[ Upstream commit 3fa750dcf29e8606e3969d13d8e188cc1c0f511d ]
write_cache_pages() is used in both background and integrity writeback
scenarios by various filesystems. Background writeback is mostly
concerned with cleaning a certain number of dirty pages based on various
mm heuristics. It may not write the full set of dirty pages or wait for
I/O to complete. Integrity writeback is responsible for persisting a set
of dirty pages before the writeback job completes. For example, an
fsync() call must perform integrity writeback to ensure data is on disk
before the call returns.
write_cache_pages() unconditionally breaks out of its processing loop in
the event of a ->writepage() error. This is fine for background
writeback, which had no strict requirements and will eventually come
around again. This can cause problems for integrity writeback on
filesystems that might need to clean up state associated with failed page
writeouts. For example, XFS performs internal delayed allocation
accounting before returning a ->writepage() error, where applicable. If
the current writeback happens to be associated with an unmount and
write_cache_pages() completes the writeback prematurely due to error, the
filesystem is unmounted in an inconsistent state if dirty+delalloc pages
still exist.
To handle this problem, update write_cache_pages() to always process the
full set of pages for integrity writeback regardless of ->writepage()
errors. Save the first encountered error and return it to the caller once
complete. This facilitates XFS (or any other fs that expects integrity
writeback to process the entire set of dirty pages) to clean up its
internal state completely in the event of persistent mapping errors.
Background writeback continues to exit on the first error encountered.
[akpm@linux-foundation.org: fix typo in comment]
Link: http://lkml.kernel.org/r/20181116134304.32440-1-bfoster@redhat.com
Signed-off-by: Brian Foster <bfoster@redhat.com>
commit 2e898e4c0a3897ccd434adac5abb8330194f527b upstream.
lock_page_memcg()/unlock_page_memcg() use spin_lock_irqsave/restore() if
the page's memcg is undergoing move accounting, which occurs when a
process leaves its memcg for a new one that has
memory.move_charge_at_immigrate set.
unlocked_inode_to_wb_begin,end() use spin_lock_irq/spin_unlock_irq() if
the given inode is switching writeback domains. Switches occur when
enough writes are issued from a new domain.
This existing pattern is thus suspicious:
lock_page_memcg(page);
unlocked_inode_to_wb_begin(inode, &locked);
unlocked_inode_to_wb_end(inode, locked);
unlock_page_memcg(page);
If both inode switch and process memcg migration are both in-flight then
unlocked_inode_to_wb_end() will unconditionally enable interrupts while
still holding the lock_page_memcg() irq spinlock. This suggests the
possibility of deadlock if an interrupt occurs before unlock_page_memcg().
truncate
__cancel_dirty_page
lock_page_memcg
<interrupts mistakenly enabled>
<interrupt>
end_page_writeback
test_clear_page_writeback
lock_page_memcg
<deadlock>
unlock_page_memcg
Due to configuration limitations this deadlock is not currently possible
because we don't mix cgroup writeback (a cgroupv2 feature) and
memory.move_charge_at_immigrate (a cgroupv1 feature).
If the kernel is hacked to always claim inode switching and memcg
moving_account, then this script triggers lockup in less than a minute:
cd /mnt/cgroup/memory
mkdir a b
echo 1 > a/memory.move_charge_at_immigrate
echo 1 > b/memory.move_charge_at_immigrate
echo $BASHPID > a/cgroup.procs
while true; do
dd if=/dev/zero of=/mnt/big bs=1M count=256
done
while true; do
sync
done &
sleep 1h &
SLEEP=$!
while true; do
echo $SLEEP > a/cgroup.procs
echo $SLEEP > b/cgroup.procs
done
The deadlock does not seem possible, so it's debatable if there's any
reason to modify the kernel. I suggest we should to prevent future
surprises. And Wang Long said "this deadlock occurs three times in our
environment", so there's more reason to apply this, even to stable.
Stable 4.4 has minor conflicts applying this patch. For a clean 4.4 patch
see "[PATCH for-4.4] writeback: safer lock nesting"
https://lkml.org/lkml/2018/4/11/146
Wang Long said "this deadlock occurs three times in our environment"
[gthelen@google.com: v4]
Link: http://lkml.kernel.org/r/20180411084653.254724-1-gthelen@google.com
[akpm@linux-foundation.org: comment tweaks, struct initialization simplification]
Change-Id: Ibb773e8045852978f6207074491d262f1b3fb613
Link: http://lkml.kernel.org/r/20180410005908.167976-1-gthelen@google.com
Fixes: 682aa8e1a6a1 ("writeback: implement unlocked_inode_to_wb transaction and use it for stat updates")
Signed-off-by: Greg Thelen <gthelen@google.com>
Reported-by: Wang Long <wanglong19@meituan.com>
Acked-by: Wang Long <wanglong19@meituan.com>
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Tejun Heo <tj@kernel.org>
Cc: Nicholas Piggin <npiggin@gmail.com>
Cc: <stable@vger.kernel.org> [v4.2+]
[natechancellor: Adjust context due to lack of b93b016313b3b]
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
global_page_state is error prone as a recent bug report pointed out [1].
It only returns proper values for zone based counters as the enum it
gets suggests. We already have global_node_page_state so let's rename
global_page_state to global_zone_page_state to be more explicit here.
All existing users seems to be correct:
$ git grep "global_page_state(NR_" | sed 's@.*(\(NR_[A-Z_]*\)).*@\1@' | sort | uniq -c
2 NR_BOUNCE
2 NR_FREE_CMA_PAGES
11 NR_FREE_PAGES
1 NR_KERNEL_STACK_KB
1 NR_MLOCK
2 NR_PAGETABLE
This patch shouldn't introduce any functional change.
