path: root/mm
2015-02-11memcg, shmem: fix shmem migration to use lrucareMichal Hocko
commit f5e03a4989e80a86f8b514659dca8539132e6e09 upstream. It has been reported that 965GM might trigger VM_BUG_ON_PAGE(!lrucare && PageLRU(oldpage), oldpage) in mem_cgroup_migrate when shmem wants to replace a swap cache page because of shmem_should_replace_page (the page is allocated from an inappropriate zone). shmem_replace_page expects that the oldpage is not on LRU list and calls mem_cgroup_migrate without lrucare. This is obviously incorrect because swapcache pages might be on the LRU list (e.g. swapin readahead page). Fix this by enabling lrucare for the migration in shmem_replace_page. Also clarify that lrucare should be used even if one of the pages might be on LRU list. The BUG_ON will trigger only when CONFIG_DEBUG_VM is enabled but even without that the migration code might leave the old page on an inappropriate memcg' LRU which is not that critical because the page would get removed with its last reference but it is still confusing. Fixes: 0a31bc97c80c ("mm: memcontrol: rewrite uncharge API") Signed-off-by: Michal Hocko <mhocko@suse.cz> Reported-by: Chris Wilson <chris@chris-wilson.co.uk> Reported-by: Dave Airlie <airlied@gmail.com> Acked-by: Hugh Dickins <hughd@google.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-02-11mm: pagewalk: call pte_hole() for VM_PFNMAP during walk_page_rangeShiraz Hashim
commit 23aaed6659df9adfabe9c583e67a36b54e21df46 upstream. walk_page_range() silently skips vma having VM_PFNMAP set, which leads to undesirable behaviour at client end (who called walk_page_range). Userspace applications get the wrong data, so the effect is like just confusing users (if the applications just display the data) or sometimes killing the processes (if the applications do something with misunderstanding virtual addresses due to the wrong data.) For example for pagemap_read, when no callbacks are called against VM_PFNMAP vma, pagemap_read may prepare pagemap data for next virtual address range at wrong index. Eventually userspace may get wrong pagemap data for a task. Corresponding to a VM_PFNMAP marked vma region, kernel may report mappings from subsequent vma regions. User space in turn may account more pages (than really are) to the task. In my case I was using procmem, procrack (Android utility) which uses pagemap interface to account RSS pages of a task. Due to this bug it was giving a wrong picture for vmas (with VM_PFNMAP set). Fixes: a9ff785e4437 ("mm/pagewalk.c: walk_page_range should avoid VM_PFNMAP areas") Signed-off-by: Shiraz Hashim <shashim@codeaurora.org> Acked-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-02-05memcg: remove extra newlines from memcg oom kill logGreg Thelen
commit 0346dadbf041a2606bcb5bd27828b0d105897f4a upstream. Commit e61734c55c24 ("cgroup: remove cgroup->name") added two extra newlines to memcg oom kill log messages. This makes dmesg hard to read and parse. The issue affects 3.15+. Example: Task in /t <<< extra #1 killed as a result of limit of /t <<< extra #2 memory: usage 102400kB, limit 102400kB, failcnt 274712 Remove the extra newlines from memcg oom kill messages, so the messages look like: Task in /t killed as a result of limit of /t memory: usage 102400kB, limit 102400kB, failcnt 240649 Fixes: e61734c55c24 ("cgroup: remove cgroup->name") Signed-off-by: Greg Thelen <gthelen@google.com> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-02-05vm: make stack guard page errors return VM_FAULT_SIGSEGV rather than SIGBUSLinus Torvalds
commit 9c145c56d0c8a0b62e48c8d71e055ad0fb2012ba upstream. The stack guard page error case has long incorrectly caused a SIGBUS rather than a SIGSEGV, but nobody actually noticed until commit fee7e49d4514 ("mm: propagate error from stack expansion even for guard page") because that error case was never actually triggered in any normal situations. Now that we actually report the error, people noticed the wrong signal that resulted. So far, only the test suite of libsigsegv seems to have actually cared, but there are real applications that use libsigsegv, so let's not wait for any of those to break. Reported-and-tested-by: Takashi Iwai <tiwai@suse.de> Tested-by: Jan Engelhardt <jengelh@inai.de> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> # "s390 still compiles and boots" Cc: linux-arch@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-02-05vm: add VM_FAULT_SIGSEGV handling supportLinus Torvalds
commit 33692f27597fcab536d7cbbcc8f52905133e4aa7 upstream. The core VM already knows about VM_FAULT_SIGBUS, but cannot return a "you should SIGSEGV" error, because the SIGSEGV case was generally handled by the caller - usually the architecture fault handler. That results in lots of duplication - all the architecture fault handlers end up doing very similar "look up vma, check permissions, do retries etc" - but it generally works. However, there are cases where the VM actually wants to SIGSEGV, and applications _expect_ SIGSEGV. In particular, when accessing the stack guard page, libsigsegv expects a SIGSEGV. And it usually got one, because the stack growth is handled by that duplicated architecture fault handler. However, when the generic VM layer started propagating the error return from the stack expansion in commit fee7e49d4514 ("mm: propagate error from stack expansion even for guard page"), that now exposed the existing VM_FAULT_SIGBUS result to user space. And user space really expected SIGSEGV, not SIGBUS. To fix that case, we need to add a VM_FAULT_SIGSEGV, and teach all those duplicate architecture fault handlers about it. They all already have the code to handle SIGSEGV, so it's about just tying that new return value to the existing code, but it's all a bit annoying. This is the mindless minimal patch to do this. A more extensive patch would be to try to gather up the mostly shared fault handling logic into one generic helper routine, and long-term we really should do that cleanup. Just from this patch, you can generally see that most architectures just copied (directly or indirectly) the old x86 way of doing things, but in the meantime that original x86 model has been improved to hold the VM semaphore for shorter times etc and to handle VM_FAULT_RETRY and other "newer" things, so it would be a good idea to bring all those improvements to the generic case and teach other architectures about them too. Reported-and-tested-by: Takashi Iwai <tiwai@suse.de> Tested-by: Jan Engelhardt <jengelh@inai.de> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> # "s390 still compiles and boots" Cc: linux-arch@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-29mm: get rid of radix tree gfp mask for pagecache_get_pageMichal Hocko
commit 45f87de57f8fad59302fd263dd81ffa4843b5b24 upstream. Commit 2457aec63745 ("mm: non-atomically mark page accessed during page cache allocation where possible") has added a separate parameter for specifying gfp mask for radix tree allocations. Not only this is less than optimal from the API point of view because it is error prone, it is also buggy currently because grab_cache_page_write_begin is using GFP_KERNEL for radix tree and if fgp_flags doesn't contain FGP_NOFS (mostly controlled by fs by AOP_FLAG_NOFS flag) but the mapping_gfp_mask has __GFP_FS cleared then the radix tree allocation wouldn't obey the restriction and might recurse into filesystem and cause deadlocks. This is the case for most filesystems unfortunately because only ext4 and gfs2 are using AOP_FLAG_NOFS. Let's simply remove radix_gfp_mask parameter because the allocation context is same for both page cache and for the radix tree. Just make sure that the radix tree gets only the sane subset of the mask (e.g. do not pass __GFP_WRITE). Long term it is more preferable to convert remaining users of AOP_FLAG_NOFS to use mapping_gfp_mask instead and simplify this interface even further. Reported-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-16mm: Don't count the stack guard page towards RLIMIT_STACKLinus Torvalds
