Otherwise we might be mapping in a page in a new mapping, but that page
(through the swapcache) would later be mapped into an old mapping too.
The page->mapping must be the case that works for everybody, not just
the mapping that happened to page it in first.
Here's the scenario:
- page gets allocated/mapped by process A. Let's call the anon_vma we
associate the page with 'A' to keep it easy to track.
- Process A forks, creating process B. The anon_vma in B is 'B', and has
a chain that looks like 'B' -> 'A'. Everything is fine.
- Swapping happens. The page (with mapping pointing to 'A') gets swapped
out (perhaps not to disk - it's enough to assume that it's just not
mapped any more, and lives entirely in the swap-cache)
- Process B pages it in, which goes like this:
do_swap_page ->
page = lookup_swap_cache(entry);
set_pte_at(mm, address, page_table, pte);
page_add_anon_rmap(page, vma, address);
And think about what happens here!
In particular, what happens is that this will now be the "first"
mapping of that page, so page_add_anon_rmap() used to do
if (first)
__page_set_anon_rmap(page, vma, address);
and notice what anon_vma it will use? It will use the anon_vma for
process B!
What happens then? Trivial: process 'A' also pages it in (nothing
happens, it's not the first mapping), and then process 'B' execve's
or exits or unmaps, making anon_vma B go away.
End result: process A has a page that points to anon_vma B, but
anon_vma B does not exist any more. This can go on forever. Forget
about RCU grace periods, forget about locking, forget anything like
that. The bug is simply that page->mapping points to an anon_vma
that was correct at one point, but was _not_ the one that was shared
by all users of that possible mapping.
Changing it to always use the deepest anon_vma in the anonvma chain gets
us to the safest model.
This can be improved in certain cases: if we know the page is private to
just this particular mapping (for example, it's a new page, or it is the
only swapcache entry), we could pick the top (most specific) anon_vma.
But that's a future optimization. Make it _work_ reliably first.
Tested-by: Borislav Petkov <bp@alien8.de> [ "What do you know, I think you fixed it!" ]
We want to walk the chain in reverse order when cloning it, so that the
order of the result chain will be the same as the order in the source
chain. When we add entries to the chain, they go at the head of the
chain, so we want to add the source head last.
Tested-by: Borislav Petkov <bp@alien8.de> [ "No, it still oopses" ]
Fix a memory leak in anon_vma_fork(), where we fail to tear down the
anon_vmas attached to the new VMA in case setting up the new anon_vma
fails.
This bug also has the potential to leave behind anon_vma_chain structs
with pointers to invalid memory.
Reported-by: Minchan Kim <minchan.kim@gmail.com>
Signed-off-by: Rik van Riel <riel@redhat.com>
The VM currently assumes that an inactive, mapped and referenced file page
is in use and promotes it to the active list.
However, every mapped file page starts out like this and thus a problem
arises when workloads create a stream of such pages that are used only for
a short time. By flooding the active list with those pages, the VM
quickly gets into trouble finding eligible reclaim canditates. The result
is long allocation latencies and eviction of the wrong pages.
This patch reuses the PG_referenced page flag (used for unmapped file
pages) to implement a usage detection that scales with the speed of LRU
list cycling (i.e. memory pressure).
If the scanner encounters those pages, the flag is set and the page cycled
again on the inactive list. Only if it returns with another page table
reference it is activated. Otherwise it is reclaimed as 'not recently
used cache'.
This effectively changes the minimum lifetime of a used-once mapped file
page from a full memory cycle to an inactive list cycle, which allows it
to occur in linear streams without affecting the stable working set of the
system.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Cc: Minchan Kim <minchan.kim@gmail.com>
Cc: OSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
When a VMA is in an inconsistent state during setup or teardown, the worst
that can happen is that the rmap code will not be able to find the page.
The mapping is in the process of being torn down (PTEs just got
invalidated by munmap), or set up (no PTEs have been instantiated yet).
It is also impossible for the rmap code to follow a pointer to an already
freed VMA, because the rmap code holds the anon_vma->lock, which the VMA
teardown code needs to take before the VMA is removed from the anon_vma
chain.
Hence, we should not need the VM_LOCK_RMAP locking at all.
Cc: Nick Piggin <npiggin@suse.de>
Cc: Larry Woodman <lwoodman@redhat.com>
When the parent process breaks the COW on a page, both the original which
is mapped at child and the new page which is mapped parent end up in that
same anon_vma. Generally this won't be a problem, but for some workloads
it could preserve the O(N) rmap scanning complexity.
