path: root/mm
2010-09-09mm: Move vma_stack_continue into mm.hStefan Bader
So it can be used by all that need to check for that. Signed-off-by: Stefan Bader <stefan.bader@canonical.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: percpu: fix a mismatch between code and comment percpu: fix a memory leak in pcpu_extend_area_map() percpu: add __percpu notations to UP allocator percpu: handle __percpu notations in UP accessors
2010-08-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: ceph: fix get_ticket_handler() error handling ceph: don't BUG on ENOMEM during mds reconnect ceph: ceph_mdsc_build_path() returns an ERR_PTR ceph: Fix warnings ceph: ceph_get_inode() returns an ERR_PTR ceph: initialize fields on new dentry_infos ceph: maintain i_head_snapc when any caps are dirty, not just for data ceph: fix osd request lru adjustment when sending request ceph: don't improperly set dir complete when holding EXCL cap mm: exporting account_page_dirty ceph: direct requests in snapped namespace based on nonsnap parent ceph: queue cap snap writeback for realm children on snap update ceph: include dirty xattrs state in snapped caps ceph: fix xattr cap writeback ceph: fix multiple mds session shutdown
2010-08-28mm: fix hang on anon_vma->root->lockHugh Dickins
After several hours, kbuild tests hang with anon_vma_prepare() spinning on a newly allocated anon_vma's lock - on a box with CONFIG_TREE_PREEMPT_RCU=y (which makes this very much more likely, but it could happen without). The ever-subtle page_lock_anon_vma() now needs a further twist: since anon_vma_prepare() and anon_vma_fork() are liable to change the ->root of a reused anon_vma structure at any moment, page_lock_anon_vma() needs to check page_mapped() again before succeeding, otherwise page_unlock_anon_vma() might address a different root->lock. Signed-off-by: Hugh Dickins <hughd@google.com> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Christoph Lameter <cl@linux.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-27percpu: fix a mismatch between code and commentNamhyung Kim
When pcpu_build_alloc_info() searches best_upa value, it ignores current value if the number of waste units exceeds 1/3 of the number of total cpus. But the comment on the code says that it will ignore if wastage is over 25%. Modify the comment. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2010-08-27percpu: fix a memory leak in pcpu_extend_area_map()Huang Shijie
The original code did not free the old map. This patch fixes it. tj: use @old as memcpy source instead of @chunk->map, and indentation and description update Signed-off-by: Huang Shijie <shijie8@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: stable@kernel.org
2010-08-25Merge branch '2.6.36-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dgc/xfsdev * '2.6.36-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/dgc/xfsdev: xfs: do not discard page cache data on EAGAIN xfs: don't do memory allocation under the CIL context lock xfs: Reduce log force overhead for delayed logging xfs: dummy transactions should not dirty VFS state xfs: ensure f_ffree returned by statfs() is non-negative xfs: handle negative wbc->nr_to_write during sync writeback writeback: write_cache_pages doesn't terminate at nr_to_write <= 0 xfs: fix untrusted inode number lookup xfs: ensure we mark all inodes in a freed cluster XFS_ISTALE xfs: unlock items before allowing the CIL to commit
2010-08-24guard page for stacks that grow upwardsLuck, Tony
pa-risc and ia64 have stacks that grow upwards. Check that they do not run into other mappings. By making VM_GROWSUP 0x0 on architectures that do not ever use it, we can avoid some unpleasant #ifdefs in check_stack_guard_page(). Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-24writeback: write_cache_pages doesn't terminate at nr_to_write <= 0Dave Chinner