[1] http://lkml.kernel.org/r/201707260628.v6Q6SmaS030814@www262.sakura.ne.jp
Link: http://lkml.kernel.org/r/20170801134256.5400-2-hannes@cmpxchg.org
Signed-off-by: Michal Hocko <mhocko@suse.com>
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Cc: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp>
Cc: Josef Bacik <josef@toxicpanda.com>
Cc: Vladimir Davydov <vdavydov.dev@gmail.com>
Jaegeuk and Brad report a NULL pointer crash when writeback ending tries
to update the memcg stats:
BUG: unable to handle kernel NULL pointer dereference at 00000000000003b0
IP: test_clear_page_writeback+0x12e/0x2c0
RIP: 0010:test_clear_page_writeback+0x12e/0x2c0
Call Trace:
<IRQ>
end_page_writeback+0x47/0x70
f2fs_write_end_io+0x76/0x180 [f2fs]
bio_endio+0x9f/0x120
blk_update_request+0xa8/0x2f0
scsi_end_request+0x39/0x1d0
scsi_io_completion+0x211/0x690
scsi_finish_command+0xd9/0x120
scsi_softirq_done+0x127/0x150
__blk_mq_complete_request_remote+0x13/0x20
flush_smp_call_function_queue+0x56/0x110
generic_smp_call_function_single_interrupt+0x13/0x30
smp_call_function_single_interrupt+0x27/0x40
call_function_single_interrupt+0x89/0x90
RIP: 0010:native_safe_halt+0x6/0x10
(gdb) l *(test_clear_page_writeback+0x12e)
0xffffffff811bae3e is in test_clear_page_writeback (./include/linux/memcontrol.h:619).
614 mod_node_page_state(page_pgdat(page), idx, val);
615 if (mem_cgroup_disabled() || !page->mem_cgroup)
616 return;
617 mod_memcg_state(page->mem_cgroup, idx, val);
618 pn = page->mem_cgroup->nodeinfo[page_to_nid(page)];
619 this_cpu_add(pn->lruvec_stat->count[idx], val);
620 }
621
622 unsigned long mem_cgroup_soft_limit_reclaim(pg_data_t *pgdat, int order,
623 gfp_t gfp_mask,
The issue is that writeback doesn't hold a page reference and the page
might get freed after PG_writeback is cleared (and the mapping is
unlocked) in test_clear_page_writeback(). The stat functions looking up
the page's node or zone are safe, as those attributes are static across
allocation and free cycles. But page->mem_cgroup is not, and it will
get cleared if we race with truncation or migration.
It appears this race window has been around for a while, but less likely
to trigger when the memcg stats were updated first thing after
PG_writeback is cleared. Recent changes reshuffled this code to update
the global node stats before the memcg ones, though, stretching the race
window out to an extent where people can reproduce the problem.
Update test_clear_page_writeback() to look up and pin page->mem_cgroup
before clearing PG_writeback, then not use that pointer afterward. It
is a partial revert of 62cccb8c8e7a ("mm: simplify lock_page_memcg()")
but leaves the pageref-holding callsites that aren't affected alone.
Link: http://lkml.kernel.org/r/20170809183825.GA26387@cmpxchg.org
Fixes: 62cccb8c8e7a ("mm: simplify lock_page_memcg()")
Reported-by: Jaegeuk Kim <jaegeuk@kernel.org>
Tested-by: Jaegeuk Kim <jaegeuk@kernel.org>
Reported-by: Bradley Bolen <bradleybolen@gmail.com>
Tested-by: Brad Bolen <bradleybolen@gmail.com>
Cc: Vladimir Davydov <vdavydov@virtuozzo.com>
Cc: <stable@vger.kernel.org> [4.6+]
Currently the writeback statistics code uses a percpu counters to hold
various statistics. Furthermore we have 2 families of functions - those
which disable local irq and those which doesn't and whose names begin
with double underscore. However, they both end up calling
__add_wb_stats which in turn calls percpu_counter_add_batch which is
already irq-safe.
Exploiting this fact allows to eliminated the __wb_* functions since
they don't add any further protection than we already have.
Furthermore, refactor the wb_* function to call __add_wb_stat directly
without the irq-disabling dance. This will likely result in better
runtime of code which deals with modifying the stat counters.
While at it also document why percpu_counter_add_batch is in fact
preempt and irq-safe since at least 3 people got confused.
Link: http://lkml.kernel.org/r/1498029937-27293-1-git-send-email-nborisov@suse.com
Signed-off-by: Nikolay Borisov <nborisov@suse.com>
Acked-by: Tejun Heo <tj@kernel.org>
Cc: Josef Bacik <jbacik@fb.com>
Cc: Mel Gorman <mgorman@techsingularity.net>
Cc: Jeff Layton <jlayton@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jlayton/linux
Pull Writeback error handling fixes from Jeff Layton:
"The main rationale for all of these changes is to tighten up writeback
error reporting to userland. There are many ways now that writeback
errors can be lost, such that fsync/fdatasync/msync return 0 when
writeback actually failed.
This pile contains a small set of cleanups and writeback error
handling fixes that I was able to break off from the main pile (#2).
Two of the patches in this pile are trivial. The exceptions are the
patch to fix up error handling in write_one_page, and the patch to
make JFS pay attention to write_one_page errors"
* tag 'for-linus-v4.13-1' of git://git.kernel.org/pub/scm/linux/kernel/git/jlayton/linux:
fs: remove call_fsync helper function
mm: clean up error handling in write_one_page
JFS: do not ignore return code from write_one_page()
mm: drop "wait" parameter from write_one_page()
lruvecs are at the intersection of the NUMA node and memcg, which is the
scope for most paging activity.
Introduce a convenient accounting infrastructure that maintains
statistics per node, per memcg, and the lruvec itself.
Then convert over accounting sites for statistics that are already
tracked in both nodes and memcgs and can be easily switched.
[hannes@cmpxchg.org: fix crash in the new cgroup stat keeping code]
Link: http://lkml.kernel.org/r/20170531171450.GA10481@cmpxchg.org
[hannes@cmpxchg.org: don't track uncharged pages at all
Link: http://lkml.kernel.org/r/20170605175254.GA8547@cmpxchg.org
[hannes@cmpxchg.org: add missing free_percpu()]
Link: http://lkml.kernel.org/r/20170605175354.GB8547@cmpxchg.org
[linux@roeck-us.net: hexagon: fix build error caused by include file order]
Link: http://lkml.kernel.org/r/20170617153721.GA4382@roeck-us.net
Link: http://lkml.kernel.org/r/20170530181724.27197-6-hannes@cmpxchg.org
Acked-by: Vladimir Davydov <vdavydov.dev@gmail.com>
Cc: Michal Hocko <mhocko@suse.com>
Don't try to check PageError since that's potentially racy and not
necessarily going to be set after writepage errors out.
Instead, check the mapping for an error after writepage returns. That
should also help us detect errors that occurred if the VM tried to
clean the page earlier due to memory pressure.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
The callers all set it to 1.
