path: root/mm/percpu-vm.c
2010-05-01percpu: move vmalloc based chunk management into percpu-vm.cTejun Heo
Separate out and move chunk management (creation/desctruction and [de]population) code into percpu-vm.c which is included by percpu.c and compiled together. The interface for chunk management is defined as follows. * pcpu_populate_chunk - populate the specified range of a chunk * pcpu_depopulate_chunk - depopulate the specified range of a chunk * pcpu_create_chunk - create a new chunk * pcpu_destroy_chunk - destroy a chunk, always preceded by full depop * pcpu_addr_to_page - translate address to physical address * pcpu_verify_alloc_info - check alloc_info is acceptable during init Other than wrapping vmalloc_to_page() inside pcpu_addr_to_page() and dummy pcpu_verify_alloc_info() implementation, this patch only moves code around. This separation is to allow alternate chunk management implementation. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: David Howells <dhowells@redhat.com> Cc: Graff Yang <graff.yang@gmail.com> Cc: Sonic Zhang <sonic.adi@gmail.com>
