path: root/mm
2011-06-17mm: avoid anon_vma_chain allocation under anon_vma lockLinus Torvalds
Hugh Dickins points out that lockdep (correctly) spots a potential deadlock on the anon_vma lock, because we now do a GFP_KERNEL allocation of anon_vma_chain while doing anon_vma_clone(). The problem is that page reclaim will want to take the anon_vma lock of any anonymous pages that it will try to reclaim. So re-organize the code in anon_vma_clone() slightly: first do just a GFP_NOWAIT allocation, which will usually work fine. But if that fails, let's just drop the lock and re-do the allocation, now with GFP_KERNEL. End result: not only do we avoid the locking problem, this also ends up getting better concurrency in case the allocation does need to block. Tim Chen reports that with all these anon_vma locking tweaks, we're now almost back up to the spinlock performance. Reported-and-tested-by: Hugh Dickins <hughd@google.com> Tested-by: Tim Chen <tim.c.chen@linux.intel.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Andi Kleen <ak@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-17mm: avoid repeated anon_vma lock/unlock sequences in unlink_anon_vmas()Peter Zijlstra
This matches the anon_vma_clone() case, and uses the same lock helper functions. Because of the need to potentially release the anon_vma's, it's a bit more complex, though. We traverse the 'vma->anon_vma_chain' in two phases: the first loop gets the anon_vma lock (with the helper function that only takes the lock once for the whole loop), and removes any entries that don't need any more processing. The second phase just traverses the remaining list entries (without holding the anon_vma lock), and does any actual freeing of the anon_vma's that is required. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Tested-by: Hugh Dickins <hughd@google.com> Tested-by: Tim Chen <tim.c.chen@linux.intel.com> Cc: Andi Kleen <ak@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-17mm: avoid repeated anon_vma lock/unlock sequences in anon_vma_clone()Linus Torvalds
In anon_vma_clone() we traverse the vma->anon_vma_chain of the source vma, locking the anon_vma for each entry. But they are all going to have the same root entry, which means that we're locking and unlocking the same lock over and over again. Which is expensive in locked operations, but can get _really_ expensive when that root entry sees any kind of lock contention. In fact, Tim Chen reports a big performance regression due to this: when we switched to use a mutex instead of a spinlock, the contention case gets much worse. So to alleviate this all, this commit creates a small helper function (lock_anon_vma_root()) that can be used to take the lock just once rather than taking and releasing it over and over again. We still have the same "take the lock and release" it behavior in the exit path (in unlink_anon_vmas()), but that one is a bit harder to fix since we're actually freeing the anon_vma entries as we go, and that will touch the lock too. Reported-and-tested-by: Tim Chen <tim.c.chen@linux.intel.com> Tested-by: Hugh Dickins <hughd@google.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Andi Kleen <ak@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-16migrate: don't account swapcache as shmemAndrea Arcangeli
swapcache will reach the below code path in migrate_page_move_mapping, and swapcache is accounted as NR_FILE_PAGES but it's not accounted as NR_SHMEM. Hugh pointed out we must use PageSwapCache instead of comparing mapping to &swapper_space, to avoid build failure with CONFIG_SWAP=n. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-16mm: get rid of the most spurious find_vma_prev() usersLinus Torvalds
We have some users of this function that date back to before the vma list was doubly linked, and just are silly. These days, you can find the previous vma by just following the vma->vm_prev pointer. In some cases you don't need any find_vma() lookup at all, and in other cases you're better off with the regular "find_vma()" that uses the vma cache front-end lookup. Some "find_vma_prev()" users are still valid, though. For example, in the case of a stack that grows up, it can be the case that we don't find any 'vma' at all (because we're looking up an address that is past the last vma), and that the stack that we want to grow is the 'prev' vma. But that kind of special case aside, we generally should prefer to use 'find_vma()'. Noticed due to a totally unrelated POWER memory corruption bug that just happened to hit in 'find_vma_prev()' and made me go "Hmm - why are we using that function here?". Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15ksm: fix NULL pointer dereference in scan_get_next_rmap_item()Hugh Dickins
Andrea Righi reported a case where an exiting task can race against ksmd::scan_get_next_rmap_item (http://lkml.org/lkml/2011/6/1/742) easily triggering a NULL pointer dereference in ksmd. ksm_scan.mm_slot == &ksm_mm_head with only one registered mm CPU 1 (__ksm_exit) CPU 2 (scan_get_next_rmap_item) list_empty() is false lock slot == &ksm_mm_head list_del(slot->mm_list) (list now empty) unlock lock slot = list_entry(slot->mm_list.next) (list is empty, so slot is still ksm_mm_head) unlock slot->mm == NULL ... Oops Close this race by revalidating that the new slot is not simply the list head again. Andrea's test case: #include <stdio.h> #include <stdlib.h> #include <unistd.h> #include <sys/mman.h> #define BUFSIZE getpagesize() int main(int argc, char **argv) { void *ptr; if (posix_memalign(&ptr, getpagesize(), BUFSIZE) < 0) { perror("posix_memalign"); exit(1); } if (madvise(ptr, BUFSIZE, MADV_MERGEABLE) < 0) { perror("madvise"); exit(1); } *(char *)NULL = 0; return 0; } Reported-by: Andrea Righi <andrea@betterlinux.com> Tested-by: Andrea Righi <andrea@betterlinux.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15mm: compaction: abort compaction if too many pages are isolated and caller ↵Mel Gorman
