git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen
* 'upstream/tidy-xen-mmu-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen:
xen: fix compile without CONFIG_XEN_DEBUG_FS
Use arbitrary_virt_to_machine() to deal with ioremapped pud updates.
Use arbitrary_virt_to_machine() to deal with ioremapped pmd updates.
xen/mmu: remove all ad-hoc stats stuff
xen: use normal virt_to_machine for ptes
xen: make a pile of mmu pvop functions static
vmalloc: remove vmalloc_sync_all() from alloc_vm_area()
xen: condense everything onto xen_set_pte
xen: use mmu_update for xen_set_pte_at()
xen: drop all the special iomap pte paths.
Two new stats in per-memcg memory.stat which tracks the number of page
faults and number of major page faults.
"pgfault"
"pgmajfault"
They are different from "pgpgin"/"pgpgout" stat which count number of
pages charged/discharged to the cgroup and have no meaning of reading/
writing page to disk.
It is valuable to track the two stats for both measuring application's
performance as well as the efficiency of the kernel page reclaim path.
Counting pagefaults per process is useful, but we also need the aggregated
value since processes are monitored and controlled in cgroup basis in
memcg.
Functional test: check the total number of pgfault/pgmajfault of all
memcgs and compare with global vmstat value:
$ cat /proc/vmstat | grep fault
pgfault 1070751
pgmajfault 553
$ cat /dev/cgroup/memory.stat | grep fault
pgfault 1071138
pgmajfault 553
total_pgfault 1071142
total_pgmajfault 553
$ cat /dev/cgroup/A/memory.stat | grep fault
pgfault 199
pgmajfault 0
total_pgfault 199
total_pgmajfault 0
Performance test: run page fault test(pft) wit 16 thread on faulting in
15G anon pages in 16G container. There is no regression noticed on the
"flt/cpu/s"
Sample output from pft:
TAG pft:anon-sys-default:
Gb Thr CLine User System Wall flt/cpu/s fault/wsec
15 16 1 0.67s 233.41s 14.76s 16798.546 266356.260
N Min Max Median Avg Stddev
x 10 16682.962 17344.027 16913.524 16928.812 166.5362
+ 10 16695.568 16923.896 16820.604 16824.652 84.816568
No difference proven at 95.0% confidence
[akpm@linux-foundation.org: fix build]
[hughd@google.com: shmem fix]
Signed-off-by: Ying Han <yinghan@google.com>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com>
The new API exports numa_maps per-memcg basis. This is a piece of useful
information where it exports per-memcg page distribution across real numa
nodes.
One of the usecases is evaluating application performance by combining
this information w/ the cpu allocation to the application.
The output of the memory.numastat tries to follow w/ simiar format of
numa_maps like:
total=<total pages> N0=<node 0 pages> N1=<node 1 pages> ...
file=<total file pages> N0=<node 0 pages> N1=<node 1 pages> ...
anon=<total anon pages> N0=<node 0 pages> N1=<node 1 pages> ...
unevictable=<total anon pages> N0=<node 0 pages> N1=<node 1 pages> ...
And we have per-node:
total = file + anon + unevictable
$ cat /dev/cgroup/memory/memory.numa_stat
total=250020 N0=87620 N1=52367 N2=45298 N3=64735
file=225232 N0=83402 N1=46160 N2=40522 N3=55148
anon=21053 N0=3424 N1=6207 N2=4776 N3=6646
unevictable=3735 N0=794 N1=0 N2=0 N3=2941
Cc: Balbir Singh <balbir@in.ibm.com>
Acked-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Cc: Minchan Kim <minchan.kim@gmail.com>
The caller of the function has been renamed to zone_nr_lru_pages(), and
this is just fixing up in the memcg code. The current name is easily to
be mis-read as zone's total number of pages.
If the memcg reclaim code detects the target memcg below its limit it
exits and returns a guaranteed non-zero value so that the charge is
retried.
Nowadays, the charge side checks the memcg limit itself and does not rely
on this non-zero return value trick.
This patch removes it. The reclaim code will now always return the true
number of pages it reclaimed on its own.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Acked-by: Rik van Riel<riel@redhat.com>
Acked-by: Ying Han<yinghan@google.com>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Cc: Balbir Singh <balbir@linux.vnet.ibm.com>
During memory reclaim we determine the number of pages to be scanned per
zone as
(anon + file) >> priority.
