path: root/mm
2009-11-02mm: remove incorrect swap_count() from try_to_unuse()Bo Liu
In try_to_unuse(), swcount is a local copy of *swap_map, including the SWAP_HAS_CACHE bit; but a wrong comparison against swap_count(*swap_map), which masks off the SWAP_HAS_CACHE bit, succeeded where it should fail. That had the effect of resetting the mm from which to start searching for the next swap page, to an irrelevant mm instead of to an mm in which this swap page had been found: which may increase search time by ~20%. But we're used to swapoff being slow, so never noticed the slowdown. Remove that one spurious use of swap_count(): Bo Liu thought it merely redundant, Hugh rewrote the description since it was measurably wrong. Signed-off-by: Bo Liu <bo-liu@hotmail.com> Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-31NOMMU: Don't pass NULL pointers to fput() in do_mmap_pgoff()David Howells
Don't pass NULL pointers to fput() in the error handling paths of the NOMMU do_mmap_pgoff() as it can't handle it. The following can be used as a test program: int main() { static long long a[1024 * 1024 * 20] = { 0 }; return a;} Without the patch, the code oopses in atomic_long_dec_and_test() as called by fput() after the kernel complains that it can't allocate that big a chunk of memory. With the patch, the kernel just complains about the allocation size and then the program segfaults during execve() as execve() can't complete the allocation of all the new ELF program segments. Reported-by: Robin Getz <rgetz@blackfin.uclinux.org> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Robin Getz <rgetz@blackfin.uclinux.org> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: sched: move rq_weight data array out of .percpu percpu: allow pcpu_alloc() to be called with IRQs off
2009-10-29Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: backing-dev: ensure that a removed bdi no longer has super_block referencing it block: use after free bug in __blkdev_get block: silently error unsupported empty barriers too
2009-10-29Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc/ppc64: Use preempt_schedule_irq instead of preempt_schedule powerpc: Minor cleanup to lib/Kconfig.debug powerpc: Minor cleanup to sound/ppc/Kconfig powerpc: Minor cleanup to init/Kconfig powerpc: Limit memory hotplug support to PPC64 Book-3S machines powerpc: Limit hugetlbfs support to PPC64 Book-3S machines powerpc: Fix compile errors found by new ppc64e_defconfig powerpc: Add a Book-3E 64-bit defconfig powerpc/booke: Fix xmon single step on PowerPC Book-E powerpc: Align vDSO base address powerpc: Fix segment mapping in vdso32 powerpc/iseries: Remove compiler version dependent hack powerpc/perf_events: Fix priority of MSR HV vs PR bits powerpc/5200: Update defconfigs drivers/serial/mpc52xx_uart.c: Use UPIO_MEM rather than SERIAL_IO_MEM powerpc/boot/dts: drop obsolete 'fsl5200-clocking' of: Remove nested function mpc5200: support for the MAN mpc5200 based board mucmc52 mpc5200: support for the MAN mpc5200 based board uc101
2009-10-29Merge branch 'hwpoison-2.6.32' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6 * 'hwpoison-2.6.32' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6: HWPOISON: fix invalid page count in printk output HWPOISON: Allow schedule_on_each_cpu() from keventd HWPOISON: fix/proc/meminfo alignment HWPOISON: fix oops on ksm pages HWPOISON: Fix page count leak in hwpoison late kill in do_swap_page HWPOISON: return early on non-LRU pages HWPOISON: Add brief hwpoison description to Documentation HWPOISON: Clean up PR_MCE_KILL interface
2009-10-29mm: don't call pte_unmap() against an improper pteDaisuke Nishimura
There are some places where we do like: pte = pte_map(); do { (do break in some conditions) } while (pte++, ...); pte_unmap(pte - 1); But if the loop breaks at the first loop, pte_unmap() unmaps invalid pte. This patch is a fix for this problem. Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Reviewd-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29mm: fix sparsemem configurationRussell King
Currently, sparsemem is only available if EXPERIMENTAL is enabled. However, it hasn't ever been marked experimental. It's been about four years since sparsemem was merged, and we have platforms which depend on it; allow architectures to decide whether sparsemem should be the default memory model. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29vmscan: order evictable rescue in LRU putbackJohannes Weiner
