Almost all current users of vm_munmap are ignoring the return value and
so they do not handle potential error. This means that some VMAs might
stay behind. This patch doesn't try to solve those potential problems.
Quite contrary it adds a new failure mode by using down_write_killable
in vm_munmap. This should be safer than other failure modes, though,
because the process is guaranteed to die as soon as it leaves the kernel
and exit_mmap will clean the whole address space.
This will help in the OOM conditions when the oom victim might be stuck
waiting for the mmap_sem for write which in turn can block oom_reaper
which relies on the mmap_sem for read to make a forward progress and
reclaim the address space of the victim.
Signed-off-by: Michal Hocko <mhocko@suse.com>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
Cc: Konstantin Khlebnikov <koct9i@gmail.com>
All the callers of vm_mmap seem to check for the failure already and
bail out in one way or another on the error which means that we can
change it to use killable version of vm_mmap_pgoff and return -EINTR if
the current task gets killed while waiting for mmap_sem. This also
means that vm_mmap_pgoff can be killable by default and drop the
additional parameter.
Please note that load_elf_binary is ignoring vm_mmap error for
current->personality & MMAP_PAGE_ZERO case but that shouldn't be a
problem because the address is not used anywhere and we never return to
the userspace if we got killed.
Acked-by: Vlastimil Babka <vbabka@suse.cz>
This is a follow up work for oom_reaper [1]. As the async OOM killing
depends on oom_sem for read we would really appreciate if a holder for
write didn't stood in the way. This patchset is changing many of
down_write calls to be killable to help those cases when the writer is
blocked and waiting for readers to release the lock and so help
__oom_reap_task to process the oom victim.
Most of the patches are really trivial because the lock is help from a
shallow syscall paths where we can return EINTR trivially and allow the
current task to die (note that EINTR will never get to the userspace as
the task has fatal signal pending). Others seem to be easy as well as
the callers are already handling fatal errors and bail and return to
userspace which should be sufficient to handle the failure gracefully.
I am not familiar with all those code paths so a deeper review is really
appreciated.
As this work is touching more areas which are not directly connected I
have tried to keep the CC list as small as possible and people who I
believed would be familiar are CCed only to the specific patches (all
should have received the cover though).
This patchset is based on linux-next and it depends on
down_write_killable for rw_semaphores which got merged into tip
locking/rwsem branch and it is merged into this next tree. I guess it
would be easiest to route these patches via mmotm because of the
dependency on the tip tree but if respective maintainers prefer other
way I have no objections.
I haven't covered all the mmap_write(mm->mmap_sem) instances here
$ git grep "down_write(.*\<mmap_sem\>)" next/master | wc -l
98
$ git grep "down_write(.*\<mmap_sem\>)" | wc -l
62
I have tried to cover those which should be relatively easy to review in
this series because this alone should be a nice improvement. Other
places can be changed on top.
[0] http://lkml.kernel.org/r/1456752417-9626-1-git-send-email-mhocko@kernel.org
[1] http://lkml.kernel.org/r/1452094975-551-1-git-send-email-mhocko@kernel.org
[2] http://lkml.kernel.org/r/1456750705-7141-1-git-send-email-mhocko@kernel.org
This patch (of 18):
This is the first step in making mmap_sem write waiters killable. It
focuses on the trivial ones which are taking the lock early after
entering the syscall and they are not changing state before.
Therefore it is very easy to change them to use down_write_killable and
immediately return with -EINTR. This will allow the waiter to pass away
without blocking the mmap_sem which might be required to make a forward
progress. E.g. the oom reaper will need the lock for reading to
dismantle the OOM victim address space.
The only tricky function in this patch is vm_mmap_pgoff which has many
call sites via vm_mmap. To reduce the risk keep vm_mmap with the
original non-killable semantic for now.
vm_munmap callers do not bother checking the return value so open code
it into the munmap syscall path for now for simplicity.
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Since commit 84638335900f ("mm: rework virtual memory accounting")
RLIMIT_DATA limits both brk() and private mmap() but this's disabled by
default because of incompatibility with older versions of valgrind.
Valgrind always set limit to zero and fails if RLIMIT_DATA is enabled.
Fortunately it changes only rlim_cur and keeps rlim_max for reverting
limit back when needed.
This patch checks current usage also against rlim_max if rlim_cur is
zero. This is safe because task anyway can increase rlim_cur up to
rlim_max. Size of brk is still checked against rlim_cur, so this part
is completely compatible - zero rlim_cur forbids brk() but allows
private mmap().
Link: http://lkml.kernel.org/r/56A28613.5070104@de.ibm.com
Signed-off-by: Konstantin Khlebnikov <koct9i@gmail.com>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Nobody uses it.
Pull x86 protection key support from Ingo Molnar:
"This tree adds support for a new memory protection hardware feature
that is available in upcoming Intel CPUs: 'protection keys' (pkeys).
