path: root/mm
2008-10-23Merge branch 'proc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/adobriyan/proc * 'proc' of git://git.kernel.org/pub/scm/linux/kernel/git/adobriyan/proc: (35 commits) proc: remove fs/proc/proc_misc.c proc: move /proc/vmcore creation to fs/proc/vmcore.c proc: move pagecount stuff to fs/proc/page.c proc: move all /proc/kcore stuff to fs/proc/kcore.c proc: move /proc/schedstat boilerplate to kernel/sched_stats.h proc: move /proc/modules boilerplate to kernel/module.c proc: move /proc/diskstats boilerplate to block/genhd.c proc: move /proc/zoneinfo boilerplate to mm/vmstat.c proc: move /proc/vmstat boilerplate to mm/vmstat.c proc: move /proc/pagetypeinfo boilerplate to mm/vmstat.c proc: move /proc/buddyinfo boilerplate to mm/vmstat.c proc: move /proc/vmallocinfo to mm/vmalloc.c proc: move /proc/slabinfo boilerplate to mm/slub.c, mm/slab.c proc: move /proc/slab_allocators boilerplate to mm/slab.c proc: move /proc/interrupts boilerplate code to fs/proc/interrupts.c proc: move /proc/stat to fs/proc/stat.c proc: move rest of /proc/partitions code to block/genhd.c proc: move /proc/cpuinfo code to fs/proc/cpuinfo.c proc: move /proc/devices code to fs/proc/devices.c proc: move rest of /proc/locks to fs/locks.c ...
2008-10-23memcg: fix page_cgroup allocationKAMEZAWA Hiroyuki
page_cgroup_init() is called from mem_cgroup_init(). But at this point, we cannot call alloc_bootmem(). (and this caused panic at boot.) This patch moves page_cgroup_init() to init/main.c. Time table is following: == parse_args(). # we can trust mem_cgroup_subsys.disabled bit after this. .... cgroup_init_early() # "early" init of cgroup. .... setup_arch() # memmap is allocated. ... page_cgroup_init(); mem_init(); # we cannot call alloc_bootmem after this. .... cgroup_init() # mem_cgroup is initialized. == Before page_cgroup_init(), mem_map must be initialized. So, I added page_cgroup_init() to init/main.c directly. (*) maybe this is not very clean but - cgroup_init_early() is too early - in cgroup_init(), we have to use vmalloc instead of alloc_bootmem(). use of vmalloc area in x86-32 is important and we should avoid very large vmalloc() in x86-32. So, we want to use alloc_bootmem() and added page_cgroup_init() directly to init/main.c [akpm@linux-foundation.org: remove unneeded/bad mem_cgroup_subsys declaration] [akpm@linux-foundation.org: fix build] Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Tested-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-23mm: page_cgroup needs linux/vmalloc.h for vmalloc_node()/vfree().Paul Mundt
mm/page_cgroup.c: In function 'init_section_page_cgroup': mm/page_cgroup.c:111: error: implicit declaration of function 'vmalloc_node' mm/page_cgroup.c:111: warning: assignment makes pointer from integer without a cast mm/page_cgroup.c: In function '__free_page_cgroup': mm/page_cgroup.c:140: error: implicit declaration of function 'vfree' Signed-off-by: Paul Mundt <lethal@linux-sh.org> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-23proc: move /proc/zoneinfo boilerplate to mm/vmstat.cAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Christoph Lameter <cl@linux-foundation.org>
2008-10-23proc: move /proc/vmstat boilerplate to mm/vmstat.cAlexey Dobriyan
2008-10-23proc: move /proc/pagetypeinfo boilerplate to mm/vmstat.cAlexey Dobriyan
2008-10-23proc: move /proc/buddyinfo boilerplate to mm/vmstat.cAlexey Dobriyan
2008-10-23proc: move /proc/vmallocinfo to mm/vmalloc.cAlexey Dobriyan
2008-10-23proc: move /proc/slabinfo boilerplate to mm/slub.c, mm/slab.cAlexey Dobriyan
Lose dummy ->write hook in case of SLUB, it's possible now. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-10-23proc: move /proc/slab_allocators boilerplate to mm/slab.cAlexey Dobriyan
2008-10-23proc: switch /proc/meminfo to seq_fileAlexey Dobriyan
and move it to fs/proc/meminfo.c while I'm at it. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2008-10-20mm: remove duplicated #include'sHuang Weiyi
Removed duplicated #include <linux/vmalloc.h> in mm/vmalloc.c and "internal.h" in mm/memory.c. Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20Export tiny shmem_file_setup for DRM-GEMHugh Dickins
We're trying to keep the !CONFIG_SHMEM tiny-shmem.c (using ramfs without swap) in synch with CONFIG_SHMEM shmem.c (and mpm is preparing patches to combine them). I was glad to see EXPORT_SYMBOL_GPL(shmem_file_setup) go into shmem.c, but why not support DRM-GEM when !CONFIG_SHMEM too? But caution says still depend on MMU, since !CONFIG_MMU is.. different. Signed-off-by: Hugh Dickins <hugh@veritas.com> Acked-by: Matt Mackall <mpm@selenic.com> Acked-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86 ACPI: fix breakage of resume on 64-bit UP systems with SMP kernel Introduce is_vmalloc_or_module_addr() and use with DEBUG_VIRTUAL
