[ Upstream commit 8a8c35fadfaf55629a37ef1a8ead1b8fb32581d2 ]
Beginning at commit d52d3997f843 ("ipv6: Create percpu rt6_info"), the
following INFO splat is logged:
[ INFO: suspicious RCU usage. ]
4.1.0-rc7-next-20150612 #1 Not tainted
kernel/sched/core.c:7318 Illegal context switch in RCU-bh read-side critical section!
rcu_scheduler_active = 1, debug_locks = 0
3 locks held by systemd/1:
#0: (rtnl_mutex){+.+.+.}, at: [<ffffffff815f0c8f>] rtnetlink_rcv+0x1f/0x40
#1: (rcu_read_lock_bh){......}, at: [<ffffffff816a34e2>] ipv6_add_addr+0x62/0x540
#2: (addrconf_hash_lock){+...+.}, at: [<ffffffff816a3604>] ipv6_add_addr+0x184/0x540
stack backtrace:
CPU: 0 PID: 1 Comm: systemd Not tainted 4.1.0-rc7-next-20150612 #1
Hardware name: TOSHIBA TECRA A50-A/TECRA A50-A, BIOS Version 4.20 04/17/2014
Call Trace:
dump_stack+0x4c/0x6e
lockdep_rcu_suspicious+0xe7/0x120
___might_sleep+0x1d5/0x1f0
__might_sleep+0x4d/0x90
kmem_cache_alloc+0x47/0x250
create_object+0x39/0x2e0
kmemleak_alloc_percpu+0x61/0xe0
pcpu_alloc+0x370/0x630
Additional backtrace lines are truncated. In addition, the above splat
is followed by several "BUG: sleeping function called from invalid
context at mm/slub.c:1268" outputs. As suggested by Martin KaFai Lau,
these are the clue to the fix. Routine kmemleak_alloc_percpu() always
uses GFP_KERNEL for its allocations, whereas it should follow the gfp
from its callers.
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
Reviewed-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com>
Acked-by: Martin KaFai Lau <kafai@fb.com>
Cc: Martin KaFai Lau <kafai@fb.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: <stable@vger.kernel.org> [3.18+]
[ Upstream commit c5f3b1a51a591c18c8b33983908e7fdda6ae417e ]
The kmemleak scanning thread can run for minutes. Callbacks like
kmemleak_free() are allowed during this time, the race being taken care
of by the object->lock spinlock. Such lock also prevents a memory block
from being freed or unmapped while it is being scanned by blocking the
kmemleak_free() -> ... -> __delete_object() function until the lock is
released in scan_object().
When a kmemleak error occurs (e.g. it fails to allocate its metadata),
kmemleak_enabled is set and __delete_object() is no longer called on
freed objects. If kmemleak_scan is running at the same time,
kmemleak_free() no longer waits for the object scanning to complete,
allowing the corresponding memory block to be freed or unmapped (in the
case of vfree()). This leads to kmemleak_scan potentially triggering a
page fault.
This patch separates the kmemleak_free() enabling/disabling from the
overall kmemleak_enabled nob so that we can defer the disabling of the
object freeing tracking until the scanning thread completed. The
kmemleak_free_part() is deliberately ignored by this patch since this is
only called during boot before the scanning thread started.
Reported-by: Vignesh Radhakrishnan <vigneshr@codeaurora.org>
Tested-by: Vignesh Radhakrishnan <vigneshr@codeaurora.org>
[ Upstream commit 85bd839983778fcd0c1c043327b14a046e979b39 ]
Izumi found the following oops when hot re-adding a node:
BUG: unable to handle kernel paging request at ffffc90008963690
IP: __wake_up_bit+0x20/0x70
Oops: 0000 [#1] SMP
CPU: 68 PID: 1237 Comm: rs:main Q:Reg Not tainted 4.1.0-rc5 #80
Hardware name: FUJITSU PRIMEQUEST2800E/SB, BIOS PRIMEQUEST 2000 Series BIOS Version 1.87 04/28/2015
task: ffff880838df8000 ti: ffff880017b94000 task.ti: ffff880017b94000
RIP: 0010:[<ffffffff810dff80>] [<ffffffff810dff80>] __wake_up_bit+0x20/0x70
RSP: 0018:ffff880017b97be8 EFLAGS: 00010246
RAX: ffffc90008963690 RBX: 00000000003c0000 RCX: 000000000000a4c9
RDX: 0000000000000000 RSI: ffffea101bffd500 RDI: ffffc90008963648
RBP: ffff880017b97c08 R08: 0000000002000020 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: ffff8a0797c73800
R13: ffffea101bffd500 R14: 0000000000000001 R15: 00000000003c0000
FS: 00007fcc7ffff700(0000) GS:ffff880874800000(0000) knlGS:0000000000000000
CR2: ffffc90008963690 CR3: 0000000836761000 CR4: 00000000001407e0
Call Trace:
unlock_page+0x6d/0x70
generic_write_end+0x53/0xb0
xfs_vm_write_end+0x29/0x80 [xfs]
generic_perform_write+0x10a/0x1e0
xfs_file_buffered_aio_write+0x14d/0x3e0 [xfs]
xfs_file_write_iter+0x79/0x120 [xfs]
__vfs_write+0xd4/0x110
vfs_write+0xac/0x1c0
SyS_write+0x58/0xd0
system_call_fastpath+0x12/0x76
Code: 5d c3 66 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 55 48 89 e5 48 83 ec 20 65 48 8b 04 25 28 00 00 00 48 89 45 f8 31 c0 48 8d 47 48 <48> 39 47 48 48 c7 45 e8 00 00 00 00 48 c7 45 f0 00 00 00 00 48
RIP [<ffffffff810dff80>] __wake_up_bit+0x20/0x70
RSP <ffff880017b97be8>
Reproduce method (re-add a node)::
Hot-add nodeA --> remove nodeA --> hot-add nodeA (panic)
This seems an use-after-free problem, and the root cause is
zone->wait_table was not set to *NULL* after free it in
try_offline_node.
When hot re-add a node, we will reuse the pgdat of it, so does the zone
struct, and when add pages to the target zone, it will init the zone
first (including the wait_table) if the zone is not initialized. The
judgement of zone initialized is based on zone->wait_table:
static inline bool zone_is_initialized(struct zone *zone)
return !!zone->wait_table;
so if we do not set the zone->wait_table to *NULL* after free it, the
memory hotplug routine will skip the init of new zone when hot re-add
the node, and the wait_table still points to the freed memory, then we
will access the invalid address when trying to wake up the waiting
people after the i/o operation with the page is done, such as mentioned
above.
Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com>
Reported-by: Taku Izumi <izumi.taku@jp.fujitsu.com>
Reviewed by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Cc: Tang Chen <tangchen@cn.fujitsu.com>
[ Upstream commit b0dc2b9bb4ab782115b964310518ee0b17784277 ]
NUMA balancing is meant to be disabled by default on UMA machines but
the check is using nr_node_ids (highest node) instead of
num_online_nodes (online nodes).
The consequences are that a UMA machine with a node ID of 1 or higher
will enable NUMA balancing. This will incur useless overhead due to
minor faults with the impact depending on the workload. These are the
impact on the stats when running a kernel build on a single node machine
whose node ID happened to be 1:
vanilla patched
NUMA base PTE updates 5113158 0
NUMA huge PMD updates 643 0
NUMA page range updates 5442374 0
NUMA hint faults 2109622 0
NUMA hint local faults 2109622 0
NUMA hint local percent 100 100
NUMA pages migrated 0 0
Cc: <stable@vger.kernel.org> [3.8+]
[ Upstream commit 602498f9aa43d4951eece3fd6ad95a6d0a78d537 ]
If multiple soft offline events hit one free page/hugepage concurrently,
soft_offline_page() can handle the free page/hugepage multiple times,
which makes num_poisoned_pages counter increased more than once. This
patch fixes this wrong counting by checking TestSetPageHWPoison for normal
papes and by checking the return value of dequeue_hwpoisoned_huge_page()
for hugepages.
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Acked-by: Dean Nelson <dnelson@redhat.com>
Cc: <stable@vger.kernel.org> [3.14+]
[ Upstream commit 464d1387acb94dc43ba772b35242345e3d2ead1b ]
mm/page-writeback.c has several places where 1 is added to the divisor
to prevent division by zero exceptions; however, if the original
divisor is equivalent to -1, adding 1 leads to division by zero.
There are three places where +1 is used for this purpose - one in
pos_ratio_polynom() and two in bdi_position_ratio(). The second one
in bdi_position_ratio() actually triggered div-by-zero oops on a
machine running a 3.10 kernel. The divisor is
x_intercept - bdi_setpoint + 1 == span + 1
span is confirmed to be (u32)-1. It isn't clear how it ended up that
but it could be from write bandwidth calculation underflow fixed by
c72efb658f7c ("writeback: fix possible underflow in write bandwidth
calculation").
