path: root/mm/thrash.c
2011-07-25mm: swap-token: add a comment for priority agingKOSAKI Motohiro
Document some swap token aging design decisions. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25mm: swap-token: makes global variables to function localKOSAKI Motohiro
global_faults and last_aging are only used in grab_swap_token(). Move them into grab_swap_token(). Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25mm: swap-token: fix dead linkKOSAKI Motohiro
http://www.cs.wm.edu/~sjiang/token.pdf is now dead. Replace it with an alive alternative. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15vmscan: implement swap token priority agingKOSAKI Motohiro
While testing for memcg aware swap token, I observed a swap token was often grabbed an intermittent running process (eg init, auditd) and they never release a token. Why? Some processes (eg init, auditd, audispd) wake up when a process exiting. And swap token can be get first page-in process when a process exiting makes no swap token owner. Thus such above intermittent running process often get a token. And currently, swap token priority is only decreased at page fault path. Then, if the process sleep immediately after to grab swap token, the swap token priority never be decreased. That's obviously undesirable. This patch implement very poor (and lightweight) priority aging. It only be affect to the above corner case and doesn't change swap tendency workload performance (eg multi process qsbench load) Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15vmscan: implement swap token traceKOSAKI Motohiro
This is useful for observing swap token activity. example output: zsh-1845 [000] 598.962716: update_swap_token_priority: mm=ffff88015eaf7700 old_prio=1 new_prio=0 memtoy-1830 [001] 602.033900: update_swap_token_priority: mm=ffff880037a45880 old_prio=947 new_prio=949 memtoy-1830 [000] 602.041509: update_swap_token_priority: mm=ffff880037a45880 old_prio=949 new_prio=951 memtoy-1830 [000] 602.051959: update_swap_token_priority: mm=ffff880037a45880 old_prio=951 new_prio=953 memtoy-1830 [000] 602.052188: update_swap_token_priority: mm=ffff880037a45880 old_prio=953 new_prio=955 memtoy-1830 [001] 602.427184: put_swap_token: token_mm=ffff880037a45880 zsh-1789 [000] 602.427281: replace_swap_token: old_token_mm= (null) old_prio=0 new_token_mm=ffff88015eaf7018 new_prio=2 zsh-1789 [001] 602.433456: update_swap_token_priority: mm=ffff88015eaf7018 old_prio=2 new_prio=4 zsh-1789 [000] 602.437613: update_swap_token_priority: mm=ffff88015eaf7018 old_prio=4 new_prio=6 zsh-1789 [000] 602.443924: update_swap_token_priority: mm=ffff88015eaf7018 old_prio=6 new_prio=8 zsh-1789 [000] 602.451873: update_swap_token_priority: mm=ffff88015eaf7018 old_prio=8 new_prio=10 zsh-1789 [001] 602.462639: update_swap_token_priority: mm=ffff88015eaf7018 old_prio=10 new_prio=12 Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Rik van Riel<riel@redhat.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15vmscan,memcg: memcg aware swap tokenKOSAKI Motohiro
Currently, memcg reclaim can disable swap token even if the swap token mm doesn't belong in its memory cgroup. It's slightly risky. If an admin creates very small mem-cgroup and silly guy runs contentious heavy memory pressure workload, every tasks are going to lose swap token and then system may become unresponsive. That's bad. This patch adds 'memcg' parameter into disable_swap_token(). and if the parameter doesn't match swap token, VM doesn't disable it. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Rik van Riel<riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-23mm: pass mm to grab_swap_tokenHugh Dickins
If a kthread happens to use get_user_pages() on an mm (as KSM does), there's a chance that it will end up trying to read in a swap page, then oops in grab_swap_token() because the kthread has no mm: GUP passes down the right mm, so grab_swap_token() ought to be using it. We have not identified a stronger case than KSM's daemon (not yet in mainline), but the issue must have come up before, since RHEL has included a fix for this for years (though a different fix, they just back out of grab_swap_token if current->mm is unset: which is what we first proposed, but using the right mm here seems more correct). Reported-by: Izik Eidus <ieidus@redhat.com> Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11Bug in mm/thrash.c function grab_swap_token()Mika Kukkonen
Following bug was uncovered by compiling with '-W' flag: CC mm/thrash.o mm/thrash.c: In function ‘grab_swap_token’: mm/thrash.c:52: warning: comparison of unsigned expression < 0 is always false Variable token_priority is unsigned, so decrementing first and then checking the result does not work; fixed by reversing the test, patch attached (compile tested only). I am not sure if likely() makes much sense in this new situation, but I'll let somebody else to make a decision on that. Signed-off-by: Mika Kukkonen <mikukkon@iki.fi> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] make mm/thrash.c:global_faults staticAdrian Bunk