Assume
scan = (anon + file) >> priority.
If scan < SWAP_CLUSTER_MAX, the scan will be skipped for this time and
priority gets higher. This has some problems.
1. This increases priority as 1 without any scan.
To do scan in this priority, amount of pages should be larger than 512M.
If pages>>priority < SWAP_CLUSTER_MAX, it's recorded and scan will be
batched, later. (But we lose 1 priority.)
If memory size is below 16M, pages >> priority is 0 and no scan in
DEF_PRIORITY forever.
2. If zone->all_unreclaimabe==true, it's scanned only when priority==0.
So, x86's ZONE_DMA will never be recoverred until the user of pages
frees memory by itself.
3. With memcg, the limit of memory can be small. When using small memcg,
it gets priority < DEF_PRIORITY-2 very easily and need to call
wait_iff_congested().
For doing scan before priorty=9, 64MB of memory should be used.
Then, this patch tries to scan SWAP_CLUSTER_MAX of pages in force...when
1. the target is enough small.
2. it's kswapd or memcg reclaim.
Then we can avoid rapid priority drop and may be able to recover
all_unreclaimable in a small zones. And this patch removes nr_saved_scan.
This will allow scanning in this priority even when pages >> priority is
very small.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Acked-by: Ying Han <yinghan@google.com>
Presently, memory cgroup's direct reclaim frees memory from the current
node. But this has some troubles. Usually when a set of threads works in
a cooperative way, they tend to operate on the same node. So if they hit
limits under memcg they will reclaim memory from themselves, damaging the
active working set.
For example, assume 2 node system which has Node 0 and Node 1 and a memcg
which has 1G limit. After some work, file cache remains and the usages
are
Node 0: 1M
Node 1: 998M.
and run an application on Node 0, it will eat its foot before freeing
unnecessary file caches.
This patch adds round-robin for NUMA and adds equal pressure to each node.
When using cpuset's spread memory feature, this will work very well.
But yes, a better algorithm is needed.
[akpm@linux-foundation.org: comment editing]
[kamezawa.hiroyu@jp.fujitsu.com: fix time comparisons]
Move page-freeing code out of swap_cgroup_mutex in the hope that it could
reduce few of theoretical contentions between swapons and/or swapoffs.
This is just a cleanup, no functional changes.
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
It allocated one more page than necessary if @max_pages was a multiple of
SC_PER_PAGE.
Commit ca371c0d7e23 ("memcg: fix page_cgroup fatal error in FLATMEM")
removes call to alloc_bootmem() in the function so that it can be marked
as __meminit to reduce memory usage when MEMORY_HOTPLUG=n.
Also as the new helper function alloc_page_cgroup() is called only in the
function, it should be marked too.
next_mz is assigned to NULL if __mem_cgroup_largest_soft_limit_node
selects the same mz. This doesn't make much sense as we assign to the
variable right in the next loop.
Compiler will probably optimize this out but it is little bit confusing
for the code reading.
We recently added the change in global background reclaim which counts the
return value of soft_limit reclaim. Now this patch adds the similar logic
on global direct reclaim.
We should skip scanning global LRU on shrink_zone if soft_limit reclaim
does enough work. This is the first step where we start with counting the
nr_scanned and nr_reclaimed from soft_limit reclaim into global
scan_control.
The global kswapd scans per-zone LRU and reclaims pages regardless of the
cgroup. It breaks memory isolation since one cgroup can end up reclaiming
pages from another cgroup. Instead we should rely on memcg-aware target
reclaim including per-memcg kswapd and soft_limit hierarchical reclaim under
memory pressure.
In the global background reclaim, we do soft reclaim before scanning the
per-zone LRU. However, the return value is ignored. This patch is the first
step to skip shrink_zone() if soft_limit reclaim does enough work.
This is part of the effort which tries to reduce reclaiming pages in global
LRU in memcg. The per-memcg background reclaim patchset further enhances the
per-cgroup targetting reclaim, which I should have V4 posted shortly.
Try running multiple memory intensive workloads within seperate memcgs. Watch
the counters of soft_steal in memory.stat.