commit 690eac53daff34169a4d74fc7bfbd388c4896abb upstream. Commit fee7e49d4514 ("mm: propagate error from stack expansion even for guard page") made sure that we return the error properly for stack growth conditions. It also theorized that counting the guard page towards the stack limit might break something, but also said "Let's see if anybody notices". Somebody did notice. Apparently android-x86 sets the stack limit very close to the limit indeed, and including the guard page in the rlimit check causes the android 'zygote' process problems. So this adds the (fairly trivial) code to make the stack rlimit check be against the actual real stack size, rather than the size of the vma that includes the guard page. Reported-and-tested-by: Chih-Wei Huang <cwhuang@android-x86.org> Cc: Jay Foad <jay.foad@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-16mm: propagate error from stack expansion even for guard pageLinus Torvalds
commit fee7e49d45149fba60156f5b59014f764d3e3728 upstream. Jay Foad reports that the address sanitizer test (asan) sometimes gets confused by a stack pointer that ends up being outside the stack vma that is reported by /proc/maps. This happens due to an interaction between RLIMIT_STACK and the guard page: when we do the guard page check, we ignore the potential error from the stack expansion, which effectively results in a missing guard page, since the expected stack expansion won't have been done. And since /proc/maps explicitly ignores the guard page (commit d7824370e263: "mm: fix up some user-visible effects of the stack guard page"), the stack pointer ends up being outside the reported stack area. This is the minimal patch: it just propagates the error. It also effectively makes the guard page part of the stack limit, which in turn measn that the actual real stack is one page less than the stack limit. Let's see if anybody notices. We could teach acct_stack_growth() to allow an extra page for a grow-up/grow-down stack in the rlimit test, but I don't want to add more complexity if it isn't needed. Reported-and-tested-by: Jay Foad <jay.foad@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-16mm, vmscan: prevent kswapd livelock due to pfmemalloc-throttled process ↵Vlastimil Babka
being killed commit 9e5e3661727eaf960d3480213f8e87c8d67b6956 upstream. Charles Shirron and Paul Cassella from Cray Inc have reported kswapd stuck in a busy loop with nothing left to balance, but kswapd_try_to_sleep() failing to sleep. Their analysis found the cause to be a combination of several factors: 1. A process is waiting in throttle_direct_reclaim() on pgdat->pfmemalloc_wait 2. The process has been killed (by OOM in this case), but has not yet been scheduled to remove itself from the waitqueue and die. 3. kswapd checks for throttled processes in prepare_kswapd_sleep(): if (waitqueue_active(&pgdat->pfmemalloc_wait)) { wake_up(&pgdat->pfmemalloc_wait); return false; // kswapd will not go to sleep } However, for a process that was already killed, wake_up() does not remove the process from the waitqueue, since try_to_wake_up() checks its state first and returns false when the process is no longer waiting. 4. kswapd is running on the same CPU as the only CPU that the process is allowed to run on (through cpus_allowed, or possibly single-cpu system). 5. CONFIG_PREEMPT_NONE=y kernel is used. If there's nothing to balance, kswapd encounters no voluntary preemption points and repeatedly fails prepare_kswapd_sleep(), blocking the process from running and removing itself from the waitqueue, which would let kswapd sleep. So, the source of the problem is that we prevent kswapd from going to sleep until there are processes waiting on the pfmemalloc_wait queue, and a process waiting on a queue is guaranteed to be removed from the queue only when it gets scheduled. This was done to make sure that no process is left sleeping on pfmemalloc_wait when kswapd itself goes to sleep. However, it isn't necessary to postpone kswapd sleep until the pfmemalloc_wait queue actually empties. To prevent processes from being left sleeping, it's actually enough to guarantee that all processes waiting on pfmemalloc_wait queue have been woken up by the time we put kswapd to sleep. This patch therefore fixes this issue by substituting 'wake_up' with 'wake_up_all' and removing 'return false' in the code snippet from prepare_kswapd_sleep() above. Note that if any process puts itself in the queue after this waitqueue_active() check, or after the wake up itself, it means that the process will also wake up kswapd - and since we are under prepare_to_wait(), the wake up won't be missed. Also we update the comment prepare_kswapd_sleep() to hopefully more clearly describe the races it is preventing. Fixes: 5515061d22f0 ("mm: throttle direct reclaimers if PF_MEMALLOC reserves are low and swap is backed by network storage") Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Vladimir Davydov <vdavydov@parallels.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-16mm: protect set_page_dirty() from ongoing truncationJohannes Weiner
commit 2d6d7f98284648c5ed113fe22a132148950b140f upstream. Tejun, while reviewing the code, spotted the following race condition between the dirtying and truncation of a page: __set_page_dirty_nobuffers() __delete_from_page_cache() if (TestSetPageDirty(page)) page->mapping = NULL if (PageDirty()) dec_zone_page_state(page, NR_FILE_DIRTY); dec_bdi_stat(mapping->backing_dev_info, BDI_RECLAIMABLE); if (page->mapping) account_page_dirtied(page) __inc_zone_page_state(page, NR_FILE_DIRTY); __inc_bdi_stat(mapping->backing_dev_info, BDI_RECLAIMABLE); which results in an imbalance of NR_FILE_DIRTY and BDI_RECLAIMABLE. Dirtiers usually lock out truncation, either by holding the page lock directly, or in case of zap_pte_range(), by pinning the mapcount with the page table lock held. The notable exception to this rule, though, is do_wp_page(), for which this race exists. However, do_wp_page() already waits for a locked page to unlock before setting the dirty bit, in order to prevent a race where clear_page_dirty() misses the page bit in the presence of dirty ptes. Upgrade that wait to a fully locked set_page_dirty() to also cover the situation explained above. Afterwards, the code in set_page_dirty() dealing with a truncation race is no longer needed. Remove it. Reported-by: Tejun Heo <tj@kernel.org> Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-08mm/CMA: fix boot regression due to physical address of high_memoryJoonsoo Kim
commit 6b101e2a3ce4d2a0312087598bd1ab4a1db2ac40 upstream. high_memory isn't direct mapped memory so retrieving it's physical address isn't appropriate. But, it would be useful to check physical address of highmem boundary so it's justfiable to get physical address from it. In x86, there is a validation check if CONFIG_DEBUG_VIRTUAL and it triggers following boot failure reported by Ingo. ... BUG: Int 6: CR2 00f06f53 ... Call Trace: dump_stack+0x41/0x52 early_idt_handler+0x6b/0x6b cma_declare_contiguous+0x33/0x212 dma_contiguous_reserve_area+0x31/0x4e dma_contiguous_reserve+0x11d/0x125 setup_arch+0x7b5/0xb63 start_kernel+0xb8/0x3e6 i386_start_kernel+0x79/0x7d To fix boot regression, this patch implements workaround to avoid validation check in x86 when retrieving physical address of high_memory. __pa_nodebug() used by this patch is implemented only in x86 so there is no choice but to use dirty #ifdef. [akpm@linux-foundation.org: tweak comment] Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Reported-by: Ingo Molnar <mingo@kernel.org> Tested-by: Ingo Molnar <mingo@kernel.org> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-12-03slab: fix nodeid bounds check for non-contiguous node IDsPaul Mackerras
