path: root/mm
2019-07-23mm/zswap: Do not disable preemption in zswap_frontswap_store()Luis Claudio R. Goncalves
[ Upstream commit 4e4cf4be79635e67144632d9135286381acbc95a ] Zswap causes "BUG: scheduling while atomic" by blocking on a rt_spin_lock() with preemption disabled. The preemption is disabled by get_cpu_var() in zswap_frontswap_store() to protect the access of the zswap_dstmem percpu variable. Use get_locked_var() to protect the percpu zswap_dstmem variable, making the code preemptive. As get_cpu_ptr() also disables preemption, replace it by this_cpu_ptr() and remove the counterpart put_cpu_ptr(). Steps to Reproduce: 1. # grubby --args "zswap.enabled=1" --update-kernel DEFAULT 2. # reboot 3. Calculate the amount o memory to be used by the test: ---> grep MemAvailable /proc/meminfo ---> Add 25% ~ 50% to that value 4. # stress --vm 1 --vm-bytes ${MemAvailable+25%} --timeout 240s Usually, in less than 5 minutes the backtrace listed below appears, followed by a kernel panic: | BUG: scheduling while atomic: kswapd1/181/0x00000002 | | Preemption disabled at: | [<ffffffff8b2a6cda>] zswap_frontswap_store+0x21a/0x6e1 | | Kernel panic - not syncing: scheduling while atomic | CPU: 14 PID: 181 Comm: kswapd1 Kdump: loaded Not tainted 5.0.14-rt9 #1 | Hardware name: AMD Pence/Pence, BIOS WPN2321X_Weekly_12_03_21 03/19/2012 | Call Trace: | panic+0x106/0x2a7 | __schedule_bug.cold+0x3f/0x51 | __schedule+0x5cb/0x6f0 | schedule+0x43/0xd0 | rt_spin_lock_slowlock_locked+0x114/0x2b0 | rt_spin_lock_slowlock+0x51/0x80 | zbud_alloc+0x1da/0x2d0 | zswap_frontswap_store+0x31a/0x6e1 | __frontswap_store+0xab/0x130 | swap_writepage+0x39/0x70 | pageout.isra.0+0xe3/0x320 | shrink_page_list+0xa8e/0xd10 | shrink_inactive_list+0x251/0x840 | shrink_node_memcg+0x213/0x770 | shrink_node+0xd9/0x450 | balance_pgdat+0x2d5/0x510 | kswapd+0x218/0x470 | kthread+0xfb/0x130 | ret_from_fork+0x27/0x50 Cc: stable-rt@vger.kernel.org Reported-by: Ping Fang <pifang@redhat.com> Signed-off-by: Luis Claudio R. Goncalves <lgoncalv@redhat.com> Reviewed-by: Daniel Bristot de Oliveira <bristot@redhat.com> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
2019-07-19Merge tag 'v4.19.59' into v4.19-rtSteven Rostedt (VMware)
This is the 4.19.59 stable release
2019-07-10mm/vmscan.c: prevent useless kswapd loopsShakeel Butt
commit dffcac2cb88e4ec5906235d64a83d802580b119e upstream. In production we have noticed hard lockups on large machines running large jobs due to kswaps hoarding lru lock within isolate_lru_pages when sc->reclaim_idx is 0 which is a small zone. The lru was couple hundred GiBs and the condition (page_zonenum(page) > sc->reclaim_idx) in isolate_lru_pages() was basically skipping GiBs of pages while holding the LRU spinlock with interrupt disabled. On further inspection, it seems like there are two issues: (1) If kswapd on the return from balance_pgdat() could not sleep (i.e. node is still unbalanced), the classzone_idx is unintentionally set to 0 and the whole reclaim cycle of kswapd will try to reclaim only the lowest and smallest zone while traversing the whole memory. (2) Fundamentally isolate_lru_pages() is really bad when the allocation has woken kswapd for a smaller zone on a very large machine running very large jobs. It can hoard the LRU spinlock while skipping over 100s of GiBs of pages. This patch only fixes (1). (2) needs a more fundamental solution. To fix (1), in the kswapd context, if pgdat->kswapd_classzone_idx is invalid use the classzone_idx of the previous kswapd loop otherwise use the one the waker has requested. Link: http://lkml.kernel.org/r/20190701201847.251028-1-shakeelb@google.com Fixes: e716f2eb24de ("mm, vmscan: prevent kswapd sleeping prematurely due to mismatched classzone_idx") Signed-off-by: Shakeel Butt <shakeelb@google.com> Reviewed-by: Yang Shi <yang.shi@linux.alibaba.com> Acked-by: Mel Gorman <mgorman@techsingularity.net> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Hillf Danton <hdanton@sina.com> Cc: Roman Gushchin <guro@fb.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-07-10mm/mlock.c: change count_mm_mlocked_page_nr return typeswkhack
[ Upstream commit 0874bb49bb21bf24deda853e8bf61b8325e24bcb ] On a 64-bit machine the value of "vma->vm_end - vma->vm_start" may be negative when using 32 bit ints and the "count >> PAGE_SHIFT"'s result will be wrong. So change the local variable and return value to unsigned long to fix the problem. Link: http://lkml.kernel.org/r/20190513023701.83056-1-swkhack@gmail.com Fixes: 0cf2f6f6dc60 ("mm: mlock: check against vma for actual mlock() size") Signed-off-by: swkhack <swkhack@gmail.com> Acked-by: Michal Hocko <mhocko@suse.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-07-03mm/page_idle.c: fix oops because end_pfn is larger than max_pfnColin Ian King
commit 7298e3b0a149c91323b3205d325e942c3b3b9ef6 upstream. Currently the calcuation of end_pfn can round up the pfn number to more than the actual maximum number of pfns, causing an Oops. Fix this by ensuring end_pfn is never more than max_pfn. This can be easily triggered when on systems where the end_pfn gets rounded up to more than max_pfn using the idle-page stress-ng stress test: sudo stress-ng --idle-page 0 BUG: unable to handle kernel paging request at 00000000000020d8 #PF error: [normal kernel read fault] PGD 0 P4D 0 Oops: 0000 [#1] SMP PTI CPU: 1 PID: 11039 Comm: stress-ng-idle- Not tainted 5.0.0-5-generic #6-Ubuntu Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1ubuntu1 04/01/2014 RIP: 0010:page_idle_get_page+0xc8/0x1a0 Code: 0f b1 0a 75 7d 48 8b 03 48 89 c2 48 c1 e8 33 83 e0 07 48 c1 ea 36 48 8d 0c 40 4c 8d 24 88 49 c1 e4 07 4c 03 24 d5 00 89 c3 be <49> 8b 44 24 58 48 8d b8 80 a1 02 00 e8 07 d5 77 00 48 8b 53 08 48 RSP: 0018:ffffafd7c672fde8 EFLAGS: 00010202 RAX: 0000000000000005 RBX: ffffe36341fff700 RCX: 000000000000000f RDX: 0000000000000284 RSI: 0000000000000275 RDI: 0000000001fff700 RBP: ffffafd7c672fe00 R08: ffffa0bc34056410 R09: 0000000000000276 R10: ffffa0bc754e9b40 R11: ffffa0bc330f6400 R12: 0000000000002080 R13: ffffe36341fff700 R14: 0000000000080000 R15: ffffa0bc330f6400 FS: 00007f0ec1ea5740(0000) GS:ffffa0bc7db00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 00000000000020d8 CR3: 0000000077d68000 CR4: 00000000000006e0 Call Trace: page_idle_bitmap_write+0x8c/0x140 sysfs_kf_bin_write+0x5c/0x70 kernfs_fop_write+0x12e/0x1b0 __vfs_write+0x1b/0x40 vfs_write+0xab/0x1b0 ksys_write+0x55/0xc0 __x64_sys_write+0x1a/0x20 do_syscall_64+0x5a/0x110 entry_SYSCALL_64_after_hwframe+0x44/0xa9 Link: http://lkml.kernel.org/r/20190618124352.28307-1-colin.king@canonical.com Fixes: 33c3fc71c8cf ("mm: introduce idle page tracking") Signed-off-by: Colin Ian King <colin.king@canonical.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Vladimir Davydov <vdavydov.dev@gmail.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Mike Rapoport <rppt@linux.vnet.ibm.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-07-03mm: hugetlb: soft-offline: dissolve_free_huge_page() return zero on !PageHugeNaoya Horiguchi
commit faf53def3b143df11062d87c12afe6afeb6f8cc7 upstream. madvise(MADV_SOFT_OFFLINE) often returns -EBUSY when calling soft offline for hugepages with overcommitting enabled. That was caused by the suboptimal code in current soft-offline code. See the following part: ret = migrate_pages(&pagelist, new_page, NULL, MPOL_MF_MOVE_ALL, MIGRATE_SYNC, MR_MEMORY_FAILURE); if (ret) { ... } else { /* * We set PG_hwpoison only when the migration source hugepage * was successfully dissolved, because otherwise hwpoisoned * hugepage remains on free hugepage list, then userspace will * find it as SIGBUS by allocation failure. That's not expected * in soft-offlining. */ ret = dissolve_free_huge_page(page); if (!ret) { if (set_hwpoison_free_buddy_page(page)) num_poisoned_pages_inc(); } } return ret; Here dissolve_free_huge_page() returns -EBUSY if the migration source page was freed into buddy in migrate_pages(), but even in that case we actually has a chance that set_hwpoison_free_buddy_page() succeeds. So that means current code gives up offlining too early now. dissolve_free_huge_page() checks that a given hugepage is suitable for dissolving, where we should return success for !PageHuge() case because the given hugepage is considered as already dissolved. This change also affects other callers of dissolve_free_huge_page(), which are cleaned up together. [n-horiguchi@ah.jp.nec.com: v3] Link: http://lkml.kernel.org/r/1560761476-4651-3-git-send-email-n-horiguchi@ah.jp.nec.comLink: http://lkml.kernel.org/r/1560154686-18497-3-git-send-email-n-horiguchi@ah.jp.nec.com Fixes: 6bc9b56433b76 ("mm: fix race on soft-offlining") Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Reported-by: Chen, Jerry T <jerry.t.chen@intel.com> Tested-by: Chen, Jerry T <jerry.t.chen@intel.com> Reviewed-by: Mike Kravetz <mike.kravetz@oracle.com> Reviewed-by: Oscar Salvador <osalvador@suse.de> Cc: Michal Hocko <mhocko@kernel.org> Cc: Xishi Qiu <xishi.qiuxishi@alibaba-inc.com> Cc: "Chen, Jerry T" <jerry.t.chen@intel.com> Cc: "Zhuo, Qiuxu" <qiuxu.zhuo@intel.com> Cc: <stable@vger.kernel.org> [4.19+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-07-03mm: soft-offline: return -EBUSY if set_hwpoison_free_buddy_page() failsNaoya Horiguchi
commit b38e5962f8ed0d2a2b28a887fc2221f7f41db119 upstream. The pass/fail of soft offline should be judged by checking whether the raw error page was finally contained or not (i.e. the result of set_hwpoison_free_buddy_page()), but current code do not work like that. It might lead us to misjudge the test result when set_hwpoison_free_buddy_page() fails. Without this fix, there are cases where madvise(MADV_SOFT_OFFLINE) may not offline the original page and will not return an error. Link: http://lkml.kernel.org/r/1560154686-18497-2-git-send-email-n-horiguchi@ah.jp.nec.com Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Fixes: 6bc9b56433b76 ("mm: fix race on soft-offlining") Reviewed-by: Mike Kravetz <mike.kravetz@oracle.com> Reviewed-by: Oscar Salvador <osalvador@suse.de> Cc: Michal Hocko <mhocko@kernel.org> Cc: Xishi Qiu <xishi.qiuxishi@alibaba-inc.com> Cc: "Chen, Jerry T" <jerry.t.chen@intel.com> Cc: "Zhuo, Qiuxu" <qiuxu.zhuo@intel.com> Cc: <stable@vger.kernel.org> [4.19+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-07-03mm/mempolicy.c: fix an incorrect rebind node in mpol_rebind_nodemaskzhong jiang
