path: root/mm/mmap.c
2011-01-13brk: fix min_brk lower bound computation for COMPAT_BRKJiri Kosina
Even if CONFIG_COMPAT_BRK is set in the kernel configuration, it can still be overriden by randomize_va_space sysctl. If this is the case, the min_brk computation in sys_brk() implementation is wrong, as it solely takes into account COMPAT_BRK setting, assuming that brk start is not randomized. But that might not be the case if randomize_va_space sysctl has been set to '2' at the time the binary has been loaded from disk. In such case, the check has to be done in a same way as in !CONFIG_COMPAT_BRK case. In addition to that, the check for the COMPAT_BRK case introduced back in a5b4592c ("brk: make sys_brk() honor COMPAT_BRK when computing lower bound") is slightly wrong -- the lower bound shouldn't be mm->end_code, but mm->end_data instead, as that's where the legacy applications expect brk section to start (i.e. immediately after last global variable). [akpm@linux-foundation.org: fix comment] Signed-off-by: Jiri Kosina <jkosina@suse.cz> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13thp: avoid breaking huge pmd invariants in case of vma_adjust failuresAndrea Arcangeli
An huge pmd can only be mapped if the corresponding 2M virtual range is fully contained in the vma. At times the VM calls split_vma twice, if the first split_vma succeeds and the second fail, the first split_vma remains in effect and it's not rolled back. For split_vma or vma_adjust to fail an allocation failure is needed so it's a very unlikely event (the out of memory killer would normally fire before any allocation failure is visible to kernel and userland and if an out of memory condition happens it's unlikely to happen exactly here). Nevertheless it's safer to ensure that no huge pmd can be left around if the vma is adjusted in a way that can't fit hugepages anymore at the new vm_start/vm_end address. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13thp: khugepaged vma mergeAndrea Arcangeli
register in khugepaged if the vma grows. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-15install_special_mapping skips security_file_mmap check.Tavis Ormandy
The install_special_mapping routine (used, for example, to setup the vdso) skips the security check before insert_vm_struct, allowing a local attacker to bypass the mmap_min_addr security restriction by limiting the available pages for special mappings. bprm_mm_init() also skips the check, and although I don't think this can be used to bypass any restrictions, I don't see any reason not to have the security check. $ uname -m x86_64 $ cat /proc/sys/vm/mmap_min_addr 65536 $ cat install_special_mapping.s section .bss resb BSS_SIZE section .text global _start _start: mov eax, __NR_pause int 0x80 $ nasm -D__NR_pause=29 -DBSS_SIZE=0xfffed000 -f elf -o install_special_mapping.o install_special_mapping.s $ ld -m elf_i386 -Ttext=0x10000 -Tbss=0x11000 -o install_special_mapping install_special_mapping.o $ ./install_special_mapping & [1] 14303 $ cat /proc/14303/maps 0000f000-00010000 r-xp 00000000 00:00 0 [vdso] 00010000-00011000 r-xp 00001000 00:19 2453665 /home/taviso/install_special_mapping 00011000-ffffe000 rwxp 00000000 00:00 0 [stack] It's worth noting that Red Hat are shipping with mmap_min_addr set to 4096. Signed-off-by: Tavis Ormandy <taviso@google.com> Acked-by: Kees Cook <kees@ubuntu.com> Acked-by: Robert Swiecki <swiecki@google.com> [ Changed to not drop the error code - akpm ] Reviewed-by: James Morris <jmorris@namei.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-30audit mmapAl Viro
Normal syscall audit doesn't catch 5th argument of syscall. It also doesn't catch the contents of userland structures pointed to be syscall argument, so for both old and new mmap(2) ABI it doesn't record the descriptor we are mapping. For old one it also misses flags. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-09-22mmap: call unlink_anon_vmas() in __split_vma() in case of errorAndrea Arcangeli
If __split_vma fails because of an out of memory condition the anon_vma_chain isn't teardown and freed potentially leading to rmap walks accessing freed vma information plus there's a memleak. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Johannes Weiner <jweiner@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-24guard page for stacks that grow upwardsLuck, Tony
pa-risc and ia64 have stacks that grow upwards. Check that they do not run into other mappings. By making VM_GROWSUP 0x0 on architectures that do not ever use it, we can avoid some unpleasant #ifdefs in check_stack_guard_page(). Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-21mm: make the vma list be doubly linkedLinus Torvalds
It's a really simple list, and several of the users want to go backwards in it to find the previous vma. So rather than have to look up the previous entry with 'find_vma_prev()' or something similar, just make it doubly linked instead. Tested-by: Ian Campbell <ijc@hellion.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09mmap: remove unnecessary lock from __vma_linkAndrea Arcangeli
