path: root/mm
2015-07-17mm/cma_debug: correct size input to bitmap functionJoonsoo Kim
In CMA, 1 bit in bitmap means 1 << order_per_bits pages so size of bitmap is cma->count >> order_per_bits rather than just cma->count. This patch fixes it. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Michal Nazarewicz <mina86@mina86.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Stefan Strogin <stefan.strogin@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-17mm/cma_debug: fix debugging alloc/free interfaceJoonsoo Kim
CMA has alloc/free interface for debugging. It is intended that alloc/free occurs in specific CMA region, but, currently, alloc/free interface is on root dir due to the bug so we can't select CMA region where alloc/free happens. This patch fixes this problem by making alloc/free interface per CMA region. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Michal Nazarewicz <mina86@mina86.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Stefan Strogin <stefan.strogin@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-17mm/page_owner: set correct gfp_mask on page_ownerJoonsoo Kim
Currently, we set wrong gfp_mask to page_owner info in case of isolated freepage by compaction and split page. It causes incorrect mixed pageblock report that we can get from '/proc/pagetypeinfo'. This metric is really useful to measure fragmentation effect so should be accurate. This patch fixes it by setting correct information. Without this patch, after kernel build workload is finished, number of mixed pageblock is 112 among roughly 210 movable pageblocks. But, with this fix, output shows that mixed pageblock is just 57. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-17mm/page_owner: fix possible access violationJoonsoo Kim
When I tested my new patches, I found that page pointer which is used for setting page_owner information is changed. This is because page pointer is used to set new migratetype in loop. After this work, page pointer could be out of bound. If this wrong pointer is used for page_owner, access violation happens. Below is error message that I got. BUG: unable to handle kernel paging request at 0000000000b00018 IP: [<ffffffff81025f30>] save_stack_address+0x30/0x40 PGD 1af2d067 PUD 166e0067 PMD 0 Oops: 0002 [#1] SMP ...snip... Call Trace: print_context_stack+0xcf/0x100 dump_trace+0x15f/0x320 save_stack_trace+0x2f/0x50 __set_page_owner+0x46/0x70 __isolate_free_page+0x1f7/0x210 split_free_page+0x21/0xb0 isolate_freepages_block+0x1e2/0x410 compaction_alloc+0x22d/0x2d0 migrate_pages+0x289/0x8b0 compact_zone+0x409/0x880 compact_zone_order+0x6d/0x90 try_to_compact_pages+0x110/0x210 __alloc_pages_direct_compact+0x3d/0xe6 __alloc_pages_nodemask+0x6cd/0x9a0 alloc_pages_current+0x91/0x100 runtest_store+0x296/0xa50 simple_attr_write+0xbd/0xe0 __vfs_write+0x28/0xf0 vfs_write+0xa9/0x1b0 SyS_write+0x46/0xb0 system_call_fastpath+0x16/0x75 This patch fixes this error by moving up set_page_owner(). Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Vlastimil Babka <vbabka@suse.cz> Acked-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-17mm, meminit: suppress unused memory variable warningMel Gorman
The kbuild test robot reported the following tree: git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git master head: 14a6f1989dae9445d4532941bdd6bbad84f4c8da commit: 3b242c66ccbd60cf47ab0e8992119d9617548c23 x86: mm: enable deferred struct page initialisation on x86-64 date: 3 days ago config: x86_64-randconfig-x006-201527 (attached as .config) reproduce: git checkout 3b242c66ccbd60cf47ab0e8992119d9617548c23 # save the attached .config to linux build tree make ARCH=x86_64 All warnings (new ones prefixed by >>): mm/page_alloc.c: In function 'early_page_uninitialised': >> mm/page_alloc.c:247:6: warning: unused variable 'nid' [-Wunused-variable] int nid = early_pfn_to_nid(pfn); It's due to the NODE_DATA macro ignoring the nid parameter on !NUMA configurations. This patch avoids the warning by not declaring nid. Signed-off-by: Mel Gorman <mgorman@suse.de> Reported-by: Wu Fengguang <fengguang.wu@intel.com> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-09mm: avoid setting up anonymous pages into file mappingKirill A. Shutemov
Reading page fault handler code I've noticed that under right circumstances kernel would map anonymous pages into file mappings: if the VMA doesn't have vm_ops->fault() and the VMA wasn't fully populated on ->mmap(), kernel would handle page fault to not populated pte with do_anonymous_page(). Let's change page fault handler to use do_anonymous_page() only on anonymous VMA (->vm_ops == NULL) and make sure that the VMA is not shared. For file mappings without vm_ops->fault() or shred VMA without vm_ops, page fault on pte_none() entry would lead to SIGBUS. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Oleg Nesterov <oleg@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Willy Tarreau <w@1wt.eu> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more vfs updates from Al Viro: "Assorted VFS fixes and related cleanups (IMO the most interesting in that part are f_path-related things and Eric's descriptor-related stuff). UFS regression fixes (it got broken last cycle). 9P fixes. fs-cache series, DAX patches, Jan's file_remove_suid() work" [ I'd say this is much more than "fixes and related cleanups". The file_table locking rule change by Eric Dumazet is a rather big and fundamental update even if the patch isn't huge. - Linus ] * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (49 commits) 9p: cope with bogus responses from server in p9_client_{read,write} p9_client_write(): avoid double p9_free_req() 9p: forgetting to cancel request on interrupted zero-copy RPC dax: bdev_direct_access() may sleep block: Add support for DAX reads/writes to block devices dax: Use copy_from_iter_nocache dax: Add block size note to documentation fs/file.c: __fget() and dup2() atomicity rules fs/file.c: don't acquire files->file_lock in fd_install() fs:super:get_anon_bdev: fix race condition could cause dev exceed its upper limitation vfs: avoid creation of inode number 0 in get_next_ino namei: make set_root_rcu() return void make simple_positive() public ufs: use dir_pages instead of ufs_dir_pages() pagemap.h: move dir_pages() over there remove the pointless include of lglock.h fs: cleanup slight list_entry abuse xfs: Correctly lock inode when removing suid and file capabilities fs: Call security_ops->inode_killpriv on truncate fs: Provide function telling whether file_remove_privs() will do anything ...