$ cat /dev/cgroup/A/memory.stat | grep 'soft'
soft_steal 240000
soft_scan 240000
total_soft_steal 240000
total_soft_scan 240000
This patch:
We would like to skip shrink_zone() if soft_limit reclaim does enough
work. Also, we need to make the memory pressure balanced across per-memcg
zones, like the logic vm-core. This patch is the first step where we
start with counting the nr_scanned and nr_reclaimed from soft_limit
reclaim into the global scan_control.
Add cgroup subsystem callbacks for per-thread attachment in atomic contexts
Add can_attach_task(), pre_attach(), and attach_task() as new callbacks
for cgroups's subsystem interface. Unlike can_attach and attach, these
are for per-thread operations, to be called potentially many times when
attaching an entire threadgroup.
Also, the old "bool threadgroup" interface is removed, as replaced by
this. All subsystems are modified for the new interface - of note is
cpuset, which requires from/to nodemasks for attach to be globally scoped
(though per-cpuset would work too) to persist from its pre_attach to
attach_task and attach.
This is a pre-patch for cgroup-procs-writable.patch.
Signed-off-by: Ben Blum <bblum@andrew.cmu.edu>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Li Zefan <lizf@cn.fujitsu.com>
Cc: Matt Helsley <matthltc@us.ibm.com>
Reviewed-by: Paul Menage <menage@google.com>
Cc: Miao Xie <miaox@cn.fujitsu.com>
git://git.kernel.org/pub/scm/linux/kernel/git/djm/tmem
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/djm/tmem:
xen: cleancache shim to Xen Transcendent Memory
ocfs2: add cleancache support
ext4: add cleancache support
btrfs: add cleancache support
ext3: add cleancache support
mm/fs: add hooks to support cleancache
mm: cleancache core ops functions and config
fs: add field to superblock to support cleancache
mm/fs: cleancache documentation
Fix up trivial conflict in fs/btrfs/extent_io.c due to includes
The type of vma->vm_flags is 'unsigned long'. Neither 'int' nor
'unsigned int'. This patch fixes such misuse.
[ Changed to use a typedef - we'll extend it to cover more cases
later, since there has been discussion about making it a 64-bit
type.. - Linus ]
This fourth patch of eight in this cleancache series provides the
core hooks in VFS for: initializing cleancache per filesystem;
capturing clean pages reclaimed by page cache; attempting to get
pages from cleancache before filesystem read; and ensuring coherency
between pagecache, disk, and cleancache. Note that the placement
of these hooks was stable from 2.6.18 to 2.6.38; a minor semantic
change was required due to a patchset in 2.6.39.
All hooks become no-ops if CONFIG_CLEANCACHE is unset, or become
a check of a boolean global if CONFIG_CLEANCACHE is set but no
cleancache "backend" has claimed cleancache_ops.
Details and a FAQ can be found in Documentation/vm/cleancache.txt
[v8: minchan.kim@gmail.com: adapt to new remove_from_page_cache function]
Signed-off-by: Chris Mason <chris.mason@oracle.com>
Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com>
Reviewed-by: Jeremy Fitzhardinge <jeremy@goop.org>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Cc: Matthew Wilcox <matthew@wil.cx>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Rik Van Riel <riel@redhat.com>
Cc: Jan Beulich <JBeulich@novell.com>
Cc: Andreas Dilger <adilger@sun.com>
Cc: Ted Ts'o <tytso@mit.edu>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Joel Becker <joel.becker@oracle.com>
Cc: Nitin Gupta <ngupta@vflare.org>
This third patch of eight in this cleancache series provides
the core code for cleancache that interfaces between the hooks in
VFS and individual filesystems and a cleancache backend. It also
includes build and config patches.
Two new files are added: mm/cleancache.c and include/linux/cleancache.h.
Note that CONFIG_CLEANCACHE can default to on; in systems that do
not provide a cleancache backend, all hooks devolve to a simple
check of a global enable flag, so performance impact should
be negligible but can be reduced to zero impact if config'ed off.
However for this first commit, it defaults to off.
