drop the read-lock and return to user
space.
The (perhaps somewhat simpler) alternative is to just make all the
callers of mlock_vma_pages_range() know that the mmap lock got dropped,
and just re-grab the mmap semaphore if it needs to mlock more than one
vma region.
So we can do this "downgrade mmap sem while populating mlocked regions"
thing right, but the way it was done here was absolutely not correct.
Thus the revert, in the expectation that we will do it all correctly
some day.
The initial implementation of checking TIF_MEMDIE covers the cases of OOM
killing. If the process has been OOM killed, the TIF_MEMDIE is set and it
return immediately. This patch includes:
1. add the case that the SIGKILL is sent by user processes. The
process can try to get_user_pages() unlimited memory even if a user
process has sent a SIGKILL to it(maybe a monitor find the process
exceed its memory limit and try to kill it). In the old
implementation, the SIGKILL won't be handled until the get_user_pages()
returns.
2. change the return value to be ERESTARTSYS. It makes no sense to
return ENOMEM if the get_user_pages returned by getting a SIGKILL
signal. Considering the general convention for a system call
interrupted by a signal is ERESTARTNOSYS, so the current return value
is consistant to that.
Lee:
An unfortunate side effect of "make-get_user_pages-interruptible" is that
it prevents a SIGKILL'd task from munlock-ing pages that it had mlocked,
resulting in freeing of mlocked pages. Freeing of mlocked pages, in
itself, is not so bad. We just count them now--altho' I had hoped to
remove this stat and add PG_MLOCKED to the free pages flags check.
However, consider pages in shared libraries mapped by more than one task
that a task mlocked--e.g., via mlockall(). If the task that mlocked the
pages exits via SIGKILL, these pages would be left mlocked and
unevictable.
Proposed fix:
Add another GUP flag to ignore sigkill when calling get_user_pages from
munlock()--similar to Kosaki Motohiro's 'IGNORE_VMA_PERMISSIONS flag for
the same purpose. We are not actually allocating memory in this case,
which "make-get_user_pages-interruptible" intends to avoid. We're just
munlocking pages that are already resident and mapped, and we're reusing
get_user_pages() to access those pages.
?? Maybe we should combine 'IGNORE_VMA_PERMISSIONS and '_IGNORE_SIGKILL
into a single flag: GUP_FLAGS_MUNLOCK ???
[Lee.Schermerhorn@hp.com: ignore sigkill in get_user_pages during munlock]
Signed-off-by: Paul Menage <menage@google.com>
Signed-off-by: Ying Han <yinghan@google.com>
Reviewed-by: Pekka Enberg <penberg@cs.helsinki.fi>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Cc: Hugh Dickins <hugh@veritas.com>
Cc: Oleg Nesterov <oleg@tv-sign.ru>
Cc: Rohit Seth <rohitseth@google.com>
Impact: move the BTS buffer accounting to the mlock bucket
Add alloc_locked_buffer() and free_locked_buffer() functions to mm/mlock.c
to kalloc a buffer and account the locked memory to current.
Account the memory for the BTS buffer to the tracer.
Fix an unitialized return value when compiling on parisc (with CONFIG_UNEVICTABLE_LRU=y):
mm/mlock.c: In function `__mlock_vma_pages_range':
mm/mlock.c:165: warning: `ret' might be used uninitialized in this function
Signed-off-by: Helge Deller <deller@gmx.de>
[ It isn't ever really used uninitialized, since no caller should ever
call this function with an empty range. But the compiler is correct
that from a local analysis standpoint that is impossible to see, and
fixing the warning is appropriate. ]
lockdep warns about following message at boot time on one of my test
machine. Then, schedule_on_each_cpu() sholdn't be called when the task
have mmap_sem.
Actually, lru_add_drain_all() exist to prevent the unevictalble pages
stay on reclaimable lru list. but currenct unevictable code can rescue
unevictable pages although it stay on reclaimable list.
So removing is better.