Also, make it clear that this function will not set any sort of AS_*
error, and that the caller must do so if necessary. No existing caller
uses this on normal files, so none of them need it.
Also, add __must_check here since, in general, the callers need to handle
an error here in some fashion.
Link: http://lkml.kernel.org/r/20170525103303.6524-1-jlayton@redhat.com
Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com>
Reviewed-by: Matthew Wilcox <mawilcox@microsoft.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull ext4 updates from Ted Ts'o:
- add GETFSMAP support
- some performance improvements for very large file systems and for
random write workloads into a preallocated file
- bug fixes and cleanups.
* tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4:
jbd2: cleanup write flags handling from jbd2_write_superblock()
ext4: mark superblock writes synchronous for nobarrier mounts
ext4: inherit encryption xattr before other xattrs
ext4: replace BUG_ON with WARN_ONCE in ext4_end_bio()
ext4: avoid unnecessary transaction stalls during writeback
ext4: preload block group descriptors
ext4: make ext4_shutdown() static
ext4: support GETFSMAP ioctls
vfs: add common GETFSMAP ioctl definitions
ext4: evict inline data when writing to memory map
ext4: remove ext4_xattr_check_entry()
ext4: rename ext4_xattr_check_names() to ext4_xattr_check_entries()
ext4: merge ext4_xattr_list() into ext4_listxattr()
ext4: constify static data that is never modified
ext4: trim return value and 'dir' argument from ext4_insert_dentry()
jbd2: fix dbench4 performance regression for 'nobarrier' mounts
jbd2: Fix lockdep splat with generic/270 test
mm: retry writepages() on ENOMEM when doing an data integrity writeback
The memory controllers stat function names are awkwardly long and
arbitrarily different from the zone and node stat functions.
The current interface is named:
mem_cgroup_read_stat()
mem_cgroup_update_stat()
mem_cgroup_inc_stat()
mem_cgroup_dec_stat()
mem_cgroup_update_page_stat()
mem_cgroup_inc_page_stat()
mem_cgroup_dec_page_stat()
This patch renames it to match the corresponding node stat functions:
memcg_page_state() [node_page_state()]
mod_memcg_state() [mod_node_state()]
inc_memcg_state() [inc_node_state()]
dec_memcg_state() [dec_node_state()]
mod_memcg_page_state() [mod_node_page_state()]
inc_memcg_page_state() [inc_node_page_state()]
dec_memcg_page_state() [dec_node_page_state()]
Link: http://lkml.kernel.org/r/20170404220148.28338-4-hannes@cmpxchg.org
The current duplication is a high-maintenance mess, and it's painful to
add new items or query memcg state from the rest of the VM.
This increases the size of the stat array marginally, but we should aim
to track all these stats on a per-cgroup level anyway.
Link: http://lkml.kernel.org/r/20170404220148.28338-3-hannes@cmpxchg.org
Use setup_deferrable_timer() instead of init_timer_deferrable() to
simplify the code.
Link: http://lkml.kernel.org/r/e8e3d4280a34facbc007346f31df833cec28801e.1488070291.git.geliangtang@gmail.com
Signed-off-by: Geliang Tang <geliangtang@gmail.com>
Currently, file system's writepages() function must not fail with an
ENOMEM, since if they do, it's possible for buffered data to be lost.
This is because on a data integrity writeback writepages() gets called
but once, and if it returns ENOMEM, if you're lucky the error will get
reflected back to the userspace process calling fsync(). If you
aren't lucky, the user is unmounting the file system, and the dirty
pages will simply be lost.
For this reason, file system code generally will use GFP_NOFS, and in
some cases, will retry the allocation in a loop, on the theory that
"kernel livelocks are temporary; data loss is forever".
Unfortunately, this can indeed cause livelocks, since inside the
writepages() call, the file system is holding various mutexes, and
these mutexes may prevent the OOM killer from killing its targetted
victim if it is also holding on to those mutexes.
A better solution would be to allow writepages() to call the memory
allocator with flags that give greater latitude to the allocator to
fail, and then release its locks and return ENOMEM, and in the case of
background writeback, the writes can be retried at a later time. In
the case of data-integrity writeback retry after waiting a brief
amount of time.
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
dependency
Instead of including the full <linux/signal.h>, we are going to include the
types-only <linux/signal_types.h> header in <linux/sched.h>, to further
decouple the scheduler header from the signal headers.
This means that various files which relied on the full <linux/signal.h> need
to be updated to gain an explicit dependency on it.
Update the code that relies on sched.h's inclusion of the <linux/signal.h> header.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Fix typos and add the following to the scripts/spelling.txt:
comsume||consume
comsumer||consumer
comsuming||consuming
I see some variable names with this pattern, but this commit is only
touching comment blocks to avoid unexpected impact.
Link: http://lkml.kernel.org/r/1481573103-11329-19-git-send-email-yamada.masahiro@socionext.com
wb_domain_writeout_inc()
The likely/unlikely profiler noticed that the unlikely statement in
wb_domain_writeout_inc() is constantly wrong. This is due to the "not"
(!) being outside the unlikely statement. It is likely that
dom->period_time will be set, but unlikely that it wont be. Move the
not into the unlikely statement.
Link: http://lkml.kernel.org/r/20170206120035.3c2e2b91@gandalf.local.home
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
We will want to have struct backing_dev_info allocated separately from
struct request_queue. As the first step add pointer to backing_dev_info
to request_queue and convert all users touching it. No functional
changes in this patch.
Signed-off-by: Jens Axboe <axboe@fb.com>
This is an exceptionally complicated function with just one caller
(tag_pages_for_writeback). We devote a large portion of the runtime of
the test suite to testing this one function which has one caller. By
introducing the new function radix_tree_iter_tag_set(), we can eliminate
all of the complexity while keeping the performance. The caller can now
use a fairly standard radix_tree_for_each() loop, and it doesn't need to
worry about tricksy things like 'start' wrapping.
The test suite continues to spend a large amount of time investigating
this function, but now it's testing the underlying primitives such as
radix_tree_iter_resume() and the radix_tree_for_each_tagged() iterator
which are also used by other parts of the kernel.
