path: root/mm/mprotect.c
2007-10-23fix mprotect vma_wants_writenotify protHugh Dickins
Fix mprotect bug in recent commit 3ed75eb8f1cd89565966599c4f77d2edb086d5b0 (setup vma->vm_page_prot by vm_get_page_prot()): the vma_wants_writenotify case was setting the same prot as when not. Nothing wrong with the use of protection_map[] in mmap_region(), but use vm_get_page_prot() there too in the same ~VM_SHARED way. Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: Coly Li <coyli@suse.de> Cc: Tony Luck <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19setup vma->vm_page_prot by vm_get_page_prot()Coly Li
This patch uses vm_get_page_prot() to setup vma->vm_page_prot. Though inside vm_get_page_prot() the protection flags is AND with (VM_READ|VM_WRITE|VM_EXEC|VM_SHARED), it does not hurt correct code. Signed-off-by: Coly Li <coyli@suse.de> Cc: Hugh Dickins <hugh@veritas.com> Cc: Tony Luck <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16flush icache before set_pte() on ia64: flush icache at set_pteKAMEZAWA Hiroyuki
Current ia64 kernel flushes icache by lazy_mmu_prot_update() *after* set_pte(). This is too late. This patch removes lazy_mmu_prot_update and add modfied set_pte() for flushing if necessary. This patch flush icache of a page when new pte has exec bit. && new pte has present bit && new pte is user's page. && (old *ptep is not present || new pte's pfn is not same to old *ptep's ptn) && new pte's page has no Pg_arch_1 bit. Pg_arch_1 is set when a page is cache consistent. I think this condition checks are much easier to understand than considering "Where sync_icache_dcache() should be inserted ?". pte_user() for ia64 was removed by http://lkml.org/lkml/2007/6/12/67 as clean-up. So, I added it again. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19mm: variable length argument supportOllie Wild
Remove the arg+env limit of MAX_ARG_PAGES by copying the strings directly from the old mm into the new mm. We create the new mm before the binfmt code runs, and place the new stack at the very top of the address space. Once the binfmt code runs and figures out where the stack should be, we move it downwards. It is a bit peculiar in that we have one task with two mm's, one of which is inactive. [a.p.zijlstra@chello.nl: limit stack size] Signed-off-by: Ollie Wild <aaw@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: <linux-arch@vger.kernel.org> Cc: Hugh Dickins <hugh@veritas.com> [bunk@stusta.de: unexport bprm_mm_init] Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-01[PATCH] paravirt: lazy mmu mode hooks.patchZachary Amsden
Implement lazy MMU update hooks which are SMP safe for both direct and shadow page tables. The idea is that PTE updates and page invalidations while in lazy mode can be batched into a single hypercall. We use this in VMI for shadow page table synchronization, and it is a win. It also can be used by PPC and for direct page tables on Xen. For SMP, the enter / leave must happen under protection of the page table locks for page tables which are being modified. This is because otherwise, you end up with stale state in the batched hypercall, which other CPUs can race ahead of. Doing this under the protection of the locks guarantees the synchronization is correct, and also means that spurious faults which are generated during this window by remote CPUs are properly handled, as the page fault handler must re-check the PTE under protection of the same lock. Signed-off-by: Zachary Amsden <zach@vmware.com> Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] mm: optimize the new mprotect() code a bitPeter Zijlstra
mprotect() resets the page protections, which could result in extra write faults for those pages whose dirty state we track using write faults and are dirty already. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] mm: tracking shared dirty pagesPeter Zijlstra
Tracking of dirty pages in shared writeable mmap()s. The idea is simple: write protect clean shared writeable pages, catch the write-fault, make writeable and set dirty. On page write-back clean all the PTE dirty bits and write protect them once again. The implementation is a tad harder, mainly because the default backing_dev_info capabilities were too loosely maintained. Hence it is not enough to test the backing_dev_info for cap_account_dirty. The current heuristic is as follows, a VMA is eligible when: - its shared writeable (vm_flags & (VM_WRITE|VM_SHARED)) == (VM_WRITE|VM_SHARED) - it is not a 'special' mapping (vm_flags & (VM_PFNMAP|VM_INSERTPAGE)) == 0 - the backing_dev_info is cap_account_dirty mapping_cap_account_dirty(vma->vm_file->f_mapping) - f_op->mmap() didn't change the default page protection Page from remap_pfn_range() are explicitly excluded because their COW semantics are already horrid enough (see vm_normal_page() in do_wp_page()) and because they don't have a backing store anyway. mprotect() is taught about the new behaviour as well. However it overrides the last condition. Cleaning the pages on write-back is done with page_mkclean() a new rmap call. It can be called on any page, but is currently only implemented for mapped pages, if the page is found the be of a VMA that accounts dirty pages it will also wrprotect the PTE. Finally, in fs/buffers.c:try_to_free_buffers(); remove clear_page_dirty() from under ->private_lock. This seems to be safe, since ->private_lock is used to serialize access to the buffers, not the page itself. This is needed because clear_page_dirty() will call into page_mkclean() and would thereby violate locking order. [dhowells@redhat.com: Provide a page_mkclean() implementation for NOMMU] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] add page_mkwrite() vm_operations methodDavid Howells