At any rate, +1 isn't a proper protection against div-by-zero. This
patch converts all +1 protections to |1. Note that
bdi_update_dirty_ratelimit() was already using |1 before this patch.
Cc: stable@vger.kernel.org
Signed-off-by: Jens Axboe <axboe@fb.com>
[ Upstream commit 09789e5de18e4e442870b2d700831f5cb802eb05 ]
Currently memory_failure() calls shake_page() to sweep pages out from
pcplists only when the victim page is 4kB LRU page or thp head page.
But we should do this for a thp tail page too.
Consider that a memory error hits a thp tail page whose head page is on
a pcplist when memory_failure() runs. Then, the current kernel skips
shake_pages() part, so hwpoison_user_mappings() returns without calling
split_huge_page() nor try_to_unmap() because PageLRU of the thp head is
still cleared due to the skip of shake_page().
As a result, me_huge_page() runs for the thp, which is broken behavior.
One effect is a leak of the thp. And another is to fail to isolate the
memory error, so later access to the error address causes another MCE,
which kills the processes which used the thp.
This patch fixes this problem by calling shake_page() for thp tail case.
Fixes: 385de35722c9 ("thp: allow a hwpoisoned head page to be put back to LRU")
Reviewed-by: Andi Kleen <ak@linux.intel.com>
Cc: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
Cc: Jin Dongming <jin.dongming@np.css.fujitsu.com>
Cc: <stable@vger.kernel.org> [3.4+]
[ Upstream commit e66f17ff71772b209eed39de35aaa99ba819c93d ]
We have a race condition between move_pages() and freeing hugepages, where
move_pages() calls follow_page(FOLL_GET) for hugepages internally and
tries to get its refcount without preventing concurrent freeing. This
race crashes the kernel, so this patch fixes it by moving FOLL_GET code
for hugepages into follow_huge_pmd() with taking the page table lock.
This patch intentionally removes page==NULL check after pte_page.
This is justified because pte_page() never returns NULL for any
architectures or configurations.
This patch changes the behavior of follow_huge_pmd() for tail pages and
then tail pages can be pinned/returned. So the caller must be changed to
properly handle the returned tail pages.
We could have a choice to add the similar locking to
follow_huge_(addr|pud) for consistency, but it's not necessary because
currently these functions don't support FOLL_GET flag, so let's leave it
for future development.
Here is the reproducer:
$ cat movepages.c
#include <stdio.h>
#include <stdlib.h>
#include <numaif.h>
#define ADDR_INPUT 0x700000000000UL
#define HPS 0x200000
#define PS 0x1000
int main(int argc, char *argv[]) {
int i;
int nr_hp = strtol(argv[1], NULL, 0);
int nr_p = nr_hp * HPS / PS;
int ret;
void **addrs;
int *status;
int *nodes;
pid_t pid;
pid = strtol(argv[2], NULL, 0);
addrs = malloc(sizeof(char *) * nr_p + 1);
status = malloc(sizeof(char *) * nr_p + 1);
nodes = malloc(sizeof(char *) * nr_p + 1);
while (1) {
for (i = 0; i < nr_p; i++) {
addrs[i] = (void *)ADDR_INPUT + i * PS;
nodes[i] = 1;
status[i] = 0;
ret = numa_move_pages(pid, nr_p, addrs, nodes, status,
MPOL_MF_MOVE_ALL);
if (ret == -1)
err("move_pages");
nodes[i] = 0;
status[i] = 0;
MPOL_MF_MOVE_ALL);
if (ret == -1)
err("move_pages");
return 0;
$ cat hugepage.c
#include <stdio.h>
#include <sys/mman.h>
#include <string.h>
char *p;
while (1) {
p = mmap((void *)ADDR_INPUT, nr_hp * HPS, PROT_READ | PROT_WRITE,
MAP_PRIVATE | MAP_ANONYMOUS | MAP_HUGETLB, -1, 0);
if (p != (void *)ADDR_INPUT) {
perror("mmap");
break;
memset(p, 0, nr_hp * HPS);
munmap(p, nr_hp * HPS);
$ sysctl vm.nr_hugepages=40
$ ./hugepage 10 &
$ ./movepages 10 $(pgrep -f hugepage)
Fixes: e632a938d914 ("mm: migrate: add hugepage migration code to move_pages()")
Reported-by: Hugh Dickins <hughd@google.com>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Luiz Capitulino <lcapitulino@redhat.com>
Cc: Nishanth Aravamudan <nacc@linux.vnet.ibm.com>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
Cc: Steve Capper <steve.capper@linaro.org>
Cc: <stable@vger.kernel.org> [3.12+]
[ Upstream commit 97534127012f0e396eddea4691f4c9b170aed74b ]
Commit 61f77eda9bbf ("mm/hugetlb: reduce arch dependent code around
follow_huge_*") broke follow_huge_pmd() on s390, where pmd and pte
layout differ and using pte_page() on a huge pmd will return wrong
results. Using pmd_page() instead fixes this.
All architectures that were touched by that commit have pmd_page()
defined, so this should not break anything on other architectures.
Fixes: 61f77eda "mm/hugetlb: reduce arch dependent code around follow_huge_*"
Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Acked-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Michal Hocko <mhocko@suse.cz>, Andrea Arcangeli <aarcange@redhat.com>
Acked-by: David Rientjes <rientjes@google.com>
[ Upstream commit 9ab3b598d2dfbdb0153ffa7e4b1456bbff59a25d ]
A race condition starts to be visible in recent mmotm, where a PG_hwpoison
flag is set on a migration source page *before* it's back in buddy page
poo= l.
This is problematic because no page flag is supposed to be set when
freeing (see __free_one_page().) So the user-visible effect of this race
is that it could trigger the BUG_ON() when soft-offlining is called.
The root cause is that we call lru_add_drain_all() to make sure that the
page is in buddy, but that doesn't work because this function just
schedule= s a work item and doesn't wait its completion.
drain_all_pages() does drainin= g directly, so simply dropping
lru_add_drain_all() solves this problem.
Fixes: f15bdfa802bf ("mm/memory-failure.c: fix memory leak in successful soft offlining")
Cc: Chen Gong <gong.chen@linux.intel.com>
Cc: <stable@vger.kernel.org> [3.11+]
[ Upstream commit c72efb658f7c8b27ca3d0efb5cfd5ded9fcac89e ]
From 1ebf33901ecc75d9496862dceb1ef0377980587c Mon Sep 17 00:00:00 2001
Date: Mon, 23 Mar 2015 00:08:19 -0400
2f800fbd777b ("writeback: fix dirtied pages accounting on redirty")
introduced account_page_redirty() which reverts stat updates for a
redirtied page, making BDI_DIRTIED no longer monotonically increasing.
bdi_update_write_bandwidth() uses the delta in BDI_DIRTIED as the
basis for bandwidth calculation. While unlikely, since the above
patch, the newer value may be lower than the recorded past value and
underflow the bandwidth calculation leading to a wild result.
Fix it by subtracing min of the old and new values when calculating
delta. AFAIK, there hasn't been any report of it happening but the
resulting erratic behavior would be non-critical and temporary, so
it's possible that the issue is happening without being reported. The
risk of the fix is very low, so tagged for -stable.
Cc: Jan Kara <jack@suse.cz>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Fixes: 2f800fbd777b ("writeback: fix dirtied pages accounting on redirty")
[ Upstream commit 7d70e15480c0450d2bfafaad338a32e884fc215e ]
global_update_bandwidth() uses static variable update_time as the
timestamp for the last update but forgets to initialize it to
INITIALIZE_JIFFIES.
This means that global_dirty_limit will be 5 mins into the future on
32bit and some large amount jiffies into the past on 64bit. This
isn't critical as the only effect is that global_dirty_limit won't be
updated for the first 5 mins after booting on 32bit machines,
especially given the auxiliary nature of global_dirty_limit's role -
protecting against global dirty threshold's sudden dips; however, it
does lead to unintended suboptimal behavior. Fix it.
Fixes: c42843f2f0bb ("writeback: introduce smoothed global dirty limit")
Acked-by: Jan Kara <jack@suse.cz>
[ Upstream commit cfa869438282be84ad4110bba5027ef1fbbe71e4 ]
Commit 3c605096d315 ("mm/page_alloc: restrict max order of merging on
isolated pageblock") changed the logic of unset_migratetype_isolate to
check the buddy allocator and explicitly call __free_pages to merge.
