path: root/mm/page_alloc.c
2008-04-30infrastructure to debug (dynamic) objectsThomas Gleixner
We can see an ever repeating problem pattern with objects of any kind in the kernel: 1) freeing of active objects 2) reinitialization of active objects Both problems can be hard to debug because the crash happens at a point where we have no chance to decode the root cause anymore. One problem spot are kernel timers, where the detection of the problem often happens in interrupt context and usually causes the machine to panic. While working on a timer related bug report I had to hack specialized code into the timer subsystem to get a reasonable hint for the root cause. This debug hack was fine for temporary use, but far from a mergeable solution due to the intrusiveness into the timer code. The code further lacked the ability to detect and report the root cause instantly and keep the system operational. Keeping the system operational is important to get hold of the debug information without special debugging aids like serial consoles and special knowledge of the bug reporter. The problems described above are not restricted to timers, but timers tend to expose it usually in a full system crash. Other objects are less explosive, but the symptoms caused by such mistakes can be even harder to debug. Instead of creating specialized debugging code for the timer subsystem a generic infrastructure is created which allows developers to verify their code and provides an easy to enable debug facility for users in case of trouble. The debugobjects core code keeps track of operations on static and dynamic objects by inserting them into a hashed list and sanity checking them on object operations and provides additional checks whenever kernel memory is freed. The tracked object operations are: - initializing an object - adding an object to a subsystem list - deleting an object from a subsystem list Each operation is sanity checked before the operation is executed and the subsystem specific code can provide a fixup function which allows to prevent the damage of the operation. When the sanity check triggers a warning message and a stack trace is printed. The list of operations can be extended if the need arises. For now it's limited to the requirements of the first user (timers). The core code enqueues the objects into hash buckets. The hash index is generated from the address of the object to simplify the lookup for the check on kfree/vfree. Each bucket has it's own spinlock to avoid contention on a global lock. The debug code can be compiled in without being active. The runtime overhead is minimal and could be optimized by asm alternatives. A kernel command line option enables the debugging code. Thanks to Ingo Molnar for review, suggestions and cleanup patches. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Greg KH <greg@kroah.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29page allocator: smarter retry of costly-order allocationsNishanth Aravamudan
Because of page order checks in __alloc_pages(), hugepage (and similarly large order) allocations will not retry unless explicitly marked __GFP_REPEAT. However, the current retry logic is nearly an infinite loop (or until reclaim does no progress whatsoever). For these costly allocations, that seems like overkill and could potentially never terminate. Mel observed that allowing current __GFP_REPEAT semantics for hugepage allocations essentially killed the system. I believe this is because we may continue to reclaim small orders of pages all over, but never have enough to satisfy the hugepage allocation request. This is clearly only a problem for large order allocations, of which hugepages are the most obvious (to me). Modify try_to_free_pages() to indicate how many pages were reclaimed. Use that information in __alloc_pages() to eventually fail a large __GFP_REPEAT allocation when we've reclaimed an order of pages equal to or greater than the allocation's order. This relies on lumpy reclaim functioning as advertised. Due to fragmentation, lumpy reclaim may not be able to free up the order needed in one invocation, so multiple iterations may be requred. In other words, the more fragmented memory is, the more retry attempts __GFP_REPEAT will make (particularly for higher order allocations). This changes the semantics of __GFP_REPEAT subtly, but *only* for allocations > PAGE_ALLOC_COSTLY_ORDER. With this patch, for those size allocations, we will try up to some point (at least 1<<order reclaimed pages), rather than forever (which is the case for allocations <= PAGE_ALLOC_COSTLY_ORDER). This change improves the /proc/sys/vm/nr_hugepages interface with a follow-on patch that makes pool allocations use __GFP_REPEAT. Rather than administrators repeatedly echo'ing a particular value into the sysctl, and forcing reclaim into action manually, this change allows for the sysctl to attempt a reasonable effort itself. Similarly, dynamic pool growth should be more successful under load, as lumpy reclaim can try to free up pages, rather than failing right away. Choosing to reclaim only up to the order of the requested allocation strikes a balance between not failing hugepage allocations and returning to the caller when it's unlikely to every succeed. Because of lumpy reclaim, if we have freed the order requested, hopefully it has been in big chunks and those chunks will allow our allocation to succeed. If that isn't the case after freeing up the current order, I don't think it is likely to succeed in the future, although it is possible given a particular fragmentation pattern. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Cc: Andy Whitcroft <apw@shadowen.org> Tested-by: Mel Gorman <mel@csn.ul.ie> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29mm: fix misleading __GFP_REPEAT related commentsNishanth Aravamudan
