path: root/mm/nommu.c
2012-11-15mm: export a function to get vm committed memoryK. Y. Srinivasan
It will be useful to be able to access global memory commitment from device drivers. On the Hyper-V platform, the host has a policy engine to balance the available physical memory amongst all competing virtual machines hosted on a given node. This policy engine is driven by a number of metrics including the memory commitment reported by the guests. The balloon driver for Linux on Hyper-V will use this function to retrieve guest memory commitment. This function is also used in Xen self ballooning code. [akpm@linux-foundation.org: coding-style tweak] Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Acked-by: David Rientjes <rientjes@google.com> Acked-by: Dan Magenheimer <dan.magenheimer@oracle.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-09mm: replace vma prio_tree with an interval treeMichel Lespinasse
Implement an interval tree as a replacement for the VMA prio_tree. The algorithms are similar to lib/interval_tree.c; however that code can't be directly reused as the interval endpoints are not explicitly stored in the VMA. So instead, the common algorithm is moved into a template and the details (node type, how to get interval endpoints from the node, etc) are filled in using the C preprocessor. Once the interval tree functions are available, using them as a replacement to the VMA prio tree is a relatively simple, mechanical job. Signed-off-by: Michel Lespinasse <walken@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Hillf Danton <dhillf@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09mm: kill vma flag VM_RESERVED and mm->reserved_vm counterKonstantin Khlebnikov
A long time ago, in v2.4, VM_RESERVED kept swapout process off VMA, currently it lost original meaning but still has some effects: | effect | alternative flags -+------------------------+--------------------------------------------- 1| account as reserved_vm | VM_IO 2| skip in core dump | VM_IO, VM_DONTDUMP 3| do not merge or expand | VM_IO, VM_DONTEXPAND, VM_HUGETLB, VM_PFNMAP 4| do not mlock | VM_IO, VM_DONTEXPAND, VM_HUGETLB, VM_PFNMAP This patch removes reserved_vm counter from mm_struct. Seems like nobody cares about it, it does not exported into userspace directly, it only reduces total_vm showed in proc. Thus VM_RESERVED can be replaced with VM_IO or pair VM_DONTEXPAND | VM_DONTDUMP. remap_pfn_range() and io_remap_pfn_range() set VM_IO|VM_DONTEXPAND|VM_DONTDUMP. remap_vmalloc_range() set VM_DONTEXPAND | VM_DONTDUMP. [akpm@linux-foundation.org: drivers/vfio/pci/vfio_pci.c fixup] Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Carsten Otte <cotte@de.ibm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Eric Paris <eparis@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: James Morris <james.l.morris@oracle.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Kentaro Takeda <takedakn@nttdata.co.jp> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Robert Richter <robert.richter@amd.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Venkatesh Pallipadi <venki@google.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09mm: kill vma flag VM_EXECUTABLE and mm->num_exe_file_vmasKonstantin Khlebnikov
Currently the kernel sets mm->exe_file during sys_execve() and then tracks number of vmas with VM_EXECUTABLE flag in mm->num_exe_file_vmas, as soon as this counter drops to zero kernel resets mm->exe_file to NULL. Plus it resets mm->exe_file at last mmput() when mm->mm_users drops to zero. VMA with VM_EXECUTABLE flag appears after mapping file with flag MAP_EXECUTABLE, such vmas can appears only at sys_execve() or after vma splitting, because sys_mmap ignores this flag. Usually binfmt module sets mm->exe_file and mmaps executable vmas with this file, they hold mm->exe_file while task is running. comment from v2.6.25-6245-g925d1c4 ("procfs task exe symlink"), where all this stuff was introduced: > The kernel implements readlink of /proc/pid/exe by getting the file from > the first executable VMA. Then the path to the file is reconstructed and > reported as the result. > > Because of the VMA walk the code is slightly different on nommu systems. > This patch avoids separate /proc/pid/exe code on nommu systems. Instead of > walking the VMAs to find the first executable file-backed VMA