The bounds check for nodeid in ____cache_alloc_node gives false positives on machines where the node IDs are not contiguous, leading to a panic at boot time. For example, on a POWER8 machine the node IDs are typically 0, 1, 16 and 17. This means that num_online_nodes() returns 4, so when ____cache_alloc_node is called with nodeid = 16 the VM_BUG_ON triggers, like this: kernel BUG at /home/paulus/kernel/kvm/mm/slab.c:3079! Call Trace: .____cache_alloc_node+0x5c/0x270 (unreliable) .kmem_cache_alloc_node_trace+0xdc/0x360 .init_list+0x3c/0x128 .kmem_cache_init+0x1dc/0x258 .start_kernel+0x2a0/0x568 start_here_common+0x20/0xa8 To fix this, we instead compare the nodeid with MAX_NUMNODES, and additionally make sure it isn't negative (since nodeid is an int). The check is there mainly to protect the array dereference in the get_node() call in the next line, and the array being dereferenced is of size MAX_NUMNODES. If the nodeid is in range but invalid (for example if the node is off-line), the BUG_ON in the next line will catch that. Fixes: 14e50c6a9bc2 ("mm: slab: Verify the nodeid passed to ____cache_alloc_node") Signed-off-by: Paul Mackerras <paulus@samba.org> Reviewed-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Reviewed-by: Pekka Enberg <penberg@kernel.org> Acked-by: David Rientjes <rientjes@google.com> Cc: Christoph Lameter <cl@linux.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-03mm: fix anon_vma_clone() error treatmentDaniel Forrest
Andrew Morton noticed that the error return from anon_vma_clone() was being dropped and replaced with -ENOMEM (which is not itself a bug because the only error return value from anon_vma_clone() is -ENOMEM). I did an audit of callers of anon_vma_clone() and discovered an actual bug where the error return was being lost. In __split_vma(), between Linux 3.11 and 3.12 the code was changed so the err variable is used before the call to anon_vma_clone() and the default initial value of -ENOMEM is overwritten. So a failure of anon_vma_clone() will return success since err at this point is now zero. Below is a patch which fixes this bug and also propagates the error return value from anon_vma_clone() in all cases. Fixes: ef0855d334e1 ("mm: mempolicy: turn vma_set_policy() into vma_dup_policy()") Signed-off-by: Daniel Forrest <dan.forrest@ssec.wisc.edu> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Tim Hartrick <tim@edgecast.com> Cc: Hugh Dickins <hughd@google.com> Cc: Michel Lespinasse <walken@google.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: <stable@vger.kernel.org> [3.12+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-03mm: fix swapoff hang after page migration and forkHugh Dickins
I've been seeing swapoff hangs in recent testing: it's cycling around trying unsuccessfully to find an mm for some remaining pages of swap. I have been exercising swap and page migration more heavily recently, and now notice a long-standing error in copy_one_pte(): it's trying to add dst_mm to swapoff's mmlist when it finds a swap entry, but is doing so even when it's a migration entry or an hwpoison entry. Which wouldn't matter much, except it adds dst_mm next to src_mm, assuming src_mm is already on the mmlist: which may not be so. Then if pages are later swapped out from dst_mm, swapoff won't be able to find where to replace them. There's already a !non_swap_entry() test for stats: move that up before the swap_duplicate() and the addition to mmlist. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Kelley Nielsen <kelleynnn@gmail.com> Cc: <stable@vger.kernel.org> [2.6.18+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-02mm/vmpressure.c: fix race in vmpressure_work_fn()Andrew Morton
In some android devices, there will be a "divide by zero" exception. vmpr->scanned could be zero before spin_lock(&vmpr->sr_lock). Addresses https://bugzilla.kernel.org/show_bug.cgi?id=88051 [akpm@linux-foundation.org: neaten] Reported-by: ji_ang <ji_ang@163.com> Cc: Anton Vorontsov <anton.vorontsov@linaro.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-02mm: frontswap: invalidate expired data on a dup-store failureWeijie Yang
If a frontswap dup-store failed, it should invalidate the expired page in the backend, or it could trigger some data corruption issue. Such as: 1. use zswap as the frontswap backend with writeback feature 2. store a swap page(version_1) to entry A, success 3. dup-store a newer page(version_2) to the same entry A, fail 4. use __swap_writepage() write version_2 page to swapfile, success 5. zswap do shrink, writeback version_1 page to swapfile 6. version_2 page is overwrited by version_1, data corrupt. This patch fixes this issue by invalidating expired data immediately when meet a dup-store failure. Signed-off-by: Weijie Yang <weijie.yang@samsung.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Seth Jennings <sjennings@variantweb.net> Cc: Dan Streetman <ddstreet@ieee.org> Cc: Minchan Kim <minchan@kernel.org> Cc: Bob Liu <bob.liu@oracle.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs fix from Al Viro: "Fix for a really embarrassing braino in iov_iter. Kudos to paulus..." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: Fix thinko in iov_iter_single_seg_count
2014-11-13mem-hotplug: reset node present pages when hot-adding a new pgdatTang Chen
When memory is hot-added, all the memory is in offline state. So clear all zones' present_pages because they will be updated in online_pages() and offline_pages(). Otherwise, /proc/zoneinfo will corrupt: When the memory of node2 is offline: # cat /proc/zoneinfo ...... Node 2, zone Movable ...... spanned 8388608 present 8388608 managed 0 When we online memory on node2: # cat /proc/zoneinfo ...... Node 2, zone Movable ...... spanned 8388608 present 16777216 managed 8388608 Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com> Reviewed-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: <stable@vger.kernel.org> [3.16+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-13mem-hotplug: reset node managed pages when hot-adding a new pgdatTang Chen
In free_area_init_core(), zone->managed_pages is set to an approximate value for lowmem, and will be adjusted when the bootmem allocator frees pages into the buddy system. But free_area_init_core() is also called by hotadd_new_pgdat() when hot-adding memory. As a result, zone->managed_pages of the newly added node's pgdat is set to an approximate value in the very beginning. Even if the memory on that node has node been onlined, /sys/device/system/node/nodeXXX/meminfo has wrong value: hot-add node2 (memory not onlined) cat /sys/device/system/node/node2/meminfo Node 2 MemTotal: 33554432 kB Node 2 MemFree: 0 kB Node 2 MemUsed: 33554432 kB Node 2 Active: 0 kB This patch fixes this problem by reset node managed pages to 0 after hot-adding a new node. 1. Move reset_managed_pages_done from reset_node_managed_pages() to reset_all_zones_managed_pages() 2. Make reset_node_managed_pages() non-static 3. Call reset_node_managed_pages() in hotadd_new_pgdat() after pgdat is initialized Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com> Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: <stable@vger.kernel.org> [3.16+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-13mm/debug-pagealloc: correct freepage accounting and order resettingJoonsoo Kim
One thing I did in this patch is fixing freepage accounting. If we clear guard page and link it onto isolate buddy list, we should not increase freepage count. This patch adds conditional branch to skip counting in this case. Without this patch, this overcounting happens frequently if guard order is set and CMA is used. Another thing fixed in this patch is the target to reset order. In __free_one_page(), we check the buddy page whether it is a guard page or not. And, if so, we should clear guard attribute on the buddy page and reset order of it to 0. But, current code resets original page's order rather than buddy one's. Maybe, this doesn't have any problem, because whole merged page's order will be re-assigned soon. But, it is better to correct code. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Gioh Kim <gioh.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-13mm, compaction: prevent infinite loop in compact_zoneVlastimil Babka