The definition and use of __GFP_REPEAT, __GFP_NOFAIL and __GFP_NORETRY in the core VM have somewhat differing comments as to their actual semantics. Annoyingly, the flags definition has inline and header comments, which might be interpreted as not being equivalent. Just add references to the header comments in the inline ones so they don't go out of sync in the future. In their use in __alloc_pages() clarify that the current implementation treats low-order allocations and __GFP_REPEAT allocations as distinct cases. To clarify, the flags' semantics are: __GFP_NORETRY means try no harder than one run through __alloc_pages __GFP_REPEAT means __GFP_NOFAIL __GFP_NOFAIL means repeat forever order <= PAGE_ALLOC_COSTLY_ORDER means __GFP_NOFAIL Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29mm: fix usemap initializationKAMEZAWA Hiroyuki
usemap must be initialized only when pfn is within zone. If not, it corrupts memory. And this patch also reduces the number of calls to set_pageblock_migratetype() from (pfn & (pageblock_nr_pages -1) to !(pfn & (pageblock_nr_pages-1) it should be called once per pageblock. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Cc: Hugh Dickins <hugh@veritas.com> Cc: Shi Weihua <shiwh@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mm/page_alloc.c: remove hand-coded get_order()Pavel Machek
Remove hand-coded get_order() from page_alloc.c. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28memory hotplug: free memmaps allocated by bootmemYasunori Goto
This patch is to free memmaps which is allocated by bootmem. Freeing usemap is not necessary. The pages of usemap may be necessary for other sections. If removing section is last section on the node, its section is the final user of usemap page. (usemaps are allocated on its section by previous patch.) But it shouldn't be freed too, because the section must be logical offline state which all pages are isolated against page allocater. If it is freed, page alloctor may use it which will be removed physically soon. It will be disaster. So, this patch keeps it as it is. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Badari Pulavarty <pbadari@us.ibm.com> Cc: Yinghai Lu <yhlu.kernel@gmail.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28pageflags: eliminate PG_xxx aliasesChristoph Lameter
Remove aliases of PG_xxx. We can easily drop those now and alias by specifying the PG_xxx flag in the macro that generates the functions. Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Andy Whitcroft <apw@shadowen.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mm/page_alloc.c: fix indentationS.Caglar Onur
zlc_setup(): handle jiffies wraparound (10ed273f5016c582413dfbc468dd084957d847e1) changes tab with spaces Signed-off-by: S.Caglar Onur <caglar@pardus.org.tr> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mm: filter based on a nodemask as well as a gfp_maskMel Gorman
The MPOL_BIND policy creates a zonelist that is used for allocations controlled by that mempolicy. As the per-node zonelist is already being filtered based on a zone id, this patch adds a version of __alloc_pages() that takes a nodemask for further filtering. This eliminates the need for MPOL_BIND to create a custom zonelist. A positive benefit of this is that allocations using MPOL_BIND now use the local node's distance-ordered zonelist instead of a custom node-id-ordered zonelist. I.e., pages will be allocated from the closest allowed node with available memory. [Lee.Schermerhorn@hp.com: Mempolicy: update stale documentation and comments] [Lee.Schermerhorn@hp.com: Mempolicy: make dequeue_huge_page_vma() obey MPOL_BIND nodemask] [Lee.Schermerhorn@hp.com: Mempolicy: make dequeue_huge_page_vma() obey MPOL_BIND nodemask rework] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mm: have zonelist contains structs with both a zone pointer and zone_idxMel Gorman
Filtering zonelists requires very frequent use of zone_idx(). This is costly as it involves a lookup of another structure and a substraction operation. As the zone_idx is often required, it should be quickly accessible. The node idx could also be stored here if it was found that accessing zone->node is significant which may be the case on workloads where nodemasks are heavily used. This patch introduces a struct zoneref to store a zone pointer and a zone index. The zonelist then consists of an array of these struct zonerefs which are looked up as necessary. Helpers are given for accessing the zone index as well as the node index. [kamezawa.hiroyu@jp.fujitsu.com: Suggested struct zoneref instead of embedding information in pointers] [hugh@veritas.com: mm-have-zonelist: fix memcg ooms] [hugh@veritas.com: just return do_try_to_free_pages] [hugh@veritas.com: do_try_to_free_pages gfp_mask redundant] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Christoph Lameter <clameter@sgi.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Christoph Lameter <clameter@sgi.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mm: use two zonelist that are filtered by GFP maskMel Gorman
