path: root/mm/vmalloc.c
2013-11-13mm: kmemleak: avoid false negatives on vmalloc'ed objectsCatalin Marinas
Commit 248ac0e1943a ("mm/vmalloc: remove guard page from between vmap blocks") had the side effect of making vmap_area.va_end member point to the next vmap_area.va_start. This was creating an artificial reference to vmalloc'ed objects and kmemleak was rarely reporting vmalloc() leaks. This patch marks the vmap_area containing pointers explicitly and reduces the min ref_count to 2 as vm_struct still contains a reference to the vmalloc'ed object. The kmemleak add_scan_area() function has been improved to allow a SIZE_MAX argument covering the rest of the object (for simpler calling sites). Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-13revert mm/vmalloc.c: emit the failure message before returnWanpeng Li
Don't warn twice in __vmalloc_area_node and __vmalloc_node_range if __vmalloc_area_node allocation failure. This patch reverts commit 46c001a2753f ("mm/vmalloc.c: emit the failure message before return"). Signed-off-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Reviewed-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Mitsuo Hayasaka <mitsuo.hayasaka.hu@hitachi.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-13mm/vmalloc: revert "mm/vmalloc.c: check VM_UNINITIALIZED flag in s_show ↵Wanpeng Li
instead of show_numa_info" The VM_UNINITIALIZED/VM_UNLIST flag introduced by f5252e009d5b ("mm: avoid null pointer access in vm_struct via /proc/vmallocinfo") is used to avoid accessing the pages field with unallocated page when show_numa_info() is called. This patch moves the check just before show_numa_info in order that some messages still can be dumped via /proc/vmallocinfo. This patch reverts commit d157a55815ff ("mm/vmalloc.c: check VM_UNINITIALIZED flag in s_show instead of show_numa_info"); Reviewed-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Signed-off-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Mitsuo Hayasaka <mitsuo.hayasaka.hu@hitachi.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-13mm/vmalloc: fix show vmap_area information race with vmap_area tear downWanpeng Li
There is a race window between vmap_area tear down and show vmap_area information. A B remove_vm_area spin_lock(&vmap_area_lock); va->vm = NULL; va->flags &= ~VM_VM_AREA; spin_unlock(&vmap_area_lock); spin_lock(&vmap_area_lock); if (va->flags & (VM_LAZY_FREE | VM_LAZY_FREEZING)) return 0; if (!(va->flags & VM_VM_AREA)) { seq_printf(m, "0x%pK-0x%pK %7ld vm_map_ram\n", (void *)va->va_start, (void *)va->va_end, va->va_end - va->va_start); return 0; } free_unmap_vmap_area(va); flush_cache_vunmap free_unmap_vmap_area_noflush unmap_vmap_area free_vmap_area_noflush va->flags |= VM_LAZY_FREE The assumption !VM_VM_AREA represents vm_map_ram allocation is introduced by d4033afdf828 ("mm, vmalloc: iterate vmap_area_list, instead of vmlist, in vmallocinfo()"). However, !VM_VM_AREA also represents vmap_area is being tear down in race window mentioned above. This patch fix it by don't dump any information for !VM_VM_AREA case and also remove (VM_LAZY_FREE | VM_LAZY_FREEING) check since they are not possible for !VM_VM_AREA case. Suggested-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Mitsuo Hayasaka <mitsuo.hayasaka.hu@hitachi.com> Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-13mm/vmalloc: don't set area->caller twiceWanpeng Li
The caller address has already been set in set_vmalloc_vm(), there's no need to set it again in __vmalloc_area_node. Reviewed-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Signed-off-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Mitsuo Hayasaka <mitsuo.hayasaka.hu@hitachi.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-13mm/vmalloc: use NUMA_NO_NODEJianguo Wu
Use more appropriate "if (node == NUMA_NO_NODE)" instead of "if (node < 0)" Signed-off-by: Jianguo Wu <wujianguo@huawei.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11mm/vmalloc: use wrapper function get_vm_area_size to caculate size of vm areaWanpeng Li
Use wrapper function get_vm_area_size to calculate size of vm area. Signed-off-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Rik van Riel <riel@redhat.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Tejun Heo <tj@kernel.org> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11mm, vmalloc: use well-defined find_last_bit() funcJoonsoo Kim
