path: root/mm/vmalloc.c
2020-09-03mm/vunmap: add cond_resched() in vunmap_pmd_rangeSasha Levin
[ Upstream commit e47110e90584a22e9980510b00d0dfad3a83354e ] Like zap_pte_range add cond_resched so that we can avoid softlockups as reported below. On non-preemptible kernel with large I/O map region (like the one we get when using persistent memory with sector mode), an unmap of the namespace can report below softlockups. 22724.027334] watchdog: BUG: soft lockup - CPU#49 stuck for 23s! [ndctl:50777] NIP [c0000000000dc224] plpar_hcall+0x38/0x58 LR [c0000000000d8898] pSeries_lpar_hpte_invalidate+0x68/0xb0 Call Trace: flush_hash_page+0x114/0x200 hpte_need_flush+0x2dc/0x540 vunmap_page_range+0x538/0x6f0 free_unmap_vmap_area+0x30/0x70 remove_vm_area+0xfc/0x140 __vunmap+0x68/0x270 __iounmap.part.0+0x34/0x60 memunmap+0x54/0x70 release_nodes+0x28c/0x300 device_release_driver_internal+0x16c/0x280 unbind_store+0x124/0x170 drv_attr_store+0x44/0x60 sysfs_kf_write+0x64/0x90 kernfs_fop_write+0x1b0/0x290 __vfs_write+0x3c/0x70 vfs_write+0xd8/0x260 ksys_write+0xdc/0x130 system_call+0x5c/0x70 Reported-by: Harish Sriram <harish@linux.ibm.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: <stable@vger.kernel.org> Link: http://lkml.kernel.org/r/20200807075933.310240-1-aneesh.kumar@linux.ibm.com Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2020-04-29vmalloc: fix remap_vmalloc_range() bounds checksJann Horn
commit bdebd6a2831b6fab69eb85cee74a8ba77f1a1cc2 upstream. remap_vmalloc_range() has had various issues with the bounds checks it promises to perform ("This function checks that addr is a valid vmalloc'ed area, and that it is big enough to cover the vma") over time, e.g.: - not detecting pgoff<<PAGE_SHIFT overflow - not detecting (pgoff<<PAGE_SHIFT)+usize overflow - not checking whether addr and addr+(pgoff<<PAGE_SHIFT) are the same vmalloc allocation - comparing a potentially wildly out-of-bounds pointer with the end of the vmalloc region In particular, since commit fc9702273e2e ("bpf: Add mmap() support for BPF_MAP_TYPE_ARRAY"), unprivileged users can cause kernel null pointer dereferences by calling mmap() on a BPF map with a size that is bigger than the distance from the start of the BPF map to the end of the address space. This could theoretically be used as a kernel ASLR bypass, by using whether mmap() with a given offset oopses or returns an error code to perform a binary search over the possible address range. To allow remap_vmalloc_range_partial() to verify that addr and addr+(pgoff<<PAGE_SHIFT) are in the same vmalloc region, pass the offset to remap_vmalloc_range_partial() instead of adding it to the pointer in remap_vmalloc_range(). In remap_vmalloc_range_partial(), fix the check against get_vm_area_size() by using size comparisons instead of pointer comparisons, and add checks for pgoff. Fixes: 833423143c3a ("[PATCH] mm: introduce remap_vmalloc_range()") Signed-off-by: Jann Horn <jannh@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Cc: stable@vger.kernel.org Cc: Alexei Starovoitov <ast@kernel.org> Cc: Daniel Borkmann <daniel@iogearbox.net> Cc: Martin KaFai Lau <kafai@fb.com> Cc: Song Liu <songliubraving@fb.com> Cc: Yonghong Song <yhs@fb.com> Cc: Andrii Nakryiko <andriin@fb.com> Cc: John Fastabend <john.fastabend@gmail.com> Cc: KP Singh <kpsingh@chromium.org> Link: http://lkml.kernel.org/r/20200415222312.236431-1-jannh@google.com Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-03-25x86/mm: split vmalloc_sync_all()Joerg Roedel
commit 763802b53a427ed3cbd419dbba255c414fdd9e7c upstream. Commit 3f8fd02b1bf1 ("mm/vmalloc: Sync unmappings in __purge_vmap_area_lazy()") introduced a call to vmalloc_sync_all() in the vunmap() code-path. While this change was necessary to maintain correctness on x86-32-pae kernels, it also adds additional cycles for architectures that don't need it. Specifically on x86-64 with CONFIG_VMAP_STACK=y some people reported severe performance regressions in micro-benchmarks because it now also calls the x86-64 implementation of vmalloc_sync_all() on vunmap(). But the vmalloc_sync_all() implementation on x86-64 is only needed for newly created mappings. To avoid the unnecessary work on x86-64 and to gain the performance back, split up vmalloc_sync_all() into two functions: * vmalloc_sync_mappings(), and * vmalloc_sync_unmappings() Most call-sites to vmalloc_sync_all() only care about new mappings being synchronized. The only exception is the new call-site added in the above mentioned commit. Shile Zhang directed us to a report of an 80% regression in reaim throughput. Fixes: 3f8fd02b1bf1 ("mm/vmalloc: Sync unmappings in __purge_vmap_area_lazy()") Reported-by: kernel test robot <oliver.sang@intel.com> Reported-by: Shile Zhang <shile.zhang@linux.alibaba.com> Signed-off-by: Joerg Roedel <jroedel@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Tested-by: Borislav Petkov <bp@suse.de> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> [GHES] Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: <stable@vger.kernel.org> Link: http://lkml.kernel.org/r/20191009124418.8286-1-joro@8bytes.org Link: https://lists.01.org/hyperkitty/list/lkp@lists.01.org/thread/4D3JPPHBNOSPFK2KEPC6KGKS6J25AIDB/ Link: http://lkml.kernel.org/r/20191113095530.228959-1-shile.zhang@linux.alibaba.com Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-01-23mm, debug_pagealloc: don't rely on static keys too earlyVlastimil Babka
commit 8e57f8acbbd121ecfb0c9dc13b8b030f86c6bd3b upstream. Commit 96a2b03f281d ("mm, debug_pagelloc: use static keys to enable debugging") has introduced a static key to reduce overhead when debug_pagealloc is compiled in but not enabled. It relied on the assumption that jump_label_init() is called before parse_early_param() as in start_kernel(), so when the "debug_pagealloc=on" option is parsed, it is safe to enable the static key. However, it turns out multiple architectures call parse_early_param() earlier from their setup_arch(). x86 also calls jump_label_init() even earlier, so no issue was found while testing the commit, but same is not true for e.g. ppc64 and s390 where the kernel would not boot with debug_pagealloc=on as found by our QA. To fix this without tricky changes to init code of multiple architectures, this patch partially reverts the static key conversion from 96a2b03f281d. Init-time and non-fastpath calls (such as in arch code) of debug_pagealloc_enabled() will again test a simple bool variable. Fastpath mm code is converted to a new debug_pagealloc_enabled_static() variant that relies on the static key, which is enabled in a well-defined point in mm_init() where it's guaranteed that jump_label_init() has been called, regardless of architecture. [sfr@canb.auug.org.au: export _debug_pagealloc_enabled_early] Link: http://lkml.kernel.org/r/20200106164944.063ac07b@canb.auug.org.au Link: http://lkml.kernel.org/r/20191219130612.23171-1-vbabka@suse.cz Fixes: 96a2b03f281d ("mm, debug_pagelloc: use static keys to enable debugging") Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Matthew Wilcox <willy@infradead.org> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Qian Cai <cai@lca.pw> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-09-25augmented rbtree: add new RB_DECLARE_CALLBACKS_MAX macroMichel Lespinasse
Add RB_DECLARE_CALLBACKS_MAX, which generates augmented rbtree callbacks for the case where the augmented value is a scalar whose definition follows a max(f(node)) pattern. This actually covers all present uses of RB_DECLARE_CALLBACKS, and saves some (source) code duplication in the various RBCOMPUTE function definitions. [walken@google.com: fix mm/vmalloc.c] Link: http://lkml.kernel.org/r/CANN689FXgK13wDYNh1zKxdipeTuALG4eKvKpsdZqKFJ-rvtGiQ@mail.gmail.com [walken@google.com: re-add check to check_augmented()] Link: http://lkml.kernel.org/r/20190727022027.GA86863@google.com Link: http://lkml.kernel.org/r/20190703040156.56953-3-walken@google.com Signed-off-by: Michel Lespinasse <walken@google.com> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: David Howells <dhowells@redhat.com> Cc: Davidlohr Bueso <dbueso@suse.de> Cc: Uladzislau Rezki <urezki@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-09-24mm/vmalloc.c: move 'area->pages' after if statementAustin Kim