A simple fix is to ensure that, when a page which is mapped child gets
reused in do_wp_page, because we already are the exclusive owner, the page
gets moved to our own exclusive child's anon_vma.
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk>
When an anonymous page is inherited from a parent process, the
vma->anon_vma can differ from the page anon_vma. This can trip up
__page_check_anon_rmap, which is indirectly called from do_swap_page().
Remove that obsolete check to prevent an oops.
The old anon_vma code can lead to scalability issues with heavily forking
workloads. Specifically, each anon_vma will be shared between the parent
process and all its child processes.
In a workload with 1000 child processes and a VMA with 1000 anonymous
pages per process that get COWed, this leads to a system with a million
anonymous pages in the same anon_vma, each of which is mapped in just one
of the 1000 processes. However, the current rmap code needs to walk them
all, leading to O(N) scanning complexity for each page.
This can result in systems where one CPU is walking the page tables of
1000 processes in page_referenced_one, while all other CPUs are stuck on
the anon_vma lock. This leads to catastrophic failure for a benchmark
like AIM7, where the total number of processes can reach in the tens of
thousands. Real workloads are still a factor 10 less process intensive
than AIM7, but they are catching up.
This patch changes the way anon_vmas and VMAs are linked, which allows us
to associate multiple anon_vmas with a VMA. At fork time, each child
process gets its own anon_vmas, in which its COWed pages will be
instantiated. The parents' anon_vma is also linked to the VMA, because
non-COWed pages could be present in any of the children.
This reduces rmap scanning complexity to O(1) for the pages of the 1000
child processes, with O(N) complexity for at most 1/N pages in the system.
This reduces the average scanning cost in heavily forking workloads from
O(N) to 2.
The only real complexity in this patch stems from the fact that linking a
VMA to anon_vmas now involves memory allocations. This means vma_adjust
can fail, if it needs to attach a VMA to anon_vma structures. This in
turn means error handling needs to be added to the calling functions.
A second source of complexity is that, because there can be multiple
anon_vmas, the anon_vma linking in vma_adjust can no longer be done under
"the" anon_vma lock. To prevent the rmap code from walking up an
incomplete VMA, this patch introduces the VM_LOCK_RMAP VMA flag. This bit
flag uses the same slot as the NOMMU VM_MAPPED_COPY, with an ifdef in mm.h
to make sure it is impossible to compile a kernel that needs both symbolic
values for the same bitflag.
Some test results:
Without the anon_vma changes, when AIM7 hits around 9.7k users (on a test
box with 16GB RAM and not quite enough IO), the system ends up running
>99% in system time, with every CPU on the same anon_vma lock in the
pageout code.
With these changes, AIM7 hits the cross-over point around 29.7k users.
This happens with ~99% IO wait time, there never seems to be any spike in
system time. The anon_vma lock contention appears to be resolved.
[akpm@linux-foundation.org: cleanups]
A frequent questions from users about memory management is what numbers of
swap ents are user for processes. And this information will give some
hints to oom-killer.
Besides we can count the number of swapents per a process by scanning
/proc/<pid>/smaps, this is very slow and not good for usual process
information handler which works like 'ps' or 'top'. (ps or top is now
enough slow..)
This patch adds a counter of swapents to mm_counter and update is at each
swap events. Information is exported via /proc/<pid>/status file as
[kamezawa@bluextal memory]$ cat /proc/self/status
State: R (running)
Tgid: 2910
Pid: 2910
PPid: 2823
TracerPid: 0
Uid: 500 500 500 500
Gid: 500 500 500 500
FDSize: 256
Groups: 500
VmPeak: 82696 kB
VmSize: 82696 kB
VmLck: 0 kB
VmHWM: 432 kB
VmRSS: 432 kB
VmData: 172 kB
VmStk: 84 kB
VmExe: 48 kB
VmLib: 1568 kB
VmPTE: 40 kB
VmSwap: 0 kB <=============== this.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Reviewed-by: Christoph Lameter <cl@linux-foundation.org>
Presently, per-mm statistics counter is defined by macro in sched.h
This patch modifies it to
- defined in mm.h as inlinf functions
- use array instead of macro's name creation.
This patch is for reducing patch size in future patch to modify
implementation of per-mm counter.
In global VM, FILE_MAPPED is used but memcg uses MAPPED_FILE. This makes
grep difficult. Replace memcg's MAPPED_FILE with FILE_MAPPED
And in global VM, mapped shared memory is accounted into FILE_MAPPED.