Several people have reported occasionally seeing processes stuck in compact_zone(), even triggering soft lockups, in 3.18-rc2+. Testing a revert of commit e14c720efdd7 ("mm, compaction: remember position within pageblock in free pages scanner") fixed the issue, although the stuck processes do not appear to involve the free scanner. Finally, by code inspection, the bug was found in isolate_migratepages() which uses a slightly different condition to detect if the migration and free scanners have met, than compact_finished(). That has not been a problem until commit e14c720efdd7 allowed the free scanner position between individual invocations to be in the middle of a pageblock. In a relatively rare case, the migration scanner position can end up at the beginning of a pageblock, with the free scanner position in the middle of the same pageblock. If it's the migration scanner's turn, isolate_migratepages() exits immediately (without updating the position), while compact_finished() decides to continue compaction, resulting in a potentially infinite loop. The system can recover only if another process creates enough high-order pages to make the watermark checks in compact_finished() pass. This patch fixes the immediate problem by bumping the migration scanner's position to meet the free scanner in isolate_migratepages(), when both are within the same pageblock. This causes compact_finished() to terminate properly. A more robust check in compact_finished() is planned as a cleanup for better future maintainability. Fixes: e14c720efdd73 ("mm, compaction: remember position within pageblock in free pages scanner) Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Reported-by: P. Christeas <xrg@linux.gr> Tested-by: P. Christeas <xrg@linux.gr> Link: http://marc.info/?l=linux-mm&m=141508604232522&w=2 Reported-by: Norbert Preining <preining@logic.at> Tested-by: Norbert Preining <preining@logic.at> Link: https://lkml.org/lkml/2014/11/4/904 Reported-by: Pavel Machek <pavel@ucw.cz> Link: https://lkml.org/lkml/2014/11/7/164 Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-13mm: alloc_contig_range: demote pages busy message from warn to infoMichal Nazarewicz
Having test_pages_isolated failure message as a warning confuses users into thinking that it is more serious than it really is. In reality, if called via CMA, allocation will be retried so a single test_pages_isolated failure does not prevent allocation from succeeding. Demote the warning message to an info message and reformat it such that the text "failed" does not appear and instead a less worrying "PFNS busy" is used. This message is trivially reproducible on a 10GB x86 machine on 3.16.y kernels configured with CONFIG_DMA_CMA. Signed-off-by: Michal Nazarewicz <mina86@mina86.com> Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Cc: Peter Hurley <peter@hurleysoftware.com> Cc: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-13mm/slab: fix unalignment problem on Malta with EVA due to slab mergeJoonsoo Kim
Unlike SLUB, sometimes, object isn't started at the beginning of the slab in SLAB. This causes the unalignment problem after slab merging is supported by commit 12220dea07f1 ("mm/slab: support slab merge"). Following is the report from Markos that fail to boot on Malta with EVA. Calibrating delay loop... 19.86 BogoMIPS (lpj=99328) pid_max: default: 32768 minimum: 301 Mount-cache hash table entries: 4096 (order: 0, 16384 bytes) Mountpoint-cache hash table entries: 4096 (order: 0, 16384 bytes) Kernel bug detected[#1]: CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.17.0-05639-g12220dea07f1 #1631 task: 1f04f5d8 ti: 1f050000 task.ti: 1f050000 epc : 80141190 alloc_unbound_pwq+0x234/0x304 Not tainted ra : 80141184 alloc_unbound_pwq+0x228/0x304 Process swapper/0 (pid: 1, threadinfo=1f050000, task=1f04f5d8, tls=00000000) Call Trace: alloc_unbound_pwq+0x234/0x304 apply_workqueue_attrs+0x11c/0x294 __alloc_workqueue_key+0x23c/0x470 init_workqueues+0x320/0x400 do_one_initcall+0xe8/0x23c kernel_init_freeable+0x9c/0x224 kernel_init+0x10/0x100 ret_from_kernel_thread+0x14/0x1c [ end trace cb88537fdc8fa200 ] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b alloc_unbound_pwq() allocates slab object from pool_workqueue. This kmem_cache requires 256 bytes alignment, but, current merging code doesn't honor that, and merge it with kmalloc-256. kmalloc-256 requires only cacheline size alignment so that above failure occurs. However, in x86, kmalloc-256 is luckily aligned in 256 bytes, so the problem didn't happen on it. To fix this problem, this patch introduces alignment mismatch check in find_mergeable(). This will fix the problem. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Reported-by: Markos Chandras <Markos.Chandras@imgtec.com> Tested-by: Markos Chandras <Markos.Chandras@imgtec.com> Acked-by: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-13mm/page_alloc: restrict max order of merging on isolated pageblockJoonsoo Kim
Current pageblock isolation logic could isolate each pageblock individually. This causes freepage accounting problem if freepage with pageblock order on isolate pageblock is merged with other freepage on normal pageblock. We can prevent merging by restricting max order of merging to pageblock order if freepage is on isolate pageblock. A side-effect of this change is that there could be non-merged buddy freepage even if finishing pageblock isolation, because undoing pageblock isolation is just to move freepage from isolate buddy list to normal buddy list rather than to consider merging. So, the patch also makes undoing pageblock isolation consider freepage merge. When un-isolation, freepage with more than pageblock order and it's buddy are checked. If they are on normal pageblock, instead of just moving, we isolate the freepage and free it in order to get merged. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Cc: Mel Gorman <mgorman@suse.de> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Minchan Kim <minchan@kernel.org> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Cc: Tang Chen <tangchen@cn.fujitsu.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Cc: Wen Congyang <wency@cn.fujitsu.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Michal Nazarewicz <mina86@mina86.com> Cc: Laura Abbott <lauraa@codeaurora.org> Cc: Heesub Shin <heesub.shin@samsung.com> Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com> Cc: Ritesh Harjani <ritesh.list@gmail.com> Cc: Gioh Kim <gioh.kim@lge.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-13mm/page_alloc: move freepage counting logic to __free_one_page()Joonsoo Kim
All the caller of __free_one_page() has similar freepage counting logic, so we can move it to __free_one_page(). This reduce line of code and help future maintenance. This is also preparation step for "mm/page_alloc: restrict max order of merging on isolated pageblock" which fix the freepage counting problem on freepage with more than pageblock order. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Cc: Mel Gorman <mgorman@suse.de> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Minchan Kim <minchan@kernel.org> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Cc: Tang Chen <tangchen@cn.fujitsu.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Cc: Wen Congyang <wency@cn.fujitsu.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Michal Nazarewicz <mina86@mina86.com> Cc: Laura Abbott <lauraa@codeaurora.org> Cc: Heesub Shin <heesub.shin@samsung.com> Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com> Cc: Ritesh Harjani <ritesh.list@gmail.com> Cc: Gioh Kim <gioh.kim@lge.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-13mm/page_alloc: add freepage on isolate pageblock to correct buddy listJoonsoo Kim