we store a > reference to the exec'd file in the mm_struct. > > That reference would prevent the filesystem holding the executable file > from being unmounted even after unmapping the VMAs. So we track the number > of VM_EXECUTABLE VMAs and drop the new reference when the last one is > unmapped. This avoids pinning the mounted filesystem. exe_file's vma accounting is hooked into every file mmap/unmmap and vma split/merge just to fix some hypothetical pinning fs from umounting by mm, which already unmapped all its executable files, but still alive. Seems like currently nobody depends on this behaviour. We can try to remove this logic and keep mm->exe_file until final mmput(). mm->exe_file is still protected with mm->mmap_sem, because we want to change it via new sys_prctl(PR_SET_MM_EXE_FILE). Also via this syscall task can change its mm->exe_file and unpin mountpoint explicitly. Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Carsten Otte <cotte@de.ibm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Eric Paris <eparis@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: James Morris <james.l.morris@oracle.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Kentaro Takeda <takedakn@nttdata.co.jp> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Robert Richter <robert.richter@amd.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Venkatesh Pallipadi <venki@google.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09mm: kill vma flag VM_CAN_NONLINEARKonstantin Khlebnikov
Move actual pte filling for non-linear file mappings into the new special vma operation: ->remap_pages(). Filesystems must implement this method to get non-linear mapping support, if it uses filemap_fault() then generic_file_remap_pages() can be used. Now device drivers can implement this method and obtain nonlinear vma support. Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Carsten Otte <cotte@de.ibm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> #arch/tile Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Eric Paris <eparis@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: James Morris <james.l.morris@oracle.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Kentaro Takeda <takedakn@nttdata.co.jp> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Robert Richter <robert.richter@amd.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Venkatesh Pallipadi <venki@google.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-09-26make get_file() return its argumentAl Viro
simplifies a bunch of callers... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-04nommu: fix compilation of nommu.cGreg Ungerer
Compiling 3.5-rc1 for nommu targets gives: CC mm/nommu.o mm/nommu.c: In function ‘sys_mmap_pgoff’: mm/nommu.c:1489:2: error: ‘ret’ undeclared (first use in this function) mm/nommu.c:1489:2: note: each undeclared identifier is reported only once for each function it appears in It is trivially fixed by replacing 'ret' with the local variable that is already defined for the return value 'retval'. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-01new helper: vm_mmap_pgoff()Al Viro
take it to mm/util.c, convert vm_mmap() to use of that one and take it to mm/util.c as well, convert both sys_mmap_pgoff() to use of vm_mmap_pgoff() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-01kill do_mmap() completelyAl Viro
just pull into vm_mmap() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-01switch aio and shm to do_mmap_pgoff(), make do_mmap() staticAl Viro
after all, 0 bytes and 0 pages is the same thing... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-01take security_mmap_file() outside of ->mmap_semAl Viro
2012-05-31split ->file_mmap() into ->mmap_addr()/->mmap_file()Al Viro
... i.e. file-dependent and address-dependent checks. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-30unexport do_mmap()Al Viro
2012-04-21kill mm argument of vm_munmap()Al Viro
it's always current->mm Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-04-20VM: add "vm_mmap()" helper functionLinus Torvalds