If !area->pages statement is true where memory allocation fails, area is freed. In this case 'area->pages = pages' should not executed. So move 'area->pages = pages' after if statement. [akpm@linux-foundation.org: give area->pages the same treatment] Link: http://lkml.kernel.org/r/20190830035716.GA190684@LGEARND20B15 Signed-off-by: Austin Kim <austindh.kim@gmail.com> Acked-by: Michal Hocko <mhocko@suse.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Uladzislau Rezki (Sony) <urezki@gmail.com> Cc: Roman Gushchin <guro@fb.com> Cc: Roman Penyaev <rpenyaev@suse.de> Cc: Rick Edgecombe <rick.p.edgecombe@intel.com> Cc: Mike Rapoport <rppt@linux.ibm.com> Cc: Andrey Ryabinin <aryabinin@virtuozzo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-09-24mm/vmalloc: modify struct vmap_area to reduce its sizePengfei Li
Objective --------- The current implementation of struct vmap_area wasted space. After applying this commit, sizeof(struct vmap_area) has been reduced from 11 words to 8 words. Description ----------- 1) Pack "subtree_max_size", "vm" and "purge_list". This is no problem because A) "subtree_max_size" is only used when vmap_area is in "free" tree B) "vm" is only used when vmap_area is in "busy" tree C) "purge_list" is only used when vmap_area is in vmap_purge_list 2) Eliminate "flags". ;Since only one flag VM_VM_AREA is being used, and the same thing can be done by judging whether "vm" is NULL, then the "flags" can be eliminated. Link: http://lkml.kernel.org/r/20190716152656.12255-3-lpf.vector@gmail.com Signed-off-by: Pengfei Li <lpf.vector@gmail.com> Suggested-by: Uladzislau Rezki (Sony) <urezki@gmail.com> Reviewed-by: Uladzislau Rezki (Sony) <urezki@gmail.com> Cc: Hillf Danton <hdanton@sina.com> Cc: Matthew Wilcox <willy@infradead.org> Cc: Michal Hocko <mhocko@suse.com> Cc: Oleksiy Avramchenko <oleksiy.avramchenko@sonymobile.com> Cc: Roman Gushchin <guro@fb.com> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-09-24mm/vmalloc: do not keep unpurged areas in the busy treeUladzislau Rezki (Sony)
The busy tree can be quite big, even though the area is freed or unmapped it still stays there until "purge" logic removes it. 1) Optimize and reduce the size of "busy" tree by removing a node from it right away as soon as user triggers free paths. It is possible to do so, because the allocation is done using another augmented tree. The vmalloc test driver shows the difference, for example the "fix_size_alloc_test" is ~11% better comparing with default configuration: sudo ./test_vmalloc.sh performance <default> Summary: fix_size_alloc_test loops: 1000000 avg: 993985 usec Summary: full_fit_alloc_test loops: 1000000 avg: 973554 usec Summary: long_busy_list_alloc_test loops: 1000000 avg: 12617652 usec <default> <this patch> Summary: fix_size_alloc_test loops: 1000000 avg: 882263 usec Summary: full_fit_alloc_test loops: 1000000 avg: 973407 usec Summary: long_busy_list_alloc_test loops: 1000000 avg: 12593929 usec <this patch> 2) Since the busy tree now contains allocated areas only and does not interfere with lazily free nodes, introduce the new function show_purge_info() that dumps "unpurged" areas that is propagated through "/proc/vmallocinfo". 3) Eliminate VM_LAZY_FREE flag. Link: http://lkml.kernel.org/r/20190716152656.12255-2-lpf.vector@gmail.com Signed-off-by: Uladzislau Rezki (Sony) <urezki@gmail.com> Signed-off-by: Pengfei Li <lpf.vector@gmail.com> Cc: Roman Gushchin <guro@fb.com> Cc: Uladzislau Rezki <urezki@gmail.com> Cc: Hillf Danton <hdanton@sina.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Matthew Wilcox <willy@infradead.org> Cc: Oleksiy Avramchenko <oleksiy.avramchenko@sonymobile.com> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-09-04vmalloc: lift the arm flag for coherent mappings to common codeChristoph Hellwig
The arm architecture had a VM_ARM_DMA_CONSISTENT flag to mark DMA coherent remapping for a while. Lift this flag to common code so that we can use it generically. We also check it in the only place VM_USERMAP is directly check so that we can entirely replace that flag as well (although I'm not even sure why we'd want to allow remapping DMA appings, but I'd rather not change behavior). Signed-off-by: Christoph Hellwig <hch@lst.de>
2019-08-13mm/vmalloc.c: fix percpu free VM area search criteriaKuppuswamy Sathyanarayanan
Recent changes to the vmalloc code by commit 68ad4a330433 ("mm/vmalloc.c: keep track of free blocks for vmap allocation") can cause spurious percpu allocation failures. These, in turn, can result in panic()s in the slub code. One such possible panic was reported by Dave Hansen in following link https://lkml.org/lkml/2019/6/19/939. Another related panic observed is, RIP: 0033:0x7f46f7441b9b Call Trace: dump_stack+0x61/0x80 pcpu_alloc.cold.30+0x22/0x4f mem_cgroup_css_alloc+0x110/0x650 cgroup_apply_control_enable+0x133/0x330 cgroup_mkdir+0x41b/0x500 kernfs_iop_mkdir+0x5a/0x90 vfs_mkdir+0x102/0x1b0 do_mkdirat+0x7d/0xf0 do_syscall_64+0x5b/0x180 entry_SYSCALL_64_after_hwframe+0x44/0xa9 VMALLOC memory manager divides the entire VMALLOC space (VMALLOC_START to VMALLOC_END) into multiple VM areas (struct vm_areas), and it mainly uses two lists (vmap_area_list & free_vmap_area_list) to track the used and free VM areas in VMALLOC space. And pcpu_get_vm_areas(offsets[], sizes[], nr_vms, align) function is used for allocating congruent VM areas for percpu memory allocator. In order to not conflict with VMALLOC users, pcpu_get_vm_areas allocates VM areas near the end of the VMALLOC space. So the search for free vm_area for the given requirement starts near VMALLOC_END and moves upwards towards VMALLOC_START. Prior to commit 68ad4a330433, the search for free vm_area in pcpu_get_vm_areas() involves following two main steps. Step 1: Find a aligned "base" adress near VMALLOC_END. va = free vm area near VMALLOC_END Step 2: Loop through number of requested vm_areas and check, Step 2.1: if (base < VMALLOC_START) 1. fail with error Step 2.2: // end is offsets[area] + sizes[area] if (base + end > va->vm_end) 1. Move the base downwards and repeat Step 2 Step 2.3: if (base + start < va->vm_start) 1. Move to previous free vm_area node, find aligned base address and repeat Step 2 But Commit 68ad4a330433 removed Step 2.2 and modified Step 2.3 as below: Step 2.3: if (base + start < va->vm_start || base + end > va->vm_end) 1. Move to previous free vm_area node, find aligned base address and repeat Step 2 Above change is the root cause of spurious percpu memory allocation failures. For example, consider a case where a relatively large vm_area (~ 30 TB) was ignored in free vm_area search because it did not pass the base + end < vm->vm_end boundary check. Ignoring such large free vm_area's would lead to not finding free vm_area within boundary of VMALLOC_start to VMALLOC_END which in turn leads to allocation failures. So modify the search algorithm to include Step 2.2. Link: http://lkml.kernel.org/r/20190729232139.91131-1-sathyanarayanan.kuppuswamy@linux.intel.com Fixes: 68ad4a330433 ("mm/vmalloc.c: keep track of free blocks for vmap allocation") Signed-off-by: Kuppuswamy Sathyanarayanan <sathyanarayanan.kuppuswamy@linux.intel.com> Reported-by: Dave Hansen <dave.hansen@intel.com> Acked-by: Dennis Zhou <dennis@kernel.org> Reviewed-by: Uladzislau Rezki (Sony) <urezki@gmail.com> Cc: Roman Gushchin <guro@fb.com> Cc: sathyanarayanan kuppuswamy <sathyanarayanan.kuppuswamy@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-07-22mm/vmalloc: Sync unmappings in __purge_vmap_area_lazy()Joerg Roedel
