path: root/mm/rmap.c
2010-05-25mm: migration: avoid race between shift_arg_pages() and rmap_walk() during ↵Mel Gorman
migration by not migrating temporary stacks Page migration requires rmap to be able to find all ptes mapping a page at all times, otherwise the migration entry can be instantiated, but it is possible to leave one behind if the second rmap_walk fails to find the page. If this page is later faulted, migration_entry_to_page() will call BUG because the page is locked indicating the page was migrated by the migration PTE not cleaned up. For example kernel BUG at include/linux/swapops.h:105! invalid opcode: 0000 [#1] PREEMPT SMP ... Call Trace: [<ffffffff810e951a>] handle_mm_fault+0x3f8/0x76a [<ffffffff8130c7a2>] do_page_fault+0x44a/0x46e [<ffffffff813099b5>] page_fault+0x25/0x30 [<ffffffff8114de33>] load_elf_binary+0x152a/0x192b [<ffffffff8111329b>] search_binary_handler+0x173/0x313 [<ffffffff81114896>] do_execve+0x219/0x30a [<ffffffff8100a5c6>] sys_execve+0x43/0x5e [<ffffffff8100320a>] stub_execve+0x6a/0xc0 RIP [<ffffffff811094ff>] migration_entry_wait+0xc1/0x129 There is a race between shift_arg_pages and migration that triggers this bug. A temporary stack is setup during exec and later moved. If migration moves a page in the temporary stack and the VMA is then removed before migration completes, the migration PTE may not be found leading to a BUG when the stack is faulted. This patch causes pages within the temporary stack during exec to be skipped by migration. It does this by marking the VMA covering the temporary stack with an otherwise impossible combination of VMA flags. These flags are cleared when the temporary stack is moved to its final location. [kamezawa.hiroyu@jp.fujitsu.com: idea for having migration skip temporary stacks] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Rik van Riel <riel@redhat.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Christoph Lameter <cl@linux.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25mm: migration: share the anon_vma ref counts between KSM and page migrationMel Gorman
For clarity of review, KSM and page migration have separate refcounts on the anon_vma. While clear, this is a waste of memory. This patch gets KSM and page migration to share their toys in a spirit of harmony. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25mm: migration: take a reference to the anon_vma before migratingMel Gorman
This patchset is a memory compaction mechanism that reduces external fragmentation memory by moving GFP_MOVABLE pages to a fewer number of pageblocks. The term "compaction" was chosen as there are is a number of mechanisms that are not mutually exclusive that can be used to defragment memory. For example, lumpy reclaim is a form of defragmentation as was slub "defragmentation" (really a form of targeted reclaim). Hence, this is called "compaction" to distinguish it from other forms of defragmentation. In this implementation, a full compaction run involves two scanners operating within a zone - a migration and a free scanner. The migration scanner starts at the beginning of a zone and finds all movable pages within one pageblock_nr_pages-sized area and isolates them on a migratepages list. The free scanner begins at the end of the zone and searches on a per-area basis for enough free pages to migrate all the pages on the migratepages list. As each area is respectively migrated or exhausted of free pages, the scanners are advanced one area. A compaction run completes within a zone when the two scanners meet. This method is a bit primitive but is easy to understand and greater sophistication would require maintenance of counters on a per-pageblock basis. This would have a big impact on allocator fast-paths to improve compaction which is a poor trade-off. It also does not try relocate virtually contiguous pages to be physically contiguous. However, assuming transparent hugepages were in use, a hypothetical khugepaged might reuse compaction code to isolate free pages, split them and relocate userspace pages for promotion. Memory compaction can be triggered in one of three ways. It may be triggered explicitly by writing any value to /proc/sys/vm/compact_memory and compacting all of memory. It can be triggered on a per-node basis by writing any value to /sys/devices/system/node/nodeN/compact where N is the node ID to be compacted. When a process fails to allocate a high-order page, it may compact memory in an attempt to satisfy the allocation instead of entering direct reclaim. Explicit compaction does not finish until the two scanners meet and direct compaction ends if a suitable page becomes available that would meet watermarks. The series is in 14 patches. The first three are not "core" to the series but are important pre-requisites. Patch 1 reference counts anon_vma for rmap_walk_anon(). Without this patch, it's possible to use anon_vma after free if the caller is not holding a VMA or mmap_sem for the pages in question. While there should be no existing user that causes this problem, it's a requirement for memory compaction to be stable. The patch is at the start of the series for bisection reasons. Patch 2 merges the KSM and migrate counts. It could be merged with patch 1 but would be slightly harder to review. Patch 3 skips over unmapped anon pages during migration as there are no guarantees about the anon_vma existing. There is a window between when a page was isolated and migration started during which anon_vma could disappear. Patch 4 notes that PageSwapCache pages can still be migrated even if they are unmapped. Patch 5 allows CONFIG_MIGRATION to be set without CONFIG_NUMA Patch 6 exports a "unusable free space index" via debugfs. It's a measure of external fragmentation that takes the size of the allocation request into account. It can also be calculated from userspace so can be dropped if requested Patch 7 exports a "fragmentation index" which only has meaning when an allocation request fails. It determines if an allocation failure would be due to a lack of memory or external fragmentation. Patch 8 moves the definition for LRU isolation modes for use by compaction Patch 9 is the compaction mechanism although it's unreachable at this point Patch 10 adds a means of compacting all of memory with a proc trgger Patch 11 adds a means of compacting a specific node with a sysfs trigger Patch 12 adds "direct compaction" before "direct reclaim" if it is determined there is a good chance of success. Patch 13 adds a sysctl that allows tuning of the threshold at which the kernel will compact or direct reclaim Patch 14 temporarily disables compaction if an allocation failure occurs after compaction. Testing of compaction was in three stages. For the test, debugging, preempt, the sleep watchdog and lockdep were all enabled but nothing nasty popped out. min_free_kbytes was tuned as recommended by hugeadm to help fragmentation avoidance and high-order allocations. It was tested on X86, X86-64 and PPC64. Ths first test represents one of the easiest cases that can be faced for lumpy reclaim or memory compaction. 