path: root/mm
2012-07-27mm: failslab: Add support to force slab alloc failures based on size.Krishna Reddy
Any alloc request, with size greater than PAGE_SIZE, to slab allocator is not guarnateed to succeed, even though enough memory is available, as memory can get fully fragmented over the time. This allows finding the slab allocator requests with size greater than PAGE_SIZE early and avoid finding issues much late in product life cyle. Change-Id: Ibf13e626a671d41569415a56e775ac5e96b90ba3 Signed-off-by: Krishna Reddy <vdumpa@nvidia.com> Reviewed-on: http://git-master/r/116855 GVS: Gerrit_Virtual_Submit Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com> (cherry picked from commit 604a65f8e3c9472886b48b1a287f78f11235d1ce) Reviewed-on: http://git-master/r/118193 Reviewed-by: Alex Waterman <alexw@nvidia.com>
2012-01-24Merge branch 'linux-3.1.y' into android-tegra-nv-3.1Varun Wadekar
Linux 3.1.10 Change-Id: I465d184c492e8041dd0cd90f2cb70fde17ba7118 Signed-off-by: Varun Wadekar <vwadekar@nvidia.com>
2012-01-18memcg: add mem_cgroup_replace_page_cache() to fix LRU issueKAMEZAWA Hiroyuki
commit ab936cbcd02072a34b60d268f94440fd5cf1970b upstream. Commit ef6a3c6311 ("mm: add replace_page_cache_page() function") added a function replace_page_cache_page(). This function replaces a page in the radix-tree with a new page. WHen doing this, memory cgroup needs to fix up the accounting information. memcg need to check PCG_USED bit etc. In some(many?) cases, 'newpage' is on LRU before calling replace_page_cache(). So, memcg's LRU accounting information should be fixed, too. This patch adds mem_cgroup_replace_page_cache() and removes the old hooks. In that function, old pages will be unaccounted without touching res_counter and new page will be accounted to the memcg (of old page). WHen overwriting pc->mem_cgroup of newpage, take zone->lru_lock and avoid races with LRU handling. Background: replace_page_cache_page() is called by FUSE code in its splice() handling. Here, 'newpage' is replacing oldpage but this newpage is not a newly allocated page and may be on LRU. LRU mis-accounting will be critical for memory cgroup because rmdir() checks the whole LRU is empty and there is no account leak. If a page is on the other LRU than it should be, rmdir() will fail. This bug was added in March 2011, but no bug report yet. I guess there are not many people who use memcg and FUSE at the same time with upstream kernels. The result of this bug is that admin cannot destroy a memcg because of account leak. So, no panic, no deadlock. And, even if an active cgroup exist, umount can succseed. So no problem at shutdown. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Miklos Szeredi <mszeredi@suse.cz> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-18slub: fix a possible memleak in __slab_alloc()Eric Dumazet
commit 73736e0387ba0e6d2b703407b4d26168d31516a7 upstream. Zhihua Che reported a possible memleak in slub allocator on CONFIG_PREEMPT=y builds. It is possible current thread migrates right before disabling irqs in __slab_alloc(). We must check again c->freelist, and perform a normal allocation instead of scratching c->freelist. Many thanks to Zhihua Che for spotting this bug, introduced in 2.6.39 V2: Its also possible an IRQ freed one (or several) object(s) and populated c->freelist, so its not a CONFIG_PREEMPT only problem. Reported-by: Zhihua Che <zhihua.che@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Christoph Lameter <cl@linux.com> Signed-off-by: Pekka Enberg <penberg@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-11mm/mempolicy.c: refix mbind_range() vma issueKOSAKI Motohiro
commit e26a51148f3ebd859bca8bf2e0f212839b447f62 upstream. commit 8aacc9f550 ("mm/mempolicy.c: fix pgoff in mbind vma merge") is the slightly incorrect fix. Why? Think following case. 1. map 4 pages of a file at offset 0 [0123] 2. map 2 pages just after the first mapping of the same file but with page offset 2 [0123][23] 3. mbind() 2 pages from the first mapping at offset 2. mbind_range() should treat new vma is, [0123][23] |23| mbind vma but it does [0123][23] |01| mbind vma Oops. then, it makes wrong vma merge and splitting ([01][0123] or similar). This patch fixes it. [testcase] test result - before the patch case4: 126: test failed. expect '2,4', actual '2,2,2' case5: passed case6: passed case7: passed case8: passed case_n: 246: test failed. expect '4,2', actual '1,4' ------------[ cut here ]------------ kernel BUG at mm/filemap.c:135! invalid opcode: 0000 [#4] SMP DEBUG_PAGEALLOC (snip long bug on messages) test result - after the patch case4: passed case5: passed case6: passed case7: passed case8: passed case_n: passed source: mbind_vma_test.c ============================================================ #include <numaif.h> #include <numa.h> #include <sys/mman.h> #include <stdio.h> #include <unistd.h> #include <stdlib.h> #include <string.h> static unsigned long pagesize; void* mmap_addr; struct bitmask *nmask; char buf[1024]; FILE *file; char retbuf[10240] = ""; int mapped_fd; char *rubysrc = "ruby -e '\ pid = %d; \ vstart = 0x%llx; \ vend = 0x%llx; \ s = `pmap -q #{pid}`; \ rary = []; \ s.each_line {|line|; \ ary=line.split(\" \"); \ addr = ary[0].to_i(16); \ if(vstart <= addr && addr < vend) then \ rary.push(ary[1].to_i()/4); \ end; \ }; \ print rary.join(\",\"); \ '"; void init(void) { void* addr; char buf[128]; nmask = numa_allocate_nodemask(); numa_bitmask_setbit(nmask, 0); pagesize = getpagesize(); sprintf(buf, "%s", "mbind_vma_XXXXXX"); mapped_fd = mkstemp(buf); if (mapped_fd == -1) perror("mkstemp "), exit(1); unlink(buf); if (lseek(mapped_fd, pagesize*8, SEEK_SET) < 0) perror("lseek "), exit(1); if (write(mapped_fd, "\0", 1) < 0) perror("write "), exit(1); addr = mmap(NULL, pagesize*8, PROT_NONE, MAP_SHARED, mapped_fd, 0); if (addr == MAP_FAILED) perror("mmap "), exit(1); if (mprotect(addr+pagesize, pagesize*6, PROT_READ|PROT_WRITE) < 0) perror("mprotect "), exit(1); mmap_addr = addr + pagesize; /* make page populate */ memset(mmap_addr, 0, pagesize*6); } void fin(void) { void* addr = mmap_addr - pagesize; munmap(addr, pagesize*8); memset(buf, 0, sizeof(buf)); memset(retbuf, 0, sizeof(retbuf)); } void mem_bind(int index, int len) { int err; err = mbind(mmap_addr+pagesize*index, pagesize*len, MPOL_BIND, nmask->maskp, nmask->size, 0); if (err) perror("mbind "), exit(err); } void mem_interleave(int index, int len) { int err; err = mbind(mmap_addr+pagesize*index, pagesize*len, MPOL_INTERLEAVE, nmask->maskp, nmask->size, 0); if (err) perror("mbind "), exit(err); } void mem_unbind(int index, int len) { int err; err = mbind(mmap_addr+pagesize*index, pagesize*len, MPOL_DEFAULT, NULL, 0, 0); if (err) perror("mbind "), exit(err); } void Assert(char *expected, char *value, char *name, int line) { if (strcmp(expected, value) == 0) { fprintf(stderr, "%s: passed\n", name); return; } else { fprintf(stderr, "%s: %d: test failed. expect '%s', actual '%s'\n", name, line, expected, value); // exit(1); } } /* AAAA PPPPPPNNNNNN might become PPNNNNNNNNNN case 4 below */ void case4(void) { init(); sprintf(buf, rubysrc, getpid(), mmap_addr, mmap_addr+pagesize*6); mem_bind(0, 4); mem_unbind(2, 2); file = popen(buf, "r"); fread(retbuf, sizeof(retbuf), 1, file); Assert("2,4", retbuf, "case4", __LINE__); fin(); } /* AAAA PPPPPPNNNNNN might become PPPPPPPPPPNN case 5 below */ void case5(void) { init(); sprintf(buf, rubysrc, getpid(), mmap_addr, mmap_addr+pagesize*6); mem_bind(0, 2); mem_bind(2, 2); file = popen(buf, "r"); fread(retbuf, sizeof(retbuf), 1, file); Assert("4,2", retbuf, "case5", __LINE__); fin(); } /* AAAA PPPPNNNNXXXX might become PPPPPPPPPPPP 6 */ void case6(void) { init(); sprintf(buf, rubysrc, getpid(), mmap_addr, mmap_addr+pagesize*6); mem_bind(0, 2); mem_bind(4, 2); mem_bind(2, 2); file = popen(buf, "r"); fread(retbuf, sizeof(retbuf), 1, file); Assert("6", retbuf, "case6", __LINE__); fin(); } /* AAAA PPPPNNNNXXXX might become PPPPPPPPXXXX 7 */ void case7(void) { init(); sprintf(buf, rubysrc, getpid(), mmap_addr, mmap_addr+pagesize*6); mem_bind(0, 2); mem_interleave(4, 2); mem_bind(2, 2); file = popen(buf, "r"); fread(retbuf, sizeof(retbuf), 1, file); Assert("4,2", retbuf, "case7", __LINE__); fin(); } /* AAAA PPPPNNNNXXXX might become PPPPNNNNNNNN 8 */ void case8(void) { init(); sprintf(buf, rubysrc, getpid(), mmap_addr, mmap_addr+pagesize*6); mem_bind(0, 2); mem_interleave(4, 2); mem_interleave(2, 2); file = popen(buf, "r"); fread(retbuf, sizeof(retbuf), 1, file); Assert("2,4", retbuf, "case8", __LINE__); fin(); } void case_n(void) { init(); sprintf(buf, rubysrc, getpid(), mmap_addr, mmap_addr+pagesize*6); /* make redundunt mappings [0][1234][34][7] */ mmap(mmap_addr + pagesize*4, pagesize*2, PROT_READ|PROT_WRITE, MAP_FIXED|MAP_SHARED, mapped_fd, pagesize*3); /* Expect to do nothing. */ mem_unbind(2, 2); file = popen(buf, "r"); fread(retbuf, sizeof(retbuf), 1, file); Assert("4,2", retbuf, "case_n", __LINE__); fin(); } int main(int argc, char** argv) { case4(); case5(); case6(); case7(); case8(); case_n(); return 0; } ============================================================= Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Caspar Zhang <caspar@casparzhang.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Change-Id: I43dc85715b04c36ba118d6e63c96786c634e2eea Reviewed-on: http://git-master/r/74202 Reviewed-by: Varun Wadekar <vwadekar@nvidia.com> Tested-by: Varun Wadekar <vwadekar@nvidia.com>
2012-01-11mm: hugetlb: fix non-atomic enqueue of huge pageHillf Danton
commit b0365c8d0cb6e79eb5f21418ae61ab511f31b575 upstream. If a huge page is enqueued under the protection of hugetlb_lock, then the operation is atomic and safe. Signed-off-by: Hillf Danton <dhillf@gmail.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Change-Id: I82b34c64333393dc83d2c892114c9fb5cf432ea4 Reviewed-on: http://git-master/r/74201 Reviewed-by: Varun Wadekar <vwadekar@nvidia.com> Tested-by: Varun Wadekar <vwadekar@nvidia.com>
2012-01-11memcg: keep root group unchanged if creation failsHillf Danton
commit a41c58a6665cc995e237303b05db42100b71b65e upstream. If the request is to create non-root group and we fail to meet it, we should leave the root unchanged. Signed-off-by: Hillf Danton <dhillf@gmail.com> Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Balbir Singh <bsingharora@gmail.com> Cc: David Rientjes <rientjes@google.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Change-Id: Ib38fb531508f5c250e9e52f6dc3432db32c315ad Reviewed-on: http://git-master/r/74192 Reviewed-by: Varun Wadekar <vwadekar@nvidia.com> Tested-by: Varun Wadekar <vwadekar@nvidia.com>
2012-01-11vfs: __read_cache_page should use gfp argument rather than GFP_KERNELDave Kleikamp
commit e6f67b8c05f5e129e126f4409ddac6f25f58ffcb upstream. lockdep reports a deadlock in jfs because a special inode's rw semaphore is taken recursively. The mapping's gfp mask is GFP_NOFS, but is not used when __read_cache_page() calls add_to_page_cache_lru(). Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com> Acked-by: Hugh Dickins <hughd@google.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Change-Id: I200c86387cc650dbfb33c8a22ae943ed6996648a Reviewed-on: http://git-master/r/74187 Reviewed-by: Varun Wadekar <vwadekar@nvidia.com> Tested-by: Varun Wadekar <vwadekar@nvidia.com>
2012-01-11oom: fix integer overflow of points in oom_badnessFrantisek Hrbata
