Hiroaki Wakabayashi points out that when mlock() has been interrupted
by SIGKILL, the subsequent munlock() takes unnecessarily long because
its use of __get_user_pages() insists on faulting in all the pages
which mlock() never reached.
It's worse than slowness if mlock() is terminated by Out Of Memory kill:
the munlock_vma_pages_all() in exit_mmap() insists on faulting in all the
pages which mlock() could not find memory for; so innocent bystanders are
killed too, and perhaps the system hangs.
__get_user_pages() does a lot that's silly for munlock(): so remove the
munlock option from __mlock_vma_pages_range(), and use a simple loop of
follow_page()s in munlock_vma_pages_range() instead; ignoring absent
pages, and not marking present pages as accessed or dirty.
(Change munlock() to only go so far as mlock() reached? That does not
work out, given the convention that mlock() claims complete success even
when it has to give up early - in part so that an underlying file can be
extended later, and those pages locked which earlier would give SIGBUS.)
Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Cc: <stable@kernel.org>
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
Cc: Nick Piggin <npiggin@suse.de>
Reviewed-by: Hiroaki Wakabayashi <primulaelatior@gmail.com>
When round-robin freeing pages from the PCP lists, empty lists may be
encountered. In the event one of the lists has more pages than another,
there may be numerous checks for list_empty() which is undesirable. This
patch maintains a count of pages to free which is incremented when empty
lists are encountered. The intention is that more pages will then be
freed from fuller lists than the empty ones reducing the number of empty
list checks in the free path.
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
The following two patches remove searching in the page allocator fast-path
by maintaining multiple free-lists in the per-cpu structure. At the time
the search was introduced, increasing the per-cpu structures would waste a
lot of memory as per-cpu structures were statically allocated at
compile-time. This is no longer the case.
The patches are as follows. They are based on mmotm-2009-08-27.
Patch 1 adds multiple lists to struct per_cpu_pages, one per
migratetype that can be stored on the PCP lists.
Patch 2 notes that the pcpu drain path check empty lists multiple times. The
patch reduces the number of checks by maintaining a count of free
lists encountered. Lists containing pages will then free multiple
pages in batch
The patches were tested with kernbench, netperf udp/tcp, hackbench and
sysbench. The netperf tests were not bound to any CPU in particular and
were run such that the results should be 99% confidence that the reported
results are within 1% of the estimated mean. sysbench was run with a
postgres background and read-only tests. Similar to netperf, it was run
multiple times so that it's 99% confidence results are within 1%. The
patches were tested on x86, x86-64 and ppc64 as
x86: Intel Pentium D 3GHz with 8G RAM (no-brand machine)
kernbench - No significant difference, variance well within noise
netperf-udp - 1.34% to 2.28% gain
netperf-tcp - 0.45% to 1.22% gain
hackbench - Small variances, very close to noise
sysbench - Very small gains
x86-64: AMD Phenom 9950 1.3GHz with 8G RAM (no-brand machine)
netperf-udp - 1.83% to 10.42% gains
netperf-tcp - No conclusive until buffer >= PAGE_SIZE
4096 +15.83%
8192 + 0.34% (not significant)
16384 + 1%
hackbench - Small gains, very close to noise
sysbench - 0.79% to 1.6% gain
ppc64: PPC970MP 2.5GHz with 10GB RAM (it's a terrasoft powerstation)
netperf-udp - 2-3% gain for almost all buffer sizes tested
netperf-tcp - losses on small buffers, gains on larger buffers
possibly indicates some bad caching effect.
hackbench - No significant difference
sysbench - 2-4% gain
This patch:
Currently the per-cpu page allocator searches the PCP list for pages of
the correct migrate-type to reduce the possibility of pages being
inappropriate placed from a fragmentation perspective. This search is
potentially expensive in a fast-path and undesirable. Splitting the
per-cpu list into multiple lists increases the size of a per-cpu structure
and this was potentially a major problem at the time the search was
introduced. These problem has been mitigated as now only the necessary
number of structures is allocated for the running system.