1. Machine freshly booted and configured for hugepage usage with a) hugeadm --create-global-mounts b) hugeadm --pool-pages-max DEFAULT:8G c) hugeadm --set-recommended-min_free_kbytes d) hugeadm --set-recommended-shmmax The min_free_kbytes here is important. Anti-fragmentation works best when pageblocks don't mix. hugeadm knows how to calculate a value that will significantly reduce the worst of external-fragmentation-related events as reported by the mm_page_alloc_extfrag tracepoint. 2. Load up memory a) Start updatedb b) Create in parallel a X files of pagesize*128 in size. Wait until files are created. By parallel, I mean that 4096 instances of dd were launched, one after the other using &. The crude objective being to mix filesystem metadata allocations with the buffer cache. c) Delete every second file so that pageblocks are likely to have holes d) kill updatedb if it's still running At this point, the system is quiet, memory is full but it's full with clean filesystem metadata and clean buffer cache that is unmapped. This is readily migrated or discarded so you'd expect lumpy reclaim to have no significant advantage over compaction but this is at the POC stage. 3. In increments, attempt to allocate 5% of memory as hugepages. Measure how long it took, how successful it was, how many direct reclaims took place and how how many compactions. Note the compaction figures might not fully add up as compactions can take place for orders other than the hugepage size X86 vanilla compaction Final page count 913 916 (attempted 1002) pages reclaimed 68296 9791 X86-64 vanilla compaction Final page count: 901 902 (attempted 1002) Total pages reclaimed: 112599 53234 PPC64 vanilla compaction Final page count: 93 94 (attempted 110) Total pages reclaimed: 103216 61838 There was not a dramatic improvement in success rates but it wouldn't be expected in this case either. What was important is that fewer pages were reclaimed in all cases reducing the amount of IO required to satisfy a huge page allocation. The second tests were all performance related - kernbench, netperf, iozone and sysbench. None showed anything too remarkable. The last test was a high-order allocation stress test. Many kernel compiles are started to fill memory with a pressured mix of unmovable and movable allocations. During this, an attempt is made to allocate 90% of memory as huge pages - one at a time with small delays between attempts to avoid flooding the IO queue. vanilla compaction Percentage of request allocated X86 98 99 Percentage of request allocated X86-64 95 98 Percentage of request allocated PPC64 55 70 This patch: rmap_walk_anon() does not use page_lock_anon_vma() for looking up and locking an anon_vma and it does not appear to have sufficient locking to ensure the anon_vma does not disappear from under it. This patch copies an approach used by KSM to take a reference on the anon_vma while pages are being migrated. This should prevent rmap_walk() running into nasty surprises later because anon_vma has been freed. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Rik van Riel <riel@redhat.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-11rmap: remove anon_vma check in page_address_in_vma()Naoya Horiguchi
Currently page_address_in_vma() compares vma->anon_vma and page_anon_vma(page) for parameter check, but in 2.6.34 a vma can have multiple anon_vmas with anon_vma_chain, so current check does not work. (For anonymous page shared by multiple processes, some verified (page,vma) pairs return -EFAULT wrongly.) We can go to checking all anon_vmas in the "same_vma" chain, but it needs to meet lock requirement. Instead, we can remove anon_vma check safely because page_address_in_vma() assumes that page and vma are already checked to belong to the identical process. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-24rmap: anon_vma_prepare() can leak anon_vma_chainOleg Nesterov
If find_mergeable_anon_vma() succeeds but another thread installs ->anon_vma before we take ptl, then allocated == NULL but avc should be freed. Change the code to check avc != NULL to detect this case. Also, a couple of whitespace changes to make the critical section more visible. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: Borislav Petkov <bp@alien8.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-19rmap: add exclusively owned pages to the newest anon_vmaRik van Riel
The recent anon_vma fixes cause many anonymous pages to end up in the parent process anon_vma, even when the page is exclusively owned by the current process. Adding exclusively owned anonymous pages to the top anon_vma reduces rmap scanning overhead, especially in workloads with forking servers. This patch adds a parameter to __page_set_anon_rmap that can be used to indicate whether or not the added page is exclusively owned by the current process. Pages added through page_add_new_anon_rmap are exclusively owned by the current process, and can be added to the top anon_vma. Pages added through page_add_anon_rmap can be either shared or exclusively owned, so we do the conservative thing and add it to the oldest anon_vma. A next step would be to add the exclusive parameter to page_add_anon_rmap, to be used from functions where we do know for sure whether a page is exclusively owned. Signed-off-by: Rik van Riel <riel@redhat.com> Reviewed-by: Johannes Weiner <hannes@cmpxchg.org> Lightly-tested-by: Borislav Petkov <bp@alien8.de> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> [ Edited to look nicer - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-12anonvma: when setting up page->mapping, we need to pick the _oldest_ anonvmaLinus Torvalds