There's no anon-vma related mangling happening inside __vma_link anymore so no need of anon_vma locking there. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09mm: always lock the root (oldest) anon_vmaRik van Riel
Always (and only) lock the root (oldest) anon_vma whenever we do something in an anon_vma. The recently introduced anon_vma scalability is due to the rmap code scanning only the VMAs that need to be scanned. Many common operations still took the anon_vma lock on the root anon_vma, so always taking that lock is not expected to introduce any scalability issues. However, always taking the same lock does mean we only need to take one lock, which means rmap_walk on pages from any anon_vma in the vma is excluded from occurring during an munmap, expand_stack or other operation that needs to exclude rmap_walk and similar functions. Also add the proper locking to vma_adjust. Signed-off-by: Rik van Riel <riel@redhat.com> Tested-by: Larry Woodman <lwoodman@redhat.com> Acked-by: Larry Woodman <lwoodman@redhat.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09mm: change direct call of spin_lock(anon_vma->lock) to inline functionRik van Riel
Subsitute a direct call of spin_lock(anon_vma->lock) with an inline function doing exactly the same. This makes it easier to do the substitution to the root anon_vma lock in a following patch. We will deal with the handful of special locks (nested, dec_and_lock, etc) separately. Signed-off-by: Rik van Riel <riel@redhat.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Tested-by: Larry Woodman <lwoodman@redhat.com> Acked-by: Larry Woodman <lwoodman@redhat.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09mm: rename anon_vma_lock to vma_lock_anon_vmaRik van Riel
Rename anon_vma_lock to vma_lock_anon_vma. This matches the naming style used in page_lock_anon_vma and will come in really handy further down in this patch series. Signed-off-by: Rik van Riel <riel@redhat.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Tested-by: Larry Woodman <lwoodman@redhat.com> Acked-by: Larry Woodman <lwoodman@redhat.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-06-09perf: Add non-exec mmap() trackingEric B Munson
Add the capacility to track data mmap()s. This can be used together with PERF_SAMPLE_ADDR for data profiling. Signed-off-by: Anton Blanchard <anton@samba.org> [Updated code for stable perf ABI] Signed-off-by: Eric B Munson <ebmunson@us.ibm.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <1274193049-25997-1-git-send-email-ebmunson@us.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-27mmap: check ->vm_ops before dereferencingRik van Riel
Check whether the VMA has a vm_ops before calling close, just like we check vm_ops before calling open a few dozen lines higher up in the function. Signed-off-by: Rik van Riel <riel@redhat.com> Reported-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-12vma_adjust: fix the copying of anon_vma chainsLinus Torvalds
When we move the boundaries between two vma's due to things like mprotect, we need to make sure that the anon_vma of the pages that got moved from one vma to another gets properly copied around. And that was not always the case, in this rather hard-to-follow code sequence. Clarify the code, and fix it so that it copies the anon_vma from the right source. Reviewed-by: Rik van Riel <riel@redhat.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Tested-by: Borislav Petkov <bp@alien8.de> [ "Yeah, not so much this one either" ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-12Simplify and comment on anon_vma re-use for anon_vma_prepare()Linus Torvalds
This changes the anon_vma reuse case to require that we only reuse simple anon_vma's - ie the case when the vma only has a single anon_vma associated with it. This means that a reuse of an anon_vma from an adjacent vma will always guarantee that both vma's are associated not only with the same anon_vma, they will also have the same anon_vma chain (of just a single entry in this case). And since anon_vma re-use was the only case where the same anon_vma might be associated with different chains of anon_vma's, we now have the case that every vma that shares the same anon_vma will always also have the same chain. That makes it much easier to think about merging vma's that share the same anon_vma's: you can always just drop the other anon_vma chain in anon_vma_merge() since you know that they are always identical. This also splits up the function to validate the anon_vma re-use, and adds a lot of commentary about the possible races. Reviewed-by: Rik van Riel <riel@redhat.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Tested-by: Borislav Petkov <bp@alien8.de> [ "That didn't fix it" ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12Add generic sys_old_mmap()Christoph Hellwig
Add a generic implementation of the old mmap() syscall, which expects its argument in a memory block and switch all architectures over to use it. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: James Morris <jmorris@namei.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Ungerer <gerg@uclinux.org> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06mm: remove VM_LOCK_RMAP codeRik van Riel