The page that is being freed in this path never had prep_new_page called
so set_page_refcounted is called explicitly but there is no call to
kernel_map_pages. With the default kernel_map_pages this is mostly
harmless but if kernel_map_pages does any manipulation of the page
tables (unmapping or setting pages to read only) this may trigger a
fault:
alloc_contig_range test_pages_isolated(ceb00, ced00) failed
Unable to handle kernel paging request at virtual address ffffffc0cec00000
pgd = ffffffc045fc4000
[ffffffc0cec00000] *pgd=0000000000000000
Internal error: Oops: 9600004f [#1] PREEMPT SMP
Modules linked in: exfatfs
CPU: 1 PID: 23237 Comm: TimedEventQueue Not tainted 3.10.49-gc72ad36-dirty #1
task: ffffffc03de52100 ti: ffffffc015388000 task.ti: ffffffc015388000
PC is at memset+0xc8/0x1c0
LR is at kernel_map_pages+0x1ec/0x244
Fix this by calling kernel_map_pages to ensure the page is set in the
page table properly
Fixes: 3c605096d315 ("mm/page_alloc: restrict max order of merging on isolated pageblock")
Signed-off-by: Laura Abbott <lauraa@codeaurora.org>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
Cc: Xishi Qiu <qiuxishi@huawei.com>
Cc: Vladimir Davydov <vdavydov@parallels.com>
Acked-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Gioh Kim <gioh.kim@lge.com>
Cc: Michal Nazarewicz <mina86@mina86.com>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
[ Upstream commit b0dc3a342af36f95a68fe229b8f0f73552c5ca08 ]
Qiu Xishi reported the following BUG when testing hot-add/hot-remove node under
stress condition:
BUG: unable to handle kernel paging request at 0000000000025f60
IP: next_online_pgdat+0x1/0x50
PGD 0
Oops: 0000 [#1] SMP
ACPI: Device does not support D3cold
Modules linked in: fuse nls_iso8859_1 nls_cp437 vfat fat loop dm_mod coretemp mperf crc32c_intel ghash_clmulni_intel aesni_intel ablk_helper cryptd lrw gf128mul glue_helper aes_x86_64 pcspkr microcode igb dca i2c_algo_bit ipv6 megaraid_sas iTCO_wdt i2c_i801 i2c_core iTCO_vendor_support tg3 sg hwmon ptp lpc_ich pps_core mfd_core acpi_pad rtc_cmos button ext3 jbd mbcache sd_mod crc_t10dif scsi_dh_alua scsi_dh_rdac scsi_dh_hp_sw scsi_dh_emc scsi_dh ahci libahci libata scsi_mod [last unloaded: rasf]
CPU: 23 PID: 238 Comm: kworker/23:1 Tainted: G O 3.10.15-5885-euler0302 #1
Hardware name: HUAWEI TECHNOLOGIES CO.,LTD. Huawei N1/Huawei N1, BIOS V100R001 03/02/2015
Workqueue: events vmstat_update
task: ffffa800d32c0000 ti: ffffa800d32ae000 task.ti: ffffa800d32ae000
RIP: 0010: next_online_pgdat+0x1/0x50
RSP: 0018:ffffa800d32afce8 EFLAGS: 00010286
RAX: 0000000000001440 RBX: ffffffff81da53b8 RCX: 0000000000000082
RDX: 0000000000000000 RSI: 0000000000000082 RDI: 0000000000000000
RBP: ffffa800d32afd28 R08: ffffffff81c93bfc R09: ffffffff81cbdc96
R10: 00000000000040ec R11: 00000000000000a0 R12: ffffa800fffb3440
R13: ffffa800d32afd38 R14: 0000000000000017 R15: ffffa800e6616800
FS: 0000000000000000(0000) GS:ffffa800e6600000(0000) knlGS:0000000000000000
CR2: 0000000000025f60 CR3: 0000000001a0b000 CR4: 00000000001407e0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Call Trace:
refresh_cpu_vm_stats+0xd0/0x140
vmstat_update+0x11/0x50
process_one_work+0x194/0x3d0
worker_thread+0x12b/0x410
kthread+0xc6/0xd0
ret_from_fork+0x7c/0xb0
The cause is the "memset(pgdat, 0, sizeof(*pgdat))" at the end of
try_offline_node, which will reset all the content of pgdat to 0, as the
pgdat is accessed lock-free, so that the users still using the pgdat
will panic, such as the vmstat_update routine.
process A: offline node XX:
vmstat_updat()
refresh_cpu_vm_stats()
for_each_populated_zone()
find online node XX
cond_resched()
offline cpu and memory, then try_offline_node()
node_set_offline(nid), and memset(pgdat, 0, sizeof(*pgdat))
zone = next_zone(zone)
pg_data_t *pgdat = zone->zone_pgdat; // here pgdat is NULL now
next_online_pgdat(pgdat)
next_online_node(pgdat->node_id); // NULL pointer access
So the solution here is postponing the reset of obsolete pgdat from
try_offline_node() to hotadd_new_pgdat(), and just resetting
pgdat->nr_zones and pgdat->classzone_idx to be 0 rather than the memset
0 to avoid breaking pointer information in pgdat.
Reported-by: Xishi Qiu <qiuxishi@huawei.com>
Suggested-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Taku Izumi <izumi.taku@jp.fujitsu.com>
Cc: Xie XiuQi <xiexiuqi@huawei.com>
[ Upstream commit 3fe89b3e2a7bbf3e97657104b9b33a9d81b950b3 ]
I have constantly stumbled upon "kernel BUG at mm/rmap.c:399!" after
upgrading to 3.19 and had no luck with 4.0-rc1 neither.
So, after looking into new logic introduced by commit 7a3ef208e662 ("mm:
prevent endless growth of anon_vma hierarchy"), I found chances are that
unlink_anon_vmas() is called without incrementing dst->anon_vma->degree
in anon_vma_clone() due to allocation failure. If dst->anon_vma is not
NULL in error path, its degree will be incorrectly decremented in
unlink_anon_vmas() and eventually underflow when exiting as a result of
another call to unlink_anon_vmas(). That's how "kernel BUG at
mm/rmap.c:399!" is triggered for me.
This patch fixes the underflow by dropping dst->anon_vma when allocation
fails. It's safe to do so regardless of original value of dst->anon_vma
because dst->anon_vma doesn't have valid meaning if anon_vma_clone()
fails. Besides, callers don't care dst->anon_vma in such case neither.
Also suggested by Michal Hocko, we can clean up vma_adjust() a bit as
anon_vma_clone() now does the work.
[akpm@linux-foundation.org: tweak comment]
Fixes: 7a3ef208e662 ("mm: prevent endless growth of anon_vma hierarchy")
Signed-off-by: Leon Yu <chianglungyu@gmail.com>
Signed-off-by: Konstantin Khlebnikov <koct9i@gmail.com>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
[ Upstream commit b800c91a0517071156e772d4fb329ad33590da62 ]
Fix for BUG_ON(anon_vma->degree) splashes in unlink_anon_vmas() ("kernel
BUG at mm/rmap.c:399!") caused by commit 7a3ef208e662 ("mm: prevent
Anon_vma_clone() is usually called for a copy of source vma in
destination argument. If source vma has anon_vma it should be already
in dst->anon_vma. NULL in dst->anon_vma is used as a sign that it's
called from anon_vma_fork(). In this case anon_vma_clone() finds
anon_vma for reusing.
Vma_adjust() calls it differently and this breaks anon_vma reusing
logic: anon_vma_clone() links vma to old anon_vma and updates degree
counters but vma_adjust() overrides vma->anon_vma right after that. As
a result final unlink_anon_vmas() decrements degree for wrong anon_vma.
This patch assigns ->anon_vma before calling anon_vma_clone().
Reported-and-tested-by: Chris Clayton <chris2553@googlemail.com>
Reported-and-tested-by: Oded Gabbay <oded.gabbay@amd.com>
Reported-and-tested-by: Chih-Wei Huang <cwhuang@android-x86.org>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Daniel Forrest <dan.forrest@ssec.wisc.edu>
Cc: stable@vger.kernel.org # to match back-porting of 7a3ef208e662
[ Upstream commit 7a3ef208e662f4b63d43a23f61a64a129c525bbc ]
Constantly forking task causes unlimited grow of anon_vma chain. Each
next child allocates new level of anon_vmas and links vma to all
previous levels because pages might be inherited from any level.
This patch adds heuristic which decides to reuse existing anon_vma
instead of forking new one. It adds counter anon_vma->degree which
counts linked vmas and directly descending anon_vmas and reuses anon_vma
if counter is lower than two. As a result each anon_vma has either vma
or at least two descending anon_vmas. In such trees half of nodes are
leafs with alive vmas, thus count of anon_vmas is no more than two times
bigger than count of vmas.
This heuristic reuses anon_vmas as few as possible because each reuse
adds false aliasing among vmas and rmap walker ought to scan more ptes
when it searches where page is might be mapped.