Currently a node has two sets of zonelists, one for each zone type in the system and a second set for GFP_THISNODE allocations. Based on the zones allowed by a gfp mask, one of these zonelists is selected. All of these zonelists consume memory and occupy cache lines. This patch replaces the multiple zonelists per-node with two zonelists. The first contains all populated zones in the system, ordered by distance, for fallback allocations when the target/preferred node has no free pages. The second contains all populated zones in the node suitable for GFP_THISNODE allocations. An iterator macro is introduced called for_each_zone_zonelist() that interates through each zone allowed by the GFP flags in the selected zonelist. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Christoph Lameter <clameter@sgi.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mm: remember what the preferred zone is for zone_statisticsMel Gorman
On NUMA, zone_statistics() is used to record events like numa hit, miss and foreign. It assumes that the first zone in a zonelist is the preferred zone. When multiple zonelists are replaced by one that is filtered, this is no longer the case. This patch records what the preferred zone is rather than assuming the first zone in the zonelist is it. This simplifies the reading of later patches in this set. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Christoph Lameter <clameter@sgi.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mm: introduce node_zonelist() for accessing the zonelist for a GFP maskMel Gorman
Introduce a node_zonelist() helper function. It is used to lookup the appropriate zonelist given a node and a GFP mask. The patch on its own is a cleanup but it helps clarify parts of the two-zonelist-per-node patchset. If necessary, it can be merged with the next patch in this set without problems. Reviewed-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Christoph Lameter <clameter@sgi.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mm: use zonelists instead of zones when direct reclaiming pagesMel Gorman
The following patches replace multiple zonelists per node with two zonelists that are filtered based on the GFP flags. The patches as a set fix a bug with regard to the use of MPOL_BIND and ZONE_MOVABLE. With this patchset, the MPOL_BIND will apply to the two highest zones when the highest zone is ZONE_MOVABLE. This should be considered as an alternative fix for the MPOL_BIND+ZONE_MOVABLE in 2.6.23 to the previously discussed hack that filters only custom zonelists. The first patch cleans up an inconsistency where direct reclaim uses zonelist->zones where other places use zonelist. The second patch introduces a helper function node_zonelist() for looking up the appropriate zonelist for a GFP mask which simplifies patches later in the set. The third patch defines/remembers the "preferred zone" for numa statistics, as it is no longer always the first zone in a zonelist. The forth patch replaces multiple zonelists with two zonelists that are filtered. The two zonelists are due to the fact that the memoryless patchset introduces a second set of zonelists for __GFP_THISNODE. The fifth patch introduces helper macros for retrieving the zone and node indices of entries in a zonelist. The final patch introduces filtering of the zonelists based on a nodemask. Two zonelists exist per node, one for normal allocations and one for __GFP_THISNODE. Performance results varied depending on the machine configuration. In real workloads the gain/loss will depend on how much the userspace portion of the benchmark benefits from having more cache available due to reduced referencing of zonelists. These are the range of performance losses/gains when running against 2.6.24-rc4-mm1. The set and these machines are a mix of i386, x86_64 and ppc64 both NUMA and non-NUMA. loss to gain Total CPU time on Kernbench: -0.86% to 1.13% Elapsed time on Kernbench: -0.79% to 0.76% page_test from aim9: -4.37% to 0.79% brk_test from aim9: -0.71% to 4.07% fork_test from aim9: -1.84% to 4.60% exec_test from aim9: -0.71% to 1.08% This patch: The allocator deals with zonelists which indicate the order in which zones should be targeted for an allocation. Similarly, direct reclaim of pages iterates over an array of zones. For consistency, this patch converts direct reclaim to use a zonelist. No functionality is changed by this patch. This simplifies zonelist iterators in the next patch. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Christoph Lameter <clameter@sgi.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-19nodemask: use new node_to_cpumask_ptr functionMike Travis
* Use new node_to_cpumask_ptr. This creates a pointer to the cpumask for a given node. This definition is in mm patch: asm-generic-add-node_to_cpumask_ptr-macro.patch * Use new set_cpus_allowed_ptr function. Depends on: [mm-patch]: asm-generic-add-node_to_cpumask_ptr-macro.patch [sched-devel]: sched: add new set_cpus_allowed_ptr function [x86/latest]: x86: add cpus_scnprintf function Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Greg Banks <gnb@melbourne.sgi.com> Cc: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-03-04memcg: bad page if page_cgroup when freeHugh Dickins
Replace free_hot_cold_page's VM_BUG_ON(page_get_page_cgroup(page)) by a "Bad page state" and clear: most users don't have CONFIG_DEBUG_VM on, and if it were set here, it'd likely cause corruption when the page is reused. Don't use page_assign_page_cgroup to clear it: that should be private to memcontrol.c, and always called with the lock taken; and memmap_init_zone doesn't need it either - like page->mapping and other pointers throughout the kernel, Linux assumes pointers in zeroed structures are NULL pointers. Instead use page_reset_bad_cgroup, added to memcontrol.h for this only. Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: David Rientjes <rientjes@google.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hirokazu Takahashi <taka@valinux.co.jp> Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04zlc_setup(): handle jiffies wraparoundKOSAKI Motohiro
