path: root/mm/swap.c
2006-03-28[PATCH] for_each_possible_cpu: fixes for generic partKAMEZAWA Hiroyuki
replaces for_each_cpu with for_each_possible_cpu(). Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[PATCH] mm: less atomic opsNick Piggin
In the page release paths, we can be sure that nobody will mess with our page->flags because the refcount has dropped to 0. So no need for atomic operations here. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[PATCH] mm: PageActive no testsetNick Piggin
PG_active is protected by zone->lru_lock, it does not need TestSet/TestClear operations. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[PATCH] mm: PageLRU no testsetNick Piggin
PG_lru is protected by zone->lru_lock. It does not need TestSet/TestClear operations. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[PATCH] mm: never ClearPageLRU released pagesNick Piggin
If vmscan finds a zero refcount page on the lru list, never ClearPageLRU it. This means the release code need not hold ->lru_lock to stabilise PageLRU, so that lock may be skipped entirely when releasing !PageLRU pages (because we know PageLRU won't have been temporarily cleared by vmscan, which was previously guaranteed by holding the lock to synchronise against vmscan). Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-17[PATCH] fix race in pagevec_strip?Christoph Lameter
We can call try_to_release_page() with PagePrivate off and a valid page->mapping This may cause all sorts of trouble for the filesystem *_releasepage() handlers. XFS bombs out in that case. Lock the page before checking for page private. Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-08[PATCH] percpu_counter_sum()Andrew Morton
Implement percpu_counter_sum(). This is a more accurate but slower version of percpu_counter_read_positive(). We need this for Alex's speedup-ext3_statfs patch and for the nr_file accounting fix. Otherwise these things would be too inaccurate on large CPU counts. Cc: Ravikiran G Thirumalai <kiran@scalex86.org> Cc: Alex Tomas <alex@clusterfs.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-14[PATCH] compound page: use page[1].lruHugh Dickins
If a compound page has its own put_page_testzero destructor (the only current example is free_huge_page), that is noted in page[1].mapping of the compound page. But that's rather a poor place to keep it: functions which call set_page_dirty_lock after get_user_pages (e.g. Infiniband's __ib_umem_release) ought to be checking first, otherwise set_page_dirty is liable to crash on what's not the address of a struct address_space. And now I'm about to make that worse: it turns out that every compound page needs a destructor, so we can no longer rely on hugetlb pages going their own special way, to avoid further problems of page->mapping reuse. For example, not many people know that: on 50% of i386 -Os builds, the first tail page of a compound page purports to be PageAnon (when its destructor has an odd address), which surprises page_add_file_rmap. Keep the compound page destructor in page[1].lru.next instead. And to free up the common pairing of mapping and index, also move compound page order from index to lru.prev. Slab reuses page->lru too: but if we ever need slab to use compound pages, it can easily stack its use above this. (akpm: decoded version of the above: the tail pages of a compound page now have ->mapping==NULL, so there's no need for the set_page_dirty[_lock]() caller to check that they're not compund pages before doing the dirty). Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-07[PATCH] mm: compound release fixNick Piggin
Compound pages on SMP systems can now often be freed from pagetables via the release_pages path. This uses put_page_testzero which does not handle compound pages at all. Releasing constituent pages from process mappings decrements their count to a large negative number and leaks the reference at the head page - net result is a memory leak. The problem was hidden because the debug check in put_page_testzero itself actually did take compound pages into consideration. Fix the bug and the debug check. Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] mm: migration page refcounting fixNick Piggin
Migration code currently does not take a reference to target page properly, so between unlocking the pte and trying to take a new reference to the page with isolate_lru_page, anything could happen to it. Fix this by holding the pte lock until we get a chance to elevate the refcount. Other small cleanups while we're here. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[XFS] Export pagevec_lookup for use on the XFS page writeout path,Christoph Hellwig