There's a background article at LWN.net:
https://lwn.net/Articles/643797/
The gist is that protection keys allow the encoding of
user-controllable permission masks in the pte. So instead of having a
fixed protection mask in the pte (which needs a system call to change
and works on a per page basis), the user can map a (handful of)
protection mask variants and can change the masks runtime relatively
cheaply, without having to change every single page in the affected
virtual memory range.
This allows the dynamic switching of the protection bits of large
amounts of virtual memory, via user-space instructions. It also
allows more precise control of MMU permission bits: for example the
executable bit is separate from the read bit (see more about that
below).
This tree adds the MM infrastructure and low level x86 glue needed for
that, plus it adds a high level API to make use of protection keys -
if a user-space application calls:
mmap(..., PROT_EXEC);
or
mprotect(ptr, sz, PROT_EXEC);
(note PROT_EXEC-only, without PROT_READ/WRITE), the kernel will notice
this special case, and will set a special protection key on this
memory range. It also sets the appropriate bits in the Protection
Keys User Rights (PKRU) register so that the memory becomes unreadable
and unwritable.
So using protection keys the kernel is able to implement 'true'
PROT_EXEC on x86 CPUs: without protection keys PROT_EXEC implies
PROT_READ as well. Unreadable executable mappings have security
advantages: they cannot be read via information leaks to figure out
ASLR details, nor can they be scanned for ROP gadgets - and they
cannot be used by exploits for data purposes either.
We know about no user-space code that relies on pure PROT_EXEC
mappings today, but binary loaders could start making use of this new
feature to map binaries and libraries in a more secure fashion.
There is other pending pkeys work that offers more high level system
call APIs to manage protection keys - but those are not part of this
pull request.
Right now there's a Kconfig that controls this feature
(CONFIG_X86_INTEL_MEMORY_PROTECTION_KEYS) that is default enabled
(like most x86 CPU feature enablement code that has no runtime
overhead), but it's not user-configurable at the moment. If there's
any serious problem with this then we can make it configurable and/or
flip the default"
* 'mm-pkeys-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (38 commits)
x86/mm/pkeys: Fix mismerge of protection keys CPUID bits
mm/pkeys: Fix siginfo ABI breakage caused by new u64 field
x86/mm/pkeys: Fix access_error() denial of writes to write-only VMA
mm/core, x86/mm/pkeys: Add execute-only protection keys support
x86/mm/pkeys: Create an x86 arch_calc_vm_prot_bits() for VMA flags
x86/mm/pkeys: Allow kernel to modify user pkey rights register
x86/fpu: Allow setting of XSAVE state
x86/mm: Factor out LDT init from context init
mm/core, x86/mm/pkeys: Add arch_validate_pkey()
mm/core, arch, powerpc: Pass a protection key in to calc_vm_flag_bits()
x86/mm/pkeys: Actually enable Memory Protection Keys in the CPU
x86/mm/pkeys: Add Kconfig prompt to existing config option
x86/mm/pkeys: Dump pkey from VMA in /proc/pid/smaps
x86/mm/pkeys: Dump PKRU with other kernel registers
mm/core, x86/mm/pkeys: Differentiate instruction fetches
x86/mm/pkeys: Optimize fault handling in access_error()
mm/core: Do not enforce PKEY permissions on remote mm access
um, pkeys: Add UML arch_*_access_permitted() methods
mm/gup, x86/mm/pkeys: Check VMAs and PTEs for protection keys
x86/mm/gup: Simplify get_user_pages() PTE bit handling
Kernel style prefers a single string over split strings when the string is
'user-visible'.
Miscellanea:
- Add a missing newline
- Realign arguments
Acked-by: Tejun Heo <tj@kernel.org> [percpu]
Currently we have two copies of the same code which implements memory
overcommitment logic. Let's move it into mm/util.c and hence avoid
duplication. No functional changes here.
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
max_map_count sysctl unrelated to scheduler. Move its bits from
include/linux/sched/sysctl.h to include/linux/mm.h.
Grazvydas Ignotas has reported a regression in remap_file_pages()
emulation.
Testcase:
#define _GNU_SOURCE
#include <assert.h>
#include <stdlib.h>
#include <stdio.h>
#include <sys/mman.h>
#define SIZE (4096 * 3)
int main(int argc, char **argv)
unsigned long *p;
long i;
p = mmap(NULL, SIZE, PROT_READ | PROT_WRITE,
MAP_SHARED | MAP_ANONYMOUS, -1, 0);
if (p == MAP_FAILED) {
perror("mmap");
return -1;
for (i = 0; i < SIZE / 4096; i++)
p[i * 4096 / sizeof(*p)] = i;
if (remap_file_pages(p, 4096, 0, 1, 0)) {
perror("remap_file_pages");
return -1;
if (remap_file_pages(p, 4096 * 2, 0, 1, 0)) {
return -1;
assert(p[0] == 1);
munmap(p, SIZE);
return 0;
The second remap_file_pages() fails with -EINVAL.
The reason is that remap_file_pages() emulation assumes that the target
vma covers whole area we want to over map. That assumption is broken by
first remap_file_pages() call: it split the area into two vma.