This patch replaces a list search in the per-cpu allocator with one list
per migrate type. The potential snag with this approach is when bulk
freeing pages. We round-robin free pages based on migrate type which has
little bearing on the cache hotness of the page and potentially checks
empty lists repeatedly in the event the majority of PCP pages are of one
type.
Acked-by: Nick Piggin <npiggin@suse.de>
Cc: Minchan Kim <minchan.kim@gmail.com>
Current oom_kill doesn't only kill the victim process, but also kill all
thas shread the same mm. it mean vfork parent will be killed.
This is definitely incorrect. another process have another oom_adj. we
shouldn't ignore their oom_adj (it might have OOM_DISABLE).
following caller hit the minefield.
switch (constraint) {
case CONSTRAINT_MEMORY_POLICY:
oom_kill_process(current, gfp_mask, order, 0, NULL,
"No available memory (MPOL_BIND)");
break;
Note: force_sig(SIGKILL) send SIGKILL to all thread in the process.
We don't need to care multi thread in here.
Cc: Paul Menage <menage@google.com>
oom-killer kills a process, not task. Then oom_score should be calculated
as per-process too. it makes consistency more and makes speed up
select_bad_process().
Currently, OOM logic callflow is here.
__out_of_memory()
select_bad_process() for each task
badness() calculate badness of one task
oom_kill_process() search child
oom_kill_task() kill target task and mm shared tasks with it
example, process-A have two thread, thread-A and thread-B and it have very
fat memory and each thread have following oom_adj and oom_score.
thread-A: oom_adj = OOM_DISABLE, oom_score = 0
thread-B: oom_adj = 0, oom_score = very-high
Then, select_bad_process() select thread-B, but oom_kill_task() refuse
kill the task because thread-A have OOM_DISABLE. Thus __out_of_memory()
call select_bad_process() again. but select_bad_process() select the same
task. It mean kernel fall in livelock.
The fact is, select_bad_process() must select killable task. otherwise
OOM logic go into livelock.
And root cause is, oom_adj shouldn't be per-thread value. it should be
per-process value because OOM-killer kill a process, not thread. Thus
This patch moves oomkilladj (now more appropriately named oom_adj) from
struct task_struct to struct signal_struct. it naturally prevent
select_bad_process() choose wrong task.
Commit 084f71ae5c(kill page_queue_congested()) removed
page_queue_congested(). Remove the page_queue_congested() comment in
vmscan pageout() too.
Signed-off-by: Vincent Li <macli@brc.ubc.ca>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
For mem_cgroup, shrink_zone() may call shrink_list() with nr_to_scan=1, in
which case shrink_list() _still_ calls isolate_pages() with the much
larger SWAP_CLUSTER_MAX. It effectively scales up the inactive list scan
rate by up to 32 times.
For example, with 16k inactive pages and DEF_PRIORITY=12, (16k >> 12)=4.
So when shrink_zone() expects to scan 4 pages in the active/inactive list,
the active list will be scanned 4 pages, while the inactive list will be
(over) scanned SWAP_CLUSTER_MAX=32 pages in effect. And that could break
the balance between the two lists.
It can further impact the scan of anon active list, due to the anon
active/inactive ratio rebalance logic in balance_pgdat()/shrink_zone():
inactive anon list over scanned => inactive_anon_is_low() == TRUE
=> shrink_active_list()
=> active anon list over scanned
So the end result may be
- anon inactive => over scanned
- anon active => over scanned (maybe not as much)
- file inactive => over scanned
- file active => under scanned (relatively)
The accesses to nr_saved_scan are not lock protected and so not 100%
accurate, however we can tolerate small errors and the resulted small
imbalanced scan rates between zones.
Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
The name `zone_nr_pages' can be mis-read as zone's (total) number pages,
but it actually returns zone's LRU list number pages.
This is being done by allowing boot time allocations to specify that they
may want a sub-page sized amount of memory.
