path: root/mm
2011-06-06mm: fix ENOSPC returned by handle_mm_fault()Hugh Dickins
Al Viro observes that in the hugetlb case, handle_mm_fault() may return a value of the kind ENOSPC when its caller is expecting a value of the kind VM_FAULT_SIGBUS: fix alloc_huge_page()'s failure returns. Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-02Revert "mm: fail GFP_DMA allocations when ZONE_DMA is not configured"Linus Torvalds
This reverts commit a197b59ae6e8bee56fcef37ea2482dc08414e2ac. As rmk says: "Commit a197b59ae6e8 (mm: fail GFP_DMA allocations when ZONE_DMA is not configured) is causing regressions on ARM with various drivers which use GFP_DMA. The behaviour up until now has been to silently ignore that flag when CONFIG_ZONE_DMA is not enabled, and to allocate from the normal zone. However, as a result of the above commit, such allocations now fail which causes drivers to fail. These are regressions compared to the previous kernel version." so just revert it. Requested-by: Russell King <linux@arm.linux.org.uk> Acked-by: Andrew Morton <akpm@linux-foundation.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-29mm, rmap: Add yet more comments to page_get_anon_vma/page_lock_anon_vmaPeter Zijlstra
Inspired by an analysis from Hugh on why again all this doesn't explode in our face. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-28mm: fix page_lock_anon_vma leaving mutex lockedHugh Dickins
On one machine I've been getting hangs, a page fault's anon_vma_prepare() waiting in anon_vma_lock(), other processes waiting for that page's lock. This is a replay of last year's f18194275c39 "mm: fix hang on anon_vma->root->lock". The new page_lock_anon_vma() places too much faith in its refcount: when it has acquired the mutex_trylock(), it's possible that a racing task in anon_vma_alloc() has just reallocated the struct anon_vma, set refcount to 1, and is about to reset its anon_vma->root. Fix this by saving anon_vma->root, and relying on the usual page_mapped() check instead of a refcount check: if page is still mapped, the anon_vma is still ours; if page is not still mapped, we're no longer interested. Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-28mm: fix kernel BUG at mm/rmap.c:1017!Hugh Dickins
I've hit the "address >= vma->vm_end" check in do_page_add_anon_rmap() just once. The stack showed khugepaged allocation trying to compact pages: the call to page_add_anon_rmap() coming from remove_migration_pte(). That path holds anon_vma lock, but does not hold mmap_sem: it can therefore race with a split_vma(), and in commit 5f70b962ccc2 "mmap: avoid unnecessary anon_vma lock" we just took away the anon_vma lock protection when adjusting vma->vm_end. I don't think that particular BUG_ON ever caught anything interesting, so better replace it by a comment, than reinstate the anon_vma locking. Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-28tmpfs: fix race between truncate and writepageHugh Dickins
While running fsx on tmpfs with a memhog then swapoff, swapoff was hanging (interruptibly), repeatedly failing to locate the owner of a 0xff entry in the swap_map. Although shmem_writepage() does abandon when it sees incoming page index is beyond eof, there was still a window in which shmem_truncate_range() could come in between writepage's dropping lock and updating swap_map, find the half-completed swap_map entry, and in trying to free it, leave it in a state that swap_shmem_alloc() could not correct. Arguably a bug in __swap_duplicate()'s and swap_entry_free()'s handling of the different cases, but easiest to fix by moving swap_shmem_alloc() under cover of the lock. More interesting than the bug: it's been there since 2.6.33, why could I not see it with earlier kernels? The mmotm of two weeks ago seems to have some magic for generating races, this is just one of three I found. With yesterday's git I first saw this in mainline, bisected in search of that magic, but the easy reproducibility evaporated. Oh well, fix the bug. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (36 commits) Cache xattr security drop check for write v2 fs: block_page_mkwrite should wait for writeback to finish mm: Wait for writeback when grabbing pages to begin a write configfs: remove unnecessary dentry_unhash on rmdir, dir rename fat: remove unnecessary dentry_unhash on rmdir, dir rename hpfs: remove unnecessary dentry_unhash on rmdir, dir rename minix: remove unnecessary dentry_unhash on rmdir, dir rename fuse: remove unnecessary dentry_unhash on rmdir, dir rename coda: remove unnecessary dentry_unhash on rmdir, dir rename afs: remove unnecessary dentry_unhash on rmdir, dir rename affs: remove unnecessary dentry_unhash on rmdir, dir rename 9p: remove unnecessary dentry_unhash on rmdir, dir rename ncpfs: fix rename over directory with dangling references ncpfs: document dentry_unhash usage ecryptfs: remove unnecessary dentry_unhash on rmdir, dir rename hostfs: remove unnecessary dentry_unhash on rmdir, dir rename hfsplus: remove unnecessary dentry_unhash on rmdir, dir rename hfs: remove unnecessary dentry_unhash on rmdir, dir rename omfs: remove unnecessary dentry_unhash on rmdir, dir rneame udf: remove unnecessary dentry_unhash from rmdir, dir rename ...
