arch/arm/Kconfig
Change-Id: If8aaaf3efcbbf6c9017b38efb6d76ef933f147fa
commit 52cef189165d74a5d6030184a8e05595194c69ca upstream.
Commit 30765b92 ("slab, lockdep: Annotate the locks before using
them") moves the init_lock_keys() call from after g_cpucache_up =
FULL, to before it. And overlooks the fact that init_node_lock_keys()
tests for it and ignores everything !FULL.
Introduce a LATE stage and change the lockdep test to be <LATE.
Acked-by: Christoph Lameter <cl@linux.com>
Cc: Pekka Enberg <penberg@kernel.org>
commit ea4039a34c4c206d015d34a49d0b00868e37db1d upstream.
If we fail to prepare an anon_vma, the {new, old}_page should be released,
or they will leak.
Signed-off-by: Hillf Danton <dhillf@gmail.com>
Reviewed-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: Johannes Weiner <jweiner@redhat.com>
Under the following conditions, __alloc_pages_slowpath can loop
forever:
gfp_mask & __GFP_WAIT is true
gfp_mask & __GFP_FS is false
reclaim and compaction make no progress
order <= PAGE_ALLOC_COSTLY_ORDER
The gfp conditions are normally invalid, because !__GFP_FS
disables most of the reclaim methods that __GFP_WAIT would
wait for. However, these conditions happen very often during
suspend and resume, when pm_restrict_gfp_mask() effectively
converts all GFP_KERNEL allocations into __GFP_WAIT.
The oom killer is not run because gfp_mask & __GFP_FS is false,
but should_alloc_retry will always return true when order is less
than PAGE_ALLOC_COSTLY_ORDER. __alloc_pages_slowpath will
loop forever between the rebalance label and should_alloc_retry,
unless another thread happens to release enough pages to satisfy
the allocation.
Add a check to detect when PM has disabled __GFP_FS, and do not
retry if reclaim is not making any progress.
[taken from patch on lkml by Mel Gorman, commit message by ccross]
Change-Id: I864a24e9d9fd98bd0e3d6e9c1e85b6c1b766850e
Signed-off-by: Colin Cross <ccross@android.com>
The arguments to shrink functions have changed, update
ashmem_shrink to match.
Change-Id: Id279d22d761a2a7c4965c957960eef804d06cc07
Signed-off-by: Bjorn Bringert <bringert@android.com>
Change-Id: I509d18b21832e229737ea7ebaa231fb107eb61d7
Change-Id: Ie527d18f3352ede06d565826c8d35ded1638203a
Signed-off-by: Colin Cross <ccross@google.com>
Change-Id: I1412cc9560de8c4feb1162fc30922f0e3362a476
Signed-off-by: Arve Hjønnevåg <arve@android.com>
Bug: 2595601
Change-Id: I47c0016f594f9354fb8658ccb26e3d395bcb137b
Forward port of ashmem to 2.6.27.
Signed-off-by: Robert Love <rlove@google.com>
ashmem: Don't install fault handler for private mmaps.
Ashmem is used to create named private heaps. If this heap is backed
by a tmpfs file it will allocate two pages for every page touched.
In 2.6.27, the extra page would later be freed, but 2.6.29 does not
scan anonymous pages when running without swap so the memory is not
freed while the file is referenced. This change changes the behavior
of private ashmem mmaps to match /dev/zero instead tmpfs.
ashmem: Add common prefix to name reported in /proc/pid/maps
ashmem: don't require a page aligned size
This makes ashmem more similar to shmem and mmap, by
not requiring the specified size to be page aligned,
instead rounding it internally as needed.
Signed-off-by: Marco Nelissen <marcone@android.com>
By default the kernel tries to keep half as much memory free at each
order as it does for one order below. This can be too agressive when
running without swap.
Change-Id: I5efc1a0b50f41ff3ac71e92d2efd175dedd54ead
commit 7a401a972df8e184b3d1a3fc958c0a4ddee8d312 upstream.
bdi_prune_sb() in bdi_unregister() attempts to removes the bdi links
from all super_blocks and then del_timer_sync() the writeback timer.
However, this can race with __mark_inode_dirty(), leading to
bdi_wakeup_thread_delayed() rearming the writeback timer on the bdi
we're unregistering, after we've called del_timer_sync().
This can end up with the bdi being freed with an active timer inside it,
as in the case of the following dump after the removal of an SD card.
Fix this by redoing the del_timer_sync() in bdi_destory().