Credits: Cleancache_ops design derived from Jeremy Fitzhardinge
design for tmem
[v8: dan.magenheimer@oracle.com: fix exportfs call affecting btrfs]
[v8: akpm@linux-foundation.org: use static inline function, not macro]
[v7: dan.magenheimer@oracle.com: cleanup sysfs and remove cleancache prefix]
[v6: JBeulich@novell.com: robustly handle buggy fs encode_fh actor definition]
[v5: jeremy@goop.org: clean up global usage and static var names]
[v5: jeremy@goop.org: simplify init hook and any future fs init changes]
[v5: hch@infradead.org: cleaner non-global interface for ops registration]
[v4: adilger@sun.com: interface must support exportfs FS's]
[v4: hch@infradead.org: interface must support 64-bit FS on 32-bit kernel]
[v3: akpm@linux-foundation.org: use one ops struct to avoid pointer hops]
[v3: akpm@linux-foundation.org: document and ensure PageLocked reqts are met]
[v3: ngupta@vflare.org: fix success/fail codes, change funcs to void]
[v2: viro@ZenIV.linux.org.uk: use sane types]
Acked-by: Al Viro <viro@ZenIV.linux.org.uk>
Acked-by: Andrew Morton <akpm@linux-foundation.org>
Acked-by: Nitin Gupta <ngupta@vflare.org>
Acked-by: Minchan Kim <minchan.kim@gmail.com>
Acked-by: Andreas Dilger <adilger@sun.com>
Acked-by: Jan Beulich <JBeulich@novell.com>
Cc: Chris Mason <chris.mason@oracle.com>
Commit a71ae47a2cbf ("slub: Fix double bit unlock in debug mode")
removed the only goto to this label, resulting in
mm/slub.c: In function '__slab_alloc':
mm/slub.c:1834: warning: label 'unlock_out' defined but not used
fixed trivially by the removal of the label itself too.
Cc: Christoph Lameter <cl@linux.com>
The functions probe_kernel_write() and probe_kernel_read() do not modify
the src pointer. Allow const pointers to be passed in without the need
of a typecast.
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com>
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
Link: http://lkml.kernel.org/r/1305824936.1465.4.camel@gandalf.stny.rr.com
* 'for-2.6.40/core' of git://git.kernel.dk/linux-2.6-block: (40 commits)
cfq-iosched: free cic_index if cfqd allocation fails
cfq-iosched: remove unused 'group_changed' in cfq_service_tree_add()
cfq-iosched: reduce bit operations in cfq_choose_req()
cfq-iosched: algebraic simplification in cfq_prio_to_maxrq()
blk-cgroup: Initialize ioc->cgroup_changed at ioc creation time
block: move bd_set_size() above rescan_partitions() in __blkdev_get()
block: call elv_bio_merged() when merged
cfq-iosched: Make IO merge related stats per cpu
cfq-iosched: Fix a memory leak of per cpu stats for root group
backing-dev: Kill set but not used var in bdi_debug_stats_show()
block: get rid of on-stack plugging debug checks
blk-throttle: Make no throttling rule group processing lockless
blk-cgroup: Make cgroup stat reset path blkg->lock free for dispatch stats
blk-cgroup: Make 64bit per cpu stats safe on 32bit arch
blk-throttle: Make dispatch stats per cpu
blk-throttle: Free up a group only after one rcu grace period
blk-throttle: Use helper function to add root throtl group to lists
blk-throttle: Introduce a helper function to fill in device details
blk-throttle: Dynamically allocate root group
blk-cgroup: Allow sleeping while dynamically allocating a group
Currently on nommu arch mmap(),mremap() and munmap() doesn't do
page_align() which isn't consist with mmu arch and cause some issues.
First, some drivers' mmap() function depends on vma->vm_end - vma->start
is page aligned which is true on mmu arch but not on nommu. eg: uvc
camera driver.
Second munmap() may return -EINVAL[split file] error in cases when end is
not page aligned(passed into from userspace) but vma->vm_end is aligned
dure to split or driver's mmap() ops.
Add page alignment to fix those issues.
Signed-off-by: Bob Liu <lliubbo@gmail.com>
Cc: Greg Ungerer <gerg@snapgear.com>
The zone->lru_lock is heavily contented in workload where activate_page()
is frequently used. We could do batch activate_page() to reduce the lock
contention. The batched pages will be added into zone list when the pool
is full or page reclaim is trying to drain them.
For example, in a 4 socket 64 CPU system, create a sparse file and 64
processes, processes shared map to the file. Each process read access the
whole file and then exit. The process exit will do unmap_vmas() and cause
a lot of activate_page() call. In such workload, we saw about 58% total
time reduction with below patch. Other workloads with a lot of
activate_page also benefits a lot too.