commit ff05b6f7ae762b6eb464183eec994b28ea09f6dd upstream. An integer overflow will happen on 64bit archs if task's sum of rss, swapents and nr_ptes exceeds (2^31)/1000 value. This was introduced by commit f755a04 oom: use pte pages in OOM score where the oom score computation was divided into several steps and it's no longer computed as one expression in unsigned long(rss, swapents, nr_pte are unsigned long), where the result value assigned to points(int) is in range(1..1000). So there could be an int overflow while computing 176 points *= 1000; and points may have negative value. Meaning the oom score for a mem hog task will be one. 196 if (points <= 0) 197 return 1; For example: [ 3366] 0 3366 35390480 24303939 5 0 0 oom01 Out of memory: Kill process 3366 (oom01) score 1 or sacrifice child Here the oom1 process consumes more than 24303939(rss)*4096~=92GB physical memory, but it's oom score is one. In this situation the mem hog task is skipped and oom killer kills another and most probably innocent task with oom score greater than one. The points variable should be of type long instead of int to prevent the int overflow. Signed-off-by: Frantisek Hrbata <fhrbata@redhat.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Oleg Nesterov <oleg@redhat.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Change-Id: I56c6a8a4aadca809e04276eabe5552935c51387f Reviewed-on: http://git-master/r/74176 Reviewed-by: Varun Wadekar <vwadekar@nvidia.com> Tested-by: Varun Wadekar <vwadekar@nvidia.com>
2012-01-11percpu: fix per_cpu_ptr_to_phys() handling of non-page-aligned addressesEugene Surovegin
commit 9f57bd4d6dc69a4e3bf43044fa00fcd24dd363e3 upstream. per_cpu_ptr_to_phys() incorrectly rounds up its result for non-kmalloc case to the page boundary, which is bogus for any non-page-aligned address. This affects the only in-tree user of this function - sysfs handler for per-cpu 'crash_notes' physical address. The trouble is that the crash_notes per-cpu variable is not page-aligned: crash_notes = 0xc08e8ed4 PER-CPU OFFSET VALUES: CPU 0: 3711f000 CPU 1: 37129000 CPU 2: 37133000 CPU 3: 3713d000 So, the per-cpu addresses are: crash_notes on CPU 0: f7a07ed4 => phys 36b57ed4 crash_notes on CPU 1: f7a11ed4 => phys 36b4ded4 crash_notes on CPU 2: f7a1bed4 => phys 36b43ed4 crash_notes on CPU 3: f7a25ed4 => phys 36b39ed4 However, /sys/devices/system/cpu/cpu*/crash_notes says: /sys/devices/system/cpu/cpu0/crash_notes: 36b57000 /sys/devices/system/cpu/cpu1/crash_notes: 36b4d000 /sys/devices/system/cpu/cpu2/crash_notes: 36b43000 /sys/devices/system/cpu/cpu3/crash_notes: 36b39000 As you can see, all values are rounded down to a page boundary. Consequently, this is where kexec sets up the NOTE segments, and thus where the secondary kernel is looking for them. However, when the first kernel crashes, it saves the notes to the unaligned addresses, where they are not found. Fix it by adding offset_in_page() to the translated page address. -tj: Combined Eugene's and Petr's commit messages. Signed-off-by: Eugene Surovegin <ebs@ebshome.net> Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Petr Tesarik <ptesarik@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Change-Id: I2c141bbe1ddfb7f91749af4411f884125ea6e14e Reviewed-on: http://git-master/r/74173 Reviewed-by: Varun Wadekar <vwadekar@nvidia.com> Tested-by: Varun Wadekar <vwadekar@nvidia.com>
2012-01-06mm/mempolicy.c: refix mbind_range() vma issueKOSAKI Motohiro
2012-01-06mm: hugetlb: fix non-atomic enqueue of huge pageHillf Danton
2012-01-06memcg: keep root group unchanged if creation failsHillf Danton
2012-01-06vfs: __read_cache_page should use gfp argument rather than GFP_KERNELDave Kleikamp
2012-01-06oom: fix integer overflow of points in oom_badnessFrantisek Hrbata
2012-01-06percpu: fix per_cpu_ptr_to_phys() handling of non-page-aligned addressesEugene Surovegin
2012-01-05Linux 3.1.7Varun Wadekar
Change-Id: I99507d7cfdcee064f808856dc2ce99d806fd864f
2011-12-21percpu: fix chunk range calculationTejun Heo
commit a855b84c3d8c73220d4d3cd392a7bee7c83de70e upstream. Percpu allocator recorded the cpus which map to the first and last units in pcpu_first/last_unit_cpu respectively and used them to determine the address range of a chunk - e.g. it assumed that the first unit has the lowest address in a chunk while the last unit has the highest address. This simply isn't true. Groups in a chunk can have arbitrary positive or negative offsets from the previous one and there is no guarantee that the first unit occupies the lowest offset while the last one the highest. Fix it by actually comparing unit offsets to determine cpus occupying the lowest and highest offsets. Also, rename pcu_first/last_unit_cpu to pcpu_low/high_unit_cpu to avoid confusion. The chunk address range is used to flush cache on vmalloc area map/unmap and decide whether a given address is in the first chunk by per_cpu_ptr_to_phys() and the bug was discovered by invalid per_cpu_ptr_to_phys() translation for crash_note. Kudos to Dave Young for tracking down the problem. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: WANG Cong <xiyou.wangcong@gmail.com> Reported-by: Dave Young <dyoung@redhat.com> Tested-by: Dave Young <dyoung@redhat.com> LKML-Reference: <4EC21F67.10905@redhat.com> Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-21mm: vmalloc: check for page allocation failure before vmlist insertionMel Gorman
