path: root/mm/truncate.c
2012-12-20mm: drop vmtruncateMarco Stornelli
Removed vmtruncate Signed-off-by: Marco Stornelli <marco.stornelli@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-10-09mm: use clear_page_mlock() in page_remove_rmap()Hugh Dickins
We had thought that pages could no longer get freed while still marked as mlocked; but Johannes Weiner posted this program to demonstrate that truncating an mlocked private file mapping containing COWed pages is still mishandled: #include <sys/types.h> #include <sys/mman.h> #include <sys/stat.h> #include <stdlib.h> #include <unistd.h> #include <fcntl.h> #include <stdio.h> int main(void) { char *map; int fd; system("grep mlockfreed /proc/vmstat"); fd = open("chigurh", O_CREAT|O_EXCL|O_RDWR); unlink("chigurh"); ftruncate(fd, 4096); map = mmap(NULL, 4096, PROT_WRITE, MAP_PRIVATE, fd, 0); map[0] = 11; mlock(map, sizeof(fd)); ftruncate(fd, 0); close(fd); munlock(map, sizeof(fd)); munmap(map, 4096); system("grep mlockfreed /proc/vmstat"); return 0; } The anon COWed pages are not caught by truncation's clear_page_mlock() of the pagecache pages; but unmap_mapping_range() unmaps them, so we ought to look out for them there in page_remove_rmap(). Indeed, why should truncation or invalidation be doing the clear_page_mlock() when removing from pagecache? mlock is a property of mapping in userspace, not a property of pagecache: an mlocked unmapped page is nonsensical. Reported-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik van Riel <riel@redhat.com> Cc: Michel Lespinasse <walken@google.com> Cc: Ying Han <yinghan@google.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09mm: fix invalidate_complete_page2() lock orderingHugh Dickins
In fuzzing with trinity, lockdep protested "possible irq lock inversion dependency detected" when isolate_lru_page() reenabled interrupts while still holding the supposedly irq-safe tree_lock: invalidate_inode_pages2 invalidate_complete_page2 spin_lock_irq(&mapping->tree_lock) clear_page_mlock isolate_lru_page spin_unlock_irq(&zone->lru_lock) isolate_lru_page() is correct to enable interrupts unconditionally: invalidate_complete_page2() is incorrect to call clear_page_mlock() while holding tree_lock, which is supposed to nest inside lru_lock. Both truncate_complete_page() and invalidate_complete_page() call clear_page_mlock() before taking tree_lock to remove page from radix_tree. I guess invalidate_complete_page2() preferred to test PageDirty (again) under tree_lock before committing to the munlock; but since the page has already been unmapped, its state is already somewhat inconsistent, and no worse if clear_page_mlock() moved up. Reported-by: Sasha Levin <levinsasha928@gmail.com> Deciphered-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Cc: Rik van Riel <riel@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michel Lespinasse <walken@google.com> Cc: Ying Han <yinghan@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29mm/fs: remove truncate_rangeHugh Dickins
Remove vmtruncate_range(), and remove the truncate_range method from struct inode_operations: only tmpfs ever supported it, and tmpfs has now converted over to using the fallocate method of file_operations. Update Documentation accordingly, adding (setlease and) fallocate lines. And while we're in mm.h, remove duplicate declarations of shmem_lock() and shmem_file_setup(): everyone is now using the ones in shmem_fs.h. Based-on-patch-by: Cong Wang <amwang@redhat.com> Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Cong Wang <amwang@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28mm for fs: add truncate_pagecache_range()Hugh Dickins
Holepunching filesystems ext4 and xfs are using truncate_inode_pages_range but forgetting to unmap pages first (ocfs2 remembers). This is not really a bug, since races already require truncate_inode_page() to handle that case once the page is locked; but it can be very inefficient if the file being punched happens to be mapped into many vmas. Provide a drop-in replacement truncate_pagecache_range() which does the unmapping pass first, handling the awkward mismatch between arguments to truncate_inode_pages_range() and arguments to unmap_mapping_range(). Note that holepunching does not unmap privately COWed pages in the range: POSIX requires that we do so when truncating, but it's hard to justify, difficult to implement without an i_size cutoff, and no filesystem is attempting to implement it. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Andreas Dilger <adilger.kernel@dilger.ca> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Ben Myers <bpm@sgi.com> Cc: Alex Elder <elder@kernel.org> Cc: Christoph Hellwig <hch@lst.de> Cc: Dave Chinner <david@fromorbit.