When a VMA is in an inconsistent state during setup or teardown, the worst that can happen is that the rmap code will not be able to find the page. The mapping is in the process of being torn down (PTEs just got invalidated by munmap), or set up (no PTEs have been instantiated yet). It is also impossible for the rmap code to follow a pointer to an already freed VMA, because the rmap code holds the anon_vma->lock, which the VMA teardown code needs to take before the VMA is removed from the anon_vma chain. Hence, we should not need the VM_LOCK_RMAP locking at all. Signed-off-by: Rik van Riel <riel@redhat.com> Cc: Nick Piggin <npiggin@suse.de> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Larry Woodman <lwoodman@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06mm: change anon_vma linking to fix multi-process server scalability issueRik van Riel
The old anon_vma code can lead to scalability issues with heavily forking workloads. Specifically, each anon_vma will be shared between the parent process and all its child processes. In a workload with 1000 child processes and a VMA with 1000 anonymous pages per process that get COWed, this leads to a system with a million anonymous pages in the same anon_vma, each of which is mapped in just one of the 1000 processes. However, the current rmap code needs to walk them all, leading to O(N) scanning complexity for each page. This can result in systems where one CPU is walking the page tables of 1000 processes in page_referenced_one, while all other CPUs are stuck on the anon_vma lock. This leads to catastrophic failure for a benchmark like AIM7, where the total number of processes can reach in the tens of thousands. Real workloads are still a factor 10 less process intensive than AIM7, but they are catching up. This patch changes the way anon_vmas and VMAs are linked, which allows us to associate multiple anon_vmas with a VMA. At fork time, each child process gets its own anon_vmas, in which its COWed pages will be instantiated. The parents' anon_vma is also linked to the VMA, because non-COWed pages could be present in any of the children. This reduces rmap scanning complexity to O(1) for the pages of the 1000 child processes, with O(N) complexity for at most 1/N pages in the system. This reduces the average scanning cost in heavily forking workloads from O(N) to 2. The only real complexity in this patch stems from the fact that linking a VMA to anon_vmas now involves memory allocations. This means vma_adjust can fail, if it needs to attach a VMA to anon_vma structures. This in turn means error handling needs to be added to the calling functions. A second source of complexity is that, because there can be multiple anon_vmas, the anon_vma linking in vma_adjust can no longer be done under "the" anon_vma lock. To prevent the rmap code from walking up an incomplete VMA, this patch introduces the VM_LOCK_RMAP VMA flag. This bit flag uses the same slot as the NOMMU VM_MAPPED_COPY, with an ifdef in mm.h to make sure it is impossible to compile a kernel that needs both symbolic values for the same bitflag. Some test results: Without the anon_vma changes, when AIM7 hits around 9.7k users (on a test box with 16GB RAM and not quite enough IO), the system ends up running >99% in system time, with every CPU on the same anon_vma lock in the pageout code. With these changes, AIM7 hits the cross-over point around 29.7k users. This happens with ~99% IO wait time, there never seems to be any spike in system time. The anon_vma lock contention appears to be resolved. [akpm@linux-foundation.org: cleanups] Signed-off-by: Rik van Riel <riel@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Larry Woodman <lwoodman@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06mm: use rlimit helpersJiri Slaby
Make sure compiler won't do weird things with limits. E.g. fetching them twice may return 2 different values after writable limits are implemented. I.e. either use rlimit helpers added in 3e10e716abf3c71bdb5d86b8f507f9e72236c9cd ("resource: add helpers for fetching rlimits") or ACCESS_ONCE if not applicable. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06mm: mlock_vma_pages_range() only return success or failureKOSAKI Motohiro
Currently, mlock_vma_pages_range() only return len or 0. then current error handling of mmap_region() is meaningless complex. This patch makes simplify and makes consist with brk() code. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Rik van Riel <riel@redhat.com> Cc: KAMEZAWA Hiroyuki <kamewzawa.hiroyu@jp.fujitsu.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06mm: mlock_vma_pages_range() never return negative valueKOSAKI Motohiro
Currently, mlock_vma_pages_range() never return negative value. Then, we can remove some worthless error check. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Rik van Riel <riel@redhat.com> Cc: KAMEZAWA Hiroyuki <kamewzawa.hiroyu@jp.fujitsu.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-30mm: move sys_mmap_pgoff from util.cHugh Dickins