commit 1368edf0647ac112d8cfa6ce47257dc950c50f5c upstream. Commit f5252e00 ("mm: avoid null pointer access in vm_struct via /proc/vmallocinfo") adds newly allocated vm_structs to the vmlist after it is fully initialised. Unfortunately, it did not check that __vmalloc_area_node() successfully populated the area. In the event of allocation failure, the vmalloc area is freed but the pointer to freed memory is inserted into the vmlist leading to a a crash later in get_vmalloc_info(). This patch adds a check for ____vmalloc_area_node() failure within __vmalloc_node_range. It does not use "goto fail" as in the previous error path as a warning was already displayed by __vmalloc_area_node() before it called vfree in its failure path. Credit goes to Luciano Chavez for doing all the real work of identifying exactly where the problem was. Signed-off-by: Mel Gorman <mgorman@suse.de> Reported-by: Luciano Chavez <lnx1138@linux.vnet.ibm.com> Tested-by: Luciano Chavez <lnx1138@linux.vnet.ibm.com> Reviewed-by: Rik van Riel <riel@redhat.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-21mm: Ensure that pfn_valid() is called once per pageblock when reserving ↵Michal Hocko
pageblocks commit d021563888312018ca65681096f62e36c20e63cc upstream. setup_zone_migrate_reserve() expects that zone->start_pfn starts at pageblock_nr_pages aligned pfn otherwise we could access beyond an existing memblock resulting in the following panic if CONFIG_HOLES_IN_ZONE is not configured and we do not check pfn_valid: IP: [<c02d331d>] setup_zone_migrate_reserve+0xcd/0x180 *pdpt = 0000000000000000 *pde = f000ff53f000ff53 Oops: 0000 [#1] SMP Pid: 1, comm: swapper Not tainted 3.0.7-0.7-pae #1 VMware, Inc. VMware Virtual Platform/440BX Desktop Reference Platform EIP: 0060:[<c02d331d>] EFLAGS: 00010006 CPU: 0 EIP is at setup_zone_migrate_reserve+0xcd/0x180 EAX: 000c0000 EBX: f5801fc0 ECX: 000c0000 EDX: 00000000 ESI: 000c01fe EDI: 000c01fe EBP: 00140000 ESP: f2475f58 DS: 007b ES: 007b FS: 00d8 GS: 0000 SS: 0068 Process swapper (pid: 1, ti=f2474000 task=f2472cd0 task.ti=f2474000) Call Trace: [<c02d389c>] __setup_per_zone_wmarks+0xec/0x160 [<c02d3a1f>] setup_per_zone_wmarks+0xf/0x20 [<c08a771c>] init_per_zone_wmark_min+0x27/0x86 [<c020111b>] do_one_initcall+0x2b/0x160 [<c086639d>] kernel_init+0xbe/0x157 [<c05cae26>] kernel_thread_helper+0x6/0xd Code: a5 39 f5 89 f7 0f 46 fd 39 cf 76 40 8b 03 f6 c4 08 74 32 eb 91 90 89 c8 c1 e8 0e 0f be 80 80 2f 86 c0 8b 14 85 60 2f 86 c0 89 c8 <2b> 82 b4 12 00 00 c1 e0 05 03 82 ac 12 00 00 8b 00 f6 c4 08 0f EIP: [<c02d331d>] setup_zone_migrate_reserve+0xcd/0x180 SS:ESP 0068:f2475f58 CR2: 00000000000012b4 We crashed in pageblock_is_reserved() when accessing pfn 0xc0000 because highstart_pfn = 0x36ffe. The issue was introduced in 3.0-rc1 by 6d3163ce ("mm: check if any page in a pageblock is reserved before marking it MIGRATE_RESERVE"). Make sure that start_pfn is always aligned to pageblock_nr_pages to ensure that pfn_valid s always called at the start of each pageblock. Architectures with holes in pageblocks will be correctly handled by pfn_valid_within in pageblock_is_reserved. Signed-off-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Mel Gorman <mgorman@suse.de> Tested-by: Dang Bo <bdang@vmware.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: David Rientjes <rientjes@google.com> Cc: Arve Hjnnevg <arve@android.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: John Stultz <john.stultz@linaro.org> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-21thp: set compound tail page _count to zeroYouquan Song
commit 58a84aa92723d1ac3e1cc4e3b0ff49291663f7e1 upstream. Commit 70b50f94f1644 ("mm: thp: tail page refcounting fix") keeps all page_tail->_count zero at all times. But the current kernel does not set page_tail->_count to zero if a 1GB page is utilized. So when an IOMMU 1GB page is used by KVM, it wil result in a kernel oops because a tail page's _count does not equal zero. kernel BUG at include/linux/mm.h:386! invalid opcode: 0000 [#1] SMP Call Trace: gup_pud_range+0xb8/0x19d get_user_pages_fast+0xcb/0x192 ? trace_hardirqs_off+0xd/0xf hva_to_pfn+0x119/0x2f2 gfn_to_pfn_memslot+0x2c/0x2e kvm_iommu_map_pages+0xfd/0x1c1 kvm_iommu_map_memslots+0x7c/0xbd kvm_iommu_map_guest+0xaa/0xbf kvm_vm_ioctl_assigned_device+0x2ef/0xa47 kvm_vm_ioctl+0x36c/0x3a2 do_vfs_ioctl+0x49e/0x4e4 sys_ioctl+0x5a/0x7c system_call_fastpath+0x16/0x1b RIP gup_huge_pud+0xf2/0x159 Signed-off-by: Youquan Song <youquan.song@intel.com> Reviewed-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-14Merge branch 'linux-3.1.5' into android-tegra-nv-3.1Varun Wadekar
Conflicts: arch/arm/Kconfig Change-Id: If8aaaf3efcbbf6c9017b38efb6d76ef933f147fa Signed-off-by: Varun Wadekar <vwadekar@nvidia.com>
2011-12-09slab, lockdep: Fix silly bugPeter Zijlstra
commit 52cef189165d74a5d6030184a8e05595194c69ca upstream. Commit 30765b92 ("slab, lockdep: Annotate the locks before using them") moves the init_lock_keys() call from after g_cpucache_up = FULL, to before it. And overlooks the fact that init_node_lock_keys() tests for it and ignores everything !FULL. Introduce a LATE stage and change the lockdep test to be <LATE. Acked-by: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09hugetlb: release pages in the error path of hugetlb_cow()Hillf Danton
commit ea4039a34c4c206d015d34a49d0b00868e37db1d upstream. If we fail to prepare an anon_vma, the {new, old}_page should be released, or they will leak. Signed-off-by: Hillf Danton <dhillf@gmail.com> Reviewed-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Johannes Weiner <jweiner@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michal Hocko <mhocko@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-30mm: avoid livelock on !__GFP_FS allocationsMel Gorman