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-22Merge tag 'stable/for-linus-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/mm Pull cleancache changes from Konrad Rzeszutek Wilk: "This has some patches for the cleancache API that should have been submitted a _long_ time ago. They are basically cleanups: - rename of flush to invalidate - moving reporting of statistics into debugfs - use __read_mostly as necessary. Oh, and also the MAINTAINERS file change. The files (except the MAINTAINERS file) have been in #linux-next for months now. The late addition of MAINTAINERS file is a brain-fart on my side - didn't realize I needed that just until I was typing this up - and I based that patch on v3.3 - so the tree is on top of v3.3." * tag 'stable/for-linus-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/mm: MAINTAINERS: Adding cleancache API to the list. mm: cleancache: Use __read_mostly as appropiate. mm: cleancache: report statistics via debugfs instead of sysfs. mm: zcache/tmem/cleancache: s/flush/invalidate/ mm: cleancache: s/flush/invalidate/
2012-02-23mm: fix comment typo of truncate_inode_pages_rangeLiu Bo
The typo of API truncate_inode_pages_range is not updated. Signed-off-by: Liu Bo <liubo2009@cn.fujitsu.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-01-23mm: cleancache: s/flush/invalidate/Dan Magenheimer
Per akpm suggestions alter the use of the term flush to be invalidate. The next patch will do this across all MM. This change is completely cosmetic. [v9: akpm@linux-foundation.org: change "flush" to "invalidate", part 3] Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com> Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Jan Beulich <JBeulich@novell.com> Reviewed-by: Seth Jennings <sjenning@linux.vnet.ibm.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Hugh Dickins <hughd@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Nitin Gupta <ngupta@vflare.org> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Chris Mason <chris.mason@oracle.com> Cc: Rik Riel <riel@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> [v10: Fixed fs: move code out of buffer.c conflict change] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-10-31mm: Map most files to use export.h instead of module.hPaul Gortmaker
The files changed within are only using the EXPORT_SYMBOL macro variants. They are not using core modular infrastructure and hence don't need module.h but only the export.h header. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-08-03mm: a few small updates for radix-swapHugh Dickins
Remove PageSwapBacked (!page_is_file_cache) cases from add_to_page_cache_locked() and add_to_page_cache_lru(): those pages now go through shmem_add_to_page_cache(). Remove a comment on maximum tmpfs size from fsstack_copy_inode_size(), and add a comment on swap entries to invalidate_mapping_pages(). And mincore_page() uses find_get_page() on what might be shmem or a tmpfs file: allow for a radix_tree_exceptional_entry(), and proceed to find_get_page() on swapper_space if so (oh, swapper_space needs #ifdef). Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25mm: pincer in truncate_inode_pages_rangeHugh Dickins
truncate_inode_pages_range()'s final loop has a nice pincer property, bringing start and end together, squeezing out the last pages. But the range handling missed out on that, just sliding up the range, perhaps letting pages come in behind it. Add one more test to give it the same pincer effect. Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25mm: consistent truncate and invalidate loopsHugh Dickins
Make the pagevec_lookup loops in truncate_inode_pages_range(), invalidate_mapping_pages() and invalidate_inode_pages2_range() more consistent with each other. They were relying upon page->index of an unlocked page, but apologizing for it: accept it, embrace it, add comments and WARN_ONs, and simplify the index handling. invalidate_inode_pages2_range() had special handling for a wrapped page->index + 1 = 0 case; but MAX_LFS_FILESIZE doesn't let us anywhere near there, and a corrupt page->index in the radix_tree could cause more trouble than that would catch. Remove that wrapped handling. invalidate_inode_pages2_range() uses min() to limit the pagevec_lookup when near the end of the range: copy that into the other two, although it's less useful than you might think (it limits the use of the buffer, rather than the indices looked up). Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25mm: tidy vmtruncate_range and related functionsHugh Dickins
Use consistent variable names in truncate_pagecache(), truncate_setsize(), vmtruncate() and vmtruncate_range(). unmap_mapping_range() and vmtruncate_range() have mismatched interfaces: don't change either, but make the vmtruncates more precise about what they expect unmap_mapping_range() to do. vmtruncate_range() is currently called only with page-aligned start and end+1: can handle unaligned start, but unaligned end+1 would hit BUG_ON in truncate_inode_pages_range() (lacks partial clearing of the end page). Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-20fs: kill i_alloc_semChristoph Hellwig