is asynchronous V2 Asynchronous compaction is used when promoting to huge pages. This is all very nice but if there are a number of processes in compacting memory, a large number of pages can be isolated. An "asynchronous" process can stall for long periods of time as a result with a user reporting that firefox can stall for 10s of seconds. This patch aborts asynchronous compaction if too many pages are isolated as it's better to fail a hugepage promotion than stall a process. [minchan.kim@gmail.com: return COMPACT_PARTIAL for abort] Reported-and-tested-by: Ury Stankevich <urykhy@gmail.com> Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15mm: vmscan: do not use page_count without a page pinAndrea Arcangeli
It is unsafe to run page_count during the physical pfn scan because compound_head could trip on a dangling pointer when reading page->first_page if the compound page is being freed by another CPU. [mgorman@suse.de: split out patch] Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Michal Hocko <mhocko@suse.cz> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15mm: compaction: ensure that the compaction free scanner does not move to the ↵Mel Gorman
next zone Compaction works with two scanners, a migration and a free scanner. When the scanners crossover, migration within the zone is complete. The location of the scanner is recorded on each cycle to avoid excesive scanning. When a zone is small and mostly reserved, it's very easy for the migration scanner to be close to the end of the zone. Then the following situation can occurs o migration scanner isolates some pages near the end of the zone o free scanner starts at the end of the zone but finds that the migration scanner is already there o free scanner gets reinitialised for the next cycle as cc->migrate_pfn + pageblock_nr_pages moving the free scanner into the next zone o migration scanner moves into the next zone When this happens, NR_ISOLATED accounting goes haywire because some of the accounting happens against the wrong zone. One zones counter remains positive while the other goes negative even though the overall global count is accurate. This was reported on X86-32 with !SMP because !SMP allows the negative counters to be visible. The fact that it is the bug should theoritically be possible there. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15compaction: checks correct fragmentation indexShaohua Li
fragmentation_index() returns -1000 when the allocation might succeed This doesn't match the comment and code in compaction_suitable(). I thought compaction_suitable should return COMPACT_PARTIAL in -1000 case, because in this case allocation could succeed depending on watermarks. The impact of this is that compaction starts and compact_finished() is called which rechecks the watermarks and the free lists. It should have the same result in that compaction should not start but is more expensive. Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Shaohua Li <shaohua.li@intel.com> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15mm/memory-failure.c: fix page isolated count mismatchMinchan Kim
Pages isolated for migration are accounted with the vmstat counters NR_ISOLATE_[ANON|FILE]. Callers of migrate_pages() are expected to increment these counters when pages are isolated from the LRU. Once the pages have been migrated, they are put back on the LRU or freed and the isolated count is decremented. Memory failure is not properly accounting for pages it isolates causing the NR_ISOLATED counters to be negative. On SMP builds, this goes unnoticed as negative counters are treated as 0 due to expected per-cpu drift. On UP builds, the counter is treated by too_many_isolated() as a large value causing processes to enter D state during page reclaim or compaction. This patch accounts for pages isolated by memory failure correctly. [mel@csn.ul.ie: rewrote changelog] Reviewed-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Cc: Andi Kleen <andi@firstfloor.org> Acked-by: Mel Gorman <mel@csn.ul.ie> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15memcg: avoid percpu cached charge draining at softlimitKAMEZAWA Hiroyuki
Based on Michal Hocko's comment. We are not draining per cpu cached charges during soft limit reclaim because background reclaim doesn't care about charges. It tries to free some memory and charges will not give any. Cached charges might influence only selection of the biggest soft limit offender but as the call is done only after the selection has been already done it makes no change. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Reviewed-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15memcg: fix percpu cached charge draining frequencyKAMEZAWA Hiroyuki