Link: http://lkml.kernel.org/r/20120816024610.GA5350@evergreen.ssec.wisc.edu
Fixes: 5beb49305251 ("mm: change anon_vma linking to fix multi-process server scalability issue")
[akpm@linux-foundation.org: fix typo, per Rik]
Reported-by: Daniel Forrest <dan.forrest@ssec.wisc.edu>
Tested-by: Michal Hocko <mhocko@suse.cz>
Tested-by: Jerome Marchand <jmarchan@redhat.com>
Cc: <stable@vger.kernel.org> [2.6.34+]
[ Upstream commit fb7332a9fedfd62b1ba6530c86f39f0fa38afd49 ]
On architectures with hardware broadcasting of TLB invalidation messages
, it makes sense to reduce the range of the mmu_gather structure when
unmapping page ranges based on the dirty address information passed to
tlb_remove_tlb_entry.
arm64 already does this by directly manipulating the start/end fields
of the gather structure, but this confuses the generic code which
does not expect these fields to change and can end up calculating
invalid, negative ranges when forcing a flush in zap_pte_range.
This patch moves the minimal range calculation out of the arm64 code
and into the generic implementation, simplifying zap_pte_range in the
process (which no longer needs to care about start/end, since they will
point to the appropriate ranges already). With the range being tracked
by core code, the need_flush flag is dropped in favour of checking that
the end of the range has actually been set.
Cc: Russell King - ARM Linux <linux@arm.linux.org.uk>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
commit ba4877b9ca51f80b5d30f304a46762f0509e1635 upstream.
Vinayak Menon has reported that an excessive number of tasks was throttled
in the direct reclaim inside too_many_isolated() because NR_ISOLATED_FILE
was relatively high compared to NR_INACTIVE_FILE. However it turned out
that the real number of NR_ISOLATED_FILE was 0 and the per-cpu
vm_stat_diff wasn't transferred into the global counter.
vmstat_work which is responsible for the sync is defined as deferrable
delayed work which means that the defined timeout doesn't wake up an idle
CPU. A CPU might stay in an idle state for a long time and general effort
is to keep such a CPU in this state as long as possible which might lead
to all sorts of troubles for vmstat consumers as can be seen with the
excessive direct reclaim throttling.
This patch basically reverts 39bf6270f524 ("VM statistics: Make timer
deferrable") but it shouldn't cause any problems for idle CPUs because
only CPUs with an active per-cpu drift are woken up since 7cc36bbddde5
("vmstat: on-demand vmstat workers v8") and CPUs which are idle for a
longer time shouldn't have per-cpu drift.
Fixes: 39bf6270f524 (VM statistics: Make timer deferrable)
Reported-by: Vinayak Menon <vinmenon@codeaurora.org>
Acked-by: Christoph Lameter <cl@linux.com>
Cc: Minchan Kim <minchan@kernel.org>
commit ff59909a077b3c51c168cb658601c6b63136a347 upstream.
The vmstat interfaces are good at hiding negative counts (at least when
CONFIG_SMP); but if you peer behind the curtain, you find that
nr_isolated_anon and nr_isolated_file soon go negative, and grow ever
more negative: so they can absorb larger and larger numbers of isolated
pages, yet still appear to be zero.
I'm happy to avoid a congestion_wait() when too_many_isolated() myself;
but I guess it's there for a good reason, in which case we ought to get
too_many_isolated() working again.
The imbalance comes from isolate_migratepages()'s ISOLATE_ABORT case:
putback_movable_pages() decrements the NR_ISOLATED counts, but we forgot
to call acct_isolated() to increment them.
It is possible that the bug whcih this patch fixes could cause OOM kills
when the system still has a lot of reclaimable page cache.
Fixes: edc2ca612496 ("mm, compaction: move pageblock checks up from isolate_migratepages_range()")
commit 9cb12d7b4ccaa976f97ce0c5fd0f1b6a83bc2a75 upstream.
For whatever reason, generic_access_phys() only remaps one page, but
actually allows to access arbitrary size. It's quite easy to trigger
large reads, like printing out large structure with gdb, which leads to a
crash. Fix it by remapping correct size.
Fixes: 28b2ee20c7cb ("access_process_vm device memory infrastructure")
Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
commit 372549c2a3778fd3df445819811c944ad54609ca upstream.
What we want to check here is whether there is highorder freepage in buddy
list of other migratetype in order to steal it without fragmentation.
But, current code just checks cc->order which means allocation request
order. So, this is wrong.
Without this fix, non-movable synchronous compaction below pageblock order
would not stopped until compaction is complete, because migratetype of
most pageblocks are movable and high order freepage made by compaction is
usually on movable type buddy list.
There is some report related to this bug. See below link.
http://www.spinics.net/lists/linux-mm/msg81666.html
Although the issued system still has load spike comes from compaction,
this makes that system completely stable and responsive according to his
report.
stress-highalloc test in mmtests with non movable order 7 allocation
doesn't show any notable difference in allocation success rate, but, it
shows more compaction success rate.
Compaction success rate (Compaction success * 100 / Compaction stalls, %)
18.47 : 28.94
Fixes: 1fb3f8ca0e92 ("mm: compaction: capture a suitable high-order page immediately when it is made available")
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Reviewed-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
commit 8138a67a5557ffea3a21dfd6f037842d4e748513 upstream.
I noticed that "allowed" can easily overflow by falling below 0, because
(total_vm / 32) can be larger than "allowed". The problem occurs in
OVERCOMMIT_NONE mode.
In this case, a huge allocation can success and overcommit the system
(despite OVERCOMMIT_NONE mode). All subsequent allocations will fall
(system-wide), so system become unusable.
The problem was masked out by commit c9b1d0981fcc
("mm: limit growth of 3% hardcoded other user reserve"),
but it's easy to reproduce it on older kernels:
1) set overcommit_memory sysctl to 2
2) mmap() large file multiple times (with VM_SHARED flag)
3) try to malloc() large amount of memory
It also can be reproduced on newer kernels, but miss-configured
sysctl_user_reserve_kbytes is required.
Fix this issue by switching to signed arithmetic here.
Signed-off-by: Roman Gushchin <klamm@yandex-team.ru>
Cc: Andrew Shewmaker <agshew@gmail.com>
Cc: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
commit 5703b087dc8eaf47bfb399d6cf512d471beff405 upstream.
I noticed, that "allowed" can easily overflow by falling below 0,
because (total_vm / 32) can be larger than "allowed". The problem
occurs in OVERCOMMIT_NONE mode.
[akpm@linux-foundation.org: use min_t]
commit 99592d598eca62bdbbf62b59941c189176dfc614 upstream.
When studying page stealing, I noticed some weird looking decisions in
try_to_steal_freepages(). The first I assume is a bug (Patch 1), the
following two patches were driven by evaluation.
Testing was done with stress-highalloc of mmtests, using the
mm_page_alloc_extfrag tracepoint and postprocessing to get counts of how
often page stealing occurs for individual migratetypes, and what
migratetypes are used for fallbacks. Arguably, the worst case of page
stealing is when UNMOVABLE allocation steals from MOVABLE pageblock.
RECLAIMABLE allocation stealing from MOVABLE allocation is also not ideal,
so the goal is to minimize these two cases.
The evaluation of v2 wasn't always clear win and Joonsoo questioned the
results. Here I used different baseline which includes RFC compaction
improvements from [1]. I found that the compaction improvements reduce
variability of stress-highalloc, so there's less noise in the data.
First, let's look at stress-highalloc configured to do sync compaction,
and how these patches reduce page stealing events during the test. First
column is after fresh reboot, other two are reiterations of test without
reboot. That was all accumulater over 5 re-iterations (so the benchmark
was run 5x3 times with 5 fresh restarts).
Baseline:
3.19-rc4 3.19-rc4 3.19-rc4
5-nothp-1 5-nothp-2 5-nothp-3
Page alloc extfrag event 10264225 8702233 10244125
Extfrag fragmenting 10263271 8701552 10243473
Extfrag fragmenting for unmovable 13595 17616 15960
Extfrag fragmenting unmovable placed with movable 7989 12193 8447
Extfrag fragmenting for reclaimable 658 1840 1817
Extfrag fragmenting reclaimable placed with movable 558 1677 1679
Extfrag fragmenting for movable 10249018 8682096 10225696
With Patch 1:
6-nothp-1 6-nothp-2 6-nothp-3
Page alloc extfrag event 11834954 9877523 9774860
Extfrag fragmenting 11833993 9876880 9774245
Extfrag fragmenting for unmovable 7342 16129 11712
Extfrag fragmenting unmovable placed with movable 4191 10547 6270
Extfrag fragmenting for reclaimable 373 1130 923
Extfrag fragmenting reclaimable placed with movable 302 906 738
Extfrag fragmenting for movable 11826278 9859621 9761610
With Patch 2:
7-nothp-1 7-nothp-2 7-nothp-3
Page alloc extfrag event 4725990 3668793 3807436
Extfrag fragmenting 4725104 3668252 3806898
Extfrag fragmenting for unmovable 6678 7974 7281
Extfrag fragmenting unmovable placed with movable 2051 3829 4017
Extfrag fragmenting for reclaimable 429 1208 1278
Extfrag fragmenting reclaimable placed with movable 369 976 1034
Extfrag fragmenting for movable 4717997 3659070 3798339
With Patch 3:
8-nothp-1 8-nothp-2 8-nothp-3
Page alloc extfrag event 5016183 4700142 3850633
Extfrag fragmenting 5015325 4699613 3850072
Extfrag fragmenting for unmovable 1312 3154 3088
Extfrag fragmenting unmovable placed with movable 1115 2777 2714
Extfrag fragmenting for reclaimable 437 1193 1097
Extfrag fragmenting reclaimable placed with movable 330 969 879
Extfrag fragmenting for movable 5013576 4695266 3845887
In v2 we've seen apparent regression with Patch 1 for unmovable events,
this is now gone, suggesting it was indeed noise. Here, each patch
improves the situation for unmovable events. Reclaimable is improved by
patch 1 and then either the same modulo noise, or perhaps sligtly worse -
a small price for unmovable improvements, IMHO. The number of movable
allocations falling back to other migratetypes is most noisy, but it's
reduced to half at Patch 2 nevertheless. These are least critical as
compaction can move them around.