2008-10-20make mm/rmap.c:anon_vma_cachep staticAdrian Bunk
This patch makes the needlessly global anon_vma_cachep static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20memcg: allocate all page_cgroup at bootKAMEZAWA Hiroyuki
Allocate all page_cgroup at boot and remove page_cgroup poitner from struct page. This patch adds an interface as struct page_cgroup *lookup_page_cgroup(struct page*) All FLATMEM/DISCONTIGMEM/SPARSEMEM and MEMORY_HOTPLUG is supported. Remove page_cgroup pointer reduces the amount of memory by - 4 bytes per PAGE_SIZE. - 8 bytes per PAGE_SIZE if memory controller is disabled. (even if configured.) On usual 8GB x86-32 server, this saves 8MB of NORMAL_ZONE memory. On my x86-64 server with 48GB of memory, this saves 96MB of memory. I think this reduction makes sense. By pre-allocation, kmalloc/kfree in charge/uncharge are removed. This means - we're not necessary to be afraid of kmalloc faiulre. (this can happen because of gfp_mask type.) - we can avoid calling kmalloc/kfree. - we can avoid allocating tons of small objects which can be fragmented. - we can know what amount of memory will be used for this extra-lru handling. I added printk message as "allocated %ld bytes of page_cgroup" "please try cgroup_disable=memory option if you don't want" maybe enough informative for users. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20memcg: atomic ops for page_cgroup->flagsKAMEZAWA Hiroyuki
This patch makes page_cgroup->flags to be atomic_ops and define functions (and macros) to access it. Before trying to modify memory resource controller, this atomic operation on flags is necessary. Most of flags in this patch is for LRU and modfied under mz->lru_lock but we'll add another flags which is not for LRU soon. For example, we'll place LOCK bit on flags field. We need atomic operation to modify LRU bit without LOCK. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20memcg: optimize per-cpu statisticsKAMEZAWA Hiroyuki
Some obvious optimization to memcg. I found mem_cgroup_charge_statistics() is a little big (in object) and does unnecessary address calclation. This patch is for optimization to reduce the size of this function. And res_counter_charge() is 'likely' to succeed. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20memcg: avoid accounting special pagesKAMEZAWA Hiroyuki
There are not-on-LRU pages which can be mapped and they are not worth to be accounted. (becasue we can't shrink them and need dirty codes to handle specical case) We'd like to make use of usual objrmap/radix-tree's protcol and don't want to account out-of-vm's control pages. When special_mapping_fault() is called, page->mapping is tend to be NULL and it's charged as Anonymous page. insert_page() also handles some special pages from drivers. This patch is for avoiding to account special pages. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20memcg: make page->mapping NULL before unchargeKAMEZAWA Hiroyuki
This patch tries to make page->mapping to be NULL before mem_cgroup_uncharge_cache_page() is called. "page->mapping == NULL" is a good check for "whether the page is still radix-tree or not". This patch also adds BUG_ON() to mem_cgroup_uncharge_cache_page(); Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20memcg: move charge swapin under lockKAMEZAWA Hiroyuki
While page-cache's charge/uncharge is done under page_lock(), swap-cache isn't. (anonymous page is charged when it's newly allocated.) This patch moves do_swap_page()'s charge() call under lock. I don't see any bad problem *now* but this fix will be good for future for avoiding unnecessary racy state. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20mm: extract do_pages_move() out of sys_move_pages()Brice Goglin
To prepare the chunking, move the sys_move_pages() code that is used when nodes!=NULL into do_pages_move(). And rename do_move_pages() into do_move_page_to_node_array(). Signed-off-by: Brice Goglin <Brice.Goglin@inria.fr> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20mm: don't vmalloc a huge page_to_node array for do_pages_stat()Brice Goglin
do_pages_stat() does not need any page_to_node entry for real. Just pass the pointers to the user-space page address array and to the user-space status array, and have do_pages_stat() traverse the former and fill the latter directly. Signed-off-by: Brice Goglin <Brice.Goglin@inria.fr> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20mm: stop returning -ENOENT from sys_move_pages() if nothing got migratedBrice Goglin