Isolators putting a page back to the LRU do not hold the page lock, and if the page is mlocked, another thread might munlock it concurrently. Expecting this, the putback code re-checks the evictability of a page when it just moved it to the unevictable list in order to correct its decision. The problem, however, is that ordering is not garuanteed between setting PG_lru when moving the page to the list and checking PG_mlocked afterwards: #0: #1 spin_lock() if (TestClearPageMlocked()) if (PageLRU()) move to evictable list SetPageLRU() spin_unlock() if (!PageMlocked()) move to evictable list The PageMlocked() check may get reordered before SetPageLRU() in #0, resulting in #0 not moving the still mlocked page, and in #1 failing to isolate and move the page as well. The page is now stranded on the unevictable list. The race condition is very unlikely. The consequence currently is one page falling off the reclaim grid and eventually getting freed with PG_unevictable set, which triggers a warning in the page allocator. TestClearPageMlocked() in #1 already provides full memory barrier semantics. This patch adds an explicit full barrier to force ordering between SetPageLRU() and PageMlocked() so that either one of the competitors rescues the page. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29do_mbind(): fix memory leakKOSAKI Motohiro
If migrate_prep is failed, new variable is leaked. This patch fixes it. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29mbind(): fix leak of never putback pagesKOSAKI Motohiro
If mbind() receives an invalid address, do_mbind leaks a page. The following test program detects this leak. This patch fixes it. migrate_efault.c ======================================= #include <numaif.h> #include <numa.h> #include <sys/mman.h> #include <stdio.h> #include <unistd.h> #include <stdlib.h> #include <string.h> static unsigned long pagesize; static void* make_hole_mapping(void) { void* addr; addr = mmap(NULL, pagesize*3, PROT_READ|PROT_WRITE, MAP_ANON|MAP_PRIVATE, 0, 0); if (addr == MAP_FAILED) return NULL; /* make page populate */ memset(addr, 0, pagesize*3); /* make memory hole */ munmap(addr+pagesize, pagesize); return addr; } int main(int argc, char** argv) { void* addr; int ch; int node; struct bitmask *nmask = numa_allocate_nodemask(); int err; int node_set = 0; while ((ch = getopt(argc, argv, "n:")) != -1){ switch (ch){ case 'n': node = strtol(optarg, NULL, 0); numa_bitmask_setbit(nmask, node); node_set = 1; break; default: ; } } argc -= optind; argv += optind; if (!node_set) numa_bitmask_setbit(nmask, 0); pagesize = getpagesize(); addr = make_hole_mapping(); err = mbind(addr, pagesize*3, MPOL_BIND, nmask->maskp, nmask->size, MPOL_MF_MOVE_ALL); if (err) perror("mbind "); return 0; } ======================================= Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29vmscan: limit VM_EXEC protection to file pagesWu Fengguang
It is possible to have !Anon but SwapBacked pages, and some apps could create huge number of such pages with MAP_SHARED|MAP_ANONYMOUS. These pages go into the ANON lru list, and hence shall not be protected: we only care mapped executable files. Failing to do so may trigger OOM. Tested-by: Christian Borntraeger <borntraeger@de.ibm.com> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29revert "mm: oom analysis: add buffer cache information to show_free_areas()"Andrew Morton
Revert commit 71de1ccbe1fb40203edd3beb473f8580d917d2ca Author: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> AuthorDate: Mon Sep 21 17:01:31 2009 -0700 Commit: Linus Torvalds <torvalds@linux-foundation.org> CommitDate: Tue Sep 22 07:17:27 2009 -0700 mm: oom analysis: add buffer cache information to show_free_areas() show_free_areas() is called during page allocation failures, and page allocation failures can occur in any calling context. But nr_blockdev_pages() takes VFS locks which should not be taken from hard IRQ context (at least). The result is lockdep warnings (and deadlockability) during page allocation failures. Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Rik van Riel <riel@redhat.com> Cc: David Rientjes <rientjes@google.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29congestion_wait(): don't use WRITEKOSAKI Motohiro
commit 8aa7e847d (Fix congestion_wait() sync/async vs read/write confusion) replace WRITE with BLK_RW_ASYNC. Unfortunately, concurrent mm development made the unchanged place accidentally. This patch fixes it too. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Jens Axboe <jens.axboe@oracle.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29hwpoison: fix oops on ksm pagesHugh Dickins
Memory failure on a KSM page currently oopses on its NULL anon_vma in page_lock_anon_vma(): that may not be much worse than the consequence of ignoring it, but it is better to be consistent with how ZERO_PAGE and hugetlb pages and other awkward cases are treated. Just skip it. We could fix it for 2.6.32 at the KSM end, by putting a dummy anon_vma pointer in there; but that would get harder next time, when KSM will put a pointer to something else there (and I'm not currently planning to do any work to open that up to memory_failure). So I would prefer this simple PageKsm test, until the other exceptions are handled. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29backing-dev: ensure that a removed bdi no longer has super_block referencing itJens Axboe