Our intention in here is to find last_bit within the region to flush. There is well-defined function, find_last_bit() for this purpose and its performance may be slightly better than current implementation. So change it. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11mm, vmalloc: remove useless variable in vmap_blockJoonsoo Kim
vbq in vmap_block isn't used. So remove it. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09mm/vmalloc.c: fix an overflow bug in alloc_vmap_area()Zhang Yanfei
When searching a vmap area in the vmalloc space, we use (addr + size - 1) to check if the value is less than addr, which is an overflow. But we assign (addr + size) to vmap_area->va_end. So if we come across the below case: (addr + size - 1) : not overflow (addr + size) : overflow we will assign an overflow value (e.g 0) to vmap_area->va_end, And this will trigger BUG in __insert_vmap_area, causing system panic. So using (addr + size) to check the overflow should be the correct behaviour, not (addr + size - 1). Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Reported-by: Ghennadi Procopciuc <unix140@gmail.com> Tested-by: Daniel Baluta <dbaluta@ixiacom.com> Cc: David Rientjes <rientjes@google.com> Cc: Minchan Kim <minchan@kernel.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09vfree: don't schedule free_work() if llist_add() returns falseOleg Nesterov
vfree() only needs schedule_work(&p->wq) if p->list was empty, otherwise vfree_deferred->wq is already pending or it is running and didn't do llist_del_all() yet. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09mm/vmalloc.c: check VM_UNINITIALIZED flag in s_show instead of show_numa_infoZhang Yanfei
We should check the VM_UNITIALIZED flag in s_show(). If this flag is set, that said, the vm_struct is not fully initialized. So it is unnecessary to try to show the information contained in vm_struct. We checked this flag in show_numa_info(), but I think it's better to check it earlier. Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09mm/vmalloc.c: rename VM_UNLIST to VM_UNINITIALIZEDZhang Yanfei
VM_UNLIST was used to indicate that the vm_struct is not listed in vmlist. But after commit 4341fa454796 ("mm, vmalloc: remove list management of vmlist after initializing vmalloc"), the meaning of this flag changed. It now means the vm_struct is not fully initialized. So renaming it to VM_UNINITIALIZED seems more reasonable. Also change clear_vm_unlist to clear_vm_uninitialized_flag. Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09mm/vmalloc.c: emit the failure message before returnZhang Yanfei
Use goto to jump to the fail label to give a failure message before returning NULL. This makes the failure handling in this function consistent. Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09mm/vmalloc.c: remove alloc_map from vmap_blockZhang Yanfei
As we have removed the dead code in the vb_alloc, it seems there is no place to use the alloc_map. So there is no reason to maintain the alloc_map in vmap_block. Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09mm/vmalloc.c: remove unused purge_fragmented_blocks_thiscpuZhang Yanfei
This function is nowhere used now, so remove it. Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09mm/vmalloc.c: remove dead code in vb_allocZhang Yanfei
Space in a vmap block that was once allocated is considered dirty and not made available for allocation again before the whole block is recycled. The result is that free space within a vmap block is always contiguous. So if a vmap block has enough free space for allocation, the allocation is impossible to fail. Thus, the fragmented block purging was never invoked from vb_alloc(). So remove this dead code. [ Same patches also sent by: Chanho Min <chanho.min@lge.com> Johannes Weiner <hannes@cmpxchg.org> but git doesn't do "multiple authors" ] Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09mm/vmalloc.c: unbreak __vunmap()Dan Carpenter
There is an extra semi-colon so the function always returns. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03mm, vmalloc: use clamp() to simplify codeZhang Yanfei
2013-07-03mm, vmalloc: remove insert_vmalloc_vm()Zhang Yanfei
Now this function is nowhere used, we can remove it directly. Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Acked-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03mm, vmalloc: call setup_vmalloc_vm() instead of insert_vmalloc_vm()Zhang Yanfei