WARNING: at /home/rabin/kernel/arm/lib/debugobjects.c:262 debug_print_object+0x9c/0xc8()
ODEBUG: free active (active state 0) object type: timer_list hint: wakeup_timer_fn+0x0/0x180
Modules linked in:
Backtrace:
[<c00109dc>] (dump_backtrace+0x0/0x110) from [<c0236e4c>] (dump_stack+0x18/0x1c)
r6:c02bc638 r5:00000106 r4:c79f5d18 r3:00000000
[<c0236e34>] (dump_stack+0x0/0x1c) from [<c0025e6c>] (warn_slowpath_common+0x54/0x6c)
[<c0025e18>] (warn_slowpath_common+0x0/0x6c) from [<c0025f28>] (warn_slowpath_fmt+0x38/0x40)
r8:20000013 r7:c780c6f0 r6:c031613c r5:c780c6f0 r4:c02b1b29
r3:00000009
[<c0025ef0>] (warn_slowpath_fmt+0x0/0x40) from [<c015eb4c>] (debug_print_object+0x9c/0xc8)
r3:c02b1b29 r2:c02bc662
[<c015eab0>] (debug_print_object+0x0/0xc8) from [<c015f574>] (debug_check_no_obj_freed+0xac/0x1dc)
r6:c7964000 r5:00000001 r4:c7964000
[<c015f4c8>] (debug_check_no_obj_freed+0x0/0x1dc) from [<c00a9e38>] (kmem_cache_free+0x88/0x1f8)
[<c00a9db0>] (kmem_cache_free+0x0/0x1f8) from [<c014286c>] (blk_release_queue+0x70/0x78)
[<c01427fc>] (blk_release_queue+0x0/0x78) from [<c015290c>] (kobject_release+0x70/0x84)
r5:c79641f0 r4:c796420c
[<c015289c>] (kobject_release+0x0/0x84) from [<c0153ce4>] (kref_put+0x68/0x80)
r7:00000083 r6:c74083d0 r5:c015289c r4:c796420c
[<c0153c7c>] (kref_put+0x0/0x80) from [<c01527d0>] (kobject_put+0x48/0x5c)
r5:c79643b4 r4:c79641f0
[<c0152788>] (kobject_put+0x0/0x5c) from [<c013ddd8>] (blk_cleanup_queue+0x68/0x74)
r4:c7964000
[<c013dd70>] (blk_cleanup_queue+0x0/0x74) from [<c01a6370>] (mmc_blk_put+0x78/0xe8)
r5:00000000 r4:c794c400
[<c01a62f8>] (mmc_blk_put+0x0/0xe8) from [<c01a64b4>] (mmc_blk_release+0x24/0x38)
r5:c794c400 r4:c0322824
[<c01a6490>] (mmc_blk_release+0x0/0x38) from [<c00de11c>] (__blkdev_put+0xe8/0x170)
r5:c78d5e00 r4:c74083c0
[<c00de034>] (__blkdev_put+0x0/0x170) from [<c00de2c0>] (blkdev_put+0x11c/0x12c)
r8:c79f5f70 r7:00000001 r6:c74083d0 r5:00000083 r4:c74083c0
r3:00000000
[<c00de1a4>] (blkdev_put+0x0/0x12c) from [<c00b0724>] (kill_block_super+0x60/0x6c)
r7:c7942300 r6:c79f4000 r5:00000083 r4:c74083c0
[<c00b06c4>] (kill_block_super+0x0/0x6c) from [<c00b0a94>] (deactivate_locked_super+0x44/0x70)
r6:c79f4000 r5:c031af64 r4:c794dc00 r3:c00b06c4
[<c00b0a50>] (deactivate_locked_super+0x0/0x70) from [<c00b1358>] (deactivate_super+0x6c/0x70)
r5:c794dc00 r4:c794dc00
[<c00b12ec>] (deactivate_super+0x0/0x70) from [<c00c88b0>] (mntput_no_expire+0x188/0x194)
r5:c794dc00 r4:c7942300
[<c00c8728>] (mntput_no_expire+0x0/0x194) from [<c00c95e0>] (sys_umount+0x2e4/0x310)
r6:c7942300 r5:00000000 r4:00000000 r3:00000000
[<c00c92fc>] (sys_umount+0x0/0x310) from [<c000d940>] (ret_fast_syscall+0x0/0x30)
---[ end trace e5c83c92ada51c76 ]---
Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com>
commit 70b50f94f1644e2aa7cb374819cfd93f3c28d725 upstream.
Michel while working on the working set estimation code, noticed that
calling get_page_unless_zero() on a random pfn_to_page(random_pfn)
wasn't safe, if the pfn ended up being a tail page of a transparent
hugepage under splitting by __split_huge_page_refcount().
He then found the problem could also theoretically materialize with
page_cache_get_speculative() during the speculative radix tree lookups
that uses get_page_unless_zero() in SMP if the radix tree page is freed
and reallocated and get_user_pages is called on it before
page_cache_get_speculative has a chance to call get_page_unless_zero().
So the best way to fix the problem is to keep page_tail->_count zero at
all times. This will guarantee that get_page_unless_zero() can never
succeed on any tail page. page_tail->_mapcount is guaranteed zero and
is unused for all tail pages of a compound page, so we can simply
account the tail page references there and transfer them to
tail_page->_count in __split_huge_page_refcount() (in addition to the
head_page->_mapcount).
While debugging this s/_count/_mapcount/ change I also noticed get_page is
called by direct-io.c on pages returned by get_user_pages. That wasn't
entirely safe because the two atomic_inc in get_page weren't atomic. As
opposed to other get_user_page users like secondary-MMU page fault to
establish the shadow pagetables would never call any superflous get_page
after get_user_page returns. It's safer to make get_page universally safe
for tail pages and to use get_page_foll() within follow_page (inside
get_user_pages()). get_page_foll() is safe to do the refcounting for tail
pages without taking any locks because it is run within PT lock protected
critical sections (PT lock for pte and page_table_lock for
pmd_trans_huge).
The standard get_page() as invoked by direct-io instead will now take
the compound_lock but still only for tail pages. The direct-io paths
are usually I/O bound and the compound_lock is per THP so very
finegrined, so there's no risk of scalability issues with it. A simple
direct-io benchmarks with all lockdep prove locking and spinlock
debugging infrastructure enabled shows identical performance and no
overhead. So it's worth it. Ideally direct-io should stop calling
get_page() on pages returned by get_user_pages(). The spinlock in
get_page() is already optimized away for no-THP builds but doing
get_page() on tail pages returned by GUP is generally a rare operation
and usually only run in I/O paths.