Under the following conditions, __alloc_pages_slowpath can loop forever: gfp_mask & __GFP_WAIT is true gfp_mask & __GFP_FS is false reclaim and compaction make no progress order <= PAGE_ALLOC_COSTLY_ORDER The gfp conditions are normally invalid, because !__GFP_FS disables most of the reclaim methods that __GFP_WAIT would wait for. However, these conditions happen very often during suspend and resume, when pm_restrict_gfp_mask() effectively converts all GFP_KERNEL allocations into __GFP_WAIT. The oom killer is not run because gfp_mask & __GFP_FS is false, but should_alloc_retry will always return true when order is less than PAGE_ALLOC_COSTLY_ORDER. __alloc_pages_slowpath will loop forever between the rebalance label and should_alloc_retry, unless another thread happens to release enough pages to satisfy the allocation. Add a check to detect when PM has disabled __GFP_FS, and do not retry if reclaim is not making any progress. [taken from patch on lkml by Mel Gorman, commit message by ccross] Change-Id: I864a24e9d9fd98bd0e3d6e9c1e85b6c1b766850e Signed-off-by: Colin Cross <ccross@android.com>
2011-11-30mm: ashmem: Fix arguments to ashmem_shrinkColin Cross
The arguments to shrink functions have changed, update ashmem_shrink to match. Change-Id: Id279d22d761a2a7c4965c957960eef804d06cc07 Signed-off-by: Colin Cross <ccross@android.com>
2011-11-30Support lseek(2) in ashmem driverBjorn Bringert
Signed-off-by: Bjorn Bringert <bringert@android.com> Change-Id: I509d18b21832e229737ea7ebaa231fb107eb61d7
2011-11-30ashmem: Update arguments of shrinker for 2.6.35Colin Cross
Change-Id: Ie527d18f3352ede06d565826c8d35ded1638203a Signed-off-by: Colin Cross <ccross@google.com>
2011-11-30ashmem: Fix ASHMEM_SET_PROT_MASK.Arve Hjønnevåg
Change-Id: I1412cc9560de8c4feb1162fc30922f0e3362a476 Signed-off-by: Arve Hjønnevåg <arve@android.com>
2011-11-30Implement read(2) in ashmem driverBjorn Bringert
Bug: 2595601 Change-Id: I47c0016f594f9354fb8658ccb26e3d395bcb137b Signed-off-by: Bjorn Bringert <bringert@android.com>
2011-11-30ashmem for 2.6.27.Robert Love
Forward port of ashmem to 2.6.27. Signed-off-by: Robert Love <rlove@google.com> ashmem: Don't install fault handler for private mmaps. Ashmem is used to create named private heaps. If this heap is backed by a tmpfs file it will allocate two pages for every page touched. In 2.6.27, the extra page would later be freed, but 2.6.29 does not scan anonymous pages when running without swap so the memory is not freed while the file is referenced. This change changes the behavior of private ashmem mmaps to match /dev/zero instead tmpfs. Signed-off-by: Arve Hjønnevåg <arve@android.com> ashmem: Add common prefix to name reported in /proc/pid/maps Signed-off-by: Arve Hjønnevåg <arve@android.com> ashmem: don't require a page aligned size This makes ashmem more similar to shmem and mmap, by not requiring the specified size to be page aligned, instead rounding it internally as needed. Signed-off-by: Marco Nelissen <marcone@android.com>
2011-11-30mm: Add min_free_order_shift tunable.Arve Hjønnevåg
By default the kernel tries to keep half as much memory free at each order as it does for one order below. This can be too agressive when running without swap. Change-Id: I5efc1a0b50f41ff3ac71e92d2efd175dedd54ead Signed-off-by: Arve Hjønnevåg <arve@android.com>
2011-11-21backing-dev: ensure wakeup_timer is deletedRabin Vincent
commit 7a401a972df8e184b3d1a3fc958c0a4ddee8d312 upstream. bdi_prune_sb() in bdi_unregister() attempts to removes the bdi links from all super_blocks and then del_timer_sync() the writeback timer. However, this can race with __mark_inode_dirty(), leading to bdi_wakeup_thread_delayed() rearming the writeback timer on the bdi we're unregistering, after we've called del_timer_sync(). This can end up with the bdi being freed with an active timer inside it, as in the case of the following dump after the removal of an SD card. Fix this by redoing the del_timer_sync() in bdi_destory(). ------------[ cut here ]------------ WARNING: at /home/rabin/kernel/arm/lib/debugobjects.c:262 debug_print_object+0x9c/0xc8() ODEBUG: free active (active state 0) object type: timer_list hint: wakeup_timer_fn+0x0/0x180 Modules linked in: Backtrace: [<c00109dc>] (dump_backtrace+0x0/0x110) from [<c0236e4c>] (dump_stack+0x18/0x1c) r6:c02bc638 r5:00000106 r4:c79f5d18 r3:00000000 [<c0236e34>] (dump_stack+0x0/0x1c) from [<c0025e6c>] (warn_slowpath_common+0x54/0x6c) [<c0025e18>] (warn_slowpath_common+0x0/0x6c) from [<c0025f28>] (warn_slowpath_fmt+0x38/0x40) r8:20000013 r7:c780c6f0 r6:c031613c r5:c780c6f0 r4:c02b1b29 r3:00000009 [<c0025ef0>] (warn_slowpath_fmt+0x0/0x40) from [<c015eb4c>] (debug_print_object+0x9c/0xc8) r3:c02b1b29 r2:c02bc662 [<c015eab0>] (debug_print_object+0x0/0xc8) from [<c015f574>] (debug_check_no_obj_freed+0xac/0x1dc) r6:c7964000 r5:00000001 r4:c7964000 [<c015f4c8>] (debug_check_no_obj_freed+0x0/0x1dc) from [<c00a9e38>] (kmem_cache_free+0x88/0x1f8) [<c00a9db0>] (kmem_cache_free+0x0/0x1f8) from [<c014286c>] (blk_release_queue+0x70/0x78) [<c01427fc>] (blk_release_queue+0x0/0x78) from [<c015290c>] (kobject_release+0x70/0x84) r5:c79641f0 r4:c796420c [<c015289c>] (kobject_release+0x0/0x84) from [<c0153ce4>] (kref_put+0x68/0x80) r7:00000083 r6:c74083d0 r5:c015289c r4:c796420c [<c0153c7c>] (kref_put+0x0/0x80) from [<c01527d0>] (kobject_put+0x48/0x5c) r5:c79643b4 r4:c79641f0 [<c0152788>] (kobject_put+0x0/0x5c) from [<c013ddd8>] (blk_cleanup_queue+0x68/0x74) r4:c7964000 [<c013dd70>] (blk_cleanup_queue+0x0/0x74) from [<c01a6370>] (mmc_blk_put+0x78/0xe8) r5:00000000 r4:c794c400 [<c01a62f8>] (mmc_blk_put+0x0/0xe8) from [<c01a64b4>] (mmc_blk_release+0x24/0x38) r5:c794c400 r4:c0322824 [<c01a6490>] (mmc_blk_release+0x0/0x38) from [<c00de11c>] (__blkdev_put+0xe8/0x170) r5:c78d5e00 r4:c74083c0 [<c00de034>] (__blkdev_put+0x0/0x170) from [<c00de2c0>] (blkdev_put+0x11c/0x12c) r8:c79f5f70 