Overall this seems more consistent with the other hash table allocations,
and allows making two supposedly mm-only variables really mm-only
(nr_{kernel,all}_pages).
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Sizing of memory allocations shouldn't depend on the number of physical
pages found in a system, as that generally includes (perhaps a huge amount
of) non-RAM pages. The amount of what actually is usable as storage
should instead be used as a basis here.
Some of the calculations (i.e. those not intending to use high memory)
should likely even use (totalram_pages - totalhigh_pages).
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
Cc: Dave Airlie <airlied@linux.ie>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Cc: Patrick McHardy <kaber@trash.net>
In line with that, the memory hotplug code should update num_physpages in
a way that it retains its original (post-boot) meaning; in particular,
decreasing the value should at best be done with great care - this patch
doesn't try to ever decrease this value at all as it doesn't really seem
meaningful to do so.
Cc: Yasunori Goto <y-goto@jp.fujitsu.com>
Cc: Badari Pulavarty <pbadari@us.ibm.com>
Cc: Dave Hansen <haveblue@us.ibm.com>
After anti-fragmentation was merged, a bug was reported whereby devices
that depended on high-order atomic allocations were failing. The solution
was to preserve a property in the buddy allocator which tended to keep the
minimum number of free pages in the zone at the lower physical addresses
and contiguous. To preserve this property, MIGRATE_RESERVE was introduced
and a number of pageblocks at the start of a zone would be marked
"reserve", the number of which depended on min_free_kbytes.
Anti-fragmentation works by avoiding the mixing of page migratetypes
within the same pageblock. One way of helping this is to increase
min_free_kbytes because it becomes less like that it will be necessary to
place pages of of MIGRATE_RESERVE is unbounded, the free memory is kept
there in large contiguous blocks instead of helping anti-fragmentation as
much as it should. With the page-allocator tracepoint patches applied, it
was found during anti-fragmentation tests that the number of
fragmentation-related events were far higher than expected even with
min_free_kbytes at higher values.
This patch limits the number of MIGRATE_RESERVE blocks that exist per zone
to two. For example, with a sufficient min_free_kbytes, 4MB of memory
will be kept aside on an x86-64 and remain more or less free and
contiguous for the systems uptime. This should be sufficient for devices
depending on high-order atomic allocations while helping fragmentation
control when min_free_kbytes is tuned appropriately. As side-effect of
this patch is that the reserve variable is converted to int as unsigned
long was the wrong type to use when ensuring that only the required number
of reserve blocks are created.
With the patches applied, fragmentation-related events as measured by the
page allocator tracepoints were significantly reduced when running some
fragmentation stress-tests on systems with min_free_kbytes tuned to a
value appropriate for hugepage allocations at runtime. On x86, the events
recorded were reduced by 99.8%, on x86-64 by 99.72% and on ppc64 by
99.83%.
Enlighten the reader of this code about what reference count makes a page
cache page freeable.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reviewed-by: Christoph Lameter <cl@linux-foundation.org>
Make page_has_private() return a true boolean value and remove the double
negations from the two callsites using it for arithmetic.
page_is_file_cache() has been used for both boolean checks and LRU
arithmetic, which was always a bit weird.
Now that page_lru_base_type() exists for LRU arithmetic, make
page_is_file_cache() a real predicate function and adjust the
boolean-using callsites to drop those pesky double negations.
Instead of abusing page_is_file_cache() for LRU list index arithmetic, add
another helper with a more appropriate name and convert the non-boolean
users of page_is_file_cache() accordingly.
This new helper gives the LRU base type a page is supposed to live on,
inactive anon or inactive file.
[hugh.dickins@tiscali.co.uk: convert del_page_from_lru() also]
Remove double negations where the operand is already boolean.
The kzalloc mempool zeros items when they are initially allocated, but
does not rezero used items that are returned to the pool. Consequently
mempool_alloc()s may return non-zeroed memory.
Since there are/were only two in-tree users for
mempool_create_kzalloc_pool(), and 'fixing' this in a way that will
re-zero used (but not new) items before first use is non-trivial, just
remove it.