On x86-32 with PTI enabled, parts of the kernel page-tables are not shared between processes. This can cause mappings in the vmalloc/ioremap area to persist in some page-tables after the region is unmapped and released. When the region is re-used the processes with the old mappings do not fault in the new mappings but still access the old ones. This causes undefined behavior, in reality often data corruption, kernel oopses and panics and even spontaneous reboots. Fix this problem by activly syncing unmaps in the vmalloc/ioremap area to all page-tables in the system before the regions can be re-used. References: https://bugzilla.suse.com/show_bug.cgi?id=1118689 Fixes: 5d72b4fba40ef ('x86, mm: support huge I/O mapping capability I/F') Signed-off-by: Joerg Roedel <jroedel@suse.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Dave Hansen <dave.hansen@linux.intel.com> Link: https://lkml.kernel.org/r/20190719184652.11391-4-joro@8bytes.org
2019-07-12mm: vmalloc: show number of vmalloc pages in /proc/meminfoRoman Gushchin
Vmalloc() is getting more and more used these days (kernel stacks, bpf and percpu allocator are new top users), and the total % of memory consumed by vmalloc() can be pretty significant and changes dynamically. /proc/meminfo is the best place to display this information: its top goal is to show top consumers of the memory. Since the VmallocUsed field in /proc/meminfo is not in use for quite a long time (it has been defined to 0 by a5ad88ce8c7f ("mm: get rid of 'vmalloc_info' from /proc/meminfo")), let's reuse it for showing the actual physical memory consumption of vmalloc(). Link: http://lkml.kernel.org/r/20190417194002.12369-3-guro@fb.com Signed-off-by: Roman Gushchin <guro@fb.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Vlastimil Babka <vbabka@suse.cz> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Matthew Wilcox <willy@infradead.org> Cc: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-07-12mm/vmalloc.c: spelling> s/informaion/information/Geert Uytterhoeven
Link: http://lkml.kernel.org/r/20190607113509.15032-1-geert+renesas@glider.be Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Souptick Joarder <jrdr.linux@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-07-12mm/vmalloc.c: switch to WARN_ON() and move it under unlink_va()Uladzislau Rezki (Sony)
Trigger a warning if an object that is about to be freed is detached. We used to have a BUG_ON(), but even though it is considered as faulty behaviour that is not a good reason to break a system. Link: http://lkml.kernel.org/r/20190606120411.8298-5-urezki@gmail.com Signed-off-by: Uladzislau Rezki (Sony) <urezki@gmail.com> Cc: Roman Gushchin <guro@fb.com> Cc: Hillf Danton <hdanton@sina.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Matthew Wilcox <willy@infradead.org> Cc: Oleksiy Avramchenko <oleksiy.avramchenko@sonymobile.com> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-07-12mm/vmalloc.c: get rid of one single unlink_va() when mergeUladzislau Rezki (Sony)
It does not make sense to try to "unlink" the node that is definitely not linked with a list nor tree. On the first merge step VA just points to the previously disconnected busy area. On the second step, check if the node has been merged and do "unlink" if so, because now it points to an object that must be linked. Link: http://lkml.kernel.org/r/20190606120411.8298-4-urezki@gmail.com Signed-off-by: Uladzislau Rezki (Sony) <urezki@gmail.com> Acked-by: Hillf Danton <hdanton@sina.com> Reviewed-by: Roman Gushchin <guro@fb.com> Cc: Matthew Wilcox <willy@infradead.org> Cc: Michal Hocko <mhocko@suse.com> Cc: Oleksiy Avramchenko <oleksiy.avramchenko@sonymobile.com> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-07-12mm/vmalloc.c: preload a CPU with one object for split purposeUladzislau Rezki (Sony)
Refactor the NE_FIT_TYPE split case when it comes to an allocation of one extra object. We need it in order to build a remaining space. The preload is done per CPU in non-atomic context with GFP_KERNEL flags. More permissive parameters can be beneficial for systems which are suffer from high memory pressure or low memory condition. For example on my KVM system(4xCPUs, no swap, 256MB RAM) i can simulate the failure of page allocation with GFP_NOWAIT flags. Using "stress-ng" tool and starting N workers spinning on fork() and exit(), i can trigger below trace: <snip> [ 179.815161] stress-ng-fork: page allocation failure: order:0, mode:0x40800(GFP_NOWAIT|__GFP_COMP), nodemask=(null),cpuset=/,mems_allowed=0 [ 179.815168] CPU: 0 PID: 12612 Comm: stress-ng-fork Not tainted 5.2.0-rc3+ #1003 [ 179.815170] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1 04/01/2014 [ 179.815171] Call Trace: [ 179.815178] dump_stack+0x5c/0x7b [ 179.815182] warn_alloc+0x108/0x190 [ 179.815187] __alloc_pages_slowpath+0xdc7/0xdf0 [ 179.815191] __alloc_pages_nodemask+0x2de/0x330 [ 179.815194] cache_grow_begin+0x77/0x420 [ 179.815197] fallback_alloc+0x161/0x200 [ 179.815200] kmem_cache_alloc+0x1c9/0x570 [ 179.815202] alloc_vmap_area+0x32c/0x990 [ 179.815206] __get_vm_area_node+0xb0/0x170 [ 179.815208] __vmalloc_node_range+0x6d/0x230 [ 179.815211] ? _do_fork+0xce/0x3d0 [ 179.815213] copy_process.part.46+0x850/0x1b90 [ 179.815215] ? _do_fork+0xce/0x3d0 [ 179.815219] _do_fork+0xce/0x3d0 [ 179.815226] ? __do_page_fault+0x2bf/0x4e0 [ 179.815229] do_syscall_64+0x55/0x130 [ 179.815231] entry_SYSCALL_64_after_hwframe+0x44/0xa9 [ 179.815234] RIP: 0033:0x7fedec4c738b ... [ 179.815237] RSP: 002b:00007ffda469d730 EFLAGS: 00000246 ORIG_RAX: 0000000000000038 [ 179.815239] RAX: ffffffffffffffda RBX: 00007ffda469d730 RCX: 00007fedec4c738b [ 179.815240] RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000001200011 [ 179.815241] RBP: 00007ffda469d780 R08: 00007fededd6e300 R09: 00007ffda47f50a0 [ 179.815242] R10: 00007fededd6e5d0 R11: 0000000000000246 R12: 0000000000000000 [ 179.815243] R13: 0000000000000020 R14: 0000000000000000 R15: 0000000000000000 [ 179.815245] Mem-Info: [ 179.815249] active_anon:12686 inactive_anon:14760 isolated_anon:0 active_file:502 inactive_file:61 isolated_file:70 unevictable:2 dirty:0 writeback:0 unstable:0 slab_reclaimable:2380 slab_unreclaimable:7520 mapped:15069 shmem:14813 pagetables:10833 bounce:0 free:1922 free_pcp:229 free_cma:0 <snip> Link: http://lkml.kernel.org/r/20190606120411.8298-3-urezki@gmail.com Signed-off-by: Uladzislau Rezki (Sony) <urezki@gmail.com> Cc: Hillf Danton <hdanton@sina.com> Cc: Matthew Wilcox <willy@infradead.org> Cc: Michal Hocko <mhocko@suse.com> Cc: Oleksiy Avramchenko <oleksiy.avramchenko@sonymobile.com> Cc: Roman Gushchin <guro@fb.com> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-07-12mm/vmalloc.c: remove "node" argumentUladzislau Rezki (Sony)
Patch series "Some cleanups for the KVA/vmalloc", v5. This patch (of 4): Remove unused argument from the __alloc_vmap_area() function. Link: http://lkml.kernel.org/r/20190606120411.8298-2-urezki@gmail.com Signed-off-by: Uladzislau Rezki (Sony) <urezki@gmail.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Reviewed-by: Roman Gushchin <guro@fb.com> Cc: Hillf Danton <hdanton@sina.com> Cc: Matthew Wilcox <willy@infradead.org> Cc: Michal Hocko <mhocko@suse.com> Cc: Oleksiy Avramchenko <oleksiy.avramchenko@sonymobile.com> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-07-12mm/pgtable: drop pgtable_t variable from pte_fn_t functionsAnshuman Khandual