I noticed XFS writeback in 2.6.36-rc1 was much slower than it should have been. Enabling writeback tracing showed: flush-253:16-8516 [007] 1342952.351608: wbc_writepage: bdi 253:16: towrt=1024 skip=0 mode=0 kupd=0 bgrd=1 reclm=0 cyclic=1 more=0 older=0x0 start=0x0 end=0x0 flush-253:16-8516 [007] 1342952.351654: wbc_writepage: bdi 253:16: towrt=1023 skip=0 mode=0 kupd=0 bgrd=1 reclm=0 cyclic=1 more=0 older=0x0 start=0x0 end=0x0 flush-253:16-8516 [000] 1342952.369520: wbc_writepage: bdi 253:16: towrt=0 skip=0 mode=0 kupd=0 bgrd=1 reclm=0 cyclic=1 more=0 older=0x0 start=0x0 end=0x0 flush-253:16-8516 [000] 1342952.369542: wbc_writepage: bdi 253:16: towrt=-1 skip=0 mode=0 kupd=0 bgrd=1 reclm=0 cyclic=1 more=0 older=0x0 start=0x0 end=0x0 flush-253:16-8516 [000] 1342952.369549: wbc_writepage: bdi 253:16: towrt=-2 skip=0 mode=0 kupd=0 bgrd=1 reclm=0 cyclic=1 more=0 older=0x0 start=0x0 end=0x0 Writeback is not terminating in background writeback if ->writepage is returning with wbc->nr_to_write == 0, resulting in sub-optimal single page writeback on XFS. Fix the write_cache_pages loop to terminate correctly when this situation occurs and so prevent this sub-optimal background writeback pattern. This improves sustained sequential buffered write performance from around 250MB/s to 750MB/s for a 100GB file on an XFS filesystem on my 8p test VM. Cc:<stable@kernel.org> Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Wu Fengguang <fengguang.wu@intel.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2010-08-22mm: exporting account_page_dirtyMichael Rubin
This allows code outside of the mm core to safely manipulate page state and not worry about the other accounting. Not using these routines means that some code will lose track of the accounting and we get bugs. This has happened once already. Signed-off-by: Michael Rubin <mrubin@google.com> Signed-off-by: Sage Weil <sage@newdream.net>
2010-08-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6: slab: fix object alignment slub: add missing __percpu markup in mm/slub_def.h
2010-08-21mm: make stack guard page logic use vm_prev pointerLinus Torvalds
Like the mlock() change previously, this makes the stack guard check code use vma->vm_prev to see what the mapping below the current stack is, rather than have to look it up with find_vma(). Also, accept an abutting stack segment, since that happens naturally if you split the stack with mlock or mprotect. Tested-by: Ian Campbell <ijc@hellion.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-21mm: make the mlock() stack guard page checks stricterLinus Torvalds
If we've split the stack vma, only the lowest one has the guard page. Now that we have a doubly linked list of vma's, checking this is trivial. Tested-by: Ian Campbell <ijc@hellion.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-21mm: make the vma list be doubly linkedLinus Torvalds
It's a really simple list, and several of the users want to go backwards in it to find the previous vma. So rather than have to look up the previous entry with 'find_vma_prev()' or something similar, just make it doubly linked instead. Tested-by: Ian Campbell <ijc@hellion.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-20oom: __task_cred() need rcu_read_lock()KOSAKI Motohiro
dump_tasks() needs to hold the RCU read lock around its access of the target task's UID. To this end it should use task_uid() as it only needs that one thing from the creds. The fact that dump_tasks() holds tasklist_lock is insufficient to prevent the target process replacing its credentials on another CPU. Then, this patch change to call rcu_read_lock() explicitly. =================================================== [ INFO: suspicious rcu_dereference_check() usage. ] --------------------------------------------------- mm/oom_kill.c:410 invoked rcu_dereference_check() without protection! other info that might help us debug this: rcu_scheduler_active = 1, debug_locks = 1 4 locks held by kworker/1:2/651: #0: (events){+.+.+.}, at: [<ffffffff8106aae7>] process_one_work+0x137/0x4a0 #1: (moom_work){+.+...}, at: [<ffffffff8106aae7>] process_one_work+0x137/0x4a0 #2: (tasklist_lock){.+.+..}, at: [<ffffffff810fafd4>] out_of_memory+0x164/0x3f0 #3: (&(&p->alloc_lock)->rlock){+.+...}, at: [<ffffffff810fa48e>] find_lock_task_mm+0x2e/0x70 Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-20oom: fix tasklist_lock leakKOSAKI Motohiro
Commit 0aad4b3124 ("oom: fold __out_of_memory into out_of_memory") introduced a tasklist_lock leak. Then it caused following obvious danger warnings and panic. ================================================ [ BUG: lock held when returning to user space! ] ------------------------------------------------ rsyslogd/1422 is leaving the kernel with locks still held! 1 lock held by rsyslogd/1422: #0: (tasklist_lock){.+.+.+}, at: [<ffffffff810faf64>] out_of_memory+0x164/0x3f0 BUG: scheduling while atomic: rsyslogd/1422/0x00000002 INFO: lockdep is turned off. This patch fixes it. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-20oom: fix NULL pointer dereferenceKOSAKI Motohiro