Signed-off-by: Sage Weil <sage@newdream.net>
Fix the following 'make includecheck' warning:
mm/nommu.c: internal.h is included more than once.
Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
Acked-by: Greg Ungerer <gerg@snapgear.com>
mm/shmem.c: linux/vfs.h is included more than once.
After commit 355cfa73 ("mm: modify swap_map and add SWAP_HAS_CACHE flag"),
only the context which have set SWAP_HAS_CACHE flag by swapcache_prepare()
or get_swap_page() would call add_to_swap_cache(). So add_to_swap_cache()
doesn't return -EEXIST any more.
Even though it doesn't return -EEXIST, it's not good behavior conceptually
to call swapcache_prepare() in the -EEXIST case, because it means clearing
SWAP_HAS_CACHE flag while the entry is on swap cache.
This patch removes redundant codes and comments from callers of it, and
adds VM_BUG_ON() in error path of add_to_swap_cache() and some comments.
Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Balbir Singh <balbir@linux.vnet.ibm.com>
read_swap_cache_async() will busy-wait while a entry doesn't exist in swap
cache but it has SWAP_HAS_CACHE flag.
Such entries can exist on add/delete path of swap cache. On add path,
add_to_swap_cache() is called soon after SWAP_HAS_CACHE flag is set, and
on delete path, swapcache_free() will be called (SWAP_HAS_CACHE flag is
cleared) soon after __delete_from_swap_cache() is called. So, the
busy-wait works well in most cases.
But this mechanism can cause soft lockup if add_to_swap_cache() sleeps and
read_swap_cache_async() tries to swap-in the same entry on the same cpu.
This patch calls radix_tree_preload() before swapcache_prepare() and
divides add_to_swap_cache() into two part: radix_tree_preload() part and
radix_tree_insert() part(define it as __add_to_swap_cache()).
buddy lists
The page allocation trace event reports that a page was successfully
allocated but it does not specify where it came from. When analysing
performance, it can be important to distinguish between pages coming from
the per-cpu allocator and pages coming from the buddy lists as the latter
requires the zone lock to the taken and more data structures to be
examined.
This patch adds a trace event for __rmqueue reporting when a page is being
allocated from the buddy lists. It distinguishes between being called to
refill the per-cpu lists or whether it is a high-order allocation.
Similarly, this patch adds an event to catch when the PCP lists are being
drained a little and pages are going back to the buddy lists.
This is trickier to draw conclusions from but high activity on those
events could explain why there were a large number of cache misses on a
page-allocator-intensive workload. The coalescing and splitting of
buddies involves a lot of writing of page metadata and cache line bounces
not to mention the acquisition of an interrupt-safe lock necessary to
enter this path.
[akpm@linux-foundation.org: fix build]
Reviewed-by: Ingo Molnar <mingo@elte.hu>
Cc: Larry Woodman <lwoodman@redhat.com>
Cc: Li Ming Chun <macli@brc.ubc.ca>
back to other migratetypes
Fragmentation avoidance depends on being able to use free pages from lists
of the appropriate migrate type. In the event this is not possible,
__rmqueue_fallback() selects a different list and in some circumstances
change the migratetype of the pageblock. Simplistically, the more times
this event occurs, the more likely that fragmentation will be a problem
later for hugepage allocation at least but there are other considerations
such as the order of page being split to satisfy the allocation.
This patch adds a trace event for __rmqueue_fallback() that reports what
page is being used for the fallback, the orders of relevant pages, the
desired migratetype and the migratetype of the lists being used, whether
the pageblock changed type and whether this event is important with
respect to fragmentation avoidance or not. This information can be used
to help analyse fragmentation avoidance and help decide whether
min_free_kbytes should be increased or not.
This patch adds trace events for the allocation and freeing of pages,
including the freeing of pagevecs. Using the events, it will be known
what struct page and pfns are being allocated and freed and what the call
site was in many cases.