In free_pcppages_bulk(), we use cached migratetype of freepage to determine type of buddy list where freepage will be added. This information is stored when freepage is added to pcp list, so if isolation of pageblock of this freepage begins after storing, this cached information could be stale. In other words, it has original migratetype rather than MIGRATE_ISOLATE. There are two problems caused by this stale information. One is that we can't keep these freepages from being allocated. Although this pageblock is isolated, freepage will be added to normal buddy list so that it could be allocated without any restriction. And the other problem is incorrect freepage accounting. Freepages on isolate pageblock should not be counted for number of freepage. Following is the code snippet in free_pcppages_bulk(). /* MIGRATE_MOVABLE list may include MIGRATE_RESERVEs */ __free_one_page(page, page_to_pfn(page), zone, 0, mt); trace_mm_page_pcpu_drain(page, 0, mt); if (likely(!is_migrate_isolate_page(page))) { __mod_zone_page_state(zone, NR_FREE_PAGES, 1); if (is_migrate_cma(mt)) __mod_zone_page_state(zone, NR_FREE_CMA_PAGES, 1); } As you can see above snippet, current code already handle second problem, incorrect freepage accounting, by re-fetching pageblock migratetype through is_migrate_isolate_page(page). But, because this re-fetched information isn't used for __free_one_page(), first problem would not be solved. This patch try to solve this situation to re-fetch pageblock migratetype before __free_one_page() and to use it for __free_one_page(). In addition to move up position of this re-fetch, this patch use optimization technique, re-fetching migratetype only if there is isolate pageblock. Pageblock isolation is rare event, so we can avoid re-fetching in common case with this optimization. This patch also correct migratetype of the tracepoint output. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Minchan Kim <minchan@kernel.org> Acked-by: Michal Nazarewicz <mina86@mina86.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Cc: Mel Gorman <mgorman@suse.de> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Cc: Tang Chen <tangchen@cn.fujitsu.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Cc: Wen Congyang <wency@cn.fujitsu.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Laura Abbott <lauraa@codeaurora.org> Cc: Heesub Shin <heesub.shin@samsung.com> Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com> Cc: Ritesh Harjani <ritesh.list@gmail.com> Cc: Gioh Kim <gioh.kim@lge.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-13mm/page_alloc: fix incorrect isolation behavior by rechecking migratetypeJoonsoo Kim
Before describing bugs itself, I first explain definition of freepage. 1. pages on buddy list are counted as freepage. 2. pages on isolate migratetype buddy list are *not* counted as freepage. 3. pages on cma buddy list are counted as CMA freepage, too. Now, I describe problems and related patch. Patch 1: There is race conditions on getting pageblock migratetype that it results in misplacement of freepages on buddy list, incorrect freepage count and un-availability of freepage. Patch 2: Freepages on pcp list could have stale cached information to determine migratetype of buddy list to go. This causes misplacement of freepages on buddy list and incorrect freepage count. Patch 4: Merging between freepages on different migratetype of pageblocks will cause freepages accouting problem. This patch fixes it. Without patchset [3], above problem doesn't happens on my CMA allocation test, because CMA reserved pages aren't used at all. So there is no chance for above race. With patchset [3], I did simple CMA allocation test and get below result: - Virtual machine, 4 cpus, 1024 MB memory, 256 MB CMA reservation - run kernel build (make -j16) on background - 30 times CMA allocation(8MB * 30 = 240MB) attempts in 5 sec interval - Result: more than 5000 freepage count are missed With patchset [3] and this patchset, I found that no freepage count are missed so that I conclude that problems are solved. On my simple memory offlining test, these problems also occur on that environment, too. This patch (of 4): There are two paths to reach core free function of buddy allocator, __free_one_page(), one is free_one_page()->__free_one_page() and the other is free_hot_cold_page()->free_pcppages_bulk()->__free_one_page(). Each paths has race condition causing serious problems. At first, this patch is focused on first type of freepath. And then, following patch will solve the problem in second type of freepath. In the first type of freepath, we got migratetype of freeing page without holding the zone lock, so it could be racy. There are two cases of this race. 1. pages are added to isolate buddy list after restoring orignal migratetype CPU1 CPU2 get migratetype => return MIGRATE_ISOLATE call free_one_page() with MIGRATE_ISOLATE grab the zone lock unisolate pageblock release the zone lock grab the zone lock call __free_one_page() with MIGRATE_ISOLATE freepage go into isolate buddy list, although pageblock is already unisolated This may cause two problems. One is that we can't use this page anymore until next isolation attempt of this pageblock, because freepage is on isolate buddy list. The other is that freepage accouting could be wrong due to merging between different buddy list. Freepages on isolate buddy list aren't counted as freepage, but ones on normal buddy list are counted as freepage. If merge happens, buddy freepage on normal buddy list is inevitably moved to isolate buddy list without any consideration of freepage accouting so it could be incorrect. 2. pages are added to normal buddy list while pageblock is isolated. It is similar with above case. This also may cause two problems. One is that we can't keep these freepages from being allocated. Although this pageblock is isolated, freepage would be added to normal buddy list so that it could be allocated without any restriction. And the other problem is same as case 1, that it, incorrect freepage accouting. This race condition would be prevented by checking migratetype again with holding the zone lock. Because it is somewhat heavy operation and it isn't needed in common case, we want to avoid rechecking as much as possible. So this patch introduce new variable, nr_isolate_pageblock in struct zone to check if there is isolated pageblock. With this, we can avoid to re-check migratetype in common case and do it only if there is isolated pageblock or migratetype is MIGRATE_ISOLATE. This solve above mentioned problems. Changes from v3: Add one more check in free_one_page() that checks whether migratetype is MIGRATE_ISOLATE or not. Without this, abovementioned case 1 could happens. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Minchan Kim <minchan@kernel.org> Acked-by: Michal Nazarewicz <mina86@mina86.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Cc: Mel Gorman <mgorman@suse.de> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Cc: Tang Chen <tangchen@cn.fujitsu.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Cc: Wen Congyang <wency@cn.fujitsu.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Laura Abbott <lauraa@codeaurora.org> Cc: Heesub Shin <heesub.shin@samsung.com> Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com> Cc: Ritesh Harjani <ritesh.list@gmail.com> Cc: Gioh Kim <gioh.kim@lge.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-13mm/compaction: skip the range until proper target pageblock is metJoonsoo Kim
Commit 7d49d8868336 ("mm, compaction: reduce zone checking frequency in the migration scanner") has a side-effect that changes the iteration range calculation. Before the change, block_end_pfn is calculated using start_pfn, but now it blindly adds pageblock_nr_pages to the previous value. This causes the problem that isolation_start_pfn is larger than block_end_pfn when we isolate the page with more than pageblock order. In this case, isolation would fail due to an invalid range parameter. To prevent this, this patch implements skipping the range until a proper target pageblock is met. Without this patch, CMA with more than pageblock order always fails but with this patch it will succeed. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Minchan Kim <minchan@kernel.org> Cc: Michal Nazarewicz <mina86@mina86.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-13Fix thinko in iov_iter_single_seg_countPaul Mackerras
