path: root/mm/nobootmem.c
2012-07-11memblock: free allocated memblock_reserved_regions laterYinghai Lu
memblock_free_reserved_regions() calls memblock_free(), but memblock_free() would double reserved.regions too, so we could free the old range for reserved.regions. Also tj said there is another bug which could be related to this. | I don't think we're saving any noticeable | amount by doing this "free - give it to page allocator - reserve | again" dancing. We should just allocate regions aligned to page | boundaries and free them later when memblock is no longer in use. in that case, when DEBUG_PAGEALLOC, will get panic: memblock_free: [0x0000102febc080-0x0000102febf080] memblock_free_reserved_regions+0x37/0x39 BUG: unable to handle kernel paging request at ffff88102febd948 IP: [<ffffffff836a5774>] __next_free_mem_range+0x9b/0x155 PGD 4826063 PUD cf67a067 PMD cf7fa067 PTE 800000102febd160 Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC CPU 0 Pid: 0, comm: swapper Not tainted 3.5.0-rc2-next-20120614-sasha #447 RIP: 0010:[<ffffffff836a5774>] [<ffffffff836a5774>] __next_free_mem_range+0x9b/0x155 See the discussion at https://lkml.org/lkml/2012/6/13/469 So try to allocate with PAGE_SIZE alignment and free it later. Reported-by: Sasha Levin <levinsasha928@gmail.com> Acked-by: Tejun Heo <tj@kernel.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-11mm: sparse: fix usemap allocation above node descriptor sectionYinghai Lu
After commit f5bf18fa22f8 ("bootmem/sparsemem: remove limit constraint in alloc_bootmem_section"), usemap allocations may easily be placed outside the optimal section that holds the node descriptor, even if there is space available in that section. This results in unnecessary hotplug dependencies that need to have the node unplugged before the section holding the usemap. The reason is that the bootmem allocator doesn't guarantee a linear search starting from the passed allocation goal but may start out at a much higher address absent an upper limit. Fix this by trying the allocation with the limit at the section end, then retry without if that fails. This keeps the fix from f5bf18fa22f8 of not panicking if the allocation does not fit in the section, but still makes sure to try to stay within the section at first. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: <stable@vger.kernel.org> [3.3.x, 3.4.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29mm: remove sparsemem allocation details from the bootmem allocatorJohannes Weiner
alloc_bootmem_section() derives allocation area constraints from the specified sparsemem section. This is a bit specific for a generic memory allocator like bootmem, though, so move it over to sparsemem. As __alloc_bootmem_node_nopanic() already retries failed allocations with relaxed area constraints, the fallback code in sparsemem.c can be removed and the code becomes a bit more compact overall. [akpm@linux-foundation.org: fix build] Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Tejun Heo <tj@kernel.org> Acked-by: David S. Miller <davem@davemloft.net> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Gavin Shan <shangw@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29mm: nobootmem: unify allocation policy of (non-)panicking node allocationsJohannes Weiner
While the panicking node-specific allocation function tries to satisfy node+goal, goal, node, anywhere, the non-panicking function still does node+goal, goal, anywhere. Make it simpler: define the panicking version in terms of the non-panicking one, like the node-agnostic interface, so they always behave the same way apart from how to deal with allocation failure. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Yinghai Lu <yinghai@kernel.org> Acked-by: Tejun Heo <tj@kernel.org> Acked-by: David S. Miller <davem@davemloft.net> Cc: Gavin Shan <shangw@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29mm: nobootmem: panic on node-specific allocation failureJohannes Weiner
__alloc_bootmem_node and __alloc_bootmem_low_node documentation claims the functions panic on allocation failure. Do it. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Yinghai Lu <yinghai@kernel.org> Acked-by: Tejun Heo <tj@kernel.org> Acked-by: David S. Miller <davem@davemloft.net> Cc: Gavin Shan <shangw@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-10mm: nobootmem: fix sign extend problem in __free_pages_memory()Russ Anderson
Systems with 8 TBytes of memory or greater can hit a problem where only the the first 8 TB of memory shows up. This is due to "int i" being smaller than "unsigned long start_aligned", causing the high bits to be dropped. The fix is to change `i' to unsigned long to match start_aligned and end_aligned. Thanks to Jack Steiner for assistance tracking this down. Signed-off-by: Russ Anderson <rja@sgi.com> Cc: Jack Steiner <steiner@sgi.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Tejun Heo <tj@kernel.org> Cc: David S. Miller <davem@davemloft.net> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Gavin Shan <shangw@linux.vnet.ibm.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-25mm: nobootmem: Correct alloc_bootmem semantics.David Miller