Drop the pgtable_t variable from all implementation for pte_fn_t as none of them use it. apply_to_pte_range() should stop computing it as well. Should help us save some cycles. Link: http://lkml.kernel.org/r/1556803126-26596-1-git-send-email-anshuman.khandual@arm.com Signed-off-by: Anshuman Khandual <anshuman.khandual@arm.com> Acked-by: Matthew Wilcox <willy@infradead.org> Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org> Cc: Russell King <linux@armlinux.org.uk> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Logan Gunthorpe <logang@deltatee.com> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Dan Williams <dan.j.williams@intel.com> Cc: <jglisse@redhat.com> Cc: Mike Rapoport <rppt@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-07-08Merge tag 'arm64-upstream' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux Pull arm64 updates from Catalin Marinas: - arm64 support for syscall emulation via PTRACE_SYSEMU{,_SINGLESTEP} - Wire up VM_FLUSH_RESET_PERMS for arm64, allowing the core code to manage the permissions of executable vmalloc regions more strictly - Slight performance improvement by keeping softirqs enabled while touching the FPSIMD/SVE state (kernel_neon_begin/end) - Expose a couple of ARMv8.5 features to user (HWCAP): CondM (new XAFLAG and AXFLAG instructions for floating point comparison flags manipulation) and FRINT (rounding floating point numbers to integers) - Re-instate ARM64_PSEUDO_NMI support which was previously marked as BROKEN due to some bugs (now fixed) - Improve parking of stopped CPUs and implement an arm64-specific panic_smp_self_stop() to avoid warning on not being able to stop secondary CPUs during panic - perf: enable the ARM Statistical Profiling Extensions (SPE) on ACPI platforms - perf: DDR performance monitor support for iMX8QXP - cache_line_size() can now be set from DT or ACPI/PPTT if provided to cope with a system cache info not exposed via the CPUID registers - Avoid warning on hardware cache line size greater than ARCH_DMA_MINALIGN if the system is fully coherent - arm64 do_page_fault() and hugetlb cleanups - Refactor set_pte_at() to avoid redundant READ_ONCE(*ptep) - Ignore ACPI 5.1 FADTs reported as 5.0 (infer from the 'arm_boot_flags' introduced in 5.1) - CONFIG_RANDOMIZE_BASE now enabled in defconfig - Allow the selection of ARM64_MODULE_PLTS, currently only done via RANDOMIZE_BASE (and an erratum workaround), allowing modules to spill over into the vmalloc area - Make ZONE_DMA32 configurable * tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (54 commits) perf: arm_spe: Enable ACPI/Platform automatic module loading arm_pmu: acpi: spe: Add initial MADT/SPE probing ACPI/PPTT: Add function to return ACPI 6.3 Identical tokens ACPI/PPTT: Modify node flag detection to find last IDENTICAL x86/entry: Simplify _TIF_SYSCALL_EMU handling arm64: rename dump_instr as dump_kernel_instr arm64/mm: Drop [PTE|PMD]_TYPE_FAULT arm64: Implement panic_smp_self_stop() arm64: Improve parking of stopped CPUs arm64: Expose FRINT capabilities to userspace arm64: Expose ARMv8.5 CondM capability to userspace arm64: defconfig: enable CONFIG_RANDOMIZE_BASE arm64: ARM64_MODULES_PLTS must depend on MODULES arm64: bpf: do not allocate executable memory arm64/kprobes: set VM_FLUSH_RESET_PERMS on kprobe instruction pages arm64/mm: wire up CONFIG_ARCH_HAS_SET_DIRECT_MAP arm64: module: create module allocations without exec permissions arm64: Allow user selection of ARM64_MODULE_PLTS acpi/arm64: ignore 5.1 FADTs that are reported as 5.0 arm64: Allow selecting Pseudo-NMI again ...
2019-06-29mm/vmalloc.c: avoid bogus -Wmaybe-uninitialized warningArnd Bergmann
gcc gets confused in pcpu_get_vm_areas() because there are too many branches that affect whether 'lva' was initialized before it gets used: mm/vmalloc.c: In function 'pcpu_get_vm_areas': mm/vmalloc.c:991:4: error: 'lva' may be used uninitialized in this function [-Werror=maybe-uninitialized] insert_vmap_area_augment(lva, &va->rb_node, ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ &free_vmap_area_root, &free_vmap_area_list); ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ mm/vmalloc.c:916:20: note: 'lva' was declared here struct vmap_area *lva; ^~~ Add an intialization to NULL, and check whether this has changed before the first use. [akpm@linux-foundation.org: tweak comments] Link: http://lkml.kernel.org/r/20190618092650.2943749-1-arnd@arndb.de Fixes: 68ad4a330433 ("mm/vmalloc.c: keep track of free blocks for vmap allocation") Signed-off-by: Arnd Bergmann <arnd@arndb.de> Reviewed-by: Uladzislau Rezki (Sony) <urezki@gmail.com> Cc: Joel Fernandes <joelaf@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-06-24arm64/mm: wire up CONFIG_ARCH_HAS_SET_DIRECT_MAPArd Biesheuvel
Wire up the special helper functions to manipulate aliases of vmalloc regions in the linear map. Acked-by: Will Deacon <will@kernel.org> Signed-off-by: Ard Biesheuvel <ard.biesheuvel@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2019-06-03mm/vmalloc: Avoid rare case of flushing TLB with weird argumentsRick Edgecombe
In a rare case, flush_tlb_kernel_range() could be called with a start higher than the end. In vm_remove_mappings(), in case page_address() returns 0 for all pages (for example they were all in highmem), _vm_unmap_aliases() will be called with start = ULONG_MAX, end = 0 and flush = 1. If at the same time, the vmalloc purge operation is triggered by something else while the current operation is between remove_vm_area() and _vm_unmap_aliases(), then the vm mapping just removed will be already purged. In this case the call of vm_unmap_aliases() may not find any other mappings to flush and so end up flushing start = ULONG_MAX, end = 0. So only set flush = true if we find something in the direct mapping that we need to flush, and this way this can't happen. Signed-off-by: Rick Edgecombe <rick.p.edgecombe@intel.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@intel.com> Cc: David S. Miller <davem@davemloft.net> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Meelis Roos <mroos@linux.ee> Cc: Nadav Amit <namit@vmware.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Thomas Gleixner <tglx@linutronix.de> Fixes: 868b104d7379 ("mm/vmalloc: Add flag for freeing of special permsissions") Link: https://lkml.kernel.org/r/20190527211058.2729-3-rick.p.edgecombe@intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2019-06-03mm/vmalloc: Fix calculation of direct map addr rangeRick Edgecombe
The calculation of the direct map address range to flush was wrong. This could cause the RO direct map alias to not get flushed. Today this shouldn't be a problem because this flush is only needed on x86 right now and the spurious fault handler will fix cached RO->RW translations. In the future though, it could cause the permissions to remain RO in the TLB for the direct map alias, and then the page would return from the page allocator to some other component as RO and cause a crash. So fix fix the address range calculation so the flush will include the direct map range. Signed-off-by: Rick Edgecombe <rick.p.edgecombe@intel.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@intel.com> Cc: David S. Miller <davem@davemloft.net> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Meelis Roos <mroos@linux.ee> Cc: Nadav Amit <namit@vmware.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Fixes: 868b104d7379 ("mm/vmalloc: Add flag for freeing of special permsissions") Link: https://lkml.kernel.org/r/20190527211058.2729-2-rick.p.edgecombe@intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2019-06-01mm/vmalloc.c: fix typo in commentAndrew Morton
Reported-by: Nicholas Joll <najoll@posteo.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-05-21treewide: Add SPDX license identifier for missed filesThomas Gleixner
Add SPDX license identifiers to all files which: - Have no license information of any form - Have EXPORT_.*_SYMBOL_GPL inside which was used in the initial scan/conversion to ignore the file These files fall under the project license, GPL v2 only. The resulting SPDX license identifier is: GPL-2.0-only Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-18mm/vmap: add DEBUG_AUGMENT_LOWEST_MATCH_CHECK macroUladzislau Rezki (Sony)
This macro adds some debug code to check that vmap allocations are happened in ascending order. By default this option is set to 0 and not active. It requires recompilation of the kernel to activate it. Set to 1, compile the kernel. [urezki@gmail.com: v4] Link: http://lkml.kernel.org/r/20190406183508.25273-4-urezki@gmail.com Link: http://lkml.kernel.org/r/20190402162531.10888-4-urezki@gmail.com Signed-off-by: Uladzislau Rezki (Sony) <urezki@gmail.com> Reviewed-by: Roman Gushchin <guro@fb.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Joel Fernandes <joelaf@google.com> Cc: Matthew Wilcox <willy@infradead.org> Cc: Michal Hocko <mhocko@suse.com> Cc: Oleksiy Avramchenko <oleksiy.avramchenko@sonymobile.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Tejun Heo <tj@kernel.org> Cc: Thomas Garnier <thgarnie@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-05-18mm/vmap: add DEBUG_AUGMENT_PROPAGATE_CHECK macroUladzislau Rezki (Sony)