If we look at success rates, the patches don't affect them, that didn't change.
Baseline:
Success 1 Min 49.00 ( 0.00%) 42.00 ( 14.29%) 41.00 ( 16.33%)
Success 1 Mean 51.00 ( 0.00%) 45.00 ( 11.76%) 42.60 ( 16.47%)
Success 1 Max 55.00 ( 0.00%) 51.00 ( 7.27%) 46.00 ( 16.36%)
Success 2 Min 53.00 ( 0.00%) 47.00 ( 11.32%) 44.00 ( 16.98%)
Success 2 Mean 59.60 ( 0.00%) 50.80 ( 14.77%) 48.20 ( 19.13%)
Success 2 Max 64.00 ( 0.00%) 56.00 ( 12.50%) 52.00 ( 18.75%)
Success 3 Min 84.00 ( 0.00%) 82.00 ( 2.38%) 78.00 ( 7.14%)
Success 3 Mean 85.60 ( 0.00%) 82.80 ( 3.27%) 79.40 ( 7.24%)
Success 3 Max 86.00 ( 0.00%) 83.00 ( 3.49%) 80.00 ( 6.98%)
Patch 1:
Success 1 Min 49.00 ( 0.00%) 44.00 ( 10.20%) 44.00 ( 10.20%)
Success 1 Mean 51.80 ( 0.00%) 46.00 ( 11.20%) 45.80 ( 11.58%)
Success 1 Max 54.00 ( 0.00%) 49.00 ( 9.26%) 49.00 ( 9.26%)
Success 2 Min 58.00 ( 0.00%) 49.00 ( 15.52%) 48.00 ( 17.24%)
Success 2 Mean 60.40 ( 0.00%) 51.80 ( 14.24%) 50.80 ( 15.89%)
Success 2 Max 63.00 ( 0.00%) 54.00 ( 14.29%) 55.00 ( 12.70%)
Success 3 Min 84.00 ( 0.00%) 81.00 ( 3.57%) 79.00 ( 5.95%)
Success 3 Mean 85.00 ( 0.00%) 81.60 ( 4.00%) 79.80 ( 6.12%)
Success 3 Max 86.00 ( 0.00%) 82.00 ( 4.65%) 82.00 ( 4.65%)
Patch 2:
Success 1 Min 50.00 ( 0.00%) 44.00 ( 12.00%) 39.00 ( 22.00%)
Success 1 Mean 52.80 ( 0.00%) 45.60 ( 13.64%) 42.40 ( 19.70%)
Success 1 Max 55.00 ( 0.00%) 46.00 ( 16.36%) 47.00 ( 14.55%)
Success 2 Min 52.00 ( 0.00%) 48.00 ( 7.69%) 45.00 ( 13.46%)
Success 2 Mean 53.40 ( 0.00%) 49.80 ( 6.74%) 48.80 ( 8.61%)
Success 2 Max 57.00 ( 0.00%) 52.00 ( 8.77%) 52.00 ( 8.77%)
Success 3 Mean 85.00 ( 0.00%) 82.40 ( 3.06%) 79.60 ( 6.35%)
Patch 3:
Success 1 Min 46.00 ( 0.00%) 44.00 ( 4.35%) 42.00 ( 8.70%)
Success 1 Mean 50.20 ( 0.00%) 45.60 ( 9.16%) 44.00 ( 12.35%)
Success 1 Max 52.00 ( 0.00%) 47.00 ( 9.62%) 47.00 ( 9.62%)
Success 2 Min 53.00 ( 0.00%) 49.00 ( 7.55%) 48.00 ( 9.43%)
Success 2 Mean 55.80 ( 0.00%) 50.60 ( 9.32%) 49.00 ( 12.19%)
Success 2 Max 59.00 ( 0.00%) 52.00 ( 11.86%) 51.00 ( 13.56%)
Success 3 Min 84.00 ( 0.00%) 80.00 ( 4.76%) 79.00 ( 5.95%)
Success 3 Mean 85.40 ( 0.00%) 81.60 ( 4.45%) 80.40 ( 5.85%)
Success 3 Max 87.00 ( 0.00%) 83.00 ( 4.60%) 82.00 ( 5.75%)
While there's no improvement here, I consider reduced fragmentation events
to be worth on its own. Patch 2 also seems to reduce scanning for free
pages, and migrations in compaction, suggesting it has somewhat less work
to do:
Patch 1:
Compaction stalls 4153 3959 3978
Compaction success 1523 1441 1446
Compaction failures 2630 2517 2531
Page migrate success 4600827 4943120 5104348
Page migrate failure 19763 16656 17806
Compaction pages isolated 9597640 10305617 10653541
Compaction migrate scanned 77828948 86533283 87137064
Compaction free scanned 517758295 521312840 521462251
Compaction cost 5503 5932 6110
Patch 2:
Compaction stalls 3800 3450 3518
Compaction success 1421 1316 1317
Compaction failures 2379 2134 2201
Page migrate success 4160421 4502708 4752148
Page migrate failure 19705 14340 14911
Compaction pages isolated 8731983 9382374 9910043
Compaction migrate scanned 98362797 96349194 98609686
Compaction free scanned 496512560 469502017 480442545
Compaction cost 5173 5526 5811
As with v2, /proc/pagetypeinfo appears unaffected with respect to numbers
of unmovable and reclaimable pageblocks.
Configuring the benchmark to allocate like THP page fault (i.e. no sync
compaction) gives much noisier results for iterations 2 and 3 after
reboot. This is not so surprising given how [1] offers lower improvements
in this scenario due to less restarts after deferred compaction which
would change compaction pivot.
Baseline:
5-thp-1 5-thp-2 5-thp-3
Page alloc extfrag event 8148965 6227815 6646741
Extfrag fragmenting 8147872 6227130 6646117
Extfrag fragmenting for unmovable 10324 12942 15975
Extfrag fragmenting unmovable placed with movable 5972 8495 10907
Extfrag fragmenting for reclaimable 601 1707 2210
Extfrag fragmenting reclaimable placed with movable 520 1570 2000
Extfrag fragmenting for movable 8136947 6212481 6627932
Patch 1:
6-thp-1 6-thp-2 6-thp-3
Page alloc extfrag event 8345457 7574471 7020419
Extfrag fragmenting 8343546 7573777 7019718
Extfrag fragmenting for unmovable 10256 18535 30716
Extfrag fragmenting unmovable placed with movable 6893 11726 22181
Extfrag fragmenting for reclaimable 465 1208 1023
Extfrag fragmenting reclaimable placed with movable 353 996 843
Extfrag fragmenting for movable 8332825 7554034 6987979
Patch 2:
7-thp-1 7-thp-2 7-thp-3
Page alloc extfrag event 3512847 3020756 2891625
Extfrag fragmenting 3511940 3020185 2891059
Extfrag fragmenting for unmovable 9017 6892 6191
Extfrag fragmenting unmovable placed with movable 1524 3053 2435
Extfrag fragmenting for reclaimable 445 1081 1160
Extfrag fragmenting reclaimable placed with movable 375 918 986
Extfrag fragmenting for movable 3502478 3012212 2883708
Patch 3:
8-thp-1 8-thp-2 8-thp-3
Page alloc extfrag event 3181699 3082881 2674164
Extfrag fragmenting 3180812 3082303 2673611
Extfrag fragmenting for unmovable 1201 4031 4040
Extfrag fragmenting unmovable placed with movable 974 3611 3645
Extfrag fragmenting for reclaimable 478 1165 1294
Extfrag fragmenting reclaimable placed with movable 387 985 1030
Extfrag fragmenting for movable 3179133 3077107 2668277
The improvements for first iteration are clear, the rest is much noisier
and can appear like regression for Patch 1. Anyway, patch 2 rectifies it.
Allocation success rates are again unaffected so there's no point in
making this e-mail any longer.