In addition, this patch add lru_add_drain_all() to sys_mlock() and
sys_mlockall(). it isn't must. but it reduce the failure of moving to
unevictable list. its failure can rescue in vmscan later. but reducing
is better.
Note, if above rescuing happend, the Mlocked and the Unevictable field
mismatching happend in /proc/meminfo. but it doesn't cause any real
trouble.
[ INFO: possible circular locking dependency detected ]
2.6.28-rc2-mm1 #2
lvm/1103 is trying to acquire lock:
(&cpu_hotplug.lock){--..}, at: [<c0130789>] get_online_cpus+0x29/0x50
but task is already holding lock:
(&mm->mmap_sem){----}, at: [<c01878ae>] sys_mlockall+0x4e/0xb0
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #3 (&mm->mmap_sem){----}:
[<c0153da2>] check_noncircular+0x82/0x110
[<c0185e6a>] might_fault+0x4a/0xa0
[<c0156161>] validate_chain+0xb11/0x1070
[<c0156923>] __lock_acquire+0x263/0xa10
[<c015714c>] lock_acquire+0x7c/0xb0 (*) grab mmap_sem
[<c0185e9b>] might_fault+0x7b/0xa0
[<c0294dd0>] copy_to_user+0x30/0x60
[<c01ae3ec>] filldir+0x7c/0xd0
[<c01e3a6a>] sysfs_readdir+0x11a/0x1f0 (*) grab sysfs_mutex
[<c01ae370>] filldir+0x0/0xd0
[<c01ae4c6>] vfs_readdir+0x86/0xa0 (*) grab i_mutex
[<c01ae75b>] sys_getdents+0x6b/0xc0
[<c010355a>] syscall_call+0x7/0xb
[<ffffffff>] 0xffffffff
-> #2 (sysfs_mutex){--..}:
[<c01e3d2c>] sysfs_addrm_start+0x2c/0xc0
[<c015714c>] lock_acquire+0x7c/0xb0 (*) grab sysfs_mutex
[<c04f8b55>] mutex_lock_nested+0xa5/0x2f0
[<c01e422f>] create_dir+0x3f/0x90
[<c01e42a9>] sysfs_create_dir+0x29/0x50
[<c04faaf5>] _spin_unlock+0x25/0x40
[<c028f21d>] kobject_add_internal+0xcd/0x1a0
[<c028f37a>] kobject_set_name_vargs+0x3a/0x50
[<c028f41d>] kobject_init_and_add+0x2d/0x40
[<c019d4d2>] sysfs_slab_add+0xd2/0x180
[<c019d580>] sysfs_add_func+0x0/0x70
[<c019d5dc>] sysfs_add_func+0x5c/0x70 (*) grab slub_lock
[<c01400f2>] run_workqueue+0x172/0x200
[<c014008f>] run_workqueue+0x10f/0x200
[<c0140bd0>] worker_thread+0x0/0xf0
[<c0140c6c>] worker_thread+0x9c/0xf0
[<c0143c80>] autoremove_wake_function+0x0/0x50
[<c0143972>] kthread+0x42/0x70
[<c0143930>] kthread+0x0/0x70
[<c01042db>] kernel_thread_helper+0x7/0x1c
-> #1 (slub_lock){----}:
[<c0153d2d>] check_noncircular+0xd/0x110
[<c04f650f>] slab_cpuup_callback+0x11f/0x1d0
[<c015433d>] mark_lock+0x35d/0xd00
[<c04f93a3>] down_read+0x43/0x80
[<c04f650f>] slab_cpuup_callback+0x11f/0x1d0 (*) grab slub_lock
[<c04fd9ac>] notifier_call_chain+0x3c/0x70
[<c04f5454>] _cpu_up+0x84/0x110
[<c04f552b>] cpu_up+0x4b/0x70 (*) grab cpu_hotplug.lock
[<c06d1530>] kernel_init+0x0/0x170
[<c06d15e5>] kernel_init+0xb5/0x170
-> #0 (&cpu_hotplug.lock){--..}:
[<c0155bff>] validate_chain+0x5af/0x1070
[<c040f7e0>] dev_status+0x0/0x50
[<c017bc30>] lru_add_drain_per_cpu+0x0/0x10
[<c0130789>] get_online_cpus+0x29/0x50 (*) grab cpu_hotplug.lock
[<c0140cf2>] schedule_on_each_cpu+0x32/0xe0
[<c0187095>] __mlock_vma_pages_range+0x85/0x2c0
[<c0156945>] __lock_acquire+0x285/0xa10