Andrew Morton suggested activate_page() and putback_lru_pages() should
follow the same path to active pages, but this is hard to implement (see
commit 7a608572a282a ("Revert "mm: batch activate_page() to reduce lock
contention")). On the other hand, do we really need putback_lru_pages()
to follow the same path? I tested several FIO/FFSB benchmark (about 20
scripts for each benchmark) in 3 machines here from 2 sockets to 4
sockets. My test doesn't show anything significant with/without below
patch (there is slight difference but mostly some noise which we found
even without below patch before). Below patch basically returns to the
same as my first post.
I tested some microbenchmarks:
case-anon-cow-rand-mt 0.58%
case-anon-cow-rand -3.30%
case-anon-cow-seq-mt -0.51%
case-anon-cow-seq -5.68%
case-anon-r-rand-mt 0.23%
case-anon-r-rand 0.81%
case-anon-r-seq-mt -0.71%
case-anon-r-seq -1.99%
case-anon-rx-rand-mt 2.11%
case-anon-rx-seq-mt 3.46%
case-anon-w-rand-mt -0.03%
case-anon-w-rand -0.50%
case-anon-w-seq-mt -1.08%
case-anon-w-seq -0.12%
case-anon-wx-rand-mt -5.02%
case-anon-wx-seq-mt -1.43%
case-fork 1.65%
case-fork-sleep -0.07%
case-fork-withmem 1.39%
case-hugetlb -0.59%
case-lru-file-mmap-read-mt -0.54%
case-lru-file-mmap-read 0.61%
case-lru-file-mmap-read-rand -2.24%
case-lru-file-readonce -0.64%
case-lru-file-readtwice -11.69%
case-lru-memcg -1.35%
case-mmap-pread-rand-mt 1.88%
case-mmap-pread-rand -15.26%
case-mmap-pread-seq-mt 0.89%
case-mmap-pread-seq -69.72%
case-mmap-xread-rand-mt 0.71%
case-mmap-xread-seq-mt 0.38%
The most significent are:
which use activate_page a lot. others are basically variations because
each run has slightly difference.
In UP case, 'size mm/swap.o'
before the two patches:
6466 896 4 7366 1cc6 mm/swap.o
after the two patches:
6343 896 4 7243 1c4b mm/swap.o
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
Cc: Hiroyuki Kamezawa <kamezawa.hiroyuki@gmail.com>
I believe I found a problem in __alloc_pages_slowpath, which allows a
process to get stuck endlessly looping, even when lots of memory is
available.
Running an I/O and memory intensive stress-test I see a 0-order page
allocation with __GFP_IO and __GFP_WAIT, running on a system with very
little free memory. Right about the same time that the stress-test gets
killed by the OOM-killer, the utility trying to allocate memory gets stuck
in __alloc_pages_slowpath even though most of the systems memory was freed
by the oom-kill of the stress-test.
The utility ends up looping from the rebalance label down through the
wait_iff_congested continiously. Because order=0,
__alloc_pages_direct_compact skips the call to get_page_from_freelist.
Because all of the reclaimable memory on the system has already been
reclaimed, __alloc_pages_direct_reclaim skips the call to
get_page_from_freelist. Since there is no __GFP_FS flag, the block with
__alloc_pages_may_oom is skipped. The loop hits the wait_iff_congested,
then jumps back to rebalance without ever trying to
get_page_from_freelist. This loop repeats infinitely.
The test case is pretty pathological. Running a mix of I/O stress-tests
that do a lot of fork() and consume all of the system memory, I can pretty
reliably hit this on 600 nodes, in about 12 hours. 32GB/node.
Signed-off-by: Andrew Barry <abarry@cray.com>
Signed-off-by: Minchan Kim <minchan.kim@gmail.com>
Reviewed-by: Rik van Riel<riel@redhat.com>
Cc: <stable@kernel.org>
The noswapaccount parameter has been deprecated since 2.6.38 without any
complaints from users so we can remove it. swapaccount=0|1 can be used
instead.
As we are removing the parameter we can also clean up swapaccount because
it doesn't have to accept an empty string anymore (to match noswapaccount)
and so we can push = into __setup macro rather than checking "=1" resp.
"=0" strings
Moving show_numa_map() from mempolicy.c to task_mmu.c solves several
issues.
- Having the show() operation "miles away" from the corresponding
seq_file iteration operations is a maintenance burden.