The solution is to check next adjacent vmas, if they map the same file
with the same flags.
Fixes: c8d78c1823f4 ("mm: replace remap_file_pages() syscall with emulation")
Reported-by: Grazvydas Ignotas <notasas@gmail.com>
Tested-by: Grazvydas Ignotas <notasas@gmail.com>
Cc: <stable@vger.kernel.org> [4.0+]
Protection keys provide new page-based protection in hardware.
But, they have an interesting attribute: they only affect data
accesses and never affect instruction fetches. That means that
if we set up some memory which is set as "access-disabled" via
protection keys, we can still execute from it.
This patch uses protection keys to set up mappings to do just that.
If a user calls:
or
(note PROT_EXEC-only without PROT_READ/WRITE), the kernel will
notice this, and set a special protection key on the memory. It
also sets the appropriate bits in the Protection Keys User Rights
(PKRU) register so that the memory becomes unreadable and
unwritable.
I haven't found any userspace that does this today. With this
facility in place, we expect userspace to move to use it
eventually. Userspace _could_ start doing this today. Any
PROT_EXEC calls get converted to PROT_READ inside the kernel, and
would transparently be upgraded to "true" PROT_EXEC with this
code. IOW, userspace never has to do any PROT_EXEC runtime
detection.
This feature provides enhanced protection against leaking
executable memory contents. This helps thwart attacks which are
attempting to find ROP gadgets on the fly.
But, the security provided by this approach is not comprehensive.
The PKRU register which controls access permissions is a normal
user register writable from unprivileged userspace. An attacker
who can execute the 'wrpkru' instruction can easily disable the
protection provided by this feature.
The protection key that is used for execute-only support is
permanently dedicated at compile time. This is fine for now
because there is currently no API to set a protection key other
than this one.
Despite there being a constant PKRU value across the entire
system, we do not set it unless this feature is in use in a
process. That is to preserve the PKRU XSAVE 'init state',
which can lead to faster context switches.
PKRU *is* a user register and the kernel is modifying it. That
means that code doing:
pkru = rdpkru()
pkru |= 0x100;
wrpkru(pkru);
could lose the bits in PKRU that enforce execute-only
permissions. To avoid this, we suggest avoiding ever calling
mmap() or mprotect() when the PKRU value is expected to be
unstable.
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Cc: Borislav Petkov <bp@suse.de>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Chen Gang <gang.chen.5i5j@gmail.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Dave Hansen <dave@sr71.net>
Cc: David Hildenbrand <dahi@linux.vnet.ibm.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Piotr Kwapulinski <kwapulinski.piotr@gmail.com>
Cc: Stephen Smalley <sds@tycho.nsa.gov>
Cc: Vladimir Murzin <vladimir.murzin@arm.com>
Cc: keescook@google.com
Cc: linux-mm@kvack.org
Link: http://lkml.kernel.org/r/20160212210240.CB4BB5CA@viggo.jf.intel.com
This plumbs a protection key through calc_vm_flag_bits(). We
could have done this in calc_vm_prot_bits(), but I did not feel
super strongly which way to go. It was pretty arbitrary which
one to use.
Cc: Arve Hjønnevåg <arve@android.com>
Cc: David Airlie <airlied@linux.ie>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Geliang Tang <geliangtang@163.com>
Cc: Leon Romanovsky <leon@leon.nu>
Cc: Maxime Coquelin <mcoquelin.stm32@gmail.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Riley Andrews <riandrews@android.com>
Cc: Vladimir Davydov <vdavydov@virtuozzo.com>
Cc: devel@driverdev.osuosl.org
Cc: linux-api@vger.kernel.org
Cc: linuxppc-dev@lists.ozlabs.org
Link: http://lkml.kernel.org/r/20160212210231.E6F1F0D6@viggo.jf.intel.com
Provide a stable basis for the pkeys patches, which touches various
x86 details.
Sequence vma_lock_anon_vma() - vma_unlock_anon_vma() isn't safe if
anon_vma appeared between lock and unlock. We have to check anon_vma
first or call anon_vma_prepare() to be sure that it's here. There are
only few users of these legacy helpers. Let's get rid of them.
This patch fixes anon_vma lock imbalance in validate_mm(). Write lock
isn't required here, read lock is enough.
And reorders expand_downwards/expand_upwards: security_mmap_addr() and
wrapping-around check don't have to be under anon vma lock.
Link: https://lkml.kernel.org/r/CACT4Y+Y908EjM2z=706dv4rV6dWtxTLK9nFg9_7DhRMLppBo2g@mail.gmail.com
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
The mmap_sem for reading in validate_mm called from expand_stack is not
enough to prevent the argumented rbtree rb_subtree_gap information to
change from under us because expand_stack may be running from other
threads concurrently which will hold the mmap_sem for reading too.
The argumented rbtree is updated with vma_gap_update under the
page_table_lock so use it in browse_rb() too to avoid false positives.
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Tested-by: Dmitry Vyukov <dvyukov@google.com>
This patch provides a way of working around a slight regression
introduced by commit 84638335900f ("mm: rework virtual memory
accounting").
