path: root/mm
2011-07-31Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6: slab: use NUMA_NO_NODE slab: remove one NR_CPUS dependency
2011-07-31slab: use NUMA_NO_NODEAndrew Morton
Use the nice enumerated constant. Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2011-07-30Merge branch 'slub/lockless' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6 * 'slub/lockless' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6: (21 commits) slub: When allocating a new slab also prep the first object slub: disable interrupts in cmpxchg_double_slab when falling back to pagelock Avoid duplicate _count variables in page_struct Revert "SLUB: Fix build breakage in linux/mm_types.h" SLUB: Fix build breakage in linux/mm_types.h slub: slabinfo update for cmpxchg handling slub: Not necessary to check for empty slab on load_freelist slub: fast release on full slab slub: Add statistics for the case that the current slab does not match the node slub: Get rid of the another_slab label slub: Avoid disabling interrupts in free slowpath slub: Disable interrupts in free_debug processing slub: Invert locking and avoid slab lock slub: Rework allocator fastpaths slub: Pass kmem_cache struct to lock and freeze slab slub: explicit list_lock taking slub: Add cmpxchg_double_slab() mm: Rearrange struct page slub: Move page->frozen handling near where the page->freelist handling occurs slub: Do not use frozen page flag but a bit in the page counters ...
2011-07-28slab: remove one NR_CPUS dependencyEric Dumazet
Reduce high order allocations in do_tune_cpucache() for some setups. (NR_CPUS=4096 -> we need 64KB) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Christoph Lameter <cl@linux.com> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26fail_page_alloc: simplify debugfs initializationAkinobu Mita
Now cleanup_fault_attr_dentries() recursively removes a directory, So we can simplify the error handling in the initialization code and no need to hold dentry structs for each debugfs file. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26failslab: simplify debugfs initializationAkinobu Mita
Now cleanup_fault_attr_dentries() recursively removes a directory, So we can simplify the error handling in the initialization code and no need to hold dentry structs for each debugfs file. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26fault-injection: use debugfs_remove_recursiveAkinobu Mita
Use debugfs_remove_recursive() to simplify initialization and deinitialization of fault injection debugfs files. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26cpusets: randomize node rotor used in cpuset_mem_spread_node()Michal Hocko
[ This patch has already been accepted as commit 0ac0c0d0f837 but later reverted (commit 35926ff5fba8) because it itroduced arch specific __node_random which was defined only for x86 code so it broke other archs. This is a followup without any arch specific code. Other than that there are no functional changes.] Some workloads that create a large number of small files tend to assign too many pages to node 0 (multi-node systems). Part of the reason is that the rotor (in cpuset_mem_spread_node()) used to assign nodes starts at node 0 for newly created tasks. This patch changes the rotor to be initialized to a random node number of the cpuset. [akpm@linux-foundation.org: fix layout] [Lee.Schermerhorn@hp.com: Define stub numa_random() for !NUMA configuration] [mhocko@suse.cz: Make it arch independent] [akpm@linux-foundation.org: fix CONFIG_NUMA=y, MAX_NUMNODES>1 build] Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Michal Hocko <mhocko@suse.cz> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Paul Menage <menage@google.com> Cc: Jack Steiner <steiner@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: David Rientjes <rientjes@google.com> Cc: Jack Steiner <steiner@sgi.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Paul Menage <menage@google.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Robin Holt <holt@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26memcg: get rid of percpu_charge_mutex lockMichal Hocko
percpu_charge_mutex protects from multiple simultaneous per-cpu charge caches draining because we might end up having too many work items. At least this was the case until commit 26fe61684449 ("memcg: fix percpu cached charge draining frequency") when we introduced a more targeted draining for async mode. Now that also sync draining is targeted we can safely remove mutex because we will not send more work than the current number of CPUs. FLUSHING_CACHED_CHARGE protects from sending the same work multiple times and stock->nr_pages == 0 protects from pointless sending a work if there is obviously nothing to be done. This is of course racy but we can live with it as the race window is really small (we would have to see FLUSHING_CACHED_CHARGE cleared while nr_pages would be still non-zero). The only remaining place where we can race is synchronous mode when we rely on FLUSHING_CACHED_CHARGE test which might have been set by other drainer on the same group but we should wait in that case as well. Signed-off-by: Michal Hocko <mhocko@suse.cz> Cc: Balbir Singh <bsingharora@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26memcg: add mem_cgroup_same_or_subtree() helperMichal Hocko
We are checking whether a given two groups are same or at least in the same subtree of a hierarchy at several places. Let's make a helper for it to make code easier to read. Signed-off-by: Michal Hocko <mhocko@suse.cz> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <bsingharora@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26memcg: unify sync and async per-cpu charge cache drainingMichal Hocko