i_alloc_sem is a rather special rw_semaphore. It's the last one that may be released by a non-owner, and it's write side is always mirrored by real exclusion. It's intended use it to wait for all pending direct I/O requests to finish before starting a truncate. Replace it with a hand-grown construct: - exclusion for truncates is already guaranteed by i_mutex, so it can simply fall way - the reader side is replaced by an i_dio_count member in struct inode that counts the number of pending direct I/O requests. Truncate can't proceed as long as it's non-zero - when i_dio_count reaches non-zero we wake up a pending truncate using wake_up_bit on a new bit in i_flags - new references to i_dio_count can't appear while we are waiting for it to read zero because the direct I/O count always needs i_mutex (or an equivalent like XFS's i_iolock) for starting a new operation. This scheme is much simpler, and saves the space of a spinlock_t and a struct list_head in struct inode (typically 160 bits on a non-debug 64-bit system). Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-06-27mm: fix assertion mapping->nrpages == 0 in end_writeback()Jan Kara
Under heavy memory and filesystem load, users observe the assertion mapping->nrpages == 0 in end_writeback() trigger. This can be caused by page reclaim reclaiming the last page from a mapping in the following race: CPU0 CPU1 ... shrink_page_list() __remove_mapping() __delete_from_page_cache() radix_tree_delete() evict_inode() truncate_inode_pages() truncate_inode_pages_range() pagevec_lookup() - finds nothing end_writeback() mapping->nrpages != 0 -> BUG page->mapping = NULL mapping->nrpages-- Fix the problem by doing a reliable check of mapping->nrpages under mapping->tree_lock in end_writeback(). Analyzed by Jay <jinshan.xiong@whamcloud.com>, lost in LKML, and dug out by Miklos Szeredi <mszeredi@suse.de>. Cc: Jay <jinshan.xiong@whamcloud.com> Cc: Miklos Szeredi <mszeredi@suse.de> Signed-off-by: Jan Kara <jack@suse.cz> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27tmpfs: take control of its truncate_rangeHugh Dickins
2.6.35's new truncate convention gave tmpfs the opportunity to control its file truncation, no longer enforced from outside by vmtruncate(). We shall want to build upon that, to handle pagecache and swap together. Slightly redefine the ->truncate_range interface: let it now be called between the unmap_mapping_range()s, with the filesystem responsible for doing the truncate_inode_pages_range() from it - just as the filesystem is nowadays responsible for doing that from its ->setattr. Let's rename shmem_notify_change() to shmem_setattr(). Instead of calling the generic truncate_setsize(), bring that code in so we can call shmem_truncate_range() - which will later be updated to perform its own variant of truncate_inode_pages_range(). Remove the punch_hole unmap_mapping_range() from shmem_truncate_range(): now that the COW's unmap_mapping_range() comes after ->truncate_range, there is no need to call it a third time. Export shmem_truncate_range() and add it to the list in shmem_fs.h, so that i915_gem_object_truncate() can call it explicitly in future; get this patch in first, then update drm/i915 once this is available (until then, i915 will just be doing the truncate_inode_pages() twice). Though introduced five years ago, no other filesystem is implementing ->truncate_range, and its only other user is madvise(,,MADV_REMOVE): we expect to convert it to fallocate(,FALLOC_FL_PUNCH_HOLE,,) shortly, whereupon ->truncate_range can be removed from inode_operations - shmem_truncate_range() will help i915 across that transition too. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27mm: move vmtruncate_range to truncate.cHugh Dickins
You would expect to find vmtruncate_range() next to vmtruncate() in mm/truncate.c: move it there. Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26mm/fs: add hooks to support cleancacheDan Magenheimer
This fourth patch of eight in this cleancache series provides the core hooks in VFS for: initializing cleancache per filesystem; capturing clean pages reclaimed by page cache; attempting to get pages from cleancache before filesystem read; and ensuring coherency between pagecache, disk, and cleancache. Note that the placement of these hooks was stable from 2.6.18 to 2.6.38; a minor semantic change was required due to a patchset in 2.6.39. All hooks become no-ops if CONFIG_CLEANCACHE is unset, or become a check of a boolean global if CONFIG_CLEANCACHE is set but no cleancache "backend" has claimed cleancache_ops. Details and a FAQ can be found in Documentation/vm/cleancache.txt [v8: minchan.kim@gmail.com: adapt to new remove_from_page_cache function] Signed-off-by: Chris Mason <chris.mason@oracle.com> Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com> Reviewed-by: Jeremy Fitzhardinge <jeremy@goop.org> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik Van Riel <riel@redhat.com> Cc: Jan Beulich <JBeulich@novell.com> Cc: Andreas Dilger <adilger@sun.com> Cc: Ted Ts'o <tytso@mit.edu> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <joel.becker@oracle.com> Cc: Nitin Gupta <ngupta@vflare.org>
