commit 7810e6781e0fcbca78b91cf65053f895bf59e85f upstream.
In __alloc_pages_slowpath() we reset zonelist and preferred_zoneref for
allocations that can ignore memory policies. The zonelist is obtained
from current CPU's node. This is a problem for __GFP_THISNODE
allocations that want to allocate on a different node, e.g. because the
allocating thread has been migrated to a different CPU.
This has been observed to break SLAB in our 4.4-based kernel, because
there it relies on __GFP_THISNODE working as intended. If a slab page
is put on wrong node's list, then further list manipulations may corrupt
the list because page_to_nid() is used to determine which node's
list_lock should be locked and thus we may take a wrong lock and race.
Current SLAB implementation seems to be immune by luck thanks to commit
511e3a058812 ("mm/slab: make cache_grow() handle the page allocated on
arbitrary node") but there may be others assuming that __GFP_THISNODE
works as promised.
We can fix it by simply removing the zonelist reset completely. There
is actually no reason to reset it, because memory policies and cpusets
don't affect the zonelist choice in the first place. This was different
when commit 183f6371aac2 ("mm: ignore mempolicies when using
ALLOC_NO_WATERMARK") introduced the code, as mempolicies provided their
own restricted zonelists.
We might consider this for 4.17 although I don't know if there's
anything currently broken.
SLAB is currently not affected, but in kernels older than 4.7 that don't
yet have 511e3a058812 ("mm/slab: make cache_grow() handle the page
allocated on arbitrary node") it is. That's at least 4.4 LTS. Older
ones I'll have to check.
So stable backports should be more important, but will have to be
reviewed carefully, as the code went through many changes. BTW I think
that also the ac->preferred_zoneref reset is currently useless if we
don't also reset ac->nodemask from a mempolicy to NULL first (which we
probably should for the OOM victims etc?), but I would leave that for a
separate patch.
Link: http://lkml.kernel.org/r/20180525130853.13915-1-vbabka@suse.cz
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
Fixes: 183f6371aac2 ("mm: ignore mempolicies when using ALLOC_NO_WATERMARK")
Acked-by: Mel Gorman <mgorman@techsingularity.net>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: <stable@vger.kernel.org>
commit 520495fe96d74e05db585fc748351e0504d8f40d upstream.
When booting with very large numbers of gigantic (i.e. 1G) pages, the
operations in the loop of gather_bootmem_prealloc, and specifically
prep_compound_gigantic_page, takes a very long time, and can cause a
softlockup if enough pages are requested at boot.
For example booting with 3844 1G pages requires prepping
(set_compound_head, init the count) over 1 billion 4K tail pages, which
takes considerable time.
Add a cond_resched() to the outer loop in gather_bootmem_prealloc() to
prevent this lockup.
Tested: Booted with softlockup_panic=1 hugepagesz=1G hugepages=3844 and
no softlockup is reported, and the hugepages are reported as
successfully setup.
Link: http://lkml.kernel.org/r/20180627214447.260804-1-cannonmatthews@google.com
Signed-off-by: Cannon Matthews <cannonmatthews@google.com>
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
Reviewed-by: Mike Kravetz <mike.kravetz@oracle.com>
Cc: Andres Lagar-Cavilla <andreslc@google.com>
Cc: Peter Feiner <pfeiner@google.com>
commit 423913ad4ae5b3e8fb8983f70969fb522261ba26 upstream.
Commit be83bbf80682 ("mmap: introduce sane default mmap limits") was
introduced to catch problems in various ad-hoc character device drivers
doing mmap and getting the size limits wrong. In the process, it used
"known good" limits for the normal cases of mapping regular files and
block device drivers.
It turns out that the "s_maxbytes" limit was less "known good" than I
thought. In particular, /proc doesn't set it, but exposes one regular
file to mmap: /proc/vmcore. As a result, that file got limited to the
default MAX_INT s_maxbytes value.
This went unnoticed for a while, because apparently the only thing that
needs it is the s390 kernel zfcpdump, but there might be other tools
that use this too.
Vasily suggested just changing s_maxbytes for all of /proc, which isn't
wrong, but makes me nervous at this stage. So instead, just make the
new mmap limit always be MAX_LFS_FILESIZE for regular files, which won't
affect anything else. It wasn't the regular file case I was worried
about.
I'd really prefer for maxsize to have been per-inode, but that is not
how things are today.
Fixes: be83bbf80682 ("mmap: introduce sane default mmap limits")
Reported-by: Vasily Gorbik <gor@linux.ibm.com>
commit be83bbf806822b1b89e0a0f23cd87cddc409e429 upstream.
The internal VM "mmap()" interfaces are based on the mmap target doing
everything using page indexes rather than byte offsets, because
traditionally (ie 32-bit) we had the situation that the byte offset
didn't fit in a register. So while the mmap virtual address was limited
by the word size of the architecture, the backing store was not.
So we're basically passing "pgoff" around as a page index, in order to
be able to describe backing store locations that are much bigger than
the word size (think files larger than 4GB etc).
But while this all makes a ton of sense conceptually, we've been dogged
by various drivers that don't really understand this, and internally
work with byte offsets, and then try to work with the page index by
turning it into a byte offset with "pgoff << PAGE_SHIFT".
Which obviously can overflow.
Adding the size of the mapping to it to get the byte offset of the end
of the backing store just exacerbates the problem, and if you then use
this overflow-prone value to check various limits of your device driver
mmap capability, you're just setting yourself up for problems.
The correct thing for drivers to do is to do their limit math in page
indices, the way the interface is designed. Because the generic mmap
code _does_ test that the index doesn't overflow, since that's what the
mmap code really cares about.
HOWEVER.
Finding and fixing various random drivers is a sisyphean task, so let's
just see if we can just make the core mmap() code do the limiting for
us. Realistically, the only "big" backing stores we need to care about
are regular files and block devices, both of which are known to do this
properly, and which have nice well-defined limits for how much data they
can access.
So let's special-case just those two known cases, and then limit other
random mmap users to a backing store that still fits in "unsigned long".
Realistically, that's not much of a limit at all on 64-bit, and on
32-bit architectures the only worry might be the GPU drivers, which can
have big physical address spaces.
To make it possible for drivers like that to say that they are 64-bit
clean, this patch does repurpose the "FMODE_UNSIGNED_OFFSET" bit in the
file flags to allow drivers to mark their file descriptors as safe in
the full 64-bit mmap address space.
[ The timing for doing this is less than optimal, and this should really
go in a merge window. But realistically, this needs wide testing more
than it needs anything else, and being main-line is the only way to do
that.
So the earlier the better, even if it's outside the proper development
cycle - Linus ]
Cc: Dan Carpenter <dan.carpenter@oracle.com>
Cc: Willy Tarreau <w@1wt.eu>
Cc: Dave Airlie <airlied@redhat.com>
commit 145e1a71e090575c74969e3daa8136d1e5b99fc8 upstream.
George Boole would have noticed a slight error in 4.16 commit
69d763fc6d3a ("mm: pin address_space before dereferencing it while
isolating an LRU page"). Fix it, to match both the comment above it,
and the original behaviour.
Although anonymous pages are not marked PageDirty at first, we have an
old habit of calling SetPageDirty when a page is removed from swap
cache: so there's a category of ex-swap pages that are easily
migratable, but were inadvertently excluded from compaction's async
migration in 4.16.
Link: http://lkml.kernel.org/r/alpine.LSU.2.11.1805302014001.12558@eggly.anvils
Fixes: 69d763fc6d3a ("mm: pin address_space before dereferencing it while isolating an LRU page")
Acked-by: Minchan Kim <minchan@kernel.org>
Reported-by: Ivan Kalvachev <ikalvachev@gmail.com>
Cc: "Huang, Ying" <ying.huang@intel.com>
Cc: Jan Kara <jack@suse.cz>
[ Upstream commit e92bb4dd9673945179b1fc738c9817dd91bfb629 ]
When page_mapping() is called and the mapping is dereferenced in
page_evicatable() through shrink_active_list(), it is possible for the
inode to be truncated and the embedded address space to be freed at the
same time. This may lead to the following race.