This macro adds some debug code to check that the augment tree is maintained correctly, meaning that every node contains valid subtree_max_size value. By default this option is set to 0 and not active. It requires recompilation of the kernel to activate it. Set to 1, compile the kernel. [urezki@gmail.com: v4] Link: http://lkml.kernel.org/r/20190406183508.25273-3-urezki@gmail.com Link: http://lkml.kernel.org/r/20190402162531.10888-3-urezki@gmail.com Signed-off-by: Uladzislau Rezki (Sony) <urezki@gmail.com> Reviewed-by: Roman Gushchin <guro@fb.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Joel Fernandes <joelaf@google.com> Cc: Matthew Wilcox <willy@infradead.org> Cc: Michal Hocko <mhocko@suse.com> Cc: Oleksiy Avramchenko <oleksiy.avramchenko@sonymobile.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Tejun Heo <tj@kernel.org> Cc: Thomas Garnier <thgarnie@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-05-18mm/vmalloc.c: keep track of free blocks for vmap allocationUladzislau Rezki (Sony)
Patch series "improve vmap allocation", v3. Objective --------- Please have a look for the description at: https://lkml.org/lkml/2018/10/19/786 but let me also summarize it a bit here as well. The current implementation has O(N) complexity. Requests with different permissive parameters can lead to long allocation time. When i say "long" i mean milliseconds. Description ----------- This approach organizes the KVA memory layout into free areas of the 1-ULONG_MAX range, i.e. an allocation is done over free areas lookups, instead of finding a hole between two busy blocks. It allows to have lower number of objects which represent the free space, therefore to have less fragmented memory allocator. Because free blocks are always as large as possible. It uses the augment tree where all free areas are sorted in ascending order of va->va_start address in pair with linked list that provides O(1) access to prev/next elements. Since the tree is augment, we also maintain the "subtree_max_size" of VA that reflects a maximum available free block in its left or right sub-tree. Knowing that, we can easily traversal toward the lowest (left most path) free area. Allocation: ~O(log(N)) complexity. It is sequential allocation method therefore tends to maximize locality. The search is done until a first suitable block is large enough to encompass the requested parameters. Bigger areas are split. I copy paste here the description of how the area is split, since i described it in https://lkml.org/lkml/2018/10/19/786 <snip> A free block can be split by three different ways. Their names are FL_FIT_TYPE, LE_FIT_TYPE/RE_FIT_TYPE and NE_FIT_TYPE, i.e. they correspond to how requested size and alignment fit to a free block. FL_FIT_TYPE - in this case a free block is just removed from the free list/tree because it fully fits. Comparing with current design there is an extra work with rb-tree updating. LE_FIT_TYPE/RE_FIT_TYPE - left/right edges fit. In this case what we do is just cutting a free block. It is as fast as a current design. Most of the vmalloc allocations just end up with this case, because the edge is always aligned to 1. NE_FIT_TYPE - Is much less common case. Basically it happens when requested size and alignment does not fit left nor right edges, i.e. it is between them. In this case during splitting we have to build a remaining left free area and place it back to the free list/tree. Comparing with current design there are two extra steps. First one is we have to allocate a new vmap_area structure. Second one we have to insert that remaining free block to the address sorted list/tree. In order to optimize a first case there is a cache with free_vmap objects. Instead of allocating from slab we just take an object from the cache and reuse it. Second one is pretty optimized. Since we know a start point in the tree we do not do a search from the top. Instead a traversal begins from a rb-tree node we split. <snip> De-allocation. ~O(log(N)) complexity. An area is not inserted straight away to the tree/list, instead we identify the spot first, checking if it can be merged around neighbors. The list provides O(1) access to prev/next, so it is pretty fast to check it. Summarizing. If merged then large coalesced areas are created, if not the area is just linked making more fragments. There is one more thing that i should mention here. After modification of VA node, its subtree_max_size is updated if it was/is the biggest area in its left or right sub-tree. Apart of that it can also be populated back to upper levels to fix the tree. For more details please have a look at the __augment_tree_propagate_from() function and the description. Tests and stressing ------------------- I use the "test_vmalloc.sh" test driver available under "tools/testing/selftests/vm/" since 5.1-rc1 kernel. Just trigger "sudo ./test_vmalloc.sh" to find out how to deal with it. Tested on different platforms including x86_64/i686/ARM64/x86_64_NUMA. Regarding last one, i do not have any physical access to NUMA system, therefore i emulated it. The time of stressing is days. If you run the test driver in "stress mode", you also need the patch that is in Andrew's tree but not in Linux 5.1-rc1. So, please apply it: http://git.cmpxchg.org/cgit.cgi/linux-mmotm.git/commit/?id=e0cf7749bade6da318e98e934a24d8b62fab512c After massive testing, i have not identified any problems like memory leaks, crashes or kernel panics. I find it stable, but more testing would be good. Performance analysis -------------------- I have used two systems to test. One is i5-3320M CPU @ 2.60GHz and another is HiKey960(arm64) board. i5-3320M runs on 4.20 kernel, whereas Hikey960 uses 4.15 kernel. I have both system which could run on 5.1-rc1 as well, but the results have not been ready by time i an writing this. Currently it consist of 8 tests. There are three of them which correspond to different types of splitting(to compare with default). We have 3 ones(see above). Another 5 do allocations in different conditions. a) sudo ./test_vmalloc.sh performance When the test driver is run in "performance" mode, it runs all available tests pinned to first online CPU with sequential execution test order. We do it in order to get stable and repeatable results. Take a look at time difference in "long_busy_list_alloc_test". It is not surprising because the worst case is O(N). # i5-3320M How many cycles all tests took: CPU0=646919905370(default) cycles vs CPU0=193290498550(patched) cycles # See detailed table with results here: ftp://vps418301.ovh.net/incoming/vmap_test_results_v2/i5-3320M_performance_default.txt ftp://vps418301.ovh.net/incoming/vmap_test_results_v2/i5-3320M_performance_patched.txt # Hikey960 8x CPUs How many cycles all tests took: CPU0=3478683207 cycles vs CPU0=463767978 cycles # See detailed table with results here: ftp://vps418301.ovh.net/incoming/vmap_test_results_v2/HiKey960_performance_default.txt ftp://vps418301.ovh.net/incoming/vmap_test_results_v2/HiKey960_performance_patched.txt b) time sudo ./test_vmalloc.sh test_repeat_count=1 With this configuration, all tests are run on all available online CPUs. Before running each CPU shuffles its tests execution order. It gives random allocation behaviour. So it is rough comparison, but it puts in the picture for sure. # i5-3320M <default> vs <patched> real 101m22.813s real 0m56.805s user 0m0.011s user 0m0.015s sys 0m5.076s sys 0m0.023s # See detailed table with results here: ftp://vps418301.ovh.net/incoming/vmap_test_results_v2/i5-3320M_test_repeat_count_1_default.txt ftp://vps418301.ovh.net/incoming/vmap_test_results_v2/i5-3320M_test_repeat_count_1_patched.txt # Hikey960 8x CPUs <default> vs <patched> real unknown real 4m25.214s user unknown user 0m0.011s sys unknown sys 0m0.670s I did not manage to complete this test on "default Hikey960" kernel version. After 24 hours it was still running, therefore i had to cancel it. That is why real/user/sys are "unknown". This patch (of 3): Currently an allocation of the new vmap area is done over busy list iteration(complexity O(n)) until a suitable hole is found between two busy areas. Therefore each new allocation causes the list