Commit b940fd7035 ("oom: remove unnecessary code and cleanup") added an unnecessary NULL pointer dereference. remove it. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-20lib/radix-tree.c: fix overflow in radix_tree_range_tag_if_tagged()Jan Kara
When radix_tree_maxindex() is ~0UL, it can happen that scanning overflows index and tree traversal code goes astray reading memory until it hits unreadable memory. Check for overflow and exit in that case. Signed-off-by: Jan Kara <jack@suse.cz> Cc: Christoph Hellwig <hch@lst.de> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-17shmem: put_super must percpu_counter_destroyHugh Dickins
list_add() corruption messages reported from shmem_fill_super()'s recently introduced percpu_counter_init(): shmem_put_super() needs to remember to percpu_counter_destroy(). And also check error from percpu_counter_init(). Reported-bisected-and-tested-by: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-15mm: fix up some user-visible effects of the stack guard pageLinus Torvalds
This commit makes the stack guard page somewhat less visible to user space. It does this by: - not showing the guard page in /proc/<pid>/maps It looks like lvm-tools will actually read /proc/self/maps to figure out where all its mappings are, and effectively do a specialized "mlockall()" in user space. By not showing the guard page as part of the mapping (by just adding PAGE_SIZE to the start for grows-up pages), lvm-tools ends up not being aware of it. - by also teaching the _real_ mlock() functionality not to try to lock the guard page. That would just expand the mapping down to create a new guard page, so there really is no point in trying to lock it in place. It would perhaps be nice to show the guard page specially in /proc/<pid>/maps (or at least mark grow-down segments some way), but let's not open ourselves up to more breakage by user space from programs that depends on the exact deails of the 'maps' file. Special thanks to Henrique de Moraes Holschuh for diving into lvm-tools source code to see what was going on with the whole new warning. Reported-and-tested-by: François Valenduc <francois.valenduc@tvcablenet.be Reported-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-14mm/page-writeback: fix non-kernel-doc function commentsRandy Dunlap
Remove leading /** from non-kernel-doc function comments to prevent kernel-doc warnings. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-14mm: fix page table unmap for stack guard page properlyLinus Torvalds
We do in fact need to unmap the page table _before_ doing the whole stack guard page logic, because if it is needed (mainly 32-bit x86 with PAE and CONFIG_HIGHPTE, but other architectures may use it too) then it will do a kmap_atomic/kunmap_atomic. And those kmaps will create an atomic region that we cannot do allocations in. However, the whole stack expand code will need to do anon_vma_prepare() and vma_lock_anon_vma() and they cannot do that in an atomic region. Now, a better model might actually be to do the anon_vma_prepare() when _creating_ a VM_GROWSDOWN segment, and not have to worry about any of this at page fault time. But in the meantime, this is the straightforward fix for the issue. See https://bugzilla.kernel.org/show_bug.cgi?id=16588 for details. Reported-by: Wylda <wylda@volny.cz> Reported-by: Sedat Dilek <sedat.dilek@gmail.com> Reported-by: Mike Pagano <mpagano@gentoo.org> Reported-by: François Valenduc <francois.valenduc@tvcablenet.be> Tested-by: Ed Tomlinson <edt@aei.ca> Cc: Pekka Enberg <penberg@kernel.org> Cc: Greg KH <gregkh@suse.de> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-13NOMMU: Remove an extraneous no_printk()David Howells
Remove an extraneous no_printk() in mm/nommu.c that got missed when the function got generalised from several things that used it in commit 12fdff3fc248 ("Add a dummy printk function for the maintenance of unused printks"). Without this, the following error is observed: mm/nommu.c:41: error: conflicting types for 'no_printk' include/linux/kernel.h:314: error: previous definition of 'no_printk' was here Reported-by: Michal Simek <monstr@monstr.eu> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-13mm: fix missing page table unmap for stack guard page failure caseLinus Torvalds