commit 29b190fa774dd1b72a1a6f19687d55dc72ea83be upstream. mpol_rebind_nodemask() is called for MPOL_BIND and MPOL_INTERLEAVE mempoclicies when the tasks's cpuset's mems_allowed changes. For policies created without MPOL_F_STATIC_NODES or MPOL_F_RELATIVE_NODES, it works by remapping the policy's allowed nodes (stored in v.nodes) using the previous value of mems_allowed (stored in w.cpuset_mems_allowed) as the domain of map and the new mems_allowed (passed as nodes) as the range of the map (see the comment of bitmap_remap() for details). The result of remapping is stored back as policy's nodemask in v.nodes, and the new value of mems_allowed should be stored in w.cpuset_mems_allowed to facilitate the next rebind, if it happens. However, 213980c0f23b ("mm, mempolicy: simplify rebinding mempolicies when updating cpusets") introduced a bug where the result of remapping is stored in w.cpuset_mems_allowed instead. Thus, a mempolicy's allowed nodes can evolve in an unexpected way after a series of rebinding due to cpuset mems_allowed changes, possibly binding to a wrong node or a smaller number of nodes which may e.g. overload them. This patch fixes the bug so rebinding again works as intended. [vbabka@suse.cz: new changlog] Link: http://lkml.kernel.org/r/ef6a69c6-c052-b067-8f2c-9d615c619bb9@suse.cz Link: http://lkml.kernel.org/r/1558768043-23184-1-git-send-email-zhongjiang@huawei.com Fixes: 213980c0f23b ("mm, mempolicy: simplify rebinding mempolicies when updating cpusets") Signed-off-by: zhong jiang <zhongjiang@huawei.com> Reviewed-by: Vlastimil Babka <vbabka@suse.cz> Cc: Oscar Salvador <osalvador@suse.de> Cc: Anshuman Khandual <khandual@linux.vnet.ibm.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Ralph Campbell <rcampbell@nvidia.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-06-22coredump: fix race condition between collapse_huge_page() and core dumpingAndrea Arcangeli
commit 59ea6d06cfa9247b586a695c21f94afa7183af74 upstream. When fixing the race conditions between the coredump and the mmap_sem holders outside the context of the process, we focused on mmget_not_zero()/get_task_mm() callers in 04f5866e41fb70 ("coredump: fix race condition between mmget_not_zero()/get_task_mm() and core dumping"), but those aren't the only cases where the mmap_sem can be taken outside of the context of the process as Michal Hocko noticed while backporting that commit to older -stable kernels. If mmgrab() is called in the context of the process, but then the mm_count reference is transferred outside the context of the process, that can also be a problem if the mmap_sem has to be taken for writing through that mm_count reference. khugepaged registration calls mmgrab() in the context of the process, but the mmap_sem for writing is taken later in the context of the khugepaged kernel thread. collapse_huge_page() after taking the mmap_sem for writing doesn't modify any vma, so it's not obvious that it could cause a problem to the coredump, but it happens to modify the pmd in a way that breaks an invariant that pmd_trans_huge_lock() relies upon. collapse_huge_page() needs the mmap_sem for writing just to block concurrent page faults that call pmd_trans_huge_lock(). Specifically the invariant that "!pmd_trans_huge()" cannot become a "pmd_trans_huge()" doesn't hold while collapse_huge_page() runs. The coredump will call __get_user_pages() without mmap_sem for reading, which eventually can invoke a lockless page fault which will need a functional pmd_trans_huge_lock(). So collapse_huge_page() needs to use mmget_still_valid() to check it's not running concurrently with the coredump... as long as the coredump can invoke page faults without holding the mmap_sem for reading. This has "Fixes: khugepaged" to facilitate backporting, but in my view it's more a bug in the coredump code that will eventually have to be rewritten to stop invoking page faults without the mmap_sem for reading. So the long term plan is still to drop all mmget_still_valid(). Link: http://lkml.kernel.org/r/20190607161558.32104-1-aarcange@redhat.com Fixes: ba76149f47d8 ("thp: khugepaged") Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Reported-by: Michal Hocko <mhocko@suse.com> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Jann Horn <jannh@google.com> Cc: Hugh Dickins <hughd@google.com> Cc: Mike Rapoport <rppt@linux.vnet.ibm.com> Cc: Mike Kravetz <mike.kravetz@oracle.com> Cc: Peter Xu <peterx@redhat.com> Cc: Jason Gunthorpe <jgg@mellanox.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-06-19mm/vmscan.c: fix trying to reclaim unevictable LRU pageMinchan Kim
commit a58f2cef26e1ca44182c8b22f4f4395e702a5795 upstream. There was the below bug report from Wu Fangsuo. On the CMA allocation path, isolate_migratepages_range() could isolate unevictable LRU pages and reclaim_clean_page_from_list() can try to reclaim them if they are clean file-backed pages. page:ffffffbf02f33b40 count:86 mapcount:84 mapping:ffffffc08fa7a810 index:0x24 flags: 0x19040c(referenced|uptodate|arch_1|mappedtodisk|unevictable|mlocked) raw: 000000000019040c ffffffc08fa7a810 0000000000000024 0000005600000053 raw: ffffffc009b05b20 ffffffc009b05b20 0000000000000000 ffffffc09bf3ee80 page dumped because: VM_BUG_ON_PAGE(PageLRU(page) || PageUnevictable(page)) page->mem_cgroup:ffffffc09bf3ee80 ------------[ cut here ]------------ kernel BUG at /home/build/farmland/adroid9.0/kernel/linux/mm/vmscan.c:1350! Internal error: Oops - BUG: 0 [#1] PREEMPT SMP Modules linked in: CPU: 0 PID: 7125 Comm: syz-executor Tainted: G S 4.14.81 #3 Hardware name: ASR AQUILAC EVB (DT) task: ffffffc00a54cd00 task.stack: ffffffc009b00000 PC is at shrink_page_list+0x1998/0x3240 LR is at shrink_page_list+0x1998/0x3240 pc : [<ffffff90083a2158>] lr : [<ffffff90083a2158>] pstate: 60400045 sp : ffffffc009b05940 .. shrink_page_list+0x1998/0x3240 reclaim_clean_pages_from_list+0x3c0/0x4f0 alloc_contig_range+0x3bc/0x650 cma_alloc+0x214/0x668 ion_cma_allocate+0x98/0x1d8 ion_alloc+0x200/0x7e0 ion_ioctl+0x18c/0x378 do_vfs_ioctl+0x17c/0x1780 SyS_ioctl+0xac/0xc0 Wu found it's due to commit ad6b67041a45 ("mm: remove SWAP_MLOCK in ttu"). Before that, unevictable pages go to cull_mlocked so that we can't reach the VM_BUG_ON_PAGE line. To fix the issue, this patch filters out unevictable LRU pages from the reclaim_clean_pages_from_list in CMA. Link: http://lkml.kernel.org/r/20190524071114.74202-1-minchan@kernel.org Fixes: ad6b67041a45 ("mm: remove SWAP_MLOCK in ttu") Signed-off-by: Minchan Kim <minchan@kernel.org> Reported-by: Wu Fangsuo <fangsuowu@asrmicro.com> Debugged-by: Wu Fangsuo <fangsuowu@asrmicro.com> Tested-by: Wu Fangsuo <fangsuowu@asrmicro.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Pankaj Suryawanshi <pankaj.suryawanshi@einfochips.com> Cc: <stable@vger.kernel.org> [4.12+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-06-19mm/list_lru.c: fix memory leak in __memcg_init_list_lru_nodeShakeel Butt
commit 3510955b327176fd4cbab5baa75b449f077722a2 upstream. Syzbot reported following memory leak: ffffffffda RBX: 0000000000000003 RCX: 0000000000441f79 BUG: memory leak unreferenced object 0xffff888114f26040 (size 32): comm "syz-executor626", pid 7056, jiffies 4294948701 (age 39.410s) hex dump (first 32 bytes): 40 60 f2 14 81 88 ff ff 40 60 f2 14 81 88 ff ff @`......@`...... 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ backtrace: slab_post_alloc_hook mm/slab.h:439 [inline] slab_alloc mm/slab.c:3326 [inline] kmem_cache_alloc_trace+0x13d/0x280 mm/slab.c:3553 kmalloc include/linux/slab.h:547 [inline] __memcg_init_list_lru_node+0x58/0xf0 mm/list_lru.c:352 memcg_init_list_lru_node mm/list_lru.c:375 [inline] memcg_init_list_lru mm/list_lru.c:459 [inline] __list_lru_init+0x193/0x2a0 mm/list_lru.c:626 alloc_super+0x2e0/0x310 fs/super.c:269 sget_userns+0x94/0x2a0 fs/super.c:609 sget+0x8d/0xb0 fs/super.c:660 mount_nodev+0x31/0xb0 fs/super.c:1387 fuse_mount+0x2d/0x40 fs/fuse/inode.c:1236 legacy_get_tree+0x27/0x80 fs/fs_context.c:661 vfs_get_tree+0x2e/0x120 fs/super.c:1476 do_new_mount fs/namespace.c:2790 [inline] do_mount+0x932/0xc50 fs/namespace.c:3110 ksys_mount+0xab/0x120 fs/namespace.c:3319 __do_sys_mount fs/namespace.c:3333 [inline] __se_sys_mount fs/namespace.c:3330 [inline] __x64_sys_mount+0x26/0x30 fs/namespace.c:3330 do_syscall_64+0x76/0x1a0 arch/x86/entry/common.c:301 entry_SYSCALL_64_after_hwframe+0x44/0xa9 This is a simple off by one bug on the error path. Link: http://lkml.kernel.org/r/20190528043202.99980-1-shakeelb@google.com Fixes: 60d3fd32a7a9 ("list_lru: introduce per-memcg lists") Reported-by: syzbot+f90a420dfe2b1b03cb2c@syzkaller.appspotmail.com Signed-off-by: Shakeel Butt <shakeelb@google.com> Acked-by: Michal Hocko <mhocko@suse.com> Reviewed-by: Kirill Tkhai <ktkhai@virtuozzo.com> Cc: <stable@vger.kernel.org> [4.0+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-06-15percpu: do not search past bitmap when allocating an areaDennis Zhou
[ Upstream commit 8c43004af01635cc9fbb11031d070e5e0d327ef2 ] pcpu_find_block_fit() guarantees that a fit is found within PCPU_BITMAP_BLOCK_BITS. Iteration is used to determine the first fit as it compares against the block's contig_hint. This can lead to incorrectly scanning past the end of the bitmap. The behavior was okay given the check after for bit_off >= end and the correctness of the hints from pcpu_find_block_fit(). This patch fixes this by bounding the end offset by the number of bits in a chunk. Signed-off-by: Dennis Zhou <dennis@kernel.org> Reviewed-by: Peng Fan <peng.fan@nxp.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-06-15percpu: remove spurious lock dependency between percpu and schedJohn Sperbeck
[ Upstream commit 198790d9a3aeaef5792d33a560020861126edc22 ] In free_percpu() we sometimes call pcpu_schedule_balance_work() to queue a work item (which does a wakeup) while holding pcpu_lock. This creates an unnecessary lock dependency between pcpu_lock and the scheduler's pi_lock. There are other places where we call pcpu_schedule_balance_work() without hold pcpu_lock, and this case doesn't need to be different. Moving the call outside the lock prevents the following lockdep splat when running tools/testing/selftests/bpf/{test_maps,test_progs} in sequence with lockdep enabled: ====================================================== WARNING: possible circular locking dependency detected 5.1.0-dbg-DEV #1 Not tainted ------------------------------------------------------ kworker/23:255/18872 is trying to acquire lock: 000000000bc79290 (&(&pool->lock)->rlock){-.-.}, at: __queue_work+0xb2/0x520 but task is already holding lock: 00000000e3e7a6aa (pcpu_lock){..-.}, at: free_percpu+0x36/0x260 which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #4 (pcpu_lock){..-.}: lock_acquire+0x9e/0x180 _raw_spin_lock_irqsave+0x3a/0x50 pcpu_alloc+0xfa/0x780 __alloc_percpu_gfp+0x12/0x20 alloc_htab_elem+0x184/0x2b0 __htab_percpu_map_update_elem+0x252/0x290 bpf_percpu_hash_update+0x7c/0x130 __do_sys_bpf+0x1912/0x1be0 __x64_sys_bpf+0x1a/0x20 do_syscall_64+0x59/0x400 entry_SYSCALL_64_after_hwframe+0x49/0xbe -> #3 (&htab->buckets[i].lock){....}: lock_acquire+0x9e/0x180 _raw_spin_lock_irqsave+0x3a/0x50 htab_map_update_elem+0x1af/0x3a0 -> #2 (&rq->lock){-.-.