mremap() had a clever optimization where move_ptes() did not take the
anon_vma lock to avoid a race with anon rmap users such as page migration.
Instead, the avc's were ordered in such a way that the origin vma was
always visited by rmap before the destination. This ordering and the use
of page table locks rmap usage safe. However, we want to replace the use
of linked lists in anon rmap with an interval tree, and this will make it
harder to impose such ordering as the interval tree will always be sorted
by the avc->vma->vm_pgoff value. For now, let's replace the
anon_vma_moveto_tail() ordering function with proper anon_vma locking in
move_ptes(). Once we have the anon interval tree in place, we will
re-introduce an optimization to avoid taking these locks in the most
common cases.
Signed-off-by: Michel Lespinasse <walken@google.com>
Cc: Daniel Santos <daniel.santos@pobox.com>
Implement an interval tree as a replacement for the VMA prio_tree. The
algorithms are similar to lib/interval_tree.c; however that code can't be
directly reused as the interval endpoints are not explicitly stored in the
VMA. So instead, the common algorithm is moved into a template and the
details (node type, how to get interval endpoints from the node, etc) are
filled in using the C preprocessor.
Once the interval tree functions are available, using them as a
replacement to the VMA prio tree is a relatively simple, mechanical job.
Cc: Hillf Danton <dhillf@gmail.com>
Fix an anon_vma locking issue in the following situation:
- vma has no anon_vma
- next has an anon_vma
- vma is being shrunk / next is being expanded, due to an mprotect call
We need to take next's anon_vma lock to avoid races with rmap users (such
as page migration) while next is being expanded.
Reviewed-by: Andrea Arcangeli <aarcange@redhat.com>
People get confused by find_vma_prepare(), because it doesn't care about
what it returns in its output args, when its callers won't be interested.
Clarify by passing in end-of-range address too, and returning failure if
any existing vma overlaps the new range: instead of returning an ambiguous
vma which most callers then must check. find_vma_links() is a clearer
name.
This does revert 2.6.27's dfe195fb79e88 ("mm: fix uninitialized variables
for find_vma_prepare callers"), but it looks like gcc 4.3.0 was one of
those releases too eager to shout about uninitialized variables: only
copy_vma() warns with 4.5.1 and 4.7.1, which a BUG on error silences.
[hughd@google.com: fix warning, remove BUG()]
Cc: Benny Halevy <bhalevy@tonian.com>
Acked-by: Hillf Danton <dhillf@gmail.com>
A long time ago, in v2.4, VM_RESERVED kept swapout process off VMA,
currently it lost original meaning but still has some effects:
| effect | alternative flags
1| account as reserved_vm | VM_IO
2| skip in core dump | VM_IO, VM_DONTDUMP
3| do not merge or expand | VM_IO, VM_DONTEXPAND, VM_HUGETLB, VM_PFNMAP
4| do not mlock | VM_IO, VM_DONTEXPAND, VM_HUGETLB, VM_PFNMAP
This patch removes reserved_vm counter from mm_struct. Seems like nobody
cares about it, it does not exported into userspace directly, it only
reduces total_vm showed in proc.
Thus VM_RESERVED can be replaced with VM_IO or pair VM_DONTEXPAND | VM_DONTDUMP.
remap_pfn_range() and io_remap_pfn_range() set VM_IO|VM_DONTEXPAND|VM_DONTDUMP.
remap_vmalloc_range() set VM_DONTEXPAND | VM_DONTDUMP.
[akpm@linux-foundation.org: drivers/vfio/pci/vfio_pci.c fixup]
Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
Cc: Carsten Otte <cotte@de.ibm.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Eric Paris <eparis@redhat.com>
Cc: James Morris <james.l.morris@oracle.com>
Cc: Jason Baron <jbaron@redhat.com>
Cc: Kentaro Takeda <takedakn@nttdata.co.jp>
Cc: Matt Helsley <matthltc@us.ibm.com>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Robert Richter <robert.richter@amd.com>
Cc: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Cc: Venkatesh Pallipadi <venki@google.com>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Currently the kernel sets mm->exe_file during sys_execve() and then tracks
number of vmas with VM_EXECUTABLE flag in mm->num_exe_file_vmas, as soon
as this counter drops to zero kernel resets mm->exe_file to NULL. Plus it
resets mm->exe_file at last mmput() when mm->mm_users drops to zero.