A patchset reworking sys_move_pages(). It removes the possibly large vmalloc by using multiple chunks when migrating large buffers. It also dramatically increases the throughput for large buffers since the lookup in new_page_node() is now limited to a single chunk, causing the quadratic complexity to have a much slower impact. There is no need to use any radix-tree-like structure to improve this lookup. sys_move_pages() duration on a 4-quadcore-opteron 2347HE (1.9Gz), migrating between nodes #2 and #3: length move_pages (us) move_pages+patch (us) 4kB 126 98 40kB 198 168 400kB 963 937 4MB 12503 11930 40MB 246867 11848 Patches #1 and #4 are the important ones: 1) stop returning -ENOENT from sys_move_pages() if nothing got migrated 2) don't vmalloc a huge page_to_node array for do_pages_stat() 3) extract do_pages_move() out of sys_move_pages() 4) rework do_pages_move() to work on page_sized chunks 5) move_pages: no need to set pp->page to ZERO_PAGE(0) by default This patch: There is no point in returning -ENOENT from sys_move_pages() if all pages were already on the right node, while we return 0 if only 1 page was not. Most application don't know where their pages are allocated, so it's not an error to try to migrate them anyway. Just return 0 and let the status array in user-space be checked if the application needs details. It will make the upcoming chunked-move_pages() support much easier. Signed-off-by: Brice Goglin <Brice.Goglin@inria.fr> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20memory hotplug: release memory regions in PAGES_PER_SECTION chunksNathan Fontenot
During hotplug memory remove, memory regions should be released on a PAGES_PER_SECTION size chunks. This mirrors the code in add_memory where resources are requested on a PAGES_PER_SECTION size. Attempting to release the entire memory region fails because there is not a single resource for the total number of pages being removed. Instead the resources for the pages are split in PAGES_PER_SECTION size chunks as requested during memory add. Signed-off-by: Nathan Fontenot <nfont@austin.ibm.com> Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Acked-by: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20setup_per_zone_pages_min(): take zone->lock instead of zone->lru_lockGerald Schaefer
This replaces zone->lru_lock in setup_per_zone_pages_min() with zone->lock. There seems to be no need for the lru_lock anymore, but there is a need for zone->lock instead, because that function may call move_freepages() via setup_zone_migrate_reserve(). Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Tested-by: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20hugepage: support ZERO_PAGE()KOSAKI Motohiro
Presently hugepage doesn't use zero page at all because zero page is only used for coredumping and hugepage can't core dump. However we have now implemented hugepage coredumping. Therefore we should implement the zero page of hugepage. Implementation note: o Why do we only check VM_SHARED for zero page? normal page checked as .. static inline int use_zero_page(struct vm_area_struct *vma) { if (vma->vm_flags & (VM_LOCKED | VM_SHARED)) return 0; return !vma->vm_ops || !vma->vm_ops->fault; } First, hugepages are never mlock()ed. We aren't concerned with VM_LOCKED. Second, hugetlbfs is a pseudo filesystem, not a real filesystem and it doesn't have any file backing. Thus ops->fault checking is meaningless. o Why don't we use zero page if !pte. !pte indicate {pud, pmd} doesn't exist or some error happened. So we shouldn't return zero page if any error occurred. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Adam Litke <agl@us.ibm.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Kawai Hidehiro <hidehiro.kawai.ez@hitachi.com> Cc: Mel Gorman <mel@skynet.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20mm: print out meminit for memmapYinghai Lu
Improve debuggability of memory setup problems. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20mm: hugetlb.c make functions static, use NULL rather than 0Harvey Harrison
mm/hugetlb.c:265:17: warning: symbol 'resv_map_alloc' was not declared. Should it be static? mm/hugetlb.c:277:6: warning: symbol 'resv_map_release' was not declared. Should it be static? mm/hugetlb.c:292:9: warning: Using plain integer as NULL pointer mm/hugetlb.c:1750:5: warning: symbol 'unmap_ref_private' was not declared. Should it be static? Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20mm: rewrite vmap layerNick Piggin