For performance, memory cgroup caches some "charge" from res_counter into per cpu cache. This works well but because it's cache, it needs to be flushed in some cases. Typical cases are 1. when someone hit limit. 2. when rmdir() is called and need to charges to be 0. But "1" has problem. Recently, with large SMP machines, we see many kworker runs because of flushing memcg's cache. Bad things in implementation are that even if a cpu contains a cache for memcg not related to a memcg which hits limit, drain code is called. This patch does A) check percpu cache contains a useful data or not. B) check other asynchronous percpu draining doesn't run. C) don't call local cpu callback. (*)This patch avoid changing the calling condition with hard-limit. When I run "cat 1Gfile > /dev/null" under 300M limit memcg, [Before] 13767 kamezawa 20 0 98.6m 424 416 D 10.0 0.0 0:00.61 cat 58 root 20 0 0 0 0 S 0.6 0.0 0:00.09 kworker/2:1 60 root 20 0 0 0 0 S 0.6 0.0 0:00.08 kworker/4:1 4 root 20 0 0 0 0 S 0.3 0.0 0:00.02 kworker/0:0 57 root 20 0 0 0 0 S 0.3 0.0 0:00.05 kworker/1:1 61 root 20 0 0 0 0 S 0.3 0.0 0:00.05 kworker/5:1 62 root 20 0 0 0 0 S 0.3 0.0 0:00.05 kworker/6:1 63 root 20 0 0 0 0 S 0.3 0.0 0:00.05 kworker/7:1 [After] 2676 root 20 0 98.6m 416 416 D 9.3 0.0 0:00.87 cat 2626 kamezawa 20 0 15192 1312 920 R 0.3 0.0 0:00.28 top 1 root 20 0 19384 1496 1204 S 0.0 0.0 0:00.66 init 2 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kthreadd 3 root 20 0 0 0 0 S 0.0 0.0 0:00.00 ksoftirqd/0 4 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kworker/0:0 [akpm@linux-foundation.org: make percpu_charge_mutex static, tweak comments] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Reviewed-by: Michal Hocko <mhocko@suse.cz> Tested-by: Ying Han <yinghan@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15memcg: fix wrong check of noswap with softlimitKAMEZAWA Hiroyuki
Hierarchical reclaim doesn't swap out if memsw and resource limits are thye same (memsw_is_minimum == true) because we would hit mem+swap limit anyway (during hard limit reclaim). If it comes to the soft limit we shouldn't consider memsw_is_minimum at all because it doesn't make much sense. Either the soft limit is bellow the hard limit and then we cannot hit mem+swap limit or the direct reclaim takes a precedence. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Acked-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15memcg: fix init_page_cgroup nid with sparsememKAMEZAWA Hiroyuki
Commit 21a3c9646873 ("memcg: allocate memory cgroup structures in local nodes") makes page_cgroup allocation as NUMA aware. But that caused a problem https://bugzilla.kernel.org/show_bug.cgi?id=36192. The problem was getting a NID from invalid struct pages, which was not initialized because it was out-of-node, out of [node_start_pfn, node_end_pfn) Now, with sparsemem, page_cgroup_init scans pfn from 0 to max_pfn. But this may scan a pfn which is not on any node and can access memmap which is not initialized. This makes page_cgroup_init() for SPARSEMEM node aware and remove a code to get nid from page->flags. (Then, we'll use valid NID always.) [akpm@linux-foundation.org: try to fix up comments] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15mm: memory.numa_stat: fix file permissionKAMEZAWA Hiroyuki
Commit 406eb0c9ba76 ("memcg: add memory.numastat api for numa statistics") adds memory.numa_stat file for memory cgroup. But the file permissions are wrong. [kamezawa@bluextal linux-2.6]$ ls -l /cgroup/memory/A/memory.numa_stat ---------- 1 root root 0 Jun 9 18:36 /cgroup/memory/A/memory.numa_stat This patch fixes the permission as [root@bluextal kamezawa]# ls -l /cgroup/memory/A/memory.numa_stat -r--r--r-- 1 root root 0 Jun 10 16:49 /cgroup/memory/A/memory.numa_stat Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Ying Han <yinghan@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15mm: fix negative commitlimit when gigantic hugepages are allocatedRafael Aquini
When 1GB hugepages are allocated on a system, free(1) reports less available memory than what really is installed in the box. Also, if the total size of hugepages allocated on a system is over half of the total memory size, CommitLimit becomes a negative number. The problem is that gigantic hugepages (order > MAX_ORDER) can only be allocated at boot with bootmem, thus its frames are not accounted to 'totalram_pages'. However, they are accounted to hugetlb_total_pages() What happens to turn CommitLimit into a negative number is this calculation, in fs/proc/meminfo.c: allowed = ((totalram_pages - hugetlb_total_pages()) * sysctl_overcommit_ratio / 100) + total_swap_pages; A similar calculation occurs in __vm_enough_memory() in mm/mmap.c. Also, every vm statistic which depends on 'totalram_pages' will render confusing values, as if system were 'missing' some part of its memory. Impact of this bug: When gigantic hugepages are allocated and sysctl_overcommit_memory == OVERCOMMIT_NEVER. In a such situation, __vm_enough_memory() goes through the mentioned 'allowed' calculation and might end up mistakenly returning -ENOMEM, thus forcing the system to start reclaiming pages earlier than it would be ususal, and this could cause detrimental impact to overall system's performance, depending on the workload. Besides the aforementioned scenario, I can only think of this causing annoyances with memory reports from /proc/meminfo and free(1). [akpm@linux-foundation.org: standardize comment layout] Reported-by: Russ Anderson <rja@sgi.com> Signed-off-by: Rafael Aquini <aquini@linux.com> Acked-by: Russ Anderson <rja@sgi.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Christoph Lameter <cl@linux.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15mm/memory_hotplug.c: fix building of node hotplug zonelistKAMEZAWA Hiroyuki