[1] http://marc.info/?l=linux-mm&m=142166196321125&w=2
This patch (of 3):
When __rmqueue_fallback() is called to allocate a page of order X, it will
find a page of order Y >= X of a fallback migratetype, which is different
from the desired migratetype. With the help of try_to_steal_freepages(),
it may change the migratetype (to the desired one) also of:
1) all currently free pages in the pageblock containing the fallback page
2) the fallback pageblock itself
3) buddy pages created by splitting the fallback page (when Y > X)
These decisions take the order Y into account, as well as the desired
migratetype, with the goal of preventing multiple fallback allocations
that could e.g. distribute UNMOVABLE allocations among multiple
pageblocks.
Originally, decision for 1) has implied the decision for 3). Commit
47118af076f6 ("mm: mmzone: MIGRATE_CMA migration type added") changed that
(probably unintentionally) so that the buddy pages in case 3) are always
changed to the desired migratetype, except for CMA pageblocks.
Commit fef903efcf0c ("mm/page_allo.c: restructure free-page stealing code
and fix a bug") did some refactoring and added a comment that the case of
3) is intended. Commit 0cbef29a7821 ("mm: __rmqueue_fallback() should
respect pageblock type") removed the comment and tried to restore the
original behavior where 1) implies 3), but due to the previous
refactoring, the result is instead that only 2) implies 3) - and the
conditions for 2) are less frequently met than conditions for 1). This
may increase fragmentation in situations where the code decides to steal
all free pages from the pageblock (case 1)), but then gives back the buddy
pages produced by splitting.
This patch restores the original intended logic where 1) implies 3).
During testing with stress-highalloc from mmtests, this has shown to
decrease the number of events where UNMOVABLE and RECLAIMABLE allocations
steal from MOVABLE pageblocks, which can lead to permanent fragmentation.
In some cases it has increased the number of events when MOVABLE
allocations steal from UNMOVABLE or RECLAIMABLE pageblocks, but these are
fixable by sync compaction and thus less harmful.
Note that evaluation has shown that the behavior introduced by
47118af076f6 for buddy pages in case 3) is actually even better than the
original logic, so the following patch will introduce it properly once
again. For stable backports of this patch it makes thus sense to only fix
versions containing 0cbef29a7821.
[iamjoonsoo.kim@lge.com: tracepoint fix]
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
Acked-by: Minchan Kim <minchan@kernel.org>
Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
commit 9fbc1f635fd0bd28cb32550211bf095753ac637a upstream.
If __unmap_hugepage_range() tries to unmap the address range over which
hugepage migration is on the way, we get the wrong page because pte_page()
doesn't work for migration entries. This patch simply clears the pte for
migration entries as we do for hwpoison entries.
Fixes: 290408d4a2 ("hugetlb: hugepage migration core")
commit a8bda28d87c38c6aa93de28ba5d30cc18e865a11 upstream.
There is a race condition between hugepage migration and
change_protection(), where hugetlb_change_protection() doesn't care about
migration entries and wrongly overwrites them. That causes unexpected
results like kernel crash. HWPoison entries also can cause the same
problem.
This patch adds is_hugetlb_entry_(migration|hwpoisoned) check in this
function to do proper actions.
commit 0f792cf949a0be506c2aa8bfac0605746b146dda upstream.
When running the test which causes the race as shown in the previous patch,
we can hit the BUG "get_page() on refcount 0 page" in hugetlb_fault().
This race happens when pte turns into migration entry just after the first
check of is_hugetlb_entry_migration() in hugetlb_fault() passed with false.
To fix this, we need to check pte_present() again after huge_ptep_get().
This patch also reorders taking ptl and doing pte_page(), because
pte_page() should be done in ptl. Due to this reordering, we need use
trylock_page() in page != pagecache_page case to respect locking order.
Fixes: 66aebce747ea ("hugetlb: fix race condition in hugetlb_fault()")
commit cbef8478bee55775ac312a574aad48af7bb9cf9f upstream.
Migrating hugepages and hwpoisoned hugepages are considered as non-present
hugepages, and they are referenced via migration entries and hwpoison
entries in their page table slots.
This behavior causes race condition because pmd_huge() doesn't tell
non-huge pages from migrating/hwpoisoned hugepages. follow_page_mask() is
one example where the kernel would call follow_page_pte() for such
hugepage while this function is supposed to handle only normal pages.
To avoid this, this patch makes pmd_huge() return true when pmd_none() is
true *and* pmd_present() is false. We don't have to worry about mixing up
non-present pmd entry with normal pmd (pointing to leaf level pte entry)
because pmd_present() is true in normal pmd.
The same race condition could happen in (x86-specific) gup_pmd_range(),
where this patch simply adds pmd_present() check instead of pmd_huge().
This is because gup_pmd_range() is fast path. If we have non-present
hugepage in this function, we will go into gup_huge_pmd(), then return 0
at flag mask check, and finally fall back to the slow path.
commit f5e03a4989e80a86f8b514659dca8539132e6e09 upstream.
It has been reported that 965GM might trigger
VM_BUG_ON_PAGE(!lrucare && PageLRU(oldpage), oldpage)
in mem_cgroup_migrate when shmem wants to replace a swap cache page
because of shmem_should_replace_page (the page is allocated from an
inappropriate zone). shmem_replace_page expects that the oldpage is not
on LRU list and calls mem_cgroup_migrate without lrucare. This is
obviously incorrect because swapcache pages might be on the LRU list
(e.g. swapin readahead page).
Fix this by enabling lrucare for the migration in shmem_replace_page.
Also clarify that lrucare should be used even if one of the pages might
be on LRU list.
The BUG_ON will trigger only when CONFIG_DEBUG_VM is enabled but even
without that the migration code might leave the old page on an
inappropriate memcg' LRU which is not that critical because the page
would get removed with its last reference but it is still confusing.
Fixes: 0a31bc97c80c ("mm: memcontrol: rewrite uncharge API")
Reported-by: Chris Wilson <chris@chris-wilson.co.uk>
Reported-by: Dave Airlie <airlied@gmail.com>
commit 23aaed6659df9adfabe9c583e67a36b54e21df46 upstream.
walk_page_range() silently skips vma having VM_PFNMAP set, which leads
to undesirable behaviour at client end (who called walk_page_range).
Userspace applications get the wrong data, so the effect is like just
confusing users (if the applications just display the data) or sometimes
killing the processes (if the applications do something with
misunderstanding virtual addresses due to the wrong data.)
For example for pagemap_read, when no callbacks are called against
VM_PFNMAP vma, pagemap_read may prepare pagemap data for next virtual
address range at wrong index.
Eventually userspace may get wrong pagemap data for a task.
Corresponding to a VM_PFNMAP marked vma region, kernel may report
mappings from subsequent vma regions. User space in turn may account
more pages (than really are) to the task.
In my case I was using procmem, procrack (Android utility) which uses
pagemap interface to account RSS pages of a task. Due to this bug it
was giving a wrong picture for vmas (with VM_PFNMAP set).
Fixes: a9ff785e4437 ("mm/pagewalk.c: walk_page_range should avoid VM_PFNMAP areas")
Signed-off-by: Shiraz Hashim <shashim@codeaurora.org>
commit 0346dadbf041a2606bcb5bd27828b0d105897f4a upstream.
Commit e61734c55c24 ("cgroup: remove cgroup->name") added two extra
newlines to memcg oom kill log messages. This makes dmesg hard to read
and parse. The issue affects 3.15+.
Example:
Task in /t <<< extra #1
killed as a result of limit of /t
<<< extra #2
memory: usage 102400kB, limit 102400kB, failcnt 274712
Remove the extra newlines from memcg oom kill messages, so the messages
look like:
Task in /t killed as a result of limit of /t
memory: usage 102400kB, limit 102400kB, failcnt 240649
Fixes: e61734c55c24 ("cgroup: remove cgroup->name")
Signed-off-by: Greg Thelen <gthelen@google.com>
Acked-by: Michal Hocko <mhocko@suse.cz>
commit 9c145c56d0c8a0b62e48c8d71e055ad0fb2012ba upstream.
The stack guard page error case has long incorrectly caused a SIGBUS
rather than a SIGSEGV, but nobody actually noticed until commit
fee7e49d4514 ("mm: propagate error from stack expansion even for guard
page") because that error case was never actually triggered in any
normal situations.
Now that we actually report the error, people noticed the wrong signal
that resulted. So far, only the test suite of libsigsegv seems to have
actually cared, but there are real applications that use libsigsegv, so
let's not wait for any of those to break.
Reported-and-tested-by: Takashi Iwai <tiwai@suse.de>
Tested-by: Jan Engelhardt <jengelh@inai.de>
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> # "s390 still compiles and boots"
commit 33692f27597fcab536d7cbbcc8f52905133e4aa7 upstream.
The core VM already knows about VM_FAULT_SIGBUS, but cannot return a
"you should SIGSEGV" error, because the SIGSEGV case was generally
handled by the caller - usually the architecture fault handler.
That results in lots of duplication - all the architecture fault
handlers end up doing very similar "look up vma, check permissions, do
retries etc" - but it generally works. However, there are cases where
the VM actually wants to SIGSEGV, and applications _expect_ SIGSEGV.