Here we pass flags with only VM_ALLOC bit set, it is unnecessary to call clear_vm_unlist to clear VM_UNLIST bit. So use setup_vmalloc_vm instead of insert_vmalloc_vm. Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Acked-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03mm, vmalloc: only call setup_vmalloc_vm() only in __get_vm_area_node()Zhang Yanfei
Now for insert_vmalloc_vm, it only calls the two functions: - setup_vmalloc_vm: fill vm_struct and vmap_area instances - clear_vm_unlist: clear VM_UNLIST bit in vm_struct->flags So in __get_vm_area_node(), if VM_UNLIST bit unset in flags, that is the else branch here, we don't need to clear VM_UNLIST bit for vm->flags since this bit is obviously not set. That is to say, we could only call setup_vmalloc_vm instead of insert_vmalloc_vm here. And then we could even remove the if test here. Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Acked-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03vmalloc: introduce remap_vmalloc_range_partialHATAYAMA Daisuke
We want to allocate ELF note segment buffer on the 2nd kernel in vmalloc space and remap it to user-space in order to reduce the risk that memory allocation fails on system with huge number of CPUs and so with huge ELF note segment that exceeds 11-order block size. Although there's already remap_vmalloc_range for the purpose of remapping vmalloc memory to user-space, we need to specify user-space range via vma. Mmap on /proc/vmcore needs to remap range across multiple objects, so the interface that requires vma to cover full range is problematic. This patch introduces remap_vmalloc_range_partial that receives user-space range as a pair of base address and size and can be used for mmap on /proc/vmcore case. remap_vmalloc_range is rewritten using remap_vmalloc_range_partial. [akpm@linux-foundation.org: use PAGE_ALIGNED()] Signed-off-by: HATAYAMA Daisuke <d.hatayama@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Atsushi Kumagai <kumagai-atsushi@mxc.nes.nec.co.jp> Cc: Lisa Mitchell <lisa.mitchell@hp.com> Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03vmalloc: make find_vm_area check in rangeHATAYAMA Daisuke
Currently, __find_vmap_area searches for the kernel VM area starting at a given address. This patch changes this behavior so that it searches for the kernel VM area to which the address belongs. This change is needed by remap_vmalloc_range_partial to be introduced in later patch that receives any position of kernel VM area as target address. This patch changes the condition (addr > va->va_start) to the equivalent (addr >= va->va_end) by taking advantage of the fact that each kernel VM area is non-overlapping. Signed-off-by: HATAYAMA Daisuke <d.hatayama@jp.fujitsu.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Atsushi Kumagai <kumagai-atsushi@mxc.nes.nec.co.jp> Cc: Lisa Mitchell <lisa.mitchell@hp.com> Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-07mm/vmalloc.c: add vfree commentAndrew Morton
2013-05-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS updates from Al Viro, Misc cleanups all over the place, mainly wrt /proc interfaces (switch create_proc_entry to proc_create(), get rid of the deprecated create_proc_read_entry() in favor of using proc_create_data() and seq_file etc). 7kloc removed. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits) don't bother with deferred freeing of fdtables proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h proc: Make the PROC_I() and PDE() macros internal to procfs proc: Supply a function to remove a proc entry by PDE take cgroup_open() and cpuset_open() to fs/proc/base.c ppc: Clean up scanlog ppc: Clean up rtas_flash driver somewhat hostap: proc: Use remove_proc_subtree() drm: proc: Use remove_proc_subtree() drm: proc: Use minor->index to label things, not PDE->name drm: Constify drm_proc_list[] zoran: Don't print proc_dir_entry data in debug reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show() proc: Supply an accessor for getting the data from a PDE's parent airo: Use remove_proc_subtree() rtl8192u: Don't need to save device proc dir PDE rtl8187se: Use a dir under /proc/net/r8180/ proc: Add proc_mkdir_data() proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h} proc: Move PDE_NET() to fs/proc/proc_net.c ...