The branches of the if (i->type & ITER_BVEC) statement in iov_iter_single_seg_count() are the wrong way around; if ITER_BVEC is clear then we use i->bvec, when we should be using i->iov. This fixes it. In my case, the symptom that this caused was that a KVM guest doing filesystem operations on a virtual disk would result in one of qemu's threads on the host going into an infinite loop in generic_perform_write(). The loop would hit the copied == 0 case and call iov_iter_single_seg_count() to reduce the number of bytes to try to process, but because of the error, iov_iter_single_seg_count() would just return i->count and the loop made no progress and continued forever. Cc: stable@vger.kernel.org # 3.16+ Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-11-07Merge tag 'xfs-for-linus-3.18-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dgc/linux-xfs Pull xfs fixes from Dave Chinner: "This update fixes a warning in the new pagecache_isize_extended() and updates some related comments, another fix for zero-range misbehaviour, and an unforntuately large set of fixes for regressions in the bulkstat code. The bulkstat fixes are large but necessary. I wouldn't normally push such a rework for a -rcX update, but right now xfsdump can silently create incomplete dumps on 3.17 and it's possible that even xfsrestore won't notice that the dumps were incomplete. Hence we need to get this update into 3.17-stable kernels ASAP. In more detail, the refactoring work I committed in 3.17 has exposed a major hole in our QA coverage. With both xfsdump (the major user of bulkstat) and xfsrestore silently ignoring missing files in the dump/restore process, incomplete dumps were going unnoticed if they were being triggered. Many of the dump/restore filesets were so small that they didn't evenhave a chance of triggering the loop iteration bugs we introduced in 3.17, so we didn't exercise the code sufficiently, either. We have already taken steps to improve QA coverage in xfstests to avoid this happening again, and I've done a lot of manual verification of dump/restore on very large data sets (tens of millions of inodes) of the past week to verify this patch set results in bulkstat behaving the same way as it does on 3.16. Unfortunately, the fixes are not exactly simple - in tracking down the problem historic API warts were discovered (e.g xfsdump has been working around a 20 year old bug in the bulkstat API for the past 10 years) and so that complicated the process of diagnosing and fixing the problems. i.e. we had to fix bugs in the code as well as discover and re-introduce the userspace visible API bugs that we unwittingly "fixed" in 3.17 that xfsdump relied on to work correctly. Summary: - incorrect warnings about i_mutex locking in pagecache_isize_extended() and updates comments to match expected locking - another zero-range bug fix for stray file size updates - a bunch of fixes for regression in the bulkstat code introduced in 3.17" * tag 'xfs-for-linus-3.18-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/dgc/linux-xfs: xfs: track bulkstat progress by agino xfs: bulkstat error handling is broken xfs: bulkstat main loop logic is a mess xfs: bulkstat chunk-formatter has issues xfs: bulkstat chunk formatting cursor is broken xfs: bulkstat btree walk doesn't terminate mm: Fix comment before truncate_setsize() xfs: rework zero range to prevent invalid i_size updates mm: Remove false WARN_ON from pagecache_isize_extended() xfs: Check error during inode btree iteration in xfs_bulkstat() xfs: bulkstat doesn't release AGI buffer on error
2014-11-07mm: Fix comment before truncate_setsize()Jan Kara
XFS doesn't always hold i_mutex when calling truncate_setsize() and it uses a different lock to serialize truncates and writes. So fix the comment before truncate_setsize(). Reported-by: Jan Beulich <JBeulich@suse.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Dave Chinner <david@fromorbit.com>
2014-11-03Merge branch 'fixes-for-v3.18' of ↵Linus Torvalds
git://git.linaro.org/people/mszyprowski/linux-dma-mapping Pull CMA and DMA-mapping fixes from Marek Szyprowski: "This contains important fixes for recently introduced highmem support for default contiguous memory region used for dma-mapping subsystem" * 'fixes-for-v3.18' of git://git.linaro.org/people/mszyprowski/linux-dma-mapping: mm, cma: make parameters order consistent in func declaration and definition mm: cma: Use %pa to print physical addresses mm: cma: Ensure that reservations never cross the low/high mem boundary mm: cma: Always consider a 0 base address reservation as dynamic mm: cma: Don't crash on allocation if CMA area can't be activated
2014-10-30mm: Remove false WARN_ON from pagecache_isize_extended()Jan Kara
The WARN_ON checking whether i_mutex is held in pagecache_isize_extended() was wrong because some filesystems (e.g. XFS) use different locks for serialization of truncates / writes. So just remove the check. Signed-off-by: Jan Kara <jack@suse.cz> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2014-10-29mm/balloon_compaction: fix deflation when compaction is disabledKonstantin Khlebnikov
If CONFIG_BALLOON_COMPACTION=n balloon_page_insert() does not link pages with balloon and doesn't set PagePrivate flag, as a result balloon_page_dequeue() cannot get any pages because it thinks that all of them are isolated. Without balloon compaction nobody can isolate ballooned pages. It's safe to remove this check. Fixes: d6d86c0a7f8d ("mm/balloon_compaction: redesign ballooned pages management"). Signed-off-by: Konstantin Khlebnikov <k.khlebnikov@samsung.com> Reported-by: Matt Mullins <mmullins@mmlx.us> Cc: <stable@vger.kernel.org> [3.17] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-29mm/slab_common: don't check for duplicate cache namesMikulas Patocka
The SLUB cache merges caches with the same size and alignment and there was long standing bug with this behavior: - create the cache named "foo" - create the cache named "bar" (which is merged with "foo") - delete the cache named "foo" (but it stays allocated because "bar" uses it) - create the cache named "foo" again - it fails because the name "foo" is already used That bug was fixed in commit 694617474e33 ("slab_common: fix the check for duplicate slab names") by not warning on duplicate cache names when the SLUB subsystem is used. Recently, cache merging was implemented the with SLAB subsystem too, in 12220dea07f1 ("mm/slab: support slab merge")). Therefore we need stop checking for duplicate names even for the SLAB subsystem. This patch fixes the bug by removing the check. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Acked-by: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-29mm: rmap: split out page_remove_file_rmap()Johannes Weiner
page_remove_rmap() has too many branches on PageAnon() and is hard to follow. Move the file part into a separate function. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: Vladimir Davydov <vdavydov@parallels.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-29mm: memcontrol: fix missed end-writeback page accountingJohannes Weiner