Before that commit RLIMIT_DATA have control only over size of the brk
region. But that change have caused problems with all existing versions
of valgrind, because it set RLIMIT_DATA to zero.
This patch fixes rlimit check (limit actually in bytes, not pages) and
by default turns it into warning which prints at first VmData misuse:
"mmap: top (795): VmData 516096 exceed data ulimit 512000. Will be forbidden soon."
Behavior is controlled by boot param ignore_rlimit_data=y/n and by sysfs
/sys/module/kernel/parameters/ignore_rlimit_data. For now it set to "y".
[akpm@linux-foundation.org: tweak kernel-parameters.txt text[
Link: http://lkml.kernel.org/r/20151228211015.GL2194@uranus
Reported-by: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: Cyrill Gorcunov <gorcunov@gmail.com>
Cc: Vegard Nossum <vegard.nossum@oracle.com>
Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com>
Cc: Kees Cook <keescook@google.com>
Cc: Willy Tarreau <w@1wt.eu>
Cc: Pavel Emelyanov <xemul@virtuozzo.com>
changes
Dmitry Vyukov has reported[1] possible deadlock (triggered by his
syzkaller fuzzer):
Possible unsafe locking scenario:
CPU0 CPU1
lock(&hugetlbfs_i_mmap_rwsem_key);
lock(&mapping->i_mmap_rwsem);
Both traces points to mm_take_all_locks() as a source of the problem.
It doesn't take care about ordering or hugetlbfs_i_mmap_rwsem_key (aka
mapping->i_mmap_rwsem for hugetlb mapping) vs. i_mmap_rwsem.
huge_pmd_share() does memory allocation under hugetlbfs_i_mmap_rwsem_key
and allocator can take i_mmap_rwsem if it hit reclaim. So we need to
take i_mmap_rwsem from all hugetlb VMAs before taking i_mmap_rwsem from
rest of VMAs.
The patch also documents locking order for hugetlbfs_i_mmap_rwsem_key.
[1] http://lkml.kernel.org/r/CACT4Y+Zu95tBs-0EvdiAKzUOsb4tczRRfCRTpLr4bg_OP9HuVg@mail.gmail.com
Reviewed-by: Michal Hocko <mhocko@suse.com>
When inspecting a vague code inside prctl(PR_SET_MM_MEM) call (which
testing the RLIMIT_DATA value to figure out if we're allowed to assign
new @start_brk, @brk, @start_data, @end_data from mm_struct) it's been
commited that RLIMIT_DATA in a form it's implemented now doesn't do
anything useful because most of user-space libraries use mmap() syscall
for dynamic memory allocations.
Linus suggested to convert RLIMIT_DATA rlimit into something suitable
for anonymous memory accounting. But in this patch we go further, and
the changes are bundled together as:
* keep vma counting if CONFIG_PROC_FS=n, will be used for limits
* replace mm->shared_vm with better defined mm->data_vm
* account anonymous executable areas as executable
* account file-backed growsdown/up areas as stack
* drop struct file* argument from vm_stat_account
* enforce RLIMIT_DATA for size of data areas
This way code looks cleaner: now code/stack/data classification depends
only on vm_flags state:
VM_EXEC & ~VM_WRITE -> code (VmExe + VmLib in proc)
VM_GROWSUP | VM_GROWSDOWN -> stack (VmStk)
VM_WRITE & ~VM_SHARED & !stack -> data (VmData)
The rest (VmSize - VmData - VmStk - VmExe - VmLib) could be called
"shared", but that might be strange beast like readonly-private or VM_IO
area.
- RLIMIT_AS limits whole address space "VmSize"
- RLIMIT_STACK limits stack "VmStk" (but each vma individually)
- RLIMIT_DATA now limits "VmData"
Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org>
Address Space Layout Randomization (ASLR) provides a barrier to
exploitation of user-space processes in the presence of security
vulnerabilities by making it more difficult to find desired code/data
which could help an attack. This is done by adding a random offset to
the location of regions in the process address space, with a greater
range of potential offset values corresponding to better protection/a
larger search-space for brute force, but also to greater potential for
fragmentation.
The offset added to the mmap_base address, which provides the basis for
the majority of the mappings for a process, is set once on process exec
in arch_pick_mmap_layout() and is done via hard-coded per-arch values,
which reflect, hopefully, the best compromise for all systems. The
trade-off between increased entropy in the offset value generation and
the corresponding increased variability in address space fragmentation
is not absolute, however, and some platforms may tolerate higher amounts
of entropy. This patch introduces both new Kconfig values and a sysctl
interface which may be used to change the amount of entropy used for
offset generation on a system.
The direct motivation for this change was in response to the
libstagefright vulnerabilities that affected Android, specifically to
information provided by Google's project zero at:
http://googleprojectzero.blogspot.com/2015/09/stagefrightened.html
The attack presented therein, by Google's project zero, specifically
targeted the limited randomness used to generate the offset added to the
mmap_base address in order to craft a brute-force-based attack.