Link: http://lkml.kernel.org/r/1480369871-5271-57-git-send-email-mawilcox@linuxonhyperv.com
Signed-off-by: Matthew Wilcox <willy@infradead.org>
Tested-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Konstantin Khlebnikov <koct9i@gmail.com>
Cc: Ross Zwisler <ross.zwisler@linux.intel.com>
Cc: Matthew Wilcox <mawilcox@microsoft.com>
Note in the bdi_writeback structure whenever a task ends up sleeping
waiting for progress. We can use that information in the lower layers
to increase the priority of writes.
File pages use a set of radix tree tags (DIRTY, TOWRITE, WRITEBACK,
etc.) to accelerate finding the pages with a specific tag in the radix
tree during inode writeback. But for anonymous pages in the swap cache,
there is no inode writeback. So there is no need to find the pages with
some writeback tags in the radix tree. It is not necessary to touch
radix tree writeback tags for pages in the swap cache.
Per Rik van Riel's suggestion, a new flag AS_NO_WRITEBACK_TAGS is
introduced for address spaces which don't need to update the writeback
tags. The flag is set for swap caches. It may be used for DAX file
systems, etc.
With this patch, the swap out bandwidth improved 22.3% (from ~1.2GB/s to
~1.48GBps) in the vm-scalability swap-w-seq test case with 8 processes.
The test is done on a Xeon E5 v3 system. The swap device used is a RAM
simulated PMEM (persistent memory) device. The improvement comes from
the reduced contention on the swap cache radix tree lock. To test
sequential swapping out, the test case uses 8 processes, which
sequentially allocate and write to the anonymous pages until RAM and
part of the swap device is used up.
Details of comparison is as follow,
base base+patch
%stddev %change %stddev
2506952 ± 2% +28.1% 3212076 ± 7% vm-scalability.throughput
1207402 ± 7% +22.3% 1476578 ± 6% vmstat.swap.so
10.86 ± 12% -23.4% 8.31 ± 16% perf-profile.cycles-pp._raw_spin_lock_irq.__add_to_swap_cache.add_to_swap_cache.add_to_swap.shrink_page_list
10.82 ± 13% -33.1% 7.24 ± 14% perf-profile.cycles-pp._raw_spin_lock_irqsave.__remove_mapping.shrink_page_list.shrink_inactive_list.shrink_zone_memcg
10.36 ± 11% -100.0% 0.00 ± -1% perf-profile.cycles-pp._raw_spin_lock_irqsave.__test_set_page_writeback.bdev_write_page.__swap_writepage.swap_writepage
10.52 ± 12% -100.0% 0.00 ± -1% perf-profile.cycles-pp._raw_spin_lock_irqsave.test_clear_page_writeback.end_page_writeback.page_endio.pmem_rw_page
Link: http://lkml.kernel.org/r/1472578089-5560-1-git-send-email-ying.huang@intel.com
Signed-off-by: "Huang, Ying" <ying.huang@intel.com>
Cc: Shaohua Li <shli@kernel.org>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Wu Fengguang <fengguang.wu@intel.com>
throttle_vm_writeout() was introduced back in 2005 to fix OOMs caused by
excessive pageout activity during the reclaim. Too many pages could be
put under writeback therefore LRUs would be full of unreclaimable pages
until the IO completes and in turn the OOM killer could be invoked.
There have been some important changes introduced since then in the
reclaim path though. Writers are throttled by balance_dirty_pages when
initiating the buffered IO and later during the memory pressure, the
direct reclaim is throttled by wait_iff_congested if the node is
considered congested by dirty pages on LRUs and the underlying bdi is
congested by the queued IO. The kswapd is throttled as well if it
encounters pages marked for immediate reclaim or under writeback which
signals that that there are too many pages under writeback already.
Finally should_reclaim_retry does congestion_wait if the reclaim cannot
make any progress and there are too many dirty/writeback pages.
Another important aspect is that we do not issue any IO from the direct
reclaim context anymore. In a heavy parallel load this could queue a
lot of IO which would be very scattered and thus unefficient which would
just make the problem worse.
This three mechanisms should throttle and keep the amount of IO in a
steady state even under heavy IO and memory pressure so yet another
throttling point doesn't really seem helpful. Quite contrary, Mikulas
Patocka has reported that swap backed by dm-crypt doesn't work properly
because the swapout IO cannot make sufficient progress as the writeout
path depends on dm_crypt worker which has to allocate memory to perform
the encryption. In order to guarantee a forward progress it relies on
the mempool allocator. mempool_alloc(), however, prefers to use the
underlying (usually page) allocator before it grabs objects from the
pool. Such an allocation can dive into the memory reclaim and
consequently to throttle_vm_writeout. If there are too many dirty or
pages under writeback it will get throttled even though it is in fact a
flusher to clear pending pages.
kworker/u4:0 D ffff88003df7f438 10488 6 2 0x00000000
Workqueue: kcryptd kcryptd_crypt [dm_crypt]
Call Trace:
schedule+0x3c/0x90
schedule_timeout+0x1d8/0x360
io_schedule_timeout+0xa4/0x110
congestion_wait+0x86/0x1f0
throttle_vm_writeout+0x44/0xd0
shrink_zone_memcg+0x613/0x720
shrink_zone+0xe0/0x300
do_try_to_free_pages+0x1ad/0x450
try_to_free_pages+0xef/0x300
__alloc_pages_nodemask+0x879/0x1210
alloc_pages_current+0xa1/0x1f0
new_slab+0x2d7/0x6a0
___slab_alloc+0x3fb/0x5c0
__slab_alloc+0x51/0x90
kmem_cache_alloc+0x27b/0x310
mempool_alloc_slab+0x1d/0x30
mempool_alloc+0x91/0x230
bio_alloc_bioset+0xbd/0x260
kcryptd_crypt+0x114/0x3b0 [dm_crypt]
Let's just drop throttle_vm_writeout altogether. It is not very much
helpful anymore.
I have tried to test a potential writeback IO runaway similar to the one
described in the original patch which has introduced that [1]. Small
virtual machine (512MB RAM, 4 CPUs, 2G of swap space and disk image on a
rather slow NFS in a sync mode on the host) with 8 parallel writers each
writing 1G worth of data. As soon as the pagecache fills up and the
direct reclaim hits then I start anon memory consumer in a loop
(allocating 300M and exiting after populating it) in the background to
make the memory pressure even stronger as well as to disrupt the steady
state for the IO. The direct reclaim is throttled because of the
congestion as well as kswapd hitting congestion_wait due to nr_immediate
but throttle_vm_writeout doesn't ever trigger the sleep throughout the
test. Dirty+writeback are close to nr_dirty_threshold with some
fluctuations caused by the anon consumer.
