path: root/mm/readahead.c
2010-05-25readahead.c: fix commentHuang Shijie
Fix a wrong comment over page_cache_async_readahead(). Signed-off-by: Huang Shijie <shijie8@gmail.com> Acked-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-07readahead: fix NULL filp dereferenceWu Fengguang
btrfs relocate_file_extent_cluster() calls us with NULL filp: [ 4005.426805] BUG: unable to handle kernel NULL pointer dereference at 00000021 [ 4005.426818] IP: [<c109a130>] page_cache_sync_readahead+0x18/0x3e Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Yan Zheng <yanzheng@21cn.com> Reported-by: Kirill A. Shutemov <kirill@shutemov.name> Tested-by: Kirill A. Shutemov <kirill@shutemov.name> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-06readahead: introduce FMODE_RANDOM for POSIX_FADV_RANDOMWu Fengguang
This fixes inefficient page-by-page reads on POSIX_FADV_RANDOM. POSIX_FADV_RANDOM used to set ra_pages=0, which leads to poor performance: a 16K read will be carried out in 4 _sync_ 1-page reads. In other places, ra_pages==0 means - it's ramfs/tmpfs/hugetlbfs/sysfs/configfs - some IO error happened where multi-page read IO won't help or should be avoided. POSIX_FADV_RANDOM actually want a different semantics: to disable the *heuristic* readahead algorithm, and to use a dumb one which faithfully submit read IO for whatever application requests. So introduce a flag FMODE_RANDOM for POSIX_FADV_RANDOM. Note that the random hint is not likely to help random reads performance noticeably. And it may be too permissive on huge request size (its IO size is not limited by read_ahead_kb). In Quentin's report (http://lkml.org/lkml/2009/12/24/145), the overall (NFS read) performance of the application increased by 313%! Tested-by: Quentin Barnes <qbarnes+nfs@yahoo-inc.com> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Andi Kleen <andi@firstfloor.org> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: David Howells <dhowells@redhat.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@infradead.org> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: Chuck Lever <chuck.lever@oracle.com> Cc: <stable@kernel.org> [2.6.33.x] Cc: <qbarnes+nfs@yahoo-inc.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-17readahead: add blk_run_backing_devHisashi Hifumi
I added blk_run_backing_dev on page_cache_async_readahead so readahead I/O is unpluged to improve throughput on especially RAID environment. The normal case is, if page N become uptodate at time T(N), then T(N) <= T(N+1) holds. With RAID (and NFS to some degree), there is no strict ordering, the data arrival time depends on runtime status of individual disks, which breaks that formula. So in do_generic_file_read(), just after submitting the async readahead IO request, the current page may well be uptodate, so the page won't be locked, and the block device won't be implicitly unplugged: if (PageReadahead(page)) page_cache_async_readahead() if (!PageUptodate(page)) goto page_not_up_to_date; //... page_not_up_to_date: lock_page_killable(page); Therefore explicit unplugging can help. Following is the test result with dd. #dd if=testdir/testfile of=/dev/null bs=16384 -2.6.30-rc6 1048576+0 records in 1048576+0 records out 17179869184 bytes (17 GB) copied, 224.182 seconds, 76.6 MB/s -2.6.30-rc6-patched 1048576+0 records in 1048576+0 records out 17179869184 bytes (17 GB) copied, 206.465 seconds, 83.2 MB/s (7Disks RAID-0 Array) -2.6.30-rc6 1054976+0 records in 1054976+0 records out 17284726784 bytes (17 GB) copied, 212.233 seconds, 81.4 MB/s -2.6.30-rc6-patched 1054976+0 records out 17284726784 bytes (17 GB) copied, 198.878 seconds, 86.9 MB/s (7Disks RAID-5 Array) The patch was found to improve performance with the SCST scsi target driver. See http://sourceforge.net/mailarchive/forum.php?thread_name=a0272b440906030714g67eabc5k8f847fb1e538cc62%40mail.gmail.com&forum_name=scst-devel [akpm@linux-foundation.org: unbust comment layout] [akpm@linux-foundation.org: "fix" CONFIG_BLOCK=n] Signed-off-by: Hisashi Hifumi <hifumi.hisashi@oss.ntt.co.jp> Acked-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Tested-by: Ronald <intercommit@gmail.com> Cc: Bart Van Assche <bart.vanassche@gmail.com> Cc: Vladislav Bolkhovitin <vst@vlnb.net> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16readahead: introduce context readahead algorithmWu Fengguang