.. which didn't show up in my tests because it's a no-op on x86-64 and most other architectures. But we enter the function with the last-level page table mapped, and should unmap it at exit. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-12mm: keep a guard page below a grow-down stack segmentLinus Torvalds
This is a rather minimally invasive patch to solve the problem of the user stack growing into a memory mapped area below it. Whenever we fill the first page of the stack segment, expand the segment down by one page. Now, admittedly some odd application might _want_ the stack to grow down into the preceding memory mapping, and so we may at some point need to make this a process tunable (some people might also want to have more than a single page of guarding), but let's try the minimal approach first. Tested with trivial application that maps a single page just below the stack, and then starts recursing. Without this, we will get a SIGSEGV _after_ the stack has smashed the mapping. With this patch, we'll get a nice SIGBUS just as the stack touches the page just above the mapping. Requested-by: Keith Packard <keithp@keithp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-12Merge branch 'hwpoison' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6 * 'hwpoison' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6: hugetlb: add missing unlock in avoidcopy path in hugetlb_cow() hwpoison: rename CONFIG HWPOISON, hugetlb: support hwpoison injection for hugepage HWPOISON, hugetlb: detect hwpoison in hugetlb code HWPOISON, hugetlb: isolate corrupted hugepage HWPOISON, hugetlb: maintain mce_bad_pages in handling hugepage error HWPOISON, hugetlb: set/clear PG_hwpoison bits on hugepage HWPOISON, hugetlb: enable error handling path for hugepage hugetlb, rmap: add reverse mapping for hugepage hugetlb: move definition of is_vm_hugetlb_page() to hugepage_inline.h Fix up trivial conflicts in mm/memory-failure.c
2010-08-12Merge branch 'stable/xen-swiotlb-0.8.6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/xen-swiotlb-0.8.6' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: x86: Detect whether we should use Xen SWIOTLB. pci-swiotlb-xen: Add glue code to setup dma_ops utilizing xen_swiotlb_* functions. swiotlb-xen: SWIOTLB library for Xen PV guest with PCI passthrough. xen/mmu: inhibit vmap aliases rather than trying to clear them out vmap: add flag to allow lazy unmap to be disabled at runtime xen: Add xen_create_contiguous_region xen: Rename the balloon lock xen: Allow unprivileged Xen domains to create iomap pages xen: use _PAGE_IOMAP in ioremap to do machine mappings Fix up trivial conflicts (adding both xen swiotlb and xen pci platform driver setup close to each other) in drivers/xen/{Kconfig,Makefile} and include/xen/xen-ops.h
2010-08-12writeback: add comment to the dirty limit functionsWu Fengguang
Document global_dirty_limits() and bdi_dirty_limit(). Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Dave Chinner <david@fromorbit.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-12writeback: avoid unnecessary calculation of bdi dirty thresholdsWu Fengguang
Split get_dirty_limits() into global_dirty_limits()+bdi_dirty_limit(), so that the latter can be avoided when under global dirty background threshold (which is the normal state for most systems). Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Christoph Hellwig <hch@infradead.org> Cc: Dave Chinner <david@fromorbit.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-12writeback: balance_dirty_pages(): reduce calls to global_page_stateWu Fengguang