This new refcounting on page_tail->_mapcount in addition to avoiding new
RCU critical sections will also allow the working set estimation code to
work without any further complexity associated to the tail page
refcounting with THP.
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Reported-by: Michel Lespinasse <walken@google.com>
Reviewed-by: Michel Lespinasse <walken@google.com>
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
Cc: David Gibson <david@gibson.dropbear.id.au>
commit f5252e009d5b87071a919221e4f6624184005368 upstream.
The /proc/vmallocinfo shows information about vmalloc allocations in
vmlist that is a linklist of vm_struct. It, however, may access pages
field of vm_struct where a page was not allocated. This results in a null
pointer access and leads to a kernel panic.
Why this happens: In __vmalloc_node_range() called from vmalloc(), newly
allocated vm_struct is added to vmlist at __get_vm_area_node() and then,
some fields of vm_struct such as nr_pages and pages are set at
__vmalloc_area_node(). In other words, it is added to vmlist before it is
fully initialized. At the same time, when the /proc/vmallocinfo is read,
it accesses the pages field of vm_struct according to the nr_pages field
at show_numa_info(). Thus, a null pointer access happens.
The patch adds the newly allocated vm_struct to the vmlist *after* it is
fully initialized. So, it can avoid accessing the pages field with
unallocated page when show_numa_info() is called.
Signed-off-by: Mitsuo Hayasaka <mitsuo.hayasaka.hu@hitachi.com>
Cc: Namhyung Kim <namhyung@gmail.com>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
I don't usually pay much attention to the stale "? " addresses in
stack backtraces, but this lucky report from Pawel Sikora hints that
mremap's move_ptes() has inadequate locking against page migration.
3.0 BUG_ON(!PageLocked(p)) in migration_entry_to_page():
kernel BUG at include/linux/swapops.h:105!
RIP: 0010:[<ffffffff81127b76>] [<ffffffff81127b76>]
migration_entry_wait+0x156/0x160
[<ffffffff811016a1>] handle_pte_fault+0xae1/0xaf0
[<ffffffff810feee2>] ? __pte_alloc+0x42/0x120
[<ffffffff8112c26b>] ? do_huge_pmd_anonymous_page+0xab/0x310
[<ffffffff81102a31>] handle_mm_fault+0x181/0x310
[<ffffffff81106097>] ? vma_adjust+0x537/0x570
[<ffffffff81424bed>] do_page_fault+0x11d/0x4e0
[<ffffffff81109a05>] ? do_mremap+0x2d5/0x570
[<ffffffff81421d5f>] page_fault+0x1f/0x30
mremap's down_write of mmap_sem, together with i_mmap_mutex or lock,
and pagetable locks, were good enough before page migration (with its
requirement that every migration entry be found) came in, and enough
while migration always held mmap_sem; but not enough nowadays, when
there's memory hotremove and compaction.
The danger is that move_ptes() lets a migration entry dodge around
behind remove_migration_pte()'s back, so it's in the old location when
looking at the new, then in the new location when looking at the old.
Either mremap's move_ptes() must additionally take anon_vma lock(), or
migration's remove_migration_pte() must stop peeking for is_swap_entry()
before it takes pagetable lock.
Consensus chooses the latter: we prefer to add overhead to migration
than to mremapping, which gets used by JVMs and by exec stack setup.
Reported-and-tested-by: Paweł Sikora <pluto@agmk.net>
Acked-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: stable@vger.kernel.org
* 'for-linus' of git://git.kernel.dk/linux-block:
floppy: use del_timer_sync() in init cleanup
blk-cgroup: be able to remove the record of unplugged device
block: Don't check QUEUE_FLAG_SAME_COMP in __blk_complete_request
mm: Add comment explaining task state setting in bdi_forker_thread()
mm: Cleanup clearing of BDI_pending bit in bdi_forker_thread()
block: simplify force plug flush code a little bit
block: change force plug flush call order
block: Fix queue_flag update when rq_affinity goes from 2 to 1
block: separate priority boosting from REQ_META
block: remove READ_META and WRITE_META
xen-blkback: fixed indentation and comments
xen-blkback: Don't disconnect backend until state switched to XenbusStateClosed.
* 'slab/urgent' of git://github.com/penberg/linux:
slub: add slab with one free object to partial list tail
The found entries by find_get_pages() could be all swap entries. In
this case we skip the entries, but make sure the skipped entries are
accounted, so we don't keep looping.
Using nr_found > nr_skip to simplify code as suggested by Eric.
Reported-and-tested-by: Eric Dumazet <eric.dumazet@gmail.com>
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
Xen backend drivers (e.g., blkback and netback) would sometimes fail to
map grant pages into the vmalloc address space allocated with
alloc_vm_area(). The GNTTABOP_map_grant_ref would fail because Xen could
not find the page (in the L2 table) containing the PTEs it needed to
update.
(XEN) mm.c:3846:d0 Could not find L1 PTE for address fbb42000
netback and blkback were making the hypercall from a kernel thread where
task->active_mm != &init_mm and alloc_vm_area() was only updating the page
tables for init_mm. The usual method of deferring the update to the page
tables of other processes (i.e., after taking a fault) doesn't work as a
fault cannot occur during the hypercall.
This would work on some systems depending on what else was using vmalloc.
Fix this by reverting ef691947d8a3 ("vmalloc: remove vmalloc_sync_all()
from alloc_vm_area()") and add a comment to explain why it's needed.
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Ian Campbell <Ian.Campbell@citrix.com>
Cc: Keir Fraser <keir.xen@gmail.com>
Cc: <stable@kernel.org> [3.0.x]
Revert the post-3.0 commit 82f9d486e59f5 ("memcg: add
memory.vmscan_stat").