Otherwise we might be mapping in a page in a new mapping, but that page (through the swapcache) would later be mapped into an old mapping too. The page->mapping must be the case that works for everybody, not just the mapping that happened to page it in first. Here's the scenario: - page gets allocated/mapped by process A. Let's call the anon_vma we associate the page with 'A' to keep it easy to track. - Process A forks, creating process B. The anon_vma in B is 'B', and has a chain that looks like 'B' -> 'A'. Everything is fine. - Swapping happens. The page (with mapping pointing to 'A') gets swapped out (perhaps not to disk - it's enough to assume that it's just not mapped any more, and lives entirely in the swap-cache) - Process B pages it in, which goes like this: do_swap_page -> page = lookup_swap_cache(entry); ... set_pte_at(mm, address, page_table, pte); page_add_anon_rmap(page, vma, address); And think about what happens here! In particular, what happens is that this will now be the "first" mapping of that page, so page_add_anon_rmap() used to do if (first) __page_set_anon_rmap(page, vma, address); and notice what anon_vma it will use? It will use the anon_vma for process B! What happens then? Trivial: process 'A' also pages it in (nothing happens, it's not the first mapping), and then process 'B' execve's or exits or unmaps, making anon_vma B go away. End result: process A has a page that points to anon_vma B, but anon_vma B does not exist any more. This can go on forever. Forget about RCU grace periods, forget about locking, forget anything like that. The bug is simply that page->mapping points to an anon_vma that was correct at one point, but was _not_ the one that was shared by all users of that possible mapping. Changing it to always use the deepest anon_vma in the anonvma chain gets us to the safest model. This can be improved in certain cases: if we know the page is private to just this particular mapping (for example, it's a new page, or it is the only swapcache entry), we could pick the top (most specific) anon_vma. But that's a future optimization. Make it _work_ reliably first. Reviewed-by: Rik van Riel <riel@redhat.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Tested-by: Borislav Petkov <bp@alien8.de> [ "What do you know, I think you fixed it!" ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-12anon_vma: clone the anon_vma chain in the right orderLinus Torvalds
We want to walk the chain in reverse order when cloning it, so that the order of the result chain will be the same as the order in the source chain. When we add entries to the chain, they go at the head of the chain, so we want to add the source head last. Reviewed-by: Rik van Riel <riel@redhat.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Tested-by: Borislav Petkov <bp@alien8.de> [ "No, it still oopses" ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-05rmap: fix anon_vma_fork() memory leakRik van Riel
Fix a memory leak in anon_vma_fork(), where we fail to tear down the anon_vmas attached to the new VMA in case setting up the new anon_vma fails. This bug also has the potential to leave behind anon_vma_chain structs with pointers to invalid memory. Reported-by: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06vmscan: detect mapped file pages used only onceJohannes Weiner
The VM currently assumes that an inactive, mapped and referenced file page is in use and promotes it to the active list. However, every mapped file page starts out like this and thus a problem arises when workloads create a stream of such pages that are used only for a short time. By flooding the active list with those pages, the VM quickly gets into trouble finding eligible reclaim canditates. The result is long allocation latencies and eviction of the wrong pages. This patch reuses the PG_referenced page flag (used for unmapped file pages) to implement a usage detection that scales with the speed of LRU list cycling (i.e. memory pressure). If the scanner encounters those pages, the flag is set and the page cycled again on the inactive list. Only if it returns with another page table reference it is activated. Otherwise it is reclaimed as 'not recently used cache'. This effectively changes the minimum lifetime of a used-once mapped file page from a full memory cycle to an inactive list cycle, which allows it to occur in linear streams without affecting the stable working set of the system. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: OSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06mm: remove VM_LOCK_RMAP codeRik van Riel
When a VMA is in an inconsistent state during setup or teardown, the worst that can happen is that the rmap code will not be able to find the page. The mapping is in the process of being torn down (PTEs just got invalidated by munmap), or set up (no PTEs have been instantiated yet). It is also impossible for the rmap code to follow a pointer to an already freed VMA, because the rmap code holds the anon_vma->lock, which the VMA teardown code needs to take before the VMA is removed from the anon_vma chain. Hence, we should not need the VM_LOCK_RMAP locking at all. Signed-off-by: Rik van Riel <riel@redhat.com> Cc: Nick Piggin <npiggin@suse.de> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Larry Woodman <lwoodman@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06rmap: move exclusively owned pages to own anon_vma in do_wp_page()Rik van Riel
When the parent process breaks the COW on a page, both the original which is mapped at child and the new page which is mapped parent end up in that same anon_vma. Generally this won't be a problem, but for some workloads it could preserve the O(N) rmap scanning complexity. A simple fix is to ensure that, when a page which is mapped child gets reused in do_wp_page, because we already are the exclusive owner, the page gets moved to our own exclusive child's anon_vma. Signed-off-by: Rik van Riel <riel@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Larry Woodman <lwoodman@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06rmap: remove obsolete check from __page_check_anon_rmap()Rik van Riel