When the bdi is being removed, we have to ensure that no super_blocks currently have that cached in sb->s_bdi. Normally this is ensured by the sb having a longer life span than the bdi, but if the device is suddenly yanked, we have to kill this reference. sb->s_bdi is pointed to freed memory at that point. This fixes a problem with sync(1) hanging when a USB stick is pulled without cleanly umounting it first. Reported-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-29percpu: allow pcpu_alloc() to be called with IRQs offJiri Kosina
pcpu_alloc() and pcpu_extend_area_map() perform a series of spin_lock_irq()/spin_unlock_irq() calls, which make them unsafe with respect to being called from contexts which have IRQs off. This patch converts the code to perform save/restore of flags instead, making pcpu_alloc() (or __alloc_percpu() respectively) to be called from early kernel startup stage, where IRQs are off. This is needed for proper initialization of per-cpu rq_weight data from sched_init(). tj: added comment explaining why irqsave/restore is used in alloc path. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Tejun Heo <tj@kernel.org>
2009-10-27powerpc: Limit memory hotplug support to PPC64 Book-3S machinesKumar Gala
Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-10-19HWPOISON: fix invalid page count in printk outputWu Fengguang
The madvise injector already holds a reference when passing in a page to the memory-failure code. The code corrects for this additional reference for its checks, but the final printk output didn't. Fix that. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-10-19HWPOISON: fix oops on ksm pagesHugh Dickins
Memory failure on a KSM page currently oopses on its NULL anon_vma in page_lock_anon_vma(): that may not be much worse than the consequence of ignoring it, but it is better to be consistent with how ZERO_PAGE and hugetlb pages and other awkward cases are treated. Just skip it. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-10-19HWPOISON: Fix page count leak in hwpoison late kill in do_swap_pageAndi Kleen
When returning due to a poisoned page drop the page count. It wasn't a fatal problem because noone cares about the page count on a poisoned page (except when it wraps), but it's cleaner to fix it. Pointed out by Linus. Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-10-19HWPOISON: return early on non-LRU pagesWu Fengguang
Right now we have some trouble with non atomic access to page flags when locking the page. To plug this hole for now, limit error recovery to LRU pages for now. This could be better fixed by defining a suitable protocol, but let's go this simple way for now This avoids unnecessary races with __set_page_locked() and __SetPageSlab*() and maybe more non-atomic page flag operations. This loses isolated pages which are currently in page reclaim, but these are relatively limited compared to the total memory. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> [AK: new description, bug fixes, cleanups]
2009-10-13Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: cciss: Add cciss_allow_hpsa module parameter cciss: Fix multiple calls to pci_release_regions blk-settings: fix function parameter kernel-doc notation writeback: kill space in debugfs item name writeback: account IO throttling wait as iowait elv_iosched_store(): fix strstrip() misuse cfq-iosched: avoid probable slice overrun when idling cfq-iosched: apply bool value where we return 0/1 cfq-iosched: fix think time allowed for seekers cfq-iosched: fix the slice residual sign cfq-iosched: abstract out the 'may this cfqq dispatch' logic block: use proper BLK_RW_ASYNC in blk_queue_start_tag() block: Seperate read and write statistics of in_flight requests v2 block: get rid of kblock_schedule_delayed_work() cfq-iosched: fix possible problem with jiffies wraparound cfq-iosched: fix issue with rq-rq merging and fifo list ordering
2009-10-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: percpu: fix compile warnings
2009-10-12percpu: fix compile warningsTejun Heo
Fix the following two compile warnings which show up on i386. mm/percpu.c:1873: warning: comparison of distinct pointer types lacks a cast mm/percpu.c:1879: warning: format '%lx' expects type 'long unsigned int', but argument 2 has type 'size_t' Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Randy Dunlap <randy.dunlap@oracle.com>
2009-10-11headers: remove sched.h from interrupt.hAlexey Dobriyan