Introduce page cache context based readahead algorithm. This is to better support concurrent read streams in general. RATIONALE --------- The current readahead algorithm detects interleaved reads in a _passive_ way. Given a sequence of interleaved streams 1,1001,2,1002,3,4,1003,5,1004,1005,6,... By checking for (offset == prev_offset + 1), it will discover the sequentialness between 3,4 and between 1004,1005, and start doing sequential readahead for the individual streams since page 4 and page 1005. The context readahead algorithm guarantees to discover the sequentialness no matter how the streams are interleaved. For the above example, it will start sequential readahead since page 2 and 1002. The trick is to poke for page @offset-1 in the page cache when it has no other clues on the sequentialness of request @offset: if the current requenst belongs to a sequential stream, that stream must have accessed page @offset-1 recently, and the page will still be cached now. So if page @offset-1 is there, we can take request @offset as a sequential access. BENEFICIARIES ------------- - strictly interleaved reads i.e. 1,1001,2,1002,3,1003,... the current readahead will take them as silly random reads; the context readahead will take them as two sequential streams. - cooperative IO processes i.e. NFS and SCST They create a thread pool, farming off (sequential) IO requests to different threads which will be performing interleaved IO. It was not easy(or possible) to reliably tell from file->f_ra all those cooperative processes working on the same sequential stream, since they will have different file->f_ra instances. And NFSD's file->f_ra is particularly unusable, since their file objects are dynamically created for each request. The nfsd does have code trying to restore the f_ra bits, but not satisfactory. The new scheme is to detect the sequential pattern via looking up the page cache, which provides one single and consistent view of the pages recently accessed. That makes sequential detection for cooperative processes possible. USER REPORT ----------- Vladislav recommends the addition of context readahead as a result of his SCST benchmarks. It leads to 6%~40% performance gains in various cases and achieves equal performance in others. http://lkml.org/lkml/2009/3/19/239 OVERHEADS --------- In theory, it introduces one extra page cache lookup per random read. However the below benchmark shows context readahead to be slightly faster, wondering.. Randomly reading 200MB amount of data on a sparse file, repeat 20 times for each block size. The average throughputs are: original ra context ra gain 4K random reads: 65.561MB/s 65.648MB/s +0.1% 16K random reads: 124.767MB/s 124.951MB/s +0.1% 64K random reads: 162.123MB/s 162.278MB/s +0.1% Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Jeff Moyer <jmoyer@redhat.com> Tested-by: Vladislav Bolkhovitin <vst@vlnb.net> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16readahead: move the random read case to bottomWu Fengguang
Split all readahead cases, and move the random one to bottom. No behavior changes. This is to prepare for the introduction of context readahead, and make it easy for inserting accounting/tracing points for each case. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Vladislav Bolkhovitin <vst@vlnb.net> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Ying Han <yinghan@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16readahead: record mmap read-around states in file_ra_stateWu Fengguang
Mmap read-around now shares the same code style and data structure with readahead code. This also removes do_page_cache_readahead(). Its last user, mmap read-around, has been changed to call ra_submit(). The no-readahead-if-congested logic is dumped by the way. Users will be pretty sensitive about the slow loading of executables. So it's unfavorable to disabled mmap read-around on a congested queue. [akpm@linux-foundation.org: coding-style fixes] Cc: Nick Piggin <npiggin@suse.de> Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: Ying Han <yinghan@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16readahead: remove sync/async readahead call dependencyWu Fengguang