When an anonymous page is inherited from a parent process, the vma->anon_vma can differ from the page anon_vma. This can trip up __page_check_anon_rmap, which is indirectly called from do_swap_page(). Remove that obsolete check to prevent an oops. Signed-off-by: Rik van Riel <riel@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Larry Woodman <lwoodman@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06mm: change anon_vma linking to fix multi-process server scalability issueRik van Riel
The old anon_vma code can lead to scalability issues with heavily forking workloads. Specifically, each anon_vma will be shared between the parent process and all its child processes. In a workload with 1000 child processes and a VMA with 1000 anonymous pages per process that get COWed, this leads to a system with a million anonymous pages in the same anon_vma, each of which is mapped in just one of the 1000 processes. However, the current rmap code needs to walk them all, leading to O(N) scanning complexity for each page. This can result in systems where one CPU is walking the page tables of 1000 processes in page_referenced_one, while all other CPUs are stuck on the anon_vma lock. This leads to catastrophic failure for a benchmark like AIM7, where the total number of processes can reach in the tens of thousands. Real workloads are still a factor 10 less process intensive than AIM7, but they are catching up. This patch changes the way anon_vmas and VMAs are linked, which allows us to associate multiple anon_vmas with a VMA. At fork time, each child process gets its own anon_vmas, in which its COWed pages will be instantiated. The parents' anon_vma is also linked to the VMA, because non-COWed pages could be present in any of the children. This reduces rmap scanning complexity to O(1) for the pages of the 1000 child processes, with O(N) complexity for at most 1/N pages in the system. This reduces the average scanning cost in heavily forking workloads from O(N) to 2. The only real complexity in this patch stems from the fact that linking a VMA to anon_vmas now involves memory allocations. This means vma_adjust can fail, if it needs to attach a VMA to anon_vma structures. This in turn means error handling needs to be added to the calling functions. A second source of complexity is that, because there can be multiple anon_vmas, the anon_vma linking in vma_adjust can no longer be done under "the" anon_vma lock. To prevent the rmap code from walking up an incomplete VMA, this patch introduces the VM_LOCK_RMAP VMA flag. This bit flag uses the same slot as the NOMMU VM_MAPPED_COPY, with an ifdef in mm.h to make sure it is impossible to compile a kernel that needs both symbolic values for the same bitflag. Some test results: Without the anon_vma changes, when AIM7 hits around 9.7k users (on a test box with 16GB RAM and not quite enough IO), the system ends up running >99% in system time, with every CPU on the same anon_vma lock in the pageout code. With these changes, AIM7 hits the cross-over point around 29.7k users. This happens with ~99% IO wait time, there never seems to be any spike in system time. The anon_vma lock contention appears to be resolved. [akpm@linux-foundation.org: cleanups] Signed-off-by: Rik van Riel <riel@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Larry Woodman <lwoodman@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06mm: count swap usageKAMEZAWA Hiroyuki
A frequent questions from users about memory management is what numbers of swap ents are user for processes. And this information will give some hints to oom-killer. Besides we can count the number of swapents per a process by scanning /proc/<pid>/smaps, this is very slow and not good for usual process information handler which works like 'ps' or 'top'. (ps or top is now enough slow..) This patch adds a counter of swapents to mm_counter and update is at each swap events. Information is exported via /proc/<pid>/status file as [kamezawa@bluextal memory]$ cat /proc/self/status Name: cat State: R (running) Tgid: 2910 Pid: 2910 PPid: 2823 TracerPid: 0 Uid: 500 500 500 500 Gid: 500 500 500 500 FDSize: 256 Groups: 500 VmPeak: 82696 kB VmSize: 82696 kB VmLck: 0 kB VmHWM: 432 kB VmRSS: 432 kB VmData: 172 kB VmStk: 84 kB VmExe: 48 kB VmLib: 1568 kB VmPTE: 40 kB VmSwap: 0 kB <=============== this. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06mm: clean up mm_counterKAMEZAWA Hiroyuki
Presently, per-mm statistics counter is defined by macro in sched.h This patch modifies it to - defined in mm.h as inlinf functions - use array instead of macro's name creation. This patch is for reducing patch size in future patch to modify implementation of per-mm counter. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16memcg: make memcg's file mapped consistent with global VMKAMEZAWA Hiroyuki
In global VM, FILE_MAPPED is used but memcg uses MAPPED_FILE. This makes grep difficult. Replace memcg's MAPPED_FILE with FILE_MAPPED And in global VM, mapped shared memory is accounted into FILE_MAPPED. But memcg doesn't. fix it. Note: page_is_file_cache() just checks SwapBacked or not. So, we need to check PageAnon. Cc: Balbir Singh <balbir@in.ibm.com> Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15mm: simplify try_to_unmap_one()KOSAKI Motohiro
SWAP_MLOCK mean "We marked the page as PG_MLOCK, please move it to unevictable-lru". So, following code is easy confusable. if (vma->vm_flags & VM_LOCKED) { ret = SWAP_MLOCK; goto out_unmap; } Plus, if the VMA doesn't have VM_LOCKED, We don't need to check the needed of calling mlock_vma_page(). Also, add some commentary to try_to_unmap_one(). Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15ksm: rmap_walk to remove_migation_ptesHugh Dickins