2015-07-03Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block fixes from Jens Axboe: "Mainly sending this off now for the writeback fixes, since they fix a real regression introduced with the cgroup writeback changes. The NVMe fix could wait for next pull for this series, but it's simple enough that we might as well include it. This contains: - two cgroup writeback fixes from Tejun, fixing a user reported issue with luks crypt devices hanging when being closed. - NVMe error cleanup fix from Jon Derrick, fixing a case where we'd attempt to free an unregistered IRQ" * 'for-linus' of git://git.kernel.dk/linux-block: NVMe: Fix irq freeing when queue_request_irq fails writeback: don't drain bdi_writeback_congested on bdi destruction writeback: don't embed root bdi_writeback_congested in bdi_writeback
2015-07-02Merge tag 'module_init-alternate_initcall-v4.1-rc8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull module_init replacement part two from Paul Gortmaker: "Replace module_init with appropriate alternate initcall in non modules. This series converts non-modular code that is using the module_init() call to hook itself into the system to instead use one of our alternate priority initcalls. Unlike the previous series that used device_initcall and hence was a runtime no-op, these commits change to one of the alternate initcalls, because (a) we have them and (b) it seems like the right thing to do. For example, it would seem logical to use arch_initcall for arch specific setup code and fs_initcall for filesystem setup code. This does mean however, that changes in the init ordering will be taking place, and so there is a small risk that some kind of implicit init ordering issue may lie uncovered. But I think it is still better to give these ones sensible priorities than to just assign them all to device_initcall in order to exactly preserve the old ordering. Thad said, we have already made similar changes in core kernel code in commit c96d6660dc65 ("kernel: audit/fix non-modular users of module_init in core code") without any regressions reported, so this type of change isn't without precedent. It has also got the same local testing and linux-next coverage as all the other pull requests that I'm sending for this merge window have got. Once again, there is an unused module_exit function removal that shows up as an outlier upon casual inspection of the diffstat" * tag 'module_init-alternate_initcall-v4.1-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: x86: perf_event_intel_pt.c: use arch_initcall to hook in enabling x86: perf_event_intel_bts.c: use arch_initcall to hook in enabling mm/page_owner.c: use late_initcall to hook in enabling lib/list_sort: use late_initcall to hook in self tests arm: use subsys_initcall in non-modular pl320 IPC code powerpc: don't use module_init for non-modular core hugetlb code powerpc: use subsys_initcall for Freescale Local Bus x86: don't use module_init for non-modular core bootflag code netfilter: don't use module_init/exit in core IPV4 code fs/notify: don't use module_init for non-modular inotify_user code mm: replace module_init usages with subsys_initcall in nommu.c
2015-07-02writeback: don't drain bdi_writeback_congested on bdi destructionTejun Heo
52ebea749aae ("writeback: make backing_dev_info host cgroup-specific bdi_writebacks") made bdi (backing_dev_info) host per-cgroup wb's (bdi_writeback's). As the congested state needs to be per-wb and referenced from blkcg side and multiple wbs, the patch made all non-root cong's (bdi_writeback_congested's) reference counted and indexed on bdi. When a bdi is destroyed, cgwb_bdi_destroy() tries to drain all non-root cong's; however, this can hang indefinitely because wb's can also be referenced from blkcg_gq's which are destroyed after bdi destruction is complete. This patch fixes the bug by updating bdi destruction to not wait for cong's to drain. A cong is unlinked from bdi->cgwb_congested_tree on bdi destuction regardless of its reference count as the bdi may go away any point after destruction. wb_congested_put() checks whether the cong is already unlinked on release. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Jon Christopherson <jon@jons.org> Link: https://bugzilla.kernel.org/show_bug.cgi?id=100681 Fixes: 52ebea749aae ("writeback: make backing_dev_info host cgroup-specific bdi_writebacks") Tested-by: Jon Christopherson <jon@jons.org> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-07-02writeback: don't embed root bdi_writeback_congested in bdi_writebackTejun Heo
52ebea749aae ("writeback: make backing_dev_info host cgroup-specific bdi_writebacks") made bdi (backing_dev_info) host per-cgroup wb's (bdi_writeback's). As the congested state needs to be per-wb and referenced from blkcg side and multiple wbs, the patch made all non-root cong's (bdi_writeback_congested's) reference counted and indexed on bdi. When a bdi is destroyed, cgwb_bdi_destroy() tries to drain all non-root cong's; however, this can hang indefinitely because wb's can also be referenced from blkcg_gq's which are destroyed after bdi destruction is complete. To fix the bug, bdi destruction will be updated to not wait for cong's to drain, which naturally means that cong's may outlive the associated bdi. This is fine for non-root cong's but is problematic for the root cong's which are embedded in their bdi's as they may end up getting dereferenced after the containing bdi's are freed. This patch makes root cong's behave the same as non-root cong's. They are no longer embedded in their bdi's but allocated separately during bdi initialization, indexed and reference counted the same way. * As cong handling is the same for all wb's, wb->congested initialization is moved into wb_init(). * When !CONFIG_CGROUP_WRITEBACK, there was no indexing or refcnting. bdi->wb_congested is now a pointer pointing to the root cong allocated during bdi init and minimal refcnting operations are implemented. * The above makes root wb init paths diverge depending on CONFIG_CGROUP_WRITEBACK. root wb init is moved to cgwb_bdi_init(). This patch in itself shouldn't cause any consequential behavior differences but prepares for the actual fix. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Jon Christopherson <jon@jons.org> Link: https://bugzilla.kernel.org/show_bug.cgi?id=100681 Tested-by: Jon Christopherson <jon@jons.org> Added <linux/slab.h> include to backing-dev.h for kfree() definition. Signed-off-by: Jens Axboe <axboe@fb.com>
2015-07-01Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge third patchbomb from Andrew Morton: - the rest of MM - scripts/gdb updates - ipc/ updates - lib/ updates - MAINTAINERS updates - various other misc things * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (67 commits) genalloc: rename of_get_named_gen_pool() to of_gen_pool_get() genalloc: rename dev_get_gen_pool() to gen_pool_get() x86: opt into HAVE_COPY_THREAD_TLS, for both 32-bit and 64-bit MAINTAINERS: add zpool MAINTAINERS: BCACHE: Kent Overstreet has changed email address MAINTAINERS: move Jens Osterkamp to CREDITS MAINTAINERS: remove unused nbd.h pattern MAINTAINERS: update brcm gpio filename pattern MAINTAINERS: update brcm dts pattern MAINTAINERS: update sound soc intel patterns MAINTAINERS: remove website for paride MAINTAINERS: update Emulex ocrdma email addresses bcache: use kvfree() in various places libcxgbi: use kvfree() in cxgbi_free_big_mem() target: use kvfree() in session alloc and free IB/ehca: use kvfree() in ipz_queue_{cd}tor() drm/nouveau/gem: use kvfree() in u_free() drm: use kvfree() in drm_free_large() cxgb4: use kvfree() in t4_free_mem() cxgb3: use kvfree() in cxgb_free_mem() ...