VMA with VM_EXECUTABLE flag appears after mapping file with flag
MAP_EXECUTABLE, such vmas can appears only at sys_execve() or after vma
splitting, because sys_mmap ignores this flag. Usually binfmt module sets
mm->exe_file and mmaps executable vmas with this file, they hold
mm->exe_file while task is running.
comment from v2.6.25-6245-g925d1c4 ("procfs task exe symlink"),
where all this stuff was introduced:
> The kernel implements readlink of /proc/pid/exe by getting the file from
> the first executable VMA. Then the path to the file is reconstructed and
> reported as the result.
> Because of the VMA walk the code is slightly different on nommu systems.
> This patch avoids separate /proc/pid/exe code on nommu systems. Instead of
> walking the VMAs to find the first executable file-backed VMA we store a
> reference to the exec'd file in the mm_struct.
> That reference would prevent the filesystem holding the executable file
> from being unmounted even after unmapping the VMAs. So we track the number
> of VM_EXECUTABLE VMAs and drop the new reference when the last one is
> unmapped. This avoids pinning the mounted filesystem.
exe_file's vma accounting is hooked into every file mmap/unmmap and vma
split/merge just to fix some hypothetical pinning fs from umounting by mm,
which already unmapped all its executable files, but still alive.
Seems like currently nobody depends on this behaviour. We can try to
remove this logic and keep mm->exe_file until final mmput().
mm->exe_file is still protected with mm->mmap_sem, because we want to
change it via new sys_prctl(PR_SET_MM_EXE_FILE). Also via this syscall
task can change its mm->exe_file and unpin mountpoint explicitly.
Move actual pte filling for non-linear file mappings into the new special
vma operation: ->remap_pages().
Filesystems must implement this method to get non-linear mapping support,
if it uses filemap_fault() then generic_file_remap_pages() can be used.
Now device drivers can implement this method and obtain nonlinear vma support.
Cc: Chris Metcalf <cmetcalf@tilera.com> #arch/tile
Merge VM_INSERTPAGE into VM_MIXEDMAP. VM_MIXEDMAP VMA can mix pure-pfn
ptes, special ptes and normal ptes.
Now copy_page_range() always copies VM_MIXEDMAP VMA on fork like
VM_PFNMAP. If driver populates whole VMA at mmap() it probably not
expects page-faults.
This patch removes special check from vma_wants_writenotify() which
disables pages write tracking for VMA populated via vm_instert_page().
BDI below mapped file should not use dirty-accounting, moreover
do_wp_page() can handle this.
vm_insert_page() still marks vma after first usage. Usually it is called
from f_op->mmap() handler under mm->mmap_sem write-lock, so it able to
change vma->vm_flags. Caller must set VM_MIXEDMAP at mmap time if it
wants to call this function from other places, for example from page-fault
handler.
simplifies a bunch of callers...
Pull perf fixes from Ingo Molnar:
"This tree contains misc fixlets: a perf script python binding fix, a
uprobes fix and a syscall tracing fix."
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf tools: Add missing files to build the python binding
uprobes: Fix mmap_region()'s mm->mm_rb corruption if uprobe_mmap() fails
tracing/syscalls: Fix perf syscall tracing when syscall_nr == -1
Occasionally an isolated BUG_ON(mm->nr_ptes) gets reported, indicating
that not all the page tables allocated could be found and freed when
exit_mmap() tore down the user address space.