Move sys_mmap_pgoff() from mm/util.c to mm/mmap.c and mm/nommu.c, where we'd expect to find such code: especially now that it contains the MAP_HUGETLB handling. Revert mm/util.c to how it was in 2.6.32. This patch just ignores MAP_HUGETLB in the nommu case, as in 2.6.32, whereas 2.6.33-rc2 reported -ENOSYS. Perhaps validate_mmap_request() should reject it with -EINVAL? Add that later if necessary. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15mm: uncached vma support with writenotifyMagnus Damm
Modify the generic mmap() code to keep the cache attribute in vma->vm_page_prot regardless if writenotify is enabled or not. Without this patch the cache configuration selected by f_op->mmap() is overwritten if writenotify is enabled, making it impossible to keep the vma uncached. Needed by drivers such as drivers/video/sh_mobile_lcdcfb.c which uses deferred io together with uncached memory. Signed-off-by: Magnus Damm <damm@opensource.se> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jaya Kumar <jayakumar.lkml@gmail.com> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15mmap: don't return ENOMEM when mapcount is temporarily exceeded in munmap()KOSAKI Motohiro
On ia64, the following test program exit abnormally, because glibc thread library called abort(). ======================================================== (gdb) bt #0 0xa000000000010620 in __kernel_syscall_via_break () #1 0x20000000003208e0 in raise () from /lib/libc.so.6.1 #2 0x2000000000324090 in abort () from /lib/libc.so.6.1 #3 0x200000000027c3e0 in __deallocate_stack () from /lib/libpthread.so.0 #4 0x200000000027f7c0 in start_thread () from /lib/libpthread.so.0 #5 0x200000000047ef60 in __clone2 () from /lib/libc.so.6.1 ======================================================== The fact is, glibc call munmap() when thread exitng time for freeing stack, and it assume munlock() never fail. However, munmap() often make vma splitting and it with many mapcount make -ENOMEM. Oh well, that's crazy, because stack unmapping never increase mapcount. The maxcount exceeding is only temporary. internal temporary exceeding shouldn't make ENOMEM. This patch does it. test_max_mapcount.c ================================================================== #include<stdio.h> #include<stdlib.h> #include<string.h> #include<pthread.h> #include<errno.h> #include<unistd.h> #define THREAD_NUM 30000 #define MAL_SIZE (8*1024*1024) void *wait_thread(void *args) { void *addr; addr = malloc(MAL_SIZE); sleep(10); return NULL; } void *wait_thread2(void *args) { sleep(60); return NULL; } int main(int argc, char *argv[]) { int i; pthread_t thread[THREAD_NUM], th; int ret, count = 0; pthread_attr_t attr; ret = pthread_attr_init(&attr); if(ret) { perror("pthread_attr_init"); } ret = pthread_attr_setdetachstate(&attr, PTHREAD_CREATE_DETACHED); if(ret) { perror("pthread_attr_setdetachstate"); } for (i = 0; i < THREAD_NUM; i++) { ret = pthread_create(&th, &attr, wait_thread, NULL); if(ret) { fprintf(stderr, "[%d] ", count); perror("pthread_create"); } else { printf("[%d] create OK.\n", count); } count++; ret = pthread_create(&thread[i], &attr, wait_thread2, NULL); if(ret) { fprintf(stderr, "[%d] ", count); perror("pthread_create"); } else { printf("[%d] create OK.\n", count); } count++; } sleep(3600); return 0; } ================================================================== [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-11switch do_brk() to get_unmapped_area()Al Viro
2009-12-11Take arch_mmap_check() into get_unmapped_area()Al Viro
Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-11fix a struct file leak in do_mmap_pgoff()Al Viro
2009-10-25LSM: imbed ima calls in the security hooksMimi Zohar
Based on discussions on LKML and LSM, where there are consecutive security_ and ima_ calls in the vfs layer, move the ima_ calls to the existing security_ hooks. Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-27const: mark struct vm_struct_operationsAlexey Dobriyan
* mark struct vm_area_struct::vm_ops as const * mark vm_ops in AGP code But leave TTM code alone, something is fishy there with global vm_ops being used. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22hugetlb: add MAP_HUGETLB for mmaping pseudo-anonymous huge page regionsEric B Munson
Add a flag for mmap that will be used to request a huge page region that will look like anonymous memory to userspace. This is accomplished by using a file on the internal vfsmount. MAP_HUGETLB is a modifier of MAP_ANONYMOUS and so must be specified with it. The region will behave the same as a MAP_ANONYMOUS region using small pages. [akpm@linux-foundation.org: fix arch definitions of MAP_HUGETLB] Signed-off-by: Eric B Munson <ebmunson@us.ibm.com> Acked-by: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Adam Litke <agl@us.ibm.com> Cc: David Gibson <david@gibson.dropbear.id.au> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22mmap: save some cycles for the shared anonymous mappingHuang Shijie