The readahead call scheme is error-prone in that it expects the call sites to check for async readahead after doing a sync one. I.e. if (!page) page_cache_sync_readahead(); page = find_get_page(); if (page && PageReadahead(page)) page_cache_async_readahead(); This is because PG_readahead could be set by a sync readahead for the _current_ newly faulted in page, and the readahead code simply expects one more callback on the same page to start the async readahead. If the caller fails to do so, it will miss the PG_readahead bits and never able to start an async readahead. Eliminate this insane constraint by piggy-backing the async part into the current readahead window. Now if an async readahead should be started immediately after a sync one, the readahead logic itself will do it. So the following code becomes valid: (the 'else' in particular) if (!page) page_cache_sync_readahead(); else if (PageReadahead(page)) page_cache_async_readahead(); Cc: Nick Piggin <npiggin@suse.de> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Ying Han <yinghan@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16readahead: increase interleaved readahead sizeWu Fengguang
Make sure interleaved readahead size is larger than request size. This also makes the readahead window grow up more quickly. Reported-by: Xu Chenfeng <xcf@ustc.edu.cn> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Ying Han <yinghan@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16readahead: remove one unnecessary radix tree lookupWu Fengguang
(hit_readahead_marker != 0) means the page at @offset is present, so we can search for non-present page starting from @offset+1. Reported-by: Xu Chenfeng <xcf@ustc.edu.cn> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Ying Han <yinghan@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16readahead: apply max_sane_readahead() limit in ondemand_readahead()Wu Fengguang
Just in case someone aggressively sets a huge readahead size. Cc: Nick Piggin <npiggin@suse.de> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Ying Han <yinghan@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16readahead: move max_sane_readahead() calls into force_page_cache_readahead()Wu Fengguang
Impact: code simplification. Cc: Nick Piggin <npiggin@suse.de> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Ying Han <yinghan@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-03FS-Cache: Recruit a page flags for cache managementDavid Howells
Recruit a page flag to aid in cache management. The following extra flag is defined: (1) PG_fscache (PG_private_2) The marked page is backed by a local cache and is pinning resources in the cache driver. If PG_fscache is set, then things that checked for PG_private will now also check for that. This includes things like truncation and page invalidation. The function page_has_private() had been added to make the checks for both PG_private and PG_private_2 at the same time. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2009-04-03FS-Cache: Release page->private after failed readaheadDavid Howells
The attached patch causes read_cache_pages() to release page-private data on a page for which add_to_page_cache() fails. If the filler function fails, then the problematic page is left attached to the pagecache (with appropriate flags set, one presumes) and the remaining to-be-attached pages are invalidated and discarded. This permits pages with caching references associated with them to be cleaned up. The invalidatepage() address space op is called (indirectly) to do the honours. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2009-03-26Move the default_backing_dev_info out of readahead.c and into backing-dev.cJens Axboe
It really makes no sense to have it in readahead.c, so move it where it belongs. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-20vmscan: split LRU lists into anon & file setsRik van Riel
Split the LRU lists in two, one set for pages that are backed by real file systems ("file") and one for pages that are backed by memory and swap ("anon"). The latter includes tmpfs. The advantage of doing this is that the VM will not have to scan over lots of anonymous pages (which we generally do not want to swap out), just to find the page cache pages that it should evict. This patch has the infrastructure and a basic policy to balance how much we scan the anon lists and how much we scan the file lists. The big policy changes are in separate patches. [lee.schermerhorn@hp.com: collect lru meminfo statistics from correct offset] [kosaki.motohiro@jp.fujitsu.com: prevent incorrect oom under split_lru] [kosaki.motohiro@jp.fujitsu.com: fix pagevec_move_tail() doesn't treat unevictable page] [hugh@veritas.com: memcg swapbacked pages active] [hugh@veritas.com: splitlru: BDI_CAP_SWAP_BACKED] [akpm@linux-foundation.org: fix /proc/vmstat units] [nishimura@mxp.nes.nec.co.jp: memcg: fix handling of shmem migration] [kosaki.motohiro@jp.fujitsu.com: adjust Quicklists field of /proc/meminfo] [kosaki.motohiro@jp.fujitsu.com: fix style issue of get_scan_ratio()] Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16Remove Andrew Morton's old email accountsFrancois Cami