2013-04-29kexec, vmalloc: export additional vmalloc layer informationAtsushi Kumagai
Now, vmap_area_list is exported as VMCOREINFO for makedumpfile to get the start address of vmalloc region (vmalloc_start). The address which contains vmalloc_start value is represented as below: vmap_area_list.next - OFFSET(vmap_area.list) + OFFSET(vmap_area.va_start) However, both OFFSET(vmap_area.va_start) and OFFSET(vmap_area.list) aren't exported as VMCOREINFO. So this patch exports them externally with small cleanup. [akpm@linux-foundation.org: vmalloc.h should include list.h for list_head] Signed-off-by: Atsushi Kumagai <kumagai-atsushi@mxc.nes.nec.co.jp> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Atsushi Kumagai <kumagai-atsushi@mxc.nes.nec.co.jp> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Dave Anderson <anderson@redhat.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Ingo Molnar <mingo@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29mm, vmalloc: remove list management of vmlist after initializing vmallocJoonsoo Kim
Now, there is no need to maintain vmlist after initializing vmalloc. So remove related code and data structure. Signed-off-by: Joonsoo Kim <js1304@gmail.com> Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Atsushi Kumagai <kumagai-atsushi@mxc.nes.nec.co.jp> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Dave Anderson <anderson@redhat.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Ingo Molnar <mingo@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29mm, vmalloc: export vmap_area_list, instead of vmlistJoonsoo Kim
Although our intention is to unexport internal structure entirely, but there is one exception for kexec. kexec dumps address of vmlist and makedumpfile uses this information. We are about to remove vmlist, then another way to retrieve information of vmalloc layer is needed for makedumpfile. For this purpose, we export vmap_area_list, instead of vmlist. Signed-off-by: Joonsoo Kim <js1304@gmail.com> Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: Dave Anderson <anderson@redhat.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Atsushi Kumagai <kumagai-atsushi@mxc.nes.nec.co.jp> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29mm, vmalloc: iterate vmap_area_list, instead of vmlist, in vmallocinfo()Joonsoo Kim
This patch is a preparatory step for removing vmlist entirely. For above purpose, we change iterating a vmap_list codes to iterating a vmap_area_list. It is somewhat trivial change, but just one thing should be noticed. Using vmap_area_list in vmallocinfo() introduce ordering problem in SMP system. In s_show(), we retrieve some values from vm_struct. vm_struct's values is not fully setup when va->vm is assigned. Full setup is notified by removing VM_UNLIST flag without holding a lock. When we see that VM_UNLIST is removed, it is not ensured that vm_struct has proper values in view of other CPUs. So we need smp_[rw]mb for ensuring that proper values is assigned when we see that VM_UNLIST is removed. Therefore, this patch not only change a iteration list, but also add a appropriate smp_[rw]mb to right places. Signed-off-by: Joonsoo Kim <js1304@gmail.com> Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Atsushi Kumagai <kumagai-atsushi@mxc.nes.nec.co.jp> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Dave Anderson <anderson@redhat.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Ingo Molnar <mingo@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29mm, vmalloc: iterate vmap_area_list in get_vmalloc_info()Joonsoo Kim
This patch is a preparatory step for removing vmlist entirely. For above purpose, we change iterating a vmap_list codes to iterating a vmap_area_list. It is somewhat trivial change, but just one thing should be noticed. vmlist is lack of information about some areas in vmalloc address space. For example, vm_map_ram() allocate area in vmalloc address space, but it doesn't make a link with vmlist. To provide full information about vmalloc address space is better idea, so we don't use va->vm and use vmap_area directly. This makes get_vmalloc_info() more precise. Signed-off-by: Joonsoo Kim <js1304@gmail.com> Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Atsushi Kumagai <kumagai-atsushi@mxc.nes.nec.co.jp> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Dave Anderson <anderson@redhat.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Ingo Molnar <mingo@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29mm, vmalloc: iterate vmap_area_list, instead of vmlist in vread/vwrite()Joonsoo Kim
Now, when we hold a vmap_area_lock, va->vm can't be discarded. So we can safely access to va->vm when iterating a vmap_area_list with holding a vmap_area_lock. With this property, change iterating vmlist codes in vread/vwrite() to iterating vmap_area_list. There is a little difference relate to lock, because vmlist_lock is mutex, but, vmap_area_lock is spin_lock. It may introduce a spinning overhead during vread/vwrite() is executing. But, these are debug-oriented functions, so this overhead is not real problem for common case. Signed-off-by: Joonsoo Kim <js1304@gmail.com> Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Atsushi Kumagai <kumagai-atsushi@mxc.nes.nec.co.jp> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Dave Anderson <anderson@redhat.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Ingo Molnar <mingo@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29mm, vmalloc: protect va->vm by vmap_area_lockJoonsoo Kim