}: lock_acquire+0x9e/0x180 _raw_spin_lock+0x2f/0x40 task_fork_fair+0x37/0x160 sched_fork+0x211/0x310 copy_process.part.43+0x7b1/0x2160 _do_fork+0xda/0x6b0 kernel_thread+0x29/0x30 rest_init+0x22/0x260 arch_call_rest_init+0xe/0x10 start_kernel+0x4fd/0x520 x86_64_start_reservations+0x24/0x26 x86_64_start_kernel+0x6f/0x72 secondary_startup_64+0xa4/0xb0 -> #1 (&p->pi_lock){-.-.}: lock_acquire+0x9e/0x180 _raw_spin_lock_irqsave+0x3a/0x50 try_to_wake_up+0x41/0x600 wake_up_process+0x15/0x20 create_worker+0x16b/0x1e0 workqueue_init+0x279/0x2ee kernel_init_freeable+0xf7/0x288 kernel_init+0xf/0x180 ret_from_fork+0x24/0x30 -> #0 (&(&pool->lock)->rlock){-.-.}: __lock_acquire+0x101f/0x12a0 lock_acquire+0x9e/0x180 _raw_spin_lock+0x2f/0x40 __queue_work+0xb2/0x520 queue_work_on+0x38/0x80 free_percpu+0x221/0x260 pcpu_freelist_destroy+0x11/0x20 stack_map_free+0x2a/0x40 bpf_map_free_deferred+0x3c/0x50 process_one_work+0x1f7/0x580 worker_thread+0x54/0x410 kthread+0x10f/0x150 ret_from_fork+0x24/0x30 other info that might help us debug this: Chain exists of: &(&pool->lock)->rlock --> &htab->buckets[i].lock --> pcpu_lock Possible unsafe locking scenario: CPU0 CPU1 ---- ---- lock(pcpu_lock); lock(&htab->buckets[i].lock); lock(pcpu_lock); lock(&(&pool->lock)->rlock); *** DEADLOCK *** 3 locks held by kworker/23:255/18872: #0: 00000000b36a6e16 ((wq_completion)events){+.+.}, at: process_one_work+0x17a/0x580 #1: 00000000dfd966f0 ((work_completion)(&map->work)){+.+.}, at: process_one_work+0x17a/0x580 #2: 00000000e3e7a6aa (pcpu_lock){..-.}, at: free_percpu+0x36/0x260 stack backtrace: CPU: 23 PID: 18872 Comm: kworker/23:255 Not tainted 5.1.0-dbg-DEV #1 Hardware name: ... Workqueue: events bpf_map_free_deferred Call Trace: dump_stack+0x67/0x95 print_circular_bug.isra.38+0x1c6/0x220 check_prev_add.constprop.50+0x9f6/0xd20 __lock_acquire+0x101f/0x12a0 lock_acquire+0x9e/0x180 _raw_spin_lock+0x2f/0x40 __queue_work+0xb2/0x520 queue_work_on+0x38/0x80 free_percpu+0x221/0x260 pcpu_freelist_destroy+0x11/0x20 stack_map_free+0x2a/0x40 bpf_map_free_deferred+0x3c/0x50 process_one_work+0x1f7/0x580 worker_thread+0x54/0x410 kthread+0x10f/0x150 ret_from_fork+0x24/0x30 Signed-off-by: John Sperbeck <jsperbeck@google.com> Signed-off-by: Dennis Zhou <dennis@kernel.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-06-15mm/slab.c: fix an infinite loop in leaks_show()Qian Cai
[ Upstream commit 745e10146c31b1c6ed3326286704ae251b17f663 ] "cat /proc/slab_allocators" could hang forever on SMP machines with kmemleak or object debugging enabled due to other CPUs running do_drain() will keep making kmemleak_object or debug_objects_cache dirty and unable to escape the first loop in leaks_show(), do { set_store_user_clean(cachep); drain_cpu_caches(cachep); ... } while (!is_store_user_clean(cachep)); For example, do_drain slabs_destroy slab_destroy kmem_cache_free __cache_free ___cache_free kmemleak_free_recursive delete_object_full __delete_object put_object free_object_rcu kmem_cache_free cache_free_debugcheck --> dirty kmemleak_object One approach is to check cachep->name and skip both kmemleak_object and debug_objects_cache in leaks_show(). The other is to set store_user_clean after drain_cpu_caches() which leaves a small window between drain_cpu_caches() and set_store_user_clean() where per-CPU caches could be dirty again lead to slightly wrong information has been stored but could also speed up things significantly which sounds like a good compromise. For example, # cat /proc/slab_allocators 0m42.778s # 1st approach 0m0.737s # 2nd approach [akpm@linux-foundation.org: tweak comment] Link: http://lkml.kernel.org/r/20190411032635.10325-1-cai@lca.pw Fixes: d31676dfde25 ("mm/slab: alternative implementation for DEBUG_SLAB_LEAK") Signed-off-by: Qian Cai <cai@lca.pw> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-06-15mm/cma_debug.c: fix the break condition in cma_maxchunk_get()Yue Hu
[ Upstream commit f0fd50504a54f5548eb666dc16ddf8394e44e4b7 ] If not find zero bit in find_next_zero_bit(), it will return the size parameter passed in, so the start bit should be compared with bitmap_maxno rather than cma->count. Although getting maxchunk is working fine due to zero value of order_per_bit currently, the operation will be stuck if order_per_bit is set as non-zero. Link: http://lkml.kernel.org/r/20190319092734.276-1-zbestahu@gmail.com Signed-off-by: Yue Hu <huyue2@yulong.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Michal Hocko <mhocko@suse.com> Cc: Joe Perches <joe@perches.com> Cc: David Rientjes <rientjes@google.com> Cc: Dmitry Safonov <d.safonov@partner.samsung.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-06-15mm: page_mkclean vs MADV_DONTNEED raceAneesh Kumar K.V
[ Upstream commit 024eee0e83f0df52317be607ca521e0fc572aa07 ] MADV_DONTNEED is handled with mmap_sem taken in read mode. We call page_mkclean without holding mmap_sem. MADV_DONTNEED implies that pages in the region are unmapped and subsequent access to the pages in that range is handled as a new page fault. This implies that if we don't have parallel access to the region when MADV_DONTNEED is run we expect those range to be unallocated. w.r.t page_mkclean() we need to make sure that we don't break the MADV_DONTNEED semantics. MADV_DONTNEED check for pmd_none without holding pmd_lock. This implies we skip the pmd if we temporarily mark pmd none. Avoid doing that while marking the page clean. Keep the sequence same for dax too even though we don't support MADV_DONTNEED for dax mapping The bug was noticed by code review and I didn't observe any failures w.r.t test run. This is similar to commit 58ceeb6bec86d9140f9d91d71a710e963523d063 Author: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Date: Thu Apr 13 14:56:26 2017 -0700 thp: fix MADV_DONTNEED vs. MADV_FREE race commit ced108037c2aa542b3ed8b7afd1576064ad1362a Author: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Date: Thu Apr 13 14:56:20 2017 -0700 thp: fix MADV_DONTNEED vs. numa balancing race Link: http://lkml.kernel.org/r/20190321040610.14226-1-aneesh.kumar@linux.ibm.com Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.ibm.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Dan Williams <dan.j.williams@intel.com> Cc:"Kirill A . Shutemov" <kirill@shutemov.name> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-06-15mm/cma.c: fix the bitmap status to show failed allocation reasonYue Hu
[ Upstream commit 2b59e01a3aa665f751d1410b99fae9336bd424e1 ] Currently one bit in cma bitmap represents number of pages rather than one page, cma->count means cma size in pages. So to find available pages via find_next_zero_bit()/find_next_bit() we should use cma size not in pages but in bits although current free pages number is correct due to zero value of order_per_bit. Once order_per_bit is changed the bitmap status will be incorrect. The size input in cma_debug_show_areas() is not correct. It will affect the available pages at some position to debug the failure issue. This is an example with order_per_bit = 1 Before this change: [ 4.120060] cma: number of available pages: 1@93+4@108+7@121+7@137+7@153+7@169+7@185+7@201+3@213+3@221+3@229+3@237+3@245+3@253+3@261+3@269+3@277+3@285+3@293+3@301+3@309+3@317+3@325+19@333+15@369+512@512=> 638 free of 1024 total pages After this change: [ 4.143234] cma: number of available pages: 2@93+8@108+14@121+14@137+14@153+14@169+14@185+14@201+6@213+6@221+6@229+6@237+6@245+6@253+6@261+6@269+6@277+6@285+6@293+6@301+6@309+6@317+6@325+38@333+30@369=> 252 free of 1024 total pages Obviously the bitmap status before is incorrect. Link: http://lkml.kernel.org/r/20190320060829.9144-1-zbestahu@gmail.com Signed-off-by: Yue Hu <huyue2@yulong.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Mike Rapoport <rppt@linux.vnet.ibm.com> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Laura Abbott <labbott@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-06-15mm/cma.c: fix crash on CMA allocation if bitmap allocation failsYue Hu
[ Upstream commit 1df3a339074e31db95c4790ea9236874b13ccd87 ] f022d8cb7ec7 ("mm: cma: Don't crash on allocation if CMA area can't be activated") fixes the crash issue when activation fails via setting cma->count as 0, same logic exists if bitmap allocation fails. Link: http://lkml.kernel.org/r/20190325081309.6004-1-zbestahu@gmail.com Signed-off-by: Yue Hu <huyue2@yulong.com> Reviewed-by: Anshuman Khandual <anshuman.khandual@arm.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Laura Abbott <labbott@redhat.com> Cc: Mike Rapoport <rppt@linux.vnet.ibm.com> Cc: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-06-15mem-hotplug: fix node spanned pages when we have a node with only ZONE_MOVABLELinxu Fang
[ Upstream commit 299c83dce9ea3a79bb4b5511d2cb996b6b8e5111 ] 342332e6a925 ("mm/page_alloc.c: introduce kernelcore=mirror option") and later patches rewrote the calculation of node spanned pages. e506b99696a2 ("mem-hotplug: fix node spanned pages when we have a movable node"), but the current code still has problems, When we have a node with only zone_movable and the node id is not zero, the size of node spanned pages is double added. That's because we have an empty normal zone, and zone_start_pfn or zone_end_pfn is not between arch_zone_lowest_possible_pfn and arch_zone_highest_possible_pfn, so we need to use clamp to constrain the range just like the commit <96e907d13602> (bootmem: Reimplement __absent_pages_in_range() using for_each_mem_pfn_range()). e.g. Zone ranges: DMA [mem 0x0000000000001000-0x0000000000ffffff] DMA32 [mem 0x0000000001000000-0x00000000ffffffff] Normal [mem 0x0000000100000000-0x000000023fffffff] Movable zone start for each node Node 0: 0x0000000100000000 Node 1: 0x0000000140000000 Early memory node ranges node 0: [mem 0x0000000000001000-0x000000000009efff] node 0: [mem 0x0000000000100000-0x00000000bffdffff] node 0: [mem 0x0000000100000000-0x000000013fffffff] node 1: [mem 0x0000000140000000-0x000000023fffffff] node 0 DMA spanned:0xfff present:0xf9e absent:0x61 node 0 DMA32 spanned:0xff000 present:0xbefe0 absent:0x40020 node 0 Normal spanned:0 present:0 absent:0 node 0 Movable spanned:0x40000 present:0x40000 absent:0 On node 0 totalpages(node_present_pages): 1048446 node_spanned_pages:1310719 node 1 DMA spanned:0 present:0 absent:0 node 1 DMA32 spanned:0 present:0 absent:0 node 1 Normal spanned:0x100000 present:0x100000 absent:0 node 1 Movable spanned:0x100000 present:0x100000 absent:0 On node 1 totalpages(node_present_pages): 2097152 node_spanned_pages:2097152 Memory: 6967796K/12582392K available (16388K kernel code, 3686K rwdata, 4468K rodata, 2160K init, 10444K bss, 5614596K reserved, 0K cma-reserved) It shows that the current memory of node 1 is double added. After this patch, the problem is fixed. node 0 DMA spanned:0xfff present:0xf9e absent:0x61 node 0 DMA32 spanned:0xff000 present:0xbefe0 absent:0x40020 node 0 Normal spanned:0 present:0 absent:0 node 0 Movable spanned:0x40000 present:0x40000 absent:0 On node 0 totalpages(node_present_pages): 1048446 node_spanned_pages:1310719 node 1 DMA spanned:0 present:0 absent:0 node 1 DMA32 spanned:0 present:0 absent:0 node 1 Normal spanned:0 present:0 absent:0 node 1 Movable spanned:0x100000 present:0x100000 absent:0 On node 1 totalpages(node_present_pages): 1048576 node_spanned_pages:1048576 memory: 6967796K/8388088K available (16388K kernel code, 3686K rwdata, 4468K rodata, 2160K init, 10444K bss, 1420292K reserved, 0K cma-reserved) Link: http://lkml.kernel.org/r/1554178276-10372-1-git-send-email-fanglinxu@huawei.com Signed-off-by: Linxu Fang <fanglinxu@huawei.com> Cc: Taku Izumi <izumi.taku@jp.fujitsu.com> Cc: Xishi Qiu <qiuxishi@huawei.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Pavel Tatashin <pavel.tatashin@microsoft.com> Cc: Oscar Salvador <osalvador@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-06-15hugetlbfs: on restore reserve error path retain subpool reservationMike Kravetz