r7:00000001 r6:c74083d0 r5:00000083 r4:c74083c0 r3:00000000 [<c00de1a4>] (blkdev_put+0x0/0x12c) from [<c00b0724>] (kill_block_super+0x60/0x6c) r7:c7942300 r6:c79f4000 r5:00000083 r4:c74083c0 [<c00b06c4>] (kill_block_super+0x0/0x6c) from [<c00b0a94>] (deactivate_locked_super+0x44/0x70) r6:c79f4000 r5:c031af64 r4:c794dc00 r3:c00b06c4 [<c00b0a50>] (deactivate_locked_super+0x0/0x70) from [<c00b1358>] (deactivate_super+0x6c/0x70) r5:c794dc00 r4:c794dc00 [<c00b12ec>] (deactivate_super+0x0/0x70) from [<c00c88b0>] (mntput_no_expire+0x188/0x194) r5:c794dc00 r4:c7942300 [<c00c8728>] (mntput_no_expire+0x0/0x194) from [<c00c95e0>] (sys_umount+0x2e4/0x310) r6:c7942300 r5:00000000 r4:00000000 r3:00000000 [<c00c92fc>] (sys_umount+0x0/0x310) from [<c000d940>] (ret_fast_syscall+0x0/0x30) ---[ end trace e5c83c92ada51c76 ]--- Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11mm: thp: tail page refcounting fixAndrea Arcangeli
commit 70b50f94f1644e2aa7cb374819cfd93f3c28d725 upstream. Michel while working on the working set estimation code, noticed that calling get_page_unless_zero() on a random pfn_to_page(random_pfn) wasn't safe, if the pfn ended up being a tail page of a transparent hugepage under splitting by __split_huge_page_refcount(). He then found the problem could also theoretically materialize with page_cache_get_speculative() during the speculative radix tree lookups that uses get_page_unless_zero() in SMP if the radix tree page is freed and reallocated and get_user_pages is called on it before page_cache_get_speculative has a chance to call get_page_unless_zero(). So the best way to fix the problem is to keep page_tail->_count zero at all times. This will guarantee that get_page_unless_zero() can never succeed on any tail page. page_tail->_mapcount is guaranteed zero and is unused for all tail pages of a compound page, so we can simply account the tail page references there and transfer them to tail_page->_count in __split_huge_page_refcount() (in addition to the head_page->_mapcount). While debugging this s/_count/_mapcount/ change I also noticed get_page is called by direct-io.c on pages returned by get_user_pages. That wasn't entirely safe because the two atomic_inc in get_page weren't atomic. As opposed to other get_user_page users like secondary-MMU page fault to establish the shadow pagetables would never call any superflous get_page after get_user_page returns. It's safer to make get_page universally safe for tail pages and to use get_page_foll() within follow_page (inside get_user_pages()). get_page_foll() is safe to do the refcounting for tail pages without taking any locks because it is run within PT lock protected critical sections (PT lock for pte and page_table_lock for pmd_trans_huge). The standard get_page() as invoked by direct-io instead will now take the compound_lock but still only for tail pages. The direct-io paths are usually I/O bound and the compound_lock is per THP so very finegrined, so there's no risk of scalability issues with it. A simple direct-io benchmarks with all lockdep prove locking and spinlock debugging infrastructure enabled shows identical performance and no overhead. So it's worth it. Ideally direct-io should stop calling get_page() on pages returned by get_user_pages(). The spinlock in get_page() is already optimized away for no-THP builds but doing get_page() on tail pages returned by GUP is generally a rare operation and usually only run in I/O paths. This new refcounting on page_tail->_mapcount in addition to avoiding new RCU critical sections will also allow the working set estimation code to work without any further complexity associated to the tail page refcounting with THP. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Reported-by: Michel Lespinasse <walken@google.com> Reviewed-by: Michel Lespinasse <walken@google.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Hugh Dickins <hughd@google.com> Cc: Johannes Weiner <jweiner@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11mm: avoid null pointer access in vm_struct via /proc/vmallocinfoMitsuo Hayasaka
commit f5252e009d5b87071a919221e4f6624184005368 upstream. The /proc/vmallocinfo shows information about vmalloc allocations in vmlist that is a linklist of vm_struct. It, however, may access pages field of vm_struct where a page was not allocated. This results in a null pointer access and leads to a kernel panic. Why this happens: In __vmalloc_node_range() called from vmalloc(), newly allocated vm_struct is added to vmlist at __get_vm_area_node() and then, some fields of vm_struct such as nr_pages and pages are set at __vmalloc_area_node(). In other words, it is added to vmlist before it is fully initialized. At the same time, when the /proc/vmallocinfo is read, it accesses the pages field of vm_struct according to the nr_pages field at show_numa_info(). Thus, a null pointer access happens. The patch adds the newly allocated vm_struct to the vmlist *after* it is fully initialized. So, it can avoid accessing the pages field with unallocated page when show_numa_info() is called. Signed-off-by: Mitsuo Hayasaka <mitsuo.hayasaka.hu@hitachi.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: David Rientjes <rientjes@google.com> Cc: Namhyung Kim <namhyung@gmail.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-19mm: fix race between mremap and removing migration entryHugh Dickins