2011-05-28Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (25 commits) perf: Fix SIGIO handling perf top: Don't stop if no kernel symtab is found perf top: Handle kptr_restrict perf top: Remove unused macro perf events: initialize fd array to -1 instead of 0 perf tools: Make sure kptr_restrict warnings fit 80 col terms perf tools: Fix build on older systems perf symbols: Handle /proc/sys/kernel/kptr_restrict perf: Remove duplicate headers ftrace: Add internal recursive checks tracing: Update btrfs's tracepoints to use u64 interface tracing: Add __print_symbolic_u64 to avoid warnings on 32bit machine ftrace: Set ops->flag to enabled even on static function tracing tracing: Have event with function tracer check error return ftrace: Have ftrace_startup() return failure code jump_label: Check entries limit in __jump_label_update ftrace/recordmcount: Avoid STT_FUNC symbols as base on ARM scripts/tags.sh: Add magic for trace-events for etags too scripts/tags.sh: Fix ctags for DEFINE_EVENT() x86/ftrace: Fix compiler warning in ftrace.c ...
2011-05-28Cache xattr security drop check for write v2Andi Kleen
Some recent benchmarking on btrfs showed that a major scaling bottleneck on large systems on btrfs is currently the xattr lookup on every write. Why xattr lookup on every write I hear you ask? write wants to drop suid and security related xattrs that could set o capabilities for executables. To do that it currently looks up security.capability on EVERY write (even for non executables) to decide whether to drop it or not. In btrfs this causes an additional tree walk, hitting some per file system locks and quite bad scalability. In a simple read workload on a 8S system I saw over 90% CPU time in spinlocks related to that. Chris Mason tells me this is also a problem in ext4, where it hits the global mbcache lock. This patch adds a simple per inode to avoid this problem. We only do the lookup once per file and then if there is no xattr cache the decision. All xattr changes clear the flag. I also used the same flag to avoid the suid check, although that one is pretty cheap. A file system can also set this flag when it creates the inode, if it has a cheap way to do so. This is done for some common file systems in followon patches. With this patch a major part of the lock contention disappears for btrfs. Some testing on smaller systems didn't show significant performance changes, but at least it helps the larger systems and is generally more efficient. v2: Rename is_sgid. add file system helper. Cc: chris.mason@oracle.com Cc: josef@redhat.com Cc: viro@zeniv.linux.org.uk Cc: agruen@linbit.com Cc: Serge E. Hallyn <serue@us.ibm.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-28mm: Wait for writeback when grabbing pages to begin a writeDarrick J. Wong
When grabbing a page for a buffered IO write, the mm should wait for writeback on the page to complete so that the page does not become writable during the IO operation. This change is needed to provide page stability during writes for all filesystems. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-27Merge branch 'tip/perf/urgent' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into perf/urgent
2011-05-26Merge branch 'upstream/tidy-xen-mmu-2.6.39' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen * 'upstream/tidy-xen-mmu-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen: xen: fix compile without CONFIG_XEN_DEBUG_FS Use arbitrary_virt_to_machine() to deal with ioremapped pud updates. Use arbitrary_virt_to_machine() to deal with ioremapped pmd updates. xen/mmu: remove all ad-hoc stats stuff xen: use normal virt_to_machine for ptes xen: make a pile of mmu pvop functions static vmalloc: remove vmalloc_sync_all() from alloc_vm_area() xen: condense everything onto xen_set_pte xen: use mmu_update for xen_set_pte_at() xen: drop all the special iomap pte paths.