People can use the real name an an index into MAINTAINERS to find the current email address. Signed-off-by: Francois Cami <francois.cami@free.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26mm: readahead scan locklessNick Piggin
radix_tree_next_hole() is implemented as a series of radix_tree_lookup()s. So it can be called locklessly, under rcu_read_lock(). Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Hugh Dickins <hugh@veritas.com> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Reviewed-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30mm: bdi: export BDI attributes in sysfsPeter Zijlstra
Provide a place in sysfs (/sys/class/bdi) for the backing_dev_info object. This allows us to see and set the various BDI specific variables. In particular this properly exposes the read-ahead window for all relevant users and /sys/block/<block>/queue/read_ahead_kb should be deprecated. With patient help from Kay Sievers and Greg KH [mszeredi@suse.cz] - split off NFS and FUSE changes into separate patches - document new sysfs attributes under Documentation/ABI - do bdi_class_init as a core_initcall, otherwise the "default" BDI won't be initialized - remove bdi_init_fmt macro, it's not used very much [akpm@linux-foundation.org: fix ia64 warning] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Kay Sievers <kay.sievers@vrfy.org> Acked-by: Greg KH <greg@kroah.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-19mm/readahead: fix kernel-doc notationRandy Dunlap
Fix kernel-doc notation in mm/readahead.c. Change ":" to ";" so that it doesn't get treated as a doc section heading. Move the comment block ending "*/" to a line by itself so that the text on that last line is not lost (dropped). Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17mm: bdi init hooksPeter Zijlstra
provide BDI constructor/destructor hooks [akpm@linux-foundation.org: compile fix] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16mm: buffered write cleanupNick Piggin
Quite a bit of code is used in maintaining these "cached pages" that are probably pretty unlikely to get used. It would require a narrow race where the page is inserted concurrently while this process is allocating a page in order to create the spare page. Then a multi-page write into an uncached part of the file, to make use of it. Next, the buffered write path (and others) uses its own LRU pagevec when it should be just using the per-CPU LRU pagevec (which will cut down on both data and code size cacheline footprint). Also, these private LRU pagevecs are emptied after just a very short time, in contrast with the per-CPU pagevecs that are persistent. Net result: 7.3 times fewer lru_lock acquisitions required to add the pages to pagecache for a bulk write (in 4K chunks). [this gets rid of some cond_resched() calls in readahead.c and mpage.c due to clashes in -mm. What put them there, and why? ] Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16mm: use lockless radix-tree probeNick Piggin
Probing pages and radix_tree_tagged are lockless operations with the lockless radix-tree. Convert these users to RCU locking rather than using tree_lock. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16readahead: remove several readahead macrosFengguang Wu
Remove VM_MAX_CACHE_HIT, MAX_RA_PAGES and MIN_RA_PAGES. Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16readahead: basic support of interleaved readsFengguang Wu
This is a simplified version of the pagecache context based readahead. It handles the case of multiple threads reading on the same fd and invalidating each others' readahead state. It does the trick by scanning the pagecache and recovering the current read stream's readahead status. The algorithm works in a opportunistic way, in that it does not try to detect interleaved reads _actively_, which requires a probe into the page cache (which means a little more overhead for random reads). It only tries to handle a previously started sequential readahead whose state was overwritten by another concurrent stream, and it can do this job pretty well. Negative and positive examples(or what you can expect from it): 1) it cannot detect and serve perfect request-by-request interleaved reads right: time stream 1 stream 2 0 1 1 1001 2 2 3 1002 4 3 5 1003 6 4 7 1004 8 5 9 1005 Here no single readahead will be carried out. 2) However, if it's two concurrent reads by two threads, the chance of the initial sequential readahead be started is huge. Once the first sequential readahead is started for a stream, this patch will ensure that the readahead window continues to rampup and won't be disturbed by other streams. time stream 1 stream 2 0 1 1 2 2 1001 3 3 4 1002 5 1003 6 4 7 5 8 1004 9 6 10 1005 11 7 12 1006 13 1007 Here stream 1 will start a readahead at page 2, and stream 2 will start its first readahead at page 1003. From then on the two streams will be served right. Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16readahead: combine file_ra_state.prev_index/prev_offset into prev_posFengguang Wu
Combine the file_ra_state members unsigned long prev_index unsigned int prev_offset into loff_t prev_pos It is more consistent and better supports huge files. Thanks to Peter for the nice proposal! [akpm@linux-foundation.org: fix shift overflow] Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16readahead: compacting file_ra_stateFengguang Wu
Use 'unsigned int' instead of 'unsigned long' for readahead sizes. This helps reduce memory consumption on 64bit CPU when a lot of files are opened. CC: Andi Kleen <andi@firstfloor.org> Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-10Fix warnings with !CONFIG_BLOCKJens Axboe
Hide everything in blkdev.h with CONFIG_BLOCK isn't set, and fixup the (few) files that fail to build because they were relying on blkdev.h pulling in extra includes for them. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-19readahead: sanify file_ra_state namesFengguang Wu
Rename some file_ra_state variables and remove some accessors. It results in much simpler code. Kudos to Rusty! Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19readahead: split ondemand readahead interface into two functionsRusty Russell
Split ondemand readahead interface into two functions. I think this makes it a little clearer for non-readahead experts (like Rusty). Internally they both call ondemand_readahead(), but the page argument is changed to an obvious boolean flag. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19mm: share PG_readahead and PG_reclaimFengguang Wu
Share the same page flag bit for PG_readahead and PG_reclaim. One is used only on file reads, another is only for emergency writes. One is used mostly for fresh/young pages, another is for old pages. Combinations of possible interactions are: a) clear PG_reclaim => implicit clear of PG_readahead it will delay an asynchronous readahead into a synchronous one it actually does _good_ for readahead: the pages will be reclaimed soon, it's readahead thrashing! in this case, synchronous readahead makes more sense. b) clear PG_readahead => implicit clear of PG_reclaim one(and only one) page will not be reclaimed in time it can be avoided by checking PageWriteback(page) in readahead first c) set PG_reclaim => implicit set of PG_readahead will confuse readahead and make it restart the size rampup process it's a trivial problem, and can mostly be avoided by checking PageWriteback(page) first in readahead d) set PG_readahead => implicit set of PG_reclaim PG_readahead will never be set on already cached pages. PG_reclaim will always be cleared on dirtying a page. so not a problem. In summary, a) we get better behavior b,d) possible interactions can be avoided c) racy condition exists that might affect readahead, but the chance is _really_ low, and the hurt on readahead is trivial. Compound pages also use PG_reclaim, but for now they do not interact with reclaim/readahead code. Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19readahead: remove the old algorithmFengguang Wu
Remove the old readahead algorithm. Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: Steven Pratt <slpratt@austin.ibm.com> Cc: Ram Pai <linuxram@us.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19readahead: on-demand readahead logicFengguang Wu
