commit 3480b25743cb7404928d57efeaa3d085708b04c2 upstream.
commit 6a6160a7b5c27b3c38651baef92a14fa7072b3c1 upstream.
Halesh says:
Please find the below testcase provide to test mlock.
Test Case :
#include <sys/resource.h>
#include <stdio.h>
#include <sys/stat.h>
#include <sys/types.h>
#include <unistd.h>
#include <sys/mman.h>
#include <fcntl.h>
#include <errno.h>
#include <stdlib.h>
int main(void)
int fd,ret, i = 0;
char *addr, *addr1 = NULL;
unsigned int page_size;
struct rlimit rlim;
if (0 != geteuid())
printf("Execute this pgm as root\n");
exit(1);
/* create a file */
if ((fd = open("mmap_test.c",O_RDWR|O_CREAT,0755)) == -1)
printf("cant create test file\n");
exit(1);
page_size = sysconf(_SC_PAGE_SIZE);
/* set the MEMLOCK limit */
rlim.rlim_cur = 2000;
rlim.rlim_max = 2000;
if ((ret = setrlimit(RLIMIT_MEMLOCK,&rlim)) != 0)
printf("Cant change limit values\n");
exit(1);
addr = 0;
while (1)
/* map a page into memory each time*/
if ((addr = (char *) mmap(addr,page_size, PROT_READ |
PROT_WRITE,MAP_SHARED,fd,0)) == MAP_FAILED)
printf("cant do mmap on file\n");
exit(1);
if (0 == i)
addr1 = addr;
i++;
errno = 0;
/* lock the mapped memory pagewise*/
if ((ret = mlock((char *)addr, 1500)) == -1)
printf("errno value is %d\n", errno);
printf("cant lock maped region\n");
exit(1);
addr = addr + page_size;
This testcase results in an mlock() failure with errno 14 that is EFAULT,
but it has nowhere been specified that mlock() will return EFAULT. When I
tested the same on older kernels like 2.6.18, I got the correct result i.e
errno 12 (ENOMEM).
I think in source code mlock(2), setting errno ENOMEM has been missed in
do_mlock() , on mlock_fixup() failure.
SUSv3 requires the following behavior frmo mlock(2).
[ENOMEM]
Some or all of the address range specified by the addr and
len arguments does not correspond to valid mapped pages
in the address space of the process.
[EAGAIN]
Some or all of the memory identified by the operation could not
be locked when the call was made.
This rule isn't so nice and slighly strange. but many people think
POSIX/SUS compliance is important.
Reported-by: Halesh Sadashiv <halesh.sadashiv@ap.sony.com>
Tested-by: Halesh Sadashiv <halesh.sadashiv@ap.sony.com>
Cc: <stable@kernel.org> [2.6.25.x, 2.6.26.x]
Fix a bug in mm/mlock.c on 32-bit architectures that prevents a user from
locking more than 4GB of shared memory, or allocating more than 4GB of
shared memory in hugepages, when rlim[RLIMIT_MEMLOCK] is set to
RLIM_INFINITY.
Signed-off-by: Herbert van den Bergh <herbert.van.den.bergh@oracle.com>
Acked-by: Chris Mason <chris.mason@oracle.com>
First thing mm.h does is including sched.h solely for can_do_mlock() inline
function which has "current" dereference inside. By dealing with can_do_mlock()
mm.h can be detached from sched.h which is good. See below, why.
This patch
a) removes unconditional inclusion of sched.h from mm.h
b) makes can_do_mlock() normal function in mm/mlock.c
c) exports can_do_mlock() to not break compilation
d) adds sched.h inclusions back to files that were getting it indirectly.
e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were
getting them indirectly
Net result is:
a) mm.h users would get less code to open, read, preprocess, parse, ... if
they don't need sched.h
b) sched.h stops being dependency for significant number of files:
on x86_64 allmodconfig touching sched.h results in recompile of 4083 files,
after patch it's only 3744 (-8.3%).
Cross-compile tested on
all arm defconfigs, all mips defconfigs, all powerpc defconfigs,
alpha alpha-up
arm
i386 i386-up i386-defconfig i386-allnoconfig
ia64 ia64-up
m68k
mips
parisc parisc-up
powerpc powerpc-up
s390 s390-up
sparc sparc-up
sparc64 sparc64-up
um-x86_64
x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig
as well as my two usual configs.
mm is defined as vma->vm_mm, so use that.
Acked-by: Hugh Dickins <hugh@veritas.com>
- Move capable() from sched.h to capability.h;
- Use <linux/capability.h> where capable() is used
(in include/, block/, ipc/, kernel/, a few drivers/,
mm/, security/, & sound/;
many more drivers/ to go)
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
infrastructure for it.
Let it rip!