During memory hotplug we refresh zonelists when we online a page in a new zone. It means that the node's zonelist is not initialized until pages are onlined. So for example, "nid" passed by MEM_GOING_ONLINE notifier will point to NODE_DATA(nid) which has no zone fallback list. Moreover, if we hot-add cpu-only nodes, alloc_pages() will do no fallback. This patch makes a zonelist when a new pgdata is available. Note: in production, at fujitsu, memory should be onlined before cpu and our server didn't have any memory-less nodes and had no problems. But recent changes in MEM_GOING_ONLINE+page_cgroup will access not initialized zonelist of node. Anyway, there are memory-less node and we need some care. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15mm: compaction: fix special case -1 order checksMichal Hocko
Commit 56de7263fcf3 ("mm: compaction: direct compact when a high-order allocation fails") introduced a check for cc->order == -1 in compact_finished. We should continue compacting in that case because the request came from userspace and there is no particular order to compact for. Similar check has been added by 82478fb7 (mm: compaction: prevent division-by-zero during user-requested compaction) for compaction_suitable. The check is, however, done after zone_watermark_ok which uses order as a right hand argument for shifts. Not only watermark check is pointless if we can break out without it but it also uses 1 << -1 which is not well defined (at least from C standard). Let's move the -1 check above zone_watermark_ok. [minchan.kim@gmail.com> - caught compaction_suitable] Signed-off-by: Michal Hocko <mhocko@suse.cz> Cc: Mel Gorman <mgorman@suse.de> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hioryu@jp.fujitsu.com> Acked-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15mm: fix wrong kunmap_atomic() pointerSteven Rostedt
Running a ktest.pl test, I hit the following bug on x86_32: ------------[ cut here ]------------ WARNING: at arch/x86/mm/highmem_32.c:81 __kunmap_atomic+0x64/0xc1() Hardware name: Modules linked in: Pid: 93, comm: sh Not tainted 2.6.39-test+ #1 Call Trace: [<c04450da>] warn_slowpath_common+0x7c/0x91 [<c042f5df>] ? __kunmap_atomic+0x64/0xc1 [<c042f5df>] ? __kunmap_atomic+0x64/0xc1^M [<c0445111>] warn_slowpath_null+0x22/0x24 [<c042f5df>] __kunmap_atomic+0x64/0xc1 [<c04d4a22>] unmap_vmas+0x43a/0x4e0 [<c04d9065>] exit_mmap+0x91/0xd2 [<c0443057>] mmput+0x43/0xad [<c0448358>] exit_mm+0x111/0x119 [<c044855f>] do_exit+0x1ff/0x5fa [<c0454ea2>] ? set_current_blocked+0x3c/0x40 [<c0454f24>] ? sigprocmask+0x7e/0x8e [<c0448b55>] do_group_exit+0x65/0x88 [<c0448b90>] sys_exit_group+0x18/0x1c [<c0c3915f>] sysenter_do_call+0x12/0x38 ---[ end trace 8055f74ea3c0eb62 ]--- Running a ktest.pl git bisect, found the culprit: commit e303297e6c3a ("mm: extended batches for generic mmu_gather") But although this was the commit triggering the bug, it was not the one originally responsible for the bug. That was commit d16dfc550f53 ("mm: mmu_gather rework"). The code in zap_pte_range() has something that looks like the following: pte = pte_offset_map_lock(mm, pmd, addr, &ptl); do { [...] } while (pte++, addr += PAGE_SIZE, addr != end); pte_unmap_unlock(pte - 1, ptl); The pte starts off pointing at the first element in the page table directory that was returned by the pte_offset_map_lock(). When it's done with the page, pte will be pointing to anything between the next entry and the first entry of the next page inclusive. By doing a pte - 1, this puts the pte back onto the original page, which is all that pte_unmap_unlock() needs. In most archs (64 bit), this is not an issue as the pte is ignored in the pte_unmap_unlock(). But on 32 bit archs, where things may be kmapped, it is essential that the pte passed to pte_unmap_unlock() resides on the same page that was given by pte_offest_map_lock(). The problem came in d16dfc55 ("mm: mmu_gather rework") where it introduced a "break;" from the while loop. This alone did not seem to easily trigger the bug. But the modifications made by e303297e6 caused that "break;" to be hit on the first iteration, before the pte++. The pte not being incremented will now cause pte_unmap_unlock(pte - 1) to be pointing to the previous page. This will cause the wrong page to be unmapped, and also trigger the warning above. The simple solution is to just save the pointer given by pte_offset_map_lock() and use it in the unlock. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15vmscan: implement swap token priority agingKOSAKI Motohiro
While testing for memcg aware swap token, I observed a swap token was often grabbed an intermittent running process (eg init, auditd) and they never release a token. Why? Some processes (eg init, auditd, audispd) wake up when a process exiting. And swap token can be get first page-in process when a process exiting makes no swap token owner. Thus such above intermittent running process often get a token. And currently, swap token priority is only decreased at page fault path. Then, if the process sleep immediately after to grab swap token, the swap token priority never be decreased. That's obviously undesirable. This patch implement very poor (and lightweight) priority aging. It only be affect to the above corner case and doesn't change swap tendency workload performance (eg multi process qsbench load) Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15vmscan: implement swap token traceKOSAKI Motohiro