[1] https://www2.kernel.org/pub/linux/kernel/people/akpm/patches/2.6/2.6.9-rc1/2.6.9-rc1-mm3/broken-out/vm-pageout-throttling.patch
Link: http://lkml.kernel.org/r/1471171473-21418-1-git-send-email-mhocko@kernel.org
Reported-by: Mikulas Patocka <mpatocka@redhat.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: NeilBrown <neilb@suse.com>
Cc: Ondrej Kozina <okozina@redhat.com>
Install the callbacks via the state machine and let the core invoke
the callbacks on the already online CPUs.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: Jens Axboe <axboe@fb.com>
Cc: linux-mm@kvack.org
Cc: rt@linutronix.de
Link: http://lkml.kernel.org/r/20160818125731.27256-6-bigeasy@linutronix.de
If per-zone LRU accounting is available then there is no point
approximating whether reclaim and compaction should retry based on pgdat
statistics. This is effectively a revert of "mm, vmstat: remove zone
and node double accounting by approximating retries" with the difference
that inactive/active stats are still available. This preserves the
history of why the approximation was retried and why it had to be
reverted to handle OOM kills on 32-bit systems.
Link: http://lkml.kernel.org/r/1469110261-7365-4-git-send-email-mgorman@techsingularity.net
Signed-off-by: Mel Gorman <mgorman@techsingularity.net>
Acked-by: Minchan Kim <minchan@kernel.org>
With the reintroduction of per-zone LRU stats, highmem_file_pages is
redundant so remove it.
[mgorman@techsingularity.net: wrong stat is being accumulated in highmem_dirtyable_memory]
Link: http://lkml.kernel.org/r/20160725092324.GM10438@techsingularity.netLink: http://lkml.kernel.org/r/1469110261-7365-3-git-send-email-mgorman@techsingularity.net
When I tested vmscale in mmtest in 32bit, I found the benchmark was slow
down 0.5 times.
base node
1 global-1
User 12.98 16.04
System 147.61 166.42
Elapsed 26.48 38.08
With vmstat, I found IO wait avg is much increased compared to base.
The reason was highmem_dirtyable_memory accumulates free pages and
highmem_file_pages from HIGHMEM to MOVABLE zones which was wrong. With
that, dirth_thresh in throtlle_vm_write is always 0 so that it calls
congestion_wait frequently if writeback starts.
With this patch, it is much recovered.
base node fi
1 global-1 fix
User 12.98 16.04 13.78
System 147.61 166.42 143.92
Elapsed 26.48 38.08 29.64
Link: http://lkml.kernel.org/r/1468404004-5085-4-git-send-email-mgorman@techsingularity.net
Signed-off-by: Minchan Kim <minchan@kernel.org>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
The number of LRU pages, dirty pages and writeback pages must be
accounted for on both zones and nodes because of the reclaim retry
logic, compaction retry logic and highmem calculations all depending on
per-zone stats.
Many lowmem allocations are immune from OOM kill due to a check in
__alloc_pages_may_oom for (ac->high_zoneidx < ZONE_NORMAL) since commit
03668b3ceb0c ("oom: avoid oom killer for lowmem allocations"). The
exception is costly high-order allocations or allocations that cannot
fail. If the __alloc_pages_may_oom avoids OOM-kill for low-order lowmem
allocations then it would fall through to __alloc_pages_direct_compact.
This patch will blindly retry reclaim for zone-constrained allocations
in should_reclaim_retry up to MAX_RECLAIM_RETRIES. This is not ideal
but without per-zone stats there are not many alternatives. The impact
it that zone-constrained allocations may delay before considering the
OOM killer.
As there is no guarantee enough memory can ever be freed to satisfy
compaction, this patch avoids retrying compaction for zone-contrained
allocations.
In combination, that means that the per-node stats can be used when
deciding whether to continue reclaim using a rough approximation. While
it is possible this will make the wrong decision on occasion, it will
not infinite loop as the number of reclaim attempts is capped by
The final step is calculating the number of dirtyable highmem pages. As
those calculations only care about the global count of file pages in
highmem. This patch uses a global counter used instead of per-zone
stats as it is sufficient.
In combination, this allows the per-zone LRU and dirty state counters to
be removed.
[mgorman@techsingularity.net: fix acct_highmem_file_pages()]
Link: http://lkml.kernel.org/r/1468853426-12858-4-git-send-email-mgorman@techsingularity.netLink: http://lkml.kernel.org/r/1467970510-21195-35-git-send-email-mgorman@techsingularity.net
Suggested by: Michal Hocko <mhocko@kernel.org>
Acked-by: Hillf Danton <hillf.zj@alibaba-inc.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Rik van Riel <riel@surriel.com>
As reclaim is now node-based, it follows that page write activity due to
page reclaim should also be accounted for on the node. For consistency,
also account page writes and page dirtying on a per-node basis.
After this patch, there are a few remaining zone counters that may appear
strange but are fine. NUMA stats are still per-zone as this is a
user-space interface that tools consume. NR_MLOCK, NR_SLAB_*,
NR_PAGETABLE, NR_KERNEL_STACK and NR_BOUNCE are all allocations that
potentially pin low memory and cannot trivially be reclaimed on demand.
This information is still useful for debugging a page allocation failure
warning.
Link: http://lkml.kernel.org/r/1467970510-21195-21-git-send-email-mgorman@techsingularity.net
Cc: Hillf Danton <hillf.zj@alibaba-inc.com>
There are now a number of accounting oddities such as mapped file pages
being accounted for on the node while the total number of file pages are
accounted on the zone. This can be coped with to some extent but it's
confusing so this patch moves the relevant file-based accounted. Due to
throttling logic in the page allocator for reliable OOM detection, it is
still necessary to track dirty and writeback pages on a per-zone basis.
[mgorman@techsingularity.net: fix NR_ZONE_WRITE_PENDING accounting]
Link: http://lkml.kernel.org/r/1468404004-5085-5-git-send-email-mgorman@techsingularity.net
Link: http://lkml.kernel.org/r/1467970510-21195-20-git-send-email-mgorman@techsingularity.net
Historically dirty pages were spread among zones but now that LRUs are
per-node it is more appropriate to consider dirty pages in a node.