Concretely, the attack was against the mediaserver process, which was
limited to respawning every 5 seconds, on an arm device. The hard-coded
8 bits used resulted in an average expected success rate of defeating
the mmap ASLR after just over 10 minutes (128 tries at 5 seconds a
piece). With this patch, and an accompanying increase in the entropy
value to 16 bits, the same attack would take an average expected time of
over 45 hours (32768 tries), which makes it both less feasible and more
likely to be noticed.
The introduced Kconfig and sysctl options are limited by per-arch
minimum and maximum values, the minimum of which was chosen to match the
current hard-coded value and the maximum of which was chosen so as to
give the greatest flexibility without generating an invalid mmap_base
address, generally a 3-4 bits less than the number of bits in the
user-space accessible virtual address space.
When decided whether or not to change the default value, a system
developer should consider that mmap_base address could be placed
anywhere up to 2^(value) bits away from the non-randomized location,
which would introduce variable-sized areas above and below the mmap_base
address such that the maximum vm_area_struct size may be reduced,
preventing very large allocations.
This patch (of 4):
ASLR only uses as few as 8 bits to generate the random offset for the
mmap base address on 32 bit architectures. This value was chosen to
prevent a poorly chosen value from dividing the address space in such a
way as to prevent large allocations. This may not be an issue on all
platforms. Allow the specification of a minimum number of bits so that
platforms desiring greater ASLR protection may determine where to place
the trade-off.
Signed-off-by: Daniel Cashman <dcashman@google.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Don Zickus <dzickus@redhat.com>
Cc: Heinrich Schuchardt <xypron.glpk@gmx.de>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Mark Salyzyn <salyzyn@android.com>
Cc: Jeff Vander Stoep <jeffv@google.com>
Cc: Nick Kralevich <nnk@google.com>
Cc: Hector Marco-Gisbert <hecmargi@upv.es>
The following flag comparison in mmap_region makes no sense:
if (!(vm_flags & MAP_FIXED))
return -ENOMEM;
The condition is always false and thus the above "return -ENOMEM" is
never executed. The vm_flags must not be compared with MAP_FIXED flag.
The vm_flags may only be compared with VM_* flags. MAP_FIXED has the
same value as VM_MAYREAD.
Hitting the rlimit is a slow path and find_vma_intersection should
realize that there is no overlapping VMA for !MAP_FIXED case pretty
quickly.
Signed-off-by: Piotr Kwapulinski <kwapulinski.piotr@gmail.com>
Cc: Chris Metcalf <cmetcalf@ezchip.com>
Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Simplify may_expand_vm().
[akpm@linux-foundation.org: further simplification, per Naoya Horiguchi]
Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com>
Requiring special mappings to give a list of struct pages is
inflexible: it prevents sane use of IO memory in a special
mapping, it's inefficient (it requires arch code to initialize a
list of struct pages, and it requires the mm core to walk the
entire list just to figure out how long it is), and it prevents
arch code from doing anything fancy when a special mapping fault
occurs.
Add a .fault method as an alternative to filling in a .pages
array.
Looks-OK-to: Andrew Morton <akpm@linux-foundation.org>
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Link: http://lkml.kernel.org/r/a26d1677c0bc7e774c33f469451a78ca31e9e6af.1451446564.git.luto@kernel.org
The cost of faulting in all memory to be locked can be very high when
working with large mappings. If only portions of the mapping will be used
this can incur a high penalty for locking.
For the example of a large file, this is the usage pattern for a large
statical language model (probably applies to other statical or graphical
models as well). For the security example, any application transacting in
data that cannot be swapped out (credit card data, medical records, etc).
This patch introduces the ability to request that pages are not
pre-faulted, but are placed on the unevictable LRU when they are finally
faulted in. The VM_LOCKONFAULT flag will be used together with VM_LOCKED
and has no effect when set without VM_LOCKED. Setting the VM_LOCKONFAULT
flag for a VMA will cause pages faulted into that VMA to be added to the
unevictable LRU when they are faulted or if they are already present, but
will not cause any missing pages to be faulted in.
Exposing this new lock state means that we cannot overload the meaning of
the FOLL_POPULATE flag any longer. Prior to this patch it was used to
mean that the VMA for a fault was locked. This means we need the new
FOLL_MLOCK flag to communicate the locked state of a VMA. FOLL_POPULATE
will now only control if the VMA should be populated and in the case of
VM_LOCKONFAULT, it will not be set.
Signed-off-by: Eric B Munson <emunson@akamai.com>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: Shuah Khan <shuahkh@osg.samsung.com>
Make __install_special_mapping() args order match the caller, so the
caller can pass their register args directly to callee with no touch.
For most of architectures, args (at least the first 5th args) are in
registers, so this change will have effect on most of architectures.
For -O2, __install_special_mapping() may be inlined under most of
architectures, but for -Os, it should not. So this change can get a
little better performance for -Os, at least.
When fget() fails we can return -EBADF directly.