This is useful for observing swap token activity. example output: zsh-1845 [000] 598.962716: update_swap_token_priority: mm=ffff88015eaf7700 old_prio=1 new_prio=0 memtoy-1830 [001] 602.033900: update_swap_token_priority: mm=ffff880037a45880 old_prio=947 new_prio=949 memtoy-1830 [000] 602.041509: update_swap_token_priority: mm=ffff880037a45880 old_prio=949 new_prio=951 memtoy-1830 [000] 602.051959: update_swap_token_priority: mm=ffff880037a45880 old_prio=951 new_prio=953 memtoy-1830 [000] 602.052188: update_swap_token_priority: mm=ffff880037a45880 old_prio=953 new_prio=955 memtoy-1830 [001] 602.427184: put_swap_token: token_mm=ffff880037a45880 zsh-1789 [000] 602.427281: replace_swap_token: old_token_mm= (null) old_prio=0 new_token_mm=ffff88015eaf7018 new_prio=2 zsh-1789 [001] 602.433456: update_swap_token_priority: mm=ffff88015eaf7018 old_prio=2 new_prio=4 zsh-1789 [000] 602.437613: update_swap_token_priority: mm=ffff88015eaf7018 old_prio=4 new_prio=6 zsh-1789 [000] 602.443924: update_swap_token_priority: mm=ffff88015eaf7018 old_prio=6 new_prio=8 zsh-1789 [000] 602.451873: update_swap_token_priority: mm=ffff88015eaf7018 old_prio=8 new_prio=10 zsh-1789 [001] 602.462639: update_swap_token_priority: mm=ffff88015eaf7018 old_prio=10 new_prio=12 Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Rik van Riel<riel@redhat.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15vmscan,memcg: memcg aware swap tokenKOSAKI Motohiro
Currently, memcg reclaim can disable swap token even if the swap token mm doesn't belong in its memory cgroup. It's slightly risky. If an admin creates very small mem-cgroup and silly guy runs contentious heavy memory pressure workload, every tasks are going to lose swap token and then system may become unresponsive. That's bad. This patch adds 'memcg' parameter into disable_swap_token(). and if the parameter doesn't match swap token, VM doesn't disable it. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Rik van Riel<riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15mm/memory.c: fix kernel-doc notationRandy Dunlap
Fix new kernel-doc warnings in mm/memory.c: Warning(mm/memory.c:1327): No description found for parameter 'tlb' Warning(mm/memory.c:1327): Excess function parameter 'tlbp' description in 'unmap_vmas' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15mm: remove khugepaged double thp vmstat update with CONFIG_NUMA=nAndrea Arcangeli
Johannes noticed the vmstat update is already taken care of by khugepaged_alloc_hugepage() internally. The only places that are required to update the vmstat are the callers of alloc_hugepage (callers of khugepaged_alloc_hugepage aren't). Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Reported-by: Johannes Weiner <jweiner@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: Johannes Weiner <jweiner@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6: SLAB: Record actual last user of freed objects. slub: always align cpu_slab to honor cmpxchg_double requirement
2011-06-07Merge branch 'for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: vfs: make unlink() and rmdir() return ENOENT in preference to EROFS lmLogOpen() broken failure exit usb: remove bad dput after dentry_unhash more conservative S_NOSEC handling
2011-06-06mm: fix ENOSPC returned by handle_mm_fault()Hugh Dickins
Al Viro observes that in the hugetlb case, handle_mm_fault() may return a value of the kind ENOSPC when its caller is expecting a value of the kind VM_FAULT_SIGBUS: fix alloc_huge_page()'s failure returns. Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-03more conservative S_NOSEC handlingAl Viro
Caching "we have already removed suid/caps" was overenthusiastic as merged. On network filesystems we might have had suid/caps set on another client, silently picked by this client on revalidate, all of that *without* clearing the S_NOSEC flag. AFAICS, the only reasonably sane way to deal with that is * new superblock flag; unless set, S_NOSEC is not going to be set. * local block filesystems set it in their ->mount() (more accurately, mount_bdev() does, so does btrfs ->mount(), users of mount_bdev() other than local block ones clear it) * if any network filesystem (or a cluster one) wants to use S_NOSEC, it'll need to set MS_NOSEC in sb->s_flags *AND* take care to clear S_NOSEC when inode attribute changes are picked from other clients. It's not an earth-shattering hole (anybody that can set suid on another client will almost certainly be able to write to the file before doing that anyway), but it's a bug that needs fixing. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-06-03SLAB: Record actual last user of freed objects.Suleiman Souhlal
Currently, when using CONFIG_DEBUG_SLAB, we put in kfree() or kmem_cache_free() as the last user of free objects, which is not very useful, so change it to the caller of those functions instead. Acked-by: David Rientjes <rientjes@google.com> Acked-by: Christoph Lameter <cl@linux.com> Signed-off-by: Suleiman Souhlal <suleiman@google.com> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2011-06-03slub: always align cpu_slab to honor cmpxchg_double requirementChris Metcalf