Currently we have two ways how to drain per-CPU caches for charges. drain_all_stock_sync will synchronously drain all caches while drain_all_stock_async will asynchronously drain only those that refer to a given memory cgroup or its subtree in hierarchy. Targeted async draining has been introduced by 26fe6168 (memcg: fix percpu cached charge draining frequency) to reduce the cpu workers number. sync draining is currently triggered only from mem_cgroup_force_empty which is triggered only by userspace (mem_cgroup_force_empty_write) or when a cgroup is removed (mem_cgroup_pre_destroy). Although these are not usually frequent operations it still makes some sense to do targeted draining as well, especially if the box has many CPUs. This patch unifies both methods to use the single code (drain_all_stock) which relies on the original async implementation and just adds flush_work to wait on all caches that are still under work for the sync mode. We are using FLUSHING_CACHED_CHARGE bit check to prevent from waiting on a work that we haven't triggered. Please note that both sync and async functions are currently protected by percpu_charge_mutex so we cannot race with other drainers. Signed-off-by: Michal Hocko <mhocko@suse.cz> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <bsingharora@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26memcg: do not try to drain per-cpu caches without pagesMichal Hocko
drain_all_stock_async tries to optimize a work to be done on the work queue by excluding any work for the current CPU because it assumes that the context we are called from already tried to charge from that cache and it's failed so it must be empty already. While the assumption is correct we can optimize it even more by checking the current number of pages in the cache. This will also reduce a work on other CPUs with an empty stock. For the current CPU we can simply call drain_local_stock rather than deferring it to the work queue. [kamezawa.hiroyu@jp.fujitsu.com: use drain_local_stock for current CPU optimization] Signed-off-by: Michal Hocko <mhocko@suse.cz> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26memcg: add memory.vmscan_statKAMEZAWA Hiroyuki
The commit log of 0ae5e89c60c9 ("memcg: count the soft_limit reclaim in...") says it adds scanning stats to memory.stat file. But it doesn't because we considered we needed to make a concensus for such new APIs. This patch is a trial to add memory.scan_stat. This shows - the number of scanned pages(total, anon, file) - the number of rotated pages(total, anon, file) - the number of freed pages(total, anon, file) - the number of elaplsed time (including sleep/pause time) for both of direct/soft reclaim. The biggest difference with oringinal Ying's one is that this file can be reset by some write, as # echo 0 ...../memory.scan_stat Example of output is here. This is a result after make -j 6 kernel under 300M limit. [kamezawa@bluextal ~]$ cat /cgroup/memory/A/memory.scan_stat [kamezawa@bluextal ~]$ cat /cgroup/memory/A/memory.vmscan_stat scanned_pages_by_limit 9471864 scanned_anon_pages_by_limit 6640629 scanned_file_pages_by_limit 2831235 rotated_pages_by_limit 4243974 rotated_anon_pages_by_limit 3971968 rotated_file_pages_by_limit 272006 freed_pages_by_limit 2318492 freed_anon_pages_by_limit 962052 freed_file_pages_by_limit 1356440 elapsed_ns_by_limit 351386416101 scanned_pages_by_system 0 scanned_anon_pages_by_system 0 scanned_file_pages_by_system 0 rotated_pages_by_system 0 rotated_anon_pages_by_system 0 rotated_file_pages_by_system 0 freed_pages_by_system 0 freed_anon_pages_by_system 0 freed_file_pages_by_system 0 elapsed_ns_by_system 0 scanned_pages_by_limit_under_hierarchy 9471864 scanned_anon_pages_by_limit_under_hierarchy 6640629 scanned_file_pages_by_limit_under_hierarchy 2831235 rotated_pages_by_limit_under_hierarchy 4243974 rotated_anon_pages_by_limit_under_hierarchy 3971968 rotated_file_pages_by_limit_under_hierarchy 272006 freed_pages_by_limit_under_hierarchy 2318492 freed_anon_pages_by_limit_under_hierarchy 962052 freed_file_pages_by_limit_under_hierarchy 1356440 elapsed_ns_by_limit_under_hierarchy 351386416101 scanned_pages_by_system_under_hierarchy 0 scanned_anon_pages_by_system_under_hierarchy 0 scanned_file_pages_by_system_under_hierarchy 0 rotated_pages_by_system_under_hierarchy 0 rotated_anon_pages_by_system_under_hierarchy 0 rotated_file_pages_by_system_under_hierarchy 0 freed_pages_by_system_under_hierarchy 0 freed_anon_pages_by_system_under_hierarchy 0 freed_file_pages_by_system_under_hierarchy 0 elapsed_ns_by_system_under_hierarchy 0 total_xxxx is for hierarchy management. This will be useful for further memcg developments and need to be developped before we do some complicated rework on LRU/softlimit management. This patch adds a new struct memcg_scanrecord into scan_control struct. sc->nr_scanned at el is not designed for exporting information. For example, nr_scanned is reset frequentrly and incremented +2 at scanning mapped pages. To avoid complexity, I added a new param in scan_control which is for exporting scanning score. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Michal Hocko <mhocko@suse.cz> Cc: Ying Han <yinghan@google.com> Cc: Andrew Bresticker <abrestic@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26memcg: fix behavior of mem_cgroup_resize_limit()Daisuke Nishimura
Commit 22a668d7c3ef ("memcg: fix behavior under memory.limit equals to memsw.limit") introduced "memsw_is_minimum" flag, which becomes true when mem_limit == memsw_limit. The flag is checked at the beginning of reclaim, and "noswap" is set if the flag is true, because using swap is meaningless in this case. This works well in most cases, but when we try to shrink mem_limit, which is the same as memsw_limit now, we might fail to shrink mem_limit because swap doesn't used. This patch fixes this behavior by: - check MEM_CGROUP_RECLAIM_SHRINK at the begining of reclaim - If it is set, don't set "noswap" flag even if memsw_is_minimum is true. Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <bsingharora@gmail.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Ying Han <yinghan@google.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26memcg: fix vmscan count in small memcgsKAMEZAWA Hiroyuki