A side-effect of making ksm pages swappable is that they have to be placed on the LRUs: which then exposes them to isolate_lru_page() and hence to page migration. Add rmap_walk() for remove_migration_ptes() to use: rmap_walk_anon() and rmap_walk_file() in rmap.c, but rmap_walk_ksm() in ksm.c. Perhaps some consolidation with existing code is possible, but don't attempt that yet (try_to_unmap needs to handle nonlinears, but migration pte removal does not). rmap_walk() is sadly less general than it appears: rmap_walk_anon(), like remove_anon_migration_ptes() which it replaces, avoids calling page_lock_anon_vma(), because that includes a page_mapped() test which fails when all migration ptes are in place. That was valid when NUMA page migration was introduced (holding mmap_sem provided the missing guarantee that anon_vma's slab had not already been destroyed), but I believe not valid in the memory hotremove case added since. For now do the same as before, and consider the best way to fix that unlikely race later on. When fixed, we can probably use rmap_walk() on hwpoisoned ksm pages too: for now, they remain among hwpoison's various exceptions (its PageKsm test comes before the page is locked, but its page_lock_anon_vma fails safely if an anon gets upgraded). Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Izik Eidus <ieidus@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Chris Wright <chrisw@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15ksm: share anon page without allocatingHugh Dickins
When ksm pages were unswappable, it made no sense to include them in mem cgroup accounting; but now that they are swappable (although I see no strict logical connection) the principle of least surprise implies that they should be accounted (with the usual dissatisfaction, that a shared page is accounted to only one of the cgroups using it). This patch was intended to add mem cgroup accounting where necessary; but turned inside out, it now avoids allocating a ksm page, instead upgrading an anon page to ksm - which brings its existing mem cgroup accounting with it. Thus mem cgroups don't appear in the patch at all. This upgrade from PageAnon to PageKsm takes place under page lock (via a somewhat hacky NULL kpage interface), and audit showed only one place which needed to cope with the race - page_referenced() is sometimes used without page lock, so page_lock_anon_vma() needs an ACCESS_ONCE() to be sure of getting anon_vma and flags together (no problem if the page goes ksm an instant after, the integrity of that anon_vma list is unaffected). Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Izik Eidus <ieidus@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Chris Wright <chrisw@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15ksm: hold anon_vma in rmap_itemHugh Dickins
For full functionality, page_referenced_one() and try_to_unmap_one() need to know the vma: to pass vma down to arch-dependent flushes, or to observe VM_LOCKED or VM_EXEC. But KSM keeps no record of vma: nor can it, since vmas get split and merged without its knowledge. Instead, note page's anon_vma in its rmap_item when adding to stable tree: all the vmas which might map that page are listed by its anon_vma. page_referenced_ksm() and try_to_unmap_ksm() then traverse the anon_vma, first to find the probable vma, that which matches rmap_item's mm; but if that is not enough to locate all instances, traverse again to try the others. This catches those occasions when fork has duplicated a pte of a ksm page, but ksmd has not yet come around to assign it an rmap_item. But each rmap_item in the stable tree which refers to an anon_vma needs to take a reference to it. Andrea's anon_vma design cleverly avoided a reference count (an anon_vma was free when its list of vmas was empty), but KSM now needs to add that. Is a 32-bit count sufficient? I believe so - the anon_vma is only free when both count is 0 and list is empty. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Izik Eidus <ieidus@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Chris Wright <chrisw@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15ksm: let shared pages be swappableHugh Dickins
Initial implementation for swapping out KSM's shared pages: add page_referenced_ksm() and try_to_unmap_ksm(), which rmap.c calls when faced with a PageKsm page. Most of what's needed can be got from the rmap_items listed from the stable_node of the ksm page, without discovering the actual vma: so in this patch just fake up a struct vma for page_referenced_one() or try_to_unmap_one(), then refine that in the next patch. Add VM_NONLINEAR to ksm_madvise()'s list of exclusions: it has always been implicit there (being only set with VM_SHARED, already excluded), but let's make it explicit, to help justify the lack of nonlinear unmap. Rely on the page lock to protect against concurrent modifications to that page's node of the stable tree. The awkward part is not swapout but swapin: do_swap_page() and page_add_anon_rmap() now have to allow for new possibilities - perhaps a ksm page still in swapcache, perhaps a swapcache page associated with one location in one anon_vma now needed for another location or anon_vma. (And the vma might even be no longer VM_MERGEABLE when that happens.) ksm_might_need_to_copy() checks for that case, and supplies a duplicate page when necessary, simply leaving it to a subsequent pass of ksmd to rediscover the identity and merge them back into one ksm page. Disappointingly primitive: but the alternative would have to accumulate unswappable info about the swapped out ksm pages, limiting swappability. Remove page_add_ksm_rmap(): page_add_anon_rmap() now has to allow for the particular case it was handling, so just use it instead. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Izik Eidus <ieidus@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Chris Wright <chrisw@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15mm: pass address down to rmap onesHugh Dickins
KSM swapping will know where page_referenced_one() and try_to_unmap_one() should look. It could hack page->index to get them to do what it wants, but it seems cleaner now to pass the address down to them. Make the same change to page_mkclean_one(), since it follows the same pattern; but there's no real need in its case. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Izik Eidus <ieidus@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Nick Piggin <npiggin@suse.de> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15mm: CONFIG_MMU for PG_mlockedHugh Dickins