CPU1 CPU2
truncate(inode) shrink_active_list()
... page_evictable(page)
truncate_inode_page(mapping, page);
delete_from_page_cache(page)
spin_lock_irqsave(&mapping->tree_lock, flags);
__delete_from_page_cache(page, NULL)
page_cache_tree_delete(..)
... mapping = page_mapping(page);
page->mapping = NULL;
spin_unlock_irqrestore(&mapping->tree_lock, flags);
page_cache_free_page(mapping, page)
put_page(page)
if (put_page_testzero(page)) -> false
- inode now has no pages and can be freed including embedded address_space
mapping_unevictable(mapping)
test_bit(AS_UNEVICTABLE, &mapping->flags);
- we've dereferenced mapping which is potentially already free.
Similar race exists between swap cache freeing and page_evicatable()
too.
The address_space in inode and swap cache will be freed after a RCU
grace period. So the races are fixed via enclosing the page_mapping()
and address_space usage in rcu_read_lock/unlock(). Some comments are
added in code to make it clear what is protected by the RCU read lock.
Link: http://lkml.kernel.org/r/20180212081227.1940-1-ying.huang@intel.com
Signed-off-by: "Huang, Ying" <ying.huang@intel.com>
Cc: Mel Gorman <mgorman@techsingularity.net>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Michal Hocko <mhocko@suse.com>
[ Upstream commit 77da2ba0648a4fd52e5ff97b8b2b8dd312aec4b0 ]
This patch fixes a corner case for KSM. When two pages belong or
belonged to the same transparent hugepage, and they should be merged,
KSM fails to split the page, and therefore no merging happens.
This bug can be reproduced by:
* making sure ksm is running (in case disabling ksmtuned)
* enabling transparent hugepages
* allocating a THP-aligned 1-THP-sized buffer
e.g. on amd64: posix_memalign(&p, 1<<21, 1<<21)
* filling it with the same values
e.g. memset(p, 42, 1<<21)
* performing madvise to make it mergeable
e.g. madvise(p, 1<<21, MADV_MERGEABLE)
* waiting for KSM to perform a few scans
The expected outcome is that the all the pages get merged (1 shared and
the rest sharing); the actual outcome is that no pages get merged (1
unshared and the rest volatile)
The reason of this behaviour is that we increase the reference count
once for both pages we want to merge, but if they belong to the same
hugepage (or compound page), the reference counter used in both cases is
the one of the head of the compound page. This means that
split_huge_page will find a value of the reference counter too high and
will fail.
This patch solves this problem by testing if the two pages to merge
belong to the same hugepage when attempting to merge them. If so, the
hugepage is split safely. This means that the hugepage is not split if
not necessary.
Link: http://lkml.kernel.org/r/1521548069-24758-1-git-send-email-imbrenda@linux.vnet.ibm.com
Signed-off-by: Claudio Imbrenda <imbrenda@linux.vnet.ibm.com>
Co-authored-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
[ Upstream commit a06ad633a37c64a0cd4c229fc605cee8725d376e ]
Calling swapon() on a zero length swap file on SSD can lead to a
divide-by-zero.
Although creating such files isn't possible with mkswap and they woud be
considered invalid, it would be better for the swapon code to be more
robust and handle this condition gracefully (return -EINVAL).
Especially since the fix is small and straightforward.
To help with wear leveling on SSD, the swapon syscall calculates a
random position in the swap file using modulo p->highest_bit, which is
set to maxpages - 1 in read_swap_header.
If the swap file is zero length, read_swap_header sets maxpages=1 and
last_page=0, resulting in p->highest_bit=0 and we divide-by-zero when we
modulo p->highest_bit in swapon syscall.
This can be prevented by having read_swap_header return zero if
last_page is zero.
Link: http://lkml.kernel.org/r/5AC747C1020000A7001FA82C@prv-mh.provo.novell.com
Signed-off-by: Thomas Abraham <tabraham@suse.com>
Reported-by: <Mark.Landis@Teradata.com>
Cc: Randy Dunlap <rdunlap@infradead.org>
[ Upstream commit 914b6dfff790544d9b77dfd1723adb3745ec9700 ]
A crash is observed when kmemleak_scan accesses the object->pointer,
likely due to the following race.
TASK A TASK B TASK C
kmemleak_write
(with "scan" and
NOT "scan=on")
kmemleak_scan()
create_object
kmem_cache_alloc fails
kmemleak_disable
kmemleak_do_cleanup
kmemleak_free_enabled = 0
kfree
kmemleak_free bails out
(kmemleak_free_enabled is 0)
slub frees object->pointer
update_checksum
crash - object->pointer
freed (DEBUG_PAGEALLOC)
kmemleak_do_cleanup waits for the scan thread to complete, but not for
direct call to kmemleak_scan via kmemleak_write. So add a wait for
kmemleak_scan completion before disabling kmemleak_free, and while at it
fix the comment on stop_scan_thread.
[vinmenon@codeaurora.org: fix stop_scan_thread comment]
Link: http://lkml.kernel.org/r/1522219972-22809-1-git-send-email-vinmenon@codeaurora.org
Link: http://lkml.kernel.org/r/1522063429-18992-1-git-send-email-vinmenon@codeaurora.org
Signed-off-by: Vinayak Menon <vinmenon@codeaurora.org>
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
[ Upstream commit 8970a63e965b43288c4f5f40efbc2bbf80de7f16 ]
Alexander reported a use of uninitialized memory in __mpol_equal(),
which is caused by incorrect use of preferred_node.
When mempolicy in mode MPOL_PREFERRED with flags MPOL_F_LOCAL, it uses
numa_node_id() instead of preferred_node, however, __mpol_equal() uses
preferred_node without checking whether it is MPOL_F_LOCAL or not.
[akpm@linux-foundation.org: slight comment tweak]
Link: http://lkml.kernel.org/r/4ebee1c2-57f6-bcb8-0e2d-1833d1ee0bb7@huawei.com
Fixes: fc36b8d3d819 ("mempolicy: use MPOL_F_LOCAL to Indicate Preferred Local Policy")
Signed-off-by: Yisheng Xie <xieyisheng1@huawei.com>
Reported-by: Alexander Potapenko <glider@google.com>
Tested-by: Alexander Potapenko <glider@google.com>
Cc: Dmitriy Vyukov <dvyukov@google.com>
[ Upstream commit 69d763fc6d3aee787a3e8c8c35092b4f4960fa5d ]
Minchan Kim asked the following question -- what locks protects
address_space destroying when race happens between inode trauncation and
__isolate_lru_page? Jan Kara clarified by describing the race as follows
CPU1 CPU2
truncate(inode) __isolate_lru_page()
put_page(page)
if (mapping && !mapping->a_ops->migratepage)
The race is theoretically possible but unlikely. Before the
delete_from_page_cache, truncate_cleanup_page is called so the page is
likely to be !PageDirty or PageWriteback which gets skipped by the only
caller that checks the mappping in __isolate_lru_page. Even if the race
occurs, a substantial amount of work has to happen during a tiny window
with no preemption but it could potentially be done using a virtual
machine to artifically slow one CPU or halt it during the critical
window.
This patch should eliminate the race with truncation by try-locking the
page before derefencing mapping and aborting if the lock was not
acquired. There was a suggestion from Huang Ying to use RCU as a
side-effect to prevent mapping being freed. However, I do not like the
solution as it's an unconventional means of preserving a mapping and
it's not a context where rcu_read_lock is obviously protecting rcu data.
Link: http://lkml.kernel.org/r/20180104102512.2qos3h5vqzeisrek@techsingularity.net
Fixes: c82449352854 ("mm: compaction: make isolate_lru_page() filter-aware again")
Signed-off-by: Mel Gorman <mgorman@techsingularity.net>
[ Upstream commit 0486a38bcc4749808edbc848f1bcf232042770fc ]
As in manpage of migrate_pages, the errno should be set to EINVAL when
none of the node IDs specified by new_nodes are on-line and allowed by
the process's current cpuset context, or none of the specified nodes
contain memory. However, when test by following case:
new_nodes = 0;
old_nodes = 0xf;
ret = migrate_pages(pid, old_nodes, new_nodes, MAX);
The ret will be 0 and no errno is set. As the new_nodes is empty, we
should expect EINVAL as documented.