2011-05-26memcg: add the pagefault count into memcg statsYing Han
Two new stats in per-memcg memory.stat which tracks the number of page faults and number of major page faults. "pgfault" "pgmajfault" They are different from "pgpgin"/"pgpgout" stat which count number of pages charged/discharged to the cgroup and have no meaning of reading/ writing page to disk. It is valuable to track the two stats for both measuring application's performance as well as the efficiency of the kernel page reclaim path. Counting pagefaults per process is useful, but we also need the aggregated value since processes are monitored and controlled in cgroup basis in memcg. Functional test: check the total number of pgfault/pgmajfault of all memcgs and compare with global vmstat value: $ cat /proc/vmstat | grep fault pgfault 1070751 pgmajfault 553 $ cat /dev/cgroup/memory.stat | grep fault pgfault 1071138 pgmajfault 553 total_pgfault 1071142 total_pgmajfault 553 $ cat /dev/cgroup/A/memory.stat | grep fault pgfault 199 pgmajfault 0 total_pgfault 199 total_pgmajfault 0 Performance test: run page fault test(pft) wit 16 thread on faulting in 15G anon pages in 16G container. There is no regression noticed on the "flt/cpu/s" Sample output from pft: TAG pft:anon-sys-default: Gb Thr CLine User System Wall flt/cpu/s fault/wsec 15 16 1 0.67s 233.41s 14.76s 16798.546 266356.260 +-------------------------------------------------------------------------+ N Min Max Median Avg Stddev x 10 16682.962 17344.027 16913.524 16928.812 166.5362 + 10 16695.568 16923.896 16820.604 16824.652 84.816568 No difference proven at 95.0% confidence [akpm@linux-foundation.org: fix build] [hughd@google.com: shmem fix] Signed-off-by: Ying Han <yinghan@google.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26memcg: add memory.numastat api for numa statisticsYing Han
The new API exports numa_maps per-memcg basis. This is a piece of useful information where it exports per-memcg page distribution across real numa nodes. One of the usecases is evaluating application performance by combining this information w/ the cpu allocation to the application. The output of the memory.numastat tries to follow w/ simiar format of numa_maps like: total=<total pages> N0=<node 0 pages> N1=<node 1 pages> ... file=<total file pages> N0=<node 0 pages> N1=<node 1 pages> ... anon=<total anon pages> N0=<node 0 pages> N1=<node 1 pages> ... unevictable=<total anon pages> N0=<node 0 pages> N1=<node 1 pages> ... And we have per-node: total = file + anon + unevictable $ cat /dev/cgroup/memory/memory.numa_stat total=250020 N0=87620 N1=52367 N2=45298 N3=64735 file=225232 N0=83402 N1=46160 N2=40522 N3=55148 anon=21053 N0=3424 N1=6207 N2=4776 N3=6646 unevictable=3735 N0=794 N1=0 N2=0 N3=2941 Signed-off-by: Ying Han <yinghan@google.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26memcg: rename mem_cgroup_zone_nr_pages() to mem_cgroup_zone_nr_lru_pages()Ying Han
The caller of the function has been renamed to zone_nr_lru_pages(), and this is just fixing up in the memcg code. The current name is easily to be mis-read as zone's total number of pages. Signed-off-by: Ying Han <yinghan@google.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26memcg: remove unused retry signal from reclaimJohannes Weiner
If the memcg reclaim code detects the target memcg below its limit it exits and returns a guaranteed non-zero value so that the charge is retried. Nowadays, the charge side checks the memcg limit itself and does not rely on this non-zero return value trick. This patch removes it. The reclaim code will now always return the true number of pages it reclaimed on its own. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Rik van Riel<riel@redhat.com> Acked-by: Ying Han<yinghan@google.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26memcg: fix get_scan_count() for small targetsKAMEZAWA Hiroyuki
During memory reclaim we determine the number of pages to be scanned per zone as (anon + file) >> priority. Assume scan = (anon + file) >> priority. If scan < SWAP_CLUSTER_MAX, the scan will be skipped for this time and priority gets higher. This has some problems. 1. This increases priority as 1 without any scan. To do scan in this priority, amount of pages should be larger than 512M. If pages>>priority < SWAP_CLUSTER_MAX, it's recorded and scan will be batched, later. (But we lose 1 priority.) If memory size is below 16M, pages >> priority is 0 and no scan in DEF_PRIORITY forever. 2. If zone->all_unreclaimabe==true, it's scanned only when priority==0. So, x86's ZONE_DMA will never be recoverred until the user of pages frees memory by itself. 3. With memcg, the limit of memory can be small. When using small memcg, it gets priority < DEF_PRIORITY-2 very easily and need to call wait_iff_congested(). For doing scan before priorty=9, 64MB of memory should be used. Then, this patch tries to scan SWAP_CLUSTER_MAX of pages in force...when 1. the target is enough small. 2. it's kswapd or memcg reclaim. Then we can avoid rapid priority drop and may be able to recover all_unreclaimable in a small zones. And this patch removes nr_saved_scan. This will allow scanning in this priority even when pages >> priority is very small. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Ying Han <yinghan@google.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26memcg: reclaim memory from nodes in round-robin orderYing Han
Presently, memory cgroup's direct reclaim frees memory from the current node. But this has some troubles. Usually when a set of threads works in a cooperative way, they tend to operate on the same node. So if they hit limits under memcg they will reclaim memory from themselves, damaging the active working set. For example, assume 2 node system which has Node 0 and Node 1 and a memcg which has 1G limit. After some work, file cache remains and the usages are Node 0: 1M Node 1: 998M. and run an application on Node 0, it will eat its foot before freeing unnecessary file caches. This patch adds round-robin for NUMA and adds equal pressure to each node. When using cpuset's spread memory feature, this will work very well. But yes, a better algorithm is needed. [akpm@linux-foundation.org: comment editing] [kamezawa.hiroyu@jp.fujitsu.com: fix time comparisons] Signed-off-by: Ying Han <yinghan@google.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26memcg: move page-freeing code out of lockNamhyung Kim