After m68k's task_thread_info() doesn't refer to current, it's possible to remove sched.h from interrupt.h and not break m68k! Many thanks to Heiko Carstens for allowing this. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-10-09kmemleak: Check for NULL pointer returned by create_object()Catalin Marinas
This patch adds NULL pointer checking in the early_alloc() function. Reported-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-09kmemleak: Use GFP_ATOMIC for early_alloc().Tetsuo Handa
We can't use GFP_KERNEL inside rcu_read_lock(). Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-09writeback: kill space in debugfs item nameWu Fengguang
The space is not script friendly, kill it. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-09writeback: account IO throttling wait as iowaitWu Fengguang
It makes sense to do IOWAIT when someone is blocked due to IO throttle, as suggested by Kame and Peter. There is an old comment for not doing IOWAIT on throttle, however it has been mismatching the code for a long time. If we stop accounting IOWAIT for 2.6.32, it could be an undesirable behavior change. So restore the io_schedule. CC: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> CC: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-08Merge branch 'sparc-perf-events-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sparc-perf-events-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: mm, perf_event: Make vmalloc_user() align base kernel virtual address to SHMLBA perf_event: Provide vmalloc() based mmap() backing
2009-10-08mm, perf_event: Make vmalloc_user() align base kernel virtual address to SHMLBADavid Miller
When a vmalloc'd area is mmap'd into userspace, some kind of co-ordination is necessary for this to work on platforms with cpu D-caches which can have aliases. Otherwise kernel side writes won't be seen properly in userspace and vice versa. If the kernel side mapping and the user side one have the same alignment, modulo SHMLBA, this can work as long as VM_SHARED is shared of VMA and for all current users this is true. VM_SHARED will force SHMLBA alignment of the user side mmap on platforms with D-cache aliasing matters. The bulk of this patch is just making it so that a specific alignment can be passed down into __get_vm_area_node(). All existing callers pass in '1' which preserves existing behavior. vmalloc_user() gives SHMLBA for the alignment. As a side effect this should get the video media drivers and other vmalloc_user() users into more working shape on such systems. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> LKML-Reference: <200909211922.n8LJMYjw029425@imap1.linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-08mm: includecheck fix: vmalloc.cJaswinder Singh Rajput
fix the following 'make includecheck' warning: mm/vmalloc.c: linux/highmem.h is included more than once. Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-08ksm: more on default valuesHugh Dickins
Adjust the max_kernel_pages default to a quarter of totalram_pages, instead of nr_free_buffer_pages() / 4: the KSM pages themselves come from highmem, and even on a 16GB PAE machine, 4GB of KSM pages would only be pinning 32MB of lowmem with their rmap_items, so no need for the more obscure calculation (nor for its own special init function). There is no way for the user to switch KSM on if CONFIG_SYSFS is not enabled, so in that case default run to KSM_RUN_MERGE. Update KSM Documentation and Kconfig to reflect the new defaults. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Izik Eidus <ieidus@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-04Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: (41 commits) Revert "Seperate read and write statistics of in_flight requests" cfq-iosched: don't delay async queue if it hasn't dispatched at all block: Topology ioctls cfq-iosched: use assigned slice sync value, not default cfq-iosched: rename 'desktop' sysfs entry to 'low_latency' cfq-iosched: implement slower async initiate and queue ramp up cfq-iosched: delay async IO dispatch, if sync IO was just done cfq-iosched: add a knob for desktop interactiveness Add a tracepoint for block request remapping block: allow large discard requests block: use normal I/O path for discard requests swapfile: avoid NULL pointer dereference in swapon when s_bdev is NULL fs/bio.c: move EXPORT* macros to line after function Add missing blk_trace_remove_sysfs to be in pair with blk_trace_init_sysfs cciss: fix build when !PROC_FS block: Do not clamp max_hw_sectors for stacking devices block: Set max_sectors correctly for stacking devices cciss: cciss_host_attr_groups should be const cciss: Dynamically allocate the drive_info_struct for each logical drive. cciss: Add usage_count attribute to each logical drive in /sys ...