Commit 0a31bc97c80c ("mm: memcontrol: rewrite uncharge API") changed page migration to uncharge the old page right away. The page is locked, unmapped, truncated, and off the LRU, but it could race with writeback ending, which then doesn't unaccount the page properly: test_clear_page_writeback() migration wait_on_page_writeback() TestClearPageWriteback() mem_cgroup_migrate() clear PCG_USED mem_cgroup_update_page_stat() if (PageCgroupUsed(pc)) decrease memcg pages under writeback release pc->mem_cgroup->move_lock The per-page statistics interface is heavily optimized to avoid a function call and a lookup_page_cgroup() in the file unmap fast path, which means it doesn't verify whether a page is still charged before clearing PageWriteback() and it has to do it in the stat update later. Rework it so that it looks up the page's memcg once at the beginning of the transaction and then uses it throughout. The charge will be verified before clearing PageWriteback() and migration can't uncharge the page as long as that is still set. The RCU lock will protect the memcg past uncharge. As far as losing the optimization goes, the following test results are from a microbenchmark that maps, faults, and unmaps a 4GB sparse file three times in a nested fashion, so that there are two negative passes that don't account but still go through the new transaction overhead. There is no actual difference: old: 33.195102545 seconds time elapsed ( +- 0.01% ) new: 33.199231369 seconds time elapsed ( +- 0.03% ) The time spent in page_remove_rmap()'s callees still adds up to the same, but the time spent in the function itself seems reduced: # Children Self Command Shared Object Symbol old: 0.12% 0.11% filemapstress [kernel.kallsyms] [k] page_remove_rmap new: 0.12% 0.08% filemapstress [kernel.kallsyms] [k] page_remove_rmap Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Vladimir Davydov <vdavydov@parallels.com> Cc: <stable@vger.kernel.org> [3.17.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-29mm: page-writeback: inline account_page_dirtied() into single callerJohannes Weiner
A follow-up patch would have changed the call signature. To save the trouble, just fold it instead. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Vladimir Davydov <vdavydov@parallels.com> Cc: <stable@vger.kernel.org> [3.17.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-29memory-hotplug: clear pgdat which is allocated by bootmem in try_offline_node()Yasuaki Ishimatsu
When hot adding the same memory after hot removal, the following messages are shown: WARNING: CPU: 20 PID: 6 at mm/page_alloc.c:4968 free_area_init_node+0x3fe/0x426() ... Call Trace: dump_stack+0x46/0x58 warn_slowpath_common+0x81/0xa0 warn_slowpath_null+0x1a/0x20 free_area_init_node+0x3fe/0x426 hotadd_new_pgdat+0x90/0x110 add_memory+0xd4/0x200 acpi_memory_device_add+0x1aa/0x289 acpi_bus_attach+0xfd/0x204 acpi_bus_attach+0x178/0x204 acpi_bus_scan+0x6a/0x90 acpi_device_hotplug+0xe8/0x418 acpi_hotplug_work_fn+0x1f/0x2b process_one_work+0x14e/0x3f0 worker_thread+0x11b/0x510 kthread+0xe1/0x100 ret_from_fork+0x7c/0xb0 The detaled explanation is as follows: When hot removing memory, pgdat is set to 0 in try_offline_node(). But if the pgdat is allocated by bootmem allocator, the clearing step is skipped. And when hot adding the same memory, the uninitialized pgdat is reused. But free_area_init_node() checks wether pgdat is set to zero. As a result, free_area_init_node() hits WARN_ON(). This patch clears pgdat which is allocated by bootmem allocator in try_offline_node(). Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Zhang Zhen <zhenzhang.zhang@huawei.com> Cc: Wang Nan <wangnan0@huawei.com> Cc: Tang Chen <tangchen@cn.fujitsu.com> Reviewed-by: Toshi Kani <toshi.kani@hp.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-29mm, thp: fix collapsing of hugepages on madviseDavid Rientjes
If an anonymous mapping is not allowed to fault thp memory and then madvise(MADV_HUGEPAGE) is used after fault, khugepaged will never collapse this memory into thp memory. This occurs because the madvise(2) handler for thp, hugepage_madvise(), clears VM_NOHUGEPAGE on the stack and it isn't stored in vma->vm_flags until the final action of madvise_behavior(). This causes the khugepaged_enter_vma_merge() to be a no-op in hugepage_madvise() when the vma had previously had VM_NOHUGEPAGE set. Fix this by passing the correct vma flags to the khugepaged mm slot handler. There's no chance khugepaged can run on this vma until after madvise_behavior() returns since we hold mm->mmap_sem. It would be possible to clear VM_NOHUGEPAGE directly from vma->vm_flags in hugepage_advise(), but I didn't want to introduce special case behavior into madvise_behavior(). I think it's best to just let it always set vma->vm_flags itself. Signed-off-by: David Rientjes <rientjes@google.com> Reported-by: Suleiman Souhlal <suleiman@google.com> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-29mm: free compound page with correct orderYu Zhao
Compound page should be freed by put_page() or free_pages() with correct order. Not doing so will cause tail pages leaked. The compound order can be obtained by compound_order() or use HPAGE_PMD_ORDER in our case. Some people would argue the latter is faster but I prefer the former which is more general. This bug was observed not just on our servers (the worst case we saw is 11G leaked on a 48G machine) but also on our workstations running Ubuntu based distro. $ cat /proc/vmstat | grep thp_zero_page_alloc thp_zero_page_alloc 55 thp_zero_page_alloc_failed 0 This means there is (thp_zero_page_alloc - 1) * (2M - 4K) memory leaked. Fixes: 97ae17497e99 ("thp: implement refcounting for huge zero page") Signed-off-by: Yu Zhao <yuzhao@google.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: David Rientjes <rientjes@google.com> Cc: Bob Liu <lliubbo@gmail.com> Cc: <stable@vger.kernel.org> [3.8+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-29mm/compaction.c: avoid premature range skip in isolate_migratepages_rangeJoonsoo Kim
Commit edc2ca612496 ("mm, compaction: move pageblock checks up from isolate_migratepages_range()") commonizes isolate_migratepages variants and make them use isolate_migratepages_block(). isolate_migratepages_block() could stop the execution when enough pages are isolated, but, there is no code in isolate_migratepages_range() to handle this case. In the result, even if isolate_migratepages_block() returns prematurely without checking all pages in the range, isolate_migratepages_block() is called repeately on the following pageblock and some pages in the previous range are skipped to check. Then, CMA is failed frequently due to this fact. To fix this problem, this patch let isolate_migratepages_range() know the situation that enough pages are isolated and stop the isolation in that case. Note that isolate_migratepages() has no such problem, because, it always stops the isolation after just one call of isolate_migratepages_block(). Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: David Rientjes <rientjes@google.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Michal Nazarewicz <mina86@mina86.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Christoph Lameter <cl@linux.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-29cgroup/kmemleak: add kmemleak_free() for cgroup deallocations.Wang Nan
Commit ff7ee93f4715 ("cgroup/kmemleak: Annotate alloc_page() for cgroup allocations") introduces kmemleak_alloc() for alloc_page_cgroup(), but corresponding kmemleak_free() is missing, which makes kmemleak be wrongly disabled after memory offlining. Log is pasted at the end of this commit message. This patch add kmemleak_free() into free_page_cgroup(). During page offlining, this patch removes corresponding entries in kmemleak rbtree. After that, the freed memory can be allocated again by other subsystems without killing kmemleak. bash # for x in 1 2 3 4; do echo offline > /sys/devices/system/memory/memory$x/state ; sleep 1; done ; dmesg | grep leak Offlined Pages 32768 kmemleak: Cannot insert 0xffff880016969000 into the object search tree (overlaps existing) CPU: 0 PID: 412 Comm: sleep Not tainted 3.17.0-rc5+ #86 Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011 Call Trace: dump_stack+0x46/0x58 create_object+0x266/0x2c0 kmemleak_alloc+0x26/0x50 kmem_cache_alloc+0xd3/0x160 __sigqueue_alloc+0x49/0xd0 __send_signal+0xcb/0x410 send_signal+0x45/0x90 __group_send_sig_info+0x13/0x20 do_notify_parent+0x1bb/0x260 do_exit+0x767/0xa40 do_group_exit+0x44/0xa0 SyS_exit_group+0x17/0x20 system_call_fastpath+0x16/0x1b kmemleak: Kernel memory leak detector disabled kmemleak: Object 0xffff880016900000 (size 524288): kmemleak: comm "swapper/0", pid 0, jiffies 4294667296 kmemleak: min_count = 0 kmemleak: count = 0 kmemleak: flags = 0x1 kmemleak: checksum = 0 kmemleak: backtrace: log_early+0x63/0x77 kmemleak_alloc+0x4b/0x50 init_section_page_cgroup+0x7f/0xf5 page_cgroup_init+0xc5/0xd0 start_kernel+0x333/0x408 x86_64_start_reservations+0x2a/0x2c x86_64_start_kernel+0xf5/0xfc Fixes: ff7ee93f4715 (cgroup/kmemleak: Annotate alloc_page() for cgroup allocations) Signed-off-by: Wang Nan <wangnan0@huawei.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: <stable@vger.kernel.org> [3.2+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-28zap_pte_range: update addr when forcing flush after TLB batching faiureWill Deacon