On an architecture without CMPXCHG_LOCAL but with DEBUG_VM enabled, the VM_BUG_ON() in __pcpu_double_call_return_bool() will cause an early panic during boot unless we always align cpu_slab properly. In principle we could remove the alignment-testing VM_BUG_ON() for architectures that don't have CMPXCHG_LOCAL, but leaving it in means that new code will tend not to break x86 even if it is introduced on another platform, and it's low cost to require alignment. Acked-by: David Rientjes <rientjes@google.com> Acked-by: Christoph Lameter <cl@linux.com> Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2011-06-02Revert "mm: fail GFP_DMA allocations when ZONE_DMA is not configured"Linus Torvalds
This reverts commit a197b59ae6e8bee56fcef37ea2482dc08414e2ac. As rmk says: "Commit a197b59ae6e8 (mm: fail GFP_DMA allocations when ZONE_DMA is not configured) is causing regressions on ARM with various drivers which use GFP_DMA. The behaviour up until now has been to silently ignore that flag when CONFIG_ZONE_DMA is not enabled, and to allocate from the normal zone. However, as a result of the above commit, such allocations now fail which causes drivers to fail. These are regressions compared to the previous kernel version." so just revert it. Requested-by: Russell King <linux@arm.linux.org.uk> Acked-by: Andrew Morton <akpm@linux-foundation.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-29mm, rmap: Add yet more comments to page_get_anon_vma/page_lock_anon_vmaPeter Zijlstra
Inspired by an analysis from Hugh on why again all this doesn't explode in our face. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-28mm: fix page_lock_anon_vma leaving mutex lockedHugh Dickins
On one machine I've been getting hangs, a page fault's anon_vma_prepare() waiting in anon_vma_lock(), other processes waiting for that page's lock. This is a replay of last year's f18194275c39 "mm: fix hang on anon_vma->root->lock". The new page_lock_anon_vma() places too much faith in its refcount: when it has acquired the mutex_trylock(), it's possible that a racing task in anon_vma_alloc() has just reallocated the struct anon_vma, set refcount to 1, and is about to reset its anon_vma->root. Fix this by saving anon_vma->root, and relying on the usual page_mapped() check instead of a refcount check: if page is still mapped, the anon_vma is still ours; if page is not still mapped, we're no longer interested. Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-28mm: fix kernel BUG at mm/rmap.c:1017!Hugh Dickins
I've hit the "address >= vma->vm_end" check in do_page_add_anon_rmap() just once. The stack showed khugepaged allocation trying to compact pages: the call to page_add_anon_rmap() coming from remove_migration_pte(). That path holds anon_vma lock, but does not hold mmap_sem: it can therefore race with a split_vma(), and in commit 5f70b962ccc2 "mmap: avoid unnecessary anon_vma lock" we just took away the anon_vma lock protection when adjusting vma->vm_end. I don't think that particular BUG_ON ever caught anything interesting, so better replace it by a comment, than reinstate the anon_vma locking. Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-28tmpfs: fix race between truncate and writepageHugh Dickins
While running fsx on tmpfs with a memhog then swapoff, swapoff was hanging (interruptibly), repeatedly failing to locate the owner of a 0xff entry in the swap_map. Although shmem_writepage() does abandon when it sees incoming page index is beyond eof, there was still a window in which shmem_truncate_range() could come in between writepage's dropping lock and updating swap_map, find the half-completed swap_map entry, and in trying to free it, leave it in a state that swap_shmem_alloc() could not correct. Arguably a bug in __swap_duplicate()'s and swap_entry_free()'s handling of the different cases, but easiest to fix by moving swap_shmem_alloc() under cover of the lock. More interesting than the bug: it's been there since 2.6.33, why could I not see it with earlier kernels? The mmotm of two weeks ago seems to have some magic for generating races, this is just one of three I found. With yesterday's git I first saw this in mainline, bisected in search of that magic, but the easy reproducibility evaporated. Oh well, fix the bug. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (36 commits) Cache xattr security drop check for write v2 fs: block_page_mkwrite should wait for writeback to finish mm: Wait for writeback when grabbing pages to begin a write configfs: remove unnecessary dentry_unhash on rmdir, dir rename fat: remove unnecessary dentry_unhash on rmdir, dir rename hpfs: remove unnecessary dentry_unhash on rmdir, dir rename minix: remove unnecessary dentry_unhash on rmdir, dir rename fuse: remove unnecessary dentry_unhash on rmdir, dir rename coda: remove unnecessary dentry_unhash on rmdir, dir rename afs: remove unnecessary dentry_unhash on rmdir, dir rename affs: remove unnecessary dentry_unhash on rmdir, dir rename 9p: remove unnecessary dentry_unhash on rmdir, dir rename ncpfs: fix rename over directory with dangling references ncpfs: document dentry_unhash usage ecryptfs: remove unnecessary dentry_unhash on rmdir, dir rename hostfs: remove unnecessary dentry_unhash on rmdir, dir rename hfsplus: remove unnecessary dentry_unhash on rmdir, dir rename hfs: remove unnecessary dentry_unhash on rmdir, dir rename omfs: remove unnecessary dentry_unhash on rmdir, dir rneame udf: remove unnecessary dentry_unhash from rmdir, dir rename ...