[ Upstream commit 0919e1b69ab459e06df45d3ba6658d281962db80 ] When a huge page is allocated, PagePrivate() is set if the allocation consumed a reservation. When freeing a huge page, PagePrivate is checked. If set, it indicates the reservation should be restored. PagePrivate being set at free huge page time mostly happens on error paths. When huge page reservations are created, a check is made to determine if the mapping is associated with an explicitly mounted filesystem. If so, pages are also reserved within the filesystem. The default action when freeing a huge page is to decrement the usage count in any associated explicitly mounted filesystem. However, if the reservation is to be restored the reservation/use count within the filesystem should not be decrementd. Otherwise, a subsequent page allocation and free for the same mapping location will cause the file filesystem usage to go 'negative'. Filesystem Size Used Avail Use% Mounted on nodev 4.0G -4.0M 4.1G - /opt/hugepool To fix, when freeing a huge page do not adjust filesystem usage if PagePrivate() is set to indicate the reservation should be restored. I did not cc stable as the problem has been around since reserves were added to hugetlbfs and nobody has noticed. Link: http://lkml.kernel.org/r/20190328234704.27083-2-mike.kravetz@oracle.com Signed-off-by: Mike Kravetz <mike.kravetz@oracle.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Davidlohr Bueso <dave@stgolabs.net> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: "Kirill A . Shutemov" <kirill.shutemov@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-06-15mm/hmm: select mmu notifier when selecting HMMJérôme Glisse
[ Upstream commit 734fb89968900b5c5f8edd5038bd4cdeab8c61d2 ] To avoid random config build issue, select mmu notifier when HMM is selected. In any cases when HMM get selected it will be by users that will also wants the mmu notifier. Link: http://lkml.kernel.org/r/20190403193318.16478-2-jglisse@redhat.com Signed-off-by: Jérôme Glisse <jglisse@redhat.com> Acked-by: Balbir Singh <bsingharora@gmail.com> Cc: Ralph Campbell <rcampbell@nvidia.com> Cc: John Hubbard <jhubbard@nvidia.com> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Dan Carpenter <dan.carpenter@oracle.com> Cc: Ira Weiny <ira.weiny@intel.com> Cc: Matthew Wilcox <willy@infradead.org> Cc: Souptick Joarder <jrdr.linux@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-06-14Merge tag 'v4.19.50' into v4.19-rtSteven Rostedt (VMware)
This is the 4.19.50 stable release
2019-06-14Merge tag 'v4.19.47' into v4.19-rtSteven Rostedt (VMware)
This is the 4.19.47 stable release Conflicts: drivers/char/random.c kernel/irq_work.c Issues with kernel/irq/manage.c A use after free bug was fixed in stable. But it requires a backport of changes from rt-devel. The bug still exists in this tree for PREEMPT_RT, but will be fixed when backporting the rt-devel patches.
2019-06-09memcg: make it work on sparse non-0-node systemsJiri Slaby
commit 3e8589963773a5c23e2f1fe4bcad0e9a90b7f471 upstream. We have a single node system with node 0 disabled: Scanning NUMA topology in Northbridge 24 Number of physical nodes 2 Skipping disabled node 0 Node 1 MemBase 0000000000000000 Limit 00000000fbff0000 NODE_DATA(1) allocated [mem 0xfbfda000-0xfbfeffff] This causes crashes in memcg when system boots: BUG: unable to handle kernel NULL pointer dereference at 0000000000000008 #PF error: [normal kernel read fault] ... RIP: 0010:list_lru_add+0x94/0x170 ... Call Trace: d_lru_add+0x44/0x50 dput.part.34+0xfc/0x110 __fput+0x108/0x230 task_work_run+0x9f/0xc0 exit_to_usermode_loop+0xf5/0x100 It is reproducible as far as 4.12. I did not try older kernels. You have to have a new enough systemd, e.g. 241 (the reason is unknown -- was not investigated). Cannot be reproduced with systemd 234. The system crashes because the size of lru array is never updated in memcg_update_all_list_lrus and the reads are past the zero-sized array, causing dereferences of random memory. The root cause are list_lru_memcg_aware checks in the list_lru code. The test in list_lru_memcg_aware is broken: it assumes node 0 is always present, but it is not true on some systems as can be seen above. So fix this by avoiding checks on node 0. Remember the memcg-awareness by a bool flag in struct list_lru. Link: http://lkml.kernel.org/r/20190522091940.3615-1-jslaby@suse.cz Fixes: 60d3fd32a7a9 ("list_lru: introduce per-memcg lists") Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Michal Hocko <mhocko@suse.com> Suggested-by: Vladimir Davydov <vdavydov.dev@gmail.com> Acked-by: Vladimir Davydov <vdavydov.dev@gmail.com> Reviewed-by: Shakeel Butt <shakeelb@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-22hugetlb: use same fault hash key for shared and private mappingsMike Kravetz
commit 1b426bac66e6cc83c9f2d92b96e4e72acf43419a upstream. hugetlb uses a fault mutex hash table to prevent page faults of the same pages concurrently. The key for shared and private mappings is different. Shared keys off address_space and file index. Private keys off mm and virtual address. Consider a private mappings of a populated hugetlbfs file. A fault will map the page from the file and if needed do a COW to map a writable page. Hugetlbfs hole punch uses the fault mutex to prevent mappings of file pages. It uses the address_space file index key. However, private mappings will use a different key and could race with this code to map the file page. This causes problems (BUG) for the page cache remove code as it expects the page to be unmapped. A sample stack is: page dumped because: VM_BUG_ON_PAGE(page_mapped(page)) kernel BUG at mm/filemap.c:169! ... RIP: 0010:unaccount_page_cache_page+0x1b8/0x200 ... Call Trace: __delete_from_page_cache+0x39/0x220 delete_from_page_cache+0x45/0x70 remove_inode_hugepages+0x13c/0x380 ? __add_to_page_cache_locked+0x162/0x380 hugetlbfs_fallocate+0x403/0x540 ? _cond_resched+0x15/0x30 ? __inode_security_revalidate+0x5d/0x70 ? selinux_file_permission+0x100/0x130 vfs_fallocate+0x13f/0x270 ksys_fallocate+0x3c/0x80 __x64_sys_fallocate+0x1a/0x20 do_syscall_64+0x5b/0x180 entry_SYSCALL_64_after_hwframe+0x44/0xa9 There seems to be another potential COW issue/race with this approach of different private and shared keys as noted in commit 8382d914ebf7 ("mm, hugetlb: improve page-fault scalability"). Since every hugetlb mapping (even anon and private) is actually a file mapping, just use the address_space index key for all mappings. This results in potentially more hash collisions. However, this should not be the common case. Link: http://lkml.kernel.org/r/20190328234704.27083-3-mike.kravetz@oracle.com Link: http://lkml.kernel.org/r/20190412165235.t4sscoujczfhuiyt@linux-r8p5 Fixes: b5cec28d36f5 ("hugetlbfs: truncate_hugepages() takes a range of pages") Signed-off-by: Mike Kravetz <mike.kravetz@oracle.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Reviewed-by: Davidlohr Bueso <dbueso@suse.de> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: "Kirill A . Shutemov" <kirill.shutemov@linux.intel.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-22mm/hugetlb.c: don't put_page in lock of hugetlb_lockKai Shen
commit 2bf753e64b4a702e27ce26ff520c59563c62f96b upstream. spinlock recursion happened when do LTP test: #!/bin/bash ./runltp -p -f hugetlb & ./runltp -p -f hugetlb & ./runltp -p -f hugetlb & ./runltp -p -f hugetlb & ./runltp -p -f hugetlb & The dtor returned by get_compound_page_dtor in __put_compound_page may be the function of free_huge_page which will lock the hugetlb_lock, so don't put_page in lock of hugetlb_lock. BUG: spinlock recursion on CPU#0, hugemmap05/1079 lock: hugetlb_lock+0x0/0x18, .magic: dead4ead, .owner: hugemmap05/1079, .owner_cpu: 0 Call trace: dump_backtrace+0x0/0x198 show_stack+0x24/0x30 dump_stack+0xa4/0xcc spin_dump+0x84/0xa8 do_raw_spin_lock+0xd0/0x108 _raw_spin_lock+0x20/0x30 free_huge_page+0x9c/0x260 __put_compound_page+0x44/0x50 __put_page+0x2c/0x60 alloc_surplus_huge_page.constprop.19+0xf0/0x140 hugetlb_acct_memory+0x104/0x378 hugetlb_reserve_pages+0xe0/0x250 hugetlbfs_file_mmap+0xc0/0x140 mmap_region+0x3e8/0x5b0 do_mmap+0x280/0x460 vm_mmap_pgoff+0xf4/0x128 ksys_mmap_pgoff+0xb4/0x258 __arm64_sys_mmap+0x34/0x48 el0_svc_common+0x78/0x130 el0_svc_handler+0x38/0x78 el0_svc+0x8/0xc Link: http://lkml.kernel.org/r/b8ade452-2d6b-0372-32c2-703644032b47@huawei.com Fixes: 9980d744a0 ("mm, hugetlb: get rid of surplus page accounting tricks") Signed-off-by: Kai Shen <shenkai8@huawei.com> Signed-off-by: Feilong Lin <linfeilong@huawei.com> Reported-by: Wang Wang <wangwang2@huawei.com> Reviewed-by: Oscar Salvador <osalvador@suse.de> Reviewed-by: Mike Kravetz <mike.kravetz@oracle.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Michal Hocko <mhocko@suse.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-22mm/huge_memory: fix vmf_insert_pfn_{pmd, pud}() crash, handle unaligned ↵Dan Williams
addresses commit fce86ff5802bac3a7b19db171aa1949ef9caac31 upstream. Starting with c6f3c5ee40c1 ("mm/huge_memory.c: fix modifying of page protection by insert_pfn_pmd()") vmf_insert_pfn_pmd() internally calls pmdp_set_access_flags(). That helper enforces a pmd aligned @address argument via VM_BUG_ON() assertion. Update the implementation to take a 'struct vm_fault' argument directly and apply the address alignment fixup internally to fix crash signatures like: kernel BUG at arch/x86/mm/pgtable.c:515! invalid opcode: 0000 [#1] SMP NOPTI CPU: 51 PID: 43713 Comm: java Tainted: G OE 4.19.35 #1 [..] RIP: 0010:pmdp_set_access_flags+0x48/0x50 [..] Call Trace: vmf_insert_pfn_pmd+0x198/0x350 dax_iomap_fault+0xe82/0x1190 ext4_dax_huge_fault+0x103/0x1f0 ? __switch_to_asm+0x40/0x70 __handle_mm_fault+0x3f6/0x1370 ? __switch_to_asm+0x34/0x70 ? __switch_to_asm+0x40/0x70 handle_mm_fault+0xda/0x200 __do_page_fault+0x249/0x4f0 do_page_fault+0x32/0x110 ? page_fault+0x8/0x30 page_fault+0x1e/0x30 Link: http://lkml.kernel.org/r/155741946350.372037.11148198430068238140.stgit@dwillia2-desk3.amr.corp.intel.com Fixes: c6f3c5ee40c1 ("mm/huge_memory.c: fix modifying of page protection by insert_pfn_pmd()") Signed-off-by: Dan Williams <dan.j.williams@intel.com> Reported-by: Piotr Balcer <piotr.balcer@intel.com> Tested-by: Yan Ma <yan.ma@intel.com> Tested-by: Pankaj Gupta <pagupta@redhat.com> Reviewed-by: Matthew Wilcox <willy@infradead.org> Reviewed-by: Jan Kara <jack@suse.cz> Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.ibm.com> Cc: Chandan Rajendra <chandan@linux.ibm.com> Cc: Souptick Joarder <jrdr.linux@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-22mm/mincore.c: make mincore() more conservativeJiri Kosina