The page alloc tracepoints be used as an indicator as to whether the
workload was heavily dependant on the page allocator or not. You can make
a guess based on vmstat but you can't get a per-process breakdown.
Depending on the call path, the call_site for page allocation may be
__get_free_pages() instead of a useful callsite. Instead of passing down
a return address similar to slab debugging, the user should enable the
stacktrace and seg-addr options to get a proper stack trace.
The pagevec free tracepoint has a different usecase. It can be used to
get a idea of how many pages are being dumped off the LRU and whether it
is kswapd doing the work or a process doing direct reclaim.
The function free_cold_page() has no callers so delete it.
vread/vwrite access vmalloc area without checking there is a page or not.
In most case, this works well.
In old ages, the caller of get_vm_ara() is only IOREMAP and there is no
memory hole within vm_struct's [addr...addr + size - PAGE_SIZE] (
-PAGE_SIZE is for a guard page.)
After per-cpu-alloc patch, it uses get_vm_area() for reserve continuous
virtual address but remap _later_. There tend to be a hole in valid
vmalloc area in vm_struct lists. Then, skip the hole (not mapped page) is
necessary. This patch updates vread/vwrite() for avoiding memory hole.
Routines which access vmalloc area without knowing for which addr is used
are
- /proc/kcore
- /dev/kmem
kcore checks IOREMAP, /dev/kmem doesn't. After this patch, IOREMAP is
checked and /dev/kmem will avoid to read/write it. Fixes to /proc/kcore
will be in the next patch in series.
Cc: WANG Cong <xiyou.wangcong@gmail.com>
Cc: Mike Smith <scgtrp@gmail.com>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
vmap area should be purged after vm_struct is removed from the list
because vread/vwrite etc...believes the range is valid while it's on
vm_struct list.
Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com>
page during __rmqueue_fallback
When there are no pages of a target migratetype free, the page allocator
selects a high-order block of another migratetype to allocate from. When
the order of the page taken is greater than pageblock_order, all
pageblocks within that high-order page should change migratetype so that
pages are later freed to the correct free-lists.
The current behaviour is that pageblocks change migratetype if the order
being split matches the pageblock_order. When pageblock_order <
MAX_ORDER-1, ownership is not changing correct and pages are being later
freed to the incorrect list and this impacts fragmentation avoidance.
This patch changes all pageblocks within the high-order page being split
to the correct migratetype. Without the patch, allocation success rates
for hugepages under stress were about 59% of physical memory on x86-64.
With the patch applied, this goes up to 65%.
Cc: Andy Whitcroft <apw@shadowen.org>
Right now, if you inadvertently pass NULL to kmem_cache_create() at boot
time, it crashes much later after boot somewhere deep inside sysfs which
makes it very non obvious to figure out what's going on.
mremap move's use of ksm_madvise() was assuming -ENOMEM on failure,
because ksm_madvise used to say -EAGAIN for that; but ksm_madvise now says
-ENOMEM (letting madvise convert that to -EAGAIN), and can also say
-ERESTARTSYS when signalled: so pass the error from ksm_madvise.
Acked-by: Izik Eidus <ieidus@redhat.com>
Just as the swapoff system call allocates many pages of RAM to various
processes, perhaps triggering OOM, so "echo 2 >/sys/kernel/mm/ksm/run"
(unmerge) is liable to allocate many pages of RAM to various processes,
perhaps triggering OOM; and each is normally run from a modest admin
process (swapoff or shell), easily repeated until it succeeds.
So treat unmerge_and_remove_all_rmap_items() in the same way that we treat
try_to_unuse(): generalize PF_SWAPOFF to PF_OOM_ORIGIN, and bracket both
with that, to ask the OOM killer to kill them first, to prevent them from
spawning more and more OOM kills.
A few cleanups, given the munlock fix: the comment on ksm_test_exit() no
longer applies, and it can be made private to ksm.c; there's no more
reference to mmu_gather or tlb.h, and mmap.c doesn't need ksm.h.