But memcg doesn't. fix it.
Note:
page_is_file_cache() just checks SwapBacked or not.
So, we need to check PageAnon.
Cc: Balbir Singh <balbir@in.ibm.com>
Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
SWAP_MLOCK mean "We marked the page as PG_MLOCK, please move it to
unevictable-lru". So, following code is easy confusable.
if (vma->vm_flags & VM_LOCKED) {
ret = SWAP_MLOCK;
goto out_unmap;
Plus, if the VMA doesn't have VM_LOCKED, We don't need to check
the needed of calling mlock_vma_page().
Also, add some commentary to try_to_unmap_one().
Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk>
A side-effect of making ksm pages swappable is that they have to be placed
on the LRUs: which then exposes them to isolate_lru_page() and hence to
page migration.
Add rmap_walk() for remove_migration_ptes() to use: rmap_walk_anon() and
rmap_walk_file() in rmap.c, but rmap_walk_ksm() in ksm.c. Perhaps some
consolidation with existing code is possible, but don't attempt that yet
(try_to_unmap needs to handle nonlinears, but migration pte removal does
not).
rmap_walk() is sadly less general than it appears: rmap_walk_anon(), like
remove_anon_migration_ptes() which it replaces, avoids calling
page_lock_anon_vma(), because that includes a page_mapped() test which
fails when all migration ptes are in place. That was valid when NUMA page
migration was introduced (holding mmap_sem provided the missing guarantee
that anon_vma's slab had not already been destroyed), but I believe not
valid in the memory hotremove case added since.
For now do the same as before, and consider the best way to fix that
unlikely race later on. When fixed, we can probably use rmap_walk() on
hwpoisoned ksm pages too: for now, they remain among hwpoison's various
exceptions (its PageKsm test comes before the page is locked, but its
page_lock_anon_vma fails safely if an anon gets upgraded).
Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Cc: Izik Eidus <ieidus@redhat.com>
Cc: Chris Wright <chrisw@redhat.com>
When ksm pages were unswappable, it made no sense to include them in mem
cgroup accounting; but now that they are swappable (although I see no
strict logical connection) the principle of least surprise implies that
they should be accounted (with the usual dissatisfaction, that a shared
page is accounted to only one of the cgroups using it).
This patch was intended to add mem cgroup accounting where necessary; but
turned inside out, it now avoids allocating a ksm page, instead upgrading
an anon page to ksm - which brings its existing mem cgroup accounting with
it. Thus mem cgroups don't appear in the patch at all.
This upgrade from PageAnon to PageKsm takes place under page lock (via a
somewhat hacky NULL kpage interface), and audit showed only one place
which needed to cope with the race - page_referenced() is sometimes used
without page lock, so page_lock_anon_vma() needs an ACCESS_ONCE() to be
sure of getting anon_vma and flags together (no problem if the page goes
ksm an instant after, the integrity of that anon_vma list is unaffected).
For full functionality, page_referenced_one() and try_to_unmap_one() need
to know the vma: to pass vma down to arch-dependent flushes, or to observe
VM_LOCKED or VM_EXEC. But KSM keeps no record of vma: nor can it, since
vmas get split and merged without its knowledge.
Instead, note page's anon_vma in its rmap_item when adding to stable tree:
all the vmas which might map that page are listed by its anon_vma.
page_referenced_ksm() and try_to_unmap_ksm() then traverse the anon_vma,
first to find the probable vma, that which matches rmap_item's mm; but if
that is not enough to locate all instances, traverse again to try the
others. This catches those occasions when fork has duplicated a pte of a
ksm page, but ksmd has not yet come around to assign it an rmap_item.
But each rmap_item in the stable tree which refers to an anon_vma needs to
take a reference to it. Andrea's anon_vma design cleverly avoided a
reference count (an anon_vma was free when its list of vmas was empty),
but KSM now needs to add that. Is a 32-bit count sufficient? I believe
so - the anon_vma is only free when both count is 0 and list is empty.
Initial implementation for swapping out KSM's shared pages: add
page_referenced_ksm() and try_to_unmap_ksm(), which rmap.c calls when
faced with a PageKsm page.
Most of what's needed can be got from the rmap_items listed from the
stable_node of the ksm page, without discovering the actual vma: so in
this patch just fake up a struct vma for page_referenced_one() or
try_to_unmap_one(), then refine that in the next patch.