commit 134fca9063ad4851de767d1768180e5dede9a881 upstream. The semantics of what mincore() considers to be resident is not completely clear, but Linux has always (since 2.3.52, which is when mincore() was initially done) treated it as "page is available in page cache". That's potentially a problem, as that [in]directly exposes meta-information about pagecache / memory mapping state even about memory not strictly belonging to the process executing the syscall, opening possibilities for sidechannel attacks. Change the semantics of mincore() so that it only reveals pagecache information for non-anonymous mappings that belog to files that the calling process could (if it tried to) successfully open for writing; otherwise we'd be including shared non-exclusive mappings, which - is the sidechannel - is not the usecase for mincore(), as that's primarily used for data, not (shared) text [jkosina@suse.cz: v2] Link: http://lkml.kernel.org/r/20190312141708.6652-2-vbabka@suse.cz [mhocko@suse.com: restructure can_do_mincore() conditions] Link: http://lkml.kernel.org/r/nycvar.YFH.7.76.1903062342020.19912@cbobk.fhfr.pm Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Josh Snyder <joshs@netflix.com> Acked-by: Michal Hocko <mhocko@suse.com> Originally-by: Linus Torvalds <torvalds@linux-foundation.org> Originally-by: Dominique Martinet <asmadeus@codewreck.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dave Chinner <david@fromorbit.com> Cc: Kevin Easton <kevin@guarana.org> Cc: Matthew Wilcox <willy@infradead.org> Cc: Cyril Hrubis <chrubis@suse.cz> Cc: Tejun Heo <tj@kernel.org> Cc: Kirill A. Shutemov <kirill@shutemov.name> Cc: Daniel Gruss <daniel@gruss.cc> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-16mm/memory.c: fix modifying of page protection by insert_pfn()Jan Kara
[ Upstream commit cae85cb8add35f678cf487139d05e083ce2f570a ] Aneesh has reported that PPC triggers the following warning when excercising DAX code: IP set_pte_at+0x3c/0x190 LR insert_pfn+0x208/0x280 Call Trace: insert_pfn+0x68/0x280 dax_iomap_pte_fault.isra.7+0x734/0xa40 __xfs_filemap_fault+0x280/0x2d0 do_wp_page+0x48c/0xa40 __handle_mm_fault+0x8d0/0x1fd0 handle_mm_fault+0x140/0x250 __do_page_fault+0x300/0xd60 handle_page_fault+0x18 Now that is WARN_ON in set_pte_at which is VM_WARN_ON(pte_hw_valid(*ptep) && !pte_protnone(*ptep)); The problem is that on some architectures set_pte_at() cannot cope with a situation where there is already some (different) valid entry present. Use ptep_set_access_flags() instead to modify the pfn which is built to deal with modifying existing PTE. Link: http://lkml.kernel.org/r/20190311084537.16029-1-jack@suse.cz Fixes: b2770da64254 "mm: add vm_insert_mixed_mkwrite()" Signed-off-by: Jan Kara <jack@suse.cz> Reported-by: "Aneesh Kumar K.V" <aneesh.kumar@linux.ibm.com> Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.ibm.com> Acked-by: Dan Williams <dan.j.williams@intel.com> Cc: Chandan Rajendra <chandan@linux.ibm.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com>
2019-05-16mm/memory_hotplug.c: drop memory device reference after find_memory_block()David Hildenbrand
[ Upstream commit 89c02e69fc5245f8a2f34b58b42d43a737af1a5e ] Right now we are using find_memory_block() to get the node id for the pfn range to online. We are missing to drop a reference to the memory block device. While the device still gets unregistered via device_unregister(), resulting in no user visible problem, the device is never released via device_release(), resulting in a memory leak. Fix that by properly using a put_device(). Link: http://lkml.kernel.org/r/20190411110955.1430-1-david@redhat.com Fixes: d0dc12e86b31 ("mm/memory_hotplug: optimize memory hotplug") Signed-off-by: David Hildenbrand <david@redhat.com> Reviewed-by: Oscar Salvador <osalvador@suse.de> Reviewed-by: Wei Yang <richard.weiyang@gmail.com> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Pankaj Gupta <pagupta@redhat.com> Cc: David Hildenbrand <david@redhat.com> Cc: Pavel Tatashin <pasha.tatashin@soleen.com> Cc: Qian Cai <cai@lca.pw> Cc: Arun KS <arunks@codeaurora.org> Cc: Mathieu Malaterre <malat@debian.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-05-16mm: fix inactive list balancing between NUMA nodes and cgroupsJohannes Weiner
[ Upstream commit 3b991208b897f52507168374033771a984b947b1 ] During !CONFIG_CGROUP reclaim, we expand the inactive list size if it's thrashing on the node that is about to be reclaimed. But when cgroups are enabled, we suddenly ignore the node scope and use the cgroup scope only. The result is that pressure bleeds between NUMA nodes depending on whether cgroups are merely compiled into Linux. This behavioral difference is unexpected and undesirable. When the refault adaptivity of the inactive list was first introduced, there were no statistics at the lruvec level - the intersection of node and memcg - so it was better than nothing. But now that we have that infrastructure, use lruvec_page_state() to make the list balancing decision always NUMA aware. [hannes@cmpxchg.org: fix bisection hole] Link: http://lkml.kernel.org/r/20190417155241.GB23013@cmpxchg.org Link: http://lkml.kernel.org/r/20190412144438.2645-1-hannes@cmpxchg.org Fixes: 2a2e48854d70 ("mm: vmscan: fix IO/refault regression in cache workingset transition") Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Shakeel Butt <shakeelb@google.com> Cc: Roman Gushchin <guro@fb.com> Cc: Michal Hocko <mhocko@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-05-10slab: fix a crash by reading /proc/slab_allocatorsQian Cai
[ Upstream commit fcf88917dd435c6a4cb2830cb086ee58605a1d85 ] The commit 510ded33e075 ("slab: implement slab_root_caches list") changes the name of the list node within "struct kmem_cache" from "list" to "root_caches_node", but leaks_show() still use the "list" which causes a crash when reading /proc/slab_allocators. You need to have CONFIG_SLAB=y and CONFIG_MEMCG=y to see the problem, because without MEMCG all slab caches are root caches, and the "list" node happens to be the right one. Fixes: 510ded33e075 ("slab: implement slab_root_caches list") Signed-off-by: Qian Cai <cai@lca.pw> Reviewed-by: Tobin C. Harding <tobin@kernel.org> Cc: Tejun Heo <tj@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-05-08mm/kmemleak.c: fix unused-function warningArnd Bergmann
commit dce5b0bdeec61bdbee56121ceb1d014151d5cab1 upstream. The only references outside of the #ifdef have been removed, so now we get a warning in non-SMP configurations: mm/kmemleak.c:1404:13: error: unused function 'scan_large_block' [-Werror,-Wunused-function] Add a new #ifdef around it. Link: http://lkml.kernel.org/r/20190416123148.3502045-1-arnd@arndb.de Fixes: 298a32b13208 ("kmemleak: powerpc: skip scanning holes in the .bss section") Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Vincent Whitchurch <vincent.whitchurch@axis.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Nobuhiro Iwamatsu <nobuhiro1.iwamatsu@toshiba.co.jp> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-08kmemleak: powerpc: skip scanning holes in the .bss sectionCatalin Marinas
[ Upstream commit 298a32b132087550d3fa80641ca58323c5dfd4d9 ] Commit 2d4f567103ff ("KVM: PPC: Introduce kvm_tmp framework") adds kvm_tmp[] into the .bss section and then free the rest of unused spaces back to the page allocator. kernel_init kvm_guest_init kvm_free_tmp free_reserved_area free_unref_page free_unref_page_prepare With DEBUG_PAGEALLOC=y, it will unmap those pages from kernel. As the result, kmemleak scan will trigger a panic when it scans the .bss section with unmapped pages. This patch creates dedicated kmemleak objects for the .data, .bss and potentially .data..ro_after_init sections to allow partial freeing via the kmemleak_free_part() in the powerpc kvm_free_tmp() function. Link: http://lkml.kernel.org/r/20190321171917.62049-1-catalin.marinas@arm.com Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Reported-by: Qian Cai <cai@lca.pw> Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc) Tested-by: Qian Cai <cai@lca.pw> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Avi Kivity <avi@redhat.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Radim Krcmar <rkrcmar@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-05-04mm: prevent get_user_pages() from overflowing page refcountLinus Torvalds
commit 8fde12ca79aff9b5ba951fce1a2641901b8d8e64 upstream. If the page refcount wraps around past zero, it will be freed while there are still four billion references to it. One of the possible avenues for an attacker to try to make this happen is by doing direct IO on a page multiple times. This patch makes get_user_pages() refuse to take a new page reference if there are already more than two billion references to the page. Reported-by: Jann Horn <jannh@google.com> Acked-by: Matthew Wilcox <willy@infradead.org> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-02mm: Fix warning in insert_pfn()Jan Kara
commit f2c57d91b0d96aa13ccff4e3b178038f17b00658 upstream. In DAX mode a write pagefault can race with write(2) in the following way: CPU0 CPU1 write fault for mapped zero page (hole) dax_iomap_rw() iomap_apply() xfs_file_iomap_begin() - allocates blocks dax_iomap_actor() invalidate_inode_pages2_range() - invalidates radix tree entries in given range dax_iomap_pte_fault() grab_mapping_entry() - no entry found, creates empty ... xfs_file_iomap_begin() - finds already allocated block ... vmf_insert_mixed_mkwrite() - WARNs and does nothing because there is still zero page mapped in PTE unmap_mapping_pages() This race results in WARN_ON from insert_pfn() and is occasionally triggered by fstest generic/344. Note that the race is otherwise harmless as before write(2) on CPU0 is finished, we will invalidate page tables properly and thus user of mmap will see modified data from write(2) from that point on. So just restrict the warning only to the case when the PFN in PTE is not zero page. Link: http://lkml.kernel.org/r/20180824154542.26872-1-jack@suse.cz Signed-off-by: Jan Kara <jack@suse.cz> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Dave Jiang <dave.jiang@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-04-28Merge tag 'v4.19.37' into v4.19-rtSteven Rostedt (VMware)
This is the 4.19.37 stable release Conflicts: include/linux/sched/mm.h kernel/sched/fair.c