jiffies subtraction may cause an overflow problem. It should be using time_after(). [akpm@linux-foundation.org: include jiffies.h] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Paul Jackson <pj@sgi.com> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-23Solve section mismatch for free_area_init_core.Alexander van Heukelum
WARNING: vmlinux.o(.meminit.text+0x649): Section mismatch in reference from the function free_area_init_core() to the function .init.text:setup_usemap() The function __meminit free_area_init_core() references a function __init setup_usemap(). If free_area_init_core is only used by setup_usemap then annotate free_area_init_core with a matching annotation. The warning is covers this stack of functions in mm/page_alloc.c: alloc_bootmem_node must be marked __init. alloc_bootmem_node is used by setup_usemap, if !SPARSEMEM. (usemap_size is only used by setup_usemap, if !SPARSEMEM.) setup_usemap is only used by free_area_init_core. free_area_init_core is only used by free_area_init_node. free_area_init_node is used by: arch/alpha/mm/numa.c: __init paging_init() arch/arm/mm/init.c: __init bootmem_init_node() arch/avr32/mm/init.c: __init paging_init() arch/cris/arch-v10/mm/init.c: __init paging_init() arch/cris/arch-v32/mm/init.c: __init paging_init() arch/m32r/mm/discontig.c: __init zone_sizes_init() arch/m32r/mm/init.c: __init zone_sizes_init() arch/m68k/mm/motorola.c: __init paging_init() arch/m68k/mm/sun3mmu.c: __init paging_init() arch/mips/sgi-ip27/ip27-memory.c: __init paging_init() arch/parisc/mm/init.c: __init paging_init() arch/sparc/mm/srmmu.c: __init srmmu_paging_init() arch/sparc/mm/sun4c.c: __init sun4c_paging_init() arch/sparc64/mm/init.c: __init paging_init() mm/page_alloc.c: __init free_area_init_nodes() mm/page_alloc.c: __init free_area_init() and mm/memory_hotplug.c: hotadd_new_pgdat() hotadd_new_pgdat can not be an __init function, but: It is compiled for MEMORY_HOTPLUG configurations only MEMORY_HOTPLUG depends on SPARSEMEM || X86_64_ACPI_NUMA X86_64_ACPI_NUMA depends on X86_64 ARCH_FLATMEM_ENABLE depends on X86_32 ARCH_DISCONTIGMEM_ENABLE depends on X86_32 So X86_64_ACPI_NUMA implies SPARSEMEM, right? So we can mark the stack of functions __init for !SPARSEMEM, but we must mark them __meminit for SPARSEMEM configurations. This is ok, because then the calls to alloc_bootmem_node are also avoided. Compile-tested on: silly minimal config defconfig x86_32 defconfig x86_64 defconfig x86_64 -HIBERNATION +MEMORY_HOTPLUG Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Reviewed-by: Sam Ravnborg <sam@ravnborg.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08misc: removal of final callers using fastcallHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Memory controller: memory accountingBalbir Singh
Add the accounting hooks. The accounting is carried out for RSS and Page Cache (unmapped) pages. There is now a common limit and accounting for both. The RSS accounting is accounted at page_add_*_rmap() and page_remove_rmap() time. Page cache is accounted at add_to_page_cache(), __delete_from_page_cache(). Swap cache is also accounted for. Each page's page_cgroup is protected with the last bit of the page_cgroup pointer, this makes handling of race conditions involving simultaneous mappings of a page easier. A reference count is kept in the page_cgroup to deal with cases where a page might be unmapped from the RSS of all tasks, but still lives in the page cache. Credits go to Vaidyanathan Srinivasan for helping with reference counting work of the page cgroup. Almost all of the page cache accounting code has help from Vaidyanathan Srinivasan. [hugh@veritas.com: fix swapoff breakage] [akpm@linux-foundation.org: fix locking] Signed-off-by: Vaidyanathan Srinivasan <svaidy@linux.vnet.ibm.com> Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Pavel Emelianov <xemul@openvz.org> Cc: Paul Menage <menage@google.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Kirill Korotaev <dev@sw.ru> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: David Rientjes <rientjes@google.com> Cc: <Valdis.Kletnieks@vt.edu> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05Include count of pagecache pages in show_mem() outputLarry Woodman
The show_mem() output does not include the total number of pagecache pages. This would be helpful when analyzing the debug information in the /var/log/messages file after OOM kills occur. This patch includes the total pagecache pages in that output. Signed-off-by: Larry Woodman <lwoodman@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05mm: remove fastcall from mm/Harvey Harrison
fastcall is always defined to be empty, remove it [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05page allocator: remove unused arguments in zone_init_free_lists()Andi Kleen
Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05Page allocator: get rid of the list of cold pagesChristoph Lameter
We have repeatedly discussed if the cold pages still have a point. There is one way to join the two lists: Use a single list and put the cold pages at the end and the hot pages at the beginning. That way a single list can serve for both types of allocations. The discussion of the RFC for this and Mel's measurements indicate that there may not be too much of a point left to having separate lists for hot and cold pages (see http://marc.info/?t=119492914200001&r=1&w=2). Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Martin Bligh <mbligh@mbligh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05Page allocator: clean up pcp draining functionsChristoph Lameter