being grown. Due to over fragmented list and different permissive parameters an allocation can take a long time. For example on embedded devices it is milliseconds. This patch organizes the KVA memory layout into free areas of the 1-ULONG_MAX range. It uses an augment red-black tree that keeps blocks sorted by their offsets in pair with linked list keeping the free space in order of increasing addresses. Nodes are augmented with the size of the maximum available free block in its left or right sub-tree. Thus, that allows to take a decision and traversal toward the block that will fit and will have the lowest start address, i.e. it is sequential allocation. Allocation: to allocate a new block a search is done over the tree until a suitable lowest(left most) block is large enough to encompass: the requested size, alignment and vstart point. If the block is bigger than requested size - it is split. De-allocation: when a busy vmap area is freed it can either be merged or inserted to the tree. Red-black tree allows efficiently find a spot whereas a linked list provides a constant-time access to previous and next blocks to check if merging can be done. In case of merging of de-allocated memory chunk a large coalesced area is created. Complexity: ~O(log(N)) [urezki@gmail.com: v3] Link: http://lkml.kernel.org/r/20190402162531.10888-2-urezki@gmail.com [urezki@gmail.com: v4] Link: http://lkml.kernel.org/r/20190406183508.25273-2-urezki@gmail.com Link: http://lkml.kernel.org/r/20190321190327.11813-2-urezki@gmail.com Signed-off-by: Uladzislau Rezki (Sony) <urezki@gmail.com> Reviewed-by: Roman Gushchin <guro@fb.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Matthew Wilcox <willy@infradead.org> Cc: Thomas Garnier <thgarnie@google.com> Cc: Oleksiy Avramchenko <oleksiy.avramchenko@sonymobile.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Joel Fernandes <joelaf@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-05-14mm/vmalloc.c: convert vmap_lazy_nr to atomic_long_tUladzislau Rezki (Sony)
vmap_lazy_nr variable has atomic_t type that is 4 bytes integer value on both 32 and 64 bit systems. lazy_max_pages() deals with "unsigned long" that is 8 bytes on 64 bit system, thus vmap_lazy_nr should be 8 bytes on 64 bit as well. Link: http://lkml.kernel.org/r/20190131162452.25879-1-urezki@gmail.com Signed-off-by: Uladzislau Rezki (Sony) <urezki@gmail.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Reviewed-by: William Kucharski <william.kucharski@oracle.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Matthew Wilcox <willy@infradead.org> Cc: Thomas Garnier <thgarnie@google.com> Cc: Oleksiy Avramchenko <oleksiy.avramchenko@sonymobile.com> Cc: Joel Fernandes <joelaf@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-05-14mm/vmalloc.c: add priority threshold to __purge_vmap_area_lazy()Uladzislau Rezki (Sony)
Commit 763b218ddfaf ("mm: add preempt points into __purge_vmap_area_lazy()") introduced some preempt points, one of those is making an allocation more prioritized over lazy free of vmap areas. Prioritizing an allocation over freeing does not work well all the time, i.e. it should be rather a compromise. 1) Number of lazy pages directly influences the busy list length thus on operations like: allocation, lookup, unmap, remove, etc. 2) Under heavy stress of vmalloc subsystem I run into a situation when memory usage gets increased hitting out_of_memory -> panic state due to completely blocking of logic that frees vmap areas in the __purge_vmap_area_lazy() function. Establish a threshold passing which the freeing is prioritized back over allocation creating a balance between each other. Using vmalloc test driver in "stress mode", i.e. When all available test cases are run simultaneously on all online CPUs applying a pressure on the vmalloc subsystem, my HiKey 960 board runs out of memory due to the fact that __purge_vmap_area_lazy() logic simply is not able to free pages in time. How I run it: 1) You should build your kernel with CONFIG_TEST_VMALLOC=m 2) ./tools/testing/selftests/vm/test_vmalloc.sh stress During this test "vmap_lazy_nr" pages will go far beyond acceptable lazy_max_pages() threshold, that will lead to enormous busy list size and other problems including allocation time and so on. Link: http://lkml.kernel.org/r/20190124115648.9433-3-urezki@gmail.com Signed-off-by: Uladzislau Rezki (Sony) <urezki@gmail.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Michal Hocko <mhocko@suse.com> Cc: Matthew Wilcox <willy@infradead.org> Cc: Thomas Garnier <thgarnie@google.com> Cc: Oleksiy Avramchenko <oleksiy.avramchenko@sonymobile.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Joel Fernandes <joelaf@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Tejun Heo <tj@kernel.org> Cc: Joel Fernandes <joel@joelfernandes.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-04-30mm/vmalloc: Add flag for freeing of special permsissionsRick Edgecombe
Add a new flag VM_FLUSH_RESET_PERMS, for enabling vfree operations to immediately clear executable TLB entries before freeing pages, and handle resetting permissions on the directmap. This flag is useful for any kind of memory with elevated permissions, or where there can be related permissions changes on the directmap. Today this is RO+X and RO memory. Although this enables directly vfreeing non-writeable memory now, non-writable memory cannot be freed in an interrupt because the allocation itself is used as a node on deferred free list. So when RO memory needs to be freed in an interrupt the code doing the vfree needs to have its own work queue, as was the case before the deferred vfree list was added to vmalloc. For architectures with set_direct_map_ implementations this whole operation can be done with one TLB flush when centralized like this. For others with directmap permissions, currently only arm64, a backup method using set_memory functions is used to reset the directmap. When arm64 adds set_direct_map_ functions, this backup can be removed. When the TLB is flushed to both remove TLB entries for the vmalloc range mapping and the direct map permissions, the lazy purge operation could be done to try to save a TLB flush later. However today vm_unmap_aliases could flush a TLB range that does not include the directmap. So a helper is added with extra parameters that can allow both the vmalloc address and the direct mapping to be flushed during this operation. The behavior of the normal vm_unmap_aliases function is unchanged. Suggested-by: Dave Hansen <dave.hansen@intel.com> Suggested-by: Andy Lutomirski <luto@kernel.org> Suggested-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Rick Edgecombe <rick.p.edgecombe@intel.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: <akpm@linux-foundation.org> Cc: <ard.biesheuvel@linaro.org> Cc: <deneen.t.dock@intel.com> Cc: <kernel-hardening@lists.openwall.com> Cc: <kristen@linux.intel.com> Cc: <linux_dti@icloud.com> Cc: Borislav Petkov <bp@alien8.de> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Nadav Amit <nadav.amit@gmail.com> Cc: Rik van Riel <riel@surriel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Link: https://lkml.kernel.org/r/20190426001143.4983-17-namit@vmware.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2019-03-05docs/core-api/mm: fix return value descriptions in mm/Mike Rapoport
Many kernel-doc comments in mm/ have the return value descriptions either misformatted or omitted at all which makes kernel-doc script unhappy: $ make V=1 htmldocs ... ./mm/util.c:36: info: Scanning doc for kstrdup ./mm/util.c:41: warning: No description found for return value of 'kstrdup' ./mm/util.c:57: info: Scanning doc for kstrdup_const ./mm/util.c:66: warning: No description found for return value of 'kstrdup_const' ./mm/util.c:75: info: Scanning doc for kstrndup ./mm/util.c:83: warning: No description found for return value of 'kstrndup' ... Fixing the formatting and adding the missing return value descriptions eliminates ~100 such warnings. Link: http://lkml.kernel.org/r/1549549644-4903-4-git-send-email-rppt@linux.ibm.com Signed-off-by: Mike Rapoport <rppt@linux.ibm.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-03-05docs/mm: vmalloc: re-indent kernel-doc comemntsMike Rapoport