Rewrite the vmap allocator to use rbtrees and lazy tlb flushing, and provide a fast, scalable percpu frontend for small vmaps (requires a slightly different API, though). The biggest problem with vmap is actually vunmap. Presently this requires a global kernel TLB flush, which on most architectures is a broadcast IPI to all CPUs to flush the cache. This is all done under a global lock. As the number of CPUs increases, so will the number of vunmaps a scaled workload will want to perform, and so will the cost of a global TLB flush. This gives terrible quadratic scalability characteristics. Another problem is that the entire vmap subsystem works under a single lock. It is a rwlock, but it is actually taken for write in all the fast paths, and the read locking would likely never be run concurrently anyway, so it's just pointless. This is a rewrite of vmap subsystem to solve those problems. The existing vmalloc API is implemented on top of the rewritten subsystem. The TLB flushing problem is solved by using lazy TLB unmapping. vmap addresses do not have to be flushed immediately when they are vunmapped, because the kernel will not reuse them again (would be a use-after-free) until they are reallocated. So the addresses aren't allocated again until a subsequent TLB flush. A single TLB flush then can flush multiple vunmaps from each CPU. XEN and PAT and such do not like deferred TLB flushing because they can't always handle multiple aliasing virtual addresses to a physical address. They now call vm_unmap_aliases() in order to flush any deferred mappings. That call is very expensive (well, actually not a lot more expensive than a single vunmap under the old scheme), however it should be OK if not called too often. The virtual memory extent information is stored in an rbtree rather than a linked list to improve the algorithmic scalability. There is a per-CPU allocator for small vmaps, which amortizes or avoids global locking. To use the per-CPU interface, the vm_map_ram / vm_unmap_ram interfaces must be used in place of vmap and vunmap. Vmalloc does not use these interfaces at the moment, so it will not be quite so scalable (although it will use lazy TLB flushing). As a quick test of performance, I ran a test that loops in the kernel, linearly mapping then touching then unmapping 4 pages. Different numbers of tests were run in parallel on an 4 core, 2 socket opteron. Results are in nanoseconds per map+touch+unmap. threads vanilla vmap rewrite 1 14700 2900 2 33600 3000 4 49500 2800 8 70631 2900 So with a 8 cores, the rewritten version is already 25x faster. In a slightly more realistic test (although with an older and less scalable version of the patch), I ripped the not-very-good vunmap batching code out of XFS, and implemented the large buffer mapping with vm_map_ram and vm_unmap_ram... along with a couple of other tricks, I was able to speed up a large directory workload by 20x on a 64 CPU system. I believe vmap/vunmap is actually sped up a lot more than 20x on such a system, but I'm running into other locks now. vmap is pretty well blown off the profiles. Before: 1352059 total 0.1401 798784 _write_lock 8320.6667 <- vmlist_lock 529313 default_idle 1181.5022 15242 smp_call_function 15.8771 <- vmap tlb flushing 2472 __get_vm_area_node 1.9312 <- vmap 1762 remove_vm_area 4.5885 <- vunmap 316 map_vm_area 0.2297 <- vmap 312 kfree 0.1950 300 _spin_lock 3.1250 252 sn_send_IPI_phys 0.4375 <- tlb flushing 238 vmap 0.8264 <- vmap 216 find_lock_page 0.5192 196 find_next_bit 0.3603 136 sn2_send_IPI 0.2024 130 pio_phys_write_mmr 2.0312 118 unmap_kernel_range 0.1229 After: 78406 total 0.0081 40053 default_idle 89.4040 33576 ia64_spinlock_contention 349.7500 1650 _spin_lock 17.1875 319 __reg_op 0.5538 281 _atomic_dec_and_lock 1.0977 153 mutex_unlock 1.5938 123 iget_locked 0.1671 117 xfs_dir_lookup 0.1662 117 dput 0.1406 114 xfs_iget_core 0.0268 92 xfs_da_hashname 0.1917 75 d_alloc 0.0670 68 vmap_page_range 0.0462 <- vmap 58 kmem_cache_alloc 0.0604 57 memset 0.0540 52 rb_next 0.1625 50 __copy_user 0.0208 49 bitmap_find_free_region 0.2188 <- vmap 46 ia64_sn_udelay 0.1106 45 find_inode_fast 0.1406 42 memcmp 0.2188 42 finish_task_switch 0.1094 42 __d_lookup 0.0410 40 radix_tree_lookup_slot 0.1250 37 _spin_unlock_irqrestore 0.3854 36 xfs_bmapi 0.0050 36 kmem_cache_free 0.0256 35 xfs_vn_getattr 0.0322 34 radix_tree_lookup 0.1062 33 __link_path_walk 0.0035 31 xfs_da_do_buf 0.0091 30 _xfs_buf_find 0.0204 28 find_get_page 0.0875 27 xfs_iread 0.0241 27 __strncpy_from_user 0.2812 26 _xfs_buf_initialize 0.0406 24 _xfs_buf_lookup_pages 0.0179 24 vunmap_page_range 0.0250 <- vunmap 23 find_lock_page 0.0799 22 vm_map_ram 0.0087 <- vmap 20 kfree 0.0125 19 put_page 0.0330 18 __kmalloc 0.0176 17 xfs_da_node_lookup_int 0.0086 17 _read_lock 0.0885 17 page_waitqueue 0.0664 vmap has gone from being the top 5 on the profiles and flushing the crap out of all TLBs, to using less than 1% of kernel time. [akpm@linux-foundation.org: cleanups, section fix] [akpm@linux-foundation.org: fix build on alpha] Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20mmap.c: deinline a few functionsDenys Vlasenko