- Add comments explaing how drain_pages() works. - Eliminate useless functions - Rename drain_all_local_pages to drain_all_pages(). It does drain all pages not only those of the local processor. - Eliminate useless interrupt off / on sequences. drain_pages() disables interrupts on its own. The execution thread is pinned to processor by the caller. So there is no need to disable interrupts. - Put drain_all_pages() declaration in gfp.h and remove the declarations from suspend.h and from mm/memory_hotplug.c - Make software suspend call drain_all_pages(). The draining of processor local pages is may not the right approach if software suspend wants to support SMP. If they call drain_all_pages then we can make drain_pages() static. [akpm@linux-foundation.org: fix build] Signed-off-by: Christoph Lameter <clameter@sgi.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Daniel Walker <dwalker@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-17mm: fix section mismatch warning in page_alloc.cSam Ravnborg
With CONFIG_HOTPLUG=n and CONFIG_HOTPLUG_CPU=y we saw following warning: WARNING: mm/built-in.o(.text+0x6864): Section mismatch: reference to .init.text: (between 'process_zones' and 'pageset_cpuup_callback') The culprit was zone_batchsize() which were annotated __devinit but used from process_zones() which is annotated __cpuinit. zone_batchsize() are used from another function annotated __meminit so the only valid option is to drop the annotation of zone_batchsize() so we know it is always valid to use it. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-08Fix crash with FLAT_MEMORY and ARCH_PFN_OFFSET != 0Thomas Bogendoerfer
When using FLAT_MEMORY and ARCH_PFN_OFFSET is not 0, the kernel crashes in memmap_init_zone(). This bug got introduced by commit c713216deebd95d2b0ab38fef8bb2361c0180c2d Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Acked-by: Mel Gorman <mel@csn.ul.ie> Cc: Bob Picco <bob.picco@hp.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Andi Kleen <ak@muc.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "Keith Mannthey" <kmannth@gmail.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-17mm: fix page allocation for larger I/O segmentsMel Gorman
In some cases the IO subsystem is able to merge requests if the pages are adjacent in physical memory. This was achieved in the allocator by having expand() return pages in physically contiguous order in situations were a large buddy was split. However, list-based anti-fragmentation changed the order pages were returned in to avoid searching in buffered_rmqueue() for a page of the appropriate migrate type. This patch restores behaviour of rmqueue_bulk() preserving the physical order of pages returned by the allocator without incurring increased search costs for anti-fragmentation. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Mark Lord <mlord@pobox.com Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-29Fix boot problem with iSeries lacking hugepage supportMel Gorman
Ordinarily the size of a pageblock is determined at compile-time based on the hugepage size. On PPC64, the hugepage size is determined at runtime based on what is supported by the machine. With legacy machines such as iSeries that do not support hugepages, HPAGE_SHIFT is 0. This results in pageblock_order being set to -PAGE_SHIFT and a crash results shortly afterwards. This patch adds a function to select a sensible value for pageblock order by default when HUGETLB_PAGE_SIZE_VARIABLE is set. It checks that HPAGE_SHIFT is a sensible value before using the hugepage size; if it is not MAX_ORDER-1 is used. This is a fix for 2.6.24. Credit goes to Stephen Rothwell for identifying the bug and testing candidate patches. Additional credit goes to Andy Whitcroft for spotting a problem with respects to IA-64 before releasing. Additional credit to David Gibson for testing with the libhugetlbfs test suite. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Tested-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-28prep_zero_page: remove bogus BUG_ONHugh Dickins
2.6.11 gave __GFP_ZERO's prep_zero_page a bogus "highmem may have to wait" assertion. Presumably added under the misconception that clear_highpage uses nonatomic kmap; but then and now it uses kmap_atomic, so no problem. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-12Revert "Bias the placement of kernel pages at lower PFNs"Linus Torvalds
This reverts commit 5adc5be7cd1bcef6bb64f5255d2a33f20a3cf5be. Alexey Dobriyan reports that it causes huge slowdowns under some loads, in his case a "mkfs.ext2" on a 30G partition. With the placement bias, the mkfs took over four minutes, with it reverted it's back to about ten seconds for Alexey. Reported-and-tested-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-20spelling fixes: mm/Simon Arlott
Spelling fixes in mm/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-17oom: serialize out of memory callsDavid Rientjes
A final allocation attempt with a very high watermark needs to be attempted before invoking out_of_memory(). OOM killer serialization needs to occur before this final attempt, otherwise tasks attempting to OOM-lock all zones in its zonelist may spin and acquire the lock unnecessarily after the OOM condition has already been alleviated. If the final allocation does succeed, the zonelist is simply OOM-unlocked and __alloc_pages() returns the page. Otherwise, the OOM killer is invoked. If the task cannot acquire OOM-locks on all zones in its zonelist, it is put to sleep and the allocation is retried when it gets rescheduled. One of its zones is already marked as being in the OOM killer so it'll hopefully be getting some free memory soon, at least enough to satisfy a high watermark allocation attempt. This prevents needlessly killing a task when the OOM condition would have already been alleviated if it had simply been given enough time. Cc: Andrea Arcangeli <andrea@suse.de> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17oom: change all_unreclaimable zone member to flagsDavid Rientjes