Link: http://lkml.kernel.org/r/1467970510-21195-17-git-send-email-mgorman@techsingularity.net
This moves the LRU lists from the zone to the node and related data such
as counters, tracing, congestion tracking and writeback tracking.
Unfortunately, due to reclaim and compaction retry logic, it is
necessary to account for the number of LRU pages on both zone and node
logic. Most reclaim logic is based on the node counters but the retry
logic uses the zone counters which do not distinguish inactive and
active sizes. It would be possible to leave the LRU counters on a
per-zone basis but it's a heavier calculation across multiple cache
lines that is much more frequent than the retry checks.
Other than the LRU counters, this is mostly a mechanical patch but note
that it introduces a number of anomalies. For example, the scans are
per-zone but using per-node counters. We also mark a node as congested
when a zone is congested. This causes weird problems that are fixed
later but is easier to review.
In the event that there is excessive overhead on 32-bit systems due to
the nodes being on LRU then there are two potential solutions
1. Long-term isolation of highmem pages when reclaim is lowmem
When pages are skipped, they are immediately added back onto the LRU
list. If lowmem reclaim persisted for long periods of time, the same
highmem pages get continually scanned. The idea would be that lowmem
keeps those pages on a separate list until a reclaim for highmem pages
arrives that splices the highmem pages back onto the LRU. It potentially
could be implemented similar to the UNEVICTABLE list.
That would reduce the skip rate with the potential corner case is that
highmem pages have to be scanned and reclaimed to free lowmem slab pages.
2. Linear scan lowmem pages if the initial LRU shrink fails
This will break LRU ordering but may be preferable and faster during
memory pressure than skipping LRU pages.
Link: http://lkml.kernel.org/r/1467970510-21195-4-git-send-email-mgorman@techsingularity.net
Here's basic implementation of huge pages support for shmem/tmpfs.
It's all pretty streight-forward:
- shmem_getpage() allcoates huge page if it can and try to inserd into
radix tree with shmem_add_to_page_cache();
- shmem_add_to_page_cache() puts the page onto radix-tree if there's
space for it;
- shmem_undo_range() removes huge pages, if it fully within range.
Partial truncate of huge pages zero out this part of THP.
This have visible effect on fallocate(FALLOC_FL_PUNCH_HOLE)
behaviour. As we don't really create hole in this case,
lseek(SEEK_HOLE) may have inconsistent results depending what
pages happened to be allocated.
- no need to change shmem_fault: core-mm will map an compound page as
huge if VMA is suitable;
Link: http://lkml.kernel.org/r/1466021202-61880-30-git-send-email-kirill.shutemov@linux.intel.com
wait_sb_inodes() currently does a walk of all inodes in the filesystem
to find dirty one to wait on during sync. This is highly inefficient
and wastes a lot of CPU when there are lots of clean cached inodes that
we don't need to wait on.
To avoid this "all inode" walk, we need to track inodes that are
currently under writeback that we need to wait for. We do this by
adding inodes to a writeback list on the sb when the mapping is first
tagged as having pages under writeback. wait_sb_inodes() can then walk
this list of "inodes under IO" and wait specifically just for the inodes
that the current sync(2) needs to wait for.
Define a couple helpers to add/remove an inode from the writeback list
and call them when the overall mapping is tagged for or cleared from
writeback. Update wait_sb_inodes() to walk only the inodes under
writeback due to the sync.
With this change, filesystem sync times are significantly reduced for
fs' with largely populated inode caches and otherwise no other work to
do. For example, on a 16xcpu 2GHz x86-64 server, 10TB XFS filesystem
with a ~10m entry inode cache, sync times are reduced from ~7.3s to less
than 0.1s when the filesystem is fully clean.
Link: http://lkml.kernel.org/r/1466594593-6757-2-git-send-email-bfoster@redhat.com
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Josef Bacik <jbacik@fb.com>
Tested-by: Holger Hoffstätte <holger.hoffstaette@applied-asynchrony.com>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
As vm.dirty_[background_]bytes can't be applied verbatim to multiple
cgroup writeback domains, they get converted to percentages in
domain_dirty_limits() and applied the same way as
vm.dirty_[background]ratio. However, if the specified bytes is lower
than 1% of available memory, the calculated ratios become zero and the
writeback domain gets throttled constantly.
Fix it by using per-PAGE_SIZE instead of percentage for ratio
calculations. Also, the updated DIV_ROUND_UP() usages now should
yield 1/4096 (0.0244%) as the minimum ratio as long as the specified
bytes are above zero.
Reported-by: Miao Xie <miaoxie@huawei.com>
Link: http://lkml.kernel.org/g/57333E75.3080309@huawei.com
Cc: stable@vger.kernel.org # v4.2+
Fixes: 9fc3a43e1757 ("writeback: separate out domain_dirty_limits()")
Adjusted comment based on Jan's suggestion.
When nfsd is exporting a filesystem over NFS which is then NFS-mounted
on the local machine there is a risk of deadlock. This happens when
there are lots of dirty pages in the NFS filesystem and they cause NFSD
to be throttled, either in throttle_vm_writeout() or in
balance_dirty_pages().
To avoid this problem the PF_LESS_THROTTLE flag is set for NFSD threads
and it provides a 25% increase to the limits that affect NFSD. Any
process writing to an NFS filesystem will be throttled well before the
number of dirty NFS pages reaches the limit imposed on NFSD, so NFSD
will not deadlock on pages that it needs to write out. At least it
shouldn't.
All processes are allowed a small excess margin to avoid performing too
many calculations: ratelimit_pages.
ratelimit_pages is set so that if a thread on every CPU uses the entire
margin, the total will only go 3% over the limit, and this is much less
than the 25% bonus that PF_LESS_THROTTLE provides, so this margin
shouldn't be a problem. But it is.
The "total memory" that these 3% and 25% are calculated against are not
really total memory but are "global_dirtyable_memory()" which doesn't
include anonymous memory, just free memory and page-cache memory.
The "ratelimit_pages" number is based on whatever the
global_dirtyable_memory was on the last CPU hot-plug, which might not be
what you expect, but is probably close to the total freeable memory.
The throttle threshold uses the global_dirtable_memory at the moment
when the throttling happens, which could be much less than at the last
CPU hotplug. So if lots of anonymous memory has been allocated, thus
pushing out lots of page-cache pages, then NFSD might end up being
throttled due to dirty NFS pages because the "25%" bonus it gets is
calculated against a rather small amount of dirtyable memory, while the
"3%" margin that other processes are allowed to dirty without penalty is
calculated against a much larger number.