__vma_link_file and expand_downwards functions are not small, yeat they are marked inline. They probably had one callsite sometime in the past, but now they have more. In order to prevent similar thing, I also deinlined expand_upwards, despite it having only pne callsite. Nowadays gcc auto-inlines such static functions anyway. In find_extend_vma, I removed one extra level of indirection. Patch is deliberately generated with -U $BIGNUM to make it easier to see that functions are big. Result: # size */*/mmap.o */vmlinux text data bss dec hex filename 9514 188 16 9718 25f6 0.org/mm/mmap.o 9237 188 16 9441 24e1 deinline/mm/mmap.o 6124402 858996 389480 7372878 70804e 0.org/vmlinux 6124113 858996 389480 7372589 707f2d deinline/vmlinux Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20mm: page lock use lock bitopsNick Piggin
trylock_page, unlock_page open and close a critical section. Hence, we can use the lock bitops to get the desired memory ordering. Also, mark trylock as likely to succeed (and remove the annotation from callers). Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20mm: unlockless reclaimNick Piggin
unlock_page is fairly expensive. It can be avoided in page reclaim success path. By definition if we have any other references to the page it would be a bug anyway. Signed-off-by: Nick Piggin <npiggin@suse.de> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20mm: pagecache insertion fewer atomicsNick Piggin
Setting and clearing the page locked when inserting it into swapcache / pagecache when it has no other references can use non-atomic page flags operations because no other CPU may be operating on it at this time. This saves one atomic operation when inserting a page into pagecache. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20mlock: make mlock error return Posixly CorrectLee Schermerhorn
Rework Posix error return for mlock(). Posix requires error code for mlock*() system calls for some conditions that differ from what kernel low level functions, such as get_user_pages(), return for those conditions. For more info, see: http://marc.info/?l=linux-kernel&m=121750892930775&w=2 This patch provides the same translation of get_user_pages() error codes to posix specified error codes in the context of the mlock rework for unevictable lru. [akpm@linux-foundation.org: fix build] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20mlock: revert mainline handling of mlock error returnLee Schermerhorn
This change is intended to make mlock() error returns correct. make_page_present() is a lower level function used by more than mlock(). Subsequent patch[es] will add this error return fixup in an mlock specific path. Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20vmscan: don't accumulate scan pressure on unrelated listsJohannes Weiner
During each reclaim scan we accumulate scan pressure on unrelated lists which will result in bogus scans and unwanted reclaims eventually. Scanning lists with few reclaim candidates results in a lot of rotation and therefor also disturbs the list balancing, putting even more pressure on the wrong lists. In a test-case with much streaming IO, and therefor a crowded inactive file page list, swapping started because a) anon pages were reclaimed after swap_cluster_max reclaim invocations -- nr_scan of this list has just accumulated b) active file pages were scanned because *their* nr_scan has also accumulated through the same logic. And this in return created a lot of rotation for file pages and resulted in a decrease of file list priority, again increasing the pressure on anon pages. The result was an evicted working set of anon pages while there were tons of inactive file pages that should have been taken instead. Signed-off-by: Johannes Weiner <hannes@saeurebad.de> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20mlock: count attempts to free mlocked pageLee Schermerhorn
Allow free of mlock()ed pages. This shouldn't happen, but during developement, it occasionally did. This patch allows us to survive that condition, while keeping the statistics and events correct for debug. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20vmscan: unevictable LRU scan sysctlLee Schermerhorn
This patch adds a function to scan individual or all zones' unevictable lists and move any pages that have become evictable onto the respective zone's inactive list, where shrink_inactive_list() will deal with them. Adds sysctl to scan all nodes, and per node attributes to individual nodes' zones. Kosaki: If evictable page found in unevictable lru when write /proc/sys/vm/scan_unevictable_pages, print filename and file offset of these pages. [akpm@linux-foundation.org: fix one CONFIG_MMU=n build error] [kosaki.motohiro@jp.fujitsu.com: adapt vmscan-unevictable-lru-scan-sysctl.patch to new sysfs API] Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20swap: cull unevictable pages in fault pathLee Schermerhorn