Add VM_NONLINEAR to ksm_madvise()'s list of exclusions: it has always been
implicit there (being only set with VM_SHARED, already excluded), but
let's make it explicit, to help justify the lack of nonlinear unmap.
Rely on the page lock to protect against concurrent modifications to that
page's node of the stable tree.
The awkward part is not swapout but swapin: do_swap_page() and
page_add_anon_rmap() now have to allow for new possibilities - perhaps a
ksm page still in swapcache, perhaps a swapcache page associated with one
location in one anon_vma now needed for another location or anon_vma.
(And the vma might even be no longer VM_MERGEABLE when that happens.)
ksm_might_need_to_copy() checks for that case, and supplies a duplicate
page when necessary, simply leaving it to a subsequent pass of ksmd to
rediscover the identity and merge them back into one ksm page.
Disappointingly primitive: but the alternative would have to accumulate
unswappable info about the swapped out ksm pages, limiting swappability.
Remove page_add_ksm_rmap(): page_add_anon_rmap() now has to allow for the
particular case it was handling, so just use it instead.
KSM swapping will know where page_referenced_one() and try_to_unmap_one()
should look. It could hack page->index to get them to do what it wants,
but it seems cleaner now to pass the address down to them.
Make the same change to page_mkclean_one(), since it follows the same
pattern; but there's no real need in its case.
Cc: Wu Fengguang <fengguang.wu@intel.com>
Remove three degrees of obfuscation, left over from when we had
CONFIG_UNEVICTABLE_LRU. MLOCK_PAGES is CONFIG_HAVE_MLOCKED_PAGE_BIT is
CONFIG_HAVE_MLOCK is CONFIG_MMU. rmap.o (and memory-failure.o) are only
built when CONFIG_MMU, so don't need such conditions at all.
Somehow, I feel no compulsion to remove the CONFIG_HAVE_MLOCK* lines from
169 defconfigs: leave those to evolve in due course.
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
There's contorted mlock/munlock handling in try_to_unmap_anon() and
try_to_unmap_file(), which we'd prefer not to repeat for KSM swapping.
Simplify it by moving it all down into try_to_unmap_one().
One thing is then lost, try_to_munlock()'s distinction between when no vma
holds the page mlocked, and when a vma does mlock it, but we could not get
mmap_sem to set the page flag. But its only caller takes no interest in
that distinction (and is better testing SWAP_MLOCK anyway), so let's keep
the code simple and return SWAP_AGAIN for both cases.
try_to_unmap_file()'s TTU_MUNLOCK nonlinear handling was particularly
amusing: once unravelled, it turns out to have been choosing between two
different ways of doing the same nothing. Ah, no, one way was actually
returning SWAP_FAIL when it meant to return SWAP_SUCCESS.
[kosaki.motohiro@jp.fujitsu.com: comment adding to mlocking in try_to_unmap_one]
[akpm@linux-foundation.org: remove test of MLOCK_PAGES]
At present we define PageAnon(page) by the low PAGE_MAPPING_ANON bit set
in page->mapping, with the higher bits a pointer to the anon_vma; and have
defined PageKsm(page) as that with NULL anon_vma.
But KSM swapping will need to store a pointer there: so in preparation for
that, now define PAGE_MAPPING_FLAGS as the low two bits, including
PAGE_MAPPING_KSM (always set along with PAGE_MAPPING_ANON, until some
other use for the bit emerges).
Declare page_rmapping(page) to return the pointer part of page->mapping,
and page_anon_vma(page) to return the anon_vma pointer when that's what it
is. Use these in a few appropriate places: notably, unuse_vma() has been
testing page->mapping, but is better to be testing page_anon_vma() (cases
may be added in which flag bits are set without any pointer).
When the code jumps to the `out', `referenced' is still zero. So there is
no need to check it.
Signed-off-by: Huang Shijie <shijie8@gmail.com>
Acked-by: Wu Fengguang <fengguang.wu@intel.com>
Just simplify the code when `mlocked' is true.
Fix the comment for try_to_unmap_anon() with the new arguments.
Swap is duplicated (reference count incremented by one) whenever the same
swap page is inserted into another mm (when forking finds a swap entry in
place of a pte, or when reclaim unmaps a pte to insert the swap entry).
swap_info_struct's vmalloc'ed swap_map is the array of these reference
counts: but what happens when the unsigned short (or unsigned char since
the preceding patch) is full? (and its high bit is kept for a cache flag)
We then lose track of it, never freeing, leaving it in use until swapoff:
at which point we _hope_ that a single pass will have found all instances,
assume there are no more, and will lose user data if we're wrong.