2019-04-27percpu: stop printing kernel addressesMatteo Croce
commit 00206a69ee32f03e6f40837684dcbe475ea02266 upstream. Since commit ad67b74d2469d9b8 ("printk: hash addresses printed with %p"), at boot "____ptrval____" is printed instead of actual addresses: percpu: Embedded 38 pages/cpu @(____ptrval____) s124376 r0 d31272 u524288 Instead of changing the print to "%px", and leaking kernel addresses, just remove the print completely, cfr. e.g. commit 071929dbdd865f77 ("arm64: Stop printing the virtual memory layout"). Signed-off-by: Matteo Croce <mcroce@redhat.com> Signed-off-by: Dennis Zhou <dennis@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-04-27mm/vmstat.c: fix /proc/vmstat format for CONFIG_DEBUG_TLBFLUSH=y CONFIG_SMP=nKonstantin Khlebnikov
commit e8277b3b52240ec1caad8e6df278863e4bf42eac upstream. Commit 58bc4c34d249 ("mm/vmstat.c: skip NR_TLB_REMOTE_FLUSH* properly") depends on skipping vmstat entries with empty name introduced in 7aaf77272358 ("mm: don't show nr_indirectly_reclaimable in /proc/vmstat") but reverted in b29940c1abd7 ("mm: rename and change semantics of nr_indirectly_reclaimable_bytes"). So skipping no longer works and /proc/vmstat has misformatted lines " 0". This patch simply shows debug counters "nr_tlb_remote_*" for UP. Link: http://lkml.kernel.org/r/155481488468.467.4295519102880913454.stgit@buzz Fixes: 58bc4c34d249 ("mm/vmstat.c: skip NR_TLB_REMOTE_FLUSH* properly") Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Roman Gushchin <guro@fb.com> Cc: Jann Horn <jannh@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-04-27coredump: fix race condition between mmget_not_zero()/get_task_mm() and core ↵Andrea Arcangeli
dumping commit 04f5866e41fb70690e28397487d8bd8eea7d712a upstream. The core dumping code has always run without holding the mmap_sem for writing, despite that is the only way to ensure that the entire vma layout will not change from under it. Only using some signal serialization on the processes belonging to the mm is not nearly enough. This was pointed out earlier. For example in Hugh's post from Jul 2017: https://lkml.kernel.org/r/alpine.LSU.2.11.1707191716030.2055@eggly.anvils "Not strictly relevant here, but a related note: I was very surprised to discover, only quite recently, how handle_mm_fault() may be called without down_read(mmap_sem) - when core dumping. That seems a misguided optimization to me, which would also be nice to correct" In particular because the growsdown and growsup can move the vm_start/vm_end the various loops the core dump does around the vma will not be consistent if page faults can happen concurrently. Pretty much all users calling mmget_not_zero()/get_task_mm() and then taking the mmap_sem had the potential to introduce unexpected side effects in the core dumping code. Adding mmap_sem for writing around the ->core_dump invocation is a viable long term fix, but it requires removing all copy user and page faults and to replace them with get_dump_page() for all binary formats which is not suitable as a short term fix. For the time being this solution manually covers the places that can confuse the core dump either by altering the vma layout or the vma flags while it runs. Once ->core_dump runs under mmap_sem for writing the function mmget_still_valid() can be dropped. Allowing mmap_sem protected sections to run in parallel with the coredump provides some minor parallelism advantage to the swapoff code (which seems to be safe enough by never mangling any vma field and can keep doing swapins in parallel to the core dumping) and to some other corner case. In order to facilitate the backporting I added "Fixes: 86039bd3b4e6" however the side effect of this same race condition in /proc/pid/mem should be reproducible since before 2.6.12-rc2 so I couldn't add any other "Fixes:" because there's no hash beyond the git genesis commit. Because find_extend_vma() is the only location outside of the process context that could modify the "mm" structures under mmap_sem for reading, by adding the mmget_still_valid() check to it, all other cases that take the mmap_sem for reading don't need the new check after mmget_not_zero()/get_task_mm(). The expand_stack() in page fault context also doesn't need the new check, because all tasks under core dumping are frozen. Link: http://lkml.kernel.org/r/20190325224949.11068-1-aarcange@redhat.com Fixes: 86039bd3b4e6 ("userfaultfd: add new syscall to provide memory externalization") Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Reported-by: Jann Horn <jannh@google.com> Suggested-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Peter Xu <peterx@redhat.com> Reviewed-by: Mike Rapoport <rppt@linux.ibm.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Reviewed-by: Jann Horn <jannh@google.com> Acked-by: Jason Gunthorpe <jgg@mellanox.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-04-20mm: hide incomplete nr_indirectly_reclaimable in /proc/zoneinfoRoman Gushchin
[fixed differently upstream, this is a work-around to resolve it for 4.19.y] Yongqin reported that /proc/zoneinfo format is broken in 4.14 due to commit 7aaf77272358 ("mm: don't show nr_indirectly_reclaimable in /proc/vmstat") Node 0, zone DMA per-node stats nr_inactive_anon 403 nr_active_anon 89123 nr_inactive_file 128887 nr_active_file 47377 nr_unevictable 2053 nr_slab_reclaimable 7510 nr_slab_unreclaimable 10775 nr_isolated_anon 0 nr_isolated_file 0 <...> nr_vmscan_write 0 nr_vmscan_immediate_reclaim 0 nr_dirtied 6022 nr_written 5985 74240 ^^^^^^^^^^ pages free 131656 The problem is caused by the nr_indirectly_reclaimable counter, which is hidden from the /proc/vmstat, but not from the /proc/zoneinfo. Let's fix this inconsistency and hide the counter from /proc/zoneinfo exactly as from /proc/vmstat. BTW, in 4.19+ the counter has been renamed and exported by the commit b29940c1abd7 ("mm: rename and change semantics of nr_indirectly_reclaimable_bytes"), so there is no such a problem anymore. Cc: <stable@vger.kernel.org> # 4.14.x-4.18.x Fixes: 7aaf77272358 ("mm: don't show nr_indirectly_reclaimable in /proc/vmstat") Reported-by: Yongqin Liu <yongqin.liu@linaro.org> Signed-off-by: Roman Gushchin <guro@fb.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-04-17mm: writeback: use exact memcg dirty countsGreg Thelen
commit 0b3d6e6f2dd0a7b697b1aa8c167265908940624b upstream. Since commit a983b5ebee57 ("mm: memcontrol: fix excessive complexity in memory.stat reporting") memcg dirty and writeback counters are managed as: 1) per-memcg per-cpu values in range of [-32..32] 2) per-memcg atomic counter When a per-cpu counter cannot fit in [-32..32] it's flushed to the atomic. Stat readers only check the atomic. Thus readers such as balance_dirty_pages() may see a nontrivial error margin: 32 pages per cpu. Assuming 100 cpus: 4k x86 page_size: 13 MiB error per memcg 64k ppc page_size: 200 MiB error per memcg Considering that dirty+writeback are used together for some decisions the errors double. This inaccuracy can lead to undeserved oom kills. One nasty case is when all per-cpu counters hold positive values offsetting an atomic negative value (i.e. per_cpu[*]=32, atomic=n_cpu*-32). balance_dirty_pages() only consults the atomic and does not consider throttling the next n_cpu*32 dirty pages. If the file_lru is in the 13..200 MiB range then there's absolutely no dirty throttling, which burdens vmscan with only dirty+writeback pages thus resorting to oom kill. It could be argued that tiny containers are not supported, but it's more subtle. It's the amount the space available for file lru that matters. If a container has memory.max-200MiB of non reclaimable memory, then it will also suffer such oom kills on a 100 cpu machine. The following test reliably ooms without this patch. This patch avoids oom kills. $ cat test mount -t cgroup2 none /dev/cgroup cd /dev/cgroup echo +io +memory > cgroup.subtree_control mkdir test cd test echo 10M > memory.max (echo $BASHPID > cgroup.procs && exec /memcg-writeback-stress /foo) (echo $BASHPID > cgroup.procs && exec dd if=/dev/zero of=/foo bs=2M count=100) $ cat memcg-writeback-stress.c /* * Dirty pages from all but one cpu. * Clean pages from the non dirtying cpu. * This is to stress per cpu counter imbalance. * On a 100 cpu machine: * - per memcg per cpu dirty count is 32 pages for each of 99 cpus * - per memcg atomic is -99*32 pages * - thus the complete dirty limit: sum of all counters 0 * - balance_dirty_pages() only sees atomic count -99*32 pages, which * it max()s to 0. * - So a workload can dirty -99*32 pages before balance_dirty_pages() * cares. */ #define _GNU_SOURCE #include <err.h> #include <fcntl.h> #include <sched.h> #include <stdlib.h> #include <stdio.h> #include <sys/stat.h> #include <sys/sysinfo.h> #include <sys/types.h> #include <unistd.h> static char *buf; static int bufSize; static void set_affinity(int cpu) { cpu_set_t affinity; CPU_ZERO(&affinity); CPU_SET(cpu, &affinity); if (sched_setaffinity(0, sizeof(affinity), &affinity)) err(1, "sched_setaffinity"); } static void dirty_on(int output_fd, int cpu) { int i, wrote; set_affinity(cpu); for (i = 0; i < 32; i++) { for (wrote = 0; wrote < bufSize; ) { int ret = write(output_fd, buf+wrote, bufSize-wrote); if (ret == -1) err(1, "write"); wrote += ret; } } } int main(int argc, char **argv) { int cpu, flush_cpu = 1, output_fd; const char *output; if (argc != 2) errx(1, "usage: output_file"); output = argv[1]; bufSize = getpagesize(); buf = malloc(getpagesize()); if (buf == NULL) errx(1, "malloc failed"); output_fd = open(output, O_CREAT|O_RDWR); if (output_fd == -1) err(1, "open(%s)", output); for (cpu = 0; cpu < get_nprocs(); cpu++) { if (cpu != flush_cpu) dirty_on(output_fd, cpu); } set_affinity(flush_cpu); if (fsync(output_fd)) err(1, "fsync(%s)", output); if (close(output_fd)) err(1, "close(%s)", output); free(buf); } Make balance_dirty_pages() and wb_over_bg_thresh() work harder to collect exact per memcg counters. This avoids the aforementioned oom kills. This does not affect the overhead of memory.stat, which still reads the single atomic counter. Why not use percpu_counter? memcg already handles cpus going offline, so no need for that overhead from percpu_counter. And the percpu_counter spinlocks are more heavyweight than is required. It probably also makes sense to use exact dirty and writeback counters in memcg oom reports. But that is saved for later. Link: http://lkml.kernel.org/r/20190329174609.164344-1-gthelen@google.com Signed-off-by: Greg Thelen <gthelen@google.com> Reviewed-by: Roman Gushchin <guro@fb.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@kernel.org> Cc: Vladimir Davydov <vdavydov.dev@gmail.com> Cc: Tejun Heo <tj@kernel.org> Cc: <stable@vger.kernel.org> [4.16+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-04-17mm/huge_memory.c: fix modifying of page protection by insert_pfn_pmd()Aneesh Kumar K.V