To fix the case like above, this patch check whether target nodes AND
current task_nodes is empty, and then check whether AND
node_states[N_MEMORY] is empty.
Link: http://lkml.kernel.org/r/1510882624-44342-4-git-send-email-xieyisheng1@huawei.com
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Chris Salls <salls@cs.ucsb.edu>
Cc: Christopher Lameter <cl@linux.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Tan Xiaojun <tanxiaojun@huawei.com>
[ Upstream commit 56521e7a02b7b84a5e72691a1fb15570e6055545 ]
As Xiaojun reported the ltp of migrate_pages01 will fail on arm64 system
which has 4 nodes[0...3], all have memory and CONFIG_NODES_SHIFT=2:
migrate_pages01 0 TINFO : test_invalid_nodes
migrate_pages01 14 TFAIL : migrate_pages_common.c:45: unexpected failure - returned value = 0, expected: -1
migrate_pages01 15 TFAIL : migrate_pages_common.c:55: call succeeded unexpectedly
In this case the test_invalid_nodes of migrate_pages01 will call:
SYSC_migrate_pages as:
migrate_pages(0, , {0x0000000000000001}, 64, , {0x0000000000000010}, 64) = 0
The new nodes specifies one or more node IDs that are greater than the
maximum supported node ID, however, the errno is not set to EINVAL as
expected.
As man pages of set_mempolicy[1], mbind[2], and migrate_pages[3]
mentioned, when nodemask specifies one or more node IDs that are greater
than the maximum supported node ID, the errno should set to EINVAL.
However, get_nodes only check whether the part of bits
[BITS_PER_LONG*BITS_TO_LONGS(MAX_NUMNODES), maxnode) is zero or not, and
remain [MAX_NUMNODES, BITS_PER_LONG*BITS_TO_LONGS(MAX_NUMNODES)
unchecked.
This patch is to check the bits of [MAX_NUMNODES, maxnode) in get_nodes
to let migrate_pages set the errno to EINVAL when nodemask specifies one
or more node IDs that are greater than the maximum supported node ID,
which follows the manpage's guide.
[1] http://man7.org/linux/man-pages/man2/set_mempolicy.2.html
[2] http://man7.org/linux/man-pages/man2/mbind.2.html
[3] http://man7.org/linux/man-pages/man2/migrate_pages.2.html
Link: http://lkml.kernel.org/r/1510882624-44342-3-git-send-email-xieyisheng1@huawei.com
Reported-by: Tan Xiaojun <tanxiaojun@huawei.com>
commit 3f1959721558a976aaf9c2024d5bc884e6411bf7 upstream.
Using module_init() is wrong. E.g. ACPI adds and onlines memory before
our memory notifier gets registered.
This makes sure that ACPI memory detected during boot up will not result
in a kernel crash.
Easily reproducible with QEMU, just specify a DIMM when starting up.
Link: http://lkml.kernel.org/r/20180522100756.18478-3-david@redhat.com
Fixes: 786a8959912e ("kasan: disable memory hotplug")
Signed-off-by: David Hildenbrand <david@redhat.com>
Acked-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Alexander Potapenko <glider@google.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
commit ab1e8d8960b68f54af42b6484b5950bd13a4054b upstream.
It is unsafe to do virtual to physical translations before mm_init() is
called if struct page is needed in order to determine the memory section
number (see SECTION_IN_PAGE_FLAGS). This is because only in mm_init()
we initialize struct pages for all the allocated memory when deferred
struct pages are used.
My recent fix in commit c9e97a1997 ("mm: initialize pages on demand
during boot") exposed this problem, because it greatly reduced number of
pages that are initialized before mm_init(), but the problem existed
even before my fix, as Fengguang Wu found.
Below is a more detailed explanation of the problem.
We initialize struct pages in four places:
1. Early in boot a small set of struct pages is initialized to fill the
first section, and lower zones.
2. During mm_init() we initialize "struct pages" for all the memory that
is allocated, i.e reserved in memblock.
3. Using on-demand logic when pages are allocated after mm_init call
(when memblock is finished)
4. After smp_init() when the rest free deferred pages are initialized.
The problem occurs if we try to do va to phys translation of a memory
between steps 1 and 2. Because we have not yet initialized struct pages
for all the reserved pages, it is inherently unsafe to do va to phys if
the translation itself requires access of "struct page" as in case of
this combination: CONFIG_SPARSE && !CONFIG_SPARSE_VMEMMAP
The following path exposes the problem:
start_kernel()
trap_init()
setup_cpu_entry_areas()
setup_cpu_entry_area(cpu)
get_cpu_gdt_paddr(cpu)
per_cpu_ptr_to_phys(addr)
pcpu_addr_to_page(addr)
virt_to_page(addr)
pfn_to_page(__pa(addr) >> PAGE_SHIFT)
We disable this path by not allowing NEED_PER_CPU_KM with deferred
struct pages feature.
The problems are discussed in these threads:
http://lkml.kernel.org/r/20180418135300.inazvpxjxowogyge@wfg-t540p.sh.intel.com
http://lkml.kernel.org/r/20180419013128.iurzouiqxvcnpbvz@wfg-t540p.sh.intel.com
http://lkml.kernel.org/r/20180426202619.2768-1-pasha.tatashin@oracle.com
Link: http://lkml.kernel.org/r/20180515175124.1770-1-pasha.tatashin@oracle.com
Fixes: 3a80a7fa7989 ("mm: meminit: initialise a subset of struct pages if CONFIG_DEFERRED_STRUCT_PAGE_INIT is set")
Signed-off-by: Pavel Tatashin <pasha.tatashin@oracle.com>
Cc: Steven Sistare <steven.sistare@oracle.com>
Cc: Daniel Jordan <daniel.m.jordan@oracle.com>
Cc: Fengguang Wu <fengguang.wu@intel.com>
Cc: Dennis Zhou <dennisszhou@gmail.com>
commit a3b609ef9f8b1dbfe97034ccad6cd3fe71fbe7ab upstream.
Only functions doing more than one read are modified. Consumeres
happened to deal with possibly changing data, but it does not seem like
a good thing to rely on.
Signed-off-by: Mateusz Guzik <mguzik@redhat.com>
Acked-by: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: Jarod Wilson <jarod@redhat.com>
Cc: Jan Stancek <jstancek@redhat.com>
Cc: Anshuman Khandual <anshuman.linux@gmail.com>
complete during a read
commit ebded02788b5d7c7600f8cff26ae07896d568649 upstream.
In the generic read paths the kernel looks up a page in the page cache
and if it's up to date, it is used. If not, the page lock is acquired
to wait for IO to complete and then check the page. If multiple
processes are waiting on IO, they all serialise against the lock and
duplicate the checks. This is unnecessary.
The page lock in itself does not give any guarantees to the callers
about the page state as it can be immediately truncated or reclaimed
after the page is unlocked. It's sufficient to wait_on_page_locked and
then continue if the page is up to date on wakeup.
It is possible that a truncated but up-to-date page is returned but the
reference taken during read prevents it disappearing underneath the
caller and the data is still valid if PageUptodate.
The overall impact is small as even if processes serialise on the lock,
the lock section is tiny once the IO is complete. Profiles indicated
that unlock_page and friends are generally a tiny portion of a
read-intensive workload. An artificial test was created that had
instances of dd access a cache-cold file on an ext4 filesystem and
measure how long the read took.
paralleldd
4.4.0 4.4.0
vanilla avoidlock
Amean Elapsd-1 5.28 ( 0.00%) 5.15 ( 2.50%)
Amean Elapsd-4 5.29 ( 0.00%) 5.17 ( 2.12%)
Amean Elapsd-7 5.28 ( 0.00%) 5.18 ( 1.78%)
Amean Elapsd-12 5.20 ( 0.00%) 5.33 ( -2.50%)
Amean Elapsd-21 5.14 ( 0.00%) 5.21 ( -1.41%)
Amean Elapsd-30 5.30 ( 0.00%) 5.12 ( 3.38%)
Amean Elapsd-48 5.78 ( 0.00%) 5.42 ( 6.21%)
Amean Elapsd-79 6.78 ( 0.00%) 6.62 ( 2.46%)
Amean Elapsd-110 9.09 ( 0.00%) 8.99 ( 1.15%)
Amean Elapsd-128 10.60 ( 0.00%) 10.43 ( 1.66%)
The impact is small but intuitively, it makes sense to avoid unnecessary
calls to lock_page.
commit 32b635298ff4e991d8d8f64dc23782b02eec29c3 upstream.
do_read_cache_page and __read_cache_page duplicate page filler code when
filling the page for the first time. This patch simply removes the
duplicate logic.
commit 316bda0e6cc5f36f94b4af8bded16d642c90ad75 upstream.