shmem_zero_setup() does not change vm_start, pgoff or vm_flags, only some drivers change them (such as /driver/video/bfin-t350mcqb-fb.c). Move these codes to a more proper place to save cycles for shared anonymous mapping. Signed-off-by: Huang Shijie <shijie8@gmail.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22mmap: avoid unnecessary anon_vma lock acquisition in vma_adjust()Lee Schermerhorn
We noticed very erratic behavior [throughput] with the AIM7 shared workload running on recent distro [SLES11] and mainline kernels on an 8-socket, 32-core, 256GB x86_64 platform. On the SLES11 kernel [2.6.27.19+] with Barcelona processors, as we increased the load [10s of thousands of tasks], the throughput would vary between two "plateaus"--one at ~65K jobs per minute and one at ~130K jpm. The simple patch below causes the results to smooth out at the ~130k plateau. But wait, there's more: We do not see this behavior on smaller platforms--e.g., 4 socket/8 core. This could be the result of the larger number of cpus on the larger platform--a scalability issue--or it could be the result of the larger number of interconnect "hops" between some nodes in this platform and how the tasks for a given load end up distributed over the nodes' cpus and memories--a stochastic NUMA effect. The variability in the results are less pronounced [on the same platform] with Shanghai processors and with mainline kernels. With 31-rc6 on Shanghai processors and 288 file systems on 288 fibre attached storage volumes, the curves [jpm vs load] are both quite flat with the patched kernel consistently producing ~3.9% better throughput [~80K jpm vs ~77K jpm] than the unpatched kernel. Profiling indicated that the "slow" runs were incurring high[er] contention on an anon_vma lock in vma_adjust(), apparently called from the sbrk() system call. The patch: A comment in mm/mmap.c:vma_adjust() suggests that we don't really need the anon_vma lock when we're only adjusting the end of a vma, as is the case for brk(). The comment questions whether it's worth while to optimize for this case. Apparently, on the newer, larger x86_64 platforms, with interesting NUMA topologies, it is worth while--especially considering that the patch [if correct!] is quite simple. We can detect this condition--no overlap with next vma--by noting a NULL "importer". The anon_vma pointer will also be NULL in this case, so simply avoid loading vma->anon_vma to avoid the lock. However, we DO need to take the anon_vma lock when we're inserting a vma ['insert' non-NULL] even when we have no overlap [NULL "importer"], so we need to check for 'insert', as well. And Hugh points out that we should also take it when adjusting vm_start (so that rmap.c can rely upon vma_address() while it holds the anon_vma lock). akpm: Zhang Yanmin reprts a 150% throughput improvement with aim7, so it might be -stable material even though thiss isn't a regression: "this issue is not clear on dual socket Nehalem machine (2*4*2 cpu), but is severe on large machine (4*8*2 cpu)" [hugh.dickins@tiscali.co.uk: test vma start too] Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Nick Piggin <npiggin@suse.de> Cc: Eric Whitney <eric.whitney@hp.com> Tested-by: "Zhang, Yanmin" <yanmin_zhang@linux.intel.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22mmap: remove unnecessary codeHuang Shijie
If (flags & MAP_LOCKED) is true, it means vm_flags has already contained the bit VM_LOCKED which is set by calc_vm_flag_bits(). So there is no need to reset it again, just remove it. Signed-off-by: Huang Shijie <shijie8@gmail.com> Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22ksm: clean up obsolete referencesHugh Dickins
A few cleanups, given the munlock fix: the comment on ksm_test_exit() no longer applies, and it can be made private to ksm.c; there's no more reference to mmu_gather or tlb.h, and mmap.c doesn't need ksm.h. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Acked-by: Izik Eidus <ieidus@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22ksm: remove VM_MERGEABLE_FLAGSHugh Dickins
KSM originally stood for Kernel Shared Memory: but the kernel has long supported shared memory, and VM_SHARED and VM_MAYSHARE vmas, and KSM is something else. So we switched to saying "merge" instead of "share". But Chris Wright points out that this is confusing where mmap.c merges adjacent vmas: most especially in the name VM_MERGEABLE_FLAGS, used by is_mergeable_vma() to let vmas be merged despite flags being different. Call it VMA_MERGE_DESPITE_FLAGS? Perhaps, but at present it consists only of VM_CAN_NONLINEAR: so for now it's clearer on all sides to use that directly, with a comment on it in is_mergeable_vma(). Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Acked-by: Izik Eidus <ieidus@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22ksm: fix deadlock with munlock in exit_mmapAndrea Arcangeli