There's usually nothing we can say about it, beyond that it's probably a
sign of some bad memory or memory corruption; though it might still
indicate a bug in vma or page table management (and did recently reveal a
race in THP, fixed a few months ago).
But one overdue change we can make is from BUG_ON to WARN_ON.
It's fairly likely that the system will crash shortly afterwards in some
other way (for example, the BUG_ON(page_mapped(page)) in
__delete_from_page_cache(), once an inode mapped into the lost page tables
gets evicted); but might tell us more before that.
Change the BUG_ON(page_mapped) to WARN_ON too? Later perhaps: I'm less
eager, since that one has several times led to fixes.
This patch fixes:
https://bugzilla.redhat.com/show_bug.cgi?id=843640
If mmap_region()->uprobe_mmap() fails, unmap_and_free_vma path
does unmap_region() but does not remove the soon-to-be-freed vma
from rb tree. Actually there are more problems but this is how
William noticed this bug.
Perhaps we could do do_munmap() + return in this case, but in
fact it is simply wrong to abort if uprobe_mmap() fails. Until
at least we move the !UPROBE_COPY_INSN code from
install_breakpoint() to uprobe_register().
For example, uprobe_mmap()->install_breakpoint() can fail if the
probed insn is not supported (remember, uprobe_register()
succeeds if nobody mmaps inode/offset), mmap() should not fail
in this case.
dup_mmap()->uprobe_mmap() is wrong too by the same reason,
fork() can race with uprobe_register() and fail for no reason if
it wins the race and does install_breakpoint() first.
And, if nothing else, both mmap_region() and dup_mmap() return
success if uprobe_mmap() fails. Change them to ignore the error
code from uprobe_mmap().
Reported-and-tested-by: William Cohen <wcohen@redhat.com>
Acked-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Cc: <stable@vger.kernel.org> # v3.5
Cc: Anton Arapov <anton@redhat.com>
Cc: William Cohen <wcohen@redhat.com>
Link: http://lkml.kernel.org/r/20120819171042.GB26957@redhat.com
Merge Andrew's second set of patches:
- MM
- a few random fixes
- a couple of RTC leftovers
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (120 commits)
rtc/rtc-88pm80x: remove unneed devm_kfree
rtc/rtc-88pm80x: assign ret only when rtc_register_driver fails
mm: hugetlbfs: close race during teardown of hugetlbfs shared page tables
tmpfs: distribute interleave better across nodes
mm: remove redundant initialization
mm: warn if pg_data_t isn't initialized with zero
mips: zero out pg_data_t when it's allocated
memcg: gix memory accounting scalability in shrink_page_list
mm/sparse: remove index_init_lock
mm/sparse: more checks on mem_section number
mm/sparse: optimize sparse_index_alloc
memcg: add mem_cgroup_from_css() helper
memcg: further prevent OOM with too many dirty pages
memcg: prevent OOM with too many dirty pages
mm: mmu_notifier: fix freed page still mapped in secondary MMU
mm: memcg: only check anon swapin page charges for swap cache
mm: memcg: only check swap cache pages for repeated charging
mm: memcg: split swapin charge function into private and public part
mm: memcg: remove needless !mm fixup to init_mm when charging
mm: memcg: remove unneeded shmem charge type
vm_stat_account() accounts the shared_vm, stack_vm and reserved_vm now.
But we can also account for total_vm in the vm_stat_account() which makes
the code tidy.
Even for mprotect_fixup(), we can get the right result in the end.
Signed-off-by: Huang Shijie <shijie8@gmail.com>
Remove insert_vm_struct()->uprobe_mmap(). It is not needed, nobody
except arch/ia64/kernel/perfmon.c uses insert_vm_struct(vma)
with vma->vm_file != NULL.
And it is wrong. Again, get_user_pages() can not succeed before
vma_link(vma) makes is visible to find_vma(). And even if this
worked, we must not insert the new bp before this mapping is
visible to vma_prio_tree_foreach() for uprobe_unregister().