We assume there is enough inactive page cache if the size of inactive
file lru is greater than the size of active file lru, in which case we
force-scan file lru ignoring anonymous pages. While this logic works
fine when there are plenty of page cache pages, it fails if the size of
file lru is small (several MB): in this case (lru_size >> prio) will be
0 for normal scan priorities, as a result, if inactive file lru happens
to be larger than active file lru, anonymous pages of a cgroup will
never get evicted unless the system experiences severe memory pressure,
even if there are gigabytes of unused anonymous memory there, which is
unfair in respect to other cgroups, whose workloads might be page cache
oriented.
This patch attempts to fix this by elaborating the "enough inactive page
cache" check: it makes it not only check that inactive lru size > active
lru size, but also that we will scan something from the cgroup at the
current scan priority. If these conditions do not hold, we proceed to
SCAN_FRACT as usual.
Signed-off-by: Vladimir Davydov <vdavydov@virtuozzo.com>
commit 71546d100422bcc2c543dadeb9328728997cd23a upstream.
microblaze build broke due to missing declaration of the
cond_resched() invocation added recently. Let's include linux/sched.h
explicitly.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
commit 2e898e4c0a3897ccd434adac5abb8330194f527b upstream.
lock_page_memcg()/unlock_page_memcg() use spin_lock_irqsave/restore() if
the page's memcg is undergoing move accounting, which occurs when a
process leaves its memcg for a new one that has
memory.move_charge_at_immigrate set.
unlocked_inode_to_wb_begin,end() use spin_lock_irq/spin_unlock_irq() if
the given inode is switching writeback domains. Switches occur when
enough writes are issued from a new domain.
This existing pattern is thus suspicious:
lock_page_memcg(page);
unlocked_inode_to_wb_begin(inode, &locked);
unlocked_inode_to_wb_end(inode, locked);
unlock_page_memcg(page);
If both inode switch and process memcg migration are both in-flight then
unlocked_inode_to_wb_end() will unconditionally enable interrupts while
still holding the lock_page_memcg() irq spinlock. This suggests the
possibility of deadlock if an interrupt occurs before unlock_page_memcg().
truncate
__cancel_dirty_page
lock_page_memcg
<interrupts mistakenly enabled>
<interrupt>
end_page_writeback
test_clear_page_writeback
lock_page_memcg
<deadlock>
unlock_page_memcg
Due to configuration limitations this deadlock is not currently possible
because we don't mix cgroup writeback (a cgroupv2 feature) and
memory.move_charge_at_immigrate (a cgroupv1 feature).
If the kernel is hacked to always claim inode switching and memcg
moving_account, then this script triggers lockup in less than a minute:
cd /mnt/cgroup/memory
mkdir a b
echo 1 > a/memory.move_charge_at_immigrate
echo 1 > b/memory.move_charge_at_immigrate
echo $BASHPID > a/cgroup.procs
while true; do
dd if=/dev/zero of=/mnt/big bs=1M count=256
done
while true; do
sync
done &
sleep 1h &
SLEEP=$!
while true; do
echo $SLEEP > a/cgroup.procs
echo $SLEEP > b/cgroup.procs
done
The deadlock does not seem possible, so it's debatable if there's any
reason to modify the kernel. I suggest we should to prevent future
surprises. And Wang Long said "this deadlock occurs three times in our
environment", so there's more reason to apply this, even to stable.
Stable 4.4 has minor conflicts applying this patch. For a clean 4.4 patch
see "[PATCH for-4.4] writeback: safer lock nesting"
https://lkml.org/lkml/2018/4/11/146
Wang Long said "this deadlock occurs three times in our environment"
[gthelen@google.com: v4]
Link: http://lkml.kernel.org/r/20180411084653.254724-1-gthelen@google.com
[akpm@linux-foundation.org: comment tweaks, struct initialization simplification]
Change-Id: Ibb773e8045852978f6207074491d262f1b3fb613
Link: http://lkml.kernel.org/r/20180410005908.167976-1-gthelen@google.com
Fixes: 682aa8e1a6a1 ("writeback: implement unlocked_inode_to_wb transaction and use it for stat updates")
Signed-off-by: Greg Thelen <gthelen@google.com>
Reported-by: Wang Long <wanglong19@meituan.com>
Acked-by: Wang Long <wanglong19@meituan.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Nicholas Piggin <npiggin@gmail.com>
Cc: <stable@vger.kernel.org> [v4.2+]
[natechancellor: Applied to 4.4 based on Greg's backport on lkml.org]
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
commit abc1be13fd113ddef5e2d807a466286b864caed3 upstream.
f2fs specifies the __GFP_ZERO flag for allocating some of its pages.
Unfortunately, the page cache also uses the mapping's GFP flags for
allocating radix tree nodes. It always masked off the __GFP_HIGHMEM
flag, and masks off __GFP_ZERO in some paths, but not all. That causes
radix tree nodes to be allocated with a NULL list_head, which causes
backtraces like:
__list_del_entry+0x30/0xd0
list_lru_del+0xac/0x1ac
page_cache_tree_insert+0xd8/0x110
The __GFP_DMA and __GFP_DMA32 flags would also be able to sneak through
if they are ever used. Fix them all by using GFP_RECLAIM_MASK at the
innermost location, and remove it from earlier in the callchain.
Link: http://lkml.kernel.org/r/20180411060320.14458-2-willy@infradead.org
Fixes: 449dd6984d0e ("mm: keep page cache radix tree nodes in check")
Signed-off-by: Matthew Wilcox <mawilcox@microsoft.com>
Reported-by: Chris Fries <cfries@google.com>
Debugged-by: Minchan Kim <minchan@kernel.org>
commit c20cd45eb01748f0fba77a504f956b000df4ea73 upstream.
page_cache_read has been historically using page_cache_alloc_cold to
allocate a new page. This means that mapping_gfp_mask is used as the
base for the gfp_mask. Many filesystems are setting this mask to
GFP_NOFS to prevent from fs recursion issues. page_cache_read is called
from the vm_operations_struct::fault() context during the page fault.
This context doesn't need the reclaim protection normally.
ceph and ocfs2 which call filemap_fault from their fault handlers seem
to be OK because they are not taking any fs lock before invoking generic
implementation. xfs which takes XFS_MMAPLOCK_SHARED is safe from the
reclaim recursion POV because this lock serializes truncate and punch
hole with the page faults and it doesn't get involved in the reclaim.
There is simply no reason to deliberately use a weaker allocation
context when a __GFP_FS | __GFP_IO can be used. The GFP_NOFS protection
might be even harmful. There is a push to fail GFP_NOFS allocations
rather than loop within allocator indefinitely with a very limited
reclaim ability. Once we start failing those requests the OOM killer
might be triggered prematurely because the page cache allocation failure
is propagated up the page fault path and end up in
pagefault_out_of_memory.
We cannot play with mapping_gfp_mask directly because that would be racy
wrt. parallel page faults and it might interfere with other users who
really rely on NOFS semantic from the stored gfp_mask. The mask is also
inode proper so it would even be a layering violation. What we can do
instead is to push the gfp_mask into struct vm_fault and allow fs layer
to overwrite it should the callback need to be called with a different
allocation context.
Initialize the default to (mapping_gfp_mask | __GFP_FS | __GFP_IO)
because this should be safe from the page fault path normally. Why do
we care about mapping_gfp_mask at all then? Because this doesn't hold
only reclaim protection flags but it also might contain zone and
movability restrictions (GFP_DMA32, __GFP_MOVABLE and others) so we have
to respect those.