2011-05-28Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (25 commits) perf: Fix SIGIO handling perf top: Don't stop if no kernel symtab is found perf top: Handle kptr_restrict perf top: Remove unused macro perf events: initialize fd array to -1 instead of 0 perf tools: Make sure kptr_restrict warnings fit 80 col terms perf tools: Fix build on older systems perf symbols: Handle /proc/sys/kernel/kptr_restrict perf: Remove duplicate headers ftrace: Add internal recursive checks tracing: Update btrfs's tracepoints to use u64 interface tracing: Add __print_symbolic_u64 to avoid warnings on 32bit machine ftrace: Set ops->flag to enabled even on static function tracing tracing: Have event with function tracer check error return ftrace: Have ftrace_startup() return failure code jump_label: Check entries limit in __jump_label_update ftrace/recordmcount: Avoid STT_FUNC symbols as base on ARM scripts/tags.sh: Add magic for trace-events for etags too scripts/tags.sh: Fix ctags for DEFINE_EVENT() x86/ftrace: Fix compiler warning in ftrace.c ...
2011-05-28Cache xattr security drop check for write v2Andi Kleen
Some recent benchmarking on btrfs showed that a major scaling bottleneck on large systems on btrfs is currently the xattr lookup on every write. Why xattr lookup on every write I hear you ask? write wants to drop suid and security related xattrs that could set o capabilities for executables. To do that it currently looks up security.capability on EVERY write (even for non executables) to decide whether to drop it or not. In btrfs this causes an additional tree walk, hitting some per file system locks and quite bad scalability. In a simple read workload on a 8S system I saw over 90% CPU time in spinlocks related to that. Chris Mason tells me this is also a problem in ext4, where it hits the global mbcache lock. This patch adds a simple per inode to avoid this problem. We only do the lookup once per file and then if there is no xattr cache the decision. All xattr changes clear the flag. I also used the same flag to avoid the suid check, although that one is pretty cheap. A file system can also set this flag when it creates the inode, if it has a cheap way to do so. This is done for some common file systems in followon patches. With this patch a major part of the lock contention disappears for btrfs. Some testing on smaller systems didn't show significant performance changes, but at least it helps the larger systems and is generally more efficient. v2: Rename is_sgid. add file system helper. Cc: chris.mason@oracle.com Cc: josef@redhat.com Cc: viro@zeniv.linux.org.uk Cc: agruen@linbit.com Cc: Serge E. Hallyn <serue@us.ibm.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-28mm: Wait for writeback when grabbing pages to begin a writeDarrick J. Wong
When grabbing a page for a buffered IO write, the mm should wait for writeback on the page to complete so that the page does not become writable during the IO operation. This change is needed to provide page stability during writes for all filesystems. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-27Merge branch 'tip/perf/urgent' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into perf/urgent
2011-05-26Merge branch 'upstream/tidy-xen-mmu-2.6.39' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen * 'upstream/tidy-xen-mmu-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen: xen: fix compile without CONFIG_XEN_DEBUG_FS Use arbitrary_virt_to_machine() to deal with ioremapped pud updates. Use arbitrary_virt_to_machine() to deal with ioremapped pmd updates. xen/mmu: remove all ad-hoc stats stuff xen: use normal virt_to_machine for ptes xen: make a pile of mmu pvop functions static vmalloc: remove vmalloc_sync_all() from alloc_vm_area() xen: condense everything onto xen_set_pte xen: use mmu_update for xen_set_pte_at() xen: drop all the special iomap pte paths.