Remove three degrees of obfuscation, left over from when we had CONFIG_UNEVICTABLE_LRU. MLOCK_PAGES is CONFIG_HAVE_MLOCKED_PAGE_BIT is CONFIG_HAVE_MLOCK is CONFIG_MMU. rmap.o (and memory-failure.o) are only built when CONFIG_MMU, so don't need such conditions at all. Somehow, I feel no compulsion to remove the CONFIG_HAVE_MLOCK* lines from 169 defconfigs: leave those to evolve in due course. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Izik Eidus <ieidus@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Nick Piggin <npiggin@suse.de> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15mm: mlocking in try_to_unmap_oneHugh Dickins
There's contorted mlock/munlock handling in try_to_unmap_anon() and try_to_unmap_file(), which we'd prefer not to repeat for KSM swapping. Simplify it by moving it all down into try_to_unmap_one(). One thing is then lost, try_to_munlock()'s distinction between when no vma holds the page mlocked, and when a vma does mlock it, but we could not get mmap_sem to set the page flag. But its only caller takes no interest in that distinction (and is better testing SWAP_MLOCK anyway), so let's keep the code simple and return SWAP_AGAIN for both cases. try_to_unmap_file()'s TTU_MUNLOCK nonlinear handling was particularly amusing: once unravelled, it turns out to have been choosing between two different ways of doing the same nothing. Ah, no, one way was actually returning SWAP_FAIL when it meant to return SWAP_SUCCESS. [kosaki.motohiro@jp.fujitsu.com: comment adding to mlocking in try_to_unmap_one] [akpm@linux-foundation.org: remove test of MLOCK_PAGES] Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Izik Eidus <ieidus@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15mm: define PAGE_MAPPING_FLAGSHugh Dickins
At present we define PageAnon(page) by the low PAGE_MAPPING_ANON bit set in page->mapping, with the higher bits a pointer to the anon_vma; and have defined PageKsm(page) as that with NULL anon_vma. But KSM swapping will need to store a pointer there: so in preparation for that, now define PAGE_MAPPING_FLAGS as the low two bits, including PAGE_MAPPING_KSM (always set along with PAGE_MAPPING_ANON, until some other use for the bit emerges). Declare page_rmapping(page) to return the pointer part of page->mapping, and page_anon_vma(page) to return the anon_vma pointer when that's what it is. Use these in a few appropriate places: notably, unuse_vma() has been testing page->mapping, but is better to be testing page_anon_vma() (cases may be added in which flag bits are set without any pointer). Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Izik Eidus <ieidus@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Nick Piggin <npiggin@suse.de> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15rmap: move label `out' to a better placeHuang Shijie
When the code jumps to the `out', `referenced' is still zero. So there is no need to check it. Signed-off-by: Huang Shijie <shijie8@gmail.com> Acked-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15rmap: simplify try_to_unmap_file()Huang Shijie
Just simplify the code when `mlocked' is true. Signed-off-by: Huang Shijie <shijie8@gmail.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15rmap: fix the comment for try_to_unmap_anonHuang Shijie
Fix the comment for try_to_unmap_anon() with the new arguments. Signed-off-by: Huang Shijie <shijie8@gmail.com> Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15swap_info: swap count continuationsHugh Dickins
Swap is duplicated (reference count incremented by one) whenever the same swap page is inserted into another mm (when forking finds a swap entry in place of a pte, or when reclaim unmaps a pte to insert the swap entry). swap_info_struct's vmalloc'ed swap_map is the array of these reference counts: but what happens when the unsigned short (or unsigned char since the preceding patch) is full? (and its high bit is kept for a cache flag) We then lose track of it, never freeing, leaving it in use until swapoff: at which point we _hope_ that a single pass will have found all instances, assume there are no more, and will lose user data if we're wrong. Swapping of KSM pages has not yet been enabled; but it is implemented, and makes it very easy for a user to overflow the maximum swap count: possible with ordinary process pages, but unlikely, even when pid_max has been raised from PID_MAX_DEFAULT. This patch implements swap count continuations: when the count overflows, a continuation page is allocated and linked to the original vmalloc'ed map page, and this used to hold the continuation counts for that entry and its neighbours. These continuation pages are seldom referenced: the common paths all work on the original swap_map, only referring to a continuation page when the low "digit" of a count is incremented or decremented through SWAP_MAP_MAX. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-01mm/rmap.c: fix commentHuang Shijie
The page_address_in_vma() is not only used in unuse_vma(). Signed-off-by: Huang Shijie <shijie8@gmail.com> Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24Merge branch 'hwpoison' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6 * 'hwpoison' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6: (21 commits) HWPOISON: Enable error_remove_page on btrfs HWPOISON: Add simple debugfs interface to inject hwpoison on arbitary PFNs HWPOISON: Add madvise() based injector for hardware poisoned pages v4 HWPOISON: Enable error_remove_page for NFS HWPOISON: Enable .remove_error_page for migration aware file systems HWPOISON: The high level memory error handler in the VM v7 HWPOISON: Add PR_MCE_KILL prctl to control early kill behaviour per process HWPOISON: shmem: call set_page_dirty() with locked page HWPOISON: Define a new error_remove_page address space op for async truncation HWPOISON: Add invalidate_inode_page HWPOISON: Refactor truncate to allow direct truncating of page v2 HWPOISON: check and isolate corrupted free pages v2 HWPOISON: Handle hardware poisoned pages in try_to_unmap HWPOISON: Use bitmask/action code for try_to_unmap behaviour HWPOISON: x86: Add VM_FAULT_HWPOISON handling to x86 page fault handler v2 HWPOISON: Add poison check to page fault handling HWPOISON: Add basic support for poisoned pages in fault handler v3 HWPOISON: Add new SIGBUS error codes for hardware poison signals HWPOISON: Add support for poison swap entries v2 HWPOISON: Export some rmap vma locking to outside world ...