Acked-by: Oleg Nesterov <oleg@redhat.com>
It is still a little better to remove it, although it should be skipped
by "-O2".
Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com>=0A=
Cosmetic, but expand_upwards() and expand_downwards() overuse vma->vm_mm,
a local variable makes sense imho.
Cc: Andrey Konovalov <andreyknvl@google.com>
Cc: Davidlohr Bueso <dave@stgolabs.net>
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
Cc: Sasha Levin <sasha.levin@oracle.com>
"mm->locked_vm += grow" and vm_stat_account() in acct_stack_growth() are
not safe; multiple threads using the same ->mm can do this at the same
time trying to expans different vma's under down_read(mmap_sem). This
means that one of the "locked_vm += grow" changes can be lost and we can
miss munlock_vma_pages_all() later.
Move this code into the caller(s) under mm->page_table_lock. All other
updates to ->locked_vm hold mmap_sem for writing.
linux/mm.h provides offset_in_page() macro. Let's use already predefined
macro instead of (addr & ~PAGE_MASK).
Signed-off-by: Alexander Kuleshov <kuleshovmail@gmail.com>
Before the main loop, vma is already is NULL. There is no need to set it
to NULL again.
Reviewed-by: Oleg Nesterov <oleg@redhat.com>
Acked-by: David Rientjes <rientjes@google.com>
For VM_PFNMAP and VM_MIXEDMAP we use vm_ops->pfn_mkwrite instead of
vm_ops->page_mkwrite to notify abort write access. This means we want
vma->vm_page_prot to be write-protected if the VMA provides this vm_ops.
A theoretical scenario that will cause these missed events is:
On writable mapping with vm_ops->pfn_mkwrite, but without
vm_ops->page_mkwrite: read fault followed by write access to the pfn.
Writable pte will be set up on read fault and write fault will not be
generated.
I found it examining Dave's complaint on generic/080:
http://lkml.kernel.org/g/20150831233803.GO3902@dastard
Although I don't think it's the reason.
It shouldn't be a problem for ext2/ext4 as they provide both pfn_mkwrite
and page_mkwrite.
[akpm@linux-foundation.org: add local vm_ops to avoid 80-cols mess]
Cc: Yigal Korman <yigal@plexistor.com>
Acked-by: Boaz Harrosh <boaz@plexistor.com>
Cc: Matthew Wilcox <matthew.r.wilcox@intel.com>
Cc: Jan Kara <jack@suse.cz>
Revert commit 6dc296e7df4c "mm: make sure all file VMAs have ->vm_ops
set".
Will Deacon reports that it "causes some mmap regressions in LTP, which
appears to use a MAP_PRIVATE mmap of /dev/zero as a way to get anonymous
pages in some of its tests (specifically mmap10 [1])".
William Shuman reports Oracle crashes.
So revert the patch while we work out what to do.
Reported-by: William Shuman <wshuman3@gmail.com>
Reported-by: Will Deacon <will.deacon@arm.com>
We rely on vma->vm_ops == NULL to detect anonymous VMA: see
vma_is_anonymous(), but some drivers doesn't set ->vm_ops.
As a result we can end up with anonymous page in private file mapping.
That should not lead to serious misbehaviour, but nevertheless is wrong.
Let's fix by setting up dummy ->vm_ops for file mmapping if f_op->mmap()
didn't set its own.
The patch also adds sanity check into __vma_link_rb(). It will help
catch broken VMAs which inserted directly into mm_struct via
insert_vm_struct().
Cc: Minchan Kim <minchan@kernel.org>
Add the additional "vm_flags_t vm_flags" argument to do_mmap_pgoff(),
rename it to do_mmap(), and re-introduce do_mmap_pgoff() as a simple
wrapper on top of do_mmap(). Perhaps we should update the callers of
do_mmap_pgoff() and kill it later.
This way mpx_mmap() can simply call do_mmap(vm_flags => VM_MPX) and do not
play with vm internals.
After this change mmap_region() has a single user outside of mmap.c,
arch/tile/mm/elf.c:arch_setup_additional_pages(). It would be nice to
change arch/tile/ and unexport mmap_region().
[kirill@shutemov.name: fix build]
Acked-by: Dave Hansen <dave.hansen@linux.intel.com>
Tested-by: Dave Hansen <dave.hansen@linux.intel.com>
There's no point in initializing vma->vm_pgoff if the insertion attempt
will be failing anyway. Run the checks before performing the
initialization.
Cc: Michal Hocko <mhocko@kernel.org>
__split_vma() doesn't need out_err label, neither need initializing err.
copy_vma() can return NULL directly when kmem_cache_alloc() fails.