2011-03-22mm: deactivate invalidated pagesMinchan Kim
Recently, there are reported problem about thrashing. (http://marc.info/?l=rsync&m=128885034930933&w=2) It happens by backup workloads(ex, nightly rsync). That's because the workload makes just use-once pages and touches pages twice. It promotes the page into active list so that it results in working set page eviction. Some app developer want to support POSIX_FADV_NOREUSE. But other OSes don't support it, either. (http://marc.info/?l=linux-mm&m=128928979512086&w=2) By other approach, app developers use POSIX_FADV_DONTNEED. But it has a problem. If kernel meets page is writing during invalidate_mapping_pages, it can't work. It makes for application programmer to use it since they always have to sync data before calling fadivse(..POSIX_FADV_DONTNEED) to make sure the pages could be discardable. At last, they can't use deferred write of kernel so that they could see performance loss. (http://insights.oetiker.ch/linux/fadvise.html) In fact, invalidation is very big hint to reclaimer. It means we don't use the page any more. So let's move the writing page into inactive list's head if we can't truncate it right now. Why I move page to head of lru on this patch, Dirty/Writeback page would be flushed sooner or later. It can prevent writeout of pageout which is less effective than flusher's writeout. Originally, I reused lru_demote of Peter with some change so added his Signed-off-by. Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Reported-by: Ben Gamari <bgamari.foss@gmail.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22mm: change __remove_from_page_cache()Minchan Kim
Now we renamed remove_from_page_cache with delete_from_page_cache. As consistency of __remove_from_swap_cache and remove_from_swap_cache, we change internal page cache handling function name, too. Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Cc: Christoph Hellwig <hch@infradead.org> Acked-by: Hugh Dickins <hughd@google.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22mm: truncate: change remove_from_page_cacheMinchan Kim
This patch series changes remove_from_page_cache()'s page ref counting rule. Page cache ref count is decreased in delete_from_page_cache(). So we don't need to decrease the page reference in callers. Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Cc: Dan Magenheimer <dan.magenheimer@oracle.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Hugh Dickins <hughd@google.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-25memcg: more mem_cgroup_uncharge() batchingHugh Dickins
It seems odd that truncate_inode_pages_range(), called not only when truncating but also when evicting inodes, has mem_cgroup_uncharge_start and _end() batching in its second loop to clear up a few leftovers, but not in its first loop that does almost all the work: add them there too. Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-20mm: fix truncate_setsize() commentJan Kara
Contrary to what the comment says, truncate_setsize() should be called *before* filesystem truncated blocks. Signed-off-by: Jan Kara <jack@suse.cz> Cc: Christoph Hellwig <hch@infradead.org> Cc: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-02Call the filesystem back whenever a page is removed from the page cacheLinus Torvalds
NFS needs to be able to release objects that are stored in the page cache once the page itself is no longer visible from the page cache. This patch adds a callback to the address space operations that allows filesystems to perform page cleanups once the page has been removed from the page cache. Original patch by: Linus Torvalds <torvalds@linux-foundation.org> [trondmy: cover the cases of invalidate_inode_pages2() and truncate_inode_pages()] Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-08-09check ATTR_SIZE contraints in inode_change_okChristoph Hellwig
Make sure we check the truncate constraints early on in ->setattr by adding those checks to inode_change_ok. Also clean up and document inode_change_ok to make this obvious. As a fallout we don't have to call inode_newsize_ok from simple_setsize and simplify it down to a truncate_setsize which doesn't return an error. This simplifies a lot of setattr implementations and means we use truncate_setsize almost everywhere. Get rid of fat_setsize now that it's trivial and mark ext2_setsize static to make the calling convention obvious. Keep the inode_newsize_ok in vmtruncate for now as all callers need an audit for its removal anyway. Note: setattr code in ecryptfs doesn't call inode_change_ok at all and needs a deeper audit, but that is left for later. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27fs: introduce new truncate sequencenpiggin@suse.de