2015-07-01Add __init attribute to new_kmalloc_cacheChristoph Lameter
Avoid the warning: WARNING: mm/built-in.o(.text.unlikely+0xc22): Section mismatch in reference from the function .new_kmalloc_cache() to the variable .init.rodata:kmalloc_info The function .new_kmalloc_cache() references the variable __initconst kmalloc_info. Signed-off-by: Christoph Lameter <cl@linux.com> Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Tested-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30mm: meminit: finish initialisation of struct pages before basic setupMel Gorman
Waiman Long reported that 24TB machines hit OOM during basic setup when struct page initialisation was deferred. One approach is to initialise memory on demand but it interferes with page allocator paths. This patch creates dedicated threads to initialise memory before basic setup. It then blocks on a rw_semaphore until completion as a wait_queue and counter is overkill. This may be slower to boot but it's simplier overall and also gets rid of a section mangling which existed so kswapd could do the initialisation. [akpm@linux-foundation.org: include rwsem.h, use DECLARE_RWSEM, fix comment, remove unneeded cast] Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Waiman Long <waiman.long@hp.com Cc: Nathan Zimmer <nzimmer@sgi.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Scott Norton <scott.norton@hp.com> Tested-by: Daniel J Blueman <daniel@numascale.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30mm: meminit: remove mminit_verify_page_linksMel Gorman
mminit_verify_page_links() is an extremely paranoid check that was introduced when memory initialisation was being heavily reworked. Profiles indicated that up to 10% of parallel memory initialisation was spent on checking this for every page. The cost could be reduced but in practice this check only found problems very early during the initialisation rewrite and has found nothing since. This patch removes an expensive unnecessary check. Signed-off-by: Mel Gorman <mgorman@suse.de> Tested-by: Nate Zimmer <nzimmer@sgi.com> Tested-by: Waiman Long <waiman.long@hp.com> Tested-by: Daniel J Blueman <daniel@numascale.com> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Robin Holt <robinmholt@gmail.com> Cc: Nate Zimmer <nzimmer@sgi.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Waiman Long <waiman.long@hp.com> Cc: Scott Norton <scott.norton@hp.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30mm: meminit: reduce number of times pageblocks are set during struct page initMel Gorman
During parallel sturct page initialisation, ranges are checked for every PFN unnecessarily which increases boot times. This patch alters when the ranges are checked. Signed-off-by: Mel Gorman <mgorman@suse.de> Tested-by: Nate Zimmer <nzimmer@sgi.com> Tested-by: Waiman Long <waiman.long@hp.com> Tested-by: Daniel J Blueman <daniel@numascale.com> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Robin Holt <robinmholt@gmail.com> Cc: Nate Zimmer <nzimmer@sgi.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Waiman Long <waiman.long@hp.com> Cc: Scott Norton <scott.norton@hp.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30mm: meminit: free pages in large chunks where possibleMel Gorman
Parallel struct page frees pages one at a time. Try free pages as single large pages where possible. Signed-off-by: Mel Gorman <mgorman@suse.de> Tested-by: Nate Zimmer <nzimmer@sgi.com> Tested-by: Waiman Long <waiman.long@hp.com> Tested-by: Daniel J Blueman <daniel@numascale.com> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Robin Holt <robinmholt@gmail.com> Cc: Nate Zimmer <nzimmer@sgi.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Waiman Long <waiman.long@hp.com> Cc: Scott Norton <scott.norton@hp.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30mm: meminit: minimise number of pfn->page lookups during initialisationMel Gorman
Deferred struct page initialisation is using pfn_to_page() on every PFN unnecessarily. This patch minimises the number of lookups and scheduler checks. Signed-off-by: Mel Gorman <mgorman@suse.de> Tested-by: Nate Zimmer <nzimmer@sgi.com> Tested-by: Waiman Long <waiman.long@hp.com> Tested-by: Daniel J Blueman <daniel@numascale.com> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Robin Holt <robinmholt@gmail.com> Cc: Nate Zimmer <nzimmer@sgi.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Waiman Long <waiman.long@hp.com> Cc: Scott Norton <scott.norton@hp.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30mm: meminit: initialise remaining struct pages in parallel with kswapdMel Gorman
Only a subset of struct pages are initialised at the moment. When this patch is applied kswapd initialise the remaining struct pages in parallel. This should boot faster by spreading the work to multiple CPUs and initialising data that is local to the CPU. The user-visible effect on large machines is that free memory will appear to rapidly increase early in the lifetime of the system until kswapd reports that all memory is initialised in the kernel log. Once initialised there should be no other user-visibile effects. Signed-off-by: Mel Gorman <mgorman@suse.de> Tested-by: Nate Zimmer <nzimmer@sgi.com> Tested-by: Waiman Long <waiman.long@hp.com> Tested-by: Daniel J Blueman <daniel@numascale.com> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Robin Holt <robinmholt@gmail.com> Cc: Nate Zimmer <nzimmer@sgi.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Waiman Long <waiman.long@hp.com> Cc: Scott Norton <scott.norton@hp.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30mm: meminit: initialise a subset of struct pages if ↵Mel Gorman
CONFIG_DEFERRED_STRUCT_PAGE_INIT is set This patch initalises all low memory struct pages and 2G of the highest zone on each node during memory initialisation if CONFIG_DEFERRED_STRUCT_PAGE_INIT is set. That config option cannot be set but will be available in a later patch. Parallel initialisation of struct page depends on some features from memory hotplug and it is necessary to alter alter section annotations. Signed-off-by: Mel Gorman <mgorman@suse.de> Tested-by: Nate Zimmer <nzimmer@sgi.com> Tested-by: Waiman Long <waiman.long@hp.com> Tested-by: Daniel J Blueman <daniel@numascale.com> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Robin Holt <robinmholt@gmail.com> Cc: Nate Zimmer <nzimmer@sgi.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Waiman Long <waiman.long@hp.com> Cc: Scott Norton <scott.norton@hp.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30mm: meminit: inline some helper functionsMel Gorman
early_pfn_in_nid() and meminit_pfn_in_nid() are small functions that are unnecessarily visible outside memory initialisation. As well as unnecessary visibility, it's unnecessary function call overhead when initialising pages. This patch moves the helpers inline. [akpm@linux-foundation.org: fix build] [mhocko@suse.cz: fix build] Signed-off-by: Mel Gorman <mgorman@suse.de> Tested-by: Nate Zimmer <nzimmer@sgi.com> Tested-by: Waiman Long <waiman.long@hp.com> Tested-by: Daniel J Blueman <daniel@numascale.com> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Robin Holt <robinmholt@gmail.com> Cc: Nate Zimmer <nzimmer@sgi.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Waiman Long <waiman.long@hp.com> Cc: Scott Norton <scott.norton@hp.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30mm: meminit: make __early_pfn_to_nid SMP-safe and introduce meminit_pfn_in_nidMel Gorman