The implementation of per-memcg reclaim statistics violates how memcg
hierarchies usually behave: hierarchically.
The reclaim statistics are accounted to child memcgs and the parent
hitting the limit, but not to hierarchy levels in between. Usually,
hierarchical statistics are perfectly recursive, with each level
representing the sum of itself and all its children.
Since this exports statistics to userspace, this may lead to confusion
and problems with changing things after the release, so revert it now,
we can try again later.
Signed-off-by: Johannes Weiner <jweiner@redhat.com>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Cc: Ying Han <yinghan@google.com>
Cc: Balbir Singh <bsingharora@gmail.com>
Without swap, anonymous pages are not scanned. As such, they should not
count when considering force-scanning a small target if there is no swap.
Otherwise, targets are not force-scanned even when their effective scan
number is zero and the other conditions--kswapd/memcg--apply.
This fixes 246e87a93934 ("memcg: fix get_scan_count() for small
targets").
[akpm@linux-foundation.org: fix comment]
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Acked-by: Mel Gorman <mel@csn.ul.ie>
The vmstat_text array is only defined for CONFIG_SYSFS or CONFIG_PROC_FS,
yet it is referenced for per-node vmstat with CONFIG_NUMA:
drivers/built-in.o: In function `node_read_vmstat':
node.c:(.text+0x1106df): undefined reference to `vmstat_text'
Introduced in commit fa25c503dfa2 ("mm: per-node vmstat: show proper
vmstats").
Define the array for CONFIG_NUMA as well.
[akpm@linux-foundation.org: remove unneeded ifdefs]
Signed-off-by: David Rientjes <rientjes@google.com>
Reported-by: Cong Wang <amwang@redhat.com>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
When compiling mm/mempolicy.c with struct user copy checks the following
warning is shown:
In file included from arch/x86/include/asm/uaccess.h:572,
from include/linux/uaccess.h:5,
from include/linux/highmem.h:7,
from include/linux/pagemap.h:10,
from include/linux/mempolicy.h:70,
from mm/mempolicy.c:68:
In function `copy_from_user',
inlined from `compat_sys_get_mempolicy' at mm/mempolicy.c:1415:
arch/x86/include/asm/uaccess_64.h:64: warning: call to `copy_from_user_overflow' declared with attribute warning: copy_from_user() buffer size is not provably correct
LD mm/built-in.o
Fix this by passing correct buffer size value.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
commit 9d8cebd4bcd7 ("mm: fix mbind vma merge problem") didn't really
fix the mbind vma merge problem due to wrong pgoff value passing to
vma_merge(), which made vma_merge() always return NULL.
Before the patch applied, we are getting a result like:
addr = 0x7fa58f00c000
[snip]
7fa58f00c000-7fa58f00d000 rw-p 00000000 00:00 0
7fa58f00d000-7fa58f00e000 rw-p 00000000 00:00 0
7fa58f00e000-7fa58f00f000 rw-p 00000000 00:00 0
here 7fa58f00c000->7fa58f00f000 we get 3 VMAs which are expected to be
merged described as described in commit 9d8cebd.
Re-testing the patched kernel with the reproducer provided in commit
9d8cebd, we get the correct result:
addr = 0x7ffa5aaa2000
[snip]
7ffa5aaa2000-7ffa5aaa6000 rw-p 00000000 00:00 0
7fffd556f000-7fffd5584000 rw-p 00000000 00:00 0 [stack]
Signed-off-by: Caspar Zhang <caspar@casparzhang.com>
Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
Cc: Minchan Kim <minchan.kim@gmail.com>
CC: Wu Fengguang <fengguang.wu@intel.com>
CC: Andrew Morton <akpm@linux-foundation.org>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
bdi_forker_thread() clears BDI_pending bit at the end of the main loop.
However clearing of this bit must not be done in some cases which is
handled by calling 'continue' from switch statement. That's kind of
unusual construct and without a good reason so change the function into
more intuitive code flow.
The slab has just one free object, adding it to partial list head doesn't make
sense. And it can cause lock contentation. For example,
1. CPU takes the slab from partial list
2. fetch an object
3. switch to another slab
4. free an object, then the slab is added to partial list again
In this way n->list_lock will be heavily contended.
In fact, Alex had a hackbench regression. 3.1-rc1 performance drops about 70%
against 3.0. This patch fixes it.
Reported-by: Alex Shi <alex.shi@intel.com>
Signed-off-by: Shaohua Li <shli@kernel.org>
Signed-off-by: Pekka Enberg <penberg@kernel.org>
Commit 79dfdaccd1d5 ("memcg: make oom_lock 0 and 1 based rather than
counter") tried to oom lock the hierarchy and roll back upon
encountering an already locked memcg.
The code is confused when it comes to detecting a locked memcg, though,
so it would fail and rollback after locking one memcg and encountering
an unlocked second one.
The result is that oom-locking hierarchies fails unconditionally and
that every oom killer invocation simply goes to sleep on the oom
waitqueue forever. The tasks practically hang forever without anyone
intervening, possibly holding locks that trip up unrelated tasks, too.
Acked-by: Michal Hocko <mhocko@suse.cz>
ZONE_CONGESTED is only cleared in kswapd, but pages can be freed in any
task. It's possible ZONE_CONGESTED isn't cleared in some cases:
1. the zone is already balanced just entering balance_pgdat() for
order-0 because concurrent tasks free memory. In this case, later
check will skip the zone as it's balanced so the flag isn't cleared.