Acked-by: Srikar Dronamraju <srikar.vnet.ibm.com>
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/20120729182238.GA20349@redhat.com
Remove copy_vma()->uprobe_mmap(new_vma), it is absolutely wrong.
This new_vma was just initialized to represent the new unmapped
area, [vm_start, vm_end) was returned by get_unmapped_area() in
the caller.
This means that uprobe_mmap()->get_user_pages() will fail for
sure, simply because find_vma() can never succeed. And I
verified that sys_mremap()->mremap_to() indeed always fails with
the wrong ENOMEM code if [addr, addr+old_len] is probed.
And why this uprobe_mmap() was added? I believe the intent was
wrong. Note that the caller is going to do move_page_tables(),
all registered uprobes are already faulted in, we only change
the virtual addresses.
NOTE: However, somehow we need to close the race with
uprobe_register() which relies on map_info->vaddr. This needs
another fix I'll try to do later. Probably we need uprobe_mmap()
in move_vma() but we can not do this right now, this can confuse
uprobes_state.counter (which I still hope we are going to kill).
Link: http://lkml.kernel.org/r/20120729182236.GA20342@redhat.com
Pull vfs changes from Al Viro.
"A lot of misc stuff. The obvious groups:
* Miklos' atomic_open series; kills the damn abuse of
->d_revalidate() by NFS, which was the major stumbling block for
all work in that area.
* ripping security_file_mmap() and dealing with deadlocks in the
area; sanitizing the neighborhood of vm_mmap()/vm_munmap() in
general.
* ->encode_fh() switched to saner API; insane fake dentry in
mm/cleancache.c gone.
* assorted annotations in fs (endianness, __user)
* parts of Artem's ->s_dirty work (jff2 and reiserfs parts)
* ->update_time() work from Josef.
* other bits and pieces all over the place.
Normally it would've been in two or three pull requests, but
signal.git stuff had eaten a lot of time during this cycle ;-/"
Fix up trivial conflicts in Documentation/filesystems/vfs.txt (the
'truncate_range' inode method was removed by the VM changes, the VFS
update adds an 'update_time()' method), and in fs/btrfs/ulist.[ch] (due
to sparse fix added twice, with other changes nearby).
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (95 commits)
nfs: don't open in ->d_revalidate
vfs: retry last component if opening stale dentry
vfs: nameidata_to_filp(): don't throw away file on error
vfs: nameidata_to_filp(): inline __dentry_open()
vfs: do_dentry_open(): don't put filp
vfs: split __dentry_open()
vfs: do_last() common post lookup
vfs: do_last(): add audit_inode before open
vfs: do_last(): only return EISDIR for O_CREAT
vfs: do_last(): check LOOKUP_DIRECTORY
vfs: do_last(): make ENOENT exit RCU safe
vfs: make follow_link check RCU safe
vfs: do_last(): use inode variable
vfs: do_last(): inline walk_component()
vfs: do_last(): make exit RCU safe
vfs: split do_lookup()
Btrfs: move over to use ->update_time
fs: introduce inode operation ->update_time
reiserfs: get rid of resierfs_sync_super
reiserfs: mark the superblock as dirty a bit later
take it to mm/util.c, convert vm_mmap() to use of that one and
take it to mm/util.c as well, convert both sys_mmap_pgoff() to
use of vm_mmap_pgoff()
just pull into vm_mmap()
after all, 0 bytes and 0 pages is the same thing...
it really should be done by get_unmapped_area(); that cuts down on
the amount of callers considerably and it's the right place for
that stuff anyway.
... i.e. file-dependent and address-dependent checks.
The "if (mm)" check is not required in find_vma, as the kernel code
calls find_vma only when it is absolutely sure that the mm_struct arg to
it is non-NULL.
Remove the if(mm) check and adding the a WARN_ONCE(!mm) for now. This
will serve the purpose of mandating that the execution
context(user-mode/kernel-mode) be known before find_vma is called. Also
fixed 2 checkpatch.pl errors in the declaration of the rb_node and
vma_tmp local variables.