This is a minimal readahead algorithm that aims to replace the current one. It is more flexible and reliable, while maintaining almost the same behavior and performance. Also it is full integrated with adaptive readahead. It is designed to be called on demand: - on a missing page, to do synchronous readahead - on a lookahead page, to do asynchronous readahead In this way it eliminated the awkward workarounds for cache hit/miss, readahead thrashing, retried read, and unaligned read. It also adopts the data structure introduced by adaptive readahead, parameterizes readahead pipelining with `lookahead_index', and reduces the current/ahead windows to one single window. HEURISTICS The logic deals with four cases: - sequential-next found a consistent readahead window, so push it forward - random standalone small read, so read as is - sequential-first create a new readahead window for a sequential/oversize request - lookahead-clueless hit a lookahead page not associated with the readahead window, so create a new readahead window and ramp it up In each case, three parameters are determined: - readahead index: where the next readahead begins - readahead size: how much to readahead - lookahead size: when to do the next readahead (for pipelining) BEHAVIORS The old behaviors are maximally preserved for trivial sequential/random reads. Notable changes are: - It no longer imposes strict sequential checks. It might help some interleaved cases, and clustered random reads. It does introduce risks of a random lookahead hit triggering an unexpected readahead. But in general it is more likely to do good than to do evil. - Interleaved reads are supported in a minimal way. Their chances of being detected and proper handled are still low. - Readahead thrashings are better handled. The current readahead leads to tiny average I/O sizes, because it never turn back for the thrashed pages. They have to be fault in by do_generic_mapping_read() one by one. Whereas the on-demand readahead will redo readahead for them. OVERHEADS The new code reduced the overheads of - excessively calling the readahead routine on small sized reads (the current readahead code insists on seeing all requests) - doing a lot of pointless page-cache lookups for small cached files (the current readahead only turns itself off after 256 cache hits, unfortunately most files are < 1MB, so never see that chance) That accounts for speedup of - 0.3% on 1-page sequential reads on sparse file - 1.2% on 1-page cache hot sequential reads - 3.2% on 256-page cache hot sequential reads - 1.3% on cache hot `tar /lib` However, it does introduce one extra page-cache lookup per cache miss, which impacts random reads slightly. That's 1% overheads for 1-page random reads on sparse file. PERFORMANCE The basic benchmark setup is - 2.6.20 kernel with on-demand readahead - 1MB max readahead size - 2.9GHz Intel Core 2 CPU - 2GB memory - 160G/8M Hitachi SATA II 7200 RPM disk The benchmarks show that - it maintains the same performance for trivial sequential/random reads - sysbench/OLTP performance on MySQL gains up to 8% - performance on readahead thrashing gains up to 3 times iozone throughput (KB/s): roughly the same ========================================== iozone -c -t1 -s 4096m -r 64k 2.6.20 on-demand gain first run " Initial write " 61437.27 64521.53 +5.0% " Rewrite " 47893.02 48335.20 +0.9% " Read " 62111.84 62141.49 +0.0% " Re-read " 62242.66 62193.17 -0.1% " Reverse Read " 50031.46 49989.79 -0.1% " Stride read " 8657.61 8652.81 -0.1% " Random read " 13914.28 13898.23 -0.1% " Mixed workload " 19069.27 19033.32 -0.2% " Random write " 14849.80 14104.38 -5.0% " Pwrite " 62955.30 65701.57 +4.4% " Pread " 62209.99 62256.26 +0.1% second run " Initial write " 60810.31 66258.69 +9.0% " Rewrite " 49373.89 57833.66 +17.1% " Read " 62059.39 62251.28 +0.3% " Re-read " 62264.32 62256.82 -0.0% " Reverse Read " 49970.96 50565.72 +1.2% " Stride read " 8654.81 8638.45 -0.2% " Random read " 13901.44 13949.91 +0.3% " Mixed workload " 19041.32 19092.04 +0.3% " Random write " 14019.99 14161.72 +1.0% " Pwrite " 64121.67 68224.17 +6.4% " Pread " 62225.08 62274.28 +0.1% In summary, writes are unstable, reads are pretty close on average: access pattern 2.6.20 on-demand gain Read 62085.61 62196.38 +0.2% Re-read 62253.49 62224.99 -0.0% Reverse Read 50001.21 50277.75 +0.6% Stride read 8656.21 8645.63 -0.1% Random read 13907.86 13924.07 +0.1% Mixed workload 19055.29 19062.68 +0.0% Pread 62217.53 62265.27 +0.1% aio-stress: roughly the same ============================ aio-stress -l -s4096 -r128 -t1 -o1 knoppix511-dvd-cn.iso aio-stress -l -s4096 -r128 -t1 -o3 knoppix511-dvd-cn.iso 2.6.20 on-demand delta sequential 92.57s 92.54s -0.0% random 311.87s 312.15s +0.1% sysbench fileio: roughly the same ================================= sysbench --test=fileio --file-io-mode=async --file-test-mode=rndrw \ --file-total-size=4G --file-block-size=64K \ --num-threads=001 --max-requests=10000 --max-time=900 run threads 2.6.20 on-demand delta first run 1 59.1974s 59.2262s +0.0% 2 58.0575s 58.2269s +0.3% 4 48.0545s 47.1164s -2.0% 8 41.0684s 41.2229s +0.4% 16 35.8817s 36.4448s +1.6% 32 32.6614s 32.8240s +0.5% 64 23.7601s 24.1481s +1.6% 128 24.3719s 23.8225s -2.3% 256 23.2366s 22.0488s -5.1% second run 1 59.6720s 59.5671s -0.2% 8 41.5158s 41.9541s +1.1% 64 25.0200s 23.9634s -4.2% 256 22.5491s 20.9486s -7.1% Note that the numbers are not very stable because of the writes. The overall performance is close when we sum all seconds up: sum all up 495.046s 491.514s -0.7% sysbench oltp (trans/sec): up to 8% gain ======================================== sysbench --test=oltp --oltp-table-size=10000000 --oltp-read-only \ --mysql-socket=/var/run/mysqld/mysqld.sock \ --mysql-user=root --mysql-password=readahead \ --num-threads=064 --max-requests=10000 --max-time=900 run 10000-transactions run threads 2.6.20 on-demand gain 1 62.81 64.56 +2.8% 2 67.97 70.93 +4.4% 4 81.81 85.87 +5.0% 8 94.60 97.89 +3.5% 16 99.07 104.68 +5.7% 32 95.93 104.28 +8.7% 64 96.48 103.68 +7.5% 5000-transactions run 1 48.21 48.65 +0.9% 8 68.60 70.19 +2.3% 64 70.57 74.72 +5.9% 2000-transactions run 1 37.57 38.04 +1.3% 2 38.43 38.99 +1.5% 4 45.39 46.45 +2.3% 8 51.64 52.36 +1.4% 16 54.39 55.18 +1.5% 32 52.13 54.49 +4.5% 64 54.13 54.61 +0.9% That's interesting results. Some investigations show that - MySQL is accessing the db file non-uniformly: some parts are more hot than others - It is mostly doing 4-page random reads, and sometimes doing two reads in a row, the latter one triggers a 16-page readahead. - The on-demand readahead leaves many lookahead pages (flagged PG_readahead) there. Many of them will be hit, and trigger more readahead pages. Which might save more seeks. - Naturally, the readahead windows tend to lie in hot areas, and the lookahead pages in hot areas is more likely to be hit. - The more overall read density, the more possible gain. That also explains the adaptive readahead tricks for clustered random reads. readahead thrashing: 3 times better =================================== We boot kernel with "mem=128m single", and start a 100KB/s stream on every second, until reaching 200 streams. max throughput min avg I/O size 2.6.20: 5MB/s 16KB on-demand: 15MB/s 140KB Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: Steven Pratt <slpratt@austin.ibm.com> Cc: Ram Pai <linuxram@us.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19readahead: data structure and routinesFengguang Wu
Extend struct file_ra_state to support the on-demand readahead logic. Also define some helpers for it. Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: Steven Pratt <slpratt@austin.ibm.com> Cc: Ram Pai <linuxram@us.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19readahead: MIN_RA_PAGES/MAX_RA_PAGES macrosFengguang Wu
Define two convenient macros for read-ahead: - MAX_RA_PAGES: rounded down counterpart of VM_MAX_READAHEAD - MIN_RA_PAGES: rounded _up_ counterpart of VM_MIN_READAHEAD Note that the rounded up MIN_RA_PAGES will work flawlessly with _large_ page sizes like 64k. Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: Steven Pratt <slpratt@austin.ibm.com> Cc: Ram Pai <linuxram@us.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19readahead: add look-ahead support to __do_page_cache_readahead()Fengguang Wu
Add look-ahead support to __do_page_cache_readahead(). It works by - mark the Nth backwards page with PG_readahead, (which instructs the page's first reader to invoke readahead) - and only do the marking for newly allocated pages. (to prevent blindly doing readahead on already cached pages) Look-ahead is a technique to achieve I/O pipelining: While the application is working through a chunk of cached pages, the kernel reads-ahead the next chunk of pages _before_ time of need. It effectively hides low level I/O latencies to high level applications. Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: Steven Pratt <slpratt@austin.ibm.com> Cc: Ram Pai <linuxram@us.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07readahead: code cleanupJan Kara
Rename file_ra_state.prev_page to prev_index and file_ra_state.offset to prev_offset. Also update of prev_index in do_generic_mapping_read() is now moved close to the update of prev_offset. [wfg@mail.ustc.edu.cn: fix it] Signed-off-by: Jan Kara <jack@suse.cz> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: WU Fengguang <wfg@mail.ustc.edu.cn> Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07readahead: improve heuristic detecting sequential readsJan Kara