2. high order balance fallbacks to order-0. quote from Mel: At the
end of balance_pgdat(), kswapd uses the following logic;
If reclaiming at high order {
for each zone {
if all_unreclaimable
skip
if watermark is not met
order = 0
loop again
/* watermark is met */
clear congested
i.e. it clears ZONE_CONGESTED if it the zone is balanced. if not,
it restarts balancing at order-0. However, if the higher zones are
balanced for order-0, kswapd will miss clearing ZONE_CONGESTED as
that only happens after a zone is shrunk. This can mean that
wait_iff_congested() stalls unnecessarily.
This patch makes kswapd clear ZONE_CONGESTED during its initial
highmem->dma scan for zones that are already balanced.
I get the below warning:
BUG: using smp_processor_id() in preemptible [00000000] code: bash/746
caller is native_sched_clock+0x37/0x6e
Pid: 746, comm: bash Tainted: G W 3.0.0+ #254
Call Trace:
[<ffffffff813435c6>] debug_smp_processor_id+0xc2/0xdc
[<ffffffff8104158d>] native_sched_clock+0x37/0x6e
[<ffffffff81116219>] try_to_free_mem_cgroup_pages+0x7d/0x270
[<ffffffff8114f1f8>] mem_cgroup_force_empty+0x24b/0x27a
[<ffffffff8114ff21>] ? sys_close+0x38/0x138
[<ffffffff8114f257>] mem_cgroup_force_empty_write+0x17/0x19
[<ffffffff810c72fb>] cgroup_file_write+0xa8/0xba
[<ffffffff811522d2>] vfs_write+0xb3/0x138
[<ffffffff8115241a>] sys_write+0x4a/0x71
[<ffffffff8114ffd9>] ? sys_close+0xf0/0x138
[<ffffffff8176deab>] system_call_fastpath+0x16/0x1b
sched_clock() can't be used with preempt enabled. And we don't need
fast approach to get clock here, so let's use ktime API.
Tested-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Commit d1a05b6973c7 ("memcg do not try to drain per-cpu caches without
pages") added a drain_local_stock() call to a preemptible section.
The draining task looks up the cpu-local stock twice to set the
draining-flag, then to drain the stock and clear the flag again. If the
task is migrated to a different CPU in between, noone will clear the
flag on the first stock and it will be forever undrainable. Its charge
can not be recovered and the cgroup can not be deleted anymore.
Properly pin the task to the executing CPU while draining stocks.
Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com
git://git.kernel.org/pub/scm/linux/kernel/git/wfg/writeback
* 'urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/wfg/writeback:
squeeze max-pause area and drop pass-good area
Revert the pass-good area introduced in ffd1f609ab10 ("writeback:
introduce max-pause and pass-good dirty limits") and make the max-pause
area smaller and safe.
This fixes ~30% performance regression in the ext3 data=writeback
fio_mmap_randwrite_64k/fio_mmap_randrw_64k test cases, where there are
12 JBOD disks, on each disk runs 8 concurrent tasks doing reads+writes.
Using deadline scheduler also has a regression, but not that big as CFQ,
so this suggests we have some write starvation.
The test logs show that
- the disks are sometimes under utilized
- global dirty pages sometimes rush high to the pass-good area for
several hundred seconds, while in the mean time some bdi dirty pages
drop to very low value (bdi_dirty << bdi_thresh). Then suddenly the
global dirty pages dropped under global dirty threshold and bdi_dirty
rush very high (for example, 2 times higher than bdi_thresh). During
which time balance_dirty_pages() is not called at all.
So the problems are
1) The random writes progress so slow that they break the assumption of
the max-pause logic that "8 pages per 200ms is typically more than
enough to curb heavy dirtiers".
2) The max-pause logic ignored task_bdi_thresh and thus opens the possibility
for some bdi's to over dirty pages, leading to (bdi_dirty >> bdi_thresh)
and then (bdi_thresh >> bdi_dirty) for others.
3) The higher max-pause/pass-good thresholds somehow leads to the bad
swing of dirty pages.
The fix is to allow the task to slightly dirty over task_bdi_thresh, but
no way to exceed bdi_dirty and/or global dirty_thresh.
Tests show that it fixed the JBOD regression completely (both behavior
and performance), while still being able to cut down large pause times
in balance_dirty_pages() for single-disk cases.
Reported-by: Li Shaohua <shaohua.li@intel.com>
Tested-by: Li Shaohua <shaohua.li@intel.com>
Acked-by: Jan Kara <jack@suse.cz>
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
Followup to 33dd4e0ec911 "mm: make some struct page's const" which missed the
HASHED_PAGE_VIRTUAL case.
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Cc: Michel Lespinasse <walken@google.com>
Commit db64fe02258f ("mm: rewrite vmap layer") introduced code that does
address calculations under the assumption that VMAP_BLOCK_SIZE is a
power of two. However, this might not be true if CONFIG_NR_CPUS is not
set to a power of two.
Wrong vmap_block index/offset values could lead to memory corruption.
However, this has never been observed in practice (or never been
diagnosed correctly); what caught this was the BUG_ON in vb_alloc() that
checks for inconsistent vmap_block indices.
To fix this, ensure that VMAP_BLOCK_SIZE always is a power of two.
BugLink: https://bugzilla.kernel.org/show_bug.cgi?id=31572
Reported-by: Pavel Kysilka <goldenfish@linuxsoft.cz>
Reported-by: Matias A. Fonzo <selk@dragora.org>
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
Cc: Nick Piggin <npiggin@suse.de>
Cc: Krzysztof Helt <krzysztof.h1@poczta.fm>
Cc: 2.6.28+ <stable@kernel.org>
This reverts commit 8521fc50d433507a7cdc96bec280f9e5888a54cc.