__early_pfn_to_nid() use static variables to cache recent lookups as memblock lookups are very expensive but it assumes that memory initialisation is single-threaded. Parallel initialisation of struct pages will break that assumption so this patch makes __early_pfn_to_nid() SMP-safe by requiring the caller to cache recent search information. early_pfn_to_nid() keeps the same interface but is only safe to use early in boot due to the use of a global static variable. meminit_pfn_in_nid() is an SMP-safe version that callers must maintain their own state for. Signed-off-by: Mel Gorman <mgorman@suse.de> Tested-by: Nate Zimmer <nzimmer@sgi.com> Tested-by: Waiman Long <waiman.long@hp.com> Tested-by: Daniel J Blueman <daniel@numascale.com> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Robin Holt <robinmholt@gmail.com> Cc: Nate Zimmer <nzimmer@sgi.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Waiman Long <waiman.long@hp.com> Cc: Scott Norton <scott.norton@hp.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30mm: page_alloc: pass PFN to __free_pages_bootmemMel Gorman
__free_pages_bootmem prepares a page for release to the buddy allocator and assumes that the struct page is initialised. Parallel initialisation of struct pages defers initialisation and __free_pages_bootmem can be called for struct pages that cannot yet map struct page to PFN. This patch passes PFN to __free_pages_bootmem with no other functional change. Signed-off-by: Mel Gorman <mgorman@suse.de> Tested-by: Nate Zimmer <nzimmer@sgi.com> Tested-by: Waiman Long <waiman.long@hp.com> Tested-by: Daniel J Blueman <daniel@numascale.com> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Robin Holt <robinmholt@gmail.com> Cc: Nate Zimmer <nzimmer@sgi.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Waiman Long <waiman.long@hp.com> Cc: Scott Norton <scott.norton@hp.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30mm: meminit: only set page reserved in the memblock regionNathan Zimmer
Currently each page struct is set as reserved upon initialization. This patch leaves the reserved bit clear and only sets the reserved bit when it is known the memory was allocated by the bootmem allocator. This makes it easier to distinguish between uninitialised struct pages and reserved struct pages in later patches. Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Nathan Zimmer <nzimmer@sgi.com> Signed-off-by: Mel Gorman <mgorman@suse.de> Tested-by: Nate Zimmer <nzimmer@sgi.com> Tested-by: Waiman Long <waiman.long@hp.com> Tested-by: Daniel J Blueman <daniel@numascale.com> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Robin Holt <robinmholt@gmail.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Waiman Long <waiman.long@hp.com> Cc: Scott Norton <scott.norton@hp.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30mm: meminit: move page initialization into a separate functionRobin Holt
Currently, memmap_init_zone() has all the smarts for initializing a single page. A subset of this is required for parallel page initialisation and so this patch breaks up the monolithic function in preparation. Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Nathan Zimmer <nzimmer@sgi.com> Signed-off-by: Mel Gorman <mgorman@suse.de> Tested-by: Nate Zimmer <nzimmer@sgi.com> Tested-by: Waiman Long <waiman.long@hp.com> Tested-by: Daniel J Blueman <daniel@numascale.com> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Robin Holt <robinmholt@gmail.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Waiman Long <waiman.long@hp.com> Cc: Scott Norton <scott.norton@hp.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30memblock: introduce a for_each_reserved_mem_region iteratorRobin Holt
Struct page initialisation had been identified as one of the reasons why large machines take a long time to boot. Patches were posted a long time ago to defer initialisation until they were first used. This was rejected on the grounds it should not be necessary to hurt the fast paths. This series reuses much of the work from that time but defers the initialisation of memory to kswapd so that one thread per node initialises memory local to that node. After applying the series and setting the appropriate Kconfig variable I see this in the boot log on a 64G machine [ 7.383764] kswapd 0 initialised deferred memory in 188ms [ 7.404253] kswapd 1 initialised deferred memory in 208ms [ 7.411044] kswapd 3 initialised deferred memory in 216ms [ 7.411551] kswapd 2 initialised deferred memory in 216ms On a 1TB machine, I see [ 8.406511] kswapd 3 initialised deferred memory in 1116ms [ 8.428518] kswapd 1 initialised deferred memory in 1140ms [ 8.435977] kswapd 0 initialised deferred memory in 1148ms [ 8.437416] kswapd 2 initialised deferred memory in 1148ms Once booted the machine appears to work as normal. Boot times were measured from the time shutdown was called until ssh was available again. In the 64G case, the boot time savings are negligible. On the 1TB machine, the savings were 16 seconds. Nate Zimmer said: : On an older 8 TB box with lots and lots of cpus the boot time, as : measure from grub to login prompt, the boot time improved from 1484 : seconds to exactly 1000 seconds. Waiman Long said: : I ran a bootup timing test on a 12-TB 16-socket IvyBridge-EX system. From : grub menu to ssh login, the bootup time was 453s before the patch and 265s : after the patch - a saving of 188s (42%). Daniel Blueman said: : On a 7TB, 1728-core NumaConnect system with 108 NUMA nodes, we're seeing : stock 4.0 boot in 7136s. This drops to 2159s, or a 70% reduction with : this patchset. Non-temporal PMD init (https://lkml.org/lkml/2015/4/23/350) : drops this to 1045s. This patch (of 13): As part of initializing struct page's in 2MiB chunks, we noticed that at the end of free_all_bootmem(), there was nothing which had forced the reserved/allocated 4KiB pages to be initialized. This helper function will be used for that expansion. Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Nate Zimmer <nzimmer@sgi.com> Signed-off-by: Mel Gorman <mgorman@suse.de> Tested-by: Nate Zimmer <nzimmer@sgi.com> Tested-by: Waiman Long <waiman.long@hp.com> Tested-by: Daniel J Blueman <daniel@numascale.com> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Robin Holt <robinmholt@gmail.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Waiman Long <waiman.long@hp.com> Cc: Scott Norton <scott.norton@hp.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-29Fix kmalloc slab creation sequenceChristoph Lameter
This patch restores the slab creation sequence that was broken by commit 4066c33d0308f8 and also reverts the portions that introduced the KMALLOC_LOOP_XXX macros. Those can never really work since the slab creation is much more complex than just going from a minimum to a maximum number. The latest upstream kernel boots cleanly on my machine with a 64 bit x86 configuration under KVM using either SLAB or SLUB. Fixes: 4066c33d0308f8 ("support the slub_debug boot option") Reported-by: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-26Merge tag 'trace-v4.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing updates from Steven Rostedt: "This patch series contains several clean ups and even a new trace clock "monitonic raw". Also some enhancements to make the ring buffer even faster. But the biggest and most noticeable change is the renaming of the ftrace* files, structures and variables that have to deal with trace events. Over the years I've had several developers tell me about their confusion with what ftrace is compared to events. Technically, "ftrace" is the infrastructure to do the function hooks, which include tracing and also helps with live kernel patching. But the trace events are a separate entity altogether, and the files that affect the trace events should not be named "ftrace". These include: include/trace/ftrace.h -> include/trace/trace_events.h include/linux/ftrace_event.h -> include/linux/trace_events.h Also, functions that are specific for trace events have also been renamed: ftrace_print_*() -> trace_print_*() (un)register_ftrace_event() -> (un)register_trace_event() ftrace_event_name() -> trace_event_name() ftrace_trigger_soft_disabled() -> trace_trigger_soft_disabled() ftrace_define_fields_##call() -> trace_define_fields_##call() ftrace_get_offsets_##call() -> trace_get_offsets_##call() Structures have been renamed: ftrace_event_file -> trace_event_file ftrace_event_{call,class} -> trace_event_{call,class} ftrace_event_buffer -> trace_event_buffer ftrace_subsystem_dir -> trace_subsystem_dir ftrace_event_raw_##call -> trace_event_raw_##call ftrace_event_data_offset_##call-> trace_event_data_offset_##call ftrace_event_type_funcs_##call -> trace_event_type_funcs_##call And a few various variables and flags have also been updated. This has been sitting in linux-next for some time, and I have not heard a single complaint about this rename breaking anything. Mostly because these functions, variables and structures are mostly internal to the tracing system and are seldom (if ever) used by anything external to that" * tag 'trace-v4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: (33 commits) ring_buffer: Allow to exit the ring buffer benchmark immediately ring-buffer-benchmark: Fix the wrong type ring-buffer-benchmark: Fix the wrong param in module_param ring-buffer: Add enum names for the context levels ring-buffer: Remove useless unused tracing_off_permanent() ring-buffer: Give NMIs a chance to lock the reader_lock ring-buffer: Add trace_recursive checks to ring_buffer_write() ring-buffer: Allways do the trace_recursive checks ring-buffer: Move recursive check to per_cpu descriptor ring-buffer: Add unlikelys to make fast path the default tracing: Rename ftrace_get_offsets_##call() to trace_event_get_offsets_##call() tracing: Rename ftrace_define_fields_##call() to trace_event_define_fields_##call() tracing: Rename ftrace_event_type_funcs_##call to trace_event_type_funcs_##call tracing: Rename ftrace_data_offset_##call to trace_event_data_offset_##call tracing: Rename ftrace_raw_##call event structures to trace_event_raw_##call tracing: Rename ftrace_trigger_soft_disabled() to trace_trigger_soft_disabled() tracing: Rename FTRACE_EVENT_FL_* flags to EVENT_FILE_FL_* tracing: Rename struct ftrace_subsystem_dir to trace_subsystem_dir tracing: Rename ftrace_event_name() to trace_event_name() tracing: Rename FTRACE_MAX_EVENT to TRACE_EVENT_TYPE_MAX ...
2015-06-26Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge second patchbomb from Andrew Morton: - most of the rest of MM - lots of misc things - procfs updates - printk feature work - updates to get_maintainer, MAINTAINERS, checkpatch - lib/ updates * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (96 commits) exit,stats: /* obey this comment */ coredump: add __printf attribute to cn_*printf functions coredump: use from_kuid/kgid when formatting corename fs/reiserfs: remove unneeded cast NILFS2: support NFSv2 export fs/befs/btree.c: remove unneeded initializations fs/minix: remove unneeded cast init/do_mounts.c: add create_dev() failure log kasan: remove duplicate definition of the macro KASAN_FREE_PAGE fs/efs: femove unneeded cast checkpatch: emit "NOTE: <types>" message only once after multiple files checkpatch: emit an error when there's a diff in a changelog checkpatch: validate MODULE_LICENSE content checkpatch: add multi-line handling for PREFER_ETHER_ADDR_COPY checkpatch: suggest using eth_zero_addr() and eth_broadcast_addr() checkpatch: fix processing of MEMSET issues checkpatch: suggest using ether_addr_equal*() checkpatch: avoid NOT_UNIFIED_DIFF errors on cover-letter.patch files checkpatch: remove local from codespell path checkpatch: add --showfile to allow input via pipe to show filenames ...
2015-06-25kasan: remove duplicate definition of the macro KASAN_FREE_PAGEWang Long
Remove duplicate definition of the macro KASAN_FREE_PAGE in mm/kasan/kasan.h Signed-off-by: Wang Long <long.wanglong@huawei.com> Acked-by: Andrey Ryabinin <a.ryabinin@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-25zpool: remove zpool_evict()Dan Streetman
Remove zpool_evict() helper function. As zbud is currently the only zpool implementation that supports eviction, add zpool and zpool_ops references to struct zbud_pool and directly call zpool_ops->evict(zpool, handle) on eviction. Currently zpool provides the zpool_evict helper which locks the zpool list lock and searches through all pools to find the specific one matching the caller, and call the corresponding zpool_ops->evict function. However, this is unnecessary, as the zbud pool can simply keep a reference to the zpool that created it, as well as the zpool_ops, and directly call the zpool_ops->evict function, when it needs to evict a page. This avoids a spinlock and list search in zpool for each eviction. Signed-off-by: Dan Streetman <ddstreet@ieee.org> Cc: Seth Jennings <sjennings@variantweb.net> Cc: Minchan Kim <minchan@kernel.org> Cc: Nitin Gupta <ngupta@vflare.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-25zpool: change pr_info to pr_debugDan Streetman
Change the pr_info() calls to pr_debug(). There's no need for the extra verbosity in the log. Also change the msg formats to be consistent. Signed-off-by: Dan Streetman <ddstreet@ieee.org> Cc: Kees Cook <keescook@chromium.org> Cc: Minchan Kim <minchan@kernel.org> Cc: Ganesh Mahendran <opensource.ganesh@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-25zswap: runtime enable/disableDan Streetman
Change the "enabled" parameter to be configurable at runtime. Remove the enabled check from init(), and move it to the frontswap store() function; when enabled, pages will be stored, and when disabled, pages won't be stored. This is almost identical to Seth's patch from 2 years ago: http://lkml.iu.edu/hypermail/linux/kernel/1307.2/04289.html [akpm@linux-foundation.org: tweak documentation] Signed-off-by: Dan Streetman <ddstreet@ieee.org> Suggested-by: Seth Jennings <sjennings@variantweb.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-25zsmalloc: remove obsolete ZSMALLOC_DEBUGMarcin Jabrzyk
The DEBUG define in zsmalloc is useless, there is no usage of it at all. Signed-off-by: Marcin Jabrzyk <m.jabrzyk@samsung.com> Acked-by: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Nitin Gupta <ngupta@vflare.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-25mm/hugetlb: remove unused arch hook prepare/release_hugepageDominik Dingel
With s390 dropping support for emulated hugepages, the last user of arch_prepare_hugepage and arch_release_hugepage is gone. Signed-off-by: Dominik Dingel <dingel@linux.vnet.ibm.com> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-25Merge branch 'for-4.2/writeback' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull cgroup writeback support from Jens Axboe: "This is the big pull request for adding cgroup writeback support. This code has been in development for a long time, and it has been simmering in for-next for a good chunk of this cycle too. This is one of those problems that has been talked about for at least half a decade, finally there's a solution and code to go with it. Also see last weeks writeup on LWN: http://lwn.net/Articles/648292/" * 'for-4.2/writeback' of git://git.kernel.dk/linux-block: (85 commits) writeback, blkio: add documentation for cgroup writeback support vfs, writeback: replace FS_CGROUP_WRITEBACK with SB_I_CGROUPWB writeback: do foreign inode detection iff cgroup writeback is enabled v9fs: fix error handling in v9fs_session_init() bdi: fix wrong error return value in cgwb_create() buffer: remove unusued 'ret' variable writeback: disassociate inodes from dying bdi_writebacks writeback: implement foreign cgroup inode bdi_writeback switching writeback: add lockdep annotation to inode_to_wb() writeback: use unlocked_inode_to_wb transaction in inode_congested() writeback: implement unlocked_inode_to_wb transaction and use it for stat updates writeback: implement [locked_]inode_to_wb_and_lock_list() writeback: implement foreign cgroup inode detection writeback: make writeback_control track the inode being written back writeback: relocate wb[_try]_get(), wb_put(), inode_{attach|detach}_wb() mm: vmscan: disable memcg direct reclaim stalling if cgroup writeback support is in use writeback: implement memcg writeback domain based throttling writeback: reset wb_domain->dirty_limit[_tstmp] when memcg domain size changes writeback: implement memcg wb_domain writeback: update wb_over_bg_thresh() to use wb_domain aware operations ...