- The need to export ad hoc info like struct proc_maps_private is
eliminated.
- The implementation of show_numa_map() can be improved in a simple
manner by cooperating with the other seq_file operations (start,
stop, etc) -- something that would be messy to do without this
change.
Signed-off-by: Stephen Wilson <wilsons@start.ca>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
This function has been superseded by gather_hugetbl_stats() and is no
longer needed.
Improve the prototype of gather_stats() to take a struct numa_maps as
argument instead of a generic void *. Update all callers to make the
required type explicit.
Since gather_stats() is not needed before its definition and is scheduled
to be moved out of mempolicy.c the declaration is removed as well.
Mapping statistics in a NUMA environment is now computed using the generic
walk_page_range() logic. Remove the old/equivalent functionality.
Converting show_numa_map() to use the generic routine decouples the
function from mempolicy.c, allowing it to be moved out of the mm subsystem
and into fs/proc.
Also, include KSM pages in /proc/pid/numa_maps statistics. The pagewalk
logic implemented by check_pte_range() failed to account for such pages as
they were not applicable to the page migration case.
In commit 48fce3429d ("mempolicies: unexport get_vma_policy()")
get_vma_policy() was marked static as all clients were local to
mempolicy.c.
However, the decision to generate /proc/pid/numa_maps in the numa memory
policy code and outside the procfs subsystem introduces an artificial
interdependency between the two systems. Exporting get_vma_policy() once
again is the first step to clean up this interdependency.
Implement generic xattrs for tmpfs filesystems. The Feodra project, while
trying to replace suid apps with file capabilities, realized that tmpfs,
which is used on the build systems, does not support file capabilities and
thus cannot be used to build packages which use file capabilities. Xattrs
are also needed for overlayfs.
The xattr interface is a bit odd. If a filesystem does not implement any
{get,set,list}xattr functions the VFS will call into some random LSM hooks
and the running LSM can then implement some method for handling xattrs.
SELinux for example provides a method to support security.selinux but no
other security.* xattrs.
As it stands today when one enables CONFIG_TMPFS_POSIX_ACL tmpfs will have
xattr handler routines specifically to handle acls. Because of this tmpfs
would loose the VFS/LSM helpers to support the running LSM. To make up
for that tmpfs had stub functions that did nothing but call into the LSM
hooks which implement the helpers.
This new patch does not use the LSM fallback functions and instead just
implements a native get/set/list xattr feature for the full security.* and
trusted.* namespace like a normal filesystem. This means that tmpfs can
now support both security.selinux and security.capability, which was not
previously possible.
The basic implementation is that I attach a:
struct shmem_xattr {
struct list_head list; /* anchored by shmem_inode_info->xattr_list */
char *name;
size_t size;
char value[0];
Into the struct shmem_inode_info for each xattr that is set. This
implementation could easily support the user.* namespace as well, except
some care needs to be taken to prevent large amounts of unswappable memory
being allocated for unprivileged users.
[mszeredi@suse.cz: new config option, suport trusted.*, support symlinks]
Signed-off-by: Eric Paris <eparis@redhat.com>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Acked-by: Serge Hallyn <serge.hallyn@ubuntu.com>
Tested-by: Serge Hallyn <serge.hallyn@ubuntu.com>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Tested-by: Jordi Pujol <jordipujolp@gmail.com>
The bootmem wrapper with memblock supports top-down now, so we no longer
need this trick.
Signed-off-by: Yinghai LU <yinghai@kernel.org>
Cc: Olaf Hering <olaf@aepfle.de>
Cc: Tejun Heo <tj@kernel.org>
Cc: Lucas De Marchi <lucas.demarchi@profusion.mobi>
The page allocator will improperly return a page from ZONE_NORMAL even
when __GFP_DMA is passed if CONFIG_ZONE_DMA is disabled. The caller
expects DMA memory, perhaps for ISA devices with 16-bit address registers,
and may get higher memory resulting in undefined behavior.
This patch causes the page allocator to return NULL in such circumstances
with a warning emitted to the kernel log on the first occurrence.
Signed-off-by: David Rientjes <rientjes@google.com>
online_pages() is only compiled for CONFIG_MEMORY_HOTPLUG_SPARSE, so there
is no need to support CONFIG_FLATMEM code within it.
This patch removes code that is never used.