KSM originally stood for Kernel Shared Memory: but the kernel has long
supported shared memory, and VM_SHARED and VM_MAYSHARE vmas, and KSM is
something else. So we switched to saying "merge" instead of "share".
But Chris Wright points out that this is confusing where mmap.c merges
adjacent vmas: most especially in the name VM_MERGEABLE_FLAGS, used by
is_mergeable_vma() to let vmas be merged despite flags being different.
Call it VMA_MERGE_DESPITE_FLAGS? Perhaps, but at present it consists
only of VM_CAN_NONLINEAR: so for now it's clearer on all sides to use
that directly, with a comment on it in is_mergeable_vma().
Add Documentation/vm/ksm.txt: how to use the Kernel Samepage Merging feature
Cc: Michael Kerrisk <mtk.manpages@googlemail.com>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
At present KSM is just a waste of space if you don't have CONFIG_SYSFS=y
to provide the /sys/kernel/mm/ksm files to tune and activate it.
Make KSM depend on SYSFS? Could do, but it might be better to provide
some defaults so that KSM works out-of-the-box, ready for testers to
madvise MADV_MERGEABLE, even without SYSFS.
Though anyone serious is likely to want to retune the numbers to their
taste once they have experience; and whether these settings ever reach
2.6.32 can be discussed along the way.
Save 1kB from tiny kernels by #ifdef'ing the SYSFS side of it.
Rawhide users have reported hang at startup when cryptsetup is run: the
same problem can be simply reproduced by running a program int main() {
mlockall(MCL_CURRENT | MCL_FUTURE); return 0; }
The problem is that exit_mmap() applies munlock_vma_pages_all() to
clean up VM_LOCKED areas, and its current implementation (stupidly)
tries to fault in absent pages, for example where PROT_NONE prevented
them being faulted in when mlocking. Whereas the "ksm: fix oom
deadlock" patch, knowing there's a race by which KSM might try to fault
in pages after exit_mmap() had finally zapped the range, backs out of
such faults doing nothing when its ksm_test_exit() notices mm_users 0.
So revert that part of "ksm: fix oom deadlock" which moved the
ksm_exit() call from before exit_mmap() to the middle of exit_mmap();
and remove those ksm_test_exit() checks from the page fault paths, so
allowing the munlocking to proceed without interference.
ksm_exit, if there are rmap_items still chained on this mm slot, takes
mmap_sem write side: so preventing KSM from working on an mm while
exit_mmap runs. And KSM will bail out as soon as it notices that
mm_users is already zero, thanks to its internal ksm_test_exit checks.
So that when a task is killed by OOM killer or the user, KSM will not
indefinitely prevent it from running exit_mmap to release its memory.
This does break a part of what "ksm: fix oom deadlock" was trying to
achieve. When unmerging KSM (echo 2 >/sys/kernel/mm/ksm), and even
when ksmd itself has to cancel a KSM page, it is possible that the
first OOM-kill victim would be the KSM process being faulted: then its
memory won't be freed until a second victim has been selected (freeing
memory for the unmerging fault to complete).
But the OOM killer is already liable to kill a second victim once the
intended victim's p->mm goes to NULL: so there's not much point in
rejecting this KSM patch before fixing that OOM behaviour. It is very
much more important to allow KSM users to boot up, than to haggle over
an unlikely and poorly supported OOM case.
We also intend to fix munlocking to not fault pages: at which point
this patch _could_ be reverted; though that would be controversial, so
we hope to find a better solution.
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Acked-by: Justin M. Forbes <jforbes@redhat.com>
Acked-for-now-by: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Cc: Izik Eidus <ieidus@redhat.com>
There's a now-obvious deadlock in KSM's out-of-memory handling:
imagine ksmd or KSM_RUN_UNMERGE handling, holding ksm_thread_mutex,
trying to allocate a page to break KSM in an mm which becomes the
OOM victim (quite likely in the unmerge case): it's killed and goes
to exit, and hangs there waiting to acquire ksm_thread_mutex.
