Few of the notifier_chain_register() callers use __init in the definition
of notifier_call. It is incorrect as the function definition should be
available after the initializations (they do not unregister them during
initializations).
This patch fixes all such usages to _not_ have the notifier_call __init
section.
Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com>
Basic problem: pages of a shared memory segment can only be migrated once.
In 2.6.16 through 2.6.17-rc1, shared memory mappings do not have a
migratepage address space op. Therefore, migrate_pages() falls back to
default processing. In this path, it will try to pageout() dirty pages.
Once a shared memory page has been migrated it becomes dirty, so
migrate_pages() will try to page it out. However, because the page count
is 3 [cache + current + pte], pageout() will return PAGE_KEEP because
is_page_cache_freeable() returns false. This will abort all subsequent
migrations.
This patch adds a migratepage address space op to shared memory segments to
avoid taking the default path. We use the "migrate_page()" function
because it knows how to migrate dirty pages. This allows shared memory
segment pages to migrate, subject to other conditions such as # pte's
referencing the page [page_mapcount(page)], when requested.
I think this is safe. If we're migrating a shared memory page, then we
found the page via a page table, so it must be in memory.
Can be verified with memtoy and the shmem-mbind-test script, both
available at: http://free.linux.hp.com/~lts/Tools/
Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com>
Acked-by: Christoph Lameter <clameter@sgi.com>
gather_stats() is called with a spinlock held from check_pte_range. We
cannot reschedule with a lock held.
Signed-off-by: Christoph Lameter <clameter@sgi.com>
Fix up some whitespace damage.
Fix oom_kill_task() so it doesn't call mmput() (which may sleep) while
holding tasklist_lock.
Signed-off-by: David S. Peterson <dsp@llnl.gov>
Dave Peterson <dsp@llnl.gov> points out that badness() is playing with
mm_structs without taking a reference on them.
mmput() can sleep, so taking a reference here (inside tasklist_lock) is
hard. Fix it up via task_lock() instead.
Convert for-loops that explicitly reference "NR_CPUS" into the
potentially more efficient for_each_possible_cpu() construct.
Signed-off-by: John Hawkes <hawkes@sgi.com>
Cc: Matt Mackall <mpm@selenic.com>
madvise_remove needs to respect file and mmap protections.
Signed-off-by: Hugh Dickins <hugh@veritas.com>
[ Will the real CVE-2006-1524 stand up, please.. ]
Signed-off-by: Coywolf Qi Hunt <qiyong@fc-cn.com>
EXPORT_SYMBOL'ing of a static function is not a good idea.
Cc: Christoph Lameter <clameter@engr.sgi.com>
This patch is an enhancement of OVERCOMMIT_GUESS algorithm in
__vm_enough_memory() in mm/nommu.c.
When the OVERCOMMIT_GUESS algorithm calculates the number of free pages,
the algorithm subtracts the number of reserved pages from the result
nr_free_pages().
Signed-off-by: Hideo Aoki <haoki@redhat.com>
__vm_enough_memory() in mm/mmap.c.
nr_free_pages().
These patches are an enhancement of OVERCOMMIT_GUESS algorithm in
__vm_enough_memory().
- why the kernel needed patching
When the kernel can't allocate anonymous pages in practice, currnet
OVERCOMMIT_GUESS could return success. This implementation might be
the cause of oom kill in memory pressure situation.
If the Linux runs with page reservation features like
/proc/sys/vm/lowmem_reserve_ratio and without swap region, I think
the oom kill occurs easily.
- the overall design approach in the patch
When the OVERCOMMET_GUESS algorithm calculates number of free pages,
the reserved free pages are regarded as non-free pages.
This change helps to avoid the pitfall that the number of free pages
become less than the number which the kernel tries to keep free.
- testing results
I tested the patches using my test kernel module.
If the patches aren't applied to the kernel, __vm_enough_memory()
returns success in the situation but autual page allocation is
failed.
On the other hand, if the patches are applied to the kernel, memory
allocation failure is avoided since __vm_enough_memory() returns
failure in the situation.
I checked that on i386 SMP 16GB memory machine. I haven't tested on
nommu environment currently.
This patch adds totalreserve_pages for __vm_enough_memory().
Calculate_totalreserve_pages() checks maximum lowmem_reserve pages and
pages_high in each zone. Finally, the function stores the sum of each
zone to totalreserve_pages.
The totalreserve_pages is calculated when the VM is initilized.
And the variable is updated when /proc/sys/vm/lowmem_reserve_raito
or /proc/sys/vm/min_free_kbytes are changed.
- Remove sparse comment
- Remove duplicated include
- Return the correct error condition in migrate_page_remove_references().
The code checks for newbrk with oldbrk which are page aligned before making
a check for the memory limit set of data segment. If the memory limit is
not page aligned in that case it bypasses the test for the limit if the
memory allocation is still for the same page.