Convert the int all_unreclaimable member of struct zone to unsigned long flags. This can now be used to specify several different zone flags such as all_unreclaimable and reclaim_in_progress, which can now be removed and converted to a per-zone flag. Flags are set and cleared as follows: zone_set_flag(struct zone *zone, zone_flags_t flag) zone_clear_flag(struct zone *zone, zone_flags_t flag) Defines the first zone flags, ZONE_ALL_UNRECLAIMABLE and ZONE_RECLAIM_LOCKED, which have the same semantics as the old zone->all_unreclaimable and zone->reclaim_in_progress, respectively. Also converts all current users that set or clear either flag to use the new interface. Helper functions are defined to test the flags: int zone_is_all_unreclaimable(const struct zone *zone) int zone_is_reclaim_locked(const struct zone *zone) All flag operators are of the atomic variety because there are currently readers that are implemented that do not take zone->lock. [akpm@linux-foundation.org: add needed include] Cc: Andrea Arcangeli <andrea@suse.de> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17oom: move prototypes to appropriate header fileDavid Rientjes
Move the OOM killer's extern function prototypes to include/linux/oom.h and include it where necessary. [clg@fr.ibm.com: build fix] Cc: Andrea Arcangeli <andrea@suse.de> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16memory unplug: page offlineKAMEZAWA Hiroyuki
Logic. - set all pages in [start,end) as isolated migration-type. by this, all free pages in the range will be not-for-use. - Migrate all LRU pages in the range. - Test all pages in the range's refcnt is zero or not. Todo: - allocate migration destination page from better area. - confirm page_count(page)== 0 && PageReserved(page) page is safe to be freed.. (I don't like this kind of page but.. - Find out pages which cannot be migrated. - more running tests. - Use reclaim for unplugging other memory type area. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16memory unplug: page isolationKAMEZAWA Hiroyuki
Implement generic chunk-of-pages isolation method by using page grouping ops. This patch add MIGRATE_ISOLATE to MIGRATE_TYPES. By this - MIGRATE_TYPES increases. - bitmap for migratetype is enlarged. pages of MIGRATE_ISOLATE migratetype will not be allocated even if it is free. By this, you can isolated *freed* pages from users. How-to-free pages is not a purpose of this patch. You may use reclaim and migrate codes to free pages. If start_isolate_page_range(start,end) is called, - migratetype of the range turns to be MIGRATE_ISOLATE if its type is MIGRATE_MOVABLE. (*) this check can be updated if other memory reclaiming works make progress. - MIGRATE_ISOLATE is not on migratetype fallback list. - All free pages and will-be-freed pages are isolated. To check all pages in the range are isolated or not, use test_pages_isolated(), To cancel isolation, use undo_isolate_page_range(). Changes V6 -> V7 - removed unnecessary #ifdef There are HOLES_IN_ZONE handling codes...I'm glad if we can remove them.. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Breakout page_order() to internal.h to avoid special knowledge of the buddy ↵Mel Gorman
allocator The statistics patch later needs to know what order a free page is on the free lists. Rather than having special knowledge of page_private() when PageBuddy() is set, this patch places out page_order() in internal.h and adds a VM_BUG_ON to catch using it on non-PageBuddy pages. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Christoph Lameter <clameter@sgi.com> Acked-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16mm/page_alloc.c: make code staticAdrian Bunk
This patch makes needlessly global code static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Print out statistics in relation to fragmentation avoidance to ↵Mel Gorman
/proc/pagetypeinfo This patch provides fragmentation avoidance statistics via /proc/pagetypeinfo. The information is collected only on request so there is no runtime overhead. The statistics are in three parts: The first part prints information on the size of blocks that pages are being grouped on and looks like Page block order: 10 Pages per block: 1024 The second part is a more detailed version of /proc/buddyinfo and looks like Free pages count per migrate type at order 0 1 2 3 4 5 6 7 8 9 10 Node 0, zone DMA, type Unmovable 0 0 0 0 0 0 0 0 0 0 0 Node 0, zone DMA, type Reclaimable 1 0 0 0 0 0 0 0 0 0 0 Node 0, zone DMA, type Movable 0 0 0 0 0 0 0 0 0 0 0 Node 0, zone DMA, type Reserve 0 4 4 0 0 0 0 1 0 1 0 Node 0, zone Normal, type Unmovable 111 8 4 4 2 3 1 0 0 0 0 Node 0, zone Normal, type Reclaimable 293 89 8 0 0 0 0 0 0 0 0 Node 0, zone Normal, type Movable 1 6 13 9 7 6 3 0 0 0 0 Node 0, zone Normal, type Reserve 0 0 0 0 0 0 0 0 0 0 4 The third part looks like Number of blocks type Unmovable Reclaimable Movable Reserve Node 0, zone DMA 0 1 2 1 Node 0, zone Normal 3 17 94 4 To walk the zones within a node with interrupts disabled, walk_zones_in_node() is introduced and shared between /proc/buddyinfo, /proc/zoneinfo and /proc/pagetypeinfo to reduce code duplication. It seems specific to what vmstat.c requires but could be broken out as a general utility function in mmzone.c if there were other other potential users. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Andy Whitcroft <apw@shadowen.org> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Do not depend on MAX_ORDER when grouping pages by mobilityMel Gorman