Introduce a new truncate calling sequence into fs/mm subsystems. Rather than setattr > vmtruncate > truncate, have filesystems call their truncate sequence from ->setattr if filesystem specific operations are required. vmtruncate is deprecated, and truncate_pagecache and inode_newsize_ok helpers introduced previously should be used. simple_setattr is introduced for simple in-ram filesystems to implement the new truncate sequence. Eventually all filesystems should be converted to implement a setattr, and the default code in notify_change should go away. simple_setsize is also introduced to perform just the ATTR_SIZE portion of simple_setattr (ie. changing i_size and trimming pagecache). To implement the new truncate sequence: - filesystem specific manipulations (eg freeing blocks) must be done in the setattr method rather than ->truncate. - vmtruncate can not be used by core code to trim blocks past i_size in the event of write failure after allocation, so this must be performed in the fs code. - convert usage of helpers block_write_begin, nobh_write_begin, cont_write_begin, and *blockdev_direct_IO* to use _newtrunc postfixed variants. These avoid calling vmtruncate to trim blocks (see previous). - inode_setattr should not be used. generic_setattr is a new function to be used to copy simple attributes into the generic inode. - make use of the better opportunity to handle errors with the new sequence. Big problem with the previous calling sequence: the filesystem is not called until i_size has already changed. This means it is not allowed to fail the call, and also it does not know what the previous i_size was. Also, generic code calling vmtruncate to truncate allocated blocks in case of error had no good way to return a meaningful error (or, for example, atomically handle block deallocation). Cc: Christoph Hellwig <hch@lst.de> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-01-13vfs: Fix vmtruncate() regressionOGAWA Hirofumi
If __block_prepare_write() was failed in block_write_begin(), the allocated blocks can be outside of ->i_size. But new truncate_pagecache() in vmtuncate() does nothing if new < old. It means the above usage is not working anymore. So, this patch fixes it by removing "new < old" check. It would need more cleanup/change. But, now -rc and truncate working is in progress, so, this tried to fix it minimum change. Acked-by: Nick Piggin <npiggin@suse.de> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16memcg: coalesce uncharge during unmap/truncateKAMEZAWA Hiroyuki
In massive parallel enviroment, res_counter can be a performance bottleneck. One strong techinque to reduce lock contention is reducing calls by coalescing some amount of calls into one. Considering charge/uncharge chatacteristic, - charge is done one by one via demand-paging. - uncharge is done by - in chunk at munmap, truncate, exit, execve... - one by one via vmscan/paging. It seems we have a chance to coalesce uncharges for improving scalability at unmap/truncation. This patch is a for coalescing uncharge. For avoiding scattering memcg's structure to functions under /mm, this patch adds memcg batch uncharge information to the task. A reason for per-task batching is for making use of caller's context information. We do batched uncharge (deleyed uncharge) when truncation/unmap occurs but do direct uncharge when uncharge is called by memory reclaim (vmscan.c). The degree of coalescing depends on callers - at invalidate/trucate... pagevec size - at unmap ....ZAP_BLOCK_SIZE (memory itself will be freed in this degree.) Then, we'll not coalescing too much. On x86-64 8cpu server, I tested overheads of memcg at page fault by running a program which does map/fault/unmap in a loop. Running a task per a cpu by taskset and see sum of the number of page faults in 60secs. [without memcg config] 40156968 page-faults # 0.085 M/sec ( +- 0.046% ) 27.67 cache-miss/faults [root cgroup] 36659599 page-faults # 0.077 M/sec ( +- 0.247% ) 31.58 miss/faults [in a child cgroup] 18444157 page-faults # 0.039 M/sec ( +- 0.133% ) 69.96 miss/faults [child with this patch] 27133719 page-faults # 0.057 M/sec ( +- 0.155% ) 47.16 miss/faults We can see some amounts of improvement. (root cgroup doesn't affected by this patch) Another patch for "charge" will follow this and above will be improved more. Changelog(since 2009/10/02): - renamed filed of memcg_batch (as pages to bytes, memsw to memsw_bytes) - some clean up and commentary/description updates. - added initialize code to copy_process(). (possible bug fix) Changelog(old): - fixed !CONFIG_MEM_CGROUP case. - rebased onto the latest mmotm + softlimit fix patches. - unified patch for callers - added commetns. - make ->do_batch as bool. - removed css_get() at el. We don't need it. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-04mm: fix comments for invalidate_inode_pages2()Peng Tao