2011-05-26memcg: add the pagefault count into memcg statsYing Han
Two new stats in per-memcg memory.stat which tracks the number of page faults and number of major page faults. "pgfault" "pgmajfault" They are different from "pgpgin"/"pgpgout" stat which count number of pages charged/discharged to the cgroup and have no meaning of reading/ writing page to disk. It is valuable to track the two stats for both measuring application's performance as well as the efficiency of the kernel page reclaim path. Counting pagefaults per process is useful, but we also need the aggregated value since processes are monitored and controlled in cgroup basis in memcg. Functional test: check the total number of pgfault/pgmajfault of all memcgs and compare with global vmstat value: $ cat /proc/vmstat | grep fault pgfault 1070751 pgmajfault 553 $ cat /dev/cgroup/memory.stat | grep fault pgfault 1071138 pgmajfault 553 total_pgfault 1071142 total_pgmajfault 553 $ cat /dev/cgroup/A/memory.stat | grep fault pgfault 199 pgmajfault 0 total_pgfault 199 total_pgmajfault 0 Performance test: run page fault test(pft) wit 16 thread on faulting in 15G anon pages in 16G container. There is no regression noticed on the "flt/cpu/s" Sample output from pft: TAG pft:anon-sys-default: Gb Thr CLine User System Wall flt/cpu/s fault/wsec 15 16 1 0.67s 233.41s 14.76s 16798.546 266356.260 +-------------------------------------------------------------------------+ N Min Max Median Avg Stddev x 10 16682.962 17344.027 16913.524 16928.812 166.5362 + 10 16695.568 16923.896 16820.604 16824.652 84.816568 No difference proven at 95.0% confidence [akpm@linux-foundation.org: fix build] [hughd@google.com: shmem fix] Signed-off-by: Ying Han <yinghan@google.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26memcg: add memory.numastat api for numa statisticsYing Han
The new API exports numa_maps per-memcg basis. This is a piece of useful information where it exports per-memcg page distribution across real numa nodes. One of the usecases is evaluating application performance by combining this information w/ the cpu allocation to the application. The output of the memory.numastat tries to follow w/ simiar format of numa_maps like: total=<total pages> N0=<node 0 pages> N1=<node 1 pages> ... file=<total file pages> N0=<node 0 pages> N1=<node 1 pages> ... anon=<total anon pages> N0=<node 0 pages> N1=<node 1 pages> ... unevictable=<total anon pages> N0=<node 0 pages> N1=<node 1 pages> ... And we have per-node: total = file + anon + unevictable $ cat /dev/cgroup/memory/memory.numa_stat total=250020 N0=87620 N1=52367 N2=45298 N3=64735 file=225232 N0=83402 N1=46160 N2=40522 N3=55148 anon=21053 N0=3424 N1=6207 N2=4776 N3=6646 unevictable=3735 N0=794 N1=0 N2=0 N3=2941 Signed-off-by: Ying Han <yinghan@google.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26memcg: rename mem_cgroup_zone_nr_pages() to mem_cgroup_zone_nr_lru_pages()Ying Han
The caller of the function has been renamed to zone_nr_lru_pages(), and this is just fixing up in the memcg code. The current name is easily to be mis-read as zone's total number of pages. Signed-off-by: Ying Han <yinghan@google.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26memcg: remove unused retry signal from reclaimJohannes Weiner
If the memcg reclaim code detects the target memcg below its limit it exits and returns a guaranteed non-zero value so that the charge is retried. Nowadays, the charge side checks the memcg limit itself and does not rely on this non-zero return value trick. This patch removes it. The reclaim code will now always return the true number of pages it reclaimed on its own. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Rik van Riel<riel@redhat.com> Acked-by: Ying Han<yinghan@google.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26memcg: fix get_scan_count() for small targetsKAMEZAWA Hiroyuki
During memory reclaim we determine the number of pages to be scanned per zone as (anon + file) >> priority. Assume scan = (anon + file) >> priority. If scan < SWAP_CLUSTER_MAX, the scan will be skipped for this time and priority gets higher. This has some problems. 1. This increases priority as 1 without any scan. To do scan in this priority, amount of pages should be larger than 512M. If pages>>priority < SWAP_CLUSTER_MAX, it's recorded and scan will be batched, later. (But we lose 1 priority.) If memory size is below 16M, pages >> priority is 0 and no scan in DEF_PRIORITY forever. 2. If zone->all_unreclaimabe==true, it's scanned only when priority==0. So, x86's ZONE_DMA will never be recoverred until the user of pages frees memory by itself. 3. With memcg, the limit of memory can be small. When using small memcg, it gets priority < DEF_PRIORITY-2 very easily and need to call wait_iff_congested(). For doing scan before priorty=9, 64MB of memory should be used. Then, this patch tries to scan SWAP_CLUSTER_MAX of pages in force...when 1. the target is enough small. 2. it's kswapd or memcg reclaim. Then we can avoid rapid priority drop and may be able to recover all_unreclaimable in a small zones. And this patch removes nr_saved_scan. This will allow scanning in this priority even when pages >> priority is very small. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Ying Han <yinghan@google.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26memcg: reclaim memory from nodes in round-robin orderYing Han
Presently, memory cgroup's direct reclaim frees memory from the current node. But this has some troubles. Usually when a set of threads works in a cooperative way, they tend to operate on the same node. So if they hit limits under memcg they will reclaim memory from themselves, damaging the active working set. For example, assume 2 node system which has Node 0 and Node 1 and a memcg which has 1G limit. After some work, file cache remains and the usages are Node 0: 1M Node 1: 998M. and run an application on Node 0, it will eat its foot before freeing unnecessary file caches. This patch adds round-robin for NUMA and adds equal pressure to each node. When using cpuset's spread memory feature, this will work very well. But yes, a better algorithm is needed. [akpm@linux-foundation.org: comment editing] [kamezawa.hiroyu@jp.fujitsu.com: fix time comparisons] Signed-off-by: Ying Han <yinghan@google.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26memcg: move page-freeing code out of lockNamhyung Kim
Move page-freeing code out of swap_cgroup_mutex in the hope that it could reduce few of theoretical contentions between swapons and/or swapoffs. This is just a cleanup, no functional changes. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26memcg: fix off-by-one when calculating swap cgroup map lengthNamhyung Kim
It allocated one more page than necessary if @max_pages was a multiple of SC_PER_PAGE. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