The comments above __alloc_bootmem_node() claim that the code will first try the allocation using 'goal' and if that fails it will try again but with the 'goal' requirement dropped. Unfortunately, this is not what the code does, so fix it to do so. This is important for nobootmem conversions to architectures such as sparc where MAX_DMA_ADDRESS is infinity. On such architectures all of the allocations done by generic spots, such as the sparse-vmemmap implementation, will pass in: __pa(MAX_DMA_ADDRESS) as the goal, and with the limit given as "-1" this will always fail unless we add the appropriate fallback logic here. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-28Merge branch 'master' into x86/memblockTejun Heo
Conflicts & resolutions: * arch/x86/xen/setup.c dc91c728fd "xen: allow extra memory to be in multiple regions" 24aa07882b "memblock, x86: Replace memblock_x86_reserve/free..." conflicted on xen_add_extra_mem() updates. The resolution is trivial as the latter just want to replace memblock_x86_reserve_range() with memblock_reserve(). * drivers/pci/intel-iommu.c 166e9278a3f "x86/ia64: intel-iommu: move to drivers/iommu/" 5dfe8660a3d "bootmem: Replace work_with_active_regions() with..." conflicted as the former moved the file under drivers/iommu/. Resolved by applying the chnages from the latter on the moved file. * mm/Kconfig 6661672053a "memblock: add NO_BOOTMEM config symbol" c378ddd53f9 "memblock, x86: Make ARCH_DISCARD_MEMBLOCK a config option" conflicted trivially. Both added config options. Just letting both add their own options resolves the conflict. * mm/memblock.c d1f0ece6cdc "mm/memblock.c: small function definition fixes" ed7b56a799c "memblock: Remove memblock_memory_can_coalesce()" confliected. The former updates function removed by the latter. Resolution is trivial. Signed-off-by: Tejun Heo <tj@kernel.org>
2011-10-31mm: Map most files to use export.h instead of module.hPaul Gortmaker
The files changed within are only using the EXPORT_SYMBOL macro variants. They are not using core modular infrastructure and hence don't need module.h but only the export.h header. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-07-14memblock, x86: Replace memblock_x86_reserve/free_range() with generic onesTejun Heo
Other than sanity check and debug message, the x86 specific version of memblock reserve/free functions are simple wrappers around the generic versions - memblock_reserve/free(). This patch adds debug messages with caller identification to the generic versions and replaces x86 specific ones and kills them. arch/x86/include/asm/memblock.h and arch/x86/mm/memblock.c are empty after this change and removed. Signed-off-by: Tejun Heo <tj@kernel.org> Link: http://lkml.kernel.org/r/1310462166-31469-14-git-send-email-tj@kernel.org Cc: Yinghai Lu <yinghai@kernel.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2011-07-14memblock, x86: Replace __get_free_all_memory_range() with ↵Tejun Heo
for_each_free_mem_range() __get_free_all_memory_range() walks memblock, calculates free memory areas and fills in the specified range. It can be easily replaced with for_each_free_mem_range(). Convert free_low_memory_core_early() and add_highpages_with_active_regions() to for_each_free_mem_range(). This leaves __get_free_all_memory_range() without any user. Kill it and related functions. Signed-off-by: Tejun Heo <tj@kernel.org> Link: http://lkml.kernel.org/r/1310462166-31469-10-git-send-email-tj@kernel.org Cc: Yinghai Lu <yinghai@kernel.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2011-07-14memblock, x86: Make free_all_memory_core_early() explicitly free lowmem onlyTejun Heo
nomemblock is currently used only by x86 and on x86_32 free_all_memory_core_early() silently freed only the low mem because get_free_all_memory_range() in arch/x86/mm/memblock.c implicitly limited range to max_low_pfn. Rename free_all_memory_core_early() to free_low_memory_core_early() and make it call __get_free_all_memory_range() and limit the range to max_low_pfn explicitly. This makes things clearer and also is consistent with the bootmem behavior. This leaves get_free_all_memory_range() without any user. Kill it. Signed-off-by: Tejun Heo <tj@kernel.org> Link: http://lkml.kernel.org/r/1310462166-31469-9-git-send-email-tj@kernel.org Cc: Yinghai Lu <yinghai@kernel.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2011-07-14memblock, x86: Replace memblock_x86_find_in_range_node() with generic ↵Tejun Heo