Commit 246e87a93934 ("memcg: fix get_scan_count() for small targets") fixes the memcg/kswapd behavior against small targets and prevent vmscan priority too high. But the implementation is too naive and adds another problem to small memcg. It always force scan to 32 pages of file/anon and doesn't handle swappiness and other rotate_info. It makes vmscan to scan anon LRU regardless of swappiness and make reclaim bad. This patch fixes it by adjusting scanning count with regard to swappiness at el. At a test "cat 1G file under 300M limit." (swappiness=20) before patch scanned_pages_by_limit 360919 scanned_anon_pages_by_limit 180469 scanned_file_pages_by_limit 180450 rotated_pages_by_limit 31 rotated_anon_pages_by_limit 25 rotated_file_pages_by_limit 6 freed_pages_by_limit 180458 freed_anon_pages_by_limit 19 freed_file_pages_by_limit 180439 elapsed_ns_by_limit 429758872 after patch scanned_pages_by_limit 180674 scanned_anon_pages_by_limit 24 scanned_file_pages_by_limit 180650 rotated_pages_by_limit 35 rotated_anon_pages_by_limit 24 rotated_file_pages_by_limit 11 freed_pages_by_limit 180634 freed_anon_pages_by_limit 0 freed_file_pages_by_limit 180634 elapsed_ns_by_limit 367119089 scanned_pages_by_system 0 the numbers of scanning anon are decreased(as expected), and elapsed time reduced. By this patch, small memcgs will work better. (*) Because the amount of file-cache is much bigger than anon, recalaim_stat's rotate-scan counter make scanning files more. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Michal Hocko <mhocko@suse.cz> Cc: Ying Han <yinghan@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26memcg: change memcg_oom_mutex to spinlockMichal Hocko
memcg_oom_mutex is used to protect memcg OOM path and eventfd interface for oom_control. None of the critical sections which it protects sleep (eventfd_signal works from atomic context and the rest are simple linked list resp. oom_lock atomic operations). Mutex is also too heavyweight for those code paths because it triggers a lot of scheduling. It also makes makes convoying effects more visible when we have a big number of oom killing because we take the lock mutliple times during mem_cgroup_handle_oom so we have multiple places where many processes can sleep. Signed-off-by: Michal Hocko <mhocko@suse.cz> Cc: Balbir Singh <bsingharora@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26memcg: make oom_lock 0 and 1 based rather than counterMichal Hocko
Commit 867578cb ("memcg: fix oom kill behavior") introduced a oom_lock counter which is incremented by mem_cgroup_oom_lock when we are about to handle memcg OOM situation. mem_cgroup_handle_oom falls back to a sleep if oom_lock > 1 to prevent from multiple oom kills at the same time. The counter is then decremented by mem_cgroup_oom_unlock called from the same function. This works correctly but it can lead to serious starvations when we have many processes triggering OOM and many CPUs available for them (I have tested with 16 CPUs). Consider a process (call it A) which gets the oom_lock (the first one that got to mem_cgroup_handle_oom and grabbed memcg_oom_mutex) and other processes that are blocked on the mutex. While A releases the mutex and calls mem_cgroup_out_of_memory others will wake up (one after another) and increase the counter and fall into sleep (memcg_oom_waitq). Once A finishes mem_cgroup_out_of_memory it takes the mutex again and decreases oom_lock and wakes other tasks (if releasing memory by somebody else - e.g. killed process - hasn't done it yet). A testcase would look like: Assume malloc XXX is a program allocating XXX Megabytes of memory which touches all allocated pages in a tight loop # swapoff SWAP_DEVICE # cgcreate -g memory:A # cgset -r memory.oom_control=0 A # cgset -r memory.limit_in_bytes= 200M # for i in `seq 100` # do # cgexec -g memory:A malloc 10 & # done The main problem here is that all processes still race for the mutex and there is no guarantee that we will get counter back to 0 for those that got back to mem_cgroup_handle_oom. In the end the whole convoy in/decreases the counter but we do not get to 1 that would enable killing so nothing useful can be done. The time is basically unbounded because it highly depends on scheduling and ordering on mutex (I have seen this taking hours...). This patch replaces the counter by a simple {un}lock semantic. As mem_cgroup_oom_{un}lock works on the a subtree of a hierarchy we have to make sure that nobody else races with us which is guaranteed by the memcg_oom_mutex. We have to be careful while locking subtrees because we can encounter a subtree which is already locked: hierarchy: A / \ B \ /\ \ C D E B - C - D tree might be already locked. While we want to enable locking E subtree because OOM situations cannot influence each other we definitely do not want to allow locking A. Therefore we have to refuse lock if any subtree is already locked and clear up the lock for all nodes that have been set up to the failure point. On the other hand we have to make sure that the rest of the world will recognize that a group is under OOM even though it doesn't have a lock. Therefore we have to introduce under_oom variable which is incremented and decremented for the whole subtree when we enter resp. leave mem_cgroup_handle_oom. under_oom, unlike oom_lock, doesn't need be updated under memcg_oom_mutex because its users only check a single group and they use atomic operations for that. This can be checked easily by the following