I was browsing through the internet and read a discussion at
https://lkml.org/lkml/2012/3/27/342 which discusses removal of the
validation check within find_vma. Since no-one responded, I decided to
send this patch with Andrew's suggestions.
[akpm@linux-foundation.org: add remove-me comment]
Signed-off-by: Rajman Mekaco <rajman.mekaco@gmail.com>
Cc: Kautuk Consul <consul.kautuk@gmail.com>
Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Pull user-space probe instrumentation from Ingo Molnar:
"The uprobes code originates from SystemTap and has been used for years
in Fedora and RHEL kernels. This version is much rewritten, reviews
from PeterZ, Oleg and myself shaped the end result.
This tree includes uprobes support in 'perf probe' - but SystemTap
(and other tools) can take advantage of user probe points as well.
Sample usage of uprobes via perf, for example to profile malloc()
calls without modifying user-space binaries.
First boot a new kernel with CONFIG_UPROBE_EVENT=y enabled.
If you don't know which function you want to probe you can pick one
from 'perf top' or can get a list all functions that can be probed
within libc (binaries can be specified as well):
$ perf probe -F -x /lib/libc.so.6
To probe libc's malloc():
$ perf probe -x /lib64/libc.so.6 malloc
Added new event:
probe_libc:malloc (on 0x7eac0)
You can now use it in all perf tools, such as:
perf record -e probe_libc:malloc -aR sleep 1
Make use of it to create a call graph (as the flat profile is going to
look very boring):
$ perf record -e probe_libc:malloc -gR make
[ perf record: Woken up 173 times to write data ]
[ perf record: Captured and wrote 44.190 MB perf.data (~1930712
$ perf report | less
32.03% git libc-2.15.so [.] malloc
--- malloc
29.49% cc1 libc-2.15.so [.] malloc
--- malloc
|--0.95%-- 0x208eb1000000000
|--0.63%-- htab_traverse_noresize
11.04% as libc-2.15.so [.] malloc
--- malloc
7.15% ld libc-2.15.so [.] malloc
--- malloc
5.07% sh libc-2.15.so [.] malloc
--- malloc
4.99% python-config libc-2.15.so [.] malloc
--- malloc
4.54% make libc-2.15.so [.] malloc
--- malloc
|--7.34%-- glob
| |--93.18%-- 0x41588f
| --6.82%-- glob
| 0x41588f
Or:
$ perf report -g flat | less
# Overhead Command Shared Object Symbol
27.19%
malloc
24.77%
malloc
11.02%
malloc
6.57%
malloc
The core uprobes design is fairly straightforward: uprobes probe
points register themselves at (inode:offset) addresses of
libraries/binaries, after which all existing (or new) vmas that map
that address will have a software breakpoint injected at that address.
vmas are COW-ed to preserve original content. The probe points are
kept in an rbtree.
If user-space executes the probed inode:offset instruction address
then an event is generated which can be recovered from the regular
perf event channels and mmap-ed ring-buffer.
Multiple probes at the same address are supported, they create a
dynamic callback list of event consumers.
The basic model is further complicated by the XOL speedup: the
original instruction that is probed is copied (in an architecture
specific fashion) and executed out of line when the probe triggers.
The XOL area is a single vma per process, with a fixed number of
entries (which limits probe execution parallelism).
The API: uprobes are installed/removed via
/sys/kernel/debug/tracing/uprobe_events, the API is integrated to
align with the kprobes interface as much as possible, but is separate
to it.
Injecting a probe point is privileged operation, which can be relaxed
by setting perf_paranoid to -1.
You can use multiple probes as well and mix them with kprobes and
regular PMU events or tracepoints, when instrumenting a task."
Fix up trivial conflicts in mm/memory.c due to previous cleanup of
unmap_single_vma().