Signed-off-by: Ram Gupta <ram.gupta5@gmail.com>
The earlier patch to consolidate mmu and nommu page allocation and
refcounting by using compound pages for nommu allocations had a bug:
kmalloc slabs who's pages were initially allocated by a non-__GFP_COMP
allocator could be passed into mm/nommu.c kmalloc allocations which really
wanted __GFP_COMP underlying pages. Fix that by having nommu pass
__GFP_COMP to all higher order slab allocations.
Signed-off-by: Luke Yang <luke.adi@gmail.com>
Acked-by: Nick Piggin <npiggin@suse.de>
Add a statistics counter which is incremented everytime the alien cache
overflows. alien_cache limit is hardcoded to 12 right now. We can use
this statistics to tune alien cache if needed in the future.
Signed-off-by: Alok N Kataria <alokk@calsoftinc.com>
Signed-off-by: Ravikiran Thirumalai <kiran@scalex86.org>
Signed-off-by: Shai Fultheim <shai@scalex86.org>
Allocate off-slab slab descriptors from node local memory.
Rohit found an obscure bug causing buddy list corruption.
page_is_buddy is using a non-atomic test (PagePrivate && page_count == 0)
to determine whether or not a free page's buddy is itself free and in the
buddy lists.
Each of the conjuncts may be true at different times due to unrelated
conditions, so the non-atomic page_is_buddy test may find each conjunct to
be true even if they were not both true at the same time (ie. the page was
not on the buddy lists).
Signed-off-by: Martin Bligh <mbligh@google.com>
Signed-off-by: Rohit Seth <rohitseth@google.com>
Signed-off-by: Nick Piggin <npiggin@suse.de>
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
The node setup code would try to allocate the node metadata in the node
itself, but that fails if there is no memory in there.
This can happen with memory hotplug when the hotplug area defines an so
far empty node.
Now use bootmem to try to allocate the mem_map in other nodes.
And if it fails don't panic, but just ignore the node.
To make this work I added a new __alloc_bootmem_nopanic function that
does what its name implies.
TBD should try to use nearby nodes here. Currently we just use any.
It's hard to do it better because bootmem doesn't have proper fallback
lists yet.
Signed-off-by: Andi Kleen <ak@suse.de>
This patch updates the comments to match the actual code.
Signed-off-by: Martin Waitz <tali@admingilde.org>
this changes if() BUG(); constructs to BUG_ON() which is
cleaner, contains unlikely() and can better optimized away.
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de>
Remove the recently-added LINUX_FADV_ASYNC_WRITE and LINUX_FADV_WRITE_WAIT
fadvise() additions, do it in a new sys_sync_file_range() syscall instead.
Reasons:
- It's more flexible. Things which would require two or three syscalls with
fadvise() can be done in a single syscall.
- Using fadvise() in this manner is something not covered by POSIX.
The patch wires up the syscall for x86.
The sycall is implemented in the new fs/sync.c. The intention is that we can
move sys_fsync(), sys_fdatasync() and perhaps sys_sync() into there later.
Documentation for the syscall is in fs/sync.c.
A test app (sync_file_range.c) is in
http://www.zip.com.au/~akpm/linux/patches/stuff/ext3-tools.tar.gz.
The available-to-GPL-modules do_sync_file_range() is for knfsd: "A COMMIT can
say NFS_DATA_SYNC or NFS_FILE_SYNC. I can skip the ->fsync call for
NFS_DATA_SYNC which is hopefully the more common."
Note: the `async' writeout mode SYNC_FILE_RANGE_WRITE will turn synchronous if
the queue is congested. This is trivial to fix: add a new flag bit, set
wbc->nonblocking. But I'm not sure that we want to expose implementation
details down to that level.
Note: it's notable that we can sync an fd which wasn't opened for writing.
Same with fsync() and fdatasync()).
Note: the code takes some care to handle attempts to sync file contents
outside the 16TB offset on 32-bit machines. It makes such attempts appear to
succeed, for best 32-bit/64-bit compatibility. Perhaps it should make such
requests fail...
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Cc: Michael Kerrisk <mtk-manpages@gmx.net>
Cc: Ulrich Drepper <drepper@redhat.com>
Cc: Neil Brown <neilb@cse.unsw.edu.au>
The boot cmdline is parsed in parse_early_param() and
parse_args(,unknown_bootoption).
And __setup() is used in obsolete_checksetup().
start_kernel()
-> parse_args()
-> unknown_bootoption()
-> obsolete_checksetup()
If __setup()'s callback (->setup_func()) returns 1 in
obsolete_checksetup(), obsolete_checksetup() thinks a parameter was
handled.
If ->setup_func() returns 0, obsolete_checksetup() tries other
->setup_func(). If all ->setup_func() that matched a parameter returns 0,
a parameter is seted to argv_init[].
Then, when runing /sbin/init or init=app, argv_init[] is passed to the app.
If the app doesn't ignore those arguments, it will warning and exit.
This patch fixes a wrong usage of it, however fixes obvious one only.
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
With strict page reservation, I think kernel should enforce number of free
hugetlb page don't fall below reserved count. Currently it is possible in
the sysctl path. Add proper check in sysctl to disallow that.
Signed-off-by: Ken Chen <kenneth.w.chen@intel.com>
Cc: David Gibson <david@gibson.dropbear.id.au>
git-commit: d5d4b0aa4e1430d73050babba999365593bdb9d2
"[PATCH] optimize follow_hugetlb_page" breaks mlock on hugepage areas.