Add a new VMA operation to notify a filesystem or other driver about the MMU generating a fault because userspace attempted to write to a page mapped through a read-only PTE. This facility permits the filesystem or driver to: (*) Implement storage allocation/reservation on attempted write, and so to deal with problems such as ENOSPC more gracefully (perhaps by generating SIGBUS). (*) Delay making the page writable until the contents have been written to a backing cache. This is useful for NFS/AFS when using FS-Cache/CacheFS. It permits the filesystem to have some guarantee about the state of the cache. (*) Account and limit number of dirty pages. This is one piece of the puzzle needed to make shared writable mapping work safely in FUSE. Needed by cachefs (Or is it cachefiles? Or fscache? <head spins>). At least four other groups have stated an interest in it or a desire to use the functionality it provides: FUSE, OCFS2, NTFS and JFFS2. Also, things like EXT3 really ought to use it to deal with the case of shared-writable mmap encountering ENOSPC before we permit the page to be dirtied. From: Peter Zijlstra <a.p.zijlstra@chello.nl> get_user_pages(.write=1, .force=1) can generate COW hits on read-only shared mappings, this patch traps those as mkpage_write candidates and fails to handle them the old way. Signed-off-by: David Howells <dhowells@redhat.com> Cc: Miklos Szeredi <miklos@szeredi.hu> Cc: Joel Becker <Joel.Becker@oracle.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] Swapless page migration: add R/W migration entriesChristoph Lameter
Implement read/write migration ptes We take the upper two swapfiles for the two types of migration ptes and define a series of macros in swapops.h. The VM is modified to handle the migration entries. migration entries can only be encountered when the page they are pointing to is locked. This limits the number of places one has to fix. We also check in copy_pte_range and in mprotect_pte_range() for migration ptes. We check for migration ptes in do_swap_cache and call a function that will then wait on the page lock. This allows us to effectively stop all accesses to apge. Migration entries are created by try_to_unmap if called for migration and removed by local functions in migrate.c From: Hugh Dickins <hugh@veritas.com> Several times while testing swapless page migration (I've no NUMA, just hacking it up to migrate recklessly while running load), I've hit the BUG_ON(!PageLocked(p)) in migration_entry_to_page. This comes from an orphaned migration entry, unrelated to the current correctly locked migration, but hit by remove_anon_migration_ptes as it checks an address in each vma of the anon_vma list. Such an orphan may be left behind if an earlier migration raced with fork: copy_one_pte can duplicate a migration entry from parent to child, after remove_anon_migration_ptes has checked the child vma, but before it has removed it from the parent vma. (If the process were later to fault on this orphaned entry, it would hit the same BUG from migration_entry_wait.) This could be fixed by locking anon_vma in copy_one_pte, but we'd rather not. There's no such problem with file pages, because vma_prio_tree_add adds child vma after parent vma, and the page table locking at each end is enough to serialize. Follow that example with anon_vma: add new vmas to the tail instead of the head. (There's no corresponding problem when inserting migration entries, because a missed pte will leave the page count and mapcount high, which is allowed for. And there's no corresponding problem when migrating via swap, because a leftover swap entry will be correctly faulted. But the swapless method has no refcounting of its entries.) From: Ingo Molnar <mingo@elte.hu> pte_unmap_unlock() takes the pte pointer as an argument. From: Hugh Dickins <hugh@veritas.com> Several times while testing swapless page migration, gcc has tried to exec a pointer instead of a string: smells like COW mappings are not being properly write-protected on fork. The protection in copy_one_pte looks very convincing, until at last you realize that the second arg to make_migration_entry is a boolean "write", and SWP_MIGRATION_READ is 30. Anyway, it's better done like in change_pte_range, using is_write_migration_entry and make_migration_entry_read. From: Hugh Dickins <hugh@veritas.com> Remove unnecessary obfuscation from sys_swapon's range check on swap type, which blew up causing memory corruption once swapless migration made MAX_SWAPFILES no longer 2 ^ MAX_SWAPFILES_SHIFT. Signed-off-by: Hugh Dickins <hugh@veritas.com> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Christoph Lameter <clameter@engr.sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> From: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] likely cleanup: remove unlikely in sys_mprotect()Hua Zhong
With likely/unlikely profiling on my not-so-busy-typical-developmentsystem there are 5k misses vs 2k hits. So I guess we should remove the unlikely. Signed-off-by: Hua Zhong <hzhong@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[PATCH] Enable mprotect on huge pagesZhang, Yanmin