commit c6f3c5ee40c10bb65725047a220570f718507001 upstream. With some architectures like ppc64, set_pmd_at() cannot cope with a situation where there is already some (different) valid entry present. Use pmdp_set_access_flags() instead to modify the pfn which is built to deal with modifying existing PMD entries. This is similar to commit cae85cb8add3 ("mm/memory.c: fix modifying of page protection by insert_pfn()") We also do similar update w.r.t insert_pfn_pud eventhough ppc64 don't support pud pfn entries now. Without this patch we also see the below message in kernel log "BUG: non-zero pgtables_bytes on freeing mm:" Link: http://lkml.kernel.org/r/20190402115125.18803-1-aneesh.kumar@linux.ibm.com Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.ibm.com> Reported-by: Chandan Rajendra <chandan@linux.ibm.com> Reviewed-by: Jan Kara <jack@suse.cz> Cc: Dan Williams <dan.j.williams@intel.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-04-05page_poison: play nicely with KASANQian Cai
[ Upstream commit 4117992df66a26fa33908b4969e04801534baab1 ] KASAN does not play well with the page poisoning (CONFIG_PAGE_POISONING). It triggers false positives in the allocation path: BUG: KASAN: use-after-free in memchr_inv+0x2ea/0x330 Read of size 8 at addr ffff88881f800000 by task swapper/0 CPU: 0 PID: 0 Comm: swapper Not tainted 5.0.0-rc1+ #54 Call Trace: dump_stack+0xe0/0x19a print_address_description.cold.2+0x9/0x28b kasan_report.cold.3+0x7a/0xb5 __asan_report_load8_noabort+0x19/0x20 memchr_inv+0x2ea/0x330 kernel_poison_pages+0x103/0x3d5 get_page_from_freelist+0x15e7/0x4d90 because KASAN has not yet unpoisoned the shadow page for allocation before it checks memchr_inv() but only found a stale poison pattern. Also, false positives in free path, BUG: KASAN: slab-out-of-bounds in kernel_poison_pages+0x29e/0x3d5 Write of size 4096 at addr ffff8888112cc000 by task swapper/0/1 CPU: 5 PID: 1 Comm: swapper/0 Not tainted 5.0.0-rc1+ #55 Call Trace: dump_stack+0xe0/0x19a print_address_description.cold.2+0x9/0x28b kasan_report.cold.3+0x7a/0xb5 check_memory_region+0x22d/0x250 memset+0x28/0x40 kernel_poison_pages+0x29e/0x3d5 __free_pages_ok+0x75f/0x13e0 due to KASAN adds poisoned redzones around slab objects, but the page poisoning needs to poison the whole page. Link: http://lkml.kernel.org/r/20190114233405.67843-1-cai@lca.pw Signed-off-by: Qian Cai <cai@lca.pw> Acked-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-04-05mm/slab.c: kmemleak no scan alien cachesQian Cai
[ Upstream commit 92d1d07daad65c300c7d0b68bbef8867e9895d54 ] Kmemleak throws endless warnings during boot due to in __alloc_alien_cache(), alc = kmalloc_node(memsize, gfp, node); init_arraycache(&alc->ac, entries, batch); kmemleak_no_scan(ac); Kmemleak does not track the array cache (alc->ac) but the alien cache (alc) instead, so let it track the latter by lifting kmemleak_no_scan() out of init_arraycache(). There is another place that calls init_arraycache(), but alloc_kmem_cache_cpus() uses the percpu allocation where will never be considered as a leak. kmemleak: Found object by alias at 0xffff8007b9aa7e38 CPU: 190 PID: 1 Comm: swapper/0 Not tainted 5.0.0-rc2+ #2 Call trace: dump_backtrace+0x0/0x168 show_stack+0x24/0x30 dump_stack+0x88/0xb0 lookup_object+0x84/0xac find_and_get_object+0x84/0xe4 kmemleak_no_scan+0x74/0xf4 setup_kmem_cache_node+0x2b4/0x35c __do_tune_cpucache+0x250/0x2d4 do_tune_cpucache+0x4c/0xe4 enable_cpucache+0xc8/0x110 setup_cpu_cache+0x40/0x1b8 __kmem_cache_create+0x240/0x358 create_cache+0xc0/0x198 kmem_cache_create_usercopy+0x158/0x20c kmem_cache_create+0x50/0x64 fsnotify_init+0x58/0x6c do_one_initcall+0x194/0x388 kernel_init_freeable+0x668/0x688 kernel_init+0x18/0x124 ret_from_fork+0x10/0x18 kmemleak: Object 0xffff8007b9aa7e00 (size 256): kmemleak: comm "swapper/0", pid 1, jiffies 4294697137 kmemleak: min_count = 1 kmemleak: count = 0 kmemleak: flags = 0x1 kmemleak: checksum = 0 kmemleak: backtrace: kmemleak_alloc+0x84/0xb8 kmem_cache_alloc_node_trace+0x31c/0x3a0 __kmalloc_node+0x58/0x78 setup_kmem_cache_node+0x26c/0x35c __do_tune_cpucache+0x250/0x2d4 do_tune_cpucache+0x4c/0xe4 enable_cpucache+0xc8/0x110 setup_cpu_cache+0x40/0x1b8 __kmem_cache_create+0x240/0x358 create_cache+0xc0/0x198 kmem_cache_create_usercopy+0x158/0x20c kmem_cache_create+0x50/0x64 fsnotify_init+0x58/0x6c do_one_initcall+0x194/0x388 kernel_init_freeable+0x668/0x688 kernel_init+0x18/0x124 kmemleak: Not scanning unknown object at 0xffff8007b9aa7e38 CPU: 190 PID: 1 Comm: swapper/0 Not tainted 5.0.0-rc2+ #2 Call trace: dump_backtrace+0x0/0x168 show_stack+0x24/0x30 dump_stack+0x88/0xb0 kmemleak_no_scan+0x90/0xf4 setup_kmem_cache_node+0x2b4/0x35c __do_tune_cpucache+0x250/0x2d4 do_tune_cpucache+0x4c/0xe4 enable_cpucache+0xc8/0x110 setup_cpu_cache+0x40/0x1b8 __kmem_cache_create+0x240/0x358 create_cache+0xc0/0x198 kmem_cache_create_usercopy+0x158/0x20c kmem_cache_create+0x50/0x64 fsnotify_init+0x58/0x6c do_one_initcall+0x194/0x388 kernel_init_freeable+0x668/0x688 kernel_init+0x18/0x124 ret_from_fork+0x10/0x18 Link: http://lkml.kernel.org/r/20190129184518.39808-1-cai@lca.pw Fixes: 1fe00d50a9e8 ("slab: factor out initialization of array cache") Signed-off-by: Qian Cai <cai@lca.pw> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-04-05mm/vmalloc.c: fix kernel BUG at mm/vmalloc.c:512!Uladzislau Rezki (Sony)
[ Upstream commit afd07389d3f4933c7f7817a92fb5e053d59a3182 ] One of the vmalloc stress test case triggers the kernel BUG(): <snip> [60.562151] ------------[ cut here ]------------ [60.562154] kernel BUG at mm/vmalloc.c:512! [60.562206] invalid opcode: 0000 [#1] PREEMPT SMP PTI [60.562247] CPU: 0 PID: 430 Comm: vmalloc_test/0 Not tainted 4.20.0+ #161 [60.562293] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1 04/01/2014 [60.562351] RIP: 0010:alloc_vmap_area+0x36f/0x390 <snip> it can happen due to big align request resulting in overflowing of calculated address, i.e. it becomes 0 after ALIGN()'s fixup. Fix it by checking if calculated address is within vstart/vend range. Link: http://lkml.kernel.org/r/20190124115648.9433-2-urezki@gmail.com Signed-off-by: Uladzislau Rezki (Sony) <urezki@gmail.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Joel Fernandes <joelaf@google.com> Cc: Matthew Wilcox <willy@infradead.org> Cc: Michal Hocko <mhocko@suse.com> Cc: Oleksiy Avramchenko <oleksiy.avramchenko@sonymobile.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Tejun Heo <tj@kernel.org> Cc: Thomas Garnier <thgarnie@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-04-05mm, mempolicy: fix uninit memory accessVlastimil Babka
[ Upstream commit 2e25644e8da4ed3a27e7b8315aaae74660be72dc ] Syzbot with KMSAN reports (excerpt): ================================================================== BUG: KMSAN: uninit-value in mpol_rebind_policy mm/mempolicy.c:353 [inline] BUG: KMSAN: uninit-value in mpol_rebind_mm+0x249/0x370 mm/mempolicy.c:384 CPU: 1 PID: 17420 Comm: syz-executor4 Not tainted 4.20.0-rc7+ #15 Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011 Call Trace: __dump_stack lib/dump_stack.c:77 [inline] dump_stack+0x173/0x1d0 lib/dump_stack.c:113 kmsan_report+0x12e/0x2a0 mm/kmsan/kmsan.c:613 __msan_warning+0x82/0xf0 mm/kmsan/kmsan_instr.c:295 mpol_rebind_policy mm/mempolicy.c:353 [inline] mpol_rebind_mm+0x249/0x370 mm/mempolicy.c:384 update_tasks_nodemask+0x608/0xca0 kernel/cgroup/cpuset.c:1120 update_nodemasks_hier kernel/cgroup/cpuset.c:1185 [inline] update_nodemask kernel/cgroup/cpuset.c:1253 [inline] cpuset_write_resmask+0x2a98/0x34b0 kernel/cgroup/cpuset.c:1728 ... Uninit was created at: kmsan_save_stack_with_flags mm/kmsan/kmsan.c:204 [inline] kmsan_internal_poison_shadow+0x92/0x150 mm/kmsan/kmsan.c:158 kmsan_kmalloc+0xa6/0x130 mm/kmsan/kmsan_hooks.c:176 kmem_cache_alloc+0x572/0xb90 mm/slub.c:2777 mpol_new mm/mempolicy.c:276 [inline] do_mbind mm/mempolicy.c:1180 [inline] kernel_mbind+0x8a7/0x31a0 mm/mempolicy.c:1347 __do_sys_mbind mm/mempolicy.c:1354 [inline] As it's difficult to report where exactly the uninit value resides in the mempolicy object, we have to guess a bit. mm/mempolicy.c:353 contains this part of mpol_rebind_policy(): if (!mpol_store_user_nodemask(pol) && nodes_equal(pol->w.cpuset_mems_allowed, *newmask)) "mpol_store_user_nodemask(pol)" is testing pol->flags, which I couldn't ever see being uninitialized after leaving mpol_new(). So I'll guess it's actually about accessing pol->w.cpuset_mems_allowed on line 354, but still part of statement starting on line 353. For w.cpuset_mems_allowed to be not initialized, and the nodes_equal() reachable for a mempolicy where mpol_set_nodemask() is called in do_mbind(), it seems the only possibility is a MPOL_PREFERRED policy with empty set of nodes, i.e. MPOL_LOCAL equivalent, with MPOL_F_LOCAL flag. Let's exclude such policies from the nodes_equal() check. Note the uninit access should be benign anyway, as rebinding this kind of policy is always a no-op. Therefore no actual need for stable inclusion. Link: http://lkml.kernel.org/r/a71997c3-e8ae-a787-d5ce-3db05768b27c@suse.cz Link: http://lkml.kernel.org/r/73da3e9c-cc84-509e-17d9-0c434bb9967d@suse.cz Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Reported-by: syzbot+b19c2dc2c990ea657a71@syzkaller.appspotmail.com Cc: Alexander Potapenko <glider@google.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Michal Hocko <mhocko@suse.com> Cc: David Rientjes <rientjes@google.com> Cc: Yisheng Xie <xieyisheng1@huawei.com> Cc: zhong jiang <zhongjiang@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-04-05memcg: killed threads should not invoke memcg OOM killerTetsuo Handa
[ Upstream commit 7775face207922ea62a4e96b9cd45abfdc7b9840 ] If a memory cgroup contains a single process with many threads (including different process group sharing the mm) then it is possible to trigger a race when the oom killer complains that there are no oom elible tasks and complain into the log which is both annoying and confusing because there is no actual problem. The race looks as follows: P1 oom_reaper P2 try_charge try_charge mem_cgroup_out_of_memory mutex_lock(oom_lock) out_of_memory oom_kill_process(P1,P2) wake_oom_reaper mutex_unlock(oom_lock) oom_reap_task mutex_lock(oom_lock) select_bad_process # no victim The problem is more visible with many threads. Fix this by checking for fatal_signal_pending from mem_cgroup_out_of_memory when the oom_lock is already held. The oom bypass is safe because we do the same early in the try_charge path already. The situation migh have changed in the mean time. It should be safe to check for fatal_signal_pending and tsk_is_oom_victim but for a better code readability abstract the current charge bypass condition into should_force_charge and reuse it from that path. " Link: http://lkml.kernel.org/r/01370f70-e1f6-ebe4-b95e-0df21a0bc15e@i-love.sakura.ne.jp Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: David Rientjes <rientjes@google.com> Cc: Kirill Tkhai <ktkhai@virtuozzo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-04-05mm,oom: don't kill global init via memory.oom.groupTetsuo Handa