Rawhide users have reported hang at startup when cryptsetup is run: the same problem can be simply reproduced by running a program int main() { mlockall(MCL_CURRENT | MCL_FUTURE); return 0; } The problem is that exit_mmap() applies munlock_vma_pages_all() to clean up VM_LOCKED areas, and its current implementation (stupidly) tries to fault in absent pages, for example where PROT_NONE prevented them being faulted in when mlocking. Whereas the "ksm: fix oom deadlock" patch, knowing there's a race by which KSM might try to fault in pages after exit_mmap() had finally zapped the range, backs out of such faults doing nothing when its ksm_test_exit() notices mm_users 0. So revert that part of "ksm: fix oom deadlock" which moved the ksm_exit() call from before exit_mmap() to the middle of exit_mmap(); and remove those ksm_test_exit() checks from the page fault paths, so allowing the munlocking to proceed without interference. ksm_exit, if there are rmap_items still chained on this mm slot, takes mmap_sem write side: so preventing KSM from working on an mm while exit_mmap runs. And KSM will bail out as soon as it notices that mm_users is already zero, thanks to its internal ksm_test_exit checks. So that when a task is killed by OOM killer or the user, KSM will not indefinitely prevent it from running exit_mmap to release its memory. This does break a part of what "ksm: fix oom deadlock" was trying to achieve. When unmerging KSM (echo 2 >/sys/kernel/mm/ksm), and even when ksmd itself has to cancel a KSM page, it is possible that the first OOM-kill victim would be the KSM process being faulted: then its memory won't be freed until a second victim has been selected (freeing memory for the unmerging fault to complete). But the OOM killer is already liable to kill a second victim once the intended victim's p->mm goes to NULL: so there's not much point in rejecting this KSM patch before fixing that OOM behaviour. It is very much more important to allow KSM users to boot up, than to haggle over an unlikely and poorly supported OOM case. We also intend to fix munlocking to not fault pages: at which point this patch _could_ be reverted; though that would be controversial, so we hope to find a better solution. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Justin M. Forbes <jforbes@redhat.com> Acked-for-now-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Izik Eidus <ieidus@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22ksm: fix oom deadlockHugh Dickins
There's a now-obvious deadlock in KSM's out-of-memory handling: imagine ksmd or KSM_RUN_UNMERGE handling, holding ksm_thread_mutex, trying to allocate a page to break KSM in an mm which becomes the OOM victim (quite likely in the unmerge case): it's killed and goes to exit, and hangs there waiting to acquire ksm_thread_mutex. Clearly we must not require ksm_thread_mutex in __ksm_exit, simple though that made everything else: perhaps use mmap_sem somehow? And part of the answer lies in the comments on unmerge_ksm_pages: __ksm_exit should also leave all the rmap_item removal to ksmd. But there's a fundamental problem, that KSM relies upon mmap_sem to guarantee the consistency of the mm it's dealing with, yet exit_mmap tears down an mm without taking mmap_sem. And bumping mm_users won't help at all, that just ensures that the pages the OOM killer assumes are on their way to being freed will not be freed. The best answer seems to be, to move the ksm_exit callout from just before exit_mmap, to the middle of exit_mmap: after the mm's pages have been freed (if the mmu_gather is flushed), but before its page tables and vma structures have been freed; and down_write,up_write mmap_sem there to serialize with KSM's own reliance on mmap_sem. But KSM then needs to be careful, whenever it downs mmap_sem, to check that the mm is not already exiting: there's a danger of using find_vma on a layout that's being torn apart, or writing into page tables which have been freed for reuse; and even do_anonymous_page and __do_fault need to check they're not being called by break_ksm to reinstate a pte after zap_pte_range has zapped that page table. Though it might be clearer to add an exiting flag, set while holding mmap_sem in __ksm_exit, that wouldn't cover the issue of reinstating a zapped pte. All we need is to check whether mm_users is 0 - but must remember that ksmd may detect that before __ksm_exit is reached. So, ksm_test_exit(mm) added to comment such checks on mm->mm_users. __ksm_exit now has to leave clearing up the rmap_items to ksmd, that needs ksm_thread_mutex; but shift the exiting mm just after the ksm_scan cursor so that it will soon be dealt with. __ksm_enter raise mm_count to hold the mm_struct, ksmd's exit processing (exactly like its processing when it finds all VM_MERGEABLEs unmapped) mmdrop it, similar procedure for KSM_RUN_UNMERGE (which has stopped ksmd). But also give __ksm_exit a fast path: when there's no complication (no rmap_items attached to mm and it's not at the ksm_scan cursor), it can safely do all the exiting work itself. This is not just an optimization: when ksmd is not running, the raised mm_count would otherwise leak mm_structs. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Acked-by: Izik Eidus <ieidus@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-21perf: Do the big rename: Performance Counters -> Performance EventsIngo Molnar