invalidate_inode_pages2() returns -EBUSY *NOT* -EIO if any pages could not be invalidated. Signed-off-by: Peng Tao <bergwolf@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: truncate: use new helpers truncate: new helpers fs: fix overflow in sys_mount() for in-kernel calls fs: Make unload_nls() NULL pointer safe freeze_bdev: grab active reference to frozen superblocks freeze_bdev: kill bd_mount_sem exofs: remove BKL from super operations fs/romfs: correct error-handling code vfs: seq_file: add helpers for data filling vfs: remove redundant position check in do_sendfile vfs: change sb->s_maxbytes to a loff_t vfs: explicitly cast s_maxbytes in fiemap_check_ranges libfs: return error code on failed attr set seq_file: return a negative error code when seq_path_root() fails. vfs: optimize touch_time() too vfs: optimization for touch_atime() vfs: split generic_forget_inode() so that hugetlbfs does not have to copy it fs/inode.c: add dev-id and inode number for debugging in init_special_inode() libfs: make simple_read_from_buffer conventional
2009-09-24truncate: new helpersnpiggin@suse.de
Introduce new truncate helpers truncate_pagecache and inode_newsize_ok. vmtruncate is also consolidated from mm/memory.c and mm/nommu.c and into mm/truncate.c. Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-09-16HWPOISON: Define a new error_remove_page address space op for async truncationAndi Kleen
Truncating metadata pages is not safe right now before we haven't audited all file systems. To enable truncation only for data address space define a new address_space callback error_remove_page. This is used for memory_failure.c memory error handling. This can be then set to truncate_inode_page() This patch just defines the new operation and adds documentation. Callers and users come in followon patches. Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-09-16HWPOISON: Add invalidate_inode_pageWu Fengguang
Add a simple way to invalidate a single page This is just a refactoring of the truncate.c code. Originally from Fengguang, modified by Andi Kleen. Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-09-16HWPOISON: Refactor truncate to allow direct truncating of page v2Nick Piggin
Extract out truncate_inode_page() out of the truncate path so that it can be used by memory-failure.c [AK: description, headers, fix typos] v2: Some white space changes from Fengguang Wu Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-06-16mm: remove __invalidate_mapping_pages variantMike Waychison
Remove __invalidate_mapping_pages atomic variant now that its sole caller can sleep (fixed in eccb95cee4f0d56faa46ef22fb94dd4a3578d3eb ("vfs: fix lock inversion in drop_pagecache_sb()")). This fixes softlockups that can occur while in the drop_caches path. Signed-off-by: Mike Waychison <mikew@google.com> Cc: Jan Kara <jack@suse.cz> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Dave Chinner <david@fromorbit.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-29memcg: fix deadlock between lock_page_cgroup and mapping tree_lockDaisuke Nishimura
mapping->tree_lock can be acquired from interrupt context. Then, following dead lock can occur. Assume "A" as a page. CPU0: lock_page_cgroup(A) interrupted -> take mapping->tree_lock. CPU1: take mapping->tree_lock -> lock_page_cgroup(A) This patch tries to fix above deadlock by moving memcg's hook to out of mapping->tree_lock. charge/uncharge of pagecache/swapcache is protected by page lock, not tree_lock. After this patch, lock_page_cgroup() is not called under mapping->tree_lock. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-03FS-Cache: Recruit a page flags for cache managementDavid Howells
Recruit a page flag to aid in cache management. The following extra flag is defined: (1) PG_fscache (PG_private_2) The marked page is backed by a local cache and is pinning resources in the cache driver. If PG_fscache is set, then things that checked for PG_private will now also check for that. This includes things like truncation and page invalidation. The function page_has_private() had been added to make the checks for both PG_private and PG_private_2 at the same time. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2008-10-20mmap: handle mlocked pages during map, remap, unmapRik van Riel