Move page-freeing code out of swap_cgroup_mutex in the hope that it could reduce few of theoretical contentions between swapons and/or swapoffs. This is just a cleanup, no functional changes. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26memcg: fix off-by-one when calculating swap cgroup map lengthNamhyung Kim
It allocated one more page than necessary if @max_pages was a multiple of SC_PER_PAGE. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26memcg: mark init_section_page_cgroup() properlyNamhyung Kim
Commit ca371c0d7e23 ("memcg: fix page_cgroup fatal error in FLATMEM") removes call to alloc_bootmem() in the function so that it can be marked as __meminit to reduce memory usage when MEMORY_HOTPLUG=n. Also as the new helper function alloc_page_cgroup() is called only in the function, it should be marked too. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26memcg: remove pointless next_mz nullification in mem_cgroup_soft_limit_reclaim()Michal Hocko
next_mz is assigned to NULL if __mem_cgroup_largest_soft_limit_node selects the same mz. This doesn't make much sense as we assign to the variable right in the next loop. Compiler will probably optimize this out but it is little bit confusing for the code reading. Signed-off-by: Michal Hocko <mhocko@suse.cz> Acked-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26memcg: add the soft_limit reclaim in global direct reclaim.Ying Han
We recently added the change in global background reclaim which counts the return value of soft_limit reclaim. Now this patch adds the similar logic on global direct reclaim. We should skip scanning global LRU on shrink_zone if soft_limit reclaim does enough work. This is the first step where we start with counting the nr_scanned and nr_reclaimed from soft_limit reclaim into global scan_control. Signed-off-by: Ying Han <yinghan@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Rik van Riel <riel@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26memcg: count the soft_limit reclaim in global background reclaimYing Han
The global kswapd scans per-zone LRU and reclaims pages regardless of the cgroup. It breaks memory isolation since one cgroup can end up reclaiming pages from another cgroup. Instead we should rely on memcg-aware target reclaim including per-memcg kswapd and soft_limit hierarchical reclaim under memory pressure. In the global background reclaim, we do soft reclaim before scanning the per-zone LRU. However, the return value is ignored. This patch is the first step to skip shrink_zone() if soft_limit reclaim does enough work. This is part of the effort which tries to reduce reclaiming pages in global LRU in memcg. The per-memcg background reclaim patchset further enhances the per-cgroup targetting reclaim, which I should have V4 posted shortly. Try running multiple memory intensive workloads within seperate memcgs. Watch the counters of soft_steal in memory.stat. $ cat /dev/cgroup/A/memory.stat | grep 'soft' soft_steal 240000 soft_scan 240000 total_soft_steal 240000 total_soft_scan 240000 This patch: In the global background reclaim, we do soft reclaim before scanning the per-zone LRU. However, the return value is ignored. We would like to skip shrink_zone() if soft_limit reclaim does enough work. Also, we need to make the memory pressure balanced across per-memcg zones, like the logic vm-core. This patch is the first step where we start with counting the nr_scanned and nr_reclaimed from soft_limit reclaim into the global scan_control. Signed-off-by: Ying Han <yinghan@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Acked-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26cgroups: add per-thread subsystem callbacksBen Blum
Add cgroup subsystem callbacks for per-thread attachment in atomic contexts Add can_attach_task(), pre_attach(), and attach_task() as new callbacks for cgroups's subsystem interface. Unlike can_attach and attach, these are for per-thread operations, to be called potentially many times when attaching an entire threadgroup. Also, the old "bool threadgroup" interface is removed, as replaced by this. All subsystems are modified for the new interface - of note is cpuset, which requires from/to nodemasks for attach to be globally scoped (though per-cpuset would work too) to persist from its pre_attach to attach_task and attach. This is a pre-patch for cgroup-procs-writable.patch. Signed-off-by: Ben Blum <bblum@andrew.cmu.edu> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Reviewed-by: Paul Menage <menage@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: David Rientjes <rientjes@google.com> Cc: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djm/tmem * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/djm/tmem: xen: cleancache shim to Xen Transcendent Memory ocfs2: add cleancache support ext4: add cleancache support btrfs: add cleancache support ext3: add cleancache support mm/fs: add hooks to support cleancache mm: cleancache core ops functions and config fs: add field to superblock to support cleancache mm/fs: cleancache documentation Fix up trivial conflict in fs/btrfs/extent_io.c due to includes
2011-05-26mm: don't access vm_flags as 'int'KOSAKI Motohiro
The type of vma->vm_flags is 'unsigned long'. Neither 'int' nor 'unsigned int'. This patch fixes such misuse. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> [ Changed to use a typedef - we'll extend it to cover more cases later, since there has been discussion about making it a 64-bit type.. - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26mm/fs: add hooks to support cleancacheDan Magenheimer