This patch makes the needlessly global "global_faults" static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] new scheme to preempt swap tokenAshwin Chaugule
The new swap token patches replace the current token traversal algo. The old algo had a crude timeout parameter that was used to handover the token from one task to another. This algo, transfers the token to the tasks that are in need of the token. The urgency for the token is based on the number of times a task is required to swap-in pages. Accordingly, the priority of a task is incremented if it has been badly affected due to swap-outs. To ensure that the token doesnt bounce around rapidly, the token holders are given a priority boost. The priority of tasks is also decremented, if their rate of swap-in's keeps reducing. This way, the condition to check whether to pre-empt the swap token, is a matter of comparing two task's priority fields. [akpm@osdl.org: cleanups] Signed-off-by: Ashwin Chaugule <ashwin.chaugule@celunite.com> Cc: Rik van Riel <riel@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-28[PATCH] temporarily disable swap token on memory pressureRik van Riel
Some users (hi Zwane) have seen a problem when running a workload that eats nearly all of physical memory - th system does an OOM kill, even when there is still a lot of swap free. The problem appears to be a very big task that is holding the swap token, and the VM has a very hard time finding any other page in the system that is swappable. Instead of ignoring the swap token when sc->priority reaches 0, we could simply take the swap token away from the memory hog and make sure we don't give it back to the memory hog for a few seconds. This patch resolves the problem Zwane ran into. Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] swaptoken tuningRik Van Riel
It turns out that the original swap token implementation, by Song Jiang, only enforced the swap token while the task holding the token is handling a page fault. This patch approximates that, without adding an additional flag to the mm_struct, by checking whether the mm->mmap_sem is held for reading, like the page fault code does. This patch has the effect of automatically, and gradually, disabling the enforcement of the swap token when there is little or no paging going on, and "turning up" the intensity of the swap token code the more the task holding the token is thrashing. Thanks to Song Jiang for pointing out this aspect of the token based thrashing control concept. The new code shows a slight degradation over the old swap token code, but still a big win over running without the swap token. 2.6.12+ swap token disabled $ for i in `seq 10` ; do /usr/bin/time ./qsbench -n 30000000 -p 3 ; done 101.74user 23.13system 8:26.91elapsed 24%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (38597major+430315minor)pagefaults 0swaps 101.98user 24.91system 8:03.06elapsed 26%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (33939major+430457minor)pagefaults 0swaps 101.93user 22.12system 7:34.90elapsed 27%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (33166major+421267minor)pagefaults 0swaps 101.82user 22.38system 8:31.40elapsed 24%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (39338major+433262minor)pagefaults 0swaps 2.6.12+ swap token enabled, timeout 300 seconds $ for i in `seq 4` ; do /usr/bin/time ./qsbench -n 30000000 -p 3 ; done 102.58user 16.08system 3:41.44elapsed 53%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (19707major+285786minor)pagefaults 0swaps 102.07user 19.56system 4:00.64elapsed 50%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (19012major+299259minor)pagefaults 0swaps 102.64user 18.25system 4:07.31elapsed 48%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (21990major+304831minor)pagefaults 0swaps 101.39user 19.41system 5:15.81elapsed 38%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (24850major+323321minor)pagefaults 0swaps 2.6.12+ with new swap token code, timeout 300 seconds $ for i in `seq 4` ; do /usr/bin/time ./qsbench -n 30000000 -p 3 ; done 101.87user 24.66system 5:53.20elapsed 35%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (26848major+363497minor)pagefaults 0swaps 102.83user 19.95system 4:17.25elapsed 47%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (19946major+305722minor)pagefaults 0swaps 102.09user 19.46system 5:12.57elapsed 38%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (25461major+334994minor)pagefaults 0swaps 101.67user 20.61system 4:52.97elapsed 41%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (22190major+329508minor)pagefaults 0swaps Signed-off-by: Rik Van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