Bye-bye Performance Counters, welcome Performance Events! In the past few months the perfcounters subsystem has grown out its initial role of counting hardware events, and has become (and is becoming) a much broader generic event enumeration, reporting, logging, monitoring, analysis facility. Naming its core object 'perf_counter' and naming the subsystem 'perfcounters' has become more and more of a misnomer. With pending code like hw-breakpoints support the 'counter' name is less and less appropriate. All in one, we've decided to rename the subsystem to 'performance events' and to propagate this rename through all fields, variables and API names. (in an ABI compatible fashion) The word 'event' is also a bit shorter than 'counter' - which makes it slightly more convenient to write/handle as well. Thanks goes to Stephane Eranian who first observed this misnomer and suggested a rename. User-space tooling and ABI compatibility is not affected - this patch should be function-invariant. (Also, defconfigs were not touched to keep the size down.) This patch has been generated via the following script: FILES=$(find * -type f | grep -vE 'oprofile|[^K]config') sed -i \ -e 's/PERF_EVENT_/PERF_RECORD_/g' \ -e 's/PERF_COUNTER/PERF_EVENT/g' \ -e 's/perf_counter/perf_event/g' \ -e 's/nb_counters/nb_events/g' \ -e 's/swcounter/swevent/g' \ -e 's/tpcounter_event/tp_event/g' \ $FILES for N in $(find . -name perf_counter.[ch]); do M=$(echo $N | sed 's/perf_counter/perf_event/g') mv $N $M done FILES=$(find . -name perf_event.*) sed -i \ -e 's/COUNTER_MASK/REG_MASK/g' \ -e 's/COUNTER/EVENT/g' \ -e 's/\<event\>/event_id/g' \ -e 's/counter/event/g' \ -e 's/Counter/Event/g' \ $FILES ... to keep it as correct as possible. This script can also be used by anyone who has pending perfcounters patches - it converts a Linux kernel tree over to the new naming. We tried to time this change to the point in time where the amount of pending patches is the smallest: the end of the merge window. Namespace clashes were fixed up in a preparatory patch - and some stylistic fallout will be fixed up in a subsequent patch. ( NOTE: 'counters' are still the proper terminology when we deal with hardware registers - and these sed scripts are a bit over-eager in renaming them. I've undone some of that, but in case there's something left where 'counter' would be better than 'event' we can undo that on an individual basis instead of touching an otherwise nicely automated patch. ) Suggested-by: Stephane Eranian <eranian@google.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Paul Mackerras <paulus@samba.org> Reviewed-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Howells <dhowells@redhat.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: <linux-arch@vger.kernel.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-18mm: Fix problem of parameter in noteJianjun Kong
'current' is a pointer, so the right form is 'down_write(&current->mm->mmap_sem)'. Signed-off-by: Jianjun Kong <jianjun@zeuux.org> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-17Security/SELinux: seperate lsm specific mmap_min_addrEric Paris
Currently SELinux enforcement of controls on the ability to map low memory is determined by the mmap_min_addr tunable. This patch causes SELinux to ignore the tunable and instead use a seperate Kconfig option specific to how much space the LSM should protect. The tunable will now only control the need for CAP_SYS_RAWIO and SELinux permissions will always protect the amount of low memory designated by CONFIG_LSM_MMAP_MIN_ADDR. This allows users who need to disable the mmap_min_addr controls (usual reason being they run WINE as a non-root user) to do so and still have SELinux controls preventing confined domains (like a web server) from being able to map some area of low memory. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-06-11Merge branch 'perfcounters-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perfcounters-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (574 commits) perf_counter: Turn off by default perf_counter: Add counter->id to the throttle event perf_counter: Better align code perf_counter: Rename L2 to LL cache perf_counter: Standardize event names perf_counter: Rename enums perf_counter tools: Clean up u64 usage perf_counter: Rename perf_counter_limit sysctl perf_counter: More paranoia settings perf_counter: powerpc: Implement generalized cache events for POWER processors perf_counters: powerpc: Add support for POWER7 processors perf_counter: Accurate period data perf_counter: Introduce struct for sample data perf_counter tools: Normalize data using per sample period data perf_counter: Annotate exit ctx recursion perf_counter tools: Propagate signals properly perf_counter tools: Small frequency related fixes perf_counter: More aggressive frequency adjustment perf_counter/x86: Fix the model number of Intel Core2 processors perf_counter, x86: Correct some event and umask values for Intel processors ...