This fourth patch of eight in this cleancache series provides the core hooks in VFS for: initializing cleancache per filesystem; capturing clean pages reclaimed by page cache; attempting to get pages from cleancache before filesystem read; and ensuring coherency between pagecache, disk, and cleancache. Note that the placement of these hooks was stable from 2.6.18 to 2.6.38; a minor semantic change was required due to a patchset in 2.6.39. All hooks become no-ops if CONFIG_CLEANCACHE is unset, or become a check of a boolean global if CONFIG_CLEANCACHE is set but no cleancache "backend" has claimed cleancache_ops. Details and a FAQ can be found in Documentation/vm/cleancache.txt [v8: minchan.kim@gmail.com: adapt to new remove_from_page_cache function] Signed-off-by: Chris Mason <chris.mason@oracle.com> Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com> Reviewed-by: Jeremy Fitzhardinge <jeremy@goop.org> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik Van Riel <riel@redhat.com> Cc: Jan Beulich <JBeulich@novell.com> Cc: Andreas Dilger <adilger@sun.com> Cc: Ted Ts'o <tytso@mit.edu> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <joel.becker@oracle.com> Cc: Nitin Gupta <ngupta@vflare.org>
2011-05-26mm: cleancache core ops functions and configDan Magenheimer
This third patch of eight in this cleancache series provides the core code for cleancache that interfaces between the hooks in VFS and individual filesystems and a cleancache backend. It also includes build and config patches. Two new files are added: mm/cleancache.c and include/linux/cleancache.h. Note that CONFIG_CLEANCACHE can default to on; in systems that do not provide a cleancache backend, all hooks devolve to a simple check of a global enable flag, so performance impact should be negligible but can be reduced to zero impact if config'ed off. However for this first commit, it defaults to off. Details and a FAQ can be found in Documentation/vm/cleancache.txt Credits: Cleancache_ops design derived from Jeremy Fitzhardinge design for tmem [v8: dan.magenheimer@oracle.com: fix exportfs call affecting btrfs] [v8: akpm@linux-foundation.org: use static inline function, not macro] [v7: dan.magenheimer@oracle.com: cleanup sysfs and remove cleancache prefix] [v6: JBeulich@novell.com: robustly handle buggy fs encode_fh actor definition] [v5: jeremy@goop.org: clean up global usage and static var names] [v5: jeremy@goop.org: simplify init hook and any future fs init changes] [v5: hch@infradead.org: cleaner non-global interface for ops registration] [v4: adilger@sun.com: interface must support exportfs FS's] [v4: hch@infradead.org: interface must support 64-bit FS on 32-bit kernel] [v3: akpm@linux-foundation.org: use one ops struct to avoid pointer hops] [v3: akpm@linux-foundation.org: document and ensure PageLocked reqts are met] [v3: ngupta@vflare.org: fix success/fail codes, change funcs to void] [v2: viro@ZenIV.linux.org.uk: use sane types] Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com> Reviewed-by: Jeremy Fitzhardinge <jeremy@goop.org> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: Al Viro <viro@ZenIV.linux.org.uk> Acked-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Nitin Gupta <ngupta@vflare.org> Acked-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: Andreas Dilger <adilger@sun.com> Acked-by: Jan Beulich <JBeulich@novell.com> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik Van Riel <riel@redhat.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Ted Ts'o <tytso@mit.edu> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <joel.becker@oracle.com>
2011-05-25slub: remove no-longer used 'unlock_out' labelLinus Torvalds
Commit a71ae47a2cbf ("slub: Fix double bit unlock in debug mode") removed the only goto to this label, resulting in mm/slub.c: In function '__slab_alloc': mm/slub.c:1834: warning: label 'unlock_out' defined but not used fixed trivially by the removal of the label itself too. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Christoph Lameter <cl@linux.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25maccess,probe_kernel: Make write/read src const void *Steven Rostedt
The functions probe_kernel_write() and probe_kernel_read() do not modify the src pointer. Allow const pointers to be passed in without the need of a typecast. Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1305824936.1465.4.camel@gandalf.stny.rr.com
2011-05-25Merge branch 'for-2.6.40/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.40/core' of git://git.kernel.dk/linux-2.6-block: (40 commits) cfq-iosched: free cic_index if cfqd allocation fails cfq-iosched: remove unused 'group_changed' in cfq_service_tree_add() cfq-iosched: reduce bit operations in cfq_choose_req() cfq-iosched: algebraic simplification in cfq_prio_to_maxrq() blk-cgroup: Initialize ioc->cgroup_changed at ioc creation time block: move bd_set_size() above rescan_partitions() in __blkdev_get() block: call elv_bio_merged() when merged cfq-iosched: Make IO merge related stats per cpu cfq-iosched: Fix a memory leak of per cpu stats for root group backing-dev: Kill set but not used var in bdi_debug_stats_show() block: get rid of on-stack plugging debug checks blk-throttle: Make no throttling rule group processing lockless blk-cgroup: Make cgroup stat reset path blkg->lock free for dispatch stats blk-cgroup: Make 64bit per cpu stats safe on 32bit arch blk-throttle: Make dispatch stats per cpu blk-throttle: Free up a group only after one rcu grace period blk-throttle: Use helper function to add root throtl group to lists blk-throttle: Introduce a helper function to fill in device details blk-throttle: Dynamically allocate root group blk-cgroup: Allow sleeping while dynamically allocating a group ...