The patch incorrectly assumes that using atomic FLUSHING_CACHED_CHARGE
bit operations is sufficient but that is not true. Johannes Weiner has
reported a crash during parallel memory cgroup removal:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000018
IP: [<ffffffff81083b70>] css_is_ancestor+0x20/0x70
Oops: 0000 [#1] PREEMPT SMP
Pid: 19677, comm: rmdir Tainted: G W 3.0.0-mm1-00188-gf38d32b #35 ECS MCP61M-M3/MCP61M-M3
RIP: 0010:[<ffffffff81083b70>] css_is_ancestor+0x20/0x70
RSP: 0018:ffff880077b09c88 EFLAGS: 00010202
Process rmdir (pid: 19677, threadinfo ffff880077b08000, task ffff8800781bb310)
Call Trace:
[<ffffffff810feba3>] mem_cgroup_same_or_subtree+0x33/0x40
[<ffffffff810feccf>] drain_all_stock+0x11f/0x170
[<ffffffff81103211>] mem_cgroup_force_empty+0x231/0x6d0
[<ffffffff811036c4>] mem_cgroup_pre_destroy+0x14/0x20
[<ffffffff81080559>] cgroup_rmdir+0xb9/0x500
[<ffffffff81114d26>] vfs_rmdir+0x86/0xe0
[<ffffffff81114e7b>] do_rmdir+0xfb/0x110
[<ffffffff81114ea6>] sys_rmdir+0x16/0x20
[<ffffffff8154d76b>] system_call_fastpath+0x16/0x1b
We are crashing because we try to dereference cached memcg when we are
checking whether we should wait for draining on the cache. The cache is
already cleaned up, though.
There is also a theoretical chance that the cached memcg gets freed
between we test for the FLUSHING_CACHED_CHARGE and dereference it in
mem_cgroup_same_or_subtree:
CPU0 CPU1 CPU2
mem=stock->cached
stock->cached=NULL
clear_bit
test_and_set_bit
test_bit() ...
<preempted> mem_cgroup_destroy
use after free
The percpu_charge_mutex protected from this race because sync draining
is exclusive.
It is safer to revert now and come up with a more parallel
implementation later.
Reported-by: Johannes Weiner <jweiner@redhat.com>
Acked-by: Johannes Weiner <jweiner@redhat.com>
Cc: stable@kernel.org
deactivate_slab() has the comparison if more than the minimum number of
partial pages are in the partial list wrong. An effect of this may be that
empty pages are not freed from deactivate_slab(). The result could be an
OOM due to growth of the partial slabs per node. Frees mostly occur from
__slab_free which is okay so this would only affect use cases where a lot
of switching around of per cpu slabs occur.
Switching per cpu slabs occurs with high frequency if debugging options are
enabled.
Reported-and-tested-by: Xiaotian Feng <xtfeng@gmail.com>
Signed-off-by: Christoph Lameter <cl@linux.com>
The check_bytes() function is used by slub debugging. It returns a pointer
to the first unmatching byte for a character in the given memory area.
If the character for matching byte is greater than 0x80, check_bytes()
doesn't work. Becuase 64-bit pattern is generated as below.
value64 = value | value << 8 | value << 16 | value << 24;
value64 = value64 | value64 << 32;
The integer promotions are performed and sign-extended as the type of value
is u8. The upper 32 bits of value64 is 0xffffffff in the first line, and
the second line has no effect.
This fixes the 64-bit pattern generation.
Cc: Matt Mackall <mpm@selenic.com>
Reviewed-by: Marcin Slusarz <marcin.slusarz@gmail.com>
When a slab is freed by __slab_free() and the slab can only contain a
single object ever then it was full (and therefore not on the partial
lists but on the full list in the debug case) before we reached
slab_empty.
This caused the following full list corruption when SLUB debugging was enabled:
[ 5913.233035] ------------[ cut here ]------------
[ 5913.233097] WARNING: at lib/list_debug.c:53 __list_del_entry+0x8d/0x98()
[ 5913.233101] Hardware name: Adamo 13
[ 5913.233105] list_del corruption. prev->next should be ffffea000434fd20, but was ffffea0004199520
[ 5913.233108] Modules linked in: nfs fscache fuse ebtable_nat ebtables ppdev parport_pc lp parport ipt_MASQUERADE iptable_nat nf_nat nfsd lockd nfs_acl auth_rpcgss xt_CHECKSUM sunrpc iptable_mangle bridge stp llc cpufreq_ondemand acpi_cpufreq freq_table mperf ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 ip6table_filter ip6_tables rfcomm bnep arc4 iwlagn snd_hda_codec_hdmi snd_hda_codec_idt snd_hda_intel btusb mac80211 snd_hda_codec bluetooth snd_hwdep snd_seq snd_seq_device snd_pcm usb_debug dell_wmi sparse_keymap cdc_ether usbnet cdc_acm uvcvideo cdc_wdm mii cfg80211 snd_timer dell_laptop videodev dcdbas snd microcode v4l2_compat_ioctl32 soundcore joydev tg3 pcspkr snd_page_alloc iTCO_wdt i2c_i801 rfkill iTCO_vendor_support wmi virtio_net kvm_intel kvm ipv6 xts gf128mul dm_crypt i915 drm_kms_helper drm i2c_algo_bit i2c_core video [last unloaded: scsi_wait_scan]
[ 5913.233213] Pid: 0, comm: swapper Not tainted 3.0.0+ #127
[ 5913.233213] Call Trace:
[ 5913.233213] <IRQ> [<ffffffff8105df18>] warn_slowpath_common+0x83/0x9b
[ 5913.233213] [<ffffffff8105dfd3>] warn_slowpath_fmt+0x46/0x48
[ 5913.233213] [<ffffffff8127e7c1>] __list_del_entry+0x8d/0x98
[ 5913.233213] [<ffffffff8127e7da>] list_del+0xe/0x2d
[ 5913.233213] [<ffffffff814e0430>] __slab_free+0x1db/0x235
[ 5913.233213] [<ffffffff811706ab>] ? bvec_free_bs+0x35/0x37
[ 5913.233213] [<ffffffff81133085>] kmem_cache_free+0x88/0x102
[ 5913.233213] [<ffffffff811706ab>] bvec_free_bs+0x35/0x37
[ 5913.233213] [<ffffffff811706e1>] bio_free+0x34/0x64
[ 5913.233213] [<ffffffff813dc390>] dm_bio_destructor+0x12/0x14
[ 5913.233213] [<ffffffff8116fef6>] bio_put+0x2b/0x2d
[ 5913.233213] [<ffffffff813dccab>] clone_endio+0x9e/0xb4
[ 5913.233213] [<ffffffff8116f7dd>] bio_endio+0x2d/0x2f
[ 5913.233213] [<ffffffffa00148da>] crypt_dec_pending+0x5c/0x8b [dm_crypt]
[ 5913.233213] [<ffffffffa00150a9>] crypt_endio+0x78/0x81 [dm_crypt]
[ Full discussion here: https://lkml.org/lkml/2011/8/4/375 ]
Make sure that we remove such a slab also from the full lists.