Some kernel-doc comments in mm/vmalloc.c have leading tab in indentation. This leads to excessive indentation in the generated HTML and to the inconsistency of its layout ([1] vs [2]). Besides, multi-line Note: sections are not handled properly with extra indentation. [1] https://www.kernel.org/doc/html/v4.20/core-api/mm-api.html?#c.vm_map_ram [2] https://www.kernel.org/doc/html/v4.20/core-api/mm-api.html?#c.vfree Link: http://lkml.kernel.org/r/1549549644-4903-2-git-send-email-rppt@linux.ibm.com Signed-off-by: Mike Rapoport <rppt@linux.ibm.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-03-05mm/vmalloc.c: fix kernel BUG at mm/vmalloc.c:512!Uladzislau Rezki (Sony)
One of the vmalloc stress test case triggers the kernel BUG(): <snip> [60.562151] ------------[ cut here ]------------ [60.562154] kernel BUG at mm/vmalloc.c:512! [60.562206] invalid opcode: 0000 [#1] PREEMPT SMP PTI [60.562247] CPU: 0 PID: 430 Comm: vmalloc_test/0 Not tainted 4.20.0+ #161 [60.562293] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1 04/01/2014 [60.562351] RIP: 0010:alloc_vmap_area+0x36f/0x390 <snip> it can happen due to big align request resulting in overflowing of calculated address, i.e. it becomes 0 after ALIGN()'s fixup. Fix it by checking if calculated address is within vstart/vend range. Link: http://lkml.kernel.org/r/20190124115648.9433-2-urezki@gmail.com Signed-off-by: Uladzislau Rezki (Sony) <urezki@gmail.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Joel Fernandes <joelaf@google.com> Cc: Matthew Wilcox <willy@infradead.org> Cc: Michal Hocko <mhocko@suse.com> Cc: Oleksiy Avramchenko <oleksiy.avramchenko@sonymobile.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Tejun Heo <tj@kernel.org> Cc: Thomas Garnier <thgarnie@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-03-05vmalloc: export __vmalloc_node_range for CONFIG_TEST_VMALLOC_MODULEUladzislau Rezki (Sony)
Export __vmaloc_node_range() function if CONFIG_TEST_VMALLOC_MODULE is enabled. Some test cases in vmalloc test suite module require and make use of that function. Please note, that it is not supposed to be used for other purposes. We need it only for performance analysis, stressing and stability check of vmalloc allocator. Link: http://lkml.kernel.org/r/20190103142108.20744-2-urezki@gmail.com Signed-off-by: Uladzislau Rezki (Sony) <urezki@gmail.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Michal Hocko <mhocko@suse.com> Cc: Kees Cook <keescook@chromium.org> Cc: Matthew Wilcox <willy@infradead.org> Cc: Shuah Khan <shuah@kernel.org> Cc: Oleksiy Avramchenko <oleksiy.avramchenko@sonymobile.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-03-05mm/vmalloc: pass VM_USERMAP flags directly to __vmalloc_node_range()Roman Penyaev
vmalloc_user*() calls differ from normal vmalloc() only in that they set VM_USERMAP flags for the area. During the whole history of vmalloc.c changes now it is possible simply to pass VM_USERMAP flags directly to __vmalloc_node_range() call instead of finding the area (which obviously takes time) after the allocation. Link: http://lkml.kernel.org/r/20190103145954.16942-4-rpenyaev@suse.de Signed-off-by: Roman Penyaev <rpenyaev@suse.de> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Joe Perches <joe@perches.com> Cc: "Luis R. Rodriguez" <mcgrof@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-03-05mm/vmalloc: do not call kmemleak_free() on not yet accounted memoryRoman Penyaev
__vmalloc_area_node() calls vfree() on error path, which in turn calls kmemleak_free(), but area is not yet accounted by kmemleak_vmalloc(). Link: http://lkml.kernel.org/r/20190103145954.16942-3-rpenyaev@suse.de Signed-off-by: Roman Penyaev <rpenyaev@suse.de> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Michal Hocko <mhocko@suse.com> Cc: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Joe Perches <joe@perches.com> Cc: "Luis R. Rodriguez" <mcgrof@kernel.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-03-05mm/vmalloc: fix size check for remap_vmalloc_range_partial()Roman Penyaev
When VM_NO_GUARD is not set area->size includes adjacent guard page, thus for correct size checking get_vm_area_size() should be used, but not area->size. This fixes possible kernel oops when userspace tries to mmap an area on 1 page bigger than was allocated by vmalloc_user() call: the size check inside remap_vmalloc_range_partial() accounts non-existing guard page also, so check successfully passes but vmalloc_to_page() returns NULL (guard page does not physically exist). The following code pattern example should trigger an oops: static int oops_mmap(struct file *file, struct vm_area_struct *vma) { void *mem; mem = vmalloc_user(4096); BUG_ON(!mem); /* Do not care about mem leak */ return remap_vmalloc_range(vma, mem, 0); } And userspace simply mmaps size + PAGE_SIZE: mmap(NULL, 8192, PROT_WRITE|PROT_READ, MAP_PRIVATE, fd, 0); Possible candidates for oops which do not have any explicit size checks: *** drivers/media/usb/stkwebcam/stk-webcam.c: v4l_stk_mmap[789] ret = remap_vmalloc_range(vma, sbuf->buffer, 0); Or the following one: *** drivers/video/fbdev/core/fbmem.c static int fb_mmap(struct file *file, struct vm_area_struct * vma) ... res = fb->fb_mmap(info, vma); Where fb_mmap callback calls remap_vmalloc_range() directly without any explicit checks: *** drivers/video/fbdev/vfb.c static int vfb_mmap(struct fb_info *info, struct vm_area_struct *vma) { return remap_vmalloc_range(vma, (void *)info->fix.smem_start, vma->vm_pgoff); } Link: http://lkml.kernel.org/r/20190103145954.16942-2-rpenyaev@suse.de Signed-off-by: Roman Penyaev <rpenyaev@suse.de> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Joe Perches <joe@perches.com> Cc: "Luis R. Rodriguez" <mcgrof@kernel.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-03-05mm/vmalloc.c: make vmalloc_32_user() align base kernel virtual address to SHMLBARoman Penyaev
This patch repeats the original one from David S Miller: 2dca6999eed5 ("mm, perf_event: Make vmalloc_user() align base kernel virtual address to SHMLBA") but for missed vmalloc_32_user() case, which also requires correct alignment of virtual address on kernel side to avoid D-caches aliases. A bit of copy-paste from original patch to recover in memory of what is all about: When a vmalloc'd area is mmap'd into userspace, some kind of co-ordination is necessary for this to work on platforms with cpu D-caches which can have aliases. Otherwise kernel side writes won't be seen properly in userspace and vice versa. If the kernel side mapping and the user side one have the same alignment, modulo SHMLBA, this can work as long as VM_SHARED is shared of VMA and for all current users this is true. VM_SHARED will force SHMLBA alignment of the user side mmap on platforms with D-cache aliasing matters. David S. Miller > What are the user-visible runtime effects of this change? In simple words: proper alignment avoids possible difference in data, seen by different virtual mapings: userspace and kernel in our case. I.e. userspace reads cache line A, kernel writes to cache line B. Both cache lines correspond to the same physical memory (thus aliases). So this should fix data corruption for archs with vivt and vipt caches, e.g. armv6. Personally I've never worked with this archs, I just spotted the strange difference in code: for one case we do alignment, for another - not. I have a strong feeling that David simply missed vmalloc_32_user() case. > > Is a -stable backport needed? No, I do not think so. The only one user of vmalloc_32_user() is virtual frame buffer device drivers/video/fbdev/vfb.c, which has in the description "The main use of this frame buffer device is testing and debugging the frame buffer subsystem. Do NOT enable it for normal systems!". And it seems to me that this vfb.c does not need 32bit addressable pages (vmalloc_32_user() case), because it is virtual device and should not care about things like dma32 zones, etc. Probably is better to clean the code and switch vfb.c from vmalloc_32_user() to vmalloc_user() case and wipe out vmalloc_32_user() from vmalloc.c completely. But I'm not very much sure that this is worth to do, that's so minor, so we can leave it as is. Link: http://lkml.kernel.org/r/20190108110944.23591-1-rpenyaev@suse.de Signed-off-by: Roman Penyaev <rpenyaev@suse.de> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Michal Hocko <mhocko@suse.com> Cc: David S. Miller <davem@davemloft.net> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-03-05mm/vmalloc.c: don't dereference possible NULL pointer in __vunmap()Liviu Dudau