2011-05-25nommu: add page alignment to mmapBob Liu
Currently on nommu arch mmap(),mremap() and munmap() doesn't do page_align() which isn't consist with mmu arch and cause some issues. First, some drivers' mmap() function depends on vma->vm_end - vma->start is page aligned which is true on mmu arch but not on nommu. eg: uvc camera driver. Second munmap() may return -EINVAL[split file] error in cases when end is not page aligned(passed into from userspace) but vma->vm_end is aligned dure to split or driver's mmap() ops. Add page alignment to fix those issues. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Bob Liu <lliubbo@gmail.com> Cc: David Howells <dhowells@redhat.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Greg Ungerer <gerg@snapgear.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: batch activate_page() to reduce lock contentionShaohua Li
The zone->lru_lock is heavily contented in workload where activate_page() is frequently used. We could do batch activate_page() to reduce the lock contention. The batched pages will be added into zone list when the pool is full or page reclaim is trying to drain them. For example, in a 4 socket 64 CPU system, create a sparse file and 64 processes, processes shared map to the file. Each process read access the whole file and then exit. The process exit will do unmap_vmas() and cause a lot of activate_page() call. In such workload, we saw about 58% total time reduction with below patch. Other workloads with a lot of activate_page also benefits a lot too. Andrew Morton suggested activate_page() and putback_lru_pages() should follow the same path to active pages, but this is hard to implement (see commit 7a608572a282a ("Revert "mm: batch activate_page() to reduce lock contention")). On the other hand, do we really need putback_lru_pages() to follow the same path? I tested several FIO/FFSB benchmark (about 20 scripts for each benchmark) in 3 machines here from 2 sockets to 4 sockets. My test doesn't show anything significant with/without below patch (there is slight difference but mostly some noise which we found even without below patch before). Below patch basically returns to the same as my first post. I tested some microbenchmarks: case-anon-cow-rand-mt 0.58% case-anon-cow-rand -3.30% case-anon-cow-seq-mt -0.51% case-anon-cow-seq -5.68% case-anon-r-rand-mt 0.23% case-anon-r-rand 0.81% case-anon-r-seq-mt -0.71% case-anon-r-seq -1.99% case-anon-rx-rand-mt 2.11% case-anon-rx-seq-mt 3.46% case-anon-w-rand-mt -0.03% case-anon-w-rand -0.50% case-anon-w-seq-mt -1.08% case-anon-w-seq -0.12% case-anon-wx-rand-mt -5.02% case-anon-wx-seq-mt -1.43% case-fork 1.65% case-fork-sleep -0.07% case-fork-withmem 1.39% case-hugetlb -0.59% case-lru-file-mmap-read-mt -0.54% case-lru-file-mmap-read 0.61% case-lru-file-mmap-read-rand -2.24% case-lru-file-readonce -0.64% case-lru-file-readtwice -11.69% case-lru-memcg -1.35% case-mmap-pread-rand-mt 1.88% case-mmap-pread-rand -15.26% case-mmap-pread-seq-mt 0.89% case-mmap-pread-seq -69.72% case-mmap-xread-rand-mt 0.71% case-mmap-xread-seq-mt 0.38% The most significent are: case-lru-file-readtwice -11.69% case-mmap-pread-rand -15.26% case-mmap-pread-seq -69.72% which use activate_page a lot. others are basically variations because each run has slightly difference. In UP case, 'size mm/swap.o' before the two patches: text data bss dec hex filename 6466 896 4 7366 1cc6 mm/swap.o after the two patches: text data bss dec hex filename 6343 896 4 7243 1c4b mm/swap.o Signed-off-by: Shaohua Li <shaohua.li@intel.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Hiroyuki Kamezawa <kamezawa.hiroyuki@gmail.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm/page_alloc.c: prevent unending loop in __alloc_pages_slowpath()Andrew Barry
I believe I found a problem in __alloc_pages_slowpath, which allows a process to get stuck endlessly looping, even when lots of memory is available. Running an I/O and memory intensive stress-test I see a 0-order page allocation with __GFP_IO and __GFP_WAIT, running on a system with very little free memory. Right about the same time that the stress-test gets killed by the OOM-killer, the utility trying to allocate memory gets stuck in __alloc_pages_slowpath even though most of the systems memory was freed by the oom-kill of the stress-test. The utility ends up looping from the rebalance label down through the wait_iff_congested continiously. Because order=0, __alloc_pages_direct_compact skips the call to get_page_from_freelist. Because all of the reclaimable memory on the system has already been reclaimed, __alloc_pages_direct_reclaim skips the call to get_page_from_freelist. Since there is no __GFP_FS flag, the block with __alloc_pages_may_oom is skipped. The loop hits the wait_iff_congested, then jumps back to rebalance without ever trying to get_page_from_freelist. This loop repeats infinitely. The test case is pretty pathological. Running a mix of I/O stress-tests that do a lot of fork() and consume all of the system memory, I can pretty reliably hit this on 600 nodes, in about 12 hours. 32GB/node. Signed-off-by: Andrew Barry <abarry@cray.com> Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: Rik van Riel<riel@redhat.com> Acked-by: Mel Gorman <mgorman@suse.de> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25memsw: remove noswapaccount kernel parameterMichal Hocko