test case: # cgcreate -g memory:A # cgset -r memory.use_hierarchy=1 A # cgset -r memory.oom_control=1 A # cgset -r memory.limit_in_bytes= 100M # cgset -r memory.memsw.limit_in_bytes= 100M # cgcreate -g memory:A/B # cgset -r memory.oom_control=1 A/B # cgset -r memory.limit_in_bytes=20M # cgset -r memory.memsw.limit_in_bytes=20M # cgexec -g memory:A/B malloc 30 & #->this will be blocked by OOM of group B # cgexec -g memory:A malloc 80 & #->this will be blocked by OOM of group A While B gets oom_lock A will not get it. Both of them go into sleep and wait for an external action. We can make the limit higher for A to enforce waking it up # cgset -r memory.memsw.limit_in_bytes=300M A # cgset -r memory.limit_in_bytes=300M A malloc in A has to wake up even though it doesn't have oom_lock. Finally, the unlock path is very easy because we always unlock only the subtree we have locked previously while we always decrement under_oom. Signed-off-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <bsingharora@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26memcg: consolidate memory cgroup lru stat functionsKAMEZAWA Hiroyuki
In mm/memcontrol.c, there are many lru stat functions as.. mem_cgroup_zone_nr_lru_pages mem_cgroup_node_nr_file_lru_pages mem_cgroup_nr_file_lru_pages mem_cgroup_node_nr_anon_lru_pages mem_cgroup_nr_anon_lru_pages mem_cgroup_node_nr_unevictable_lru_pages mem_cgroup_nr_unevictable_lru_pages mem_cgroup_node_nr_lru_pages mem_cgroup_nr_lru_pages mem_cgroup_get_local_zonestat Some of them are under #ifdef MAX_NUMNODES >1 and others are not. This seems bad. This patch consolidates all functions into mem_cgroup_zone_nr_lru_pages() mem_cgroup_node_nr_lru_pages() mem_cgroup_nr_lru_pages() For these functions, "which LRU?" information is passed by a mask. example: mem_cgroup_nr_lru_pages(mem, BIT(LRU_ACTIVE_ANON)) And I added some macro as ALL_LRU, ALL_LRU_FILE, ALL_LRU_ANON. example: mem_cgroup_nr_lru_pages(mem, ALL_LRU) BTW, considering layout of NUMA memory placement of counters, this patch seems to be better. Now, when we gather all LRU information, we scan in following orer for_each_lru -> for_each_node -> for_each_zone. This means we'll touch cache lines in different node in turn. After patch, we'll scan for_each_node -> for_each_zone -> for_each_lru(mask) Then, we'll gather information in the same cacheline at once. [akpm@linux-foundation.org: fix warnigns, build error] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Ying Han <yinghan@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26memcg: export memory cgroup's swappiness with mem_cgroup_swappiness()KAMEZAWA Hiroyuki
Each memory cgroup has a 'swappiness' value which can be accessed by get_swappiness(memcg). The major user is try_to_free_mem_cgroup_pages() and swappiness is passed by argument. It's propagated by scan_control. get_swappiness() is a static function but some planned updates will need to get swappiness from files other than memcontrol.c This patch exports get_swappiness() as mem_cgroup_swappiness(). With this, we can remove the argument of swapiness from try_to_free... and drop swappiness from scan_control. only memcg uses it. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Ying Han <yinghan@google.com> Cc: Shaohua Li <shaohua.li@intel.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wfg/writeback * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/wfg/writeback: (27 commits) mm: properly reflect task dirty limits in dirty_exceeded logic writeback: don't busy retry writeback on new/freeing inodes writeback: scale IO chunk size up to half device bandwidth writeback: trace global_dirty_state writeback: introduce max-pause and pass-good dirty limits writeback: introduce smoothed global dirty limit writeback: consolidate variable names in balance_dirty_pages() writeback: show bdi write bandwidth in debugfs writeback: bdi write bandwidth estimation writeback: account per-bdi accumulated written pages writeback: make writeback_control.nr_to_write straight writeback: skip tmpfs early in balance_dirty_pages_ratelimited_nr() writeback: trace event writeback_queue_io writeback: trace event writeback_single_inode writeback: remove .nonblocking and .encountered_congestion writeback: remove writeback_control.more_io writeback: skip balance_dirty_pages() for in-memory fs writeback: add bdi_dirty_limit() kernel-doc writeback: avoid extra sync work at enqueue time writeback: elevate queue_io() into wb_writeback() ... Fix up trivial conflicts in fs/fs-writeback.c and mm/filemap.c
2011-07-25Merge 'akpm' patch seriesLinus Torvalds
* Merge akpm patch series: (122 commits) drivers/connector/cn_proc.c: remove unused local Documentation/SubmitChecklist: add RCU debug config options reiserfs: use hweight_long() reiserfs: use proper little-endian bitops pnpacpi: register disabled resources drivers/rtc/rtc-tegra.c: properly initialize spinlock drivers/rtc/rtc-twl.c: check return value of twl_rtc_write_u8() in twl_rtc_set_time() drivers/rtc: add support for Qualcomm PMIC8xxx RTC drivers/rtc/rtc-s3c.c: support clock gating drivers/rtc/rtc-mpc5121.c: add support for RTC on MPC5200 init: skip calibration delay if previously done misc/eeprom: add eeprom access driver for digsy_mtc board misc/eeprom: add driver for microwire 93xx46 EEPROMs checkpatch.pl: update $logFunctions checkpatch: make utf-8 test --strict checkpatch.pl: add ability to ignore various messages checkpatch: add a "prefer __aligned" check checkpatch: validate signature styles and To: and Cc: lines checkpatch: add __rcu as a sparse modifier checkpatch: suggest using min_t or max_t ... Did this as a merge because of (trivial) conflicts in - Documentation/feature-removal-schedule.txt - arch/xtensa/include/asm/uaccess.h that were just easier to fix up in the merge than in the patch series.