[<c0188f09>] vma_merge+0xa9/0x1d0
[<c0187450>] mlock_fixup+0x180/0x200
[<c0187548>] do_mlockall+0x78/0x90 (*) grab mmap_sem
[<c01878e1>] sys_mlockall+0x81/0xb0
1 lock held by lvm/1103:
#0: (&mm->mmap_sem){----}, at: [<c01878ae>] sys_mlockall+0x4e/0xb0
stack backtrace:
Pid: 1103, comm: lvm Not tainted 2.6.28-rc2-mm1 #2
Call Trace:
[<c01555fc>] print_circular_bug_tail+0x7c/0xd0
Tested-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com>
Rework Posix error return for mlock().
Posix requires error code for mlock*() system calls for some conditions
that differ from what kernel low level functions, such as
get_user_pages(), return for those conditions. For more info, see:
http://marc.info/?l=linux-kernel&m=121750892930775&w=2
This patch provides the same translation of get_user_pages()
error codes to posix specified error codes in the context
of the mlock rework for unevictable lru.
[akpm@linux-foundation.org: fix build]
Add NR_MLOCK zone page state, which provides a (conservative) count of
mlocked pages (actually, the number of mlocked pages moved off the LRU).
Reworked by lts to fit in with the modified mlock page support in the
Reclaim Scalability series.
[kosaki.motohiro@jp.fujitsu.com: fix incorrect Mlocked field of /proc/meminfo]
[lee.schermerhorn@hp.com: mlocked-pages: add event counting with statistics]
Signed-off-by: Nick Piggin <npiggin@suse.de>
Signed-off-by: Rik van Riel <riel@redhat.com>
Originally by Nick Piggin <npiggin@suse.de>
Remove mlocked pages from the LRU using "unevictable infrastructure"
during mmap(), munmap(), mremap() and truncate(). Try to move back to
normal LRU lists on munmap() when last mlocked mapping removed. Remove
PageMlocked() status when page truncated from file.
[akpm@linux-foundation.org: cleanup]
[kamezawa.hiroyu@jp.fujitsu.com: fix double unlock_page()]
[kosaki.motohiro@jp.fujitsu.com: split LRU: munlock rework]
[lee.schermerhorn@hp.com: mlock: fix __mlock_vma_pages_range comment block]
[akpm@linux-foundation.org: remove bogus kerneldoc token]
Signed-off-by: KAMEZAWA Hiroyuki <kamewzawa.hiroyu@jp.fujitsu.com>
We need to hold the mmap_sem for write to initiatate mlock()/munlock()
because we may need to merge/split vmas. However, this can lead to very
long lock hold times attempting to fault in a large memory region to mlock
it into memory. This can hold off other faults against the mm
[multithreaded tasks] and other scans of the mm, such as via /proc. To
alleviate this, downgrade the mmap_sem to read mode during the population
of the region for locking. This is especially the case if we need to
reclaim memory to lock down the region. We [probably?] don't need to do
this for unlocking as all of the pages should be resident--they're already
mlocked.
Now, the caller's of the mlock functions [mlock_fixup() and
mlock_vma_pages_range()] expect the mmap_sem to be returned in write mode.
Changing all callers appears to be way too much effort at this point.