2009-09-22ksm: no debug in page_dup_rmap()Hugh Dickins
page_dup_rmap(), used on each mapped page when forking, was originally just an inline atomic_inc of mapcount. 2.6.22 added CONFIG_DEBUG_VM out-of-line checks to it, which would need to be ever-so-slightly complicated to allow for the PageKsm() we're about to define. But I think these checks never caught anything. And if it's coding errors we're worried about, such checks should be in page_remove_rmap() too, not just when forking; whereas if it's pagetable corruption we're worried about, then they shouldn't be limited to CONFIG_DEBUG_VM. Oh, just revert page_dup_rmap() to an inline atomic_inc of mapcount. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Chris Wright <chrisw@redhat.com> Signed-off-by: Izik Eidus <ieidus@redhat.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Avi Kivity <avi@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22mm: clean up page_remove_rmap()KOSAKI Motohiro
page_remove_rmap() has multiple PageAnon() tests and it has deep nesting. Clean this up. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-16HWPOISON: The high level memory error handler in the VM v7Andi Kleen
Add the high level memory handler that poisons pages that got corrupted by hardware (typically by a two bit flip in a DIMM or a cache) on the Linux level. The goal is to prevent everyone from accessing these pages in the future. This done at the VM level by marking a page hwpoisoned and doing the appropriate action based on the type of page it is. The code that does this is portable and lives in mm/memory-failure.c To quote the overview comment: High level machine check handler. Handles pages reported by the hardware as being corrupted usually due to a 2bit ECC memory or cache failure. This focuses on pages detected as corrupted in the background. When the current CPU tries to consume corruption the currently running process can just be killed directly instead. This implies that if the error cannot be handled for some reason it's safe to just ignore it because no corruption has been consumed yet. Instead when that happens another machine check will happen. Handles page cache pages in various states. The tricky part here is that we can access any page asynchronous to other VM users, because memory failures could happen anytime and anywhere, possibly violating some of their assumptions. This is why this code has to be extremely careful. Generally it tries to use normal locking rules, as in get the standard locks, even if that means the error handling takes potentially a long time. Some of the operations here are somewhat inefficient and have non linear algorithmic complexity, because the data structures have not been optimized for this case. This is in particular the case for the mapping from a vma to a process. Since this case is expected to be rare we hope we can get away with this. There are in principle two strategies to kill processes on poison: - just unmap the data and wait for an actual reference before killing - kill as soon as corruption is detected. Both have advantages and disadvantages and should be used in different situations. Right now both are implemented and can be switched with a new sysctl vm.memory_failure_early_kill The default is early kill. The patch does some rmap data structure walking on its own to collect processes to kill. This is unusual because normally all rmap data structure knowledge is in rmap.c only. I put it here for now to keep everything together and rmap knowledge has been seeping out anyways Includes contributions from Johannes Weiner, Chris Mason, Fengguang Wu, Nick Piggin (who did a lot of great work) and others. Cc: npiggin@suse.de Cc: riel@redhat.com Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rik van Riel <riel@redhat.com> Reviewed-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com>
2009-09-16HWPOISON: Handle hardware poisoned pages in try_to_unmapAndi Kleen
When a page has the poison bit set replace the PTE with a poison entry. This causes the right error handling to be done later when a process runs into it. v2: add a new flag to not do that (needed for the memory-failure handler later) (Fengguang) v3: remove unnecessary is_migration_entry() test (Fengguang, Minchan) Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-09-16HWPOISON: Use bitmask/action code for try_to_unmap behaviourAndi Kleen
try_to_unmap currently has multiple modi (migration, munlock, normal unmap) which are selected by magic flag variables. The logic is not very straight forward, because each of these flag change multiple behaviours (e.g. migration turns off aging, not only sets up migration ptes etc.) Also the different flags interact in magic ways. A later patch in this series adds another mode to try_to_unmap, so this becomes quickly unmanageable. Replace the different flags with a action code (migration, munlock, munmap) and some additional flags as modifiers (ignore mlock, ignore aging). This makes the logic more straight forward and allows easier extension to new behaviours. Change all the caller to declare what they want to do. This patch is supposed to be a nop in behaviour. If anyone can prove it is not that would be a bug. Cc: Lee.Schermerhorn@hp.com Cc: npiggin@suse.de Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-09-16HWPOISON: Export some rmap vma locking to outside worldAndi Kleen
Needed for later patch that walks rmap entries on its own. This used to be very frowned upon, but memory-failure.c does some rather specialized rmap walking and rmap has been stable for quite some time, so I think it's ok now to export it. Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-08-26mm: fix for infinite churning of mlocked pagesMinchan Kim
An mlocked page might lose the isolatation race. This causes the page to clear PG_mlocked while it remains in a VM_LOCKED vma. This means it can be put onto the [in]active list. We can rescue it by using try_to_unmap() in shrink_page_list(). But now, As Wu Fengguang pointed out, vmscan has a bug. If the page has PG_referenced, it can't reach try_to_unmap() in shrink_page_list() but is put into the active list. If the page is referenced repeatedly, it can remain on the [in]active list without being moving to the unevictable list. This patch fixes it. Reported-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: KOSAKI Motohiro <<kosaki.motohiro@jp.fujitsu.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18memcg: add file-based RSS accountingBalbir Singh