I mis-interpret pages argument and made get_page() unconditional. It
should only get a ref count when "pages" argument is non-null.
Credit goes to Adam Litke who spotted the bug.
Acked-by: Adam Litke <agl@us.ibm.com>
find_trylock_page() is an odd interface in that it doesn't take a reference
like the others. Now that XFS no longer uses it, and its last remaining
caller actually wants an elevated refcount, opencode that callsite and
schedule find_trylock_page() for removal.
Acked-by: Hugh Dickins <hugh@veritas.com>
Fix a lot of typos. Eyeballed by jmc@ in OpenBSD.
replaces for_each_cpu with for_each_possible_cpu().
Helper functions for for_each_online_pgdat/for_each_zone look too big to be
inlined. Speed of these helper macro itself is not very important. (inner
loops are tend to do more work than this)
This patch make helper function to be out-of-lined.
inline out-of-line
.text 005c0680 005bf6a0
005c0680 - 005bf6a0 = FE0 = 4Kbytes.
By using for_each_online_pgdat(), pgdat_list is not necessary now. This patch
removes it.
Replace for_each_pgdat() with for_each_online_pgdat().
Add a list_head to bootmem_data_t and make bootmems use it. bootmem list is
sorted by node_boot_start.
Only nodes against which init_bootmem() is called are linked to the list.
(i386 allocates bootmem only from one node(0) not from all online nodes.)
A summary:
1. for_each_online_pgdat() traverses all *online* nodes.
2. alloc_bootmem() allocates memory only from initialized-for-bootmem nodes.
This patch removes zone_mem_map.
pfn_to_page uses pgdat, page_to_pfn uses zone. page_to_pfn can use pgdat
instead of zone, which is only one user of zone_mem_map. By modifing it,
we can remove zone_mem_map.
Cc: Dave Hansen <haveblue@us.ibm.com>
Cc: Christoph Lameter <christoph@lameter.com>
There are 3 memory models, FLATMEM, DISCONTIGMEM, SPARSEMEM.
Each arch has its own page_to_pfn(), pfn_to_page() for each models.
But most of them can use the same arithmetic.
This patch adds asm-generic/memory_model.h, which includes generic
page_to_pfn(), pfn_to_page() definitions for each memory model.
When CONFIG_OUT_OF_LINE_PFN_TO_PAGE=y, out-of-line functions are
used instead of macro. This is enabled by some archs and reduces
text size.
Cc: Hugh Dickins <hugh@veritas.com>
Cc: Andi Kleen <ak@muc.de>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Ian Molton <spyro@f2s.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Hirokazu Takata <takata.hirokazu@renesas.com>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp>
Cc: Richard Curnow <rc@rc0.org.uk>
Cc: William Lee Irwin III <wli@holomorphy.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp>
Cc: Chris Zankel <chris@zankel.net>
Cc: "Luck, Tony" <tony.luck@intel.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial:
drivers/char/ftape/lowlevel/fdc-io.c: Correct a comment
Kconfig help: MTD_JEDECPROBE already supports Intel
Remove ugly debugging stuff
do_mounts.c: Minor ROOT_DEV comment cleanup
BUG_ON() Conversion in drivers/s390/block/dasd_devmap.c
BUG_ON() Conversion in mm/mempool.c
BUG_ON() Conversion in mm/memory.c
BUG_ON() Conversion in kernel/fork.c
BUG_ON() Conversion in ipc/sem.c
BUG_ON() Conversion in fs/ext2/
BUG_ON() Conversion in fs/hfs/
BUG_ON() Conversion in fs/dcache.c
BUG_ON() Conversion in fs/buffer.c
BUG_ON() Conversion in input/serio/hp_sdc_mlc.c
BUG_ON() Conversion in md/dm-table.c
BUG_ON() Conversion in md/dm-path-selector.c
BUG_ON() Conversion in drivers/isdn
BUG_ON() Conversion in drivers/char
BUG_ON() Conversion in drivers/mtd/
Add another allocator to the common mempool code: a kzalloc/kfree allocator
This will be used by the next patch in the series to replace a mempool-backed
kzalloc allocator. It is also very likely that there will be more users in
the future.
Signed-off-by: Matthew Dobson <colpatch@us.ibm.com>
Add another allocator to the common mempool code: a kmalloc/kfree allocator
This will be used by the next patch in the series to replace duplicate
mempool-backed kmalloc allocators in several places in the kernel. It is also
very likely that there will be more users in the future.
Convert two mempool users that currently use their own mempool-backed page
allocators to use the generic mempool page allocator.
Also included are 2 trivial whitespace fixes.
mempool-backed page allocators in 2 places in the kernel. It is also likely
Currently, get_user_pages() returns fully coherent pages to the kernel for
anything other than anonymous pages. This is a problem for things like
fuse and the SCSI generic ioctl SG_IO which can potentially wish to do DMA
to anonymous pages passed in by users.
The fix is to add a new memory management API: flush_anon_page() which
is used in get_user_pages() to make anonymous pages coherent.
Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