So, restore write mode before returning. Note that this opens a window
where the mmap list could change in a multithreaded process. So, at least
for mlock_fixup(), where we could be called in a loop over multiple vmas,
we check that a vma still exists at the start address and that vma still
covers the page range [start,end). If not, we return an error, -EAGAIN,
and let the caller deal with it.
Return -EAGAIN from mlock_vma_pages_range() function and mlock_fixup() if
the vma at 'start' disappears or changes so that the page range
[start,end) is no longer contained in the vma. Again, let the caller deal
with it. Looks like only sys_remap_file_pages() [via mmap_region()]
should actually care.
With this patch, I no longer see processes like ps(1) blocked for seconds
or minutes at a time waiting for a large [multiple gigabyte] region to be
locked down. However, I occassionally see delays while unlocking or
unmapping a large mlocked region. Should we also downgrade the mmap_sem
for the unlock path?
Make sure that mlocked pages also live on the unevictable LRU, so kswapd
will not scan them over and over again.
This is achieved through various strategies:
1) add yet another page flag--PG_mlocked--to indicate that
the page is locked for efficient testing in vmscan and,
optionally, fault path. This allows early culling of
unevictable pages, preventing them from getting to
page_referenced()/try_to_unmap(). Also allows separate
accounting of mlock'd pages, as Nick's original patch
did.
Note: Nick's original mlock patch used a PG_mlocked
flag. I had removed this in favor of the PG_unevictable
flag + an mlock_count [new page struct member]. I
restored the PG_mlocked flag to eliminate the new
count field.
2) add the mlock/unevictable infrastructure to mm/mlock.c,
with internal APIs in mm/internal.h. This is a rework
of Nick's original patch to these files, taking into
account that mlocked pages are now kept on unevictable
LRU list.
3) update vmscan.c:page_evictable() to check PageMlocked()
and, if vma passed in, the vm_flags. Note that the vma
will only be passed in for new pages in the fault path;
and then only if the "cull unevictable pages in fault
path" patch is included.
4) add try_to_unlock() to rmap.c to walk a page's rmap and
ClearPageMlocked() if no other vmas have it mlocked.
Reuses as much of try_to_unmap() as possible. This
effectively replaces the use of one of the lru list links
as an mlock count. If this mechanism let's pages in mlocked
vmas leak through w/o PG_mlocked set [I don't know that it
does], we should catch them later in try_to_unmap(). One
hopes this will be rare, as it will be relatively expensive.
Original mm/internal.h, mm/rmap.c and mm/mlock.c changes:
splitlru: introduce __get_user_pages():
New munlock processing need to GUP_FLAGS_IGNORE_VMA_PERMISSIONS.
because current get_user_pages() can't grab PROT_NONE pages theresore it
cause PROT_NONE pages can't munlock.
[akpm@linux-foundation.org: fix this for pagemap-pass-mm-into-pagewalkers.patch]
[akpm@linux-foundation.org: untangle patch interdependencies]
[akpm@linux-foundation.org: fix things after out-of-order merging]
[hugh@veritas.com: fix page-flags mess]
[lee.schermerhorn@hp.com: fix munlock page table walk - now requires 'mm']
[kosaki.motohiro@jp.fujitsu.com: build fix]
[kosaki.motohiro@jp.fujitsu.com: fix truncate race and sevaral comments]
[kosaki.motohiro@jp.fujitsu.com: splitlru: introduce __get_user_pages()]
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
Halesh says:
Please find the below testcase provide to test mlock.