Inserting and removing an entry to vmlist is linear time complexity, so it is inefficient. Following patches will try to remove vmlist entirely. This patch is preparing step for it. For removing vmlist, iterating vmlist codes should be changed to iterating a vmap_area_list. Before implementing that, we should make sure that when we iterate a vmap_area_list, accessing to va->vm doesn't cause a race condition. This patch ensure that when iterating a vmap_area_list, there is no race condition for accessing to vm_struct. Signed-off-by: Joonsoo Kim <js1304@gmail.com> Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Atsushi Kumagai <kumagai-atsushi@mxc.nes.nec.co.jp> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Dave Anderson <anderson@redhat.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Ingo Molnar <mingo@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29mm, vmalloc: move get_vmalloc_info() to vmalloc.cJoonsoo Kim
Now get_vmalloc_info() is in fs/proc/mmu.c. There is no reason that this code must be here and it's implementation needs vmlist_lock and it iterate a vmlist which may be internal data structure for vmalloc. It is preferable that vmlist_lock and vmlist is only used in vmalloc.c for maintainability. So move the code to vmalloc.c Signed-off-by: Joonsoo Kim <js1304@gmail.com> Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Atsushi Kumagai <kumagai-atsushi@mxc.nes.nec.co.jp> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Dave Anderson <anderson@redhat.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Ingo Molnar <mingo@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-10make vfree() safe to call from interrupt contextsAl Viro
A bunch of RCU callbacks want to be able to do vfree() and end up with rather kludgy schemes. Just let vfree() do the right thing - put the victim on llist and schedule actual __vunmap() via schedule_work(), so that it runs from non-interrupt context. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-23mm: use NUMA_NO_NODEDavid Rientjes
Make a sweep through mm/ and convert code that uses -1 directly to using the more appropriate NUMA_NO_NODE. Signed-off-by: David Rientjes <rientjes@google.com> Reviewed-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-11mm: use IS_ENABLED(CONFIG_NUMA) instead of NUMA_BUILDKirill A. Shutemov
We don't need custom NUMA_BUILD anymore, since we have handy IS_ENABLED(). Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09mm: use %pK for /proc/vmallocinfoKees Cook
In the paranoid case of sysctl kernel.kptr_restrict=2, mask the kernel virtual addresses in /proc/vmallocinfo too. Signed-off-by: Kees Cook <keescook@chromium.org> Reported-by: Brad Spengler <spender@grsecurity.net> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09mm: kill vma flag VM_RESERVED and mm->reserved_vm counterKonstantin Khlebnikov
A long time ago, in v2.4, VM_RESERVED kept swapout process off VMA, currently it lost original meaning but still has some effects: | effect | alternative flags -+------------------------+--------------------------------------------- 1| account as reserved_vm | VM_IO 2| skip in core dump | VM_IO, VM_DONTDUMP 3| do not merge or expand | VM_IO, VM_DONTEXPAND, VM_HUGETLB, VM_PFNMAP 4| do not mlock | VM_IO, VM_DONTEXPAND, VM_HUGETLB, VM_PFNMAP This patch removes reserved_vm counter from mm_struct. Seems like nobody cares about it, it does not exported into userspace directly, it only reduces total_vm showed in proc. Thus VM_RESERVED can be replaced with VM_IO or pair VM_DONTEXPAND | VM_DONTDUMP. remap_pfn_range() and io_remap_pfn_range() set VM_IO|VM_DONTEXPAND|VM_DONTDUMP. remap_vmalloc_range() set VM_DONTEXPAND | VM_DONTDUMP. [akpm@linux-foundation.org: drivers/vfio/pci/vfio_pci.c fixup] Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Carsten Otte <cotte@de.ibm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Eric Paris <eparis@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: James Morris <james.l.morris@oracle.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Kentaro Takeda <takedakn@nttdata.co.jp> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Robert Richter <robert.richter@amd.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Venkatesh Pallipadi <venki@google.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm: make vb_alloc() more foolproofJan Kara
If someone calls vb_alloc() (or vm_map_ram() for that matter) to allocate 0 bytes (0 pages), get_order() returns BITS_PER_LONG - PAGE_CACHE_SHIFT and interesting stuff happens. So make debugging such problems easier and warn about 0-size allocation. [akpm@linux-foundation.org: use WARN_ON-return-value feature] Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31vmalloc: walk vmap_areas by sorted list instead of rb_next()Hong zhi guo