Swapping of KSM pages has not yet been enabled; but it is implemented,
and makes it very easy for a user to overflow the maximum swap count:
possible with ordinary process pages, but unlikely, even when pid_max
has been raised from PID_MAX_DEFAULT.
This patch implements swap count continuations: when the count overflows,
a continuation page is allocated and linked to the original vmalloc'ed
map page, and this used to hold the continuation counts for that entry
and its neighbours. These continuation pages are seldom referenced:
the common paths all work on the original swap_map, only referring to
a continuation page when the low "digit" of a count is incremented or
decremented through SWAP_MAP_MAX.
The page_address_in_vma() is not only used in unuse_vma().
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6
* 'hwpoison' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6: (21 commits)
HWPOISON: Enable error_remove_page on btrfs
HWPOISON: Add simple debugfs interface to inject hwpoison on arbitary PFNs
HWPOISON: Add madvise() based injector for hardware poisoned pages v4
HWPOISON: Enable error_remove_page for NFS
HWPOISON: Enable .remove_error_page for migration aware file systems
HWPOISON: The high level memory error handler in the VM v7
HWPOISON: Add PR_MCE_KILL prctl to control early kill behaviour per process
HWPOISON: shmem: call set_page_dirty() with locked page
HWPOISON: Define a new error_remove_page address space op for async truncation
HWPOISON: Add invalidate_inode_page
HWPOISON: Refactor truncate to allow direct truncating of page v2
HWPOISON: check and isolate corrupted free pages v2
HWPOISON: Handle hardware poisoned pages in try_to_unmap
HWPOISON: Use bitmask/action code for try_to_unmap behaviour
HWPOISON: x86: Add VM_FAULT_HWPOISON handling to x86 page fault handler v2
HWPOISON: Add poison check to page fault handling
HWPOISON: Add basic support for poisoned pages in fault handler v3
HWPOISON: Add new SIGBUS error codes for hardware poison signals
HWPOISON: Add support for poison swap entries v2
HWPOISON: Export some rmap vma locking to outside world
page_dup_rmap(), used on each mapped page when forking, was originally
just an inline atomic_inc of mapcount. 2.6.22 added CONFIG_DEBUG_VM
out-of-line checks to it, which would need to be ever-so-slightly
complicated to allow for the PageKsm() we're about to define.
But I think these checks never caught anything. And if it's coding errors
we're worried about, such checks should be in page_remove_rmap() too, not
just when forking; whereas if it's pagetable corruption we're worried
about, then they shouldn't be limited to CONFIG_DEBUG_VM.
Oh, just revert page_dup_rmap() to an inline atomic_inc of mapcount.
Signed-off-by: Chris Wright <chrisw@redhat.com>
Signed-off-by: Izik Eidus <ieidus@redhat.com>
Cc: Avi Kivity <avi@redhat.com>
page_remove_rmap() has multiple PageAnon() tests and it has deep nesting.
Clean this up.
Acked-by: Mel Gorman <mel@csn.ul.ie>
Reviewed-by: Wu Fengguang <fengguang.wu@intel.com>
Add the high level memory handler that poisons pages
that got corrupted by hardware (typically by a two bit flip in a DIMM
or a cache) on the Linux level. The goal is to prevent everyone
from accessing these pages in the future.
This done at the VM level by marking a page hwpoisoned
and doing the appropriate action based on the type of page
it is.
The code that does this is portable and lives in mm/memory-failure.c
To quote the overview comment:
High level machine check handler. Handles pages reported by the
hardware as being corrupted usually due to a 2bit ECC memory or cache
failure.
This focuses on pages detected as corrupted in the background.
When the current CPU tries to consume corruption the currently
running process can just be killed directly instead. This implies
that if the error cannot be handled for some reason it's safe to
just ignore it because no corruption has been consumed yet. Instead
when that happens another machine check will happen.
Handles page cache pages in various states. The tricky part
here is that we can access any page asynchronous to other VM
users, because memory failures could happen anytime and anywhere,
possibly violating some of their assumptions. This is why this code
has to be extremely careful. Generally it tries to use normal locking
rules, as in get the standard locks, even if that means the
error handling takes potentially a long time.
Some of the operations here are somewhat inefficient and have non
linear algorithmic complexity, because the data structures have not
been optimized for this case. This is in particular the case
for the mapping from a vma to a process. Since this case is expected
to be rare we hope we can get away with this.
