path: root/mm/page_cgroup.c
2009-06-18memcg: remove some redundant checksLi Zefan
We don't need to check do_swap_account in the case that the function which checks do_swap_account will never get called if do_swap_account == 0. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18memcg: add file-based RSS accountingBalbir Singh
Add file RSS tracking per memory cgroup We currently don't track file RSS, the RSS we report is actually anon RSS. All the file mapped pages, come in through the page cache and get accounted there. This patch adds support for accounting file RSS pages. It should 1. Help improve the metrics reported by the memory resource controller 2. Will form the basis for a future shared memory accounting heuristic that has been proposed by Kamezawa. Unfortunately, we cannot rename the existing "rss" keyword used in memory.stat to "anon_rss". We however, add "mapped_file" data and hope to educate the end user through documentation. [hugh.dickins@tiscali.co.uk: fix mem_cgroup_update_mapped_file_stat oops] Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.cn> Cc: Paul Menage <menage@google.com> Cc: Dhaval Giani <dhaval@linux.vnet.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18cgroups: make messages more readableRandy Dunlap
Fix some cgroup messages to read better. Update MAINTAINERS to include mm/*cgroup* files. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-12memcg: fix page_cgroup fatal error in FLATMEMKAMEZAWA Hiroyuki
Now, SLAB is configured in very early stage and it can be used in init routine now. But replacing alloc_bootmem() in FLAT/DISCONTIGMEM's page_cgroup() initialization breaks the allocation, now. (Works well in SPARSEMEM case...it supports MEMORY_HOTPLUG and size of page_cgroup is in reasonable size (< 1 << MAX_ORDER.) This patch revive FLATMEM+memory cgroup by using alloc_bootmem. In future, We stop to support FLATMEM (if no users) or rewrite codes for flatmem completely.But this will adds more messy codes and overheads. Reported-by: Li Zefan <lizf@cn.fujitsu.com> Tested-by: Li Zefan <lizf@cn.fujitsu.com> Tested-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-06-11memcg: don't use bootmem allocator in setup codeYinghai Lu
The bootmem allocator is no longer available for page_cgroup_init() because we set up the kernel slab allocator much earlier now. Cc: Ingo Molnar <mingo@elte.hu> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-04-02memcg: remove redundant message at swaponKAMEZAWA Hiroyuki
It's pointed out that swap_cgroup's message at swapon() is nonsense. Because * It can be calculated very easily if all necessary information is written in Kconfig. * It's not necessary to annoying people at every swapon(). In other view, now, memory usage per swp_entry is reduced to 2bytes from 8bytes(64bit) and I think it's reasonably small. Reported-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02cgroups: use css id in swap cgroup for saving memory v5KAMEZAWA Hiroyuki
Try to use CSS ID for records in swap_cgroup. By this, on 64bit machine, size of swap_cgroup goes down to 2 bytes from 8bytes. This means, when 2GB of swap is equipped, (assume the page size is 4096bytes) From size of swap_cgroup = 2G/4k * 8 = 4Mbytes. To size of swap_cgroup = 2G/4k * 2 = 1Mbytes. Reduction is large. Of course, there are trade-offs. This CSS ID will add overhead to swap-in/swap-out/swap-free. But in general, - swap is a resource which the user tend to avoid use. - If swap is never used, swap_cgroup area is not used. - Reading traditional manuals, size of swap should be proportional to size of memory. Memory size of machine is increasing now. I think reducing size of swap_cgroup makes sense. Note: - ID->CSS lookup routine has no locks, it's under RCU-Read-Side. - memcg can be obsolete at rmdir() but not freed while refcnt from swap_cgroup is available. Changelog v4->v5: - reworked on to memcg-charge-swapcache-to-proper-memcg.patch Changlog ->v4: - fixed not configured case. - deleted unnecessary comments. - fixed NULL pointer bug. - fixed message in dmesg. [nishimura@mxp.nes.nec.co.jp: css_tryget can be called twice in !PageCgroupUsed case] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Paul Menage <menage@google.com> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-11memcg: use __GFP_NOWARN in page cgroup allocationKAMEZAWA Hiroyuki
page_cgroup's page allocation at init/memory hotplug uses kmalloc() and vmalloc(). If kmalloc() failes, vmalloc() is used. This is because vmalloc() is very limited resource on 32bit systems. We want to use kmalloc() first. But in this kind of call, __GFP_NOWARN should be specified. Reported-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: add mem_cgroup_disabled()Hirokazu Takahashi