Test-case:
#define _GNU_SOURCE
#include <stdio.h>
#include <unistd.h>
#include <stdlib.h>
#include <string.h>
#include <assert.h>
void *find_vdso_vaddr(void)
FILE *perl;
char buf[32] = {};
perl = popen("perl -e 'open STDIN,qq|/proc/@{[getppid]}/maps|;"
"/^(.*?)-.*vdso/ && print hex $1 while <>'", "r");
fread(buf, sizeof(buf), 1, perl);
fclose(perl);
return (void *)atol(buf);
#define PAGE_SIZE 4096
void *get_unmapped_area(void)
void *p = mmap(0, PAGE_SIZE, PROT_NONE,
MAP_PRIVATE|MAP_ANONYMOUS, -1,0);
assert(p != MAP_FAILED);
munmap(p, PAGE_SIZE);
return p;
char save[2][PAGE_SIZE];
int main(void)
void *vdso = find_vdso_vaddr();
void *page[2];
assert(vdso);
memcpy(save, vdso, sizeof (save));
// force another fault on the next check
assert(madvise(vdso, 2 * PAGE_SIZE, MADV_DONTNEED) == 0);
page[0] = mremap(vdso,
PAGE_SIZE, PAGE_SIZE, MREMAP_FIXED | MREMAP_MAYMOVE,
get_unmapped_area());
page[1] = mremap(vdso + PAGE_SIZE,
assert(page[0] != MAP_FAILED && page[1] != MAP_FAILED);
printf("match: %d %d\n",
!memcmp(save[0], page[0], PAGE_SIZE),
!memcmp(save[1], page[1], PAGE_SIZE));
return 0;
fails without this patch. Before the previous commit it gets the wrong
page, now it segfaults (which is imho better).
This is because copy_vma() wrongly assumes that if vma->vm_file == NULL
is irrelevant until the first fault which will use do_anonymous_page().
This is obviously wrong for the special mapping.
Cc: Pavel Emelyanov <xemul@parallels.com>
Test-case:
#include <stdio.h>
#include <unistd.h>
#include <stdlib.h>
#include <string.h>
#include <assert.h>
FILE *perl;
char buf[32] = {};
fclose(perl);
int main(void)
assert(vdso);
// of course they should differ, and they do so far
printf("vdso pages differ: %d\n",
!!memcmp(vdso, vdso + PAGE_SIZE, PAGE_SIZE));
// split into 2 vma's
assert(mprotect(vdso, PAGE_SIZE, PROT_READ) == 0);
// now they no longer differ, the 2nd vm_pgoff is wrong
return 0;
Output:
vdso pages differ: 1
vdso pages differ: 0
This is because split_vma() correctly updates ->vm_pgoff, but the logic
in insert_vm_struct() and special_mapping_fault() is absolutely broken,
so the fault at vdso + PAGE_SIZE return the 1st page. The same happens
if you simply unmap the 1st page.
special_mapping_fault() does:
pgoff = vmf->pgoff - vma->vm_pgoff;
and this is _only_ correct if vma->vm_start mmaps the first page from
->vm_private_data array.
vdso or any other user of install_special_mapping() is not anonymous,
it has the "backing storage" even if it is just the array of pages.
So we actually need to make vm_pgoff work as an offset in this array.
Note: this also allows to fix another problem: currently gdb can't access
"[vvar]" memory because in this case special_mapping_fault() doesn't work.
Now that we can use ->vm_pgoff we can implement ->access() and fix this.
vma->vm_userfaultfd_ctx is yet another vma parameter that vma_merge
must be aware about so that we can merge vmas back like they were
originally before arming the userfaultfd on some memory range.
Acked-by: Pavel Emelyanov <xemul@parallels.com>
Cc: Sanidhya Kashyap <sanidhya.gatech@gmail.com>
Cc: zhang.zhanghailiang@huawei.com
Cc: Andres Lagar-Cavilla <andreslc@google.com>
Cc: Peter Feiner <pfeiner@google.com>
Cc: "Dr. David Alan Gilbert" <dgilbert@redhat.com>
Cc: "Huangpeng (Peter)" <peter.huangpeng@huawei.com>
Today proc and sysfs do not contain any executable files. Several
applications today mount proc or sysfs without noexec and nosuid and
then depend on there being no exectuables files on proc or sysfs.
Having any executable files show on proc or sysfs would cause
a user space visible regression, and most likely security problems.
Therefore commit to never allowing executables on proc and sysfs by
adding a new flag to mark them as filesystems without executables and
enforce that flag.
Test the flag where MNT_NOEXEC is tested today, so that the only user
visible effect will be that exectuables will be treated as if the
execute bit is cleared.
The filesystems proc and sysfs do not currently incoporate any
executable files so this does not result in any user visible effects.
This makes it unnecessary to vet changes to proc and sysfs tightly for
adding exectuable files or changes to chattr that would modify
existing files, as no matter what the individual file say they will
not be treated as exectuable files by the vfs.
Not having to vet changes to closely is important as without this we
are only one proc_create call (or another goof up in the
implementation of notify_change) from having problematic executables
on proc. Those mistakes are all too easy to make and would create
a situation where there are security issues or the assumptions of
some program having to be broken (and cause userspace regressions).
The simple check for zero length memory mapping may be performed
earlier. So that in case of zero length memory mapping some unnecessary
code is not executed at all. It does not make the code less readable
and saves some CPU cycles.