Originally by Nick Piggin <npiggin@suse.de> Remove mlocked pages from the LRU using "unevictable infrastructure" during mmap(), munmap(), mremap() and truncate(). Try to move back to normal LRU lists on munmap() when last mlocked mapping removed. Remove PageMlocked() status when page truncated from file. [akpm@linux-foundation.org: cleanup] [kamezawa.hiroyu@jp.fujitsu.com: fix double unlock_page()] [kosaki.motohiro@jp.fujitsu.com: split LRU: munlock rework] [lee.schermerhorn@hp.com: mlock: fix __mlock_vma_pages_range comment block] [akpm@linux-foundation.org: remove bogus kerneldoc token] Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: KAMEZAWA Hiroyuki <kamewzawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16Remove Andrew Morton's old email accountsFrancois Cami
People can use the real name an an index into MAINTAINERS to find the current email address. Signed-off-by: Francois Cami <francois.cami@free.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-02VFS: fix dio write returning EIO when try_to_release_page failsHisashi Hifumi
Dio write returns EIO when try_to_release_page fails because bh is still referenced. The patch commit 3f31fddfa26b7594b44ff2b34f9a04ba409e0f91 Author: Mingming Cao <cmm@us.ibm.com> Date: Fri Jul 25 01:46:22 2008 -0700 jbd: fix race between free buffer and commit transaction was merged into 2.6.27-rc1, but I noticed that this patch is not enough to fix the race. I did fsstress test heavily to 2.6.27-rc1, and found that dio write still sometimes got EIO through this test. The patch above fixed race between freeing buffer(dio) and committing transaction(jbd) but I discovered that there is another race, freeing buffer(dio) and ext3/4_ordered_writepage. : background_writeout() ->write_cache_pages() ->ext3_ordered_writepage() walk_page_buffers() -> take a bh ref block_write_full_page() -> unlock_page : <- end_page_writeback : <- race! (dio write->try_to_release_page fails) walk_page_buffers() ->release a bh ref ext3_ordered_writepage holds bh ref and does unlock_page remaining taking a bh ref, so this causes the race and failure of try_to_release_page. To fix this race, I used the approach of falling back to buffered writes if try_to_release_page() fails on a page. [akpm@linux-foundation.org: cleanups] Signed-off-by: Hisashi Hifumi <hifumi.hisashi@oss.ntt.co.jp> Cc: Chris Mason <chris.mason@oracle.com> Cc: Jan Kara <jack@suse.cz> Cc: Mingming Cao <cmm@us.ibm.com> Cc: Zach Brown <zach.brown@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-04mm: rename page trylockNick Piggin
Converting page lock to new locking bitops requires a change of page flag operation naming, so we might as well convert it to something nicer (!TestSetPageLocked_Lock => trylock_page, SetPageLocked => set_page_locked). This also facilitates lockdeping of page lock. Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-02mm: dont clear PG_uptodate on truncate/invalidateMiklos Szeredi
Brian Wang reported that a FUSE filesystem exported through NFS could return I/O errors on read. This was traced to splice_direct_to_actor() returning a short or zero count when racing with page invalidation. However this is not FUSE or NFSD specific, other filesystems (notably NFS) also call invalidate_inode_pages2() to purge stale data from the cache. If this happens while such pages are sitting in a pipe buffer, then splice(2) from the pipe can return zero, and read(2) from the pipe can return ENODATA. The zero return is especially bad, since it implies end-of-file or disconnected pipe/socket, and is documented as such for splice. But returning an error for read() is also nasty, when in fact there was no error (data becoming stale is not an error). The same problems can be triggered by "hole punching" with madvise(MADV_REMOVE). Fix this by not clearing the PG_uptodate flag on truncation and invalidation. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Acked-by: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26mm: spinlock tree_lockNick Piggin
mapping->tree_lock has no read lockers. convert the lock from an rwlock to a spinlock. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Hugh Dickins <hugh@veritas.com> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Reviewed-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28fix invalidate_inode_pages2_range() to not clear retHisashi Hifumi
DIO invalidates page cache through invalidate_inode_pages2_range(). invalidate_inode_pages2_range() sets ret=-EIO when invalidate_complete_page2() fails, but this ret is cleared if do_launder_page() succeed on a page of next index. In this case, dio is carried out even if invalidate_complete_page2() fails on some pages. This can cause inconsistency between memory and blocks on HDD because the page cache still exists. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Hisashi Hifumi <hifumi.hisashi@oss.ntt.co.jp> Cc: Badari Pulavarty <pbadari@us.ibm.com> Cc: Ken Chen <kenchen@google.com> Cc: Zach Brown <zach.brown@oracle.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Chuck Lever <cel@citi.umich.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-03docbook: fix kernel-api source filesRandy Dunlap