2.6.16-rc3 uses hugetlb on-demand paging, but it doesn_t support hugetlb mprotect. From: David Gibson <david@gibson.dropbear.id.au> Remove a test from the mprotect() path which checks that the mprotect()ed range on a hugepage VMA is hugepage aligned (yes, really, the sense of is_aligned_hugepage_range() is the opposite of what you'd guess :-/). In fact, we don't need this test. If the given addresses match the beginning/end of a hugepage VMA they must already be suitably aligned. If they don't, then mprotect_fixup() will attempt to split the VMA. The very first test in split_vma() will check for a badly aligned address on a hugepage VMA and return -EINVAL if necessary. From: "Chen, Kenneth W" <kenneth.w.chen@intel.com> On i386 and x86-64, pte flag _PAGE_PSE collides with _PAGE_PROTNONE. The identify of hugetlb pte is lost when changing page protection via mprotect. A page fault occurs later will trigger a bug check in huge_pte_alloc(). The fix is to always make new pte a hugetlb pte and also to clean up legacy code where _PAGE_PRESENT is forced on in the pre-faulting day. Signed-off-by: Zhang Yanmin <yanmin.zhang@intel.com> Cc: David Gibson <david@gibson.dropbear.id.au> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: William Lee Irwin III <wli@holomorphy.com> Signed-off-by: Ken Chen <kenneth.w.chen@intel.com> Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-22[PATCH] unpaged: private write VM_RESERVEDHugh Dickins
The PageReserved removal in 2.6.15-rc1 issued a "deprecated" message when you tried to mmap or mprotect MAP_PRIVATE PROT_WRITE a VM_RESERVED, and failed with -EACCES: because do_wp_page lacks the refinement to COW pages in those areas, nor do we expect to find anonymous pages in them; and it seemed just bloat to add code for handling such a peculiar case. But immediately it caused vbetool and ddcprobe (using lrmi) to fail. So revert the "deprecated" messages, letting mmap and mprotect succeed. But leave do_wp_page's BUG_ON(vma->vm_flags & VM_RESERVED) in place until we've added the code to do it right: so this particular patch is only good if the app doesn't really need to write to that private area. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] mm: pte_offset_map_lock loopsHugh Dickins
Convert those common loops using page_table_lock on the outside and pte_offset_map within to use just pte_offset_map_lock within instead. These all hold mmap_sem (some exclusively, some not), so at no level can a page table be whipped away from beneath them. But whereas pte_alloc loops tested with the "atomic" pmd_present, these loops are testing with pmd_none, which on i386 PAE tests both lower and upper halves. That's now unsafe, so add a cast into pmd_none to test only the vital lower half: we lose a little sensitivity to a corrupt middle directory, but not enough to worry about. It appears that i386 and UML were the only architectures vulnerable in this way, and pgd and pud no problem. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] core remove PageReservedNick Piggin
Remove PageReserved() calls from core code by tightening VM_RESERVED handling in mm/ to cover PageReserved functionality. PageReserved special casing is removed from get_page and put_page. All setting and clearing of PageReserved is retained, and it is now flagged in the page_alloc checks to help ensure we don't introduce any refcount based freeing of Reserved pages. MAP_PRIVATE, PROT_WRITE of VM_RESERVED regions is tentatively being deprecated. We never completely handled it correctly anyway, and is be reintroduced in future if required (Hugh has a proof of concept). Once PageReserved() calls are removed from kernel/power/swsusp.c, and all arch/ and driver code, the Set and Clear calls, and the PG_reserved bit can be trivially removed. Last real user of PageReserved is swsusp, which uses PageReserved to determine whether a struct page points to valid memory or not. This still needs to be addressed (a generic page_is_ram() should work). A last caveat: the ZERO_PAGE is now refcounted and managed with rmap (and thus mapcounted and count towards shared rss). These writes to the struct page could cause excessive cacheline bouncing on big systems. There are a number of ways this could be addressed if it is an issue. Signed-off-by: Nick Piggin <npiggin@suse.de> Refcount bug fix for filemap_xip.c Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] mm: vm_stat_account unshackledHugh Dickins
The original vm_stat_account has fallen into disuse, with only one user, and only one user of vm_stat_unaccount. It's easier to keep track if we convert them all to __vm_stat_account, then free it from its __shackles. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-21[PATCH] mm: add a note about partially hardcoded VM_* flagsPaolo 'Blaisorblade' Giarrusso
Hugh made me note this line for permission checking in mprotect(): if ((newflags & ~(newflags >> 4)) & 0xf) { after figuring out what's that about, I decided it's nasty enough. Btw Hugh itself didn't like the 0xf. We can safely change it to VM_READ|VM_WRITE|VM_EXEC because we never change VM_SHARED, so no need to check that. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Acked-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