In the fault paths that install new anonymous pages, check whether the page is evictable or not using lru_cache_add_active_or_unevictable(). If the page is evictable, just add it to the active lru list [via the pagevec cache], else add it to the unevictable list. This "proactive" culling in the fault path mimics the handling of mlocked pages in Nick Piggin's series to keep mlocked pages off the lru lists. Notes: 1) This patch is optional--e.g., if one is concerned about the additional test in the fault path. We can defer the moving of nonreclaimable pages until when vmscan [shrink_*_list()] encounters them. Vmscan will only need to handle such pages once, but if there are a lot of them it could impact system performance. 2) The 'vma' argument to page_evictable() is require to notice that we're faulting a page into an mlock()ed vma w/o having to scan the page's rmap in the fault path. Culling mlock()ed anon pages is currently the only reason for this patch. 3) We can't cull swap pages in read_swap_cache_async() because the vma argument doesn't necessarily correspond to the swap cache offset passed in by swapin_readahead(). This could [did!] result in mlocking pages in non-VM_LOCKED vmas if [when] we tried to cull in this path. 4) Move set_pte_at() to after where we add page to lru to keep it hidden from other tasks that might walk the page table. We already do it in this order in do_anonymous() page. And, these are COW'd anon pages. Is this safe? [riel@redhat.com: undo an overzealous code cleanup] Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20vmstat: mlocked pages statisticsNick Piggin
Add NR_MLOCK zone page state, which provides a (conservative) count of mlocked pages (actually, the number of mlocked pages moved off the LRU). Reworked by lts to fit in with the modified mlock page support in the Reclaim Scalability series. [kosaki.motohiro@jp.fujitsu.com: fix incorrect Mlocked field of /proc/meminfo] [lee.schermerhorn@hp.com: mlocked-pages: add event counting with statistics] Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20mmap: handle mlocked pages during map, remap, unmapRik van Riel
Originally by Nick Piggin <npiggin@suse.de> Remove mlocked pages from the LRU using "unevictable infrastructure" during mmap(), munmap(), mremap() and truncate(). Try to move back to normal LRU lists on munmap() when last mlocked mapping removed. Remove PageMlocked() status when page truncated from file. [akpm@linux-foundation.org: cleanup] [kamezawa.hiroyu@jp.fujitsu.com: fix double unlock_page()] [kosaki.motohiro@jp.fujitsu.com: split LRU: munlock rework] [lee.schermerhorn@hp.com: mlock: fix __mlock_vma_pages_range comment block] [akpm@linux-foundation.org: remove bogus kerneldoc token] Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: KAMEZAWA Hiroyuki <kamewzawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20mlock: downgrade mmap sem while populating mlocked regionsLee Schermerhorn
We need to hold the mmap_sem for write to initiatate mlock()/munlock() because we may need to merge/split vmas. However, this can lead to very long lock hold times attempting to fault in a large memory region to mlock it into memory. This can hold off other faults against the mm [multithreaded tasks] and other scans of the mm, such as via /proc. To alleviate this, downgrade the mmap_sem to read mode during the population of the region for locking. This is especially the case if we need to reclaim memory to lock down the region. We [probably?] don't need to do this for unlocking as all of the pages should be resident--they're already mlocked. Now, the caller's of the mlock functions [mlock_fixup() and mlock_vma_pages_range()] expect the mmap_sem to be returned in write mode. Changing all callers appears to be way too much effort at this point. So, restore write mode before returning. Note that this opens a window where the mmap list could change in a multithreaded process. So, at least for mlock_fixup(), where we could be called in a loop over multiple vmas, we check that a vma still exists at the start address and that vma still covers the page range [start,end). If not, we return an error, -EAGAIN, and let the caller deal with it. Return -EAGAIN from mlock_vma_pages_range() function and mlock_fixup() if the vma at 'start' disappears or changes so that the page range [start,end) is no longer contained in the vma. Again, let the caller deal with it. Looks like only sys_remap_file_pages() [via mmap_region()] should actually care. With this patch, I no longer see processes like ps(1) blocked for seconds or minutes at a time waiting for a large [multiple gigabyte] region to be locked down. However, I occassionally see delays while unlocking or unmapping a large mlocked region. Should we also downgrade the mmap_sem for the unlock path? Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20mlock: mlocked pages are unevictableNick Piggin