In particular, when accessing the stack guard page, libsigsegv expects a
SIGSEGV. And it usually got one, because the stack growth is handled by
that duplicated architecture fault handler.
However, when the generic VM layer started propagating the error return
from the stack expansion in commit fee7e49d4514 ("mm: propagate error
from stack expansion even for guard page"), that now exposed the
existing VM_FAULT_SIGBUS result to user space. And user space really
expected SIGSEGV, not SIGBUS.
To fix that case, we need to add a VM_FAULT_SIGSEGV, and teach all those
duplicate architecture fault handlers about it. They all already have
the code to handle SIGSEGV, so it's about just tying that new return
value to the existing code, but it's all a bit annoying.
This is the mindless minimal patch to do this. A more extensive patch
would be to try to gather up the mostly shared fault handling logic into
one generic helper routine, and long-term we really should do that
cleanup.
Just from this patch, you can generally see that most architectures just
copied (directly or indirectly) the old x86 way of doing things, but in
the meantime that original x86 model has been improved to hold the VM
semaphore for shorter times etc and to handle VM_FAULT_RETRY and other
"newer" things, so it would be a good idea to bring all those
improvements to the generic case and teach other architectures about
them too.
commit 45f87de57f8fad59302fd263dd81ffa4843b5b24 upstream.
Commit 2457aec63745 ("mm: non-atomically mark page accessed during page
cache allocation where possible") has added a separate parameter for
specifying gfp mask for radix tree allocations.
Not only this is less than optimal from the API point of view because it
is error prone, it is also buggy currently because
grab_cache_page_write_begin is using GFP_KERNEL for radix tree and if
fgp_flags doesn't contain FGP_NOFS (mostly controlled by fs by
AOP_FLAG_NOFS flag) but the mapping_gfp_mask has __GFP_FS cleared then
the radix tree allocation wouldn't obey the restriction and might
recurse into filesystem and cause deadlocks. This is the case for most
filesystems unfortunately because only ext4 and gfs2 are using
AOP_FLAG_NOFS.
Let's simply remove radix_gfp_mask parameter because the allocation
context is same for both page cache and for the radix tree. Just make
sure that the radix tree gets only the sane subset of the mask (e.g. do
not pass __GFP_WRITE).
Long term it is more preferable to convert remaining users of
AOP_FLAG_NOFS to use mapping_gfp_mask instead and simplify this
interface even further.
Reported-by: Dave Chinner <david@fromorbit.com>
commit 690eac53daff34169a4d74fc7bfbd388c4896abb upstream.
Commit fee7e49d4514 ("mm: propagate error from stack expansion even for
guard page") made sure that we return the error properly for stack
growth conditions. It also theorized that counting the guard page
towards the stack limit might break something, but also said "Let's see
if anybody notices".
Somebody did notice. Apparently android-x86 sets the stack limit very
close to the limit indeed, and including the guard page in the rlimit
check causes the android 'zygote' process problems.
So this adds the (fairly trivial) code to make the stack rlimit check be
against the actual real stack size, rather than the size of the vma that
includes the guard page.
Cc: Jay Foad <jay.foad@gmail.com>
commit fee7e49d45149fba60156f5b59014f764d3e3728 upstream.
Jay Foad reports that the address sanitizer test (asan) sometimes gets
confused by a stack pointer that ends up being outside the stack vma
that is reported by /proc/maps.
This happens due to an interaction between RLIMIT_STACK and the guard
page: when we do the guard page check, we ignore the potential error
from the stack expansion, which effectively results in a missing guard
page, since the expected stack expansion won't have been done.
And since /proc/maps explicitly ignores the guard page (commit
d7824370e263: "mm: fix up some user-visible effects of the stack guard
page"), the stack pointer ends up being outside the reported stack area.
This is the minimal patch: it just propagates the error. It also
effectively makes the guard page part of the stack limit, which in turn
measn that the actual real stack is one page less than the stack limit.
Let's see if anybody notices. We could teach acct_stack_growth() to
allow an extra page for a grow-up/grow-down stack in the rlimit test,
but I don't want to add more complexity if it isn't needed.
Reported-and-tested-by: Jay Foad <jay.foad@gmail.com>
being killed
commit 9e5e3661727eaf960d3480213f8e87c8d67b6956 upstream.
Charles Shirron and Paul Cassella from Cray Inc have reported kswapd
stuck in a busy loop with nothing left to balance, but
kswapd_try_to_sleep() failing to sleep. Their analysis found the cause
to be a combination of several factors:
1. A process is waiting in throttle_direct_reclaim() on pgdat->pfmemalloc_wait
2. The process has been killed (by OOM in this case), but has not yet been
scheduled to remove itself from the waitqueue and die.
3. kswapd checks for throttled processes in prepare_kswapd_sleep():
if (waitqueue_active(&pgdat->pfmemalloc_wait)) {
wake_up(&pgdat->pfmemalloc_wait);
return false; // kswapd will not go to sleep
However, for a process that was already killed, wake_up() does not remove
the process from the waitqueue, since try_to_wake_up() checks its state
first and returns false when the process is no longer waiting.
4. kswapd is running on the same CPU as the only CPU that the process is
allowed to run on (through cpus_allowed, or possibly single-cpu system).
5. CONFIG_PREEMPT_NONE=y kernel is used. If there's nothing to balance, kswapd
encounters no voluntary preemption points and repeatedly fails
prepare_kswapd_sleep(), blocking the process from running and removing
itself from the waitqueue, which would let kswapd sleep.
So, the source of the problem is that we prevent kswapd from going to
sleep until there are processes waiting on the pfmemalloc_wait queue,
and a process waiting on a queue is guaranteed to be removed from the
queue only when it gets scheduled. This was done to make sure that no
process is left sleeping on pfmemalloc_wait when kswapd itself goes to
sleep.
However, it isn't necessary to postpone kswapd sleep until the
pfmemalloc_wait queue actually empties. To prevent processes from being
left sleeping, it's actually enough to guarantee that all processes
waiting on pfmemalloc_wait queue have been woken up by the time we put
kswapd to sleep.
This patch therefore fixes this issue by substituting 'wake_up' with
'wake_up_all' and removing 'return false' in the code snippet from
prepare_kswapd_sleep() above. Note that if any process puts itself in
the queue after this waitqueue_active() check, or after the wake up
itself, it means that the process will also wake up kswapd - and since
we are under prepare_to_wait(), the wake up won't be missed. Also we
update the comment prepare_kswapd_sleep() to hopefully more clearly
describe the races it is preventing.
Fixes: 5515061d22f0 ("mm: throttle direct reclaimers if PF_MEMALLOC reserves are low and swap is backed by network storage")
Signed-off-by: Vladimir Davydov <vdavydov@parallels.com>
commit 2d6d7f98284648c5ed113fe22a132148950b140f upstream.
Tejun, while reviewing the code, spotted the following race condition
between the dirtying and truncation of a page:
__set_page_dirty_nobuffers() __delete_from_page_cache()
if (TestSetPageDirty(page))
page->mapping = NULL
if (PageDirty())
dec_zone_page_state(page, NR_FILE_DIRTY);
dec_bdi_stat(mapping->backing_dev_info, BDI_RECLAIMABLE);
if (page->mapping)
account_page_dirtied(page)
__inc_zone_page_state(page, NR_FILE_DIRTY);
__inc_bdi_stat(mapping->backing_dev_info, BDI_RECLAIMABLE);
which results in an imbalance of NR_FILE_DIRTY and BDI_RECLAIMABLE.
Dirtiers usually lock out truncation, either by holding the page lock
directly, or in case of zap_pte_range(), by pinning the mapcount with
the page table lock held. The notable exception to this rule, though,
is do_wp_page(), for which this race exists. However, do_wp_page()
already waits for a locked page to unlock before setting the dirty bit,
in order to prevent a race where clear_page_dirty() misses the page bit
in the presence of dirty ptes. Upgrade that wait to a fully locked
set_page_dirty() to also cover the situation explained above.
Afterwards, the code in set_page_dirty() dealing with a truncation race
is no longer needed. Remove it.
Reported-by: Tejun Heo <tj@kernel.org>
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
commit 6b101e2a3ce4d2a0312087598bd1ab4a1db2ac40 upstream.
high_memory isn't direct mapped memory so retrieving it's physical address
isn't appropriate. But, it would be useful to check physical address of
highmem boundary so it's justfiable to get physical address from it. In
x86, there is a validation check if CONFIG_DEBUG_VIRTUAL and it triggers
following boot failure reported by Ingo.
BUG: Int 6: CR2 00f06f53
Call Trace:
dump_stack+0x41/0x52
early_idt_handler+0x6b/0x6b
cma_declare_contiguous+0x33/0x212
dma_contiguous_reserve_area+0x31/0x4e
dma_contiguous_reserve+0x11d/0x125
setup_arch+0x7b5/0xb63
start_kernel+0xb8/0x3e6
i386_start_kernel+0x79/0x7d
To fix boot regression, this patch implements workaround to avoid
validation check in x86 when retrieving physical address of high_memory.