[ Upstream commit d342a0b38674867ea67fde47b0e1e60ffe9f17a2 ] Since setting global init process to some memory cgroup is technically possible, oom_kill_memcg_member() must check it. Tasks in /test1 are going to be killed due to memory.oom.group set Memory cgroup out of memory: Killed process 1 (systemd) total-vm:43400kB, anon-rss:1228kB, file-rss:3992kB, shmem-rss:0kB oom_reaper: reaped process 1 (systemd), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000008b #include <stdio.h> #include <string.h> #include <unistd.h> #include <sys/types.h> #include <sys/stat.h> #include <fcntl.h> int main(int argc, char *argv[]) { static char buffer[10485760]; static int pipe_fd[2] = { EOF, EOF }; unsigned int i; int fd; char buf[64] = { }; if (pipe(pipe_fd)) return 1; if (chdir("/sys/fs/cgroup/")) return 1; fd = open("cgroup.subtree_control", O_WRONLY); write(fd, "+memory", 7); close(fd); mkdir("test1", 0755); fd = open("test1/memory.oom.group", O_WRONLY); write(fd, "1", 1); close(fd); fd = open("test1/cgroup.procs", O_WRONLY); write(fd, "1", 1); snprintf(buf, sizeof(buf) - 1, "%d", getpid()); write(fd, buf, strlen(buf)); close(fd); snprintf(buf, sizeof(buf) - 1, "%lu", sizeof(buffer) * 5); fd = open("test1/memory.max", O_WRONLY); write(fd, buf, strlen(buf)); close(fd); for (i = 0; i < 10; i++) if (fork() == 0) { char c; close(pipe_fd[1]); read(pipe_fd[0], &c, 1); memset(buffer, 0, sizeof(buffer)); sleep(3); _exit(0); } close(pipe_fd[0]); close(pipe_fd[1]); sleep(3); return 0; } [ 37.052923][ T9185] a.out invoked oom-killer: gfp_mask=0xcc0(GFP_KERNEL), order=0, oom_score_adj=0 [ 37.056169][ T9185] CPU: 4 PID: 9185 Comm: a.out Kdump: loaded Not tainted 5.0.0-rc4-next-20190131 #280 [ 37.059205][ T9185] Hardware name: VMware, Inc. VMware Virtual Platform/440BX Desktop Reference Platform, BIOS 6.00 04/13/2018 [ 37.062954][ T9185] Call Trace: [ 37.063976][ T9185] dump_stack+0x67/0x95 [ 37.065263][ T9185] dump_header+0x51/0x570 [ 37.066619][ T9185] ? trace_hardirqs_on+0x3f/0x110 [ 37.068171][ T9185] ? _raw_spin_unlock_irqrestore+0x3d/0x70 [ 37.069967][ T9185] oom_kill_process+0x18d/0x210 [ 37.071515][ T9185] out_of_memory+0x11b/0x380 [ 37.072936][ T9185] mem_cgroup_out_of_memory+0xb6/0xd0 [ 37.074601][ T9185] try_charge+0x790/0x820 [ 37.076021][ T9185] mem_cgroup_try_charge+0x42/0x1d0 [ 37.077629][ T9185] mem_cgroup_try_charge_delay+0x11/0x30 [ 37.079370][ T9185] do_anonymous_page+0x105/0x5e0 [ 37.080939][ T9185] __handle_mm_fault+0x9cb/0x1070 [ 37.082485][ T9185] handle_mm_fault+0x1b2/0x3a0 [ 37.083819][ T9185] ? handle_mm_fault+0x47/0x3a0 [ 37.085181][ T9185] __do_page_fault+0x255/0x4c0 [ 37.086529][ T9185] do_page_fault+0x28/0x260 [ 37.087788][ T9185] ? page_fault+0x8/0x30 [ 37.088978][ T9185] page_fault+0x1e/0x30 [ 37.090142][ T9185] RIP: 0033:0x7f8b183aefe0 [ 37.091433][ T9185] Code: 20 f3 44 0f 7f 44 17 d0 f3 44 0f 7f 47 30 f3 44 0f 7f 44 17 c0 48 01 fa 48 83 e2 c0 48 39 d1 74 a3 66 0f 1f 84 00 00 00 00 00 <66> 44 0f 7f 01 66 44 0f 7f 41 10 66 44 0f 7f 41 20 66 44 0f 7f 41 [ 37.096917][ T9185] RSP: 002b:00007fffc5d329e8 EFLAGS: 00010206 [ 37.098615][ T9185] RAX: 00000000006010e0 RBX: 0000000000000008 RCX: 0000000000c30000 [ 37.100905][ T9185] RDX: 00000000010010c0 RSI: 0000000000000000 RDI: 00000000006010e0 [ 37.103349][ T9185] RBP: 0000000000000000 R08: 00007f8b188f4740 R09: 0000000000000000 [ 37.105797][ T9185] R10: 00007fffc5d32420 R11: 00007f8b183aef40 R12: 0000000000000005 [ 37.108228][ T9185] R13: 0000000000000000 R14: ffffffffffffffff R15: 0000000000000000 [ 37.110840][ T9185] memory: usage 51200kB, limit 51200kB, failcnt 125 [ 37.113045][ T9185] memory+swap: usage 0kB, limit 9007199254740988kB, failcnt 0 [ 37.115808][ T9185] kmem: usage 0kB, limit 9007199254740988kB, failcnt 0 [ 37.117660][ T9185] Memory cgroup stats for /test1: cache:0KB rss:49484KB rss_huge:30720KB shmem:0KB mapped_file:0KB dirty:0KB writeback:0KB inactive_anon:0KB active_anon:49700KB inactive_file:0KB active_file:0KB unevictable:0KB [ 37.123371][ T9185] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,oom_memcg=/test1,task_memcg=/test1,task=a.out,pid=9188,uid=0 [ 37.128158][ T9185] Memory cgroup out of memory: Killed process 9188 (a.out) total-vm:14456kB, anon-rss:10324kB, file-rss:504kB, shmem-rss:0kB [ 37.132710][ T9185] Tasks in /test1 are going to be killed due to memory.oom.group set [ 37.132833][ T54] oom_reaper: reaped process 9188 (a.out), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB [ 37.135498][ T9185] Memory cgroup out of memory: Killed process 1 (systemd) total-vm:43400kB, anon-rss:1228kB, file-rss:3992kB, shmem-rss:0kB [ 37.143434][ T9185] Memory cgroup out of memory: Killed process 9182 (a.out) total-vm:14456kB, anon-rss:76kB, file-rss:588kB, shmem-rss:0kB [ 37.144328][ T54] oom_reaper: reaped process 1 (systemd), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB [ 37.147585][ T9185] Memory cgroup out of memory: Killed process 9183 (a.out) total-vm:14456kB, anon-rss:6228kB, file-rss:512kB, shmem-rss:0kB [ 37.157222][ T9185] Memory cgroup out of memory: Killed process 9184 (a.out) total-vm:14456kB, anon-rss:6228kB, file-rss:508kB, shmem-rss:0kB [ 37.157259][ T9185] Memory cgroup out of memory: Killed process 9185 (a.out) total-vm:14456kB, anon-rss:6228kB, file-rss:512kB, shmem-rss:0kB [ 37.157291][ T9185] Memory cgroup out of memory: Killed process 9186 (a.out) total-vm:14456kB, anon-rss:4180kB, file-rss:508kB, shmem-rss:0kB [ 37.157306][ T54] oom_reaper: reaped process 9183 (a.out), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB [ 37.157328][ T9185] Memory cgroup out of memory: Killed process 9187 (a.out) total-vm:14456kB, anon-rss:4180kB, file-rss:512kB, shmem-rss:0kB [ 37.157452][ T9185] Memory cgroup out of memory: Killed process 9189 (a.out) total-vm:14456kB, anon-rss:6228kB, file-rss:512kB, shmem-rss:0kB [ 37.158733][ T9185] Memory cgroup out of memory: Killed process 9190 (a.out) total-vm:14456kB, anon-rss:552kB, file-rss:512kB, shmem-rss:0kB [ 37.160083][ T54] oom_reaper: reaped process 9186 (a.out), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB [ 37.160187][ T54] oom_reaper: reaped process 9189 (a.out), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB [ 37.206941][ T54] oom_reaper: reaped process 9185 (a.out), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB [ 37.212300][ T9185] Memory cgroup out of memory: Killed process 9191 (a.out) total-vm:14456kB, anon-rss:4180kB, file-rss:512kB, shmem-rss:0kB [ 37.212317][ T54] oom_reaper: reaped process 9190 (a.out), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB [ 37.218860][ T9185] Memory cgroup out of memory: Killed process 9192 (a.out) total-vm:14456kB, anon-rss:1080kB, file-rss:512kB, shmem-rss:0kB [ 37.227667][ T54] oom_reaper: reaped process 9192 (a.out), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB [ 37.292323][ T9193] abrt-hook-ccpp (9193) used greatest stack depth: 10480 bytes left [ 37.351843][ T1] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000008b [ 37.354833][ T1] CPU: 7 PID: 1 Comm: systemd Kdump: loaded Not tainted 5.0.0-rc4-next-20190131 #280 [ 37.357876][ T1] Hardware name: VMware, Inc. VMware Virtual Platform/440BX Desktop Reference Platform, BIOS 6.00 04/13/2018 [ 37.361685][ T1] Call Trace: [ 37.363239][ T1] dump_stack+0x67/0x95 [ 37.365010][ T1] panic+0xfc/0x2b0 [ 37.366853][ T1] do_exit+0xd55/0xd60 [ 37.368595][ T1] do_group_exit+0x47/0xc0 [ 37.370415][ T1] get_signal+0x32a/0x920 [ 37.372449][ T1] ? _raw_spin_unlock_irqrestore+0x3d/0x70 [ 37.374596][ T1] do_signal+0x32/0x6e0 [ 37.376430][ T1] ? exit_to_usermode_loop+0x26/0x9b [ 37.378418][ T1] ? prepare_exit_to_usermode+0xa8/0xd0 [ 37.380571][ T1] exit_to_usermode_loop+0x3e/0x9b [ 37.382588][ T1] prepare_exit_to_usermode+0xa8/0xd0 [ 37.384594][ T1] ? page_fault+0x8/0x30 [ 37.386453][ T1] retint_user+0x8/0x18 [ 37.388160][ T1] RIP: 0033:0x7f42c06974a8 [ 37.389922][ T1] Code: Bad RIP value. [ 37.391788][ T1] RSP: 002b:00007ffc3effd388 EFLAGS: 00010213 [ 37.394075][ T1] RAX: 000000000000000e RBX: 00007ffc3effd390 RCX: 0000000000000000 [ 37.396963][ T1] RDX: 000000000000002a RSI: 00007ffc3effd390 RDI: 0000000000000004 [ 37.399550][ T1] RBP: 00007ffc3effd680 R08: 0000000000000000 R09: 0000000000000000 [ 37.402334][ T1] R10: 00000000ffffffff R11: 0000000000000246 R12: 0000000000000001 [ 37.404890][ T1] R13: ffffffffffffffff R14: 0000000000000884 R15: 000056460b1ac3b0 Link: http://lkml.kernel.org/r/201902010336.x113a4EO027170@www262.sakura.ne.jp Fixes: 3d8b38eb81cac813 ("mm, oom: introduce memory.oom.group") Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Roman Gushchin <guro@fb.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-04-05mm, swap: bounds check swap_info array accesses to avoid NULL derefsDaniel Jordan
[ Upstream commit c10d38cc8d3e43f946b6c2bf4602c86791587f30 ] Dan Carpenter reports a potential NULL dereference in get_swap_page_of_type: Smatch complains that the NULL checks on "si" aren't consistent. This seems like a real bug because we have not ensured that the type is valid and so "si" can be NULL. Add the missing check for NULL, taking care to use a read barrier to ensure CPU1 observes CPU0's updates in the correct order: CPU0 CPU1 alloc_swap_info() if (type >= nr_swapfiles) swap_info[type] = p /* handle invalid entry */ smp_wmb() smp_rmb() ++nr_swapfiles p = swap_info[type] Without smp_rmb, CPU1 might observe CPU0's write to nr_swapfiles before CPU0's write to swap_info[type] and read NULL from swap_info[type]. Ying Huang noticed other places in swapfile.c don't order these reads properly. Introduce swap_type_to_swap_info to encourage correct usage. Use READ_ONCE and WRITE_ONCE to follow the Linux Kernel Memory Model (see tools/memory-model/Documentation/explanation.txt). This ordering need not be enforced in places where swap_lock is held (e.g. si_swapinfo) because swap_lock serializes updates to nr_swapfiles and the swap_info array. Link: http://lkml.kernel.org/r/20190131024410.29859-1-daniel.m.jordan@oracle.com Fixes: ec8acf20afb8 ("swap: add per-partition lock for swapfile") Signed-off-by: Daniel Jordan <daniel.m.jordan@oracle.com> Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Suggested-by: "Huang, Ying" <ying.huang@intel.com> Reviewed-by: Andrea Parri <andrea.parri@amarulasolutions.com> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Andi Kleen <ak@linux.intel.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Omar Sandoval <osandov@fb.com> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: Shaohua Li <shli@kernel.org> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Tejun Heo <tj@kernel.org> Cc: Will Deacon <will.deacon@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