There are in principle two strategies to kill processes on poison:
- just unmap the data and wait for an actual reference before
killing
- kill as soon as corruption is detected.
Both have advantages and disadvantages and should be used
in different situations. Right now both are implemented and can
be switched with a new sysctl vm.memory_failure_early_kill
The default is early kill.
The patch does some rmap data structure walking on its own to collect
processes to kill. This is unusual because normally all rmap data structure
knowledge is in rmap.c only. I put it here for now to keep
everything together and rmap knowledge has been seeping out anyways
Includes contributions from Johannes Weiner, Chris Mason, Fengguang Wu,
Nick Piggin (who did a lot of great work) and others.
Cc: npiggin@suse.de
Cc: riel@redhat.com
Reviewed-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com>
When a page has the poison bit set replace the PTE with a poison entry.
This causes the right error handling to be done later when a process runs
into it.
v2: add a new flag to not do that (needed for the memory-failure handler
later) (Fengguang)
v3: remove unnecessary is_migration_entry() test (Fengguang, Minchan)
try_to_unmap currently has multiple modi (migration, munlock, normal unmap)
which are selected by magic flag variables. The logic is not very straight
forward, because each of these flag change multiple behaviours (e.g.
migration turns off aging, not only sets up migration ptes etc.)
Also the different flags interact in magic ways.
A later patch in this series adds another mode to try_to_unmap, so
this becomes quickly unmanageable.
Replace the different flags with a action code (migration, munlock, munmap)
and some additional flags as modifiers (ignore mlock, ignore aging).
This makes the logic more straight forward and allows easier extension
to new behaviours. Change all the caller to declare what they want to
do.
This patch is supposed to be a nop in behaviour. If anyone can prove
it is not that would be a bug.
Cc: Lee.Schermerhorn@hp.com
Cc: npiggin@suse.de
Needed for later patch that walks rmap entries on its own.
This used to be very frowned upon, but memory-failure.c does
some rather specialized rmap walking and rmap has been stable
for quite some time, so I think it's ok now to export it.
An mlocked page might lose the isolatation race. This causes the page to
clear PG_mlocked while it remains in a VM_LOCKED vma. This means it can
be put onto the [in]active list. We can rescue it by using try_to_unmap()
in shrink_page_list().
But now, As Wu Fengguang pointed out, vmscan has a bug. If the page has
PG_referenced, it can't reach try_to_unmap() in shrink_page_list() but is
put into the active list. If the page is referenced repeatedly, it can
remain on the [in]active list without being moving to the unevictable
list.
This patch fixes it.
Reported-by: Wu Fengguang <fengguang.wu@intel.com>
Signed-off-by: Minchan Kim <minchan.kim@gmail.com>
Reviewed-by: KOSAKI Motohiro <<kosaki.motohiro@jp.fujitsu.com>
Add file RSS tracking per memory cgroup
We currently don't track file RSS, the RSS we report is actually anon RSS.
All the file mapped pages, come in through the page cache and get
accounted there. This patch adds support for accounting file RSS pages.
It should
1. Help improve the metrics reported by the memory resource controller
2. Will form the basis for a future shared memory accounting heuristic
that has been proposed by Kamezawa.
Unfortunately, we cannot rename the existing "rss" keyword used in
memory.stat to "anon_rss". We however, add "mapped_file" data and hope to
educate the end user through documentation.
[hugh.dickins@tiscali.co.uk: fix mem_cgroup_update_mapped_file_stat oops]
Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Li Zefan <lizf@cn.fujitsu.cn>
Cc: Paul Menage <menage@google.com>
Cc: Dhaval Giani <dhaval@linux.vnet.ibm.com>
Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp>
Collect vma->vm_flags of the VMAs that actually referenced the page.
This is preparing for more informed reclaim heuristics, eg. to protect
executable file pages more aggressively. For now only the VM_EXEC bit
will be used by the caller.
Thanks to Johannes, Peter and Minchan for all the good tips.
Acked-by: Peter Zijlstra <peterz@infradead.org>
Reviewed-by: Johannes Weiner <hannes@cmpxchg.org>
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
Currently, nobody wants to turn UNEVICTABLE_LRU off. Thus this
configurability is unnecessary.
Acked-by: Minchan Kim <minchan.kim@gmail.com>
Cc: Matt Mackall <mpm@selenic.com>
My old address will shut down in a few days time: remove it from the tree,
and add a tmpfs (shmem filesystem) maintainer entry with the new address.
Signed-off-by: Hugh Dickins <hugh@veritas.com>
When I tested following program, I found that the mlocked counter
is strange. It cannot free some mlocked pages.