Make sure that mlocked pages also live on the unevictable LRU, so kswapd will not scan them over and over again. This is achieved through various strategies: 1) add yet another page flag--PG_mlocked--to indicate that the page is locked for efficient testing in vmscan and, optionally, fault path. This allows early culling of unevictable pages, preventing them from getting to page_referenced()/try_to_unmap(). Also allows separate accounting of mlock'd pages, as Nick's original patch did. Note: Nick's original mlock patch used a PG_mlocked flag. I had removed this in favor of the PG_unevictable flag + an mlock_count [new page struct member]. I restored the PG_mlocked flag to eliminate the new count field. 2) add the mlock/unevictable infrastructure to mm/mlock.c, with internal APIs in mm/internal.h. This is a rework of Nick's original patch to these files, taking into account that mlocked pages are now kept on unevictable LRU list. 3) update vmscan.c:page_evictable() to check PageMlocked() and, if vma passed in, the vm_flags. Note that the vma will only be passed in for new pages in the fault path; and then only if the "cull unevictable pages in fault path" patch is included. 4) add try_to_unlock() to rmap.c to walk a page's rmap and ClearPageMlocked() if no other vmas have it mlocked. Reuses as much of try_to_unmap() as possible. This effectively replaces the use of one of the lru list links as an mlock count. If this mechanism let's pages in mlocked vmas leak through w/o PG_mlocked set [I don't know that it does], we should catch them later in try_to_unmap(). One hopes this will be rare, as it will be relatively expensive. Original mm/internal.h, mm/rmap.c and mm/mlock.c changes: Signed-off-by: Nick Piggin <npiggin@suse.de> splitlru: introduce __get_user_pages(): New munlock processing need to GUP_FLAGS_IGNORE_VMA_PERMISSIONS. because current get_user_pages() can't grab PROT_NONE pages theresore it cause PROT_NONE pages can't munlock. [akpm@linux-foundation.org: fix this for pagemap-pass-mm-into-pagewalkers.patch] [akpm@linux-foundation.org: untangle patch interdependencies] [akpm@linux-foundation.org: fix things after out-of-order merging] [hugh@veritas.com: fix page-flags mess] [lee.schermerhorn@hp.com: fix munlock page table walk - now requires 'mm'] [kosaki.motohiro@jp.fujitsu.com: build fix] [kosaki.motohiro@jp.fujitsu.com: fix truncate race and sevaral comments] [kosaki.motohiro@jp.fujitsu.com: splitlru: introduce __get_user_pages()] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20SHM_LOCKED pages are unevictableLee Schermerhorn
Shmem segments locked into memory via shmctl(SHM_LOCKED) should not be kept on the normal LRU, since scanning them is a waste of time and might throw off kswapd's balancing algorithms. Place them on the unevictable LRU list instead. Use the AS_UNEVICTABLE flag to mark address_space of SHM_LOCKed shared memory regions as unevictable. Then these pages will be culled off the normal LRU lists during vmscan. Add new wrapper function to clear the mapping's unevictable state when/if shared memory segment is munlocked. Add 'scan_mapping_unevictable_page()' to mm/vmscan.c to scan all pages in the shmem segment's mapping [struct address_space] for evictability now that they're no longer locked. If so, move them to the appropriate zone lru list. Changes depend on [CONFIG_]UNEVICTABLE_LRU. [kosaki.motohiro@jp.fujitsu.com: revert shm change] Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Kosaki Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20Ramfs and Ram Disk pages are unevictableLee Schermerhorn
Christoph Lameter pointed out that ram disk pages also clutter the LRU lists. When vmscan finds them dirty and tries to clean them, the ram disk writeback function just redirties the page so that it goes back onto the active list. Round and round she goes... With the ram disk driver [rd.c] replaced by the newer 'brd.c', this is no longer the case, as ram disk pages are no longer maintained on the lru. [This makes them unmigratable for defrag or memory hot remove, but that can be addressed by a separate patch series.] However, the ramfs pages behave like ram disk pages used to, so: Define new address_space flag [shares address_space flags member with mapping's gfp mask] to indicate that the address space contains all unevictable pages. This will provide for efficient testing of ramfs pages in page_evictable(). Also provide wrapper functions to set/test the unevictable state to minimize #ifdefs in ramfs driver and any other users of this facility. Set the unevictable state on address_space structures for new ramfs inodes. Test the unevictable state in page_evictable() to cull unevictable pages. These changes depend on [CONFIG_]UNEVICTABLE_LRU. [riel@redhat.com: undo the brd.c part] Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Rik van Riel <riel@redhat.com> Debugged-by: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20Unevictable LRU Page StatisticsLee Schermerhorn