Reducing the number of times balance_dirty_pages calls global_page_state reduces the cache references and so improves write performance on a variety of workloads. 'perf stats' of simple fio write tests shows the reduction in cache access. Where the test is fio 'write,mmap,600Mb,pre_read' on AMD AthlonX2 with 3Gb memory (dirty_threshold approx 600 Mb) running each test 10 times, dropping the fasted & slowest values then taking the average & standard deviation average (s.d.) in millions (10^6) 2.6.31-rc8 648.6 (14.6) +patch 620.1 (16.5) Achieving this reduction is by dropping clip_bdi_dirty_limit as it rereads the counters to apply the dirty_threshold and moving this check up into balance_dirty_pages where it has already read the counters. Also by rearrange the for loop to only contain one copy of the limit tests allows the pdflush test after the loop to use the local copies of the counters rather than rereading them. In the common case with no throttling it now calls global_page_state 5 fewer times and bdi_stat 2 fewer. Fengguang: This patch slightly changes behavior by replacing clip_bdi_dirty_limit() with the explicit check (nr_reclaimable + nr_writeback >= dirty_thresh) to avoid exceeding the dirty limit. Since the bdi dirty limit is mostly accurate we don't need to do routinely clip. A simple dirty limit check would be enough. The check is necessary because, in principle we should throttle everything calling balance_dirty_pages() when we're over the total limit, as said by Peter. We now set and clear dirty_exceeded not only based on bdi dirty limits, but also on the global dirty limit. The global limit check is added in place of clip_bdi_dirty_limit() for safety and not intended as a behavior change. The bdi limits should be tight enough to keep all dirty pages under the global limit at most time; occasional small exceeding should be OK though. The change makes the logic more obvious: the global limit is the ultimate goal and shall be always imposed. We may now start background writeback work based on outdated conditions. That's safe because the bdi flush thread will (and have to) double check the states. It reduces overall overheads because the test based on old states still have good chance to be right. [akpm@linux-foundation.org] fix uninitialized dirty_exceeded Signed-off-by: Richard Kennedy <richard@rsk.demon.co.uk> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Jan Kara <jack@suse.cz> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Christoph Hellwig <hch@infradead.org> Cc: Dave Chinner <david@fromorbit.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-12mm: fix fatal kernel-doc errorRandy Dunlap
Fix a fatal kernel-doc error due to a #define coming between a function's kernel-doc notation and the function signature. (kernel-doc cannot handle this) Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11memcg: convert to use zone_to_nid() from bare zone->zone_pgdat->node_idKOSAKI Motohiro
We have zone_to_nid(). this patch convert all existing users of zone->zone_pgdat->node_id. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Nishimura Daisuke <d-nishimura@mtf.biglobe.ne.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11memcg: remove nid and zid argument from mem_cgroup_soft_limit_reclaim()KOSAKI Motohiro
mem_cgroup_soft_limit_reclaim() has zone, nid and zid argument. but nid and zid can be calculated from zone. So remove it. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Nishimura Daisuke <d-nishimura@mtf.biglobe.ne.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11memcg: mem_cgroup_shrink_node_zone() doesn't need sc.nodemaskKOSAKI Motohiro
Currently mem_cgroup_shrink_node_zone() call shrink_zone() directly. thus it doesn't need to initialize sc.nodemask because shrink_zone() doesn't use it at all. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Nishimura Daisuke <d-nishimura@mtf.biglobe.ne.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11memcg: kill unnecessary initialization in mem_cgroup_shrink_node_zone()KOSAKI Motohiro
sc.nr_reclaimed and sc.nr_scanned have already been initialized few lines above "struct scan_control sc = {}" statement. So, This patch remove this unnecessary code. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Nishimura Daisuke <d-nishimura@mtf.biglobe.ne.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11memcg: sc.nr_to_reclaim should be initializedKOSAKI Motohiro
Currently, mem_cgroup_shrink_node_zone() initialize sc.nr_to_reclaim as 0. It mean shrink_zone() only scan 32 pages and immediately return even if it doesn't reclaim any pages. This patch fixes it. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Nishimura Daisuke <d-nishimura@mtf.biglobe.ne.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11memcg: avoid css_get()KAMEZAWA Hiroyuki