Currently mobility grouping works at the MAX_ORDER_NR_PAGES level. This makes sense for the majority of users where this is also the huge page size. However, on platforms like ia64 where the huge page size is runtime configurable it is desirable to group at a lower order. On x86_64 and occasionally on x86, the hugepage size may not always be MAX_ORDER_NR_PAGES. This patch groups pages together based on the value of HUGETLB_PAGE_ORDER. It uses a compile-time constant if possible and a variable where the huge page size is runtime configurable. It is assumed that grouping should be done at the lowest sensible order and that the user would not want to override this. If this is not true, page_block order could be forced to a variable initialised via a boot-time kernel parameter. One potential issue with this patch is that IA64 now parses hugepagesz with early_param() instead of __setup(). __setup() is called after the memory allocator has been initialised and the pageblock bitmaps already setup. In tests on one IA64 there did not seem to be any problem with using early_param() and in fact may be more correct as it guarantees the parameter is handled before the parsing of hugepages=. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Andy Whitcroft <apw@shadowen.org> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Fix calculation in move_freepages_block for counting pagesMel Gorman
move_freepages_block() returns the number of blocks moved. This value is used to determine if a block of pages should be stolen for the exclusive use of a migrate type or not. However, the value returned is being used correctly. This patch fixes the calculation to return the number of base pages that have been moved. This should be considered a fix to the patch move-free-pages-between-lists-on-steal.patch Credit to Andy Whitcroft for spotting the problem. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Andy Whitcroft <apw@shadowen.org> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16don't group high order atomic allocationsMel Gorman
Grouping high-order atomic allocations together was intended to allow bursty users of atomic allocations to work such as e1000 in situations where their preallocated buffers were depleted. This did not work in at least one case with a wireless network adapter needing order-1 allocations frequently. To resolve that, the free pages used for min_free_kbytes were moved to separate contiguous blocks with the patch bias-the-location-of-pages-freed-for-min_free_kbytes-in-the-same-max_order_nr_pages-blocks. It is felt that keeping the free pages in the same contiguous blocks should be sufficient for bursty short-lived high-order atomic allocations to succeed, maybe even with the e1000. Even if there is a failure, increasing the value of min_free_kbytes will free pages as contiguous bloks in contrast to the standard buddy allocator which makes no attempt to keep the minimum number of free pages contiguous. This patch backs out grouping high order atomic allocations together to determine if it is really needed or not. If a new report comes in about high-order atomic allocations failing, the feature can be reintroduced to determine if it fixes the problem or not. As a side-effect, this patch reduces by 1 the number of bits required to track the mobility type of pages within a MAX_ORDER_NR_PAGES block. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16remove PAGE_GROUP_BY_MOBILITYMel Gorman
Grouping pages by mobility can be disabled at compile-time. This was considered undesirable by a number of people. However, in the current stack of patches, it is not a simple case of just dropping the configurable patch as it would cause merge conflicts. This patch backs out the configuration option. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Bias the location of pages freed for min_free_kbytes in the same ↵Mel Gorman
MAX_ORDER_NR_PAGES blocks The standard buddy allocator always favours the smallest block of pages. The effect of this is that the pages free to satisfy min_free_kbytes tends to be preserved since boot time at the same location of memory ffor a very long time and as a contiguous block. When an administrator sets the reserve at 16384 at boot time, it tends to be the same MAX_ORDER blocks that remain free. This allows the occasional high atomic allocation to succeed up until the point the blocks are split. In practice, it is difficult to split these blocks but when they do split, the benefit of having min_free_kbytes for contiguous blocks disappears. Additionally, increasing min_free_kbytes once the system has been running for some time has no guarantee of creating contiguous blocks. On the other hand, CONFIG_PAGE_GROUP_BY_MOBILITY favours splitting large blocks when there are no free pages of the appropriate type available. A side-effect of this is that all blocks in memory tends to be used up and the contiguous free blocks from boot time are not preserved like in the vanilla allocator. This can cause a problem if a new caller is unwilling to reclaim or does not reclaim for long enough. A failure scenario was found for a wireless network device allocating order-1 atomic allocations but the allocations were not intense or frequent enough for a whole block of pages to be