This continues the theme started with vm_brk() and vm_munmap(): vm_mmap() does the same thing as do_mmap(), but additionally does the required VM locking. This uninlines (and rewrites it to be clearer) do_mmap(), which sadly duplicates it in mm/mmap.c and mm/nommu.c. But that way we don't have to export our internal do_mmap_pgoff() function. Some day we hopefully don't have to export do_mmap() either, if all modular users can become the simpler vm_mmap() instead. We're actually very close to that already, with the notable exception of the (broken) use in i810, and a couple of stragglers in binfmt_elf. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-20VM: add "vm_munmap()" helper functionLinus Torvalds
Like the vm_brk() function, this is the same as "do_munmap()", except it does the VM locking for the caller. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-20VM: add "vm_brk()" helper functionLinus Torvalds
It does the same thing as "do_brk()", except it handles the VM locking too. It turns out that all external callers want that anyway, so we can make do_brk() static to just mm/mmap.c while at it. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-24NOMMU: Don't need to clear vm_mm when deleting a VMADavid Howells
Don't clear vm_mm in a deleted VMA as it's unnecessary and might conceivably break the filesystem or driver VMA close routine. Reported-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-24NOMMU: Lock i_mmap_mutex for access to the VMA prio listDavid Howells
Lock i_mmap_mutex for access to the VMA prio list to prevent concurrent access. Currently, certain parts of the mmap handling are protected by the region mutex, but not all. Reported-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-16xen: map foreign pages for shared rings by updating the PTEs directlyDavid Vrabel
When mapping a foreign page with xenbus_map_ring_valloc() with the GNTTABOP_map_grant_ref hypercall, set the GNTMAP_contains_pte flag and pass a pointer to the PTE (in init_mm). After the page is mapped, the usual fault mechanism can be used to update additional MMs. This allows the vmalloc_sync_all() to be removed from alloc_vm_area(). Signed-off-by: David Vrabel <david.vrabel@citrix.com> Acked-by: Andrew Morton <akpm@linux-foundation.org> [v1: Squashed fix by Michal for no-mmu case] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Michal Simek <monstr@monstr.eu>
2011-10-31mm: Map most files to use export.h instead of module.hPaul Gortmaker
The files changed within are only using the EXPORT_SYMBOL macro variants. They are not using core modular infrastructure and hence don't need module.h but only the export.h header. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-07-25mmap: fix and tidy up overcommit page arithmeticDmitry Fink
- shmem pages are not immediately available, but they are not potentially available either, even if we swap them out, they will just relocate from memory into swap, total amount of immediate and potentially available memory is not going to be affected, so we shouldn't count them as potentially free in the first place. - nr_free_pages() is not an expensive operation anymore, there is no need to split the decision making in two halves and repeat code. Signed-off-by: Dmitry Fink <dmitry.fink@palm.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-22Merge branch 'ptrace' of git://git.kernel.org/pub/scm/linux/kernel/git/oleg/miscLinus Torvalds
* 'ptrace' of git://git.kernel.org/pub/scm/linux/kernel/git/oleg/misc: (39 commits) ptrace: do_wait(traced_leader_killed_by_mt_exec) can block forever ptrace: fix ptrace_signal() && STOP_DEQUEUED interaction connector: add an event for monitoring process tracers ptrace: dont send SIGSTOP on auto-attach if PT_SEIZED ptrace: mv send-SIGSTOP from do_fork() to ptrace_init_task() ptrace_init_task: initialize child->jobctl explicitly has_stopped_jobs: s/task_is_stopped/SIGNAL_STOP_STOPPED/ ptrace: make former thread ID available via PTRACE_GETEVENTMSG after PTRACE_EVENT_EXEC stop ptrace: wait_consider_task: s/same_thread_group/ptrace_reparented/ ptrace: kill real_parent_is_ptracer() in in favor of ptrace_reparented() ptrace: ptrace_reparented() should check same_thread_group() redefine thread_group_leader() as exit_signal >= 0 do not change dead_task->exit_signal kill task_detached() reparent_leader: check EXIT_DEAD instead of task_detached() make do_notify_parent() __must_check, update the callers __ptrace_detach: avoid task_detached(), check do_notify_parent() kill tracehook_notify_death() make do_notify_parent() return bool ptrace: s/tracehook_tracer_task()/ptrace_parent()/ ...