Fix docbook problems in kernel-api.tmpl. These cause the generated docbook to be incorrect. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05page migraton: handle orphaned pagesShaohua Li
Orphaned page might have fs-private metadata, the page is truncated. As the page hasn't mapping, page migration refuse to migrate the page. It appears the page is only freed in page reclaim and if zone watermark is low, the page is never freed, as a result migration always fail. I thought we could free the metadata so such page can be freed in migration and make migration more reliable. [akpm@linux-foundation.org: go direct to try_to_free_buffers()] Signed-off-by: Shaohua Li <shaohua.li@intel.com> Acked-by: Nick Piggin <npiggin@suse.de> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05Fix dirty page accounting leak with ext3 data=journalBjorn Steinbrink
In 46d2277c796f9f4937bfa668c40b2e3f43e93dd0 ("Clean up and make try_to_free_buffers() not race with dirty pages"), try_to_free_buffers was changed to bail out if the page was dirty. That in turn caused truncate_complete_page to leak massive amounts of memory, because the dirty bit was only cleared after the call to try_to_free_buffers. So the call to cancel_dirty_page was moved up to have the dirty bit cleared early in 3e67c0987d7567ad666641164a153dca9a43b11d ("truncate: clear page dirtiness before running try_to_free_buffers()"). The problem with that fix is, that the page can be redirtied after cancel_dirty_page was called, eg. like this: truncate_complete_page() cancel_dirty_page() // PG_dirty cleared, decr. dirty pages do_invalidatepage() ext3_invalidatepage() journal_invalidatepage() journal_unmap_buffer() __dispose_buffer() __journal_unfile_buffer() __journal_temp_unlink_buffer() mark_buffer_dirty(); // PG_dirty set, incr. dirty pages And then we end up with dirty pages being wrongly accounted. As a result, in ecdfc9787fe527491baefc22dce8b2dbd5b2908d ("Resurrect 'try_to_free_buffers()' VM hackery") the changes to try_to_free_buffers were reverted, so the original reason for the massive memory leak is gone, and we can also revert the move of the call to cancel_dirty_page from truncate_complete_page and get the accounting right again. I'm not sure if it matters, but opposed to the final check in __remove_from_page_cache, this one also cares about the task io accounting, so maybe we want to use this instead, although it's not quite the clean fix either. Signed-off-by: Björn Steinbrink <B.Steinbrink@gmx.de> Tested-by: Krzysztof Piotr Oledzki <ole@ans.pl> Cc: Jan Kara <jack@ucw.cz> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Osterried <osterried@jesse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05Pagecache zeroing: zero_user_segment, zero_user_segments and zero_userChristoph Lameter
Simplify page cache zeroing of segments of pages through 3 functions zero_user_segments(page, start1, end1, start2, end2) Zeros two segments of the page. It takes the position where to start and end the zeroing which avoids length calculations and makes code clearer. zero_user_segment(page, start, end) Same for a single segment. zero_user(page, start, length) Length variant for the case where we know the length. We remove the zero_user_page macro. Issues: 1. Its a macro. Inline functions are preferable. 2. The KM_USER0 macro is only defined for HIGHMEM. Having to treat this special case everywhere makes the code needlessly complex. The parameter for zeroing is always KM_USER0 except in one single case that we open code. Avoiding KM_USER0 makes a lot of code not having to be dealing with the special casing for HIGHMEM anymore. Dealing with kmap is only necessary for HIGHMEM configurations. In those configurations we use KM_USER0 like we do for a series of other functions defined in highmem.h. Since KM_USER0 is depends on HIGHMEM the existing zero_user_page function could not be a macro. zero_user_* functions introduced here can be be inline because that constant is not used when these functions are called. Also extract the flushing of the caches to be outside of the kmap. [akpm@linux-foundation.org: fix nfs and ntfs build] [akpm@linux-foundation.org: fix ntfs build some more] Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Steven French <sfrench@us.ibm.com> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: <linux-ext4@vger.kernel.org> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: David Chinner <dgc@sgi.com> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: Steven French <sfrench@us.ibm.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-03do_invalidatepage() comment typo fixFengguang Wu
Fix a typo in the comment for do_invalidatepage(). Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Signed-off-by: Adrian Bunk <bunk@kernel.org>