Reported-and-tested-by: Dave Jones <davej@redhat.com>
* 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
slab, lockdep: Annotate the locks before using them
lockdep: Clear whole lockdep_map on initialization
slab, lockdep: Annotate slab -> rcu -> debug_object -> slab
lockdep: Fix up warning
lockdep: Fix trace_hardirqs_on_caller()
futex: Fix regression with read only mappings
Fernando found we hit the regular OFF_SLAB 'recursion' before we
annotate the locks, cure this.
The relevant portion of the stack-trace:
> [ 0.000000] [<c085e24f>] rt_spin_lock+0x50/0x56
> [ 0.000000] [<c04fb406>] __cache_free+0x43/0xc3
> [ 0.000000] [<c04fb23f>] kmem_cache_free+0x6c/0xdc
> [ 0.000000] [<c04fb2fe>] slab_destroy+0x4f/0x53
> [ 0.000000] [<c04fb396>] free_block+0x94/0xc1
> [ 0.000000] [<c04fc551>] do_tune_cpucache+0x10b/0x2bb
> [ 0.000000] [<c04fc8dc>] enable_cpucache+0x7b/0xa7
> [ 0.000000] [<c0bd9d3c>] kmem_cache_init_late+0x1f/0x61
> [ 0.000000] [<c0bba687>] start_kernel+0x24c/0x363
> [ 0.000000] [<c0bba0ba>] i386_start_kernel+0xa9/0xaf
Reported-by: Fernando Lopez-Lezcano <nando@ccrma.Stanford.EDU>
Acked-by: Pekka Enberg <penberg@kernel.org>
Link: http://lkml.kernel.org/r/1311888176.2617.379.camel@laptop
Lockdep thinks there's lock recursion through:
kmem_cache_free()
cache_flusharray()
spin_lock(&l3->list_lock) <----------------.
free_block() |
slab_destroy() |
call_rcu() |
debug_object_activate() |
debug_object_init() |
__debug_object_init() |
kmem_cache_alloc() |
cache_alloc_refill() |
spin_lock(&l3->list_lock) --'
Now debug objects doesn't use SLAB_DESTROY_BY_RCU and hence there is no
actual possibility of recursing. Luckily debug objects marks it slab
with SLAB_DEBUG_OBJECTS so we can identify the thing.
Mark all SLAB_DEBUG_OBJECTS (all one!) slab caches with a special
lockdep key so that lockdep sees its a different cachep.
Also add a WARN on trying to create a SLAB_DESTROY_BY_RCU |
SLAB_DEBUG_OBJECTS cache, to avoid possible future trouble.
Reported-and-tested-by: Sebastian Siewior <sebastian@breakpoint.cc>
[ fixes to the initial patch ]
Reported-by: Thomas Gleixner <tglx@linutronix.de>
Link: http://lkml.kernel.org/r/1311341165.27400.58.camel@twins
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'apei-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6:
ACPI, APEI, EINJ Param support is disabled by default
APEI GHES: 32-bit buildfix
ACPI: APEI build fix
ACPI, APEI, GHES: Add hardware memory error recovery support
HWPoison: add memory_failure_queue()
ACPI, APEI, GHES, Error records content based throttle
ACPI, APEI, GHES, printk support for recoverable error via NMI
lib, Make gen_pool memory allocator lockless
lib, Add lock-less NULL terminated single list
Add Kconfig option ARCH_HAVE_NMI_SAFE_CMPXCHG
ACPI, APEI, Add WHEA _OSC support
ACPI, APEI, Add APEI bit support in generic _OSC call
ACPI, APEI, GHES, Support disable GHES at boot time
ACPI, APEI, GHES, Prevent GHES to be built as module
ACPI, APEI, Use apei_exec_run_optional in APEI EINJ and ERST
ACPI, APEI, Add apei_exec_run_optional
ACPI, APEI, GHES, Do not ratelimit fatal error printk before panic
ACPI, APEI, ERST, Fix erst-dbg long record reading issue
ACPI, APEI, ERST, Prevent erst_dbg from loading if ERST is disabled
Make the radix_tree exceptional cases, mostly in filemap.c, clearer.