Clearly we must not require ksm_thread_mutex in __ksm_exit, simple
though that made everything else: perhaps use mmap_sem somehow?
And part of the answer lies in the comments on unmerge_ksm_pages:
__ksm_exit should also leave all the rmap_item removal to ksmd.
But there's a fundamental problem, that KSM relies upon mmap_sem to
guarantee the consistency of the mm it's dealing with, yet exit_mmap
tears down an mm without taking mmap_sem. And bumping mm_users won't
help at all, that just ensures that the pages the OOM killer assumes
are on their way to being freed will not be freed.
The best answer seems to be, to move the ksm_exit callout from just
before exit_mmap, to the middle of exit_mmap: after the mm's pages
have been freed (if the mmu_gather is flushed), but before its page
tables and vma structures have been freed; and down_write,up_write
mmap_sem there to serialize with KSM's own reliance on mmap_sem.
But KSM then needs to be careful, whenever it downs mmap_sem, to
check that the mm is not already exiting: there's a danger of using
find_vma on a layout that's being torn apart, or writing into page
tables which have been freed for reuse; and even do_anonymous_page
and __do_fault need to check they're not being called by break_ksm
to reinstate a pte after zap_pte_range has zapped that page table.
Though it might be clearer to add an exiting flag, set while holding
mmap_sem in __ksm_exit, that wouldn't cover the issue of reinstating
a zapped pte. All we need is to check whether mm_users is 0 - but
must remember that ksmd may detect that before __ksm_exit is reached.
So, ksm_test_exit(mm) added to comment such checks on mm->mm_users.
__ksm_exit now has to leave clearing up the rmap_items to ksmd,
that needs ksm_thread_mutex; but shift the exiting mm just after the
ksm_scan cursor so that it will soon be dealt with. __ksm_enter raise
mm_count to hold the mm_struct, ksmd's exit processing (exactly like
its processing when it finds all VM_MERGEABLEs unmapped) mmdrop it,
similar procedure for KSM_RUN_UNMERGE (which has stopped ksmd).
But also give __ksm_exit a fast path: when there's no complication
(no rmap_items attached to mm and it's not at the ksm_scan cursor),
it can safely do all the exiting work itself. This is not just an
optimization: when ksmd is not running, the raised mm_count would
otherwise leak mm_structs.
Do some housekeeping in ksm.c, to help make the next patch easier
to understand: remove the function remove_mm_from_lists, distributing
its code to its callsites scan_get_next_rmap_item and __ksm_exit.
That turns out to be a win in scan_get_next_rmap_item: move its
remove_trailing_rmap_items and cursor advancement up, and it becomes
simpler than before. __ksm_exit becomes messier, but will change
again; and moving its remove_trailing_rmap_items up lets us strengthen
the unstable tree item's age condition in remove_rmap_item_from_tree.
break_ksm has been looping endlessly ignoring VM_FAULT_OOM: that should
only be a problem for ksmd when a memory control group imposes limits
(normally the OOM killer will kill others with an mm until it succeeds);
but in general (especially for MADV_UNMERGEABLE and KSM_RUN_UNMERGE) we
do need to route the error (or kill) back to the caller (or sighandling).
Test signal_pending in unmerge_ksm_pages, which could be a lengthy
procedure if it has to spill into swap: returning -ERESTARTSYS so that
trivial signals will restart but fatals will terminate (is that right?
we do different things in different places in mm, none exactly this).
unmerge_and_remove_all_rmap_items was forgetting to lock when going
down the mm_list: fix that. Whether it's successful or not, reset
ksm_scan cursor to head; but only if it's successful, reset seqnr
(shown in full_scans) - page counts will have gone down to zero.
This patch leaves a significant OOM deadlock, but it's a good step
on the way, and that deadlock is fixed in a subsequent patch.
1. We don't use __break_cow entry point now: merge it into break_cow.
2. remove_all_slot_rmap_items is just a special case of
remove_trailing_rmap_items: use the latter instead.