2011-07-08mm/nommu.c: fix remap_pfn_range()Bob Liu
remap_pfn_range() means map physical address pfn<<PAGE_SHIFT to user addr. For nommu arch it's implemented by vma->vm_start = pfn << PAGE_SHIFT which is wrong acroding the original meaning of this function. And some driver developer using remap_pfn_range() with correct parameter will get unexpected result because vm_start is changed. It should be implementd like addr = pfn << PAGE_SHIFT but which is meanless on nommu arch, this patch just make it simply return. Parameter name and setting of vma->vm_flags also be fixed. Signed-off-by: Bob Liu <lliubbo@gmail.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: David Howells <dhowells@redhat.com> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Bob Liu <lliubbo@gmail.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-22ptrace: kill trivial tracehooksTejun Heo
At this point, tracehooks aren't useful to mainline kernel and mostly just add an extra layer of obfuscation. Although they have comments, without actual in-kernel users, it is difficult to tell what are their assumptions and they're actually trying to achieve. To mainline kernel, they just aren't worth keeping around. This patch kills the following trivial tracehooks. * Ones testing whether task is ptraced. Replace with ->ptrace test. tracehook_expect_breakpoints() tracehook_consider_ignored_signal() tracehook_consider_fatal_signal() * ptrace_event() wrappers. Call directly. tracehook_report_exec() tracehook_report_exit() tracehook_report_vfork_done() * ptrace_release_task() wrapper. Call directly. tracehook_finish_release_task() * noop tracehook_prepare_release_task() tracehook_report_death() This doesn't introduce any behavior change. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Christoph Hellwig <hch@infradead.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com>
2011-05-25nommu: add page alignment to mmapBob Liu
Currently on nommu arch mmap(),mremap() and munmap() doesn't do page_align() which isn't consist with mmu arch and cause some issues. First, some drivers' mmap() function depends on vma->vm_end - vma->start is page aligned which is true on mmu arch but not on nommu. eg: uvc camera driver. Second munmap() may return -EINVAL[split file] error in cases when end is not page aligned(passed into from userspace) but vma->vm_end is aligned dure to split or driver's mmap() ops. Add page alignment to fix those issues. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Bob Liu <lliubbo@gmail.com> Cc: David Howells <dhowells@redhat.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Greg Ungerer <gerg@snapgear.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: nommu: fix a compile warning in do_mmap_pgoff()Namhyung Kim
Because 'ret' is declared as int, not unsigned long, no need to cast the error contants into unsigned long. If you compile this code on a 64-bit machine somehow, you'll see following warning: CC mm/nommu.o mm/nommu.c: In function `do_mmap_pgoff': mm/nommu.c:1411: warning: overflow in implicit constant conversion Signed-off-by: Namhyung Kim <namhyung@gmail.com> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: David Howells <dhowells@redhat.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: nommu: fix a potential memory leak in do_mmap_private()Namhyung Kim
If f_op->read() fails and sysctl_nr_trim_pages > 1, there could be a memory leak between @region->vm_end and @region->vm_top. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: David Howells <dhowells@redhat.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: nommu: check the vma list when unmapping file-mapped vmaNamhyung Kim
Now we have the sorted vma list, use it in do_munmap() to check that we have an exact match. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: David Howells <dhowells@redhat.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: nommu: find vma using the sorted vma listNamhyung Kim
Now we have the sorted vma list, use it in the find_vma[_exact]() rather than doing linear search on the rb-tree. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: David Howells <dhowells@redhat.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: nommu: don't scan the vma list when deletingNamhyung Kim
Since commit 297c5eee3724 ("mm: make the vma list be doubly linked") made it a doubly linked list, we don't need to scan the list when deleting @vma. And the original code didn't update the prev pointer. Fix it too. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: David Howells <dhowells@redhat.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: nommu: sort mm->mmap list properlyNamhyung Kim