* 'perf-uprobes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (21 commits)
perf probe: Detect probe target when m/x options are absent
perf probe: Provide perf interface for uprobes
tracing: Fix kconfig warning due to a typo
tracing: Provide trace events interface for uprobes
tracing: Extract out common code for kprobes/uprobes trace events
tracing: Modify is_delete, is_return from int to bool
uprobes/core: Decrement uprobe count before the pages are unmapped
uprobes/core: Make background page replacement logic account for rss_stat counters
uprobes/core: Optimize probe hits with the help of a counter
uprobes/core: Allocate XOL slots for uprobes use
uprobes/core: Handle breakpoint and singlestep exceptions
uprobes/core: Rename bkpt to swbp
uprobes/core: Make order of function parameters consistent across functions
uprobes/core: Make macro names consistent
uprobes: Update copyright notices
uprobes/core: Move insn to arch specific structure
uprobes/core: Remove uprobe_opcode_sz
uprobes/core: Make instruction tables volatile
uprobes: Move to kernel/events/
uprobes/core: Clean up, refactor and improve the code
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/uprobes
The VM accounting makes no sense at this level, and half of the callers
didn't ever actually use the end result. The only time we want to
unaccount the memory is when we actually remove the vma, so do the
accounting at that point instead.
This simplifies the interfaces (no need to pass down that silly page
counter to functions that really don't care), and also makes it much
more obvious what is actually going on: we do vm_[un]acct_memory() when
adding or removing the vma, not on random page walking.
None of the callers want to pass in 'zap_details', and it doesn't even
make sense for the case of actually unmapping vma's. So remove the
argument, and clean up the interface.
it's always current->mm
This continues the theme started with vm_brk() and vm_munmap():
vm_mmap() does the same thing as do_mmap(), but additionally does the
required VM locking.
This uninlines (and rewrites it to be clearer) do_mmap(), which sadly
duplicates it in mm/mmap.c and mm/nommu.c. But that way we don't have
to export our internal do_mmap_pgoff() function.
Some day we hopefully don't have to export do_mmap() either, if all
modular users can become the simpler vm_mmap() instead. We're actually
very close to that already, with the notable exception of the (broken)
use in i810, and a couple of stragglers in binfmt_elf.
Like the vm_brk() function, this is the same as "do_munmap()", except it
does the VM locking for the caller.
It does the same thing as "do_brk()", except it handles the VM locking
too.
It turns out that all external callers want that anyway, so we can make
do_brk() static to just mm/mmap.c while at it.
Uprobes has a callback (uprobe_munmap()) in the unmap path to
maintain the uprobes count.
In the exit path this callback gets called in unlink_file_vma().
However by the time unlink_file_vma() is called, the pages would
have been unmapped (in unmap_vmas()) and the task->rss_stat counts
accounted (in zap_pte_range()).
If the exiting process has probepoints, uprobe_munmap() checks if
the breakpoint instruction was around before decrementing the probe
count.
This results in a file backed page being reread by uprobe_munmap()
and hence it does not find the breakpoint.
This patch fixes this problem by moving the callback to
unmap_single_vma(). Since unmap_single_vma() may not unmap the
complete vma, add start and end parameters to uprobe_munmap().
This bug became apparent courtesy of commit c3f0327f8e9d
("mm: add rss counters consistency check").
Signed-off-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: Jim Keniston <jkenisto@linux.vnet.ibm.com>
Cc: Linux-mm <linux-mm@kvack.org>
Cc: Arnaldo Carvalho de Melo <acme@infradead.org>
Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Link: http://lkml.kernel.org/r/20120411103527.23245.9835.sendpatchset@srdronam.in.ibm.com
Merge in latest upstream (and the latest perf development tree),
to prepare for tooling changes, and also to pick up v3.4 MM
changes that the uprobes code needs to take care of.
Maintain a per-mm counter: number of uprobes that are inserted
on this process address space.