2009-10-01memcg: reduce check for softlimit excessKAMEZAWA Hiroyuki
In charge/uncharge/reclaim path, usage_in_excess is calculated repeatedly and it takes res_counter's spin_lock every time. This patch removes unnecessary calls for res_count_soft_limit_excess. Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-01memcg: some modification to softlimit under hierarchical memory reclaim.KAMEZAWA Hiroyuki
This patch clean up/fixes for memcg's uncharge soft limit path. Problems: Now, res_counter_charge()/uncharge() handles softlimit information at charge/uncharge and softlimit-check is done when event counter per memcg goes over limit. Now, event counter per memcg is updated only when memory usage is over soft limit. Here, considering hierarchical memcg management, ancesotors should be taken care of. Now, ancerstors(hierarchy) are handled in charge() but not in uncharge(). This is not good. Prolems: 1. memcg's event counter incremented only when softlimit hits. That's bad. It makes event counter hard to be reused for other purpose. 2. At uncharge, only the lowest level rescounter is handled. This is bug. Because ancesotor's event counter is not incremented, children should take care of them. 3. res_counter_uncharge()'s 3rd argument is NULL in most case. ops under res_counter->lock should be small. No "if" sentense is better. Fixes: * Removed soft_limit_xx poitner and checks in charge and uncharge. Do-check-only-when-necessary scheme works enough well without them. * make event-counter of memcg incremented at every charge/uncharge. (per-cpu area will be accessed soon anyway) * All ancestors are checked at soft-limit-check. This is necessary because ancesotor's event counter may never be modified. Then, they should be checked at the same time. Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-01memcg: fix refcnt going negativeKAMEZAWA Hiroyuki
__mem_cgroup_largest_soft_limit_node() returns a mem_cgroup_per_zone "mz" with incremnted mz->mem->css's refcnt. Then, the caller of this function has to call css_put(mz->mem->css). But, mz can be !NULL even if "not found" i.e. without css_get(). By this, css->refcnt will go down to minus. This may cause various things...one of results will be initite-loop in css_tryget() as this. INFO: RCU detected CPU 0 stall (t=10000 jiffies) sending NMI to all CPUs: NMI backtrace for cpu 0 CPU 0: <snip> <<EOE>> <IRQ> [<ffffffff810884bd>] trace_hardirqs_off+0xd/0x10 [<ffffffff8102a940>] flat_send_IPI_mask+0x90/0xb0 [<ffffffff8102a9c9>] flat_send_IPI_all+0x69/0x70 [<ffffffff81027372>] arch_trigger_all_cpu_backtrace+0x62/0xa0 [<ffffffff810bff8e>] __rcu_pending+0x7e/0x370 [<ffffffff810c02c7>] rcu_check_callbacks+0x47/0x130 [<ffffffff81063a26>] update_process_times+0x46/0x70 [<ffffffff81085930>] tick_sched_timer+0x60/0x160 [<ffffffff810858d0>] ? tick_sched_timer+0x0/0x160 [<ffffffff8107a03a>] __run_hrtimer+0xba/0x150 [<ffffffff8107a325>] hrtimer_interrupt+0xd5/0x1b0 [<ffffffff81426dfe>] ? trace_hardirqs_off_thunk+0x3a/0x3c [<ffffffff8142cacd>] smp_apic_timer_interrupt+0x6d/0x9b [<ffffffff8100cb33>] apic_timer_interrupt+0x13/0x20 <EOI> [<ffffffff811317b6>] ? mem_cgroup_walk_tree+0x156/0x180 [<ffffffff811316d3>] ? mem_cgroup_walk_tree+0x73/0x180 [<ffffffff81131692>] ? mem_cgroup_walk_tree+0x32/0x180 [<ffffffff81131a00>] ? mem_cgroup_get_local_stat+0x0/0x110 [<ffffffff81131d5b>] ? mem_control_stat_show+0x14b/0x330 [<ffffffff810a57fd>] ? cgroup_seqfile_show+0x3d/0x60 Above shows CPU0 caught in css_tryget()'s inifinite loop because of bad refcnt. This is a fix to set mz=NULL at the top of retry path. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-01mm/rmap.c: fix commentHuang Shijie
The page_address_in_vma() is not only used in unuse_vma(). Signed-off-by: Huang Shijie <shijie8@gmail.com> Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-01swapfile: avoid NULL pointer dereference in swapon when s_bdev is NULLSuresh Jayaraman
While testing Swap over NFS patchset, I noticed an oops that was triggered during swapon. Investigating further, the NULL pointer deference is due to the SSD device check/optimization in the swapon code that assumes s_bdev could never be NULL. inode->i_sb->s_bdev could be NULL in a few cases. For e.g. one such case is loopback NFS mount, there could be others as well. Fix this by ensuring s_bdev is not NULL before we try to deference s_bdev. Signed-off-by: Suresh Jayaraman <sjayaraman@suse.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-29percpu: make allocation failures more verboseTejun Heo
Warn and dump stack when percpu allocation fails. percpu allocator is still young and unchecked NULL percpu pointer usage can result in random memory corruption when combined with the pointer shifting in access macros. Allocation failures should be rare and the warning message will be disabled after certain times. Signed-off-by: Tejun Heo <tj@kernel.org>