__pa_nodebug() used by this patch is implemented only in x86 so there is
no choice but to use dirty #ifdef.
Reported-by: Ingo Molnar <mingo@kernel.org>
Tested-by: Ingo Molnar <mingo@kernel.org>
The bounds check for nodeid in ____cache_alloc_node gives false
positives on machines where the node IDs are not contiguous, leading to
a panic at boot time. For example, on a POWER8 machine the node IDs are
typically 0, 1, 16 and 17. This means that num_online_nodes() returns
4, so when ____cache_alloc_node is called with nodeid = 16 the VM_BUG_ON
triggers, like this:
kernel BUG at /home/paulus/kernel/kvm/mm/slab.c:3079!
Call Trace:
.____cache_alloc_node+0x5c/0x270 (unreliable)
.kmem_cache_alloc_node_trace+0xdc/0x360
.init_list+0x3c/0x128
.kmem_cache_init+0x1dc/0x258
.start_kernel+0x2a0/0x568
start_here_common+0x20/0xa8
To fix this, we instead compare the nodeid with MAX_NUMNODES, and
additionally make sure it isn't negative (since nodeid is an int). The
check is there mainly to protect the array dereference in the get_node()
call in the next line, and the array being dereferenced is of size
MAX_NUMNODES. If the nodeid is in range but invalid (for example if the
node is off-line), the BUG_ON in the next line will catch that.
Fixes: 14e50c6a9bc2 ("mm: slab: Verify the nodeid passed to ____cache_alloc_node")
Reviewed-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Reviewed-by: Pekka Enberg <penberg@kernel.org>
Cc: Christoph Lameter <cl@linux.com>
Andrew Morton noticed that the error return from anon_vma_clone() was
being dropped and replaced with -ENOMEM (which is not itself a bug
because the only error return value from anon_vma_clone() is -ENOMEM).
I did an audit of callers of anon_vma_clone() and discovered an actual
bug where the error return was being lost. In __split_vma(), between
Linux 3.11 and 3.12 the code was changed so the err variable is used
before the call to anon_vma_clone() and the default initial value of
-ENOMEM is overwritten. So a failure of anon_vma_clone() will return
success since err at this point is now zero.
Below is a patch which fixes this bug and also propagates the error
return value from anon_vma_clone() in all cases.
Fixes: ef0855d334e1 ("mm: mempolicy: turn vma_set_policy() into vma_dup_policy()")
Signed-off-by: Daniel Forrest <dan.forrest@ssec.wisc.edu>
Cc: Konstantin Khlebnikov <koct9i@gmail.com>
Cc: Tim Hartrick <tim@edgecast.com>
Cc: Michel Lespinasse <walken@google.com>
I've been seeing swapoff hangs in recent testing: it's cycling around
trying unsuccessfully to find an mm for some remaining pages of swap.
I have been exercising swap and page migration more heavily recently,
and now notice a long-standing error in copy_one_pte(): it's trying to
add dst_mm to swapoff's mmlist when it finds a swap entry, but is doing
so even when it's a migration entry or an hwpoison entry.
Which wouldn't matter much, except it adds dst_mm next to src_mm,
assuming src_mm is already on the mmlist: which may not be so. Then if
pages are later swapped out from dst_mm, swapoff won't be able to find
where to replace them.
There's already a !non_swap_entry() test for stats: move that up before
the swap_duplicate() and the addition to mmlist.
Cc: Kelley Nielsen <kelleynnn@gmail.com>
Cc: <stable@vger.kernel.org> [2.6.18+]
In some android devices, there will be a "divide by zero" exception.
vmpr->scanned could be zero before spin_lock(&vmpr->sr_lock).
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=88051
[akpm@linux-foundation.org: neaten]
Reported-by: ji_ang <ji_ang@163.com>
Cc: Anton Vorontsov <anton.vorontsov@linaro.org>
If a frontswap dup-store failed, it should invalidate the expired page
in the backend, or it could trigger some data corruption issue.
Such as:
1. use zswap as the frontswap backend with writeback feature
2. store a swap page(version_1) to entry A, success
3. dup-store a newer page(version_2) to the same entry A, fail
4. use __swap_writepage() write version_2 page to swapfile, success
5. zswap do shrink, writeback version_1 page to swapfile
6. version_2 page is overwrited by version_1, data corrupt.
This patch fixes this issue by invalidating expired data immediately
when meet a dup-store failure.
Signed-off-by: Weijie Yang <weijie.yang@samsung.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Seth Jennings <sjennings@variantweb.net>
Cc: Dan Streetman <ddstreet@ieee.org>
Cc: Bob Liu <bob.liu@oracle.com>
Pull vfs fix from Al Viro:
"Fix for a really embarrassing braino in iov_iter. Kudos to paulus..."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
Fix thinko in iov_iter_single_seg_count
When memory is hot-added, all the memory is in offline state. So clear
all zones' present_pages because they will be updated in online_pages()
and offline_pages(). Otherwise, /proc/zoneinfo will corrupt:
When the memory of node2 is offline:
# cat /proc/zoneinfo
Node 2, zone Movable
spanned 8388608
present 8388608
managed 0
When we online memory on node2:
spanned 8388608
present 16777216
managed 8388608
Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com>
Cc: <stable@vger.kernel.org> [3.16+]
In free_area_init_core(), zone->managed_pages is set to an approximate
value for lowmem, and will be adjusted when the bootmem allocator frees
pages into the buddy system.
But free_area_init_core() is also called by hotadd_new_pgdat() when
hot-adding memory. As a result, zone->managed_pages of the newly added
node's pgdat is set to an approximate value in the very beginning.
Even if the memory on that node has node been onlined,
/sys/device/system/node/nodeXXX/meminfo has wrong value:
hot-add node2 (memory not onlined)
cat /sys/device/system/node/node2/meminfo
Node 2 MemTotal: 33554432 kB
Node 2 MemFree: 0 kB
Node 2 MemUsed: 33554432 kB
Node 2 Active: 0 kB
This patch fixes this problem by reset node managed pages to 0 after
hot-adding a new node.
1. Move reset_managed_pages_done from reset_node_managed_pages() to
reset_all_zones_managed_pages()
2. Make reset_node_managed_pages() non-static
3. Call reset_node_managed_pages() in hotadd_new_pgdat() after pgdat
is initialized
Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
One thing I did in this patch is fixing freepage accounting. If we
clear guard page and link it onto isolate buddy list, we should not
increase freepage count. This patch adds conditional branch to skip
counting in this case. Without this patch, this overcounting happens
frequently if guard order is set and CMA is used.
Another thing fixed in this patch is the target to reset order. In
__free_one_page(), we check the buddy page whether it is a guard page or
not. And, if so, we should clear guard attribute on the buddy page and
reset order of it to 0. But, current code resets original page's order
rather than buddy one's. Maybe, this doesn't have any problem, because
whole merged page's order will be re-assigned soon. But, it is better
to correct code.
Several people have reported occasionally seeing processes stuck in
compact_zone(), even triggering soft lockups, in 3.18-rc2+.
Testing a revert of commit e14c720efdd7 ("mm, compaction: remember
position within pageblock in free pages scanner") fixed the issue,
although the stuck processes do not appear to involve the free scanner.
Finally, by code inspection, the bug was found in isolate_migratepages()
which uses a slightly different condition to detect if the migration and
free scanners have met, than compact_finished(). That has not been a
problem until commit e14c720efdd7 allowed the free scanner position
between individual invocations to be in the middle of a pageblock.
In a relatively rare case, the migration scanner position can end up at
the beginning of a pageblock, with the free scanner position in the
middle of the same pageblock. If it's the migration scanner's turn,
isolate_migratepages() exits immediately (without updating the
position), while compact_finished() decides to continue compaction,
resulting in a potentially infinite loop. The system can recover only
if another process creates enough high-order pages to make the watermark
checks in compact_finished() pass.
This patch fixes the immediate problem by bumping the migration
scanner's position to meet the free scanner in isolate_migratepages(),
when both are within the same pageblock. This causes compact_finished()
to terminate properly. A more robust check in compact_finished() is
planned as a cleanup for better future maintainability.
Fixes: e14c720efdd73 ("mm, compaction: remember position within pageblock in free pages scanner)
Reported-by: P. Christeas <xrg@linux.gr>
Tested-by: P. Christeas <xrg@linux.gr>
Link: http://marc.info/?l=linux-mm&m=141508604232522&w=2
Reported-by: Norbert Preining <preining@logic.at>
Tested-by: Norbert Preining <preining@logic.at>
Link: https://lkml.org/lkml/2014/11/4/904
Reported-by: Pavel Machek <pavel@ucw.cz>
Link: https://lkml.org/lkml/2014/11/7/164