2015-06-25Merge branch 'for-4.2/core' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull core block IO update from Jens Axboe: "Nothing really major in here, mostly a collection of smaller optimizations and cleanups, mixed with various fixes. In more detail, this contains: - Addition of policy specific data to blkcg for block cgroups. From Arianna Avanzini. - Various cleanups around command types from Christoph. - Cleanup of the suspend block I/O path from Christoph. - Plugging updates from Shaohua and Jeff Moyer, for blk-mq. - Eliminating atomic inc/dec of both remaining IO count and reference count in a bio. From me. - Fixes for SG gap and chunk size support for data-less (discards) IO, so we can merge these better. From me. - Small restructuring of blk-mq shared tag support, freeing drivers from iterating hardware queues. From Keith Busch. - A few cfq-iosched tweaks, from Tahsin Erdogan and me. Makes the IOPS mode the default for non-rotational storage" * 'for-4.2/core' of git://git.kernel.dk/linux-block: (35 commits) cfq-iosched: fix other locations where blkcg_to_cfqgd() can return NULL cfq-iosched: fix sysfs oops when attempting to read unconfigured weights cfq-iosched: move group scheduling functions under ifdef cfq-iosched: fix the setting of IOPS mode on SSDs blktrace: Add blktrace.c to BLOCK LAYER in MAINTAINERS file block, cgroup: implement policy-specific per-blkcg data block: Make CFQ default to IOPS mode on SSDs block: add blk_set_queue_dying() to blkdev.h blk-mq: Shared tag enhancements block: don't honor chunk sizes for data-less IO block: only honor SG gap prevention for merges that contain data block: fix returnvar.cocci warnings block, dm: don't copy bios for request clones block: remove management of bi_remaining when restoring original bi_end_io block: replace trylock with mutex_lock in blkdev_reread_part() block: export blkdev_reread_part() and __blkdev_reread_part() suspend: simplify block I/O handling block: collapse bio bit space block: remove unused BIO_RW_BLOCK and BIO_EOF flags block: remove BIO_EOPNOTSUPP ...
2015-06-24Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge first patchbomb from Andrew Morton: - a few misc things - ocfs2 udpates - kernel/watchdog.c feature work (took ages to get right) - most of MM. A few tricky bits are held up and probably won't make 4.2. * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (91 commits) mm: kmemleak_alloc_percpu() should follow the gfp from per_alloc() mm, thp: respect MPOL_PREFERRED policy with non-local node tmpfs: truncate prealloc blocks past i_size mm/memory hotplug: print the last vmemmap region at the end of hot add memory mm/mmap.c: optimization of do_mmap_pgoff function mm: kmemleak: optimise kmemleak_lock acquiring during kmemleak_scan mm: kmemleak: avoid deadlock on the kmemleak object insertion error path mm: kmemleak: do not acquire scan_mutex in kmemleak_do_cleanup() mm: kmemleak: fix delete_object_*() race when called on the same memory block mm: kmemleak: allow safe memory scanning during kmemleak disabling memcg: convert mem_cgroup->under_oom from atomic_t to int memcg: remove unused mem_cgroup->oom_wakeups frontswap: allow multiple backends x86, mirror: x86 enabling - find mirrored memory ranges mm/memblock: allocate boot time data structures from mirrored memory mm/memblock: add extra "flags" to memblock to allow selection of memory based on attribute mm: do not ignore mapping_gfp_mask in page cache allocation paths mm/cma.c: fix typos in comments mm/oom_kill.c: print points as unsigned int mm/hugetlb: handle races in alloc_huge_page and hugetlb_reserve_pages ...