Acked-by: Michal Hocko <mhocko@suse.cz>
The creators of the C language gave us the while keyword. Let's use
that instead of synthesizing it from if+goto.
Made possible by 6597d783397a ("mm/mmap.c: replace find_vma_prepare()
with clearer find_vma_links()").
[akpm@linux-foundation.org: fix 80-col overflows]
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Cc: Roman Gushchin <klamm@yandex-team.ru>
We converted some of the usages of ACCESS_ONCE to READ_ONCE in the mm/
tree since it doesn't work reliably on non-scalar types.
This patch removes the rest of the usages of ACCESS_ONCE, and use the new
READ_ONCE API for the read accesses. This makes things cleaner, instead
of using separate/multiple sets of APIs.
Signed-off-by: Jason Low <jason.low2@hp.com>
Acked-by: Davidlohr Bueso <dave@stgolabs.net>
Reviewed-by: Christian Borntraeger <borntraeger@de.ibm.com>
__mlock_vma_pages_range() doesn't necessarily mlock pages. It depends on
vma flags. The same codepath is used for MAP_POPULATE.
Let's rename __mlock_vma_pages_range() to populate_vma_page_range().
This patch also drops mlock_vma_pages_range() references from
documentation. It has gone in cea10a19b797 ("mm: directly use
__mlock_vma_pages_range() in find_extend_vma()").
Cc: Michel Lespinasse <walken@google.com>
I have constantly stumbled upon "kernel BUG at mm/rmap.c:399!" after
upgrading to 3.19 and had no luck with 4.0-rc1 neither.
So, after looking into new logic introduced by commit 7a3ef208e662 ("mm:
prevent endless growth of anon_vma hierarchy"), I found chances are that
unlink_anon_vmas() is called without incrementing dst->anon_vma->degree
in anon_vma_clone() due to allocation failure. If dst->anon_vma is not
NULL in error path, its degree will be incorrectly decremented in
unlink_anon_vmas() and eventually underflow when exiting as a result of
another call to unlink_anon_vmas(). That's how "kernel BUG at
mm/rmap.c:399!" is triggered for me.
This patch fixes the underflow by dropping dst->anon_vma when allocation
fails. It's safe to do so regardless of original value of dst->anon_vma
because dst->anon_vma doesn't have valid meaning if anon_vma_clone()
fails. Besides, callers don't care dst->anon_vma in such case neither.
Also suggested by Michal Hocko, we can clean up vma_adjust() a bit as
anon_vma_clone() now does the work.
[akpm@linux-foundation.org: tweak comment]
Fixes: 7a3ef208e662 ("mm: prevent endless growth of anon_vma hierarchy")
Signed-off-by: Leon Yu <chianglungyu@gmail.com>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
I noticed, that "allowed" can easily overflow by falling below 0,
because (total_vm / 32) can be larger than "allowed". The problem
occurs in OVERCOMMIT_NONE mode.
In this case, a huge allocation can success and overcommit the system
(despite OVERCOMMIT_NONE mode). All subsequent allocations will fall
(system-wide), so system become unusable.
The problem was masked out by commit c9b1d0981fcc
("mm: limit growth of 3% hardcoded other user reserve"),
but it's easy to reproduce it on older kernels:
1) set overcommit_memory sysctl to 2
2) mmap() large file multiple times (with VM_SHARED flag)
3) try to malloc() large amount of memory
It also can be reproduced on newer kernels, but miss-configured
sysctl_user_reserve_kbytes is required.
Fix this issue by switching to signed arithmetic here.
[akpm@linux-foundation.org: use min_t]
Signed-off-by: Roman Gushchin <klamm@yandex-team.ru>
Cc: Andrew Shewmaker <agshew@gmail.com>
Cc: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
The problem is that we check nr_ptes/nr_pmds in exit_mmap() which happens
*before* pgd_free(). And if an arch does pte/pmd allocation in
pgd_alloc() and frees them in pgd_free() we see offset in counters by the
time of the checks.
We tried to workaround this by offsetting expected counter value according
to FIRST_USER_ADDRESS for both nr_pte and nr_pmd in exit_mmap(). But it
doesn't work in some cases:
1. ARM with LPAE enabled also has non-zero USER_PGTABLES_CEILING, but
upper addresses occupied with huge pmd entries, so the trick with
offsetting expected counter value will get really ugly: we will have
to apply it nr_pmds, but not nr_ptes.
2. Metag has non-zero FIRST_USER_ADDRESS, but doesn't do allocation
pte/pmd page tables allocation in pgd_alloc(), just setup a pgd entry
which is allocated at boot and shared accross all processes.
The proposal is to move the check to check_mm() which happens *after*
pgd_free() and do proper accounting during pgd_alloc() and pgd_free()
which would bring counters to zero if nothing leaked.
Reported-by: Tyler Baker <tyler.baker@linaro.org>
Tested-by: Tyler Baker <tyler.baker@linaro.org>
Tested-by: Nishanth Menon <nm@ti.com>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