Test Case :
#include <sys/resource.h>
#include <stdio.h>
#include <sys/stat.h>
#include <sys/types.h>
#include <unistd.h>
#include <sys/mman.h>
#include <fcntl.h>
#include <errno.h>
#include <stdlib.h>
int main(void)
int fd,ret, i = 0;
char *addr, *addr1 = NULL;
unsigned int page_size;
struct rlimit rlim;
if (0 != geteuid())
printf("Execute this pgm as root\n");
exit(1);
/* create a file */
if ((fd = open("mmap_test.c",O_RDWR|O_CREAT,0755)) == -1)
printf("cant create test file\n");
exit(1);
page_size = sysconf(_SC_PAGE_SIZE);
/* set the MEMLOCK limit */
rlim.rlim_cur = 2000;
rlim.rlim_max = 2000;
if ((ret = setrlimit(RLIMIT_MEMLOCK,&rlim)) != 0)
printf("Cant change limit values\n");
exit(1);
addr = 0;
while (1)
/* map a page into memory each time*/
if ((addr = (char *) mmap(addr,page_size, PROT_READ |
PROT_WRITE,MAP_SHARED,fd,0)) == MAP_FAILED)
printf("cant do mmap on file\n");
exit(1);
if (0 == i)
addr1 = addr;
i++;
errno = 0;
/* lock the mapped memory pagewise*/
if ((ret = mlock((char *)addr, 1500)) == -1)
printf("errno value is %d\n", errno);
printf("cant lock maped region\n");
exit(1);
addr = addr + page_size;
This testcase results in an mlock() failure with errno 14 that is EFAULT,
but it has nowhere been specified that mlock() will return EFAULT. When I
tested the same on older kernels like 2.6.18, I got the correct result i.e
errno 12 (ENOMEM).
I think in source code mlock(2), setting errno ENOMEM has been missed in
do_mlock() , on mlock_fixup() failure.
SUSv3 requires the following behavior frmo mlock(2).
[ENOMEM]
Some or all of the address range specified by the addr and
len arguments does not correspond to valid mapped pages
in the address space of the process.
[EAGAIN]
Some or all of the memory identified by the operation could not
be locked when the call was made.
This rule isn't so nice and slighly strange. but many people think
POSIX/SUS compliance is important.
Reported-by: Halesh Sadashiv <halesh.sadashiv@ap.sony.com>
Tested-by: Halesh Sadashiv <halesh.sadashiv@ap.sony.com>
Cc: <stable@kernel.org> [2.6.25.x, 2.6.26.x]
Fix a bug in mm/mlock.c on 32-bit architectures that prevents a user from
locking more than 4GB of shared memory, or allocating more than 4GB of
shared memory in hugepages, when rlim[RLIMIT_MEMLOCK] is set to
RLIM_INFINITY.
Signed-off-by: Herbert van den Bergh <herbert.van.den.bergh@oracle.com>
Acked-by: Chris Mason <chris.mason@oracle.com>
First thing mm.h does is including sched.h solely for can_do_mlock() inline
function which has "current" dereference inside. By dealing with can_do_mlock()
mm.h can be detached from sched.h which is good. See below, why.
This patch
a) removes unconditional inclusion of sched.h from mm.h
b) makes can_do_mlock() normal function in mm/mlock.c
c) exports can_do_mlock() to not break compilation
d) adds sched.h inclusions back to files that were getting it indirectly.
e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were
getting them indirectly
Net result is:
a) mm.h users would get less code to open, read, preprocess, parse, ... if
they don't need sched.h
b) sched.h stops being dependency for significant number of files:
on x86_64 allmodconfig touching sched.h results in recompile of 4083 files,
after patch it's only 3744 (-8.3%).
Cross-compile tested on
all arm defconfigs, all mips defconfigs, all powerpc defconfigs,
alpha alpha-up
arm
i386 i386-up i386-defconfig i386-allnoconfig
ia64 ia64-up
m68k
mips
parisc parisc-up
powerpc powerpc-up
s390 s390-up
sparc sparc-up
sparc64 sparc64-up
um-x86_64
x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig
as well as my two usual configs.
mm is defined as vma->vm_mm, so use that.
Acked-by: Hugh Dickins <hugh@veritas.com>
- Move capable() from sched.h to capability.h;
- Use <linux/capability.h> where capable() is used
(in include/, block/, ipc/, kernel/, a few drivers/,
mm/, security/, & sound/;
many more drivers/ to go)
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
infrastructure for it.
Let it rip!