To remove this possibility of deadlock we need to make sure that the
margin granted to PF_LESS_THROTTLE exceeds that rate-limit margin.
Simply adding ratelimit_pages isn't enough as that should be multiplied
by the number of cpus.
So add "global_wb_domain.dirty_limit / 32" as that more accurately
reflects the current total over-shoot margin. This ensures that the
number of dirty NFS pages never gets so high that nfsd will be throttled
waiting for them to be written.
Link: http://lkml.kernel.org/r/87futgowwv.fsf@notabene.neil.brown.name
Signed-off-by: NeilBrown <neilb@suse.com>
ZONE_MOVABLE could be treated as highmem so we need to consider it for
accurate calculation of dirty pages. And, in following patches,
ZONE_CMA will be introduced and it can be treated as highmem, too. So,
instead of manually adding stat of ZONE_MOVABLE, looping all zones and
check whether the zone is highmem or not and add stat of the zone which
can be treated as highmem.
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Cc: Laura Abbott <lauraa@codeaurora.org>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
Cc: Michal Nazarewicz <mina86@mina86.com>
Pull writeback fix from Jens Axboe:
"Just a single fix for domain aware writeback, fixing a regression that
can cause balance_dirty_pages() to keep looping while not getting any
work done"
* 'for-linus' of git://git.kernel.dk/linux-block:
writeback: Fix performance regression in wb_over_bg_thresh()
Commit 947e9762a8dd ("writeback: update wb_over_bg_thresh() to use
wb_domain aware operations") unintentionally changed this function's
meaning from "are there more dirty pages than the background writeback
threshold" to "are there more dirty pages than the writeback threshold".
The background writeback threshold is typically half of the writeback
threshold, so this had the effect of raising the number of dirty pages
required to cause a writeback worker to perform background writeout.
This can cause a very severe performance regression when a BDI uses
BDI_CAP_STRICTLIMIT because balance_dirty_pages() and the writeback worker
can now disagree on whether writeback should be initiated.
For example, in a system having 1GB of RAM, a single spinning disk, and a
"pass-through" FUSE filesystem mounted over the disk, application code
mmapped a 128MB file on the disk and was randomly dirtying pages in that
mapping.
Because FUSE uses strictlimit and has a default max_ratio of only 1%, in
balance_dirty_pages, thresh is ~200, bg_thresh is ~100, and the
dirty_freerun_ceiling is the average of those, ~150. So, it pauses the
dirtying processes when we have 151 dirty pages and wakes up a background
writeback worker. But the worker tests the wrong threshold (200 instead of
100), so it does not initiate writeback and just returns.
Thus, balance_dirty_pages keeps looping, sleeping and then waking up the
worker who will do nothing. It remains stuck in this state until the few
dirty pages that we have finally expire and we write them back for that
reason. Then the whole process repeats, resulting in near-zero throughput
through the FUSE BDI.
The fix is to call the parameterized variant of wb_calc_thresh, so that the
worker will do writeback if the bg_thresh is exceeded which was the
behavior before the referenced commit.
Fixes: 947e9762a8dd ("writeback: update wb_over_bg_thresh() to use wb_domain aware operations")
Signed-off-by: Howard Cochran <hcochran@kernelspring.com>
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
Cc: <stable@vger.kernel.org> # v4.2+
Tested-by Sedat Dilek <sedat.dilek@gmail.com>
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time
ago with promise that one day it will be possible to implement page
cache with bigger chunks than PAGE_SIZE.
This promise never materialized. And unlikely will.
We have many places where PAGE_CACHE_SIZE assumed to be equal to
PAGE_SIZE. And it's constant source of confusion on whether
PAGE_CACHE_* or PAGE_* constant should be used in a particular case,
especially on the border between fs and mm.
Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much
breakage to be doable.
Let's stop pretending that pages in page cache are special. They are
not.
The changes are pretty straight-forward:
- <foo> << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- <foo> >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN};
- page_cache_get() -> get_page();
- page_cache_release() -> put_page();
This patch contains automated changes generated with coccinelle using
script below. For some reason, coccinelle doesn't patch header files.
I've called spatch for them manually.
The only adjustment after coccinelle is revert of changes to
PAGE_CAHCE_ALIGN definition: we are going to drop it later.
There are few places in the code where coccinelle didn't reach. I'll
fix them manually in a separate patch. Comments and documentation also
will be addressed with the separate patch.
virtual patch
expression E;
- E << (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
expression E;
- E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
- PAGE_CACHE_SHIFT
+ PAGE_SHIFT
- PAGE_CACHE_SIZE
+ PAGE_SIZE
- PAGE_CACHE_MASK
+ PAGE_MASK
expression E;
- PAGE_CACHE_ALIGN(E)
+ PAGE_ALIGN(E)
expression E;
- page_cache_get(E)
+ get_page(E)
expression E;
- page_cache_release(E)
+ put_page(E)
There are several users that nest lock_page_memcg() inside lock_page()
to prevent page->mem_cgroup from changing. But the page lock prevents
pages from moving between cgroups, so that is unnecessary overhead.
Remove lock_page_memcg() in contexts with locked contexts and fix the
debug code in the page stat functions to be okay with the page lock.
Acked-by: Vladimir Davydov <vdavydov@virtuozzo.com>
Now that migration doesn't clear page->mem_cgroup of live pages anymore,
it's safe to make lock_page_memcg() and the memcg stat functions take
pages, and spare the callers from memcg objects.
[akpm@linux-foundation.org: fix warnings]
Suggested-by: Vladimir Davydov <vdavydov@virtuozzo.com>
These patches tag the page cache radix tree eviction entries with the
memcg an evicted page belonged to, thus making per-cgroup LRU reclaim
work properly and be as adaptive to new cache workingsets as global
reclaim already is.
This should have been part of the original thrash detection patch
series, but was deferred due to the complexity of those patches.
This patch (of 5):
So far the only sites that needed to exclude charge migration to
stabilize page->mem_cgroup have been per-cgroup page statistics, hence
the name mem_cgroup_begin_page_stat(). But per-cgroup thrash detection
will add another site that needs to ensure page->mem_cgroup lifetime.
Rename these locking functions to the more generic lock_page_memcg() and
unlock_page_memcg(). Since charge migration is a cgroup1 feature only,
we might be able to delete it at some point, and these now easy to
identify locking sites along with it.