Signed-off-by: Michal Hocko <mhocko@suse.com>
Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Acked-by: Jan Kara <jack@suse.com>
Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Cc: Mark Fasheh <mfasheh@suse.com>
commit a9f2a846f0503e7d729f552e3ccfe2279010fe94 upstream.
cache_reap() is initially scheduled in start_cpu_timer() via
schedule_delayed_work_on(). But then the next iterations are scheduled
via schedule_delayed_work(), i.e. using WORK_CPU_UNBOUND.
Thus since commit ef557180447f ("workqueue: schedule WORK_CPU_UNBOUND
work on wq_unbound_cpumask CPUs") there is no guarantee the future
iterations will run on the originally intended cpu, although it's still
preferred. I was able to demonstrate this with
/sys/module/workqueue/parameters/debug_force_rr_cpu. IIUC, it may also
happen due to migrating timers in nohz context. As a result, some cpu's
would be calling cache_reap() more frequently and others never.
This patch uses schedule_delayed_work_on() with the current cpu when
scheduling the next iteration.
Link: http://lkml.kernel.org/r/20180411070007.32225-1-vbabka@suse.cz
Fixes: ef557180447f ("workqueue: schedule WORK_CPU_UNBOUND work on wq_unbound_cpumask CPUs")
Acked-by: Pekka Enberg <penberg@kernel.org>
Acked-by: Christoph Lameter <cl@linux.com>
Cc: Lai Jiangshan <jiangshanlai@gmail.com>
Cc: John Stultz <john.stultz@linaro.org>
Cc: Stephen Boyd <sboyd@kernel.org>
commit c877ef8ae7b8edaedccad0fc8c23d4d1de7e2480 upstream.
The right variable definition should be wb_congested_state that
include WB_async_congested and WB_sync_congested. So fix it.
Signed-off-by: Kaixu Xia <xiakaixu@huawei.com>
Acked-by: Tejun Heo <tj@kernel.org>
Signed-off-by: Jens Axboe <axboe@fb.com>
Cc: Nathan Chancellor <natechancellor@gmail.com>
[ Upstream commit 7f6f60a1ba52538c16f26930bfbcfe193d9d746a ]
earlyprintk=efi,keep does not work any more with a warning
in mm/early_ioremap.c: WARN_ON(system_state != SYSTEM_BOOTING):
Boot just hangs because of the earlyprintk within the earlyprintk
implementation code itself.
This is caused by a new introduced middle state in:
69a78ff226fe ("init: Introduce SYSTEM_SCHEDULING state")
early_ioremap() is fine in both SYSTEM_BOOTING and SYSTEM_SCHEDULING
states, original condition should be updated accordingly.
Signed-off-by: Dave Young <dyoung@redhat.com>
Cc: bp@suse.de
Cc: linux-efi@vger.kernel.org
Cc: linux-mm@kvack.org
Link: http://lkml.kernel.org/r/20171209041610.GA3249@dhcp-128-65.nay.redhat.com
commit f35157417215ec138c920320c746fdb3e04ef1d5 upstream.
Provide a function, kmemdup_nul(), that will create a NUL-terminated string
from an unterminated character array where the length is known in advance.
This is better than kstrndup() in situations where we already know the
string length as the strnlen() in kstrndup() is superfluous.
commit bb422a738f6566f7439cd347d54e321e4fe92a9f upstream.
Syzbot caught an oops at unregister_shrinker() because combination of
commit 1d3d4437eae1bb29 ("vmscan: per-node deferred work") and fault
injection made register_shrinker() fail and the caller of
register_shrinker() did not check for failure.
[ 554.881422] FAULT_INJECTION: forcing a failure.
[ 554.881422] name failslab, interval 1, probability 0, space 0, times 0
[ 554.881438] CPU: 1 PID: 13231 Comm: syz-executor1 Not tainted 4.14.0-rc8+ #82
[ 554.881443] Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
[ 554.881445] Call Trace:
[ 554.881459] dump_stack+0x194/0x257
[ 554.881474] ? arch_local_irq_restore+0x53/0x53
[ 554.881486] ? find_held_lock+0x35/0x1d0
[ 554.881507] should_fail+0x8c0/0xa40
[ 554.881522] ? fault_create_debugfs_attr+0x1f0/0x1f0
[ 554.881537] ? check_noncircular+0x20/0x20
[ 554.881546] ? find_next_zero_bit+0x2c/0x40
[ 554.881560] ? ida_get_new_above+0x421/0x9d0
[ 554.881577] ? find_held_lock+0x35/0x1d0
[ 554.881594] ? __lock_is_held+0xb6/0x140
[ 554.881628] ? check_same_owner+0x320/0x320
[ 554.881634] ? lock_downgrade+0x990/0x990
[ 554.881649] ? find_held_lock+0x35/0x1d0
[ 554.881672] should_failslab+0xec/0x120
[ 554.881684] __kmalloc+0x63/0x760
[ 554.881692] ? lock_downgrade+0x990/0x990
[ 554.881712] ? register_shrinker+0x10e/0x2d0
[ 554.881721] ? trace_event_raw_event_module_request+0x320/0x320
[ 554.881737] register_shrinker+0x10e/0x2d0
[ 554.881747] ? prepare_kswapd_sleep+0x1f0/0x1f0
[ 554.881755] ? _down_write_nest_lock+0x120/0x120
[ 554.881765] ? memcpy+0x45/0x50
[ 554.881785] sget_userns+0xbcd/0xe20
(...snipped...)
[ 554.898693] kasan: CONFIG_KASAN_INLINE enabled
[ 554.898724] kasan: GPF could be caused by NULL-ptr deref or user memory access
[ 554.898732] general protection fault: 0000 [#1] SMP KASAN
[ 554.898737] Dumping ftrace buffer:
[ 554.898741] (ftrace buffer empty)
[ 554.898743] Modules linked in:
[ 554.898752] CPU: 1 PID: 13231 Comm: syz-executor1 Not tainted 4.14.0-rc8+ #82
[ 554.898755] Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
[ 554.898760] task: ffff8801d1dbe5c0 task.stack: ffff8801c9e38000
[ 554.898772] RIP: 0010:__list_del_entry_valid+0x7e/0x150
[ 554.898775] RSP: 0018:ffff8801c9e3f108 EFLAGS: 00010246
[ 554.898780] RAX: dffffc0000000000 RBX: 0000000000000000 RCX: 0000000000000000
[ 554.898784] RDX: 0000000000000000 RSI: ffff8801c53c6f98 RDI: ffff8801c53c6fa0
[ 554.898788] RBP: ffff8801c9e3f120 R08: 1ffff100393c7d55 R09: 0000000000000004
[ 554.898791] R10: ffff8801c9e3ef70 R11: 0000000000000000 R12: 0000000000000000
[ 554.898795] R13: dffffc0000000000 R14: 1ffff100393c7e45 R15: ffff8801c53c6f98
[ 554.898800] FS: 0000000000000000(0000) GS:ffff8801db300000(0000) knlGS:0000000000000000
[ 554.898804] CS: 0010 DS: 002b ES: 002b CR0: 0000000080050033
[ 554.898807] CR2: 00000000dbc23000 CR3: 00000001c7269000 CR4: 00000000001406e0
[ 554.898813] DR0: 0000000020000000 DR1: 0000000020000000 DR2: 0000000000000000
[ 554.898816] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000600
[ 554.898818] Call Trace:
[ 554.898828] unregister_shrinker+0x79/0x300
[ 554.898837] ? perf_trace_mm_vmscan_writepage+0x750/0x750
[ 554.898844] ? down_write+0x87/0x120
[ 554.898851] ? deactivate_super+0x139/0x1b0
[ 554.898857] ? down_read+0x150/0x150
[ 554.898864] ? check_same_owner+0x320/0x320
[ 554.898875] deactivate_locked_super+0x64/0xd0
[ 554.898883] deactivate_super+0x141/0x1b0
Since allowing register_shrinker() callers to call unregister_shrinker()
when register_shrinker() failed can simplify error recovery path, this
patch makes unregister_shrinker() no-op when register_shrinker() failed.