When I was reading nommu code, I found that it handles the vma list/tree in an unusual way. IIUC, because there can be more than one identical/overrapped vmas in the list/tree, it sorts the tree more strictly and does a linear search on the tree. But it doesn't applied to the list (i.e. the list could be constructed in a different order than the tree so that we can't use the list when finding the first vma in that order). Since inserting/sorting a vma in the tree and link is done at the same time, we can easily construct both of them in the same order. And linear searching on the tree could be more costly than doing it on the list, it can be converted to use the list. Also, after the commit 297c5eee3724 ("mm: make the vma list be doubly linked") made the list be doubly linked, there were a couple of code need to be fixed to construct the list properly. Patch 1/6 is a preparation. It maintains the list sorted same as the tree and construct doubly-linked list properly. Patch 2/6 is a simple optimization for the vma deletion. Patch 3/6 and 4/6 convert tree traversal to list traversal and the rest are simple fixes and cleanups. This patch: @vma added into @mm should be sorted by start addr, end addr and VMA struct addr in that order because we may get identical VMAs in the @mm. However this was true only for the rbtree, not for the list. This patch fixes this by remembering 'rb_prev' during the tree traversal like find_vma_prepare() does and linking the @vma via __vma_link_list(). After this patch, we can iterate the whole VMAs in correct order simply by using @mm->mmap list. [akpm@linux-foundation.org: avoid duplicating __vma_link_list()] Signed-off-by: Namhyung Kim <namhyung@gmail.com> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: David Howells <dhowells@redhat.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25arch, mm: filter disallowed nodes from arch specific show_mem functionsDavid Rientjes
Architectures that implement their own show_mem() function did not pass the filter argument to show_free_areas() to appropriately avoid emitting the state of nodes that are disallowed in the current context. This patch now passes the filter argument to show_free_areas() so those nodes are now avoided. This patch also removes the show_free_areas() wrapper around __show_free_areas() and converts existing callers to pass an empty filter. ia64 emits additional information for each node, so skip_free_areas_zone() must be made global to filter disallowed nodes and it is converted to use a nid argument rather than a zone for this use case. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Helge Deller <deller@gmx.de> Cc: James Bottomley <jejb@parisc-linux.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-29NOMMU: implement access_remote_vmMike Frysinger
Recent vm changes brought in a new function which the core procfs code utilizes. So implement it for nommu systems too to avoid link failures. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Simon Horman <horms@verge.net.au> Tested-by: Ithamar Adema <ithamar.adema@team-embedded.nl> Acked-by: Greg Ungerer <gerg@uclinux.org>
2011-03-24Merge branch 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits) Documentation/iostats.txt: bit-size reference etc. cfq-iosched: removing unnecessary think time checking cfq-iosched: Don't clear queue stats when preempt. blk-throttle: Reset group slice when limits are changed blk-cgroup: Only give unaccounted_time under debug cfq-iosched: Don't set active queue in preempt block: fix non-atomic access to genhd inflight structures block: attempt to merge with existing requests on plug flush block: NULL dereference on error path in __blkdev_get() cfq-iosched: Don't update group weights when on service tree fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away block: Require subsystems to explicitly allocate bio_set integrity mempool jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging fs: make fsync_buffers_list() plug mm: make generic_writepages() use plugging blk-cgroup: Add unaccounted time to timeslice_used. block: fixup plugging stubs for !CONFIG_BLOCK block: remove obsolete comments for blkdev_issue_zeroout. blktrace: Use rq->cmd_flags directly in blk_add_trace_rq. ... Fix up conflicts in fs/{aio.c,super.c}
2011-03-23mm: arch: rename in_gate_area_no_task to in_gate_area_no_mmStephen Wilson
Now that gate vma's are referenced with respect to a particular mm and not a particular task it only makes sense to propagate the change to this predicate as well. Signed-off-by: Stephen Wilson <wilsons@start.ca> Reviewed-by: Michel Lespinasse <walken@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-01-13mlock: do not hold mmap_sem for extended periods of timeMichel Lespinasse
__get_user_pages gets a new 'nonblocking' parameter to signal that the caller is prepared to re-acquire mmap_sem and retry the operation if needed. This is used to split off long operations if they are going to block on a disk transfer, or when we detect contention on the mmap_sem. [akpm@linux-foundation.org: remove ref to rwsem_is_contended()] Signed-off-by: Michel Lespinasse <walken@google.com> Cc: Hugh Dickins <hughd@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Nick Piggin <npiggin@kernel.dk> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-24nommu: Provide stubbed alloc/free_vm_area() implementation.Paul Mundt
Now that these have been introduced in to the vmalloc API, sync up the nommu side of things. At present we don't deal with VMAs as such, so for the time being these will simply BUG() out. In the future it should be possible to support this interface by layering on top of the vm_regions. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-12-24nommu: Fix up vmalloc_node() symbol export regression.Paul Mundt