We check mem_cgroup is disabled or not by checking mem_cgroup_subsys.disabled. I think it has more references than expected, now. replacing if (mem_cgroup_subsys.disabled) with if (mem_cgroup_disabled()) give us good look, I think. [kamezawa.hiroyu@jp.fujitsu.com: fix typo] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: synchronized LRUKAMEZAWA Hiroyuki
A big patch for changing memcg's LRU semantics. Now, - page_cgroup is linked to mem_cgroup's its own LRU (per zone). - LRU of page_cgroup is not synchronous with global LRU. - page and page_cgroup is one-to-one and statically allocated. - To find page_cgroup is on what LRU, you have to check pc->mem_cgroup as - lru = page_cgroup_zoneinfo(pc, nid_of_pc, zid_of_pc); - SwapCache is handled. And, when we handle LRU list of page_cgroup, we do following. pc = lookup_page_cgroup(page); lock_page_cgroup(pc); .....................(1) mz = page_cgroup_zoneinfo(pc); spin_lock(&mz->lru_lock); .....add to LRU spin_unlock(&mz->lru_lock); unlock_page_cgroup(pc); But (1) is spin_lock and we have to be afraid of dead-lock with zone->lru_lock. So, trylock() is used at (1), now. Without (1), we can't trust "mz" is correct. This is a trial to remove this dirty nesting of locks. This patch changes mz->lru_lock to be zone->lru_lock. Then, above sequence will be written as spin_lock(&zone->lru_lock); # in vmscan.c or swap.c via global LRU mem_cgroup_add/remove/etc_lru() { pc = lookup_page_cgroup(page); mz = page_cgroup_zoneinfo(pc); if (PageCgroupUsed(pc)) { ....add to LRU } spin_lock(&zone->lru_lock); # in vmscan.c or swap.c via global LRU This is much simpler. (*) We're safe even if we don't take lock_page_cgroup(pc). Because.. 1. When pc->mem_cgroup can be modified. - at charge. - at account_move(). 2. at charge the PCG_USED bit is not set before pc->mem_cgroup is fixed. 3. at account_move() the page is isolated and not on LRU. Pros. - easy for maintenance. - memcg can make use of laziness of pagevec. - we don't have to duplicated LRU/Active/Unevictable bit in page_cgroup. - LRU status of memcg will be synchronized with global LRU's one. - # of locks are reduced. - account_move() is simplified very much. Cons. - may increase cost of LRU rotation. (no impact if memcg is not configured.) Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: swap cgroup for remembering usageKAMEZAWA Hiroyuki
For accounting swap, we need a record per swap entry, at least. This patch adds following function. - swap_cgroup_swapon() .... called from swapon - swap_cgroup_swapoff() ... called at the end of swapoff. - swap_cgroup_record() .... record information of swap entry. - swap_cgroup_lookup() .... lookup information of swap entry. This patch just implements "how to record information". No actual method for limit the usage of swap. These routine uses flat table to record and lookup. "wise" lookup system like radix-tree requires requires memory allocation at new records but swap-out is usually called under memory shortage (or memcg hits limit.) So, I used static allocation. (maybe dynamic allocation is not very hard but it adds additional memory allocation in memory shortage path.) Note1: In this, we use pointer to record information and this means 8bytes per swap entry. I think we can reduce this when we create "id of cgroup" in the range of 0-65535 or 0-255. Reported-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Tested-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Reported-by: Hugh Dickins <hugh@veritas.com> Reported-by: Balbir Singh <balbir@linux.vnet.ibm.com> Reported-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Pavel Emelianov <xemul@openvz.org> Cc: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: do not recalculate section unnecessarily in init_section_page_cgroupFernando Luis Vazquez Cao
In init_section_page_cgroup() the section a given pfn belongs to is calculated at the top of the function and, despite the fact that the pfn/section correspondence does not change, it is recalculated further down the same function. By computing this just once and reusing that value we save some bytes in the object file and do not waste CPU cycles. Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06mm: make init_section_page_cgroup() staticKOSAKI Motohiro
Sparse output following warning. mm/page_cgroup.c:100:15: warning: symbol 'init_section_page_cgroup' was not declared. Should it be static? cleanup here. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-10page_cgroup should ignore empty nodesKAMEZAWA Hiroyuki