2009-06-05perf_counter: Generate mmap events for install_special_mapping()Peter Zijlstra
In order to track the vdso also generate mmap events for install_special_mapping(). Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-04perf_counter: Remove munmap stuffPeter Zijlstra
In name of keeping it simple, only track mmap events. Userspace will have to remove old overlapping maps when it encounters them. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-04security: use mmap_min_addr indepedently of security modelsChristoph Lameter
This patch removes the dependency of mmap_min_addr on CONFIG_SECURITY. It also sets a default mmap_min_addr of 4096. mmapping of addresses below 4096 will only be possible for processes with CAP_SYS_RAWIO. Signed-off-by: Christoph Lameter <cl@linux-foundation.org> Acked-by: Eric Paris <eparis@redhat.com> Looks-ok-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: James Morris <jmorris@namei.org>
2009-05-18Merge commit 'v2.6.30-rc6' into perfcounters/coreIngo Molnar
Merge reason: this branch was on an -rc4 base, merge it up to -rc6 to get the latest upstream fixes. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-05-02mm: fix Committed_AS underflow on large NR_CPUS environmentKOSAKI Motohiro
The Committed_AS field can underflow in certain situations: > # while true; do cat /proc/meminfo | grep _AS; sleep 1; done | uniq -c > 1 Committed_AS: 18446744073709323392 kB > 11 Committed_AS: 18446744073709455488 kB > 6 Committed_AS: 35136 kB > 5 Committed_AS: 18446744073709454400 kB > 7 Committed_AS: 35904 kB > 3 Committed_AS: 18446744073709453248 kB > 2 Committed_AS: 34752 kB > 9 Committed_AS: 18446744073709453248 kB > 8 Committed_AS: 34752 kB > 3 Committed_AS: 18446744073709320960 kB > 7 Committed_AS: 18446744073709454080 kB > 3 Committed_AS: 18446744073709320960 kB > 5 Committed_AS: 18446744073709454080 kB > 6 Committed_AS: 18446744073709320960 kB Because NR_CPUS can be greater than 1000 and meminfo_proc_show() does not check for underflow. But NR_CPUS proportional isn't good calculation. In general, possibility of lock contention is proportional to the number of online cpus, not theorical maximum cpus (NR_CPUS). The current kernel has generic percpu-counter stuff. using it is right way. it makes code simplify and percpu_counter_read_positive() don't make underflow issue. Reported-by: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Eric B Munson <ebmunson@us.ibm.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: <stable@kernel.org> [All kernel versions] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-29Merge branch 'linus' into perfcounters/coreIngo Molnar
Merge reason: This brach was on -rc1, refresh it to almost-rc4 to pick up the latest upstream fixes. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-16mm: pass correct mm when growing stackHugh Dickins
Tetsuo Handa reports seeing the WARN_ON(current->mm == NULL) in security_vm_enough_memory(), when do_execve() is touching the target mm's stack, to set up its args and environment. Yes, a UMH_NO_WAIT or UMH_WAIT_PROC call_usermodehelper() spawns an mm-less kernel thread to do the exec. And in any case, that vm_enough_memory check when growing stack ought to be done on the target mm, not on the execer's mm (though apart from the warning, it only makes a slight tweak to OVERCOMMIT_NEVER behaviour). Reported-by: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp> Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-06perf_counter: executable mmap() informationPeter Zijlstra
Currently the profiling information returns userspace IPs but no way to correlate them to userspace code. Userspace could look into /proc/$pid/maps but that might not be current or even present anymore at the time of analyzing the IPs. Therefore provide means to track the mmap information and provide it in the output stream. XXX: only covers mmap()/munmap(), mremap() and mprotect() are missing. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Paul Mackerras <paulus@samba.org> Cc: Andrew Morton <akpm@linux-foundation.org> Orig-LKML-Reference: <20090330171023.417259499@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