Signed-off-by: Daniel Kiper <dkiper@net-space.pl>
Acked-by: Dave Hansen <dave@linux.vnet.ibm.com>
Acked-by: David Rientjes <rientjes@google.com>
It's pointless that deactive_page's operates on unevictable pages. This
patch removes unnecessary overhead which might be a bit problem in case
that there are many unevictable page in system(ex, mprotect workload)
[akpm@linux-foundation.org: tidy up comment]
Previously the mmap sequential readahead is triggered by updating
ra->prev_pos on each page fault and compare it with current page offset.
It costs dirtying the cache line on each _minor_ page fault. So remove
the ra->prev_pos recording, and instead tag PG_readahead to trigger the
possible sequential readahead. It's not only more simple, but also will
work more reliably and reduce cache line bouncing on concurrent page
faults on shared struct file.
In the mosbench exim benchmark which does multi-threaded page faults on
shared struct file, the ra->mmap_miss and ra->prev_pos updates are found
to cause excessive cache line bouncing on tmpfs, which actually disabled
readahead totally (shmem_backing_dev_info.ra_pages == 0).
So remove the ra->prev_pos recording, and instead tag PG_readahead to
trigger the possible sequential readahead. It's not only more simple, but
also will work more reliably on concurrent reads on shared struct file.
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
Tested-by: Tim Chen <tim.c.chen@intel.com>
Reported-by: Andi Kleen <ak@linux.intel.com>
The original INT_MAX is too large, reduce it to
- avoid unnecessarily dirtying/bouncing the cache line
- restore mmap read-around faster on changed access pattern
Background: in the mosbench exim benchmark which does multi-threaded page
faults on shared struct file, the ra->mmap_miss updates are found to cause
excessive cache line bouncing on tmpfs. The ra state updates are needless
for tmpfs because it actually disabled readahead totally
Reduce readahead overheads by returning early in do_sync_mmap_readahead().
tmpfs has ra_pages=0 and it can page fault really fast (not constraint by
IO if not swapping).
Change each shrinker's API by consolidating the existing parameters into
shrink_control struct. This will simplify any further features added w/o
touching each file of shrinker.
[akpm@linux-foundation.org: fix warning]
[kosaki.motohiro@jp.fujitsu.com: fix up new shrinker API]
[akpm@linux-foundation.org: fix xfs warning]
[akpm@linux-foundation.org: update gfs2]
Acked-by: Pavel Emelyanov <xemul@openvz.org>
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Consolidate the existing parameters to shrink_slab() into a new
shrink_control struct. This is needed later to pass the same struct to
shrinkers.
Pass __GFP_NORETRY|__GFP_NOWARN for readahead page allocations.
readahead page allocations are completely optional. They are OK to fail
and in particular shall not trigger OOM on themselves.
Reported-by: Dave Young <hidave.darkstar@gmail.com>
Reviewed-by: Pekka Enberg <penberg@kernel.org>
MIGRATE_RESERVE
This fixes a problem where the first pageblock got marked MIGRATE_RESERVE
even though it only had a few free pages. eg, On current ARM port, The
kernel starts at offset 0x8000 to leave room for boot parameters, and the
memory is freed later.
This in turn caused no contiguous memory to be reserved and frequent
kswapd wakeups that emptied the caches to get more contiguous memory.
Unfortunatelly, ARM needs order-2 allocation for pgd (see
arm/mm/pgd.c#pgd_alloc()). Therefore the issue is not minor nor easy
avoidable.
[kosaki.motohiro@jp.fujitsu.com: added some explanation]
[kosaki.motohiro@jp.fujitsu.com: add !pfn_valid_within() to check]
[minchan.kim@gmail.com: check end_pfn in pageblock_is_reserved]
Signed-off-by: John Stultz <john.stultz@linaro.org>
Signed-off-by: Arve Hjønnevåg <arve@android.com>
Acked-by: Mel Gorman <mel@csn.ul.ie>
isolate_lru_page() must be called only with stable reference to the page,
this is what is written in the comment above it, this is reasonable.