Report unevictable pages per zone and system wide. Kosaki Motohiro added support for memory controller unevictable statistics. [riel@redhat.com: fix printk in show_free_areas()] [akpm@linux-foundation.org: fix units in /proc/vmstats] Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Debugged-by: Hiroshi Shimamoto <h-shimamoto@ct.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20unevictable lru: add event counting with statisticsLee Schermerhorn
Fix to unevictable-lru-page-statistics.patch Add unevictable lru infrastructure vm events to the statistics patch. Rename the "NORECL_" and "noreclaim_" symbols and text strings to "UNEVICTABLE_" and "unevictable_", respectively. Currently, both the infrastructure and the mlocked pages event are added by a single patch later in the series. This makes it difficult to add or rework the incremental patches. The events actually "belong" with the stats, so pull them up to here. Also, restore the event counting to putback_lru_page(). This was removed from previous patch in series where it was "misplaced". The actual events weren't defined that early. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Rik van Riel <riel@redhat.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20Unevictable LRU InfrastructureLee Schermerhorn
When the system contains lots of mlocked or otherwise unevictable pages, the pageout code (kswapd) can spend lots of time scanning over these pages. Worse still, the presence of lots of unevictable pages can confuse kswapd into thinking that more aggressive pageout modes are required, resulting in all kinds of bad behaviour. Infrastructure to manage pages excluded from reclaim--i.e., hidden from vmscan. Based on a patch by Larry Woodman of Red Hat. Reworked to maintain "unevictable" pages on a separate per-zone LRU list, to "hide" them from vmscan. Kosaki Motohiro added the support for the memory controller unevictable lru list. Pages on the unevictable list have both PG_unevictable and PG_lru set. Thus, PG_unevictable is analogous to and mutually exclusive with PG_active--it specifies which LRU list the page is on. The unevictable infrastructure is enabled by a new mm Kconfig option [CONFIG_]UNEVICTABLE_LRU. A new function 'page_evictable(page, vma)' in vmscan.c tests whether or not a page may be evictable. Subsequent patches will add the various !evictable tests. We'll want to keep these tests light-weight for use in shrink_active_list() and, possibly, the fault path. To avoid races between tasks putting pages [back] onto an LRU list and tasks that might be moving the page from non-evictable to evictable state, the new function 'putback_lru_page()' -- inverse to 'isolate_lru_page()' -- tests the "evictability" of a page after placing it on the LRU, before dropping the reference. If the page has become unevictable, putback_lru_page() will redo the 'putback', thus moving the page to the unevictable list. This way, we avoid "stranding" evictable pages on the unevictable list. [akpm@linux-foundation.org: fix fallout from out-of-order merge] [riel@redhat.com: fix UNEVICTABLE_LRU and !PROC_PAGE_MONITOR build] [nishimura@mxp.nes.nec.co.jp: remove redundant mapping check] [kosaki.motohiro@jp.fujitsu.com: unevictable-lru-infrastructure: putback_lru_page()/unevictable page handling rework] [kosaki.motohiro@jp.fujitsu.com: kill unnecessary lock_page() in vmscan.c] [kosaki.motohiro@jp.fujitsu.com: revert migration change of unevictable lru infrastructure] [kosaki.motohiro@jp.fujitsu.com: revert to unevictable-lru-infrastructure-kconfig-fix.patch] [kosaki.motohiro@jp.fujitsu.com: restore patch failure of vmstat-unevictable-and-mlocked-pages-vm-events.patch] Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Debugged-by: Benjamin Kidwell <benjkidwell@yahoo.com> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20more aggressively use lumpy reclaimRik van Riel
During an AIM7 run on a 16GB system, fork started failing around 32000 threads, despite the system having plenty of free swap and 15GB of pageable memory. This was on x86-64, so 8k stacks. If a higher order allocation fails, we can either: - keep evicting pages off the end of the LRUs and hope that we eventually create a contiguous region; this is somewhat unlikely if the system is under enough stress by new allocations - after trying normal eviction for a bit, use lumpy reclaim This patch switches the system to lumpy reclaim if the VM is having trouble freeing enough pages, using the same threshold for detection as used by pageout congestion wait. Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