It is because try_to_unmap_file() doesn't check real
page mappings in vmas.
That is because the goal of an address_space for a file is to find all
processes into which the file's specific interval is mapped. It is
related to the file's interval, not to pages.
Even if the page isn't really mapped by the vma, it returns SWAP_MLOCK
since the vma has VM_LOCKED, then calls try_to_mlock_page. After this the
mlocked counter is increased again.
COWed anon page in a file-backed vma could be a such case. This patch
resolves it.
-- my test program --
int main()
mlockall(MCL_CURRENT);
return 0;
-- before --
root@barrios-target-linux:~# cat /proc/meminfo | egrep 'Mlo|Unev'
Unevictable: 0 kB
Mlocked: 0 kB
-- after --
Unevictable: 8 kB
Mlocked: 8 kB
Signed-off-by: MinChan Kim <minchan.kim@gmail.com>
Acked-by: Lee Schermerhorn <lee.schermerhorn@hp.com>
Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Tested-by: Lee Schermerhorn <lee.schermerhorn@hp.com>
Cc: Hugh Dickins <hugh@veritas.com>
Remove page_remove_rmap()'s vma arg, which was only for the Eeek message.
And remove the BUG_ON(page_mapcount(page) == 0) from CONFIG_DEBUG_VM's
page_dup_rmap(): we're trying to be more resilient about that than BUGs.
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Now that bad pages are kept out of circulation, there is no need for the
infamous page_remove_rmap() BUG() - once that page is freed, its negative
mapcount will issue a "Bad page state" message and the page won't be
freed. Removing the BUG() allows more info, on subsequent pages, to be
gathered.
We do have more info about the page at this point than bad_page() can know
- notably, what the pmd is, which might pinpoint something like low 64kB
corruption - but page_remove_rmap() isn't given the address to find that.
In practice, there is only one call to page_remove_rmap() which has ever
reported anything, that from zap_pte_range() (usually on exit, sometimes
on munmap). It has all the info, so remove page_remove_rmap()'s "Eeek"
message and leave it all to zap_pte_range().
mm/memory.c already has a hardly used print_bad_pte() function, showing
some of the appropriate info: extend it to show what we want for the rmap
case: pte info, page info (when there is a page) and vma info to compare.
zap_pte_range() already knows the pmd, but print_bad_pte() is easier to
use if it works that out for itself.
Some of this info is also shown in bad_page()'s "Bad page state" message.
Keep them separate, but adjust them to match each other as far as
possible. Say "Bad page map" in print_bad_pte(), and add a TAINT_BAD_PAGE
there too.
print_bad_pte() show current->comm unconditionally (though it should get
repeated in the usually irrelevant stack trace): sorry, I misled Nick
Piggin to make it conditional on vm_mm == current->mm, but current->mm is
already NULL in the exit case. Usually current->comm is good, though
exceptionally it may not be that of the mm (when "swapoff" for example).
Moving lru_cache_add_active_or_unevictable() into page_add_new_anon_rmap()
was good but stupid: we can and should SetPageSwapBacked() there too; and
we know for sure that this anonymous, swap-backed page is not file cache.
page_lock_anon_vma() and page_unlock_anon_vma() were made available to
show_page_path() in vmscan.c; but now that has been removed, make them
static in rmap.c again, they're better kept private if possible.
lru_cache_add_active_or_unevictable() and page_add_new_anon_rmap() always
appear together. Save some symbol table space and some jumping around by
removing lru_cache_add_active_or_unevictable(), folding its code into
page_add_new_anon_rmap(): like how we add file pages to lru just after
adding them to page cache.
Remove the nearby "TODO: is this safe?" comments (yes, it is safe), and
change page_add_new_anon_rmap()'s address BUG_ON to VM_BUG_ON as
originally intended.
File pages mapped only in sequentially read mappings are perfect reclaim
canditates.
This patch makes these mappings behave like weak references, their pages
will be reclaimed unless they have a strong reference from a normal
mapping as well.
It changes the reclaim and the unmap path where they check if the page has
been referenced. In both cases, accesses through sequentially read
mappings will be ignored.
Benchmark results from KOSAKI Motohiro:
http://marc.info/?l=linux-mm&m=122485301925098&w=2
Signed-off-by: Johannes Weiner <hannes@saeurebad.de>
#ifdef in *.c file decrease source readability a bit. removing is better.
This patch doesn't have any functional change.