I don't usually pay much attention to the stale "? " addresses in stack backtraces, but this lucky report from Pawel Sikora hints that mremap's move_ptes() has inadequate locking against page migration. 3.0 BUG_ON(!PageLocked(p)) in migration_entry_to_page(): kernel BUG at include/linux/swapops.h:105! RIP: 0010:[<ffffffff81127b76>] [<ffffffff81127b76>] migration_entry_wait+0x156/0x160 [<ffffffff811016a1>] handle_pte_fault+0xae1/0xaf0 [<ffffffff810feee2>] ? __pte_alloc+0x42/0x120 [<ffffffff8112c26b>] ? do_huge_pmd_anonymous_page+0xab/0x310 [<ffffffff81102a31>] handle_mm_fault+0x181/0x310 [<ffffffff81106097>] ? vma_adjust+0x537/0x570 [<ffffffff81424bed>] do_page_fault+0x11d/0x4e0 [<ffffffff81109a05>] ? do_mremap+0x2d5/0x570 [<ffffffff81421d5f>] page_fault+0x1f/0x30 mremap's down_write of mmap_sem, together with i_mmap_mutex or lock, and pagetable locks, were good enough before page migration (with its requirement that every migration entry be found) came in, and enough while migration always held mmap_sem; but not enough nowadays, when there's memory hotremove and compaction. The danger is that move_ptes() lets a migration entry dodge around behind remove_migration_pte()'s back, so it's in the old location when looking at the new, then in the new location when looking at the old. Either mremap's move_ptes() must additionally take anon_vma lock(), or migration's remove_migration_pte() must stop peeking for is_swap_entry() before it takes pagetable lock. Consensus chooses the latter: we prefer to add overhead to migration than to mremapping, which gets used by JVMs and by exec stack setup. Reported-and-tested-by: Paweł Sikora <pluto@agmk.net> Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Mel Gorman <mgorman@suse.de> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-21Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-block: floppy: use del_timer_sync() in init cleanup blk-cgroup: be able to remove the record of unplugged device block: Don't check QUEUE_FLAG_SAME_COMP in __blk_complete_request mm: Add comment explaining task state setting in bdi_forker_thread() mm: Cleanup clearing of BDI_pending bit in bdi_forker_thread() block: simplify force plug flush code a little bit block: change force plug flush call order block: Fix queue_flag update when rq_affinity goes from 2 to 1 block: separate priority boosting from REQ_META block: remove READ_META and WRITE_META xen-blkback: fixed indentation and comments xen-blkback: Don't disconnect backend until state switched to XenbusStateClosed.
2011-09-19Merge branch 'slab/urgent' of git://github.com/penberg/linuxLinus Torvalds
* 'slab/urgent' of git://github.com/penberg/linux: slub: add slab with one free object to partial list tail
2011-09-14mm: account skipped entries to avoid looping in find_get_pagesShaohua Li
The found entries by find_get_pages() could be all swap entries. In this case we skip the entries, but make sure the skipped entries are accounted, so we don't keep looping. Using nr_found > nr_skip to simplify code as suggested by Eric. Reported-and-tested-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-14mm: sync vmalloc address space page tables in alloc_vm_area()David Vrabel
Xen backend drivers (e.g., blkback and netback) would sometimes fail to map grant pages into the vmalloc address space allocated with alloc_vm_area(). The GNTTABOP_map_grant_ref would fail because Xen could not find the page (in the L2 table) containing the PTEs it needed to update. (XEN) mm.c:3846:d0 Could not find L1 PTE for address fbb42000 netback and blkback were making the hypercall from a kernel thread where task->active_mm != &init_mm and alloc_vm_area() was only updating the page tables for init_mm. The usual method of deferring the update to the page tables of other processes (i.e., after taking a fault) doesn't work as a fault cannot occur during the hypercall. This would work on some systems depending on what else was using vmalloc. Fix this by reverting ef691947d8a3 ("vmalloc: remove vmalloc_sync_all() from alloc_vm_area()") and add a comment to explain why it's needed. Signed-off-by: David Vrabel <david.vrabel@citrix.com> Cc: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Ian Campbell <Ian.Campbell@citrix.com> Cc: Keir Fraser <keir.xen@gmail.com> Cc: <stable@kernel.org> [3.0.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-14memcg: Revert "memcg: add memory.vmscan_stat"Johannes Weiner
Revert the post-3.0 commit 82f9d486e59f5 ("memcg: add memory.vmscan_stat"). The implementation of per-memcg reclaim statistics violates how memcg hierarchies usually behave: hierarchically. The reclaim statistics are accounted to child memcgs and the parent hitting the limit, but not to hierarchy levels in between. Usually, hierarchical statistics are perfectly recursive, with each level representing the sum of itself and all its children. Since this exports statistics to userspace, this may lead to confusion and problems with changing things after the release, so revert it now, we can try again later. Signed-off-by: Johannes Weiner <jweiner@redhat.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Michal Hocko <mhocko@suse.cz> Cc: Ying Han <yinghan@google.com> Cc: Balbir Singh <bsingharora@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-14mm: vmscan: fix force-scanning small targets without swapJohannes Weiner
Without swap, anonymous pages are not scanned. As such, they should not count when considering force-scanning a small target if there is no swap. Otherwise, targets are not force-scanned even when their effective scan number is zero and the other conditions--kswapd/memcg--apply. This fixes 246e87a93934 ("memcg: fix get_scan_count() for small targets"). [akpm@linux-foundation.org: fix comment] Signed-off-by: Johannes Weiner <jweiner@redhat.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: Ying Han <yinghan@google.com> Cc: Balbir Singh <bsingharora@gmail.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-14numa: fix NUMA compile error when sysfs and procfs are disabledDavid Rientjes