Fix a total bootup freeze on ia64. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Tested-by: Li Zefan <lizf@cn.fujitsu.com> Reported-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-01memcg: memory hotplug fix for notifier callbackKAMEZAWA Hiroyuki
Fixes for memcg/memory hotplug. While memory hotplug allocate/free memmap, page_cgroup doesn't free page_cgroup at OFFLINE when page_cgroup is allocated via bootomem. (Because freeing bootmem requires special care.) Then, if page_cgroup is allocated by bootmem and memmap is freed/allocated by memory hotplug, page_cgroup->page == page is no longer true. But current MEM_ONLINE handler doesn't check it and update page_cgroup->page if it's not necessary to allocate page_cgroup. (This was not found because memmap is not freed if SPARSEMEM_VMEMMAP is y.) And I noticed that MEM_ONLINE can be called against "part of section". So, freeing page_cgroup at CANCEL_ONLINE will cause trouble. (freeing used page_cgroup) Don't rollback at CANCEL. One more, current memory hotplug notifier is stopped by slub because it sets NOTIFY_STOP_MASK to return vaule. So, page_cgroup's callback never be called. (low priority than slub now.) I think this slub's behavior is not intentional(BUG). and fixes it. Another way to be considered about page_cgroup allocation: - free page_cgroup at OFFLINE even if it's from bootmem and remove specieal handler. But it requires more changes. Addresses http://bugzilla.kernel.org/show_bug.cgi?id=12041 Signed-off-by: KAMEZAWA Hiruyoki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Tested-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-30meminit section warningsAl Viro
2008-11-12memcg: bugfix for memory hotplugKAMEZAWA Hiroyuki
The start pfn calculation in page_cgroup's memory hotplug notifier chain is wrong. Tested-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-23memcg: fix page_cgroup allocationKAMEZAWA Hiroyuki
page_cgroup_init() is called from mem_cgroup_init(). But at this point, we cannot call alloc_bootmem(). (and this caused panic at boot.) This patch moves page_cgroup_init() to init/main.c. Time table is following: == parse_args(). # we can trust mem_cgroup_subsys.disabled bit after this. .... cgroup_init_early() # "early" init of cgroup. .... setup_arch() # memmap is allocated. ... page_cgroup_init(); mem_init(); # we cannot call alloc_bootmem after this. .... cgroup_init() # mem_cgroup is initialized. == Before page_cgroup_init(), mem_map must be initialized. So, I added page_cgroup_init() to init/main.c directly. (*) maybe this is not very clean but - cgroup_init_early() is too early - in cgroup_init(), we have to use vmalloc instead of alloc_bootmem(). use of vmalloc area in x86-32 is important and we should avoid very large vmalloc() in x86-32. So, we want to use alloc_bootmem() and added page_cgroup_init() directly to init/main.c [akpm@linux-foundation.org: remove unneeded/bad mem_cgroup_subsys declaration] [akpm@linux-foundation.org: fix build] Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Tested-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-23mm: page_cgroup needs linux/vmalloc.h for vmalloc_node()/vfree().Paul Mundt
mm/page_cgroup.c: In function 'init_section_page_cgroup': mm/page_cgroup.c:111: error: implicit declaration of function 'vmalloc_node' mm/page_cgroup.c:111: warning: assignment makes pointer from integer without a cast mm/page_cgroup.c: In function '__free_page_cgroup': mm/page_cgroup.c:140: error: implicit declaration of function 'vfree' Signed-off-by: Paul Mundt <lethal@linux-sh.org> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20memcg: allocate all page_cgroup at bootKAMEZAWA Hiroyuki
Allocate all page_cgroup at boot and remove page_cgroup poitner from struct page. This patch adds an interface as struct page_cgroup *lookup_page_cgroup(struct page*) All FLATMEM/DISCONTIGMEM/SPARSEMEM and MEMORY_HOTPLUG is supported. Remove page_cgroup pointer reduces the amount of memory by - 4 bytes per PAGE_SIZE. - 8 bytes per PAGE_SIZE if memory controller is disabled. (even if configured.) On usual 8GB x86-32 server, this saves 8MB of NORMAL_ZONE memory. On my x86-64 server with 48GB of memory, this saves 96MB of memory. I think this reduction makes sense. By pre-allocation, kmalloc/kfree in charge/uncharge are removed. This means - we're not necessary to be afraid of kmalloc faiulre. (this can happen because of gfp_mask type.) - we can avoid calling kmalloc/kfree. - we can avoid allocating tons of small objects which can be fragmented. - we can know what amount of memory will be used for this extra-lru handling. I added printk message as "allocated %ld bytes of page_cgroup" "please try cgroup_disable=memory option if you don't want" maybe enough informative for users. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