2011-07-25devres: fix possible use after freeMaxin B John
devres uses the pointer value as key after it's freed, which is safe but triggers spurious use-after-free warnings on some static analysis tools. Rearrange code to avoid such warnings. Signed-off-by: Maxin B. John <maxin.john@gmail.com> Reviewed-by: Rolf Eike Beer <eike-kernel@sf-tec.de> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25writeback: account NR_WRITTEN at IO completion timeWu Fengguang
NR_WRITTEN is now accounted at block IO enqueue time, which is not very accurate as to common understanding. This moves NR_WRITTEN accounting to the IO completion time and makes it more consistent with BDI_WRITTEN, which is used for bandwidth estimation. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Michael Rubin <mrubin@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25tmpfs: simplify unuse and writepageHugh Dickins
shmem_unuse_inode() and shmem_writepage() contain a little code to cope with pages inserted independently into the filecache, probably by a filesystem stacked on top of tmpfs, then fed to its ->readpage() or ->writepage(). Unionfs was indeed experimenting with working in that way three years ago, but I find no current examples: nowadays the stacking filesystems use vfs interfaces to the lower filesystem. It's now illegal: remove most of that code, adding some WARN_ON_ONCEs. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Erez Zadok <ezk@fsl.cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25tmpfs: simplify filepage/swappageHugh Dickins
We can now simplify shmem_getpage_gfp(): there is no longer a dilemma of filepage passed in via shmem_readpage(), then swappage found, which must then be copied over to it. Although at first it's tempting to replace the **pagep arg by returning struct page *, that makes a mess of IS_ERR_OR_NULL(page)s in all the callers, so leave as is. Insert BUG_ON(!PageUptodate) when we find and lock page: some of the complication came from uninitialized pages inserted into filecache prior to readpage; but now we're in control, and only release pagelock on filecache once it's uptodate (if an error occurs in reading back from swap, the page remains in swapcache, never moved to filecache). Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25tmpfs: simplify prealloc_pageHugh Dickins
The prealloc_page handling in shmem_getpage_gfp() is unnecessarily complicated: first simplify that before going on to filepage/swappage. That's right, don't report ENOMEM when the preallocation fails: we may or may not need the page. But simply report ENOMEM once we find we do need it, instead of dropping lock, repeating allocation, unwinding on failure etc. And leave the out label on the fast path, don't goto. Fix something that looks like a bug but turns out not to be: set PageSwapBacked on prealloc_page before its mem_cgroup_cache_charge(), as the removed case was doing. That's important before adding to LRU (determines which LRU the page goes on), and does affect which path it takes through memcontrol.c, but in the end MEM_CGROUP_CHANGE_TYPE_ SHMEM is handled no differently from CACHE. Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Shaohua Li <shaohua.li@intel.com> Cc: "Zhang, Yanmin" <yanmin.zhang@intel.com> Cc: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25tmpfs: remove_shmem_readpageHugh Dickins
Remove that pernicious shmem_readpage() at last: the things we needed it for (splice, loop, sendfile, i915 GEM) are now fully taken care of by shmem_file_splice_read() and shmem_read_mapping_page_gfp(). This removal clears the way for a simpler shmem_getpage_gfp(), since page is never passed in; but leave most of that cleanup until after. sys_readahead() and sys_fadvise(POSIX_FADV_WILLNEED) will now EINVAL, instead of unexpectedly trying to read ahead on tmpfs: if that proves to be an issue for someone, then we can either arrange for them to return success instead, or try to implement async readahead on tmpfs. Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25tmpfs: pass gfp to shmem_getpage_gfpHugh Dickins
Make shmem_getpage() a wrapper, passing mapping_gfp_mask() down to shmem_getpage_gfp(), which in turn passes gfp down to shmem_swp_alloc(). Change shmem_read_mapping_page_gfp() to use shmem_getpage_gfp() in the CONFIG_SHMEM case; but leave tiny !SHMEM using read_cache_page_gfp(). Add a BUG_ON() in case anyone happens to call this on a non-shmem mapping; though we might later want to let that case route to read_cache_page_gfp(). It annoys me to have these two almost-redundant args, gfp and fault_type: I can't find a better way; but initialize fault_type only in shmem_fault(). Note that before, read_cache_page_gfp() was allocating i915_gem's pages with __GFP_NORETRY as intended; but the corresponding swap vector pages got allocated without it, leaving a small possibility of OOM. Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25tmpfs: refine shmem_file_splice_readHugh Dickins
Tidy up shmem_file_splice_read(): Remove readahead: okay, we could implement shmem readahead on swap, but have never done so before, swap being the slow exceptional path. Use shmem_getpage() instead of find_or_create_page() plus ->readpage(). Remove several comments: sorry, I found them more distracting than helpful, and this will not be the reference version of splice_read(). Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25tmpfs: clone shmem_file_splice_read()Hugh Dickins
Copy __generic_file_splice_read() and generic_file_splice_read() from fs/splice.c to shmem_file_splice_read() in mm/shmem.c. Make page_cache_pipe_buf_ops and spd_release_page() accessible to it. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Jens Axboe <jaxboe@fusionio.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25mm/futex: fix futex writes on archs with SW tracking of dirty & youngBenjamin Herrenschmidt