The noswapaccount parameter has been deprecated since 2.6.38 without any complaints from users so we can remove it. swapaccount=0|1 can be used instead. As we are removing the parameter we can also clean up swapaccount because it doesn't have to accept an empty string anymore (to match noswapaccount) and so we can push = into __setup macro rather than checking "=1" resp. "=0" strings Signed-off-by: Michal Hocko <mhocko@suse.cz> Cc: Hiroyuki Kamezawa <kamezawa.hiroyuki@gmail.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: proc: move show_numa_map() to fs/proc/task_mmu.cStephen Wilson
Moving show_numa_map() from mempolicy.c to task_mmu.c solves several issues. - Having the show() operation "miles away" from the corresponding seq_file iteration operations is a maintenance burden. - The need to export ad hoc info like struct proc_maps_private is eliminated. - The implementation of show_numa_map() can be improved in a simple manner by cooperating with the other seq_file operations (start, stop, etc) -- something that would be messy to do without this change. Signed-off-by: Stephen Wilson <wilsons@start.ca> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Hugh Dickins <hughd@google.com> Cc: David Rientjes <rientjes@google.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: remove check_huge_range()Stephen Wilson
This function has been superseded by gather_hugetbl_stats() and is no longer needed. Signed-off-by: Stephen Wilson <wilsons@start.ca> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Hugh Dickins <hughd@google.com> Cc: David Rientjes <rientjes@google.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: make gather_stats() type-safe and remove forward declarationStephen Wilson
Improve the prototype of gather_stats() to take a struct numa_maps as argument instead of a generic void *. Update all callers to make the required type explicit. Since gather_stats() is not needed before its definition and is scheduled to be moved out of mempolicy.c the declaration is removed as well. Signed-off-by: Stephen Wilson <wilsons@start.ca> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Hugh Dickins <hughd@google.com> Cc: David Rientjes <rientjes@google.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: remove MPOL_MF_STATSStephen Wilson
Mapping statistics in a NUMA environment is now computed using the generic walk_page_range() logic. Remove the old/equivalent functionality. Signed-off-by: Stephen Wilson <wilsons@start.ca> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Hugh Dickins <hughd@google.com> Cc: David Rientjes <rientjes@google.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: use walk_page_range() instead of custom page table walking codeStephen Wilson
Converting show_numa_map() to use the generic routine decouples the function from mempolicy.c, allowing it to be moved out of the mm subsystem and into fs/proc. Also, include KSM pages in /proc/pid/numa_maps statistics. The pagewalk logic implemented by check_pte_range() failed to account for such pages as they were not applicable to the page migration case. Signed-off-by: Stephen Wilson <wilsons@start.ca> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Hugh Dickins <hughd@google.com> Cc: David Rientjes <rientjes@google.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: export get_vma_policy()Stephen Wilson
In commit 48fce3429d ("mempolicies: unexport get_vma_policy()") get_vma_policy() was marked static as all clients were local to mempolicy.c. However, the decision to generate /proc/pid/numa_maps in the numa memory policy code and outside the procfs subsystem introduces an artificial interdependency between the two systems. Exporting get_vma_policy() once again is the first step to clean up this interdependency. Signed-off-by: Stephen Wilson <wilsons@start.ca> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Hugh Dickins <hughd@google.com> Cc: David Rientjes <rientjes@google.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25tmpfs: implement generic xattr supportEric Paris
Implement generic xattrs for tmpfs filesystems. The Feodra project, while trying to replace suid apps with file capabilities, realized that tmpfs, which is used on the build systems, does not support file capabilities and thus cannot be used to build packages which use file capabilities. Xattrs are also needed for overlayfs. The xattr interface is a bit odd. If a filesystem does not implement any {get,set,list}xattr functions the VFS will call into some random LSM hooks and the running LSM can then implement some method for handling xattrs. SELinux for example provides a method to support security.selinux but no other security.* xattrs. As it stands today when one enables CONFIG_TMPFS_POSIX_ACL tmpfs will have xattr handler routines specifically to handle acls. Because of this tmpfs would loose the VFS/LSM helpers to support the running LSM. To make up for that tmpfs had stub functions that did nothing but call into the LSM hooks which implement the helpers. This new patch does not use the LSM fallback functions and instead just implements a native get/set/list xattr feature for the full security.