The vmstat_text array is only defined for CONFIG_SYSFS or CONFIG_PROC_FS, yet it is referenced for per-node vmstat with CONFIG_NUMA: drivers/built-in.o: In function `node_read_vmstat': node.c:(.text+0x1106df): undefined reference to `vmstat_text' Introduced in commit fa25c503dfa2 ("mm: per-node vmstat: show proper vmstats"). Define the array for CONFIG_NUMA as well. [akpm@linux-foundation.org: remove unneeded ifdefs] Signed-off-by: David Rientjes <rientjes@google.com> Reported-by: Cong Wang <amwang@redhat.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-14mm/mempolicy.c: make copy_from_user() provably correctKAMEZAWA Hiroyuki
When compiling mm/mempolicy.c with struct user copy checks the following warning is shown: In file included from arch/x86/include/asm/uaccess.h:572, from include/linux/uaccess.h:5, from include/linux/highmem.h:7, from include/linux/pagemap.h:10, from include/linux/mempolicy.h:70, from mm/mempolicy.c:68: In function `copy_from_user', inlined from `compat_sys_get_mempolicy' at mm/mempolicy.c:1415: arch/x86/include/asm/uaccess_64.h:64: warning: call to `copy_from_user_overflow' declared with attribute warning: copy_from_user() buffer size is not provably correct LD mm/built-in.o Fix this by passing correct buffer size value. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-14mm/mempolicy.c: fix pgoff in mbind vma mergeCaspar Zhang
commit 9d8cebd4bcd7 ("mm: fix mbind vma merge problem") didn't really fix the mbind vma merge problem due to wrong pgoff value passing to vma_merge(), which made vma_merge() always return NULL. Before the patch applied, we are getting a result like: addr = 0x7fa58f00c000 [snip] 7fa58f00c000-7fa58f00d000 rw-p 00000000 00:00 0 7fa58f00d000-7fa58f00e000 rw-p 00000000 00:00 0 7fa58f00e000-7fa58f00f000 rw-p 00000000 00:00 0 here 7fa58f00c000->7fa58f00f000 we get 3 VMAs which are expected to be merged described as described in commit 9d8cebd. Re-testing the patched kernel with the reproducer provided in commit 9d8cebd, we get the correct result: addr = 0x7ffa5aaa2000 [snip] 7ffa5aaa2000-7ffa5aaa6000 rw-p 00000000 00:00 0 7fffd556f000-7fffd5584000 rw-p 00000000 00:00 0 [stack] Signed-off-by: Caspar Zhang <caspar@casparzhang.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-02mm: Add comment explaining task state setting in bdi_forker_thread()Jan Kara
CC: Wu Fengguang <fengguang.wu@intel.com> CC: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-09-02mm: Cleanup clearing of BDI_pending bit in bdi_forker_thread()Jan Kara
bdi_forker_thread() clears BDI_pending bit at the end of the main loop. However clearing of this bit must not be done in some cases which is handled by calling 'continue' from switch statement. That's kind of unusual construct and without a good reason so change the function into more intuitive code flow. CC: Wu Fengguang <fengguang.wu@intel.com> CC: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-08-27slub: add slab with one free object to partial list tailShaohua Li
The slab has just one free object, adding it to partial list head doesn't make sense. And it can cause lock contentation. For example, 1. CPU takes the slab from partial list 2. fetch an object 3. switch to another slab 4. free an object, then the slab is added to partial list again In this way n->list_lock will be heavily contended. In fact, Alex had a hackbench regression. 3.1-rc1 performance drops about 70% against 3.0. This patch fixes it. Acked-by: Christoph Lameter <cl@linux.com> Reported-by: Alex Shi <alex.shi@intel.com> Signed-off-by: Shaohua Li <shli@kernel.org> Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2011-08-25memcg: fix hierarchical oom lockingJohannes Weiner
Commit 79dfdaccd1d5 ("memcg: make oom_lock 0 and 1 based rather than counter") tried to oom lock the hierarchy and roll back upon encountering an already locked memcg. The code is confused when it comes to detecting a locked memcg, though, so it would fail and rollback after locking one memcg and encountering an unlocked second one. The result is that oom-locking hierarchies fails unconditionally and that every oom killer invocation simply goes to sleep on the oom waitqueue forever. The tasks practically hang forever without anyone intervening, possibly holding locks that trip up unrelated tasks, too. Signed-off-by: Johannes Weiner <jweiner@redhat.com> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-25vmscan: clear ZONE_CONGESTED for zone with good watermarkShaohua Li
ZONE_CONGESTED is only cleared in kswapd, but pages can be freed in any task. It's possible ZONE_CONGESTED isn't cleared in some cases: 1. the zone is already balanced just entering balance_pgdat() for order-0 because concurrent tasks free memory. In this case, later check will skip the zone as it's balanced so the flag isn't cleared. 2. high order balance fallbacks to order-0. quote from Mel: At the end of balance_pgdat(), kswapd uses the following logic; If reclaiming at high order { for each zone { if all_unreclaimable skip if watermark is not met order = 0 loop again /* watermark is met */ clear congested } } i.e. it clears ZONE_CONGESTED if it the zone is balanced. if not, it restarts balancing at order-0. However, if the higher zones are balanced for order-0, kswapd will miss clearing ZONE_CONGESTED as that only happens after a zone is shrunk. This can mean that wait_iff_congested() stalls unnecessarily. This patch makes kswapd clear ZONE_CONGESTED during its initial highmem->dma scan for zones that are already balanced. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Acked-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