Add file RSS tracking per memory cgroup We currently don't track file RSS, the RSS we report is actually anon RSS. All the file mapped pages, come in through the page cache and get accounted there. This patch adds support for accounting file RSS pages. It should 1. Help improve the metrics reported by the memory resource controller 2. Will form the basis for a future shared memory accounting heuristic that has been proposed by Kamezawa. Unfortunately, we cannot rename the existing "rss" keyword used in memory.stat to "anon_rss". We however, add "mapped_file" data and hope to educate the end user through documentation. [hugh.dickins@tiscali.co.uk: fix mem_cgroup_update_mapped_file_stat oops] Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.cn> Cc: Paul Menage <menage@google.com> Cc: Dhaval Giani <dhaval@linux.vnet.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16vmscan: report vm_flags in page_referenced()Wu Fengguang
Collect vma->vm_flags of the VMAs that actually referenced the page. This is preparing for more informed reclaim heuristics, eg. to protect executable file pages more aggressively. For now only the VM_EXEC bit will be used by the caller. Thanks to Johannes, Peter and Minchan for all the good tips. Acked-by: Peter Zijlstra <peterz@infradead.org> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16mm: remove CONFIG_UNEVICTABLE_LRU config optionKOSAKI Motohiro
Currently, nobody wants to turn UNEVICTABLE_LRU off. Thus this configurability is unnecessary. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Andi Kleen <andi@firstfloor.org> Acked-by: Minchan Kim <minchan.kim@gmail.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Matt Mackall <mpm@selenic.com> Cc: Rik van Riel <riel@redhat.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-21hugh: update email addressHugh Dickins
My old address will shut down in a few days time: remove it from the tree, and add a tmpfs (shmem filesystem) maintainer entry with the new address. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-11mm: fix mlocked page counter mismatchMinChan Kim
When I tested following program, I found that the mlocked counter is strange. It cannot free some mlocked pages. It is because try_to_unmap_file() doesn't check real page mappings in vmas. That is because the goal of an address_space for a file is to find all processes into which the file's specific interval is mapped. It is related to the file's interval, not to pages. Even if the page isn't really mapped by the vma, it returns SWAP_MLOCK since the vma has VM_LOCKED, then calls try_to_mlock_page. After this the mlocked counter is increased again. COWed anon page in a file-backed vma could be a such case. This patch resolves it. -- my test program -- int main() { mlockall(MCL_CURRENT); return 0; } -- before -- root@barrios-target-linux:~# cat /proc/meminfo | egrep 'Mlo|Unev' Unevictable: 0 kB Mlocked: 0 kB -- after -- root@barrios-target-linux:~# cat /proc/meminfo | egrep 'Mlo|Unev' Unevictable: 8 kB Mlocked: 8 kB Signed-off-by: MinChan Kim <minchan.kim@gmail.com> Acked-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Tested-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06badpage: remove vma from page_remove_rmapHugh Dickins
Remove page_remove_rmap()'s vma arg, which was only for the Eeek message. And remove the BUG_ON(page_mapcount(page) == 0) from CONFIG_DEBUG_VM's page_dup_rmap(): we're trying to be more resilient about that than BUGs. Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06badpage: replace page_remove_rmap Eeek and BUGHugh Dickins
Now that bad pages are kept out of circulation, there is no need for the infamous page_remove_rmap() BUG() - once that page is freed, its negative mapcount will issue a "Bad page state" message and the page won't be freed. Removing the BUG() allows more info, on subsequent pages, to be gathered. We do have more info about the page at this point than bad_page() can know - notably, what the pmd is, which might pinpoint something like low 64kB corruption - but page_remove_rmap() isn't given the address to find that. In practice, there is only one call to page_remove_rmap() which has ever reported anything, that from zap_pte_range() (usually on exit, sometimes on munmap). It has all the info, so remove page_remove_rmap()'s "Eeek" message and leave it all to zap_pte_range(). mm/memory.c already has a hardly used print_bad_pte() function, showing some of the appropriate info: extend it to show what we want for the rmap case: pte info, page info (when there is a page) and vma info to compare. zap_pte_range() already knows the pmd, but print_bad_pte() is easier to use if it works that out for itself. Some of this info is also shown in bad_page()'s "Bad page state" message. Keep them separate, but adjust them to match each other as far as possible. Say "Bad page map" in print_bad_pte(), and add a TAINT_BAD_PAGE there too. print_bad_pte() show current->comm unconditionally (though it should get repeated in the usually irrelevant stack trace): sorry, I misled Nick Piggin to make it conditional on vm_mm == current->mm, but current->mm is already NULL in the exit case. Usually current->comm is good, though exceptionally it may not be that of the mm (when "swapoff" for example). Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06mm: further cleanup page_add_new_anon_rmapHugh Dickins
Moving lru_cache_add_active_or_unevictable() into page_add_new_anon_rmap() was good but stupid: we can and should SetPageSwapBacked() there too; and we know for sure that this anonymous, swap-backed page is not file cache. Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06mm: make page_lock_anon_vma() staticHugh Dickins
page_lock_anon_vma() and page_unlock_anon_vma() were made available to show_page_path() in vmscan.c; but now that has been removed, make them static in rmap.c again, they're better kept private if possible. Signed-off-by: Hugh Dickins <hugh@veritas.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06mm: add_active_or_unevictable into rmapHugh Dickins
lru_cache_add_active_or_unevictable() and page_add_new_anon_rmap() always appear together. Save some symbol table space and some jumping around by removing lru_cache_add_active_or_unevictable(), folding its code into page_add_new_anon_rmap(): like how we add file pages to lru just after adding them to page cache. Remove the nearby "TODO: is this safe?" comments (yes, it is safe), and change page_add_new_anon_rmap()'s address BUG_ON to VM_BUG_ON as originally intended. Signed-off-by: Hugh Dickins <hugh@veritas.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06mm: more likely reclaim MADV_SEQUENTIAL mappingsJohannes Weiner
File pages mapped only in sequentially read mappings are perfect reclaim canditates. This patch makes these mappings behave like weak references, their pages will be reclaimed unless they have a strong reference from a normal mapping as well. It changes the reclaim and the unmap path where they check if the page has been referenced. In both cases, accesses through sequentially read mappings will be ignored. Benchmark results from KOSAKI Motohiro: http://marc.info/?l=linux-mm&m=122485301925098&w=2 Signed-off-by: Johannes Weiner <hannes@saeurebad.de> Signed-off-by: Rik van Riel <riel@redhat.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