Also, reset shrinker->nr_deferred in case unregister_shrinker() was
by error called twice.
Signed-off-by: Aliaksei Karaliou <akaraliou.dev@gmail.com>
Reported-by: syzbot <syzkaller@googlegroups.com>
Cc: Glauber Costa <glauber@scylladb.com>
commit af27d9403f5b80685b79c88425086edccecaf711 upstream.
We get a warning about some slow configurations in randconfig kernels:
mm/memory.c:83:2: error: #warning Unfortunate NUMA and NUMA Balancing config, growing page-frame for last_cpupid. [-Werror=cpp]
The warning is reasonable by itself, but gets in the way of randconfig
build testing, so I'm hiding it whenever CONFIG_COMPILE_TEST is set.
The warning was added in 2013 in commit 75980e97dacc ("mm: fold
page->_last_nid into page->flags where possible").
Cc: stable@vger.kernel.org
[ Upstream commit bde5f6bc68db51128f875a756e9082a6c6ff7b4c ]
kmemleak_scan() will scan struct page for each node and it can be really
large and resulting in a soft lockup. We have seen a soft lockup when
do scan while compile kernel:
watchdog: BUG: soft lockup - CPU#53 stuck for 22s! [bash:10287]
Call Trace:
kmemleak_scan+0x21a/0x4c0
kmemleak_write+0x312/0x350
full_proxy_write+0x5a/0xa0
__vfs_write+0x33/0x150
vfs_write+0xad/0x1a0
SyS_write+0x52/0xc0
do_syscall_64+0x61/0x1a0
entry_SYSCALL64_slow_path+0x25/0x25
Fix this by adding cond_resched every MAX_SCAN_SIZE.
Link: http://lkml.kernel.org/r/1511439788-20099-1-git-send-email-xieyisheng1@huawei.com
Suggested-by: Catalin Marinas <catalin.marinas@arm.com>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
commit b050e3769c6b4013bb937e879fc43bf1847ee819 upstream.
Since commit 97a16fc82a7c ("mm, page_alloc: only enforce watermarks for
order-0 allocations"), __zone_watermark_ok() check for high-order
allocations will shortcut per-migratetype free list checks for
ALLOC_HARDER allocations, and return true as long as there's free page
of any migratetype. The intention is that ALLOC_HARDER can allocate
from MIGRATE_HIGHATOMIC free lists, while normal allocations can't.
However, as a side effect, the watermark check will then also return
true when there are pages only on the MIGRATE_ISOLATE list, or (prior to
CMA conversion to ZONE_MOVABLE) on the MIGRATE_CMA list. Since the
allocation cannot actually obtain isolated pages, and might not be able
to obtain CMA pages, this can result in a false positive.
The condition should be rare and perhaps the outcome is not a fatal one.
Still, it's better if the watermark check is correct. There also
shouldn't be a performance tradeoff here.
Link: http://lkml.kernel.org/r/20171102125001.23708-1-vbabka@suse.cz
Fixes: 97a16fc82a7c ("mm, page_alloc: only enforce watermarks for order-0 allocations")
commit e048cb32f69038aa1c8f11e5c1b331be4181659d upstream.
The align_offset parameter is used by bitmap_find_next_zero_area_off()
to represent the offset of map's base from the previous alignment
boundary; the function ensures that the returned index, plus the
align_offset, honors the specified align_mask.
The logic introduced by commit b5be83e308f7 ("mm: cma: align to physical
address, not CMA region position") has the cma driver calculate the
offset to the *next* alignment boundary. In most cases, the base
alignment is greater than that specified when making allocations,
resulting in a zero offset whether we align up or down. In the example
given with the commit, the base alignment (8MB) was half the requested
alignment (16MB) so the math also happened to work since the offset is
8MB in both directions. However, when requesting allocations with an
alignment greater than twice that of the base, the returned index would
not be correctly aligned.
Also, the align_order arguments of cma_bitmap_aligned_mask() and
cma_bitmap_aligned_offset() should not be negative so the argument type
was made unsigned.
Fixes: b5be83e308f7 ("mm: cma: align to physical address, not CMA region position")
Link: http://lkml.kernel.org/r/20170628170742.2895-1-opendmb@gmail.com
Signed-off-by: Angus Clark <angus@angusclark.org>
Signed-off-by: Doug Berger <opendmb@gmail.com>
Acked-by: Gregory Fong <gregory.0xf0@gmail.com>
Cc: Doug Berger <opendmb@gmail.com>
Cc: Angus Clark <angus@angusclark.org>
Cc: Laura Abbott <labbott@redhat.com>
Cc: Lucas Stach <l.stach@pengutronix.de>
Cc: Shiraz Hashim <shashim@codeaurora.org>
Cc: Jaewon Kim <jaewon31.kim@samsung.com>
commit 18365225f0440d09708ad9daade2ec11275c3df9 upstream.
Laurent Dufour has noticed that hwpoinsoned pages are kept charged. In
his particular case he has hit a bad_page("page still charged to
cgroup") when onlining a hwpoison page. While this looks like something
that shouldn't happen in the first place because onlining hwpages and
returning them to the page allocator makes only little sense it shows a
real problem.
hwpoison pages do not get freed usually so we do not uncharge them (at
least not since commit 0a31bc97c80c ("mm: memcontrol: rewrite uncharge
API")). Each charge pins memcg (since e8ea14cc6ead ("mm: memcontrol:
take a css reference for each charged page")) as well and so the
mem_cgroup and the associated state will never go away. Fix this leak
by forcibly uncharging a LRU hwpoisoned page in delete_from_lru_cache().
We also have to tweak uncharge_list because it cannot rely on zero ref
count for these pages.
Fixes: 0a31bc97c80c ("mm: memcontrol: rewrite uncharge API")
Link: http://lkml.kernel.org/r/20170502185507.GB19165@dhcp22.suse.cz
Reported-by: Laurent Dufour <ldufour@linux.vnet.ibm.com>
Tested-by: Laurent Dufour <ldufour@linux.vnet.ibm.com>
Reviewed-by: Balbir Singh <bsingharora@gmail.com>
Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
commit 561b5e0709e4a248c67d024d4d94b6e31e3edf2f upstream.
Commit 1be7107fbe18 ("mm: larger stack guard gap, between vmas") has
introduced a regression in some rust and Java environments which are
trying to implement their own stack guard page. They are punching a new
MAP_FIXED mapping inside the existing stack Vma.
This will confuse expand_{downwards,upwards} into thinking that the
stack expansion would in fact get us too close to an existing non-stack
vma which is a correct behavior wrt safety. It is a real regression on
the other hand.
Let's work around the problem by considering PROT_NONE mapping as a part
of the stack. This is a gros hack but overflowing to such a mapping
would trap anyway an we only can hope that usespace knows what it is
doing and handle it propely.
Fixes: 1be7107fbe18 ("mm: larger stack guard gap, between vmas")
Link: http://lkml.kernel.org/r/20170705182849.GA18027@dhcp22.suse.cz
Debugged-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Ben Hutchings <ben@decadent.org.uk>
commit fd5bb66cd934987e49557455b6497fc006521940 upstream.
Change the zpool/compressor param callback function to release the
zswap_pools_lock spinlock before calling param_set_charp, since that
function may sleep when it calls kmalloc with GFP_KERNEL.
While this problem has existed for a while, I wasn't able to trigger it
using a tight loop changing either/both the zpool and compressor params; I
think it's very unlikely to be an issue on the stable kernels, especially
since most zswap users will change the compressor and/or zpool from sysfs
only one time each boot - or zero times, if they add the params to the
kernel boot.
Fixes: c99b42c3529e ("zswap: use charp for zswap param strings")
Link: http://lkml.kernel.org/r/20170126155821.4545-1-ddstreet@ieee.org
Signed-off-by: Dan Streetman <dan.streetman@canonical.com>
Reported-by: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com>
commit 200867af4dedfe7cb707f96773684de1d1fd21e6 upstream.
Add a work_struct to struct zswap_pool, and change __zswap_pool_empty to
use the workqueue instead of using call_rcu().