2015-06-24mm: kmemleak_alloc_percpu() should follow the gfp from per_alloc()Larry Finger
Beginning at commit d52d3997f843 ("ipv6: Create percpu rt6_info"), the following INFO splat is logged: =============================== [ INFO: suspicious RCU usage. ] 4.1.0-rc7-next-20150612 #1 Not tainted ------------------------------- kernel/sched/core.c:7318 Illegal context switch in RCU-bh read-side critical section! other info that might help us debug this: rcu_scheduler_active = 1, debug_locks = 0 3 locks held by systemd/1: #0: (rtnl_mutex){+.+.+.}, at: [<ffffffff815f0c8f>] rtnetlink_rcv+0x1f/0x40 #1: (rcu_read_lock_bh){......}, at: [<ffffffff816a34e2>] ipv6_add_addr+0x62/0x540 #2: (addrconf_hash_lock){+...+.}, at: [<ffffffff816a3604>] ipv6_add_addr+0x184/0x540 stack backtrace: CPU: 0 PID: 1 Comm: systemd Not tainted 4.1.0-rc7-next-20150612 #1 Hardware name: TOSHIBA TECRA A50-A/TECRA A50-A, BIOS Version 4.20 04/17/2014 Call Trace: dump_stack+0x4c/0x6e lockdep_rcu_suspicious+0xe7/0x120 ___might_sleep+0x1d5/0x1f0 __might_sleep+0x4d/0x90 kmem_cache_alloc+0x47/0x250 create_object+0x39/0x2e0 kmemleak_alloc_percpu+0x61/0xe0 pcpu_alloc+0x370/0x630 Additional backtrace lines are truncated. In addition, the above splat is followed by several "BUG: sleeping function called from invalid context at mm/slub.c:1268" outputs. As suggested by Martin KaFai Lau, these are the clue to the fix. Routine kmemleak_alloc_percpu() always uses GFP_KERNEL for its allocations, whereas it should follow the gfp from its callers. Reviewed-by: Catalin Marinas <catalin.marinas@arm.com> Reviewed-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Acked-by: Martin KaFai Lau <kafai@fb.com> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Martin KaFai Lau <kafai@fb.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Tejun Heo <tj@kernel.org> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: <stable@vger.kernel.org> [3.18+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-24mm, thp: respect MPOL_PREFERRED policy with non-local nodeVlastimil Babka
Since commit 077fcf116c8c ("mm/thp: allocate transparent hugepages on local node"), we handle THP allocations on page fault in a special way - for non-interleave memory policies, the allocation is only attempted on the node local to the current CPU, if the policy's nodemask allows the node. This is motivated by the assumption that THP benefits cannot offset the cost of remote accesses, so it's better to fallback to base pages on the local node (which might still be available, while huge pages are not due to fragmentation) than to allocate huge pages on a remote node. The nodemask check prevents us from violating e.g. MPOL_BIND policies where the local node is not among the allowed nodes. However, the current implementation can still give surprising results for the MPOL_PREFERRED policy when the preferred node is different than the current CPU's local node. In such case we should honor the preferred node and not use the local node, which is what this patch does. If hugepage allocation on the preferred node fails, we fall back to base pages and don't try other nodes, with the same motivation as is done for the local node hugepage allocations. The patch also moves the MPOL_INTERLEAVE check around to simplify the hugepage specific test. The difference can be demonstrated using in-tree transhuge-stress test on the following 2-node machine where half memory on one node was occupied to show the difference. > numactl --hardware available: 2 nodes (0-1) node 0 cpus: 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 32 33 34 35 node 0 size: 7878 MB node 0 free: 3623 MB node 1 cpus: 12 13 14 15 16 17 18 19 20 21 22 23 36 37 38 39 40 41 42 43 44 45 46 47 node 1 size: 8045 MB node 1 free: 7818 MB node distances: node 0 1 0: 10 21 1: 21 10 Before the patch: > numactl -p0 -C0 ./transhuge-stress transhuge-stress: 2.197 s/loop, 0.276 ms/page, 7249.168 MiB/s 7962 succeed, 0 failed, 1786 different pages > numactl -p0 -C12 ./transhuge-stress transhuge-stress: 2.962 s/loop, 0.372 ms/page, 5376.172 MiB/s 7962 succeed, 0 failed, 3873 different pages Number of successful THP allocations corresponds to free memory on node 0 in the first case and node 1 in the second case, i.e. -p parameter is ignored and cpu binding "wins". After the patch: > numactl -p0 -C0 ./transhuge-stress transhuge-stress: 2.183 s/loop, 0.274 ms/page, 7295.516 MiB/s 7962 succeed, 0 failed, 1760 different pages > numactl -p0 -C12 ./transhuge-stress transhuge-stress: 2.878 s/loop, 0.361 ms/page, 5533.638 MiB/s 7962 succeed, 0 failed, 1750 different pages > numactl -p1 -C0 ./transhuge-stress transhuge-stress: 4.628 s/loop, 0.581 ms/page, 3440.893 MiB/s 7962 succeed, 0 failed, 3918 different pages The -p parameter is respected regardless of cpu binding. > numactl -C0 ./transhuge-stress transhuge-stress: 2.202 s/loop, 0.277 ms/page, 7230.003 MiB/s 7962 succeed, 0 failed, 1750 different pages > numactl -C12 ./transhuge-stress transhuge-stress: 3.020 s/loop, 0.379 ms/page, 5273.324 MiB/s 7962 succeed, 0 failed, 3916 different pages Without -p parameter, hugepage restriction to CPU-local node works as before. Fixes: 077fcf116c8c ("mm/thp: allocate transparent hugepages on local node") Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Acked-by: David Rientjes <rientjes@google.com> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: <stable@vger.kernel.org> [4.0+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-24tmpfs: truncate prealloc blocks past i_sizeJosef Bacik
One of the rocksdb people noticed that when you do something like this fallocate(fd, FALLOC_FL_KEEP_SIZE, 0, 10M) pwrite(fd, buf, 5M, 0) ftruncate(5M) on tmpfs, the file would still take up 10M: which led to super fun issues because we were getting ENOSPC before we thought we should be getting ENOSPC. This patch fixes the problem, and mirrors what all the other fs'es do (and was agreed to be the correct behaviour at LSF). I tested it locally to make sure it worked properly with the following xfs_io -f -c "falloc -k 0 10M" -c "pwrite 0 5M" -c "truncate 5M" file Without the patch we have "Blocks: 20480", with the patch we have the correct value of "Blocks: 10240". Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-24mm/memory hotplug: print the last vmemmap region at the end of hot add memoryZhu Guihua
When hot add two nodes continuously, we found the vmemmap region info is a bit messed. The last region of node 2 is printed when node 3 hot added, like the following: Initmem setup node 2 [mem 0x0000000000000000-0xffffffffffffffff] On node 2 totalpages: 0 Built 2 zonelists in Node order, mobility grouping on. Total pages: 16090539 Policy zone: Normal init_memory_mapping: [mem 0x40000000000-0x407ffffffff] [mem 0x40000000000-0x407ffffffff] page 1G [ffffea1000000000-ffffea10001fffff] PMD -> [ffff8a077d800000-ffff8a077d9fffff] on node 2 [ffffea1000200000-ffffea10003fffff] PMD -> [ffff8a077de00000-ffff8a077dffffff] on node 2 ... [ffffea101f600000-ffffea101f9fffff] PMD -> [ffff8a074ac00000-ffff8a074affffff] on node 2 [ffffea101fa00000-ffffea101fdfffff] PMD -> [ffff8a074a800000-ffff8a074abfffff] on node 2 Initmem setup node 3 [mem 0x0000000000000000-0xffffffffffffffff] On node 3 totalpages: 0 Built 3 zonelists in Node order, mobility grouping on. Total pages: 16090539 Policy zone: Normal init_memory_mapping: [mem 0x60000000000-0x607ffffffff] [mem 0x60000000000-0x607ffffffff] page 1G [ffffea101fe00000-ffffea101fffffff] PMD -> [ffff8a074a400000-ffff8a074a5fffff] on node 2 <=== node 2 ??? [ffffea1800000000-ffffea18001fffff] PMD -> [ffff8a074a600000-ffff8a074a7fffff] on node 3 [ffffea1800200000-ffffea18005fffff] PMD -> [ffff8a074a000000-ffff8a074a3fffff] on node 3 [ffffea1800600000-ffffea18009fffff] PMD -> [ffff8a0749c00000-ffff8a0749ffffff] on node 3 ... The cause is the last region was missed at the and of hot add memory, and p_start, p_end, node_start were not reset, so when hot add memory to a new node, it will consider they are not contiguous blocks and print the previous one. So we print the last vmemmap region at the end of hot add memory to avoid the confusion. Signed-off-by: Zhu Guihua <zhugh.fnst@cn.fujitsu.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-24mm/mmap.c: optimization of do_mmap_pgoff functionPiotr Kwapulinski