This counter can be used at probe hit time to determine if we
need a lookup in the uprobes rbtree. Everytime a probe gets
inserted successfully, the probe count is incremented and
everytime a probe gets removed, the probe count is decremented.
The new uprobe_munmap hook ensures the count is correct on a
unmap or remap of a region. We expect that once a
uprobe_munmap() is called, the vma goes away. So
uprobe_unregister() finding a probe to unregister would either
mean unmap event hasnt occurred yet or a mmap event on the same
executable file occured after a unmap event.
Additionally, uprobe_mmap hook now also gets called:
a. on every executable vma that is COWed at fork.
b. a vma of interest is newly mapped; breakpoint insertion also
happens at the required address.
On process creation, make sure the probes count in the child is
set correctly.
Special cases that are taken care include:
a. mremap
b. VM_DONTCOPY vmas on fork()
c. insertion/removal races in the parent during fork().
Link: http://lkml.kernel.org/r/20120330182646.10018.85805.sendpatchset@srdronam.in.ibm.com
Merge first batch of patches from Andrew Morton:
"A few misc things and all the MM queue"
* emailed from Andrew Morton <akpm@linux-foundation.org>: (92 commits)
memcg: avoid THP split in task migration
thp: add HPAGE_PMD_* definitions for !CONFIG_TRANSPARENT_HUGEPAGE
memcg: clean up existing move charge code
mm/memcontrol.c: remove unnecessary 'break' in mem_cgroup_read()
mm/memcontrol.c: remove redundant BUG_ON() in mem_cgroup_usage_unregister_event()
mm/memcontrol.c: s/stealed/stolen/
memcg: fix performance of mem_cgroup_begin_update_page_stat()
memcg: remove PCG_FILE_MAPPED
memcg: use new logic for page stat accounting
memcg: remove PCG_MOVE_LOCK flag from page_cgroup
memcg: simplify move_account() check
memcg: remove EXPORT_SYMBOL(mem_cgroup_update_page_stat)
memcg: kill dead prev_priority stubs
memcg: remove PCG_CACHE page_cgroup flag
memcg: let css_get_next() rely upon rcu_read_lock()
cgroup: revert ss_id_lock to spinlock
idr: make idr_get_next() good for rcu_read_lock()
memcg: remove unnecessary thp check in page stat accounting
memcg: remove redundant returns
memcg: enum lru_list lru
The comment above __insert_vm_struct seems to suggest that this function
is also going to link the VMA with the anon_vma, but this is not true.
This function only links the VMA to the mm->mm_rb tree and the mm->mmap
linked list.
[akpm@linux-foundation.org: improve comment layout and text]
Signed-off-by: Kautuk Consul <consul.kautuk@gmail.com>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
When calling shmget() with SHM_HUGETLB, shmget aligns the request size to
PAGE_SIZE, but this is not sufficient.
Modify hugetlb_file_setup() to align requests to the huge page size, and
to accept an address argument so that all alignment checks can be
performed in hugetlb_file_setup(), rather than in its callers. Change
newseg() and mmap_pgoff() to match the new prototype and eliminate a now
redundant alignment check.
[akpm@linux-foundation.org: fix build]
Signed-off-by: Steven Truelove <steven.truelove@utoronto.ca>
If the required size is bigger than cached_hole_size it is better to
search from free_area_cache - it is easier to get a free region,
specifically for the 64 bit process whose address space is large enough
Do it just as hugetlb_get_unmapped_area_topdown() in arch/x86/mm/hugetlbpage.c
Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com>
In the current code, cached_hole_size is set to the maximum value if the
unmapped vma is less that free_area_cache so the next search will search
from the base address.
Actually, we can keep cached_hole_size so that if the next required size
is more than cached_hole_size, it can search from free_area_cache.