Calculation of dirty_ratelimit sometimes is not correct. E.g. initial
values of dirty_ratelimit == INIT_BW and step == 0, lead to the
following result:
UBSAN: Undefined behaviour in ../mm/page-writeback.c:1286:7
shift exponent 25600 is too large for 64-bit type 'long unsigned int'
The fix is straightforward - make step 0 if the shift exponent is too
big.
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Andy Shevchenko <andy.shevchenko@gmail.com>
The dirty balance reserve that dirty throttling has to consider is
merely memory not available to userspace allocations. There is nothing
writeback-specific about it. Generalize the name so that it's reusable
outside of that context.
There were still a number of references to my old Red Hat email
address in the kernel source. Remove these while keeping the
Red Hat copyright notices intact.
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Vince Weaver <vincent.weaver@maine.edu>
When building kernel with gcc 5.2, the below warning is raised:
mm/page-writeback.c: In function 'balance_dirty_pages.isra.10':
mm/page-writeback.c:1545:17: warning: 'm_dirty' may be used uninitialized in this function [-Wmaybe-uninitialized]
unsigned long m_dirty, m_thresh, m_bg_thresh;
The m_dirty{thresh, bg_thresh} are initialized in the block of "if
(mdtc)", so if mdts is null, they won't be initialized before being used.
Initialize m_dirty to zero, also initialize m_thresh and m_bg_thresh to
keep consistency.
They are used later by if condition: !mdtc || m_dirty <=
dirty_freerun_ceiling(m_thresh, m_bg_thresh)
If mdtc is null, dirty_freerun_ceiling will not be called at all, so the
initialization will not change any behavior other than just ceasing the
compile warning.
(akpm: the patch actually reduces .text size by ~20 bytes on gcc-4.x.y)
[akpm@linux-foundation.org: add comment]
Signed-off-by: Yang Shi <yang.shi@linaro.org>
For memcg domains, the amount of available memory was calculated as
min(the amount currently in use + headroom according to memcg,
total clean memory)
This isn't quite correct as what should be capped by the amount of
clean memory is the headroom, not the sum of memory in use and
headroom. For example, if a memcg domain has a significant amount of
dirty memory, the above can lead to a value which is lower than the
current amount in use which doesn't make much sense. In most
circumstances, the above leads to a number which is somewhat but not
drastically lower.
As the amount of memory which can be readily allocated to the memcg
domain is capped by the amount of system-wide clean memory which is
not already assigned to the memcg itself, the number we want is
min(headroom according to memcg, clean memory elsewhere in the system)
This patch updates mem_cgroup_wb_stats() to return the number of
filepages and headroom instead of the calculated available pages.
mdtc_cap_avail() is renamed to mdtc_calc_avail() and performs the
above calculation from file, headroom, dirty and globally clean pages.
v2: Dummy mem_cgroup_wb_stats() implementation wasn't updated leading
to build failure when !CGROUP_WRITEBACK. Fixed.
Fixes: c2aa723a6093 ("writeback: implement memcg writeback domain based throttling")
wb->memcg_completions
MDTC_INIT() is used to initialize dirty_throttle_control for memcg
domains. It used DTC_INIT_COMMON() to initialized mdtc->wb and
->wb_completions which is incorrect as DTC_INIT_COMMON() sets the
latter to wb->completions instead of wb->memcg_completions. This can
lead to wildly incorrect results when calculating the proportion of
dirty memory the memcg domain should get.
Remove DTC_INIT_COMMON() and update MDTC_INIT() to initialize
mdtc->wb_completions to wb->memcg_completions.
bdi_for_each_wb() is used in several places to wake up or issue
writeback work items to all wb's (bdi_writeback's) on a given bdi.
The iteration is performed by walking bdi->cgwb_tree; however, the
tree only indexes wb's which are currently active.
For example, when a memcg gets associated with a different blkcg, the
old wb is removed from the tree so that the new one can be indexed.
The old wb starts dying from then on but will linger till all its
inodes are drained. As these dying wb's may still host dirty inodes,
writeback operations which affect all wb's must include them.
bdi_for_each_wb() skipping dying wb's led to sync(2) missing and
failing to sync the inodes belonging to those wb's.
This patch adds a RCU protected @bdi->wb_list which lists all wb's
beloinging to that bdi. wb's are added on creation and removed on
release rather than on the start of destruction. bdi_for_each_wb()
usages are replaced with list_for_each[_continue]_rcu() iterations
over @bdi->wb_list and bdi_for_each_wb() and its helpers are removed.
v2: Updated as per Jan. last_wb ref leak in bdi_split_work_to_wbs()
fixed and unnecessary list head severing in cgwb_bdi_destroy()
removed.
Reported-and-tested-by: Artem Bityutskiy <dedekind1@gmail.com>
Fixes: ebe41ab0c79d ("writeback: implement bdi_for_each_wb()")
Link: http://lkml.kernel.org/g/1443012552.19983.209.camel@gmail.com
Cc: Jan Kara <jack@suse.cz>
iteration
laptop_mode_timer_fn() was using bdi_for_each_wb() without the
required RCU locking leading to the following warning.
WARNING: CPU: 0 PID: 0 at include/linux/backing-dev.h:415 laptop_mode_timer_fn+0x106/0x170()
Call Trace:
<IRQ> [<ffffffff81480cdc>] dump_stack+0x4e/0x82
[<ffffffff81051912>] warn_slowpath_common+0x82/0xc0
[<ffffffff81051a0a>] warn_slowpath_null+0x1a/0x20
[<ffffffff8115f0e6>] laptop_mode_timer_fn+0x106/0x170
[<ffffffff810ca8e3>] call_timer_fn+0xb3/0x2f0
[<ffffffff810cad25>] run_timer_softirq+0x205/0x370
[<ffffffff81056854>] __do_softirq+0xd4/0x460
[<ffffffff81056d69>] irq_exit+0x89/0xa0
[<ffffffff8185a892>] smp_apic_timer_interrupt+0x42/0x50
[<ffffffff81858a44>] apic_timer_interrupt+0x84/0x90
Fix it by adding rcu_read_lock() around the iteration.
Fixes: a06fd6b10228 ("writeback: make laptop_mode_timer_fn() handle multiple bdi_writeback's")
Reviewed-by: Jan Kara <jack@suse.com>