I haven't reproduced it myself but the fail scenario is that on such machines (notably ARM and some embedded powerpc), if you manage to hit that futex path on a writable page whose dirty bit has gone from the PTE, you'll livelock inside the kernel from what I can tell. It will go in a loop of trying the atomic access, failing, trying gup to "fix it up", getting succcess from gup, go back to the atomic access, failing again because dirty wasn't fixed etc... So I think you essentially hang in the kernel. The scenario is probably rare'ish because affected architecture are embedded and tend to not swap much (if at all) so we probably rarely hit the case where dirty is missing or young is missing, but I think Shan has a piece of SW that can reliably reproduce it using a shared writable mapping & fork or something like that. On archs who use SW tracking of dirty & young, a page without dirty is effectively mapped read-only and a page without young unaccessible in the PTE. Additionally, some architectures might lazily flush the TLB when relaxing write protection (by doing only a local flush), and expect a fault to invalidate the stale entry if it's still present on another processor. The futex code assumes that if the "in_atomic()" access -EFAULT's, it can "fix it up" by causing get_user_pages() which would then be equivalent to taking the fault. However that isn't the case. get_user_pages() will not call handle_mm_fault() in the case where the PTE seems to have the right permissions, regardless of the dirty and young state. It will eventually update those bits ... in the struct page, but not in the PTE. Additionally, it will not handle the lazy TLB flushing that can be required by some architectures in the fault case. Basically, gup is the wrong interface for the job. The patch provides a more appropriate one which boils down to just calling handle_mm_fault() since what we are trying to do is simulate a real page fault. The futex code currently attempts to write to user memory within a pagefault disabled section, and if that fails, tries to fix it up using get_user_pages(). This doesn't work on archs where the dirty and young bits are maintained by software, since they will gate access permission in the TLB, and will not be updated by gup(). In addition, there's an expectation on some archs that a spurious write fault triggers a local TLB flush, and that is missing from the picture as well. I decided that adding those "features" to gup() would be too much for this already too complex function, and instead added a new simpler fixup_user_fault() which is essentially a wrapper around handle_mm_fault() which the futex code can call. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix some nits Darren saw, fiddle comment layout] Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Reported-by: Shan Hai <haishan.bai@gmail.com> Tested-by: Shan Hai <haishan.bai@gmail.com> Cc: David Laight <David.Laight@ACULAB.COM> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Darren Hart <darren.hart@intel.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25mm: remove useless rcu lock-unlock from mapping_tagged()Konstantin Khlebnikov
radix_tree_tagged() is lockless - it reads from a member of the raid-tree root node. It does not require any protection. Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25mm: page allocator: reconsider zones for allocation after direct reclaimMel Gorman
With zone_reclaim_mode enabled, it's possible for zones to be considered full in the zonelist_cache so they are skipped in the future. If the process enters direct reclaim, the ZLC may still consider zones to be full even after reclaiming pages. Reconsider all zones for allocation if direct reclaim returns successfully. Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25mm: page allocator: initialise ZLC for first zone eligible for zone_reclaimMel Gorman
There have been a small number of complaints about significant stalls while copying large amounts of data on NUMA machines reported on a distribution bugzilla. In these cases, zone_reclaim was enabled by default due to large NUMA distances. In general, the complaints have not been about the workload itself unless it was a file server (in which case the recommendation was disable zone_reclaim). The stalls are mostly due to significant amounts of time spent scanning the preferred zone for pages to free. After a failure, it might fallback to another node (as zonelists are often node-ordered rather than zone-ordered) but stall quickly again when the next allocation attempt occurs. In bad cases, each page allocated results in a full scan of the preferred zone. Patch 1 checks the preferred zone for recent allocation failure which is particularly important if zone_reclaim has failed recently. This avoids rescanning the zone in the near future and instead falling back to another node. This may hurt node locality in some cases but a failure to zone_reclaim is more expensive than a remote access. Patch 2 clears the zlc information after direct reclaim. Otherwise, zone_reclaim can mark zones full, direct reclaim can reclaim enough pages but the zone is still not considered for allocation. This was tested on a 24-thread 2-node x86_64 machine. The tests were focused on large amounts of IO. All tests were bound to the CPUs on node-0 to avoid disturbances due to processes being scheduled on different nodes. The kernels tested are 3.0-rc6-vanilla Vanilla 3.0-rc6 zlcfirst Patch 1 applied zlcreconsider Patches 1+2 applied FS-Mark ./fs_mark -d /tmp/fsmark-10813 -D 100 -N 5000 -n 208 -L 35 -t 24 -S0 -s 524288 fsmark-3.0-rc6 3.0-rc6 3.0-rc6 vanilla zlcfirs zlcreconsider Files/s min 54.90 ( 0.00%) 49.80 (-10.24%) 49.10 (-11.81%) Files/s mean 100.11 ( 0.00%) 135.17 (25.94%) 146.93 (31.87%) Files/s stddev 57.51 ( 0.00%) 138.97 (58.62%) 158.69 (63.76%) Files/s max 361.10 ( 0.00%) 834.40 (56.72%) 802.40 (55.00%) Overhead min 76704.00 ( 0.00%) 76501.00 ( 0.27%) 77784.00 (-1.39%) Overhead mean 1485356.51 ( 0.00%) 1035797.83 (43.40%) 1594680.26 (-6.86%) Overhead stddev 1848122.53 ( 0.00%) 881489.88 (109.66%) 1772354.90 ( 4.27%) Overhead max 7989060.00 ( 0.00%) 3369118.00 (137.13%) 10135324.00 (-21.18%) MMTests Statistics: duration User/Sys Time Running Test (seconds) 501.49 493.91 499.93 Total Elapsed Time (seconds) 2451.57 2257.48 2215.92 MMTests Statistics: vmstat Page Ins 46268 63840 66008 Page Outs 90821596 90671128 88043732 Swap Ins 0 0 0 Swap Outs 0 0 0 Direct pages scanned 13091697 8966863 8971790 Kswapd pages scanned 0 1830011 1831116 Kswapd pages reclaimed 0 1829068 1829930 Direct pages reclaimed 13037777 8956828 8648314 Kswapd efficiency 100% 99% 99% Kswapd velocity 0.000 810.643 826.346 Direct efficiency 99% 99% 96% Direct velocity 5340.128 3972.068 4048.788 Percentage direct scans 100% 83% 83% Page writes by reclaim 0 3 0 Slabs scanned 796672 720640 720256 Direct inode steals 7422667 7160012 7088638 Kswapd inode steals 0 1736840 2021238 Test completes far faster with a large increase in the number of files created per second. Standard deviation is high as a small number of iterations were much higher than the mean. The number of pages scanned by zone_reclaim is reduced and kswapd is used for more work. LARGE DD 3.0-rc6 3.0-rc6 3.0-rc6 vanilla zlcfirst zlcreconsider download tar 59 ( 0.00%) 59 ( 0.00%) 55 ( 7.27%) dd source files 527 ( 