Now, memory cgroup increments css(cgroup subsys state)'s reference count per a charged page. And the reference count is kept until the page is uncharged. But this has 2 bad effect. 1. Because css_get/put calls atomic_inc()/dec, heavy call of them on large smp will not scale well. 2. Because css's refcnt cannot be in a state as "ready-to-release", cgroup's notify_on_release handler can't work with memcg. 3. css's refcnt is atomic_t, it means smaller than 32bit. Maybe too small. This has been a problem since the 1st merge of memcg. This is a trial to remove css's refcnt per a page. Even if we remove refcnt, pre_destroy() does enough synchronization as - check res->usage == 0. - check no pages on LRU. This patch removes css's refcnt per page. Even after this patch, at the 1st look, it seems css_get() is still called in try_charge(). But the logic is. - If a memcg of mm->owner is cached one, consume_stock() will work. At success, return immediately. - If consume_stock returns false, css_get() is called and go to slow path which may be blocked. At the end of slow path, css_put() is called and restart from the start if necessary. So, in the fast path, we don't call css_get() and can avoid access to shared counter. This patch can make the most possible case fast. Here is a result of multi-threaded page fault benchmark. [Before] 25.32% multi-fault-all [kernel.kallsyms] [k] clear_page_c 9.30% multi-fault-all [kernel.kallsyms] [k] _raw_spin_lock_irqsave 8.02% multi-fault-all [kernel.kallsyms] [k] try_get_mem_cgroup_from_mm <=====(*) 7.83% multi-fault-all [kernel.kallsyms] [k] down_read_trylock 5.38% multi-fault-all [kernel.kallsyms] [k] __css_put 5.29% multi-fault-all [kernel.kallsyms] [k] __alloc_pages_nodemask 4.92% multi-fault-all [kernel.kallsyms] [k] _raw_spin_lock_irq 4.24% multi-fault-all [kernel.kallsyms] [k] up_read 3.53% multi-fault-all [kernel.kallsyms] [k] css_put 2.11% multi-fault-all [kernel.kallsyms] [k] handle_mm_fault 1.76% multi-fault-all [kernel.kallsyms] [k] __rmqueue 1.64% multi-fault-all [kernel.kallsyms] [k] __mem_cgroup_commit_charge [After] 28.41% multi-fault-all [kernel.kallsyms] [k] clear_page_c 10.08% multi-fault-all [kernel.kallsyms] [k] _raw_spin_lock_irq 9.58% multi-fault-all [kernel.kallsyms] [k] down_read_trylock 9.38% multi-fault-all [kernel.kallsyms] [k] _raw_spin_lock_irqsave 5.86% multi-fault-all [kernel.kallsyms] [k] __alloc_pages_nodemask 5.65% multi-fault-all [kernel.kallsyms] [k] up_read 2.82% multi-fault-all [kernel.kallsyms] [k] handle_mm_fault 2.64% multi-fault-all [kernel.kallsyms] [k] mem_cgroup_add_lru_list 2.48% multi-fault-all [kernel.kallsyms] [k] __mem_cgroup_commit_charge Then, 8.02% of try_get_mem_cgroup_from_mm() disappears because this patch removes css_tryget() in it. (But yes, this is an extreme case.) Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11memcg: use find_lock_task_mm() in memory cgroups oomKAMEZAWA Hiroyuki
When the OOM killer scans task, it check a task is under memcg or not when it's called via memcg's context. But, as Oleg pointed out, a thread group leader may have NULL ->mm and task_in_mem_cgroup() may do wrong decision. We have to use find_lock_task_mm() in memcg as generic OOM-Killer does. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11memcg: remove mem from arg of charge_commonDaisuke Nishimura
mem_cgroup_charge_common() is always called with @mem = NULL, so it's meaningless. This patch removes it. Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11memcg: remove redundant codeDaisuke Nishimura
- try_get_mem_cgroup_from_mm() calls rcu_read_lock/unlock by itself, so we don't have to call them in task_in_mem_cgroup(). - *mz is not used in __mem_cgroup_uncharge_common(). - we don't have to call lookup_page_cgroup() in mem_cgroup_end_migration() after we've cleared PCG_MIGRATION of @oldpage. - remove empty comment. - remove redundant empty line in mem_cgroup_cache_charge(). Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11memcg: clean up waiting move acctKAMEZAWA Hiroyuki
Now, for checking a memcg is under task-account-moving, we do css_tryget() against mc.to and mc.from. But this is just complicating things. This patch makes the check easier. This patch adds a spinlock to move_charge_struct and guard modification of mc.to and mc.from. By this, we don't have to think about complicated races arount this not-critical path. [balbir@linux.vnet.ibm.com: don't crash on a null memcg being passed] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11memcg: clean up try_charge main loopKAMEZAWA Hiroyuki