3. Extend comment on unmerge_ksm_pages and rmap_items.
4. try_to_merge_two_pages should use try_to_merge_with_ksm_page
instead of duplicating its code; and so swap them around.
5. Comment on cmp_and_merge_page described last year's: update it.
ksm_scan_thread already sleeps in wait_event_interruptible until setting
ksm_run activates it; but if there's nothing on its list to look at, i.e.
nobody has yet said madvise MADV_MERGEABLE, it's a shame to be clocking
up system time and full_scans: ksmd_should_run added to check that too.
And move the mutex_lock out around it: the new counts showed that when
ksm_run is stopped, a little work often got done afterwards, because it
had been read before taking the mutex.
We kept agreeing not to bother about the unswappable shared KSM pages
which later become unshared by others: observation suggests they're not
a significant proportion. But they are disadvantageous, and it is easier
to break COW to replace them by swappable pages, than offer statistics
to show that they don't matter; then we can stop worrying about them.
Doing this in ksm_do_scan, they don't go through cmp_and_merge_page on
this pass: give them a good chance of getting into the unstable tree
on the next pass, or back into the stable, by computing checksum now.
The pages_shared and pages_sharing counts give a good picture of how
successful KSM is at sharing; but no clue to how much wasted work it's
doing to get there. Add pages_unshared (count of unique pages waiting
in the unstable tree, hoping to find a mate) and pages_volatile.
pages_volatile is harder to define. It includes those pages changing
too fast to get into the unstable tree, but also whatever other edge
conditions prevent a page getting into the trees: a high value may
deserve investigation. Don't try to calculate it from the various
conditions: it's the total of rmap_items less those accounted for.
Also show full_scans: the number of completed scans of everything
registered in the mm list.
The locking for all these counts is simply ksm_thread_mutex.
Acked-by: Andrea Arcangeli <aarcange@redhat.com>
The pages_shared count is incremented and decremented when adding a node
to and removing a node from the stable tree: easy to understand. But the
pages_sharing count was hard to follow, being adjusted in various places:
increment and decrement it when adding to and removing from the stable tree.
And the pages_sharing variable used to include the pages_shared, then those
were subtracted when shown in the pages_sharing sysfs file: now keep it as
an exclusive count of leaves hanging off the stable tree nodes, throughout.
We're not implementing swapping of KSM pages in its first release;
but when that follows, "kernel_pages_allocated" will be a very poor
name for the sysfs file showing number of nodes in the stable tree:
rename that to "pages_shared" throughout.
But we already have a "pages_shared", counting those page slots
sharing the shared pages: first rename that to... "pages_sharing".
What will become of "max_kernel_pages" when the pages shared can
be swapped? I guess it will just be removed, so keep that name.
ksm should try not to disturb other tasks as much as possible.
Signed-off-by: Izik Eidus <ieidus@redhat.com>
Cc: Chris Wright <chrisw@redhat.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Balbir Singh <balbir@in.ibm.com>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
Cc: Avi Kivity <avi@redhat.com>
Adding Hugh Dickins into the authors list.
KSM's scan allows for user pages to be COWed or unmapped at any time,
without requiring any notification. But its stable tree does assume that
when it finds a KSM page where it placed a KSM page, then it is the same
KSM page that it placed there.
mremap move could break that assumption: if an area containing a KSM page
was unmapped, then an area containing a different KSM page was moved with
mremap into the place of the original, before KSM's scan came around to
notice. That could then poison a node of the stable tree, so that memcmps
would "lie" and upset the ordering of the tree.
Probably noone will ever need mremap move on a VM_MERGEABLE area; except
that prohibiting it would make trouble for schemes in which we try making
everything VM_MERGEABLE e.g. for testing: an mremap which normally works
would then fail mysteriously.
There's no need to go to any trouble, such as re-sorting KSM's list of
rmap_items to match the new layout: simply unmerge the area to COW all its
KSM pages before moving, but leave VM_MERGEABLE on so that they're
remerged later.
Signed-off-by: Chris Wright <chrisw@redhat.com>