Commit e1ca778 ("mm: add vzalloc() and vzalloc_node() helpers") ended up accidentally deleting the vmalloc_node() symbol export, resulting in: "vmalloc_node" [net/core/pktgen.ko] undefined! "vmalloc_node" [net/netfilter/x_tables.ko] undefined! regressions. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-11-25nommu: yield CPU while disposing VMSteven J. Magnani
Depending on processor speed, page size, and the amount of memory a process is allowed to amass, cleanup of a large VM may freeze the system for many seconds. This can result in a watchdog timeout. Make sure other tasks receive some service when cleaning up large VMs. Signed-off-by: Steven J. Magnani <steve@digidescorp.com> Cc: Greg Ungerer <gerg@snapgear.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-30audit mmapAl Viro
Normal syscall audit doesn't catch 5th argument of syscall. It also doesn't catch the contents of userland structures pointed to be syscall argument, so for both old and new mmap(2) ABI it doesn't record the descriptor we are mapping. For old one it also misses flags. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-26mm: add vzalloc() and vzalloc_node() helpersDave Young
Add vzalloc() and vzalloc_node() to encapsulate the vmalloc-then-memset-zero operation. Use __GFP_ZERO to zero fill the allocated memory. Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Cc: Christoph Lameter <cl@linux-foundation.org> Acked-by: Greg Ungerer <gerg@snapgear.com> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-21mm: make the vma list be doubly linkedLinus Torvalds
It's a really simple list, and several of the users want to go backwards in it to find the previous vma. So rather than have to look up the previous entry with 'find_vma_prev()' or something similar, just make it doubly linked instead. Tested-by: Ian Campbell <ijc@hellion.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-13NOMMU: Remove an extraneous no_printk()David Howells
Remove an extraneous no_printk() in mm/nommu.c that got missed when the function got generalised from several things that used it in commit 12fdff3fc248 ("Add a dummy printk function for the maintenance of unused printks"). Without this, the following error is observed: mm/nommu.c:41: error: conflicting types for 'no_printk' include/linux/kernel.h:314: error: previous definition of 'no_printk' was here Reported-by: Michal Simek <monstr@monstr.eu> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-26nommu: allow private mappings of read-only devicesBernd Schmidt
Slightly rearrange the logic that determines capabilities and vm_flags. Disable BDI_CAP_MAP_DIRECT in all cases if the device can't support the protections. Allow private readonly mappings of readonly backing devices. Signed-off-by: Bernd Schmidt <bernds_cb1@t-online.de> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: David McCullough <davidm@snapgear.com> Acked-by: Greg Ungerer <gerg@uclinux.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: David Howells <dhowells@redhat.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-25NOMMU: Fix __get_user_pages() to pin last page on offset buffersDavid Howells
Fix __get_user_pages() to make it pin the last page on a buffer that doesn't begin at the start of a page, but is a multiple of PAGE_SIZE in size. The problem is that __get_user_pages() advances the pointer too much when it iterates to the next page if the page it's currently looking at isn't used from the first byte. This can cause the end of a short VMA to be reached prematurely, resulting in the last page being lost. Signed-off-by: Steven J. Magnani <steve@digidescorp.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-25NOMMU: Revert 'nommu: get_user_pages(): pin last page on non-page-aligned start'David Howells
Revert the following patch: commit c08c6e1f54c85fc299cf9f88cf330d6dd28a9a1d Author: Steven J. Magnani <steve@digidescorp.com> Date: Fri Mar 5 13:42:24 2010 -0800 nommu: get_user_pages(): pin last page on non-page-aligned start As it assumes that the mappings begin at the start of pages - something that isn't necessarily true on NOMMU systems. On NOMMU systems, it is possible for a mapping to only occupy part of the page, and not necessarily touch either end of it; in fact it's also possible for multiple non-overlapping mappings to coexist on one page (consider direct mappings of ROMFS files, for example). Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steven J. Magnani <steve@digidescorp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-24nommu: fix an incorrect comment in the do_mmap_shared_file()David Howells
Fix an incorrect comment in the do_mmap_shared_file(). If a mapping is requested MAP_SHARED, then a private copy cannot be made and still provide correct semantics. Signed-off-by: David Howells <dhowells@redhat.com> Reported-by: Dave Hudson <uclinux@blueteddy.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12Add generic sys_old_mmap()Christoph Hellwig
Add a generic implementation of the old mmap() syscall, which expects its argument in a memory block and switch all architectures over to use it. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: James Morris <jmorris@namei.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Ungerer <gerg@uclinux.org> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