Introduce ra.offset and store in it an offset where the previous read ended. This way we can detect whether reads are really sequential (and thus we should not mark the page as accessed repeatedly) or whether they are random and just happen to be in the same page (and the page should really be marked accessed again). Signed-off-by: Jan Kara <jack@suse.cz> Acked-by: Nick Piggin <nickpiggin@yahoo.com.au> Cc: WU Fengguang <wfg@mail.ustc.edu.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Drop __get_zone_counts()Christoph Lameter
Values are readily available via ZVC per node and global sums. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-10[PATCH] io-accounting-read-accounting nfs fixAndrew Morton
nfs's ->readpages uses read_cache_pages(). Wire it up there. [wfg@mail.ustc.edu.cn: account only successful nfs/fuse reads] Cc: Jay Lan <jlan@sgi.com> Cc: Shailabh Nagar <nagar@watson.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Chris Sturtivant <csturtiv@sgi.com> Cc: Tony Ernst <tee@sgi.com> Cc: Guillaume Thouvenin <guillaume.thouvenin@bull.net> Cc: David Wright <daw@sgi.com> Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] struct path: convert mmJosef Sipek
2006-12-07[PATCH] read_cache_pages() cleanupOGAWA Hirofumi
Use put_pages_list() instead of opencoding it. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-03[PATCH] Cleanup read_pages()OGAWA Hirofumi
Current read_pages() assume ->readpages() frees the passed pages. This patch free the pages in ->read_pages(), if those were remaining in the pages_list. So, readpages() just can ignore the remaining pages in pages_list. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Steven French <sfrench@us.ibm.com> Cc: Miklos Szeredi <miklos@szeredi.hu> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03Merge rsync://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6Steven Whitehouse
Conflicts: include/linux/kernel.h
2006-06-26spelling fixesAndreas Mohr
acquired (aquired) contiguous (contigious) successful (succesful, succesfull) surprise (suprise) whether (weather) some other misspellings Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-06-25[PATCH] kernel-doc: mm/readhead fixupRandy Dunlap
Put short function description for read_cache_pages() on one line as needed by kernel-doc. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] AOP_TRUNCATED_PAGE victims in read_pages() belong in the LRUZach Brown
AOP_TRUNCATED_PAGE victims in read_pages() belong in the LRU Nick Piggin rightly pointed out that the introduction of AOP_TRUNCATED_PAGE to read_pages() was wrong to leave A_T_P victim pages in the page cache but not put them in the LRU. Failing to do so hid them from the VM. A_T_P just means that the aop method unlocked the page rather than performing IO. It would be very rare that the page was truncated between the unlock and testing A_T_P. So we leave the pages in the LRU for likely reuse soon rather than backing them back out of the page cache. We do this by matching the behaviour before the A_T_P introduction which added pages to the LRU regardless of what ->readpage() did. This doesn't include the unrelated cleanup in Nick's initial fix which changed read_pages() to return void to match its only caller's behaviour of ignoring errors. Signed-off-by: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Zach Brown <zach.brown@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-31Merge branch 'master'Steven Whitehouse
2006-03-23[PATCH] ext3_readdir: use generic readaheadAndrew Morton
Linus points out that ext3_readdir's readahead only cuts in when ext3_readdir() is operating at the very start of the directory. So for large directories we end up performing no readahead at all and we suck. So take it all out and use the core VM's page_cache_readahead(). This means that ext3 directory reads will use all of readahead's dynamic sizing goop. Note that we're using the directory's filp->f_ra to hold the readahead state, but readahead is actually being performed against the underlying blockdev's address_space. Fortunately the readahead code is all set up to handle this. Tested with printk. It works. I was struggling to find a real workload which actually cared. (The patch also exports page_cache_readahead() to GPL modules) Cc: "Stephen C. Tweedie" <sct@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