It's hard to devise a suitable snappy name that illuminates the use by
shmem/tmpfs for swap, while keeping filemap/pagecache/radix_tree
generality. And akpm points out that /* radix_tree_deref_retry(page) */
comments look like calls that have been commented out for unknown
reason.
Skirt the naming difficulty by rearranging these blocks to handle the
transient radix_tree_deref_retry(page) case first; then just explain the
remaining shmem/tmpfs swap case in a comment.
We have already acknowledged that swapoff of a tmpfs file is slower than
it was before conversion to the generic radix_tree: a little slower
there will be acceptable, if the hotter paths are faster.
But it was a shock to find swapoff of a 500MB file 20 times slower on my
laptop, taking 10 minutes; and at that rate it significantly slows down
my testing.
Now, most of that turned out to be overhead from PROVE_LOCKING and
PROVE_RCU: without those it was only 4 times slower than before; and
more realistic tests on other machines don't fare as badly.
I've tried a number of things to improve it, including tagging the swap
entries, then doing lookup by tag: I'd expected that to halve the time,
but in practice it's erratic, and often counter-productive.
The only change I've so far found to make a consistent improvement, is
to short-circuit the way we go back and forth, gang lookup packing
entries into the array supplied, then shmem scanning that array for the
target entry. Scanning in place doubles the speed, so it's now only
twice as slow as before (or three times slower when the PROVEs are on).
So, add radix_tree_locate_item() as an expedient, once-off,
single-caller hack to do the lookup directly in place. #ifdef it on
CONFIG_SHMEM and CONFIG_SWAP, as much to document its limited
applicability as save space in other configurations. And, sadly,
#include sched.h for cond_resched().
Remove PageSwapBacked (!page_is_file_cache) cases from
add_to_page_cache_locked() and add_to_page_cache_lru(): those pages now
go through shmem_add_to_page_cache().
Remove a comment on maximum tmpfs size from fsstack_copy_inode_size(),
and add a comment on swap entries to invalidate_mapping_pages().
And mincore_page() uses find_get_page() on what might be shmem or a
tmpfs file: allow for a radix_tree_exceptional_entry(), and proceed to
find_get_page() on swapper_space if so (oh, swapper_space needs #ifdef).
But we've not yet removed the old swp_entry_t i_direct[16] from
shmem_inode_info. That's because it was still being shared with the
inline symlink. Remove it now (saving 64 or 128 bytes from shmem inode
size), and use kmemdup() for short symlinks, say, those up to 128 bytes.
I wonder why mpol_free_shared_policy() is done in shmem_destroy_inode()
rather than shmem_evict_inode(), where we usually do such freeing? I
guess it doesn't matter, and I'm not into NUMA mpol testing right now.
Reviewed-by: Pekka Enberg <penberg@kernel.org>
Convert shmem_writepage() to use shmem_delete_from_page_cache() to use
shmem_radix_tree_replace() to substitute swap entry for page pointer
atomically in the radix tree.
As with shmem_add_to_page_cache(), it's not entirely satisfactory to be
copying such code from delete_from_swap_cache, but again judged easier
to sell than making its other callers go through the extras.
Remove the toy implementation's shmem_put_swap() and shmem_get_swap(),
now unreferenced, and the hack to disable swap: it's now good to go.
The way things have worked out, info->lock no longer helps to guard the
shmem_swaplist: we increment swapped under shmem_swaplist_mutex only.
That global mutex exclusion between shmem_writepage() and shmem_unuse()
is not pretty, and we ought to find another way; but it's been forced on
us by recent race discoveries, not a consequence of this patchset.
And what has become of the WARN_ON_ONCE(1) free_swap_and_cache() if a
swap entry was found already present? That's no longer possible, the
(unknown) one inserting this page into filecache would hit the swap
entry occupying that slot.
Remove mem_cgroup_shmem_charge_fallback(): it was only required when we
had to move swappage to filecache with GFP_NOWAIT.
Remove the GFP_NOWAIT special case from mem_cgroup_cache_charge(), by
moving its call out from shmem_add_to_page_cache() to two of thats three
callers. But leave it doing mem_cgroup_uncharge_cache_page() on error:
although asymmetrical, it's easier for all 3 callers to handle.
These two changes would also be appropriate if anyone were to start
using shmem_read_mapping_page_gfp() with GFP_NOWAIT.
Remove mem_cgroup_get_shmem_target(): mc_handle_file_pte() can test
radix_tree_exceptional_entry() to get what it needs for itself.
Convert shmem_getpage_gfp(), the engine-room of shmem, to expect page or
swap entry returned from radix tree by find_lock_page().
Whereas the repetitive old method proceeded mainly under info->lock,
dropping and repeating whenever one of the conditions needed was not
met, now we can proceed without it, leaving shmem_add_to_page_cache() to
check for a race.
This way there is no need to preallocate a page, no need for an early
radix_tree_preload(), no need for mem_cgroup_shmem_charge_fallback().
Move the error unwinding down to the bottom instead of repeating it
throughout. ENOSPC handling is a little different from before: there is
no longer any race between find_lock_page() and finding swap, but we can
arrive at ENOSPC before calling shmem_recalc_inode(), which might
occasionally discover freed space.
Be stricter to check i_size before returning. info->lock is used for
little but alloced, swapped, i_blocks updates. Move i_blocks updates
out from under the max_blocks check, so even an unlimited size=0 mount
can show accurate du.