find_vmap_area() can return a NULL pointer and we're going to dereference it without checking it first. Use the existing find_vm_area() function which does exactly what we want and checks for the NULL pointer. Link: http://lkml.kernel.org/r/20181228171009.22269-1-liviu@dudau.co.uk Fixes: f3c01d2f3ade ("mm: vmalloc: avoid racy handling of debugobjects in vunmap") Signed-off-by: Liviu Dudau <liviu@dudau.co.uk> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Chintan Pandya <cpandya@codeaurora.org> Cc: Andrey Ryabinin <aryabinin@virtuozzo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-12-28mm: convert totalram_pages and totalhigh_pages variables to atomicArun KS
totalram_pages and totalhigh_pages are made static inline function. Main motivation was that managed_page_count_lock handling was complicating things. It was discussed in length here, https://lore.kernel.org/patchwork/patch/995739/#1181785 So it seemes better to remove the lock and convert variables to atomic, with preventing poteintial store-to-read tearing as a bonus. [akpm@linux-foundation.org: coding style fixes] Link: http://lkml.kernel.org/r/1542090790-21750-4-git-send-email-arunks@codeaurora.org Signed-off-by: Arun KS <arunks@codeaurora.org> Suggested-by: Michal Hocko <mhocko@suse.com> Suggested-by: Vlastimil Babka <vbabka@suse.cz> Reviewed-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Reviewed-by: Pavel Tatashin <pasha.tatashin@soleen.com> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: David Hildenbrand <david@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-10-26vfree: add debug might_sleep()Andrey Ryabinin
Add might_sleep() call to vfree() to catch potential sleep-in-atomic bugs earlier. [aryabinin@virtuozzo.com: drop might_sleep_if() from kvfree()] Link: http://lkml.kernel.org/r/7e19e4df-b1a6-29bd-9ae7-0266d50bef1d@virtuozzo.com Link: http://lkml.kernel.org/r/20180914130512.10394-3-aryabinin@virtuozzo.com Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-10-26mm/vmalloc.c: improve vfree() kerneldocAndrey Ryabinin
vfree() might sleep if called not in interrupt context. Explain that in the comment. Link: http://lkml.kernel.org/r/20180914130512.10394-2-aryabinin@virtuozzo.com Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-08-17mm: provide a fallback for PAGE_KERNEL_EXEC for architecturesLuis R. Rodriguez
Some architectures just don't have PAGE_KERNEL_EXEC. The mm/nommu.c and mm/vmalloc.c code have been using PAGE_KERNEL as a fallback for years. Move this fallback to asm-generic. Link: http://lkml.kernel.org/r/20180510185507.2439-3-mcgrof@kernel.org Signed-off-by: Luis R. Rodriguez <mcgrof@kernel.org> Suggested-by: Matthew Wilcox <willy@infradead.org> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-06-15mm: use octal not symbolic permissionsJoe Perches
mm/*.c files use symbolic and octal styles for permissions. Using octal and not symbolic permissions is preferred by many as more readable. https://lkml.org/lkml/2016/8/2/1945 Prefer the direct use of octal for permissions. Done using $ scripts/checkpatch.pl -f --types=SYMBOLIC_PERMS --fix-inplace mm/*.c and some typing. Before: $ git grep -P -w "0[0-7]{3,3}" mm | wc -l 44 After: $ git grep -P -w "0[0-7]{3,3}" mm | wc -l 86 Miscellanea: o Whitespace neatening around these conversions. Link: http://lkml.kernel.org/r/2e032ef111eebcd4c5952bae86763b541d373469.1522102887.git.joe@perches.com Signed-off-by: Joe Perches <joe@perches.com> Acked-by: David Rientjes <rientjes@google.com> Acked-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-06-07mm: vmalloc: pass proper vm_start into debugobjectsChintan Pandya
Client can call vunmap with some intermediate 'addr' which may not be the start of the VM area. Entire unmap code works with vm->vm_start which is proper but debug object API is called with 'addr'. This could be a problem within debug objects. Pass proper start address into debug object API. [akpm@linux-foundation.org: fix warning] Link: http://lkml.kernel.org/r/1523961828-9485-3-git-send-email-cpandya@codeaurora.org Signed-off-by: Chintan Pandya <cpandya@codeaurora.org> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org> Cc: Byungchul Park <byungchul.park@lge.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Florian Fainelli <f.fainelli@gmail.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Laura Abbott <labbott@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Wei Yang <richard.weiyang@gmail.com> Cc: Yisheng Xie <xieyisheng1@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-06-07mm: vmalloc: avoid racy handling of debugobjects in vunmapChintan Pandya
Currently, __vunmap flow is, 1) Release the VM area 2) Free the debug objects corresponding to that vm area. This leave some race window open. 1) Release the VM area 1.5) Some other client gets the same vm area 1.6) This client allocates new debug objects on the same vm area 2) Free the debug objects corresponding to this vm area. Here, we actually free 'other' client's debug objects. Fix this by freeing the debug objects first and then releasing the VM area. Link: http://lkml.kernel.org/r/1523961828-9485-2-git-send-email-cpandya@codeaurora.org Signed-off-by: Chintan Pandya <cpandya@codeaurora.org> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org> Cc: Byungchul Park <byungchul.park@lge.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Florian Fainelli <f.fainelli@gmail.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Laura Abbott <labbott@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Wei Yang <richard.weiyang@gmail.com> Cc: Yisheng Xie <xieyisheng1@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-06-07mm: vmalloc: clean up vunmap to avoid pgtable ops twiceChintan Pandya
vunmap does page table clear operations twice in the case when DEBUG_PAGEALLOC_ENABLE_DEFAULT is enabled. So, clean up the code as that is unintended. As a perf gain, we save few us. Below ftrace data was obtained while doing 1 MB of vmalloc/vfree on ARM64 based SoC *without* this patch applied. After this patch, we can save ~3 us (on 1 extra vunmap_page_range). CPU DURATION FUNCTION CALLS | | | | | | | 6) | __vunmap() { 6) | vmap_debug_free_range() { 6) 3.281 us | vunmap_page_range(); 6) + 45.468 us | } 6) 2.760 us | vunmap_page_range(); 6) ! 505.105 us | } [cpandya@codeaurora.org: v3] Link: http://lkml.kernel.org/r/1525176960-18408-1-git-send-email-cpandya@codeaurora.org Link: http://lkml.kernel.org/r/1523876342-10545-1-git-send-email-cpandya@codeaurora.org Signed-off-by: Chintan Pandya <cpandya@codeaurora.org> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Laura Abbott <labbott@redhat.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Florian Fainelli <f.fainelli@gmail.com> Cc: Yisheng Xie <xieyisheng1@huawei.com> Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org> Cc: Wei Yang <richard.weiyang@gmail.com> Cc: Byungchul Park <byungchul.park@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-05-16proc: introduce proc_create_seq_privateChristoph Hellwig
Variant of proc_create_data that directly take a struct seq_operations argument + a private state size and drastically reduces the boilerplate code in the callers. All trivial callers converted over. Signed-off-by: Christoph Hellwig <hch@lst.de>
2018-05-16proc: introduce proc_create_seq{,_data}Christoph Hellwig
Variants of proc_create{,_data} that directly take a struct seq_operations argument and drastically reduces the boilerplate code in the callers. All trivial callers converted over. Signed-off-by: Christoph Hellwig <hch@lst.de>