memblock calls With the previous changes, generic NUMA aware memblock API has feature parity with memblock_x86_find_in_range_node(). There currently are two users - x86 setup_node_data() and __alloc_memory_core_early() in nobootmem.c. This patch converts the former to use memblock_alloc_nid() and the latter memblock_find_range_in_node(), and kills memblock_x86_find_in_range_node() and related functions including find_memory_early_core_early() in page_alloc.c. Signed-off-by: Tejun Heo <tj@kernel.org> Link: http://lkml.kernel.org/r/1310460395-30913-9-git-send-email-tj@kernel.org Cc: Yinghai Lu <yinghai@kernel.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2011-07-13memblock: Kill MEMBLOCK_ERRORTejun Heo
25818f0f28 (memblock: Make MEMBLOCK_ERROR be 0) thankfully made MEMBLOCK_ERROR 0 and there already are codes which expect error return to be 0. There's no point in keeping MEMBLOCK_ERROR around. End its misery. Signed-off-by: Tejun Heo <tj@kernel.org> Link: http://lkml.kernel.org/r/1310457490-3356-6-git-send-email-tj@kernel.org Cc: Yinghai Lu <yinghai@kernel.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2011-05-25memblock/nobootmem: remove unneeded code from alloc_bootmem_node_high()Yinghai Lu
The bootmem wrapper with memblock supports top-down now, so we no longer need this trick. Signed-off-by: Yinghai LU <yinghai@kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Olaf Hering <olaf@aepfle.de> Cc: Tejun Heo <tj@kernel.org> Cc: Lucas De Marchi <lucas.demarchi@profusion.mobi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23crash_dump: export is_kdump_kernel to modules, consolidate elfcorehdr_addr, ↵Olaf Hering
setup_elfcorehdr and saved_max_pfn The Xen PV drivers in a crashed HVM guest can not connect to the dom0 backend drivers because both frontend and backend drivers are still in connected state. To run the connection reset function only in case of a crashdump, the is_kdump_kernel() function needs to be available for the PV driver modules. Consolidate elfcorehdr_addr, setup_elfcorehdr and saved_max_pfn into kernel/crash_dump.c Also export elfcorehdr_addr to make is_kdump_kernel() usable for modules. Leave 'elfcorehdr' as early_param(). This changes powerpc from __setup() to early_param(). It adds an address range check from x86 also on ia64 and powerpc. [akpm@linux-foundation.org: additional #includes] [akpm@linux-foundation.org: remove elfcorehdr_addr export] [akpm@linux-foundation.org: fix for Tejun's mm/nobootmem.c changes] Signed-off-by: Olaf Hering <olaf@aepfle.de> Cc: Russell King <rmk@arm.linux.org.uk> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-24bootmem: Move __alloc_memory_core_early() to nobootmem.cYinghai Lu
Now that bootmem.c and nobootmem.c are separate, there's no reason to define __alloc_memory_core_early(), which is used only by nobootmem, inside #ifdef in page_alloc.c. Move it to nobootmem.c and make it static. This patch doesn't introduce any behavior change. -tj: Updated commit description. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Acked-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tejun Heo <tj@kernel.org>
2011-02-24bootmem: Move contig_page_data definition to bootmem.c/nobootmem.cYinghai Lu
Now that bootmem.c and nobootmem.c are separate, it's cleaner to define contig_page_data in each file than in page_alloc.c with #ifdef. Move it. This patch doesn't introduce any behavior change. -v2: According to Andrew, fixed the struct layout. -tj: Updated commit description. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Acked-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tejun Heo <tj@kernel.org>
2011-02-24bootmem: Separate out CONFIG_NO_BOOTMEM code into nobootmem.cYinghai Lu
mm/bootmem.c contained code paths for both bootmem and no bootmem configurations. They implement about the same set of APIs in different ways and as a result bootmem.c contains massive amount of #ifdef CONFIG_NO_BOOTMEM. Separate out CONFIG_NO_BOOTMEM code into mm/nobootmem.c. As the common part is relatively small, duplicate them in nobootmem.c instead of creating a common file or ifdef'ing in bootmem.c. The followings are duplicated. * {min|max}_low_pfn, max_pfn, saved_max_pfn * free_bootmem_late() * ___alloc_bootmem() * __alloc_bootmem_low() The followings are applicable only to nobootmem and moved verbatim. * __free_pages_memory() * free_all_memory_core_early() The followings are not applicable to nobootmem and omitted in nobootmem.c. * reserve_bootmem_node() * reserve_bootmem() The rest split function bodies according to CONFIG_NO_BOOTMEM. Makefile is updated so that only either bootmem.c or nobootmem.c is built according to CONFIG_NO_BOOTMEM. This patch doesn't introduce any behavior change. -tj: Rewrote commit description. Suggested-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Acked-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tejun Heo <tj@kernel.org>