0.00%) 296 (78.04%) 320 (64.69%) delete source 36 ( 0.00%) 19 (89.47%) 20 (80.00%) MMTests Statistics: duration User/Sys Time Running Test (seconds) 125.03 118.98 122.01 Total Elapsed Time (seconds) 624.56 375.02 398.06 MMTests Statistics: vmstat Page Ins 3594216 439368 407032 Page Outs 23380832 23380488 23377444 Swap Ins 0 0 0 Swap Outs 0 436 287 Direct pages scanned 17482342 69315973 82864918 Kswapd pages scanned 0 519123 575425 Kswapd pages reclaimed 0 466501 522487 Direct pages reclaimed 5858054 2732949 2712547 Kswapd efficiency 100% 89% 90% Kswapd velocity 0.000 1384.254 1445.574 Direct efficiency 33% 3% 3% Direct velocity 27991.453 184832.737 208171.929 Percentage direct scans 100% 99% 99% Page writes by reclaim 0 5082 13917 Slabs scanned 17280 29952 35328 Direct inode steals 115257 1431122 332201 Kswapd inode steals 0 0 979532 This test downloads a large tarfile and copies it with dd a number of times - similar to the most recent bug report I've dealt with. Time to completion is reduced. The number of pages scanned directly is still disturbingly high with a low efficiency but this is likely due to the number of dirty pages encountered. The figures could probably be improved with more work around how kswapd is used and how dirty pages are handled but that is separate work and this result is significant on its own. Streaming Mapped Writer MMTests Statistics: duration User/Sys Time Running Test (seconds) 124.47 111.67 112.64 Total Elapsed Time (seconds) 2138.14 1816.30 1867.56 MMTests Statistics: vmstat Page Ins 90760 89124 89516 Page Outs 121028340 120199524 120736696 Swap Ins 0 86 55 Swap Outs 0 0 0 Direct pages scanned 114989363 96461439 96330619 Kswapd pages scanned 56430948 56965763 57075875 Kswapd pages reclaimed 27743219 27752044 27766606 Direct pages reclaimed 49777 46884 36655 Kswapd efficiency 49% 48% 48% Kswapd velocity 26392.541 31363.631 30561.736 Direct efficiency 0% 0% 0% Direct velocity 53780.091 53108.759 51581.004 Percentage direct scans 67% 62% 62% Page writes by reclaim 385 122 1513 Slabs scanned 43008 39040 42112 Direct inode steals 0 10 8 Kswapd inode steals 733 534 477 This test just creates a large file mapping and writes to it linearly. Time to completion is again reduced. The gains are mostly down to two things. In many cases, there is less scanning as zone_reclaim simply gives up faster due to recent failures. The second reason is that memory is used more efficiently. Instead of scanning the preferred zone every time, the allocator falls back to another zone and uses it instead improving overall memory utilisation. This patch: initialise ZLC for first zone eligible for zone_reclaim. The zonelist cache (ZLC) is used among other things to record if zone_reclaim() failed for a particular zone recently. The intention is to avoid a high cost scanning extremely long zonelists or scanning within the zone uselessly. Currently the zonelist cache is setup only after the first zone has been considered and zone_reclaim() has been called. The objective was to avoid a costly setup but zone_reclaim is itself quite expensive. If it is failing regularly such as the first eligible zone having mostly mapped pages, the cost in scanning and allocation stalls is far higher than the ZLC initialisation step. This patch initialises ZLC before the first eligible zone calls zone_reclaim(). Once initialised, it is checked whether the zone failed zone_reclaim recently. If it has, the zone is skipped. As the first zone is now being checked, additional care has to be taken about zones marked full. A zone can be marked "full" because it should not have enough unmapped pages for zone_reclaim but this is excessive as direct reclaim or kswapd may succeed where zone_reclaim fails. Only mark zones "full" after zone_reclaim fails if it failed to reclaim enough pages after scanning. Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25mm: preallocate page before lock_page() at filemap COWKAMEZAWA Hiroyuki
Currently we are keeping faulted page locked throughout whole __do_fault call (except for page_mkwrite code path) after calling file system's fault code. If we do early COW, we allocate a new page which has to be charged for a memcg (mem_cgroup_newpage_charge). This function, however, might block for unbounded amount of time if memcg oom killer is disabled or fork-bomb is running because the only way out of the OOM situation is either an external event or OOM-situation fix. In the end we are keeping the faulted page locked and blocking other processes from faulting it in which is not good at all because we are basically punishing potentially an unrelated process for OOM condition in a different group (I have seen stuck system because of ld-2.11.1.so being locked). We can do test easily. % cgcreate -g memory:A % cgset -r memory.limit_in_bytes=64M A % cgset -r memory.memsw.limit_in_bytes=64M A % cd kernel_dir; cgexec -g memory:A make -j Then, the whole system will live-locked until you kill 'make -j' by hands (or push reboot...) This is because some important page in a a shared library are locked. Considering again, the new page is not necessary to be allocated with lock_page() held. And usual page allocation may dive into long memory reclaim loop with holding lock_page() and can cause very long latency. There are 3 ways. 1. do allocation/charge before lock_page() Pros. - simple and can handle page allocation in the same manner. This will reduce holding time of lock_page() in general. Cons. - we do page allocation even if ->fault() returns error. 2. do charge after unlock_page(). Even if charge fails, it's just OOM. Pros. - no impact to non-memcg path. Cons. - implemenation requires special cares of LRU and we need to modify page_add_new_anon_rmap()... 3. do unlock->charge->lock again method. Pros. - no impact to non-memcg path. Cons. - This may kill LOCK_PAGE_RETRY optimization. We need to release lock and get it again... This patch moves "charge" and memory allocation for COW page before lock_page(). Then, we can avoid scanning LRU with holding a lock on a page and latency under lock_page() will be reduced. Then, above livelock disappears. [akpm@linux-foundation.org: fix code layout] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reported-by: Lutz Vieweg <lvml@5t9.de> Original-idea-by: Michal Hocko <mhocko@suse.cz> Cc: Michal Hocko <mhocko@suse.cz> Cc: Ying Han <yinghan@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25tmpfs: no need to use i_lockHugh Dickins