2009-09-29percpu: make pcpu_setup_first_chunk() failures more verboseTejun Heo
The parameters to pcpu_setup_first_chunk() come from different sources depending on architecture and can be quite complex. The function runs various sanity checks on the parameters and triggers BUG() if something isn't right. However, this is very early during the boot and not reporting exactly what the problem is makes debugging even harder. Add PCPU_SETUP_BUG() macro which prints out enough information about the parameters. As the macro still puts separate BUG() for each check, it won't lose any information even on the situations where only the program counter can be retrieved. While at it, also bump pcpu_dump_alloc_info() message to KERN_INFO so that it's visible on the console if boot fails to complete. Signed-off-by: Tejun Heo <tj@kernel.org>
2009-09-29percpu: make embedding first chunk allocator check vmalloc space sizeTejun Heo
Embedding first chunk allocator maintains the distances between units in the vmalloc area and thus needs vmalloc space to be larger than the maximum distances between units; otherwise, it wouldn't be able to create any dynamic chunks. This patch makes the embedding first chunk allocator check vmalloc space size and if the maximum distance between units is larger than 75% of it, print warning and, if page mapping allocator is available, fail initialization so that the system falls back onto it. This should work around percpu allocation failure problems on certain sparc64 configurations where distances between NUMA nodes are larger than the vmalloc area and makes percpu allocator more robust for future configurations. Signed-off-by: Tejun Heo <tj@kernel.org>
2009-09-29percpu: make pcpu_build_alloc_info() clear static buffersTejun Heo
pcpu_build_alloc_info() may be called multiple times when percpu is falling back to different first chunk allocator. Make it clear static buffers so that they don't contain values from previous runs. Signed-off-by: Tejun Heo <tj@kernel.org>
2009-09-29percpu: fix unit_map[] verification in pcpu_setup_first_chunk()Tejun Heo
pcpu_setup_first_chunk() incorrectly used NR_CPUS as the impossible unit number while unit number can equal and go over NR_CPUS with sparse unit map. This triggers BUG_ON() spuriously on machines which have non-power-of-two number of cpus. Use UINT_MAX instead. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-and-tested-by: Tony Vroon <tony@linx.net>
2009-09-27const: mark struct vm_struct_operationsAlexey Dobriyan
* mark struct vm_area_struct::vm_ops as const * mark vm_ops in AGP code But leave TTM code alone, something is fishy there with global vm_ops being used. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-27x86: Fix hwpoison code related build failure on 32-bit NUMAQLinus Torvalds
This build failure triggers: In file included from include/linux/suspend.h:8, from arch/x86/kernel/asm-offsets_32.c:11, from arch/x86/kernel/asm-offsets.c:2: include/linux/mm.h:503:2: error: #error SECTIONS_WIDTH+NODES_WIDTH+ZONES_WIDTH > BITS_PER_LONG - NR_PAGEFLAGS Because due to the hwpoison page flag we ran out of page flags on 32-bit. Dont turn on hwpoison on 32-bit NUMA (it's rare in any case). Also clean up the Kconfig dependencies in the generic MM code by introducing ARCH_SUPPORTS_MEMORY_FAILURE. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-26writeback: pass in super_block to bdi_start_writeback()Jens Axboe
Sometimes we only want to write pages from a specific super_block, so allow that to be passed in. This fixes a problem with commit 56a131dcf7ed36c3c6e36bea448b674ea85ed5bb causing writeback on all super_blocks on a bdi, where we only really want to sync a specific sb from writeback_inodes_sb(). Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-25Merge branch 'writeback' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'writeback' of git://git.kernel.dk/linux-2.6-block: writeback: writeback_inodes_sb() should use bdi_start_writeback() writeback: don't delay inodes redirtied by a fast dirtier writeback: make the super_block pinning more efficient writeback: don't resort for a single super_block in move_expired_inodes() writeback: move inodes from one super_block together writeback: get rid to incorrect references to pdflush in comments writeback: improve readability of the wb_writeback() continue/break logic writeback: cleanup writeback_single_inode() writeback: kupdate writeback shall not stop when more io is possible writeback: stop background writeback when below background threshold writeback: balance_dirty_pages() shall write more than dirtied pages fs: Fix busyloop in wb_writeback()
2009-09-25writeback: get rid to incorrect references to pdflush in commentsJens Axboe