When zswap destroys a pool no longer in use, it uses call_rcu() to
perform the destruction/freeing. Since that executes in softirq
context, it must not sleep. However, actually destroying the pool
involves freeing the per-cpu compressors (which requires locking the
cpu_add_remove_lock mutex) and freeing the zpool, for which the
implementation may sleep (e.g. zsmalloc calls kmem_cache_destroy, which
locks the slab_mutex). So if either mutex is currently taken, or any
other part of the compressor or zpool implementation sleeps, it will
result in a BUG().
It's not easy to reproduce this when changing zswap's params normally.
In testing with a loaded system, this does not fail:
$ cd /sys/module/zswap/parameters
$ echo lz4 > compressor ; echo zsmalloc > zpool
nor does this:
$ while true ; do
> echo lzo > compressor ; echo zbud > zpool
> sleep 1
> sleep 1
> done
although it's still possible either of those might fail, depending on
whether anything else besides zswap has locked the mutexes.
However, changing a parameter with no delay immediately causes the
schedule while atomic BUG:
$ while true ; do
> echo lzo > compressor ; echo lz4 > compressor
> done
This is essentially the same as Yu Zhao's proposed patch to zsmalloc,
but moved to zswap, to cover compressor and zpool freeing.
Fixes: f1c54846ee45 ("zswap: dynamic pool creation")
Signed-off-by: Dan Streetman <ddstreet@ieee.org>
Reported-by: Yu Zhao <yuzhao@google.com>
Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: Dan Streetman <dan.streetman@canonical.com>
commit d59b1087a98e402ed9a7cc577f4da435f9a555f5 upstream.
Calculation of dirty_ratelimit sometimes is not correct. E.g. initial
values of dirty_ratelimit == INIT_BW and step == 0, lead to the
following result:
UBSAN: Undefined behaviour in ../mm/page-writeback.c:1286:7
shift exponent 25600 is too large for 64-bit type 'long unsigned int'
The fix is straightforward - make step 0 if the shift exponent is too
big.
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Andy Shevchenko <andy.shevchenko@gmail.com>
commit e1409c325fdc1fef7b3d8025c51892355f065d15 upstream.
pageblock_pfn_to_page() is used to check there is valid pfn and all
pages in the pageblock is in a single zone. If there is a hole in the
pageblock, passing arbitrary position to pageblock_pfn_to_page() could
cause to skip whole pageblock scanning, instead of just skipping the
hole page. For deterministic behaviour, it's better to always pass
pageblock aligned range to pageblock_pfn_to_page(). It will also help
further optimization on pageblock_pfn_to_page() in the following patch.
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Aaron Lu <aaron.lu@intel.com>
commit 623446e4dc45b37740268165107cc63abb3022f0 upstream.
free_pfn and compact_cached_free_pfn are the pointer that remember
restart position of freepage scanner. When they are reset or invalid,
we set them to zone_end_pfn because freepage scanner works in reverse
direction. But, because zone range is defined as [zone_start_pfn,
zone_end_pfn), zone_end_pfn is invalid to access. Therefore, we should
not store it to free_pfn and compact_cached_free_pfn. Instead, we need
to store zone_end_pfn - 1 to them. There is one more thing we should
consider. Freepage scanner scan reversely by pageblock unit. If
free_pfn and compact_cached_free_pfn are set to middle of pageblock, it
regards that sitiation as that it already scans front part of pageblock
so we lose opportunity to scan there. To fix-up, this patch do
round_down() to guarantee that reset position will be pageblock aligned.
Note that thanks to the current pageblock_pfn_to_page() implementation,
actual access to zone_end_pfn doesn't happen until now. But, following
patch will change pageblock_pfn_to_page() so this patch is needed from
now on.
Acked-by: David Rientjes <rientjes@google.com>
commit 68ba0326b4e14988f9e0c24a6e12a85cf2acd1ca upstream.
Every current KDE system has process named ksysguardd polling files
below once in several seconds:
$ strace -e trace=open -p $(pidof ksysguardd)
Process 1812 attached
open("/etc/mtab", O_RDONLY|O_CLOEXEC) = 8
open("/proc/net/dev", O_RDONLY) = 8
open("/proc/net/wireless", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/proc/stat", O_RDONLY) = 8
open("/proc/vmstat", O_RDONLY) = 8
Hell knows what it is doing but speed up reading /proc/vmstat by 33%!
Benchmark is open+read+close 1.000.000 times.
BEFORE
$ perf stat -r 10 taskset -c 3 ./proc-vmstat
Performance counter stats for 'taskset -c 3 ./proc-vmstat' (10 runs):
13146.768464 task-clock (msec) # 0.960 CPUs utilized ( +- 0.60% )
15 context-switches # 0.001 K/sec ( +- 1.41% )
1 cpu-migrations # 0.000 K/sec ( +- 11.11% )
104 page-faults # 0.008 K/sec ( +- 0.57% )
45,489,799,349 cycles # 3.460 GHz ( +- 0.03% )
9,970,175,743 stalled-cycles-frontend # 21.92% frontend cycles idle ( +- 0.10% )
2,800,298,015 stalled-cycles-backend # 6.16% backend cycles idle ( +- 0.32% )
79,241,190,850 instructions # 1.74 insn per cycle
# 0.13 stalled cycles per insn ( +- 0.00% )
17,616,096,146 branches # 1339.956 M/sec ( +- 0.00% )
176,106,232 branch-misses # 1.00% of all branches ( +- 0.18% )
13.691078109 seconds time elapsed ( +- 0.03% )
AFTER
8688.353749 task-clock (msec) # 0.950 CPUs utilized ( +- 1.25% )
10 context-switches # 0.001 K/sec ( +- 2.13% )
104 page-faults # 0.012 K/sec ( +- 0.56% )
30,384,010,730 cycles # 3.497 GHz ( +- 0.07% )
12,296,259,407 stalled-cycles-frontend # 40.47% frontend cycles idle ( +- 0.13% )
3,370,668,651 stalled-cycles-backend # 11.09% backend cycles idle ( +- 0.69% )
28,969,052,879 instructions # 0.95 insn per cycle
# 0.42 stalled cycles per insn ( +- 0.01% )
6,308,245,891 branches # 726.058 M/sec ( +- 0.00% )
214,685,502 branch-misses # 3.40% of all branches ( +- 0.26% )
9.146081052 seconds time elapsed ( +- 0.07% )
vsnprintf() is slow because:
1. format_decode() is busy looking for format specifier: 2 branches
per character (not in this case, but in others)
2. approximately million branches while parsing format mini language
and everywhere
3. just look at what string() does /proc/vmstat is good case because
most of its content are strings
Link: http://lkml.kernel.org/r/20160806125455.GA1187@p183.telecom.by
Cc: Joe Perches <joe@perches.com>
The kaiser update made an interesting choice, never to free any shadow
page tables. Contention on global spinlock was worrying, particularly
with it held across page table scans when freeing. Something had to be
done: I was going to add refcounting; but simply never to free them is
an appealing choice, minimizing contention without complicating the code
(the more a page table is found already, the less the spinlock is used).
But leaking pages in this way is also a worry: can we get away with it?
At the very least, we need a count to show how bad it actually gets:
in principle, one might end up wasting about 1/256 of memory that way
(1/512 for when direct-mapped pages have to be user-mapped, plus 1/512
for when they are user-mapped from the vmalloc area on another occasion
(but we don't have vmalloc'ed stacks, so only large ldts are vmalloc'ed).
Add per-cpu stat NR_KAISERTABLE: including 256 at startup for the
shared pgd entries, and 1 for each intermediate page table added
thereafter for user-mapping - but leave out the 1 per mm, for its
shadow pgd, because that distracts from the monotonic increase.
Shown in /proc/vmstat as nr_overhead (0 if kaiser not enabled).
In practice, it doesn't look so bad so far: more like 1/12000 after
nine hours of gtests below; and movable pageblock segregation should
tend to cluster the kaiser tables into a subset of the address space
(if not, they will be bad for compaction too). But production may
tell a different story: keep an eye on this number, and bring back
lighter freeing if it gets out of control (maybe a shrinker).
