path: root/mm/sparse.c
2006-05-15[PATCH] add slab_is_available() routine for boot codeMike Kravetz
slab_is_available() indicates slab based allocators are available for use. SPARSEMEM code needs to know this as it can be called at various times during the boot process. Signed-off-by: Mike Kravetz <kravetz@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-01[PATCH] sparsemem interaction with memory add bug fixesMike Kravetz
This patch fixes two bugs with the way sparsemem interacts with memory add. They are: - memory leak if memmap for section already exists - calling alloc_bootmem_node() after boot These bugs were discovered and a first cut at the fixes were provided by Arnd Bergmann <arnd@arndb.de> and Joel Schopp <jschopp@us.ibm.com>. Signed-off-by: Mike Kravetz <kravetz@us.ibm.com> Signed-off-by: Joel Schopp <jschopp@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] Change maxaligned_in_smp alignemnt macros to internodealigned_in_smp ↵Ravikiran G Thirumalai
macros ____cacheline_maxaligned_in_smp is currently used to align critical structures and avoid false sharing. It uses per-arch L1_CACHE_SHIFT_MAX and people find L1_CACHE_SHIFT_MAX useless. However, we have been using ____cacheline_maxaligned_in_smp to align structures on the internode cacheline size. As per Andi's suggestion, following patch kills ____cacheline_maxaligned_in_smp and introduces INTERNODE_CACHE_SHIFT, which defaults to L1_CACHE_SHIFT for all arches. Arches needing L3/Internode cacheline alignment can define INTERNODE_CACHE_SHIFT in the arch asm/cache.h. Patch replaces ____cacheline_maxaligned_in_smp with ____cacheline_internodealigned_in_smp With this patch, L1_CACHE_SHIFT_MAX can be killed Signed-off-by: Ravikiran Thirumalai <kiran@scalex86.org> Signed-off-by: Shai Fultheim <shai@scalex86.org> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] memory hotplug: move section_mem_map alloc to sparse.cDave Hansen
This basically keeps up from having to extern __kmalloc_section_memmap(). The vaddr_in_vmalloc_area() helper could go in a vmalloc header, but that header gets hard to work with, because it needs some arch-specific macros. Just stick it in here for now, instead of creating another header. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Lion Vollnhals <webmaster@schiggl.de> Signed-off-by: Jiri Slaby <xslaby@fi.muni.cz> Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] memory hotplug prep: __section_nr helperDave Hansen
A little helper that we use in the hotplug code. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] sparsemem extreme: hotplug preparationDave Hansen
This splits up sparse_index_alloc() into two pieces. This is needed because we'll allocate the memory for the second level in a different place from where we actually consume it to keep the allocation from happening underneath a lock Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Bob Picco <bob.picco@hp.com> Cc: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] sparsemem extreme implementationBob Picco
With cleanups from Dave Hansen <haveblue@us.ibm.com> SPARSEMEM_EXTREME makes mem_section a one dimensional array of pointers to mem_sections. This two level layout scheme is able to achieve smaller memory requirements for SPARSEMEM with the tradeoff of an additional shift and load when fetching the memory section. The current SPARSEMEM implementation is a one dimensional array of mem_sections which is the default SPARSEMEM configuration. The patch attempts isolates the implementation details of the physical layout of the sparsemem section array. SPARSEMEM_EXTREME requires bootmem to be functioning at the time of memory_present() calls. This is not always feasible, so architectures which do not need it may allocate everything statically by using SPARSEMEM_STATIC. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Bob Picco <bob.picco@hp.com> Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] SPARSEMEM EXTREMEBob Picco
A new option for SPARSEMEM is ARCH_SPARSEMEM_EXTREME. Architecture platforms with a very sparse physical address space would likely want to select this option. For those architecture platforms that don't select the option, the code generated is equivalent to SPARSEMEM currently in -mm. I'll be posting a patch on ia64 ml which uses this new SPARSEMEM feature. ARCH_SPARSEMEM_EXTREME makes mem_section a one dimensional array of pointers to mem_sections. This two level layout scheme is able to achieve smaller memory requirements for SPARSEMEM with the tradeoff of an additional shift and load when fetching the memory section. The current SPARSEMEM -mm implementation is a one dimensional array of mem_sections which is the default SPARSEMEM configuration. The patch attempts isolates the implementation details of the physical layout of the sparsemem section array. ARCH_SPARSEMEM_EXTREME depends on 64BIT and is by default boolean false. I've boot tested under aim load ia64 configured for ARCH_SPARSEMEM_EXTREME. I've also boot tested a 4 way Opteron machine with !ARCH_SPARSEMEM_EXTREME and tested with aim. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Bob Picco <bob.picco@hp.com> Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] sparsemem hotplug baseAndy Whitcroft
Make sparse's initalization be accessible at runtime. This allows sparse mappings to be created after boot in a hotplug situation. This patch is separated from the previous one just to give an indication how much of the sparse infrastructure is *just* for hotplug memory. The section_mem_map doesn't really store a pointer. It stores something that is convenient to do some math against to get a pointer. It isn't valid to just do *section_mem_map, so I don't think it should be stored as a pointer. There are a couple of things I'd like to store about a section. First of all, the fact that it is !NULL does not mean that it is present. There could be such a combination where section_mem_map *is* NULL, but the math gets you properly to a real mem_map. So, I don't think that check is safe. Since we're storing 32-bit-aligned structures, we have a few bits in the bottom of the pointer to play with. Use one bit to encode whether there's really a mem_map there, and the other one to tell whether there's a valid section there. We need to distinguish between the two because sometimes there's a gap between when a section is discovered to be present and when we can get the mem_map for it. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Bob Picco <bob.picco@hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] sparsemem memory modelAndy Whitcroft
Sparsemem abstracts the use of discontiguous mem_maps[]. This kind of mem_map[] is needed by discontiguous memory machines (like in the old CONFIG_DISCONTIGMEM case) as well as memory hotplug systems. Sparsemem replaces DISCONTIGMEM when enabled, and it is hoped that it can eventually become a complete replacement. A significant advantage over DISCONTIGMEM is that it's completely separated from CONFIG_NUMA. When producing this patch, it became apparent in that NUMA and DISCONTIG are often confused. Another advantage is that sparse doesn't require each NUMA node's ranges to be contiguous. It can handle overlapping ranges between nodes with no problems, where DISCONTIGMEM currently throws away that memory. Sparsemem uses an array to provide different pfn_to_page() translations for each SECTION_SIZE area of physical memory. This is what allows the mem_map[] to be chopped up. In order to do quick pfn_to_page() operations, the section number of the page is encoded in page->flags. Part of the sparsemem infrastructure enables sharing of these bits more dynamically (at compile-time) between the page_zone() and sparsemem operations. However, on 32-bit architectures, the number of bits is quite limited, and may require growing the size of the page->flags type in certain conditions. Several things might force this to occur: a decrease in the SECTION_SIZE (if you want to hotplug smaller areas of memory), an increase in the physical address space, or an increase in the number of used page->flags. One thing to note is that, once sparsemem is present, the NUMA node information no longer needs to be stored in the page->flags. It might provide speed increases on certain platforms and will be stored there if there is room. But, if out of room, an alternate (theoretically slower) mechanism is used. This patch introduces CONFIG_FLATMEM. It is used in almost all cases where there used to be an #ifndef DISCONTIG, because SPARSEMEM and DISCONTIGMEM often have to compile out the same areas of code. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Martin Bligh <mbligh@aracnet.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Bob Picco <bob.picco@hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