The simple check for zero length memory mapping may be performed earlier. So that in case of zero length memory mapping some unnecessary code is not executed at all. It does not make the code less readable and saves some CPU cycles. Signed-off-by: Piotr Kwapulinski <kwapulinski.piotr@gmail.com> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-24mm: kmemleak: optimise kmemleak_lock acquiring during kmemleak_scanCatalin Marinas
The kmemleak memory scanning uses finer grained object->lock spinlocks primarily to avoid races with the memory block freeing. However, the pointer lookup in the rb tree requires the kmemleak_lock to be held. This is currently done in the find_and_get_object() function for each pointer-like location read during scanning. While this allows a low latency on kmemleak_*() callbacks on other CPUs, the memory scanning is slower. This patch moves the kmemleak_lock outside the scan_block() loop, acquiring/releasing it only once per scanned memory block. The allow_resched logic is moved outside scan_block() and a new scan_large_block() function is implemented which splits large blocks in MAX_SCAN_SIZE chunks with cond_resched() calls in-between. A redundant (object->flags & OBJECT_NO_SCAN) check is also removed from scan_object(). With this patch, the kmemleak scanning performance is significantly improved: at least 50% with lock debugging disabled and over an order of magnitude with lock proving enabled (on an arm64 system). Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-24mm: kmemleak: avoid deadlock on the kmemleak object insertion error pathCatalin Marinas
While very unlikely (usually kmemleak or sl*b bug), the create_object() function in mm/kmemleak.c may fail to insert a newly allocated object into the rb tree. When this happens, kmemleak disables itself and prints additional information about the object already found in the rb tree. Such printing is done with the parent->lock acquired, however the kmemleak_lock is already held. This is a potential race with the scanning thread which acquires object->lock and kmemleak_lock in a This patch removes the locking around the 'parent' object information printing. Such object cannot be freed or removed from object_tree_root and object_list since kmemleak_lock is already held. There is a very small risk that some of the object data is being modified on another CPU but the only downside is inconsistent information printing. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-24mm: kmemleak: do not acquire scan_mutex in kmemleak_do_cleanup()Catalin Marinas
The kmemleak_do_cleanup() work thread already waits for the kmemleak_scan thread to finish via kthread_stop(). Waiting in kthread_stop() while scan_mutex is held may lead to deadlock if kmemleak_scan_thread() also waits to acquire for scan_mutex. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-24mm: kmemleak: fix delete_object_*() race when called on the same memory blockCatalin Marinas
Calling delete_object_*() on the same pointer is not a standard use case (unless there is a bug in the code calling kmemleak_free()). However, during kmemleak disabling (error or user triggered via /sys), there is a potential race between kmemleak_free() calls on a CPU and __kmemleak_do_cleanup() on a different CPU. The current delete_object_*() implementation first performs a look-up holding kmemleak_lock, increments the object->use_count and then re-acquires kmemleak_lock to remove the object from object_tree_root and object_list. This patch simplifies the delete_object_*() mechanism to both look up and remove an object from the object_tree_root and object_list atomically (guarded by kmemleak_lock). This allows safe concurrent calls to delete_object_*() on the same pointer without additional locking for synchronising the kmemleak_free_enabled flag. A side effect is a slight improvement in the delete_object_*() performance by avoiding acquiring kmemleak_lock twice and incrementing/decrementing object->use_count. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-24mm: kmemleak: allow safe memory scanning during kmemleak disablingCatalin Marinas
The kmemleak scanning thread can run for minutes. Callbacks like kmemleak_free() are allowed during this time, the race being taken care of by the object->lock spinlock. Such lock also prevents a memory block from being freed or unmapped while it is being scanned by blocking the kmemleak_free() -> ... -> __delete_object() function until the lock is released in scan_object(). When a kmemleak error occurs (e.g. it fails to allocate its metadata), kmemleak_enabled is set and __delete_object() is no longer called on freed objects. If kmemleak_scan is running at the same time, kmemleak_free() no longer waits for the object scanning to complete, allowing the corresponding memory block to be freed or unmapped (in the case of vfree()). This leads to kmemleak_scan potentially triggering a page fault. This patch separates the kmemleak_free() enabling/disabling from the overall kmemleak_enabled nob so that we can defer the disabling of the object freeing tracking until the scanning thread completed. The kmemleak_free_part() is deliberately ignored by this patch since this is only called during boot before the scanning thread started. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Reported-by: Vignesh Radhakrishnan <vigneshr@codeaurora.org> Tested-by: Vignesh Radhakrishnan <vigneshr@codeaurora.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-24memcg: convert mem_cgroup->under_oom from atomic_t to intTejun Heo
memcg->under_oom tracks whether the memcg is under OOM conditions and is an atomic_t counter managed with mem_cgroup_[un]mark_under_oom(). While atomic_t appears to be simple synchronization-wise, when used as a synchronization construct like here, it's trickier and more error-prone due to weak memory ordering rules, especially around atomic_read(), and false sense of security. For example, both non-trivial read sites of memcg->under_oom are a bit problematic although not being actually broken. * mem_cgroup_oom_register_event() It isn't explicit what guarantees the memory ordering between event addition and memcg->under_oom check. This isn't broken only because memcg_oom_lock is used for both event list and memcg->oom_lock. * memcg_oom_recover() The lockless test doesn't have any explanation why this would be safe. mem_cgroup_[un]mark_under_oom() are very cold paths and there's no point in avoiding locking memcg_oom_lock there. This patch converts memcg->under_oom from atomic_t to int, puts their modifications under memcg_oom_lock and documents why the lockless test in memcg_oom_recover() is safe. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-24memcg: remove unused mem_cgroup->oom_wakeupsTejun Heo
Since commit 4942642080ea ("mm: memcg: handle non-error OOM situations more gracefully"), nobody uses mem_cgroup->oom_wakeups. Remove it. While at it, also fold memcg_wakeup_oom() into memcg_oom_recover() which is its only user. This cleanup was suggested by Michal. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