Acked-by: Jiri Kosina <jkosina@suse.cz>
commit 8efd755ac2fe262d4c8d5c9bbe054bb67dae93da upstream.
Some architectures (such as Alpha) rely on include/linux/sched.h definitions
in their mmu_context.h files.
So include sched.h before mmu_context.h.
commit 858eaaa711700ce4595e039441e239e56d7b9514 upstream.
The recently introduced batched invalidations mechanism uses its own
mechanism for shootdown. However, it does wrong accounting of
interrupts (e.g., inc_irq_stat is called for local invalidations),
trace-points (e.g., TLB_REMOTE_SHOOTDOWN for local invalidations) and
may break some platforms as it bypasses the invalidation mechanisms of
Xen and SGI UV.
This patch reuses the existing TLB flushing mechnaisms instead. We use
NULL as mm to indicate a global invalidation is required.
Fixes 72b252aed506b8 ("mm: send one IPI per CPU to TLB flush all entries after unmapping pages")
Signed-off-by: Nadav Amit <namit@vmware.com>
commit ced108037c2aa542b3ed8b7afd1576064ad1362a upstream.
In case prot_numa, we are under down_read(mmap_sem). It's critical to
not clear pmd intermittently to avoid race with MADV_DONTNEED which is
also under down_read(mmap_sem):
CPU0: CPU1:
change_huge_pmd(prot_numa=1)
pmdp_huge_get_and_clear_notify()
madvise_dontneed()
zap_pmd_range()
pmd_trans_huge(*pmd) == 0 (without ptl)
// skip the pmd
set_pmd_at();
// pmd is re-established
The race makes MADV_DONTNEED miss the huge pmd and don't clear it
which may break userspace.
Found by code analysis, never saw triggered.
Link: http://lkml.kernel.org/r/20170302151034.27829-3-kirill.shutemov@linux.intel.com
Cc: Hillf Danton <hillf.zj@alibaba-inc.com>
[jwang: adjust context for 4.4]
Signed-off-by: Jack Wang <jinpu.wang@profitbricks.com>
commit 0a85e51d37645e9ce57e5e1a30859e07810ed07c upstream.
Patch series "thp: fix few MADV_DONTNEED races"
For MADV_DONTNEED to work properly with huge pages, it's critical to not
clear pmd intermittently unless you hold down_write(mmap_sem).
Otherwise MADV_DONTNEED can miss the THP which can lead to userspace
breakage.
See example of such race in commit message of patch 2/4.
All these races are found by code inspection. I haven't seen them
triggered. I don't think it's worth to apply them to stable@.
This patch (of 4):
Restructure code in preparation for a fix.
Link: http://lkml.kernel.org/r/20170302151034.27829-2-kirill.shutemov@linux.intel.com
[jwang: adjust context for 4.4 kernel]
commit 6ea8d958a2c95a1d514015d4e29ba21a8c0a1a91 upstream.
MADVISE_WILLNEED has always been a noop for DAX (formerly XIP) mappings.
Unfortunately madvise_willneed() doesn't communicate this information
properly to the generic madvise syscall implementation. The calling
convention is quite subtle there. madvise_vma() is supposed to either
return an error or update &prev otherwise the main loop will never
advance to the next vma and it will keep looping for ever without a way
to get out of the kernel.
It seems this has been broken since introduction. Nobody has noticed
because nobody seems to be using MADVISE_WILLNEED on these DAX mappings.
[mhocko@suse.com: rewrite changelog]
Link: http://lkml.kernel.org/r/20171127115318.911-1-guoxuenan@huawei.com
Fixes: fe77ba6f4f97 ("[PATCH] xip: madvice/fadvice: execute in place")
Signed-off-by: chenjie <chenjie6@huawei.com>
Signed-off-by: guoxuenan <guoxuenan@huawei.com>
Cc: zhangyi (F) <yi.zhang@huawei.com>
Cc: Miao Xie <miaoxie@huawei.com>
Cc: Mike Rapoport <rppt@linux.vnet.ibm.com>
Cc: Shaohua Li <shli@fb.com>
Cc: Anshuman Khandual <khandual@linux.vnet.ibm.com>
Cc: Carsten Otte <cotte@de.ibm.com>
Cc: Dan Williams <dan.j.williams@intel.com>
commit a8f97366452ed491d13cf1e44241bc0b5740b1f0 upstream.
Currently, we unconditionally make page table dirty in touch_pmd().
It may result in false-positive can_follow_write_pmd().
We may avoid the situation, if we would only make the page table entry
dirty if caller asks for write access -- FOLL_WRITE.
The patch also changes touch_pud() in the same way.
[Salvatore Bonaccorso: backport for 3.16:
- Adjust context
- Drop specific part for PUD-sized transparent hugepages. Support
for PUD-sized transparent hugepages was added in v4.11-rc1
call sites"
Backport of the upstream commit f86e4271978b ("mm: check the return
value of lookup_page_ext for all call sites") is wrong for hwpoison
pages. I have accidentally negated the condition for bailout. This
basically disables hwpoison pages tracking while the code still
might crash on unusual configurations when struct pages do not have
page_ext allocated. The fix is trivial to invert the condition.
Reported-by: Jiri Slaby <jslaby@suse.cz>
commit 373c4557d2aa362702c4c2d41288fb1e54990b7c upstream.
This matters at least for the mincore syscall, which will otherwise copy
uninitialized memory from the page allocator to userspace. It is
probably also a correctness error for /proc/$pid/pagemap, but I haven't
tested that.
Removing the `walk->hugetlb_entry` condition in walk_hugetlb_range() has
no effect because the caller already checks for that.
This only reports holes in hugetlb ranges to callers who have specified
a hugetlb_entry callback.
This issue was found using an AFL-based fuzzer.
v2:
- don't crash on ->pte_hole==NULL (Andrew Morton)
- add Cc stable (Andrew Morton)
Changed for 4.4/4.9 stable backport:
- fix up conflict in the huge_pte_offset() call
Fixes: 1e25a271c8ac ("mincore: apply page table walker on do_mincore()")
Signed-off-by: Jann Horn <jannh@google.com>
commit e492080e640c2d1235ddf3441cae634cfffef7e1 upstream.
online_page_ext() and page_ext_init() allocate page_ext for each
section, but they do not allocate if the first PFN is !pfn_present(pfn)
or !pfn_valid(pfn). Then section->page_ext remains as NULL.
lookup_page_ext checks NULL only if CONFIG_DEBUG_VM is enabled. For a
valid PFN, __set_page_owner will try to get page_ext through
lookup_page_ext. Without CONFIG_DEBUG_VM lookup_page_ext will misuse
NULL pointer as value 0. This incurrs invalid address access.
This is the panic example when PFN 0x100000 is not valid but PFN
0x13FC00 is being used for page_ext. section->page_ext is NULL,
get_entry returned invalid page_ext address as 0x1DFA000 for a PFN
0x13FC00.
To avoid this panic, CONFIG_DEBUG_VM should be removed so that page_ext
will be checked at all times.
Unable to handle kernel paging request at virtual address 01dfa014
Kernel BUG at ffffff80082371e0 [verbose debug info unavailable]
Internal error: Oops: 96000045 [#1] PREEMPT SMP
Modules linked in:
PC is at __set_page_owner+0x48/0x78
LR is at __set_page_owner+0x44/0x78
get_page_from_freelist+0x880/0x8e8
__alloc_pages_nodemask+0x14c/0xc48
__do_page_cache_readahead+0xdc/0x264
filemap_fault+0x2ac/0x550
ext4_filemap_fault+0x3c/0x58
__do_fault+0x80/0x120
handle_mm_fault+0x704/0xbb0
do_page_fault+0x2e8/0x394
do_mem_abort+0x88/0x124
Pre-4.7 kernels also need commit f86e4271978b ("mm: check the return
value of lookup_page_ext for all call sites").
Link: http://lkml.kernel.org/r/20171107094131.14621-1-jaewon31.kim@samsung.com
Fixes: eefa864b701d ("mm/page_ext: resurrect struct page extending code for debugging")
Signed-off-by: Jaewon Kim <jaewon31.kim@samsung.com>
Cc: Joonsoo Kim <js1304@gmail.com>