* and trusted.* namespace like a normal filesystem. This means that tmpfs can now support both security.selinux and security.capability, which was not previously possible. The basic implementation is that I attach a: struct shmem_xattr { struct list_head list; /* anchored by shmem_inode_info->xattr_list */ char *name; size_t size; char value[0]; }; Into the struct shmem_inode_info for each xattr that is set. This implementation could easily support the user.* namespace as well, except some care needs to be taken to prevent large amounts of unswappable memory being allocated for unprivileged users. [mszeredi@suse.cz: new config option, suport trusted.*, support symlinks] Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Acked-by: Serge Hallyn <serge.hallyn@ubuntu.com> Tested-by: Serge Hallyn <serge.hallyn@ubuntu.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Hugh Dickins <hughd@google.com> Tested-by: Jordi Pujol <jordipujolp@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25memblock/nobootmem: remove unneeded code from alloc_bootmem_node_high()Yinghai Lu
The bootmem wrapper with memblock supports top-down now, so we no longer need this trick. Signed-off-by: Yinghai LU <yinghai@kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Olaf Hering <olaf@aepfle.de> Cc: Tejun Heo <tj@kernel.org> Cc: Lucas De Marchi <lucas.demarchi@profusion.mobi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: fail GFP_DMA allocations when ZONE_DMA is not configuredDavid Rientjes
The page allocator will improperly return a page from ZONE_NORMAL even when __GFP_DMA is passed if CONFIG_ZONE_DMA is disabled. The caller expects DMA memory, perhaps for ISA devices with 16-bit address registers, and may get higher memory resulting in undefined behavior. This patch causes the page allocator to return NULL in such circumstances with a warning emitted to the kernel log on the first occurrence. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: remove dependency on CONFIG_FLATMEM from online_page()Daniel Kiper
online_pages() is only compiled for CONFIG_MEMORY_HOTPLUG_SPARSE, so there is no need to support CONFIG_FLATMEM code within it. This patch removes code that is never used. Signed-off-by: Daniel Kiper <dkiper@net-space.pl> Acked-by: Dave Hansen <dave@linux.vnet.ibm.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: filter unevictable page out in deactivate_page()Minchan Kim
It's pointless that deactive_page's operates on unevictable pages. This patch removes unnecessary overhead which might be a bit problem in case that there are many unevictable page in system(ex, mprotect workload) [akpm@linux-foundation.org: tidy up comment] Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: Rik van Riel<riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25readahead: trigger mmap sequential readahead on PG_readaheadWu Fengguang
Previously the mmap sequential readahead is triggered by updating ra->prev_pos on each page fault and compare it with current page offset. It costs dirtying the cache line on each _minor_ page fault. So remove the ra->prev_pos recording, and instead tag PG_readahead to trigger the possible sequential readahead. It's not only more simple, but also will work more reliably and reduce cache line bouncing on concurrent page faults on shared struct file. In the mosbench exim benchmark which does multi-threaded page faults on shared struct file, the ra->mmap_miss and ra->prev_pos updates are found to cause excessive cache line bouncing on tmpfs, which actually disabled readahead totally (shmem_backing_dev_info.ra_pages == 0). So remove the ra->prev_pos recording, and instead tag PG_readahead to trigger the possible sequential readahead. It's not only more simple, but also will work more reliably on concurrent reads on shared struct file. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Tested-by: Tim Chen <tim.c.chen@intel.com> Reported-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25readahead: reduce unnecessary mmap_miss increasesAndi Kleen
The original INT_MAX is too large, reduce it to - avoid unnecessarily dirtying/bouncing the cache line - restore mmap read-around faster on changed access pattern Background: in the mosbench exim benchmark which does multi-threaded page faults on shared struct file, the ra->mmap_miss updates are found to cause excessive cache line bouncing on tmpfs. The ra state updates are needless for tmpfs because it actually disabled readahead totally (shmem_backing_dev_info.ra_pages == 0). Tested-by: Tim Chen <tim.c.chen@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25readahead: return early when readahead is disabledWu Fengguang
Reduce readahead overheads by returning early in do_sync_mmap_readahead(). tmpfs has ra_pages=0 and it can page fault really fast (not constraint by IO if not swapping). Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Tested-by: Tim Chen <tim.c.chen@intel.com> Reported-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