current isolate_lru_page() users and its page extra reference sources:
mm/huge_memory.c:
__collapse_huge_page_isolate() - reference from pte
mm/memcontrol.c:
mem_cgroup_move_parent() - get_page_unless_zero()
mem_cgroup_move_charge_pte_range() - reference from pte
mm/memory-failure.c:
soft_offline_page() - fixed, reference from get_any_page()
delete_from_lru_cache() - reference from caller or get_page_unless_zero()
[ seems like there bug, because __memory_failure() can call
page_action() for hpages tail, but it is ok for
isolate_lru_page(), tail getted and not in lru]
mm/memory_hotplug.c:
do_migrate_range() - fixed, get_page_unless_zero()
mm/mempolicy.c:
migrate_page_add() - reference from pte
mm/migrate.c:
do_move_page_to_node_array() - reference from follow_page()
mlock.c: - various external references
mm/vmscan.c:
putback_lru_page() - reference from isolate_lru_page()
It seems that all isolate_lru_page() users are ready now for this
restriction. So, let's replace redundant get_page_unless_zero() with
get_page() and add page initial reference count check with VM_BUG_ON()
Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
Drop first page reference only after calling isolate_lru_page() to keep
page stable reference while isolating.
isolate_lru_page() must be called only with stable reference to page. So,
let's grab normal page reference.
I was tracking down a page allocation failure that ended up in vmalloc().
Since vmalloc() uses 0-order pages, if somebody asks for an insane amount
of memory, we'll still get a warning with "order:0" in it. That's not
very useful.
During recovery, vmalloc() also nicely frees all of the memory that it got
up to the point of the failure. That is wonderful, but it also quickly
hides any issues. We have a much different sitation if vmalloc()
repeatedly fails 10GB in to:
vmalloc(100 * 1<<30);
versus repeatedly failing 4096 bytes in to a:
vmalloc(8192);
This patch will print out messages that look like this:
[ 68.123503] vmalloc: allocation failure, allocated 6680576 of 13426688 bytes
[ 68.124218] bash: page allocation failure: order:0, mode:0xd2
[ 68.124811] Pid: 3770, comm: bash Not tainted 2.6.39-rc3-00082-g85f2e68-dirty #333
[ 68.125579] Call Trace:
[ 68.125853] [<ffffffff810f6da6>] warn_alloc_failed+0x146/0x170
[ 68.126464] [<ffffffff8107e05c>] ? printk+0x6c/0x70
[ 68.126791] [<ffffffff8112b5d4>] ? alloc_pages_current+0x94/0xe0
[ 68.127661] [<ffffffff8111ed37>] __vmalloc_node_range+0x237/0x290
The 'order' variable is added for clarity when calling warn_alloc_failed()
to avoid having an unexplained '0' as an argument.
The 'tmp_mask' is because adding an open-coded '| __GFP_NOWARN' would take
us over 80 columns for the alloc_pages_node() call. If we are going to
add a line, it might as well be one that makes the sucker easier to read.
As a side issue, I also noticed that ctl_ioctl() does vmalloc() based
solely on an unverified value passed in from userspace. Granted, it's
under CAP_SYS_ADMIN, but it still frightens me a bit.
Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com>
Cc: Michal Nazarewicz <mina86@mina86.com>
This originally started as a simple patch to give vmalloc() some more
verbose output on failure on top of the plain page allocator messages.
Johannes suggested that it might be nicer to lead with the vmalloc() info
_before_ the page allocator messages.
But, I do think there's a lot of value in what __alloc_pages_slowpath()
does with its filtering and so forth.
This patch creates a new function which other allocators can call instead
of relying on the internal page allocator warnings. It also gives this
function private rate-limiting which separates it from other
printk_ratelimit() users.
cpumask_t is very big struct and cpu_vm_mask is placed wrong position.
It might lead to reduce cache hit ratio.
This patch has two change.
1) Move the place of cpumask into last of mm_struct. Because usually cpumask
is accessed only front bits when the system has cpu-hotplug capability
2) Convert cpu_vm_mask into cpumask_var_t. It may help to reduce memory
footprint if cpumask_size() will use nr_cpumask_bits properly in future.
In addition, this patch change the name of cpu_vm_mask with cpu_vm_mask_var.
It may help to detect out of tree cpu_vm_mask users.
This patch has no functional change.
[akpm@linux-foundation.org: build fix]
Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
We don't need to hold the mmmap_sem through mem_cgroup_newpage_charge(),
the mmap_sem is only hold for keeping the vma stable and we don't need the
vma stable anymore after we return from alloc_hugepage_vma().
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: Johannes Weiner <jweiner@redhat.com>