mem_cgroup_try_charge() has a big loop in it and seems to be hard to read. Most of routines are for slow path. This patch moves codes out from the loop and make it clear what's done. Summary: - refactoring a function to detect a memcg is under acccount move or not. - refactoring a function to wait for the end of moving task acct. - refactoring a main loop('s slow path) as a function and make it clear why we retry or quit by return code. - add fatal_signal_pending() check for bypassing charge loops. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11hugetlb: add missing unlock in avoidcopy path in hugetlb_cow()Naoya Horiguchi
This patch fixes possible deadlock in hugepage lock_page() by adding missing unlock_page(). libhugetlbfs test will hit this bug when the next patch in this patchset ("hugetlb, HWPOISON: move PG_HWPoison bit check") is applied. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Acked-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2010-08-11hwpoison: rename CONFIGNaoya Horiguchi
CONFIG_HUGETLBFS controls hugetlbfs interface code. OTOH, CONFIG_HUGETLB_PAGE controls hugepage management code. So we should use CONFIG_HUGETLB_PAGE here. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2010-08-11HWPOISON, hugetlb: support hwpoison injection for hugepageNaoya Horiguchi
This patch enables hwpoison injection through debug/hwpoison interfaces, with which we can test memory error handling for free or reserved hugepages (which cannot be tested by madvise() injector). [AK: Export PageHuge too for the injection module] Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Andrew Morton <akpm@linux-foundation.org> Acked-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2010-08-11HWPOISON, hugetlb: detect hwpoison in hugetlb codeNaoya Horiguchi
This patch enables to block access to hwpoisoned hugepage and also enables to block unmapping for it. Dependency: "HWPOISON, hugetlb: enable error handling path for hugepage" Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Andrew Morton <akpm@linux-foundation.org> Acked-by: Fengguang Wu <fengguang.wu@intel.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2010-08-11HWPOISON, hugetlb: isolate corrupted hugepageNaoya Horiguchi
If error hugepage is not in-use, we can fully recovery from error by dequeuing it from freelist, so return RECOVERY. Otherwise whether or not we can recovery depends on user processes, so return DELAYED. Dependency: "HWPOISON, hugetlb: enable error handling path for hugepage" Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Andrew Morton <akpm@linux-foundation.org> Acked-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2010-08-11HWPOISON, hugetlb: maintain mce_bad_pages in handling hugepage errorNaoya Horiguchi
For now all pages in the error hugepage are considered as hwpoisoned, so count all of them in mce_bad_pages. Dependency: "HWPOISON, hugetlb: enable error handling path for hugepage" Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Andrew Morton <akpm@linux-foundation.org> Acked-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2010-08-11HWPOISON, hugetlb: set/clear PG_hwpoison bits on hugepageNaoya Horiguchi
To avoid race condition between concurrent memory errors on identified hugepage, we atomically test and set PG_hwpoison bit on the head page. All pages in the error hugepage are considered as hwpoisoned for now, so set and clear all PG_hwpoison bits in the hugepage with page lock of the head page held. Dependency: "HWPOISON, hugetlb: enable error handling path for hugepage" Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Andrew Morton <akpm@linux-foundation.org> Acked-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2010-08-11HWPOISON, hugetlb: enable error handling path for hugepageNaoya Horiguchi
This patch just enables handling path. Real containing and recovering operation will be implemented in following patches. Dependency: "hugetlb, rmap: add reverse mapping for hugepage." Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Andrew Morton <akpm@linux-foundation.org> Acked-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