for dealing with delayed allocate and unwritten extents (as well). Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-06[PATCH] consolidate lru_add_drain() and lru_drain_cache()Andrew Morton
Cc: Christoph Lameter <clameter@engr.sgi.com> Cc: Rajesh Shah <rajesh.shah@intel.com> Cc: Li Shaohua <shaohua.li@intel.com> Cc: Srivatsa Vaddagiri <vatsa@in.ibm.com> Cc: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-22[PATCH] unpaged: unifdefed PageCompoundHugh Dickins
It looks like snd_xxx is not the only nopage to be using PageReserved as a way of holding a high-order page together: which no longer works, but is masked by our failure to free from VM_RESERVED areas. We cannot fix that bug without first substituting another way to hold the high-order page together, while farming out the 0-order pages from within it. That's just what PageCompound is designed for, but it's been kept under CONFIG_HUGETLB_PAGE. Remove the #ifdefs: which saves some space (out- of-line put_page), doesn't slow down what most needs to be fast (already using hugetlb), and unifies the way we handle high-order pages. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] mm/swap.c: unexport vm_acct_memoryAdrian Bunk
I didn't find any possible modular usage in the kernel. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-01Export __pagevec_release and pagevec_lookup_tagSteve French
These are needed to implement cifs_writepages Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2005-10-30[PATCH] vm: remove redundant assignment from __pagevec_release_nonlru()Tejun Heo
This patch removes redundant assignment from __pagevec_release_nonlru(). pages_to_free.cold is set to pvec->cold by pagevec_init() call right above the assignment. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] mm: split page table lockHugh Dickins
Christoph Lameter demonstrated very poor scalability on the SGI 512-way, with a many-threaded application which concurrently initializes different parts of a large anonymous area. This patch corrects that, by using a separate spinlock per page table page, to guard the page table entries in that page, instead of using the mm's single page_table_lock. (But even then, page_table_lock is still used to guard page table allocation, and anon_vma allocation.) In this implementation, the spinlock is tucked inside the struct page of the page table page: with a BUILD_BUG_ON in case it overflows - which it would in the case of 32-bit PA-RISC with spinlock debugging enabled. Splitting the lock is not quite for free: another cacheline access. Ideally, I suppose we would use split ptlock only for multi-threaded processes on multi-cpu machines; but deciding that dynamically would have its own costs. So for now enable it by config, at some number of cpus - since the Kconfig language doesn't support inequalities, let preprocessor compare that with NR_CPUS. But I don't think it's worth being user-configurable: for good testing of both split and unsplit configs, split now at 4 cpus, and perhaps change that to 8 later. There is a benefit even for singly threaded processes: kswapd can be attacking one part of the mm while another part is busy faulting. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] core remove PageReservedNick Piggin
Remove PageReserved() calls from core code by tightening VM_RESERVED handling in mm/ to cover PageReserved functionality. PageReserved special casing is removed from get_page and put_page. All setting and clearing of PageReserved is retained, and it is now flagged in the page_alloc checks to help ensure we don't introduce any refcount based freeing of Reserved pages. MAP_PRIVATE, PROT_WRITE of VM_RESERVED regions is tentatively being deprecated. We never completely handled it correctly anyway, and is be reintroduced in future if required (Hugh has a proof of concept). Once PageReserved() calls are removed from kernel/power/swsusp.c, and all arch/ and driver code, the Set and Clear calls, and the PG_reserved bit can be trivially removed. Last real user of PageReserved is swsusp, which uses PageReserved to determine whether a struct page points to valid memory or not. This still needs to be addressed (a generic page_is_ram() should work). A last caveat: the ZERO_PAGE is now refcounted and managed with rmap (and thus mapcounted and count towards shared rss). These writes to the struct page could cause excessive cacheline bouncing on big systems. There are a number of ways this could be addressed if it is an issue. Signed-off-by: Nick Piggin <npiggin@suse.de> Refcount bug fix for filemap_xip.c Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