When unmapping a range of pages in zap_pte_range, the page being unmapped is added to an mmu_gather_batch structure for asynchronous freeing. If we run out of space in the batch structure before the range has been completely unmapped, then we break out of the loop, force a TLB flush and free the pages that we have batched so far. If there are further pages to unmap, then we resume the loop where we left off. Unfortunately, we forget to update addr when we break out of the loop, which causes us to truncate the range being invalidated as the end address is exclusive. When we re-enter the loop at the same address, the page has already been freed and the pte_present test will fail, meaning that we do not reconsider the address for invalidation. This patch fixes the problem by incrementing addr by the PAGE_SIZE before breaking out of the loop on batch failure. Signed-off-by: Will Deacon <will.deacon@arm.com> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-27mm: cma: Use %pa to print physical addressesLaurent Pinchart
Casting physical addresses to unsigned long and using %lu truncates the values on systems where physical addresses are larger than 32 bits. Use %pa and get rid of the cast instead. Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Acked-by: Michal Nazarewicz <mina86@mina86.com> Acked-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com>
2014-10-27mm: cma: Ensure that reservations never cross the low/high mem boundaryLaurent Pinchart
Commit 95b0e655f914 ("ARM: mm: don't limit default CMA region only to low memory") extended CMA memory reservation to allow usage of high memory. It relied on commit f7426b983a6a ("mm: cma: adjust address limit to avoid hitting low/high memory boundary") to ensure that the reserved block never crossed the low/high memory boundary. While the implementation correctly lowered the limit, it failed to consider the case where the base..limit range crossed the low/high memory boundary with enough space on each side to reserve the requested size on either low or high memory. Rework the base and limit adjustment to fix the problem. The function now starts by rejecting the reservation altogether for fixed reservations that cross the boundary, tries to reserve from high memory first and then falls back to low memory. Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com>
2014-10-27mm: cma: Always consider a 0 base address reservation as dynamicLaurent Pinchart
The fixed parameter to cma_declare_contiguous() tells the function whether the given base address must be honoured or should be considered as a hint only. The API considers a zero base address as meaning any base address, which must never be considered as a fixed value. Part of the implementation correctly checks both fixed and base != 0, but two locations check the fixed value only. Set fixed to false when base is 0 to fix that and simplify the code. Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Acked-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com>
2014-10-27mm: cma: Don't crash on allocation if CMA area can't be activatedLaurent Pinchart
If activation of the CMA area fails its mutex won't be initialized, leading to an oops at allocation time when trying to lock the mutex. Fix this by setting the cma area count field to 0 when activation fails, leading to allocation returning NULL immediately. Cc: <stable@vger.kernel.org> # v3.17 Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Acked-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com>
2014-10-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "overlayfs merge + leak fix for d_splice_alias() failure exits" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: overlayfs: embed middle into overlay_readdir_data overlayfs: embed root into overlay_readdir_data overlayfs: make ovl_cache_entry->name an array instead of pointer overlayfs: don't hold ->i_mutex over opening the real directory fix inode leaks on d_splice_alias() failure exits fs: limit filesystem stacking depth overlay: overlay filesystem documentation overlayfs: implement show_options overlayfs: add statfs support overlay filesystem shmem: support RENAME_WHITEOUT ext4: support RENAME_WHITEOUT vfs: add RENAME_WHITEOUT vfs: add whiteout support vfs: export check_sticky() vfs: introduce clone_private_mount() vfs: export __inode_permission() to modules vfs: export do_splice_direct() to modules vfs: add i_op->dentry_open()
2014-10-24Merge tag 'pm+acpi-3.18-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management updates from Rafael Wysocki: "This is material that didn't make it to my 3.18-rc1 pull request for various reasons, mostly related to timing and travel (LinuxCon EU / LPC) plus a couple of fixes for recent bugs. The only really new thing here is the PM QoS class for memory bandwidth, but it is simple enough and users of it will be added in the next cycle. One major change in behavior is that platform devices enumerated by ACPI will use 32-bit DMA mask by default. Also included is an ACPICA update to a new upstream release, but that's mostly cleanups, changes in tools and similar. The rest is fixes and cleanups mostly. Specifics: - Fix for a recent PCI power management change that overlooked the fact that some IRQ chips might not be able to configure PCIe PME for system wakeup from Lucas Stach. - Fix for a bug introduced in 3.17 where acpi_device_wakeup() is called with a wrong ordering of arguments from Zhang Rui. - A bunch of intel_pstate driver fixes (all -stable candidates) from Dirk Brandewie, Gabriele Mazzotta and Pali Rohár. - Fixes for a rather long-standing problem with the OOM killer and the freezer that frozen processes killed by the OOM do not actually release any memory until they are thawed, so OOM-killing them is rather pointless, with a couple of cleanups on top (Michal Hocko, Cong Wang, Rafael J Wysocki). - ACPICA update to upstream release 20140926, inlcuding mostly cleanups reducing differences between the upstream ACPICA and the kernel code, tools changes (acpidump, acpiexec) and support for the _DDN object (Bob Moore, Lv Zheng). - New PM QoS class for memory bandwidth from Tomeu Vizoso. - Default 32-bit DMA mask for platform devices enumerated by ACPI (this change is mostly needed for some drivers development in progress targeted at 3.19) from Heikki Krogerus. - ACPI EC driver cleanups, mostly related to debugging, from Lv Zheng. - cpufreq-dt driver updates from Thomas Petazzoni. - powernv cpuidle driver update from Preeti U Murthy" * tag 'pm+acpi-3.18-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (34 commits) intel_pstate: Correct BYT VID values. intel_pstate: Fix BYT frequency reporting intel_pstate: Don't lose sysfs settings during cpu offline cpufreq: intel_pstate: Reflect current no_turbo state correctly cpufreq: expose scaling_cur_freq sysfs file for set_policy() drivers cpufreq: intel_pstate: Fix setting max_perf_pct in performance policy PCI / PM: handle failure to enable wakeup on PCIe PME ACPI: invoke acpi_device_wakeup() with correct parameters PM / freezer: Clean up code after recent fixes PM: convert do_each_thread to for_each_process_thread OOM, PM: OOM killed task shouldn't escape PM suspend freezer: remove obsolete comments in __thaw_task() freezer: Do not freeze tasks killed by OOM killer ACPI / platform: provide default DMA mask cpuidle: powernv: Populate cpuidle state details by querying the device-tree cpufreq: cpufreq-dt: adjust message related to regulators cpufreq: cpufreq-dt: extend with platform_data cpufreq: allow driver-specific data ACPI / EC: Cleanup coding style. ACPI / EC: Refine event/query debugging messages. ...