preserved for MIGRATE_HIGHALLOC. This was reproduced on a desktop by booting with mem=256mb, forcing the driver to allocate at order-1, running a bittorrent client (downloading a debian ISO) and building a kernel with -j2. This patch addresses the problem on the desktop machine booted with mem=256mb. It works by setting aside a reserve of MAX_ORDER_NR_PAGES blocks, the number of which depends on the value of min_free_kbytes. These blocks are only fallen back to when there is no other free pages. Then the smallest possible page is used just like the normal buddy allocator instead of the largest possible page to preserve contiguous pages The pages in free lists in the reserve blocks are never taken for another migrate type. The results is that even if min_free_kbytes is set to a low value, contiguous blocks will be preserved in the MIGRATE_RESERVE blocks. This works better than the vanilla allocator because if min_free_kbytes is increased, a new reserve block will be chosen based on the location of reclaimable pages and the block will free up as contiguous pages. In the vanilla allocator, no effort is made to target a block of pages to free as contiguous pages and min_free_kbytes pages are scattered randomly. This effect has been observed on the test machine. min_free_kbytes was set initially low but it was kept as a contiguous free block within MIGRATE_RESERVE. min_free_kbytes was then set to a higher value and over a period of time, the free blocks were within the reserve and coalescing. How long it takes to free up depends on how quickly LRU is rotating. Amusingly, this means that more activity will free the blocks faster. This mechanism potentially replaces MIGRATE_HIGHALLOC as it may be more effective than grouping contiguous free pages together. It all depends on whether the number of active atomic high allocations exceeds min_free_kbytes or not. If the number of active allocations exceeds min_free_kbytes, it's worth it but maybe in that situation, min_free_kbytes should be set higher. Once there are no more reports of allocation failures, a patch will be submitted that backs out MIGRATE_HIGHALLOC and see if the reports stay missing. Credit to Mariusz Kozlowski for discovering the problem, describing the failure scenario and testing patches and scenarios. [akpm@linux-foundation.org: cleanups] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Be more agressive about stealing when MIGRATE_RECLAIMABLE allocations fallbackMel Gorman
MIGRATE_RECLAIMABLE allocations tend to be very bursty in nature like when updatedb starts. It is likely this will occur in situations where MAX_ORDER blocks of pages are not free. This means that updatedb can scatter MIGRATE_RECLAIMABLE pages throughout the address space. This patch is more agressive about stealing blocks of pages for MIGRATE_RECLAIMABLE. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Bias the placement of kernel pages at lower PFNsMel Gorman
This patch chooses blocks with lower PFNs when placing kernel allocations. This is particularly important during fallback in low memory situations to stop unmovable pages being placed throughout the entire address space. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Do not group pages by mobility type on low memory systemsMel Gorman
Grouping pages by mobility can only successfully operate when there are more MAX_ORDER_NR_PAGES areas than mobility types. When there are insufficient areas, fallbacks cannot be avoided. This has noticeable performance impacts on machines with small amounts of memory in comparison to MAX_ORDER_NR_PAGES. For example, on IA64 with a configuration including huge pages spans 1GiB with MAX_ORDER_NR_PAGES so would need at least 4GiB of RAM before grouping pages by mobility would be useful. In comparison, an x86 would need 16MB. This patch checks the size of vm_total_pages in build_all_zonelists(). If there are not enough areas, mobility is effectivly disabled by considering all allocations as the same type (UNMOVABLE). This is achived via a __read_mostly flag. With this patch, performance is comparable to disabling grouping pages by mobility at compile-time on a test machine with insufficient memory. With this patch, it is reasonable to get rid of grouping pages by mobility a compile-time option. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Group high-order atomic allocationsMel Gorman
In rare cases, the kernel needs to allocate a high-order block of pages without sleeping. For example, this is the case with e1000 cards configured to use jumbo frames. Migrating or reclaiming pages in this situation is not an option. This patch groups these allocations together as much as possible by adding a new MIGRATE_TYPE. The MIGRATE_HIGHATOMIC type are exactly what they sound like. Care is taken that pages of other migrate types do not use the same blocks as high-order atomic allocations. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Group short-lived and reclaimable kernel allocationsMel Gorman
This patch marks a number of allocations that are either short-lived such as network buffers or are reclaimable such as inode allocations. When something like updatedb is called, long-lived and unmovable kernel allocations tend to be spread throughout the address space which increases fragmentation. This patch groups these allocations together as much as possible by adding a new MIGRATE_TYPE. The MIGRATE_RECLAIMABLE type is for allocations that can be reclaimed on demand, but not moved. i.e. they can be migrated by deleting them and re-reading the information from elsewhere. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