2.6.36's 7e496299d4d2 ("tmpfs: make tmpfs scalable with percpu_counter for used blocks") to make tmpfs scalable with percpu_counter used inode->i_lock in place of sbinfo->stat_lock around i_blocks updates; but that was adverse to scalability, and unnecessary, since info->lock is already held there in the fast paths. Remove those uses of i_lock, and add info->lock in the three error paths where it's then needed across shmem_free_blocks(). It's not actually needed across shmem_unacct_blocks(), but they're so often paired that it looks wrong to split them apart. Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25mm: pincer in truncate_inode_pages_rangeHugh Dickins
truncate_inode_pages_range()'s final loop has a nice pincer property, bringing start and end together, squeezing out the last pages. But the range handling missed out on that, just sliding up the range, perhaps letting pages come in behind it. Add one more test to give it the same pincer effect. Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25mm: consistent truncate and invalidate loopsHugh Dickins
Make the pagevec_lookup loops in truncate_inode_pages_range(), invalidate_mapping_pages() and invalidate_inode_pages2_range() more consistent with each other. They were relying upon page->index of an unlocked page, but apologizing for it: accept it, embrace it, add comments and WARN_ONs, and simplify the index handling. invalidate_inode_pages2_range() had special handling for a wrapped page->index + 1 = 0 case; but MAX_LFS_FILESIZE doesn't let us anywhere near there, and a corrupt page->index in the radix_tree could cause more trouble than that would catch. Remove that wrapped handling. invalidate_inode_pages2_range() uses min() to limit the pagevec_lookup when near the end of the range: copy that into the other two, although it's less useful than you might think (it limits the use of the buffer, rather than the indices looked up). Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25mm: tidy vmtruncate_range and related functionsHugh Dickins
Use consistent variable names in truncate_pagecache(), truncate_setsize(), vmtruncate() and vmtruncate_range(). unmap_mapping_range() and vmtruncate_range() have mismatched interfaces: don't change either, but make the vmtruncates more precise about what they expect unmap_mapping_range() to do. vmtruncate_range() is currently called only with page-aligned start and end+1: can handle unaligned start, but unaligned end+1 would hit BUG_ON in truncate_inode_pages_range() (lacks partial clearing of the end page). Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25mm: cleanup descriptions of filler argHugh Dickins
The often-NULL data arg to read_cache_page() and read_mapping_page() functions is misdescribed as "destination for read data": no, it's the first arg to the filler function, often struct file * to ->readpage(). Satisfy checkpatch.pl on those filler prototypes, and tidy up the declarations in linux/pagemap.h. Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25mmap: fix and tidy up overcommit page arithmeticDmitry Fink
- shmem pages are not immediately available, but they are not potentially available either, even if we swap them out, they will just relocate from memory into swap, total amount of immediate and potentially available memory is not going to be affected, so we shouldn't count them as potentially free in the first place. - nr_free_pages() is not an expensive operation anymore, there is no need to split the decision making in two halves and repeat code. Signed-off-by: Dmitry Fink <dmitry.fink@palm.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25mm/memblock.c: avoid abuse of RED_INACTIVEAndrew Morton
RED_INACTIVE is a slab thing, and reusing it for memblock was inappropriate, because memblock is dealing with phys_addr_t's which have a Kconfigurable sizeof(). Create a new poison type for this application. Fixes the sparse warning warning: cast truncates bits from constant value (9f911029d74e35b becomes 9d74e35b) Reported-by: H Hartley Sweeten <hartleys@visionengravers.com> Tested-by: H Hartley Sweeten <hartleys@visionengravers.com> Acked-by: Pekka Enberg <penberg@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25oom: remove references to old badness() functionDavid Rientjes
The badness() function in the oom killer was renamed to oom_badness() in a63d83f427fb ("oom: badness heuristic rewrite") since it is a globally exported function for clarity. The prototype for the old function still existed in linux/oom.h, so remove it. There are no existing users. Also fixes documentation and comment references to badness() and adjusts them accordingly. Signed-off-by: David Rientjes <rientjes@google.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25mm/memory.c: remove ZAP_BLOCK_SIZEAndrew Morton
ZAP_BLOCK_SIZE became unused in the preemptible-mmu_gather work ("mm: Remove i_mmap_lock lockbreak"). So zap it. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25mm: hugetlb: fix coding style issuesChris Forbes
Fix coding style issues flagged by checkpatch.pl Signed-off-by: Chris Forbes <chrisf@ijw.co.nz> Acked-by: Eric B Munson <emunson@mgebm.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25mm/huge_memory.c: minor lock simplification in __khugepaged_exitChris Wright
The lock is released first thing in all three branches. Simplify this by unconditionally releasing lock and remove else clause which was only there to be sure lock was released. Signed-off-by: Chris Wright <chrisw@sous-sol.org> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Johannes Weiner <jweiner@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25mm/page_cgroup.c: simplify code by using SECTION_ALIGN_UP() and ↵Daniel Kiper
SECTION_ALIGN_DOWN() macros Commit a539f3533b78e3 ("mm: add SECTION_ALIGN_UP() and SECTION_ALIGN_DOWN() macro") introduced the SECTION_ALIGN_UP() and SECTION_ALIGN_DOWN() macros. Use those macros to increase code readability. Signed-off-by: Daniel Kiper <dkiper@net-space.pl> Acked-by: David Rientjes <rientjes@google.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25mm: remove the leftovers of noswapaccountWANG Cong
In commit a2c8990aed5ab ("memsw: remove noswapaccount kernel parameter"), Michal forgot to remove some left pieces of noswapaccount in the tree, this patch removes them all. Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Acked-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25pagewalk: fix code comment for THPKOSAKI Motohiro
Commit bae9c19bf1 ("thp: split_huge_page_mm/vma") changed locking behavior of walk_page_range(). Thus this patch changes the comment too. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Hiroyuki Kamezawa <kamezawa.hiroyuki@gmail.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