This patch makes the needlessly global anon_vma_cachep static.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Acked-by: Hugh Dickins <hugh@veritas.com>
There are not-on-LRU pages which can be mapped and they are not worth to
be accounted. (becasue we can't shrink them and need dirty codes to
handle specical case) We'd like to make use of usual objrmap/radix-tree's
protcol and don't want to account out-of-vm's control pages.
When special_mapping_fault() is called, page->mapping is tend to be NULL
and it's charged as Anonymous page. insert_page() also handles some
special pages from drivers.
This patch is for avoiding to account special pages.
Cc: Balbir Singh <balbir@linux.vnet.ibm.com>
This patch adds a function to scan individual or all zones' unevictable
lists and move any pages that have become evictable onto the respective
zone's inactive list, where shrink_inactive_list() will deal with them.
Adds sysctl to scan all nodes, and per node attributes to individual
nodes' zones.
Kosaki: If evictable page found in unevictable lru when write
/proc/sys/vm/scan_unevictable_pages, print filename and file offset of
these pages.
[akpm@linux-foundation.org: fix one CONFIG_MMU=n build error]
[kosaki.motohiro@jp.fujitsu.com: adapt vmscan-unevictable-lru-scan-sysctl.patch to new sysfs API]
Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com>
Make sure that mlocked pages also live on the unevictable LRU, so kswapd
will not scan them over and over again.
This is achieved through various strategies:
1) add yet another page flag--PG_mlocked--to indicate that
the page is locked for efficient testing in vmscan and,
optionally, fault path. This allows early culling of
unevictable pages, preventing them from getting to
page_referenced()/try_to_unmap(). Also allows separate
accounting of mlock'd pages, as Nick's original patch
did.
Note: Nick's original mlock patch used a PG_mlocked
flag. I had removed this in favor of the PG_unevictable
flag + an mlock_count [new page struct member]. I
restored the PG_mlocked flag to eliminate the new
count field.
2) add the mlock/unevictable infrastructure to mm/mlock.c,
with internal APIs in mm/internal.h. This is a rework
of Nick's original patch to these files, taking into
account that mlocked pages are now kept on unevictable
LRU list.
3) update vmscan.c:page_evictable() to check PageMlocked()
and, if vma passed in, the vm_flags. Note that the vma
will only be passed in for new pages in the fault path;
and then only if the "cull unevictable pages in fault
path" patch is included.
4) add try_to_unlock() to rmap.c to walk a page's rmap and
ClearPageMlocked() if no other vmas have it mlocked.
Reuses as much of try_to_unmap() as possible. This
effectively replaces the use of one of the lru list links
as an mlock count. If this mechanism let's pages in mlocked
vmas leak through w/o PG_mlocked set [I don't know that it
does], we should catch them later in try_to_unmap(). One
hopes this will be rare, as it will be relatively expensive.
Original mm/internal.h, mm/rmap.c and mm/mlock.c changes:
Signed-off-by: Nick Piggin <npiggin@suse.de>
splitlru: introduce __get_user_pages():
New munlock processing need to GUP_FLAGS_IGNORE_VMA_PERMISSIONS.
because current get_user_pages() can't grab PROT_NONE pages theresore it
cause PROT_NONE pages can't munlock.
[akpm@linux-foundation.org: fix this for pagemap-pass-mm-into-pagewalkers.patch]
[akpm@linux-foundation.org: untangle patch interdependencies]
[akpm@linux-foundation.org: fix things after out-of-order merging]
[hugh@veritas.com: fix page-flags mess]
[lee.schermerhorn@hp.com: fix munlock page table walk - now requires 'mm']
[kosaki.motohiro@jp.fujitsu.com: build fix]
[kosaki.motohiro@jp.fujitsu.com: fix truncate race and sevaral comments]
[kosaki.motohiro@jp.fujitsu.com: splitlru: introduce __get_user_pages()]
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
The anon_vma code is very subtle, and we end up doing optimistic lookups
of anon_vmas under RCU in page_lock_anon_vma() with no locking. Other
CPU's can also see the newly allocated entry immediately after we've
exposed it by setting "vma->anon_vma" to the new value.
We protect against the anon_vma being destroyed by having the SLAB
marked as SLAB_DESTROY_BY_RCU, so the RCU lookup can depend on the
allocation not being destroyed - but it might still be free'd and
re-allocated here to a new vma.
As a result, we should not do the anon_vma list ops on a newly allocated
vma without proper locking.
Acked-by: Nick Piggin <npiggin@suse.de>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