Pull munmap/truncate race fixes from Al Viro:
"Fixes for racy use of unmap_vmas() on truncate-related codepaths"
* 'vm' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
VM: make zap_page_range() callers that act on a single VMA use separate helper
VM: make unmap_vmas() return void
VM: don't bother with feeding upper limit to tlb_finish_mmu() in exit_mmap()
VM: make zap_page_range() return void
VM: can't go through the inner loop in unmap_vmas() more than once...
VM: unmap_page_range() can return void
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates for 3.4 from James Morris:
"The main addition here is the new Yama security module from Kees Cook,
which was discussed at the Linux Security Summit last year. Its
purpose is to collect miscellaneous DAC security enhancements in one
place. This also marks a departure in policy for LSM modules, which
were previously limited to being standalone access control systems.
Chromium OS is using Yama, and I believe there are plans for Ubuntu,
at least.
This patchset also includes maintenance updates for AppArmor, TOMOYO
and others."
Fix trivial conflict in <net/sock.h> due to the jumo_label->static_key
rename.
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (38 commits)
AppArmor: Fix location of const qualifier on generated string tables
TOMOYO: Return error if fails to delete a domain
AppArmor: add const qualifiers to string arrays
AppArmor: Add ability to load extended policy
TOMOYO: Return appropriate value to poll().
AppArmor: Move path failure information into aa_get_name and rename
AppArmor: Update dfa matching routines.
AppArmor: Minor cleanup of d_namespace_path to consolidate error handling
AppArmor: Retrieve the dentry_path for error reporting when path lookup fails
AppArmor: Add const qualifiers to generated string tables
AppArmor: Fix oops in policy unpack auditing
AppArmor: Fix error returned when a path lookup is disconnected
KEYS: testing wrong bit for KEY_FLAG_REVOKED
TOMOYO: Fix mount flags checking order.
security: fix ima kconfig warning
AppArmor: Fix the error case for chroot relative path name lookup
AppArmor: fix mapping of META_READ to audit and quiet flags
AppArmor: Fix underflow in xindex calculation
AppArmor: Fix dropping of allowed operations that are force audited
AppArmor: Add mising end of structure test to caps unpacking
same story - nobody uses it and it's been pointless since
"mm: Remove i_mmap_lock lockbreak" went in.
no point, really - the only instance that cares about those arguments of
tlb_finish_mmu() is itanic and there we explicitly check if that's called
from exit_mmap() (i.e. that ->fullmm is set), in which case we ignore those
arguments completely.
Commit 6bd4837de96e ("mm: simplify find_vma_prev()") broke memory
management on PA-RISC.
After application of the patch, programs that allocate big arrays on the
stack crash with segfault, for example, this will crash if compiled
without optimization:
int main()
char array[200000];
array[199999] = 0;
return 0;
The reason is that PA-RISC has up-growing stack and the stack is usually
the last memory area. In the above example, a page fault happens above
the stack.
Previously, if we passed too high address to find_vma_prev, it returned
NULL and stored the last VMA in *pprev. After "simplify find_vma_prev"
change, it stores NULL in *pprev. Consequently, the stack area is not
found and it is not expanded, as it used to be before the change.
This patch restores the old behavior and makes it return the last VMA in
*pprev if the requested address is higher than address of any other VMA.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Currently error is -ENOMEM when rejecting VM_GROWSDOWN|VM_GROWSUP
from shared anonymous: hoist the file case's -EINVAL up for both.
Make the uprobes code readable to me:
- improve the Kconfig text so that a mere mortal gets some idea
what CONFIG_UPROBES=y is really about
- do trivial renames to standardize around the uprobes_*() namespace
- clean up and simplify various code flow details
- separate basic blocks of functionality
- line break artifact and white space related removal
- use standard local varible definition blocks
- use vertical spacing to make things more readable
- remove unnecessary volatile
- restructure comment blocks to make them more uniform and
more readable in general
Cc: Jim Keniston <jkenisto@us.ibm.com>
Link: http://lkml.kernel.org/n/tip-ewbwhb8o6navvllsauu7k07p@git.kernel.org