There's a walk by repeating rb_next to find a suitable hole. Could be simply replaced by walk on the sorted vmap_area_list. More simpler and efficient. Mutation of the list and tree only happens in pair within __insert_vmap_area and __free_vmap_area, under protection of vmap_area_lock. The patch code is also under vmap_area_lock, so the list walk is safe, and consistent with the tree walk. Tested on SMP by repeating batch of vmalloc anf vfree for random sizes and rounds for hours. Signed-off-by: Hong Zhiguo <honkiko@gmail.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30Merge branch 'for-linus-for-3.6-rc1' of ↵Linus Torvalds
git://git.linaro.org/people/mszyprowski/linux-dma-mapping Pull DMA-mapping updates from Marek Szyprowski: "Those patches are continuation of my earlier work. They contains extensions to DMA-mapping framework to remove limitation of the current ARM implementation (like limited total size of DMA coherent/write combine buffers), improve performance of buffer sharing between devices (attributes to skip cpu cache operations or creation of additional kernel mapping for some specific use cases) as well as some unification of the common code for dma_mmap_attrs() and dma_mmap_coherent() functions. All extensions have been implemented and tested for ARM architecture." * 'for-linus-for-3.6-rc1' of git://git.linaro.org/people/mszyprowski/linux-dma-mapping: ARM: dma-mapping: add support for DMA_ATTR_SKIP_CPU_SYNC attribute common: DMA-mapping: add DMA_ATTR_SKIP_CPU_SYNC attribute ARM: dma-mapping: add support for dma_get_sgtable() common: dma-mapping: introduce dma_get_sgtable() function ARM: dma-mapping: add support for DMA_ATTR_NO_KERNEL_MAPPING attribute common: DMA-mapping: add DMA_ATTR_NO_KERNEL_MAPPING attribute common: dma-mapping: add support for generic dma_mmap_* calls ARM: dma-mapping: fix error path for memory allocation failure ARM: dma-mapping: add more sanity checks in arm_dma_mmap() ARM: dma-mapping: remove custom consistent dma region mm: vmalloc: use const void * for caller argument scatterlist: add sg_alloc_table_from_pages function
2012-07-30ARM: dma-mapping: remove custom consistent dma regionMarek Szyprowski
This patch changes dma-mapping subsystem to use generic vmalloc areas for all consistent dma allocations. This increases the total size limit of the consistent allocations and removes platform hacks and a lot of duplicated code. Atomic allocations are served from special pool preallocated on boot, because vmalloc areas cannot be reliably created in atomic context. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Reviewed-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Minchan Kim <minchan@kernel.org>
2012-07-30mm: vmalloc: use const void * for caller argumentMarek Szyprowski
'const void *' is a safer type for caller function type. This patch updates all references to caller function type. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Reviewed-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Minchan Kim <minchan@kernel.org>
2012-07-24vmalloc: remove KM_USER0 from commentsCong Wang
Signed-off-by: Cong Wang <amwang@redhat.com>
2012-05-29mm: fix faulty initialization in vmalloc_init()KyongHo
The transfer of ->flags causes some of the static mapping virtual addresses to be prematurely freed (before the mapping is removed) because VM_LAZY_FREE gets "set" if tmp->flags has VM_IOREMAP set. This might cause subsequent vmalloc/ioremap calls to fail because it might allocate one of the freed virtual address ranges that aren't unmapped. va->flags has different types of flags from tmp->flags. If a region with VM_IOREMAP set is registered with vm_area_add_early(), it will be removed by __purge_vmap_area_lazy(). Fix vmalloc_init() to correctly initialize vmap_area for the given vm_struct. Also initialise va->vm. If it is not set, find_vm_area() for the early vm regions will always fail. Signed-off-by: KyongHo Cho <pullip.cho@samsung.com> Cc: "Olav Haugan" <ohaugan@codeaurora.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29mm: use kcalloc() instead of kzalloc() to allocate arrayThomas Meyer
The advantage of kcalloc is, that will prevent integer overflows which could result from the multiplication of number of elements and size and it is also a bit nicer to read. The semantic patch that makes this change is available in https://lkml.org/lkml/2011/11/25/107 Signed-off-by: Thomas Meyer <thomas@m3y3r.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-20mm: remove the second argument of k[un]map_atomic()Cong Wang
2012-01-12mm/vmalloc.c: eliminate extra loop in pcpu_get_vm_areas error pathKautuk Consul
If either of the vas or vms arrays are not properly kzalloced, then the code jumps to the err_free label. The err_free label runs a loop to check and free each of the array members of the vas and vms arrays which is not required for this situation as none of the array members have been allocated till this point. Eliminate the extra loop we have to go through by introducing a new label err_free2 and then jumping to it. [akpm@linux-foundation.org: remove now-unneeded tests] Signed-off-by: Kautuk Consul <consul.kautuk@gmail.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10mm/vmalloc.c: change void* into explict vm_struct*Minchan Kim
vmap_area->private is void* but we don't use the field for various purpose but use only for vm_struct. So change it to a vm_struct* with naming to improve for readability and type checking. Signed-off-by: Minchan Kim <minchan@kernel.org> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
